[U-Boot] Various, unrelated tree-wide typo fixes.
Fix a number of typos, including:
* "comptible", "compatble" -> "compatible" * "eanbeld" -> "enabled" * "envrionment" -> "environment" * "FTD" -> "FDT" (for "flattened device tree") * "ommitted" -> "omitted" * "overriden" -> "overridden" * "partiton" -> "partition" * "propogate" -> "propagate" * "resourse" -> "resource" * "rest in piece" -> "rest in peace" * "suport" -> "support" * "varible" -> "variable"
Signed-off-by: Robert P. J. Day rpjday@crashcourse.ca
been collecting these on a separate branch for a while, might as well submit them before starting fresh. would it have been better to break this into smaller pieces? happy to do that as well.
diff --git a/README b/README index 26d5ad2..932c71f 100644 --- a/README +++ b/README @@ -511,7 +511,7 @@ The following options need to be configured: implemetation.
CONFIG_SYS_FSL_DDR2 - Board config to use DDR2. It can be eanbeld for SoCs with + Board config to use DDR2. It can be enabled for SoCs with Freescale DDR2 or DDR3 controllers, depending on the board implementation.
diff --git a/arch/arm/cpu/armv7/Kconfig b/arch/arm/cpu/armv7/Kconfig index afeaac8..bd6108e 100644 --- a/arch/arm/cpu/armv7/Kconfig +++ b/arch/arm/cpu/armv7/Kconfig @@ -21,7 +21,7 @@ config ARMV7_BOOT_SEC_DEFAULT Say Y here to boot in secure mode by default even if non-secure mode is supported. This option is useful to boot kernels which do not suppport booting in non-secure mode. Only set this if you need it. - This can be overriden at run-time by setting the bootm_boot_mode env. + This can be overridden at run-time by setting the bootm_boot_mode env. variable to "sec" or "nonsec".
config ARMV7_VIRT diff --git a/arch/arm/cpu/armv8/fsl-layerscape/doc/README.lsch3 b/arch/arm/cpu/armv8/fsl-layerscape/doc/README.lsch3 index da5e052..7867c37 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/doc/README.lsch3 +++ b/arch/arm/cpu/armv8/fsl-layerscape/doc/README.lsch3 @@ -128,7 +128,7 @@ mcinitcmd: This environment variable is defined to initiate MC and DPL deploymen during U-boot booting.However the MC, DPC and DPL can be applied from console independently. The variable needs to be set from the console once and then on - rebooting the parameters set in the varible will automatically be + rebooting the parameters set in the variable will automatically be executed. The commmand is demostrated taking an example of mc boot using NOR Flash i.e. MC, DPL, and DPC is stored in the NOR flash:
diff --git a/arch/arm/cpu/armv8/zynqmp/mp.c b/arch/arm/cpu/armv8/zynqmp/mp.c index 58312a7..e10fc31 100644 --- a/arch/arm/cpu/armv8/zynqmp/mp.c +++ b/arch/arm/cpu/armv8/zynqmp/mp.c @@ -128,7 +128,7 @@ static void enable_clock_r5(void) writel(tmp, &crlapb_base->cpu_r5_ctrl);
/* Give some delay for clock - * to propogate */ + * to propagate */ udelay(0x500); }
diff --git a/arch/arm/dts/tegra124.dtsi b/arch/arm/dts/tegra124.dtsi index 275a509..82bf083 100644 --- a/arch/arm/dts/tegra124.dtsi +++ b/arch/arm/dts/tegra124.dtsi @@ -316,7 +316,7 @@ * driver and APB DMA based serial driver for higher baudrate * and performace. To enable the 8250 based driver, the compatible * is "nvidia,tegra124-uart", "nvidia,tegra20-uart" and to enable - * the APB DMA based serial driver, the comptible is + * the APB DMA based serial driver, the compatible is * "nvidia,tegra124-hsuart", "nvidia,tegra30-hsuart". */ uarta: serial@70006000 { diff --git a/arch/arm/dts/tegra20.dtsi b/arch/arm/dts/tegra20.dtsi index 31223e4..0b55ee0 100644 --- a/arch/arm/dts/tegra20.dtsi +++ b/arch/arm/dts/tegra20.dtsi @@ -311,7 +311,7 @@ * driver and APB DMA based serial driver for higher baudrate * and performace. To enable the 8250 based driver, the compatible * is "nvidia,tegra20-uart" and to enable the APB DMA based serial - * driver, the comptible is "nvidia,tegra20-hsuart". + * driver, the compatible is "nvidia,tegra20-hsuart". */ uarta: serial@70006000 { compatible = "nvidia,tegra20-uart"; diff --git a/arch/arm/imx-common/ddrmc-vf610.c b/arch/arm/imx-common/ddrmc-vf610.c index daf3c7e..9bc56f6 100644 --- a/arch/arm/imx-common/ddrmc-vf610.c +++ b/arch/arm/imx-common/ddrmc-vf610.c @@ -212,7 +212,7 @@ void ddrmc_ctrl_init_ddr3(struct ddr3_jedec_timings const *timings, cr_setting++; }
- /* perform default PHY settings (may be overriden by custom settings */ + /* perform default PHY settings (may be overridden by custom settings */ phy_setting = default_phy_settings; while (phy_setting->phy_rnum >= 0) { writel(phy_setting->setting, diff --git a/arch/arm/include/asm/arch-tegra/board.h b/arch/arm/include/asm/arch-tegra/board.h index 783bb3c..a3db7ed 100644 --- a/arch/arm/include/asm/arch-tegra/board.h +++ b/arch/arm/include/asm/arch-tegra/board.h @@ -20,7 +20,7 @@ void gpio_early_init(void); /* overrideable GPIO config */ /* * Hooks to allow boards to set up the pinmux for a specific function. * Has to be implemented in the board files as we don't yet support pinmux - * setup from FTD. If a board file does not implement one of those functions + * setup from FDT. If a board file does not implement one of those functions * an empty stub function will be called. */
diff --git a/arch/arm/include/asm/arch-tegra/clock.h b/arch/arm/include/asm/arch-tegra/clock.h index e56031d..7daf8bc 100644 --- a/arch/arm/include/asm/arch-tegra/clock.h +++ b/arch/arm/include/asm/arch-tegra/clock.h @@ -324,7 +324,7 @@ enum periph_id clk_id_to_periph_id(int clk_id); * @param p post divider(DIVP) * @param cpcon base PLL charge pump(CPCON) * @return 0 if ok, -1 on error (the requested PLL is incorrect and cannot - * be overriden), 1 if PLL is already correct + * be overridden), 1 if PLL is already correct */ int clock_set_rate(enum clock_id clkid, u32 n, u32 m, u32 p, u32 cpcon);
diff --git a/arch/arm/include/asm/arch-tegra124/display.h b/arch/arm/include/asm/arch-tegra124/display.h index ca6644a..c522faa 100644 --- a/arch/arm/include/asm/arch-tegra124/display.h +++ b/arch/arm/include/asm/arch-tegra124/display.h @@ -11,7 +11,7 @@ /** * Register a new display based on device tree configuration. * - * The frame buffer can be positioned by U-Boot or overriden by the fdt. + * The frame buffer can be positioned by U-Boot or overridden by the fdt. * You should pass in the U-Boot address here, and check the contents of * struct fdt_disp_config to see what was actually chosen. * diff --git a/arch/arm/mach-tegra/clock.c b/arch/arm/mach-tegra/clock.c index c50d56d..36eabc8 100644 --- a/arch/arm/mach-tegra/clock.c +++ b/arch/arm/mach-tegra/clock.c @@ -510,7 +510,7 @@ unsigned clock_get_rate(enum clock_id clkid) * @param p post divider(DIVP) * @param cpcon base PLL charge pump(CPCON) * @return 0 if ok, -1 on error (the requested PLL is incorrect and cannot - * be overriden), 1 if PLL is already correct + * be overridden), 1 if PLL is already correct */ int clock_set_rate(enum clock_id clkid, u32 n, u32 m, u32 p, u32 cpcon) { diff --git a/arch/powerpc/cpu/mpc85xx/mp.c b/arch/powerpc/cpu/mpc85xx/mp.c index 88c8e65..0addf84 100644 --- a/arch/powerpc/cpu/mpc85xx/mp.c +++ b/arch/powerpc/cpu/mpc85xx/mp.c @@ -30,7 +30,7 @@ u32 get_my_id() */ int hold_cores_in_reset(int verbose) { - /* Default to no, overriden by 'y', 'yes', 'Y', 'Yes', or '1' */ + /* Default to no, overridden by 'y', 'yes', 'Y', 'Yes', or '1' */ if (getenv_yesno("mp_holdoff") == 1) { if (verbose) { puts("Secondary cores are being held in reset.\n"); diff --git a/arch/powerpc/cpu/ppc4xx/start.S b/arch/powerpc/cpu/ppc4xx/start.S index b432b18..5647d71 100644 --- a/arch/powerpc/cpu/ppc4xx/start.S +++ b/arch/powerpc/cpu/ppc4xx/start.S @@ -144,7 +144,7 @@ #endif
