[PATCH v2] board: rockchip: add Khadas Edge2 RK3588 board
Khadas Edge2 is a Rockchip RK3588S based SBC (Single Board Computer) by Khadas.
There are tree variants depending on the DRAM size : 8G and 16G.
Specification:
Rockchip RK3588S SoC 4x ARM Cortex-A76, 4x ARM Cortex-A55 8/16GB memory LPDDR4x Mali G610MP4 GPU 3x MIPI CSI 4x lanes 2x MIPI-DSI DPHY 4x lanes 32/64GB eMMC 1x USB 2.0, 1x USB 3.0, 2x USB-Type-C 1x HDMI 2.1 output, 1x DP 1.4 output USB PD over USB Type-C
Kernel commit: 04d552993522 ("arm64: dts: rockchip: Add Khadas edge2 board")
Signed-off-by: Jacobe Zang jacobe.zang@wesion.com --- Add support for Khadas Edge2 --- Changes in v2: - defconfig: Update defconfig made from upstream - Link to v1: https://lore.kernel.org/r/20241119-edge2-v1-1-b10c5d7626ca@wesion.com --- arch/arm/mach-rockchip/rk3588/Kconfig | 23 ++++ board/khadas/khadas-edge2-rk3588s/Kconfig | 12 +++ board/khadas/khadas-edge2-rk3588s/MAINTAINERS | 6 ++ configs/khadas-edge2-rk3588s_defconfig | 146 ++++++++++++++++++++++++++ doc/board/rockchip/rockchip.rst | 1 + include/configs/khadas-edge2-rk3588s.h | 15 +++ 6 files changed, 203 insertions(+)
diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/mach-rockchip/rk3588/Kconfig index b5a0e624a53..7d817e7f1bd 100644 --- a/arch/arm/mach-rockchip/rk3588/Kconfig +++ b/arch/arm/mach-rockchip/rk3588/Kconfig @@ -74,6 +74,28 @@ config TARGET_JAGUAR_RK3588 - fan controller (AMC6821 emulation) * 80-pin Mezzanine connector
+config TARGET_KHADAS_EDGE2_RK3588 + bool "Khadas Edge2 RK3588 board" + select BOARD_LATE_INIT + help + Khadas Edge2 is a Rockchip RK3588S based SBC (Single Board Computer) + by Khadas. + + There are tree variants depending on the DRAM size : 8G and 16G. + + Specification: + + Rockchip RK3588S SoC + 4x ARM Cortex-A76, 4x ARM Cortex-A55 + 8/16GB memory LPDDR4x + Mali G610MP4 GPU + 3x MIPI CSI 4x lanes + 2x MIPI-DSI DPHY 4x lanes + 32/64GB eMMC + 1x USB 2.0, 1x USB 3.0, 2x USB-Type-C + 1x HDMI 2.1 output, 1x DP 1.4 output + USB PD over USB Type-C + config TARGET_NANOPCT6_RK3588 bool "FriendlyElec NanoPC-T6 RK3588 board" select BOARD_LATE_INIT @@ -393,6 +415,7 @@ source "board/friendlyelec/nanopi-r6c-rk3588s/Kconfig" source "board/friendlyelec/nanopi-r6s-rk3588s/Kconfig" source "board/hardkernel/odroid_m2/Kconfig" source "board/indiedroid/nova/Kconfig" +source "board/khadas/khadas-edge2-rk3588s/Kconfig" source "board/pine64/quartzpro64-rk3588/Kconfig" source "board/turing/turing-rk1-rk3588/Kconfig" source "board/radxa/rock5a-rk3588s/Kconfig" diff --git a/board/khadas/khadas-edge2-rk3588s/Kconfig b/board/khadas/khadas-edge2-rk3588s/Kconfig new file mode 100644 index 00000000000..dd7b6cd8054 --- /dev/null +++ b/board/khadas/khadas-edge2-rk3588s/Kconfig @@ -0,0 +1,12 @@ +if TARGET_KHADAS_EDGE2_RK3588 + +config SYS_BOARD + default "khadas-edge2-rk3588s" + +config SYS_VENDOR + default "khadas" + +config SYS_CONFIG_NAME + default "khadas-edge2-rk3588s" + +endif diff --git a/board/khadas/khadas-edge2-rk3588s/MAINTAINERS b/board/khadas/khadas-edge2-rk3588s/MAINTAINERS new file mode 100644 index 00000000000..3f16923b0f2 --- /dev/null +++ b/board/khadas/khadas-edge2-rk3588s/MAINTAINERS @@ -0,0 +1,6 @@ +KHADAS-EDGE2-RK3588S +M: Jacobe Zang jacobe.zang@wesion.com +S: Maintained +F: configs/khadas-edge2-rk3588s_defconfig +F: include/configs/khadas-edge2-rk3588s.h +F: dts/upstream/src/arm64/rockchip/rk3588s-khadas-edge2.dts \ No newline at end of file diff --git a/configs/khadas-edge2-rk3588s_defconfig b/configs/khadas-edge2-rk3588s_defconfig new file mode 100644 index 00000000000..bc9e8f39ec5 --- /dev/null +++ b/configs/khadas-edge2-rk3588s_defconfig @@ -0,0 +1,146 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3588s-khadas-edge2" +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x80000 +CONFIG_ROCKCHIP_RK3588=y +CONFIG_SPL_SERIAL=y +CONFIG_TARGET_KHADAS_EDGE2_RK3588=y +CONFIG_DEBUG_UART_BASE=0xFEB50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588s-khadas-edge2.