[U-Boot] [PATCH] nios2: add generic board support
This patch implements the generic board init as described in doc/README.generic-board.
Signed-off-by: Thomas Chou thomas@wytron.com.tw Signed-off-by: Scott McNutt smcnutt@psyent.com --- arch/nios2/config.mk | 2 + arch/nios2/cpu/cpu.c | 12 +++- arch/nios2/cpu/start.S | 34 ++++++++- arch/nios2/include/asm/config.h | 4 + arch/nios2/include/asm/u-boot.h | 10 +--- arch/nios2/lib/Makefile | 1 - arch/nios2/lib/board.c | 147 --------------------------------------- common/board_f.c | 7 +- common/board_r.c | 2 +- 9 files changed, 52 insertions(+), 167 deletions(-) delete mode 100644 arch/nios2/lib/board.c
diff --git a/arch/nios2/config.mk b/arch/nios2/config.mk index 82bd887..9b7c56d 100644 --- a/arch/nios2/config.mk +++ b/arch/nios2/config.mk @@ -17,3 +17,5 @@ PLATFORM_CPPFLAGS += -G0
LDFLAGS_FINAL += --gc-sections PLATFORM_RELFLAGS += -ffunction-sections -fdata-sections + +__HAVE_ARCH_GENERIC_BOARD := y diff --git a/arch/nios2/cpu/cpu.c b/arch/nios2/cpu/cpu.c index e0dcbc2..4714171 100644 --- a/arch/nios2/cpu/cpu.c +++ b/arch/nios2/cpu/cpu.c @@ -10,11 +10,13 @@ #include <nios2-io.h> #include <asm/cache.h>
+DECLARE_GLOBAL_DATA_PTR; + #if defined (CONFIG_SYS_NIOS_SYSID_BASE) extern void display_sysid (void); #endif /* CONFIG_SYS_NIOS_SYSID_BASE */
-int checkcpu (void) +int print_cpuinfo (void) { printf ("CPU : Nios-II\n"); #if !defined(CONFIG_SYS_NIOS_SYSID_BASE) @@ -47,3 +49,11 @@ void dcache_disable(void) { flush_dcache(CONFIG_SYS_DCACHE_SIZE, CONFIG_SYS_DCACHELINE_SIZE); } + +int arch_cpu_init(void) +{ + gd->cpu_clk = CONFIG_SYS_CLK_FREQ; + gd->ram_size = CONFIG_SYS_SDRAM_SIZE; + + return 0; +} diff --git a/arch/nios2/cpu/start.S b/arch/nios2/cpu/start.S index 7ce0d34..6af9b4e 100644 --- a/arch/nios2/cpu/start.S +++ b/arch/nios2/cpu/start.S @@ -134,11 +134,12 @@ _reloc: mov fp, sp
/* - * Call board_init -- never returns + * Call board_init_f -- never returns */ - movhi r4, %hi(board_init@h) - ori r4, r4, %lo(board_init@h) - callr r4 + mov r4, r0 + movhi r2, %hi(board_init_f@h) + ori r2, r2, %lo(board_init_f@h) + callr r2
/* NEVER RETURNS -- but branch to the _start just * in case ;-) @@ -146,6 +147,31 @@ _reloc: br _start
+ +/* + * relocate_code -- Nios2 handles the relocation above. But + * the generic board code monkeys with the heap, stack, etc. + * (it makes some assumptions that may not be appropriate + * for Nios). Nevertheless, we capitulate here. + * + * We'll call the board_init_r from here since this isn't + * supposed to return. + * + * void relocate_code (ulong sp, gd_t *global_data, + * ulong reloc_addr) + * __attribute__ ((noreturn)); + */ + .text + .global relocate_code + +relocate_code: + mov sp, r4 /* Set the new sp */ + mov r4, r5 + movhi r8, %hi(board_init_r@h) + ori r8, r8, %lo(board_init_r@h) + callr r8 + ret + /* * dly_clks -- Nios2 (like Nios1) doesn't have a timebase in * the core. For simple delay loops, we do our best by counting diff --git a/arch/nios2/include/asm/config.h b/arch/nios2/include/asm/config.h index cd29734..59546f0 100644 --- a/arch/nios2/include/asm/config.h +++ b/arch/nios2/include/asm/config.h @@ -7,4 +7,8 @@ #ifndef _ASM_CONFIG_H_ #define _ASM_CONFIG_H_
