Re: ZynqMP boot: no messages from SPL other than "Debug uart enabled"
Hi Michal,
Sorry I misunderstood your message, and I didn't spot the attached files. Now I booted with those two files, there's no output on the UARTs whatsoever. Is there anything else I can try?
Cheers,
András
On 30/04/2020 12:33, Michal Simek wrote:
On 30. 04. 20 12:19, Major A wrote:
Hi Michal,
can you please try these files in SD boot mode?
Done, here are two logs, both in SD boot mode.
First, log.sd is with SD card inserted (with the image files that apparently refuse to work other than the early UART message).
The other file, log.no-sd, is with no card inserted.
we don't understand each other. I sent you boot.bin and image.itb. Just copy them to SD card, switch board to sd boot mode and power it up.
Thanks, Michal
hi,
that's quite weird. Did you try any petalinux bsp and boot petalinux boot.bin on that board to make sure that board is fine?
M
On 30. 04. 20 13:01, Major A wrote:
Hi Michal,
Cheers,
András
Hi Michal,
Thanks, Michal
Hi Michal,
Yes, I did. The Petalinux image from here:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841937/Zynq+UltraSca...
works fine.
Cheers,
András
On 30/04/2020 13:03, Michal Simek wrote:
hi,
M
Hi Michal,
Cheers,
András
Hi Michal,
Thanks, Michal
Major A
Michal Simek
