[U-Boot] [PATCH v2 1/2] ARM: IGEP0033: rename config file to am335x_igep0033.h
There seems to be a naming convention for the configuration files for boards using the same SoC family. This makes easier to do changes that affect different boards based on the same SoC.
Since the IGEP COM AQUILA use a TI AM335x processor is better to rename its board config to use this naming scheme.
Signed-off-by: Javier Martinez Canillas javier.martinez@collabora.co.uk ---
Changes since v1: - Fix some issues in the commit changelog pointed out by Enric Balletbo.
boards.cfg | 2 +- include/configs/am335x_igep0033.h | 291 ++++++++++++++++++++++++++++++++++++++ include/configs/igep0033.h | 291 -------------------------------------- 3 files changed, 292 insertions(+), 292 deletions(-) create mode 100644 include/configs/am335x_igep0033.h delete mode 100644 include/configs/igep0033.h
diff --git a/boards.cfg b/boards.cfg index 7ccc7ce..d717226 100644 --- a/boards.cfg +++ b/boards.cfg @@ -302,7 +302,7 @@ igep0020_nand arm armv7 igep00x0 isee igep0030 arm armv7 igep00x0 isee omap3 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_ONENAND igep0030_nand arm armv7 igep00x0 isee omap3 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_NAND igep0032 arm armv7 igep00x0 isee omap3 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0032,BOOT_ONENAND -igep0033 arm armv7 igep0033 isee am33xx +am335x_igep0033 arm armv7 igep0033 isee am33xx am3517_evm arm armv7 am3517evm logicpd omap3 mt_ventoux arm armv7 mt_ventoux teejet omap3 omap3_zoom1 arm armv7 zoom1 logicpd omap3 diff --git a/include/configs/am335x_igep0033.h b/include/configs/am335x_igep0033.h new file mode 100644 index 0000000..e08fc14 --- /dev/null +++ b/include/configs/am335x_igep0033.h @@ -0,0 +1,291 @@ +/* + * Copyright (C) 2013, ISEE 2007 SL - http://www.isee.biz/ + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation version 2. + * + * This program is distributed "as is" WITHOUT ANY WARRANTY of any + * kind, whether express or implied; without even the implied warranty + * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef __CONFIG_IGEP0033_H +#define __CONFIG_IGEP0033_H + +#define CONFIG_AM33XX +#define CONFIG_OMAP +#define CONFIG_OMAP_COMMON + +#include <asm/arch/omap.h> + +/* Mach type */ +#define MACH_TYPE_IGEP0033 4521 /* Until the next sync */ +#define CONFIG_MACH_TYPE MACH_TYPE_IGEP0033 + +/* Clock defines */ +#define V_OSCK 24000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK) + +#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ +#define CONFIG_SYS_MALLOC_LEN (1024 << 10) +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT "U-Boot# " +#define CONFIG_SYS_NO_FLASH + +/* Display cpuinfo */ +#define CONFIG_DISPLAY_CPUINFO + +/* Flattened Device Tree */ +#define CONFIG_OF_LIBFDT + +/* Commands to include */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_BOOTZ +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ECHO +#define CONFIG_CMD_EXT4 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_FS_GENERIC +#define CONFIG_CMD_MMC +#define CONFIG_CMD_MTDPARTS +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NET +#define CONFIG_CMD_PING +#define CONFIG_CMD_UBI +#define CONFIG_CMD_UBIFS + +/* Make the verbose messages from UBI stop printing */ +#define CONFIG_UBI_SILENCE_MSG +#define CONFIG_UBIFS_SILENCE_MSG + +#define CONFIG_BOOTDELAY 1 /* negative for no autoboot */ +#define CONFIG_ENV_VARS_UBOOT_CONFIG +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x80F80000\0" \ + "dtbaddr=0x80200000\0" \ + "bootdir=/boot\0" \ + "bootfile=zImage\0" \ + "dtbfile=am335x-base0033.dtb\0" \ + "console=ttyO0,115200n8\0" \ + "mtdids=" MTDIDS_DEFAULT "\0" \ + "mtdparts=" MTDPARTS_DEFAULT "\0" \ + "mmcdev=0\0" \ + "mmcroot=/dev/mmcblk0p2 rw\0" \ + "ubiroot=ubi0:filesystem rw ubi.mtd=3,2048\0" \ + "mmcrootfstype=ext4 rootwait\0" \ + "ubirootfstype=ubifs rootwait\0" \ + "mmcargs=setenv bootargs console=${console} " \ + "root=${mmcroot} " \ + "rootfstype=${mmcrootfstype}\0" \ + "ubiargs=setenv bootargs console=${console} " \ + "root=${ubiroot} " \ + "rootfstype=${ubirootfstype}\0" \ + "bootenv=uEnv.txt\0" \ + "loadbootenv=load mmc ${mmcdev} ${loadaddr} ${bootenv}\0" \ + "importbootenv=echo Importing environment from mmc ...; " \ + "env import -t ${loadaddr} ${filesize}\0" \ + "mmcload=load mmc ${mmcdev}:2 ${loadaddr} ${bootdir}/${bootfile}; " \ + "load mmc ${mmcdev}:2 ${dtbaddr} ${bootdir}/${dtbfile}\0" \ + "ubiload=ubi part filesystem 2048; ubifsmount ubi0; " \ + "ubifsload ${loadaddr} ${bootdir}/${bootfile}; " \ + "ubifsload ${dtbaddr} ${bootdir}/${dtbfile} \0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "bootz ${loadaddr} - ${dtbaddr}\0" \ + "ubiboot=echo Booting from nand (ubifs) ...; " \ + "run ubiargs; run ubiload; " \ + "bootz ${loadaddr} - ${dtbaddr}\0" \ + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "echo SD/MMC found on device ${mmcdev};" \ + "if run loadbootenv; then " \ + "echo Loaded environment from ${bootenv};" \ + "run importbootenv;" \ + "fi;" \ + "if test -n $uenvcmd; then " \ + "echo Running uenvcmd ...;" \ + "run uenvcmd;" \ + "fi;" \ + "if run mmcload; then " \ + "run mmcboot;" \ + "fi;" \ + "else " \ + "run ubiboot;" \ + "fi;" \ + +/* Max number of command args */ +#define CONFIG_SYS_MAXARGS 16 + +/* Console I/O Buffer Size */ +#define CONFIG_SYS_CBSIZE 512 + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE \ + + sizeof(CONFIG_SYS_PROMPT) + 16) + +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_LOAD_ADDR 0x81000000 /* Default load address */ + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ +#define CONFIG_MAX_RAM_BANK_SIZE (1024 << 20) /* 1GB */ + +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +#define CONFIG_SYS_INIT_SP_ADDR (NON_SECURE_SRAM_END - \ + GENERATED_GBL_DATA_SIZE) +/* Platform/Board specific defs */ +#define CONFIG_SYS_TIMERBASE 0x48040000 /* Use Timer2 */ +#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ +#define CONFIG_SYS_HZ 1000 /* 1ms clock */ + +/* NS16550 Configuration */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK (48000000) +#define CONFIG_SYS_NS16550_COM1 0x44e09000 /* UART0 */ + +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 + +/* CPU */ +#define CONFIG_ARCH_CPU_INIT + +#define CONFIG_ENV_OVERWRITE 1 +#define CONFIG_SYS_CONSOLE_INFO_QUIET + +/* MMC support */ +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_OMAP_HSMMC +#define CONFIG_DOS_PARTITION + +/* GPIO support */ +#define CONFIG_OMAP_GPIO + +/* Ethernet support */ +#define CONFIG_DRIVER_TI_CPSW +#define CONFIG_MII +#define CONFIG_BOOTP_DEFAULT +#define CONFIG_BOOTP_DNS +#define CONFIG_BOOTP_DNS2 +#define CONFIG_BOOTP_SEND_HOSTNAME +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_SUBNETMASK +#define CONFIG_NET_RETRY_COUNT 10 +#define CONFIG_NET_MULTI +#define CONFIG_PHYLIB +#define CONFIG_PHY_ADDR 0 +#define CONFIG_PHY_SMSC + +/* NAND support */ +#define CONFIG_NAND +#define CONFIG_NAND_OMAP_GPMC +#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 +#define CONFIG_SYS_NAND_BASE (0x08000000) /* phys address CS0 */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_ONFI_DETECTION 1 +#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ +#define CONFIG_SYS_REDUNDAND_ENVIRONMENT +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET 0x180000 /* environment starts here */ +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_OFFSET + CONFIG_SYS_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) + +#define CONFIG_MTD_PARTITIONS +#define CONFIG_MTD_DEVICE +#define CONFIG_RBTREE +#define CONFIG_LZO + +#define MTDIDS_DEFAULT "nand0=omap2-nand.0" +#define MTDPARTS_DEFAULT "mtdparts=omap2-nand.0:512k(spl),"\ + "1m(uboot),256k(environment),"\ + "-(filesystem)" + +/* Unsupported features */ +#undef CONFIG_USE_IRQ + +/* Defines for SPL */ +#define CONFIG_SPL +#define CONFIG_SPL_FRAMEWORK +/* + * Place the image at the start of the ROM defined image space. + * We limit our size to the ROM-defined downloaded image area, and use the + * rest of the space for stack. + */ +#define CONFIG_SPL_TEXT_BASE 0x402F0400 +#define CONFIG_SPL_MAX_SIZE (0x4030C000 - CONFIG_SPL_TEXT_BASE) +#define CONFIG_SPL_STACK CONFIG_SYS_INIT_SP_ADDR + +#define CONFIG_SPL_BSS_START_ADDR 0x80000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ + +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ +#define CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION 1 +#define CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME "u-boot.img" +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SPL_FAT_SUPPORT +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBDISK_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_GPIO_SUPPORT +#define CONFIG_SPL_YMODEM_SUPPORT +#define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/am33xx/u-boot-spl.lds" + +#define CONFIG_SPL_BOARD_INIT +#define CONFIG_SPL_NAND_AM33XX_BCH +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_NAND_BASE +#define CONFIG_SPL_NAND_DRIVERS +#define CONFIG_SPL_NAND_ECC +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ + CONFIG_SYS_NAND_PAGE_SIZE) +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) +#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS +#define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ + 10, 11, 12, 13, 14, 15, 16, 17, \ + 18, 19, 20, 21, 22, 23, 24, 25, \ + 26, 27, 28, 29, 30, 31, 32, 33, \ + 34, 35, 36, 37, 38, 39, 40, 41, \ + 42, 43, 44, 45, 46, 47, 48, 49, \ + 50, 51, 52, 53, 54, 55, 56, 57, } + +#define CONFIG_SYS_NAND_ECCSIZE 512 +#define CONFIG_SYS_NAND_ECCBYTES 14 + +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE + +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 + +/* + * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM + * 64 bytes before this address should be set aside for u-boot.img's + * header. That is 0x800FFFC0--0x80100000 should not be used for any + * other needs. + */ +#define CONFIG_SYS_TEXT_BASE 0x80800000 +#define CONFIG_SYS_SPL_MALLOC_START 0x80208000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 + +/* + * Since SPL did pll and ddr initialization for us, + * we don't need to do it twice. + */ +#ifndef CONFIG_SPL_BUILD +#define CONFIG_SKIP_LOWLEVEL_INIT +#endif + +#endif /* ! __CONFIG_IGEP0033_H */ diff --git a/include/configs/igep0033.h b/include/configs/igep0033.h deleted file mode 100644 index e08fc14..0000000 --- a/include/configs/igep0033.h +++ /dev/null @@ -1,291 +0,0 @@ -/* - * Copyright (C) 2013, ISEE 2007 SL - http://www.isee.biz/ - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation version 2. - * - * This program is distributed "as is" WITHOUT ANY WARRANTY of any - * kind, whether express or implied; without even the implied warranty - * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#ifndef __CONFIG_IGEP0033_H -#define __CONFIG_IGEP0033_H - -#define CONFIG_AM33XX -#define CONFIG_OMAP -#define CONFIG_OMAP_COMMON - -#include <asm/arch/omap.h> - -/* Mach type */ -#define MACH_TYPE_IGEP0033 4521 /* Until the next sync */ -#define CONFIG_MACH_TYPE MACH_TYPE_IGEP0033 - -/* Clock defines */ -#define V_OSCK 24000000 /* Clock output from T2 */ -#define V_SCLK (V_OSCK) - -#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ -#define CONFIG_SYS_MALLOC_LEN (1024 << 