[PATCH v3 1/2] lib: zstd: update to latest Linux zstd 1.5.2
Update the zstd implementation to match Linux zstd 1.5.2 from commit 2aa14b1ab2.
This was motivated by running into decompression corruption issues when trying to uncompress files compressed with newer versions of zstd. zstd users also claim significantly improved decompression times with newer zstd versions which is a side benefit.
Original zstd code was copied from Linux commit 2aa14b1ab2 which is a custom-built implementation based on zstd 1.3.1. Linux switched to an implementation that is a copy of the upstream zstd code in Linux commit e0c1b49f5b, this results in a large code diff. However this should make future updates easier along with other benefits[1].
This commit is a straight mirror of the Linux zstd code, except to: - update a few #include that do not translate cleanly - linux/swab.h -> asm/byteorder.h - linux/limits.h -> linux/kernel.h - linux/module.h -> linux/compat.h - remove assert() from debug.h so it doesn't conflict with u-boot's assert() - strip out the compressor code as was done in the previous u-boot zstd - update existing zstd users to the new Linux zstd API - add a new KConfig option that sets zstd build options to minify code based on zstd's ZSTD_LIB_MINIFY[2].
These changes were tested by booting a zstd 1.5.2 compressed kernel inside a FIT. And the squashfs changes by loading a file from zstd compressed squashfs with sqfsload. buildman was used to compile test other boards and check for binary bloat, as follows:
$ buildman -b zstd2 --boards dh_imx6,m53menlo,mvebu_espressobin-88f3720,sandbox,sandbox64,stm32mp15_dhcom_basic,stm32mp15_dhcor_basic,turris_mox,turris_omnia -sS Summary of 3 commits for 9 boards (8 threads, 1 job per thread) 01: Merge tag 'tpm-23122022' of https://source.denx.de/u-boot/custodians/u-boot-tpm arm: w+ m53menlo dh_imx6 02: lib: zstd: update to latest Linux zstd 1.5.2 aarch64: (for 2/2 boards) all +535.5 rodata +965.5 text -430.0 arm: (for 5/5 boards) all +4489.6 rodata +940.0 text +3549.6 sandbox: (for 2/2 boards) all +12.0 rodata +768.0 text -756.0
[1] https://github.com/torvalds/linux/commit/e0c1b49f5b674cca7b10549c53b3791d0bb... [2] https://github.com/facebook/zstd/blob/f302ad8811643c428c4e3498e28f53a0578020...
Signed-off-by: Brandon Maier brandon.maier@collins.com --- v2: - zstd_decompress(): Handle junk at the end of the decompression buffer by checking actual size with zstd_find_frame_compressed_size(). v3: - minor formatting change to sqfs_decompressor.c to drop an unnecessary change in a printf error string. --- fs/squashfs/sqfs_decompressor.c | 15 +- include/linux/zstd.h | 1244 ++------ include/linux/zstd_errors.h | 77 + include/linux/zstd_lib.h | 2551 +++++++++++++++++ lib/Kconfig | 15 + lib/zstd/Makefile | 35 +- lib/zstd/bitstream.h | 344 --- lib/zstd/common/bitstream.h | 446 +++ lib/zstd/common/compiler.h | 184 ++ lib/zstd/common/cpu.h | 194 ++ lib/zstd/common/debug.c | 24 + lib/zstd/common/debug.h | 92 + lib/zstd/common/entropy_common.c | 357 +++ lib/zstd/common/error_private.c | 56 + lib/zstd/common/error_private.h | 145 + lib/zstd/common/fse.h | 711 +++++ lib/zstd/common/fse_decompress.c | 390 +++ lib/zstd/common/huf.h | 358 +++ lib/zstd/common/mem.h | 261 ++ lib/zstd/common/portability_macros.h | 93 + lib/zstd/common/zstd_common.c | 83 + lib/zstd/common/zstd_deps.h | 125 + lib/zstd/common/zstd_internal.h | 443 +++ lib/zstd/decompress.c | 2516 ---------------- lib/zstd/decompress/huf_decompress.c | 1740 +++++++++++ lib/zstd/decompress/zstd_ddict.c | 241 ++ lib/zstd/decompress/zstd_ddict.h | 44 + lib/zstd/decompress/zstd_decompress.c | 2131 ++++++++++++++ lib/zstd/decompress/zstd_decompress_block.c | 2072 +++++++++++++ lib/zstd/decompress/zstd_decompress_block.h | 68 + .../decompress/zstd_decompress_internal.h | 228 ++ lib/zstd/decompress_sources.h | 34 + lib/zstd/entropy_common.c | 213 -- lib/zstd/error_private.h | 43 - lib/zstd/fse.h | 545 ---- lib/zstd/fse_decompress.c | 302 -- lib/zstd/huf.h | 182 -- lib/zstd/huf_decompress.c | 930 ------ lib/zstd/mem.h | 142 - lib/zstd/zstd.c | 52 +- lib/zstd/zstd_common.c | 66 - lib/zstd/zstd_common_module.c | 32 + lib/zstd/zstd_decompress_module.c | 105 + lib/zstd/zstd_internal.h | 253 -- lib/zstd/zstd_opt.h | 1004 ------- 45 files changed, 13638 insertions(+), 7548 deletions(-) create mode 100644 include/linux/zstd_errors.h create mode 100644 include/linux/zstd_lib.h delete mode 100644 lib/zstd/bitstream.h create mode 100644 lib/zstd/common/bitstream.h create mode 100644 lib/zstd/common/compiler.h create mode 100644 lib/zstd/common/cpu.h create mode 100644 lib/zstd/common/debug.c create mode 100644 lib/zstd/common/debug.h create mode 100644 lib/zstd/common/entropy_common.c create mode 100644 lib/zstd/common/error_private.c create mode 100644 lib/zstd/common/error_private.h create mode 100644 lib/zstd/common/fse.h create mode 100644 lib/zstd/common/fse_decompress.c create mode 100644 lib/zstd/common/huf.h create mode 100644 lib/zstd/common/mem.h create mode 100644 lib/zstd/common/portability_macros.h create mode 100644 lib/zstd/common/zstd_common.c create mode 100644 lib/zstd/common/zstd_deps.h create mode 100644 lib/zstd/common/zstd_internal.h delete mode 100644 lib/zstd/decompress.c create mode 100644 lib/zstd/decompress/huf_decompress.c create mode 100644 lib/zstd/decompress/zstd_ddict.c create mode 100644 lib/zstd/decompress/zstd_ddict.h create mode 100644 lib/zstd/decompress/zstd_decompress.c create mode 100644 lib/zstd/decompress/zstd_decompress_block.c create mode 100644 lib/zstd/decompress/zstd_decompress_block.h create mode 100644 lib/zstd/decompress/zstd_decompress_internal.h create mode 100644 lib/zstd/decompress_sources.h delete mode 100644 lib/zstd/entropy_common.c delete mode 100644 lib/zstd/error_private.h delete mode 100644 lib/zstd/fse.h delete mode 100644 lib/zstd/fse_decompress.c delete mode 100644 lib/zstd/huf.h delete mode 100644 lib/zstd/huf_decompress.c delete mode 100644 lib/zstd/mem.h delete mode 100644 lib/zstd/zstd_common.c create mode 100644 lib/zstd/zstd_common_module.c create mode 100644 lib/zstd/zstd_decompress_module.c delete mode 100644 lib/zstd/zstd_internal.h delete mode 100644 lib/zstd/zstd_opt.h
diff --git a/fs/squashfs/sqfs_decompressor.c b/fs/squashfs/sqfs_decompressor.c index d69ddb24a41..6b3e01cdad7 100644 --- a/fs/squashfs/sqfs_decompressor.c +++ b/fs/squashfs/sqfs_decompressor.c @@ -40,7 +40,7 @@ int sqfs_decompressor_init(struct squashfs_ctxt *ctxt) #endif #if IS_ENABLED(CONFIG_ZSTD) case SQFS_COMP_ZSTD: - ctxt->zstd_workspace = malloc(ZSTD_DCtxWorkspaceBound()); + ctxt->zstd_workspace = malloc(zstd_dctx_workspace_bound()); if (!ctxt->zstd_workspace) return -ENOMEM; break; @@ -99,11 +99,14 @@ static int sqfs_zstd_decompress(struct squashfs_ctxt *ctxt, void *dest, size_t wsize; int ret;
- wsize = ZSTD_DCtxWorkspaceBound(); - ctx = ZSTD_initDCtx(ctxt->zstd_workspace, wsize); - ret = ZSTD_decompressDCtx(ctx, dest, dest_len, source, src_len); + wsize = zstd_dctx_workspace_bound();
- return ZSTD_isError(ret); + ctx = zstd_init_dctx(ctxt->zstd_workspace, wsize); + if (!ctx) + return -EINVAL; + ret = zstd_decompress_dctx(ctx, dest, dest_len, source, src_len); + + return zstd_is_error(ret); } #endif /* CONFIG_ZSTD */
@@ -140,7 +143,7 @@ int sqfs_decompress(struct squashfs_ctxt *ctxt, void *dest, case SQFS_COMP_ZSTD: ret = sqfs_zstd_decompress(ctxt, dest, *dest_len, source, src_len); if (ret) { - printf("ZSTD Error code: %d\n", ZSTD_getErrorCode(ret)); + printf("ZSTD Error code: %d\n", zstd_get_error_code(ret)); return -EINVAL; }
diff --git a/include/linux/zstd.h b/include/linux/zstd.h index aed20fc3bdb..3cf54d11f75 100644 --- a/include/linux/zstd.h +++ b/include/linux/zstd.h @@ -1,128 +1,97 @@ -/* SPDX-License-Identifier: (GPL-2.0 or BSD-3-Clause-Clear) */ +/* SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause */ /* - * Copyright (c) 2016-present, Yann Collet, Facebook, Inc. + * Copyright (c) Yann Collet, Facebook, Inc. * All rights reserved. + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of https://github.com/facebook/zstd) and + * the GPLv2 (found in the COPYING file in the root directory of + * https://github.com/facebook/zstd). You may select, at your option, one of the + * above-listed licenses. */
-#ifndef ZSTD_H -#define ZSTD_H +#ifndef LINUX_ZSTD_H +#define LINUX_ZSTD_H
-/* ====== Dependency ======*/ -#include <linux/types.h> /* size_t */ +/** + * This is a kernel-style API that wraps the upstream zstd API, which cannot be + * used directly because the symbols aren't exported. It exposes the minimal + * functionality which is currently required by users of zstd in the kernel. + * Expose extra functions from lib/zstd/zstd.h as needed. + */
+/* ====== Dependency ====== */ +#include <linux/types.h> +#include <linux/zstd_errors.h> +#include <linux/zstd_lib.h>
-/*-***************************************************************************** - * Introduction +/* ====== Helper Functions ====== */ +/** + * zstd_compress_bound() - maximum compressed size in worst case scenario + * @src_size: The size of the data to compress. * - * zstd, short for Zstandard, is a fast lossless compression algorithm, - * targeting real-time compression scenarios at zlib-level and better - * compression ratios. The zstd compression library provides in-memory - * compression and decompression functions. The library supports compression - * levels from 1 up to ZSTD_maxCLevel() which is 22. Levels >= 20, labeled - * ultra, should be used with caution, as they require more memory. - * Compression can be done in: - * - a single step, reusing a context (described as Explicit memory management) - * - unbounded multiple steps (described as Streaming compression) - * The compression ratio achievable on small data can be highly improved using - * compression with a dictionary in: - * - a single step (described as Simple dictionary API) - * - a single step, reusing a dictionary (described as Fast dictionary API) - ******************************************************************************/ - -/*====== Helper functions ======*/ + * Return: The maximum compressed size in the worst case scenario. + */ +size_t zstd_compress_bound(size_t src_size);
/** - * enum ZSTD_ErrorCode - zstd error codes + * zstd_is_error() - tells if a size_t function result is an error code + * @code: The function result to check for error. * - * Functions that return size_t can be checked for errors using ZSTD_isError() - * and the ZSTD_ErrorCode can be extracted using ZSTD_getErrorCode(). + * Return: Non-zero iff the code is an error. + */ +unsigned int zstd_is_error(size_t code); + +/** + * enum zstd_error_code - zstd error codes */ -typedef enum { - ZSTD_error_no_error, - ZSTD_error_GENERIC, - ZSTD_error_prefix_unknown, - ZSTD_error_version_unsupported, - ZSTD_error_parameter_unknown, - ZSTD_error_frameParameter_unsupported, - ZSTD_error_frameParameter_unsupportedBy32bits, - ZSTD_error_frameParameter_windowTooLarge, - ZSTD_error_compressionParameter_unsupported, - ZSTD_error_init_missing, - ZSTD_error_memory_allocation, - ZSTD_error_stage_wrong, - ZSTD_error_dstSize_tooSmall, - ZSTD_error_srcSize_wrong, - ZSTD_error_corruption_detected, - ZSTD_error_checksum_wrong, - ZSTD_error_tableLog_tooLarge, - ZSTD_error_maxSymbolValue_tooLarge, - ZSTD_error_maxSymbolValue_tooSmall, - ZSTD_error_dictionary_corrupted, - ZSTD_error_dictionary_wrong, - ZSTD_error_dictionaryCreation_failed, - ZSTD_error_maxCode -} ZSTD_ErrorCode; +typedef ZSTD_ErrorCode zstd_error_code;
/** - * ZSTD_maxCLevel() - maximum compression level available + * zstd_get_error_code() - translates an error function result to an error code + * @code: The function result for which zstd_is_error(code) is true. * - * Return: Maximum compression level available. + * Return: A unique error code for this error. */ -int ZSTD_maxCLevel(void); +zstd_error_code zstd_get_error_code(size_t code); + /** - * ZSTD_compressBound() - maximum compressed size in worst case scenario - * @srcSize: The size of the data to compress. + * zstd_get_error_name() - translates an error function result to a string + * @code: The function result for which zstd_is_error(code) is true. * - * Return: The maximum compressed size in the worst case scenario. + * Return: An error string corresponding to the error code. */ -size_t ZSTD_compressBound(size_t srcSize); +const char *zstd_get_error_name(size_t code); + /** - * ZSTD_isError() - tells if a size_t function result is an error code - * @code: The function result to check for error. + * zstd_min_clevel() - minimum allowed compression level * - * Return: Non-zero iff the code is an error. + * Return: The minimum allowed compression level. */ -static __attribute__((unused)) unsigned int ZSTD_isError(size_t code) -{ - return code > (size_t)-ZSTD_error_maxCode; -} +int zstd_min_clevel(void); + /** - * ZSTD_getErrorCode() - translates an error function result to a ZSTD_ErrorCode - * @functionResult: The result of a function for which ZSTD_isError() is true. + * zstd_max_clevel() - maximum allowed compression level * - * Return: The ZSTD_ErrorCode corresponding to the functionResult or 0 - * if the functionResult isn't an error. + * Return: The maximum allowed compression level. */ -static __attribute__((unused)) ZSTD_ErrorCode ZSTD_getErrorCode( - size_t functionResult) -{ - if (!ZSTD_isError(functionResult)) - return (ZSTD_ErrorCode)0; - return (ZSTD_ErrorCode)(0 - functionResult); -} +int zstd_max_clevel(void); + +/* ====== Parameter Selection ====== */
/** - * enum ZSTD_strategy - zstd compression search strategy + * enum zstd_strategy - zstd compression search strategy * - * From faster to stronger. + * From faster to stronger. See zstd_lib.h. */ -typedef enum { - ZSTD_fast, - ZSTD_dfast, - ZSTD_greedy, - ZSTD_lazy, - ZSTD_lazy2, - ZSTD_btlazy2, - ZSTD_btopt, - ZSTD_btopt2 -} ZSTD_strategy; +typedef ZSTD_strategy zstd_strategy;
/** - * struct ZSTD_compressionParameters - zstd compression parameters + * struct zstd_compression_parameters - zstd compression parameters * @windowLog: Log of the largest match distance. Larger means more * compression, and more memory needed during decompression. - * @chainLog: Fully searched segment. Larger means more compression, slower, - * and more memory (useless for fast). + * @chainLog: Fully searched segment. Larger means more compression, + * slower, and more memory (useless for fast). * @hashLog: Dispatch table. Larger means more compression, * slower, and more memory. * @searchLog: Number of searches. Larger means more compression and slower. @@ -131,1018 +100,349 @@ typedef enum { * @targetLength: Acceptable match size for optimal parser (only). Larger means * more compression, and slower. * @strategy: The zstd compression strategy. + * + * See zstd_lib.h. */ -typedef struct { - unsigned int windowLog; - unsigned int chainLog; - unsigned int hashLog; - unsigned int searchLog; - unsigned int searchLength; - unsigned int targetLength; - ZSTD_strategy strategy; -} ZSTD_compressionParameters; +typedef ZSTD_compressionParameters zstd_compression_parameters;
/** - * struct ZSTD_frameParameters - zstd frame parameters - * @contentSizeFlag: Controls whether content size will be present in the frame - * header (when known). - * @checksumFlag: Controls whether a 32-bit checksum is generated at the end - * of the frame for error detection. - * @noDictIDFlag: Controls whether dictID will be saved into the frame header - * when using dictionary compression. + * struct zstd_frame_parameters - zstd frame parameters + * @contentSizeFlag: Controls whether content size will be present in the + * frame header (when known). + * @checksumFlag: Controls whether a 32-bit checksum is generated at the + * end of the frame for error detection. + * @noDictIDFlag: Controls whether dictID will be saved into the frame + * header when using dictionary compression. * - * The default value is all fields set to 0. + * The default value is all fields set to 0. See zstd_lib.h. */ -typedef struct { - unsigned int contentSizeFlag; - unsigned int checksumFlag; - unsigned int noDictIDFlag; -} ZSTD_frameParameters; +typedef ZSTD_frameParameters zstd_frame_parameters;
/** - * struct ZSTD_parameters - zstd parameters + * struct zstd_parameters - zstd parameters * @cParams: The compression parameters. * @fParams: The frame parameters. */ -typedef struct { - ZSTD_compressionParameters cParams; - ZSTD_frameParameters fParams; -} ZSTD_parameters; +typedef ZSTD_parameters zstd_parameters;
/** - * ZSTD_getCParams() - returns ZSTD_compressionParameters for selected level - * @compressionLevel: The compression level from 1 to ZSTD_maxCLevel(). - * @estimatedSrcSize: The estimated source size to compress or 0 if unknown. - * @dictSize: The dictionary size or 0 if a dictionary isn't being used. + * zstd_get_params() - returns zstd_parameters for selected level + * @level: The compression level + * @estimated_src_size: The estimated source size to compress or 0 + * if unknown. * - * Return: The selected ZSTD_compressionParameters. + * Return: The selected zstd_parameters. */ -ZSTD_compressionParameters ZSTD_getCParams(int compressionLevel, - unsigned long long estimatedSrcSize, size_t dictSize); +zstd_parameters zstd_get_params(int level, + unsigned long long estimated_src_size);
-/** - * ZSTD_getParams() - returns ZSTD_parameters for selected level - * @compressionLevel: The compression level from 1 to ZSTD_maxCLevel(). - * @estimatedSrcSize: The estimated source size to compress or 0 if unknown. - * @dictSize: The dictionary size or 0 if a dictionary isn't being used. - * - * The same as ZSTD_getCParams() except also selects the default frame - * parameters (all zero). - * - * Return: The selected ZSTD_parameters. - */ -ZSTD_parameters ZSTD_getParams(int compressionLevel, - unsigned long long estimatedSrcSize, size_t dictSize); +/* ====== Single-pass Compression ====== */
-/*-************************************* - * Explicit memory management - **************************************/ +typedef ZSTD_CCtx zstd_cctx;
/** - * ZSTD_CCtxWorkspaceBound() - amount of memory needed to initialize a ZSTD_CCtx - * @cParams: The compression parameters to be used for compression. + * zstd_cctx_workspace_bound() - max memory needed to initialize a zstd_cctx + * @parameters: The compression parameters to be used. * * If multiple compression parameters might be used, the caller must call - * ZSTD_CCtxWorkspaceBound() for each set of parameters and use the maximum + * zstd_cctx_workspace_bound() for each set of parameters and use the maximum * size. * - * Return: A lower bound on the size of the workspace that is passed to - * ZSTD_initCCtx(). + * Return: A lower bound on the size of the workspace that is passed to + * zstd_init_cctx(). */ -size_t ZSTD_CCtxWorkspaceBound(ZSTD_compressionParameters cParams); +size_t zstd_cctx_workspace_bound(const zstd_compression_parameters *parameters);
/** - * struct ZSTD_CCtx - the zstd compression context - * - * When compressing many times it is recommended to allocate a context just once - * and reuse it for each successive compression operation. - */ -typedef struct ZSTD_CCtx_s ZSTD_CCtx; -/** - * ZSTD_initCCtx() - initialize a zstd compression context - * @workspace: The workspace to emplace the context into. It must outlive - * the returned context. - * @workspaceSize: The size of workspace. Use ZSTD_CCtxWorkspaceBound() to - * determine how large the workspace must be. - * - * Return: A compression context emplaced into workspace. - */ -ZSTD_CCtx *ZSTD_initCCtx(void *workspace, size_t workspaceSize); - -/** - * ZSTD_compressCCtx() - compress src into dst - * @ctx: The context. Must have been initialized with a workspace at - * least as large as ZSTD_CCtxWorkspaceBound(params.cParams). - * @dst: The buffer to compress src into. - * @dstCapacity: The size of the destination buffer. May be any size, but - * ZSTD_compressBound(srcSize) is guaranteed to be large enough. - * @src: The data to compress. - * @srcSize: The size of the data to compress. - * @params: The parameters to use for compression. See ZSTD_getParams(). - * - * Return: The compressed size or an error, which can be checked using - * ZSTD_isError(). - */ -size_t ZSTD_compressCCtx(ZSTD_CCtx *ctx, void *dst, size_t dstCapacity, - const void *src, size_t srcSize, ZSTD_parameters params); - -/** - * ZSTD_DCtxWorkspaceBound() - amount of memory needed to initialize a ZSTD_DCtx - * - * Return: A lower bound on the size of the workspace that is passed to - * ZSTD_initDCtx(). - */ -size_t ZSTD_DCtxWorkspaceBound(void); - -/** - * struct ZSTD_DCtx - the zstd decompression context - * - * When decompressing many times it is recommended to allocate a context just - * once and reuse it for each successive decompression operation. - */ -typedef struct ZSTD_DCtx_s ZSTD_DCtx; -/** - * ZSTD_initDCtx() - initialize a zstd decompression context - * @workspace: The workspace to emplace the context into. It must outlive - * the returned context. - * @workspaceSize: The size of workspace. Use ZSTD_DCtxWorkspaceBound() to - * determine how large the workspace must be. - * - * Return: A decompression context emplaced into workspace. - */ -ZSTD_DCtx *ZSTD_initDCtx(void *workspace, size_t workspaceSize); - -/** - * ZSTD_decompressDCtx() - decompress zstd compressed src into dst - * @ctx: The decompression context. - * @dst: The buffer to decompress src into. - * @dstCapacity: The size of the destination buffer. Must be at least as large - * as the decompressed size. If the caller cannot upper bound the - * decompressed size, then it's better to use the streaming API. - * @src: The zstd compressed data to decompress. Multiple concatenated - * frames and skippable frames are allowed. - * @srcSize: The exact size of the data to decompress. - * - * Return: The decompressed size or an error, which can be checked using - * ZSTD_isError(). - */ -size_t ZSTD_decompressDCtx(ZSTD_DCtx *ctx, void *dst, size_t dstCapacity, - const void *src, size_t srcSize); - -/*-************************ - * Simple dictionary API - **************************/ - -/** - * ZSTD_compress_usingDict() - compress src into dst using a dictionary - * @ctx: The context. Must have been initialized with a workspace at - * least as large as ZSTD_CCtxWorkspaceBound(params.cParams). - * @dst: The buffer to compress src into. - * @dstCapacity: The size of the destination buffer. May be any size, but - * ZSTD_compressBound(srcSize) is guaranteed to be large enough. - * @src: The data to compress. - * @srcSize: The size of the data to compress. - * @dict: The dictionary to use for compression. - * @dictSize: The size of the dictionary. - * @params: The parameters to use for compression. See ZSTD_getParams(). - * - * Compression using a predefined dictionary. The same dictionary must be used - * during decompression. - * - * Return: The compressed size or an error, which can be checked using - * ZSTD_isError(). - */ -size_t ZSTD_compress_usingDict(ZSTD_CCtx *ctx, void *dst, size_t dstCapacity, - const void *src, size_t srcSize, const void *dict, size_t dictSize, - ZSTD_parameters params); - -/** - * ZSTD_decompress_usingDict() - decompress src into dst using a dictionary - * @ctx: The decompression context. - * @dst: The buffer to decompress src into. - * @dstCapacity: The size of the destination buffer. Must be at least as large - * as the decompressed size. If the caller cannot upper bound the - * decompressed size, then it's better to use the streaming API. - * @src: The zstd compressed data to decompress. Multiple concatenated - * frames and skippable frames are allowed. - * @srcSize: The exact size of the data to decompress. - * @dict: The dictionary to use for decompression. The same dictionary - * must've been used to compress the data. - * @dictSize: The size of the dictionary. - * - * Return: The decompressed size or an error, which can be checked using - * ZSTD_isError(). - */ -size_t ZSTD_decompress_usingDict(ZSTD_DCtx *ctx, void *dst, size_t dstCapacity, - const void *src, size_t srcSize, const void *dict, size_t dictSize); - -/*-************************** - * Fast dictionary API - ***************************/ - -/** - * ZSTD_CDictWorkspaceBound() - memory needed to initialize a ZSTD_CDict - * @cParams: The compression parameters to be used for compression. + * zstd_init_cctx() - initialize a zstd compression context + * @workspace: The workspace to emplace the context into. It must outlive + * the returned context. + * @workspace_size: The size of workspace. Use zstd_cctx_workspace_bound() to + * determine how large the workspace must be. * - * Return: A lower bound on the size of the workspace that is passed to - * ZSTD_initCDict(). - */ -size_t ZSTD_CDictWorkspaceBound(ZSTD_compressionParameters cParams); - -/** - * struct ZSTD_CDict - a digested dictionary to be used for compression + * Return: A zstd compression context or NULL on error. */ -typedef struct ZSTD_CDict_s ZSTD_CDict; +zstd_cctx *zstd_init_cctx(void *workspace, size_t workspace_size);
/** - * ZSTD_initCDict() - initialize a digested dictionary for compression - * @dictBuffer: The dictionary to digest. The buffer is referenced by the - * ZSTD_CDict so it must outlive the returned ZSTD_CDict. - * @dictSize: The size of the dictionary. - * @params: The parameters to use for compression. See ZSTD_getParams(). - * @workspace: The workspace. It must outlive the returned ZSTD_CDict. - * @workspaceSize: The workspace size. Must be at least - * ZSTD_CDictWorkspaceBound(params.cParams). + * zstd_compress_cctx() - compress src into dst with the initialized parameters + * @cctx: The context. Must have been initialized with zstd_init_cctx(). + * @dst: The buffer to compress src into. + * @dst_capacity: The size of the destination buffer. May be any size, but + * ZSTD_compressBound(srcSize) is guaranteed to be large enough. + * @src: The data to compress. + * @src_size: The size of the data to compress. + * @parameters: The compression parameters to be used. * - * When compressing multiple messages / blocks with the same dictionary it is - * recommended to load it just once. The ZSTD_CDict merely references the - * dictBuffer, so it must outlive the returned ZSTD_CDict. - * - * Return: The digested dictionary emplaced into workspace. + * Return: The compressed size or an error, which can be checked using + * zstd_is_error(). */ -ZSTD_CDict *ZSTD_initCDict(const void *dictBuffer, size_t dictSize, - ZSTD_parameters params, void *workspace, size_t workspaceSize); +size_t zstd_compress_cctx(zstd_cctx *cctx, void *dst, size_t dst_capacity, + const void *src, size_t src_size, const zstd_parameters *parameters);
-/** - * ZSTD_compress_usingCDict() - compress src into dst using a ZSTD_CDict - * @ctx: The context. Must have been initialized with a workspace at - * least as large as ZSTD_CCtxWorkspaceBound(cParams) where - * cParams are the compression parameters used to initialize the - * cdict. - * @dst: The buffer to compress src into. - * @dstCapacity: The size of the destination buffer. May be any size, but - * ZSTD_compressBound(srcSize) is guaranteed to be large enough. - * @src: The data to compress. - * @srcSize: The size of the data to compress. - * @cdict: The digested dictionary to use for compression. - * @params: The parameters to use for compression. See ZSTD_getParams(). - * - * Compression using a digested dictionary. The same dictionary must be used - * during decompression. - * - * Return: The compressed size or an error, which can be checked using - * ZSTD_isError(). - */ -size_t ZSTD_compress_usingCDict(ZSTD_CCtx *cctx, void *dst, size_t dstCapacity, - const void *src, size_t srcSize, const ZSTD_CDict *cdict); +/* ====== Single-pass Decompression ====== */
+typedef ZSTD_DCtx zstd_dctx;
/** - * ZSTD_DDictWorkspaceBound() - memory needed to initialize a ZSTD_DDict + * zstd_dctx_workspace_bound() - max memory needed to initialize a zstd_dctx * - * Return: A lower bound on the size of the workspace that is passed to - * ZSTD_initDDict(). - */ -size_t ZSTD_DDictWorkspaceBound(void); - -/** - * struct ZSTD_DDict - a digested dictionary to be used for decompression + * Return: A lower bound on the size of the workspace that is passed to + * zstd_init_dctx(). */ -typedef struct ZSTD_DDict_s ZSTD_DDict; +size_t zstd_dctx_workspace_bound(void);
/** - * ZSTD_initDDict() - initialize a digested dictionary for decompression - * @dictBuffer: The dictionary to digest. The buffer is referenced by the - * ZSTD_DDict so it must outlive the returned ZSTD_DDict. - * @dictSize: The size of the dictionary. - * @workspace: The workspace. It must outlive the returned ZSTD_DDict. - * @workspaceSize: The workspace size. Must be at least - * ZSTD_DDictWorkspaceBound(). - * - * When decompressing multiple messages / blocks with the same dictionary it is - * recommended to load it just once. The ZSTD_DDict merely references the - * dictBuffer, so it must outlive the returned ZSTD_DDict. + * zstd_init_dctx() - initialize a zstd decompression context + * @workspace: The workspace to emplace the context into. It must outlive + * the returned context. + * @workspace_size: The size of workspace. Use zstd_dctx_workspace_bound() to + * determine how large the workspace must be. * - * Return: The digested dictionary emplaced into workspace. + * Return: A zstd decompression context or NULL on error. */ -ZSTD_DDict *ZSTD_initDDict(const void *dictBuffer, size_t dictSize, - void *workspace, size_t workspaceSize); +zstd_dctx *zstd_init_dctx(void *workspace, size_t workspace_size);
/** - * ZSTD_decompress_usingDDict() - decompress src into dst using a ZSTD_DDict - * @ctx: The decompression context. - * @dst: The buffer to decompress src into. - * @dstCapacity: The size of the destination buffer. Must be at least as large - * as the decompressed size. If the caller cannot upper bound the - * decompressed size, then it's better to use the streaming API. - * @src: The zstd compressed data to decompress. Multiple concatenated - * frames and skippable frames are allowed. - * @srcSize: The exact size of the data to decompress. - * @ddict: The digested dictionary to use for decompression. The same - * dictionary must've been used to compress the data. + * zstd_decompress_dctx() - decompress zstd compressed src into dst + * @dctx: The decompression context. + * @dst: The buffer to decompress src into. + * @dst_capacity: The size of the destination buffer. Must be at least as large + * as the decompressed size. If the caller cannot upper bound the + * decompressed size, then it's better to use the streaming API. + * @src: The zstd compressed data to decompress. Multiple concatenated + * frames and skippable frames are allowed. + * @src_size: The exact size of the data to decompress. * - * Return: The decompressed size or an error, which can be checked using - * ZSTD_isError(). + * Return: The decompressed size or an error, which can be checked using + * zstd_is_error(). */ -size_t ZSTD_decompress_usingDDict(ZSTD_DCtx *dctx, void *dst, - size_t dstCapacity, const void *src, size_t srcSize, - const ZSTD_DDict *ddict); +size_t zstd_decompress_dctx(zstd_dctx *dctx, void *dst, size_t dst_capacity, + const void *src, size_t src_size);
- -/*-************************** - * Streaming - ***************************/ +/* ====== Streaming Buffers ====== */
/** - * struct ZSTD_inBuffer - input buffer for streaming + * struct zstd_in_buffer - input buffer for streaming * @src: Start of the input buffer. * @size: Size of the input buffer. * @pos: Position where reading stopped. Will be updated. * Necessarily 0 <= pos <= size. + * + * See zstd_lib.h. */ -typedef struct ZSTD_inBuffer_s { - const void *src; - size_t size; - size_t pos; -} ZSTD_inBuffer; +typedef ZSTD_inBuffer zstd_in_buffer;
/** - * struct ZSTD_outBuffer - output buffer for streaming + * struct zstd_out_buffer - output buffer for streaming * @dst: Start of the output buffer. * @size: Size of the output buffer. * @pos: Position where writing stopped. Will be updated. * Necessarily 0 <= pos <= size. + * + * See zstd_lib.h. */ -typedef struct ZSTD_outBuffer_s { - void *dst; - size_t size; - size_t pos; -} ZSTD_outBuffer; +typedef ZSTD_outBuffer zstd_out_buffer;
+/* ====== Streaming Compression ====== */
- -/*-***************************************************************************** - * Streaming compression - HowTo - * - * A ZSTD_CStream object is required to track streaming operation. - * Use ZSTD_initCStream() to initialize a ZSTD_CStream object. - * ZSTD_CStream objects can be reused multiple times on consecutive compression - * operations. It is recommended to re-use ZSTD_CStream in situations where many - * streaming operations will be achieved consecutively. Use one separate - * ZSTD_CStream per thread for parallel execution. - * - * Use ZSTD_compressStream() repetitively to consume input stream. - * The function will automatically update both `pos` fields. - * Note that it may not consume the entire input, in which case `pos < size`, - * and it's up to the caller to present again remaining data. - * It returns a hint for the preferred number of bytes to use as an input for - * the next function call. - * - * At any moment, it's possible to flush whatever data remains within internal - * buffer, using ZSTD_flushStream(). `output->pos` will be updated. There might - * still be some content left within the internal buffer if `output->size` is - * too small. It returns the number of bytes left in the internal buffer and - * must be called until it returns 0. - * - * ZSTD_endStream() instructs to finish a frame. It will perform a flush and - * write frame epilogue. The epilogue is required for decoders to consider a - * frame completed. Similar to ZSTD_flushStream(), it may not be able to flush - * the full content if `output->size` is too small. In which case, call again - * ZSTD_endStream() to complete the flush. It returns the number of bytes left - * in the internal buffer and must be called until it returns 0. - ******************************************************************************/ +typedef ZSTD_CStream zstd_cstream;
/** - * ZSTD_CStreamWorkspaceBound() - memory needed to initialize a ZSTD_CStream - * @cParams: The compression parameters to be used for compression. + * zstd_cstream_workspace_bound() - memory needed to initialize a zstd_cstream + * @cparams: The compression parameters to be used for compression. * * Return: A lower bound on the size of the workspace that is passed to - * ZSTD_initCStream() and ZSTD_initCStream_usingCDict(). - */ -size_t ZSTD_CStreamWorkspaceBound(ZSTD_compressionParameters cParams); - -/** - * struct ZSTD_CStream - the zstd streaming compression context - */ -typedef struct ZSTD_CStream_s ZSTD_CStream; - -/*===== ZSTD_CStream management functions =====*/ -/** - * ZSTD_initCStream() - initialize a zstd streaming compression context - * @params: The zstd compression parameters. - * @pledgedSrcSize: If params.fParams.contentSizeFlag == 1 then the caller must - * pass the source size (zero means empty source). Otherwise, - * the caller may optionally pass the source size, or zero if - * unknown. - * @workspace: The workspace to emplace the context into. It must outlive - * the returned context. - * @workspaceSize: The size of workspace. - * Use ZSTD_CStreamWorkspaceBound(params.cParams) to determine - * how large the workspace must be. - * - * Return: The zstd streaming compression context. + * zstd_init_cstream(). */ -ZSTD_CStream *ZSTD_initCStream(ZSTD_parameters params, - unsigned long long pledgedSrcSize, void *workspace, - size_t workspaceSize); +size_t zstd_cstream_workspace_bound(const zstd_compression_parameters *cparams);
/** - * ZSTD_initCStream_usingCDict() - initialize a streaming compression context - * @cdict: The digested dictionary to use for compression. - * @pledgedSrcSize: Optionally the source size, or zero if unknown. - * @workspace: The workspace to emplace the context into. It must outlive - * the returned context. - * @workspaceSize: The size of workspace. Call ZSTD_CStreamWorkspaceBound() - * with the cParams used to initialize the cdict to determine - * how large the workspace must be. + * zstd_init_cstream() - initialize a zstd streaming compression context + * @parameters The zstd parameters to use for compression. + * @pledged_src_size: If params.fParams.contentSizeFlag == 1 then the caller + * must pass the source size (zero means empty source). + * Otherwise, the caller may optionally pass the source + * size, or zero if unknown. + * @workspace: The workspace to emplace the context into. It must outlive + * the returned context. + * @workspace_size: The size of workspace. + * Use zstd_cstream_workspace_bound(params->cparams) to + * determine how large the workspace must be. * - * Return: The zstd streaming compression context. + * Return: The zstd streaming compression context or NULL on error. */ -ZSTD_CStream *ZSTD_initCStream_usingCDict(const ZSTD_CDict *cdict, - unsigned long long pledgedSrcSize, void *workspace, - size_t workspaceSize); +zstd_cstream *zstd_init_cstream(const zstd_parameters *parameters, + unsigned long long pledged_src_size, void *workspace, size_t workspace_size);
-/*===== Streaming compression functions =====*/ /** - * ZSTD_resetCStream() - reset the context using parameters from creation - * @zcs: The zstd streaming compression context to reset. - * @pledgedSrcSize: Optionally the source size, or zero if unknown. + * zstd_reset_cstream() - reset the context using parameters from creation + * @cstream: The zstd streaming compression context to reset. + * @pledged_src_size: Optionally the source size, or zero if unknown. * * Resets the context using the parameters from creation. Skips dictionary - * loading, since it can be reused. If `pledgedSrcSize` is non-zero the frame + * loading, since it can be reused. If `pledged_src_size` is non-zero the frame * content size is always written into the frame header. * - * Return: Zero or an error, which can be checked using ZSTD_isError(). + * Return: Zero or an error, which can be checked using + * zstd_is_error(). */ -size_t ZSTD_resetCStream(ZSTD_CStream *zcs, unsigned long long pledgedSrcSize); +size_t zstd_reset_cstream(zstd_cstream *cstream, + unsigned long long pledged_src_size); + /** - * ZSTD_compressStream() - streaming compress some of input into output - * @zcs: The zstd streaming compression context. - * @output: Destination buffer. `output->pos` is updated to indicate how much - * compressed data was written. - * @input: Source buffer. `input->pos` is updated to indicate how much data was - * read. Note that it may not consume the entire input, in which case - * `input->pos < input->size`, and it's up to the caller to present - * remaining data again. + * zstd_compress_stream() - streaming compress some of input into output + * @cstream: The zstd streaming compression context. + * @output: Destination buffer. `output->pos` is updated to indicate how much + * compressed data was written. + * @input: Source buffer. `input->pos` is updated to indicate how much data + * was read. Note that it may not consume the entire input, in which + * case `input->pos < input->size`, and it's up to the caller to + * present remaining data again. * * The `input` and `output` buffers may be any size. Guaranteed to make some * forward progress if `input` and `output` are not empty. * - * Return: A hint for the number of bytes to use as the input for the next - * function call or an error, which can be checked using - * ZSTD_isError(). + * Return: A hint for the number of bytes to use as the input for the next + * function call or an error, which can be checked using + * zstd_is_error(). */ -size_t ZSTD_compressStream(ZSTD_CStream *zcs, ZSTD_outBuffer *output, - ZSTD_inBuffer *input); +size_t zstd_compress_stream(zstd_cstream *cstream, zstd_out_buffer *output, + zstd_in_buffer *input); + /** - * ZSTD_flushStream() - flush internal buffers into output - * @zcs: The zstd streaming compression context. - * @output: Destination buffer. `output->pos` is updated to indicate how much - * compressed data was written. + * zstd_flush_stream() - flush internal buffers into output + * @cstream: The zstd streaming compression context. + * @output: Destination buffer. `output->pos` is updated to indicate how much + * compressed data was written. * - * ZSTD_flushStream() must be called until it returns 0, meaning all the data - * has been flushed. Since ZSTD_flushStream() causes a block to be ended, + * zstd_flush_stream() must be called until it returns 0, meaning all the data + * has been flushed. Since zstd_flush_stream() causes a block to be ended, * calling it too often will degrade the compression ratio. * - * Return: The number of bytes still present within internal buffers or an - * error, which can be checked using ZSTD_isError(). + * Return: The number of bytes still present within internal buffers or an + * error, which can be checked using zstd_is_error(). */ -size_t ZSTD_flushStream(ZSTD_CStream *zcs, ZSTD_outBuffer *output); -/** - * ZSTD_endStream() - flush internal buffers into output and end the frame - * @zcs: The zstd streaming compression context. - * @output: Destination buffer. `output->pos` is updated to indicate how much - * compressed data was written. - * - * ZSTD_endStream() must be called until it returns 0, meaning all the data has - * been flushed and the frame epilogue has been written. - * - * Return: The number of bytes still present within internal buffers or an - * error, which can be checked using ZSTD_isError(). - */ -size_t ZSTD_endStream(ZSTD_CStream *zcs, ZSTD_outBuffer *output); +size_t zstd_flush_stream(zstd_cstream *cstream, zstd_out_buffer *output);
/** - * ZSTD_CStreamInSize() - recommended size for the input buffer - * - * Return: The recommended size for the input buffer. - */ -size_t ZSTD_CStreamInSize(void); -/** - * ZSTD_CStreamOutSize() - recommended size for the output buffer + * zstd_end_stream() - flush internal buffers into output and end the frame + * @cstream: The zstd streaming compression context. + * @output: Destination buffer. `output->pos` is updated to indicate how much + * compressed data was written. * - * When the output buffer is at least this large, it is guaranteed to be large - * enough to flush at least one complete compressed block. + * zstd_end_stream() must be called until it returns 0, meaning all the data has + * been flushed and the frame epilogue has been written. * - * Return: The recommended size for the output buffer. + * Return: The number of bytes still present within internal buffers or an + * error, which can be checked using zstd_is_error(). */ -size_t ZSTD_CStreamOutSize(void); +size_t zstd_end_stream(zstd_cstream *cstream, zstd_out_buffer *output);
+/* ====== Streaming Decompression ====== */
- -/*-***************************************************************************** - * Streaming decompression - HowTo - * - * A ZSTD_DStream object is required to track streaming operations. - * Use ZSTD_initDStream() to initialize a ZSTD_DStream object. - * ZSTD_DStream objects can be re-used multiple times. - * - * Use ZSTD_decompressStream() repetitively to consume your input. - * The function will update both `pos` fields. - * If `input->pos < input->size`, some input has not been consumed. - * It's up to the caller to present again remaining data. - * If `output->pos < output->size`, decoder has flushed everything it could. - * Returns 0 iff a frame is completely decoded and fully flushed. - * Otherwise it returns a suggested next input size that will never load more - * than the current frame. - ******************************************************************************/ +typedef ZSTD_DStream zstd_dstream;
/** - * ZSTD_DStreamWorkspaceBound() - memory needed to initialize a ZSTD_DStream - * @maxWindowSize: The maximum window size allowed for compressed frames. + * zstd_dstream_workspace_bound() - memory needed to initialize a zstd_dstream + * @max_window_size: The maximum window size allowed for compressed frames. * - * Return: A lower bound on the size of the workspace that is passed to - * ZSTD_initDStream() and ZSTD_initDStream_usingDDict(). + * Return: A lower bound on the size of the workspace that is passed + * to zstd_init_dstream(). */ -size_t ZSTD_DStreamWorkspaceBound(size_t maxWindowSize); +size_t zstd_dstream_workspace_bound(size_t max_window_size);
/** - * struct ZSTD_DStream - the zstd streaming decompression context - */ -typedef struct ZSTD_DStream_s ZSTD_DStream; -/*===== ZSTD_DStream management functions =====*/ -/** - * ZSTD_initDStream() - initialize a zstd streaming decompression context - * @maxWindowSize: The maximum window size allowed for compressed frames. - * @workspace: The workspace to emplace the context into. It must outlive - * the returned context. - * @workspaceSize: The size of workspace. - * Use ZSTD_DStreamWorkspaceBound(maxWindowSize) to determine - * how large the workspace must be. - * - * Return: The zstd streaming decompression context. - */ -ZSTD_DStream *ZSTD_initDStream(size_t maxWindowSize, void *workspace, - size_t workspaceSize); -/** - * ZSTD_initDStream_usingDDict() - initialize streaming decompression context - * @maxWindowSize: The maximum window size allowed for compressed frames. - * @ddict: The digested dictionary to use for decompression. - * @workspace: The workspace to emplace the context into. It must outlive - * the returned context. - * @workspaceSize: The size of workspace. - * Use ZSTD_DStreamWorkspaceBound(maxWindowSize) to determine - * how large the workspace must be. + * zstd_init_dstream() - initialize a zstd streaming decompression context + * @max_window_size: The maximum window size allowed for compressed frames. + * @workspace: The workspace to emplace the context into. It must outlive + * the returned context. + * @workspaceSize: The size of workspace. + * Use zstd_dstream_workspace_bound(max_window_size) to + * determine how large the workspace must be. * - * Return: The zstd streaming decompression context. + * Return: The zstd streaming decompression context. */ -ZSTD_DStream *ZSTD_initDStream_usingDDict(size_t maxWindowSize, - const ZSTD_DDict *ddict, void *workspace, size_t workspaceSize); +zstd_dstream *zstd_init_dstream(size_t max_window_size, void *workspace, + size_t workspace_size);
-/*===== Streaming decompression functions =====*/ /** - * ZSTD_resetDStream() - reset the context using parameters from creation - * @zds: The zstd streaming decompression context to reset. + * zstd_reset_dstream() - reset the context using parameters from creation + * @dstream: The zstd streaming decompression context to reset. * * Resets the context using the parameters from creation. Skips dictionary * loading, since it can be reused. * - * Return: Zero or an error, which can be checked using ZSTD_isError(). + * Return: Zero or an error, which can be checked using zstd_is_error(). */ -size_t ZSTD_resetDStream(ZSTD_DStream *zds); +size_t zstd_reset_dstream(zstd_dstream *dstream); + /** - * ZSTD_decompressStream() - streaming decompress some of input into output - * @zds: The zstd streaming decompression context. - * @output: Destination buffer. `output.pos` is updated to indicate how much - * decompressed data was written. - * @input: Source buffer. `input.pos` is updated to indicate how much data was - * read. Note that it may not consume the entire input, in which case - * `input.pos < input.size`, and it's up to the caller to present - * remaining data again. + * zstd_decompress_stream() - streaming decompress some of input into output + * @dstream: The zstd streaming decompression context. + * @output: Destination buffer. `output.pos` is updated to indicate how much + * decompressed data was written. + * @input: Source buffer. `input.pos` is updated to indicate how much data was + * read. Note that it may not consume the entire input, in which case + * `input.pos < input.size`, and it's up to the caller to present + * remaining data again. * * The `input` and `output` buffers may be any size. Guaranteed to make some * forward progress if `input` and `output` are not empty. - * ZSTD_decompressStream() will not consume the last byte of the frame until + * zstd_decompress_stream() will not consume the last byte of the frame until * the entire frame is flushed. * - * Return: Returns 0 iff a frame is completely decoded and fully flushed. - * Otherwise returns a hint for the number of bytes to use as the input - * for the next function call or an error, which can be checked using - * ZSTD_isError(). The size hint will never load more than the frame. + * Return: Returns 0 iff a frame is completely decoded and fully flushed. + * Otherwise returns a hint for the number of bytes to use as the + * input for the next function call or an error, which can be checked + * using zstd_is_error(). The size hint will never load more than the + * frame. */ -size_t ZSTD_decompressStream(ZSTD_DStream *zds, ZSTD_outBuffer *output, - ZSTD_inBuffer *input); +size_t zstd_decompress_stream(zstd_dstream *dstream, zstd_out_buffer *output, + zstd_in_buffer *input);
-/** - * ZSTD_DStreamInSize() - recommended size for the input buffer - * - * Return: The recommended size for the input buffer. - */ -size_t ZSTD_DStreamInSize(void); -/** - * ZSTD_DStreamOutSize() - recommended size for the output buffer - * - * When the output buffer is at least this large, it is guaranteed to be large - * enough to flush at least one complete decompressed block. - * - * Return: The recommended size for the output buffer. - */ -size_t ZSTD_DStreamOutSize(void); - - -/* --- Constants ---*/ -#define ZSTD_MAGICNUMBER 0xFD2FB528 /* >= v0.8.0 */ -#define ZSTD_MAGIC_SKIPPABLE_START 0x184D2A50U - -#define ZSTD_CONTENTSIZE_UNKNOWN (0ULL - 1) -#define ZSTD_CONTENTSIZE_ERROR (0ULL - 2) - -#define ZSTD_WINDOWLOG_MAX_32 27 -#define ZSTD_WINDOWLOG_MAX_64 27 -#define ZSTD_WINDOWLOG_MAX \ - ((unsigned int)(sizeof(size_t) == 4 \ - ? ZSTD_WINDOWLOG_MAX_32 \ - : ZSTD_WINDOWLOG_MAX_64)) -#define ZSTD_WINDOWLOG_MIN 10 -#define ZSTD_HASHLOG_MAX ZSTD_WINDOWLOG_MAX -#define ZSTD_HASHLOG_MIN 6 -#define ZSTD_CHAINLOG_MAX (ZSTD_WINDOWLOG_MAX+1) -#define ZSTD_CHAINLOG_MIN ZSTD_HASHLOG_MIN -#define ZSTD_HASHLOG3_MAX 17 -#define ZSTD_SEARCHLOG_MAX (ZSTD_WINDOWLOG_MAX-1) -#define ZSTD_SEARCHLOG_MIN 1 -/* only for ZSTD_fast, other strategies are limited to 6 */ -#define ZSTD_SEARCHLENGTH_MAX 7 -/* only for ZSTD_btopt, other strategies are limited to 4 */ -#define ZSTD_SEARCHLENGTH_MIN 3 -#define ZSTD_TARGETLENGTH_MIN 4 -#define ZSTD_TARGETLENGTH_MAX 999 - -/* for static allocation */ -#define ZSTD_FRAMEHEADERSIZE_MAX 18 -#define ZSTD_FRAMEHEADERSIZE_MIN 6 -static const size_t ZSTD_frameHeaderSize_prefix = 5; -static const size_t ZSTD_frameHeaderSize_min = ZSTD_FRAMEHEADERSIZE_MIN; -static const size_t ZSTD_frameHeaderSize_max = ZSTD_FRAMEHEADERSIZE_MAX; -/* magic number + skippable frame length */ -static const size_t ZSTD_skippableHeaderSize = 8; - - -/*-************************************* - * Compressed size functions - **************************************/ - -/** - * ZSTD_findFrameCompressedSize() - returns the size of a compressed frame - * @src: Source buffer. It should point to the start of a zstd encoded frame - * or a skippable frame. - * @srcSize: The size of the source buffer. It must be at least as large as the - * size of the frame. - * - * Return: The compressed size of the frame pointed to by `src` or an error, - * which can be check with ZSTD_isError(). - * Suitable to pass to ZSTD_decompress() or similar functions. - */ -size_t ZSTD_findFrameCompressedSize(const void *src, size_t srcSize); - -/*-************************************* - * Decompressed size functions - **************************************/ -/** - * ZSTD_getFrameContentSize() - returns the content size in a zstd frame header - * @src: It should point to the start of a zstd encoded frame. - * @srcSize: The size of the source buffer. It must be at least as large as the - * frame header. `ZSTD_frameHeaderSize_max` is always large enough. - * - * Return: The frame content size stored in the frame header if known. - * `ZSTD_CONTENTSIZE_UNKNOWN` if the content size isn't stored in the - * frame header. `ZSTD_CONTENTSIZE_ERROR` on invalid input. - */ -unsigned long long ZSTD_getFrameContentSize(const void *src, size_t srcSize); +/* ====== Frame Inspection Functions ====== */
