[U-Boot] [PULL] u-boot-socfpga/master
The following changes since commit ae27120c31d58b8bb694d9155bcffdcfae8552a6:
Merge git://git.denx.de/u-boot-dm (2015-08-06 19:56:03 -0400)
git://git.denx.de/u-boot-socfpga.git HEAD
for you to fetch changes up to bd48c0617b5c7212e5bf22169e716da878842da4:
arm: socfpga: misc: Add support for printing FPGA type (2015-08-08 14:14:30 +0200)
---------------------------------------------------------------- Dinh Nguyen (6): driver/ddr/altera: Add DDR driver for Altera's SDRAM controller driver/ddr/altera: Add the sdram calibration portion arm: socfpga: enable the Altera SDRAM controller driver ddr: altera: sequencer: add RW_MGR_MEM_NUMBER_OF_RANKS arm: socfpga: scan: Add code to get FPGA ID arm: socfpga: misc: Add support for printing FPGA type
Marek Vasut (223): arm: socfpga: Fix FPGA bitstream programming routine arm: dts: socfpga: Fix SPI aliases arm: dts: socfpga: Add mmc alias arm: socfpga: Move generated files into qts subdir net: designware: Add SoCFPGA GMAC DT compatible string net: designware: Rename the driver var name to eth_designware arm: socfpga: Move sdram_config.h to board dir ddr: altera: Move struct sdram_prot_rule prototype ddr: altera: Fix typo in mp_threshold1 programming ddr: altera: Fix debug message format in sequencer arm: socfpga: reset: Add missing reset manager regs arm: socfpga: reset: Start reworking the SoCFPGA reset manager arm: socfpga: reset: Implement unified function to toggle reset arm: socfpga: reset: Replace ad-hoc reset functions arm: socfpga: reset: Repair bridge reset handling arm: socfpga: reset: Add function to reset add peripherals arm: socfpga: reset: Add SDMMC, QSPI and DMA defines arm: socfpga: clock: Get rid of cm_config_t typedef arm: socfpga: clock: Clean up pll_config.h arm: socfpga: scan: Staticize scan_mgr_io_scan_chain_prg() arm: socfpga: scan: Zap redundant params in scan_mgr_io_scan_chain_prg() arm: socfpga: scan: Zap iocsr_scan_chain*_table() arm: socfpga: system: Rework sysmgr_enable_warmrstcfgio() arm: socfpga: system: Clean up pinmux_config.c arm: socfpga: spl: Toggle warm reset config I/O bit arm: socfpga: spl: Configure SCU and NIC-301 early arm: socfpga: spl: Add missing reset logic arm: socfpga: spl: Merge spl_board_init() into board_init_f() arm: socfpga: spl: Remove custom linker script arm: socfpga: spl: Add support for booting from SD/MMC arm: socfpga: spl: Add support for booting from QSPI arm: socfpga: spl: Add support for selecting boot device from BSEL arm: socfpga: misc: Fix warm reset arm: socfpga: misc: Add support for printing boot mode arm: socfpga: misc: Export bootmode into environment variable arm: socfpga: misc: Probe ethernet GMAC from OF arm: socfpga: misc: Reset ethernet from OF arm: socfpga: config: Move SPL GD and malloc to RAM arm: socfpga: config: Zap incorrect config options arm: socfpga: config: Exclude CONFIG_SPI_FLASH_MTD from SPL build arm: socfpga: config: Enable CONFIG_SPI_FLASH_BAR arm: socfpga: config: Fix LOADADDR arm: socfpga: config: Make CONFIG_SPI_FLASH_MTD useful Makefile: Add target for building bootable SPL image for SoCFPGA ddr: altera: Minor indent fix in set_rank_and_odt_mask() ddr: altera: Clean up ugly casts in sdram_calibration_full() ddr: altera: Zap invocation of sdr_get_addr((u32 *)BASE_RW_MGR)" ddr: altera: Dissolve invocation of sdr_get_addr(&sdr_reg_file->.*) ddr: altera: Dissolve invocation of sdr_get_addr(&sdr_scc_mgr->.