+#define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_SYS_GENERIC_GLOBAL_DATA +#define CONFIG_DISPLAY_CPUINFO + #endif diff --git a/arch/nios2/include/asm/u-boot.h b/arch/nios2/include/asm/u-boot.h index 51f6c30..cb02e98 100644 --- a/arch/nios2/include/asm/u-boot.h +++ b/arch/nios2/include/asm/u-boot.h @@ -15,15 +15,7 @@ #ifndef __ASM_NIOS2_U_BOOT_H_ #define __ASM_NIOS2_U_BOOT_H_
-typedef struct bd_info { - unsigned long bi_memstart; /* start of DRAM memory */ - phys_size_t bi_memsize; /* size of DRAM memory in bytes */ - unsigned long bi_flashstart; /* start of FLASH memory */ - unsigned long bi_flashsize; /* size of FLASH memory */ - unsigned long bi_flashoffset; /* reserved area for startup monitor */ - unsigned long bi_sramstart; /* start of SRAM memory */ - unsigned long bi_sramsize; /* size of SRAM memory */ -} bd_t; +#include <asm-generic/u-boot.h>
/* For image.h:image_check_target_arch() */ #define IH_ARCH_DEFAULT IH_ARCH_NIOS2 diff --git a/arch/nios2/lib/Makefile b/arch/nios2/lib/Makefile index 7cb25c0..079378a 100644 --- a/arch/nios2/lib/Makefile +++ b/arch/nios2/lib/Makefile @@ -6,7 +6,6 @@ #
obj-y += cache.o -obj-y += board.o obj-$(CONFIG_CMD_BOOTM) += bootm.o obj-y += libgcc.o obj-y += time.o diff --git a/arch/nios2/lib/board.c b/arch/nios2/lib/board.c deleted file mode 100644 index f24218f..0000000 --- a/arch/nios2/lib/board.c +++ /dev/null @@ -1,147 +0,0 @@ -/* - * (C) Copyright 2003, Psyent Corporation <www.psyent.com> - * Scott McNutt smcnutt@psyent.com - * - * (C) Copyright 2000-2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <stdio_dev.h> -#include <watchdog.h> -#include <malloc.h> -#include <mmc.h> -#include <net.h> -#ifdef CONFIG_STATUS_LED -#include <status_led.h> -#endif -#if defined(CONFIG_SYS_NIOS_EPCSBASE) -#include <nios2-epcs.h> -#endif -#ifdef CONFIG_CMD_NAND -#include <nand.h> /* cannot even include nand.h if it isnt configured */ -#endif - -DECLARE_GLOBAL_DATA_PTR; - -/* - * All attempts to come up with a "common" initialization sequence - * that works for all boards and architectures failed: some of the - * requirements are just _too_ different. To get rid of the resulting - * mess of board dependend #ifdef'ed code we now make the whole - * initialization sequence configurable to the user. - * - * The requirements for any new initalization function is simple: it - * receives a pointer to the "global data" structure as it's only - * argument, and returns an integer return code, where 0 means - * "continue" and != 0 means "fatal error, hang the system". - */ - - -typedef int (init_fnc_t) (void); - - -/************************************************************************ - * Initialization sequence * - ***********************************************************************/ - -init_fnc_t *init_sequence[] = { -#if defined(CONFIG_BOARD_EARLY_INIT_F) - board_early_init_f, /* Call board-specific init code early.