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_MMC_WRITE=y +CONFIG_SPL_MTD_SUPPORT=y +CONFIG_SPL_ATF=y +CONFIG_SYS_PROMPT="kedge2# " +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_SPI=y +CONFIG_SPL_SPI_SUPPORT=y +CONFIG_DM_SPI=y +# CONFIG_DM_SPI_FLASH=y +CONFIG_MMC=y +# CONFIG_MMC_SPI=y +CONFIG_CMD_SF_TEST=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_TFTPPUT=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=64 +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=0x1 +CONFIG_FASTBOOT_BUF_ADDR=0xc00800 +CONFIG_FASTBOOT_BUF_SIZE=0x07000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_I2C_MUX=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_SPL_MISC=y +CONFIG_ROCKCHIP_OTP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_HS200_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_PHY_REALTEK=y +CONFIG_MTD=y +# CONFIG_NAND=y +# CONFIG_MTD_SPI_NAND=y +CONFIG_SF_DEFAULT_SPEED=80000000 +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_XMC=y +CONFIG_SPI_FLASH_XTX=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_DM_ETH_PHY=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_PHY_ROCKCHIP_USBDP=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_TYPEC_TCPM=y +CONFIG_TYPEC_FUSB302=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_TPL_RAM=y +CONFIG_DM_RESET=y +CONFIG_SPL_DM_RESET=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_ROCKCHIP_SPI=y +CONFIG_ROCKCHIP_SFC=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Rockchip" +CONFIG_USB_GADGET_VENDOR_NUM=0x2207 +CONFIG_USB_GADGET_PRODUCT_NUM=0x350a +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_DISPLAY=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_RSA=y +CONFIG_SPL_RSA=y +CONFIG_LZ4=y +CONFIG_LZMA=y +CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index 9bab86d2347..ea98b73d33c 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -137,6 +137,7 @@ List of mainline supported Rockchip boards: - Generic RK3588S/RK3588 (generic-rk3588) - Hardkernel ODROID-M2 (odroid-m2-rk3588s) - Indiedroid Nova (nova-rk3588s) + - Khadas Edge2 (khadas-edge2-rk3588s) - Pine64 QuartzPro64 (quartzpro64-rk3588) - Radxa ROCK 5 ITX (rock-5-itx-rk3588) - Radxa ROCK 5A (rock5a-rk3588s) diff --git a/include/configs/khadas-edge2-rk3588s.h b/include/configs/khadas-edge2-rk3588s.h new file mode 100644 index 00000000000..d279cf3826a --- /dev/null +++ b/include/configs/khadas-edge2-rk3588s.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2024 Khadas Technology Co., Ltd. + */ + +#ifndef __KHADAS_EDGE2_RK3588_H +#define __KHADAS_EDGE2_RK3588_H + +#include <configs/rk3588_common.h> + +#define ROCKCHIP_DEVICE_SETTINGS \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" + +#endif /* __KHADAS_EDGE2_RK3588_H */
--- base-commit: 3073246d1be682071d8b3d07d06c2484907aed60 change-id: 20241119-edge2-18ac09a490ab
Hi Jacobe,
On 12/4/24 10:45 AM, Jacobe Zang wrote:
[You don't often get email from jacobe.zang@wesion.com. Learn why this is important at https://aka.ms/LearnAboutSenderIdentification ]
What's the third variant :)?