*) ddr: altera: Dissolve invocation of sdr_get_addr(&sdr_rw_load.*->.*) ddr: altera: Dissolve invocation of sdr_get_addr(&sdr_mgr_.*->.*) ddr: altera: Pluck out remaining sdr_get_addr() calls ddr: altera: Wrap SOCFPGA_SDR_ADDRESS into SDR_PHYGRP.*ADDRESS ddr: altera: Stop using SDR_CTRLGRP_ADDRESS directly ddr: altera: Massage addr into I/O accessors ddr: altera: Clean up hc_initialize_rom_data() ddr: altera: Clean up initialize_reg_file() ddr: altera: Clean up initialize_hps_phy() ddr: altera: Clean up reg_file_set*() ddr: altera: Clean up scc manager function args ddr: altera: Reorder scc manager functions ddr: altera: Implement universal scc manager config function ddr: altera: Clean up scc_mgr_initialize() ddr: altera: Shuffle around scc_mgr_set_*all_ranks() ddr: altera: Implement universal scc_mgr_set_all_ranks() ddr: altera: Clean up scc_mgr_load_dqs_for_write_group() ddr: altera: Clean up scc_set_bypass_mode() ddr: altera: Clean up scc_mgr_set_oct_out1_delay() ddr: altera: Clean up scc_mgr_apply_group_dq_out1_delay() ddr: altera: Clean up scc_mgr_*_delay() args ddr: altera: Clean up scc_mgr_set_hhp_extras() ddr: altera: Extract scc_mgr_set_hhp_extras() ddr: altera: Clean up scc_mgr_zero_all() ddr: altera: Clean up scc_mgr_zero_group() ddr: altera: Internal scc_mgr_apply_group_all_out_delay_add() cleanup part 1 ddr: altera: Internal scc_mgr_apply_group_all_out_delay_add() cleanup part 2 ddr: altera: Clean up scc_mgr_apply_group_all_out_delay_add_all_ranks() ddr: altera: Factor out instruction loading from rw_mgr_mem_initialize() ddr: altera: Factor out common code ddr: altera: Minor clean up of set_jump_as_return() ddr: altera: Fix ad-hoc iterative division implementation ddr: altera: Rework initialize_tracking() ddr: altera: Init my_param and my_gbl ddr: altera: Rename initialize() to phy_mgr_initialize() ddr: altera: Clean up run_mem_calibrate() ddr: altera: Clean up phy_mgr_initialize() ddr: altera: Clean up mem_config() ddr: altera: Clean up mem_precharge_and_activate() ddr: altera: Clean up set_rank_and_odt_mask() part 1 ddr: altera: Clean up set_rank_and_odt_mask() part 2 ddr: altera: Clean up set_rank_and_odt_mask() part 3 ddr: altera: Minor clean up of mem_skip_calibrate() ddr: altera: Trivial mem_calibrate() indent cleanup ddr: altera: Internal mem_calibrate() cleanup part 1 ddr: altera: Internal mem_calibrate() cleanup part 2 ddr: altera: Internal mem_calibrate() cleanup part 3 ddr: altera: Internal mem_calibrate() cleanup part 4 ddr: altera: Internal mem_calibrate() cleanup part 5 ddr: altera: Internal mem_calibrate() cleanup part 6 ddr: altera: Minor clean up of rw_mgr_mem_initialize() ddr: altera: Internal rw_mgr_mem_calibrate_vfifo() cleanup part 1 ddr: altera: Internal rw_mgr_mem_calibrate_vfifo() cleanup part 2 ddr: altera: Internal rw_mgr_mem_calibrate_vfifo() cleanup part 3 ddr: altera: Internal rw_mgr_mem_calibrate_vfifo() cleanup part 4 ddr: altera: Internal rw_mgr_mem_calibrate_vfifo() cleanup part 5 ddr: altera: Internal rw_mgr_mem_calibrate_vfifo() cleanup part 6 ddr: altera: Internal rw_mgr_mem_calibrate_vfifo() cleanup part 7 ddr: altera: Extract guaranteed write from rw_mgr_mem_calibrate_vfifo() ddr: altera: Extract DQS enable calibration from rw_mgr_mem_calibrate_vfifo() ddr: altera: Extract Centering DQ/DQS from rw_mgr_mem_calibrate_vfifo() ddr: altera: Minor rw_mgr_mem_calibrate_read_load_patterns() cleanup ddr: altera: Zap rw_mgr_mem_calibrate_read_test_patterns_all_ranks() ddr: altera: Clean up rw_mgr_mem_calibrate_read_test_patterns() ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_find_dqs_en_phase_sweep_dq_in_delay() part 1 ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_find_dqs_en_phase_sweep_dq_in_delay() part 2 ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_find_dqs_en_phase_sweep_dq_in_delay() part 3 ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_find_dqs_en_phase_sweep_dq_in_delay() part 4 ddr: altera: Clean up sdr_find_window_centre() part 1 ddr: altera: Clean up sdr_find_window_centre() part 2 ddr: altera: Clean up sdr_find_window_centre() part 3 ddr: altera: Clean up sdr_*_phase() part 1 ddr: altera: Clean up sdr_*_phase() part 2 ddr: altera: Clean up sdr_*_phase() part 3 ddr: altera: Clean up sdr_*_phase() part 4 ddr: altera: Clean up sdr_*_phase() part 5 ddr: altera: Clean up sdr_*_phase() part 6 ddr: altera: Clean up sdr_*_phase() part 7 ddr: altera: Clean up sdr_*_phase() part 8 ddr: altera: Clean up sdr_*_phase() part 9 ddr: altera: Clean up sdr_*_phase() part 10 ddr: altera: Clean up rw_mgr_*_vfifo() part 1 ddr: altera: Clean up rw_mgr_*_vfifo() part 2 ddr: altera: Clean up find_vfifo_read() ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_find_dqs_en_phase() part 1 ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_find_dqs_en_phase() part 2 ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_find_dqs_en_phase() part 3 ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_find_dqs_en_phase() part 4 ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_find_dqs_en_phase() part 5 ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_find_dqs_en_phase() part 6 ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_find_dqs_en_phase() part 7 ddr: altera: Clean up rw_mgr_mem_calibrate_read_test_all_ranks() ddr: altera: Clean up rw_mgr_mem_calibrate_read_test() part 1 ddr: altera: Clean up rw_mgr_mem_calibrate_read_test() part 2 ddr: altera: Clean up rw_mgr_mem_calibrate_read_test() part 3 ddr: altera: Clean up rw_mgr_mem_calibrate_read_test() part 4 ddr: altera: Clean up rw_mgr_mem_calibrate_read_test() part 5 ddr: altera: Clean up rw_mgr_mem_calibrate_writes() ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_center() part 1 ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_center() part 2 ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_center() part 3 ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_center() part 4 ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_center() part 5 ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_center() part 6 ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_center() part 7 ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_center() part 8 ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_center() part 9 ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_center() part 10 ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_center() part 11 ddr: altera: Clean up rw_mgr_mem_calibrate_writes_center() part 1 ddr: altera: Clean up rw_mgr_mem_calibrate_writes_center() part 2 ddr: altera: Clean up rw_mgr_mem_calibrate_writes_center() part 3 ddr: altera: Clean up rw_mgr_mem_calibrate_writes_center() part 4 ddr: altera: Clean up rw_mgr_mem_calibrate_writes_center() part 5 ddr: altera: Clean up rw_mgr_mem_calibrate_write_test() part 1 ddr: altera: Clean up rw_mgr_mem_calibrate_write_test() part 2 ddr: altera: Clean up