*/ -#endif -#if defined(CONFIG_SYS_NIOS_EPCSBASE) - epcs_reset, -#endif - - env_init, - serial_init, - console_init_f, - display_options, - checkcpu, - checkboard, - NULL, /* Terminate this list */ -}; - - -/***********************************************************************/ -void board_init(void) -{ - bd_t *bd; - init_fnc_t **init_fnc_ptr; - static gd_t gd_data; - static bd_t bd_data; - - /* Pointer is writable since we allocated a register for it. */ - gd = &gd_data; - /* compiler optimization barrier needed for GCC >= 3.4 */ - __asm__ __volatile__("" : : : "memory"); - - gd->bd = &bd_data; - gd->baudrate = CONFIG_BAUDRATE; - gd->cpu_clk = CONFIG_SYS_CLK_FREQ; - - bd = gd->bd; - bd->bi_memstart = CONFIG_SYS_SDRAM_BASE; - bd->bi_memsize = CONFIG_SYS_SDRAM_SIZE; -#ifndef CONFIG_SYS_NO_FLASH - bd->bi_flashstart = CONFIG_SYS_FLASH_BASE; -#endif -#if defined(CONFIG_SYS_SRAM_BASE) && defined(CONFIG_SYS_SRAM_SIZE) - bd->bi_sramstart = CONFIG_SYS_SRAM_BASE; - bd->bi_sramsize = CONFIG_SYS_SRAM_SIZE; -#endif - - for (init_fnc_ptr = init_sequence; *init_fnc_ptr; ++init_fnc_ptr) { - WATCHDOG_RESET(); - if ((*init_fnc_ptr) () != 0) - hang(); - } - - WATCHDOG_RESET(); - - /* The Malloc area is immediately below the monitor copy in RAM */ - mem_malloc_init(CONFIG_SYS_MALLOC_BASE, CONFIG_SYS_MALLOC_LEN); - -#ifndef CONFIG_SYS_NO_FLASH - WATCHDOG_RESET(); - bd->bi_flashsize = flash_init(); -#endif - -#ifdef CONFIG_CMD_NAND - puts("NAND: "); - nand_init(); -#endif - -#ifdef CONFIG_GENERIC_MMC - puts("MMC: "); - mmc_initialize(bd); -#endif - - WATCHDOG_RESET(); - env_relocate(); - - WATCHDOG_RESET(); - stdio_init(); - jumptable_init(); - console_init_r(); - - WATCHDOG_RESET(); - interrupt_init(); - -#if defined(CONFIG_BOARD_LATE_INIT) - board_late_init(); -#endif - -#if defined(CONFIG_CMD_NET) - puts("Net: "); - eth_initialize(bd); -#endif - - /* main_loop */ - for (;;) { - WATCHDOG_RESET(); - main_loop(); - } -} diff --git a/common/board_f.c b/common/board_f.c index d5e7622..77a1990 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -9,7 +9,6 @@ * * SPDX-License-Identifier: GPL-2.0+ */ - #include <common.h> #include <linux/compiler.h> #include <version.h> @@ -270,7 +269,7 @@ static int setup_mon_len(void) gd->mon_len = (ulong)&__bss_end - (ulong)_start; #elif defined(CONFIG_SANDBOX) gd->mon_len = (ulong)&_end - (ulong)_init; -#elif defined(CONFIG_BLACKFIN) +#elif defined(CONFIG_BLACKFIN) || defined(CONFIG_NIOS2) gd->mon_len = CONFIG_SYS_MONITOR_LEN; #else /* TODO: use (ulong)&__bss_end - (ulong)&__text_start; ? */ @@ -945,7 +944,7 @@ static init_fnc_t init_sequence_f[] = { * - board info struct */ setup_dest_addr, -#if defined(CONFIG_BLACKFIN) +#if defined(CONFIG_BLACKFIN) || defined(CONFIG_NIOS2) /* Blackfin u-boot monitor should be on top of the ram */ reserve_uboot, #endif @@ -970,7 +969,7 @@ static init_fnc_t init_sequence_f[] = { !defined(CONFIG_BLACKFIN) reserve_video, #endif -#if !defined(CONFIG_BLACKFIN) +#if !defined(CONFIG_BLACKFIN) && !defined(CONFIG_NIOS2) reserve_uboot, #endif #ifndef CONFIG_SPL_BUILD diff --git a/common/board_r.c b/common/board_r.c index ba9a68d..f9647e1 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -133,7 +133,7 @@ static int initr_reloc_global_data(void) { #ifdef __ARM__ monitor_flash_len = _end - __image_copy_start; -#elif !defined(CONFIG_SANDBOX) +#elif !defined(CONFIG_SANDBOX) && !defined(CONFIG_NIOS2) monitor_flash_len = (ulong)&__init_end - gd->relocaddr; #endif #if defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx)
Good idea. Please find below a few comments, mostly coding style related.
