[GIT PULL] Please pull u-boot-imx-master-20241018
Hi Tom,
Please pull from u-boot-imx/master, thanks.
The following changes since commit 608a31bdec6284ad6f821226e4c62c9cd3052874:
Merge patch series "Introduce the lwIP network stack" (2024-10-16 11:11:57 -0600)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-master-20241018
for you to fetch changes up to fd3f2e3f0edc1f87be4c5a39a0c81037d551c069:
cpu: imx8_cpu: Avoid revision to corrupt device tree (2024-10-18 08:02:30 -0300)
u-boot-imx-master-20241018 --------------------------
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/22796
- Switch to using upstream DT on DH i.MX8MP DHCOM PDK2/PDK3. - Add ability to build fallback DTBOs from arch/$(ARCH)/dts. - Remove fdt_high and initrd_high env variables from imx6-dhcom. - Add dummy clk for imx8. - Fix DT corruption in imx8_cpu. - Improve DDR stability on pico-imx7d. ---------------------------------------------------------------- From: Marek Vasut (1): arm64: dts: imx: Switch to using upstream DT on DH i.MX8MP DHCOM PDK2/PDK3
Marek Vasut (2): dts: Add ability to build fallback DTBOs from arch/$(ARCH)/dts ARM: dts: imx6-dhcom: Remove fdt_high and initrd_high env variables
Peng Fan (2): clk: imx8: Add dummy clk cpu: imx8_cpu: Avoid revision to corrupt device tree
Ray Chang (1): pico-imx7d: Increase ODT resistor value
Makefile | 4 + arch/arm/dts/Makefile | 2 - arch/arm/dts/imx8mp-dhcom-pdk2.dts | 158 ------------------ arch/arm/dts/imx8mp-dhcom-pdk3.dts | 317 ------------------------------------ board/technexion/pico-imx7d/spl.c | 10 +- configs/imx8mp_dhcom_pdk2_defconfig | 6 +- configs/imx8mp_dhcom_pdk3_defconfig | 6 +- drivers/clk/imx/clk-imx8qm.c | 4 + drivers/clk/imx/clk-imx8qxp.c | 4 + drivers/cpu/imx8_cpu.c | 32 ++-- dts/Kconfig | 16 ++ dts/Makefile | 14 +- include/configs/dh_imx6.h | 3 +- scripts/Makefile.dts | 6 + 14 files changed, 78 insertions(+), 504 deletions(-) delete mode 100644 arch/arm/dts/imx8mp-dhcom-pdk2.dts delete mode 100644 arch/arm/dts/imx8mp-dhcom-pdk3.dts
On Fri, Oct 18, 2024 at 9:29 AM Fabio Estevam festevam@gmail.com wrote:
Hi Tom,
Ops, please discard it. I had to manually apply this one and I messed the From line.
Will send a new PR shortly.
Fabio Estevam
