[U-Boot] [PATCH v2 0/3] spl: USB Gadget cleanup
This patchset cleans up the SPL USB Gadget Kconfig and Makfile. The first two patches are actual fixes and we might consider to add these two for the v2016.11 release. The third one adds a new config option for cleaner structure. I plan to add another USB function with SPL support which is the reason I looked into this...
Build tested using buildman for all boards on powerpc mips and arm. No new errors or warnings: Building 4 commits for 1072 boards (8 threads, 1 job per thread) 4044 0 244 /4288 P1022DS_NAND
This patchset is probably most interesting for am335x_evm_usbspl_defconfig (CONFIG_SPL_USBETH_SUPPORT) And the board with which SPL DFU support has been introduced dra7xx_evm_defconfig (CONFIG_SPL_DFU_SUPPORT, not set by default)
Due to lack of any of this hardware I did not run the binaries! Since it is mostly Makefile shuffling I don't expect any runtime behavior changes... If anyone (maybe Ravi or Lukasz, afaik you worked on the SPL DFU support for dra7xx_evm) could test the patchset on actual hardware I would be glad!
-- Stefan
Changes in v2: - Use CONFIG_SPL_RAM_SUPPORT to descide whether to compile the function in first place. - Leave DWC3 config in top level SPL Makefile (as U-Boot does)
Stefan Agner (3): spl: add RAM boot device only if it is actually defined spl: dfu: move DFU Kconfig to SPL Kconfig spl: add USB Gadget config option
Kconfig | 27 ------------------ common/spl/Kconfig | 55 +++++++++++++++++++++++++++++-------- common/spl/spl.c | 4 ++- configs/am335x_evm_usbspl_defconfig | 1 + drivers/Makefile | 4 ++- drivers/usb/gadget/Makefile | 9 ++++-- include/configs/dra7xx_evm.h | 1 - scripts/Makefile.spl | 5 +--- 8 files changed, 59 insertions(+), 47 deletions(-)
Some devices (e.g. dra7xx) support loading to RAM using DFU without having direct boot from RAM support. Make sure the linker list does not contain BOOT_DEVICE_RAM if CONFIG_SPL_RAM_SUPPORT is not enabled.
Fixes: 98136b2f26fa ("spl: Convert spl_ram_load_image() to use linker list")
Signed-off-by: Stefan Agner stefan.agner@toradex.com ---
common/spl/spl.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index bdb165a..ef17619 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -174,7 +174,7 @@ __weak void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) # define CONFIG_SPL_LOAD_FIT_ADDRESS 0 #endif
-#if defined(CONFIG_SPL_RAM_DEVICE) || defined(CONFIG_SPL_DFU_SUPPORT) +#if defined(CONFIG_SPL_RAM_SUPPORT) || defined(CONFIG_SPL_DFU_SUPPORT) static ulong spl_ram_load_read(struct spl_load_info *load, ulong sector, ulong count, void *buf) { @@ -220,7 +220,9 @@ static int spl_ram_load_image(struct spl_image_info *spl_image,
return 0; } +#if defined(CONFIG_SPL_RAM_SUPPORT) SPL_LOAD_IMAGE_METHOD(0, BOOT_DEVICE_RAM, spl_ram_load_image); +#endif #if defined(CONFIG_SPL_DFU_SUPPORT) SPL_LOAD_IMAGE_METHOD(0, BOOT_DEVICE_DFU, spl_ram_load_image); #endif
Hi Stefan,
Changes in v2:
Instead of this, how about moving it into its own file and putting that condition in the Makefile?
On 2016-11-14 12:44, Simon Glass wrote:
Hi Stefan,
Changes in v2:
Generally a good idea.
What I don't like to much that we have two orthogonal config options using that same function...
We probably should have something like:
CONFIG_SPL_RAM_SUPPORT CONFIG_SPL_RAM_ONLY_SUPPORT depends on CONFIG_SPL_RAM_SUPPORT CONFIG_SPL_DFU_SUPPORT depends on CONFIG_SPL_RAM_SUPPORT
Then we could use a single config option (CONFIG_SPL_RAM_SUPPORT) for the new file.
However, that is beyond bug fixing, and I'd rather prefer to have it in a separate patch, what do you think?
-- Stefan
Hi Stefan,
Hi Stefan,
Changes in v2:
That's fine with me.
The DFU Kconfig menu entries should be part of the SPL Kconfig file. Also avoid using the top level Makefile by moving the config dependent build artifacts to the driver/ and driver/usb/gadget/ Makfiles.
With that, DFU can be built again in SPL if CONFIG_SPL_DFU_SUPPORT is enabled.
Fixes: 6ad6102246d8 ("usb:gadget: Disallow DFU in SPL for now")
--- Tom, I checked size for am335x_evm_usbspl_defconfig, it stays fine with this patch.