/** - * ZSTD_findDecompressedSize() - returns decompressed size of a series of frames - * @src: It should point to the start of a series of zstd encoded and/or - * skippable frames. - * @srcSize: The exact size of the series of frames. + * zstd_find_frame_compressed_size() - returns the size of a compressed frame + * @src: Source buffer. It should point to the start of a zstd encoded + * frame or a skippable frame. + * @src_size: The size of the source buffer. It must be at least as large as the + * size of the frame. * - * If any zstd encoded frame in the series doesn't have the frame content size - * set, `ZSTD_CONTENTSIZE_UNKNOWN` is returned. But frame content size is always - * set when using ZSTD_compress(). The decompressed size can be very large. - * If the source is untrusted, the decompressed size could be wrong or - * intentionally modified. Always ensure the result fits within the - * application's authorized limits. ZSTD_findDecompressedSize() handles multiple - * frames, and so it must traverse the input to read each frame header. This is - * efficient as most of the data is skipped, however it does mean that all frame - * data must be present and valid. - * - * Return: Decompressed size of all the data contained in the frames if known. - * `ZSTD_CONTENTSIZE_UNKNOWN` if the decompressed size is unknown. - * `ZSTD_CONTENTSIZE_ERROR` if an error occurred. - */ -unsigned long long ZSTD_findDecompressedSize(const void *src, size_t srcSize); - -/*-************************************* - * Advanced compression functions - **************************************/ -/** - * ZSTD_checkCParams() - ensure parameter values remain within authorized range - * @cParams: The zstd compression parameters. - * - * Return: Zero or an error, which can be checked using ZSTD_isError(). + * Return: The compressed size of the frame pointed to by `src` or an error, + * which can be check with zstd_is_error(). + * Suitable to pass to ZSTD_decompress() or similar functions. */ -size_t ZSTD_checkCParams(ZSTD_compressionParameters cParams); +size_t zstd_find_frame_compressed_size(const void *src, size_t src_size);
/** - * ZSTD_adjustCParams() - optimize parameters for a given srcSize and dictSize - * @srcSize: Optionally the estimated source size, or zero if unknown. - * @dictSize: Optionally the estimated dictionary size, or zero if unknown. - * - * Return: The optimized parameters. - */ -ZSTD_compressionParameters ZSTD_adjustCParams( - ZSTD_compressionParameters cParams, unsigned long long srcSize, - size_t dictSize); - -/*--- Advanced decompression functions ---*/ - -/** - * ZSTD_isFrame() - returns true iff the buffer starts with a valid frame - * @buffer: The source buffer to check. - * @size: The size of the source buffer, must be at least 4 bytes. - * - * Return: True iff the buffer starts with a zstd or skippable frame identifier. - */ -unsigned int ZSTD_isFrame(const void *buffer, size_t size); - -/** - * ZSTD_getDictID_fromDict() - returns the dictionary id stored in a dictionary - * @dict: The dictionary buffer. - * @dictSize: The size of the dictionary buffer. - * - * Return: The dictionary id stored within the dictionary or 0 if the - * dictionary is not a zstd dictionary. If it returns 0 the - * dictionary can still be loaded as a content-only dictionary. - */ -unsigned int ZSTD_getDictID_fromDict(const void *dict, size_t dictSize); - -/** - * ZSTD_getDictID_fromDDict() - returns the dictionary id stored in a ZSTD_DDict - * @ddict: The ddict to find the id of. - * - * Return: The dictionary id stored within `ddict` or 0 if the dictionary is not - * a zstd dictionary. If it returns 0 `ddict` will be loaded as a - * content-only dictionary. - */ -unsigned int ZSTD_getDictID_fromDDict(const ZSTD_DDict *ddict); - -/** - * ZSTD_getDictID_fromFrame() - returns the dictionary id stored in a zstd frame - * @src: Source buffer. It must be a zstd encoded frame. - * @srcSize: The size of the source buffer. It must be at least as large as the - * frame header. `ZSTD_frameHeaderSize_max` is always large enough. - * - * Return: The dictionary id required to decompress the frame stored within - * `src` or 0 if the dictionary id could not be decoded. It can return - * 0 if the frame does not require a dictionary, the dictionary id - * wasn't stored in the frame, `src` is not a zstd frame, or `srcSize` - * is too small. - */ -unsigned int ZSTD_getDictID_fromFrame(const void *src, size_t srcSize); - -/** - * struct ZSTD_frameParams - zstd frame parameters stored in the frame header - * @frameContentSize: The frame content size, or 0 if not present. + * struct zstd_frame_params - zstd frame parameters stored in the frame header + * @frameContentSize: The frame content size, or ZSTD_CONTENTSIZE_UNKNOWN if not + * present. * @windowSize: The window size, or 0 if the frame is a skippable frame. + * @blockSizeMax: The maximum block size. + * @frameType: The frame type (zstd or skippable) + * @headerSize: The size of the frame header. * @dictID: The dictionary id, or 0 if not present. * @checksumFlag: Whether a checksum was used. + * + * See zstd_lib.h. */ -typedef struct { - unsigned long long frameContentSize; - unsigned int windowSize; - unsigned int dictID; - unsigned int checksumFlag; -} ZSTD_frameParams; +typedef ZSTD_frameHeader zstd_frame_header;
/** - * ZSTD_getFrameParams() - extracts parameters from a zstd or skippable frame - * @fparamsPtr: On success the frame parameters are written here. - * @src: The source buffer. It must point to a zstd or skippable frame. - * @srcSize: The size of the source buffer. `ZSTD_frameHeaderSize_max` is - * always large enough to succeed. + * zstd_get_frame_header() - extracts parameters from a zstd or skippable frame + * @params: On success the frame parameters are written here. + * @src: The source buffer. It must point to a zstd or skippable frame. + * @src_size: The size of the source buffer. * - * Return: 0 on success. If more data is required it returns how many bytes - * must be provided to make forward progress. Otherwise it returns - * an error, which can be checked using ZSTD_isError(). + * Return: 0 on success. If more data is required it returns how many bytes + * must be provided to make forward progress. Otherwise it returns + * an error, which can be checked using zstd_is_error(). */ -size_t ZSTD_getFrameParams(ZSTD_frameParams *fparamsPtr, const void *src, - size_t srcSize); - -/*-***************************************************************************** - * Buffer-less and synchronous inner streaming functions - * - * This is an advanced API, giving full control over buffer management, for - * users which need direct control over memory. - * But it's also a complex one, with many restrictions (documented below). - * Prefer using normal streaming API for an easier experience - ******************************************************************************/ - -/*-***************************************************************************** - * Buffer-less streaming compression (synchronous mode) - * - * A ZSTD_CCtx object is required to track streaming operations. - * Use ZSTD_initCCtx() to initialize a context. - * ZSTD_CCtx object can be re-used multiple times within successive compression - * operations. - * - * Start by initializing a context. - * Use ZSTD_compressBegin(), or ZSTD_compressBegin_usingDict() for dictionary - * compression, - * or ZSTD_compressBegin_advanced(), for finer parameter control. - * It's also possible to duplicate a reference context which has already been - * initialized, using ZSTD_copyCCtx() - * - * Then, consume your input using ZSTD_compressContinue(). - * There are some important considerations to keep in mind when using this - * advanced function : - * - ZSTD_compressContinue() has no internal buffer. It uses externally provided - * buffer only. - * - Interface is synchronous : input is consumed entirely and produce 1+ - * (or more) compressed blocks. - * - Caller must ensure there is enough space in `dst` to store compressed data - * under worst case scenario. Worst case evaluation is provided by - * ZSTD_compressBound(). - * ZSTD_compressContinue() doesn't guarantee recover after a failed - * compression. - * - ZSTD_compressContinue() presumes prior input ***is still accessible and - * unmodified*** (up to maximum distance size, see WindowLog). - * It remembers all previous contiguous blocks, plus one separated memory - * segment (which can itself consists of multiple contiguous blocks) - * - ZSTD_compressContinue() detects that prior input has been overwritten when - * `src` buffer overlaps. In which case, it will "discard" the relevant memory - * section from its history. - * - * Finish a frame with ZSTD_compressEnd(), which will write the last block(s) - * and optional checksum. It's possible to use srcSize==0, in which case, it - * will write a final empty block to end the frame. Without last block mark, - * frames will be considered unfinished (corrupted) by decoders. - * - * `ZSTD_CCtx` object can be re-used (ZSTD_compressBegin()) to compress some new - * frame. - ******************************************************************************/ - -/*===== Buffer-less streaming compression functions =====*/ -size_t ZSTD_compressBegin(ZSTD_CCtx *cctx, int compressionLevel); -size_t ZSTD_compressBegin_usingDict(ZSTD_CCtx *cctx, const void *dict, - size_t dictSize, int compressionLevel); -size_t ZSTD_compressBegin_advanced(ZSTD_CCtx *cctx, const void *dict, - size_t dictSize, ZSTD_parameters params, - unsigned long long pledgedSrcSize); -size_t ZSTD_copyCCtx(ZSTD_CCtx *cctx, const ZSTD_CCtx *preparedCCtx, - unsigned long long pledgedSrcSize); -size_t ZSTD_compressBegin_usingCDict(ZSTD_CCtx *cctx, const ZSTD_CDict *cdict, - unsigned long long pledgedSrcSize); -size_t ZSTD_compressContinue(ZSTD_CCtx *cctx, void *dst, size_t dstCapacity, - const void *src, size_t srcSize); -size_t ZSTD_compressEnd(ZSTD_CCtx *cctx, void *dst, size_t dstCapacity, - const void *src, size_t srcSize); - - - -/*-***************************************************************************** - * Buffer-less streaming decompression (synchronous mode) - * - * A ZSTD_DCtx object is required to track streaming operations. - * Use ZSTD_initDCtx() to initialize a context. - * A ZSTD_DCtx object can be re-used multiple times. - * - * First typical operation is to retrieve frame parameters, using - * ZSTD_getFrameParams(). It fills a ZSTD_frameParams structure which provide - * important information to correctly decode the frame, such as the minimum - * rolling buffer size to allocate to decompress data (`windowSize`), and the - * dictionary ID used. - * Note: content size is optional, it may not be present. 0 means unknown. - * Note that these values could be wrong, either because of data malformation, - * or because an attacker is spoofing deliberate false information. As a - * consequence, check that values remain within valid application range, - * especially `windowSize`, before allocation. Each application can set its own - * limit, depending on local restrictions. For extended interoperability, it is - * recommended to support at least 8 MB. - * Frame parameters are extracted from the beginning of the compressed frame. - * Data fragment must be large enough to ensure successful decoding, typically - * `ZSTD_frameHeaderSize_max` bytes. - * Result: 0: successful decoding, the `ZSTD_frameParams` structure is filled. - * >0: `srcSize` is too small, provide at least this many bytes. - * errorCode, which can be tested using ZSTD_isError(). - * - * Start decompression, with ZSTD_decompressBegin() or - * ZSTD_decompressBegin_usingDict(). Alternatively, you can copy a prepared - * context, using ZSTD_copyDCtx(). - * - * Then use ZSTD_nextSrcSizeToDecompress() and ZSTD_decompressContinue() - * alternatively. - * ZSTD_nextSrcSizeToDecompress() tells how many bytes to provide as 'srcSize' - * to ZSTD_decompressContinue(). - * ZSTD_decompressContinue() requires this _exact_ amount of bytes, or it will - * fail. - * - * The result of ZSTD_decompressContinue() is the number of bytes regenerated - * within 'dst' (necessarily <= dstCapacity). It can be zero, which is not an - * error; it just means ZSTD_decompressContinue() has decoded some metadata - * item. It can also be an error code, which can be tested with ZSTD_isError(). - * - * ZSTD_decompressContinue() needs previous data blocks during decompression, up - * to `windowSize`. They should preferably be located contiguously, prior to - * current block. Alternatively, a round buffer of sufficient size is also - * possible. Sufficient size is determined by frame parameters. - * ZSTD_decompressContinue() is very sensitive to contiguity, if 2 blocks don't - * follow each other, make sure that either the compressor breaks contiguity at - * the same place, or that previous contiguous segment is large enough to - * properly handle maximum back-reference. - * - * A frame is fully decoded when ZSTD_nextSrcSizeToDecompress() returns zero. - * Context can then be reset to start a new decompression. - * - * Note: it's possible to know if next input to present is a header or a block, - * using ZSTD_nextInputType(). This information is not required to properly - * decode a frame. - * - * == Special case: skippable frames == - * - * Skippable frames allow integration of user-defined data into a flow of - * concatenated frames. Skippable frames will be ignored (skipped) by a - * decompressor. The format of skippable frames is as follows: - * a) Skippable frame ID - 4 Bytes, Little endian format, any value from - * 0x184D2A50 to 0x184D2A5F - * b) Frame Size - 4 Bytes, Little endian format, unsigned 32-bits - * c) Frame Content - any content (User Data) of length equal to Frame Size - * For skippable frames ZSTD_decompressContinue() always returns 0. - * For skippable frames ZSTD_getFrameParams() returns fparamsPtr->windowLog==0 - * what means that a frame is skippable. - * Note: If fparamsPtr->frameContentSize==0, it is ambiguous: the frame might - * actually be a zstd encoded frame with no content. For purposes of - * decompression, it is valid in both cases to skip the frame using - * ZSTD_findFrameCompressedSize() to find its size in bytes. - * It also returns frame size as fparamsPtr->frameContentSize. - ******************************************************************************/ - -/*===== Buffer-less streaming decompression functions =====*/ -size_t ZSTD_decompressBegin(ZSTD_DCtx *dctx); -size_t ZSTD_decompressBegin_usingDict(ZSTD_DCtx *dctx, const void *dict, - size_t dictSize); -void ZSTD_copyDCtx(ZSTD_DCtx *dctx, const ZSTD_DCtx *preparedDCtx); -size_t ZSTD_nextSrcSizeToDecompress(ZSTD_DCtx *dctx); -size_t ZSTD_decompressContinue(ZSTD_DCtx *dctx, void *dst, size_t dstCapacity, - const void *src, size_t srcSize); -typedef enum { - ZSTDnit_frameHeader, - ZSTDnit_blockHeader, - ZSTDnit_block, - ZSTDnit_lastBlock, - ZSTDnit_checksum, - ZSTDnit_skippableFrame -} ZSTD_nextInputType_e; -ZSTD_nextInputType_e ZSTD_nextInputType(ZSTD_DCtx *dctx); - -/*-***************************************************************************** - * Block functions - * - * Block functions produce and decode raw zstd blocks, without frame metadata. - * Frame metadata cost is typically ~18 bytes, which can be non-negligible for - * very small blocks (< 100 bytes). User will have to take in charge required - * information to regenerate data, such as compressed and content sizes. - * - * A few rules to respect: - * - Compressing and decompressing require a context structure - * + Use ZSTD_initCCtx() and ZSTD_initDCtx() - * - It is necessary to init context before starting - * + compression : ZSTD_compressBegin() - * + decompression : ZSTD_decompressBegin() - * + variants _usingDict() are also allowed - * + copyCCtx() and copyDCtx() work too - * - Block size is limited, it must be <= ZSTD_getBlockSizeMax() - * + If you need to compress more, cut data into multiple blocks - * + Consider using the regular ZSTD_compress() instead, as frame metadata - * costs become negligible when source size is large. - * - When a block is considered not compressible enough, ZSTD_compressBlock() - * result will be zero. In which case, nothing is produced into `dst`. - * + User must test for such outcome and deal directly with uncompressed data - * + ZSTD_decompressBlock() doesn't accept uncompressed data as input!!! - * + In case of multiple successive blocks, decoder must be informed of - * uncompressed block existence to follow proper history. Use - * ZSTD_insertBlock() in such a case. - ******************************************************************************/ - -/* Define for static allocation */ -#define ZSTD_BLOCKSIZE_ABSOLUTEMAX (128 * 1024) -/*===== Raw zstd block functions =====*/ -size_t ZSTD_getBlockSizeMax(ZSTD_CCtx *cctx); -size_t ZSTD_compressBlock(ZSTD_CCtx *cctx, void *dst, size_t dstCapacity, - const void *src, size_t srcSize); -size_t ZSTD_decompressBlock(ZSTD_DCtx *dctx, void *dst, size_t dstCapacity, - const void *src, size_t srcSize); -size_t ZSTD_insertBlock(ZSTD_DCtx *dctx, const void *blockStart, - size_t blockSize); +size_t zstd_get_frame_header(zstd_frame_header *params, const void *src, + size_t src_size);
struct abuf;
@@ -1155,4 +455,4 @@ struct abuf; */ int zstd_decompress(struct abuf *in, struct abuf *out);
-#endif /* ZSTD_H */ +#endif /* LINUX_ZSTD_H */ diff --git a/include/linux/zstd_errors.h b/include/linux/zstd_errors.h new file mode 100644 index 00000000000..58b6dd45a96 --- /dev/null +++ b/include/linux/zstd_errors.h @@ -0,0 +1,77 @@ +/* + * Copyright (c) Yann Collet, Facebook, Inc. + * All rights reserved. + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. + */ + +#ifndef ZSTD_ERRORS_H_398273423 +#define ZSTD_ERRORS_H_398273423 + + +/*===== dependency =====*/ +#include <linux/types.h> /* size_t */ + + +/* ===== ZSTDERRORLIB_API : control library symbols visibility ===== */ +#define ZSTDERRORLIB_VISIBILITY +#define ZSTDERRORLIB_API ZSTDERRORLIB_VISIBILITY + +/*-********************************************* + * Error codes list + *-********************************************* + * Error codes _values_ are pinned down since v1.3.1 only. + * Therefore, don't rely on values if you may link to any version < v1.3.1. + * + * Only values < 100 are considered stable. + * + * note 1 : this API shall be used with static linking only. + * dynamic linking is not yet officially supported. + * note 2 : Prefer relying on the enum than on its value whenever possible + * This is the only supported way to use the error list < v1.3.1 + * note 3 : ZSTD_isError() is always correct, whatever the library version. + **********************************************/ +typedef enum { + ZSTD_error_no_error = 0, + ZSTD_error_GENERIC = 1, + ZSTD_error_prefix_unknown = 10, + ZSTD_error_version_unsupported = 12, + ZSTD_error_frameParameter_unsupported = 14, + ZSTD_error_frameParameter_windowTooLarge = 16, + ZSTD_error_corruption_detected = 20, + ZSTD_error_checksum_wrong = 22, + ZSTD_error_dictionary_corrupted = 30, + ZSTD_error_dictionary_wrong = 32, + ZSTD_error_dictionaryCreation_failed = 34, + ZSTD_error_parameter_unsupported = 40, + ZSTD_error_parameter_outOfBound = 42, + ZSTD_error_tableLog_tooLarge = 44, + ZSTD_error_maxSymbolValue_tooLarge = 46, + ZSTD_error_maxSymbolValue_tooSmall = 48, + ZSTD_error_stage_wrong = 60, + ZSTD_error_init_missing = 62, + ZSTD_error_memory_allocation = 64, + ZSTD_error_workSpace_tooSmall= 66, + ZSTD_error_dstSize_tooSmall = 70, + ZSTD_error_srcSize_wrong = 72, + ZSTD_error_dstBuffer_null = 74, + /* following error codes are __NOT STABLE__, they can be removed or changed in future versions */ + ZSTD_error_frameIndex_tooLarge = 100, + ZSTD_error_seekableIO = 102, + ZSTD_error_dstBuffer_wrong = 104, + ZSTD_error_srcBuffer_wrong = 105, + ZSTD_error_maxCode = 120 /* never EVER use this value directly, it can change in future versions! Use ZSTD_isError() instead */ +} ZSTD_ErrorCode; + +/*! ZSTD_getErrorCode() : + convert a `size_t` function result into a `ZSTD_ErrorCode` enum type, + which can be used to compare with enum list published above */ +ZSTDERRORLIB_API ZSTD_ErrorCode ZSTD_getErrorCode(size_t functionResult); +ZSTDERRORLIB_API const char* ZSTD_getErrorString(ZSTD_ErrorCode code); /*< Same as ZSTD_getErrorName, but using a `ZSTD_ErrorCode` enum argument */ + + + +#endif /* ZSTD_ERRORS_H_398273423 */ diff --git a/include/linux/zstd_lib.h b/include/linux/zstd_lib.h new file mode 100644 index 00000000000..70605fd2832 --- /dev/null +++ b/include/linux/zstd_lib.h @@ -0,0 +1,2551 @@ +/* + * Copyright (c) Yann Collet, Facebook, Inc. + * All rights reserved. + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. + */ + +#ifndef ZSTD_H_235446 +#define ZSTD_H_235446 + +/* ====== Dependency ======*/ +#include <linux/kernel.h> /* INT_MAX */ +#include <linux/types.h> /* size_t */ + + +/* ===== ZSTDLIB_API : control library symbols visibility ===== */ +#ifndef ZSTDLIB_VISIBLE +# if (__GNUC__ >= 4) && !defined(__MINGW32__) +# define ZSTDLIB_VISIBLE __attribute__ ((visibility ("default"))) +# define ZSTDLIB_HIDDEN __attribute__ ((visibility ("hidden"))) +# else +# define ZSTDLIB_VISIBLE +# define ZSTDLIB_HIDDEN +# endif +#endif +#define ZSTDLIB_API ZSTDLIB_VISIBLE + + +/* ***************************************************************************** + Introduction + + zstd, short for Zstandard, is a fast lossless compression algorithm, targeting + real-time compression scenarios at zlib-level and better compression ratios. + The zstd compression library provides in-memory compression and decompression + functions. + + The library supports regular compression levels from 1 up to ZSTD_maxCLevel(), + which is currently 22. Levels >= 20, labeled `--ultra`, should be used with + caution, as they require more memory. The library also offers negative + compression levels, which extend the range of speed vs. ratio preferences. + The lower the level, the faster the speed (at the cost of compression). + + Compression can be done in: + - a single step (described as Simple API) + - a single step, reusing a context (described as Explicit context) + - unbounded multiple steps (described as Streaming compression) + + The compression ratio achievable on small data can be highly improved using + a dictionary. Dictionary compression can be performed in: + - a single step (described as Simple dictionary API) + - a single step, reusing a dictionary (described as Bulk-processing + dictionary API) + + Advanced experimental functions can be accessed using + `#define ZSTD_STATIC_LINKING_ONLY` before including zstd.h. + + Advanced experimental APIs should never be used with a dynamically-linked + library. They are not "stable"; their definitions or signatures may change in + the future. Only static linking is allowed. +*******************************************************************************/ + +/*------ Version ------*/ +#define ZSTD_VERSION_MAJOR 1 +#define ZSTD_VERSION_MINOR 5 +#define ZSTD_VERSION_RELEASE 2 +#define ZSTD_VERSION_NUMBER (ZSTD_VERSION_MAJOR *100*100 + ZSTD_VERSION_MINOR *100 + ZSTD_VERSION_RELEASE) + +/*! ZSTD_versionNumber() : + * Return runtime library version, the value is (MAJOR*100*100 + MINOR*100 + RELEASE). */ +ZSTDLIB_API unsigned ZSTD_versionNumber(void); + +#define ZSTD_LIB_VERSION ZSTD_VERSION_MAJOR.ZSTD_VERSION_MINOR.ZSTD_VERSION_RELEASE +#define ZSTD_QUOTE(str) #str +#define ZSTD_EXPAND_AND_QUOTE(str) ZSTD_QUOTE(str) +#define ZSTD_VERSION_STRING ZSTD_EXPAND_AND_QUOTE(ZSTD_LIB_VERSION) + +/*! ZSTD_versionString() : + * Return runtime library version, like "1.4.5". Requires v1.3.0+. */ +ZSTDLIB_API const char* ZSTD_versionString(void); + +/* ************************************* + * Default constant + ***************************************/ +#ifndef ZSTD_CLEVEL_DEFAULT +# define ZSTD_CLEVEL_DEFAULT 3 +#endif + +/* ************************************* + * Constants + ***************************************/ + +/* All magic numbers are supposed read/written to/from files/memory using little-endian convention */ +#define ZSTD_MAGICNUMBER 0xFD2FB528 /* valid since v0.8.0 */ +#define ZSTD_MAGIC_DICTIONARY 0xEC30A437 /* valid since v0.7.0 */ +#define ZSTD_MAGIC_SKIPPABLE_START 0x184D2A50 /* all 16 values, from 0x184D2A50 to 0x184D2A5F, signal the beginning of a skippable frame */ +#define ZSTD_MAGIC_SKIPPABLE_MASK 0xFFFFFFF0 + +#define ZSTD_BLOCKSIZELOG_MAX 17 +#define ZSTD_BLOCKSIZE_MAX (1<<ZSTD_BLOCKSIZELOG_MAX) + + +/* ************************************* +* Simple API +***************************************/ +/*! ZSTD_compress() : + * Compresses `src` content as a single zstd compressed frame into already allocated `dst`. + * Hint : compression runs faster if `dstCapacity` >= `ZSTD_compressBound(srcSize)`. + * @return : compressed size written into `dst` (<= `dstCapacity), + * or an error code if it fails (which can be tested using ZSTD_isError()). */ +ZSTDLIB_API size_t ZSTD_compress( void* dst, size_t dstCapacity, + const void* src, size_t srcSize, + int compressionLevel); + +/*! ZSTD_decompress() : + * `compressedSize` : must be the _exact_ size of some number of compressed and/or skippable frames. + * `dstCapacity` is an upper bound of originalSize to regenerate. + * If user cannot imply a maximum upper bound, it's better to use streaming mode to decompress data. + * @return : the number of bytes decompressed into `dst` (<= `dstCapacity`), + * or an errorCode if it fails (which can be tested using ZSTD_isError()). */ +ZSTDLIB_API size_t ZSTD_decompress( void* dst, size_t dstCapacity, + const void* src, size_t compressedSize); + +/*! ZSTD_getFrameContentSize() : requires v1.3.0+ + * `src` should point to the start of a ZSTD encoded frame. + * `srcSize` must be at least as large as the frame header. + * hint : any size >= `ZSTD_frameHeaderSize_max` is large enough. + * @return : - decompressed size of `src` frame content, if known + * - ZSTD_CONTENTSIZE_UNKNOWN if the size cannot be determined + * - ZSTD_CONTENTSIZE_ERROR if an error occurred (e.g. invalid magic number, srcSize too small) + * note 1 : a 0 return value means the frame is valid but "empty". + * note 2 : decompressed size is an optional field, it may not be present, typically in streaming mode. + * When `return==ZSTD_CONTENTSIZE_UNKNOWN`, data to decompress could be any size. + * In which case, it's necessary to use streaming mode to decompress data. + * Optionally, application can rely on some implicit limit, + * as ZSTD_decompress() only needs an upper bound of decompressed size. + * (For example, data could be necessarily cut into blocks <= 16 KB). + * note 3 : decompressed size is always present when compression is completed using single-pass functions, + * such as ZSTD_compress(), ZSTD_compressCCtx() ZSTD_compress_usingDict() or ZSTD_compress_usingCDict(). + * note 4 : decompressed size can be very large (64-bits value), + * potentially larger than what local system can handle as a single memory segment. + * In which case, it's necessary to use streaming mode to decompress data. + * note 5 : If source is untrusted, decompressed size could be wrong or intentionally modified. + * Always ensure return value fits within application's authorized limits. + * Each application can set its own limits. + * note 6 : This function replaces ZSTD_getDecompressedSize() */ +#define ZSTD_CONTENTSIZE_UNKNOWN (0ULL - 1) +#define ZSTD_CONTENTSIZE_ERROR (0ULL - 2) +ZSTDLIB_API unsigned long long ZSTD_getFrameContentSize(const void *src, size_t srcSize); + +/*! ZSTD_getDecompressedSize() : + * NOTE: This function is now obsolete, in favor of ZSTD_getFrameContentSize(). + * Both functions work the same way, but ZSTD_getDecompressedSize() blends + * "empty", "unknown" and "error" results to the same return value (0), + * while ZSTD_getFrameContentSize() gives them separate return values. + * @return : decompressed size of `src` frame content _if known and not empty_, 0 otherwise. */ +ZSTDLIB_API unsigned long long ZSTD_getDecompressedSize(const void* src, size_t srcSize); + +/*! ZSTD_findFrameCompressedSize() : Requires v1.4.0+ + * `src` should point to the start of a ZSTD frame or skippable frame. + * `srcSize` must be >= first frame size + * @return : the compressed size of the first frame starting at `src`, + * suitable to pass as `srcSize` to `ZSTD_decompress` or similar, + * or an error code if input is invalid */ +ZSTDLIB_API size_t ZSTD_findFrameCompressedSize(const void* src, size_t srcSize); + + +/*====== Helper functions ======*/ +#define ZSTD_COMPRESSBOUND(srcSize) ((srcSize) + ((srcSize)>>8) + (((srcSize) < (128<<10)) ? (((128<<10) - (srcSize)) >> 11) /* margin, from 64 to 0 */ : 0)) /* this formula ensures that bound(A) + bound(B) <= bound(A+B) as long as A and B >= 128 KB */ +ZSTDLIB_API size_t ZSTD_compressBound(size_t srcSize); /*!< maximum compressed size in worst case single-pass scenario */ +ZSTDLIB_API unsigned ZSTD_isError(size_t code); /*!< tells if a `size_t` function result is an error code */ +ZSTDLIB_API const char* ZSTD_getErrorName(size_t code); /*!< provides readable string from an error code */ +ZSTDLIB_API int ZSTD_minCLevel(void); /*!< minimum negative compression level allowed, requires v1.4.0+ */ +ZSTDLIB_API int ZSTD_maxCLevel(void); /*!< maximum compression level available */ +ZSTDLIB_API int ZSTD_defaultCLevel(void); /*!< default compression level, specified by ZSTD_CLEVEL_DEFAULT, requires v1.5.0+ */ + + +/* ************************************* +* Explicit context +***************************************/ +/*= Compression context + * When compressing many times, + * it is recommended to allocate a context just once, + * and re-use it for each successive compression operation. + * This will make workload friendlier for system's memory. + * Note : re-using context is just a speed / resource optimization. + * It doesn't change the compression ratio, which remains identical. + * Note 2 : In multi-threaded environments, + * use one different context per thread for parallel execution. + */ +typedef struct ZSTD_CCtx_s ZSTD_CCtx; +ZSTDLIB_API ZSTD_CCtx* ZSTD_createCCtx(void); +ZSTDLIB_API size_t ZSTD_freeCCtx(ZSTD_CCtx* cctx); /* accept NULL pointer */ + +/*! ZSTD_compressCCtx() : + * Same as ZSTD_compress(), using an explicit ZSTD_CCtx. + * Important : in order to behave similarly to `ZSTD_compress()`, + * this function compresses at requested compression level, + * __ignoring any other parameter__ . + * If any advanced parameter was set using the advanced API, + * they will all be reset. Only `compressionLevel` remains. + */ +ZSTDLIB_API size_t ZSTD_compressCCtx(ZSTD_CCtx* cctx, + void* dst, size_t dstCapacity, + const void* src, size_t srcSize, + int compressionLevel); + +/*= Decompression context + * When decompressing many times, + * it is recommended to allocate a context only once, + * and re-use it for each successive compression operation. + * This will make workload friendlier for system's memory. + * Use one context per thread for parallel execution. */ +typedef struct ZSTD_DCtx_s ZSTD_DCtx; +ZSTDLIB_API ZSTD_DCtx* ZSTD_createDCtx(void); +ZSTDLIB_API size_t ZSTD_freeDCtx(ZSTD_DCtx* dctx); /* accept NULL pointer */ + +/*! ZSTD_decompressDCtx() : + * Same as ZSTD_decompress(), + * requires an allocated ZSTD_DCtx. + * Compatible with sticky parameters. + */ +ZSTDLIB_API size_t ZSTD_decompressDCtx(ZSTD_DCtx* dctx, + void* dst, size_t dstCapacity, + const void* src, size_t srcSize); + + +/* ******************************************* +* Advanced compression API (Requires v1.4.0+) +**********************************************/ + +/* API design : + * Parameters are pushed one by one into an existing context, + * using ZSTD_CCtx_set*() functions. + * Pushed parameters are sticky : they are valid for next compressed frame, and any subsequent frame. + * "sticky" parameters are applicable to `ZSTD_compress2()` and `ZSTD_compressStream*()` ! + * __They do not apply to "simple" one-shot variants such as ZSTD_compressCCtx()__ . + * + * It's possible to reset all parameters to "default" using ZSTD_CCtx_reset(). + * + * This API supersedes all other "advanced" API entry points in the experimental section. + * In the future, we expect to remove from experimental API entry points which are redundant with this API. + */ + + +/* Compression strategies, listed from fastest to strongest */ +typedef enum { ZSTD_fast=1, + ZSTD_dfast=2, + ZSTD_greedy=3, + ZSTD_lazy=4, + ZSTD_lazy2=5, + ZSTD_btlazy2=6, + ZSTD_btopt=7, + ZSTD_btultra=8, + ZSTD_btultra2=9 + /* note : new strategies _might_ be added in the future. + Only the order (from fast to strong) is guaranteed */ +} ZSTD_strategy; + +typedef enum { + + /* compression parameters + * Note: When compressing with a ZSTD_CDict these parameters are superseded + * by the parameters used to construct the ZSTD_CDict. + * See ZSTD_CCtx_refCDict() for more info (superseded-by-cdict). */ + ZSTD_c_compressionLevel=100, /* Set compression parameters according to pre-defined cLevel table. + * Note that exact compression parameters are dynamically determined, + * depending on both compression level and srcSize (when known). + * Default level is ZSTD_CLEVEL_DEFAULT==3. + * Special: value 0 means default, which is controlled by ZSTD_CLEVEL_DEFAULT. + * Note 1 : it's possible to pass a negative compression level. + * Note 2 : setting a level does not automatically set all other compression parameters + * to default. Setting this will however eventually dynamically impact the compression + * parameters which have not been manually set. The manually set + * ones will 'stick'. */ + /* Advanced compression parameters : + * It's possible to pin down compression parameters to some specific values. + * In which case, these values are no longer dynamically selected by the compressor */ + ZSTD_c_windowLog=101, /* Maximum allowed back-reference distance, expressed as power of 2. + * This will set a memory budget for streaming decompression, + * with larger values requiring more memory + * and typically compressing more. + * Must be clamped between ZSTD_WINDOWLOG_MIN and ZSTD_WINDOWLOG_MAX. + * Special: value 0 means "use default windowLog". + * Note: Using a windowLog greater than ZSTD_WINDOWLOG_LIMIT_DEFAULT + * requires explicitly allowing such size at streaming decompression stage. */ + ZSTD_c_hashLog=102, /* Size of the initial probe table, as a power of 2. + * Resulting memory usage is (1 << (hashLog+2)). + * Must be clamped between ZSTD_HASHLOG_MIN and ZSTD_HASHLOG_MAX. + * Larger tables improve compression ratio of strategies <= dFast, + * and improve speed of strategies > dFast. + * Special: value 0 means "use default hashLog". */ + ZSTD_c_chainLog=103, /* Size of the multi-probe search table, as a power of 2. + * Resulting memory usage is (1 << (chainLog+2)). + * Must be clamped between ZSTD_CHAINLOG_MIN and ZSTD_CHAINLOG_MAX. + * Larger tables result in better and slower compression. + * This parameter is useless for "fast" strategy. + * It's still useful when using "dfast" strategy, + * in which case it defines a secondary probe table. + * Special: value 0 means "use default chainLog". */ + ZSTD_c_searchLog=104, /* Number of search attempts, as a power of 2. + * More attempts result in better and slower compression. + * This parameter is useless for "fast" and "dFast" strategies. + * Special: value 0 means "use default searchLog". */ + ZSTD_c_minMatch=105, /* Minimum size of searched matches. + * Note that Zstandard can still find matches of smaller size, + * it just tweaks its search algorithm to look for this size and larger. + * Larger values increase compression and decompression speed, but decrease ratio. + * Must be clamped between ZSTD_MINMATCH_MIN and ZSTD_MINMATCH_MAX. + * Note that currently, for all strategies < btopt, effective minimum is 4. + * , for all strategies > fast, effective maximum is 6. + * Special: value 0 means "use default minMatchLength". */ + ZSTD_c_targetLength=106, /* Impact of this field depends on strategy. + * For strategies btopt, btultra & btultra2: + * Length of Match considered "good enough" to stop search. + * Larger values make compression stronger, and slower. + * For strategy fast: + * Distance between match sampling. + * Larger values make compression faster, and weaker. + * Special: value 0 means "use default targetLength". */ + ZSTD_c_strategy=107, /* See ZSTD_strategy enum definition. + * The higher the value of selected strategy, the more complex it is, + * resulting in stronger and slower compression. + * Special: value 0 means "use default strategy". */ + /* LDM mode parameters */ + ZSTD_c_enableLongDistanceMatching=160, /* Enable long distance matching. + * This parameter is designed to improve compression ratio + * for large inputs, by finding large matches at long distance. + * It increases memory usage and window size. + * Note: enabling this parameter increases default ZSTD_c_windowLog to 128 MB + * except when expressly set to a different value. + * Note: will be enabled by default if ZSTD_c_windowLog >= 128 MB and + * compression strategy >= ZSTD_btopt (== compression level 16+) */ + ZSTD_c_ldmHashLog=161, /* Size of the table for long distance matching, as a power of 2. + * Larger values increase memory usage and compression ratio, + * but decrease compression speed. + * Must be clamped between ZSTD_HASHLOG_MIN and ZSTD_HASHLOG_MAX + * default: windowlog - 7. + * Special: value 0 means "automatically determine hashlog". */ + ZSTD_c_ldmMinMatch=162, /* Minimum match size for long distance matcher. + * Larger/too small values usually decrease compression ratio. + * Must be clamped between ZSTD_LDM_MINMATCH_MIN and ZSTD_LDM_MINMATCH_MAX. + * Special: value 0 means "use default value" (default: 64). */ + ZSTD_c_ldmBucketSizeLog=163, /* Log size of each bucket in the LDM hash table for collision resolution. + * Larger values improve collision resolution but decrease compression speed. + * The maximum value is ZSTD_LDM_BUCKETSIZELOG_MAX. + * Special: value 0 means "use default value" (default: 3). */ + ZSTD_c_ldmHashRateLog=164, /* Frequency of inserting/looking up entries into the LDM hash table. + * Must be clamped between 0 and (ZSTD_WINDOWLOG_MAX - ZSTD_HASHLOG_MIN). + * Default is MAX(0, (windowLog - ldmHashLog)), optimizing hash table usage. + * Larger values improve compression speed. + * Deviating far from default value will likely result in a compression ratio decrease. + * Special: value 0 means "automatically determine hashRateLog". */ + + /* frame parameters */ + ZSTD_c_contentSizeFlag=200, /* Content size will be written into frame header _whenever known_ (default:1) + * Content size must be known at the beginning of compression. + * This is automatically the case when using ZSTD_compress2(), + * For streaming scenarios, content size must be provided with ZSTD_CCtx_setPledgedSrcSize() */ + ZSTD_c_checksumFlag=201, /* A 32-bits checksum of content is written at end of frame (default:0) */ + ZSTD_c_dictIDFlag=202, /* When applicable, dictionary's ID is written into frame header (default:1) */ + + /* multi-threading parameters */ + /* These parameters are only active if multi-threading is enabled (compiled with build macro ZSTD_MULTITHREAD). + * Otherwise, trying to set any other value than default (0) will be a no-op and return an error. + * In a situation where it's unknown if the linked library supports multi-threading or not, + * setting ZSTD_c_nbWorkers to any value >= 1 and consulting the return value provides a quick way to check this property. + */ + ZSTD_c_nbWorkers=400, /* Select how many threads will be spawned to compress in parallel. + * When nbWorkers >= 1, triggers asynchronous mode when invoking ZSTD_compressStream*() : + * ZSTD_compressStream*() consumes input and flush output if possible, but immediately gives back control to caller, + * while compression is performed in parallel, within worker thread(s). + * (note : a strong exception to this rule is when first invocation of ZSTD_compressStream2() sets ZSTD_e_end : + * in which case, ZSTD_compressStream2() delegates to ZSTD_compress2(), which is always a blocking call). + * More workers improve speed, but also increase memory usage. + * Default value is `0`, aka "single-threaded mode" : no worker is spawned, + * compression is performed inside Caller's thread, and all invocations are blocking */ + ZSTD_c_jobSize=401, /* Size of a compression job. This value is enforced only when nbWorkers >= 1. + * Each compression job is completed in parallel, so this value can indirectly impact the nb of active threads. + * 0 means default, which is dynamically determined based on compression parameters. + * Job size must be a minimum of overlap size, or ZSTDMT_JOBSIZE_MIN (= 512 KB), whichever is largest. + * The minimum size is automatically and transparently enforced. */ + ZSTD_c_overlapLog=402, /* Control the overlap size, as a fraction of window size. + * The overlap size is an amount of data reloaded from previous job at the beginning of a new job. + * It helps preserve compression ratio, while each job is compressed in parallel. + * This value is enforced only when nbWorkers >= 1. + * Larger values increase compression ratio, but decrease speed. + * Possible values range from 0 to 9 : + * - 0 means "default" : value will be determined by the library, depending on strategy + * - 1 means "no overlap" + * - 9 means "full overlap", using a full window size. + * Each intermediate rank increases/decreases load size by a factor 2 : + * 9: full window; 8: w/2; 7: w/4; 6: w/8; 5:w/16; 4: w/32; 3:w/64; 2:w/128; 1:no overlap; 0:default + * default value varies between 6 and 9, depending on strategy */ + + /* note : additional experimental parameters are also available + * within the experimental section of the API. + * At the time of this writing, they include : + * ZSTD_c_rsyncable + * ZSTD_c_format + * ZSTD_c_forceMaxWindow + * ZSTD_c_forceAttachDict + * ZSTD_c_literalCompressionMode + * ZSTD_c_targetCBlockSize + * ZSTD_c_srcSizeHint + * ZSTD_c_enableDedicatedDictSearch + * ZSTD_c_stableInBuffer + * ZSTD_c_stableOutBuffer + * ZSTD_c_blockDelimiters + * ZSTD_c_validateSequences + * ZSTD_c_useBlockSplitter + * ZSTD_c_useRowMatchFinder + * Because they are not stable, it's necessary to define ZSTD_STATIC_LINKING_ONLY to access them. + * note : never ever use experimentalParam? names directly; + * also, the enums values themselves are unstable and can still change. + */ + ZSTD_c_experimentalParam1=500, + ZSTD_c_experimentalParam2=10, + ZSTD_c_experimentalParam3=1000, + ZSTD_c_experimentalParam4=1001, + ZSTD_c_experimentalParam5=1002, + ZSTD_c_experimentalParam6=1003, + ZSTD_c_experimentalParam7=1004, + ZSTD_c_experimentalParam8=1005, + ZSTD_c_experimentalParam9=1006, + ZSTD_c_experimentalParam10=1007, + ZSTD_c_experimentalParam11=1008, + ZSTD_c_experimentalParam12=1009, + ZSTD_c_experimentalParam13=1010, + ZSTD_c_experimentalParam14=1011, + ZSTD_c_experimentalParam15=1012 +} ZSTD_cParameter; + +typedef struct { + size_t error; + int lowerBound; + int upperBound; +} ZSTD_bounds; + +/*! ZSTD_cParam_getBounds() : + * All parameters must belong to an interval with lower and upper bounds, + * otherwise they will either trigger an error or be automatically clamped. + * @return : a structure, ZSTD_bounds, which contains + * - an error status field, which must be tested using ZSTD_isError() + * - lower and upper bounds, both inclusive + */ +ZSTDLIB_API ZSTD_bounds ZSTD_cParam_getBounds(ZSTD_cParameter cParam); + +/*! ZSTD_CCtx_setParameter() : + * Set one compression parameter, selected by enum ZSTD_cParameter. + * All parameters have valid bounds. Bounds can be queried using ZSTD_cParam_getBounds(). + * Providing a value beyond bound will either clamp it, or trigger an error (depending on parameter). + * Setting a parameter is generally only possible during frame initialization (before starting compression). + * Exception : when using multi-threading mode (nbWorkers >= 1), + * the following parameters can be updated _during_ compression (within same frame): + * => compressionLevel, hashLog, chainLog, searchLog, minMatch, targetLength and strategy. + * new parameters will be active for next job only (after a flush()). + * @return : an error code (which can be tested using ZSTD_isError()). + */ +ZSTDLIB_API size_t ZSTD_CCtx_setParameter(ZSTD_CCtx* cctx, ZSTD_cParameter param, int value); + +/*! ZSTD_CCtx_setPledgedSrcSize() : + * Total input data size to be compressed as a single frame. + * Value will be written in frame header, unless if explicitly forbidden using ZSTD_c_contentSizeFlag. + * This value will also be controlled at end of frame, and trigger an error if not respected. + * @result : 0, or an error code (which can be tested with ZSTD_isError()). + * Note 1 : pledgedSrcSize==0 actually means zero, aka an empty frame. + * In order to mean "unknown content size", pass constant ZSTD_CONTENTSIZE_UNKNOWN. + * ZSTD_CONTENTSIZE_UNKNOWN is default value for any new frame. + * Note 2 : pledgedSrcSize is only valid once, for the next frame. + * It's discarded at the end of the frame, and replaced by ZSTD_CONTENTSIZE_UNKNOWN. + * Note 3 : Whenever all input data is provided and consumed in a single round, + * for example with ZSTD_compress2(), + * or invoking immediately ZSTD_compressStream2(,,,ZSTD_e_end), + * this value is automatically overridden by srcSize instead. + */ +ZSTDLIB_API size_t ZSTD_CCtx_setPledgedSrcSize(ZSTD_CCtx* cctx, unsigned long long pledgedSrcSize); + +typedef enum { + ZSTD_reset_session_only = 1, + ZSTD_reset_parameters = 2, + ZSTD_reset_session_and_parameters = 3 +} ZSTD_ResetDirective; + +/*! ZSTD_CCtx_reset() : + * There are 2 different things that can be reset, independently or jointly : + * - The session : will stop compressing current frame, and make CCtx ready to start a new one. + * Useful after an error, or to interrupt any ongoing compression. + * Any internal data not yet flushed is cancelled. + * Compression parameters and dictionary remain unchanged. + * They will be used to compress next frame. + * Resetting session never fails. + * - The parameters : changes all parameters back to "default". + * This removes any reference to any dictionary too. + * Parameters can only be changed between 2 sessions (i.e. no compression is currently ongoing) + * otherwise the reset fails, and function returns an error value (which can be tested using ZSTD_isError()) + * - Both : similar to resetting the session, followed by resetting parameters. + */ +ZSTDLIB_API size_t ZSTD_CCtx_reset(ZSTD_CCtx* cctx, ZSTD_ResetDirective reset); + +/*! ZSTD_compress2() : + * Behave the same as ZSTD_compressCCtx(), but compression parameters are set using the advanced API. + * ZSTD_compress2() always starts a new frame. + * Should cctx hold data from a previously unfinished frame, everything about it is forgotten. + * - Compression parameters are pushed into CCtx before starting compression, using ZSTD_CCtx_set*() + * - The function is always blocking, returns when compression is completed. + * Hint : compression runs faster if `dstCapacity` >= `ZSTD_compressBound(srcSize)`. + * @return : compressed size written into `dst` (<= `dstCapacity), + * or an error code if it fails (which can be tested using ZSTD_isError()). + */ +ZSTDLIB_API size_t ZSTD_compress2( ZSTD_CCtx* cctx, + void* dst, size_t dstCapacity, + const void* src, size_t srcSize); + + +/* ********************************************* +* Advanced decompression API (Requires v1.4.0+) +************************************************/ + +/* The advanced API pushes parameters one by one into an existing DCtx context. + * Parameters are sticky, and remain valid for all following frames + * using the same DCtx context. + * It's possible to reset parameters to default values using ZSTD_DCtx_reset(). + * Note : This API is compatible with existing ZSTD_decompressDCtx() and ZSTD_decompressStream(). + * Therefore, no new decompression function is necessary. + */ + +typedef enum { + + ZSTD_d_windowLogMax=100, /* Select a size limit (in power of 2) beyond which + * the streaming API will refuse to allocate memory buffer + * in order to protect the host from unreasonable memory requirements. + * This parameter is only useful in streaming mode, since no internal buffer is allocated in single-pass mode. + * By default, a decompression context accepts window sizes <= (1 << ZSTD_WINDOWLOG_LIMIT_DEFAULT). + * Special: value 0 means "use default maximum windowLog". */ + + /* note : additional experimental parameters are also available + * within the experimental section of the API. + * At the time of this writing, they include : + * ZSTD_d_format + * ZSTD_d_stableOutBuffer + * ZSTD_d_forceIgnoreChecksum + * ZSTD_d_refMultipleDDicts + * Because they are not stable, it's necessary to define ZSTD_STATIC_LINKING_ONLY to access them. + * note : never ever use experimentalParam? names directly + */ + ZSTD_d_experimentalParam1=1000, + ZSTD_d_experimentalParam2=1001, + ZSTD_d_experimentalParam3=1002, + ZSTD_d_experimentalParam4=1003 + +} ZSTD_dParameter; + +/*! ZSTD_dParam_getBounds() : + * All parameters must belong to an interval with lower and upper bounds, + * otherwise they will either trigger an error or be automatically clamped. + * @return : a structure, ZSTD_bounds, which contains + * - an error status field, which must be tested using ZSTD_isError() + * - both lower and upper bounds, inclusive + */ +ZSTDLIB_API ZSTD_bounds ZSTD_dParam_getBounds(ZSTD_dParameter dParam); + +/*! ZSTD_DCtx_setParameter() : + * Set one compression parameter, selected by enum ZSTD_dParameter. + * All parameters have valid bounds. Bounds can be queried using ZSTD_dParam_getBounds(). + * Providing a value beyond bound will either clamp it, or trigger an error (depending on parameter). + * Setting a parameter is only possible during frame initialization (before starting decompression). + * @return : 0, or an error code (which can be tested using ZSTD_isError()). + */ +ZSTDLIB_API size_t ZSTD_DCtx_setParameter(ZSTD_DCtx* dctx, ZSTD_dParameter param, int value); + +/*! ZSTD_DCtx_reset() : + * Return a DCtx to clean state. + * Session and parameters can be reset jointly or separately. + * Parameters can only be reset when no active frame is being decompressed. + * @return : 0, or an error code, which can be tested with ZSTD_isError() + */ +ZSTDLIB_API size_t ZSTD_DCtx_reset(ZSTD_DCtx* dctx, ZSTD_ResetDirective reset); + + +/* ************************** +* Streaming +****************************/ + +typedef struct ZSTD_inBuffer_s { + const void* src; /*< start of input buffer */ + size_t size; /*< size of input buffer */ + size_t pos; /*< position where reading stopped. Will be updated. Necessarily 0 <= pos <= size */ +} ZSTD_inBuffer; + +typedef struct ZSTD_outBuffer_s { + void* dst; /*< start of output buffer */ + size_t size; /*< size of output buffer */ + size_t pos; /*< position where writing stopped. Will be updated. Necessarily 0 <= pos <= size */ +} ZSTD_outBuffer; + + + +/*-*********************************************************************** +* Streaming compression - HowTo +* +* A ZSTD_CStream object is required to track streaming operation. +* Use ZSTD_createCStream() and ZSTD_freeCStream() to create/release resources. +* ZSTD_CStream objects can be reused multiple times on consecutive compression operations. +* It is recommended to re-use ZSTD_CStream since it will play nicer with system's memory, by re-using already allocated memory. +* +* For parallel execution, use one separate ZSTD_CStream per thread. +* +* note : since v1.3.0, ZSTD_CStream and ZSTD_CCtx are the same thing. +* +* Parameters are sticky : when starting a new compression on the same context, +* it will re-use the same sticky parameters as previous compression session. +* When in doubt, it's recommended to fully initialize the context before usage. +* Use ZSTD_CCtx_reset() to reset the context and ZSTD_CCtx_setParameter(), +* ZSTD_CCtx_setPledgedSrcSize(), or ZSTD_CCtx_loadDictionary() and friends to +* set more specific parameters, the pledged source size, or