/* - * Unless otherwise overriden, enable two 128MB cachable instruction regions + * Unless otherwise overridden, enable two 128MB cachable instruction regions * at CONFIG_SYS_SDRAM_BASE and another 128MB cacheable instruction region covering * NOR flash at CONFIG_SYS_FLASH_BASE. Disable all cacheable data regions. */ diff --git a/arch/powerpc/include/asm/status_led.h b/arch/powerpc/include/asm/status_led.h index 4416190..260a831 100644 --- a/arch/powerpc/include/asm/status_led.h +++ b/arch/powerpc/include/asm/status_led.h @@ -7,7 +7,7 @@ #ifndef __ASM_STATUS_LED_H__ #define __ASM_STATUS_LED_H__
-/* if not overriden */ +/* if not overridden */ #ifndef CONFIG_BOARD_SPECIFIC_LED # if defined(CONFIG_8xx) # include <mpc8xx.h> diff --git a/board/keymile/common/common.c b/board/keymile/common/common.c index a42f3ec..0829b7f 100644 --- a/board/keymile/common/common.c +++ b/board/keymile/common/common.c @@ -53,7 +53,7 @@ int set_km_env(void) sprintf((char *)buf, "0x%x", pnvramaddr); setenv("pnvramaddr", (char *)buf);
- /* try to read rootfssize (ram image) from envrionment */ + /* try to read rootfssize (ram image) from environment */ p = getenv("rootfssize"); if (p != NULL) strict_strtoul(p, 16, &rootfssize); diff --git a/board/keymile/kmp204x/ddr.c b/board/keymile/kmp204x/ddr.c index 34ac697..77af184 100644 --- a/board/keymile/kmp204x/ddr.c +++ b/board/keymile/kmp204x/ddr.c @@ -36,7 +36,7 @@ void fsl_ddr_board_options(memctl_options_t *popts, /* we have only one module, half str should be OK */ popts->half_strength_driver_enable = 1;
- /* wrlvl values overriden as recommended by ddr init func */ + /* wrlvl values overridden as recommended by ddr init func */ popts->wrlvl_override = 1; popts->wrlvl_sample = 0xf; popts->wrlvl_start = 0x6; diff --git a/cmd/i2c.c b/cmd/i2c.c index 18ce789..473153f 100644 --- a/cmd/i2c.c +++ b/cmd/i2c.c @@ -178,7 +178,7 @@ static int i2c_get_cur_bus_chip(uint chip_addr, struct udevice **devp) * i2c_init_board() - Board-specific I2C bus init * * This function is the default no-op implementation of I2C bus - * initialization. This function can be overriden by board-specific + * initialization. This function can be overridden by board-specific * implementation if needed. */ __weak diff --git a/common/env_common.c b/common/env_common.c index 13db7dc..560cad0 100644 --- a/common/env_common.c +++ b/common/env_common.c @@ -145,7 +145,7 @@ int set_default_vars(int nvars, char * const vars[]) * env_aes_cbc_get_key() - Get AES-128-CBC key for the environment * * This function shall return 16-byte array containing AES-128 key used - * to encrypt and decrypt the environment. This function must be overriden + * to encrypt and decrypt the environment. This function must be overridden * by the implementer as otherwise the environment encryption will not * work. */ diff --git a/doc/README.gpt b/doc/README.gpt index a6f6de6..3fcd835 100644 --- a/doc/README.gpt +++ b/doc/README.gpt @@ -165,7 +165,7 @@ To restore GUID partition table one needs to: The fields 'name' and 'size' are mandatory for every partition. The field 'start' is optional.