10) -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "U-Boot# " -#define CONFIG_SYS_NO_FLASH - -/* Display cpuinfo */ -#define CONFIG_DISPLAY_CPUINFO - -/* Flattened Device Tree */ -#define CONFIG_OF_LIBFDT - -/* Commands to include */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_ECHO -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_MMC -#define CONFIG_CMD_MTDPARTS -#define CONFIG_CMD_NAND -#define CONFIG_CMD_NET -#define CONFIG_CMD_PING -#define CONFIG_CMD_UBI -#define CONFIG_CMD_UBIFS - -/* Make the verbose messages from UBI stop printing */ -#define CONFIG_UBI_SILENCE_MSG -#define CONFIG_UBIFS_SILENCE_MSG - -#define CONFIG_BOOTDELAY 1 /* negative for no autoboot */ -#define CONFIG_ENV_VARS_UBOOT_CONFIG -#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG -#define CONFIG_EXTRA_ENV_SETTINGS \ - "loadaddr=0x80F80000\0" \ - "dtbaddr=0x80200000\0" \ - "bootdir=/boot\0" \ - "bootfile=zImage\0" \ - "dtbfile=am335x-base0033.dtb\0" \ - "console=ttyO0,115200n8\0" \ - "mtdids=" MTDIDS_DEFAULT "\0" \ - "mtdparts=" MTDPARTS_DEFAULT "\0" \ - "mmcdev=0\0" \ - "mmcroot=/dev/mmcblk0p2 rw\0" \ - "ubiroot=ubi0:filesystem rw ubi.mtd=3,2048\0" \ - "mmcrootfstype=ext4 rootwait\0" \ - "ubirootfstype=ubifs rootwait\0" \ - "mmcargs=setenv bootargs console=${console} " \ - "root=${mmcroot} " \ - "rootfstype=${mmcrootfstype}\0" \ - "ubiargs=setenv bootargs console=${console} " \ - "root=${ubiroot} " \ - "rootfstype=${ubirootfstype}\0" \ - "bootenv=uEnv.txt\0" \ - "loadbootenv=load mmc ${mmcdev} ${loadaddr} ${bootenv}\0" \ - "importbootenv=echo Importing environment from mmc ...; " \ - "env import -t ${loadaddr} ${filesize}\0" \ - "mmcload=load mmc ${mmcdev}:2 ${loadaddr} ${bootdir}/${bootfile}; " \ - "load mmc ${mmcdev}:2 ${dtbaddr} ${bootdir}/${dtbfile}\0" \ - "ubiload=ubi part filesystem 2048; ubifsmount ubi0; " \ - "ubifsload ${loadaddr} ${bootdir}/${bootfile}; " \ - "ubifsload ${dtbaddr} ${bootdir}/${dtbfile} \0" \ - "mmcboot=echo Booting from mmc ...; " \ - "run mmcargs; " \ - "bootz ${loadaddr} - ${dtbaddr}\0" \ - "ubiboot=echo Booting from nand (ubifs) ...; " \ - "run ubiargs; run ubiload; " \ - "bootz ${loadaddr} - ${dtbaddr}\0" \ - -#define CONFIG_BOOTCOMMAND \ - "mmc dev ${mmcdev}; if mmc rescan; then " \ - "echo SD/MMC found on device ${mmcdev};" \ - "if run loadbootenv; then " \ - "echo Loaded environment from ${bootenv};" \ - "run importbootenv;" \ - "fi;" \ - "if test -n $uenvcmd; then " \ - "echo Running uenvcmd ...;" \ - "run uenvcmd;" \ - "fi;" \ - "if run mmcload; then " \ - "run mmcboot;" \ - "fi;" \ - "else " \ - "run ubiboot;" \ - "fi;" \ - -/* Max number of command args */ -#define CONFIG_SYS_MAXARGS 16 - -/* Console I/O Buffer Size */ -#define CONFIG_SYS_CBSIZE 512 - -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE \ - + sizeof(CONFIG_SYS_PROMPT) + 16) - -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE -#define CONFIG_SYS_LOAD_ADDR 0x81000000 /* Default load address */ - -/* Physical Memory Map */ -#define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ -#define CONFIG_MAX_RAM_BANK_SIZE (1024 << 20) /* 1GB */ - -#define CONFIG_SYS_SDRAM_BASE 0x80000000 -#define CONFIG_SYS_INIT_SP_ADDR (NON_SECURE_SRAM_END - \ - GENERATED_GBL_DATA_SIZE) -/* Platform/Board specific defs */ -#define CONFIG_SYS_TIMERBASE 0x48040000 /* Use Timer2 */ -#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ -#define CONFIG_SYS_HZ 1000 /* 1ms clock */ - -/* NS16550 Configuration */ -#define CONFIG_SYS_NS16550 -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE (-4) -#define CONFIG_SYS_NS16550_CLK (48000000) -#define CONFIG_SYS_NS16550_COM1 0x44e09000 /* UART0 */ - -#define CONFIG_CONS_INDEX 1 -#define CONFIG_BAUDRATE 115200 - -/* CPU */ -#define CONFIG_ARCH_CPU_INIT - -#define CONFIG_ENV_OVERWRITE 1 -#define CONFIG_SYS_CONSOLE_INFO_QUIET - -/* MMC support */ -#define CONFIG_MMC -#define CONFIG_GENERIC_MMC -#define CONFIG_OMAP_HSMMC -#define CONFIG_DOS_PARTITION - -/* GPIO support */ -#define CONFIG_OMAP_GPIO - -/* Ethernet support */ -#define CONFIG_DRIVER_TI_CPSW -#define CONFIG_MII -#define CONFIG_BOOTP_DEFAULT -#define CONFIG_BOOTP_DNS -#define CONFIG_BOOTP_DNS2 -#define CONFIG_BOOTP_SEND_HOSTNAME -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_NET_RETRY_COUNT 10 -#define CONFIG_NET_MULTI -#define CONFIG_PHYLIB -#define CONFIG_PHY_ADDR 0 -#define CONFIG_PHY_SMSC - -/* NAND support */ -#define CONFIG_NAND -#define CONFIG_NAND_OMAP_GPMC -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 -#define CONFIG_SYS_NAND_BASE (0x08000000) /* phys address CS0 */ -#define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_ONFI_DETECTION 1 -#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT -#define CONFIG_ENV_IS_IN_NAND -#define CONFIG_ENV_OFFSET 0x180000 /* environment starts here */ -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_OFFSET + CONFIG_SYS_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) - -#define CONFIG_MTD_PARTITIONS -#define CONFIG_MTD_DEVICE -#define CONFIG_RBTREE -#define CONFIG_LZO - -#define MTDIDS_DEFAULT "nand0=omap2-nand.0" -#define MTDPARTS_DEFAULT "mtdparts=omap2-nand.0:512k(spl),"\ - "1m(uboot),256k(environment),"\ - "-(filesystem)" - -/* Unsupported features */ -#undef CONFIG_USE_IRQ - -/* Defines for SPL */ -#define CONFIG_SPL -#define CONFIG_SPL_FRAMEWORK -/* - * Place the image at the start of the ROM defined image space. - * We limit our size to the ROM-defined downloaded image area, and use the - * rest of the space for stack. - */ -#define CONFIG_SPL_TEXT_BASE 0x402F0400 -#define CONFIG_SPL_MAX_SIZE (0x4030C000 - CONFIG_SPL_TEXT_BASE) -#define CONFIG_SPL_STACK CONFIG_SYS_INIT_SP_ADDR - -#define CONFIG_SPL_BSS_START_ADDR 0x80000000 -#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ - -#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ -#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ -#define CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION 1 -#define CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME "u-boot.img" -#define CONFIG_SPL_MMC_SUPPORT -#define CONFIG_SPL_FAT_SUPPORT -#define CONFIG_SPL_LIBCOMMON_SUPPORT -#define CONFIG_SPL_LIBDISK_SUPPORT -#define CONFIG_SPL_LIBGENERIC_SUPPORT -#define CONFIG_SPL_SERIAL_SUPPORT -#define CONFIG_SPL_GPIO_SUPPORT -#define CONFIG_SPL_YMODEM_SUPPORT -#define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/am33xx/u-boot-spl.lds" - -#define CONFIG_SPL_BOARD_INIT -#define CONFIG_SPL_NAND_AM33XX_BCH -#define CONFIG_SPL_NAND_SUPPORT -#define CONFIG_SPL_NAND_BASE -#define CONFIG_SPL_NAND_DRIVERS -#define CONFIG_SPL_NAND_ECC -#define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ - CONFIG_SYS_NAND_PAGE_SIZE) -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS -#define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ - 10, 11, 12, 13, 14, 15, 16, 17, \ - 18, 19, 20, 21, 22, 23, 24, 25, \ - 26, 27, 28, 29, 30, 31, 32, 33, \ - 34, 35, 36, 37, 38, 39, 40, 41, \ - 42, 43, 44, 45, 46, 47, 48, 49, \ - 50, 51, 52, 53, 54, 55, 56, 57, } - -#define CONFIG_SYS_NAND_ECCSIZE 512 -#define CONFIG_SYS_NAND_ECCBYTES 14 - -#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE - -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 - -/* - * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM - * 64 bytes before this address should be set aside for u-boot.img's - * header. That is 0x800FFFC0--0x80100000 should not be used for any - * other needs. - */ -#define CONFIG_SYS_TEXT_BASE 0x80800000 -#define CONFIG_SYS_SPL_MALLOC_START 0x80208000 -#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 - -/* - * Since SPL did pll and ddr initialization for us, - * we don't need to do it twice. - */ -#ifndef CONFIG_SPL_BUILD -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif - -#endif /* ! __CONFIG_IGEP0033_H */
Since the IGEPv2 board and the IGEP COM Module use a TI OMAP35xx/DM37xx processor, is better to rename its board config to use this naming scheme.
boards.cfg | 10 +- include/configs/igep00x0.h | 370 --------------------------------------- include/configs/omap3_igep00x0.h | 370 +++++++++++++++++++++++++++++++++++++++ 3 files changed, 375 insertions(+), 375 deletions(-) delete mode 100644 include/configs/igep00x0.h create mode 100644 include/configs/omap3_igep00x0.h
diff --git a/boards.cfg b/boards.cfg index d717226..8f1cb6e 100644 --- a/boards.cfg +++ b/boards.cfg @@ -297,11 +297,11 @@ omap3_overo arm armv7 overo - omap3_pandora arm armv7 pandora - omap3 dig297 arm armv7 dig297 comelit omap3 cm_t35 arm armv7 cm_t35 compulab omap3 -igep0020 arm armv7 igep00x0 isee omap3 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0020,BOOT_ONENAND -igep0020_nand arm armv7 igep00x0 isee omap3 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0020,BOOT_NAND -igep0030 arm armv7 igep00x0 isee omap3 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_ONENAND -igep0030_nand arm armv7 igep00x0 isee omap3 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_NAND -igep0032 arm armv7 igep00x0 isee omap3 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0032,BOOT_ONENAND +omap3_igep0020 arm armv7 igep00x0 isee omap3 omap3_igep00x0:MACH_TYPE=MACH_TYPE_IGEP0020,BOOT_ONENAND +omap3_igep0020_nand arm armv7 igep00x0 isee omap3 omap3_igep00x0:MACH_TYPE=MACH_TYPE_IGEP0020,BOOT_NAND +omap3_igep0030 arm armv7 igep00x0 isee omap3 omap3_igep00x0:MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_ONENAND +omap3_igep0030_nand arm armv7 igep00x0 isee omap3 omap3_igep00x0:MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_NAND +omap3_igep0032 arm armv7 igep00x0 isee omap3 omap3_igep00x0:MACH_TYPE=MACH_TYPE_IGEP0032,BOOT_ONENAND am335x_igep0033 arm armv7 igep0033 isee am33xx am3517_evm arm armv7 am3517evm logicpd omap3 mt_ventoux arm armv7 mt_ventoux teejet omap3 diff --git a/include/configs/igep00x0.h b/include/configs/igep00x0.h deleted file mode 100644 index 9982cf6..0000000 --- a/include/configs/igep00x0.h +++ /dev/null @@ -1,370 +0,0 @@ -/* - * Common configuration settings for IGEP technology based boards - * - * (C) Copyright 2012 - * ISEE 2007 SL, <www.iseebcn.com> - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __IGEP00X0_H -#define __IGEP00X0_H - -#include <asm/sizes.h> - -/* - * High Level Configuration Options - */ -#define CONFIG_OMAP 1 /* in a TI OMAP core */ -#define CONFIG_OMAP34XX 1 /* which is a 34XX */ -#define CONFIG_OMAP_GPIO -#define CONFIG_OMAP_COMMON - -#define CONFIG_SDRC /* The chip has SDRC controller */ - -#include <asm/arch/cpu.h> -#include <asm/arch/omap3.h> -#include <asm/mach-types.h> - -/* - * Display CPU and Board information - */ -#define CONFIG_DISPLAY_CPUINFO 1 -#define CONFIG_DISPLAY_BOARDINFO 1 - -/* Clock Defines */ -#define V_OSCK 26000000 /* Clock output from T2 */ -#define V_SCLK (V_OSCK >> 1) - -#define CONFIG_MISC_INIT_R - -#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ -#define CONFIG_SETUP_MEMORY_TAGS 1 -#define CONFIG_INITRD_TAG 1 -#define CONFIG_REVISION_TAG 1 - -#define CONFIG_OF_LIBFDT -#define CONFIG_CMD_BOOTZ -#define CONFIG_SUPPORT_RAW_INITRD - -/* - * NS16550 Configuration - */ - -#define V_NS16550_CLK 48000000 /* 48MHz (APLL96/2) */ - -#define CONFIG_SYS_NS16550 -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE (-4) -#define CONFIG_SYS_NS16550_CLK V_NS16550_CLK - -/* select serial