Changes in v2: - Leave DWC3 config in top level SPL Makefile (as U-Boot does)
Kconfig | 27 --------------------------- common/spl/Kconfig | 26 ++++++++++++++++++++++++++ drivers/Makefile | 3 +++ drivers/usb/gadget/Makefile | 8 ++++++-- include/configs/dra7xx_evm.h | 1 - scripts/Makefile.spl | 3 --- 6 files changed, 35 insertions(+), 33 deletions(-)
diff --git a/Kconfig b/Kconfig index 1263d0b..a759e4d 100644 --- a/Kconfig +++ b/Kconfig @@ -291,33 +291,6 @@ config FIT_IMAGE_POST_PROCESS injected into the FIT creation (i.e. the blobs would have been pre- processed before being added to the FIT image).
-config SPL_DFU_SUPPORT - bool "Enable SPL with DFU to load binaries to memory device" - depends on USB - help - Currently the SPL does not have capability to load the - binaries or boot images to boot devices like ram,eMMC,SPI,etc. - This feature enables the DFU (Device Firmware Upgarde) in SPL with - RAM memory device support. The ROM code will load and execute - the SPL built with dfu. The user can load binaries (u-boot/kernel) to - selected device partition from host-pc using dfu-utils. - This feature will be useful to flash the binaries to factory - or bare-metal boards using USB interface. - -choice - bool "DFU device selection" - depends on SPL_DFU_SUPPORT - -config SPL_DFU_RAM - bool "RAM device" - depends on SPL_DFU_SUPPORT - help - select RAM/DDR memory device for loading binary images - (u-boot/kernel) to the selected device partition using - DFU and execute the u-boot/kernel from RAM. - -endchoice - config SYS_CLK_FREQ depends on ARC || ARCH_SUNXI int "CPU clock frequency" diff --git a/common/spl/Kconfig b/common/spl/Kconfig index bb99f1f..54bcba3 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -497,6 +497,32 @@ config SPL_USB_SUPPORT config options. This enables loading from USB using a configured device.
+config SPL_DFU_SUPPORT + bool "Support DFU (Device Firmware Upgarde)" + depends on SPL + select SPL_HASH_SUPPORT + help + This feature enables the DFU (Device Firmware Upgarde) in SPL with + RAM memory device support. The ROM code will load and execute + the SPL built with dfu. The user can load binaries (u-boot/kernel) to + selected device partition from host-pc using dfu-utils. + This feature is useful to flash the binaries to factory or bare-metal + boards using USB interface. + +choice + bool "DFU device selection" + depends on SPL_DFU_SUPPORT + +config SPL_DFU_RAM + bool "RAM device" + depends on SPL_DFU_SUPPORT + help + select RAM/DDR memory device for loading binary images + (u-boot/kernel) to the selected device partition using + DFU and execute the u-boot/kernel from RAM. + +endchoice + config SPL_WATCHDOG_SUPPORT bool "Support watchdog drivers" depends on SPL diff --git a/drivers/Makefile b/drivers/Makefile index 761d0b3..40aba58 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -34,6 +34,9 @@ obj-$(CONFIG_SPL_ETH_SUPPORT) += net/phy/ obj-$(CONFIG_SPL_USBETH_SUPPORT) += net/phy/ obj-$(CONFIG_SPL_MUSB_NEW_SUPPORT) += usb/musb-new/ obj-$(CONFIG_SPL_USBETH_SUPPORT) += usb/gadget/ +obj-$(CONFIG_SPL_DFU_SUPPORT) += usb/gadget/ +obj-$(CONFIG_SPL_DFU_SUPPORT) += usb/gadget/udc/ +obj-$(CONFIG_SPL_DFU_SUPPORT) += dfu/ obj-$(CONFIG_SPL_WATCHDOG_SUPPORT) += watchdog/ obj-$(CONFIG_SPL_USB_HOST_SUPPORT) += usb/host/ obj-$(CONFIG_OMAP_USB_PHY) += usb/phy/ diff --git a/drivers/usb/gadget/Makefile b/drivers/usb/gadget/Makefile index acc9964..5b18e8c 100644 --- a/drivers/usb/gadget/Makefile +++ b/drivers/usb/gadget/Makefile @@ -8,6 +8,10 @@ obj-$(CONFIG_USB_GADGET) += epautoconf.o config.o usbstring.o obj-$(CONFIG_USB_ETHER) += epautoconf.o config.o usbstring.o
