[PATCH 1/1] doc: fix AX25-AE350 RISC-V documentation
Since commit 04883bf7acca ("doc: update AX25-AE350 RISC-V documentation") `make htmldocs` produces a log of warnings like
doc/board/AndesTech/ax25-ae350.rst:373: WARNING: Block quote ends without a blank line; unexpected unindent. doc/board/AndesTech/ax25-ae350.rst:0: WARNING: Undefined substitution referenced: "_ __ ___ _ __ | (___ | |_) |".
Reformat the problematic passages.
Fixes: 04883bf7acca ("doc: update AX25-AE350 RISC-V documentation") Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/board/AndesTech/ax25-ae350.rst | 335 +++++++++++++++-------------- 1 file changed, 168 insertions(+), 167 deletions(-)
diff --git a/doc/board/AndesTech/ax25-ae350.rst b/doc/board/AndesTech/ax25-ae350.rst index a7bd1a75e8..8874325840 100644 --- a/doc/board/AndesTech/ax25-ae350.rst +++ b/doc/board/AndesTech/ax25-ae350.rst @@ -62,9 +62,10 @@ Configurations --------------
CONFIG_SKIP_LOWLEVEL_INIT: - If you want to boot this system from SPI ROM and bypass e-bios (the - other boot loader on ROM). You should undefine CONFIG_SKIP_LOWLEVEL_INIT - in "include/configs/ax25-ae350.h". + +If you want to boot this system from SPI ROM and bypass e-bios (the +other boot loader on ROM). You should undefine CONFIG_SKIP_LOWLEVEL_INIT +in "include/configs/ax25-ae350.h".
Build and boot steps -------------------- @@ -165,7 +166,7 @@ Messages of U-Boot boot on AE350 board crc32 for 80000000 ... 80050452 ==> 692dc44a RISC-V #
- *** power-off and power-on, this U-Boot is booted from spi flash *** + *** power-off and power-on, this U-Boot is booted from spi flash ***
U-Boot 2018.01-rc2-00032-gf67dd47-dirty (Dec 21 2017 - 13:56:03 +0800)
@@ -365,168 +366,168 @@ Messages of U-Boot SPL boots Kernel on AE350 board
.. code-block:: none
-U-Boot SPL 2020.01-rc1-00292-g67a3313-dirty (Nov 14 2019 - 11:26:21 +0800) -Trying to boot from RAM - -OpenSBI v0.5-1-gdd8ef28 (Nov 14 2019 11:08:39) - ____ _____ ____ _____ - / __ \ / ____| _ _ _| - | | | |_ __ ___ _ __ | (___ | |_) || | - | | | | '_ \ / _ \ '_ \ ___ | _ < | | - | |__| | |_) | __/ | | |____) | |_) || |_ - ____/| .__/ ___|_| |_|_____/|____/_____| - | | - |_| - -Platform Name : Andes AE350 -Platform HART Features : RV64ACIMSUX -Platform Max HARTs : 4 -Current Hart : 0 -Firmware Base : 0x0 -Firmware Size : 84 KB -Runtime SBI Version : 0.2 - -PMP0: 0x0000000000000000-0x000000000001ffff (A) -PMP1: 0x0000000000000000-0x00000001ffffffff (A,R,W,X) - - -U-Boot 2020.01-rc1-00292-g67a3313-dirty (Nov 14 2019 - 11:26:21 +0800) - -DRAM: 1 GiB -Flash: 64 MiB -MMC: mmc@f0e00000: 0 -Loading Environment from SPI Flash... SF: Detected mx25u1635e with page size 256 Bytes, erase size 4 KiB, total 2 MiB -OK -In: serial@f0300000 -Out: serial@f0300000 -Err: serial@f0300000 -Net: no alias for ethernet0 - -Warning: mac@e0100000 (eth0) using random MAC address - a2:ae:93:7b:cc:8f -eth0: mac@e0100000 -Hit any key to stop autoboot: 0 -6455 bytes read in 31 ms (203.1 KiB/s) -20421684 bytes read in 8647 ms (2.3 MiB/s) -## Booting kernel from Legacy Image at 00600000 ... - Image Name: - Image Type: RISC-V Linux Kernel Image (uncompressed) - Data Size: 20421620 Bytes = 19.5 MiB - Load Address: 00200000 - Entry Point: 00200000 - Verifying Checksum ... OK -## Flattened Device Tree blob at 20000000 - Booting using the fdt blob at 0x20000000 - Loading Kernel Image - Loading Device Tree to 000000001effb000, end 000000001efff936 ... OK - -Starting kernel ... - -OF: fdt: Ignoring memory range 0x0 - 0x200000 -Linux version 4.17.0-00253-g49136e10bcb2 (sqa@atcsqa07) (gcc version 7.3.0 (2019-04-06_nds64le-linux-glibc-v5_experimental)) #1 SMP PREEMPT Sat Apr 6 23:41:49 CST 2019 -bootconsole [early0] enabled -Initial ramdisk at: 0x (ptrval) (13665712 bytes) -Zone ranges: - DMA32 [mem 0x0000000000200000-0x000000003fffffff] - Normal empty -Movable zone start for each node -Early memory node ranges - node 0: [mem 0x0000000000200000-0x000000003fffffff] -Initmem setup node 0 [mem 