[PATCH] imx: imx8m{m,n,p}_venice: migrate to CONFIG_EXTRA_ENV_TEXT
Move the majority of the environment from the board headers to a separate text file.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/venice/venice.env | 34 ++++++++++++++++++++++ include/configs/imx8mm_venice.h | 47 ++----------------------------- include/configs/imx8mn_venice.h | 47 ++----------------------------- include/configs/imx8mp_venice.h | 47 ++----------------------------- 4 files changed, 40 insertions(+), 135 deletions(-) create mode 100644 board/gateworks/venice/venice.env
diff --git a/board/gateworks/venice/venice.env b/board/gateworks/venice/venice.env new file mode 100644 index 000000000000..f81804ca12c1 --- /dev/null +++ b/board/gateworks/venice/venice.env @@ -0,0 +1,34 @@ +kernel_addr_r=0x48200000 +fdt_addr_r=0x50200000 +scriptaddr=0x50280000 +ramdisk_addr_r=0x50300000 +kernel_comp_addr_r=0x40200000 +script=boot.scr +bootm_size=0x10000000 +dev=2 +preboot=gsc wd-disable +console=ttymxc1,115200 +update_firmware=tftpboot $loadaddr $image && + setexpr blkcnt $filesize + 0x1ff && + setexpr blkcnt $blkcnt / 0x200 && + mmc dev $dev && + mmc write $loadaddr $splblk $blkcnt +loadfdt=if $fsload $fdt_addr_r $dir/$fdt_file1; + then echo loaded $fdt_file1; + elif $fsload $fdt_addr_r $dir/$fdt_file2; + then echo loaded $fdt_file2; + elif $fsload $fdt_addr_r $dir/$fdt_file3; + then echo loaded $fdt_file3; + elif $fsload $fdt_addr_r $dir/$fdt_file4; + then echo loaded $fdt_file4; + elif $fsload $fdt_addr_r $dir/$fdt_file5; + then echo loaded $fdt_file5; + fi +boot_net=setenv fsload tftpboot; + run loadfdt && tftpboot $kernel_addr_r $dir/Image && + booti $kernel_addr_r - $fdt_addr_r +update_rootfs=tftpboot $loadaddr $image && + gzwrite mmc $dev $loadaddr $filesize 100000 1000000 +update_all=tftpboot $loadaddr $image && + gzwrite mmc $dev $loadaddr $filesize +erase_env=mmc dev $dev; mmc erase 0x7f08 0x40 diff --git a/include/configs/imx8mm_venice.h b/include/configs/imx8mm_venice.h index 6ecc3477f1b6..f754126854f9 100644 --- a/include/configs/imx8mm_venice.h +++ b/include/configs/imx8mm_venice.h @@ -18,13 +18,6 @@ #define CONFIG_MALLOC_F_ADDR 0x930000 #endif
-#define MEM_LAYOUT_ENV_SETTINGS \ - "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "fdt_addr_r=0x50200000\0" \ - "scriptaddr=0x50280000\0" \ - "ramdisk_addr_r=0x50300000\0" \ - "kernel_comp_addr_r=0x40200000\0" - /* Enable Distro Boot */ #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ @@ -33,45 +26,9 @@ func(USB, usb, 1) \ func(DHCP, dhcp, na) #include <config_distro_bootcmd.h> - -/* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ - BOOTENV \ - MEM_LAYOUT_ENV_SETTINGS \ - "script=boot.scr\0" \ - "bootm_size=0x10000000\0" \ - "dev=2\0" \ - "preboot=gsc wd-disable\0" \ - "console=ttymxc1,115200\0" \ - "update_firmware=" \ - "tftpboot $loadaddr $image && " \ - "setexpr blkcnt $filesize + 0x1ff && " \ - "setexpr blkcnt $blkcnt / 0x200 && " \ - "mmc dev $dev && " \ - "mmc write $loadaddr 0x42 $blkcnt\0" \ - "loadfdt=" \ - "if $fsload $fdt_addr_r $dir/$fdt_file1; " \ - "then echo loaded $fdt_file1; " \ - "elif $fsload $fdt_addr_r $dir/$fdt_file2; " \ - "then echo loaded $fdt_file2; " \ - "elif $fsload $fdt_addr_r $dir/$fdt_file3; " \ - "then echo loaded $fdt_file3; " \ - "elif $fsload $fdt_addr_r $dir/$fdt_file4; " \ - "then echo loaded $fdt_file4; " \ - "elif $fsload $fdt_addr_r $dir/$fdt_file5; " \ - "then echo loaded $fdt_file5; " \ - "fi\0" \ - "boot_net=" \ - "setenv fsload tftpboot; " \ - "run loadfdt && tftpboot $kernel_addr_r $dir/Image && " \ - "booti $kernel_addr_r - $fdt_addr_r\0" \ - "update_rootfs=" \ - "tftpboot $loadaddr $image && " \ - "gzwrite mmc $dev $loadaddr $filesize 100000 1000000\0" \ - "update_all=" \ - "tftpboot $loadaddr $image && " \ - "gzwrite mmc $dev $loadaddr $filesize\0" \ - "erase_env=mmc dev $dev; mmc erase 0x7f08 0x40\0" + "splblk=0x42\0" \ + BOOTENV
#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 #define CONFIG_SYS_INIT_RAM_SIZE SZ_2M diff --git a/include/configs/imx8mn_venice.h b/include/configs/imx8mn_venice.h index 4266eb076029..022db009e8af 100644 --- a/include/configs/imx8mn_venice.h +++ b/include/configs/imx8mn_venice.h @@ -13,13 +13,6 @@ #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#define MEM_LAYOUT_ENV_SETTINGS \ - "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "fdt_addr_r=0x50200000\0" \ - "scriptaddr=0x50280000\0" \ - "ramdisk_addr_r=0x50300000\0" \ - "kernel_comp_addr_r=0x40200000\0" - /* Enable Distro Boot */ #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ @@ -27,45 +20,9 @@ func(USB, usb, 0) \ func(DHCP, dhcp, na) #include <config_distro_bootcmd.h> - -/* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ - BOOTENV \ - MEM_LAYOUT_ENV_SETTINGS \ - "script=boot.scr\0" \ - "bootm_size=0x10000000\0" \ - "dev=2\0" \ - "preboot=gsc wd-disable\0" \ - "console=ttymxc1,115200\0" \ - "update_firmware=" \ - "tftpboot $loadaddr $image && " \ - "setexpr blkcnt $filesize + 0x1ff && " \ - "setexpr blkcnt $blkcnt / 0x200 && " \ - "mmc dev $dev && " \ - "mmc write $loadaddr 0x40 $blkcnt\0" \ - "loadfdt=" \ - "if $fsload $fdt_addr_r $dir/$fdt_file1; " \ - "then echo loaded $fdt_file1; " \ - "elif $fsload $fdt_addr_r $dir/$fdt_file2; " \ - "then echo loaded $fdt_file2; " \ - "elif $fsload $fdt_addr_r $dir/$fdt_file3; " \ - "then echo loaded $fdt_file3; " \ - "elif $fsload $fdt_addr_r $dir/$fdt_file4; " \ - "then echo loaded $fdt_file4; " \ - "elif $fsload $fdt_addr_r $dir/$fdt_file5; " \ - "then echo loaded $fdt_file5; " \ - "fi\0" \ - "boot_net=" \ - "setenv fsload tftpboot; " \ - "run loadfdt && tftpboot $kernel_addr_r $dir/Image && " \ - "booti $kernel_addr_r - $fdt_addr_r\0" \ - "update_rootfs=" \ - "tftpboot $loadaddr $image && " \ - "gzwrite mmc $dev $loadaddr $filesize 100000 1000000\0" \ - "update_all=" \ - "tftpboot $loadaddr $image && " \ - "gzwrite mmc $dev $loadaddr $filesize\0" \ - "erase_env=mmc dev $dev; mmc erase 0x7f08 0x40\0" + "splblk=0x40\0" \ + BOOTENV
#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 #define CONFIG_SYS_INIT_RAM_SIZE SZ_2M diff --git a/include/configs/imx8mp_venice.h b/include/configs/imx8mp_venice.h index 71962c54bca2..6b87f0dbc48f 100644 --- a/include/configs/imx8mp_venice.h +++ b/include/configs/imx8mp_venice.h @@ -13,13 +13,6 @@ #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
Move the majority of the environment from the board headers to a separate text file. Signed-off-by: Tim Harvey tharvey@gateworks.com
Best regards, Stefano Babic
sbabic@denx.de
Tim Harvey