<snip>
- #if defined (CONFIG_SYS_NIOS_SYSID_BASE) extern void display_sysid (void); #endif /* CONFIG_SYS_NIOS_SYSID_BASE */
While changing this line, please fix the coding style to:
+int print_cpuinfo(void)
No space before the "(".
<snip>
This empty line removal seems to have slipped in. I know, its nitpicking, but I would prefer to not change unrelated things.
Otherwise looks good:
Thanks, Stefan
Signed-off-by: Thomas Chou thomas@wytron.com.tw Signed-off-by: Scott McNutt smcnutt@psyent.com Reviewed-by: Stefan Roese sr@denx.de ---
Changes in v2: - Coding style clean up
arch/nios2/config.mk | 2 + arch/nios2/cpu/cpu.c | 12 +++- arch/nios2/cpu/start.S | 34 ++++++++- arch/nios2/include/asm/config.h | 4 + arch/nios2/include/asm/u-boot.h | 10 +--- arch/nios2/lib/Makefile | 1 - arch/nios2/lib/board.c | 147 --------------------------------------- common/board_f.c | 6 +- common/board_r.c | 2 +- 9 files changed, 52 insertions(+), 166 deletions(-) delete mode 100644 arch/nios2/lib/board.c
LDFLAGS_FINAL += --gc-sections PLATFORM_RELFLAGS += -ffunction-sections -fdata-sections + +__HAVE_ARCH_GENERIC_BOARD := y diff --git a/arch/nios2/cpu/cpu.c b/arch/nios2/cpu/cpu.c index e0dcbc2..9f17d8b 100644 --- a/arch/nios2/cpu/cpu.c +++ b/arch/nios2/cpu/cpu.c @@ -10,11 +10,13 @@ #include <nios2-io.h> #include <asm/cache.h>
-int checkcpu (void) +int print_cpuinfo(void) { printf ("CPU : Nios-II\n"); #if !defined(CONFIG_SYS_NIOS_SYSID_BASE) @@ -47,3 +49,11 @@ void dcache_disable(void) { flush_dcache(CONFIG_SYS_DCACHE_SIZE, CONFIG_SYS_DCACHELINE_SIZE); } + +int arch_cpu_init(void) +{ + gd->cpu_clk = CONFIG_SYS_CLK_FREQ; + gd->ram_size = CONFIG_SYS_SDRAM_SIZE; + + return 0; +} diff --git a/arch/nios2/cpu/start.S b/arch/nios2/cpu/start.S index 7ce0d34..6af9b4e 100644 --- a/arch/nios2/cpu/start.S +++ b/arch/nios2/cpu/start.S @@ -134,11 +134,12 @@ _reloc: mov fp, sp
obj-y += cache.o -obj-y += board.o obj-$(CONFIG_CMD_BOOTM) += bootm.o obj-y += libgcc.o obj-y += time.o diff --git a/arch/nios2/lib/board.c b/arch/nios2/lib/board.c deleted file mode 100644 index f24218f..0000000 --- a/arch/nios2/lib/board.c +++ /dev/null @@ -1,147 +0,0 @@ -/* - * (C) Copyright 2003, Psyent Corporation <www.psyent.com> - * Scott McNutt smcnutt@psyent.com - * - * (C) Copyright 2000-2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <stdio_dev.h> -#include <watchdog.h> -#include <malloc.h> -#include <mmc.h> -#include <net.h> -#ifdef CONFIG_STATUS_LED -#include <status_led.h> -#endif -#if defined(CONFIG_SYS_NIOS_EPCSBASE) -#include <nios2-epcs.h> -#endif -#ifdef CONFIG_CMD_NAND -#include <nand.h> /* cannot even include nand.h if it isnt configured */ -#endif - -DECLARE_GLOBAL_DATA_PTR; - -/* - * All attempts to come up with a "common" initialization sequence - * that works for all boards and architectures failed: some of the - * requirements are just _too_ different. To get rid of the resulting - * mess of board dependend #ifdef'ed code we now make the whole - * initialization sequence configurable to the user. - * - * The requirements for any new initalization function is simple: it - * receives a pointer to the "global data" structure as