load a dictionary. +* +* Use ZSTD_compressStream2() with ZSTD_e_continue as many times as necessary to +* consume input stream. The function will automatically update both `pos` +* fields within `input` and `output`. +* Note that the function may not consume the entire input, for example, because +* the output buffer is already full, in which case `input.pos < input.size`. +* The caller must check if input has been entirely consumed. +* If not, the caller must make some room to receive more compressed data, +* and then present again remaining input data. +* note: ZSTD_e_continue is guaranteed to make some forward progress when called, +* but doesn't guarantee maximal forward progress. This is especially relevant +* when compressing with multiple threads. The call won't block if it can +* consume some input, but if it can't it will wait for some, but not all, +* output to be flushed. +* @return : provides a minimum amount of data remaining to be flushed from internal buffers +* or an error code, which can be tested using ZSTD_isError(). +* +* At any moment, it's possible to flush whatever data might remain stuck within internal buffer, +* using ZSTD_compressStream2() with ZSTD_e_flush. `output->pos` will be updated. +* Note that, if `output->size` is too small, a single invocation with ZSTD_e_flush might not be enough (return code > 0). +* In which case, make some room to receive more compressed data, and call again ZSTD_compressStream2() with ZSTD_e_flush. +* You must continue calling ZSTD_compressStream2() with ZSTD_e_flush until it returns 0, at which point you can change the +* operation. +* note: ZSTD_e_flush will flush as much output as possible, meaning when compressing with multiple threads, it will +* block until the flush is complete or the output buffer is full. +* @return : 0 if internal buffers are entirely flushed, +* >0 if some data still present within internal buffer (the value is minimal estimation of remaining size), +* or an error code, which can be tested using ZSTD_isError(). +* +* Calling ZSTD_compressStream2() with ZSTD_e_end instructs to finish a frame. +* It will perform a flush and write frame epilogue. +* The epilogue is required for decoders to consider a frame completed. +* flush operation is the same, and follows same rules as calling ZSTD_compressStream2() with ZSTD_e_flush. +* You must continue calling ZSTD_compressStream2() with ZSTD_e_end until it returns 0, at which point you are free to +* start a new frame. +* note: ZSTD_e_end will flush as much output as possible, meaning when compressing with multiple threads, it will +* block until the flush is complete or the output buffer is full. +* @return : 0 if frame fully completed and fully flushed, +* >0 if some data still present within internal buffer (the value is minimal estimation of remaining size), +* or an error code, which can be tested using ZSTD_isError(). +* +* *******************************************************************/ + +typedef ZSTD_CCtx ZSTD_CStream; /*< CCtx and CStream are now effectively same object (>= v1.3.0) */ + /* Continue to distinguish them for compatibility with older versions <= v1.2.0 */ +/*===== ZSTD_CStream management functions =====*/ +ZSTDLIB_API ZSTD_CStream* ZSTD_createCStream(void); +ZSTDLIB_API size_t ZSTD_freeCStream(ZSTD_CStream* zcs); /* accept NULL pointer */ + +/*===== Streaming compression functions =====*/ +typedef enum { + ZSTD_e_continue=0, /* collect more data, encoder decides when to output compressed result, for optimal compression ratio */ + ZSTD_e_flush=1, /* flush any data provided so far, + * it creates (at least) one new block, that can be decoded immediately on reception; + * frame will continue: any future data can still reference previously compressed data, improving compression. + * note : multithreaded compression will block to flush as much output as possible. */ + ZSTD_e_end=2 /* flush any remaining data _and_ close current frame. + * note that frame is only closed after compressed data is fully flushed (return value == 0). + * After that point, any additional data starts a new frame. + * note : each frame is independent (does not reference any content from previous frame). + : note : multithreaded compression will block to flush as much output as possible. */ +} ZSTD_EndDirective; + +/*! ZSTD_compressStream2() : Requires v1.4.0+ + * Behaves about the same as ZSTD_compressStream, with additional control on end directive. + * - Compression parameters are pushed into CCtx before starting compression, using ZSTD_CCtx_set*() + * - Compression parameters cannot be changed once compression is started (save a list of exceptions in multi-threading mode) + * - output->pos must be <= dstCapacity, input->pos must be <= srcSize + * - output->pos and input->pos will be updated. They are guaranteed to remain below their respective limit. + * - endOp must be a valid directive + * - When nbWorkers==0 (default), function is blocking : it completes its job before returning to caller. + * - When nbWorkers>=1, function is non-blocking : it copies a portion of input, distributes jobs to internal worker threads, flush to output whatever is available, + * and then immediately returns, just indicating that there is some data remaining to be flushed. + * The function nonetheless guarantees forward progress : it will return only after it reads or write at least 1+ byte. + * - Exception : if the first call requests a ZSTD_e_end directive and provides enough dstCapacity, the function delegates to ZSTD_compress2() which is always blocking. + * - @return provides a minimum amount of data remaining to be flushed from internal buffers + * or an error code, which can be tested using ZSTD_isError(). + * if @return != 0, flush is not fully completed, there is still some data left within internal buffers. + * This is useful for ZSTD_e_flush, since in this case more flushes are necessary to empty all buffers. + * For ZSTD_e_end, @return == 0 when internal buffers are fully flushed and frame is completed. + * - after a ZSTD_e_end directive, if internal buffer is not fully flushed (@return != 0), + * only ZSTD_e_end or ZSTD_e_flush operations are allowed. + * Before starting a new compression job, or changing compression parameters, + * it is required to fully flush internal buffers. + */ +ZSTDLIB_API size_t ZSTD_compressStream2( ZSTD_CCtx* cctx, + ZSTD_outBuffer* output, + ZSTD_inBuffer* input, + ZSTD_EndDirective endOp); + + +/* These buffer sizes are softly recommended. + * They are not required : ZSTD_compressStream*() happily accepts any buffer size, for both input and output. + * Respecting the recommended size just makes it a bit easier for ZSTD_compressStream*(), + * reducing the amount of memory shuffling and buffering, resulting in minor performance savings. + * + * However, note that these recommendations are from the perspective of a C caller program. + * If the streaming interface is invoked from some other language, + * especially managed ones such as Java or Go, through a foreign function interface such as jni or cgo, + * a major performance rule is to reduce crossing such interface to an absolute minimum. + * It's not rare that performance ends being spent more into the interface, rather than compression itself. + * In which cases, prefer using large buffers, as large as practical, + * for both input and output, to reduce the nb of roundtrips. + */ +ZSTDLIB_API size_t ZSTD_CStreamInSize(void); /*< recommended size for input buffer */ +ZSTDLIB_API size_t ZSTD_CStreamOutSize(void); /*< recommended size for output buffer. Guarantee to successfully flush at least one complete compressed block. */ + + +/* ***************************************************************************** + * This following is a legacy streaming API, available since v1.0+ . + * It can be replaced by ZSTD_CCtx_reset() and ZSTD_compressStream2(). + * It is redundant, but remains fully supported. + * Streaming in combination with advanced parameters and dictionary compression + * can only be used through the new API. + ******************************************************************************/ + +/*! + * Equivalent to: + * + * ZSTD_CCtx_reset(zcs, ZSTD_reset_session_only); + * ZSTD_CCtx_refCDict(zcs, NULL); // clear the dictionary (if any) + * ZSTD_CCtx_setParameter(zcs, ZSTD_c_compressionLevel, compressionLevel); + */ +ZSTDLIB_API size_t ZSTD_initCStream(ZSTD_CStream* zcs, int compressionLevel); +/*! + * Alternative for ZSTD_compressStream2(zcs, output, input, ZSTD_e_continue). + * NOTE: The return value is different. ZSTD_compressStream() returns a hint for + * the next read size (if non-zero and not an error). ZSTD_compressStream2() + * returns the minimum nb of bytes left to flush (if non-zero and not an error). + */ +ZSTDLIB_API size_t ZSTD_compressStream(ZSTD_CStream* zcs, ZSTD_outBuffer* output, ZSTD_inBuffer* input); +/*! Equivalent to ZSTD_compressStream2(zcs, output, &emptyInput, ZSTD_e_flush). */ +ZSTDLIB_API size_t ZSTD_flushStream(ZSTD_CStream* zcs, ZSTD_outBuffer* output); +/*! Equivalent to ZSTD_compressStream2(zcs, output, &emptyInput, ZSTD_e_end). */ +ZSTDLIB_API size_t ZSTD_endStream(ZSTD_CStream* zcs, ZSTD_outBuffer* output); + + +/*-*************************************************************************** +* Streaming decompression - HowTo +* +* A ZSTD_DStream object is required to track streaming operations. +* Use ZSTD_createDStream() and ZSTD_freeDStream() to create/release resources. +* ZSTD_DStream objects can be re-used multiple times. +* +* Use ZSTD_initDStream() to start a new decompression operation. +* @return : recommended first input size +* Alternatively, use advanced API to set specific properties. +* +* Use ZSTD_decompressStream() repetitively to consume your input. +* The function will update both `pos` fields. +* If `input.pos < input.size`, some input has not been consumed. +* It's up to the caller to present again remaining data. +* The function tries to flush all data decoded immediately, respecting output buffer size. +* If `output.pos < output.size`, decoder has flushed everything it could. +* But if `output.pos == output.size`, there might be some data left within internal buffers., +* In which case, call ZSTD_decompressStream() again to flush whatever remains in the buffer. +* Note : with no additional input provided, amount of data flushed is necessarily <= ZSTD_BLOCKSIZE_MAX. +* @return : 0 when a frame is completely decoded and fully flushed, +* or an error code, which can be tested using ZSTD_isError(), +* or any other value > 0, which means there is still some decoding or flushing to do to complete current frame : +* the return value is a suggested next input size (just a hint for better latency) +* that will never request more than the remaining frame size. +* *******************************************************************************/ + +typedef ZSTD_DCtx ZSTD_DStream; /*< DCtx and DStream are now effectively same object (>= v1.3.0) */ + /* For compatibility with versions <= v1.2.0, prefer differentiating them. */ +/*===== ZSTD_DStream management functions =====*/ +ZSTDLIB_API ZSTD_DStream* ZSTD_createDStream(void); +ZSTDLIB_API size_t ZSTD_freeDStream(ZSTD_DStream* zds); /* accept NULL pointer */ + +/*===== Streaming decompression functions =====*/ + +/* This function is redundant with the advanced API and equivalent to: + * + * ZSTD_DCtx_reset(zds, ZSTD_reset_session_only); + * ZSTD_DCtx_refDDict(zds, NULL); + */ +ZSTDLIB_API size_t ZSTD_initDStream(ZSTD_DStream* zds); + +ZSTDLIB_API size_t ZSTD_decompressStream(ZSTD_DStream* zds, ZSTD_outBuffer* output, ZSTD_inBuffer* input); + +ZSTDLIB_API size_t ZSTD_DStreamInSize(void); /*!< recommended size for input buffer */ +ZSTDLIB_API size_t ZSTD_DStreamOutSize(void); /*!< recommended size for output buffer. Guarantee to successfully flush at least one complete block in all circumstances. */ + + +/* ************************ +* Simple dictionary API +***************************/ +/*! ZSTD_compress_usingDict() : + * Compression at an explicit compression level using a Dictionary. + * A dictionary can be any arbitrary data segment (also called a prefix), + * or a buffer with specified information (see zdict.h). + * Note : This function loads the dictionary, resulting in significant startup delay. + * It's intended for a dictionary used only once. + * Note 2 : When `dict == NULL || dictSize < 8` no dictionary is used. */ +ZSTDLIB_API size_t ZSTD_compress_usingDict(ZSTD_CCtx* ctx, + void* dst, size_t dstCapacity, + const void* src, size_t srcSize, + const void* dict,size_t dictSize, + int compressionLevel); + +/*! ZSTD_decompress_usingDict() : + * Decompression using a known Dictionary. + * Dictionary must be identical to the one used during compression. + * Note : This function loads the dictionary, resulting in significant startup delay. + * It's intended for a dictionary used only once. + * Note : When `dict == NULL || dictSize < 8` no dictionary is used. */ +ZSTDLIB_API size_t ZSTD_decompress_usingDict(ZSTD_DCtx* dctx, + void* dst, size_t dstCapacity, + const void* src, size_t srcSize, + const void* dict,size_t dictSize); + + +/* ********************************* + * Bulk processing dictionary API + **********************************/ +typedef struct ZSTD_CDict_s ZSTD_CDict; + +/*! ZSTD_createCDict() : + * When compressing multiple messages or blocks using the same dictionary, + * it's recommended to digest the dictionary only once, since it's a costly operation. + * ZSTD_createCDict() will create a state from digesting a dictionary. + * The resulting state can be used for future compression operations with very limited startup cost. + * ZSTD_CDict can be created once and shared by multiple threads concurrently, since its usage is read-only. + * @dictBuffer can be released after ZSTD_CDict creation, because its content is copied within CDict. + * Note 1 : Consider experimental function `ZSTD_createCDict_byReference()` if you prefer to not duplicate @dictBuffer content. + * Note 2 : A ZSTD_CDict can be created from an empty @dictBuffer, + * in which case the only thing that it transports is the @compressionLevel. + * This can be useful in a pipeline featuring ZSTD_compress_usingCDict() exclusively, + * expecting a ZSTD_CDict parameter with any data, including those without a known dictionary. */ +ZSTDLIB_API ZSTD_CDict* ZSTD_createCDict(const void* dictBuffer, size_t dictSize, + int compressionLevel); + +/*! ZSTD_freeCDict() : + * Function frees memory allocated by ZSTD_createCDict(). + * If a NULL pointer is passed, no operation is performed. */ +ZSTDLIB_API size_t ZSTD_freeCDict(ZSTD_CDict* CDict); + +/*! ZSTD_compress_usingCDict() : + * Compression using a digested Dictionary. + * Recommended when same dictionary is used multiple times. + * Note : compression level is _decided at dictionary creation time_, + * and frame parameters are hardcoded (dictID=yes, contentSize=yes, checksum=no) */ +ZSTDLIB_API size_t ZSTD_compress_usingCDict(ZSTD_CCtx* cctx, + void* dst, size_t dstCapacity, + const void* src, size_t srcSize, + const ZSTD_CDict* cdict); + + +typedef struct ZSTD_DDict_s ZSTD_DDict; + +/*! ZSTD_createDDict() : + * Create a digested dictionary, ready to start decompression operation without startup delay. + * dictBuffer can be released after DDict creation, as its content is copied inside DDict. */ +ZSTDLIB_API ZSTD_DDict* ZSTD_createDDict(const void* dictBuffer, size_t dictSize); + +/*! ZSTD_freeDDict() : + * Function frees memory allocated with ZSTD_createDDict() + * If a NULL pointer is passed, no operation is performed. */ +ZSTDLIB_API size_t ZSTD_freeDDict(ZSTD_DDict* ddict); + +/*! ZSTD_decompress_usingDDict() : + * Decompression using a digested Dictionary. + * Recommended when same dictionary is used multiple times. */ +ZSTDLIB_API size_t ZSTD_decompress_usingDDict(ZSTD_DCtx* dctx, + void* dst, size_t dstCapacity, + const void* src, size_t srcSize, + const ZSTD_DDict* ddict); + + +/* ****************************** + * Dictionary helper functions + *******************************/ + +/*! ZSTD_getDictID_fromDict() : Requires v1.4.0+ + * Provides the dictID stored within dictionary. + * if @return == 0, the dictionary is not conformant with Zstandard specification. + * It can still be loaded, but as a content-only dictionary. */ +ZSTDLIB_API unsigned ZSTD_getDictID_fromDict(const void* dict, size_t dictSize); + +/*! ZSTD_getDictID_fromCDict() : Requires v1.5.0+ + * Provides the dictID of the dictionary loaded into `cdict`. + * If @return == 0, the dictionary is not conformant to Zstandard specification, or empty. + * Non-conformant dictionaries can still be loaded, but as content-only dictionaries. */ +ZSTDLIB_API unsigned ZSTD_getDictID_fromCDict(const ZSTD_CDict* cdict); + +/*! ZSTD_getDictID_fromDDict() : Requires v1.4.0+ + * Provides the dictID of the dictionary loaded into `ddict`. + * If @return == 0, the dictionary is not conformant to Zstandard specification, or empty. + * Non-conformant dictionaries can still be loaded, but as content-only dictionaries. */ +ZSTDLIB_API unsigned ZSTD_getDictID_fromDDict(const ZSTD_DDict* ddict); + +/*! ZSTD_getDictID_fromFrame() : Requires v1.4.0+ + * Provides the dictID required to decompressed the frame stored within `src`. + * If @return == 0, the dictID could not be decoded. + * This could for one of the following reasons : + * - The frame does not require a dictionary to be decoded (most common case). + * - The frame was built with dictID intentionally removed. Whatever dictionary is necessary is a hidden information. + * Note : this use case also happens when using a non-conformant dictionary. + * - `srcSize` is too small, and as a result, the frame header could not be decoded (only possible if `srcSize < ZSTD_FRAMEHEADERSIZE_MAX`). + * - This is not a Zstandard frame. + * When identifying the exact failure cause, it's possible to use ZSTD_getFrameHeader(), which will provide a more precise error code. */ +ZSTDLIB_API unsigned ZSTD_getDictID_fromFrame(const void* src, size_t srcSize); + + +/* ***************************************************************************** + * Advanced dictionary and prefix API (Requires v1.4.0+) + * + * This API allows dictionaries to be used with ZSTD_compress2(), + * ZSTD_compressStream2(), and ZSTD_decompressDCtx(). Dictionaries are sticky, and + * only reset with the context is reset with ZSTD_reset_parameters or + * ZSTD_reset_session_and_parameters. Prefixes are single-use. + ******************************************************************************/ + + +/*! ZSTD_CCtx_loadDictionary() : Requires v1.4.0+ + * Create an internal CDict from `dict` buffer. + * Decompression will have to use same dictionary. + * @result : 0, or an error code (which can be tested with ZSTD_isError()). + * Special: Loading a NULL (or 0-size) dictionary invalidates previous dictionary, + * meaning "return to no-dictionary mode". + * Note 1 : Dictionary is sticky, it will be used for all future compressed frames. + * To return to "no-dictionary" situation, load a NULL dictionary (or reset parameters). + * Note 2 : Loading a dictionary involves building tables. + * It's also a CPU consuming operation, with non-negligible impact on latency. + * Tables are dependent on compression parameters, and for this reason, + * compression parameters can no longer be changed after loading a dictionary. + * Note 3 :`dict` content will be copied internally. + * Use experimental ZSTD_CCtx_loadDictionary_byReference() to reference content instead. + * In such a case, dictionary buffer must outlive its users. + * Note 4 : Use ZSTD_CCtx_loadDictionary_advanced() + * to precisely select how dictionary content must be interpreted. */ +ZSTDLIB_API size_t ZSTD_CCtx_loadDictionary(ZSTD_CCtx* cctx, const void* dict, size_t dictSize); + +/*! ZSTD_CCtx_refCDict() : Requires v1.4.0+ + * Reference a prepared dictionary, to be used for all next compressed frames. + * Note that compression parameters are enforced from within CDict, + * and supersede any compression parameter previously set within CCtx. + * The parameters ignored are labelled as "superseded-by-cdict" in the ZSTD_cParameter enum docs. + * The ignored parameters will be used again if the CCtx is returned to no-dictionary mode. + * The dictionary will remain valid for future compressed frames using same CCtx. + * @result : 0, or an error code (which can be tested with ZSTD_isError()). + * Special : Referencing a NULL CDict means "return to no-dictionary mode". + * Note 1 : Currently, only one dictionary can be managed. + * Referencing a new dictionary effectively "discards" any previous one. + * Note 2 : CDict is just referenced, its lifetime must outlive its usage within CCtx. */ +ZSTDLIB_API size_t ZSTD_CCtx_refCDict(ZSTD_CCtx* cctx, const ZSTD_CDict* cdict); + +/*! ZSTD_CCtx_refPrefix() : Requires v1.4.0+ + * Reference a prefix (single-usage dictionary) for next compressed frame. + * A prefix is **only used once**. Tables are discarded at end of frame (ZSTD_e_end). + * Decompression will need same prefix to properly regenerate data. + * Compressing with a prefix is similar in outcome as performing a diff and compressing it, + * but performs much faster, especially during decompression (compression speed is tunable with compression level). + * @result : 0, or an error code (which can be tested with ZSTD_isError()). + * Special: Adding any prefix (including NULL) invalidates any previous prefix or dictionary + * Note 1 : Prefix buffer is referenced. It **must** outlive compression. + * Its content must remain unmodified during compression. + * Note 2 : If the intention is to diff some large src data blob with some prior version of itself, + * ensure that the window size is large enough to contain the entire source. + * See ZSTD_c_windowLog. + * Note 3 : Referencing a prefix involves building tables, which are dependent on compression parameters. + * It's a CPU consuming operation, with non-negligible impact on latency. + * If there is a need to use the same prefix multiple times, consider loadDictionary instead. + * Note 4 : By default, the prefix is interpreted as raw content (ZSTD_dct_rawContent). + * Use experimental ZSTD_CCtx_refPrefix_advanced() to alter dictionary interpretation. */ +ZSTDLIB_API size_t ZSTD_CCtx_refPrefix(ZSTD_CCtx* cctx, + const void* prefix, size_t prefixSize); + +/*! ZSTD_DCtx_loadDictionary() : Requires v1.4.0+ + * Create an internal DDict from dict buffer, + * to be used to decompress next frames. + * The dictionary remains valid for all future frames, until explicitly invalidated. + * @result : 0, or an error code (which can be tested with ZSTD_isError()). + * Special : Adding a NULL (or 0-size) dictionary invalidates any previous dictionary, + * meaning "return to no-dictionary mode". + * Note 1 : Loading a dictionary involves building tables, + * which has a non-negligible impact on CPU usage and latency. + * It's recommended to "load once, use many times", to amortize the cost + * Note 2 :`dict` content will be copied internally, so `dict` can be released after loading. + * Use ZSTD_DCtx_loadDictionary_byReference() to reference dictionary content instead. + * Note 3 : Use ZSTD_DCtx_loadDictionary_advanced() to take control of + * how dictionary content is loaded and interpreted. + */ +ZSTDLIB_API size_t ZSTD_DCtx_loadDictionary(ZSTD_DCtx* dctx, const void* dict, size_t dictSize); + +/*! ZSTD_DCtx_refDDict() : Requires v1.4.0+ + * Reference a prepared dictionary, to be used to decompress next frames. + * The dictionary remains active for decompression of future frames using same DCtx. + * + * If called with ZSTD_d_refMultipleDDicts enabled, repeated calls of this function + * will store the DDict references in a table, and the DDict used for decompression + * will be determined at decompression time, as per the dict ID in the frame. + * The memory for the table is allocated on the first call to refDDict, and can be + * freed with ZSTD_freeDCtx(). + * + * @result : 0, or an error code (which can be tested with ZSTD_isError()). + * Note 1 : Currently, only one dictionary can be managed. + * Referencing a new dictionary effectively "discards" any previous one. + * Special: referencing a NULL DDict means "return to no-dictionary mode". + * Note 2 : DDict is just referenced, its lifetime must outlive its usage from DCtx. + */ +ZSTDLIB_API size_t ZSTD_DCtx_refDDict(ZSTD_DCtx* dctx, const ZSTD_DDict* ddict); + +/*! ZSTD_DCtx_refPrefix() : Requires v1.4.0+ + * Reference a prefix (single-usage dictionary) to decompress next frame. + * This is the reverse operation of ZSTD_CCtx_refPrefix(), + * and must use the same prefix as the one used during compression. + * Prefix is **only used once**. Reference is discarded at end of frame. + * End of frame is reached when ZSTD_decompressStream() returns 0. + * @result : 0, or an error code (which can be tested with ZSTD_isError()). + * Note 1 : Adding any prefix (including NULL) invalidates any previously set prefix or dictionary + * Note 2 : Prefix buffer is referenced. It **must** outlive decompression. + * Prefix buffer must remain unmodified up to the end of frame, + * reached when ZSTD_decompressStream() returns 0. + * Note 3 : By default, the prefix is treated as raw content (ZSTD_dct_rawContent). + * Use ZSTD_CCtx_refPrefix_advanced() to alter dictMode (Experimental section) + * Note 4 : Referencing a raw content prefix has almost no cpu nor memory cost. + * A full dictionary is more costly, as it requires building tables. + */ +ZSTDLIB_API size_t ZSTD_DCtx_refPrefix(ZSTD_DCtx* dctx, + const void* prefix, size_t prefixSize); + +/* === Memory management === */ + +/*! ZSTD_sizeof_*() : Requires v1.4.0+ + * These functions give the _current_ memory usage of selected object. + * Note that object memory usage can evolve (increase or decrease) over time. */ +ZSTDLIB_API size_t ZSTD_sizeof_CCtx(const ZSTD_CCtx* cctx); +ZSTDLIB_API size_t ZSTD_sizeof_DCtx(const ZSTD_DCtx* dctx); +ZSTDLIB_API size_t ZSTD_sizeof_CStream(const ZSTD_CStream* zcs); +ZSTDLIB_API size_t ZSTD_sizeof_DStream(const ZSTD_DStream* zds); +ZSTDLIB_API size_t ZSTD_sizeof_CDict(const ZSTD_CDict* cdict); +ZSTDLIB_API size_t ZSTD_sizeof_DDict(const ZSTD_DDict* ddict); + +#endif /* ZSTD_H_235446 */ + + +/* ************************************************************************************** + * ADVANCED AND EXPERIMENTAL FUNCTIONS + **************************************************************************************** + * The definitions in the following section are considered experimental. + * They are provided for advanced scenarios. + * They should never be used with a dynamic library, as prototypes may change in the future. + * Use them only in association with static linking. + * ***************************************************************************************/ + +#if !defined(ZSTD_H_ZSTD_STATIC_LINKING_ONLY) +#define ZSTD_H_ZSTD_STATIC_LINKING_ONLY + +/* This can be overridden externally to hide static symbols. */ +#ifndef ZSTDLIB_STATIC_API +#define ZSTDLIB_STATIC_API ZSTDLIB_VISIBLE +#endif + +/* Deprecation warnings : + * Should these warnings be a problem, it is generally possible to disable them, + * typically with -Wno-deprecated-declarations for gcc or _CRT_SECURE_NO_WARNINGS in Visual. + * Otherwise, it's also possible to define ZSTD_DISABLE_DEPRECATE_WARNINGS. + */ +#ifdef ZSTD_DISABLE_DEPRECATE_WARNINGS +# define ZSTD_DEPRECATED(message) ZSTDLIB_STATIC_API /* disable deprecation warnings */ +#else +# if (defined(GNUC) && (GNUC > 4 || (GNUC == 4 && GNUC_MINOR >= 5))) || defined(__clang__) +# define ZSTD_DEPRECATED(message) ZSTDLIB_STATIC_API __attribute__((deprecated(message))) +# elif (__GNUC__ >= 3) +# define ZSTD_DEPRECATED(message) ZSTDLIB_STATIC_API __attribute__((deprecated)) +# else +# pragma message("WARNING: You need to implement ZSTD_DEPRECATED for this compiler") +# define ZSTD_DEPRECATED(message) ZSTDLIB_STATIC_API +# endif +#endif /* ZSTD_DISABLE_DEPRECATE_WARNINGS */ + +/* ************************************************************************************** + * experimental API (static linking only) + **************************************************************************************** + * The following symbols and constants + * are not planned to join "stable API" status in the near future. + * They can still change in future versions. + * Some of them are planned to remain in the static_only section indefinitely. + * Some of them might be removed in the future (especially when redundant with existing stable functions) + * ***************************************************************************************/ + +#define ZSTD_FRAMEHEADERSIZE_PREFIX(format) ((format) == ZSTD_f_zstd1 ? 5 : 1) /* minimum input size required to query frame header size */ +#define ZSTD_FRAMEHEADERSIZE_MIN(format) ((format) == ZSTD_f_zstd1 ? 6 : 2) +#define ZSTD_FRAMEHEADERSIZE_MAX 18 /* can be useful for static allocation */ +#define ZSTD_SKIPPABLEHEADERSIZE 8 + +/* compression parameter bounds */ +#define ZSTD_WINDOWLOG_MAX_32 30 +#define ZSTD_WINDOWLOG_MAX_64 31 +#define ZSTD_WINDOWLOG_MAX ((int)(sizeof(size_t) == 4 ? ZSTD_WINDOWLOG_MAX_32 : ZSTD_WINDOWLOG_MAX_64)) +#define ZSTD_WINDOWLOG_MIN 10 +#define ZSTD_HASHLOG_MAX ((ZSTD_WINDOWLOG_MAX < 30) ? ZSTD_WINDOWLOG_MAX : 30) +#define ZSTD_HASHLOG_MIN 6 +#define ZSTD_CHAINLOG_MAX_32 29 +#define ZSTD_CHAINLOG_MAX_64 30 +#define ZSTD_CHAINLOG_MAX ((int)(sizeof(size_t) == 4 ? ZSTD_CHAINLOG_MAX_32 : ZSTD_CHAINLOG_MAX_64)) +#define ZSTD_CHAINLOG_MIN ZSTD_HASHLOG_MIN +#define ZSTD_SEARCHLOG_MAX (ZSTD_WINDOWLOG_MAX-1) +#define ZSTD_SEARCHLOG_MIN 1 +#define ZSTD_MINMATCH_MAX 7 /* only for ZSTD_fast, other strategies are limited to 6 */ +#define ZSTD_MINMATCH_MIN 3 /* only for ZSTD_btopt+, faster strategies are limited to 4 */ +#define ZSTD_TARGETLENGTH_MAX ZSTD_BLOCKSIZE_MAX +#define ZSTD_TARGETLENGTH_MIN 0 /* note : comparing this constant to an unsigned results in a tautological test */ +#define ZSTD_STRATEGY_MIN ZSTD_fast +#define ZSTD_STRATEGY_MAX ZSTD_btultra2 + + +#define ZSTD_OVERLAPLOG_MIN 0 +#define ZSTD_OVERLAPLOG_MAX 9 + +#define ZSTD_WINDOWLOG_LIMIT_DEFAULT 27 /* by default, the streaming decoder will refuse any frame + * requiring larger than (1<<ZSTD_WINDOWLOG_LIMIT_DEFAULT) window size, + * to preserve host's memory from unreasonable requirements. + * This limit can be overridden using ZSTD_DCtx_setParameter(,ZSTD_d_windowLogMax,). + * The limit does not apply for one-pass decoders (such as ZSTD_decompress()), since no additional memory is allocated */ + + +/* LDM parameter bounds */ +#define ZSTD_LDM_HASHLOG_MIN ZSTD_HASHLOG_MIN +#define ZSTD_LDM_HASHLOG_MAX ZSTD_HASHLOG_MAX +#define ZSTD_LDM_MINMATCH_MIN 4 +#define ZSTD_LDM_MINMATCH_MAX 4096 +#define ZSTD_LDM_BUCKETSIZELOG_MIN 1 +#define ZSTD_LDM_BUCKETSIZELOG_MAX 8 +#define ZSTD_LDM_HASHRATELOG_MIN 0 +#define ZSTD_LDM_HASHRATELOG_MAX (ZSTD_WINDOWLOG_MAX - ZSTD_HASHLOG_MIN) + +/* Advanced parameter bounds */ +#define ZSTD_TARGETCBLOCKSIZE_MIN 64 +#define ZSTD_TARGETCBLOCKSIZE_MAX ZSTD_BLOCKSIZE_MAX +#define ZSTD_SRCSIZEHINT_MIN 0 +#define ZSTD_SRCSIZEHINT_MAX INT_MAX + + +/* --- Advanced types --- */ + +typedef struct ZSTD_CCtx_params_s ZSTD_CCtx_params; + +typedef struct { + unsigned int offset; /* The offset of the match. (NOT the same as the offset code) + * If offset == 0 and matchLength == 0, this sequence represents the last + * literals in the block of litLength size. + */ + + unsigned int litLength; /* Literal length of the sequence. */ + unsigned int matchLength; /* Match length of the sequence. */ + + /* Note: Users of this API may provide a sequence with matchLength == litLength == offset == 0. + * In this case, we will treat the sequence as a marker for a block boundary. + */ + + unsigned int rep; /* Represents which repeat offset is represented by the field 'offset'. + * Ranges from [0, 3]. + * + * Repeat offsets are essentially previous offsets from previous sequences sorted in + * recency order. For more detail, see doc/zstd_compression_format.md + * + * If rep == 0, then 'offset' does not contain a repeat offset. + * If rep > 0: + * If litLength != 0: + * rep == 1 --> offset == repeat_offset_1 + * rep == 2 --> offset == repeat_offset_2 + * rep == 3 --> offset == repeat_offset_3 + * If litLength == 0: + * rep == 1 --> offset == repeat_offset_2 + * rep == 2 --> offset == repeat_offset_3 + * rep == 3 --> offset == repeat_offset_1 - 1 + * + * Note: This field is optional. ZSTD_generateSequences() will calculate the value of + * 'rep', but repeat offsets do not necessarily need to be calculated from an external + * sequence provider's perspective. For example, ZSTD_compressSequences() does not + * use this 'rep' field at all (as of now). + */ +} ZSTD_Sequence; + +typedef struct { + unsigned windowLog; /*< largest match distance : larger == more compression, more memory needed during decompression */ + unsigned chainLog; /*< fully searched segment : larger == more compression, slower, more memory (useless for fast) */ + unsigned hashLog; /*< dispatch table : larger == faster, more memory */ + unsigned searchLog; /*< nb of searches : larger == more compression, slower */ + unsigned minMatch; /*< match length searched : larger == faster decompression, sometimes less compression */ + unsigned targetLength; /*< acceptable match size for optimal parser (only) : larger == more compression, slower */ + ZSTD_strategy strategy; /*< see ZSTD_strategy definition above */ +} ZSTD_compressionParameters; + +typedef struct { + int contentSizeFlag; /*< 1: content size will be in frame header (when known) */ + int checksumFlag; /*< 1: generate a 32-bits checksum using XXH64 algorithm at end of frame, for error detection */ + int noDictIDFlag; /*< 1: no dictID will be saved into frame header (dictID is only useful for dictionary compression) */ +} ZSTD_frameParameters; + +typedef struct { + ZSTD_compressionParameters cParams; + ZSTD_frameParameters fParams; +} ZSTD_parameters; + +typedef enum { + ZSTD_dct_auto = 0, /* dictionary is "full" when starting with ZSTD_MAGIC_DICTIONARY, otherwise it is "rawContent" */ + ZSTD_dct_rawContent = 1, /* ensures dictionary is always loaded as rawContent, even if it starts with ZSTD_MAGIC_DICTIONARY */ + ZSTD_dct_fullDict = 2 /* refuses to load a dictionary if it does not respect Zstandard's specification, starting with ZSTD_MAGIC_DICTIONARY */ +} ZSTD_dictContentType_e; + +typedef enum { + ZSTD_dlm_byCopy = 0, /*< Copy dictionary content internally */ + ZSTD_dlm_byRef = 1 /*< Reference dictionary content -- the dictionary buffer must outlive its users. */ +} ZSTD_dictLoadMethod_e; + +typedef enum { + ZSTD_f_zstd1 = 0, /* zstd frame format, specified in zstd_compression_format.md (default) */ + ZSTD_f_zstd1_magicless = 1 /* Variant of zstd frame format, without initial 4-bytes magic number. + * Useful to save 4 bytes per generated frame. + * Decoder cannot recognise automatically this format, requiring this instruction. */ +} ZSTD_format_e; + +typedef enum { + /* Note: this enum controls ZSTD_d_forceIgnoreChecksum */ + ZSTD_d_validateChecksum = 0, + ZSTD_d_ignoreChecksum = 1 +} ZSTD_forceIgnoreChecksum_e; + +typedef enum { + /* Note: this enum controls ZSTD_d_refMultipleDDicts */ + ZSTD_rmd_refSingleDDict = 0, + ZSTD_rmd_refMultipleDDicts = 1 +} ZSTD_refMultipleDDicts_e; + +typedef enum { + /* Note: this enum and the behavior it controls are effectively internal + * implementation details of the compressor. They are expected to continue + * to evolve and should be considered only in the context of extremely + * advanced performance tuning. + * + * Zstd currently supports the use of a CDict in three ways: + * + * - The contents of the CDict can be copied into the working context. This + * means that the compression can search both the dictionary and input + * while operating on a single set of internal tables. This makes + * the compression faster per-byte of input. However, the initial copy of + * the CDict's tables incurs a fixed cost at the beginning of the + * compression. For small compressions (< 8 KB), that copy can dominate + * the cost of the compression. + * + * - The CDict's tables can be used in-place. In this model, compression is + * slower per input byte, because the compressor has to search two sets of + * tables. However, this model incurs no start-up cost (as long as the + * working context's tables can be reused). For small inputs, this can be + * faster than copying the CDict's tables. + * + * - The CDict's tables are not used at all, and instead we use the working + * context alone to reload the dictionary and use params based on the source + * size. See ZSTD_compress_insertDictionary() and ZSTD_compress_usingDict(). + * This method is effective when the dictionary sizes are very small relative + * to the input size, and the input size is fairly large to begin with. + * + * Zstd has a simple internal heuristic that selects which strategy to use + * at the beginning of a compression. However, if experimentation shows that + * Zstd is making poor choices, it is possible to override that choice with + * this enum. + */ + ZSTD_dictDefaultAttach = 0, /* Use the default heuristic. */ + ZSTD_dictForceAttach = 1, /* Never copy the dictionary. */ + ZSTD_dictForceCopy = 2, /* Always copy the dictionary. */ + ZSTD_dictForceLoad = 3 /* Always reload the dictionary */ +} ZSTD_dictAttachPref_e; + +typedef enum { + ZSTD_lcm_auto = 0, /*< Automatically determine the compression mode based on the compression level. + * Negative compression levels will be uncompressed, and positive compression + * levels will be compressed. */ + ZSTD_lcm_huffman = 1, /*< Always attempt Huffman compression. Uncompressed literals will still be + * emitted if Huffman compression is not profitable. */ + ZSTD_lcm_uncompressed = 2 /*< Always emit uncompressed literals. */ +} ZSTD_literalCompressionMode_e; + +typedef enum { + /* Note: This enum controls features which are conditionally beneficial. Zstd typically will make a final + * decision on whether or not to enable the feature (ZSTD_ps_auto), but setting the switch to ZSTD_ps_enable + * or ZSTD_ps_disable allow for a force enable/disable the feature. + */ + ZSTD_ps_auto = 0, /* Let the library automatically determine whether the feature shall be enabled */ + ZSTD_ps_enable = 1, /* Force-enable the feature */ + ZSTD_ps_disable = 2 /* Do not use the feature */ +} ZSTD_paramSwitch_e; + +/* ************************************* +* Frame size functions +***************************************/ + +/*! ZSTD_findDecompressedSize() : + * `src` should point to the start of a series of ZSTD encoded and/or skippable frames + * `srcSize` must be the _exact_ size of this series + * (i.e. there should be a frame boundary at `src + srcSize`) + * @return : - decompressed size of all data in all successive frames + * - if the decompressed size cannot be determined: ZSTD_CONTENTSIZE_UNKNOWN + * - if an error occurred: ZSTD_CONTENTSIZE_ERROR + * + * note 1 : decompressed size is an optional field, that may not be present, especially in streaming mode. + * When `return==ZSTD_CONTENTSIZE_UNKNOWN`, data to decompress could be any size. + * In which case, it's necessary to use streaming mode to decompress data. + * note 2 : decompressed size is always present when compression is done with ZSTD_compress() + * note 3 : decompressed size can be very large (64-bits value), + * potentially larger than what local system can handle as a single memory segment. + * In which case, it's necessary to use streaming mode to decompress data. + * note 4 : If source is untrusted, decompressed size could be wrong or intentionally modified. + * Always ensure result fits within application's authorized limits. + * Each application can set its own limits. + * note 5 : ZSTD_findDecompressedSize handles multiple frames, and so it must traverse the input to + * read each contained frame header. This is fast as most of the data is skipped, + * however it does mean that all frame data must be present and valid. */ +ZSTDLIB_STATIC_API unsigned long long ZSTD_findDecompressedSize(const void* src, size_t srcSize); + +/*! ZSTD_decompressBound() : + * `src` should point to the start of a series of ZSTD encoded and/or skippable frames + * `srcSize` must be the _exact_ size of this series + * (i.e. there should be a frame boundary at `src + srcSize`) + * @return : - upper-bound for the decompressed size of all data in all successive frames + * - if an error occurred: ZSTD_CONTENTSIZE_ERROR + * + * note 1 : an error can occur if `src` contains an invalid or incorrectly formatted frame. + * note 2 : the upper-bound is exact when the decompressed size field is available in every ZSTD encoded frame of `src`. + * in this case, `ZSTD_findDecompressedSize` and `ZSTD_decompressBound` return the same value. + * note 3 : when the decompressed size field isn't available, the upper-bound for that frame is calculated by: + * upper-bound = # blocks * min(128 KB, Window_Size) + */ +ZSTDLIB_STATIC_API unsigned long long ZSTD_decompressBound(const void* src, size_t srcSize); + +/*! ZSTD_frameHeaderSize() : + * srcSize must be >= ZSTD_FRAMEHEADERSIZE_PREFIX. + * @return : size of the Frame Header, + * or an error code (if srcSize is too small) */ +ZSTDLIB_STATIC_API size_t ZSTD_frameHeaderSize(const void* src, size_t srcSize); + +typedef enum { + ZSTD_sf_noBlockDelimiters = 0, /* Representation of ZSTD_Sequence has no block delimiters, sequences only */ + ZSTD_sf_explicitBlockDelimiters = 1 /* Representation of ZSTD_Sequence contains explicit block delimiters */ +} ZSTD_sequenceFormat_e; + +/*! ZSTD_generateSequences() : + * Generate sequences using ZSTD_compress2, given a source buffer. + * + * Each block will end with a dummy sequence + * with offset == 0, matchLength == 0, and litLength == length of last literals. + * litLength may be == 0, and if so, then the sequence of (of: 0 ml: 0 ll: 0) + * simply acts as a block delimiter. + * + * zc can be used to insert custom compression params. + * This function invokes ZSTD_compress2 + * + * The output of this function can be fed into ZSTD_compressSequences() with CCtx + * setting of ZSTD_c_blockDelimiters as ZSTD_sf_explicitBlockDelimiters + * @return : number of sequences generated + */ + +ZSTDLIB_STATIC_API size_t ZSTD_generateSequences(ZSTD_CCtx* zc, ZSTD_Sequence* outSeqs, + size_t outSeqsSize, const void* src, size_t srcSize); + +/*! ZSTD_mergeBlockDelimiters() : + * Given an array of ZSTD_Sequence, remove all sequences that represent block delimiters/last literals + * by merging them into the literals of the next sequence. + * + * As such, the final generated result has no explicit representation of block boundaries, + * and the final last literals segment is not represented in the sequences. + * + * The output of this function can be fed into ZSTD_compressSequences() with CCtx + * setting of ZSTD_c_blockDelimiters as ZSTD_sf_noBlockDelimiters + * @return : number of sequences left after merging + */ +ZSTDLIB_STATIC_API size_t ZSTD_mergeBlockDelimiters(ZSTD_Sequence* sequences, size_t seqsSize); + +/*! ZSTD_compressSequences() : + * Compress an array of ZSTD_Sequence, generated from the original source buffer, into dst. + * If a dictionary is included, then the cctx should reference the dict. (see: ZSTD_CCtx_refCDict(), ZSTD_CCtx_loadDictionary(), etc.) + * The entire source is compressed into a single frame. + * + * The compression behavior changes based on cctx params. In particular: + * If ZSTD_c_blockDelimiters == ZSTD_sf_noBlockDelimiters, the array of ZSTD_Sequence is expected to contain + * no block delimiters (defined in ZSTD_Sequence). Block boundaries are roughly determined based on + * the block size derived from the cctx, and sequences may be split. This is the default setting. + * + * If ZSTD_c_blockDelimiters == ZSTD_sf_explicitBlockDelimiters, the array of ZSTD_Sequence is expected to contain + * block delimiters (defined in ZSTD_Sequence). Behavior is undefined if no block delimiters are provided. + * + * If ZSTD_c_validateSequences == 0, this function will blindly accept the sequences provided. Invalid sequences cause undefined + * behavior. If ZSTD_c_validateSequences == 1, then if sequence is invalid (see doc/zstd_compression_format.md for + * specifics regarding offset/matchlength requirements) then the function will bail out and return an error. + * + * In addition to the two adjustable experimental params, there are other important cctx params. + * - ZSTD_c_minMatch MUST be set as less than or equal to the smallest match generated by the match finder. It has a minimum value of ZSTD_MINMATCH_MIN. + * - ZSTD_c_compressionLevel accordingly adjusts the strength of the entropy coder, as it would in typical compression. + * - ZSTD_c_windowLog affects offset validation: this function will return an error at higher debug levels if a provided offset + * is larger than what the spec allows for a given window log and dictionary (if present). See: doc/zstd_compression_format.md + * + * Note: Repcodes are, as of now, always re-calculated within this function, so ZSTD_Sequence::rep is unused. + * Note 2: Once we integrate ability to ingest repcodes, the explicit block delims mode must respect those repcodes exactly, + * and cannot emit an RLE block that disagrees with the repcode history + * @return : final compressed size or a ZSTD error. + */ +ZSTDLIB_STATIC_API size_t ZSTD_compressSequences(ZSTD_CCtx* const cctx, void* dst, size_t dstSize, + const ZSTD_Sequence* inSeqs, size_t inSeqsSize, + const void* src, size_t srcSize); + + +/*! ZSTD_writeSkippableFrame() : + * Generates a zstd skippable frame containing data given by src, and writes it to dst buffer. + * + * Skippable frames begin with a 4-byte magic number. There are 16 possible choices of magic number, + * ranging from ZSTD_MAGIC_SKIPPABLE_START to ZSTD_MAGIC_SKIPPABLE_START+15. + * As such, the parameter magicVariant controls the exact skippable frame magic number variant used, so + * the magic number used will be ZSTD_MAGIC_SKIPPABLE_START + magicVariant. + * + * Returns an error if destination buffer is not large enough, if the source size is not representable + * with a 4-byte unsigned int, or if the parameter magicVariant is greater than 15 (and therefore invalid). + * + * @return : number of bytes written or a ZSTD error. + */ +ZSTDLIB_STATIC_API size_t ZSTD_writeSkippableFrame(void* dst, size_t dstCapacity, + const void* src, size_t srcSize, unsigned magicVariant); + +/*! ZSTD_readSkippableFrame() : + * Retrieves a zstd skippable frame containing data given by src, and writes it to dst buffer. + * + * The parameter magicVariant will receive the magicVariant that was supplied when the frame was written, + * i.e. magicNumber - ZSTD_MAGIC_SKIPPABLE_START. This can be NULL if the caller is not interested + * in the magicVariant. + * + * Returns an error if destination buffer is not large enough, or if the frame is not skippable. + * + * @return : number of bytes written or a ZSTD error. + */ +ZSTDLIB_API size_t ZSTD_readSkippableFrame(void* dst, size_t dstCapacity, unsigned* magicVariant, + const void* src, size_t srcSize); + +/*! ZSTD_isSkippableFrame() : + * Tells if the content of `buffer` starts with a valid Frame Identifier for a skippable frame. + */ +ZSTDLIB_API unsigned ZSTD_isSkippableFrame(const void* buffer, size_t size); + + + +/* ************************************* +* Memory management +***************************************/ + +/*! ZSTD_estimate*() : + * These functions make it possible to estimate memory usage + * of a future {D,C}Ctx, before its creation. + * + * ZSTD_estimateCCtxSize() will provide a memory budget large enough + * for any compression level up to selected one. + * Note : Unlike ZSTD_estimateCStreamSize*(), this estimate + * does not include space for a window buffer. + * Therefore, the estimation is only guaranteed for single-shot compressions, not streaming. + * The estimate will assume the input may be arbitrarily large, + * which is the worst case. + * + * When srcSize can be bound by a known and rather "small" value, + * this fact can be used to provide a tighter estimation + * because the CCtx compression context will need less memory. + * This tighter estimation can be provided by more advanced functions + * ZSTD_estimateCCtxSize_usingCParams(), which can be used in tandem with ZSTD_getCParams(), + * and ZSTD_estimateCCtxSize_usingCCtxParams(), which can be used in tandem with ZSTD_CCtxParams_setParameter(). + * Both can be used to estimate memory using custom compression parameters and arbitrary srcSize limits. + * + * Note 2 : only single-threaded compression is supported. + * ZSTD_estimateCCtxSize_usingCCtxParams() will return an error code if ZSTD_c_nbWorkers is >= 1. + */ +ZSTDLIB_STATIC_API size_t ZSTD_estimateCCtxSize(int compressionLevel); +ZSTDLIB_STATIC_API size_t ZSTD_estimateCCtxSize_usingCParams(ZSTD_compressionParameters cParams); +ZSTDLIB_STATIC_API size_t ZSTD_estimateCCtxSize_usingCCtxParams(const ZSTD_CCtx_params* params); +ZSTDLIB_STATIC_API size_t ZSTD_estimateDCtxSize(void); + +/*! ZSTD_estimateCStreamSize() : + * ZSTD_estimateCStreamSize() will provide a budget large enough for any compression level up to selected one. + * It will also consider src size to be arbitrarily "large", which is worst case. + * If srcSize is known to always be small, ZSTD_estimateCStreamSize_usingCParams() can provide a tighter estimation. + * ZSTD_estimateCStreamSize_usingCParams() can be used in tandem with ZSTD_getCParams() to create cParams from compressionLevel. + * ZSTD_estimateCStreamSize_usingCCtxParams() can be used in tandem with ZSTD_CCtxParams_setParameter(). Only single-threaded compression is supported. This function will return an error code if ZSTD_c_nbWorkers is >= 1. + * Note : CStream size estimation is only correct for single-threaded compression. + * ZSTD_DStream memory budget depends on window Size. + * This information can be passed manually, using ZSTD_estimateDStreamSize, + * or deducted from a valid frame Header, using ZSTD_estimateDStreamSize_fromFrame(); + * Note : if streaming is init with function ZSTD_init?Stream_usingDict(), + * an internal ?Dict will be created, which additional size is not estimated here. + * In this case, get total size by adding ZSTD_estimate?DictSize */ +ZSTDLIB_STATIC_API size_t ZSTD_estimateCStreamSize(int compressionLevel); +ZSTDLIB_STATIC_API size_t ZSTD_estimateCStreamSize_usingCParams(ZSTD_compressionParameters cParams); +ZSTDLIB_STATIC_API size_t ZSTD_estimateCStreamSize_usingCCtxParams(const ZSTD_CCtx_params* params); +ZSTDLIB_STATIC_API size_t ZSTD_estimateDStreamSize(size_t windowSize); +ZSTDLIB_STATIC_API size_t ZSTD_estimateDStreamSize_fromFrame(const void* src, size_t srcSize); + +/*! ZSTD_estimate?DictSize() : + * ZSTD_estimateCDictSize() will bet that src size is relatively "small", and content is copied, like ZSTD_createCDict(). + * ZSTD_estimateCDictSize_advanced() makes it possible to control compression parameters precisely, like ZSTD_createCDict_advanced(). + * Note : dictionaries created by reference (`ZSTD_dlm_byRef`) are logically smaller. + */ +ZSTDLIB_STATIC_API size_t ZSTD_estimateCDictSize(size_t dictSize, int compressionLevel); +ZSTDLIB_STATIC_API size_t ZSTD_estimateCDictSize_advanced(size_t dictSize, ZSTD_compressionParameters cParams, ZSTD_dictLoadMethod_e dictLoadMethod); +ZSTDLIB_STATIC_API size_t ZSTD_estimateDDictSize(size_t dictSize, ZSTD_dictLoadMethod_e dictLoadMethod); + +/*! ZSTD_initStatic*() : + * Initialize an object using a pre-allocated fixed-size buffer. + * workspace: The memory area to emplace the object into. + * Provided pointer *must be 8-bytes aligned*. + * Buffer must outlive object. + * workspaceSize: Use ZSTD_estimate*Size() to determine + * how large workspace must be to support target scenario. + * @return : pointer to object (same address as workspace, just different type), + * or NULL if error (size too small, incorrect alignment, etc.) + * Note : zstd will never resize nor malloc() when using a static buffer. + * If the object requires more memory than available, + * zstd will just error out (typically ZSTD_error_memory_allocation). + * Note 2 : there is no