+ifdef CONFIG_SPL_BUILD +obj-$(CONFIG_SPL_DFU_SUPPORT) += f_dfu.o +endif + # new USB gadget layer dependencies ifdef CONFIG_USB_GADGET obj-$(CONFIG_USB_GADGET_AT91) += at91_udc.o @@ -18,13 +22,13 @@ obj-$(CONFIG_USB_GADGET_DWC2_OTG_PHY) += dwc2_udc_otg_phy.o obj-$(CONFIG_USB_GADGET_FOTG210) += fotg210.o obj-$(CONFIG_CI_UDC) += ci_udc.o obj-$(CONFIG_USB_GADGET_DOWNLOAD) += g_dnl.o -obj-$(CONFIG_USB_FUNCTION_THOR) += f_thor.o ifndef CONFIG_SPL_BUILD +obj-$(CONFIG_USB_FUNCTION_THOR) += f_thor.o obj-$(CONFIG_USB_FUNCTION_DFU) += f_dfu.o -endif obj-$(CONFIG_USB_FUNCTION_MASS_STORAGE) += f_mass_storage.o obj-$(CONFIG_USB_FUNCTION_FASTBOOT) += f_fastboot.o endif +endif ifdef CONFIG_USB_ETHER obj-y += ether.o obj-$(CONFIG_USB_ETH_RNDIS) += rndis.o diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 798002d..e295a84 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -133,7 +133,6 @@ #undef CONFIG_CMD_BOOTD #ifdef CONFIG_SPL_DFU_SUPPORT #define CONFIG_SPL_LOAD_FIT_ADDRESS 0x80200000 -#define CONFIG_SPL_HASH_SUPPORT #define DFU_ALT_INFO_RAM \ "dfu_alt_info_ram=" \ "kernel ram 0x80200000 0x4000000;" \ diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index e0b0117..1e3b60a 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -66,9 +66,6 @@ endif
libs-$(CONFIG_SPL_LIBDISK_SUPPORT) += disk/ libs-y += drivers/ -libs-$(CONFIG_SPL_DFU_SUPPORT) += drivers/dfu/ -libs-$(CONFIG_SPL_DFU_SUPPORT) += drivers/usb/gadget/ -libs-$(CONFIG_SPL_DFU_SUPPORT) += drivers/usb/gadget/udc/ libs-$(CONFIG_SPL_DFU_SUPPORT) += drivers/usb/dwc3/ libs-y += dts/ libs-y += fs/
Changes in v2:
Introduce USB Gadget config option. This allows to combine Makefile entries for SPL_USBETH_SUPPORT and SPL_DFU_SUPPORT.
Changes in v2: None
common/spl/Kconfig | 31 +++++++++++++++++++------------ configs/am335x_evm_usbspl_defconfig | 1 + drivers/Makefile | 5 ++--- drivers/usb/gadget/Makefile | 3 ++- scripts/Makefile.spl | 2 +- 5 files changed, 25 insertions(+), 17 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 54bcba3..7d0aec0 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -465,17 +465,6 @@ config SPL_SPI_SUPPORT enable SPI drivers that are needed for other purposes also, such as a SPI PMIC.
-config SPL_USBETH_SUPPORT - bool "Support USB Ethernet drivers" - depends on SPL - help - Enable access to the USB network subsystem and associated - drivers in SPL. This permits SPL to load U-Boot over a - USB-connected Ethernet link (such as a USB Ethernet dongle) rather - than from an onboard peripheral. Environment support is required - since the network stack uses a number of environment variables. - See also SPL_NET_SUPPORT and SPL_ETH_SUPPORT. - config SPL_USB_HOST_SUPPORT bool "Support USB host drivers" depends on SPL @@ -497,9 +486,27 @@ config SPL_USB_SUPPORT config options. This enables loading from USB using a configured device.