it's only - * argument, and returns an integer return code, where 0 means - * "continue" and != 0 means "fatal error, hang the system". - */ - - -typedef int (init_fnc_t) (void); - - -/************************************************************************ - * Initialization sequence * - ***********************************************************************/ - -init_fnc_t *init_sequence[] = { -#if defined(CONFIG_BOARD_EARLY_INIT_F) - board_early_init_f, /* Call board-specific init code early.*/ -#endif -#if defined(CONFIG_SYS_NIOS_EPCSBASE) - epcs_reset, -#endif - - env_init, - serial_init, - console_init_f, - display_options, - checkcpu, - checkboard, - NULL, /* Terminate this list */ -}; - - -/***********************************************************************/ -void board_init(void) -{ - bd_t *bd; - init_fnc_t **init_fnc_ptr; - static gd_t gd_data; - static bd_t bd_data; - - /* Pointer is writable since we allocated a register for it. */ - gd = &gd_data; - /* compiler optimization barrier needed for GCC >= 3.4 */ - __asm__ __volatile__("" : : : "memory"); - - gd->bd = &bd_data; - gd->baudrate = CONFIG_BAUDRATE; - gd->cpu_clk = CONFIG_SYS_CLK_FREQ; - - bd = gd->bd; - bd->bi_memstart = CONFIG_SYS_SDRAM_BASE; - bd->bi_memsize = CONFIG_SYS_SDRAM_SIZE; -#ifndef CONFIG_SYS_NO_FLASH - bd->bi_flashstart = CONFIG_SYS_FLASH_BASE; -#endif -#if defined(CONFIG_SYS_SRAM_BASE) && defined(CONFIG_SYS_SRAM_SIZE) - bd->bi_sramstart = CONFIG_SYS_SRAM_BASE; - bd->bi_sramsize = CONFIG_SYS_SRAM_SIZE; -#endif - - for (init_fnc_ptr = init_sequence; *init_fnc_ptr; ++init_fnc_ptr) { - WATCHDOG_RESET(); - if ((*init_fnc_ptr) () != 0) - hang(); - } - - WATCHDOG_RESET(); - - /* The Malloc area is immediately below the monitor copy in RAM */ - mem_malloc_init(CONFIG_SYS_MALLOC_BASE, CONFIG_SYS_MALLOC_LEN); - -#ifndef CONFIG_SYS_NO_FLASH - WATCHDOG_RESET(); - bd->bi_flashsize = flash_init(); -#endif - -#ifdef CONFIG_CMD_NAND - puts("NAND: "); - nand_init(); -#endif - -#ifdef CONFIG_GENERIC_MMC - puts("MMC: "); - mmc_initialize(bd); -#endif - - WATCHDOG_RESET(); - env_relocate(); - - WATCHDOG_RESET(); - stdio_init(); - jumptable_init(); - console_init_r(); - - WATCHDOG_RESET(); - interrupt_init(); - -#if defined(CONFIG_BOARD_LATE_INIT) - board_late_init(); -#endif - -#if defined(CONFIG_CMD_NET) - puts("Net: "); - eth_initialize(bd); -#endif - - /* main_loop */ - for (;;) { - WATCHDOG_RESET(); - main_loop(); - } -} diff --git a/common/board_f.c b/common/board_f.c index d5e7622..11aa555 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -270,7 +270,7 @@ static int setup_mon_len(void) gd->mon_len = (ulong)&__bss_end - (ulong)_start; #elif defined(CONFIG_SANDBOX) gd->mon_len = (ulong)&_end - (ulong)_init; -#elif defined(CONFIG_BLACKFIN) +#elif defined(CONFIG_BLACKFIN) || defined(CONFIG_NIOS2) gd->mon_len = CONFIG_SYS_MONITOR_LEN; #else /* TODO: use (ulong)&__bss_end - (ulong)&__text_start; ? */ @@ -945,7 +945,7 @@ static init_fnc_t init_sequence_f[] = { * - board info struct */ setup_dest_addr, -#if defined(CONFIG_BLACKFIN) +#if defined(CONFIG_BLACKFIN) || defined(CONFIG_NIOS2) /* Blackfin u-boot monitor should be