0x0000000000200000-0x000000003fffffff] -software IO TLB [mem 0x3b1f8000-0x3f1f8000] (64MB) mapped at [ (ptrval)- (ptrval)] -elf_platform is rv64i2p0m2p0a2p0c2p0xv5-0p0 -compatible privileged spec version 1.10 -percpu: Embedded 16 pages/cpu @ (ptrval) s28184 r8192 d29160 u65536 -Built 1 zonelists, mobility grouping on. Total pages: 258055 -Kernel command line: console=ttyS0,38400n8 debug loglevel=7 -log_buf_len individual max cpu contribution: 4096 bytes -log_buf_len total cpu_extra contributions: 12288 bytes -log_buf_len min size: 16384 bytes -log_buf_len: 32768 bytes -early log buf free: 14608(89%) -Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes) -Inode-cache hash table entries: 65536 (order: 7, 524288 bytes) -Sorting __ex_table... -Memory: 944428K/1046528K available (3979K kernel code, 246K rwdata, 1490K rodata, 13523K init, 688K bss, 102100K reserved, 0K cma-reserved) -SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 -Preemptible hierarchical RCU implementation. - Tasks RCU enabled. -NR_IRQS: 72, nr_irqs: 72, preallocated irqs: 0 -riscv,cpu_intc,0: 64 local interrupts mapped -riscv,cpu_intc,1: 64 local interrupts mapped -riscv,cpu_intc,2: 64 local interrupts mapped -riscv,cpu_intc,3: 64 local interrupts mapped -riscv,plic0,e4000000: mapped 71 interrupts to 8/8 handlers -clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x1bacf917bf, max_idle_ns: 881590412290 ns -sched_clock: 64 bits at 60MHz, resolution 16ns, wraps every 4398046511098ns -Console: colour dummy device 40x30 -Calibrating delay loop (skipped), value calculated using timer frequency.. 120.00 BogoMIPS (lpj=600000) -pid_max: default: 32768 minimum: 301 -Mount-cache hash table entries: 2048 (order: 2, 16384 bytes) -Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes) -Hierarchical SRCU implementation. -smp: Bringing up secondary CPUs ... -CPU0: online -CPU2: online -CPU3: online -smp: Brought up 1 node, 4 CPUs -devtmpfs: initialized -random: get_random_u32 called from bucket_table_alloc+0x198/0x1d8 with crng_init=0 -clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns -futex hash table entries: 1024 (order: 4, 65536 bytes) -NET: Registered protocol family 16 -Advanced Linux Sound Architecture Driver Initialized. -clocksource: Switched to clocksource riscv_clocksource -NET: Registered protocol family 2 -tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes) -TCP established hash table entries: 8192 (order: 4, 65536 bytes) -TCP bind hash table entries: 8192 (order: 5, 131072 bytes) -TCP: Hash tables configured (established 8192 bind 8192) -UDP hash table entries: 512 (order: 2, 16384 bytes) -UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) -NET: Registered protocol family 1 -RPC: Registered named UNIX socket transport module. -RPC: Registered udp transport module. -RPC: Registered tcp transport module. -RPC: Registered tcp NFSv4.1 backchannel transport module. -Unpacking initramfs... -workingset: timestamp_bits=62 max_order=18 bucket_order=0 -NFS: Registering the id_resolver key type -Key type id_resolver registered -Key type id_legacy registered -nfs4filelayout_init: NFSv4 File Layout Driver Registering... -io scheduler noop registered -io scheduler cfq registered (default) -io scheduler mq-deadline registered -io scheduler kyber registered -Console: switching to colour frame buffer device 40x30 -Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled -console [ttyS0] disabled -f0300000.serial: ttyS0 at MMIO 0xf0300020 (irq = 20, base_baud = 1228800) is a 16550A -console [ttyS0] enabled -console [ttyS0] enabled -bootconsole [early0] disabled -bootconsole [early0] disabled -loop: module loaded -tun: Universal TUN/TAP device driver, 1.6 -ftmac100: Loading version 0.2 ... -ftmac100 e0100000.mac eth0: irq 21, mapped at (ptrval) -ftmac100 e0100000.mac eth0: generated random MAC address 4e:fd:bd:f3:04:fc -ftsdc010 f0e00000.mmc: mmc0 - using hw SDIO IRQ -mmc0: new SDHC card at address d555 -ftssp010 card