+config SPL_USB_GADGET_SUPPORT + bool "Suppport USB Gadget drivers" + depends on SPL + help + Enable USB Gadget API which allows to enable USB device functions + in SPL. + +config SPL_USBETH_SUPPORT + bool "Support USB Ethernet drivers" + depends on SPL_GADGET_SUPPORT + help + Enable access to the USB network subsystem and associated + drivers in SPL. This permits SPL to load U-Boot over a + USB-connected Ethernet link (such as a USB Ethernet dongle) rather + than from an onboard peripheral. Environment support is required + since the network stack uses a number of environment variables. + See also SPL_NET_SUPPORT and SPL_ETH_SUPPORT. + config SPL_DFU_SUPPORT bool "Support DFU (Device Firmware Upgarde)" - depends on SPL + depends on SPL_GADGET_SUPPORT select SPL_HASH_SUPPORT help This feature enables the DFU (Device Firmware Upgarde) in SPL with diff --git a/configs/am335x_evm_usbspl_defconfig b/configs/am335x_evm_usbspl_defconfig index 8c28e28..fdb6f77 100644 --- a/configs/am335x_evm_usbspl_defconfig +++ b/configs/am335x_evm_usbspl_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_MUSB_NEW_SUPPORT=y CONFIG_SPL_NET_SUPPORT=y CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_GADGET_SUPPORT=y CONFIG_SPL_USBETH_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/drivers/Makefile b/drivers/Makefile index 40aba58..c19fa14 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -33,9 +33,8 @@ obj-$(CONFIG_SPL_ETH_SUPPORT) += net/ obj-$(CONFIG_SPL_ETH_SUPPORT) += net/phy/ obj-$(CONFIG_SPL_USBETH_SUPPORT) += net/phy/ obj-$(CONFIG_SPL_MUSB_NEW_SUPPORT) += usb/musb-new/ -obj-$(CONFIG_SPL_USBETH_SUPPORT) += usb/gadget/ -obj-$(CONFIG_SPL_DFU_SUPPORT) += usb/gadget/ -obj-$(CONFIG_SPL_DFU_SUPPORT) += usb/gadget/udc/ +obj-$(CONFIG_SPL_USB_GADGET_SUPPORT) += usb/gadget/ +obj-$(CONFIG_SPL_USB_GADGET_SUPPORT) += usb/gadget/udc/ obj-$(CONFIG_SPL_DFU_SUPPORT) += dfu/ obj-$(CONFIG_SPL_WATCHDOG_SUPPORT) += watchdog/ obj-$(CONFIG_SPL_USB_HOST_SUPPORT) += usb/host/ diff --git a/drivers/usb/gadget/Makefile b/drivers/usb/gadget/Makefile index 5b18e8c..0fbbb7c 100644 --- a/drivers/usb/gadget/Makefile +++ b/drivers/usb/gadget/Makefile @@ -9,6 +9,7 @@ obj-$(CONFIG_USB_GADGET) += epautoconf.o config.o usbstring.o obj-$(CONFIG_USB_ETHER) += epautoconf.o config.o usbstring.o
ifdef CONFIG_SPL_BUILD +obj-$(CONFIG_SPL_USB_GADGET_SUPPORT) += g_dnl.o obj-$(CONFIG_SPL_DFU_SUPPORT) += f_dfu.o endif
@@ -21,8 +22,8 @@ obj-$(CONFIG_USB_GADGET_DWC2_OTG) += dwc2_udc_otg.o obj-$(CONFIG_USB_GADGET_DWC2_OTG_PHY) += dwc2_udc_otg_phy.o obj-$(CONFIG_USB_GADGET_FOTG210) += fotg210.o obj-$(CONFIG_CI_UDC) += ci_udc.o -obj-$(CONFIG_USB_GADGET_DOWNLOAD) += g_dnl.o ifndef CONFIG_SPL_BUILD +obj-$(CONFIG_USB_GADGET_DOWNLOAD) += g_dnl.o obj-$(CONFIG_USB_FUNCTION_THOR) += f_thor.o obj-$(CONFIG_USB_FUNCTION_DFU) += f_dfu.o obj-$(CONFIG_USB_FUNCTION_MASS_STORAGE) += f_mass_storage.o diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index 1e3b60a..0ca8430 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -66,7 +66,7 @@ endif
libs-$(CONFIG_SPL_LIBDISK_SUPPORT) += disk/ libs-y += drivers/ -libs-$(CONFIG_SPL_DFU_SUPPORT) += drivers/usb/dwc3/ +libs-$(CONFIG_SPL_USB_GADGET_SUPPORT) += drivers/usb/dwc3/ libs-y += dts/ libs-y += fs/ libs-$(CONFIG_SPL_POST_MEM_SUPPORT) += post/drivers/
Stefan
Sure, I will test SPL-DFU with this patches on dra7xx platform.
But I see SPL-DFU does not compile (dra7xx_evm_defconfig) in current mainline. Due to other patches came in, and also SPL-DFU disabled, I agree reason to reduce spl image size limit ("usb:gadget: Disallow DFU in SPL for now" commit:6ad6a10), need to compile out dfu gadget when SPL-DFU not selected. First I will fix the spl-dfu compile issue and then will test this patch series.
Regards Ravi
On 2016-11-15 00:52, B, Ravi wrote:
Stefan
This patchset fixes exactly that issue! No need to fix it twice :-)
I just tested it again, and actually realized that I made an error in the third patch which does not allow to select SPL_DFU_SUPPORT.
Adding this: config SPL_DFU_SUPPORT bool "Support DFU (Device Firmware Upgarde)" - depends on SPL_GADGET_SUPPORT + depends on SPL_USB_GADGET_SUPPORT select SPL_HASH_SUPPORT help This feature enables the DFU (Device Firmware Upgarde) in SPL with
Allows to select SPL / TPL ---> Suppport USB Gadget drivers, and Support DFU (Device Firmware Upgarde). This compiles fine now.
Will send a v3 which integrates that fix.
-- Stefan
Hi Stephen
Now compiles for dra7x platform. Thanks for v3 patches.
Regards Ravi
B, Ravi
Stefan Agner
