[U-Boot] [PATCH RFC] OMAP: mmc: add support for second and third mmc channels
This patch adds support for the second and third mmc channels on OMAP3 processors
Boards wishing to use this feature should define CONFIG_SYS_MMC_SET_DEV in the board config
Tested on Overo
Signed-off-by: Steve Sakoman steve@sakoman.com ---
diff --git a/arch/arm/include/asm/arch-omap3/mmc_host_def.h b/arch/arm/include/asm/arch-omap3/mmc_host_def.h index aa751c9..f081b43 100644 --- a/arch/arm/include/asm/arch-omap3/mmc_host_def.h +++ b/arch/arm/include/asm/arch-omap3/mmc_host_def.h @@ -31,11 +31,18 @@ typedef struct t2 { unsigned char res1[0x274]; unsigned int devconf0; /* 0x274 */ - unsigned char res2[0x2A8]; + unsigned char res2[0x064]; + unsigned int devconf1; /* 0x2D8 */ + unsigned char res3[0x248]; unsigned int pbias_lite; /* 0x520 */ } t2_t;
#define MMCSDIO1ADPCLKISEL (1 << 24) +#define MMCSDIO2ADPCLKISEL (1 << 6) + +#define EN_MMC1 (1 << 24) +#define EN_MMC2 (1 << 25) +#define EN_MMC3 (1 << 30)
#define PBIASLITEPWRDNZ0 (1 << 1) #define PBIASSPEEDCTRL0 (1 << 2) @@ -44,7 +51,9 @@ typedef struct t2 { /* * OMAP HSMMC register definitions */ -#define OMAP_HSMMC_BASE 0x4809C000 +#define OMAP_HSMMC1_BASE 0x4809C000 +#define OMAP_HSMMC2_BASE 0x480B4000 +#define OMAP_HSMMC3_BASE 0x480AD000
typedef struct hsmmc { unsigned char res1[0x10]; diff --git a/drivers/mmc/omap3_mmc.c b/drivers/mmc/omap3_mmc.c index 96c0e65..bf650ba 100644 --- a/drivers/mmc/omap3_mmc.c +++ b/drivers/mmc/omap3_mmc.c @@ -52,7 +52,27 @@ const unsigned short mmc_transspeed_val[15][4] = {
mmc_card_data cur_card_data; static block_dev_desc_t mmc_blk_dev; -static hsmmc_t *mmc_base = (hsmmc_t *)OMAP_HSMMC_BASE; +static hsmmc_t *mmc_base = (hsmmc_t *)OMAP_HSMMC1_BASE; + +unsigned char mmc_set_dev(int dev) +{ + switch (dev) { + case 1: + mmc_base = (hsmmc_t *)OMAP_HSMMC1_BASE; + break; + case 2: + mmc_base = (hsmmc_t *)OMAP_HSMMC2_BASE; + break; + case 3: + mmc_base = (hsmmc_t *)OMAP_HSMMC3_BASE; + break; + default: + mmc_base = (hsmmc_t *)OMAP_HSMMC1_BASE; + return 1; + } + + return 0; +}
block_dev_desc_t *mmc_get_dev(int dev) { @@ -62,6 +82,7 @@ block_dev_desc_t *mmc_get_dev(int dev) unsigned char mmc_board_init(void) { t2_t *t2_base = (t2_t *)T2_BASE; + struct prcm *prcm_base = (struct prcm *)PRCM_BASE;
#if defined(CONFIG_TWL4030_POWER) twl4030_power_mmc_init(); @@ -74,6 +95,17 @@ unsigned char mmc_board_init(void) writel(readl(&t2_base->devconf0) | MMCSDIO1ADPCLKISEL, &t2_base->devconf0);
+ writel(readl(&t2_base->devconf1) | MMCSDIO2ADPCLKISEL, + &t2_base->devconf1); + + writel(readl(&prcm_base->fclken1_core) | + EN_MMC1 | EN_MMC2 | EN_MMC3, + &prcm_base->fclken1_core); + + writel(readl(&prcm_base->iclken1_core) | + EN_MMC1 | EN_MMC2 | EN_MMC3, + &prcm_base->iclken1_core); + return 1; }
@@ -512,8 +544,11 @@ unsigned long mmc_bread(int dev_num, unsigned long blknr, lbaint_t blkcnt, return 1; }
-int mmc_legacy_init(int verbose) +int mmc_legacy_init(int dev) { + if (mmc_set_dev(dev) != 0) + return 1; + if (configure_mmc(&cur_card_data) != 1) return 1;
Tested on Overo
- unsigned char res2[0x064];
- unsigned int devconf1; /* 0x2D8 */
- unsigned char res3[0x248]; unsigned int pbias_lite; /* 0x520 */
This changes the offset of pbias_lite -- 0x64+4+0x248 = 0x2b0, not 0x2a8.
The mandatory use of structs even with large reserved areas seems to invite and obscure such issues (and the comments don't help much, since nothing ensures they're accurate).
-Scott
Tested on Overo
Good catch!
Agreed -- I really hate sparse structs like this since they just invite this type of error when you fill in missing registers.
I'll fix and resubmit the patch for further comment.
Steve
Good catch!
BTW, the reason I didn't catch this in testing is that the error would only show up for mmc channel 2, which is not available on Overo (it is used for the SDIO wifi interface). My testing was done on mmc1 and mmc2.
Steve
Tested on Overo
diff --git a/arch/arm/include/asm/arch-omap3/mmc_host_def.h b/arch/arm/include/asm/arch-omap3/mmc_host_def.h index aa751c9..f081b43 100644 --- a/arch/arm/include/asm/arch-omap3/mmc_host_def.h +++ b/arch/arm/include/asm/arch-omap3/mmc_host_def.h @@ -31,11 +31,18 @@ typedef struct t2 { unsigned char res1[0x274]; unsigned int devconf0; /* 0x274 */ - unsigned char res2[0x2A8]; + unsigned char res2[0x060]; + unsigned int devconf1; /* 0x2D8 */ + unsigned char res3[0x244]; unsigned int pbias_lite; /* 0x520 */ } t2_t;
Tested on Overo
Signed-off-by: Steve Sakomansteve@sakoman.com
Tested-by: Philip Balister philip@opensdr.com
Works with mmc3 connected to an over via the TXS0206 level shifter chip.
Philip
#define MMCSDIO1ADPCLKISEL (1<< 24)
+#define MMCSDIO2ADPCLKISEL (1<< 6)
+#define EN_MMC1 (1<< 24) +#define EN_MMC2 (1<< 25) +#define EN_MMC3 (1<< 30)
#define PBIASLITEPWRDNZ0 (1<< 1) #define PBIASSPEEDCTRL0 (1<< 2) @@ -44,7 +51,9 @@ typedef struct t2 { /*
- OMAP HSMMC register definitions
- switch (dev) {
- case 1:
break;
- case 2:
break;
- case 3:
break;
- default:
return 1;
- writel(readl(&t2_base->devconf1) | MMCSDIO2ADPCLKISEL,
- writel(readl(&prcm_base->fclken1_core) |
- writel(readl(&prcm_base->iclken1_core) |
- return 1; }
- if (mmc_set_dev(dev) != 0)
return 1;
- if (configure_mmc(&cur_card_data) != 1) return 1;
Tested on Overo
Applied, thanks!
Tested on Overo
Applied, thanks!
I can't seem to find which branch this has been applied to!
I have a new patch series which depends on this. Do I need to resubmit?
Regards,
Steve
Andy Fleming
Philip Balister
Scott Wood
Steve Sakoman