Specification:
Changes in v2:
How did you generate the defconfig?
I applied your patch and ran make khadas-edge2-rk3588s_defconfig followed by make savedefconfig and they are different enough to make me suspicious of how this defconfig was generated?
help
by Khadas.
If there's a third variant, please make it explicit as well here.
Specification:
Mali G610MP4 GPU
32/64GB eMMC
- config TARGET_NANOPCT6_RK3588 bool "FriendlyElec NanoPC-T6 RK3588 board" select BOARD_LATE_INIT
+config SYS_BOARD
+config SYS_VENDOR
default "khadas"
The board seems to have an SPI-NOR flash. If it can boot from it, you probably want to enable
CONFIG_ROCKCHIP_SPI_IMAGE=y
to generate u-boot-rockchip-spi.bin?
Can one really use bootz for Aarch64 images?
Otherwise the rest of the defconfig looks pretty similar to the rock5b defconfig so I guess this is fine.
I'm very surprised there's no -u-boot.dtsi file though. You may want to check that everything that can be used in SPL/TPL makes it in the respective DT (spl/u-boot-spl.dtb and tpl/u-boot-tpl.dtb). E.g. if you want to be able to fallback to SPI-NOR for U-Boot proper when booting from eMMC/SD card, you would need everything related to the SPI controller the flash is routed to (as well as the pinmux, pinconf, regulators, etc...) be present in the TPL/SPL DT. Nothing we cannot improve in later commits though, so not necessarily a blocker.
Cheers, Quentin
On 2024/12/6 21:28, Quentin Schulz wrote:> Hi Jacobe,
Sorry for replying so late, this is a tpyo error. In fact this board only have these two variants.
Specification:
Changes in v2:
Well, I copied the defconfig from the U-boot 2017 version, v2 has delete some configurations that are not supported in the mainline and I dropped the unused configurations one by one..
So the correct way to generate the defconfig is ..?
I run the same command as you, but I didn't see the changes in git diff. Maybe there is something I forgot to do?
arch/arm/mach-rockchip/rk3588/Kconfig | 23 ++++ board/khadas/khadas-edge2-rk3588s/Kconfig | 12 +++ board/khadas/khadas-edge2-rk3588s/MAINTAINERS | 6 ++ configs/khadas-edge2-rk3588s_defconfig | 146 ++++++++++++++++ ++++++++++ doc/board/rockchip/rockchip.rst | 1 + include/configs/khadas-edge2-rk3588s.h | 15 +++ 6 files changed, 203 insertions(+)
diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/mach- rockchip/rk3588/Kconfig index b5a0e624a53..7d817e7f1bd 100644 --- a/arch/arm/mach-rockchip/rk3588/Kconfig +++ b/arch/arm/mach-rockchip/rk3588/Kconfig @@ -74,6 +74,28 @@ config TARGET_JAGUAR_RK3588 - fan controller (AMC6821 emulation) * 80-pin Mezzanine connector
help
Computer)
by Khadas.
16G.