rw_mgr_mem_calibrate_write_test() part 3 ddr: altera: Clean up rw_mgr_mem_calibrate_write_test_issue() ddr: altera: Clean up rw_mgr_mem_calibrate_vfifo_end() ddr: altera: Clean up rw_mgr_mem_calibrate_lfifo() ddr: altera: Minor clean up of rw_mgr_mem_handoff() ddr: altera: Clean up of delay_for_n_mem_clocks() part 1 ddr: altera: Clean up of delay_for_n_mem_clocks() part 2 ddr: altera: Clean up of delay_for_n_mem_clocks() part 3 ddr: altera: Clean up of delay_for_n_mem_clocks() part 4 ddr: altera: Clean up of delay_for_n_mem_clocks() part 5 arm: socfpga: Add temporary workaround for missing SD/MMC patches ddr: altera: sdram: Switch to generic_hweight32() ddr: altera: sdram: Clean up compute_errata_rows() part 1 ddr: altera: sdram: Clean up compute_errata_rows() part 2 ddr: altera: sdram: Clean up set_sdr_ctrlcfg() ddr: altera: sdram: Clean up set_sdr_dram_timing*() ddr: altera: sdram: Clean up set_sdr_addr_rw() ddr: altera: sdram: Clean up set_sdr_static_cfg() ddr: altera: sdram: Clean up set_sdr_fifo_cfg() ddr: altera: sdram: Clean up set_sdr_mp_weight() ddr: altera: sdram: Clean up set_sdr_mp_pacing() ddr: altera: sdram: Clean up set_sdr_mp_threshold() ddr: altera: sdram: Introduce socfpga_sdram_config() structure ddr: altera: sdram: Clean up sdram_mmr_init_full() part 1 ddr: altera: sdram: Clean up sdram_mmr_init_full() part 2 ddr: altera: sdram: Clean up sdram_mmr_init_full() part 3 ddr: altera: sdram: Clean up sdram_mmr_init_full() part 4 ddr: altera: sdram: Clean up sdram_mmr_init_full() part 5 ddr: altera: sdram: Clean up sdram_mmr_init_full() part 6 ddr: altera: sdram: Clean up sdram_mmr_init_full() part 7 ddr: altera: sdram: Clean up sdram_mmr_init_full() part 8 ddr: altera: sdram: Introduce socfpga_sdram_get_config() ddr: altera: sdram: Clean up sdram_calculate_size() part 1 ddr: altera: sdram: Clean up sdram_calculate_size() part 2 ddr: altera: sdram: Clean up sdram_write_verify() ddr: altera: sdram: Add missing kerneldoc ddr: altera: sdram: Minor cleanup in sdram_set_rule() ddr: altera: sdram: Minor cleanup in sdram_get_rule() ddr: altera: sdram: Make sdram_start and sdram_end into u32 ddr: altera: sequencer: Move qts-generated files to board dir ddr: altera: sequencer: Clean up mach/sdram.h ddr: altera: sequencer: Zap unused params and macros ddr: altera: sequencer: Zap bogus redefinition of RW_MGR_MEM_NUMBER_OF_RANKS ddr: altera: sequencer: Wrap ac_rom_init and inst_rom_init ddr: altera: sequencer: Wrap RW_MGR_* macros ddr: altera: sequencer: Pluck out RW_MGR_* macros from code ddr: altera: sequencer: Wrap IO_* macros ddr: altera: sequencer: Pluck out IO_* macros from code ddr: altera: sequencer: Wrap misc remaining macros ddr: altera: sequencer: Zap VFIFO_SIZE ddr: altera: sequencer: Zap SEQ_T(INIT|RESET)_CNTR._VAL ddr: altera: sequencer: Pluck out misc macros from code ddr: altera: sequencer: Clean data types ddr: altera: sequencer: Clean checkpatch issues arm: socfpga: scan: Clean up scan_chain_engine_is_idle() arm: socfpga: scan: Introduce generic JTAG accessor arm: socfpga: scan: Clean up horrible macros arm: socfpga: scan: Factor out IO chain programming