corresponding "free" function. + * Since workspace is allocated externally, it must be freed externally too. + * Note 3 : cParams : use ZSTD_getCParams() to convert a compression level + * into its associated cParams. + * Limitation 1 : currently not compatible with internal dictionary creation, triggered by + * ZSTD_CCtx_loadDictionary(), ZSTD_initCStream_usingDict() or ZSTD_initDStream_usingDict(). + * Limitation 2 : static cctx currently not compatible with multi-threading. + * Limitation 3 : static dctx is incompatible with legacy support. + */ +ZSTDLIB_STATIC_API ZSTD_CCtx* ZSTD_initStaticCCtx(void* workspace, size_t workspaceSize); +ZSTDLIB_STATIC_API ZSTD_CStream* ZSTD_initStaticCStream(void* workspace, size_t workspaceSize); /*< same as ZSTD_initStaticCCtx() */ + +ZSTDLIB_STATIC_API ZSTD_DCtx* ZSTD_initStaticDCtx(void* workspace, size_t workspaceSize); +ZSTDLIB_STATIC_API ZSTD_DStream* ZSTD_initStaticDStream(void* workspace, size_t workspaceSize); /*< same as ZSTD_initStaticDCtx() */ + +ZSTDLIB_STATIC_API const ZSTD_CDict* ZSTD_initStaticCDict( + void* workspace, size_t workspaceSize, + const void* dict, size_t dictSize, + ZSTD_dictLoadMethod_e dictLoadMethod, + ZSTD_dictContentType_e dictContentType, + ZSTD_compressionParameters cParams); + +ZSTDLIB_STATIC_API const ZSTD_DDict* ZSTD_initStaticDDict( + void* workspace, size_t workspaceSize, + const void* dict, size_t dictSize, + ZSTD_dictLoadMethod_e dictLoadMethod, + ZSTD_dictContentType_e dictContentType); + + +/*! Custom memory allocation : + * These prototypes make it possible to pass your own allocation/free functions. + * ZSTD_customMem is provided at creation time, using ZSTD_create*_advanced() variants listed below. + * All allocation/free operations will be completed using these custom variants instead of regular <stdlib.h> ones. + */ +typedef void* (*ZSTD_allocFunction) (void* opaque, size_t size); +typedef void (*ZSTD_freeFunction) (void* opaque, void* address); +typedef struct { ZSTD_allocFunction customAlloc; ZSTD_freeFunction customFree; void* opaque; } ZSTD_customMem; +static +__attribute__((__unused__)) +ZSTD_customMem const ZSTD_defaultCMem = { NULL, NULL, NULL }; /*< this constant defers to stdlib's functions */ + +ZSTDLIB_STATIC_API ZSTD_CCtx* ZSTD_createCCtx_advanced(ZSTD_customMem customMem); +ZSTDLIB_STATIC_API ZSTD_CStream* ZSTD_createCStream_advanced(ZSTD_customMem customMem); +ZSTDLIB_STATIC_API ZSTD_DCtx* ZSTD_createDCtx_advanced(ZSTD_customMem customMem); +ZSTDLIB_STATIC_API ZSTD_DStream* ZSTD_createDStream_advanced(ZSTD_customMem customMem); + +ZSTDLIB_STATIC_API ZSTD_CDict* ZSTD_createCDict_advanced(const void* dict, size_t dictSize, + ZSTD_dictLoadMethod_e dictLoadMethod, + ZSTD_dictContentType_e dictContentType, + ZSTD_compressionParameters cParams, + ZSTD_customMem customMem); + +/*! Thread pool : + * These prototypes make it possible to share a thread pool among multiple compression contexts. + * This can limit resources for applications with multiple threads where each one uses + * a threaded compression mode (via ZSTD_c_nbWorkers parameter). + * ZSTD_createThreadPool creates a new thread pool with a given number of threads. + * Note that the lifetime of such pool must exist while being used. + * ZSTD_CCtx_refThreadPool assigns a thread pool to a context (use NULL argument value + * to use an internal thread pool). + * ZSTD_freeThreadPool frees a thread pool, accepts NULL pointer. + */ +typedef struct POOL_ctx_s ZSTD_threadPool; +ZSTDLIB_STATIC_API ZSTD_threadPool* ZSTD_createThreadPool(size_t numThreads); +ZSTDLIB_STATIC_API void ZSTD_freeThreadPool (ZSTD_threadPool* pool); /* accept NULL pointer */ +ZSTDLIB_STATIC_API size_t ZSTD_CCtx_refThreadPool(ZSTD_CCtx* cctx, ZSTD_threadPool* pool); + + +/* + * This API is temporary and is expected to change or disappear in the future! + */ +ZSTDLIB_STATIC_API ZSTD_CDict* ZSTD_createCDict_advanced2( + const void* dict, size_t dictSize, + ZSTD_dictLoadMethod_e dictLoadMethod, + ZSTD_dictContentType_e dictContentType, + const ZSTD_CCtx_params* cctxParams, + ZSTD_customMem customMem); + +ZSTDLIB_STATIC_API ZSTD_DDict* ZSTD_createDDict_advanced( + const void* dict, size_t dictSize, + ZSTD_dictLoadMethod_e dictLoadMethod, + ZSTD_dictContentType_e dictContentType, + ZSTD_customMem customMem); + + +/* ************************************* +* Advanced compression functions +***************************************/ + +/*! ZSTD_createCDict_byReference() : + * Create a digested dictionary for compression + * Dictionary content is just referenced, not duplicated. + * As a consequence, `dictBuffer` **must** outlive CDict, + * and its content must remain unmodified throughout the lifetime of CDict. + * note: equivalent to ZSTD_createCDict_advanced(), with dictLoadMethod==ZSTD_dlm_byRef */ +ZSTDLIB_STATIC_API ZSTD_CDict* ZSTD_createCDict_byReference(const void* dictBuffer, size_t dictSize, int compressionLevel); + +/*! ZSTD_getCParams() : + * @return ZSTD_compressionParameters structure for a selected compression level and estimated srcSize. + * `estimatedSrcSize` value is optional, select 0 if not known */ +ZSTDLIB_STATIC_API ZSTD_compressionParameters ZSTD_getCParams(int compressionLevel, unsigned long long estimatedSrcSize, size_t dictSize); + +/*! ZSTD_getParams() : + * same as ZSTD_getCParams(), but @return a full `ZSTD_parameters` object instead of sub-component `ZSTD_compressionParameters`. + * All fields of `ZSTD_frameParameters` are set to default : contentSize=1, checksum=0, noDictID=0 */ +ZSTDLIB_STATIC_API ZSTD_parameters ZSTD_getParams(int compressionLevel, unsigned long long estimatedSrcSize, size_t dictSize); + +/*! ZSTD_checkCParams() : + * Ensure param values remain within authorized range. + * @return 0 on success, or an error code (can be checked with ZSTD_isError()) */ +ZSTDLIB_STATIC_API size_t ZSTD_checkCParams(ZSTD_compressionParameters params); + +/*! ZSTD_adjustCParams() : + * optimize params for a given `srcSize` and `dictSize`. + * `srcSize` can be unknown, in which case use ZSTD_CONTENTSIZE_UNKNOWN. + * `dictSize` must be `0` when there is no dictionary. + * cPar can be invalid : all parameters will be clamped within valid range in the @return struct. + * This function never fails (wide contract) */ +ZSTDLIB_STATIC_API ZSTD_compressionParameters ZSTD_adjustCParams(ZSTD_compressionParameters cPar, unsigned long long srcSize, size_t dictSize); + +/*! ZSTD_compress_advanced() : + * Note : this function is now DEPRECATED. + * It can be replaced by ZSTD_compress2(), in combination with ZSTD_CCtx_setParameter() and other parameter setters. + * This prototype will generate compilation warnings. */ +ZSTD_DEPRECATED("use ZSTD_compress2") +size_t ZSTD_compress_advanced(ZSTD_CCtx* cctx, + void* dst, size_t dstCapacity, + const void* src, size_t srcSize, + const void* dict,size_t dictSize, + ZSTD_parameters params); + +/*! ZSTD_compress_usingCDict_advanced() : + * Note : this function is now DEPRECATED. + * It can be replaced by ZSTD_compress2(), in combination with ZSTD_CCtx_loadDictionary() and other parameter setters. + * This prototype will generate compilation warnings. */ +ZSTD_DEPRECATED("use ZSTD_compress2 with ZSTD_CCtx_loadDictionary") +size_t ZSTD_compress_usingCDict_advanced(ZSTD_CCtx* cctx, + void* dst, size_t dstCapacity, + const void* src, size_t srcSize, + const ZSTD_CDict* cdict, + ZSTD_frameParameters fParams); + + +/*! ZSTD_CCtx_loadDictionary_byReference() : + * Same as ZSTD_CCtx_loadDictionary(), but dictionary content is referenced, instead of being copied into CCtx. + * It saves some memory, but also requires that `dict` outlives its usage within `cctx` */ +ZSTDLIB_STATIC_API size_t ZSTD_CCtx_loadDictionary_byReference(ZSTD_CCtx* cctx, const void* dict, size_t dictSize); + +/*! ZSTD_CCtx_loadDictionary_advanced() : + * Same as ZSTD_CCtx_loadDictionary(), but gives finer control over + * how to load the dictionary (by copy ? by reference ?) + * and how to interpret it (automatic ? force raw mode ? full mode only ?) */ +ZSTDLIB_STATIC_API size_t ZSTD_CCtx_loadDictionary_advanced(ZSTD_CCtx* cctx, const void* dict, size_t dictSize, ZSTD_dictLoadMethod_e dictLoadMethod, ZSTD_dictContentType_e dictContentType); + +/*! ZSTD_CCtx_refPrefix_advanced() : + * Same as ZSTD_CCtx_refPrefix(), but gives finer control over + * how to interpret prefix content (automatic ? force raw mode (default) ? full mode only ?) */ +ZSTDLIB_STATIC_API size_t ZSTD_CCtx_refPrefix_advanced(ZSTD_CCtx* cctx, const void* prefix, size_t prefixSize, ZSTD_dictContentType_e dictContentType); + +/* === experimental parameters === */ +/* these parameters can be used with ZSTD_setParameter() + * they are not guaranteed to remain supported in the future */ + + /* Enables rsyncable mode, + * which makes compressed files more rsync friendly + * by adding periodic synchronization points to the compressed data. + * The target average block size is ZSTD_c_jobSize / 2. + * It's possible to modify the job size to increase or decrease + * the granularity of the synchronization point. + * Once the jobSize is smaller than the window size, + * it will result in compression ratio degradation. + * NOTE 1: rsyncable mode only works when multithreading is enabled. + * NOTE 2: rsyncable performs poorly in combination with long range mode, + * since it will decrease the effectiveness of synchronization points, + * though mileage may vary. + * NOTE 3: Rsyncable mode limits maximum compression speed to ~400 MB/s. + * If the selected compression level is already running significantly slower, + * the overall speed won't be significantly impacted. + */ + #define ZSTD_c_rsyncable ZSTD_c_experimentalParam1 + +/* Select a compression format. + * The value must be of type ZSTD_format_e. + * See ZSTD_format_e enum definition for details */ +#define ZSTD_c_format ZSTD_c_experimentalParam2 + +/* Force back-reference distances to remain < windowSize, + * even when referencing into Dictionary content (default:0) */ +#define ZSTD_c_forceMaxWindow ZSTD_c_experimentalParam3 + +/* Controls whether the contents of a CDict + * are used in place, or copied into the working context. + * Accepts values from the ZSTD_dictAttachPref_e enum. + * See the comments on that enum for an explanation of the feature. */ +#define ZSTD_c_forceAttachDict ZSTD_c_experimentalParam4 + +/* Controlled with ZSTD_paramSwitch_e enum. + * Default is ZSTD_ps_auto. + * Set to ZSTD_ps_disable to never compress literals. + * Set to ZSTD_ps_enable to always compress literals. (Note: uncompressed literals + * may still be emitted if huffman is not beneficial to use.) + * + * By default, in ZSTD_ps_auto, the library will decide at runtime whether to use + * literals compression based on the compression parameters - specifically, + * negative compression levels do not use literal compression. + */ +#define ZSTD_c_literalCompressionMode ZSTD_c_experimentalParam5 + +/* Tries to fit compressed block size to be around targetCBlockSize. + * No target when targetCBlockSize == 0. + * There is no guarantee on compressed block size (default:0) */ +#define ZSTD_c_targetCBlockSize ZSTD_c_experimentalParam6 + +/* User's best guess of source size. + * Hint is not valid when srcSizeHint == 0. + * There is no guarantee that hint is close to actual source size, + * but compression ratio may regress significantly if guess considerably underestimates */ +#define ZSTD_c_srcSizeHint ZSTD_c_experimentalParam7 + +/* Controls whether the new and experimental "dedicated dictionary search + * structure" can be used. This feature is still rough around the edges, be + * prepared for surprising behavior! + * + * How to use it: + * + * When using a CDict, whether to use this feature or not is controlled at + * CDict creation, and it must be set in a CCtxParams set passed into that + * construction (via ZSTD_createCDict_advanced2()). A compression will then + * use the feature or not based on how the CDict was constructed; the value of + * this param, set in the CCtx, will have no effect. + * + * However, when a dictionary buffer is passed into a CCtx, such as via + * ZSTD_CCtx_loadDictionary(), this param can be set on the CCtx to control + * whether the CDict that is created internally can use the feature or not. + * + * What it does: + * + * Normally, the internal data structures of the CDict are analogous to what + * would be stored in a CCtx after compressing the contents of a dictionary. + * To an approximation, a compression using a dictionary can then use those + * data structures to simply continue what is effectively a streaming + * compression where the simulated compression of the dictionary left off. + * Which is to say, the search structures in the CDict are normally the same + * format as in the CCtx. + * + * It is possible to do better, since the CDict is not like a CCtx: the search + * structures are written once during CDict creation, and then are only read + * after that, while the search structures in the CCtx are both read and + * written as the compression goes along. This means we can choose a search + * structure for the dictionary that is read-optimized. + * + * This feature enables the use of that different structure. + * + * Note that some of the members of the ZSTD_compressionParameters struct have + * different semantics and constraints in the dedicated search structure. It is + * highly recommended that you simply set a compression level in the CCtxParams + * you pass into the CDict creation call, and avoid messing with the cParams + * directly. + * + * Effects: + * + * This will only have any effect when the selected ZSTD_strategy + * implementation supports this feature. Currently, that's limited to + * ZSTD_greedy, ZSTD_lazy, and ZSTD_lazy2. + * + * Note that this means that the CDict tables can no longer be copied into the + * CCtx, so the dict attachment mode ZSTD_dictForceCopy will no longer be + * usable. The dictionary can only be attached or reloaded. + * + * In general, you should expect compression to be faster--sometimes very much + * so--and CDict creation to be slightly slower. Eventually, we will probably + * make this mode the default. + */ +#define ZSTD_c_enableDedicatedDictSearch ZSTD_c_experimentalParam8 + +/* ZSTD_c_stableInBuffer + * Experimental parameter. + * Default is 0 == disabled. Set to 1 to enable. + * + * Tells the compressor that the ZSTD_inBuffer will ALWAYS be the same + * between calls, except for the modifications that zstd makes to pos (the + * caller must not modify pos). This is checked by the compressor, and + * compression will fail if it ever changes. This means the only flush + * mode that makes sense is ZSTD_e_end, so zstd will error if ZSTD_e_end + * is not used. The data in the ZSTD_inBuffer in the range [src, src + pos) + * MUST not be modified during compression or you will get data corruption. + * + * When this flag is enabled zstd won't allocate an input window buffer, + * because the user guarantees it can reference the ZSTD_inBuffer until + * the frame is complete. But, it will still allocate an output buffer + * large enough to fit a block (see ZSTD_c_stableOutBuffer). This will also + * avoid the memcpy() from the input buffer to the input window buffer. + * + * NOTE: ZSTD_compressStream2() will error if ZSTD_e_end is not used. + * That means this flag cannot be used with ZSTD_compressStream(). + * + * NOTE: So long as the ZSTD_inBuffer always points to valid memory, using + * this flag is ALWAYS memory safe, and will never access out-of-bounds + * memory. However, compression WILL fail if you violate the preconditions. + * + * WARNING: The data in the ZSTD_inBuffer in the range [dst, dst + pos) MUST + * not be modified during compression or you will get data corruption. This + * is because zstd needs to reference data in the ZSTD_inBuffer to find + * matches. Normally zstd maintains its own window buffer for this purpose, + * but passing this flag tells zstd to use the user provided buffer. + */ +#define ZSTD_c_stableInBuffer ZSTD_c_experimentalParam9 + +/* ZSTD_c_stableOutBuffer + * Experimental parameter. + * Default is 0 == disabled. Set to 1 to enable. + * + * Tells he compressor that the ZSTD_outBuffer will not be resized between + * calls. Specifically: (out.size - out.pos) will never grow. This gives the + * compressor the freedom to say: If the compressed data doesn't fit in the + * output buffer then return ZSTD_error_dstSizeTooSmall. This allows us to + * always decompress directly into the output buffer, instead of decompressing + * into an internal buffer and copying to the output buffer. + * + * When this flag is enabled zstd won't allocate an output buffer, because + * it can write directly to the ZSTD_outBuffer. It will still allocate the + * input window buffer (see ZSTD_c_stableInBuffer). + * + * Zstd will check that (out.size - out.pos) never grows and return an error + * if it does. While not strictly necessary, this should prevent surprises. + */ +#define ZSTD_c_stableOutBuffer ZSTD_c_experimentalParam10 + +/* ZSTD_c_blockDelimiters + * Default is 0 == ZSTD_sf_noBlockDelimiters. + * + * For use with sequence compression API: ZSTD_compressSequences(). + * + * Designates whether or not the given array of ZSTD_Sequence contains block delimiters + * and last literals, which are defined as sequences with offset == 0 and matchLength == 0. + * See the definition of ZSTD_Sequence for more specifics. + */ +#define ZSTD_c_blockDelimiters ZSTD_c_experimentalParam11 + +/* ZSTD_c_validateSequences + * Default is 0 == disabled. Set to 1 to enable sequence validation. + * + * For use with sequence compression API: ZSTD_compressSequences(). + * Designates whether or not we validate sequences provided to ZSTD_compressSequences() + * during function execution. + * + * Without validation, providing a sequence that does not conform to the zstd spec will cause + * undefined behavior, and may produce a corrupted block. + * + * With validation enabled, a if sequence is invalid (see doc/zstd_compression_format.md for + * specifics regarding offset/matchlength requirements) then the function will bail out and + * return an error. + * + */ +#define ZSTD_c_validateSequences ZSTD_c_experimentalParam12 + +/* ZSTD_c_useBlockSplitter + * Controlled with ZSTD_paramSwitch_e enum. + * Default is ZSTD_ps_auto. + * Set to ZSTD_ps_disable to never use block splitter. + * Set to ZSTD_ps_enable to always use block splitter. + * + * By default, in ZSTD_ps_auto, the library will decide at runtime whether to use + * block splitting based on the compression parameters. + */ +#define ZSTD_c_useBlockSplitter ZSTD_c_experimentalParam13 + +/* ZSTD_c_useRowMatchFinder + * Controlled with ZSTD_paramSwitch_e enum. + * Default is ZSTD_ps_auto. + * Set to ZSTD_ps_disable to never use row-based matchfinder. + * Set to ZSTD_ps_enable to force usage of row-based matchfinder. + * + * By default, in ZSTD_ps_auto, the library will decide at runtime whether to use + * the row-based matchfinder based on support for SIMD instructions and the window log. + * Note that this only pertains to compression strategies: greedy, lazy, and lazy2 + */ +#define ZSTD_c_useRowMatchFinder ZSTD_c_experimentalParam14 + +/* ZSTD_c_deterministicRefPrefix + * Default is 0 == disabled. Set to 1 to enable. + * + * Zstd produces different results for prefix compression when the prefix is + * directly adjacent to the data about to be compressed vs. when it isn't. + * This is because zstd detects that the two buffers are contiguous and it can + * use a more efficient match finding algorithm. However, this produces different + * results than when the two buffers are non-contiguous. This flag forces zstd + * to always load the prefix in non-contiguous mode, even if it happens to be + * adjacent to the data, to guarantee determinism. + * + * If you really care about determinism when using a dictionary or prefix, + * like when doing delta compression, you should select this option. It comes + * at a speed penalty of about ~2.5% if the dictionary and data happened to be + * contiguous, and is free if they weren't contiguous. We don't expect that + * intentionally making the dictionary and data contiguous will be worth the + * cost to memcpy() the data. + */ +#define ZSTD_c_deterministicRefPrefix ZSTD_c_experimentalParam15 + +/*! ZSTD_CCtx_getParameter() : + * Get the requested compression parameter value, selected by enum ZSTD_cParameter, + * and store it into int* value. + * @return : 0, or an error code (which can be tested with ZSTD_isError()). + */ +ZSTDLIB_STATIC_API size_t ZSTD_CCtx_getParameter(const ZSTD_CCtx* cctx, ZSTD_cParameter param, int* value); + + +/*! ZSTD_CCtx_params : + * Quick howto : + * - ZSTD_createCCtxParams() : Create a ZSTD_CCtx_params structure + * - ZSTD_CCtxParams_setParameter() : Push parameters one by one into + * an existing ZSTD_CCtx_params structure. + * This is similar to + * ZSTD_CCtx_setParameter(). + * - ZSTD_CCtx_setParametersUsingCCtxParams() : Apply parameters to + * an existing CCtx. + * These parameters will be applied to + * all subsequent frames. + * - ZSTD_compressStream2() : Do compression using the CCtx. + * - ZSTD_freeCCtxParams() : Free the memory, accept NULL pointer. + * + * This can be used with ZSTD_estimateCCtxSize_advanced_usingCCtxParams() + * for static allocation of CCtx for single-threaded compression. + */ +ZSTDLIB_STATIC_API ZSTD_CCtx_params* ZSTD_createCCtxParams(void); +ZSTDLIB_STATIC_API size_t ZSTD_freeCCtxParams(ZSTD_CCtx_params* params); /* accept NULL pointer */ + +/*! ZSTD_CCtxParams_reset() : + * Reset params to default values. + */ +ZSTDLIB_STATIC_API size_t ZSTD_CCtxParams_reset(ZSTD_CCtx_params* params); + +/*! ZSTD_CCtxParams_init() : + * Initializes the compression parameters of cctxParams according to + * compression level. All other parameters are reset to their default values. + */ +ZSTDLIB_STATIC_API size_t ZSTD_CCtxParams_init(ZSTD_CCtx_params* cctxParams, int compressionLevel); + +/*! ZSTD_CCtxParams_init_advanced() : + * Initializes the compression and frame parameters of cctxParams according to + * params. All other parameters are reset to their default values. + */ +ZSTDLIB_STATIC_API size_t ZSTD_CCtxParams_init_advanced(ZSTD_CCtx_params* cctxParams, ZSTD_parameters params); + +/*! ZSTD_CCtxParams_setParameter() : Requires v1.4.0+ + * Similar to ZSTD_CCtx_setParameter. + * Set one compression parameter, selected by enum ZSTD_cParameter. + * Parameters must be applied to a ZSTD_CCtx using + * ZSTD_CCtx_setParametersUsingCCtxParams(). + * @result : a code representing success or failure (which can be tested with + * ZSTD_isError()). + */ +ZSTDLIB_STATIC_API size_t ZSTD_CCtxParams_setParameter(ZSTD_CCtx_params* params, ZSTD_cParameter param, int value); + +/*! ZSTD_CCtxParams_getParameter() : + * Similar to ZSTD_CCtx_getParameter. + * Get the requested value of one compression parameter, selected by enum ZSTD_cParameter. + * @result : 0, or an error code (which can be tested with ZSTD_isError()). + */ +ZSTDLIB_STATIC_API size_t ZSTD_CCtxParams_getParameter(const ZSTD_CCtx_params* params, ZSTD_cParameter param, int* value); + +/*! ZSTD_CCtx_setParametersUsingCCtxParams() : + * Apply a set of ZSTD_CCtx_params to the compression context. + * This can be done even after compression is started, + * if nbWorkers==0, this will have no impact until a new compression is started. + * if nbWorkers>=1, new parameters will be picked up at next job, + * with a few restrictions (windowLog, pledgedSrcSize, nbWorkers, jobSize, and overlapLog are not updated). + */ +ZSTDLIB_STATIC_API size_t ZSTD_CCtx_setParametersUsingCCtxParams( + ZSTD_CCtx* cctx, const ZSTD_CCtx_params* params); + +/*! ZSTD_compressStream2_simpleArgs() : + * Same as ZSTD_compressStream2(), + * but using only integral types as arguments. + * This variant might be helpful for binders from dynamic languages + * which have troubles handling structures containing memory pointers. + */ +ZSTDLIB_STATIC_API size_t ZSTD_compressStream2_simpleArgs ( + ZSTD_CCtx* cctx, + void* dst, size_t dstCapacity, size_t* dstPos, + const void* src, size_t srcSize, size_t* srcPos, + ZSTD_EndDirective endOp); + + +/* ************************************* +* Advanced decompression functions +***************************************/ + +/*! ZSTD_isFrame() : + * Tells if the content of `buffer` starts with a valid Frame Identifier. + * Note : Frame Identifier is 4 bytes. If `size < 4`, @return will always be 0. + * Note 2 : Legacy Frame Identifiers are considered valid only if Legacy Support is enabled. + * Note 3 : Skippable Frame Identifiers are considered valid. */ +ZSTDLIB_STATIC_API unsigned ZSTD_isFrame(const void* buffer, size_t size); + +/*! ZSTD_createDDict_byReference() : + * Create a digested dictionary, ready to start decompression operation without startup delay. + * Dictionary content is referenced, and therefore stays in dictBuffer. + * It is important that dictBuffer outlives DDict, + * it must remain read accessible throughout the lifetime of DDict */ +ZSTDLIB_STATIC_API ZSTD_DDict* ZSTD_createDDict_byReference(const void* dictBuffer, size_t dictSize); + +/*! ZSTD_DCtx_loadDictionary_byReference() : + * Same as ZSTD_DCtx_loadDictionary(), + * but references `dict` content instead of copying it into `dctx`. + * This saves memory if `dict` remains around., + * However, it's imperative that `dict` remains accessible (and unmodified) while being used, so it must outlive decompression. */ +ZSTDLIB_STATIC_API size_t ZSTD_DCtx_loadDictionary_byReference(ZSTD_DCtx* dctx, const void* dict, size_t dictSize); + +/*! ZSTD_DCtx_loadDictionary_advanced() : + * Same as ZSTD_DCtx_loadDictionary(), + * but gives direct control over + * how to load the dictionary (by copy ? by reference ?) + * and how to interpret it (automatic ? force raw mode ? full mode only ?). */ +ZSTDLIB_STATIC_API size_t ZSTD_DCtx_loadDictionary_advanced(ZSTD_DCtx* dctx, const void* dict, size_t dictSize, ZSTD_dictLoadMethod_e dictLoadMethod, ZSTD_dictContentType_e dictContentType); + +/*! ZSTD_DCtx_refPrefix_advanced() : + * Same as ZSTD_DCtx_refPrefix(), but gives finer control over + * how to interpret prefix content (automatic ? force raw mode (default) ? full mode only ?) */ +ZSTDLIB_STATIC_API size_t ZSTD_DCtx_refPrefix_advanced(ZSTD_DCtx* dctx, const void* prefix, size_t prefixSize, ZSTD_dictContentType_e dictContentType); + +/*! ZSTD_DCtx_setMaxWindowSize() : + * Refuses allocating internal buffers for frames requiring a window size larger than provided limit. + * This protects a decoder context from reserving too much memory for itself (potential attack scenario). + * This parameter is only useful in streaming mode, since no internal buffer is allocated in single-pass mode. + * By default, a decompression context accepts all window sizes <= (1 << ZSTD_WINDOWLOG_LIMIT_DEFAULT) + * @return : 0, or an error code (which can be tested using ZSTD_isError()). + */ +ZSTDLIB_STATIC_API size_t ZSTD_DCtx_setMaxWindowSize(ZSTD_DCtx* dctx, size_t maxWindowSize); + +/*! ZSTD_DCtx_getParameter() : + * Get the requested decompression parameter value, selected by enum ZSTD_dParameter, + * and store it into int* value. + * @return : 0, or an error code (which can be tested with ZSTD_isError()). + */ +ZSTDLIB_STATIC_API size_t ZSTD_DCtx_getParameter(ZSTD_DCtx* dctx, ZSTD_dParameter param, int* value); + +/* ZSTD_d_format + * experimental parameter, + * allowing selection between ZSTD_format_e input compression formats + */ +#define ZSTD_d_format ZSTD_d_experimentalParam1 +/* ZSTD_d_stableOutBuffer + * Experimental parameter. + * Default is 0 == disabled. Set to 1 to enable. + * + * Tells the decompressor that the ZSTD_outBuffer will ALWAYS be the same + * between calls, except for the modifications that zstd makes to pos (the + * caller must not modify pos). This is checked by the decompressor, and + * decompression will fail if it ever changes. Therefore the ZSTD_outBuffer + * MUST be large enough to fit the entire decompressed frame. This will be + * checked when the frame content size is known. The data in the ZSTD_outBuffer + * in the range [dst, dst + pos) MUST not be modified during decompression + * or you will get data corruption. + * + * When this flags is enabled zstd won't allocate an output buffer, because + * it can write directly to the ZSTD_outBuffer, but it will still allocate + * an input buffer large enough to fit any compressed block. This will also + * avoid the memcpy() from the internal output buffer to the ZSTD_outBuffer. + * If you need to avoid the input buffer allocation use the buffer-less + * streaming API. + * + * NOTE: So long as the ZSTD_outBuffer always points to valid memory, using + * this flag is ALWAYS memory safe, and will never access out-of-bounds + * memory. However, decompression WILL fail if you violate the preconditions. + * + * WARNING: The data in the ZSTD_outBuffer in the range [dst, dst + pos) MUST + * not be modified during decompression or you will get data corruption. This + * is because zstd needs to reference data in the ZSTD_outBuffer to regenerate + * matches. Normally zstd maintains its own buffer for this purpose, but passing + * this flag tells zstd to use the user provided buffer. + */ +#define ZSTD_d_stableOutBuffer ZSTD_d_experimentalParam2 + +/* ZSTD_d_forceIgnoreChecksum + * Experimental parameter. + * Default is 0 == disabled. Set to 1 to enable + * + * Tells the decompressor to skip checksum validation during decompression, regardless + * of whether checksumming was specified during compression. This offers some + * slight performance benefits, and may be useful for debugging. + * Param has values of type ZSTD_forceIgnoreChecksum_e + */ +#define ZSTD_d_forceIgnoreChecksum ZSTD_d_experimentalParam3 + +/* ZSTD_d_refMultipleDDicts + * Experimental parameter. + * Default is 0 == disabled. Set to 1 to enable + * + * If enabled and dctx is allocated on the heap, then additional memory will be allocated + * to store references to multiple ZSTD_DDict. That is, multiple calls of ZSTD_refDDict() + * using a given ZSTD_DCtx, rather than overwriting the previous DDict reference, will instead + * store all references. At decompression time, the appropriate dictID is selected + * from the set of DDicts based on the dictID in the frame. + * + * Usage is simply calling ZSTD_refDDict() on multiple dict buffers. + * + * Param has values of byte ZSTD_refMultipleDDicts_e + * + * WARNING: Enabling this parameter and calling ZSTD_DCtx_refDDict(), will trigger memory + * allocation for the hash table. ZSTD_freeDCtx() also frees this memory. + * Memory is allocated as per ZSTD_DCtx::customMem. + * + * Although this function allocates memory for the table, the user is still responsible for + * memory management of the underlying ZSTD_DDict* themselves. + */ +#define ZSTD_d_refMultipleDDicts ZSTD_d_experimentalParam4 + + +/*! ZSTD_DCtx_setFormat() : + * This function is REDUNDANT. Prefer ZSTD_DCtx_setParameter(). + * Instruct the decoder context about what kind of data to decode next. + * This instruction is mandatory to decode data without a fully-formed header, + * such ZSTD_f_zstd1_magicless for example. + * @return : 0, or an error code (which can be tested using ZSTD_isError()). */ +ZSTD_DEPRECATED("use ZSTD_DCtx_setParameter() instead") +size_t ZSTD_DCtx_setFormat(ZSTD_DCtx* dctx, ZSTD_format_e format); + +/*! ZSTD_decompressStream_simpleArgs() : + * Same as ZSTD_decompressStream(), + * but using only integral types as arguments. + * This can be helpful for binders from dynamic languages + * which have troubles handling structures containing memory pointers. + */ +ZSTDLIB_STATIC_API size_t ZSTD_decompressStream_simpleArgs ( + ZSTD_DCtx* dctx, + void* dst, size_t dstCapacity, size_t* dstPos, + const void* src, size_t srcSize, size_t* srcPos); + + +/* ****************************************************************** +* Advanced streaming functions +* Warning : most of these functions are now redundant with the Advanced API. +* Once Advanced API reaches "stable" status, +* redundant functions will be deprecated, and then at some point removed. +********************************************************************/ + +/*===== Advanced Streaming compression functions =====*/ + +/*! ZSTD_initCStream_srcSize() : + * This function is DEPRECATED, and equivalent to: + * ZSTD_CCtx_reset(zcs, ZSTD_reset_session_only); + * ZSTD_CCtx_refCDict(zcs, NULL); // clear the dictionary (if any) + * ZSTD_CCtx_setParameter(zcs, ZSTD_c_compressionLevel, compressionLevel); + * ZSTD_CCtx_setPledgedSrcSize(zcs, pledgedSrcSize); + * + * pledgedSrcSize must be correct. If it is not known at init time, use + * ZSTD_CONTENTSIZE_UNKNOWN. Note that, for compatibility with older programs, + * "0" also disables frame content size field. It may be enabled in the future. + * This prototype will generate compilation warnings. + */ +ZSTD_DEPRECATED("use ZSTD_CCtx_reset, see zstd.h for detailed instructions") +size_t ZSTD_initCStream_srcSize(ZSTD_CStream* zcs, + int compressionLevel, + unsigned long long pledgedSrcSize); + +/*! ZSTD_initCStream_usingDict() : + * This function is DEPRECATED, and is equivalent to: + * ZSTD_CCtx_reset(zcs, ZSTD_reset_session_only); + * ZSTD_CCtx_setParameter(zcs, ZSTD_c_compressionLevel, compressionLevel); + * ZSTD_CCtx_loadDictionary(zcs, dict, dictSize); + * + * Creates of an internal CDict (incompatible with static CCtx), except if + * dict == NULL or dictSize < 8, in which case no dict is used. + * Note: dict is loaded with ZSTD_dct_auto (treated as a full zstd dictionary if + * it begins with ZSTD_MAGIC_DICTIONARY, else as raw content) and ZSTD_dlm_byCopy. + * This prototype will generate compilation warnings. + */ +ZSTD_DEPRECATED("use ZSTD_CCtx_reset, see zstd.h for detailed instructions") +size_t ZSTD_initCStream_usingDict(ZSTD_CStream* zcs, + const void* dict, size_t dictSize, + int compressionLevel); + +/*! ZSTD_initCStream_advanced() : + * This function is DEPRECATED, and is approximately equivalent to: + * ZSTD_CCtx_reset(zcs, ZSTD_reset_session_only); + * // Pseudocode: Set each zstd parameter and leave the rest as-is. + * for ((param, value) : params) { + * ZSTD_CCtx_setParameter(zcs, param, value); + * } + * ZSTD_CCtx_setPledgedSrcSize(zcs, pledgedSrcSize); + * ZSTD_CCtx_loadDictionary(zcs, dict, dictSize); + * + * dict is loaded with ZSTD_dct_auto and ZSTD_dlm_byCopy. + * pledgedSrcSize must be correct. + * If srcSize is not known at init time, use value ZSTD_CONTENTSIZE_UNKNOWN. + * This prototype will generate compilation warnings. + */ +ZSTD_DEPRECATED("use ZSTD_CCtx_reset, see zstd.h for detailed instructions") +size_t ZSTD_initCStream_advanced(ZSTD_CStream* zcs, + const void* dict, size_t dictSize, + ZSTD_parameters params, + unsigned long long pledgedSrcSize); + +/*! ZSTD_initCStream_usingCDict() : + * This function is DEPRECATED, and equivalent to: + * ZSTD_CCtx_reset(zcs, ZSTD_reset_session_only); + * ZSTD_CCtx_refCDict(zcs, cdict); + * + * note : cdict will just be referenced, and must outlive compression session + * This prototype will generate compilation warnings. + */ +ZSTD_DEPRECATED("use ZSTD_CCtx_reset and ZSTD_CCtx_refCDict, see zstd.h for detailed instructions") +size_t ZSTD_initCStream_usingCDict(ZSTD_CStream* zcs, const ZSTD_CDict* cdict); + +/*! ZSTD_initCStream_usingCDict_advanced() : + * This function is DEPRECATED, and is approximately equivalent to: + * ZSTD_CCtx_reset(zcs, ZSTD_reset_session_only); + * // Pseudocode: Set each zstd frame parameter and leave the rest as-is. + * for ((fParam, value) : fParams) { + * ZSTD_CCtx_setParameter(zcs, fParam, value); + * } + * ZSTD_CCtx_setPledgedSrcSize(zcs, pledgedSrcSize); + * ZSTD_CCtx_refCDict(zcs, cdict); + * + * same as ZSTD_initCStream_usingCDict(), with control over frame parameters. + * pledgedSrcSize must be correct. If srcSize is not known at init time, use + * value ZSTD_CONTENTSIZE_UNKNOWN. + * This prototype will generate compilation warnings. + */ +ZSTD_DEPRECATED("use ZSTD_CCtx_reset and ZSTD_CCtx_refCDict, see zstd.h for detailed instructions") +size_t ZSTD_initCStream_usingCDict_advanced(ZSTD_CStream* zcs, + const ZSTD_CDict* cdict, + ZSTD_frameParameters fParams, + unsigned long long pledgedSrcSize); + +/*! ZSTD_resetCStream() : + * This function is DEPRECATED, and is equivalent to: + * ZSTD_CCtx_reset(zcs, ZSTD_reset_session_only); + * ZSTD_CCtx_setPledgedSrcSize(zcs, pledgedSrcSize); + * Note: ZSTD_resetCStream() interprets pledgedSrcSize == 0 as ZSTD_CONTENTSIZE_UNKNOWN, but + * ZSTD_CCtx_setPledgedSrcSize() does not do the same, so ZSTD_CONTENTSIZE_UNKNOWN must be + * explicitly specified. + * + * start a new frame, using same parameters from previous frame. + * This is typically useful to skip dictionary loading stage, since it will re-use it in-place. + * Note that zcs must be init at least once before using ZSTD_resetCStream(). + * If pledgedSrcSize is not known at reset time, use macro ZSTD_CONTENTSIZE_UNKNOWN. + * If pledgedSrcSize > 0, its value must be correct, as it will be written in header, and controlled at the end. + * For the time being, pledgedSrcSize==0 is interpreted as "srcSize unknown" for compatibility with older programs, + * but it will change to mean "empty" in future version, so use macro ZSTD_CONTENTSIZE_UNKNOWN instead. + * @return : 0, or an error code (which can be tested using ZSTD_isError()) + * This prototype will generate compilation warnings. + */ +ZSTD_DEPRECATED("use ZSTD_CCtx_reset, see zstd.h for detailed instructions") +size_t ZSTD_resetCStream(ZSTD_CStream* zcs, unsigned long long pledgedSrcSize); + + +typedef struct { + unsigned long long ingested; /* nb input bytes read and buffered */ + unsigned long long consumed; /* nb input bytes actually compressed */ + unsigned long long produced; /* nb of compressed bytes generated and buffered */ + unsigned long long flushed; /* nb of compressed bytes flushed : not provided; can be tracked from caller side */ + unsigned currentJobID; /* MT only : latest started job nb */ + unsigned nbActiveWorkers; /* MT only : nb of workers actively compressing at probe time */ +} ZSTD_frameProgression; + +/* ZSTD_getFrameProgression() : + * tells how much data has been ingested (read from input) + * consumed (input actually compressed) and produced (output) for current frame. + * Note : (ingested - consumed) is amount of input data buffered internally, not yet compressed. + * Aggregates progression inside active worker threads. + */ +ZSTDLIB_STATIC_API ZSTD_frameProgression ZSTD_getFrameProgression(const ZSTD_CCtx* cctx); + +/*! ZSTD_toFlushNow() : + * Tell how many bytes are ready to be flushed immediately. + * Useful for multithreading scenarios (nbWorkers >= 1). + * Probe the oldest active job, defined as oldest job not yet entirely flushed, + * and check its output buffer. + * @return : amount of data stored in oldest job and ready to be flushed immediately. + * if @return == 0, it means either : + * + there is no active job (could be checked with ZSTD_frameProgression()), or + * + oldest job is still actively compressing data, + * but everything it has produced has also been flushed so far, + * therefore flush speed is limited by production speed of oldest job + * irrespective of the speed of concurrent (and newer) jobs. + */ +ZSTDLIB_STATIC_API size_t ZSTD_toFlushNow(ZSTD_CCtx* cctx); + + +/*===== Advanced Streaming decompression functions =====*/ + +/*! + * This function is deprecated, and is equivalent to: + * + * ZSTD_DCtx_reset(zds, ZSTD_reset_session_only); + * ZSTD_DCtx_loadDictionary(zds, dict, dictSize); + * + * note: no dictionary will be used if dict == NULL or dictSize < 8 + * Note : this prototype will be marked as deprecated and generate compilation warnings on reaching v1.5.x + */ +ZSTDLIB_STATIC_API size_t ZSTD_initDStream_usingDict(ZSTD_DStream* zds, const void* dict, size_t dictSize); + +/*! + * This function is deprecated, and is equivalent to: + * + * ZSTD_DCtx_reset(zds, ZSTD_reset_session_only); + * ZSTD_DCtx_refDDict(zds, ddict); + * + * note : ddict is referenced, it must outlive decompression session + * Note : this prototype will be marked as deprecated and generate compilation warnings on reaching v1.5.x + */ +ZSTDLIB_STATIC_API size_t ZSTD_initDStream_usingDDict(ZSTD_DStream* zds, const ZSTD_DDict* ddict); + +/*! + * This function is deprecated, and is equivalent to: + * + * ZSTD_DCtx_reset(zds, ZSTD_reset_session_only); + * + * re-use decompression parameters from previous init; saves dictionary loading + * Note : this prototype will be marked as deprecated and generate compilation warnings on reaching v1.5.x + */ +ZSTDLIB_STATIC_API size_t ZSTD_resetDStream(ZSTD_DStream* zds); + + +/* ******************************************************************* +* Buffer-less and synchronous inner streaming functions +* +* This is an advanced API, giving full control over buffer management, for users which need direct control over memory. +* But it's also a complex one, with several restrictions, documented below. +* Prefer normal streaming API for an easier experience. +********************************************************************* */ + +/* + Buffer-less streaming compression (synchronous mode) + + A ZSTD_CCtx object is required to track streaming operations. + Use ZSTD_createCCtx() / ZSTD_freeCCtx() to manage resource. + ZSTD_CCtx object can be re-used multiple times within successive compression operations. + + Start by initializing a context. + Use ZSTD_compressBegin(), or ZSTD_compressBegin_usingDict() for dictionary compression. + It's also possible to duplicate a reference context which has already been initialized, using ZSTD_copyCCtx() + + Then, consume your input using ZSTD_compressContinue(). + There are some important considerations to keep in mind when using this advanced function : + - ZSTD_compressContinue() has no internal buffer. It uses externally provided buffers only. + - Interface is synchronous : input is consumed entirely and produces 1+ compressed blocks. + - Caller must ensure there is enough space in `dst` to store compressed data under worst case scenario. + Worst case evaluation is provided by ZSTD_compressBound(). + ZSTD_compressContinue() doesn't guarantee recover after a failed compression. + - ZSTD_compressContinue() presumes prior input ***is still accessible and unmodified*** (up to maximum distance size, see WindowLog). + It remembers all previous contiguous blocks, plus one separated memory segment (which can itself consists of multiple contiguous blocks) + - ZSTD_compressContinue() detects that prior input has been overwritten when `src` buffer overlaps. + In which case, it will "discard" the relevant memory section from its history. + + Finish a frame with ZSTD_compressEnd(), which will write the last block(s) and optional checksum. + It's possible to use srcSize==0, in which case, it will write a final empty block to end the frame. + Without last block mark, frames are considered unfinished (hence corrupted) by compliant decoders. + + `ZSTD_CCtx` object can be re-used (ZSTD_compressBegin()) to compress again. +*/ + +/*===== Buffer-less streaming compression functions =====*/ +ZSTDLIB_STATIC_API size_t ZSTD_compressBegin(ZSTD_CCtx* cctx, int compressionLevel); +ZSTDLIB_STATIC_API size_t ZSTD_compressBegin_usingDict(ZSTD_CCtx* cctx, const void* dict, size_t dictSize, int compressionLevel); +ZSTDLIB_STATIC_API size_t ZSTD_compressBegin_usingCDict(ZSTD_CCtx* cctx, const ZSTD_CDict* cdict); /*< note: fails if cdict==NULL */ +ZSTDLIB_STATIC_API size_t ZSTD_copyCCtx(ZSTD_CCtx* cctx, const ZSTD_CCtx* preparedCCtx, unsigned long long pledgedSrcSize); /*< note: if pledgedSrcSize is not known, use ZSTD_CONTENTSIZE_UNKNOWN */ + +ZSTDLIB_STATIC_API size_t ZSTD_compressContinue(ZSTD_CCtx* cctx, void* dst, size_t dstCapacity, const void* src, size_t srcSize); +ZSTDLIB_STATIC_API size_t ZSTD_compressEnd(ZSTD_CCtx* cctx, void* dst, size_t dstCapacity, const void* src, size_t srcSize); + +/* The ZSTD_compressBegin_advanced() and ZSTD_compressBegin_usingCDict_advanced() are now DEPRECATED and will generate a compiler warning */ +ZSTD_DEPRECATED("use advanced API to access custom parameters") +size_t ZSTD_compressBegin_advanced(ZSTD_CCtx* cctx, const void* dict, size_t dictSize, ZSTD_parameters params, unsigned long long pledgedSrcSize); /*< pledgedSrcSize : If srcSize is not known at init time, use ZSTD_CONTENTSIZE_UNKNOWN */ +ZSTD_DEPRECATED("use advanced API to access custom parameters") +size_t ZSTD_compressBegin_usingCDict_advanced(ZSTD_CCtx* const cctx, const ZSTD_CDict* const cdict, ZSTD_frameParameters const fParams, unsigned long long const pledgedSrcSize); /* compression parameters are already set within cdict. pledgedSrcSize must be correct. If srcSize is not known, use macro ZSTD_CONTENTSIZE_UNKNOWN */ +/* + Buffer-less streaming decompression (synchronous mode) + + A ZSTD_DCtx object is required to track streaming operations. + Use ZSTD_createDCtx() / ZSTD_freeDCtx() to manage it. + A ZSTD_DCtx object can be re-used multiple times. + + First typical operation is to retrieve frame parameters, using ZSTD_getFrameHeader(). + Frame header is extracted from the beginning of compressed frame, so providing only the frame's beginning is enough. + Data fragment must be large enough to ensure successful decoding. + `ZSTD_frameHeaderSize_max` bytes is guaranteed to always be large enough. + @result : 0 : successful decoding, the `ZSTD_frameHeader` structure is correctly filled. + >0 : `srcSize` is too small, please provide at least @result bytes on next attempt. + errorCode, which can be tested using ZSTD_isError(). + + It fills a ZSTD_frameHeader structure with important information to correctly decode the frame, + such as the dictionary ID, content size, or maximum back-reference distance (`windowSize`). + Note that these values could be wrong, either because of data corruption, or because a 3rd party deliberately spoofs false information. + As a consequence, check that values remain within valid application range. + For example, do not allocate memory blindly, check that `windowSize` is within expectation. + Each application can set its own limits, depending on local restrictions. + For extended interoperability, it is recommended to support `windowSize` of at least 8 MB. + + ZSTD_decompressContinue() needs previous data blocks during decompression, up to `windowSize` bytes. + ZSTD_decompressContinue() is very sensitive to contiguity, + if 2 blocks don't follow each other, make sure that either the compressor breaks contiguity at the same place, + or that previous contiguous segment is large enough to properly handle maximum back-reference distance. + There are multiple ways to guarantee this condition. + + The most memory efficient way is to use a round buffer of sufficient size. + Sufficient size is determined by invoking ZSTD_decodingBufferSize_min(), + which can @return an error code if required value is too large for current system (in 32-bits mode). + In a round buffer methodology, ZSTD_decompressContinue() decompresses each block next to previous one, + up to the moment there is not enough room left in the buffer to guarantee decoding another full block, + which maximum size is provided in `ZSTD_frameHeader` structure, field `blockSizeMax`. + At which point, decoding can resume from the beginning of the buffer. + Note that already decoded data stored in the buffer should be flushed before being overwritten. + + There are alternatives possible, for example using two or more buffers of size `windowSize` each, though they consume more memory. + + Finally, if you control the compression process, you can also ignore all buffer size rules, + as long as the encoder and decoder progress in "lock-step", + aka use exactly the same buffer sizes, break contiguity at the same place, etc. + + Once buffers are setup, start decompression, with ZSTD_decompressBegin(). + If decompression requires a dictionary, use ZSTD_decompressBegin_usingDict() or ZSTD_decompressBegin_usingDDict(). + + Then use ZSTD_nextSrcSizeToDecompress() and ZSTD_decompressContinue() alternatively. + ZSTD_nextSrcSizeToDecompress() tells how many bytes to provide as 'srcSize' to ZSTD_decompressContinue(). + ZSTD_decompressContinue() requires this _exact_ amount of bytes, or it will fail. + + @result of ZSTD_decompressContinue() is the number of bytes regenerated within 'dst' (necessarily <= dstCapacity). + It can be zero : it just means ZSTD_decompressContinue() has decoded some metadata item. + It can also be an error code, which can be tested with ZSTD_isError(). + + A frame is fully decoded when ZSTD_nextSrcSizeToDecompress() returns zero. + Context can then be reset to start a new decompression. + + Note : it's possible to know if next input to present is a header or a block, using ZSTD_nextInputType(). + This information is not required to properly decode a frame. + + == Special case : skippable frames == + + Skippable frames allow integration of user-defined data into a flow of concatenated frames. + Skippable frames will be ignored (skipped) by decompressor. + The format of skippable frames is as follows : + a) Skippable frame ID - 4 Bytes, Little endian format, any value from 0x184D2A50 to 0x184D2A5F + b) Frame Size - 4 Bytes, Little endian format, unsigned 32-bits + c) Frame Content - any content (User Data) of length equal to Frame Size + For skippable frames ZSTD_getFrameHeader() returns zfhPtr->frameType==ZSTD_skippableFrame. + For skippable frames ZSTD_decompressContinue() always returns 0 : it only skips the content. +*/ + +/*===== Buffer-less streaming decompression functions =====*/ +typedef enum { ZSTD_frame, ZSTD_skippableFrame } ZSTD_frameType_e; +typedef struct { + unsigned long long frameContentSize; /* if == ZSTD_CONTENTSIZE_UNKNOWN, it means this field is not available. 0 means "empty" */ + unsigned long long windowSize; /* can be very large, up to <= frameContentSize */ + unsigned blockSizeMax; + ZSTD_frameType_e frameType; /* if == ZSTD_skippableFrame, frameContentSize is the size of skippable content */ + unsigned headerSize; + unsigned dictID; + unsigned checksumFlag; +} ZSTD_frameHeader; + +/*! ZSTD_getFrameHeader() : + * decode Frame Header, or requires larger `srcSize`. + * @return : 0, `zfhPtr` is correctly filled, + * >0, `srcSize` is too small, value is wanted `srcSize` amount, + * or an error code, which can be tested using ZSTD_isError() */ +ZSTDLIB_STATIC_API size_t ZSTD_getFrameHeader(ZSTD_frameHeader* zfhPtr, const void* src, size_t srcSize); /*< doesn't consume input */ +/*! ZSTD_getFrameHeader_advanced() : + * same as ZSTD_getFrameHeader(), + * with added capability to select a format (like ZSTD_f_zstd1_magicless) */ +ZSTDLIB_STATIC_API size_t ZSTD_getFrameHeader_advanced(ZSTD_frameHeader* zfhPtr, const void* src, size_t srcSize, ZSTD_format_e format); +ZSTDLIB_STATIC_API size_t ZSTD_decodingBufferSize_min(unsigned long long windowSize, unsigned long long frameContentSize); /*< when frame content size is not known, pass in frameContentSize == ZSTD_CONTENTSIZE_UNKNOWN */ + +ZSTDLIB_STATIC_API size_t ZSTD_decompressBegin(ZSTD_DCtx* dctx); +ZSTDLIB_STATIC_API size_t ZSTD_decompressBegin_usingDict(ZSTD_DCtx* dctx, const void* dict, size_t dictSize); +ZSTDLIB_STATIC_API size_t ZSTD_decompressBegin_usingDDict(ZSTD_DCtx* dctx, const ZSTD_DDict* ddict); + +ZSTDLIB_STATIC_API size_t ZSTD_nextSrcSizeToDecompress(ZSTD_DCtx* dctx); +ZSTDLIB_STATIC_API size_t ZSTD_decompressContinue(ZSTD_DCtx* dctx, void* dst, size_t dstCapacity, const void* src, size_t srcSize); + +/* misc */ +ZSTDLIB_STATIC_API void ZSTD_copyDCtx(ZSTD_DCtx* dctx, const ZSTD_DCtx* preparedDCtx); +typedef enum { ZSTDnit_frameHeader, ZSTDnit_blockHeader, ZSTDnit_block, ZSTDnit_lastBlock, ZSTDnit_checksum, ZSTDnit_skippableFrame } ZSTD_nextInputType_e; +ZSTDLIB_STATIC_API ZSTD_nextInputType_e ZSTD_nextInputType(ZSTD_DCtx* dctx); + + + + +/* ============================ */ +/* Block level API */ +/* ============================ */ + +/*! + Block functions produce and decode raw zstd blocks, without frame metadata. + Frame metadata cost is typically ~12 bytes, which can be non-negligible for very small blocks (< 100 bytes). + But users will have to take in charge needed metadata to regenerate data, such as compressed and content sizes. + + A few rules to respect : + - Compressing and decompressing require a context structure + + Use ZSTD_createCCtx() and ZSTD_createDCtx() + - It is necessary to init context before starting + + compression : any ZSTD_compressBegin*() variant, including with dictionary + + decompression : any ZSTD_decompressBegin*() variant, including with dictionary + + copyCCtx() and copyDCtx() can be used too + - Block size is limited, it must be <= ZSTD_getBlockSize() <= ZSTD_BLOCKSIZE_MAX == 128 KB + + If input is larger than a block size, it's necessary to split input data into multiple blocks + + For inputs larger than a single block, consider using regular ZSTD_compress() instead. + Frame metadata is not that costly, and quickly becomes negligible as source size grows larger than a block. + - When a block is considered not compressible enough, ZSTD_compressBlock() result will be 0 (zero) ! + ===> In which case, nothing is produced into `dst` ! + + User __must__ test for such outcome and deal directly with uncompressed data + + A block cannot be declared incompressible if ZSTD_compressBlock() return value was != 0. + Doing so would mess up with statistics history, leading to potential data corruption. + + ZSTD_decompressBlock() _doesn't accept uncompressed data as input_ !! + + In case of multiple successive blocks, should some of them be uncompressed, + decoder must be informed of their existence in order to follow proper history. + Use ZSTD_insertBlock() for such a case. +*/ + +/*===== Raw zstd block functions =====*/ +ZSTDLIB_STATIC_API size_t ZSTD_getBlockSize (const ZSTD_CCtx* cctx); +ZSTDLIB_STATIC_API size_t ZSTD_compressBlock (ZSTD_CCtx* cctx, void* dst, size_t dstCapacity, const void* src, size_t srcSize); +ZSTDLIB_STATIC_API size_t ZSTD_decompressBlock(ZSTD_DCtx* dctx, void* dst, size_t dstCapacity, const void* src, size_t srcSize); +ZSTDLIB_STATIC_API size_t ZSTD_insertBlock (ZSTD_DCtx* dctx, const void* blockStart, size_t blockSize); /*< insert uncompressed block into `dctx` history. Useful for multi-blocks decompression. */ + + +#endif /* ZSTD_H_ZSTD_STATIC_LINKING_ONLY */ + diff --git a/lib/Kconfig b/lib/Kconfig index 3c5a4ab3861..c0a8740f83d 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -691,6 +691,21 @@ config ZSTD help This enables Zstandard decompression library.
