[U-Boot] [PATCH 1/3] cmd: cbfs: fix reading the end_of_rom pointer for 64bit archs
The cast breaks the pointer on 64bit archs, so lets get rid of it.
Signed-off-by: Andre Heider a.heider@gmail.com --- cmd/cbfs.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/cbfs.c b/cmd/cbfs.c index 799ba01fcc..736f8c4527 100644 --- a/cmd/cbfs.c +++ b/cmd/cbfs.c @@ -22,7 +22,7 @@ static int do_cbfs_init(cmd_tbl_t *cmdtp, int flag, int argc, return 0; } if (argc == 2) { - end_of_rom = (int)simple_strtoul(argv[1], &ep, 16); + end_of_rom = simple_strtoul(argv[1], &ep, 16); if (*ep) { puts("\n** Invalid end of ROM **\n"); return 1;
The value at the end of the rom is not a pointer, it is an offset relative to the end of rom.
Signed-off-by: Andre Heider a.heider@gmail.com --- fs/cbfs/cbfs.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/fs/cbfs/cbfs.c b/fs/cbfs/cbfs.c index 6e1107d751..46da8f134f 100644 --- a/fs/cbfs/cbfs.c +++ b/fs/cbfs/cbfs.c @@ -168,9 +168,9 @@ static int file_cbfs_load_header(uintptr_t end_of_rom, struct cbfs_header *header) { struct cbfs_header *header_in_rom; + int32_t offset = *(u32 *)(end_of_rom - 3);
- header_in_rom = (struct cbfs_header *)(uintptr_t) - *(u32 *)(end_of_rom - 3); + header_in_rom = (struct cbfs_header *)(end_of_rom + offset + 1); swap_header(header, header_in_rom);
if (header->magic != good_magic || header->offset >
Do you have any documentation pointers to this? Even just pointing to a specific line of code in coreboot would be helpful in case anyone wants to read it up.
- int32_t offset = *(u32 *)(end_of_rom - 3);
Accessing a pointer that gets subtracted by 3 looks terribly wrong. Unfortunately it's correct, because the pointer itself is unaligned.
How about we change the logic so that we calculate an aligned pointer (after_rom?) which we sanity check for alignment and base all calculations on that instead?
That way the next time someone comes around he's not getting puzzled why we're subtracting 3 and adding 1 to the pointer ;).
Alex
Either that or a comment would be nice. But since this has been sitting around for a while and fixes a bug I think it is best to take it. Please feel free to send a follow-up patch..
We also have no tests for this code, so I'd really like to get some tests in there!
Applied to u-boot-dm, thanks!
This fixes walking the cbfs file list because the bound checks do not apply to header components.
Output of coreboot's cbfstool: Name Offset Type Size Comp cbfs master header 0x0 cbfs header 32 none fallback/romstage 0x80 stage 21344 none fallback/ramstage 0x5440 stage 36848 none config 0xe480 raw 310 none revision 0xe600 raw 575 none fallback/bl31 0xe880 payload 15931 none fallback/payload 0x12700 payload 205449 none (empty) 0x44a00 null 111768 none header pointer 0x5fec0 cbfs header 4 none
Output of u-boot's cbfsls: size type name ------------------------------------------ 32 cbfs header cbfs master header 21344 stage fallback/romstage 36848 stage fallback/ramstage 310 raw config 575 raw revision 15931 payload fallback/bl31 205449 payload fallback/payload 111768 null (empty) 4 cbfs header header pointer
Signed-off-by: Andre Heider a.heider@gmail.com --- cmd/cbfs.c | 3 +++ fs/cbfs/cbfs.c | 10 ++++++---- include/cbfs.h | 1 + 3 files changed, 10 insertions(+), 4 deletions(-)
diff --git a/cmd/cbfs.c b/cmd/cbfs.c index 736f8c4527..f5ad04c45a 100644 --- a/cmd/cbfs.c +++ b/cmd/cbfs.c @@ -113,6 +113,9 @@ static int do_cbfs_ls(cmd_tbl_t *cmdtp, int flag, int argc, printf(" %8d", file_cbfs_size(file));
switch (type) { + case CBFS_COMPONENT_CBFSHEADER: + type_name = "cbfs header"; + break; case CBFS_TYPE_STAGE: type_name = "stage"; break; diff --git a/fs/cbfs/cbfs.c b/fs/cbfs/cbfs.c index 46da8f134f..389f60702b 100644 --- a/fs/cbfs/cbfs.c +++ b/fs/cbfs/cbfs.c @@ -97,10 +97,12 @@ static int file_cbfs_next_file(u8 *start, u32 size, u32 align, }
swap_file_header(&header, fileHeader); - if (header.offset < sizeof(struct cbfs_fileheader) || - header.offset > header.len) { - file_cbfs_result = CBFS_BAD_FILE; - return -1; + if (header.type != CBFS_COMPONENT_CBFSHEADER) { + if (header.offset < sizeof(struct cbfs_fileheader) || + header.offset > header.len) { + file_cbfs_result = CBFS_BAD_FILE; + return -1; + } } newNode->next = NULL; newNode->type = header.type; diff --git a/include/cbfs.h b/include/cbfs.h index f50280107b..d5d9d8ce97 100644 --- a/include/cbfs.h +++ b/include/cbfs.h @@ -19,6 +19,7 @@ enum cbfs_result { };
enum cbfs_filetype { + CBFS_COMPONENT_CBFSHEADER = 0x02, CBFS_TYPE_STAGE = 0x10, CBFS_TYPE_PAYLOAD = 0x20, CBFS_TYPE_OPTIONROM = 0x30,
I don't see a before/after comparison? What output exactly did get fixed?
I don't quite understand what case exactly this fixes. The bounds check seems to try to find out whether the header is within the master header range, right?
So doesn't this just mean we're reading beyond the expected fs size?
Alex
switch (type) {
case CBFS_TYPE_STAGE: type_name = "stage"; break;break;
return -1;
return -1;
} newNode->next = NULL; newNode->type = header.type;}
- CBFS_COMPONENT_CBFSHEADER = 0x02, CBFS_TYPE_STAGE = 0x10, CBFS_TYPE_PAYLOAD = 0x20, CBFS_TYPE_OPTIONROM = 0x30,
I don't understand this one either.
Andre please take a look and update your commit message.
Reviewed-by: Alexander Graf agraf@suse.de
Alex
if (*ep) { puts("\n** Invalid end of ROM **\n"); return 1;end_of_rom = simple_strtoul(argv[1], &ep, 16);
Alexander Graf
Andre Heider