on top of the ram */ reserve_uboot, #endif @@ -970,7 +970,7 @@ static init_fnc_t init_sequence_f[] = { !defined(CONFIG_BLACKFIN) reserve_video, #endif -#if !defined(CONFIG_BLACKFIN) +#if !defined(CONFIG_BLACKFIN) && !defined(CONFIG_NIOS2) reserve_uboot, #endif #ifndef CONFIG_SPL_BUILD diff --git a/common/board_r.c b/common/board_r.c index ba9a68d..f9647e1 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -133,7 +133,7 @@ static int initr_reloc_global_data(void) { #ifdef __ARM__ monitor_flash_len = _end - __image_copy_start; -#elif !defined(CONFIG_SANDBOX) +#elif !defined(CONFIG_SANDBOX) && !defined(CONFIG_NIOS2) monitor_flash_len = (ulong)&__init_end - gd->relocaddr; #endif #if defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx)
Changes in v3: - Add display cpu and board info to nios2-generic board
arch/nios2/config.mk | 2 + arch/nios2/cpu/cpu.c | 14 ++++- arch/nios2/cpu/start.S | 34 ++++++++- arch/nios2/include/asm/config.h | 3 + arch/nios2/include/asm/u-boot.h | 10 +--- arch/nios2/lib/Makefile | 1 - arch/nios2/lib/board.c | 147 --------------------------------------- common/board_f.c | 6 +- common/board_r.c | 2 +- include/configs/nios2-generic.h | 2 + 10 files changed, 55 insertions(+), 166 deletions(-) delete mode 100644 arch/nios2/lib/board.c
LDFLAGS_FINAL += --gc-sections PLATFORM_RELFLAGS += -ffunction-sections -fdata-sections + +__HAVE_ARCH_GENERIC_BOARD := y diff --git a/arch/nios2/cpu/cpu.c b/arch/nios2/cpu/cpu.c index e0dcbc2..86f94b7 100644 --- a/arch/nios2/cpu/cpu.c +++ b/arch/nios2/cpu/cpu.c @@ -10,11 +10,14 @@ #include <nios2-io.h> #include <asm/cache.h>
-int checkcpu (void) +#ifdef CONFIG_DISPLAY_CPUINFO +int print_cpuinfo(void) { printf ("CPU : Nios-II\n"); #if !defined(CONFIG_SYS_NIOS_SYSID_BASE) @@ -24,6 +27,7 @@ int checkcpu (void) #endif return (0); } +#endif /* CONFIG_DISPLAY_CPUINFO */
int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { @@ -47,3 +51,11 @@ void dcache_disable(void) { flush_dcache(CONFIG_SYS_DCACHE_SIZE, CONFIG_SYS_DCACHELINE_SIZE); } + +int arch_cpu_init(void) +{ + gd->cpu_clk = CONFIG_SYS_CLK_FREQ; + gd->ram_size = CONFIG_SYS_SDRAM_SIZE; + + return 0; +} diff --git a/arch/nios2/cpu/start.S b/arch/nios2/cpu/start.S index 7ce0d34..6af9b4e 100644 --- a/arch/nios2/cpu/start.S +++ b/arch/nios2/cpu/start.S @@ -134,11 +134,12 @@ _reloc: mov fp, sp
+ +/* + * relocate_code -- Nios2 handles the relocation above. But + * the generic board code monkeys with the heap, stack, etc. + * (it makes some assumptions that may not be appropriate + * for Nios). Nevertheless, we capitulate here. + * + * We'll call the board_init_r from here since this isn't + * supposed to return. + * + * void relocate_code (ulong sp, gd_t *global_data, + * ulong reloc_addr) + * __attribute__ ((noreturn)); + */ + .text + .global relocate_code + +relocate_code: + mov sp, r4 /* Set the new sp */ + mov r4, r5 + movhi r8, %hi(board_init_r@h) + ori r8, r8, %lo(board_init_r@h) + callr r8 + ret + /* * dly_clks -- Nios2 (like Nios1) doesn't have a timebase in * the core. For simple delay loops, we do our best by counting diff --git a/arch/nios2/include/asm/config.h b/arch/nios2/include/asm/config.h index cd29734..476a32b 100644 --- a/arch/nios2/include/asm/config.h +++ b/arch/nios2/include/asm/config.h @@ -7,4 +7,7 @@ #ifndef _ASM_CONFIG_H_ #define _ASM_CONFIG_H_