+if ZSTD + +config ZSTD_LIB_MINIFY + bool "Minify Zstandard code" + default y + help + This disables various optional components and changes the + compilation flags to prioritize space-saving. + + For detailed info, see zstd's lib/README.md + + https://github.com/facebook/zstd/blob/dev/lib/README.md + +endif + config SPL_LZ4 bool "Enable LZ4 decompression support in SPL" depends on SPL diff --git a/lib/zstd/Makefile b/lib/zstd/Makefile index 12170892923..ac198700f50 100644 --- a/lib/zstd/Makefile +++ b/lib/zstd/Makefile @@ -1,4 +1,35 @@ +# SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +# ################################################################ +# Copyright (c) Facebook, Inc. +# All rights reserved. +# +# This source code is licensed under both the BSD-style license (found in the +# LICENSE file in the root directory of this source tree) and the GPLv2 (found +# in the COPYING file in the root directory of this source tree). +# You may select, at your option, one of the above-listed licenses. +# ################################################################ obj-y += zstd_decompress.o +obj-y += zstd_common.o
-zstd_decompress-y := huf_decompress.o decompress.o \ - entropy_common.o fse_decompress.o zstd_common.o zstd.o +ifeq ($(CONFIG_ZSTD_LIB_MINIFY),y) +ccflags-y += -DHUF_FORCE_DECOMPRESS_X1 +ccflags-y += -DZSTD_FORCE_DECOMPRESS_SEQUENCES_SHORT +ccflags-y += -DZSTD_NO_INLINE +ccflags-y += -DZSTD_STRIP_ERROR_STRINGS +endif + +zstd_decompress-y := \ + zstd_decompress_module.o \ + decompress/huf_decompress.o \ + decompress/zstd_ddict.o \ + decompress/zstd_decompress.o \ + decompress/zstd_decompress_block.o \ + zstd.o \ + +zstd_common-y := \ + zstd_common_module.o \ + common/debug.o \ + common/entropy_common.o \ + common/error_private.o \ + common/fse_decompress.o \ + common/zstd_common.o \ diff --git a/lib/zstd/bitstream.h b/lib/zstd/bitstream.h deleted file mode 100644 index 44abfd5eb24..00000000000 --- a/lib/zstd/bitstream.h +++ /dev/null @@ -1,344 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 or BSD-2-Clause) */ -/* - * bitstream - * Part of FSE library - * header file (to include) - * Copyright (C) 2013-2016, Yann Collet. - * - * You can contact the author at : - * - Source repository : https://github.com/Cyan4973/FiniteStateEntropy - */ -#ifndef BITSTREAM_H_MODULE -#define BITSTREAM_H_MODULE - -/* -* This API consists of small unitary functions, which must be inlined for best performance. -* Since link-time-optimization is not available for all compilers, -* these functions are defined into a .h to be included. -*/ - -/*-**************************************** -* Dependencies -******************************************/ -#include "error_private.h" /* error codes and messages */ -#include "mem.h" /* unaligned access routines */ - -/*========================================= -* Target specific -=========================================*/ -#define STREAM_ACCUMULATOR_MIN_32 25 -#define STREAM_ACCUMULATOR_MIN_64 57 -#define STREAM_ACCUMULATOR_MIN ((U32)(ZSTD_32bits() ? STREAM_ACCUMULATOR_MIN_32 : STREAM_ACCUMULATOR_MIN_64)) - -/*-****************************************** -* bitStream encoding API (write forward) -********************************************/ -/* bitStream can mix input from multiple sources. -* A critical property of these streams is that they encode and decode in **reverse** direction. -* So the first bit sequence you add will be the last to be read, like a LIFO stack. -*/ -typedef struct { - size_t bitContainer; - int bitPos; - char *startPtr; - char *ptr; - char *endPtr; -} BIT_CStream_t; - -ZSTD_STATIC size_t BIT_initCStream(BIT_CStream_t *bitC, void *dstBuffer, size_t dstCapacity); -ZSTD_STATIC void BIT_addBits(BIT_CStream_t *bitC, size_t value, unsigned nbBits); -ZSTD_STATIC void BIT_flushBits(BIT_CStream_t *bitC); -ZSTD_STATIC size_t BIT_closeCStream(BIT_CStream_t *bitC); - -/* Start with initCStream, providing the size of buffer to write into. -* bitStream will never write outside of this buffer. -* `dstCapacity` must be >= sizeof(bitD->bitContainer), otherwise @return will be an error code. -* -* bits are first added to a local register. -* Local register is size_t, hence 64-bits on 64-bits systems, or 32-bits on 32-bits systems. -* Writing data into memory is an explicit operation, performed by the flushBits function. -* Hence keep track how many bits are potentially stored into local register to avoid register overflow. -* After a flushBits, a maximum of 7 bits might still be stored into local register. -* -* Avoid storing elements of more than 24 bits if you want compatibility with 32-bits bitstream readers. -* -* Last operation is to close the bitStream. -* The function returns the final size of CStream in bytes. -* If data couldn't fit into `dstBuffer`, it will return a 0 ( == not storable) -*/ - -/*-******************************************** -* bitStream decoding API (read backward) -**********************************************/ -typedef struct { - size_t bitContainer; - unsigned bitsConsumed; - const char *ptr; - const char *start; -} BIT_DStream_t; - -typedef enum { - BIT_DStream_unfinished = 0, - BIT_DStream_endOfBuffer = 1, - BIT_DStream_completed = 2, - BIT_DStream_overflow = 3 -} BIT_DStream_status; /* result of BIT_reloadDStream() */ -/* 1,2,4,8 would be better for bitmap combinations, but slows down performance a bit ... :( */ - -ZSTD_STATIC size_t BIT_initDStream(BIT_DStream_t *bitD, const void *srcBuffer, size_t srcSize); -ZSTD_STATIC size_t BIT_readBits(BIT_DStream_t *bitD, unsigned nbBits); -ZSTD_STATIC BIT_DStream_status BIT_reloadDStream(BIT_DStream_t *bitD); -ZSTD_STATIC unsigned BIT_endOfDStream(const BIT_DStream_t *bitD); - -/* Start by invoking BIT_initDStream(). -* A chunk of the bitStream is then stored into a local register. -* Local register size is 64-bits on 64-bits systems, 32-bits on 32-bits systems (size_t). -* You can then retrieve bitFields stored into the local register, **in reverse order**. -* Local register is explicitly reloaded from memory by the BIT_reloadDStream() method. -* A reload guarantee a minimum of ((8*sizeof(bitD->bitContainer))-7) bits when its result is BIT_DStream_unfinished. -* Otherwise, it can be less than that, so proceed accordingly. -* Checking if DStream has reached its end can be performed with BIT_endOfDStream(). -*/ - -/*-**************************************** -* unsafe API -******************************************/ -ZSTD_STATIC void BIT_addBitsFast(BIT_CStream_t *bitC, size_t value, unsigned nbBits); -/* faster, but works only if value is "clean", meaning all high bits above nbBits are 0 */ - -ZSTD_STATIC void BIT_flushBitsFast(BIT_CStream_t *bitC); -/* unsafe version; does not check buffer overflow */ - -ZSTD_STATIC size_t BIT_readBitsFast(BIT_DStream_t *bitD, unsigned nbBits); -/* faster, but works only if nbBits >= 1 */ - -/*-************************************************************** -* Internal functions -****************************************************************/ -ZSTD_STATIC unsigned BIT_highbit32(register U32 val) { return 31 - __builtin_clz(val); } - -/*===== Local Constants =====*/ -static const unsigned BIT_mask[] = {0, 1, 3, 7, 0xF, 0x1F, 0x3F, 0x7F, 0xFF, - 0x1FF, 0x3FF, 0x7FF, 0xFFF, 0x1FFF, 0x3FFF, 0x7FFF, 0xFFFF, 0x1FFFF, - 0x3FFFF, 0x7FFFF, 0xFFFFF, 0x1FFFFF, 0x3FFFFF, 0x7FFFFF, 0xFFFFFF, 0x1FFFFFF, 0x3FFFFFF}; /* up to 26 bits */ - -/*-************************************************************** -* bitStream encoding -****************************************************************/ -/*! BIT_initCStream() : - * `dstCapacity` must be > sizeof(void*) - * Return: 0 if success, - otherwise an error code (can be tested using ERR_isError() ) */ -ZSTD_STATIC size_t BIT_initCStream(BIT_CStream_t *bitC, void *startPtr, size_t dstCapacity) -{ - bitC->bitContainer = 0; - bitC->bitPos = 0; - bitC->startPtr = (char *)startPtr; - bitC->ptr = bitC->startPtr; - bitC->endPtr = bitC->startPtr + dstCapacity - sizeof(bitC->ptr); - if (dstCapacity <= sizeof(bitC->ptr)) - return ERROR(dstSize_tooSmall); - return 0; -} - -/*! BIT_addBits() : - can add up to 26 bits into `bitC`. - Does not check for register overflow ! */ -ZSTD_STATIC void BIT_addBits(BIT_CStream_t *bitC, size_t value, unsigned nbBits) -{ - bitC->bitContainer |= (value & BIT_mask[nbBits]) << bitC->bitPos; - bitC->bitPos += nbBits; -} - -/*! BIT_addBitsFast() : - * works only if `value` is _clean_, meaning all high bits above nbBits are 0 */ -ZSTD_STATIC void BIT_addBitsFast(BIT_CStream_t *bitC, size_t value, unsigned nbBits) -{ - bitC->bitContainer |= value << bitC->bitPos; - bitC->bitPos += nbBits; -} - -/*! BIT_flushBitsFast() : - * unsafe version; does not check buffer overflow */ -ZSTD_STATIC void BIT_flushBitsFast(BIT_CStream_t *bitC) -{ - size_t const nbBytes = bitC->bitPos >> 3; - ZSTD_writeLEST(bitC->ptr, bitC->bitContainer); - bitC->ptr += nbBytes; - bitC->bitPos &= 7; - bitC->bitContainer >>= nbBytes * 8; /* if bitPos >= sizeof(bitContainer)*8 --> undefined behavior */ -} - -/*! BIT_flushBits() : - * safe version; check for buffer overflow, and prevents it. - * note : does not signal buffer overflow. This will be revealed later on using BIT_closeCStream() */ -ZSTD_STATIC void BIT_flushBits(BIT_CStream_t *bitC) -{ - size_t const nbBytes = bitC->bitPos >> 3; - ZSTD_writeLEST(bitC->ptr, bitC->bitContainer); - bitC->ptr += nbBytes; - if (bitC->ptr > bitC->endPtr) - bitC->ptr = bitC->endPtr; - bitC->bitPos &= 7; - bitC->bitContainer >>= nbBytes * 8; /* if bitPos >= sizeof(bitContainer)*8 --> undefined behavior */ -} - -/*! BIT_closeCStream() : - * Return: size of CStream, in bytes, - or 0 if it could not fit into dstBuffer */ -ZSTD_STATIC size_t BIT_closeCStream(BIT_CStream_t *bitC) -{ - BIT_addBitsFast(bitC, 1, 1); /* endMark */ - BIT_flushBits(bitC); - - if (bitC->ptr >= bitC->endPtr) - return 0; /* doesn't fit within authorized budget : cancel */ - - return (bitC->ptr - bitC->startPtr) + (bitC->bitPos > 0); -} - -/*-******************************************************** -* bitStream decoding -**********************************************************/ -/*! BIT_initDStream() : -* Initialize a BIT_DStream_t. -* `bitD` : a pointer to an already allocated BIT_DStream_t structure. -* `srcSize` must be the *exact* size of the bitStream, in bytes. -* @return : size of stream (== srcSize) or an errorCode if a problem is detected -*/ -ZSTD_STATIC size_t BIT_initDStream(BIT_DStream_t *bitD, const void *srcBuffer, size_t srcSize) -{ - if (srcSize < 1) { - memset(bitD, 0, sizeof(*bitD)); - return ERROR(srcSize_wrong); - } - - if (srcSize >= sizeof(bitD->bitContainer)) { /* normal case */ - bitD->start = (const char *)srcBuffer; - bitD->ptr = (const char *)srcBuffer + srcSize - sizeof(bitD->bitContainer); - bitD->bitContainer = ZSTD_readLEST(bitD->ptr); - { - BYTE const lastByte = ((const BYTE *)srcBuffer)[srcSize - 1]; - bitD->bitsConsumed = lastByte ? 8 - BIT_highbit32(lastByte) : 0; /* ensures bitsConsumed is always set */ - if (lastByte == 0) - return ERROR(GENERIC); /* endMark not present */ - } - } else { - bitD->start = (const char *)srcBuffer; - bitD->ptr = bitD->start; - bitD->bitContainer = *(const BYTE *)(bitD->start); - switch (srcSize) { - case 7: bitD->bitContainer += (size_t)(((const BYTE *)(srcBuffer))[6]) << (sizeof(bitD->bitContainer) * 8 - 16); - case 6: bitD->bitContainer += (size_t)(((const BYTE *)(srcBuffer))[5]) << (sizeof(bitD->bitContainer) * 8 - 24); - case 5: bitD->bitContainer += (size_t)(((const BYTE *)(srcBuffer))[4]) << (sizeof(bitD->bitContainer) * 8 - 32); - case 4: bitD->bitContainer += (size_t)(((const BYTE *)(srcBuffer))[3]) << 24; - case 3: bitD->bitContainer += (size_t)(((const BYTE *)(srcBuffer))[2]) << 16; - case 2: bitD->bitContainer += (size_t)(((const BYTE *)(srcBuffer))[1]) << 8; - default:; - } - { - BYTE const lastByte = ((const BYTE *)srcBuffer)[srcSize - 1]; - bitD->bitsConsumed = lastByte ? 8 - BIT_highbit32(lastByte) : 0; - if (lastByte == 0) - return ERROR(GENERIC); /* endMark not present */ - } - bitD->bitsConsumed += (U32)(sizeof(bitD->bitContainer) - srcSize) * 8; - } - - return srcSize; -} - -ZSTD_STATIC size_t BIT_getUpperBits(size_t bitContainer, U32 const start) { return bitContainer >> start; } - -ZSTD_STATIC size_t BIT_getMiddleBits(size_t bitContainer, U32 const start, U32 const nbBits) { return (bitContainer >> start) & BIT_mask[nbBits]; } - -ZSTD_STATIC size_t BIT_getLowerBits(size_t bitContainer, U32 const nbBits) { return bitContainer & BIT_mask[nbBits]; } - -/*! BIT_lookBits() : - * Provides next n bits from local register. - * local register is not modified. - * On 32-bits, maxNbBits==24. - * On 64-bits, maxNbBits==56. - * Return: value extracted - */ -ZSTD_STATIC size_t BIT_lookBits(const BIT_DStream_t *bitD, U32 nbBits) -{ - U32 const bitMask = sizeof(bitD->bitContainer) * 8 - 1; - return ((bitD->bitContainer << (bitD->bitsConsumed & bitMask)) >> 1) >> ((bitMask - nbBits) & bitMask); -} - -/*! BIT_lookBitsFast() : -* unsafe version; only works only if nbBits >= 1 */ -ZSTD_STATIC size_t BIT_lookBitsFast(const BIT_DStream_t *bitD, U32 nbBits) -{ - U32 const bitMask = sizeof(bitD->bitContainer) * 8 - 1; - return (bitD->bitContainer << (bitD->bitsConsumed & bitMask)) >> (((bitMask + 1) - nbBits) & bitMask); -} - -ZSTD_STATIC void BIT_skipBits(BIT_DStream_t *bitD, U32 nbBits) { bitD->bitsConsumed += nbBits; } - -/*! BIT_readBits() : - * Read (consume) next n bits from local register and update. - * Pay attention to not read more than nbBits contained into local register. - * Return: extracted value. - */ -ZSTD_STATIC size_t BIT_readBits(BIT_DStream_t *bitD, U32 nbBits) -{ - size_t const value = BIT_lookBits(bitD, nbBits); - BIT_skipBits(bitD, nbBits); - return value; -} - -/*! BIT_readBitsFast() : -* unsafe version; only works only if nbBits >= 1 */ -ZSTD_STATIC size_t BIT_readBitsFast(BIT_DStream_t *bitD, U32 nbBits) -{ - size_t const value = BIT_lookBitsFast(bitD, nbBits); - BIT_skipBits(bitD, nbBits); - return value; -} - -/*! BIT_reloadDStream() : -* Refill `bitD` from buffer previously set in BIT_initDStream() . -* This function is safe, it guarantees it will not read beyond src buffer. -* @return : status of `BIT_DStream_t` internal register. - if status == BIT_DStream_unfinished, internal register is filled with >= (sizeof(bitD->bitContainer)*8 - 7) bits */ -ZSTD_STATIC BIT_DStream_status BIT_reloadDStream(BIT_DStream_t *bitD) -{ - if (bitD->bitsConsumed > (sizeof(bitD->bitContainer) * 8)) /* should not happen => corruption detected */ - return BIT_DStream_overflow; - - if (bitD->ptr >= bitD->start + sizeof(bitD->bitContainer)) { - bitD->ptr -= bitD->bitsConsumed >> 3; - bitD->bitsConsumed &= 7; - bitD->bitContainer = ZSTD_readLEST(bitD->ptr); - return BIT_DStream_unfinished; - } - if (bitD->ptr == bitD->start) { - if (bitD->bitsConsumed < sizeof(bitD->bitContainer) * 8) - return BIT_DStream_endOfBuffer; - return BIT_DStream_completed; - } - { - U32 nbBytes = bitD->bitsConsumed >> 3; - BIT_DStream_status result = BIT_DStream_unfinished; - if (bitD->ptr - nbBytes < bitD->start) { - nbBytes = (U32)(bitD->ptr - bitD->start); /* ptr > start */ - result = BIT_DStream_endOfBuffer; - } - bitD->ptr -= nbBytes; - bitD->bitsConsumed -= nbBytes * 8; - bitD->bitContainer = ZSTD_readLEST(bitD->ptr); /* reminder : srcSize > sizeof(bitD) */ - return result; - } -} - -/*! BIT_endOfDStream() : -* @return Tells if DStream has exactly reached its end (all bits consumed). -*/ -ZSTD_STATIC unsigned BIT_endOfDStream(const BIT_DStream_t *DStream) -{ - return ((DStream->ptr == DStream->start) && (DStream->bitsConsumed == sizeof(DStream->bitContainer) * 8)); -} - -#endif /* BITSTREAM_H_MODULE */ diff --git a/lib/zstd/common/bitstream.h b/lib/zstd/common/bitstream.h new file mode 100644 index 00000000000..feef3a1b1d6 --- /dev/null +++ b/lib/zstd/common/bitstream.h @@ -0,0 +1,446 @@ +/* ****************************************************************** + * bitstream + * Part of FSE library + * Copyright (c) Yann Collet, Facebook, Inc. + * + * You can contact the author at : + * - Source repository : https://github.com/Cyan4973/FiniteStateEntropy + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. +****************************************************************** */ +#ifndef BITSTREAM_H_MODULE +#define BITSTREAM_H_MODULE + +/* +* This API consists of small unitary functions, which must be inlined for best performance. +* Since link-time-optimization is not available for all compilers, +* these functions are defined into a .h to be included. +*/ + +/*-**************************************** +* Dependencies +******************************************/ +#include "mem.h" /* unaligned access routines */ +#include "compiler.h" /* UNLIKELY() */ +#include "debug.h" /* assert(), DEBUGLOG(), RAWLOG() */ +#include "error_private.h" /* error codes and messages */ + + +/*========================================= +* Target specific +=========================================*/ + +#define STREAM_ACCUMULATOR_MIN_32 25 +#define STREAM_ACCUMULATOR_MIN_64 57 +#define STREAM_ACCUMULATOR_MIN ((U32)(MEM_32bits() ? STREAM_ACCUMULATOR_MIN_32 : STREAM_ACCUMULATOR_MIN_64)) + + +/*-****************************************** +* bitStream encoding API (write forward) +********************************************/ +/* bitStream can mix input from multiple sources. + * A critical property of these streams is that they encode and decode in **reverse** direction. + * So the first bit sequence you add will be the last to be read, like a LIFO stack. + */ +typedef struct { + size_t bitContainer; + unsigned bitPos; + char* startPtr; + char* ptr; + char* endPtr; +} BIT_CStream_t; + +MEM_STATIC size_t BIT_initCStream(BIT_CStream_t* bitC, void* dstBuffer, size_t dstCapacity); +MEM_STATIC void BIT_addBits(BIT_CStream_t* bitC, size_t value, unsigned nbBits); +MEM_STATIC void BIT_flushBits(BIT_CStream_t* bitC); +MEM_STATIC size_t BIT_closeCStream(BIT_CStream_t* bitC); + +/* Start with initCStream, providing the size of buffer to write into. +* bitStream will never write outside of this buffer. +* `dstCapacity` must be >= sizeof(bitD->bitContainer), otherwise @return will be an error code. +* +* bits are first added to a local register. +* Local register is size_t, hence 64-bits on 64-bits systems, or 32-bits on 32-bits systems. +* Writing data into memory is an explicit operation, performed by the flushBits function. +* Hence keep track how many bits are potentially stored into local register to avoid register overflow. +* After a flushBits, a maximum of 7 bits might still be stored into local register. +* +* Avoid storing elements of more than 24 bits if you want compatibility with 32-bits bitstream readers. +* +* Last operation is to close the bitStream. +* The function returns the final size of CStream in bytes. +* If data couldn't fit into `dstBuffer`, it will return a 0 ( == not storable) +*/ + + +/*-******************************************** +* bitStream decoding API (read backward) +**********************************************/ +typedef struct { + size_t bitContainer; + unsigned bitsConsumed; + const char* ptr; + const char* start; + const char* limitPtr; +} BIT_DStream_t; + +typedef enum { BIT_DStream_unfinished = 0, + BIT_DStream_endOfBuffer = 1, + BIT_DStream_completed = 2, + BIT_DStream_overflow = 3 } BIT_DStream_status; /* result of BIT_reloadDStream() */ + /* 1,2,4,8 would be better for bitmap combinations, but slows down performance a bit ... :( */ + +MEM_STATIC size_t BIT_initDStream(BIT_DStream_t* bitD, const void* srcBuffer, size_t srcSize); +MEM_STATIC size_t BIT_readBits(BIT_DStream_t* bitD, unsigned nbBits); +MEM_STATIC BIT_DStream_status BIT_reloadDStream(BIT_DStream_t* bitD); +MEM_STATIC unsigned BIT_endOfDStream(const BIT_DStream_t* bitD); + + +/* Start by invoking BIT_initDStream(). +* A chunk of the bitStream is then stored into a local register. +* Local register size is 64-bits on 64-bits systems, 32-bits on 32-bits systems (size_t). +* You can then retrieve bitFields stored into the local register, **in reverse order**. +* Local register is explicitly reloaded from memory by the BIT_reloadDStream() method. +* A reload guarantee a minimum of ((8*sizeof(bitD->bitContainer))-7) bits when its result is BIT_DStream_unfinished. +* Otherwise, it can be less than that, so proceed accordingly. +* Checking if DStream has reached its end can be performed with BIT_endOfDStream(). +*/ + + +/*-**************************************** +* unsafe API +******************************************/ +MEM_STATIC void BIT_addBitsFast(BIT_CStream_t* bitC, size_t value, unsigned nbBits); +/* faster, but works only if value is "clean", meaning all high bits above nbBits are 0 */ + +MEM_STATIC void BIT_flushBitsFast(BIT_CStream_t* bitC); +/* unsafe version; does not check buffer overflow */ + +MEM_STATIC size_t BIT_readBitsFast(BIT_DStream_t* bitD, unsigned nbBits); +/* faster, but works only if nbBits >= 1 */ + + + +/*-************************************************************** +* Internal functions +****************************************************************/ +MEM_STATIC unsigned BIT_highbit32 (U32 val) +{ + assert(val != 0); + { +# if (__GNUC__ >= 3) /* Use GCC Intrinsic */ + return __builtin_clz (val) ^ 31; +# else /* Software version */ + static const unsigned DeBruijnClz[32] = { 0, 9, 1, 10, 13, 21, 2, 29, + 11, 14, 16, 18, 22, 25, 3, 30, + 8, 12, 20, 28, 15, 17, 24, 7, + 19, 27, 23, 6, 26, 5, 4, 31 }; + U32 v = val; + v |= v >> 1; + v |= v >> 2; + v |= v >> 4; + v |= v >> 8; + v |= v >> 16; + return DeBruijnClz[ (U32) (v * 0x07C4ACDDU) >> 27]; +# endif + } +} + +/*===== Local Constants =====*/ +static const unsigned BIT_mask[] = { + 0, 1, 3, 7, 0xF, 0x1F, + 0x3F, 0x7F, 0xFF, 0x1FF, 0x3FF, 0x7FF, + 0xFFF, 0x1FFF, 0x3FFF, 0x7FFF, 0xFFFF, 0x1FFFF, + 0x3FFFF, 0x7FFFF, 0xFFFFF, 0x1FFFFF, 0x3FFFFF, 0x7FFFFF, + 0xFFFFFF, 0x1FFFFFF, 0x3FFFFFF, 0x7FFFFFF, 0xFFFFFFF, 0x1FFFFFFF, + 0x3FFFFFFF, 0x7FFFFFFF}; /* up to 31 bits */ +#define BIT_MASK_SIZE (sizeof(BIT_mask) / sizeof(BIT_mask[0])) + +/*-************************************************************** +* bitStream encoding +****************************************************************/ +/*! BIT_initCStream() : + * `dstCapacity` must be > sizeof(size_t) + * @return : 0 if success, + * otherwise an error code (can be tested using ERR_isError()) */ +MEM_STATIC size_t BIT_initCStream(BIT_CStream_t* bitC, + void* startPtr, size_t dstCapacity) +{ + bitC->bitContainer = 0; + bitC->bitPos = 0; + bitC->startPtr = (char*)startPtr; + bitC->ptr = bitC->startPtr; + bitC->endPtr = bitC->startPtr + dstCapacity - sizeof(bitC->bitContainer); + if (dstCapacity <= sizeof(bitC->bitContainer)) return ERROR(dstSize_tooSmall); + return 0; +} + +/*! BIT_addBits() : + * can add up to 31 bits into `bitC`. + * Note : does not check for register overflow ! */ +MEM_STATIC void BIT_addBits(BIT_CStream_t* bitC, + size_t value, unsigned nbBits) +{ + DEBUG_STATIC_ASSERT(BIT_MASK_SIZE == 32); + assert(nbBits < BIT_MASK_SIZE); + assert(nbBits + bitC->bitPos < sizeof(bitC->bitContainer) * 8); + bitC->bitContainer |= (value & BIT_mask[nbBits]) << bitC->bitPos; + bitC->bitPos += nbBits; +} + +/*! BIT_addBitsFast() : + * works only if `value` is _clean_, + * meaning all high bits above nbBits are 0 */ +MEM_STATIC void BIT_addBitsFast(BIT_CStream_t* bitC, + size_t value, unsigned nbBits) +{ + assert((value>>nbBits) == 0); + assert(nbBits + bitC->bitPos < sizeof(bitC->bitContainer) * 8); + bitC->bitContainer |= value << bitC->bitPos; + bitC->bitPos += nbBits; +} + +/*! BIT_flushBitsFast() : + * assumption : bitContainer has not overflowed + * unsafe version; does not check buffer overflow */ +MEM_STATIC void BIT_flushBitsFast(BIT_CStream_t* bitC) +{ + size_t const nbBytes = bitC->bitPos >> 3; + assert(bitC->bitPos < sizeof(bitC->bitContainer) * 8); + assert(bitC->ptr <= bitC->endPtr); + MEM_writeLEST(bitC->ptr, bitC->bitContainer); + bitC->ptr += nbBytes; + bitC->bitPos &= 7; + bitC->bitContainer >>= nbBytes*8; +} + +/*! BIT_flushBits() : + * assumption : bitContainer has not overflowed + * safe version; check for buffer overflow, and prevents it. + * note : does not signal buffer overflow. + * overflow will be revealed later on using BIT_closeCStream() */ +MEM_STATIC void BIT_flushBits(BIT_CStream_t* bitC) +{ + size_t const nbBytes = bitC->bitPos >> 3; + assert(bitC->bitPos < sizeof(bitC->bitContainer) * 8); + assert(bitC->ptr <= bitC->endPtr); + MEM_writeLEST(bitC->ptr, bitC->bitContainer); + bitC->ptr += nbBytes; + if (bitC->ptr > bitC->endPtr) bitC->ptr = bitC->endPtr; + bitC->bitPos &= 7; + bitC->bitContainer >>= nbBytes*8; +} + +/*! BIT_closeCStream() : + * @return : size of CStream, in bytes, + * or 0 if it could not fit into dstBuffer */ +MEM_STATIC size_t BIT_closeCStream(BIT_CStream_t* bitC) +{ + BIT_addBitsFast(bitC, 1, 1); /* endMark */ + BIT_flushBits(bitC); + if (bitC->ptr >= bitC->endPtr) return 0; /* overflow detected */ + return (bitC->ptr - bitC->startPtr) + (bitC->bitPos > 0); +} + + +/*-******************************************************** +* bitStream decoding +**********************************************************/ +/*! BIT_initDStream() : + * Initialize a BIT_DStream_t. + * `bitD` : a pointer to an already allocated BIT_DStream_t structure. + * `srcSize` must be the *exact* size of the bitStream, in bytes. + * @return : size of stream (== srcSize), or an errorCode if a problem is detected + */ +MEM_STATIC size_t BIT_initDStream(BIT_DStream_t* bitD, const void* srcBuffer, size_t srcSize) +{ + if (srcSize < 1) { ZSTD_memset(bitD, 0, sizeof(*bitD)); return ERROR(srcSize_wrong); } + + bitD->start = (const char*)srcBuffer; + bitD->limitPtr = bitD->start + sizeof(bitD->bitContainer); + + if (srcSize >= sizeof(bitD->bitContainer)) { /* normal case */ + bitD->ptr = (const char*)srcBuffer + srcSize - sizeof(bitD->bitContainer); + bitD->bitContainer = MEM_readLEST(bitD->ptr); + { BYTE const lastByte = ((const BYTE*)srcBuffer)[srcSize-1]; + bitD->bitsConsumed = lastByte ? 8 - BIT_highbit32(lastByte) : 0; /* ensures bitsConsumed is always set */ + if (lastByte == 0) return ERROR(GENERIC); /* endMark not present */ } + } else { + bitD->ptr = bitD->start; + bitD->bitContainer = *(const BYTE*)(bitD->start); + switch(srcSize) + { + case 7: bitD->bitContainer += (size_t)(((const BYTE*)(srcBuffer))[6]) << (sizeof(bitD->bitContainer)*8 - 16); + ZSTD_FALLTHROUGH; + + case 6: bitD->bitContainer += (size_t)(((const BYTE*)(srcBuffer))[5]) << (sizeof(bitD->bitContainer)*8 - 24); + ZSTD_FALLTHROUGH; + + case 5: bitD->bitContainer += (size_t)(((const BYTE*)(srcBuffer))[4]) << (sizeof(bitD->bitContainer)*8 - 32); + ZSTD_FALLTHROUGH; + + case 4: bitD->bitContainer += (size_t)(((const BYTE*)(srcBuffer))[3]) << 24; + ZSTD_FALLTHROUGH; + + case 3: bitD->bitContainer += (size_t)(((const BYTE*)(srcBuffer))[2]) << 16; + ZSTD_FALLTHROUGH; + + case 2: bitD->bitContainer += (size_t)(((const BYTE*)(srcBuffer))[1]) << 8; + ZSTD_FALLTHROUGH; + + default: break; + } + { BYTE const lastByte = ((const BYTE*)srcBuffer)[srcSize-1]; + bitD->bitsConsumed = lastByte ? 8 - BIT_highbit32(lastByte) : 0; + if (lastByte == 0) return ERROR(corruption_detected); /* endMark not present */ + } + bitD->bitsConsumed += (U32)(sizeof(bitD->bitContainer) - srcSize)*8; + } + + return srcSize; +} + +MEM_STATIC FORCE_INLINE_ATTR size_t BIT_getUpperBits(size_t bitContainer, U32 const start) +{ + return bitContainer >> start; +} + +MEM_STATIC FORCE_INLINE_ATTR size_t BIT_getMiddleBits(size_t bitContainer, U32 const start, U32 const nbBits) +{ + U32 const regMask = sizeof(bitContainer)*8 - 1; + /* if start > regMask, bitstream is corrupted, and result is undefined */ + assert(nbBits < BIT_MASK_SIZE); + /* x86 transform & ((1 << nbBits) - 1) to bzhi instruction, it is better + * than accessing memory. When bmi2 instruction is not present, we consider + * such cpus old (pre-Haswell, 2013) and their performance is not of that + * importance. + */ +#if defined(__x86_64__) || defined(_M_X86) + return (bitContainer >> (start & regMask)) & ((((U64)1) << nbBits) - 1); +#else + return (bitContainer >> (start & regMask)) & BIT_mask[nbBits]; +#endif +} + +MEM_STATIC FORCE_INLINE_ATTR size_t BIT_getLowerBits(size_t bitContainer, U32 const nbBits) +{ + assert(nbBits < BIT_MASK_SIZE); + return bitContainer & BIT_mask[nbBits]; +} + +/*! BIT_lookBits() : + * Provides next n bits from local register. + * local register is not modified. + * On 32-bits, maxNbBits==24. + * On 64-bits, maxNbBits==56. + * @return : value extracted */ +MEM_STATIC FORCE_INLINE_ATTR size_t BIT_lookBits(const BIT_DStream_t* bitD, U32 nbBits) +{ + /* arbitrate between double-shift and shift+mask */ +#if 1 + /* if bitD->bitsConsumed + nbBits > sizeof(bitD->bitContainer)*8, + * bitstream is likely corrupted, and result is undefined */ + return BIT_getMiddleBits(bitD->bitContainer, (sizeof(bitD->bitContainer)*8) - bitD->bitsConsumed - nbBits, nbBits); +#else + /* this code path is slower on my os-x laptop */ + U32 const regMask = sizeof(bitD->bitContainer)*8 - 1; + return ((bitD->bitContainer << (bitD->bitsConsumed & regMask)) >> 1) >> ((regMask-nbBits) & regMask); +#endif +} + +/*! BIT_lookBitsFast() : + * unsafe version; only works if nbBits >= 1 */ +MEM_STATIC size_t BIT_lookBitsFast(const BIT_DStream_t* bitD, U32 nbBits) +{ + U32 const regMask = sizeof(bitD->bitContainer)*8 - 1; + assert(nbBits >= 1); + return (bitD->bitContainer << (bitD->bitsConsumed & regMask)) >> (((regMask+1)-nbBits) & regMask); +} + +MEM_STATIC FORCE_INLINE_ATTR void BIT_skipBits(BIT_DStream_t* bitD, U32 nbBits) +{ + bitD->bitsConsumed += nbBits; +} + +/*! BIT_readBits() : + * Read (consume) next n bits from local register and update. + * Pay attention to not read more than nbBits contained into local register. + * @return : extracted value. */ +MEM_STATIC FORCE_INLINE_ATTR size_t BIT_readBits(BIT_DStream_t* bitD, unsigned nbBits) +{ + size_t const value = BIT_lookBits(bitD, nbBits); + BIT_skipBits(bitD, nbBits); + return value; +} + +/*! BIT_readBitsFast() : + * unsafe version; only works only if nbBits >= 1 */ +MEM_STATIC size_t BIT_readBitsFast(BIT_DStream_t* bitD, unsigned nbBits) +{ + size_t const value = BIT_lookBitsFast(bitD, nbBits); + assert(nbBits >= 1); + BIT_skipBits(bitD, nbBits); + return value; +} + +/*! BIT_reloadDStreamFast() : + * Similar to BIT_reloadDStream(), but with two differences: + * 1. bitsConsumed <= sizeof(bitD->bitContainer)*8 must hold! + * 2. Returns BIT_DStream_overflow when bitD->ptr < bitD->limitPtr, at this + * point you must use BIT_reloadDStream() to reload. + */ +MEM_STATIC BIT_DStream_status BIT_reloadDStreamFast(BIT_DStream_t* bitD) +{ + if (UNLIKELY(bitD->ptr < bitD->limitPtr)) + return BIT_DStream_overflow; + assert(bitD->bitsConsumed <= sizeof(bitD->bitContainer)*8); + bitD->ptr -= bitD->bitsConsumed >> 3; + bitD->bitsConsumed &= 7; + bitD->bitContainer = MEM_readLEST(bitD->ptr); + return BIT_DStream_unfinished; +} + +/*! BIT_reloadDStream() : + * Refill `bitD` from buffer previously set in BIT_initDStream() . + * This function is safe, it guarantees it will not read beyond src buffer. + * @return : status of `BIT_DStream_t` internal register. + * when status == BIT_DStream_unfinished, internal register is filled with at least 25 or 57 bits */ +MEM_STATIC BIT_DStream_status BIT_reloadDStream(BIT_DStream_t* bitD) +{ + if (bitD->bitsConsumed > (sizeof(bitD->bitContainer)*8)) /* overflow detected, like end of stream */ + return BIT_DStream_overflow; + + if (bitD->ptr >= bitD->limitPtr) { + return BIT_reloadDStreamFast(bitD); + } + if (bitD->ptr == bitD->start) { + if (bitD->bitsConsumed < sizeof(bitD->bitContainer)*8) return BIT_DStream_endOfBuffer; + return BIT_DStream_completed; + } + /* start < ptr < limitPtr */ + { U32 nbBytes = bitD->bitsConsumed >> 3; + BIT_DStream_status result = BIT_DStream_unfinished; + if (bitD->ptr - nbBytes < bitD->start) { + nbBytes = (U32)(bitD->ptr - bitD->start); /* ptr > start */ + result = BIT_DStream_endOfBuffer; + } + bitD->ptr -= nbBytes; + bitD->bitsConsumed -= nbBytes*8; + bitD->bitContainer = MEM_readLEST(bitD->ptr); /* reminder : srcSize > sizeof(bitD->bitContainer), otherwise bitD->ptr == bitD->start */ + return result; + } +} + +/*! BIT_endOfDStream() : + * @return : 1 if DStream has _exactly_ reached its end (all bits consumed). + */ +MEM_STATIC unsigned BIT_endOfDStream(const BIT_DStream_t* DStream) +{ + return ((DStream->ptr == DStream->start) && (DStream->bitsConsumed == sizeof(DStream->bitContainer)*8)); +} + + +#endif /* BITSTREAM_H_MODULE */ diff --git a/lib/zstd/common/compiler.h b/lib/zstd/common/compiler.h new file mode 100644 index 00000000000..c42d39faf9b --- /dev/null +++ b/lib/zstd/common/compiler.h @@ -0,0 +1,184 @@ +/* + * Copyright (c) Yann Collet, Facebook, Inc. + * All rights reserved. + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. + */ + +#ifndef ZSTD_COMPILER_H +#define ZSTD_COMPILER_H + +#include "portability_macros.h" + +/*-******************************************************* +* Compiler specifics +*********************************************************/ +/* force inlining */ + +#if !defined(ZSTD_NO_INLINE) +#if (defined(__GNUC__) && !defined(__STRICT_ANSI__)) || defined(__cplusplus) || defined(__STDC_VERSION__) && __STDC_VERSION__ >= 199901L /* C99 */ +# define INLINE_KEYWORD inline +#else +# define INLINE_KEYWORD +#endif + +#define FORCE_INLINE_ATTR __attribute__((always_inline)) + +#else + +#define INLINE_KEYWORD +#define FORCE_INLINE_ATTR + +#endif + +/* + On MSVC qsort requires that functions passed into it use the __cdecl calling conversion(CC). + This explicitly marks such functions as __cdecl so that the code will still compile + if a CC other than __cdecl has been made the default. +*/ +#define WIN_CDECL + +/* + * FORCE_INLINE_TEMPLATE is used to define C "templates", which take constant + * parameters. They must be inlined for the compiler to eliminate the constant + * branches. + */ +#define FORCE_INLINE_TEMPLATE static INLINE_KEYWORD FORCE_INLINE_ATTR +/* + * HINT_INLINE is used to help the compiler generate better code. It is *not* + * used for "templates", so it can be tweaked based on the compilers + * performance. + * + * gcc-4.8 and gcc-4.9 have been shown to benefit from leaving off the + * always_inline attribute. + * + * clang up to 5.0.0 (trunk) benefit tremendously from the always_inline + * attribute. + */ +#if !defined(__clang__) && defined(__GNUC__) && __GNUC__ >= 4 && __GNUC_MINOR__ >= 8 && __GNUC__ < 5 +# define HINT_INLINE static INLINE_KEYWORD +#else +# define HINT_INLINE static INLINE_KEYWORD FORCE_INLINE_ATTR +#endif + +/* UNUSED_ATTR tells the compiler it is okay if the function is unused. */ +#define UNUSED_ATTR __attribute__((unused)) + +/* force no inlining */ +#define FORCE_NOINLINE static __attribute__((__noinline__)) + + +/* target attribute */ +#define TARGET_ATTRIBUTE(target) __attribute__((__target__(target))) + +/* Target attribute for BMI2 dynamic dispatch. + * Enable lzcnt, bmi, and bmi2. + * We test for bmi1 & bmi2. lzcnt is included in bmi1. + */ +#define BMI2_TARGET_ATTRIBUTE TARGET_ATTRIBUTE("lzcnt,bmi,bmi2") + +/* prefetch + * can be disabled, by declaring NO_PREFETCH build macro */ +#if ( (__GNUC__ >= 4) || ( (__GNUC__ == 3) && (__GNUC_MINOR__ >= 1) ) ) +# define PREFETCH_L1(ptr) __builtin_prefetch((ptr), 0 /* rw==read */, 3 /* locality */) +# define PREFETCH_L2(ptr) __builtin_prefetch((ptr), 0 /* rw==read */, 2 /* locality */) +#elif defined(__aarch64__) +# define PREFETCH_L1(ptr) __asm__ __volatile__("prfm pldl1keep, %0" ::"Q"(*(ptr))) +# define PREFETCH_L2(ptr) __asm__ __volatile__("prfm pldl2keep, %0" ::"Q"(*(ptr))) +#else +# define PREFETCH_L1(ptr) (void)(ptr) /* disabled */ +# define PREFETCH_L2(ptr) (void)(ptr) /* disabled */ +#endif /* NO_PREFETCH */ + +#define CACHELINE_SIZE 64 + +#define PREFETCH_AREA(p, s) { \ + const char* const _ptr = (const char*)(p); \ + size_t const _size = (size_t)(s); \ + size_t _pos; \ + for (_pos=0; _pos<_size; _pos+=CACHELINE_SIZE) { \ + PREFETCH_L2(_ptr + _pos); \ + } \ +} + +/* vectorization + * older GCC (pre gcc-4.3 picked as the cutoff) uses a different syntax, + * and some compilers, like Intel ICC and MCST LCC, do not support it at all. */ +#if !defined(__INTEL_COMPILER) && !defined(__clang__) && defined(__GNUC__) && !defined(__LCC__) +# if (__GNUC__ == 4 && __GNUC_MINOR__ > 3) || (__GNUC__ >= 5) +# define DONT_VECTORIZE __attribute__((optimize("no-tree-vectorize"))) +# else +# define DONT_VECTORIZE _Pragma("GCC optimize("no-tree-vectorize")") +# endif +#else +# define DONT_VECTORIZE +#endif + +/* Tell the compiler that a branch is likely or unlikely. + * Only use these macros if it causes the compiler to generate better code. + * If you can remove a LIKELY/UNLIKELY annotation without speed changes in gcc + * and clang, please do. + */ +#define LIKELY(x) (__builtin_expect((x), 1)) +#define UNLIKELY(x) (__builtin_expect((x), 0)) + +#if __has_builtin(__builtin_unreachable) || (defined(__GNUC__) && (__GNUC__ > 4 || (__GNUC__ == 4 && __GNUC_MINOR__ >= 5))) +# define ZSTD_UNREACHABLE { assert(0), __builtin_unreachable(); } +#else +# define ZSTD_UNREACHABLE { assert(0); } +#endif + +/* disable warnings */ + +/*Like DYNAMIC_BMI2 but for compile time determination of BMI2 support*/ + + +/* compile time determination of SIMD support */ + +/* C-language Attributes are added in C23. */ +#if defined(__STDC_VERSION__) && (__STDC_VERSION__ > 201710L) && defined(__has_c_attribute) +# define ZSTD_HAS_C_ATTRIBUTE(x) __has_c_attribute(x) +#else +# define ZSTD_HAS_C_ATTRIBUTE(x) 0 +#endif + +/* Only use C++ attributes in C++. Some compilers report support for C++ + * attributes when compiling with C. + */ +#define ZSTD_HAS_CPP_ATTRIBUTE(x) 0 + +/* Define ZSTD_FALLTHROUGH macro for annotating switch case with the 'fallthrough' attribute. + * - C23: https://en.cppreference.com/w/c/language/attributes/fallthrough + * - CPP17: https://en.cppreference.com/w/cpp/language/attributes/fallthrough + * - Else: __attribute__((__fallthrough__)) + */ +#define ZSTD_FALLTHROUGH fallthrough + +/*-************************************************************** +* Alignment check +*****************************************************************/ + +/* this test was initially positioned in mem.h, + * but this file is removed (or replaced) for linux kernel + * so it's now hosted in compiler.h, + * which remains valid for both user & kernel spaces. + */ + +#ifndef ZSTD_ALIGNOF +/* covers gcc, clang & MSVC */ +/* note : this section must come first, before C11, + * due to a limitation in the kernel source generator */ +# define ZSTD_ALIGNOF(T) __alignof(T) + +#endif /* ZSTD_ALIGNOF */ + +/*-************************************************************** +* Sanitizer +*****************************************************************/ + + + +#endif /* ZSTD_COMPILER_H */ diff --git a/lib/zstd/common/cpu.h b/lib/zstd/common/cpu.h new file mode 100644 index 00000000000..0db7b42407e --- /dev/null +++ b/lib/zstd/common/cpu.h @@ -0,0 +1,194 @@ +/* + * Copyright (c) Facebook, Inc. + * All rights reserved. + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. + */ + +#ifndef ZSTD_COMMON_CPU_H +#define ZSTD_COMMON_CPU_H + +/* + * Implementation taken from folly/CpuId.h + * https://github.com/facebook/folly/blob/master/folly/CpuId.h + */ + +#include "mem.h" + + +typedef struct { + U32 f1c; + U32 f1d; + U32 f7b; + U32 f7c; +} ZSTD_cpuid_t; + +MEM_STATIC ZSTD_cpuid_t ZSTD_cpuid(void) { + U32 f1c = 0; + U32 f1d = 0; + U32 f7b = 0; + U32 f7c = 0; +#if defined(__i386__) && defined(__PIC__) && !defined(__clang__) && defined(__GNUC__) + /* The following block like the normal cpuid branch below, but gcc + * reserves ebx for use of its pic register so we must specially + * handle the save and restore to avoid clobbering the register + */ + U32 n; + __asm__( + "pushl %%ebx\n\t" + "cpuid\n\t" + "popl %%ebx\n\t" + : "=a"(n) + : "a"(0) + : "ecx", "edx"); + if (n >= 1) { + U32 f1a; + __asm__( + "pushl %%ebx\n\t" + "cpuid\n\t" + "popl %%ebx\n\t" + : "=a"(f1a), "=c"(f1c), "=d"(f1d) + : "a"(1)); + } + if (n >= 7) { + __asm__( + "pushl %%ebx\n\t" + "cpuid\n\t" + "movl %%ebx, %%eax\n\t" + "popl %%ebx" + : "=a"(f7b), "=c"(f7c) + : "a"(7), "c"(0) + : "edx"); + } +#elif defined(__x86_64__) || defined(_M_X64) || defined(__i386__) + U32 n; + __asm__("cpuid" : "=a"(n) : "a"(0) : "ebx", "ecx", "edx"); + if (n >= 1) { + U32 f1a; + __asm__("cpuid" : "=a"(f1a), "=c"(f1c), "=d"(f1d) : "a"(1) : "ebx"); + } + if (n >= 7) { + U32 f7a; + __asm__("cpuid" + : "=a"(f7a), "=b"(f7b), "=c"(f7c) + : "a"(7), "c"(0) + : "edx"); + } +#endif + { + ZSTD_cpuid_t cpuid; + cpuid.f1c = f1c; + cpuid.f1d = f1d; + cpuid.f7b = f7b; + cpuid.f7c = f7c; + return cpuid; + } +} + +#define X(name, r, bit) \ + MEM_STATIC int ZSTD_cpuid_##name(ZSTD_cpuid_t const cpuid) { \ + return ((cpuid.r) & (1U << bit)) != 0; \ + } + +/* cpuid(1): Processor Info and Feature Bits. */ +#define C(name, bit) X(name, f1c, bit) + C(sse3, 0) + C(pclmuldq, 1) + C(dtes64, 2) + C(monitor, 3) + C(dscpl, 4) + C(vmx, 5) + C(smx, 6) + C(eist, 7) + C(tm2, 8) + C(ssse3, 9) + C(cnxtid, 10) + C(fma, 12) + C(cx16, 13) + C(xtpr, 14) + C(pdcm, 15) + C(pcid, 17) + C(dca, 18) + C(sse41, 19) + C(sse42, 20) + C(x2apic, 21) + C(movbe, 22) + C(popcnt, 23) + C(tscdeadline, 24) + C(aes, 25) + C(xsave, 26) + C(osxsave, 27) + C(avx, 28) + C(f16c, 29) + C(rdrand, 30) +#undef C +#define D(name, bit) X(name, f1d, bit) + D(fpu, 0) + D(vme, 1) + D(de, 2) + D(pse, 3) + D(tsc, 4) + D(msr, 5) + D(pae, 6) + D(mce, 7) + D(cx8, 8) + D(apic, 9) + D(sep, 11) + D(mtrr, 12) + D(pge, 13) + D(mca, 14) + D(cmov, 15) + D(pat, 16) + D(pse36, 17) + D(psn, 18) + D(clfsh, 19) + D(ds, 21) + D(acpi, 22) + D(mmx, 23) + D(fxsr, 24) + D(sse, 25) + D(sse2, 26) + D(ss, 27) + D(htt, 28) + D(tm, 29) + D(pbe, 31) +#undef D + +/* cpuid(7): Extended Features. */ +#define B(name, bit) X(name, f7b, bit) + B(bmi1, 3) + B(hle, 4) + B(avx2, 5) + B(smep, 7) + B(bmi2, 8) + B(erms, 9) + B(invpcid, 10) + B(rtm, 11) + B(mpx, 14) + B(avx512f, 16) + B(avx512dq, 17) + B(rdseed, 18) + B(adx, 19) + B(smap, 20) + B(avx512ifma, 21) + B(pcommit, 22) + B(clflushopt, 23) + B(clwb, 24) + B(avx512pf, 26) + B(avx512er, 27) + B(avx512cd, 28) + B(sha, 29) + B(avx512bw, 30) + B(avx512vl, 31) +#undef B +#define C(name, bit) X(name, f7c, bit) + C(prefetchwt1, 0) + C(avx512vbmi, 1) +#undef C + +#undef X + +#endif /* ZSTD_COMMON_CPU_H */ diff --git a/lib/zstd/common/debug.c b/lib/zstd/common/debug.c new file mode 100644 index 00000000000..bb863c9ea61 --- /dev/null +++ b/lib/zstd/common/debug.c @@ -0,0 +1,24 @@ +/* ****************************************************************** + * debug + * Part of FSE library + * Copyright (c) Yann Collet, Facebook, Inc. + * + * You can contact the author at : + * - Source repository : https://github.com/Cyan4973/FiniteStateEntropy + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. +****************************************************************** */ + + +/* + * This module only hosts one global variable + * which can be used to dynamically influence the verbosity of traces, + * such as DEBUGLOG and RAWLOG + */ + +#include "debug.h" + +int g_debuglevel = DEBUGLEVEL; diff --git a/lib/zstd/common/debug.h b/lib/zstd/common/debug.h new file mode 100644 index 00000000000..7f43dd3c063 --- /dev/null +++ b/lib/zstd/common/debug.h @@ -0,0 +1,92 @@ +/* ****************************************************************** + * debug + * Part of FSE library + * Copyright (c) Yann Collet, Facebook, Inc. + * + * You can contact the author at : + * - Source repository : https://github.com/Cyan4973/FiniteStateEntropy + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. +****************************************************************** */ + + +/* + * The purpose of this header is to enable debug functions. + * They regroup assert(), DEBUGLOG() and RAWLOG() for run-time, + * and DEBUG_STATIC_ASSERT() for compile-time. + * + * By default, DEBUGLEVEL==0, which means run-time debug is disabled. + * + * Level 1 enables assert() only. + * Starting level 2, traces can be generated and pushed to stderr. + * The higher the level, the more verbose the traces. + * + * It's possible to dynamically adjust level using variable g_debug_level, + * which is only declared if DEBUGLEVEL>=2, + * and is a global variable, not multi-thread protected (use with care) + */ + +#ifndef DEBUG_H_12987983217 +#define DEBUG_H_12987983217 + + + +/* static assert is triggered at compile time, leaving no runtime artefact. + * static assert only works with compile-time constants. + * Also, this variant can only be used inside a function. */ +#define DEBUG_STATIC_ASSERT(c) (void)sizeof(char[(c) ? 1 : -1]) + + +/* DEBUGLEVEL is expected to be defined externally, + * typically through compiler command line. + * Value must be a number. */ +#ifndef DEBUGLEVEL +# define DEBUGLEVEL 0 +#endif + + +/* recommended values for DEBUGLEVEL : + * 0 : release mode, no debug, all run-time checks disabled + * 1 : enables assert() only, no display + * 2 : reserved, for currently active debug path + * 3 : events once per object lifetime (CCtx, CDict, etc.) + * 4 : events once per frame + * 5 : events once per block + * 6 : events once per sequence (verbose) + * 7+: events at every position (*very* verbose) + * + * It's generally inconvenient to output traces > 5. + * In which case, it's possible to selectively trigger high verbosity levels + * by modifying g_debug_level. + */ + +#if (DEBUGLEVEL>=2) +# define ZSTD_DEPS_NEED_IO +# include "zstd_deps.h" +extern int g_debuglevel; /* the variable is only declared, + it actually lives in debug.c, + and is shared by the whole process. + It's not thread-safe. + It's useful when enabling very verbose levels + on selective conditions (such as position in src) */ + +# define RAWLOG(l, ...) { \ + if (l<=g_debuglevel) { \ + ZSTD_DEBUG_PRINT(__VA_ARGS__); \ + } } +# define DEBUGLOG(l, ...) { \ + if (l<=g_debuglevel) { \ + ZSTD_DEBUG_PRINT(__FILE__ ": " __VA_ARGS__); \ + ZSTD_DEBUG_PRINT(" \n"); \ + } } +#else +# define RAWLOG(l, ...) {} /* disabled */ +# define DEBUGLOG(l, ...) {} /* disabled */ +#endif + + + +#endif /* DEBUG_H_12987983217 */ diff --git a/lib/zstd/common/entropy_common.c b/lib/zstd/common/entropy_common.c new file mode 100644 index 00000000000..fef67056f05 --- /dev/null +++ b/lib/zstd/common/entropy_common.c @@ -0,0 +1,357 @@ +/* ****************************************************************** + * Common functions of New Generation Entropy library + * Copyright (c) Yann Collet, Facebook, Inc. + * + * You can contact the author at : + * - FSE+HUF source repository : https://github.com/Cyan4973/FiniteStateEntropy + * - Public forum : https://groups.google.com/forum/#!forum/lz4c + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. +****************************************************************** */ + +/* ************************************* +* Dependencies +***************************************/ +#include "mem.h" +#include "error_private.h" /* ERR_*, ERROR */ +#define FSE_STATIC_LINKING_ONLY /* FSE_MIN_TABLELOG */ +#include "fse.h" +#define HUF_STATIC_LINKING_ONLY /* HUF_TABLELOG_ABSOLUTEMAX */ +#include "huf.h" + + +/*=== Version ===*/ +unsigned FSE_versionNumber(void) { return FSE_VERSION_NUMBER; } + + +/*=== Error Management ===*/ +unsigned FSE_isError(size_t code) { return ERR_isError(code); } +const char* FSE_getErrorName(size_t code) { return ERR_getErrorName(code); } + +unsigned HUF_isError(size_t code) { return ERR_isError(code); } +const char* HUF_getErrorName(size_t code) { return ERR_getErrorName(code); } + + +/*-************************************************************** +* FSE NCount encoding-decoding +****************************************************************/ +static U32 FSE_ctz(U32 val) +{ + assert(val != 0); + { +# if (__GNUC__ >= 3) /* GCC Intrinsic */ + return __builtin_ctz(val); +# else /* Software version */ + U32 count = 0; + while ((val & 1) == 0) { + val >>= 1; + ++count; + } + return count; +# endif + } +} + +FORCE_INLINE_TEMPLATE +size_t FSE_readNCount_body(short* normalizedCounter, unsigned* maxSVPtr, unsigned* tableLogPtr, + const void* headerBuffer, size_t hbSize) +{ + const BYTE* const istart = (const BYTE*) headerBuffer; + const BYTE* const iend = istart + hbSize; + const BYTE* ip = istart; + int nbBits; + int remaining; + int threshold; + U32 bitStream; + int bitCount; + unsigned charnum = 0; + unsigned const maxSV1 = *maxSVPtr + 1; + int previous0 = 0; + + if (hbSize < 8) { + /* This function only works when hbSize >= 8 */ + char buffer[8] = {0}; + ZSTD_memcpy(buffer, headerBuffer, hbSize); + { size_t const countSize = FSE_readNCount(normalizedCounter, maxSVPtr, tableLogPtr, + buffer, sizeof(buffer)); + if (FSE_isError(countSize)) return countSize; + if (countSize > hbSize) return ERROR(corruption_detected); + return countSize; + } } + assert(hbSize >= 8); + + /* init */ + ZSTD_memset(normalizedCounter, 0, (*maxSVPtr+1) * sizeof(normalizedCounter[0])); /* all symbols not present in NCount have a frequency of 0 */ + bitStream = MEM_readLE32(ip); + nbBits = (bitStream & 0xF) + FSE_MIN_TABLELOG; /* extract tableLog */ + if (nbBits > FSE_TABLELOG_ABSOLUTE_MAX) return ERROR(tableLog_tooLarge); + bitStream >>= 4; + bitCount = 4; + *tableLogPtr = nbBits; + remaining = (1<<nbBits)+1; + threshold = 1<<nbBits; + nbBits++; + + for (;;) { + if (previous0) { + /* Count the number of repeats. Each time the + * 2-bit repeat code is 0b11 there is another + * repeat. + * Avoid UB by setting the high bit to 1. + */ + int repeats = FSE_ctz(~bitStream | 0x80000000) >> 1; + while (repeats >= 12) { + charnum += 3 * 12; + if (LIKELY(ip <= iend-7)) { + ip += 3; + } else { + bitCount -= (int)(8 * (iend - 7 - ip)); + bitCount &= 31; + ip = iend - 4; + } + bitStream = MEM_readLE32(ip) >> bitCount; + repeats = FSE_ctz(~bitStream | 0x80000000) >> 1; + } + charnum += 3 * repeats; + bitStream >>= 2 * repeats; + bitCount += 2 * repeats; + + /* Add the final repeat which isn't 0b11. */ + assert((bitStream & 3) < 3); + charnum += bitStream & 3; + bitCount += 2; + + /* This is an error, but break and return an error + * at the end, because returning out of a loop makes + * it harder for the compiler to optimize. + */ + if (charnum >= maxSV1) break; + + /* We don't need to set the normalized count to 0 + * because we already memset the whole buffer to 0. + */ + + if (LIKELY(ip <= iend-7) || (ip + (bitCount>>3) <= iend-4)) { + assert((bitCount >> 3) <= 3); /* For first condition to work */ + ip += bitCount>>3; + bitCount &= 7; + } else { + bitCount -= (int)(8 * (iend - 4 - ip)); + bitCount &= 31; + ip = iend - 4; + } + bitStream = MEM_readLE32(ip) >> bitCount; + } + { + int const max = (2*threshold-1) - remaining; + int count; + + if ((bitStream & (threshold-1)) < (U32)max) { + count = bitStream & (threshold-1); + bitCount += nbBits-1; + } else { + count = bitStream & (2*threshold-1); + if (count >= threshold) count -= max; + bitCount += nbBits; + } + + count--; /* extra accuracy */ + /* When it matters (small blocks), this is a + * predictable branch, because we don't use -1. + */ + if (count >= 0) { + remaining -= count; + } else { + assert(count == -1); + remaining += count; + } + normalizedCounter[charnum++] = (short)count; + previous0 = !count; + + assert(threshold > 1); + if (remaining < threshold) { + /* This branch can be folded into the + * threshold update condition because we + * know that threshold > 1. + */ + if (remaining <= 1) break; + nbBits = BIT_highbit32(remaining) + 1; + threshold = 1 << (nbBits - 1); + } + if (charnum >= maxSV1) break; + + if (LIKELY(ip <= iend-7) || (ip + (bitCount>>3) <= iend-4)) { + ip += bitCount>>3; + bitCount &= 7; + } else { + bitCount -= (int)(8 * (iend - 4 - ip)); + bitCount &= 31; + ip = iend - 4; + } + bitStream = MEM_readLE32(ip) >> bitCount; + } } + if (remaining != 1) return ERROR(corruption_detected); + /* Only possible when there are too many zeros. */ + if (charnum > maxSV1) return ERROR(maxSymbolValue_tooSmall); + if (bitCount > 32) return ERROR(corruption_detected); + *maxSVPtr = charnum-1; + + ip += (bitCount+7)>>3; + return ip-istart; +} + +/* Avoids the FORCE_INLINE of the _body() function. */ +static size_t FSE_readNCount_body_default( + short* normalizedCounter, unsigned* maxSVPtr, unsigned* tableLogPtr, + const void* headerBuffer, size_t hbSize) +{ + return FSE_readNCount_body(normalizedCounter, maxSVPtr, tableLogPtr, headerBuffer, hbSize); +} + +#if DYNAMIC_BMI2 +BMI2_TARGET_ATTRIBUTE static size_t FSE_readNCount_body_bmi2( + short* normalizedCounter, unsigned* maxSVPtr, unsigned* tableLogPtr, + const void* headerBuffer, size_t hbSize) +{ + return FSE_readNCount_body(normalizedCounter, maxSVPtr, tableLogPtr, headerBuffer, hbSize); +} +#endif + +size_t FSE_readNCount_bmi2( + short* normalizedCounter, unsigned* maxSVPtr, unsigned* tableLogPtr, + const void* headerBuffer, size_t hbSize, int bmi2) +{ +#if DYNAMIC_BMI2 + if (bmi2) { + return FSE_readNCount_body_bmi2(normalizedCounter, maxSVPtr, tableLogPtr, headerBuffer, hbSize); + } +#endif + (void)bmi2; + return FSE_readNCount_body_default(normalizedCounter, maxSVPtr, tableLogPtr, headerBuffer, hbSize); +} + +size_t FSE_readNCount( + short* normalizedCounter, unsigned* maxSVPtr, unsigned* tableLogPtr, + const void* headerBuffer, size_t hbSize) +{ + return FSE_readNCount_bmi2(normalizedCounter, maxSVPtr, tableLogPtr, headerBuffer, hbSize, /* bmi2 */ 0); +} + + +/*! HUF_readStats() : + Read compact Huffman tree, saved by HUF_writeCTable(). + `huffWeight` is destination buffer. + `rankStats` is assumed to be a table of at least HUF_TABLELOG_MAX U32. + @return : size read from `src` , or an error Code . + Note : Needed by HUF_readCTable() and HUF_readDTableX?