[U-Boot] [PATCH] image: android: Support boot image v1 and v2
In new versions of Android Boot Image next fields are added to the header (and corresponding payloads are added to the image itself): - v1: Recovery DTBO - v2: DTB
Account for these new fields in next functions: 1. android_image_get_end(): as v1 and v2 have new payloads in the image, the calculation of image end address should be extended correspondingly; this is used e.g. by "bootm" command when booting the kernel from Android Boot Image 2. android_print_contents(): new fields values in v1 and v2 should be printed; the result of this function can be seen e.g. in "iminfo" command
This commit doesn't add the means for working with new payloads in v1 and v2 images (it will be done in further commits), it only updates existing functions w.r.t. changes in boot image v1/v2.
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- common/image-android.c | 44 +++++++++++++++++++++++++++++++----------- 1 file changed, 33 insertions(+), 11 deletions(-)
diff --git a/common/image-android.c b/common/image-android.c index 264bf90007..3564a64221 100644 --- a/common/image-android.c +++ b/common/image-android.c @@ -120,6 +120,7 @@ int android_image_check_header(const struct andr_img_hdr *hdr) ulong android_image_get_end(const struct andr_img_hdr *hdr) { ulong end; + /* * The header takes a full page, the remaining components are aligned * on page boundary @@ -130,6 +131,12 @@ ulong android_image_get_end(const struct andr_img_hdr *hdr) end += ALIGN(hdr->ramdisk_size, hdr->page_size); end += ALIGN(hdr->second_size, hdr->page_size);
+ if (hdr->header_version >= 1) + end += ALIGN(hdr->recovery_dtbo_size, hdr->page_size); + + if (hdr->header_version >= 2) + end += ALIGN(hdr->dtb_size, hdr->page_size); + return end; }
@@ -207,21 +214,36 @@ void android_print_contents(const struct andr_img_hdr *hdr) u32 os_ver = hdr->os_version >> 11; u32 os_lvl = hdr->os_version & ((1U << 11) - 1);
- printf("%skernel size: %x\n", p, hdr->kernel_size); - printf("%skernel address: %x\n", p, hdr->kernel_addr); - printf("%sramdisk size: %x\n", p, hdr->ramdisk_size); - printf("%sramdisk address: %x\n", p, hdr->ramdisk_addr); - printf("%ssecond size: %x\n", p, hdr->second_size); - printf("%ssecond address: %x\n", p, hdr->second_addr); - printf("%stags address: %x\n", p, hdr->tags_addr); - printf("%spage size: %x\n", p, hdr->page_size); + printf("%skernel size: %x\n", p, hdr->kernel_size); + printf("%skernel address: %x\n", p, hdr->kernel_addr); + printf("%sramdisk size: %x\n", p, hdr->ramdisk_size); + printf("%sramdisk address: %x\n", p, hdr->ramdisk_addr); + printf("%ssecond size: %x\n", p, hdr->second_size); + printf("%ssecond address: %x\n", p, hdr->second_addr); + printf("%stags address: %x\n", p, hdr->tags_addr); + printf("%spage size: %x\n", p, hdr->page_size); /* ver = A << 14 | B << 7 | C (7 bits for each of A, B, C) * lvl = ((Y - 2000) & 127) << 4 | M (7 bits for Y, 4 bits for M) */ - printf("%sos_version: %x (ver: %u.%u.%u, level: %u.%u)\n", + printf("%sos_version: %x (ver: %u.%u.%u, level: %u.%u)\n", p, hdr->os_version, (os_ver >> 7) & 0x7F, (os_ver >> 14) & 0x7F, os_ver & 0x7F, (os_lvl >> 4) + 2000, os_lvl & 0x0F); - printf("%sname: %s\n", p, hdr->name); - printf("%scmdline: %s\n", p, hdr->cmdline); + printf("%sname: %s\n", p, hdr->name); + printf("%scmdline: %s\n", p, hdr->cmdline); + printf("%sheader_version: %d\n", p, hdr->header_version); + + if (hdr->header_version >= 1) { + printf("%srecovery dtbo size: %x\n", p, + hdr->recovery_dtbo_size); + printf("%srecovery dtbo offset: %llx\n", p, + hdr->recovery_dtbo_offset); + printf("%sheader size: %x\n", p, + hdr->header_size); + } + + if (hdr->header_version >= 2) { + printf("%sdtb size: %x\n", p, hdr->dtb_size); + printf("%sdtb addr: %llx\n", p, hdr->dtb_addr); + } } #endif
- v1: Recovery DTBO
- v2: DTB
- android_image_get_end(): as v1 and v2 have new payloads in the image, the calculation of image end address should be extended correspondingly; this is used e.g. by "bootm" command when booting the kernel from Android Boot Image
- android_print_contents(): new fields values in v1 and v2 should be printed; the result of this function can be seen e.g. in "iminfo" command
Sam Protsenko