Makefile | 13 + arch/arm/dts/socfpga.dtsi | 4 + arch/arm/dts/socfpga_arria5_socdk.dts | 8 +- arch/arm/dts/socfpga_cyclone5_socdk.dts | 4 - arch/arm/dts/socfpga_cyclone5_socrates.dts | 6 - arch/arm/mach-socfpga/Makefile | 4 +- arch/arm/mach-socfpga/clock_manager.c | 28 +- arch/arm/mach-socfpga/include/mach/clock_manager.h | 12 +- arch/arm/mach-socfpga/include/mach/reset_manager.h | 60 +- arch/arm/mach-socfpga/include/mach/scan_manager.h | 75 +- arch/arm/mach-socfpga/include/mach/sdram.h | 441 +++++++++- arch/arm/mach-socfpga/include/mach/system_manager.h | 7 +- arch/arm/mach-socfpga/misc.c | 184 ++++- arch/arm/mach-socfpga/reset_manager.c | 99 +-- arch/arm/mach-socfpga/scan_manager.c | 335 ++++---- arch/arm/mach-socfpga/spl.c | 220 ++--- arch/arm/mach-socfpga/system_manager.c | 16 +- arch/arm/mach-socfpga/u-boot-spl.lds | 45 - board/altera/socfpga/Makefile | 5 +- board/altera/socfpga/{ => qts}/iocsr_config.c | 0 board/altera/socfpga/{ => qts}/iocsr_config.h | 0 board/altera/socfpga/{ => qts}/pinmux_config.c | 0 board/altera/socfpga/{ => qts}/pinmux_config.h | 0 board/altera/socfpga/{ => qts}/pll_config.h | 0 board/altera/socfpga/qts/sdram_config.h | 100 +++ board/altera/socfpga/qts/sequencer_auto.h | 128 +++ board/altera/socfpga/qts/sequencer_auto_ac_init.h | 84 ++ board/altera/socfpga/qts/sequencer_auto_inst_init.h | 268 ++++++ board/altera/socfpga/qts/sequencer_defines.h | 122 +++ board/altera/socfpga/wrap_iocsr_config.c | 41 + board/altera/socfpga/wrap_pinmux_config.c | 35 + board/altera/socfpga/wrap_pll_config.c | 144 ++++ board/altera/socfpga/wrap_sdram_config.c | 316 ++++++++ configs/socfpga_arria5_defconfig | 10 + configs/socfpga_cyclone5_defconfig | 11 + configs/socfpga_socrates_defconfig | 12 +- drivers/ddr/altera/Makefile | 11 + drivers/ddr/altera/sdram.c | 535 ++++++++++++ drivers/ddr/altera/sequencer.c | 3783 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/ddr/altera/sequencer.h | 227 ++++++ drivers/fpga/socfpga.c | 3 + drivers/net/designware.c | 3 +- include/configs/socfpga_arria5.h | 7 +- include/configs/socfpga_common.h | 63 +- include/configs/socfpga_cyclone5.h | 7 +- include/fdtdec.h | 1 + lib/fdtdec.c | 1 + scripts/Makefile.spl | 11 + 48 files changed, 6913 insertions(+), 576 deletions(-) delete mode 100644 arch/arm/mach-socfpga/u-boot-spl.lds rename board/altera/socfpga/{ => qts}/iocsr_config.c (100%) rename board/altera/socfpga/{ => qts}/iocsr_config.h (100%) rename board/altera/socfpga/{ => qts}/pinmux_config.c (100%) rename board/altera/socfpga/{ => qts}/pinmux_config.h (100%) rename board/altera/socfpga/{ => qts}/pll_config.h (100%) create mode 100644 board/altera/socfpga/qts/sdram_config.h create mode 100644 board/altera/socfpga/qts/sequencer_auto.h create mode 100644 board/altera/socfpga/qts/sequencer_auto_ac_init.h create mode 100644 board/altera/socfpga/qts/sequencer_auto_inst_init.h create mode 100644 board/altera/socfpga/qts/sequencer_defines.h create mode 100644 board/altera/socfpga/wrap_iocsr_config.c create mode 100644 board/altera/socfpga/wrap_pinmux_config.c create mode 100644 board/altera/socfpga/wrap_pll_config.c create mode 100644 board/altera/socfpga/wrap_sdram_config.c create mode 100644 drivers/ddr/altera/Makefile create mode 100644 drivers/ddr/altera/sdram.c create mode 100644 drivers/ddr/altera/sequencer.c create mode 100644 drivers/ddr/altera/sequencer.h
The following changes since commit ae27120c31d58b8bb694d9155bcffdcfae8552a6: Merge git://git.denx.de/u-boot-dm (2015-08-06 19:56:03 -0400)
are available in the git repository at: git://git.denx.de/u-boot-socfpga.git HEAD
for you to fetch changes up to bd48c0617b5c7212e5bf22169e716da878842da4: arm: socfpga: misc: Add support for printing FPGA type (2015-08-08 14:14:30
+0200)
Woohoo! Thanks :)
Best regards, Marek Vasut