() . +*/ +size_t HUF_readStats(BYTE* huffWeight, size_t hwSize, U32* rankStats, + U32* nbSymbolsPtr, U32* tableLogPtr, + const void* src, size_t srcSize) +{ + U32 wksp[HUF_READ_STATS_WORKSPACE_SIZE_U32]; + return HUF_readStats_wksp(huffWeight, hwSize, rankStats, nbSymbolsPtr, tableLogPtr, src, srcSize, wksp, sizeof(wksp), /* bmi2 */ 0); +} + +FORCE_INLINE_TEMPLATE size_t +HUF_readStats_body(BYTE* huffWeight, size_t hwSize, U32* rankStats, + U32* nbSymbolsPtr, U32* tableLogPtr, + const void* src, size_t srcSize, + void* workSpace, size_t wkspSize, + int bmi2) +{ + U32 weightTotal; + const BYTE* ip = (const BYTE*) src; + size_t iSize; + size_t oSize; + + if (!srcSize) return ERROR(srcSize_wrong); + iSize = ip[0]; + /* ZSTD_memset(huffWeight, 0, hwSize); *//* is not necessary, even though some analyzer complain ... */ + + if (iSize >= 128) { /* special header */ + oSize = iSize - 127; + iSize = ((oSize+1)/2); + if (iSize+1 > srcSize) return ERROR(srcSize_wrong); + if (oSize >= hwSize) return ERROR(corruption_detected); + ip += 1; + { U32 n; + for (n=0; n<oSize; n+=2) { + huffWeight[n] = ip[n/2] >> 4; + huffWeight[n+1] = ip[n/2] & 15; + } } } + else { /* header compressed with FSE (normal case) */ + if (iSize+1 > srcSize) return ERROR(srcSize_wrong); + /* max (hwSize-1) values decoded, as last one is implied */ + oSize = FSE_decompress_wksp_bmi2(huffWeight, hwSize-1, ip+1, iSize, 6, workSpace, wkspSize, bmi2); + if (FSE_isError(oSize)) return oSize; + } + + /* collect weight stats */ + ZSTD_memset(rankStats, 0, (HUF_TABLELOG_MAX + 1) * sizeof(U32)); + weightTotal = 0; + { U32 n; for (n=0; n<oSize; n++) { + if (huffWeight[n] > HUF_TABLELOG_MAX) return ERROR(corruption_detected); + rankStats[huffWeight[n]]++; + weightTotal += (1 << huffWeight[n]) >> 1; + } } + if (weightTotal == 0) return ERROR(corruption_detected); + + /* get last non-null symbol weight (implied, total must be 2^n) */ + { U32 const tableLog = BIT_highbit32(weightTotal) + 1; + if (tableLog > HUF_TABLELOG_MAX) return ERROR(corruption_detected); + *tableLogPtr = tableLog; + /* determine last weight */ + { U32 const total = 1 << tableLog; + U32 const rest = total - weightTotal; + U32 const verif = 1 << BIT_highbit32(rest); + U32 const lastWeight = BIT_highbit32(rest) + 1; + if (verif != rest) return ERROR(corruption_detected); /* last value must be a clean power of 2 */ + huffWeight[oSize] = (BYTE)lastWeight; + rankStats[lastWeight]++; + } } + + /* check tree construction validity */ + if ((rankStats[1] < 2) || (rankStats[1] & 1)) return ERROR(corruption_detected); /* by construction : at least 2 elts of rank 1, must be even */ + + /* results */ + *nbSymbolsPtr = (U32)(oSize+1); + return iSize+1; +} + +/* Avoids the FORCE_INLINE of the _body() function. */ +static size_t HUF_readStats_body_default(BYTE* huffWeight, size_t hwSize, U32* rankStats, + U32* nbSymbolsPtr, U32* tableLogPtr, + const void* src, size_t srcSize, + void* workSpace, size_t wkspSize) +{ + return HUF_readStats_body(huffWeight, hwSize, rankStats, nbSymbolsPtr, tableLogPtr, src, srcSize, workSpace, wkspSize, 0); +} + +#if DYNAMIC_BMI2 +static BMI2_TARGET_ATTRIBUTE size_t HUF_readStats_body_bmi2(BYTE* huffWeight, size_t hwSize, U32* rankStats, + U32* nbSymbolsPtr, U32* tableLogPtr, + const void* src, size_t srcSize, + void* workSpace, size_t wkspSize) +{ + return HUF_readStats_body(huffWeight, hwSize, rankStats, nbSymbolsPtr, tableLogPtr, src, srcSize, workSpace, wkspSize, 1); +} +#endif + +size_t HUF_readStats_wksp(BYTE* huffWeight, size_t hwSize, U32* rankStats, + U32* nbSymbolsPtr, U32* tableLogPtr, + const void* src, size_t srcSize, + void* workSpace, size_t wkspSize, + int bmi2) +{ +#if DYNAMIC_BMI2 + if (bmi2) { + return HUF_readStats_body_bmi2(huffWeight, hwSize, rankStats, nbSymbolsPtr, tableLogPtr, src, srcSize, workSpace, wkspSize); + } +#endif + (void)bmi2; + return HUF_readStats_body_default(huffWeight, hwSize, rankStats, nbSymbolsPtr, tableLogPtr, src, srcSize, workSpace, wkspSize); +} diff --git a/lib/zstd/common/error_private.c b/lib/zstd/common/error_private.c new file mode 100644 index 00000000000..6d1135f8c37 --- /dev/null +++ b/lib/zstd/common/error_private.c @@ -0,0 +1,56 @@ +/* + * Copyright (c) Yann Collet, Facebook, Inc. + * All rights reserved. + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. + */ + +/* The purpose of this file is to have a single list of error strings embedded in binary */ + +#include "error_private.h" + +const char* ERR_getErrorString(ERR_enum code) +{ +#ifdef ZSTD_STRIP_ERROR_STRINGS + (void)code; + return "Error strings stripped"; +#else + static const char* const notErrorCode = "Unspecified error code"; + switch( code ) + { + case PREFIX(no_error): return "No error detected"; + case PREFIX(GENERIC): return "Error (generic)"; + case PREFIX(prefix_unknown): return "Unknown frame descriptor"; + case PREFIX(version_unsupported): return "Version not supported"; + case PREFIX(frameParameter_unsupported): return "Unsupported frame parameter"; + case PREFIX(frameParameter_windowTooLarge): return "Frame requires too much memory for decoding"; + case PREFIX(corruption_detected): return "Corrupted block detected"; + case PREFIX(checksum_wrong): return "Restored data doesn't match checksum"; + case PREFIX(parameter_unsupported): return "Unsupported parameter"; + case PREFIX(parameter_outOfBound): return "Parameter is out of bound"; + case PREFIX(init_missing): return "Context should be init first"; + case PREFIX(memory_allocation): return "Allocation error : not enough memory"; + case PREFIX(workSpace_tooSmall): return "workSpace buffer is not large enough"; + case PREFIX(stage_wrong): return "Operation not authorized at current processing stage"; + case PREFIX(tableLog_tooLarge): return "tableLog requires too much memory : unsupported"; + case PREFIX(maxSymbolValue_tooLarge): return "Unsupported max Symbol Value : too large"; + case PREFIX(maxSymbolValue_tooSmall): return "Specified maxSymbolValue is too small"; + case PREFIX(dictionary_corrupted): return "Dictionary is corrupted"; + case PREFIX(dictionary_wrong): return "Dictionary mismatch"; + case PREFIX(dictionaryCreation_failed): return "Cannot create Dictionary from provided samples"; + case PREFIX(dstSize_tooSmall): return "Destination buffer is too small"; + case PREFIX(srcSize_wrong): return "Src size is incorrect"; + case PREFIX(dstBuffer_null): return "Operation on NULL destination buffer"; + /* following error codes are not stable and may be removed or changed in a future version */ + case PREFIX(frameIndex_tooLarge): return "Frame index is too large"; + case PREFIX(seekableIO): return "An I/O error occurred when reading/seeking"; + case PREFIX(dstBuffer_wrong): return "Destination buffer is wrong"; + case PREFIX(srcBuffer_wrong): return "Source buffer is wrong"; + case PREFIX(maxCode): + default: return notErrorCode; + } +#endif +} diff --git a/lib/zstd/common/error_private.h b/lib/zstd/common/error_private.h new file mode 100644 index 00000000000..ca5101e542f --- /dev/null +++ b/lib/zstd/common/error_private.h @@ -0,0 +1,145 @@ +/* + * Copyright (c) Yann Collet, Facebook, Inc. + * All rights reserved. + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. + */ + +/* Note : this module is expected to remain private, do not expose it */ + +#ifndef ERROR_H_MODULE +#define ERROR_H_MODULE + + + +/* **************************************** +* Dependencies +******************************************/ +#include <linux/zstd_errors.h> /* enum list */ +#include "compiler.h" +#include "debug.h" +#include "zstd_deps.h" /* size_t */ + + +/* **************************************** +* Compiler-specific +******************************************/ +#define ERR_STATIC static __attribute__((unused)) + + +/*-**************************************** +* Customization (error_public.h) +******************************************/ +typedef ZSTD_ErrorCode ERR_enum; +#define PREFIX(name) ZSTD_error_##name + + +/*-**************************************** +* Error codes handling +******************************************/ +#undef ERROR /* already defined on Visual Studio */ +#define ERROR(name) ZSTD_ERROR(name) +#define ZSTD_ERROR(name) ((size_t)-PREFIX(name)) + +ERR_STATIC unsigned ERR_isError(size_t code) { return (code > ERROR(maxCode)); } + +ERR_STATIC ERR_enum ERR_getErrorCode(size_t code) { if (!ERR_isError(code)) return (ERR_enum)0; return (ERR_enum) (0-code); } + +/* check and forward error code */ +#define CHECK_V_F(e, f) size_t const e = f; if (ERR_isError(e)) return e +#define CHECK_F(f) { CHECK_V_F(_var_err__, f); } + + +/*-**************************************** +* Error Strings +******************************************/ + +const char* ERR_getErrorString(ERR_enum code); /* error_private.c */ + +ERR_STATIC const char* ERR_getErrorName(size_t code) +{ + return ERR_getErrorString(ERR_getErrorCode(code)); +} + +/* + * Ignore: this is an internal helper. + * + * This is a helper function to help force C99-correctness during compilation. + * Under strict compilation modes, variadic macro arguments can't be empty. + * However, variadic function arguments can be. Using a function therefore lets + * us statically check that at least one (string) argument was passed, + * independent of the compilation flags. + */ +static INLINE_KEYWORD UNUSED_ATTR +void _force_has_format_string(const char *format, ...) { + (void)format; +} + +/* + * Ignore: this is an internal helper. + * + * We want to force this function invocation to be syntactically correct, but + * we don't want to force runtime evaluation of its arguments. + */ +#define _FORCE_HAS_FORMAT_STRING(...) \ + if (0) { \ + _force_has_format_string(__VA_ARGS__); \ + } + +#define ERR_QUOTE(str) #str + +/* + * Return the specified error if the condition evaluates to true. + * + * In debug modes, prints additional information. + * In order to do that (particularly, printing the conditional that failed), + * this can't just wrap RETURN_ERROR(). + */ +#define RETURN_ERROR_IF(cond, err, ...) \ + if (cond) { \ + RAWLOG(3, "%s:%d: ERROR!: check %s failed, returning %s", \ + __FILE__, __LINE__, ERR_QUOTE(cond), ERR_QUOTE(ERROR(err))); \ + _FORCE_HAS_FORMAT_STRING(__VA_ARGS__); \ + RAWLOG(3, ": " __VA_ARGS__); \ + RAWLOG(3, "\n"); \ + return ERROR(err); \ + } + +/* + * Unconditionally return the specified error. + * + * In debug modes, prints additional information. + */ +#define RETURN_ERROR(err, ...) \ + do { \ + RAWLOG(3, "%s:%d: ERROR!: unconditional check failed, returning %s", \ + __FILE__, __LINE__, ERR_QUOTE(ERROR(err))); \ + _FORCE_HAS_FORMAT_STRING(__VA_ARGS__); \ + RAWLOG(3, ": " __VA_ARGS__); \ + RAWLOG(3, "\n"); \ + return ERROR(err); \ + } while(0); + +/* + * If the provided expression evaluates to an error code, returns that error code. + * + * In debug modes, prints additional information. + */ +#define FORWARD_IF_ERROR(err, ...) \ + do { \ + size_t const err_code = (err); \ + if (ERR_isError(err_code)) { \ + RAWLOG(3, "%s:%d: ERROR!: forwarding error in %s: %s", \ + __FILE__, __LINE__, ERR_QUOTE(err), ERR_getErrorName(err_code)); \ + _FORCE_HAS_FORMAT_STRING(__VA_ARGS__); \ + RAWLOG(3, ": " __VA_ARGS__); \ + RAWLOG(3, "\n"); \ + return err_code; \ + } \ + } while(0); + + +#endif /* ERROR_H_MODULE */ diff --git a/lib/zstd/common/fse.h b/lib/zstd/common/fse.h new file mode 100644 index 00000000000..4507043b228 --- /dev/null +++ b/lib/zstd/common/fse.h @@ -0,0 +1,711 @@ +/* ****************************************************************** + * FSE : Finite State Entropy codec + * Public Prototypes declaration + * Copyright (c) Yann Collet, Facebook, Inc. + * + * You can contact the author at : + * - Source repository : https://github.com/Cyan4973/FiniteStateEntropy + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. +****************************************************************** */ + + +#ifndef FSE_H +#define FSE_H + + +/*-***************************************** +* Dependencies +******************************************/ +#include "zstd_deps.h" /* size_t, ptrdiff_t */ + + +/*-***************************************** +* FSE_PUBLIC_API : control library symbols visibility +******************************************/ +#if defined(FSE_DLL_EXPORT) && (FSE_DLL_EXPORT==1) && defined(__GNUC__) && (__GNUC__ >= 4) +# define FSE_PUBLIC_API __attribute__ ((visibility ("default"))) +#elif defined(FSE_DLL_EXPORT) && (FSE_DLL_EXPORT==1) /* Visual expected */ +# define FSE_PUBLIC_API __declspec(dllexport) +#elif defined(FSE_DLL_IMPORT) && (FSE_DLL_IMPORT==1) +# define FSE_PUBLIC_API __declspec(dllimport) /* It isn't required but allows to generate better code, saving a function pointer load from the IAT and an indirect jump.*/ +#else +# define FSE_PUBLIC_API +#endif + +/*------ Version ------*/ +#define FSE_VERSION_MAJOR 0 +#define FSE_VERSION_MINOR 9 +#define FSE_VERSION_RELEASE 0 + +#define FSE_LIB_VERSION FSE_VERSION_MAJOR.FSE_VERSION_MINOR.FSE_VERSION_RELEASE +#define FSE_QUOTE(str) #str +#define FSE_EXPAND_AND_QUOTE(str) FSE_QUOTE(str) +#define FSE_VERSION_STRING FSE_EXPAND_AND_QUOTE(FSE_LIB_VERSION) + +#define FSE_VERSION_NUMBER (FSE_VERSION_MAJOR *100*100 + FSE_VERSION_MINOR *100 + FSE_VERSION_RELEASE) +FSE_PUBLIC_API unsigned FSE_versionNumber(void); /*< library version number; to be used when checking dll version */ + + +/*-**************************************** +* FSE simple functions +******************************************/ +/*! FSE_compress() : + Compress content of buffer 'src', of size 'srcSize', into destination buffer 'dst'. + 'dst' buffer must be already allocated. Compression runs faster is dstCapacity >= FSE_compressBound(srcSize). + @return : size of compressed data (<= dstCapacity). + Special values : if return == 0, srcData is not compressible => Nothing is stored within dst !!! + if return == 1, srcData is a single byte symbol * srcSize times. Use RLE compression instead. + if FSE_isError(return), compression failed (more details using FSE_getErrorName()) +*/ +FSE_PUBLIC_API size_t FSE_compress(void* dst, size_t dstCapacity, + const void* src, size_t srcSize); + +/*! FSE_decompress(): + Decompress FSE data from buffer 'cSrc', of size 'cSrcSize', + into already allocated destination buffer 'dst', of size 'dstCapacity'. + @return : size of regenerated data (<= maxDstSize), + or an error code, which can be tested using FSE_isError() . + + ** Important ** : FSE_decompress() does not decompress non-compressible nor RLE data !!! + Why ? : making this distinction requires a header. + Header management is intentionally delegated to the user layer, which can better manage special cases. +*/ +FSE_PUBLIC_API size_t FSE_decompress(void* dst, size_t dstCapacity, + const void* cSrc, size_t cSrcSize); + + +/*-***************************************** +* Tool functions +******************************************/ +FSE_PUBLIC_API size_t FSE_compressBound(size_t size); /* maximum compressed size */ + +/* Error Management */ +FSE_PUBLIC_API unsigned FSE_isError(size_t code); /* tells if a return value is an error code */ +FSE_PUBLIC_API const char* FSE_getErrorName(size_t code); /* provides error code string (useful for debugging) */ + + +/*-***************************************** +* FSE advanced functions +******************************************/ +/*! FSE_compress2() : + Same as FSE_compress(), but allows the selection of 'maxSymbolValue' and 'tableLog' + Both parameters can be defined as '0' to mean : use default value + @return : size of compressed data + Special values : if return == 0, srcData is not compressible => Nothing is stored within cSrc !!! + if return == 1, srcData is a single byte symbol * srcSize times. Use RLE compression. + if FSE_isError(return), it's an error code. +*/ +FSE_PUBLIC_API size_t FSE_compress2 (void* dst, size_t dstSize, const void* src, size_t srcSize, unsigned maxSymbolValue, unsigned tableLog); + + +/*-***************************************** +* FSE detailed API +******************************************/ +/*! +FSE_compress() does the following: +1. count symbol occurrence from source[] into table count[] (see hist.h) +2. normalize counters so that sum(count[]) == Power_of_2 (2^tableLog) +3. save normalized counters to memory buffer using writeNCount() +4. build encoding table 'CTable' from normalized counters +5. encode the data stream using encoding table 'CTable' + +FSE_decompress() does the following: +1. read normalized counters with readNCount() +2. build decoding table 'DTable' from normalized counters +3. decode the data stream using decoding table 'DTable' + +The following API allows targeting specific sub-functions for advanced tasks. +For example, it's possible to compress several blocks using the same 'CTable', +or to save and provide normalized distribution using external method. +*/ + +/* *** COMPRESSION *** */ + +/*! FSE_optimalTableLog(): + dynamically downsize 'tableLog' when conditions are met. + It saves CPU time, by using smaller tables, while preserving or even improving compression ratio. + @return : recommended tableLog (necessarily <= 'maxTableLog') */ +FSE_PUBLIC_API unsigned FSE_optimalTableLog(unsigned maxTableLog, size_t srcSize, unsigned maxSymbolValue); + +/*! FSE_normalizeCount(): + normalize counts so that sum(count[]) == Power_of_2 (2^tableLog) + 'normalizedCounter' is a table of short, of minimum size (maxSymbolValue+1). + useLowProbCount is a boolean parameter which trades off compressed size for + faster header decoding. When it is set to 1, the compressed data will be slightly + smaller. And when it is set to 0, FSE_readNCount() and FSE_buildDTable() will be + faster. If you are compressing a small amount of data (< 2 KB) then useLowProbCount=0 + is a good default, since header deserialization makes a big speed difference. + Otherwise, useLowProbCount=1 is a good default, since the speed difference is small. + @return : tableLog, + or an errorCode, which can be tested using FSE_isError() */ +FSE_PUBLIC_API size_t FSE_normalizeCount(short* normalizedCounter, unsigned tableLog, + const unsigned* count, size_t srcSize, unsigned maxSymbolValue, unsigned useLowProbCount); + +/*! FSE_NCountWriteBound(): + Provides the maximum possible size of an FSE normalized table, given 'maxSymbolValue' and 'tableLog'. + Typically useful for allocation purpose. */ +FSE_PUBLIC_API size_t FSE_NCountWriteBound(unsigned maxSymbolValue, unsigned tableLog); + +/*! FSE_writeNCount(): + Compactly save 'normalizedCounter' into 'buffer'. + @return : size of the compressed table, + or an errorCode, which can be tested using FSE_isError(). */ +FSE_PUBLIC_API size_t FSE_writeNCount (void* buffer, size_t bufferSize, + const short* normalizedCounter, + unsigned maxSymbolValue, unsigned tableLog); + +/*! Constructor and Destructor of FSE_CTable. + Note that FSE_CTable size depends on 'tableLog' and 'maxSymbolValue' */ +typedef unsigned FSE_CTable; /* don't allocate that. It's only meant to be more restrictive than void* */ +FSE_PUBLIC_API FSE_CTable* FSE_createCTable (unsigned maxSymbolValue, unsigned tableLog); +FSE_PUBLIC_API void FSE_freeCTable (FSE_CTable* ct); + +/*! FSE_buildCTable(): + Builds `ct`, which must be already allocated, using FSE_createCTable(). + @return : 0, or an errorCode, which can be tested using FSE_isError() */ +FSE_PUBLIC_API size_t FSE_buildCTable(FSE_CTable* ct, const short* normalizedCounter, unsigned maxSymbolValue, unsigned tableLog); + +/*! FSE_compress_usingCTable(): + Compress `src` using `ct` into `dst` which must be already allocated. + @return : size of compressed data (<= `dstCapacity`), + or 0 if compressed data could not fit into `dst`, + or an errorCode, which can be tested using FSE_isError() */ +FSE_PUBLIC_API size_t FSE_compress_usingCTable (void* dst, size_t dstCapacity, const void* src, size_t srcSize, const FSE_CTable* ct); + +/*! +Tutorial : +---------- +The first step is to count all symbols. FSE_count() does this job very fast. +Result will be saved into 'count', a table of unsigned int, which must be already allocated, and have 'maxSymbolValuePtr[0]+1' cells. +'src' is a table of bytes of size 'srcSize'. All values within 'src' MUST be <= maxSymbolValuePtr[0] +maxSymbolValuePtr[0] will be updated, with its real value (necessarily <= original value) +FSE_count() will return the number of occurrence of the most frequent symbol. +This can be used to know if there is a single symbol within 'src', and to quickly evaluate its compressibility. +If there is an error, the function will return an ErrorCode (which can be tested using FSE_isError()). + +The next step is to normalize the frequencies. +FSE_normalizeCount() will ensure that sum of frequencies is == 2 ^'tableLog'. +It also guarantees a minimum of 1 to any Symbol with frequency >= 1. +You can use 'tableLog'==0 to mean "use default tableLog value". +If you are unsure of which tableLog value to use, you can ask FSE_optimalTableLog(), +which will provide the optimal valid tableLog given sourceSize, maxSymbolValue, and a user-defined maximum (0 means "default"). + +The result of FSE_normalizeCount() will be saved into a table, +called 'normalizedCounter', which is a table of signed short. +'normalizedCounter' must be already allocated, and have at least 'maxSymbolValue+1' cells. +The return value is tableLog if everything proceeded as expected. +It is 0 if there is a single symbol within distribution. +If there is an error (ex: invalid tableLog value), the function will return an ErrorCode (which can be tested using FSE_isError()). + +'normalizedCounter' can be saved in a compact manner to a memory area using FSE_writeNCount(). +'buffer' must be already allocated. +For guaranteed success, buffer size must be at least FSE_headerBound(). +The result of the function is the number of bytes written into 'buffer'. +If there is an error, the function will return an ErrorCode (which can be tested using FSE_isError(); ex : buffer size too small). + +'normalizedCounter' can then be used to create the compression table 'CTable'. +The space required by 'CTable' must be already allocated, using FSE_createCTable(). +You can then use FSE_buildCTable() to fill 'CTable'. +If there is an error, both functions will return an ErrorCode (which can be tested using FSE_isError()). + +'CTable' can then be used to compress 'src', with FSE_compress_usingCTable(). +Similar to FSE_count(), the convention is that 'src' is assumed to be a table of char of size 'srcSize' +The function returns the size of compressed data (without header), necessarily <= `dstCapacity`. +If it returns '0', compressed data could not fit into 'dst'. +If there is an error, the function will return an ErrorCode (which can be tested using FSE_isError()). +*/ + + +/* *** DECOMPRESSION *** */ + +/*! FSE_readNCount(): + Read compactly saved 'normalizedCounter' from 'rBuffer'. + @return : size read from 'rBuffer', + or an errorCode, which can be tested using FSE_isError(). + maxSymbolValuePtr[0] and tableLogPtr[0] will also be updated with their respective values */ +FSE_PUBLIC_API size_t FSE_readNCount (short* normalizedCounter, + unsigned* maxSymbolValuePtr, unsigned* tableLogPtr, + const void* rBuffer, size_t rBuffSize); + +/*! FSE_readNCount_bmi2(): + * Same as FSE_readNCount() but pass bmi2=1 when your CPU supports BMI2 and 0 otherwise. + */ +FSE_PUBLIC_API size_t FSE_readNCount_bmi2(short* normalizedCounter, + unsigned* maxSymbolValuePtr, unsigned* tableLogPtr, + const void* rBuffer, size_t rBuffSize, int bmi2); + +/*! Constructor and Destructor of FSE_DTable. + Note that its size depends on 'tableLog' */ +typedef unsigned FSE_DTable; /* don't allocate that. It's just a way to be more restrictive than void* */ +FSE_PUBLIC_API FSE_DTable* FSE_createDTable(unsigned tableLog); +FSE_PUBLIC_API void FSE_freeDTable(FSE_DTable* dt); + +/*! FSE_buildDTable(): + Builds 'dt', which must be already allocated, using FSE_createDTable(). + return : 0, or an errorCode, which can be tested using FSE_isError() */ +FSE_PUBLIC_API size_t FSE_buildDTable (FSE_DTable* dt, const short* normalizedCounter, unsigned maxSymbolValue, unsigned tableLog); + +/*! FSE_decompress_usingDTable(): + Decompress compressed source `cSrc` of size `cSrcSize` using `dt` + into `dst` which must be already allocated. + @return : size of regenerated data (necessarily <= `dstCapacity`), + or an errorCode, which can be tested using FSE_isError() */ +FSE_PUBLIC_API size_t FSE_decompress_usingDTable(void* dst, size_t dstCapacity, const void* cSrc, size_t cSrcSize, const FSE_DTable* dt); + +/*! +Tutorial : +---------- +(Note : these functions only decompress FSE-compressed blocks. + If block is uncompressed, use memcpy() instead + If block is a single repeated byte, use memset() instead ) + +The first step is to obtain the normalized frequencies of symbols. +This can be performed by FSE_readNCount() if it was saved using FSE_writeNCount(). +'normalizedCounter' must be already allocated, and have at least 'maxSymbolValuePtr[0]+1' cells of signed short. +In practice, that means it's necessary to know 'maxSymbolValue' beforehand, +or size the table to handle worst case situations (typically 256). +FSE_readNCount() will provide 'tableLog' and 'maxSymbolValue'. +The result of FSE_readNCount() is the number of bytes read from 'rBuffer'. +Note that 'rBufferSize' must be at least 4 bytes, even if useful information is less than that. +If there is an error, the function will return an error code, which can be tested using FSE_isError(). + +The next step is to build the decompression tables 'FSE_DTable' from 'normalizedCounter'. +This is performed by the function FSE_buildDTable(). +The space required by 'FSE_DTable' must be already allocated using FSE_createDTable(). +If there is an error, the function will return an error code, which can be tested using FSE_isError(). + +`FSE_DTable` can then be used to decompress `cSrc`, with FSE_decompress_usingDTable(). +`cSrcSize` must be strictly correct, otherwise decompression will fail. +FSE_decompress_usingDTable() result will tell how many bytes were regenerated (<=`dstCapacity`). +If there is an error, the function will return an error code, which can be tested using FSE_isError(). (ex: dst buffer too small) +*/ + +#endif /* FSE_H */ + +#if !defined(FSE_H_FSE_STATIC_LINKING_ONLY) +#define FSE_H_FSE_STATIC_LINKING_ONLY + +/* *** Dependency *** */ +#include "bitstream.h" + + +/* ***************************************** +* Static allocation +*******************************************/ +/* FSE buffer bounds */ +#define FSE_NCOUNTBOUND 512 +#define FSE_BLOCKBOUND(size) ((size) + ((size)>>7) + 4 /* fse states */ + sizeof(size_t) /* bitContainer */) +#define FSE_COMPRESSBOUND(size) (FSE_NCOUNTBOUND + FSE_BLOCKBOUND(size)) /* Macro version, useful for static allocation */ + +/* It is possible to statically allocate FSE CTable/DTable as a table of FSE_CTable/FSE_DTable using below macros */ +#define FSE_CTABLE_SIZE_U32(maxTableLog, maxSymbolValue) (1 + (1<<((maxTableLog)-1)) + (((maxSymbolValue)+1)*2)) +#define FSE_DTABLE_SIZE_U32(maxTableLog) (1 + (1<<(maxTableLog))) + +/* or use the size to malloc() space directly. Pay attention to alignment restrictions though */ +#define FSE_CTABLE_SIZE(maxTableLog, maxSymbolValue) (FSE_CTABLE_SIZE_U32(maxTableLog, maxSymbolValue) * sizeof(FSE_CTable)) +#define FSE_DTABLE_SIZE(maxTableLog) (FSE_DTABLE_SIZE_U32(maxTableLog) * sizeof(FSE_DTable)) + + +/* ***************************************** + * FSE advanced API + ***************************************** */ + +unsigned FSE_optimalTableLog_internal(unsigned maxTableLog, size_t srcSize, unsigned maxSymbolValue, unsigned minus); +/*< same as FSE_optimalTableLog(), which used `minus==2` */ + +/* FSE_compress_wksp() : + * Same as FSE_compress2(), but using an externally allocated scratch buffer (`workSpace`). + * FSE_COMPRESS_WKSP_SIZE_U32() provides the minimum size required for `workSpace` as a table of FSE_CTable. + */ +#define FSE_COMPRESS_WKSP_SIZE_U32(maxTableLog, maxSymbolValue) ( FSE_CTABLE_SIZE_U32(maxTableLog, maxSymbolValue) + ((maxTableLog > 12) ? (1 << (maxTableLog - 2)) : 1024) ) +size_t FSE_compress_wksp (void* dst, size_t dstSize, const void* src, size_t srcSize, unsigned maxSymbolValue, unsigned tableLog, void* workSpace, size_t wkspSize); + +size_t FSE_buildCTable_raw (FSE_CTable* ct, unsigned nbBits); +/*< build a fake FSE_CTable, designed for a flat distribution, where each symbol uses nbBits */ + +size_t FSE_buildCTable_rle (FSE_CTable* ct, unsigned char symbolValue); +/*< build a fake FSE_CTable, designed to compress always the same symbolValue */ + +/* FSE_buildCTable_wksp() : + * Same as FSE_buildCTable(), but using an externally allocated scratch buffer (`workSpace`). + * `wkspSize` must be >= `FSE_BUILD_CTABLE_WORKSPACE_SIZE_U32(maxSymbolValue, tableLog)` of `unsigned`. + * See FSE_buildCTable_wksp() for breakdown of workspace usage. + */ +#define FSE_BUILD_CTABLE_WORKSPACE_SIZE_U32(maxSymbolValue, tableLog) (((maxSymbolValue + 2) + (1ull << (tableLog)))/2 + sizeof(U64)/sizeof(U32) /* additional 8 bytes for potential table overwrite */) +#define FSE_BUILD_CTABLE_WORKSPACE_SIZE(maxSymbolValue, tableLog) (sizeof(unsigned) * FSE_BUILD_CTABLE_WORKSPACE_SIZE_U32(maxSymbolValue, tableLog)) +size_t FSE_buildCTable_wksp(FSE_CTable* ct, const short* normalizedCounter, unsigned maxSymbolValue, unsigned tableLog, void* workSpace, size_t wkspSize); + +#define FSE_BUILD_DTABLE_WKSP_SIZE(maxTableLog, maxSymbolValue) (sizeof(short) * (maxSymbolValue + 1) + (1ULL << maxTableLog) + 8) +#define FSE_BUILD_DTABLE_WKSP_SIZE_U32(maxTableLog, maxSymbolValue) ((FSE_BUILD_DTABLE_WKSP_SIZE(maxTableLog, maxSymbolValue) + sizeof(unsigned) - 1) / sizeof(unsigned)) +FSE_PUBLIC_API size_t FSE_buildDTable_wksp(FSE_DTable* dt, const short* normalizedCounter, unsigned maxSymbolValue, unsigned tableLog, void* workSpace, size_t wkspSize); +/*< Same as FSE_buildDTable(), using an externally allocated `workspace` produced with `FSE_BUILD_DTABLE_WKSP_SIZE_U32(maxSymbolValue)` */ + +size_t FSE_buildDTable_raw (FSE_DTable* dt, unsigned nbBits); +/*< build a fake FSE_DTable, designed to read a flat distribution where each symbol uses nbBits */ + +size_t FSE_buildDTable_rle (FSE_DTable* dt, unsigned char symbolValue); +/*< build a fake FSE_DTable, designed to always generate the same symbolValue */ + +#define FSE_DECOMPRESS_WKSP_SIZE_U32(maxTableLog, maxSymbolValue) (FSE_DTABLE_SIZE_U32(maxTableLog) + FSE_BUILD_DTABLE_WKSP_SIZE_U32(maxTableLog, maxSymbolValue) + (FSE_MAX_SYMBOL_VALUE + 1) / 2 + 1) +#define FSE_DECOMPRESS_WKSP_SIZE(maxTableLog, maxSymbolValue) (FSE_DECOMPRESS_WKSP_SIZE_U32(maxTableLog, maxSymbolValue) * sizeof(unsigned)) +size_t FSE_decompress_wksp(void* dst, size_t dstCapacity, const void* cSrc, size_t cSrcSize, unsigned maxLog, void* workSpace, size_t wkspSize); +/*< same as FSE_decompress(), using an externally allocated `workSpace` produced with `FSE_DECOMPRESS_WKSP_SIZE_U32(maxLog, maxSymbolValue)` */ + +size_t FSE_decompress_wksp_bmi2(void* dst, size_t dstCapacity, const void* cSrc, size_t cSrcSize, unsigned maxLog, void* workSpace, size_t wkspSize, int bmi2); +/*< Same as FSE_decompress_wksp() but with dynamic BMI2 support. Pass 1 if your CPU supports BMI2 or 0 if it doesn't. */ + +typedef enum { + FSE_repeat_none, /*< Cannot use the previous table */ + FSE_repeat_check, /*< Can use the previous table but it must be checked */ + FSE_repeat_valid /*< Can use the previous table and it is assumed to be valid */ + } FSE_repeat; + +/* ***************************************** +* FSE symbol compression API +*******************************************/ +/*! + This API consists of small unitary functions, which highly benefit from being inlined. + Hence their body are included in next section. +*/ +typedef struct { + ptrdiff_t value; + const void* stateTable; + const void* symbolTT; + unsigned stateLog; +} FSE_CState_t; + +static void FSE_initCState(FSE_CState_t* CStatePtr, const FSE_CTable* ct); + +static void FSE_encodeSymbol(BIT_CStream_t* bitC, FSE_CState_t* CStatePtr, unsigned symbol); + +static void FSE_flushCState(BIT_CStream_t* bitC, const FSE_CState_t* CStatePtr); + +/*< +These functions are inner components of FSE_compress_usingCTable(). +They allow the creation of custom streams, mixing multiple tables and bit sources. + +A key property to keep in mind is that encoding and decoding are done **in reverse direction**. +So the first symbol you will encode is the last you will decode, like a LIFO stack. + +You will need a few variables to track your CStream. They are : + +FSE_CTable ct; // Provided by FSE_buildCTable() +BIT_CStream_t bitStream; // bitStream tracking structure +FSE_CState_t state; // State tracking structure (can have several) + + +The first thing to do is to init bitStream and state. + size_t errorCode = BIT_initCStream(&bitStream, dstBuffer, maxDstSize); + FSE_initCState(&state, ct); + +Note that BIT_initCStream() can produce an error code, so its result should be tested, using FSE_isError(); +You can then encode your input data, byte after byte. +FSE_encodeSymbol() outputs a maximum of 'tableLog' bits at a time. +Remember decoding will be done in reverse direction. + FSE_encodeByte(&bitStream, &state, symbol); + +At any time, you can also add any bit sequence. +Note : maximum allowed nbBits is 25, for compatibility with 32-bits decoders + BIT_addBits(&bitStream, bitField, nbBits); + +The above methods don't commit data to memory, they just store it into local register, for speed. +Local register size is 64-bits on 64-bits systems, 32-bits on 32-bits systems (size_t). +Writing data to memory is a manual operation, performed by the flushBits function. + BIT_flushBits(&bitStream); + +Your last FSE encoding operation shall be to flush your last state value(s). + FSE_flushState(&bitStream, &state); + +Finally, you must close the bitStream. +The function returns the size of CStream in bytes. +If data couldn't fit into dstBuffer, it will return a 0 ( == not compressible) +If there is an error, it returns an errorCode (which can be tested using FSE_isError()). + size_t size = BIT_closeCStream(&bitStream); +*/ + + +/* ***************************************** +* FSE symbol decompression API +*******************************************/ +typedef struct { + size_t state; + const void* table; /* precise table may vary, depending on U16 */ +} FSE_DState_t; + + +static void FSE_initDState(FSE_DState_t* DStatePtr, BIT_DStream_t* bitD, const FSE_DTable* dt); + +static unsigned char FSE_decodeSymbol(FSE_DState_t* DStatePtr, BIT_DStream_t* bitD); + +static unsigned FSE_endOfDState(const FSE_DState_t* DStatePtr); + +/*< +Let's now decompose FSE_decompress_usingDTable() into its unitary components. +You will decode FSE-encoded symbols from the bitStream, +and also any other bitFields you put in, **in reverse order**. + +You will need a few variables to track your bitStream. They are : + +BIT_DStream_t DStream; // Stream context +FSE_DState_t DState; // State context. Multiple ones are possible +FSE_DTable* DTablePtr; // Decoding table, provided by FSE_buildDTable() + +The first thing to do is to init the bitStream. + errorCode = BIT_initDStream(&DStream, srcBuffer, srcSize); + +You should then retrieve your initial state(s) +(in reverse flushing order if you have several ones) : + errorCode = FSE_initDState(&DState, &DStream, DTablePtr); + +You can then decode your data, symbol after symbol. +For information the maximum number of bits read by FSE_decodeSymbol() is 'tableLog'. +Keep in mind that symbols are decoded in reverse order, like a LIFO stack (last in, first out). + unsigned char symbol = FSE_decodeSymbol(&DState, &DStream); + +You can retrieve any bitfield you eventually stored into the bitStream (in reverse order) +Note : maximum allowed nbBits is 25, for 32-bits compatibility + size_t bitField = BIT_readBits(&DStream, nbBits); + +All above operations only read from local register (which size depends on size_t). +Refueling the register from memory is manually performed by the reload method. + endSignal = FSE_reloadDStream(&DStream); + +BIT_reloadDStream() result tells if there is still some more data to read from DStream. +BIT_DStream_unfinished : there is still some data left into the DStream. +BIT_DStream_endOfBuffer : Dstream reached end of buffer. Its container may no longer be completely filled. +BIT_DStream_completed : Dstream reached its exact end, corresponding in general to decompression completed. +BIT_DStream_tooFar : Dstream went too far. Decompression result is corrupted. + +When reaching end of buffer (BIT_DStream_endOfBuffer), progress slowly, notably if you decode multiple symbols per loop, +to properly detect the exact end of stream. +After each decoded symbol, check if DStream is fully consumed using this simple test : + BIT_reloadDStream(&DStream) >= BIT_DStream_completed + +When it's done, verify decompression is fully completed, by checking both DStream and the relevant states. +Checking if DStream has reached its end is performed by : + BIT_endOfDStream(&DStream); +Check also the states. There might be some symbols left there, if some high probability ones (>50%) are possible. + FSE_endOfDState(&DState); +*/ + + +/* ***************************************** +* FSE unsafe API +*******************************************/ +static unsigned char FSE_decodeSymbolFast(FSE_DState_t* DStatePtr, BIT_DStream_t* bitD); +/* faster, but works only if nbBits is always >= 1 (otherwise, result will be corrupted) */ + + +/* ***************************************** +* Implementation of inlined functions +*******************************************/ +typedef struct { + int deltaFindState; + U32 deltaNbBits; +} FSE_symbolCompressionTransform; /* total 8 bytes */ + +MEM_STATIC void FSE_initCState(FSE_CState_t* statePtr, const FSE_CTable* ct) +{ + const void* ptr = ct; + const U16* u16ptr = (const U16*) ptr; + const U32 tableLog = MEM_read16(ptr); + statePtr->value = (ptrdiff_t)1<<tableLog; + statePtr->stateTable = u16ptr+2; + statePtr->symbolTT = ct + 1 + (tableLog ? (1<<(tableLog-1)) : 1); + statePtr->stateLog = tableLog; +} + + +/*! FSE_initCState2() : +* Same as FSE_initCState(), but the first symbol to include (which will be the last to be read) +* uses the smallest state value possible, saving the cost of this symbol */ +MEM_STATIC void FSE_initCState2(FSE_CState_t* statePtr, const FSE_CTable* ct, U32 symbol) +{ + FSE_initCState(statePtr, ct); + { const FSE_symbolCompressionTransform symbolTT = ((const FSE_symbolCompressionTransform*)(statePtr->symbolTT))[symbol]; + const U16* stateTable = (const U16*)(statePtr->stateTable); + U32 nbBitsOut = (U32)((symbolTT.deltaNbBits + (1<<15)) >> 16); + statePtr->value = (nbBitsOut << 16) - symbolTT.deltaNbBits; + statePtr->value = stateTable[(statePtr->value >> nbBitsOut) + symbolTT.deltaFindState]; + } +} + +MEM_STATIC void FSE_encodeSymbol(BIT_CStream_t* bitC, FSE_CState_t* statePtr, unsigned symbol) +{ + FSE_symbolCompressionTransform const symbolTT = ((const FSE_symbolCompressionTransform*)(statePtr->symbolTT))[symbol]; + const U16* const stateTable = (const U16*)(statePtr->stateTable); + U32 const nbBitsOut = (U32)((statePtr->value + symbolTT.deltaNbBits) >> 16); + BIT_addBits(bitC, statePtr->value, nbBitsOut); + statePtr->value = stateTable[ (statePtr->value >> nbBitsOut) + symbolTT.deltaFindState]; +} + +MEM_STATIC void FSE_flushCState(BIT_CStream_t* bitC, const FSE_CState_t* statePtr) +{ + BIT_addBits(bitC, statePtr->value, statePtr->stateLog); + BIT_flushBits(bitC); +} + + +/* FSE_getMaxNbBits() : + * Approximate maximum cost of a symbol, in bits. + * Fractional get rounded up (i.e : a symbol with a normalized frequency of 3 gives the same result as a frequency of 2) + * note 1 : assume symbolValue is valid (<= maxSymbolValue) + * note 2 : if freq[symbolValue]==0, @return a fake cost of tableLog+1 bits */ +MEM_STATIC U32 FSE_getMaxNbBits(const void* symbolTTPtr, U32 symbolValue) +{ + const FSE_symbolCompressionTransform* symbolTT = (const FSE_symbolCompressionTransform*) symbolTTPtr; + return (symbolTT[symbolValue].deltaNbBits + ((1<<16)-1)) >> 16; +} + +/* FSE_bitCost() : + * Approximate symbol cost, as fractional value, using fixed-point format (accuracyLog fractional bits) + * note 1 : assume symbolValue is valid (<= maxSymbolValue) + * note 2 : if freq[symbolValue]==0, @return a fake cost of tableLog+1 bits */ +MEM_STATIC U32 FSE_bitCost(const void* symbolTTPtr, U32 tableLog, U32 symbolValue, U32 accuracyLog) +{ + const FSE_symbolCompressionTransform* symbolTT = (const FSE_symbolCompressionTransform*) symbolTTPtr; + U32 const minNbBits = symbolTT[symbolValue].deltaNbBits >> 16; + U32 const threshold = (minNbBits+1) << 16; + assert(tableLog < 16); + assert(accuracyLog < 31-tableLog); /* ensure enough room for renormalization double shift */ + { U32 const tableSize = 1 << tableLog; + U32 const deltaFromThreshold = threshold - (symbolTT[symbolValue].deltaNbBits + tableSize); + U32 const normalizedDeltaFromThreshold = (deltaFromThreshold << accuracyLog) >> tableLog; /* linear interpolation (very approximate) */ + U32 const bitMultiplier = 1 << accuracyLog; + assert(symbolTT[symbolValue].deltaNbBits + tableSize <= threshold); + assert(normalizedDeltaFromThreshold <= bitMultiplier); + return (minNbBits+1)*bitMultiplier - normalizedDeltaFromThreshold; + } +} + + +/* ====== Decompression ====== */ + +typedef struct { + U16 tableLog; + U16 fastMode; +} FSE_DTableHeader; /* sizeof U32 */ + +typedef struct +{ + unsigned short newState; + unsigned char symbol; + unsigned char nbBits; +} FSE_decode_t; /* size == U32 */ + +MEM_STATIC void FSE_initDState(FSE_DState_t* DStatePtr, BIT_DStream_t* bitD, const FSE_DTable* dt) +{ + const void* ptr = dt; + const FSE_DTableHeader* const DTableH = (const FSE_DTableHeader*)ptr; + DStatePtr->state = BIT_readBits(bitD, DTableH->tableLog); + BIT_reloadDStream(bitD); + DStatePtr->table = dt + 1; +} + +MEM_STATIC BYTE FSE_peekSymbol(const FSE_DState_t* DStatePtr) +{ + FSE_decode_t const DInfo = ((const FSE_decode_t*)(DStatePtr->table))[DStatePtr->state]; + return DInfo.symbol; +} + +MEM_STATIC void FSE_updateState(FSE_DState_t* DStatePtr, BIT_DStream_t* bitD) +{ + FSE_decode_t const DInfo = ((const FSE_decode_t*)(DStatePtr->table))[DStatePtr->state]; + U32 const nbBits = DInfo.nbBits; + size_t const lowBits = BIT_readBits(bitD, nbBits); + DStatePtr->state = DInfo.newState + lowBits; +} + +MEM_STATIC BYTE FSE_decodeSymbol(FSE_DState_t* DStatePtr, BIT_DStream_t* bitD) +{ + FSE_decode_t const DInfo = ((const FSE_decode_t*)(DStatePtr->table))[DStatePtr->state]; + U32 const nbBits = DInfo.nbBits; + BYTE const symbol = DInfo.symbol; + size_t const lowBits = BIT_readBits(bitD, nbBits); + + DStatePtr->state = DInfo.newState + lowBits; + return symbol; +} + +/*! FSE_decodeSymbolFast() : + unsafe, only works if no symbol has a probability > 50% */ +MEM_STATIC BYTE FSE_decodeSymbolFast(FSE_DState_t* DStatePtr, BIT_DStream_t* bitD) +{ + FSE_decode_t const DInfo = ((const FSE_decode_t*)(DStatePtr->table))[DStatePtr->state]; + U32 const nbBits = DInfo.nbBits; + BYTE const symbol = DInfo.symbol; + size_t const lowBits = BIT_readBitsFast(bitD, nbBits); + + DStatePtr->state = DInfo.newState + lowBits; + return symbol; +} + +MEM_STATIC unsigned FSE_endOfDState(const FSE_DState_t* DStatePtr) +{ + return DStatePtr->state == 0; +} + + + +#ifndef FSE_COMMONDEFS_ONLY + +/* ************************************************************** +* Tuning parameters +****************************************************************/ +/*!MEMORY_USAGE : +* Memory usage formula : N->2^N Bytes (examples : 10 -> 1KB; 12 -> 4KB ; 16 -> 64KB; 20 -> 1MB; etc.) +* Increasing memory usage improves compression ratio +* Reduced memory usage can improve speed, due to cache effect +* Recommended max value is 14, for 16KB, which nicely fits into Intel x86 L1 cache */ +#ifndef FSE_MAX_MEMORY_USAGE +# define FSE_MAX_MEMORY_USAGE 14 +#endif +#ifndef FSE_DEFAULT_MEMORY_USAGE +# define FSE_DEFAULT_MEMORY_USAGE 13 +#endif +#if (FSE_DEFAULT_MEMORY_USAGE > FSE_MAX_MEMORY_USAGE) +# error "FSE_DEFAULT_MEMORY_USAGE must be <= FSE_MAX_MEMORY_USAGE" +#endif + +/*!FSE_MAX_SYMBOL_VALUE : +* Maximum symbol value authorized. +* Required for proper stack allocation */ +#ifndef FSE_MAX_SYMBOL_VALUE +# define FSE_MAX_SYMBOL_VALUE 255 +#endif + +/* ************************************************************** +* template functions type & suffix +****************************************************************/ +#define FSE_FUNCTION_TYPE BYTE +#define FSE_FUNCTION_EXTENSION +#define FSE_DECODE_TYPE FSE_decode_t + + +#endif /* !FSE_COMMONDEFS_ONLY */ + + +/* *************************************************************** +* Constants +*****************************************************************/ +#define FSE_MAX_TABLELOG (FSE_MAX_MEMORY_USAGE-2) +#define FSE_MAX_TABLESIZE (1U<<FSE_MAX_TABLELOG) +#define FSE_MAXTABLESIZE_MASK (FSE_MAX_TABLESIZE-1) +#define FSE_DEFAULT_TABLELOG (FSE_DEFAULT_MEMORY_USAGE-2) +#define FSE_MIN_TABLELOG 5 + +#define FSE_TABLELOG_ABSOLUTE_MAX 15 +#if FSE_MAX_TABLELOG > FSE_TABLELOG_ABSOLUTE_MAX +# error "FSE_MAX_TABLELOG > FSE_TABLELOG_ABSOLUTE_MAX is not supported" +#endif + +#define FSE_TABLESTEP(tableSize) (((tableSize)>>1) + ((tableSize)>>3) + 3) + + +#endif /* FSE_STATIC_LINKING_ONLY */ + + diff --git a/lib/zstd/common/fse_decompress.c b/lib/zstd/common/fse_decompress.c new file mode 100644 index 00000000000..a0d06095be8 --- /dev/null +++ b/lib/zstd/common/fse_decompress.c @@ -0,0 +1,390 @@ +/* ****************************************************************** + * FSE : Finite State Entropy decoder + * Copyright (c) Yann Collet, Facebook, Inc. + * + * You can contact the author at : + * - FSE source repository : https://github.com/Cyan4973/FiniteStateEntropy + * - Public forum : https://groups.google.com/forum/#!forum/lz4c + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. +****************************************************************** */ + + +/* ************************************************************** +* Includes +****************************************************************/ +#include "debug.h" /* assert */ +#include "bitstream.h" +#include "compiler.h" +#define FSE_STATIC_LINKING_ONLY +#include "fse.h" +#include "error_private.h" +#define ZSTD_DEPS_NEED_MALLOC +#include "zstd_deps.h" + + +/* ************************************************************** +* Error Management +****************************************************************/ +#define FSE_isError ERR_isError +#define FSE_STATIC_ASSERT(c) DEBUG_STATIC_ASSERT(c) /* use only *after* variable declarations */ + + +/* ************************************************************** +* Templates +****************************************************************/ +/* + designed to be included + for type-specific functions (template emulation in C) + Objective is to write these functions only once, for improved maintenance +*/ + +/* safety checks */ +#ifndef FSE_FUNCTION_EXTENSION +# error "FSE_FUNCTION_EXTENSION must be defined" +#endif +#ifndef FSE_FUNCTION_TYPE +# error "FSE_FUNCTION_TYPE must be defined" +#endif + +/* Function names */ +#define FSE_CAT(X,Y) X##Y +#define FSE_FUNCTION_NAME(X,Y) FSE_CAT(X,Y) +#define FSE_TYPE_NAME(X,Y) FSE_CAT(X,Y) + + +/* Function templates */ +FSE_DTable* FSE_createDTable (unsigned tableLog) +{ + if (tableLog > FSE_TABLELOG_ABSOLUTE_MAX) tableLog = FSE_TABLELOG_ABSOLUTE_MAX; + return (FSE_DTable*)ZSTD_malloc( FSE_DTABLE_SIZE_U32(tableLog) * sizeof (U32) ); +} + +void FSE_freeDTable (FSE_DTable* dt) +{ + ZSTD_free(dt); +} + +static size_t FSE_buildDTable_internal(FSE_DTable* dt, const short* normalizedCounter, unsigned maxSymbolValue, unsigned tableLog, void* workSpace, size_t wkspSize) +{ + void* const tdPtr = dt+1; /* because *dt is unsigned, 32-bits aligned on 32-bits */ + FSE_DECODE_TYPE* const tableDecode = (FSE_DECODE_TYPE*) (tdPtr); + U16* symbolNext = (U16*)workSpace; + BYTE* spread = (BYTE*)(symbolNext + maxSymbolValue + 1); + + U32 const maxSV1 = maxSymbolValue + 1; + U32 const tableSize = 1 << tableLog; + U32 highThreshold = tableSize-1; + + /* Sanity Checks */ + if (FSE_BUILD_DTABLE_WKSP_SIZE(tableLog, maxSymbolValue) > wkspSize) return ERROR(maxSymbolValue_tooLarge); + if (maxSymbolValue > FSE_MAX_SYMBOL_VALUE) return ERROR(maxSymbolValue_tooLarge); + if (tableLog > FSE_MAX_TABLELOG) return ERROR(tableLog_tooLarge); + + /* Init, lay down lowprob symbols */ + { FSE_DTableHeader DTableH; + DTableH.tableLog = (U16)tableLog; + DTableH.fastMode = 1; + { S16 const largeLimit= (S16)(1 << (tableLog-1)); + U32 s; + for (s=0; s<maxSV1; s++) { + if (normalizedCounter[s]==-1) { + tableDecode[highThreshold--].symbol = (FSE_FUNCTION_TYPE)s; + symbolNext[s] = 1; + } else { + if (normalizedCounter[s] >= largeLimit) DTableH.fastMode=0; + symbolNext[s] = normalizedCounter[s]; + } } } + ZSTD_memcpy(dt, &DTableH, sizeof(DTableH)); + } + + /* Spread symbols */ + if (highThreshold == tableSize - 1) { + size_t const tableMask = tableSize-1; + size_t const step = FSE_TABLESTEP(tableSize); + /* First lay down the symbols in order. + * We use a uint64_t to lay down 8 bytes at a time. This reduces branch + * misses since small blocks generally have small table logs, so nearly + * all symbols have counts <= 8. We ensure we have 8 bytes at the end of + * our buffer to handle the over-write. + */ + { + U64 const add = 0x0101010101010101ull; + size_t pos = 0; + U64 sv = 0; + U32 s; + for (s=0; s<maxSV1; ++s, sv += add) { + int i; + int const n = normalizedCounter[s]; + MEM_write64(spread + pos, sv); + for (i = 8; i < n; i += 8) { + MEM_write64(spread + pos + i, sv); + } + pos += n; + } + } + /* Now we spread those positions across the table. + * The benefit of doing it in two stages is that we avoid the the + * variable size inner loop, which caused lots of branch misses. + * Now we can run through all the positions without any branch misses. + * We unroll the loop twice, since that is what emperically worked best. + */ + { + size_t position = 0; + size_t s; + size_t const unroll = 2; + assert(tableSize % unroll == 0); /* FSE_MIN_TABLELOG is 5 */ + for (s = 0; s < (size_t)tableSize; s += unroll) { + size_t u; + for (u = 0; u < unroll; ++u) { + size_t const uPosition = (position + (u * step)) & tableMask; + tableDecode[uPosition].symbol = spread[s + u]; + } + position = (position + (unroll * step)) & tableMask; + } + assert(position == 0); + } + } else { + U32 const tableMask = tableSize-1; + U32 const step = FSE_TABLESTEP(tableSize); + U32 s, position = 0; + for (s=0; s<maxSV1; s++) { + int i; + for (i=0; i<normalizedCounter[s]; i++) { + tableDecode[position].symbol = (FSE_FUNCTION_TYPE)s; + position = (position + step) & tableMask; + while (position > highThreshold) position = (position + step) & tableMask; /* lowprob area */ + } } + if (position!