console configuration */ -#define CONFIG_CONS_INDEX 3 -#define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 -#define CONFIG_SERIAL3 3 - -/* allow to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE -#define CONFIG_BAUDRATE 115200 -#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600, \ - 115200} -#define CONFIG_GENERIC_MMC 1 -#define CONFIG_MMC 1 -#define CONFIG_OMAP_HSMMC 1 -#define CONFIG_DOS_PARTITION 1 - -/* define to enable boot progress via leds */ -#if (CONFIG_MACH_TYPE == MACH_TYPE_IGEP0020) || \ - (CONFIG_MACH_TYPE == MACH_TYPE_IGEP0030) -#define CONFIG_SHOW_BOOT_PROGRESS -#endif - -/* USB */ -#define CONFIG_MUSB_UDC 1 -#define CONFIG_USB_OMAP3 1 -#define CONFIG_TWL4030_USB 1 - -/* USB device configuration */ -#define CONFIG_USB_DEVICE 1 -#define CONFIG_USB_TTY 1 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 - -/* Change these to suit your needs */ -#define CONFIG_USBD_VENDORID 0x0451 -#define CONFIG_USBD_PRODUCTID 0x5678 -#define CONFIG_USBD_MANUFACTURER "Texas Instruments" -#define CONFIG_USBD_PRODUCT_NAME "IGEP" - -/* commands to include */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_FAT /* FAT support */ -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_I2C /* I2C serial bus support */ -#define CONFIG_CMD_MMC /* MMC support */ -#ifdef CONFIG_BOOT_ONENAND -#define CONFIG_CMD_ONENAND /* ONENAND support */ -#endif -#ifdef CONFIG_BOOT_NAND -#define CONFIG_CMD_NAND -#endif -#if (CONFIG_MACH_TYPE == MACH_TYPE_IGEP0020) || \ - (CONFIG_MACH_TYPE == MACH_TYPE_IGEP0032) -#define CONFIG_CMD_NET /* bootp, tftpboot, rarpboot */ -#endif -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PING -#define CONFIG_CMD_NFS /* NFS support */ -#define CONFIG_CMD_MTDPARTS /* Enable MTD parts commands */ -#define CONFIG_MTD_DEVICE - -#undef CONFIG_CMD_FLASH /* flinfo, erase, protect */ -#undef CONFIG_CMD_IMLS /* List all found images */ - -#define CONFIG_SYS_NO_FLASH -#define CONFIG_HARD_I2C 1 -#define CONFIG_SYS_I2C_SPEED 100000 -#define CONFIG_SYS_I2C_SLAVE 1 -#define CONFIG_DRIVER_OMAP34XX_I2C 1 - -/* - * TWL4030 - */ -#define CONFIG_TWL4030_POWER 1 - -#define CONFIG_BOOTDELAY 3 - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "usbtty=cdc_acm\0" \ - "loadaddr=0x82000000\0" \ - "dtbaddr=0x81600000\0" \ - "bootdir=/boot\0" \ - "bootfile=zImage\0" \ - "usbtty=cdc_acm\0" \ - "console=ttyO2,115200n8\0" \ - "mpurate=auto\0" \ - "vram=12M\0" \ - "dvimode=1024x768MR-16@60\0" \ - "defaultdisplay=dvi\0" \ - "mmcdev=0\0" \ - "mmcroot=/dev/mmcblk0p2 rw\0" \ - "mmcrootfstype=ext4 rootwait\0" \ - "nandroot=/dev/mtdblock4 rw\0" \ - "nandrootfstype=jffs2\0" \ - "mmcargs=setenv bootargs console=${console} " \ - "mpurate=${mpurate} " \ - "vram=${vram} " \ - "omapfb.mode=dvi:${dvimode} " \ - "omapfb.debug=y " \ - "omapdss.def_disp=${defaultdisplay} " \ - "root=${mmcroot} " \ - "rootfstype=${mmcrootfstype}\0" \ - "nandargs=setenv bootargs console=${console} " \ - "mpurate=${mpurate} " \ - "vram=${vram} " \ - "omapfb.mode=dvi:${dvimode} " \ - "omapfb.debug=y " \ - "omapdss.def_disp=${defaultdisplay} " \ - "root=${nandroot} " \ - "rootfstype=${nandrootfstype}\0" \ - "loadbootenv=load mmc ${mmcdev} ${loadaddr} uEnv.txt\0" \ - "importbootenv=echo Importing environment from mmc ...; " \ - "env import -t $loadaddr $filesize\0" \ - "loadzimage=load mmc ${mmcdev}:2 ${loadaddr} ${bootdir}/${bootfile}\0" \ - "loadfdt=load mmc ${mmcdev}:2 ${dtbaddr} ${bootdir}/${dtbfile}\0" \ - "mmcboot=echo Booting from mmc ...; " \ - "run mmcargs; " \ - "bootz ${loadaddr}\0" \ - "mmcbootfdt=echo Booting with DT from mmc ...; " \ - "bootz ${loadaddr} - ${dtbaddr}\0" \ - "nandboot=echo Booting from onenand ...; " \ - "run nandargs; " \ - "onenand read ${loadaddr} 280000 400000; " \ - "bootz ${loadaddr}\0" \ - -#define CONFIG_BOOTCOMMAND \ - "mmc dev ${mmcdev}; if mmc rescan; then " \ - "echo SD/MMC found on device ${mmcdev};" \ - "if run loadbootenv; then " \ - "run importbootenv;" \ - "fi;" \ - "if test -n $uenvcmd; then " \ - "echo Running uenvcmd ...;" \ - "run uenvcmd;" \ - "fi;" \ - "if run loadzimage; then " \ - "if test -n $dtbfile; then " \ - "if run loadfdt; then " \ - "run mmcbootfdt;" \ - "fi;" \ - "fi;" \ - "run mmcboot;" \ - "fi;" \ - "fi;" \ - "run nandboot;" \ - -#define CONFIG_AUTO_COMPLETE 1 - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "U-Boot # " -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ - sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE) - -#define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0) /* memtest */ - /* works on */ -#define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + \ - 0x01F00000) /* 31MB */ - -#define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0) /* default */ - /* load address */ - -#define CONFIG_SYS_MONITOR_LEN (256 << 10) - -/* - * OMAP3 has 12 GP timers, they can be driven by the system clock - * (12/13/16.8/19.2/38.4MHz) or by 32KHz clock. We use 13MHz (V_SCLK). - * This rate is divided by a local divisor. - */ -#define CONFIG_SYS_TIMERBASE (OMAP34XX_GPT2) -#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ -#define CONFIG_SYS_HZ 1000 - -/* - * Physical Memory Map - * - */ -#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ -#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 -#define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1 - -/* - * FLASH and environment organization - */ - -#ifdef CONFIG_BOOT_ONENAND -#define PISMO1_ONEN_SIZE GPMC_SIZE_128M /* Configure the PISMO */ - -#define CONFIG_SYS_ONENAND_BASE ONENAND_MAP - -#define ONENAND_ENV_OFFSET 0x260000 /* environment starts here */ - -#define CONFIG_ENV_IS_IN_ONENAND 1 -#define CONFIG_ENV_SIZE (512 << 10) /* Total Size Environment */ -#define CONFIG_ENV_ADDR ONENAND_ENV_OFFSET -#endif - -#ifdef CONFIG_BOOT_NAND -#define PISMO1_NAND_SIZE GPMC_SIZE_128M /* Configure the PISMO */ -#define CONFIG_NAND_OMAP_GPMC -#define CONFIG_SYS_NAND_BASE NAND_BASE -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 -#define CONFIG_ENV_OFFSET 0x260000 /* environment starts here */ -#define CONFIG_ENV_IS_IN_NAND 1 -#define CONFIG_ENV_SIZE (512 << 10) /* Total Size Environment */ -#define CONFIG_ENV_ADDR NAND_ENV_OFFSET -#define CONFIG_SYS_MAX_NAND_DEVICE 1 -#endif - -/* - * Size of malloc() pool - */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128 << 10)) - -/* - * SMSC911x Ethernet - */ -#if defined(CONFIG_CMD_NET) -#define CONFIG_SMC911X -#define CONFIG_SMC911X_32_BIT -#define CONFIG_SMC911X_BASE 0x2C000000 -#endif /* (CONFIG_CMD_NET) */ - -/* - * Leave it at 0x80008000 to allow booting new u-boot.bin with X-loader - * and older u-boot.bin with the new U-Boot SPL. - */ -#define CONFIG_SYS_TEXT_BASE 0x80008000 -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 -#define CONFIG_SYS_INIT_RAM_SIZE 0x800 -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_SIZE - \ - GENERATED_GBL_DATA_SIZE) - -/* SPL */ -#define CONFIG_SPL -#define CONFIG_SPL_FRAMEWORK -#define CONFIG_SPL_NAND_SIMPLE -#define CONFIG_SPL_TEXT_BASE 0x40200800 -#define CONFIG_SPL_MAX_SIZE (54 * 1024) -#define CONFIG_SPL_STACK LOW_LEVEL_SRAM_STACK - -/* move malloc and bss high to prevent clashing with the main image */ -#define CONFIG_SYS_SPL_MALLOC_START 0x87000000 -#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 -#define CONFIG_SPL_BSS_START_ADDR 0x87080000 /* end of minimum RAM */ -#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ - -/* MMC boot config */ -#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ -#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ -#define CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION 1 -#define CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME "u-boot.img" - -#define CONFIG_SPL_BOARD_INIT -#define CONFIG_SPL_LIBCOMMON_SUPPORT -#define CONFIG_SPL_LIBDISK_SUPPORT -#define CONFIG_SPL_I2C_SUPPORT -#define CONFIG_SPL_LIBGENERIC_SUPPORT -#define CONFIG_SPL_MMC_SUPPORT -#define CONFIG_SPL_FAT_SUPPORT -#define CONFIG_SPL_SERIAL_SUPPORT - -#define CONFIG_SPL_POWER_SUPPORT -#define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds" - -#ifdef CONFIG_BOOT_ONENAND -#define CONFIG_SPL_ONENAND_SUPPORT - -/* OneNAND boot config */ -#define CONFIG_SYS_ONENAND_U_BOOT_OFFS 0x80000 -#define CONFIG_SYS_ONENAND_PAGE_SIZE 2048 -#define CONFIG_SPL_ONENAND_LOAD_ADDR 0x80000 -#define CONFIG_SPL_ONENAND_LOAD_SIZE \ - (512 * 1024 - CONFIG_SPL_ONENAND_LOAD_ADDR) - -#endif - -#ifdef CONFIG_BOOT_NAND -#define CONFIG_SPL_NAND_SUPPORT -#define CONFIG_SPL_NAND_BASE -#define CONFIG_SPL_NAND_DRIVERS -#define CONFIG_SPL_NAND_ECC - -/* NAND boot config */ -#define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT 64 -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) -#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 -#define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9,\ - 10, 11, 12, 13} -#define CONFIG_SYS_NAND_ECCSIZE 512 -#define CONFIG_SYS_NAND_ECCBYTES 3 -#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 -#endif - -#endif /* __IGEP00X0_H */ diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h new file mode 100644 index 0000000..9982cf6 --- /dev/null +++ b/include/configs/omap3_igep00x0.h @@ -0,0 +1,370 @@ +/* + * Common configuration settings for IGEP technology based boards + * + * (C) Copyright 2012 + * ISEE 2007 SL, <www.iseebcn.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __IGEP00X0_H +#define __IGEP00X0_H + +#include <asm/sizes.h> + +/* + * High Level Configuration Options + */ +#define CONFIG_OMAP 1 /* in a TI OMAP core */ +#define CONFIG_OMAP34XX 1 /* which is a 34XX */ +#define CONFIG_OMAP_GPIO +#define CONFIG_OMAP_COMMON + +#define CONFIG_SDRC /* The chip has SDRC controller */ + +#include <asm/arch/cpu.h> +#include <asm/arch/omap3.h> +#include <asm/mach-types.h> + +/* + * Display CPU and Board information + */ +#define CONFIG_DISPLAY_CPUINFO 1 +#define CONFIG_DISPLAY_BOARDINFO 1 + +/* Clock Defines */ +#define V_OSCK 26000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK >> 1) + +#define CONFIG_MISC_INIT_R + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_REVISION_TAG 1 + +#define CONFIG_OF_LIBFDT +#define CONFIG_CMD_BOOTZ +#define CONFIG_SUPPORT_RAW_INITRD + +/* + * NS16550 Configuration + */ + +#define V_NS16550_CLK 48000000 /* 48MHz (APLL96/2) */ + +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK V_NS16550_CLK + +/* select serial console configuration */ +#define CONFIG_CONS_INDEX 3 +#define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 +#define CONFIG_SERIAL3 3 + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600, \ + 115200} +#define CONFIG_GENERIC_MMC 1 +#define CONFIG_MMC 1 +#define CONFIG_OMAP_HSMMC 1 +#define CONFIG_DOS_PARTITION 1 + +/* define to enable boot progress via leds */ +#if (CONFIG_MACH_TYPE == MACH_TYPE_IGEP0020) || \ + (CONFIG_MACH_TYPE == MACH_TYPE_IGEP0030) +#define CONFIG_SHOW_BOOT_PROGRESS +#endif + +/* USB */ +#define CONFIG_MUSB_UDC 1 +#define CONFIG_USB_OMAP3 1 +#define CONFIG_TWL4030_USB 1 + +/* USB device configuration */ +#define CONFIG_USB_DEVICE 1 +#define CONFIG_USB_TTY 1 +#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 + +/* Change these to suit your needs */ +#define CONFIG_USBD_VENDORID 0x0451 +#define CONFIG_USBD_PRODUCTID 0x5678 +#define CONFIG_USBD_MANUFACTURER "Texas