registered! -mmcblk0: mmc0:d555 SD04G 3.79 GiB -NET: Registered protocol family 10 - mmcblk0: p1 -Segment Routing with IPv6 -sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver -NET: Registered protocol family 17 -NET: Registered protocol family 15 -ALSA device list: - #0: ftssp_ac97 controller -Freeing unused kernel memory: 13520K -This architecture does not have kernel memory protection. -Sysinit starting -Sat Apr 6 23:33:53 CST 2019 -nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... + U-Boot SPL 2020.01-rc1-00292-g67a3313-dirty (Nov 14 2019 - 11:26:21 +0800) + Trying to boot from RAM + + OpenSBI v0.5-1-gdd8ef28 (Nov 14 2019 11:08:39) + ____ _____ ____ _____ + / __ \ / ____| _ _ _| + | | | |_ __ ___ _ __ | (___ | |_) || | + | | | | '_ \ / _ \ '_ \ ___ | _ < | | + | |__| | |_) | __/ | | |____) | |_) || |_ + ____/| .__/ ___|_| |_|_____/|____/_____| + | | + |_| + + Platform Name : Andes AE350 + Platform HART Features : RV64ACIMSUX + Platform Max HARTs : 4 + Current Hart : 0 + Firmware Base : 0x0 + Firmware Size : 84 KB + Runtime SBI Version : 0.2 + + PMP0: 0x0000000000000000-0x000000000001ffff (A) + PMP1: 0x0000000000000000-0x00000001ffffffff (A,R,W,X) + + + U-Boot 2020.01-rc1-00292-g67a3313-dirty (Nov 14 2019 - 11:26:21 +0800) + + DRAM: 1 GiB + Flash: 64 MiB + MMC: mmc@f0e00000: 0 + Loading Environment from SPI Flash... SF: Detected mx25u1635e with page size 256 Bytes, erase size 4 KiB, total 2 MiB + OK + In: serial@f0300000 + Out: serial@f0300000 + Err: serial@f0300000 + Net: no alias for ethernet0 + + Warning: mac@e0100000 (eth0) using random MAC address - a2:ae:93:7b:cc:8f + eth0: mac@e0100000 + Hit any key to stop autoboot: 0 + 6455 bytes read in 31 ms (203.1 KiB/s) + 20421684 bytes read in 8647 ms (2.3 MiB/s) + ## Booting kernel from Legacy Image at 00600000 ... + Image Name: + Image Type: RISC-V Linux Kernel Image (uncompressed) + Data Size: 20421620 Bytes = 19.5 MiB + Load Address: 00200000 + Entry Point: 00200000 + Verifying Checksum ... OK + ## Flattened Device Tree blob at 20000000 + Booting using the fdt blob at 0x20000000 + Loading Kernel Image + Loading Device Tree to 000000001effb000, end 000000001efff936 ... OK + + Starting kernel ... + + OF: fdt: Ignoring memory range 0x0 - 0x200000 + Linux version 4.17.0-00253-g49136e10bcb2 (sqa@atcsqa07) (gcc version 7.3.0 (2019-04-06_nds64le-linux-glibc-v5_experimental)) #1 SMP PREEMPT Sat Apr 6 23:41:49 CST 2019 + bootconsole [early0] enabled + Initial ramdisk at: 0x (ptrval) (13665712 bytes) + Zone ranges: + DMA32 [mem 0x0000000000200000-0x000000003fffffff] + Normal empty + Movable zone start for each node + Early memory node ranges + node 0: [mem 0x0000000000200000-0x000000003fffffff] + Initmem setup node 0 [mem 0x0000000000200000-0x000000003fffffff] + software IO TLB [mem 0x3b1f8000-0x3f1f8000] (64MB) mapped at [ (ptrval)- (ptrval)] + elf_platform is rv64i2p0m2p0a2p0c2p0xv5-0p0 + compatible privileged spec version 1.10 + percpu: Embedded 16 pages/cpu @ (ptrval) s28184 r8192 d29160 u65536 + Built 1 zonelists, mobility grouping on. Total pages: 258055 + Kernel command line: console=ttyS0,38400n8 debug loglevel=7 + log_buf_len individual max cpu contribution: 4096 bytes + log_buf_len total cpu_extra contributions: 12288 bytes + log_buf_len min size: 16384 bytes + log_buf_len: 32768 bytes + early log buf free: 14608(89%) + Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes) + Inode-cache hash table entries: 65536 (order: 7, 524288 bytes) + Sorting __ex_table... + Memory: 944428K/1046528K available (3979K kernel code, 246K rwdata, 1490K rodata, 13523K init, 688K bss, 102100K reserved, 0K cma-reserved) + SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 + Preemptible hierarchical RCU implementation. + Tasks RCU enabled. + NR_IRQS: 72, nr_irqs: 72, preallocated irqs: 0 + riscv,cpu_intc,0: 64 local interrupts mapped + riscv,cpu_intc,1: 64 local interrupts mapped + riscv,cpu_intc,2: 64 local interrupts mapped + riscv,cpu_intc,3: 64 local interrupts mapped + riscv,plic0,e4000000: mapped 71 interrupts to 8/8 handlers + clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x1bacf917bf, max_idle_ns: 881590412290 ns + sched_clock: 64 bits at 60MHz, resolution 16ns, wraps every 4398046511098ns + Console: colour dummy device 40x30 + Calibrating delay loop (skipped), value calculated using timer frequency.. 