=0) return ERROR(GENERIC); /* position must reach all cells once, otherwise normalizedCounter is incorrect */ + } + + /* Build Decoding table */ + { U32 u; + for (u=0; u<tableSize; u++) { + FSE_FUNCTION_TYPE const symbol = (FSE_FUNCTION_TYPE)(tableDecode[u].symbol); + U32 const nextState = symbolNext[symbol]++; + tableDecode[u].nbBits = (BYTE) (tableLog - BIT_highbit32(nextState) ); + tableDecode[u].newState = (U16) ( (nextState << tableDecode[u].nbBits) - tableSize); + } } + + return 0; +} + +size_t FSE_buildDTable_wksp(FSE_DTable* dt, const short* normalizedCounter, unsigned maxSymbolValue, unsigned tableLog, void* workSpace, size_t wkspSize) +{ + return FSE_buildDTable_internal(dt, normalizedCounter, maxSymbolValue, tableLog, workSpace, wkspSize); +} + + +#ifndef FSE_COMMONDEFS_ONLY + +/*-******************************************************* +* Decompression (Byte symbols) +*********************************************************/ +size_t FSE_buildDTable_rle (FSE_DTable* dt, BYTE symbolValue) +{ + void* ptr = dt; + FSE_DTableHeader* const DTableH = (FSE_DTableHeader*)ptr; + void* dPtr = dt + 1; + FSE_decode_t* const cell = (FSE_decode_t*)dPtr; + + DTableH->tableLog = 0; + DTableH->fastMode = 0; + + cell->newState = 0; + cell->symbol = symbolValue; + cell->nbBits = 0; + + return 0; +} + + +size_t FSE_buildDTable_raw (FSE_DTable* dt, unsigned nbBits) +{ + void* ptr = dt; + FSE_DTableHeader* const DTableH = (FSE_DTableHeader*)ptr; + void* dPtr = dt + 1; + FSE_decode_t* const dinfo = (FSE_decode_t*)dPtr; + const unsigned tableSize = 1 << nbBits; + const unsigned tableMask = tableSize - 1; + const unsigned maxSV1 = tableMask+1; + unsigned s; + + /* Sanity checks */ + if (nbBits < 1) return ERROR(GENERIC); /* min size */ + + /* Build Decoding Table */ + DTableH->tableLog = (U16)nbBits; + DTableH->fastMode = 1; + for (s=0; s<maxSV1; s++) { + dinfo[s].newState = 0; + dinfo[s].symbol = (BYTE)s; + dinfo[s].nbBits = (BYTE)nbBits; + } + + return 0; +} + +FORCE_INLINE_TEMPLATE size_t FSE_decompress_usingDTable_generic( + void* dst, size_t maxDstSize, + const void* cSrc, size_t cSrcSize, + const FSE_DTable* dt, const unsigned fast) +{ + BYTE* const ostart = (BYTE*) dst; + BYTE* op = ostart; + BYTE* const omax = op + maxDstSize; + BYTE* const olimit = omax-3; + + BIT_DStream_t bitD; + FSE_DState_t state1; + FSE_DState_t state2; + + /* Init */ + CHECK_F(BIT_initDStream(&bitD, cSrc, cSrcSize)); + + FSE_initDState(&state1, &bitD, dt); + FSE_initDState(&state2, &bitD, dt); + +#define FSE_GETSYMBOL(statePtr) fast ? FSE_decodeSymbolFast(statePtr, &bitD) : FSE_decodeSymbol(statePtr, &bitD) + + /* 4 symbols per loop */ + for ( ; (BIT_reloadDStream(&bitD)==BIT_DStream_unfinished) & (op<olimit) ; op+=4) { + op[0] = FSE_GETSYMBOL(&state1); + + if (FSE_MAX_TABLELOG*2+7 > sizeof(bitD.bitContainer)*8) /* This test must be static */ + BIT_reloadDStream(&bitD); + + op[1] = FSE_GETSYMBOL(&state2); + + if (FSE_MAX_TABLELOG*4+7 > sizeof(bitD.bitContainer)*8) /* This test must be static */ + { if (BIT_reloadDStream(&bitD) > BIT_DStream_unfinished) { op+=2; break; } } + + op[2] = FSE_GETSYMBOL(&state1); + + if (FSE_MAX_TABLELOG*2+7 > sizeof(bitD.bitContainer)*8) /* This test must be static */ + BIT_reloadDStream(&bitD); + + op[3] = FSE_GETSYMBOL(&state2); + } + + /* tail */ + /* note : BIT_reloadDStream(&bitD) >= FSE_DStream_partiallyFilled; Ends at exactly BIT_DStream_completed */ + while (1) { + if (op>(omax-2)) return ERROR(dstSize_tooSmall); + *op++ = FSE_GETSYMBOL(&state1); + if (BIT_reloadDStream(&bitD)==BIT_DStream_overflow) { + *op++ = FSE_GETSYMBOL(&state2); + break; + } + + if (op>(omax-2)) return ERROR(dstSize_tooSmall); + *op++ = FSE_GETSYMBOL(&state2); + if (BIT_reloadDStream(&bitD)==BIT_DStream_overflow) { + *op++ = FSE_GETSYMBOL(&state1); + break; + } } + + return op-ostart; +} + + +size_t FSE_decompress_usingDTable(void* dst, size_t originalSize, + const void* cSrc, size_t cSrcSize, + const FSE_DTable* dt) +{ + const void* ptr = dt; + const FSE_DTableHeader* DTableH = (const FSE_DTableHeader*)ptr; + const U32 fastMode = DTableH->fastMode; + + /* select fast mode (static) */ + if (fastMode) return FSE_decompress_usingDTable_generic(dst, originalSize, cSrc, cSrcSize, dt, 1); + return FSE_decompress_usingDTable_generic(dst, originalSize, cSrc, cSrcSize, dt, 0); +} + + +size_t FSE_decompress_wksp(void* dst, size_t dstCapacity, const void* cSrc, size_t cSrcSize, unsigned maxLog, void* workSpace, size_t wkspSize) +{ + return FSE_decompress_wksp_bmi2(dst, dstCapacity, cSrc, cSrcSize, maxLog, workSpace, wkspSize, /* bmi2 */ 0); +} + +typedef struct { + short ncount[FSE_MAX_SYMBOL_VALUE + 1]; + FSE_DTable dtable[1]; /* Dynamically sized */ +} FSE_DecompressWksp; + + +FORCE_INLINE_TEMPLATE size_t FSE_decompress_wksp_body( + void* dst, size_t dstCapacity, + const void* cSrc, size_t cSrcSize, + unsigned maxLog, void* workSpace, size_t wkspSize, + int bmi2) +{ + const BYTE* const istart = (const BYTE*)cSrc; + const BYTE* ip = istart; + unsigned tableLog; + unsigned maxSymbolValue = FSE_MAX_SYMBOL_VALUE; + FSE_DecompressWksp* const wksp = (FSE_DecompressWksp*)workSpace; + + DEBUG_STATIC_ASSERT((FSE_MAX_SYMBOL_VALUE + 1) % 2 == 0); + if (wkspSize < sizeof(*wksp)) return ERROR(GENERIC); + + /* normal FSE decoding mode */ + { + size_t const NCountLength = FSE_readNCount_bmi2(wksp->ncount, &maxSymbolValue, &tableLog, istart, cSrcSize, bmi2); + if (FSE_isError(NCountLength)) return NCountLength; + if (tableLog > maxLog) return ERROR(tableLog_tooLarge); + assert(NCountLength <= cSrcSize); + ip += NCountLength; + cSrcSize -= NCountLength; + } + + if (FSE_DECOMPRESS_WKSP_SIZE(tableLog, maxSymbolValue) > wkspSize) return ERROR(tableLog_tooLarge); + workSpace = wksp->dtable + FSE_DTABLE_SIZE_U32(tableLog); + wkspSize -= sizeof(*wksp) + FSE_DTABLE_SIZE(tableLog); + + CHECK_F( FSE_buildDTable_internal(wksp->dtable, wksp->ncount, maxSymbolValue, tableLog, workSpace, wkspSize) ); + + { + const void* ptr = wksp->dtable; + const FSE_DTableHeader* DTableH = (const FSE_DTableHeader*)ptr; + const U32 fastMode = DTableH->fastMode; + + /* select fast mode (static) */ + if (fastMode) return FSE_decompress_usingDTable_generic(dst, dstCapacity, ip, cSrcSize, wksp->dtable, 1); + return FSE_decompress_usingDTable_generic(dst, dstCapacity, ip, cSrcSize, wksp->dtable, 0); + } +} + +/* Avoids the FORCE_INLINE of the _body() function. */ +static size_t FSE_decompress_wksp_body_default(void* dst, size_t dstCapacity, const void* cSrc, size_t cSrcSize, unsigned maxLog, void* workSpace, size_t wkspSize) +{ + return FSE_decompress_wksp_body(dst, dstCapacity, cSrc, cSrcSize, maxLog, workSpace, wkspSize, 0); +} + +#if DYNAMIC_BMI2 +BMI2_TARGET_ATTRIBUTE static size_t FSE_decompress_wksp_body_bmi2(void* dst, size_t dstCapacity, const void* cSrc, size_t cSrcSize, unsigned maxLog, void* workSpace, size_t wkspSize) +{ + return FSE_decompress_wksp_body(dst, dstCapacity, cSrc, cSrcSize, maxLog, workSpace, wkspSize, 1); +} +#endif + +size_t FSE_decompress_wksp_bmi2(void* dst, size_t dstCapacity, const void* cSrc, size_t cSrcSize, unsigned maxLog, void* workSpace, size_t wkspSize, int bmi2) +{ +#if DYNAMIC_BMI2 + if (bmi2) { + return FSE_decompress_wksp_body_bmi2(dst, dstCapacity, cSrc, cSrcSize, maxLog, workSpace, wkspSize); + } +#endif + (void)bmi2; + return FSE_decompress_wksp_body_default(dst, dstCapacity, cSrc, cSrcSize, maxLog, workSpace, wkspSize); +} + + +typedef FSE_DTable DTable_max_t[FSE_DTABLE_SIZE_U32(FSE_MAX_TABLELOG)]; + + + +#endif /* FSE_COMMONDEFS_ONLY */ diff --git a/lib/zstd/common/huf.h b/lib/zstd/common/huf.h new file mode 100644 index 00000000000..5042ff87030 --- /dev/null +++ b/lib/zstd/common/huf.h @@ -0,0 +1,358 @@ +/* ****************************************************************** + * huff0 huffman codec, + * part of Finite State Entropy library + * Copyright (c) Yann Collet, Facebook, Inc. + * + * You can contact the author at : + * - Source repository : https://github.com/Cyan4973/FiniteStateEntropy + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. +****************************************************************** */ + + +#ifndef HUF_H_298734234 +#define HUF_H_298734234 + +/* *** Dependencies *** */ +#include "zstd_deps.h" /* size_t */ + + +/* *** library symbols visibility *** */ +/* Note : when linking with -fvisibility=hidden on gcc, or by default on Visual, + * HUF symbols remain "private" (internal symbols for library only). + * Set macro FSE_DLL_EXPORT to 1 if you want HUF symbols visible on DLL interface */ +#if defined(FSE_DLL_EXPORT) && (FSE_DLL_EXPORT==1) && defined(__GNUC__) && (__GNUC__ >= 4) +# define HUF_PUBLIC_API __attribute__ ((visibility ("default"))) +#elif defined(FSE_DLL_EXPORT) && (FSE_DLL_EXPORT==1) /* Visual expected */ +# define HUF_PUBLIC_API __declspec(dllexport) +#elif defined(FSE_DLL_IMPORT) && (FSE_DLL_IMPORT==1) +# define HUF_PUBLIC_API __declspec(dllimport) /* not required, just to generate faster code (saves a function pointer load from IAT and an indirect jump) */ +#else +# define HUF_PUBLIC_API +#endif + + +/* ========================== */ +/* *** simple functions *** */ +/* ========================== */ + +/* HUF_compress() : + * Compress content from buffer 'src', of size 'srcSize', into buffer 'dst'. + * 'dst' buffer must be already allocated. + * Compression runs faster if `dstCapacity` >= HUF_compressBound(srcSize). + * `srcSize` must be <= `HUF_BLOCKSIZE_MAX` == 128 KB. + * @return : size of compressed data (<= `dstCapacity`). + * Special values : if return == 0, srcData is not compressible => Nothing is stored within dst !!! + * if HUF_isError(return), compression failed (more details using HUF_getErrorName()) + */ +HUF_PUBLIC_API size_t HUF_compress(void* dst, size_t dstCapacity, + const void* src, size_t srcSize); + +/* HUF_decompress() : + * Decompress HUF data from buffer 'cSrc', of size 'cSrcSize', + * into already allocated buffer 'dst', of minimum size 'dstSize'. + * `originalSize` : **must** be the ***exact*** size of original (uncompressed) data. + * Note : in contrast with FSE, HUF_decompress can regenerate + * RLE (cSrcSize==1) and uncompressed (cSrcSize==dstSize) data, + * because it knows size to regenerate (originalSize). + * @return : size of regenerated data (== originalSize), + * or an error code, which can be tested using HUF_isError() + */ +HUF_PUBLIC_API size_t HUF_decompress(void* dst, size_t originalSize, + const void* cSrc, size_t cSrcSize); + + +/* *** Tool functions *** */ +#define HUF_BLOCKSIZE_MAX (128 * 1024) /*< maximum input size for a single block compressed with HUF_compress */ +HUF_PUBLIC_API size_t HUF_compressBound(size_t size); /*< maximum compressed size (worst case) */ + +/* Error Management */ +HUF_PUBLIC_API unsigned HUF_isError(size_t code); /*< tells if a return value is an error code */ +HUF_PUBLIC_API const char* HUF_getErrorName(size_t code); /*< provides error code string (useful for debugging) */ + + +/* *** Advanced function *** */ + +/* HUF_compress2() : + * Same as HUF_compress(), but offers control over `maxSymbolValue` and `tableLog`. + * `maxSymbolValue` must be <= HUF_SYMBOLVALUE_MAX . + * `tableLog` must be `<= HUF_TABLELOG_MAX` . */ +HUF_PUBLIC_API size_t HUF_compress2 (void* dst, size_t dstCapacity, + const void* src, size_t srcSize, + unsigned maxSymbolValue, unsigned tableLog); + +/* HUF_compress4X_wksp() : + * Same as HUF_compress2(), but uses externally allocated `workSpace`. + * `workspace` must be at least as large as HUF_WORKSPACE_SIZE */ +#define HUF_WORKSPACE_SIZE ((8 << 10) + 512 /* sorting scratch space */) +#define HUF_WORKSPACE_SIZE_U64 (HUF_WORKSPACE_SIZE / sizeof(U64)) +HUF_PUBLIC_API size_t HUF_compress4X_wksp (void* dst, size_t dstCapacity, + const void* src, size_t srcSize, + unsigned maxSymbolValue, unsigned tableLog, + void* workSpace, size_t wkspSize); + +#endif /* HUF_H_298734234 */ + +/* ****************************************************************** + * WARNING !! + * The following section contains advanced and experimental definitions + * which shall never be used in the context of a dynamic library, + * because they are not guaranteed to remain stable in the future. + * Only consider them in association with static linking. + * *****************************************************************/ +#if !defined(HUF_H_HUF_STATIC_LINKING_ONLY) +#define HUF_H_HUF_STATIC_LINKING_ONLY + +/* *** Dependencies *** */ +#include "mem.h" /* U32 */ +#define FSE_STATIC_LINKING_ONLY +#include "fse.h" + + +/* *** Constants *** */ +#define HUF_TABLELOG_MAX 12 /* max runtime value of tableLog (due to static allocation); can be modified up to HUF_TABLELOG_ABSOLUTEMAX */ +#define HUF_TABLELOG_DEFAULT 11 /* default tableLog value when none specified */ +#define HUF_SYMBOLVALUE_MAX 255 + +#define HUF_TABLELOG_ABSOLUTEMAX 12 /* absolute limit of HUF_MAX_TABLELOG. Beyond that value, code does not work */ +#if (HUF_TABLELOG_MAX > HUF_TABLELOG_ABSOLUTEMAX) +# error "HUF_TABLELOG_MAX is too large !" +#endif + + +/* **************************************** +* Static allocation +******************************************/ +/* HUF buffer bounds */ +#define HUF_CTABLEBOUND 129 +#define HUF_BLOCKBOUND(size) (size + (size>>8) + 8) /* only true when incompressible is pre-filtered with fast heuristic */ +#define HUF_COMPRESSBOUND(size) (HUF_CTABLEBOUND + HUF_BLOCKBOUND(size)) /* Macro version, useful for static allocation */ + +/* static allocation of HUF's Compression Table */ +/* this is a private definition, just exposed for allocation and strict aliasing purpose. never EVER access its members directly */ +typedef size_t HUF_CElt; /* consider it an incomplete type */ +#define HUF_CTABLE_SIZE_ST(maxSymbolValue) ((maxSymbolValue)+2) /* Use tables of size_t, for proper alignment */ +#define HUF_CTABLE_SIZE(maxSymbolValue) (HUF_CTABLE_SIZE_ST(maxSymbolValue) * sizeof(size_t)) +#define HUF_CREATE_STATIC_CTABLE(name, maxSymbolValue) \ + HUF_CElt name[HUF_CTABLE_SIZE_ST(maxSymbolValue)] /* no final ; */ + +/* static allocation of HUF's DTable */ +typedef U32 HUF_DTable; +#define HUF_DTABLE_SIZE(maxTableLog) (1 + (1<<(maxTableLog))) +#define HUF_CREATE_STATIC_DTABLEX1(DTable, maxTableLog) \ + HUF_DTable DTable[HUF_DTABLE_SIZE((maxTableLog)-1)] = { ((U32)((maxTableLog)-1) * 0x01000001) } +#define HUF_CREATE_STATIC_DTABLEX2(DTable, maxTableLog) \ + HUF_DTable DTable[HUF_DTABLE_SIZE(maxTableLog)] = { ((U32)(maxTableLog) * 0x01000001) } + + +/* **************************************** +* Advanced decompression functions +******************************************/ +size_t HUF_decompress4X1 (void* dst, size_t dstSize, const void* cSrc, size_t cSrcSize); /*< single-symbol decoder */ +#ifndef HUF_FORCE_DECOMPRESS_X1 +size_t HUF_decompress4X2 (void* dst, size_t dstSize, const void* cSrc, size_t cSrcSize); /*< double-symbols decoder */ +#endif + +size_t HUF_decompress4X_DCtx (HUF_DTable* dctx, void* dst, size_t dstSize, const void* cSrc, size_t cSrcSize); /*< decodes RLE and uncompressed */ +size_t HUF_decompress4X_hufOnly(HUF_DTable* dctx, void* dst, size_t dstSize, const void* cSrc, size_t cSrcSize); /*< considers RLE and uncompressed as errors */ +size_t HUF_decompress4X_hufOnly_wksp(HUF_DTable* dctx, void* dst, size_t dstSize, const void* cSrc, size_t cSrcSize, void* workSpace, size_t wkspSize); /*< considers RLE and uncompressed as errors */ +size_t HUF_decompress4X1_DCtx(HUF_DTable* dctx, void* dst, size_t dstSize, const void* cSrc, size_t cSrcSize); /*< single-symbol decoder */ +size_t HUF_decompress4X1_DCtx_wksp(HUF_DTable* dctx, void* dst, size_t dstSize, const void* cSrc, size_t cSrcSize, void* workSpace, size_t wkspSize); /*< single-symbol decoder */ +#ifndef HUF_FORCE_DECOMPRESS_X1 +size_t HUF_decompress4X2_DCtx(HUF_DTable* dctx, void* dst, size_t dstSize, const void* cSrc, size_t cSrcSize); /*< double-symbols decoder */ +size_t HUF_decompress4X2_DCtx_wksp(HUF_DTable* dctx, void* dst, size_t dstSize, const void* cSrc, size_t cSrcSize, void* workSpace, size_t wkspSize); /*< double-symbols decoder */ +#endif + + +/* **************************************** + * HUF detailed API + * ****************************************/ + +/*! HUF_compress() does the following: + * 1. count symbol occurrence from source[] into table count[] using FSE_count() (exposed within "fse.h") + * 2. (optional) refine tableLog using HUF_optimalTableLog() + * 3. build Huffman table from count using HUF_buildCTable() + * 4. save Huffman table to memory buffer using HUF_writeCTable() + * 5. encode the data stream using HUF_compress4X_usingCTable() + * + * The following API allows targeting specific sub-functions for advanced tasks. + * For example, it's possible to compress several blocks using the same 'CTable', + * or to save and regenerate 'CTable' using external methods. + */ +unsigned HUF_optimalTableLog(unsigned maxTableLog, size_t srcSize, unsigned maxSymbolValue); +size_t HUF_buildCTable (HUF_CElt* CTable, const unsigned* count, unsigned maxSymbolValue, unsigned maxNbBits); /* @return : maxNbBits; CTable and count can overlap. In which case, CTable will overwrite count content */ +size_t HUF_writeCTable (void* dst, size_t maxDstSize, const HUF_CElt* CTable, unsigned maxSymbolValue, unsigned huffLog); +size_t HUF_writeCTable_wksp(void* dst, size_t maxDstSize, const HUF_CElt* CTable, unsigned maxSymbolValue, unsigned huffLog, void* workspace, size_t workspaceSize); +size_t HUF_compress4X_usingCTable(void* dst, size_t dstSize, const void* src, size_t srcSize, const HUF_CElt* CTable); +size_t HUF_compress4X_usingCTable_bmi2(void* dst, size_t dstSize, const void* src, size_t srcSize, const HUF_CElt* CTable, int bmi2); +size_t HUF_estimateCompressedSize(const HUF_CElt* CTable, const unsigned* count, unsigned maxSymbolValue); +int HUF_validateCTable(const HUF_CElt* CTable, const unsigned* count, unsigned maxSymbolValue); + +typedef enum { + HUF_repeat_none, /*< Cannot use the previous table */ + HUF_repeat_check, /*< Can use the previous table but it must be checked. Note : The previous table must have been constructed by HUF_compress{1, 4}X_repeat */ + HUF_repeat_valid /*< Can use the previous table and it is assumed to be valid */ + } HUF_repeat; +/* HUF_compress4X_repeat() : + * Same as HUF_compress4X_wksp(), but considers using hufTable if *repeat != HUF_repeat_none. + * If it uses hufTable it does not modify hufTable or repeat. + * If it doesn't, it sets *repeat = HUF_repeat_none, and it sets hufTable to the table used. + * If preferRepeat then the old table will always be used if valid. + * If suspectUncompressible then some sampling checks will be run to potentially skip huffman coding */ +size_t HUF_compress4X_repeat(void* dst, size_t dstSize, + const void* src, size_t srcSize, + unsigned maxSymbolValue, unsigned tableLog, + void* workSpace, size_t wkspSize, /*< `workSpace` must be aligned on 4-bytes boundaries, `wkspSize` must be >= HUF_WORKSPACE_SIZE */ + HUF_CElt* hufTable, HUF_repeat* repeat, int preferRepeat, int bmi2, unsigned suspectUncompressible); + +/* HUF_buildCTable_wksp() : + * Same as HUF_buildCTable(), but using externally allocated scratch buffer. + * `workSpace` must be aligned on 4-bytes boundaries, and its size must be >= HUF_CTABLE_WORKSPACE_SIZE. + */ +#define HUF_CTABLE_WORKSPACE_SIZE_U32 (2*HUF_SYMBOLVALUE_MAX +1 +1) +#define HUF_CTABLE_WORKSPACE_SIZE (HUF_CTABLE_WORKSPACE_SIZE_U32 * sizeof(unsigned)) +size_t HUF_buildCTable_wksp (HUF_CElt* tree, + const unsigned* count, U32 maxSymbolValue, U32 maxNbBits, + void* workSpace, size_t wkspSize); + +/*! HUF_readStats() : + * Read compact Huffman tree, saved by HUF_writeCTable(). + * `huffWeight` is destination buffer. + * @return : size read from `src` , or an error Code . + * Note : Needed by HUF_readCTable() and HUF_readDTableXn() . */ +size_t HUF_readStats(BYTE* huffWeight, size_t hwSize, + U32* rankStats, U32* nbSymbolsPtr, U32* tableLogPtr, + const void* src, size_t srcSize); + +/*! HUF_readStats_wksp() : + * Same as HUF_readStats() but takes an external workspace which must be + * 4-byte aligned and its size must be >= HUF_READ_STATS_WORKSPACE_SIZE. + * If the CPU has BMI2 support, pass bmi2=1, otherwise pass bmi2=0. + */ +#define HUF_READ_STATS_WORKSPACE_SIZE_U32 FSE_DECOMPRESS_WKSP_SIZE_U32(6, HUF_TABLELOG_MAX-1) +#define HUF_READ_STATS_WORKSPACE_SIZE (HUF_READ_STATS_WORKSPACE_SIZE_U32 * sizeof(unsigned)) +size_t HUF_readStats_wksp(BYTE* huffWeight, size_t hwSize, + U32* rankStats, U32* nbSymbolsPtr, U32* tableLogPtr, + const void* src, size_t srcSize, + void* workspace, size_t wkspSize, + int bmi2); + +/* HUF_readCTable() : + * Loading a CTable saved with HUF_writeCTable() */ +size_t HUF_readCTable (HUF_CElt* CTable, unsigned* maxSymbolValuePtr, const void* src, size_t srcSize, unsigned *hasZeroWeights); + +/* HUF_getNbBitsFromCTable() : + * Read nbBits from CTable symbolTable, for symbol `symbolValue` presumed <= HUF_SYMBOLVALUE_MAX + * Note 1 : is not inlined, as HUF_CElt definition is private */ +U32 HUF_getNbBitsFromCTable(const HUF_CElt* symbolTable, U32 symbolValue); + +/* + * HUF_decompress() does the following: + * 1. select the decompression algorithm (X1, X2) based on pre-computed heuristics + * 2. build Huffman table from save, using HUF_readDTableX?() + * 3. decode 1 or 4 segments in parallel using HUF_decompress?X?_usingDTable() + */ + +/* HUF_selectDecoder() : + * Tells which decoder is likely to decode faster, + * based on a set of pre-computed metrics. + * @return : 0==HUF_decompress4X1, 1==HUF_decompress4X2 . + * Assumption : 0 < dstSize <= 128 KB */ +U32 HUF_selectDecoder (size_t dstSize, size_t cSrcSize); + +/* + * The minimum workspace size for the `workSpace` used in + * HUF_readDTableX1_wksp() and HUF_readDTableX2_wksp(). + * + * The space used depends on HUF_TABLELOG_MAX, ranging from ~1500 bytes when + * HUF_TABLE_LOG_MAX=12 to ~1850 bytes when HUF_TABLE_LOG_MAX=15. + * Buffer overflow errors may potentially occur if code modifications result in + * a required workspace size greater than that specified in the following + * macro. + */ +#define HUF_DECOMPRESS_WORKSPACE_SIZE ((2 << 10) + (1 << 9)) +#define HUF_DECOMPRESS_WORKSPACE_SIZE_U32 (HUF_DECOMPRESS_WORKSPACE_SIZE / sizeof(U32)) + +#ifndef HUF_FORCE_DECOMPRESS_X2 +size_t HUF_readDTableX1 (HUF_DTable* DTable, const void* src, size_t srcSize); +size_t HUF_readDTableX1_wksp (HUF_DTable* DTable, const void* src, size_t srcSize, void* workSpace, size_t wkspSize); +#endif +#ifndef HUF_FORCE_DECOMPRESS_X1 +size_t HUF_readDTableX2 (HUF_DTable* DTable, const void* src, size_t srcSize); +size_t HUF_readDTableX2_wksp (HUF_DTable* DTable, const void* src, size_t srcSize, void* workSpace, size_t wkspSize); +#endif + +size_t HUF_decompress4X_usingDTable(void* dst, size_t maxDstSize, const void* cSrc, size_t cSrcSize, const HUF_DTable* DTable); +#ifndef HUF_FORCE_DECOMPRESS_X2 +size_t HUF_decompress4X1_usingDTable(void* dst, size_t maxDstSize, const void* cSrc, size_t cSrcSize, const HUF_DTable* DTable); +#endif +#ifndef HUF_FORCE_DECOMPRESS_X1 +size_t HUF_decompress4X2_usingDTable(void* dst, size_t maxDstSize, const void* cSrc, size_t cSrcSize, const HUF_DTable* DTable); +#endif + + +/* ====================== */ +/* single stream variants */ +/* ====================== */ + +size_t HUF_compress1X (void* dst, size_t dstSize, const void* src, size_t srcSize, unsigned maxSymbolValue, unsigned tableLog); +size_t HUF_compress1X_wksp (void* dst, size_t dstSize, const void* src, size_t srcSize, unsigned maxSymbolValue, unsigned tableLog, void* workSpace, size_t wkspSize); /*< `workSpace` must be a table of at least HUF_WORKSPACE_SIZE_U64 U64 */ +size_t HUF_compress1X_usingCTable(void* dst, size_t dstSize, const void* src, size_t srcSize, const HUF_CElt* CTable); +size_t HUF_compress1X_usingCTable_bmi2(void* dst, size_t dstSize, const void* src, size_t srcSize, const HUF_CElt* CTable, int bmi2); +/* HUF_compress1X_repeat() : + * Same as HUF_compress1X_wksp(), but considers using hufTable if *repeat != HUF_repeat_none. + * If it uses hufTable it does not modify hufTable or repeat. + * If it doesn't, it sets *repeat = HUF_repeat_none, and it sets hufTable to the table used. + * If preferRepeat then the old table will always be used if valid. + * If suspectUncompressible then some sampling checks will be run to potentially skip huffman coding */ +size_t HUF_compress1X_repeat(void* dst, size_t dstSize, + const void* src, size_t srcSize, + unsigned maxSymbolValue, unsigned tableLog, + void* workSpace, size_t wkspSize, /*< `workSpace` must be aligned on 4-bytes boundaries, `wkspSize` must be >= HUF_WORKSPACE_SIZE */ + HUF_CElt* hufTable, HUF_repeat* repeat, int preferRepeat, int bmi2, unsigned suspectUncompressible); + +size_t HUF_decompress1X1 (void* dst, size_t dstSize, const void* cSrc, size_t cSrcSize); /* single-symbol decoder */ +#ifndef HUF_FORCE_DECOMPRESS_X1 +size_t HUF_decompress1X2 (void* dst, size_t dstSize, const void* cSrc, size_t cSrcSize); /* double-symbol decoder */ +#endif + +size_t HUF_decompress1X_DCtx (HUF_DTable* dctx, void* dst, size_t dstSize, const void* cSrc, size_t cSrcSize); +size_t HUF_decompress1X_DCtx_wksp (HUF_DTable* dctx, void* dst, size_t dstSize, const void* cSrc, size_t cSrcSize, void* workSpace, size_t wkspSize); +#ifndef HUF_FORCE_DECOMPRESS_X2 +size_t HUF_decompress1X1_DCtx(HUF_DTable* dctx, void* dst, size_t dstSize, const void* cSrc, size_t cSrcSize); /*< single-symbol decoder */ +size_t HUF_decompress1X1_DCtx_wksp(HUF_DTable* dctx, void* dst, size_t dstSize, const void* cSrc, size_t cSrcSize, void* workSpace, size_t wkspSize); /*< single-symbol decoder */ +#endif +#ifndef HUF_FORCE_DECOMPRESS_X1 +size_t HUF_decompress1X2_DCtx(HUF_DTable* dctx, void* dst, size_t dstSize, const void* cSrc, size_t cSrcSize); /*< double-symbols decoder */ +size_t HUF_decompress1X2_DCtx_wksp(HUF_DTable* dctx, void* dst, size_t dstSize, const void* cSrc, size_t cSrcSize, void* workSpace, size_t wkspSize); /*< double-symbols decoder */ +#endif + +size_t HUF_decompress1X_usingDTable(void* dst, size_t maxDstSize, const void* cSrc, size_t cSrcSize, const HUF_DTable* DTable); /*< automatic selection of sing or double symbol decoder, based on DTable */ +#ifndef HUF_FORCE_DECOMPRESS_X2 +size_t HUF_decompress1X1_usingDTable(void* dst, size_t maxDstSize, const void* cSrc, size_t cSrcSize, const HUF_DTable* DTable); +#endif +#ifndef HUF_FORCE_DECOMPRESS_X1 +size_t HUF_decompress1X2_usingDTable(void* dst, size_t maxDstSize, const void* cSrc, size_t cSrcSize, const HUF_DTable* DTable); +#endif + +/* BMI2 variants. + * If the CPU has BMI2 support, pass bmi2=1, otherwise pass bmi2=0. + */ +size_t HUF_decompress1X_usingDTable_bmi2(void* dst, size_t maxDstSize, const void* cSrc, size_t cSrcSize, const HUF_DTable* DTable, int bmi2); +#ifndef HUF_FORCE_DECOMPRESS_X2 +size_t HUF_decompress1X1_DCtx_wksp_bmi2(HUF_DTable* dctx, void* dst, size_t dstSize, const void* cSrc, size_t cSrcSize, void* workSpace, size_t wkspSize, int bmi2); +#endif +size_t HUF_decompress4X_usingDTable_bmi2(void* dst, size_t maxDstSize, const void* cSrc, size_t cSrcSize, const HUF_DTable* DTable, int bmi2); +size_t HUF_decompress4X_hufOnly_wksp_bmi2(HUF_DTable* dctx, void* dst, size_t dstSize, const void* cSrc, size_t cSrcSize, void* workSpace, size_t wkspSize, int bmi2); +#ifndef HUF_FORCE_DECOMPRESS_X2 +size_t HUF_readDTableX1_wksp_bmi2(HUF_DTable* DTable, const void* src, size_t srcSize, void* workSpace, size_t wkspSize, int bmi2); +#endif +#ifndef HUF_FORCE_DECOMPRESS_X1 +size_t HUF_readDTableX2_wksp_bmi2(HUF_DTable* DTable, const void* src, size_t srcSize, void* workSpace, size_t wkspSize, int bmi2); +#endif + +#endif /* HUF_STATIC_LINKING_ONLY */ + diff --git a/lib/zstd/common/mem.h b/lib/zstd/common/mem.h new file mode 100644 index 00000000000..9668f5b49e0 --- /dev/null +++ b/lib/zstd/common/mem.h @@ -0,0 +1,261 @@ +/* SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause */ +/* + * Copyright (c) Yann Collet, Facebook, Inc. + * All rights reserved. + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. + */ + +#ifndef MEM_H_MODULE +#define MEM_H_MODULE + +/*-**************************************** +* Dependencies +******************************************/ +#include <asm/unaligned.h> /* get_unaligned, put_unaligned* */ +#include <linux/compiler.h> /* inline */ +#include <asm/byteorder.h> /* swab32, swab64 */ +#include <linux/types.h> /* size_t, ptrdiff_t */ +#include "debug.h" /* DEBUG_STATIC_ASSERT */ + +/*-**************************************** +* Compiler specifics +******************************************/ +#define MEM_STATIC static inline + +/*-************************************************************** +* Basic Types +*****************************************************************/ +typedef uint8_t BYTE; +typedef uint8_t U8; +typedef int8_t S8; +typedef uint16_t U16; +typedef int16_t S16; +typedef uint32_t U32; +typedef int32_t S32; +typedef uint64_t U64; +typedef int64_t S64; + +/*-************************************************************** +* Memory I/O API +*****************************************************************/ +/*=== Static platform detection ===*/ +MEM_STATIC unsigned MEM_32bits(void); +MEM_STATIC unsigned MEM_64bits(void); +MEM_STATIC unsigned MEM_isLittleEndian(void); + +/*=== Native unaligned read/write ===*/ +MEM_STATIC U16 MEM_read16(const void* memPtr); +MEM_STATIC U32 MEM_read32(const void* memPtr); +MEM_STATIC U64 MEM_read64(const void* memPtr); +MEM_STATIC size_t MEM_readST(const void* memPtr); + +MEM_STATIC void MEM_write16(void* memPtr, U16 value); +MEM_STATIC void MEM_write32(void* memPtr, U32 value); +MEM_STATIC void MEM_write64(void* memPtr, U64 value); + +/*=== Little endian unaligned read/write ===*/ +MEM_STATIC U16 MEM_readLE16(const void* memPtr); +MEM_STATIC U32 MEM_readLE24(const void* memPtr); +MEM_STATIC U32 MEM_readLE32(const void* memPtr); +MEM_STATIC U64 MEM_readLE64(const void* memPtr); +MEM_STATIC size_t MEM_readLEST(const void* memPtr); + +MEM_STATIC void MEM_writeLE16(void* memPtr, U16 val); +MEM_STATIC void MEM_writeLE24(void* memPtr, U32 val); +MEM_STATIC void MEM_writeLE32(void* memPtr, U32 val32); +MEM_STATIC void MEM_writeLE64(void* memPtr, U64 val64); +MEM_STATIC void MEM_writeLEST(void* memPtr, size_t val); + +/*=== Big endian unaligned read/write ===*/ +MEM_STATIC U32 MEM_readBE32(const void* memPtr); +MEM_STATIC U64 MEM_readBE64(const void* memPtr); +MEM_STATIC size_t MEM_readBEST(const void* memPtr); + +MEM_STATIC void MEM_writeBE32(void* memPtr, U32 val32); +MEM_STATIC void MEM_writeBE64(void* memPtr, U64 val64); +MEM_STATIC void MEM_writeBEST(void* memPtr, size_t val); + +/*=== Byteswap ===*/ +MEM_STATIC U32 MEM_swap32(U32 in); +MEM_STATIC U64 MEM_swap64(U64 in); +MEM_STATIC size_t MEM_swapST(size_t in); + +/*-************************************************************** +* Memory I/O Implementation +*****************************************************************/ +MEM_STATIC unsigned MEM_32bits(void) +{ + return sizeof(size_t) == 4; +} + +MEM_STATIC unsigned MEM_64bits(void) +{ + return sizeof(size_t) == 8; +} + +#if defined(__LITTLE_ENDIAN) +#define MEM_LITTLE_ENDIAN 1 +#else +#define MEM_LITTLE_ENDIAN 0 +#endif + +MEM_STATIC unsigned MEM_isLittleEndian(void) +{ + return MEM_LITTLE_ENDIAN; +} + +MEM_STATIC U16 MEM_read16(const void *memPtr) +{ + return get_unaligned((const U16 *)memPtr); +} + +MEM_STATIC U32 MEM_read32(const void *memPtr) +{ + return get_unaligned((const U32 *)memPtr); +} + +MEM_STATIC U64 MEM_read64(const void *memPtr) +{ + return get_unaligned((const U64 *)memPtr); +} + +MEM_STATIC size_t MEM_readST(const void *memPtr) +{ + return get_unaligned((const size_t *)memPtr); +} + +MEM_STATIC void MEM_write16(void *memPtr, U16 value) +{ + put_unaligned(value, (U16 *)memPtr); +} + +MEM_STATIC void MEM_write32(void *memPtr, U32 value) +{ + put_unaligned(value, (U32 *)memPtr); +} + +MEM_STATIC void MEM_write64(void *memPtr, U64 value) +{ + put_unaligned(value, (U64 *)memPtr); +} + +/*=== Little endian r/w ===*/ + +MEM_STATIC U16 MEM_readLE16(const void *memPtr) +{ + return get_unaligned_le16(memPtr); +} + +MEM_STATIC void MEM_writeLE16(void *memPtr, U16 val) +{ + put_unaligned_le16(val, memPtr); +} + +MEM_STATIC U32 MEM_readLE24(const void *memPtr) +{ + return MEM_readLE16(memPtr) + (((const BYTE *)memPtr)[2] << 16); +} + +MEM_STATIC void MEM_writeLE24(void *memPtr, U32 val) +{ + MEM_writeLE16(memPtr, (U16)val); + ((BYTE *)memPtr)[2] = (BYTE)(val >> 16); +} + +MEM_STATIC U32 MEM_readLE32(const void *memPtr) +{ + return get_unaligned_le32(memPtr); +} + +MEM_STATIC void MEM_writeLE32(void *memPtr, U32 val32) +{ + put_unaligned_le32(val32, memPtr); +} + +MEM_STATIC U64 MEM_readLE64(const void *memPtr) +{ + return get_unaligned_le64(memPtr); +} + +MEM_STATIC void MEM_writeLE64(void *memPtr, U64 val64) +{ + put_unaligned_le64(val64, memPtr); +} + +MEM_STATIC size_t MEM_readLEST(const void *memPtr) +{ + if (MEM_32bits()) + return (size_t)MEM_readLE32(memPtr); + else + return (size_t)MEM_readLE64(memPtr); +} + +MEM_STATIC void MEM_writeLEST(void *memPtr, size_t val) +{ + if (MEM_32bits()) + MEM_writeLE32(memPtr, (U32)val); + else + MEM_writeLE64(memPtr, (U64)val); +} + +/*=== Big endian r/w ===*/ + +MEM_STATIC U32 MEM_readBE32(const void *memPtr) +{ + return get_unaligned_be32(memPtr); +} + +MEM_STATIC void MEM_writeBE32(void *memPtr, U32 val32) +{ + put_unaligned_be32(val32, memPtr); +} + +MEM_STATIC U64 MEM_readBE64(const void *memPtr) +{ + return get_unaligned_be64(memPtr); +} + +MEM_STATIC void MEM_writeBE64(void *memPtr, U64 val64) +{ + put_unaligned_be64(val64, memPtr); +} + +MEM_STATIC size_t MEM_readBEST(const void *memPtr) +{ + if (MEM_32bits()) + return (size_t)MEM_readBE32(memPtr); + else + return (size_t)MEM_readBE64(memPtr); +} + +MEM_STATIC void MEM_writeBEST(void *memPtr, size_t val) +{ + if (MEM_32bits()) + MEM_writeBE32(memPtr, (U32)val); + else + MEM_writeBE64(memPtr, (U64)val); +} + +MEM_STATIC U32 MEM_swap32(U32 in) +{ + return swab32(in); +} + +MEM_STATIC U64 MEM_swap64(U64 in) +{ + return swab64(in); +} + +MEM_STATIC size_t MEM_swapST(size_t in) +{ + if (MEM_32bits()) + return (size_t)MEM_swap32((U32)in); + else + return (size_t)MEM_swap64((U64)in); +} + +#endif /* MEM_H_MODULE */ diff --git a/lib/zstd/common/portability_macros.h b/lib/zstd/common/portability_macros.h new file mode 100644 index 00000000000..0e3b2c0a527 --- /dev/null +++ b/lib/zstd/common/portability_macros.h @@ -0,0 +1,93 @@ +/* + * Copyright (c) Facebook, Inc. + * All rights reserved. + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. + */ + +#ifndef ZSTD_PORTABILITY_MACROS_H +#define ZSTD_PORTABILITY_MACROS_H + +/* + * This header file contains macro defintions to support portability. + * This header is shared between C and ASM code, so it MUST only + * contain macro definitions. It MUST not contain any C code. + * + * This header ONLY defines macros to detect platforms/feature support. + * + */ + + +/* compat. with non-clang compilers */ +#ifndef __has_attribute + #define __has_attribute(x) 0 +#endif + +/* compat. with non-clang compilers */ +#ifndef __has_builtin +# define __has_builtin(x) 0 +#endif + +/* compat. with non-clang compilers */ +#ifndef __has_feature +# define __has_feature(x) 0 +#endif + +/* detects whether we are being compiled under msan */ + +/* detects whether we are being compiled under asan */ + +/* detects whether we are being compiled under dfsan */ + +/* Mark the internal assembly functions as hidden */ +#ifdef __ELF__ +# define ZSTD_HIDE_ASM_FUNCTION(func) .hidden func +#else +# define ZSTD_HIDE_ASM_FUNCTION(func) +#endif + +/* Enable runtime BMI2 dispatch based on the CPU. + * Enabled for clang & gcc >=4.8 on x86 when BMI2 isn't enabled by default. + */ +#ifndef DYNAMIC_BMI2 + #if ((defined(__clang__) && __has_attribute(__target__)) \ + || (defined(__GNUC__) \ + && (__GNUC__ >= 5 || (__GNUC__ == 4 && __GNUC_MINOR__ >= 8)))) \ + && (defined(__x86_64__) || defined(_M_X64)) \ + && !defined(__BMI2__) + # define DYNAMIC_BMI2 1 + #else + # define DYNAMIC_BMI2 0 + #endif +#endif + +/* + * Only enable assembly for GNUC comptabile compilers, + * because other platforms may not support GAS assembly syntax. + * + * Only enable assembly for Linux / MacOS, other platforms may + * work, but they haven't been tested. This could likely be + * extended to BSD systems. + * + * Disable assembly when MSAN is enabled, because MSAN requires + * 100% of code to be instrumented to work. + */ +#define ZSTD_ASM_SUPPORTED 1 + +/* + * Determines whether we should enable assembly for x86-64 + * with BMI2. + * + * Enable if all of the following conditions hold: + * - ASM hasn't been explicitly disabled by defining ZSTD_DISABLE_ASM + * - Assembly is supported + * - We are compiling for x86-64 and either: + * - DYNAMIC_BMI2 is enabled + * - BMI2 is supported at compile time + */ +#define ZSTD_ENABLE_ASM_X86_64_BMI2 0 + +#endif /* ZSTD_PORTABILITY_MACROS_H */ diff --git a/lib/zstd/common/zstd_common.c b/lib/zstd/common/zstd_common.c new file mode 100644 index 00000000000..3d7e35b309b --- /dev/null +++ b/lib/zstd/common/zstd_common.c @@ -0,0 +1,83 @@ +/* + * Copyright (c) Yann Collet, Facebook, Inc. + * All rights reserved. + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. + */ + + + +/*-************************************* +* Dependencies +***************************************/ +#define ZSTD_DEPS_NEED_MALLOC +#include "zstd_deps.h" /* ZSTD_malloc, ZSTD_calloc, ZSTD_free, ZSTD_memset */ +#include "error_private.h" +#include "zstd_internal.h" + + +/*-**************************************** +* Version +******************************************/ +unsigned ZSTD_versionNumber(void) { return ZSTD_VERSION_NUMBER; } + +const char* ZSTD_versionString(void) { return ZSTD_VERSION_STRING; } + + +/*-**************************************** +* ZSTD Error Management +******************************************/ +#undef ZSTD_isError /* defined within zstd_internal.h */ +/*! ZSTD_isError() : + * tells if a return value is an error code + * symbol is required for external callers */ +unsigned ZSTD_isError(size_t code) { return ERR_isError(code); } + +/*! ZSTD_getErrorName() : + * provides error code string from function result (useful for debugging) */ +const char* ZSTD_getErrorName(size_t code) { return ERR_getErrorName(code); } + +/*! ZSTD_getError() : + * convert a `size_t` function result into a proper ZSTD_errorCode enum */ +ZSTD_ErrorCode ZSTD_getErrorCode(size_t code) { return ERR_getErrorCode(code); } + +/*! ZSTD_getErrorString() : + * provides error code string from enum */ +const char* ZSTD_getErrorString(ZSTD_ErrorCode code) { return ERR_getErrorString(code); } + + + +/*=************************************************************** +* Custom allocator +****************************************************************/ +void* ZSTD_customMalloc(size_t size, ZSTD_customMem customMem) +{ + if (customMem.customAlloc) + return customMem.customAlloc(customMem.opaque, size); + return ZSTD_malloc(size); +} + +void* ZSTD_customCalloc(size_t size, ZSTD_customMem customMem) +{ + if (customMem.customAlloc) { + /* calloc implemented as malloc+memset; + * not as efficient as calloc, but next best guess for custom malloc */ + void* const ptr = customMem.customAlloc(customMem.opaque, size); + ZSTD_memset(ptr, 0, size); + return ptr; + } + return ZSTD_calloc(1, size); +} + +void ZSTD_customFree(void* ptr, ZSTD_customMem customMem) +{ + if (ptr!=NULL) { + if (customMem.customFree) + customMem.customFree(customMem.opaque, ptr); + else + ZSTD_free(ptr); + } +} diff --git a/lib/zstd/common/zstd_deps.h b/lib/zstd/common/zstd_deps.h new file mode 100644 index 00000000000..e45ec566831 --- /dev/null +++ b/lib/zstd/common/zstd_deps.h @@ -0,0 +1,125 @@ +/* SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause */ +/* + * Copyright (c) Facebook, Inc. + * All rights reserved. + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. + */ + +/* + * This file provides common libc dependencies that zstd requires. + * The purpose is to allow replacing this file with a custom implementation + * to compile zstd without libc support. + */ + +/* Need: + * NULL + * INT_MAX + * UINT_MAX + * ZSTD_memcpy() + * ZSTD_memset() + * ZSTD_memmove() + */ +#ifndef ZSTD_DEPS_COMMON +#define ZSTD_DEPS_COMMON + +#include <linux/kernel.h> +#include <linux/stddef.h> + +#define ZSTD_memcpy(d,s,n) __builtin_memcpy((d),(s),(n)) +#define ZSTD_memmove(d,s,n) __builtin_memmove((d),(s),(n)) +#define ZSTD_memset(d,s,n) __builtin_memset((d),(s),(n)) + +#endif /* ZSTD_DEPS_COMMON */ + +/* + * Define malloc as always failing. That means the user must + * either use ZSTD_customMem or statically allocate memory. + * Need: + * ZSTD_malloc() + * ZSTD_free() + * ZSTD_calloc() + */ +#ifdef ZSTD_DEPS_NEED_MALLOC +#ifndef ZSTD_DEPS_MALLOC +#define ZSTD_DEPS_MALLOC + +#define ZSTD_malloc(s) ({ (void)(s); NULL; }) +#define ZSTD_free(p) ((void)(p)) +#define ZSTD_calloc(n,s) ({ (void)(n); (void)(s); NULL; }) + +#endif /* ZSTD_DEPS_MALLOC */ +#endif /* ZSTD_DEPS_NEED_MALLOC */ + +/* + * Provides 64-bit math support. + * Need: + * U64 ZSTD_div64(U64 dividend, U32 divisor) + */ +#ifdef ZSTD_DEPS_NEED_MATH64 +#ifndef ZSTD_DEPS_MATH64 +#define ZSTD_DEPS_MATH64 + +#include <linux/math64.h> + +static uint64_t ZSTD_div64(uint64_t dividend, uint32_t divisor) { + return div_u64(dividend, divisor); +} + +#endif /* ZSTD_DEPS_MATH64 */ +#endif /* ZSTD_DEPS_NEED_MATH64 */ + +/* + * This is only requested when DEBUGLEVEL >= 1, meaning + * it is disabled in production. + * Need: + * assert() + */ +#ifdef ZSTD_DEPS_NEED_ASSERT +#ifndef ZSTD_DEPS_ASSERT +#define ZSTD_DEPS_ASSERT + +#include <linux/kernel.h> + +#define assert(x) WARN_ON((x)) + +#endif /* ZSTD_DEPS_ASSERT */ +#endif /* ZSTD_DEPS_NEED_ASSERT */ + +/* + * This is only requested when DEBUGLEVEL >= 2, meaning + * it is disabled in production. + * Need: + * ZSTD_DEBUG_PRINT() + */ +#ifdef ZSTD_DEPS_NEED_IO +#ifndef ZSTD_DEPS_IO +#define ZSTD_DEPS_IO + +#include <linux/printk.h> + +#define ZSTD_DEBUG_PRINT(...) pr_debug(__VA_ARGS__) + +#endif /* ZSTD_DEPS_IO */ +#endif /* ZSTD_DEPS_NEED_IO */ + +/* + * Only requested when MSAN is enabled. + * Need: + * intptr_t + */ +#ifdef ZSTD_DEPS_NEED_STDINT +#ifndef ZSTD_DEPS_STDINT +#define ZSTD_DEPS_STDINT + +/* + * The Linux Kernel doesn't provide intptr_t, only uintptr_t, which + * is an unsigned long. + */ +typedef long intptr_t; + +#endif /* ZSTD_DEPS_STDINT */ +#endif /* ZSTD_DEPS_NEED_STDINT */ diff --git a/lib/zstd/common/zstd_internal.h b/lib/zstd/common/zstd_internal.h new file mode 100644 index 00000000000..93305d9b41b --- /dev/null +++ b/lib/zstd/common/zstd_internal.h @@ -0,0 +1,443 @@ +/* + * Copyright (c) Yann Collet, Facebook, Inc. + * All rights reserved. + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. + */ + +#ifndef ZSTD_CCOMMON_H_MODULE +#define ZSTD_CCOMMON_H_MODULE + +/* this module contains definitions which must be identical + * across compression, decompression and dictBuilder. + * It also contains a few functions useful to at least 2 of them + * and which benefit from being inlined */ + +/*-************************************* +* Dependencies +***************************************/ +#include "compiler.h" +#include "cpu.h" +#include "mem.h" +#include "debug.h" /* assert, DEBUGLOG, RAWLOG, g_debuglevel */ +#include "error_private.h" +#define ZSTD_STATIC_LINKING_ONLY +#include <linux/zstd.h> +#define FSE_STATIC_LINKING_ONLY +#include "fse.h" +#define HUF_STATIC_LINKING_ONLY +#include "huf.h" +#include <linux/xxhash.h> /* XXH_reset, update, digest */ +#define ZSTD_TRACE 0 + + +/* ---- static assert (debug) --- */ +#define ZSTD_STATIC_ASSERT(c) DEBUG_STATIC_ASSERT(c) +#define ZSTD_isError ERR_isError /* for inlining */ +#define FSE_isError ERR_isError +#define HUF_isError ERR_isError + + +/*-************************************* +* shared macros +***************************************/ +#undef MIN +#undef MAX +#define MIN(a,b) ((a)<(b) ? (a) : (b)) +#define MAX(a,b) ((a)>(b) ? (a) : (b)) +#define BOUNDED(min,val,max) (MAX(min,MIN(val,max))) + + +/*-************************************* +* Common constants +***************************************/ +#define ZSTD_OPT_NUM (1<<12) + +#define ZSTD_REP_NUM 3 /* number of repcodes */ +static UNUSED_ATTR const U32 repStartValue[ZSTD_REP_NUM] = { 1, 4, 8 }; + +#define KB *(1 <<10) +#define MB *(1 <<20) +#define GB *(1U<<30) + +#define BIT7 128 +#define BIT6 64 +#define BIT5 32 +#define BIT4 16 +#define BIT1 2 +#define BIT0 1 + +#define ZSTD_WINDOWLOG_ABSOLUTEMIN 10 +static UNUSED_ATTR const size_t ZSTD_fcs_fieldSize[4] = { 0, 2, 4, 8 }; +static UNUSED_ATTR const size_t ZSTD_did_fieldSize[4] = { 0, 1, 2, 4 }; + +#define ZSTD_FRAMEIDSIZE 4 /* magic number size */ + +#define ZSTD_BLOCKHEADERSIZE 3 /* C standard doesn't allow `static const` variable to be init using another `static const` variable */ +static UNUSED_ATTR const size_t ZSTD_blockHeaderSize = ZSTD_BLOCKHEADERSIZE; +typedef enum { bt_raw, bt_rle, bt_compressed, bt_reserved } blockType_e; + +#define ZSTD_FRAMECHECKSUMSIZE 4 + +#define MIN_SEQUENCES_SIZE 1 /* nbSeq==0 */ +#define MIN_CBLOCK_SIZE (1 /*litCSize*/ + 1 /* RLE or RAW */ + MIN_SEQUENCES_SIZE /* nbSeq==0 */) /* for a non-null block */ + +#define HufLog 12 +typedef enum { set_basic, set_rle, set_compressed, set_repeat } symbolEncodingType_e; + +#define LONGNBSEQ 0x7F00 + +#define MINMATCH 3 + +#define Litbits 8 +#define MaxLit ((1<<Litbits) - 1) +#define MaxML 52 +#define MaxLL 35 +#define DefaultMaxOff 28 +#define MaxOff 31 +#define MaxSeq MAX(MaxLL, MaxML) /* Assumption : MaxOff < MaxLL,MaxML */ +#define MLFSELog 9 +#define LLFSELog 9 +#define OffFSELog 8 +#define MaxFSELog MAX(MAX(MLFSELog, LLFSELog), OffFSELog) + +#define ZSTD_MAX_HUF_HEADER_SIZE 128 /* header + <= 127 byte tree description */ +/* Each table cannot take more than #symbols * FSELog bits */ +#define ZSTD_MAX_FSE_HEADERS_SIZE (((MaxML + 1) * MLFSELog + (MaxLL + 1) * LLFSELog + (MaxOff + 1) * OffFSELog + 7) / 8) + +static UNUSED_ATTR const U8 LL_bits[MaxLL+1] = { + 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0, 0, 0, 0, 0, + 1, 1, 1, 1, 2, 2, 3, 3, + 4, 6, 7, 8, 9,10,11,12, + 13,14,15,16 +}; +static UNUSED_ATTR const S16 LL_defaultNorm[MaxLL+1] = { + 4, 3, 2, 2, 2, 2, 2, 2, + 2, 2, 2, 2, 2, 1, 1, 1, + 2, 2, 2, 2, 2, 2, 2, 2, + 2, 3, 2, 1, 1, 1, 1, 1, + -1,-1,-1,-1 +}; +#define LL_DEFAULTNORMLOG 6 /* for static allocation */ +static UNUSED_ATTR const U32 LL_defaultNormLog = LL_DEFAULTNORMLOG; + +static UNUSED_ATTR const U8 ML_bits[MaxML+1] = { + 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0, 0, 0, 0, 0, + 1, 1, 1, 1, 2, 2, 3, 3, + 4, 4, 5, 7, 8, 9,10,11, + 12,13,14,15,16 +}; +static UNUSED_ATTR const S16 ML_defaultNorm[MaxML+1] = { + 1, 4, 3, 2, 2, 2, 2, 2, + 2, 1, 1, 1, 1, 1, 1, 1, + 1, 1, 1, 1, 1, 1, 1, 1, + 1, 1, 1, 1, 1, 1, 1, 1, + 1, 1, 1, 1, 1, 1, 1, 1, + 1, 1, 1, 1, 1, 1,-1,-1, + -1,-1,-1,-1,-1 +}; +#define ML_DEFAULTNORMLOG 6 /* for static allocation */ +static UNUSED_ATTR const U32 ML_defaultNormLog = ML_DEFAULTNORMLOG; + +static UNUSED_ATTR const S16 OF_defaultNorm[DefaultMaxOff+1] = { + 1, 1, 1, 1, 1, 1, 2, 2, + 2, 1, 1, 1, 1, 1, 1, 1, + 1, 1, 1, 1, 1, 1, 1, 1, + -1,-1,-1,-1,-1 +}; +#define OF_DEFAULTNORMLOG 5 /* for static allocation */ +static UNUSED_ATTR const U32 OF_defaultNormLog = OF_DEFAULTNORMLOG; + + +/*-******************************************* +* Shared functions to include for inlining +*********************************************/ +static void ZSTD_copy8(void* dst, const void* src) { +#if defined(ZSTD_ARCH_ARM_NEON) + vst1_u8((uint8_t*)dst, vld1_u8((const uint8_t*)src)); +#else + ZSTD_memcpy(dst, src, 8); +#endif +} +#define COPY8(d,s) { ZSTD_copy8(d,s); d+=8; s+=8; } + +/* Need to use memmove here since the literal buffer can now be located within + the dst buffer. In circumstances where the op "catches up" to where the + literal buffer is, there can be partial overlaps in this call on the final + copy if the literal is being shifted by less than 16 bytes. */ +static void ZSTD_copy16(void* dst, const void* src) { +#if defined(ZSTD_ARCH_ARM_NEON) + vst1q_u8((uint8_t*)dst, vld1q_u8((const uint8_t*)src)); +#elif defined(ZSTD_ARCH_X86_SSE2) + _mm_storeu_si128((__m128i*)dst, _mm_loadu_si128((const __m128i*)src)); +#elif defined(__clang__) + ZSTD_memmove(dst, src, 16); +#else + /* ZSTD_memmove is not inlined properly by gcc */ + BYTE copy16_buf[16]; + ZSTD_memcpy(copy16_buf, src, 16); + ZSTD_memcpy(dst, copy16_buf, 16); +#endif +} +#define COPY16(d,s) { ZSTD_copy16(d,s); d+=16; s+=16; } + +#define WILDCOPY_OVERLENGTH 32 +#define WILDCOPY_VECLEN 16 + +typedef enum { + ZSTD_no_overlap, + ZSTD_overlap_src_before_dst + /* ZSTD_overlap_dst_before_src, */ +} ZSTD_overlap_e; + +/*! ZSTD_wildcopy() : + * Custom version of ZSTD_memcpy(), can over read/write up to WILDCOPY_OVERLENGTH bytes (if length==0) + * @param ovtype controls the overlap detection + * - ZSTD_no_overlap: The source and destination are guaranteed to be at least WILDCOPY_VECLEN bytes apart. + * - ZSTD_overlap_src_before_dst: The src and dst may overlap, but they MUST be at least 8 bytes apart. + * The src buffer must be before the dst buffer. + */ +MEM_STATIC FORCE_INLINE_ATTR +void ZSTD_wildcopy(void* dst, const void* src, ptrdiff_t length, ZSTD_overlap_e const ovtype) +{ + ptrdiff_t diff = (BYTE*)dst - (const BYTE*)src; + const BYTE* ip = (const BYTE*)src; + BYTE* op = (BYTE*)dst; + BYTE* const oend = op + length; + + if (ovtype == ZSTD_overlap_src_before_dst && diff < WILDCOPY_VECLEN) { + /* Handle short offset copies. */ + do { + COPY8(op, ip) + } while (op < oend); + } else { + assert(diff >= WILDCOPY_VECLEN || diff <= -WILDCOPY_VECLEN); + /* Separate out the first COPY16() call because the copy length is + * almost certain to be short, so the branches have