- If field 'size' of the last partition is 0, the partiton is extended + If field 'size' of the last partition is 0, the partition is extended up to the end of the device.
The fields 'uuid' and 'uuid_disk' are optional if CONFIG_RANDOM_UUID is diff --git a/doc/README.scrapyard b/doc/README.scrapyard index b7cf62d..200f670 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -3,7 +3,7 @@ while other board support code dies a silent death caused by negligence in combination with ordinary bitrot. Sometimes this goes by unnoticed, but often build errors will result. If nobody cares any more to resolve such problems, then the code is really dead and will -be removed from the U-Boot source tree. The remainders rest in piece +be removed from the U-Boot source tree. The remainders rest in peace in the imperishable depths of the git history. This document tries to maintain a list of such former fellows, so archaeologists can check easily if there is something they might want to dig for... diff --git a/doc/feature-removal-schedule.txt b/doc/feature-removal-schedule.txt index 4ed30df..b5a70da 100644 --- a/doc/feature-removal-schedule.txt +++ b/doc/feature-removal-schedule.txt @@ -12,7 +12,7 @@ When: Release v2013.10
Why: As the 'mtest' command is no longer default, a number of platforms have not opted to turn the command back on and thus provide unused - defines (which are likely to be propogated to new platforms from + defines (which are likely to be propagated to new platforms from copy/paste). Remove these defines when unused.
Who: Tom Rini trini@ti.com diff --git a/drivers/bios_emulator/x86emu/sys.c b/drivers/bios_emulator/x86emu/sys.c index 0ba9c0c..c2db121 100644 --- a/drivers/bios_emulator/x86emu/sys.c +++ b/drivers/bios_emulator/x86emu/sys.c @@ -35,7 +35,7 @@ * Description: This file includes subroutines which are related to * programmed I/O and memory access. Included in this module * are default functions that do nothing. For real uses these -* functions will have to be overriden by the user library. +* functions will have to be overridden by the user library. * ****************************************************************************/
diff --git a/drivers/crypto/fsl/desc.h b/drivers/crypto/fsl/desc.h index 1ac3a09..081bce5 100644 --- a/drivers/crypto/fsl/desc.h +++ b/drivers/crypto/fsl/desc.h @@ -107,7 +107,7 @@ */ #define HDR_REVERSE 0x00000800
-/* Propogate DNR property to SharedDesc */ +/* Propagate DNR property to SharedDesc */ #define HDR_PROP_DNR 0x00000800
/* JobDesc/SharedDesc share property */ diff --git a/drivers/ddr/fsl/ctrl_regs.c b/drivers/ddr/fsl/ctrl_regs.c index 1d5cec6..abd576b 100644 --- a/drivers/ddr/fsl/ctrl_regs.c +++ b/drivers/ddr/fsl/ctrl_regs.c @@ -2212,7 +2212,7 @@ static void set_ddr_wrlvl_cntl(fsl_ddr_cfg_regs_t *ddr, unsigned int wrlvl_en, * Write leveling start time * The value use for the DQS_ADJUST for the first sample * when write leveling is enabled. It probably needs to be - * overriden per platform. + * overridden per platform. */ wrlvl_start = 0x8; /* diff --git a/drivers/fpga/fpga.c b/drivers/fpga/fpga.c index 7e2f3e1..e0fb1b4 100644 --- a/drivers/fpga/fpga.c +++ b/drivers/fpga/fpga.c @@ -31,7 +31,7 @@ static void fpga_no_sup(char *fn, char *msg) else if (msg) printf("No support for %s.\n", msg); else - printf("No FPGA suport!\n"); + printf("No FPGA support!\n"); }