120.00 BogoMIPS (lpj=600000) + pid_max: default: 32768 minimum: 301 + Mount-cache hash table entries: 2048 (order: 2, 16384 bytes) + Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes) + Hierarchical SRCU implementation. + smp: Bringing up secondary CPUs ... + CPU0: online + CPU2: online + CPU3: online + smp: Brought up 1 node, 4 CPUs + devtmpfs: initialized + random: get_random_u32 called from bucket_table_alloc+0x198/0x1d8 with crng_init=0 + clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns + futex hash table entries: 1024 (order: 4, 65536 bytes) + NET: Registered protocol family 16 + Advanced Linux Sound Architecture Driver Initialized. + clocksource: Switched to clocksource riscv_clocksource + NET: Registered protocol family 2 + tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes) + TCP established hash table entries: 8192 (order: 4, 65536 bytes) + TCP bind hash table entries: 8192 (order: 5, 131072 bytes) + TCP: Hash tables configured (established 8192 bind 8192) + UDP hash table entries: 512 (order: 2, 16384 bytes) + UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) + NET: Registered protocol family 1 + RPC: Registered named UNIX socket transport module. + RPC: Registered udp transport module. + RPC: Registered tcp transport module. + RPC: Registered tcp NFSv4.1 backchannel transport module. + Unpacking initramfs... + workingset: timestamp_bits=62 max_order=18 bucket_order=0 + NFS: Registering the id_resolver key type + Key type id_resolver registered + Key type id_legacy registered + nfs4filelayout_init: NFSv4 File Layout Driver Registering... + io scheduler noop registered + io scheduler cfq registered (default) + io scheduler mq-deadline registered + io scheduler kyber registered + Console: switching to colour frame buffer device 40x30 + Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled + console [ttyS0] disabled + f0300000.serial: ttyS0 at MMIO 0xf0300020 (irq = 20, base_baud = 1228800) is a 16550A + console [ttyS0] enabled + console [ttyS0] enabled + bootconsole [early0] disabled + bootconsole [early0] disabled + loop: module loaded + tun: Universal TUN/TAP device driver, 1.6 + ftmac100: Loading version 0.2 ... + ftmac100 e0100000.mac eth0: irq 21, mapped at (ptrval) + ftmac100 e0100000.mac eth0: generated random MAC address 4e:fd:bd:f3:04:fc + ftsdc010 f0e00000.mmc: mmc0 - using hw SDIO IRQ + mmc0: new SDHC card at address d555 + ftssp010 card registered! + mmcblk0: mmc0:d555 SD04G 3.79 GiB + NET: Registered protocol family 10 + mmcblk0: p1 + Segment Routing with IPv6 + sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver + NET: Registered protocol family 17 + NET: Registered protocol family 15 + ALSA device list: + #0: ftssp_ac97 controller + Freeing unused kernel memory: 13520K + This architecture does not have kernel memory protection. + Sysinit starting + Sat Apr 6 23:33:53 CST 2019 + nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
~ # -- 2.24.1
On Sat, Dec 28, 2019 at 12:21 AM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Reviewed-by: Jagan Teki jagan@amarulasolutions.com
On Sat, Dec 28, 2019 at 2:51 AM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Tested-by: Bin Meng bmeng.cn@gmail.com
Hello Rick,
I would like to implement a 'make htmldocs' test for Gitlab. This requires that we fix all problems first.
Please, consider merging this patch with your next pull-request.
Thanks. Best regards.
Heinrich
Hi Heinrich,
Hello Rick,
Thanks for making a 'make htmldocs' test for GitLab. Please make sure travis and Azure are updated too.
Regards, Bin
Bin Meng
Jagan Teki
