[U-Boot] [PATCH 0/2] update TFABOOT defconfigs for SD boot support
- Fixes the MMC environment issue - updates TFABOOT defconfigs for SD boot support
Rajesh Bhagat (2): env: fix allow to build multiple environments configs: update TFABOOT defconfigs for SD boot support
configs/ls1043aqds_tfa_defconfig | 1 + configs/ls1043ardb_tfa_defconfig | 1 + configs/ls1046aqds_tfa_defconfig | 1 + configs/ls1046ardb_tfa_defconfig | 1 + configs/ls1088aqds_tfa_defconfig | 1 + configs/ls1088ardb_tfa_defconfig | 1 + configs/ls2088aqds_tfa_defconfig | 1 + configs/ls2088ardb_tfa_defconfig | 1 + include/environment.h | 9 --------- include/mmc.h | 3 +++ 10 files changed, 11 insertions(+), 9 deletions(-)
Patch fixes build error when enabling CONFIG_ENV_IS_IN_SPI_FLASH and CONFIG_ENV_IS_IN_MMC at the same time mentioned issue in below link:
Refer: https://lists.denx.de/pipermail/u-boot/2018-February/319565.html
build error when enabling CONFIG_ENV_IS_IN_SPI_FLASH and CONFIG_ENV_IS_IN_MMC at the same time.
Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com --- Depends on: https://patchwork.ozlabs.org/project/uboot/list/?series=83635
include/environment.h | 9 --------- include/mmc.h | 3 +++ 2 files changed, 3 insertions(+), 9 deletions(-)
diff --git a/include/environment.h b/include/environment.h index 7da1291d5b..cd96676141 100644 --- a/include/environment.h +++ b/include/environment.h @@ -162,15 +162,6 @@ extern const unsigned char default_environment[]; extern void env_reloc(void); #endif
-#ifdef CONFIG_ENV_IS_IN_MMC -#include <mmc.h> - -extern int mmc_get_env_addr(struct mmc *mmc, int copy, u32 *env_addr); -# ifdef CONFIG_SYS_MMC_ENV_PART -extern uint mmc_get_env_part(struct mmc *mmc); -# endif -#endif - #ifndef DO_DEPS_ONLY
#include <env_attr.h> diff --git a/include/mmc.h b/include/mmc.h index 95548e94c4..d84e4fca73 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -828,6 +828,9 @@ void board_mmc_power_init(void); int board_mmc_init(bd_t *bis); int cpu_mmc_init(bd_t *bis); int mmc_get_env_addr(struct mmc *mmc, int copy, u32 *env_addr); +# ifdef CONFIG_SYS_MMC_ENV_PART +extern uint mmc_get_env_part(struct mmc *mmc); +# endif int mmc_get_env_dev(void);
/* Set block count limit because of 16 bit register limit on some hardware*/
Rajesh,
Please resend this set and CC maintainers.
York
-----Original Message----- From: York Sun Sent: Thursday, January 10, 2019 2:03 AM To: Rajesh Bhagat rajesh.bhagat@nxp.com; u-boot@lists.denx.de Cc: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Subject: Re: [PATCH 1/2] env: fix allow to build multiple environments
Rajesh,
Hi York,
Will resend the patch keeping CC maintainers.
Regards, Rajesh Bhagat
York
update TFABOOT defconfig for SD boot on below NXP chasis2 and chasis3 platforms:
ls1043a, ls1046a, ls1088a and ls2088a.
configs/ls1043aqds_tfa_defconfig | 1 + configs/ls1043ardb_tfa_defconfig | 1 + configs/ls1046aqds_tfa_defconfig | 1 + configs/ls1046ardb_tfa_defconfig | 1 + configs/ls1088aqds_tfa_defconfig | 1 + configs/ls1088ardb_tfa_defconfig | 1 + configs/ls2088aqds_tfa_defconfig | 1 + configs/ls2088ardb_tfa_defconfig | 1 + 8 files changed, 8 insertions(+)
diff --git a/configs/ls1043aqds_tfa_defconfig b/configs/ls1043aqds_tfa_defconfig index 6fa0418044..a255236758 100644 --- a/configs/ls1043aqds_tfa_defconfig +++ b/configs/ls1043aqds_tfa_defconfig @@ -32,6 +32,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_IS_IN_NAND=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1043ardb_tfa_defconfig b/configs/ls1043ardb_tfa_defconfig index 662a966ebe..3cae0f2356 100644 --- a/configs/ls1043ardb_tfa_defconfig +++ b/configs/ls1043ardb_tfa_defconfig @@ -26,6 +26,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y diff --git a/configs/ls1046aqds_tfa_defconfig b/configs/ls1046aqds_tfa_defconfig index 44c5ca5b30..2412e7ee43 100644 --- a/configs/ls1046aqds_tfa_defconfig +++ b/configs/ls1046aqds_tfa_defconfig @@ -33,6 +33,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_IS_IN_NAND=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y diff --git a/configs/ls1046ardb_tfa_defconfig b/configs/ls1046ardb_tfa_defconfig index d6595eb246..0533b61b6b 100644 --- a/configs/ls1046ardb_tfa_defconfig +++ b/configs/ls1046ardb_tfa_defconfig @@ -26,6 +26,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=1550000.quadspi:1m(rcw),15m(u-boot),48m(kernel CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-rdb" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y diff --git a/configs/ls1088aqds_tfa_defconfig b/configs/ls1088aqds_tfa_defconfig index 08744dda2d..857362bb01 100644 --- a/configs/ls1088aqds_tfa_defconfig +++ b/configs/ls1088aqds_tfa_defconfig @@ -33,6 +33,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-qds" CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SCSI_AHCI=y diff --git a/configs/ls1088ardb_tfa_defconfig b/configs/ls1088ardb_tfa_defconfig index 3328af430d..01fa13c7a8 100644 --- a/configs/ls1088ardb_tfa_defconfig +++ b/configs/ls1088ardb_tfa_defconfig @@ -29,6 +29,7 @@ CONFIG_MP=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-rdb" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SCSI_AHCI=y diff --git a/configs/ls2088aqds_tfa_defconfig b/configs/ls2088aqds_tfa_defconfig index 3a523f74be..b04796cbb7 100644 --- a/configs/ls2088aqds_tfa_defconfig +++ b/configs/ls2088aqds_tfa_defconfig @@ -32,6 +32,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_FSL_CAAM=y diff --git a/configs/ls2088ardb_tfa_defconfig b/configs/ls2088ardb_tfa_defconfig index bb5e4f8bb5..016d8bcdb6 100644 --- a/configs/ls2088ardb_tfa_defconfig +++ b/configs/ls2088ardb_tfa_defconfig @@ -33,6 +33,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2088a-rdb-qspi" CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_FSL_CAAM=y
Rajesh Bhagat
York Sun