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 79cf18f..e0adb9b 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -10,7 +10,7 @@ config DM_MMC bool "Enable MMC controllers using Driver Model" depends on DM help - This enables the MultiMediaCard (MMC) uclass which suports MMC and + This enables the MultiMediaCard (MMC) uclass which supports MMC and Secure Digital I/O (SDIO) cards. Both removable (SD, micro-SD, etc.) and non-removable (e.g. eMMC chip) devices are supported. These appear as block devices in U-Boot and can support filesystems such diff --git a/drivers/mtd/nand/mxs_nand.c b/drivers/mtd/nand/mxs_nand.c index c90a3a7..94fc5c1 100644 --- a/drivers/mtd/nand/mxs_nand.c +++ b/drivers/mtd/nand/mxs_nand.c @@ -976,7 +976,7 @@ static int mxs_nand_block_bad(struct mtd_info *mtd, loff_t ofs) * counted, so we know the physical geometry. This enables us to make some * important configuration decisions. * - * The return value of this function propogates directly back to this driver's + * The return value of this function propagates directly back to this driver's * call to nand_scan(). Anything other than zero will cause this driver to * tear everything down and declare failure. */ diff --git a/drivers/mtd/nand/tegra_nand.c b/drivers/mtd/nand/tegra_nand.c index 2032f65..38bd7a5 100644 --- a/drivers/mtd/nand/tegra_nand.c +++ b/drivers/mtd/nand/tegra_nand.c @@ -884,7 +884,7 @@ static void setup_timing(unsigned timing[FDT_NAND_TIMING_COUNT], * Decode NAND parameters from the device tree * * @param blob Device tree blob - * @param node Node containing "nand-flash" compatble node + * @param node Node containing "nand-flash" compatible node * @return 0 if ok, -ve on error (FDT_ERR_...) */ static int fdt_decode_nand(const void *blob, int node, struct fdt_nand *config) diff --git a/drivers/usb/musb-new/musb_dsps.c b/drivers/usb/musb-new/musb_dsps.c index bb7c952..a71db76 100644 --- a/drivers/usb/musb-new/musb_dsps.c +++ b/drivers/usb/musb-new/musb_dsps.c @@ -627,7 +627,7 @@ static int __devinit dsps_probe(struct platform_device *pdev) /* get memory resource */ iomem = platform_get_resource(pdev, IORESOURCE_MEM, 0); if (!iomem) { - dev_err(&pdev->dev, "failed to get usbss mem resourse\n"); + dev_err(&pdev->dev, "failed to get usbss mem resource\n"); ret = -ENODEV; goto err1; } diff --git a/drivers/video/tegra.c b/drivers/video/tegra.c index 217f05f..92214d6 100644 --- a/drivers/video/tegra.c +++ b/drivers/video/tegra.c @@ -251,7 +251,7 @@ static int setup_window(struct disp_ctl_win *win, /** * Register a new display based on device tree configuration. * - * The frame buffer can be positioned by U-Boot or overriden by the fdt. + * The frame buffer can be positioned by U-Boot or overridden by the fdt. * You should pass in the U-Boot address here, and check the contents of * struct tegra_lcd_priv to see what was actually chosen. * diff --git a/include/configs/mxs.h b/include/configs/mxs.h index 0882d5d..238b16d 100644 --- a/include/configs/mxs.h +++ b/include/configs/mxs.h @@ -120,7 +120,7 @@ #define CONFIG_PL011_CLOCK 24000000 #define CONFIG_PL01x_PORTS { (void *)MXS_UARTDBG_BASE } #define CONFIG_CONS_INDEX 0 -/* Default baudrate can be overriden by board! */ +/* Default baudrate can be overridden by board! */ #ifndef CONFIG_BAUDRATE #define CONFIG_BAUDRATE 115200 #endif diff --git a/include/configs/v38b.h b/include/configs/v38b.h index 28c748d..5ebdf5b 100644 --- a/include/configs/v38b.h +++ b/include/configs/v38b.h @@ -55,7 +55,7 @@ #define SDRAM_TAPDELAY 0x10000000
/* - * PCI - no suport + * PCI - no support */ #undef CONFIG_PCI