Instruments" +#define CONFIG_USBD_PRODUCT_NAME "IGEP" + +/* commands to include */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_EXT4 +#define CONFIG_CMD_FAT /* FAT support */ +#define CONFIG_CMD_FS_GENERIC +#define CONFIG_CMD_I2C /* I2C serial bus support */ +#define CONFIG_CMD_MMC /* MMC support */ +#ifdef CONFIG_BOOT_ONENAND +#define CONFIG_CMD_ONENAND /* ONENAND support */ +#endif +#ifdef CONFIG_BOOT_NAND +#define CONFIG_CMD_NAND +#endif +#if (CONFIG_MACH_TYPE == MACH_TYPE_IGEP0020) || \ + (CONFIG_MACH_TYPE == MACH_TYPE_IGEP0032) +#define CONFIG_CMD_NET /* bootp, tftpboot, rarpboot */ +#endif +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING +#define CONFIG_CMD_NFS /* NFS support */ +#define CONFIG_CMD_MTDPARTS /* Enable MTD parts commands */ +#define CONFIG_MTD_DEVICE + +#undef CONFIG_CMD_FLASH /* flinfo, erase, protect */ +#undef CONFIG_CMD_IMLS /* List all found images */ + +#define CONFIG_SYS_NO_FLASH +#define CONFIG_HARD_I2C 1 +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 1 +#define CONFIG_DRIVER_OMAP34XX_I2C 1 + +/* + * TWL4030 + */ +#define CONFIG_TWL4030_POWER 1 + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "usbtty=cdc_acm\0" \ + "loadaddr=0x82000000\0" \ + "dtbaddr=0x81600000\0" \ + "bootdir=/boot\0" \ + "bootfile=zImage\0" \ + "usbtty=cdc_acm\0" \ + "console=ttyO2,115200n8\0" \ + "mpurate=auto\0" \ + "vram=12M\0" \ + "dvimode=1024x768MR-16@60\0" \ + "defaultdisplay=dvi\0" \ + "mmcdev=0\0" \ + "mmcroot=/dev/mmcblk0p2 rw\0" \ + "mmcrootfstype=ext4 rootwait\0" \ + "nandroot=/dev/mtdblock4 rw\0" \ + "nandrootfstype=jffs2\0" \ + "mmcargs=setenv bootargs console=${console} " \ + "mpurate=${mpurate} " \ + "vram=${vram} " \ + "omapfb.mode=dvi:${dvimode} " \ + "omapfb.debug=y " \ + "omapdss.def_disp=${defaultdisplay} " \ + "root=${mmcroot} " \ + "rootfstype=${mmcrootfstype}\0" \ + "nandargs=setenv bootargs console=${console} " \ + "mpurate=${mpurate} " \ + "vram=${vram} " \ + "omapfb.mode=dvi:${dvimode} " \ + "omapfb.debug=y " \ + "omapdss.def_disp=${defaultdisplay} " \ + "root=${nandroot} " \ + "rootfstype=${nandrootfstype}\0" \ + "loadbootenv=load mmc ${mmcdev} ${loadaddr} uEnv.txt\0" \ + "importbootenv=echo Importing environment from mmc ...; " \ + "env import -t $loadaddr $filesize\0" \ + "loadzimage=load mmc ${mmcdev}:2 ${loadaddr} ${bootdir}/${bootfile}\0" \ + "loadfdt=load mmc ${mmcdev}:2 ${dtbaddr} ${bootdir}/${dtbfile}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "bootz ${loadaddr}\0" \ + "mmcbootfdt=echo Booting with DT from mmc ...; " \ + "bootz ${loadaddr} - ${dtbaddr}\0" \ + "nandboot=echo Booting from onenand ...; " \ + "run nandargs; " \ + "onenand read ${loadaddr} 280000 400000; " \ + "bootz ${loadaddr}\0" \ + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "echo SD/MMC found on device ${mmcdev};" \ + "if run loadbootenv; then " \ + "run importbootenv;" \ + "fi;" \ + "if test -n $uenvcmd; then " \ + "echo Running uenvcmd ...;" \ + "run uenvcmd;" \ + "fi;" \ + "if run loadzimage; then " \ + "if test -n $dtbfile; then " \ + "if run loadfdt; then " \ + "run mmcbootfdt;" \ + "fi;" \ + "fi;" \ + "run mmcboot;" \ + "fi;" \ + "fi;" \ + "run nandboot;" \ + +#define CONFIG_AUTO_COMPLETE 1 + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT "U-Boot # " +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE) + +#define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0) /* memtest */ + /* works on */ +#define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + \ + 0x01F00000) /* 31MB */ + +#define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0) /* default */ + /* load address */ + +#define CONFIG_SYS_MONITOR_LEN (256 << 10) + +/* + * OMAP3 has 12 GP timers, they can be driven by the system clock + * (12/13/16.8/19.2/38.4MHz) or by 32KHz clock. We use 13MHz (V_SCLK). + * This rate is divided by a local divisor. + */ +#define CONFIG_SYS_TIMERBASE (OMAP34XX_GPT2) +#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ +#define CONFIG_SYS_HZ 1000 + +/* + * Physical Memory Map + * + */ +#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ +#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 +#define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1 + +/* + * FLASH and environment organization + */ + +#ifdef CONFIG_BOOT_ONENAND +#define PISMO1_ONEN_SIZE GPMC_SIZE_128M /* Configure the PISMO */ + +#define CONFIG_SYS_ONENAND_BASE ONENAND_MAP + +#define ONENAND_ENV_OFFSET 0x260000 /* environment starts here */ + +#define CONFIG_ENV_IS_IN_ONENAND 1 +#define CONFIG_ENV_SIZE (512 << 10) /* Total Size Environment */ +#define CONFIG_ENV_ADDR ONENAND_ENV_OFFSET +#endif + +#ifdef CONFIG_BOOT_NAND +#define PISMO1_NAND_SIZE GPMC_SIZE_128M /* Configure the PISMO */ +#define CONFIG_NAND_OMAP_GPMC +#define CONFIG_SYS_NAND_BASE NAND_BASE +#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 +#define CONFIG_ENV_OFFSET 0x260000 /* environment starts here */ +#define CONFIG_ENV_IS_IN_NAND 1 +#define CONFIG_ENV_SIZE (512 << 10) /* Total Size Environment */ +#define CONFIG_ENV_ADDR NAND_ENV_OFFSET +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#endif + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128 << 10)) + +/* + * SMSC911x Ethernet + */ +#if defined(CONFIG_CMD_NET) +#define CONFIG_SMC911X +#define CONFIG_SMC911X_32_BIT +#define CONFIG_SMC911X_BASE 0x2C000000 +#endif /* (CONFIG_CMD_NET) */ + +/* + * Leave it at 0x80008000 to allow booting new u-boot.bin with X-loader + * and older u-boot.bin with the new U-Boot SPL. + */ +#define CONFIG_SYS_TEXT_BASE 0x80008000 +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 +#define CONFIG_SYS_INIT_RAM_SIZE 0x800 