+#define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_SYS_GENERIC_GLOBAL_DATA + #endif diff --git a/arch/nios2/include/asm/u-boot.h b/arch/nios2/include/asm/u-boot.h index 51f6c30..cb02e98 100644 --- a/arch/nios2/include/asm/u-boot.h +++ b/arch/nios2/include/asm/u-boot.h @@ -15,15 +15,7 @@ #ifndef __ASM_NIOS2_U_BOOT_H_ #define __ASM_NIOS2_U_BOOT_H_
obj-y += cache.o -obj-y += board.o obj-$(CONFIG_CMD_BOOTM) += bootm.o obj-y += libgcc.o obj-y += time.o diff --git a/arch/nios2/lib/board.c b/arch/nios2/lib/board.c deleted file mode 100644 index f24218f..0000000 --- a/arch/nios2/lib/board.c +++ /dev/null @@ -1,147 +0,0 @@ -/* - * (C) Copyright 2003, Psyent Corporation <www.psyent.com> - * Scott McNutt smcnutt@psyent.com - * - * (C) Copyright 2000-2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <stdio_dev.h> -#include <watchdog.h> -#include <malloc.h> -#include <mmc.h> -#include <net.h> -#ifdef CONFIG_STATUS_LED -#include <status_led.h> -#endif -#if defined(CONFIG_SYS_NIOS_EPCSBASE) -#include <nios2-epcs.h> -#endif -#ifdef CONFIG_CMD_NAND -#include <nand.h> /* cannot even include nand.h if it isnt configured */ -#endif - -DECLARE_GLOBAL_DATA_PTR; - -/* - * All attempts to come up with a "common" initialization sequence - * that works for all boards and architectures failed: some of the - * requirements are just _too_ different. To get rid of the resulting - * mess of board dependend #ifdef'ed code we now make the whole - * initialization sequence configurable to the user. - * - * The requirements for any new initalization function is simple: it - * receives a pointer to the "global data" structure as it's only - * argument, and returns an integer return code, where 0 means - * "continue" and != 0 means "fatal error, hang the system". - */ - - -typedef int (init_fnc_t) (void); - - -/************************************************************************ - * Initialization sequence * - ***********************************************************************/ - -init_fnc_t *init_sequence[] = { -#if defined(CONFIG_BOARD_EARLY_INIT_F) - board_early_init_f, /* Call board-specific init code early.*/ -#endif -#if defined(CONFIG_SYS_NIOS_EPCSBASE) - epcs_reset, -#endif - - env_init, - serial_init, - console_init_f, - display_options, - checkcpu, - checkboard, - NULL, /* Terminate this list */ -}; - - -/***********************************************************************/ -void board_init(void) -{ - bd_t *bd; - init_fnc_t **init_fnc_ptr; - static gd_t gd_data; - static bd_t bd_data; - - /* Pointer is writable since we allocated a register for it. */ - gd = &gd_data; - /* compiler optimization barrier needed for GCC >= 3.4 */ - __asm__ __volatile__("" : : : "memory"); - - gd->bd = &bd_data; - gd->baudrate = CONFIG_BAUDRATE; - gd->cpu_clk = CONFIG_SYS_CLK_FREQ; - - bd = gd->bd; - bd->bi_memstart = CONFIG_SYS_SDRAM_BASE; - bd->bi_memsize = CONFIG_SYS_SDRAM_SIZE; -#ifndef CONFIG_SYS_NO_FLASH - bd->bi_flashstart = CONFIG_SYS_FLASH_BASE; -#endif -#if defined(CONFIG_SYS_SRAM_BASE) && defined(CONFIG_SYS_SRAM_SIZE) - bd->bi_sramstart = CONFIG_SYS_SRAM_BASE; - bd->bi_sramsize = CONFIG_SYS_SRAM_SIZE; -#endif - - for (init_fnc_ptr = init_sequence; *init_fnc_ptr; ++init_fnc_ptr) { - WATCHDOG_RESET(); - if ((*init_fnc_ptr) () != 0) - hang(); - } - - WATCHDOG_RESET(); - - /* The Malloc area is immediately below the monitor copy in RAM */ - mem_malloc_init(CONFIG_SYS_MALLOC_BASE, CONFIG_SYS_MALLOC_LEN); - -#ifndef CONFIG_SYS_NO_FLASH - WATCHDOG_RESET(); - bd->bi_flashsize = flash_init(); -#endif - -#ifdef CONFIG_CMD_NAND - puts("NAND: "); - nand_init(); -#endif - -#ifdef CONFIG_GENERIC_MMC - puts("MMC: "); - mmc_initialize(bd); -#endif - - WATCHDOG_RESET(); - env_relocate(); - - WATCHDOG_RESET(); - stdio_init(); - jumptable_init(); - console_init_r(); - - WATCHDOG_RESET(); - interrupt_init(); - -#if defined(CONFIG_BOARD_LATE_INIT) - board_late_init(); -#endif - -#if defined(CONFIG_CMD_NET) - puts("Net: "); - eth_initialize(bd); -#endif - - /* main_loop */ - for (;;) { - WATCHDOG_RESET(); - main_loop(); - } -} diff --git a/common/board_f.c b/common/board_f.c index d5e7622..11aa555 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -270,7 +270,7 @@ static int setup_mon_len(void) gd->mon_len = (ulong)&__bss_end - (ulong)_start; #elif defined(CONFIG_SANDBOX) gd->mon_len = (ulong)&_end - (ulong)_init; -#elif defined(CONFIG_BLACKFIN) +#elif defined(CONFIG_BLACKFIN) || defined(CONFIG_NIOS2) gd->mon_len = CONFIG_SYS_MONITOR_LEN; #else /* TODO: use (ulong)&__bss_end - (ulong)&__text_start; ? */ @@ -945,7 +945,7 @@ static init_fnc_t init_sequence_f[] = { * - board info struct */ setup_dest_addr, -#if defined(CONFIG_BLACKFIN) +#if defined(CONFIG_BLACKFIN) || defined(CONFIG_NIOS2) /* Blackfin u-boot monitor should be on top of the ram */ reserve_uboot, #endif @@ -970,7 +970,7 @@ static init_fnc_t init_sequence_f[] = { !defined(CONFIG_BLACKFIN) reserve_video, #endif -#if !defined(CONFIG_BLACKFIN) +#if !defined(CONFIG_BLACKFIN) && !defined(CONFIG_NIOS2) reserve_uboot, #endif #ifndef CONFIG_SPL_BUILD diff --git a/common/board_r.c b/common/board_r.c index ba9a68d..f9647e1 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -133,7 +133,7 @@ static int initr_reloc_global_data(void) { #ifdef __ARM__ monitor_flash_len = _end - __image_copy_start; -#elif !defined(CONFIG_SANDBOX) +#elif !defined(CONFIG_SANDBOX) && !defined(CONFIG_NIOS2) monitor_flash_len = (ulong)&__init_end - gd->relocaddr; #endif #if defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) diff --git a/include/configs/nios2-generic.h b/include/configs/nios2-generic.h index 1578b01..51b1d00 100644 --- a/include/configs/nios2-generic.h +++ b/include/configs/nios2-generic.h @@ -15,6 +15,8 @@ #include "../board/altera/nios2-generic/custom_fpga.h" /* fpga parameters */ #define CONFIG_BOARD_NAME "nios2-generic" /* custom board name */ #define CONFIG_BOARD_EARLY_INIT_F /* enable early board-spec. init */ +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO #define CONFIG_SYS_NIOS_SYSID_BASE CONFIG_SYS_SYSID_BASE
Applied.
Thomas Chou
Stefan Roese
Thomas Chou