I will fix it in next version ;-)
Specification:
Mali G610MP4 GPU
32/64GB eMMC
@@ -393,6 +415,7 @@ source "board/friendlyelec/nanopi-r6c-rk3588s/ Kconfig" source "board/friendlyelec/nanopi-r6s-rk3588s/Kconfig" source "board/hardkernel/odroid_m2/Kconfig" source "board/indiedroid/nova/Kconfig" +source "board/khadas/khadas-edge2-rk3588s/Kconfig" source "board/pine64/quartzpro64-rk3588/Kconfig" source "board/turing/turing-rk1-rk3588/Kconfig" source "board/radxa/rock5a-rk3588s/Kconfig" diff --git a/board/khadas/khadas-edge2-rk3588s/Kconfig b/board/khadas/ khadas-edge2-rk3588s/Kconfig new file mode 100644 index 00000000000..dd7b6cd8054 --- /dev/null +++ b/board/khadas/khadas-edge2-rk3588s/Kconfig @@ -0,0 +1,12 @@ +if TARGET_KHADAS_EDGE2_RK3588
+config SYS_BOARD
+config SYS_VENDOR
default "khadas"
+endif diff --git a/board/khadas/khadas-edge2-rk3588s/MAINTAINERS b/board/ khadas/khadas-edge2-rk3588s/MAINTAINERS new file mode 100644 index 00000000000..3f16923b0f2 --- /dev/null +++ b/board/khadas/khadas-edge2-rk3588s/MAINTAINERS @@ -0,0 +1,6 @@ +KHADAS-EDGE2-RK3588S +M: Jacobe Zang jacobe.zang@wesion.com +S: Maintained +F: configs/khadas-edge2-rk3588s_defconfig +F: include/configs/khadas-edge2-rk3588s.h +F: dts/upstream/src/arm64/rockchip/rk3588s-khadas-edge2.dts \ No newline at end of file diff --git a/configs/khadas-edge2-rk3588s_defconfig b/configs/khadas- edge2-rk3588s_defconfig new file mode 100644 index 00000000000..bc9e8f39ec5 --- /dev/null +++ b/configs/khadas-edge2-rk3588s_defconfig @@ -0,0 +1,146 @@
Yep, it has an SPI-NOR flash but we have preinstalled a custom boot system in it and we don't want users to modify, so don't enable it.
As a result u-boot-rockchip-spi.bin is no need, so I will disable the configuration next time.
Now the device use bootflow to scan all the storage then boot.
Now the base version I test is okay so I didn't add .dtsi as the required one.
Okay, thanks for your guidance.
--- Best regards, Jacobe Zang
Hi Jacobe,
So this is two instead of typo three, right?
I can correct it when apply if not other update is needed.
Specification:
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes in v2:
- bool "Khadas Edge2 RK3588 board"
- select BOARD_LATE_INIT
- help
by Khadas.
Specification:
Mali G610MP4 GPU
32/64GB eMMC
+config SYS_BOARD
- default "khadas-edge2-rk3588s"
+config SYS_VENDOR
- default "khadas"
- Copyright (c) 2024 Khadas Technology Co., Ltd.
On 2025/1/3 11:24, Kever Yang wrote:
Hi Jacobe,
Yes, this is a typo error, only two variants.
Okay, that couldn't be better.
Specification:
Thanks,
- Kever
Changes in v2:
diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/mach- rockchip/rk3588/Kconfig index b5a0e624a53..7d817e7f1bd 100644 --- a/arch/arm/mach-rockchip/rk3588/Kconfig +++ b/arch/arm/mach-rockchip/rk3588/Kconfig @@ -74,6 +74,28 @@ config TARGET_JAGUAR_RK3588 - fan controller (AMC6821 emulation) * 80-pin Mezzanine connector +config TARGET_KHADAS_EDGE2_RK3588 + bool "Khadas Edge2 RK3588 board" + select BOARD_LATE_INIT + help + Khadas Edge2 is a Rockchip RK3588S based SBC (Single Board Computer) + by Khadas.