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ + CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) + +/* SPL */ +#define CONFIG_SPL +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_NAND_SIMPLE +#define CONFIG_SPL_TEXT_BASE 0x40200800 +#define CONFIG_SPL_MAX_SIZE (54 * 1024) +#define CONFIG_SPL_STACK LOW_LEVEL_SRAM_STACK + +/* move malloc and bss high to prevent clashing with the main image */ +#define CONFIG_SYS_SPL_MALLOC_START 0x87000000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 +#define CONFIG_SPL_BSS_START_ADDR 0x87080000 /* end of minimum RAM */ +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ + +/* MMC boot config */ +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ +#define CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION 1 +#define CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME "u-boot.img" + +#define CONFIG_SPL_BOARD_INIT +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBDISK_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SPL_FAT_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT + +#define CONFIG_SPL_POWER_SUPPORT +#define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds" + +#ifdef CONFIG_BOOT_ONENAND +#define CONFIG_SPL_ONENAND_SUPPORT + +/* OneNAND boot config */ +#define CONFIG_SYS_ONENAND_U_BOOT_OFFS 0x80000 +#define CONFIG_SYS_ONENAND_PAGE_SIZE 2048 +#define CONFIG_SPL_ONENAND_LOAD_ADDR 0x80000 +#define CONFIG_SPL_ONENAND_LOAD_SIZE \ + (512 * 1024 - CONFIG_SPL_ONENAND_LOAD_ADDR) + +#endif + +#ifdef CONFIG_BOOT_NAND +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_NAND_BASE +#define CONFIG_SPL_NAND_DRIVERS +#define CONFIG_SPL_NAND_ECC + +/* NAND boot config */ +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_PAGE_COUNT 64 +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) +#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 +#define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9,\ + 10, 11, 12, 13} +#define CONFIG_SYS_NAND_ECCSIZE 512 +#define CONFIG_SYS_NAND_ECCBYTES 3 +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 +#endif + +#endif /* __IGEP00X0_H */
2013/9/2 Javier Martinez Canillas javier@dowhile0.org:
Changes since v1:
- Common configuration settings for IGEP technology based boards
- (C) Copyright 2012
- ISEE 2007 SL, <www.iseebcn.com>
- High Level Configuration Options
- Display CPU and Board information
- NS16550 Configuration
115200}
- TWL4030
"bootdir=/boot\0" \
"mpurate=auto\0" \
"vram=12M\0" \
"mmcdev=0\0" \
"vram=${vram} " \
"omapfb.debug=y " \
"vram=${vram} " \
"omapfb.debug=y " \
"run mmcargs; " \
"run nandargs; " \
"fi;" \
"run uenvcmd;" \
"fi;" \
"run mmcbootfdt;" \
"fi;" \
"fi;" \
"run mmcboot;" \
"fi;" \
"fi;" \
"run nandboot;" \
- Miscellaneous configurable options
/* works on */
/* load address */
- OMAP3 has 12 GP timers, they can be driven by the system clock
- (12/13/16.8/19.2/38.4MHz) or by 32KHz clock. We use 13MHz (V_SCLK).
- This rate is divided by a local divisor.
- Physical Memory Map
- FLASH and environment organization
- Size of malloc() pool
- SMSC911x Ethernet
- Leave it at 0x80008000 to allow booting new u-boot.bin with X-loader
- and older u-boot.bin with the new U-Boot SPL.
-#endif
10, 11, 12, 13}
115200}
- TWL4030
"bootdir=/boot\0" \
"mpurate=auto\0" \
"vram=12M\0" \
"mmcdev=0\0" \
"vram=${vram} " \
"omapfb.debug=y " \
"vram=${vram} " \
"omapfb.debug=y " \
"run mmcargs; " \
"run nandargs; " \
"fi;" \
"run uenvcmd;" \
"fi;" \
"run mmcbootfdt;" \
"fi;" \
"fi;" \
"run mmcboot;" \
"fi;" \
"fi;" \
"run nandboot;" \
/* works on */
/* load address */
- SMSC911x Ethernet
10, 11, 12, 13}
1.8.4.rc3
Acked-by: Enric Balletbo i Serra eballetbo@iseebcn.com
On Mon, Sep 2, 2013 at 1:52 PM, Enric Balletbo Serra eballetbo@gmail.com wrote:
Changes since v1:
These patches don't apply on master anymore after commit 27af930e9 ("Merge and reformat boards.cfg and MAINTAINERS"). I'll rebase the patches and repost.
Thanks a lot and best regards, Javier
Hi Javier,
Changes since v1:
If you are about to repost, can you please add '-M' flag to git format-patch command (if you use this command). This will detect renames and lower the patch size...
On 09/19/2013 05:00 PM, Igor Grinberg wrote:
Hi Javier,
Changes since v1:
Hi Igor,
Yes I do use git format-patch and I'll use -M for the next version.
Thanks for the feedback and best regards, Javier
On Thu, Sep 19, 2013 at 5:13 PM, Javier Martinez Canillas javier.martinez@collabora.co.uk wrote:
Hi Javier,
Changes since v1:
Hi Igor,
Hi Igor,
Changes since v1:
- Copyright (C) 2013, ISEE 2007 SL - http://www.isee.biz/
- published by the Free Software Foundation version 2.
- This program is distributed "as is" WITHOUT ANY WARRANTY of any
- kind, whether express or implied; without even the implied warranty
- of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
"bootdir=/boot\0" \
"mmcdev=0\0" \
"run mmcargs; " \
"fi;" \
"run uenvcmd;" \
"fi;" \
"run mmcboot;" \
"fi;" \
"else " \
"run ubiboot;" \
"fi;" \
"-(filesystem)"
- Place the image at the start of the ROM defined image space.
- We limit our size to the ROM-defined downloaded image area, and use the
- rest of the space for stack.
- 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM
- 64 bytes before this address should be set aside for u-boot.img's
- header. That is 0x800FFFC0--0x80100000 should not be used for any
- other needs.
- Since SPL did pll and ddr initialization for us,
- we don't need to do it twice.
"bootdir=/boot\0" \
"mmcdev=0\0" \
"run mmcargs; " \
"fi;" \
"run uenvcmd;" \
"fi;" \
"run mmcboot;" \
"fi;" \
"else " \
"run ubiboot;" \
"fi;" \
"-(filesystem)"
- other needs.
1.8.4.rc3
Igor Grinberg