diff --git a/include/net.h b/include/net.h index 5ee5929..06320c6 100644 --- a/include/net.h +++ b/include/net.h @@ -238,7 +238,7 @@ int eth_getenv_enetaddr(const char *name, uchar *enetaddr); int eth_setenv_enetaddr(const char *name, const uchar *enetaddr);
/** - * eth_setenv_enetaddr_by_index() - set the MAC address envrionment variable + * eth_setenv_enetaddr_by_index() - set the MAC address environment variable * * This sets up an environment variable with the given MAC address (@enetaddr). * The environment variable to be set is defined by <@base_name><@index>addr. diff --git a/lib/hashtable.c b/lib/hashtable.c index 02b4105..435e2a6 100644 --- a/lib/hashtable.c +++ b/lib/hashtable.c @@ -822,7 +822,7 @@ int himport_r(struct hsearch_data *htab, * (CONFIG_ENV_SIZE). This heuristics will result in * unreasonably large numbers (and thus memory footprint) for * big flash environments (>8,000 entries for 64 KB - * envrionment size), so we clip it to a reasonable value. + * environment size), so we clip it to a reasonable value. * On the other hand we need to add some more entries for free * space when importing very small buffers. Both boundaries can * be overwritten in the board config file if needed. diff --git a/net/eth_internal.h b/net/eth_internal.h index 6e4753c..a14b208 100644 --- a/net/eth_internal.h +++ b/net/eth_internal.h @@ -13,7 +13,7 @@ void eth_common_init(void);
/** - * eth_setenv_enetaddr_by_index() - set the MAC address envrionment variable + * eth_setenv_enetaddr_by_index() - set the MAC address environment variable * * This sets up an environment variable with the given MAC address (@enetaddr). * The environment variable to be set is defined by <@base_name><@index>addr. diff --git a/post/cpu/ppc4xx/ether.c b/post/cpu/ppc4xx/ether.c index 4c9a39b..8a4c56b 100644 --- a/post/cpu/ppc4xx/ether.c +++ b/post/cpu/ppc4xx/ether.c @@ -21,7 +21,7 @@ * CONFIG_SYS_POST_ETH_LOOPS - Number of test loops. Each loop * is tested with a different frame length. Starting with * MAX_PACKET_LENGTH and going down to MIN_PACKET_LENGTH. - * Defaults to 10 and can be overriden in the board config header. + * Defaults to 10 and can be overridden in the board config header. */
#include <post.h> diff --git a/tools/env/fw_env.config b/tools/env/fw_env.config index 6f216f9..776e16f 100644 --- a/tools/env/fw_env.config +++ b/tools/env/fw_env.config @@ -2,7 +2,7 @@ # Up to two entries are valid, in this case the redundant # environment sector is assumed present. # Notice, that the "Number of sectors" is not required on NOR and SPI-dataflash. -# Futhermore, if the Flash sector size is ommitted, this value is assumed to +# Futhermore, if the Flash sector size is omitted, this value is assumed to # be the same as the Environment size, which is valid for NOR and SPI-dataflash
# NOR example
On Fri, Jul 15, 2016 at 07:17:36AM -0400, Robert P. J. Day wrote:
Fix a number of typos, including: * "comptible", "compatble" -> "compatible" * "eanbeld" -> "enabled" * "envrionment" -> "environment" * "FTD" -> "FDT" (for "flattened device tree") * "ommitted" -> "omitted" * "overriden" -> "overridden" * "partiton" -> "partition" * "propogate" -> "propagate" * "resourse" -> "resource" * "rest in piece" -> "rest in peace" * "suport" -> "support" * "varible" -> "variable"
[snip]
All of these DT ones are going to be lost, probably, when resynced with the kernel again. Please push those upstream there instead, thanks!
[snip]
ack, of course. so resubmit after cleansing patch of all dts content? or will you take care of that? either way works for me.
rday
[snip]
Please re-submit this patch with the DT parts omitted, thanks.
Robert P. J. Day