+ Specification:
config TARGET_NANOPCT6_RK3588 bool "FriendlyElec NanoPC-T6 RK3588 board" select BOARD_LATE_INIT @@ -393,6 +415,7 @@ source "board/friendlyelec/nanopi-r6c-rk3588s/ Kconfig" source "board/friendlyelec/nanopi-r6s-rk3588s/Kconfig" source "board/hardkernel/odroid_m2/Kconfig" source "board/indiedroid/nova/Kconfig" +source "board/khadas/khadas-edge2-rk3588s/Kconfig" source "board/pine64/quartzpro64-rk3588/Kconfig" source "board/turing/turing-rk1-rk3588/Kconfig" source "board/radxa/rock5a-rk3588s/Kconfig" diff --git a/board/khadas/khadas-edge2-rk3588s/Kconfig b/board/khadas/ khadas-edge2-rk3588s/Kconfig new file mode 100644 index 00000000000..dd7b6cd8054 --- /dev/null +++ b/board/khadas/khadas-edge2-rk3588s/Kconfig @@ -0,0 +1,12 @@ +if TARGET_KHADAS_EDGE2_RK3588
+endif diff --git a/board/khadas/khadas-edge2-rk3588s/MAINTAINERS b/board/ khadas/khadas-edge2-rk3588s/MAINTAINERS new file mode 100644 index 00000000000..3f16923b0f2 --- /dev/null +++ b/board/khadas/khadas-edge2-rk3588s/MAINTAINERS @@ -0,0 +1,6 @@ +KHADAS-EDGE2-RK3588S +M: Jacobe Zang jacobe.zang@wesion.com +S: Maintained +F: configs/khadas-edge2-rk3588s_defconfig +F: include/configs/khadas-edge2-rk3588s.h +F: dts/upstream/src/arm64/rockchip/rk3588s-khadas-edge2.dts \ No newline at end of file diff --git a/configs/khadas-edge2-rk3588s_defconfig b/configs/khadas- edge2-rk3588s_defconfig new file mode 100644 index 00000000000..bc9e8f39ec5 --- /dev/null +++ b/configs/khadas-edge2-rk3588s_defconfig @@ -0,0 +1,146 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3588s-khadas-edge2" +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x80000 +CONFIG_ROCKCHIP_RK3588=y +CONFIG_SPL_SERIAL=y +CONFIG_TARGET_KHADAS_EDGE2_RK3588=y +CONFIG_DEBUG_UART_BASE=0xFEB50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588s-khadas-edge2.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_MMC_WRITE=y +CONFIG_SPL_MTD_SUPPORT=y +CONFIG_SPL_ATF=y +CONFIG_SYS_PROMPT="kedge2# " +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_SPI=y +CONFIG_SPL_SPI_SUPPORT=y +CONFIG_DM_SPI=y +# CONFIG_DM_SPI_FLASH=y +CONFIG_MMC=y +# CONFIG_MMC_SPI=y +CONFIG_CMD_SF_TEST=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_TFTPPUT=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=64 +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned- clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=0x1 +CONFIG_FASTBOOT_BUF_ADDR=0xc00800 +CONFIG_FASTBOOT_BUF_SIZE=0x07000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_I2C_MUX=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_SPL_MISC=y +CONFIG_ROCKCHIP_OTP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_HS200_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_PHY_REALTEK=y +CONFIG_MTD=y +# CONFIG_NAND=y +# CONFIG_MTD_SPI_NAND=y +CONFIG_SF_DEFAULT_SPEED=80000000 +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_XMC=y +CONFIG_SPI_FLASH_XTX=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_DM_ETH_PHY=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_PHY_ROCKCHIP_USBDP=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_TYPEC_TCPM=y +CONFIG_TYPEC_FUSB302=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_TPL_RAM=y +CONFIG_DM_RESET=y +CONFIG_SPL_DM_RESET=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_ROCKCHIP_SPI=y +CONFIG_ROCKCHIP_SFC=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Rockchip" +CONFIG_USB_GADGET_VENDOR_NUM=0x2207 +CONFIG_USB_GADGET_PRODUCT_NUM=0x350a +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_DISPLAY=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_RSA=y +CONFIG_SPL_RSA=y +CONFIG_LZ4=y +CONFIG_LZMA=y +CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/ rockchip.rst index 9bab86d2347..ea98b73d33c 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -137,6 +137,7 @@ List of mainline supported Rockchip boards: - Generic RK3588S/RK3588 (generic-rk3588) - Hardkernel ODROID-M2 (odroid-m2-rk3588s) - Indiedroid Nova (nova-rk3588s) + - Khadas Edge2 (khadas-edge2-rk3588s) - Pine64 QuartzPro64 (quartzpro64-rk3588) - Radxa ROCK 5 ITX (rock-5-itx-rk3588) - Radxa ROCK 5A (rock5a-rk3588s) diff --git a/include/configs/khadas-edge2-rk3588s.h b/include/configs/ khadas-edge2-rk3588s.h new file mode 100644 index 00000000000..d279cf3826a --- /dev/null +++ b/include/configs/khadas-edge2-rk3588s.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
Jacobe Zang
Kever Yang
Quentin Schulz