different + * probabilities. Since it is almost certain to be short, only do + * one COPY16() in the first call. Then, do two calls per loop since + * at that point it is more likely to have a high trip count. + */ +#ifdef __aarch64__ + do { + COPY16(op, ip); + } + while (op < oend); +#else + ZSTD_copy16(op, ip); + if (16 >= length) return; + op += 16; + ip += 16; + do { + COPY16(op, ip); + COPY16(op, ip); + } + while (op < oend); +#endif + } +} + +MEM_STATIC size_t ZSTD_limitCopy(void* dst, size_t dstCapacity, const void* src, size_t srcSize) +{ + size_t const length = MIN(dstCapacity, srcSize); + if (length > 0) { + ZSTD_memcpy(dst, src, length); + } + return length; +} + +/* define "workspace is too large" as this number of times larger than needed */ +#define ZSTD_WORKSPACETOOLARGE_FACTOR 3 + +/* when workspace is continuously too large + * during at least this number of times, + * context's memory usage is considered wasteful, + * because it's sized to handle a worst case scenario which rarely happens. + * In which case, resize it down to free some memory */ +#define ZSTD_WORKSPACETOOLARGE_MAXDURATION 128 + +/* Controls whether the input/output buffer is buffered or stable. */ +typedef enum { + ZSTD_bm_buffered = 0, /* Buffer the input/output */ + ZSTD_bm_stable = 1 /* ZSTD_inBuffer/ZSTD_outBuffer is stable */ +} ZSTD_bufferMode_e; + + +/*-******************************************* +* Private declarations +*********************************************/ +typedef struct seqDef_s { + U32 offBase; /* offBase == Offset + ZSTD_REP_NUM, or repcode 1,2,3 */ + U16 litLength; + U16 mlBase; /* mlBase == matchLength - MINMATCH */ +} seqDef; + +/* Controls whether seqStore has a single "long" litLength or matchLength. See seqStore_t. */ +typedef enum { + ZSTD_llt_none = 0, /* no longLengthType */ + ZSTD_llt_literalLength = 1, /* represents a long literal */ + ZSTD_llt_matchLength = 2 /* represents a long match */ +} ZSTD_longLengthType_e; + +typedef struct { + seqDef* sequencesStart; + seqDef* sequences; /* ptr to end of sequences */ + BYTE* litStart; + BYTE* lit; /* ptr to end of literals */ + BYTE* llCode; + BYTE* mlCode; + BYTE* ofCode; + size_t maxNbSeq; + size_t maxNbLit; + + /* longLengthPos and longLengthType to allow us to represent either a single litLength or matchLength + * in the seqStore that has a value larger than U16 (if it exists). To do so, we increment + * the existing value of the litLength or matchLength by 0x10000. + */ + ZSTD_longLengthType_e longLengthType; + U32 longLengthPos; /* Index of the sequence to apply long length modification to */ +} seqStore_t; + +typedef struct { + U32 litLength; + U32 matchLength; +} ZSTD_sequenceLength; + +/* + * Returns the ZSTD_sequenceLength for the given sequences. It handles the decoding of long sequences + * indicated by longLengthPos and longLengthType, and adds MINMATCH back to matchLength. + */ +MEM_STATIC ZSTD_sequenceLength ZSTD_getSequenceLength(seqStore_t const* seqStore, seqDef const* seq) +{ + ZSTD_sequenceLength seqLen; + seqLen.litLength = seq->litLength; + seqLen.matchLength = seq->mlBase + MINMATCH; + if (seqStore->longLengthPos == (U32)(seq - seqStore->sequencesStart)) { + if (seqStore->longLengthType == ZSTD_llt_literalLength) { + seqLen.litLength += 0xFFFF; + } + if (seqStore->longLengthType == ZSTD_llt_matchLength) { + seqLen.matchLength += 0xFFFF; + } + } + return seqLen; +} + +/* + * Contains the compressed frame size and an upper-bound for the decompressed frame size. + * Note: before using `compressedSize`, check for errors using ZSTD_isError(). + * similarly, before using `decompressedBound`, check for errors using: + * `decompressedBound != ZSTD_CONTENTSIZE_ERROR` + */ +typedef struct { + size_t compressedSize; + unsigned long long decompressedBound; +} ZSTD_frameSizeInfo; /* decompress & legacy */ + +const seqStore_t* ZSTD_getSeqStore(const ZSTD_CCtx* ctx); /* compress & dictBuilder */ +void ZSTD_seqToCodes(const seqStore_t* seqStorePtr); /* compress, dictBuilder, decodeCorpus (shouldn't get its definition from here) */ + +/* custom memory allocation functions */ +void* ZSTD_customMalloc(size_t size, ZSTD_customMem customMem); +void* ZSTD_customCalloc(size_t size, ZSTD_customMem customMem); +void ZSTD_customFree(void* ptr, ZSTD_customMem customMem); + + +MEM_STATIC U32 ZSTD_highbit32(U32 val) /* compress, dictBuilder, decodeCorpus */ +{ + assert(val != 0); + { +# if (__GNUC__ >= 3) /* GCC Intrinsic */ + return __builtin_clz (val) ^ 31; +# else /* Software version */ + static const U32 DeBruijnClz[32] = { 0, 9, 1, 10, 13, 21, 2, 29, 11, 14, 16, 18, 22, 25, 3, 30, 8, 12, 20, 28, 15, 17, 24, 7, 19, 27, 23, 6, 26, 5, 4, 31 }; + U32 v = val; + v |= v >> 1; + v |= v >> 2; + v |= v >> 4; + v |= v >> 8; + v |= v >> 16; + return DeBruijnClz[(v * 0x07C4ACDDU) >> 27]; +# endif + } +} + +/* + * Counts the number of trailing zeros of a `size_t`. + * Most compilers should support CTZ as a builtin. A backup + * implementation is provided if the builtin isn't supported, but + * it may not be terribly efficient. + */ +MEM_STATIC unsigned ZSTD_countTrailingZeros(size_t val) +{ + if (MEM_64bits()) { +# if (__GNUC__ >= 4) + return __builtin_ctzll((U64)val); +# else + static const int DeBruijnBytePos[64] = { 0, 1, 2, 7, 3, 13, 8, 19, + 4, 25, 14, 28, 9, 34, 20, 56, + 5, 17, 26, 54, 15, 41, 29, 43, + 10, 31, 38, 35, 21, 45, 49, 57, + 63, 6, 12, 18, 24, 27, 33, 55, + 16, 53, 40, 42, 30, 37, 44, 48, + 62, 11, 23, 32, 52, 39, 36, 47, + 61, 22, 51, 46, 60, 50, 59, 58 }; + return DeBruijnBytePos[((U64)((val & -(long long)val) * 0x0218A392CDABBD3FULL)) >> 58]; +# endif + } else { /* 32 bits */ +# if (__GNUC__ >= 3) + return __builtin_ctz((U32)val); +# else + static const int DeBruijnBytePos[32] = { 0, 1, 28, 2, 29, 14, 24, 3, + 30, 22, 20, 15, 25, 17, 4, 8, + 31, 27, 13, 23, 21, 19, 16, 7, + 26, 12, 18, 6, 11, 5, 10, 9 }; + return DeBruijnBytePos[((U32)((val & -(S32)val) * 0x077CB531U)) >> 27]; +# endif + } +} + + +/* ZSTD_invalidateRepCodes() : + * ensures next compression will not use repcodes from previous block. + * Note : only works with regular variant; + * do not use with extDict variant ! */ +void ZSTD_invalidateRepCodes(ZSTD_CCtx* cctx); /* zstdmt, adaptive_compression (shouldn't get this definition from here) */ + + +typedef struct { + blockType_e blockType; + U32 lastBlock; + U32 origSize; +} blockProperties_t; /* declared here for decompress and fullbench */ + +/*! ZSTD_getcBlockSize() : + * Provides the size of compressed block from block header `src` */ +/* Used by: decompress, fullbench (does not get its definition from here) */ +size_t ZSTD_getcBlockSize(const void* src, size_t srcSize, + blockProperties_t* bpPtr); + +/*! ZSTD_decodeSeqHeaders() : + * decode sequence header from src */ +/* Used by: decompress, fullbench (does not get its definition from here) */ +size_t ZSTD_decodeSeqHeaders(ZSTD_DCtx* dctx, int* nbSeqPtr, + const void* src, size_t srcSize); + +/* + * @returns true iff the CPU supports dynamic BMI2 dispatch. + */ +MEM_STATIC int ZSTD_cpuSupportsBmi2(void) +{ + ZSTD_cpuid_t cpuid = ZSTD_cpuid(); + return ZSTD_cpuid_bmi1(cpuid) && ZSTD_cpuid_bmi2(cpuid); +} + + +#endif /* ZSTD_CCOMMON_H_MODULE */ diff --git a/lib/zstd/decompress.c b/lib/zstd/decompress.c deleted file mode 100644 index edfddd817e9..00000000000 --- a/lib/zstd/decompress.c +++ /dev/null @@ -1,2516 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0 or BSD-3-Clause-Clear) -/** - * Copyright (c) 2016-present, Yann Collet, Facebook, Inc. - * All rights reserved. - */ - -/* *************************************************************** -* Tuning parameters -*****************************************************************/ -/*! -* MAXWINDOWSIZE_DEFAULT : -* maximum window size accepted by DStream, by default. -* Frames requiring more memory will be rejected. -*/ -#ifndef ZSTD_MAXWINDOWSIZE_DEFAULT -#define ZSTD_MAXWINDOWSIZE_DEFAULT ((1 << ZSTD_WINDOWLOG_MAX) + 1) /* defined within zstd.h */ -#endif - -/*-******************************************************* -* Dependencies -*********************************************************/ -#include "fse.h" -#include "huf.h" -#include "mem.h" /* low level memory routines */ -#include "zstd_internal.h" -#include <malloc.h> -#include <linux/kernel.h> -#include <linux/compat.h> -#include <linux/string.h> /* memcpy, memmove, memset */ - -#define ZSTD_PREFETCH(ptr) __builtin_prefetch(ptr, 0, 0) - -/*-************************************* -* Macros -***************************************/ -#define ZSTD_isError ERR_isError /* for inlining */ -#define FSE_isError ERR_isError -#define HUF_isError ERR_isError - -/*_******************************************************* -* Memory operations -**********************************************************/ -static void ZSTD_copy4(void *dst, const void *src) { memcpy(dst, src, 4); } - -/*-************************************************************* -* Context management -***************************************************************/ -typedef enum { - ZSTDds_getFrameHeaderSize, - ZSTDds_decodeFrameHeader, - ZSTDds_decodeBlockHeader, - ZSTDds_decompressBlock, - ZSTDds_decompressLastBlock, - ZSTDds_checkChecksum, - ZSTDds_decodeSkippableHeader, - ZSTDds_skipFrame -} ZSTD_dStage; - -typedef struct { - FSE_DTable LLTable[FSE_DTABLE_SIZE_U32(LLFSELog)]; - FSE_DTable OFTable[FSE_DTABLE_SIZE_U32(OffFSELog)]; - FSE_DTable MLTable[FSE_DTABLE_SIZE_U32(MLFSELog)]; - HUF_DTable hufTable[HUF_DTABLE_SIZE(HufLog)]; /* can accommodate HUF_decompress4X */ - U64 workspace[HUF_DECOMPRESS_WORKSPACE_SIZE_U32 / 2]; - U32 rep[ZSTD_REP_NUM]; -} ZSTD_entropyTables_t; - -struct ZSTD_DCtx_s { - const FSE_DTable *LLTptr; - const FSE_DTable *MLTptr; - const FSE_DTable *OFTptr; - const HUF_DTable *HUFptr; - ZSTD_entropyTables_t entropy; - const void *previousDstEnd; /* detect continuity */ - const void *base; /* start of curr segment */ - const void *vBase; /* virtual start of previous segment if it was just before curr one */ - const void *dictEnd; /* end of previous segment */ - size_t expected; - ZSTD_frameParams fParams; - blockType_e bType; /* used in ZSTD_decompressContinue(), to transfer blockType between header decoding and block decoding stages */ - ZSTD_dStage stage; - U32 litEntropy; - U32 fseEntropy; - struct xxh64_state xxhState; - size_t headerSize; - U32 dictID; - const BYTE *litPtr; - ZSTD_customMem customMem; - size_t litSize; - size_t rleSize; - BYTE litBuffer[ZSTD_BLOCKSIZE_ABSOLUTEMAX + WILDCOPY_OVERLENGTH]; - BYTE headerBuffer[ZSTD_FRAMEHEADERSIZE_MAX]; -}; /* typedef'd to ZSTD_DCtx within "zstd.h" */ - -size_t ZSTD_DCtxWorkspaceBound(void) { return ZSTD_ALIGN(sizeof(ZSTD_stack)) + ZSTD_ALIGN(sizeof(ZSTD_DCtx)); } - -size_t ZSTD_decompressBegin(ZSTD_DCtx *dctx) -{ - dctx->expected = ZSTD_frameHeaderSize_prefix; - dctx->stage = ZSTDds_getFrameHeaderSize; - dctx->previousDstEnd = NULL; - dctx->base = NULL; - dctx->vBase = NULL; - dctx->dictEnd = NULL; - dctx->entropy.hufTable[0] = (HUF_DTable)((HufLog)*0x1000001); /* cover both little and big endian */ - dctx->litEntropy = dctx->fseEntropy = 0; - dctx->dictID = 0; - ZSTD_STATIC_ASSERT(sizeof(dctx->entropy.rep) == sizeof(repStartValue)); - memcpy(dctx->entropy.rep, repStartValue, sizeof(repStartValue)); /* initial repcodes */ - dctx->LLTptr = dctx->entropy.LLTable; - dctx->MLTptr = dctx->entropy.MLTable; - dctx->OFTptr = dctx->entropy.OFTable; - dctx->HUFptr = dctx->entropy.hufTable; - return 0; -} - -ZSTD_DCtx *ZSTD_createDCtx_advanced(ZSTD_customMem customMem) -{ - ZSTD_DCtx *dctx; - - if (!customMem.customAlloc || !customMem.customFree) - return NULL; - - dctx = (ZSTD_DCtx *)ZSTD_malloc(sizeof(ZSTD_DCtx), customMem); - if (!dctx) - return NULL; - memcpy(&dctx->customMem, &customMem, sizeof(customMem)); - ZSTD_decompressBegin(dctx); - return dctx; -} - -ZSTD_DCtx *ZSTD_initDCtx(void *workspace, size_t workspaceSize) -{ - ZSTD_customMem const stackMem = ZSTD_initStack(workspace, workspaceSize); - return ZSTD_createDCtx_advanced(stackMem); -} - -size_t ZSTD_freeDCtx(ZSTD_DCtx *dctx) -{ - if (dctx == NULL) - return 0; /* support free on NULL */ - ZSTD_free(dctx, dctx->customMem); - return 0; /* reserved as a potential error code in the future */ -} - -void ZSTD_copyDCtx(ZSTD_DCtx *dstDCtx, const ZSTD_DCtx *srcDCtx) -{ - size_t const workSpaceSize = (ZSTD_BLOCKSIZE_ABSOLUTEMAX + WILDCOPY_OVERLENGTH) + ZSTD_frameHeaderSize_max; - memcpy(dstDCtx, srcDCtx, sizeof(ZSTD_DCtx) - workSpaceSize); /* no need to copy workspace */ -} - -static void ZSTD_refDDict(ZSTD_DCtx *dstDCtx, const ZSTD_DDict *ddict); - -/*-************************************************************* -* Decompression section -***************************************************************/ - -/*! ZSTD_isFrame() : - * Tells if the content of `buffer` starts with a valid Frame Identifier. - * Note : Frame Identifier is 4 bytes. If `size < 4`, @return will always be 0. - * Note 2 : Legacy Frame Identifiers are considered valid only if Legacy Support is enabled. - * Note 3 : Skippable Frame Identifiers are considered valid. */ -unsigned ZSTD_isFrame(const void *buffer, size_t size) -{ - if (size < 4) - return 0; - { - U32 const magic = ZSTD_readLE32(buffer); - if (magic == ZSTD_MAGICNUMBER) - return 1; - if ((magic & 0xFFFFFFF0U) == ZSTD_MAGIC_SKIPPABLE_START) - return 1; - } - return 0; -} - -/** ZSTD_frameHeaderSize() : -* srcSize must be >= ZSTD_frameHeaderSize_prefix. -* @return : size of the Frame Header */ -static size_t ZSTD_frameHeaderSize(const void *src, size_t srcSize) -{ - if (srcSize < ZSTD_frameHeaderSize_prefix) - return ERROR(srcSize_wrong); - { - BYTE const fhd = ((const BYTE *)src)[4]; - U32 const dictID = fhd & 3; - U32 const singleSegment = (fhd >> 5) & 1; - U32 const fcsId = fhd >> 6; - return ZSTD_frameHeaderSize_prefix + !singleSegment + ZSTD_did_fieldSize[dictID] + ZSTD_fcs_fieldSize[fcsId] + (singleSegment && !fcsId); - } -} - -/** ZSTD_getFrameParams() : -* decode Frame Header, or require larger `srcSize`. -* @return : 0, `fparamsPtr` is correctly filled, -* >0, `srcSize` is too small, result is expected `srcSize`, -* or an error code, which can be tested using ZSTD_isError() */ -size_t ZSTD_getFrameParams(ZSTD_frameParams *fparamsPtr, const void *src, size_t srcSize) -{ - const BYTE *ip = (const BYTE *)src; - - if (srcSize < ZSTD_frameHeaderSize_prefix) - return ZSTD_frameHeaderSize_prefix; - if (ZSTD_readLE32(src) != ZSTD_MAGICNUMBER) { - if ((ZSTD_readLE32(src) & 0xFFFFFFF0U) == ZSTD_MAGIC_SKIPPABLE_START) { - if (srcSize < ZSTD_skippableHeaderSize) - return ZSTD_skippableHeaderSize; /* magic number + skippable frame length */ - memset(fparamsPtr, 0, sizeof(*fparamsPtr)); - fparamsPtr->frameContentSize = ZSTD_readLE32((const char *)src + 4); - fparamsPtr->windowSize = 0; /* windowSize==0 means a frame is skippable */ - return 0; - } - return ERROR(prefix_unknown); - } - - /* ensure there is enough `srcSize` to fully read/decode frame header */ - { - size_t const fhsize = ZSTD_frameHeaderSize(src, srcSize); - if (srcSize < fhsize) - return fhsize; - } - - { - BYTE const fhdByte = ip[4]; - size_t pos = 5; - U32 const dictIDSizeCode = fhdByte & 3; - U32 const checksumFlag = (fhdByte >> 2) & 1; - U32 const singleSegment = (fhdByte >> 5) & 1; - U32 const fcsID = fhdByte >> 6; - U32 const windowSizeMax = 1U << ZSTD_WINDOWLOG_MAX; - U32 windowSize = 0; - U32 dictID = 0; - U64 frameContentSize = 0; - if ((fhdByte & 0x08) != 0) - return ERROR(frameParameter_unsupported); /* reserved bits, which must be zero */ - if (!singleSegment) { - BYTE const wlByte = ip[pos++]; - U32 const windowLog = (wlByte >> 3) + ZSTD_WINDOWLOG_ABSOLUTEMIN; - if (windowLog > ZSTD_WINDOWLOG_MAX) - return ERROR(frameParameter_windowTooLarge); /* avoids issue with 1 << windowLog */ - windowSize = (1U << windowLog); - windowSize += (windowSize >> 3) * (wlByte & 7); - } - - switch (dictIDSizeCode) { - default: /* impossible */ - case 0: break; - case 1: - dictID = ip[pos]; - pos++; - break; - case 2: - dictID = ZSTD_readLE16(ip + pos); - pos += 2; - break; - case 3: - dictID = ZSTD_readLE32(ip + pos); - pos += 4; - break; - } - switch (fcsID) { - default: /* impossible */ - case 0: - if (singleSegment) - frameContentSize = ip[pos]; - break; - case 1: frameContentSize = ZSTD_readLE16(ip + pos) + 256; break; - case 2: frameContentSize = ZSTD_readLE32(ip + pos); break; - case 3: frameContentSize = ZSTD_readLE64(ip + pos); break; - } - if (!windowSize) - windowSize = (U32)frameContentSize; - if (windowSize > windowSizeMax) - return ERROR(frameParameter_windowTooLarge); - fparamsPtr->frameContentSize = frameContentSize; - fparamsPtr->windowSize = windowSize; - fparamsPtr->dictID = dictID; - fparamsPtr->checksumFlag = checksumFlag; - } - return 0; -} - -/** ZSTD_getFrameContentSize() : -* compatible with legacy mode -* @return : decompressed size of the single frame pointed to be `src` if known, otherwise -* - ZSTD_CONTENTSIZE_UNKNOWN if the size cannot be determined -* - ZSTD_CONTENTSIZE_ERROR if an error occurred (e.g. invalid magic number, srcSize too small) */ -unsigned long long ZSTD_getFrameContentSize(const void *src, size_t srcSize) -{ - { - ZSTD_frameParams fParams; - if (ZSTD_getFrameParams(&fParams, src, srcSize) != 0) - return ZSTD_CONTENTSIZE_ERROR; - if (fParams.windowSize == 0) { - /* Either skippable or empty frame, size == 0 either way */ - return 0; - } else if (fParams.frameContentSize != 0) { - return fParams.frameContentSize; - } else { - return ZSTD_CONTENTSIZE_UNKNOWN; - } - } -} - -/** ZSTD_findDecompressedSize() : - * compatible with legacy mode - * `srcSize` must be the exact length of some number of ZSTD compressed and/or - * skippable frames - * Return: decompressed size of the frames contained */ -unsigned long long ZSTD_findDecompressedSize(const void *src, size_t srcSize) -{ - { - unsigned long long totalDstSize = 0; - while (srcSize >= ZSTD_frameHeaderSize_prefix) { - const U32 magicNumber = ZSTD_readLE32(src); - - if ((magicNumber & 0xFFFFFFF0U) == ZSTD_MAGIC_SKIPPABLE_START) { - size_t skippableSize; - if (srcSize < ZSTD_skippableHeaderSize) - return ERROR(srcSize_wrong); - skippableSize = ZSTD_readLE32((const BYTE *)src + 4) + ZSTD_skippableHeaderSize; - if (srcSize < skippableSize) { - return ZSTD_CONTENTSIZE_ERROR; - } - - src = (const BYTE *)src + skippableSize; - srcSize -= skippableSize; - continue; - } - - { - unsigned long long const ret = ZSTD_getFrameContentSize(src, srcSize); - if (ret >= ZSTD_CONTENTSIZE_ERROR) - return ret; - - /* check for overflow */ - if (totalDstSize + ret < totalDstSize) - return ZSTD_CONTENTSIZE_ERROR; - totalDstSize += ret; - } - { - size_t const frameSrcSize = ZSTD_findFrameCompressedSize(src, srcSize); - if (ZSTD_isError(frameSrcSize)) { - return ZSTD_CONTENTSIZE_ERROR; - } - - src = (const BYTE *)src + frameSrcSize; - srcSize -= frameSrcSize; - } - } - - if (srcSize) { - return ZSTD_CONTENTSIZE_ERROR; - } - - return totalDstSize; - } -} - -/** ZSTD_decodeFrameHeader() : -* `headerSize` must be the size provided by ZSTD_frameHeaderSize(). -* @return : 0 if success, or an error code, which can be tested using ZSTD_isError() */ -static size_t ZSTD_decodeFrameHeader(ZSTD_DCtx *dctx, const void *src, size_t headerSize) -{ - size_t const result = ZSTD_getFrameParams(&(dctx->fParams), src, headerSize); - if (ZSTD_isError(result)) - return result; /* invalid header */ - if (result > 0) - return ERROR(srcSize_wrong); /* headerSize too small */ - if (dctx->fParams.dictID && (dctx->dictID != dctx->fParams.dictID)) - return ERROR(dictionary_wrong); - if (dctx->fParams.checksumFlag) - xxh64_reset(&dctx->xxhState, 0); - return 0; -} - -typedef struct { - blockType_e blockType; - U32 lastBlock; - U32 origSize; -} blockProperties_t; - -/*! ZSTD_getcBlockSize() : -* Provides the size of compressed block from block header `src` */ -size_t ZSTD_getcBlockSize(const void *src, size_t srcSize, blockProperties_t *bpPtr) -{ - if (srcSize < ZSTD_blockHeaderSize) - return ERROR(srcSize_wrong); - { - U32 const cBlockHeader = ZSTD_readLE24(src); - U32 const cSize = cBlockHeader >> 3; - bpPtr->lastBlock = cBlockHeader & 1; - bpPtr->blockType = (blockType_e)((cBlockHeader >> 1) & 3); - bpPtr->origSize = cSize; /* only useful for RLE */ - if (bpPtr->blockType == bt_rle) - return 1; - if (bpPtr->blockType == bt_reserved) - return ERROR(corruption_detected); - return cSize; - } -} - -static size_t ZSTD_copyRawBlock(void *dst, size_t dstCapacity, const void *src, size_t srcSize) -{ - if (srcSize > dstCapacity) - return ERROR(dstSize_tooSmall); - memcpy(dst, src, srcSize); - return srcSize; -} - -static size_t ZSTD_setRleBlock(void *dst, size_t dstCapacity, const void *src, size_t srcSize, size_t regenSize) -{ - if (srcSize != 1) - return ERROR(srcSize_wrong); - if (regenSize > dstCapacity) - return ERROR(dstSize_tooSmall); - memset(dst, *(const BYTE *)src, regenSize); - return regenSize; -} - -/*! ZSTD_decodeLiteralsBlock() : - @return : nb of bytes read from src (< srcSize ) */ -size_t ZSTD_decodeLiteralsBlock(ZSTD_DCtx *dctx, const void *src, size_t srcSize) /* note : srcSize < BLOCKSIZE */ -{ - if (srcSize < MIN_CBLOCK_SIZE) - return ERROR(corruption_detected); - - { - const BYTE *const istart = (const BYTE *)src; - symbolEncodingType_e const litEncType = (symbolEncodingType_e)(istart[0] & 3); - - switch (litEncType) { - case set_repeat: - if (dctx->litEntropy == 0) - return ERROR(dictionary_corrupted); - /* fall-through */ - case set_compressed: - if (srcSize < 5) - return ERROR(corruption_detected); /* srcSize >= MIN_CBLOCK_SIZE == 3; here we need up to 5 for case 3 */ - { - size_t lhSize, litSize, litCSize; - U32 singleStream = 0; - U32 const lhlCode = (istart[0] >> 2) & 3; - U32 const lhc = ZSTD_readLE32(istart); - switch (lhlCode) { - case 0: - case 1: - default: /* note : default is impossible, since lhlCode into [0..3] */ - /* 2 - 2 - 10 - 10 */ - singleStream = !lhlCode; - lhSize = 3; - litSize = (lhc >> 4) & 0x3FF; - litCSize = (lhc >> 14) & 0x3FF; - break; - case 2: - /* 2 - 2 - 14 - 14 */ - lhSize = 4; - litSize = (lhc >> 4) & 0x3FFF; - litCSize = lhc >> 18; - break; - case 3: - /* 2 - 2 - 18 - 18 */ - lhSize = 5; - litSize = (lhc >> 4) & 0x3FFFF; - litCSize = (lhc >> 22) + (istart[4] << 10); - break; - } - if (litSize > ZSTD_BLOCKSIZE_ABSOLUTEMAX) - return ERROR(corruption_detected); - if (litCSize + lhSize > srcSize) - return ERROR(corruption_detected); - - if (HUF_isError( - (litEncType == set_repeat) - ? (singleStream ? HUF_decompress1X_usingDTable(dctx->litBuffer, litSize, istart + lhSize, litCSize, dctx->HUFptr) - : HUF_decompress4X_usingDTable(dctx->litBuffer, litSize, istart + lhSize, litCSize, dctx->HUFptr)) - : (singleStream - ? HUF_decompress1X2_DCtx_wksp(dctx->entropy.hufTable, dctx->litBuffer, litSize, istart + lhSize, litCSize, - dctx->entropy.workspace, sizeof(dctx->entropy.workspace)) - : HUF_decompress4X_hufOnly_wksp(dctx->entropy.hufTable, dctx->litBuffer, litSize, istart + lhSize, litCSize, - dctx->entropy.workspace, sizeof(dctx->entropy.workspace))))) - return ERROR(corruption_detected); - - dctx->litPtr = dctx->litBuffer; - dctx->litSize = litSize; - dctx->litEntropy = 1; - if (litEncType == set_compressed) - dctx->HUFptr = dctx->entropy.hufTable; - memset(dctx->litBuffer + dctx->litSize, 0, WILDCOPY_OVERLENGTH); - return litCSize + lhSize; - } - - case set_basic: { - size_t litSize, lhSize; - U32 const lhlCode = ((istart[0]) >> 2) & 3; - switch (lhlCode) { - case 0: - case 2: - default: /* note : default is impossible, since lhlCode into [0..3] */ - lhSize = 1; - litSize = istart[0] >> 3; - break; - case 1: - lhSize = 2; - litSize = ZSTD_readLE16(istart) >> 4; - break; - case 3: - lhSize = 3; - litSize = ZSTD_readLE24(istart) >> 4; - break; - } - - if (lhSize + litSize + WILDCOPY_OVERLENGTH > srcSize) { /* risk reading beyond src buffer with wildcopy */ - if (litSize + lhSize > srcSize) - return ERROR(corruption_detected); - memcpy(dctx->litBuffer, istart + lhSize, litSize); - dctx->litPtr = dctx->litBuffer; - dctx->litSize = litSize; - memset(dctx->litBuffer + dctx->litSize, 0, WILDCOPY_OVERLENGTH); - return lhSize + litSize; - } - /* direct reference into compressed stream */ - dctx->litPtr = istart + lhSize; - dctx->litSize = litSize; - return lhSize + litSize; - } - - case set_rle: { - U32 const lhlCode = ((istart[0]) >> 2) & 3; - size_t litSize, lhSize; - switch (lhlCode) { - case 0: - case 2: - default: /* note : default is impossible, since lhlCode into [0..3] */ - lhSize = 1; - litSize = istart[0] >> 3; - break; - case 1: - lhSize = 2; - litSize = ZSTD_readLE16(istart) >> 4; - break; - case 3: - lhSize = 3; - litSize = ZSTD_readLE24(istart) >> 4; - if (srcSize < 4) - return ERROR(corruption_detected); /* srcSize >= MIN_CBLOCK_SIZE == 3; here we need lhSize+1 = 4 */ - break; - } - if (litSize > ZSTD_BLOCKSIZE_ABSOLUTEMAX) - return ERROR(corruption_detected); - memset(dctx->litBuffer, istart[lhSize], litSize + WILDCOPY_OVERLENGTH); - dctx->litPtr = dctx->litBuffer; - dctx->litSize = litSize; - return lhSize + 1; - } - default: - return ERROR(corruption_detected); /* impossible */ - } - } -} - -typedef union { - FSE_decode_t realData; - U32 alignedBy4; -} FSE_decode_t4; - -static const FSE_decode_t4 LL_defaultDTable[(1 << LL_DEFAULTNORMLOG) + 1] = { - {{LL_DEFAULTNORMLOG, 1, 1}}, /* header : tableLog, fastMode, fastMode */ - {{0, 0, 4}}, /* 0 : base, symbol, bits */ - {{16, 0, 4}}, - {{32, 1, 5}}, - {{0, 3, 5}}, - {{0, 4, 5}}, - {{0, 6, 5}}, - {{0, 7, 5}}, - {{0, 9, 5}}, - {{0, 10, 5}}, - {{0, 12, 5}}, - {{0, 14, 6}}, - {{0, 16, 5}}, - {{0, 18, 5}}, - {{0, 19, 5}}, - {{0, 21, 5}}, - {{0, 22, 5}}, - {{0, 24, 5}}, - {{32, 25, 5}}, - {{0, 26, 5}}, - {{0, 27, 6}}, - {{0, 29, 6}}, - {{0, 31, 6}}, - {{32, 0, 4}}, - {{0, 1, 4}}, - {{0, 2, 5}}, - {{32, 4, 5}}, - {{0, 5, 5}}, - {{32, 7, 5}}, - {{0, 8, 5}}, - {{32, 10, 5}}, - {{0, 11, 5}}, - {{0, 13, 6}}, - {{32, 16, 5}}, - {{0, 17, 5}}, - {{32, 19, 5}}, - {{0, 20, 5}}, - {{32, 22, 5}}, - {{0, 23, 5}}, - {{0, 25, 4}}, - {{16, 25, 4}}, - {{32, 26, 5}}, - {{0, 28, 6}}, - {{0, 30, 6}}, - {{48, 0, 4}}, - {{16, 1, 4}}, - {{32, 2, 5}}, - {{32, 3, 5}}, - {{32, 5, 5}}, - {{32, 6, 5}}, - {{32, 8, 5}}, - {{32, 9, 5}}, - {{32, 11, 5}}, - {{32, 12, 5}}, - {{0, 15, 6}}, - {{32, 17, 5}}, - {{32, 18, 5}}, - {{32, 20, 5}}, - {{32, 21, 5}}, - {{32, 23, 5}}, - {{32, 24, 5}}, - {{0, 35, 6}}, - {{0, 34, 6}}, - {{0, 33, 6}}, - {{0, 32, 6}}, -}; /* LL_defaultDTable */ - -static const FSE_decode_t4 ML_defaultDTable[(1 << ML_DEFAULTNORMLOG) + 1] = { - {{ML_DEFAULTNORMLOG, 1, 1}}, /* header : tableLog, fastMode, fastMode */ - {{0, 0, 6}}, /* 0 : base, symbol, bits */ - {{0, 1, 4}}, - {{32, 2, 5}}, - {{0, 3, 5}}, - {{0, 5, 5}}, - {{0, 6, 5}}, - {{0, 8, 5}}, - {{0, 10, 6}}, - {{0, 13, 6}}, - {{0, 16, 6}}, - {{0, 19, 6}}, - {{0, 22, 6}}, - {{0, 25, 6}}, - {{0, 28, 6}}, - {{0, 31, 6}}, - {{0, 33, 6}}, - {{0, 35, 6}}, - {{0, 37, 6}}, - {{0, 39, 6}}, - {{0, 41, 6}}, - {{0, 43, 6}}, - {{0, 45, 6}}, - {{16, 1, 4}}, - {{0, 2, 4}}, - {{32, 3, 5}}, - {{0, 4, 5}}, - {{32, 6, 5}}, - {{0, 7, 5}}, - {{0, 9, 6}}, - {{0, 12, 6}}, - {{0, 15, 6}}, - {{0, 18, 6}}, - {{0, 21, 6}}, - {{0, 24, 6}}, - {{0, 27, 6}}, - {{0, 30, 6}}, - {{0, 32, 6}}, - {{0, 34, 6}}, - {{0, 36, 6}}, - {{0, 38, 6}}, - {{0, 40, 6}}, - {{0, 42, 6}}, - {{0, 44, 6}}, - {{32, 1, 4}}, - {{48, 1, 4}}, - {{16, 2, 4}}, - {{32, 4, 5}}, - {{32, 5, 5}}, - {{32, 7, 5}}, - {{32, 8, 5}}, - {{0, 11, 6}}, - {{0, 14, 6}}, - {{0, 17, 6}}, - {{0, 20, 6}}, - {{0, 23, 6}}, - {{0, 26, 6}}, - {{0, 29, 6}}, - {{0, 52, 6}}, - {{0, 51, 6}}, - {{0, 50, 6}}, - {{0, 49, 6}}, - {{0, 48, 6}}, - {{0, 47, 6}}, - {{0, 46, 6}}, -}; /* ML_defaultDTable */ - -static const FSE_decode_t4 OF_defaultDTable[(1 << OF_DEFAULTNORMLOG) + 1] = { - {{OF_DEFAULTNORMLOG, 1, 1}}, /* header : tableLog, fastMode, fastMode */ - {{0, 0, 5}}, /* 0 : base, symbol, bits */ - {{0, 6, 4}}, - {{0, 9, 5}}, - {{0, 15, 5}}, - {{0, 21, 5}}, - {{0, 3, 5}}, - {{0, 7, 4}}, - {{0, 12, 5}}, - {{0, 18, 5}}, - {{0, 23, 5}}, - {{0, 5, 5}}, - {{0, 8, 4}}, - {{0, 14, 5}}, - {{0, 20, 5}}, - {{0, 2, 5}}, - {{16, 7, 4}}, - {{0, 11, 5}}, - {{0, 17, 5}}, - {{0, 22, 5}}, - {{0, 4, 5}}, - {{16, 8, 4}}, - {{0, 13, 5}}, - {{0, 19, 5}}, - {{0, 1, 5}}, - {{16, 6, 4}}, - {{0, 10, 5}}, - {{0, 16, 5}}, - {{0, 28, 5}}, - {{0, 27, 5}}, - {{0, 26, 5}}, - {{0, 25, 5}}, - {{0, 24, 5}}, -}; /* OF_defaultDTable */ - -/*! ZSTD_buildSeqTable() : - @return : nb bytes read from src, - or an error code if it fails, testable with ZSTD_isError() -*/ -static size_t ZSTD_buildSeqTable(FSE_DTable *DTableSpace, const FSE_DTable **DTablePtr, symbolEncodingType_e type, U32 max, U32 maxLog, const void *src, - size_t srcSize, const FSE_decode_t4 *defaultTable, U32 flagRepeatTable, void *workspace, size_t workspaceSize) -{ - const void *const tmpPtr = defaultTable; /* bypass strict aliasing */ - switch (type) { - case set_rle: - if (!srcSize) - return ERROR(srcSize_wrong); - if ((*(const BYTE *)src) > max) - return ERROR(corruption_detected); - FSE_buildDTable_rle(DTableSpace, *(const BYTE *)src); - *DTablePtr = DTableSpace; - return 1; - case set_basic: *DTablePtr = (const FSE_DTable *)tmpPtr; return 0; - case set_repeat: - if (!flagRepeatTable) - return ERROR(corruption_detected); - return 0; - default: /* impossible */ - case set_compressed: { - U32 tableLog; - S16 *norm = (S16 *)workspace; - size_t const spaceUsed32 = ALIGN(sizeof(S16) * (MaxSeq + 1), sizeof(U32)) >> 2; - - if ((spaceUsed32 << 2) > workspaceSize) - return ERROR(GENERIC); - workspace = (U32 *)workspace + spaceUsed32; - workspaceSize -= (spaceUsed32 << 2); - { - size_t const headerSize = FSE_readNCount(norm, &max, &tableLog, src, srcSize); - if (FSE_isError(headerSize)) - return ERROR(corruption_detected); - if (tableLog > maxLog) - return ERROR(corruption_detected); - FSE_buildDTable_wksp(DTableSpace, norm, max, tableLog, workspace, workspaceSize); - *DTablePtr = DTableSpace; - return headerSize; - } - } - } -} - -size_t ZSTD_decodeSeqHeaders(ZSTD_DCtx *dctx, int *nbSeqPtr, const void *src, size_t srcSize) -{ - const BYTE *const istart = (const BYTE *const)src; - const BYTE *const iend = istart + srcSize; - const BYTE *ip = istart; - - /* check */ - if (srcSize < MIN_SEQUENCES_SIZE) - return ERROR(srcSize_wrong); - - /* SeqHead */ - { - int nbSeq = *ip++; - if (!nbSeq) { - *nbSeqPtr = 0; - return 1; - } - if (nbSeq > 0x7F) { - if (nbSeq == 0xFF) { - if (ip + 2 > iend) - return ERROR(srcSize_wrong); - nbSeq = ZSTD_readLE16(ip) + LONGNBSEQ, ip += 2; - } else { - if (ip >= iend) - return ERROR(srcSize_wrong); - nbSeq = ((nbSeq - 0x80) << 8) + *ip++; - } - } - *nbSeqPtr = nbSeq; - } - - /* FSE table descriptors */ - if (ip + 4 > iend) - return ERROR(srcSize_wrong); /* minimum possible size */ - { - symbolEncodingType_e const LLtype = (symbolEncodingType_e)(*ip >> 6); - symbolEncodingType_e const OFtype = (symbolEncodingType_e)((*ip >> 4) & 3); - symbolEncodingType_e const MLtype = (symbolEncodingType_e)((*ip >> 2) & 3); - ip++; - - /* Build DTables */ - { - size_t const llhSize = ZSTD_buildSeqTable(dctx->entropy.LLTable, &dctx->LLTptr, LLtype, MaxLL, LLFSELog, ip, iend - ip, - LL_defaultDTable, dctx->fseEntropy, dctx->entropy.workspace, sizeof(dctx->entropy.workspace)); - if (ZSTD_isError(llhSize)) - return ERROR(corruption_detected); - ip += llhSize; - } - { - size_t const ofhSize = ZSTD_buildSeqTable(dctx->entropy.OFTable, &dctx->OFTptr, OFtype, MaxOff, OffFSELog, ip, iend - ip, - OF_defaultDTable, dctx->fseEntropy, dctx->entropy.workspace, sizeof(dctx->entropy.workspace)); - if (ZSTD_isError(ofhSize)) - return ERROR(corruption_detected); - ip += ofhSize; - } - { - size_t const mlhSize = ZSTD_buildSeqTable(dctx->entropy.MLTable, &dctx->MLTptr, MLtype, MaxML, MLFSELog, ip, iend - ip, - ML_defaultDTable, dctx->fseEntropy, dctx->entropy.workspace, sizeof(dctx->entropy.workspace)); - if (ZSTD_isError(mlhSize)) - return ERROR(corruption_detected); - ip += mlhSize; - } - } - - return ip - istart; -} - -typedef struct { - size_t litLength; - size_t matchLength; - size_t offset; - const BYTE *match; -} seq_t; - -typedef struct { - BIT_DStream_t DStream; - FSE_DState_t stateLL; - FSE_DState_t stateOffb; - FSE_DState_t stateML; - size_t prevOffset[ZSTD_REP_NUM]; - const BYTE *base; - size_t pos; - uPtrDiff gotoDict; -} seqState_t; - -FORCE_NOINLINE -size_t ZSTD_execSequenceLast7(BYTE *op, BYTE *const oend, seq_t sequence, const BYTE **litPtr, const BYTE *const litLimit, const BYTE *const base, - const BYTE *const vBase, const BYTE *const dictEnd) -{ - BYTE *const oLitEnd = op + sequence.litLength; - size_t const sequenceLength = sequence.litLength + sequence.matchLength; - BYTE *const oMatchEnd = op + sequenceLength; /* risk : address space overflow (32-bits) */ - BYTE *const oend_w = oend - WILDCOPY_OVERLENGTH; - const BYTE *const iLitEnd = *litPtr + sequence.litLength; - const BYTE *match = oLitEnd - sequence.offset; - - /* check */ - if (oMatchEnd > oend) - return ERROR(dstSize_tooSmall); /* last match must start at a minimum distance of WILDCOPY_OVERLENGTH from oend */ - if (iLitEnd > litLimit) - return ERROR(corruption_detected); /* over-read beyond lit buffer */ - if (oLitEnd <= oend_w) - return ERROR(GENERIC); /* Precondition */ - - /* copy literals */ - if (op < oend_w) { - ZSTD_wildcopy(op, *litPtr, oend_w - op); - *litPtr += oend_w - op; - op = oend_w; - } - while (op < oLitEnd) - *op++ = *(*litPtr)++; - - /* copy Match */ - if (sequence.offset > (size_t)(oLitEnd - base)) { - /* offset beyond prefix */ - if (sequence.offset > (size_t)(oLitEnd - vBase)) - return ERROR(corruption_detected); - match = dictEnd - (base - match); - if (match + sequence.matchLength <= dictEnd) { - memmove(oLitEnd, match, sequence.matchLength); - return sequenceLength; - } - /* span extDict & currPrefixSegment */ - { - size_t const length1 = dictEnd - match; - memmove(oLitEnd, match, length1); - op = oLitEnd + length1; - sequence.matchLength -= length1; - match = base; - } - } - while (op < oMatchEnd) - *op++ = *match++; - return sequenceLength; -} - -static seq_t ZSTD_decodeSequence(seqState_t *seqState) -{ - seq_t seq; - - U32 const llCode = FSE_peekSymbol(&seqState->stateLL); - U32 const mlCode = FSE_peekSymbol(&seqState->stateML); - U32 const ofCode = FSE_peekSymbol(&seqState->stateOffb); /* <= maxOff, by table construction */ - - U32 const llBits = LL_bits[llCode]; - U32 const mlBits = ML_bits[mlCode]; - U32 const ofBits = ofCode; - U32 const totalBits = llBits + mlBits + ofBits; - - static const U32 LL_base[MaxLL + 1] = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 18, - 20, 22, 24, 28, 32, 40, 48, 64, 0x80, 0x100, 0x200, 0x400, 0x800, 0x1000, 0x2000, 0x4000, 0x8000, 0x10000}; - - static const U32 ML_base[MaxML + 1] = {3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, - 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 37, 39, 41, - 43, 47, 51, 59, 67, 83, 99, 0x83, 0x103, 0x203, 0x403, 0x803, 0x1003, 0x2003, 0x4003, 0x8003, 0x10003}; - - static const U32 OF_base[MaxOff + 1] = {0, 1, 1, 5, 0xD, 0x1D, 0x3D, 0x7D, 0xFD, 0x1FD, - 0x3FD, 0x7FD, 0xFFD, 0x1FFD, 0x3FFD, 0x7FFD, 0xFFFD, 0x1FFFD, 0x3FFFD, 0x7FFFD, - 0xFFFFD, 0x1FFFFD, 0x3FFFFD, 0x7FFFFD, 0xFFFFFD, 0x1FFFFFD, 0x3FFFFFD, 0x7FFFFFD, 0xFFFFFFD}; - - /* sequence */ - { - size_t offset; - if (!ofCode) - offset = 0; - else { - offset = OF_base[ofCode] + BIT_readBitsFast(&seqState->DStream, ofBits); /* <= (ZSTD_WINDOWLOG_MAX-1) bits */ - if (ZSTD_32bits()) - BIT_reloadDStream(&seqState->DStream); - } - - if (ofCode <= 1) { - offset += (llCode == 0); - if (offset) { - size_t temp = (offset == 3) ? seqState->prevOffset[0] - 1 : seqState->prevOffset[offset]; - temp += !temp; /* 0 is not valid; input is corrupted; force offset to 1 */ - if (offset != 1) - seqState->prevOffset[2] = seqState->prevOffset[1]; - seqState->prevOffset[1] = seqState->prevOffset[0]; - seqState->prevOffset[0] = offset = temp; - } else { - offset = seqState->prevOffset[0]; - } - } else { - seqState->prevOffset[2] = seqState->prevOffset[1]; - seqState->prevOffset[1] = seqState->prevOffset[0]; - seqState->prevOffset[0] = offset; - } - seq.offset = offset; - } - - seq.matchLength = ML_base[mlCode] + ((mlCode > 31) ? BIT_readBitsFast(&seqState->DStream, mlBits) : 0); /* <= 16 bits */ - if (ZSTD_32bits() && (mlBits + llBits > 24)) - BIT_reloadDStream(&seqState->DStream); - - seq.litLength = LL_base[llCode] + ((llCode > 15) ? BIT_readBitsFast(&seqState->DStream, llBits) : 0); /* <= 16 bits */ - if (ZSTD_32bits() || (totalBits > 64 - 7 - (LLFSELog + MLFSELog + OffFSELog))) - BIT_reloadDStream(&seqState->DStream); - - /* ANS state update */ - FSE_updateState(&seqState->stateLL, &seqState->DStream); /* <= 9 bits */ - FSE_updateState(&seqState->stateML, &seqState->DStream); /* <= 9 bits */ - if (ZSTD_32bits()) - BIT_reloadDStream(&seqState->DStream); /* <= 18 bits */ - FSE_updateState(&seqState->stateOffb, &seqState->DStream); /* <= 8 bits */ - - seq.match = NULL; - - return seq; -} - -FORCE_INLINE -size_t ZSTD_execSequence(BYTE *op, BYTE *const oend, seq_t sequence, const BYTE **litPtr, const BYTE *const litLimit, const BYTE *const base, - const BYTE *const vBase, const BYTE *const dictEnd) -{ - BYTE *const oLitEnd = op + sequence.litLength; - size_t const sequenceLength = sequence.litLength + sequence.matchLength; - BYTE *const oMatchEnd = op + sequenceLength; /* risk : address space overflow (32-bits) */ - BYTE *const oend_w = oend - WILDCOPY_OVERLENGTH; - const BYTE *const iLitEnd = *litPtr + sequence.litLength; - const BYTE *match = oLitEnd - sequence.offset; - - /* check */ - if (oMatchEnd > oend) - return ERROR(dstSize_tooSmall); /* last match must start at a minimum distance of WILDCOPY_OVERLENGTH from oend */ - if (iLitEnd > litLimit) - return ERROR(corruption_detected); /* over-read beyond lit buffer */ - if (oLitEnd > oend_w) - return ZSTD_execSequenceLast7(op, oend, sequence, litPtr, litLimit, base, vBase, dictEnd); - - /* copy Literals */ - ZSTD_copy8(op, *litPtr); - if (sequence.litLength > 8) - ZSTD_wildcopy(op + 8, (*litPtr) + 8, - sequence.litLength - 8); /* note : since oLitEnd <= oend-WILDCOPY_OVERLENGTH, no risk of overwrite beyond oend */ - op = oLitEnd; - *litPtr = iLitEnd; /* update for next sequence */ - - /* copy Match */ - if (sequence.offset > (size_t)(oLitEnd - base)) { - /* offset beyond prefix */ - if (sequence.offset > (size_t)(oLitEnd - vBase)) - return ERROR(corruption_detected); - match = dictEnd + (match - base); - if (match + sequence.matchLength <= dictEnd) { - memmove(oLitEnd, match, sequence.matchLength); - return sequenceLength; - } - /* span extDict & currPrefixSegment */ - { - size_t const length1 = dictEnd - match; - memmove(oLitEnd, match, length1); - op = oLitEnd + length1; - sequence.matchLength -= length1; - match = base; - if (op > oend_w || sequence.matchLength < MINMATCH) { - U32 i; - for (i = 0; i < sequence.matchLength; ++i) - op[i] = match[i]; - return sequenceLength; - } - } - } - /* Requirement: op <= oend_w && sequence.matchLength >= MINMATCH */ - - /* match within prefix */ - if (sequence.offset < 8) { - /* close range match, overlap */ - static const U32 dec32table[] = {0, 1, 2, 1, 4, 4, 4, 4}; /* added */ - static const int dec64table[] = {8, 8, 8, 7, 8, 9, 10, 11}; /* subtracted */ - int const sub2 = dec64table[sequence.offset]; - op[0] = match[0]; - op[1] = match[1]; - op[2] = match[2]; - op[3] = match[3]; - match += dec32table[sequence.offset]; - ZSTD_copy4(op + 4, match); - match -= sub2; - } else { - ZSTD_copy8(op, match); - } - op += 8; - match += 8; - - if (oMatchEnd > oend - (16 - MINMATCH)) { - if (op < oend_w) { - ZSTD_wildcopy(op, match, oend_w - op); - match += oend_w - op; - op = oend_w; - } - while (op < oMatchEnd) - *op++ = *match++; - } else { - ZSTD_wildcopy(op, match, (ptrdiff_t)sequence.matchLength - 8); /* works even if matchLength < 8 */ - } - return sequenceLength; -} - -static size_t ZSTD_decompressSequences(ZSTD_DCtx *dctx, void *dst, size_t maxDstSize, const void *seqStart, size_t seqSize) -{ - const BYTE *ip = (const BYTE *)seqStart; - const BYTE *const iend = ip + seqSize; - BYTE *const ostart = (BYTE * const)dst; - BYTE *const oend = ostart + maxDstSize; - BYTE *op = ostart; - const BYTE *litPtr = dctx->litPtr; - const BYTE *const litEnd = litPtr + dctx->litSize; - const BYTE *const base = (const BYTE *)(dctx->base); - const BYTE *const vBase = (const BYTE *)(dctx->vBase); - const BYTE *const dictEnd = (const BYTE *)(dctx->dictEnd); - int nbSeq; - - /* Build Decoding Tables */ - { - size_t const seqHSize = ZSTD_decodeSeqHeaders(dctx, &nbSeq, ip, seqSize); - if (ZSTD_isError(seqHSize)) - return seqHSize; - ip += seqHSize; - } - - /* Regen sequences */ - if (nbSeq) { - seqState_t seqState; - dctx->fseEntropy = 1; - { - U32 i; - for (i = 0; i < ZSTD_REP_NUM; i++) - seqState.prevOffset[i] = dctx->entropy.rep[i]; - } - CHECK_E(BIT_initDStream(&seqState.DStream, ip, iend - ip), corruption_detected); - FSE_initDState(&seqState.stateLL, &seqState.DStream, dctx->LLTptr); - FSE_initDState(&seqState.stateOffb, &seqState.DStream, dctx->OFTptr); - FSE_initDState(&seqState.stateML, &seqState.DStream, dctx->MLTptr); - - for (; (BIT_reloadDStream(&(seqState.DStream)) <= BIT_DStream_completed) && nbSeq;) { - nbSeq--; - { - seq_t const sequence = ZSTD_decodeSequence(&seqState); - size_t const oneSeqSize = ZSTD_execSequence(op, oend, sequence, &litPtr, litEnd, base, vBase, dictEnd); - if (ZSTD_isError(oneSeqSize)) - return oneSeqSize; - op += oneSeqSize; - } - } - - /* check if reached exact end */ - if (nbSeq) - return ERROR(corruption_detected); - /* save reps for next block */ - { - U32 i; - for (i = 0; i < ZSTD_REP_NUM; i++) - dctx->entropy.rep[i] = (U32)(seqState.prevOffset[i]); - } - } - - /* last literal segment */ - { - size_t const lastLLSize = litEnd - litPtr; - if (lastLLSize > (size_t)(oend - op)) - return ERROR(dstSize_tooSmall); - memcpy(op, litPtr, lastLLSize); - op += lastLLSize; - } - - return op - ostart; -} - -FORCE_INLINE seq_t ZSTD_decodeSequenceLong_generic(seqState_t *seqState, int const longOffsets) -{ - seq_t seq; - - U32 const llCode = FSE_peekSymbol(&seqState->stateLL); - U32 const mlCode = FSE_peekSymbol(&seqState->stateML); - U32 const ofCode = FSE_peekSymbol(&seqState->stateOffb); /* <= maxOff, by table construction */ - - U32 const llBits = LL_bits[llCode]; - U32 const mlBits = ML_bits[mlCode]; - U32 const ofBits = ofCode; - U32 const totalBits = llBits + mlBits + ofBits; - - static const U32 LL_base[MaxLL + 1] = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 18, - 20, 22, 24, 28, 32, 40, 48, 64, 0x80, 0x100, 0x200, 0x400, 0x800, 0x1000, 0x2000, 0x4000, 0x8000, 0x10000}; - - static const U32 ML_base[MaxML + 1] = {3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, - 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 37, 39, 41, - 43, 47, 51, 59, 67, 83, 99, 0x83, 0x103, 0x203, 0x403, 0x803, 0x1003, 0x2003, 0x4003, 0x8003, 0x10003}; - - static const U32 OF_base[MaxOff + 1] = {0, 1, 1, 5, 0xD, 0x1D, 0x3D, 0x7D, 0xFD, 0x1FD, - 0x3FD, 0x7FD, 0xFFD, 0x1FFD, 0x3FFD, 0x7FFD, 0xFFFD, 0x1FFFD, 0x3FFFD, 0x7FFFD, - 0xFFFFD, 0x1FFFFD, 0x3FFFFD, 0x7FFFFD, 0xFFFFFD, 0x1FFFFFD, 0x3FFFFFD, 0x7FFFFFD, 0xFFFFFFD}; - - /* sequence */ - { - size_t offset; - if (!ofCode) - offset = 0; - else { - if (longOffsets) { - int const extraBits = ofBits - MIN(ofBits, STREAM_ACCUMULATOR_MIN); - offset = OF_base[ofCode] + (BIT_readBitsFast(&seqState->DStream, ofBits - extraBits) << extraBits); - if (ZSTD_32bits() || extraBits) - BIT_reloadDStream(&seqState->DStream); - if (extraBits) - offset += BIT_readBitsFast(&seqState->DStream, extraBits); - } else { - offset = OF_base[ofCode] + BIT_readBitsFast(&seqState->DStream, ofBits); /* <= (ZSTD_WINDOWLOG_MAX-1) bits */ - if (ZSTD_32bits()) - BIT_reloadDStream(&seqState->DStream); - } - } - - if (ofCode <= 1) { - offset += (llCode == 0); - if (offset) { - size_t temp = (offset == 3) ? seqState->prevOffset[0] - 1 : seqState->prevOffset[offset]; - temp += !temp; /* 0 is not valid; input is corrupted; force offset to 1 */ - if (offset != 1) - seqState->prevOffset[2] = seqState->prevOffset[1]; - seqState->prevOffset[1] = seqState->prevOffset[0]; - seqState->prevOffset[0] = offset = temp; - } else { - offset = seqState->prevOffset[0]; - } - } else { - seqState->prevOffset[2] = seqState->prevOffset[1]; - seqState->prevOffset[1] = seqState->prevOffset[0]; - seqState->prevOffset[0] = offset; - } - seq.offset = offset; - } - - seq.matchLength = ML_base[mlCode] + ((mlCode > 31) ? BIT_readBitsFast(&seqState->DStream, mlBits) : 0); /* <= 16 bits */ - if (ZSTD_32bits() && (mlBits + llBits > 24)) - BIT_reloadDStream(&seqState->DStream); - - seq.litLength = LL_base[llCode] + ((llCode > 15) ? BIT_readBitsFast(&seqState->DStream, llBits) : 0); /* <= 16 bits */ - if (ZSTD_32bits() || (totalBits > 64 - 7 - (LLFSELog + MLFSELog + OffFSELog))) - BIT_reloadDStream(&seqState->DStream); - - { - size_t const pos = seqState->pos + seq.litLength; - seq.match = seqState->base + pos - seq.offset; /* single memory segment */ - if (seq.offset > pos) - seq.match += seqState->gotoDict; /* separate memory segment */ - seqState->pos = pos + seq.matchLength; - } - - /* ANS state update */ - FSE_updateState(&seqState->stateLL, &seqState->DStream); /* <= 9 bits */ - FSE_updateState(&seqState->stateML, &seqState->DStream); /* <= 9 bits */ - if (ZSTD_32bits()) - BIT_reloadDStream(&seqState->DStream); /* <= 18 bits */ - FSE_updateState(&seqState->stateOffb, &seqState->DStream); /* <= 8 bits */ - - return seq; -} - -static seq_t ZSTD_decodeSequenceLong(seqState_t *seqState, unsigned const windowSize) -{ - if (ZSTD_highbit32(windowSize) > STREAM_ACCUMULATOR_MIN) { - return ZSTD_decodeSequenceLong_generic(seqState, 1); - } else { - return ZSTD_decodeSequenceLong_generic(seqState, 0); - } -} - -FORCE_INLINE -size_t ZSTD_execSequenceLong(BYTE *op, BYTE *const oend, seq_t sequence, const BYTE **litPtr, const BYTE *const litLimit, const BYTE *const base, - const BYTE *const vBase, const BYTE *const dictEnd) -{ - BYTE *const oLitEnd = op + sequence.litLength; - size_t const sequenceLength = sequence.litLength + sequence.matchLength; - BYTE *const oMatchEnd = op + sequenceLength; /* risk : address space overflow (32-bits) */ - BYTE *const oend_w = oend - WILDCOPY_OVERLENGTH; - const BYTE *const iLitEnd = *litPtr + sequence.litLength; - const BYTE *match = sequence.match; - - /* check */ - if (oMatchEnd > oend) - return ERROR(dstSize_tooSmall); /* last match must start at a minimum distance of WILDCOPY_OVERLENGTH from oend */ - if (iLitEnd > litLimit) - return ERROR(corruption_detected); /* over-read beyond lit buffer */ - if (oLitEnd > oend_w) - return ZSTD_execSequenceLast7(op, oend, sequence, litPtr, litLimit, base, vBase, dictEnd); - - /* copy Literals */ - ZSTD_copy8(op, *litPtr); - if (sequence.litLength > 8) - ZSTD_wildcopy(op + 8, (*litPtr) + 8, - sequence.litLength - 8); /* note : since oLitEnd <= oend-WILDCOPY_OVERLENGTH, no risk of overwrite beyond oend */ - op = oLitEnd; - *litPtr = iLitEnd; /* update for next sequence */ - - /* copy Match */ - if (sequence.offset > (size_t)(oLitEnd - base)) { - /* offset beyond prefix */ - if (sequence.offset > (size_t)(oLitEnd - vBase)) - return ERROR(corruption_detected); - if (match + sequence.matchLength <= dictEnd) { - memmove(oLitEnd, match, sequence.matchLength); - return sequenceLength; - } - /* span extDict & currPrefixSegment */ - { - size_t const length1 = dictEnd - match; - memmove(oLitEnd, match, length1); - op = oLitEnd + length1; - sequence.matchLength -= length1; - match = base; - if (op > oend_w || sequence.matchLength < MINMATCH) { - U32 i; - for (i = 0; i < sequence.matchLength; ++i) - op[i] = match[i]; - return sequenceLength; - } - } - } - /* Requirement: op <= oend_w && sequence.matchLength >= MINMATCH */ - - /* match within prefix */ - if (sequence.offset < 8) { - /* close range match, overlap */ - static const U32 dec32table[] = {0, 1, 2, 1, 4, 4, 4, 4}; /* added */ - static const int dec64table[] = {8, 8, 8, 7, 8, 9, 10, 11}; /* subtracted */ - int const sub2 = dec64table[sequence.offset]; - op[0] = match[0]; - op[1] = match[1]; - op[2] = match[2]; - op[3] = match[3]; - match += dec32table[sequence.offset]; - ZSTD_copy4(op + 4, match); - match -= sub2; - } else { - ZSTD_copy8(op, match); - } - op += 8; - match += 8; - - if (oMatchEnd > oend - (16 - MINMATCH)) { - if (op < oend_w) { - ZSTD_wildcopy(op, match, oend_w - op); - match += oend_w - op; - op = oend_w; - } - while (op < oMatchEnd) - *op++ = *match++; - } else { - ZSTD_wildcopy(op, match, (ptrdiff_t)sequence.matchLength - 8); /* works even if matchLength < 8 */ - } - return sequenceLength; -} - -static size_t ZSTD_decompressSequencesLong(ZSTD_DCtx *dctx, void *dst, size_t maxDstSize, const void *seqStart, size_t seqSize) -{ - const BYTE *ip = (const BYTE *)seqStart; - const BYTE *const iend = ip + seqSize; - BYTE *const ostart = (BYTE * const)dst; - BYTE *const oend = ostart + maxDstSize; - BYTE *op = ostart; - const BYTE *litPtr = dctx->litPtr; - const BYTE *const litEnd = litPtr + dctx->litSize; - const BYTE *const base = (const BYTE *)(dctx->base); - const BYTE *const vBase = (const BYTE *)(dctx->vBase); - const BYTE *const dictEnd = (const BYTE *)(dctx->dictEnd); - unsigned const windowSize = dctx->fParams.windowSize; - int nbSeq; - - /* Build Decoding Tables */ - { - size_t const seqHSize = ZSTD_decodeSeqHeaders(dctx, &nbSeq, ip, seqSize); - if (ZSTD_isError(seqHSize)) - return seqHSize; - ip += seqHSize; - } - - /* Regen sequences */ - if (nbSeq) { -#define STORED_SEQS 4 -#define STOSEQ_MASK (STORED_SEQS - 1) -#define ADVANCED_SEQS 4 - seq_t *sequences = (seq_t *)dctx->entropy.workspace; - int const seqAdvance = MIN(nbSeq, ADVANCED_SEQS); - seqState_t seqState; - int seqNb; - ZSTD_STATIC_ASSERT(sizeof(dctx->entropy.workspace) >= sizeof(seq_t) * STORED_SEQS); - dctx->fseEntropy = 1; - { - U32 i; - for (i = 0; i < ZSTD_REP_NUM; i++) - seqState.prevOffset[i] = dctx->entropy.rep[i]; - } - seqState.base = base; - seqState.pos = (size_t)(op - base); - seqState.gotoDict = (uPtrDiff)dictEnd - (uPtrDiff)base; /* cast to avoid undefined behaviour */ - CHECK_E(BIT_initDStream(&seqState.DStream, ip, iend - ip), corruption_detected); - FSE_initDState(&seqState.stateLL, &seqState.DStream, dctx->LLTptr); - FSE_initDState(&seqState.stateOffb, &seqState.DStream, dctx->OFTptr); - FSE_initDState(&seqState.stateML, &seqState.DStream, dctx->MLTptr); - - /* prepare in advance */ - for (seqNb = 0; (BIT_reloadDStream(&seqState.DStream) <= BIT_DStream_completed) && seqNb < seqAdvance; seqNb++) { - sequences[seqNb] = ZSTD_decodeSequenceLong(&seqState, windowSize); - } - if (seqNb < seqAdvance) - return ERROR(corruption_detected); - - /* decode and decompress */ - for (; (BIT_reloadDStream(&(seqState.DStream)) <= BIT_DStream_completed) && seqNb < nbSeq; seqNb++) { - seq_t const sequence = ZSTD_decodeSequenceLong(&seqState, windowSize); - size_t const oneSeqSize = - ZSTD_execSequenceLong(op, oend, sequences[(seqNb - ADVANCED_SEQS) & STOSEQ_MASK], &litPtr, litEnd, base, vBase, dictEnd); - if (ZSTD_isError(oneSeqSize)) - return oneSeqSize; - ZSTD_PREFETCH(sequence.match); - sequences[seqNb & STOSEQ_MASK] = sequence; - op += oneSeqSize; - } - if (seqNb < nbSeq) - return ERROR(corruption_detected); - - /* finish queue */ - seqNb -= seqAdvance; - for (; seqNb < nbSeq; seqNb++) { - size_t const oneSeqSize = ZSTD_execSequenceLong(op, oend, sequences[seqNb & STOSEQ_MASK], &litPtr, litEnd, base, vBase, dictEnd); - if (ZSTD_isError(oneSeqSize)) - return oneSeqSize; - op += oneSeqSize; - } - - /* save reps for next block */ - { - U32 i; - for (i = 0; i < ZSTD_REP_NUM; i++) - dctx->entropy.rep[i] = (U32)(seqState.prevOffset[i]); - } - } - - /* last literal segment */ - { - size_t const lastLLSize = litEnd - litPtr; - if (lastLLSize > (size_t)(oend - op)) - return ERROR(dstSize_tooSmall); - memcpy(op, litPtr, lastLLSize); - op += lastLLSize; - } - - return op - ostart; -} - -static size_t ZSTD_decompressBlock_internal(ZSTD_DCtx *dctx, void *dst, size_t dstCapacity, const void *src, size_t srcSize) -{ /* blockType == blockCompressed */ - const BYTE *ip = (const BYTE *)src; - - if (srcSize >= ZSTD_BLOCKSIZE_ABSOLUTEMAX) - return ERROR(srcSize_wrong); - - /* Decode literals section */ - { - size_t const litCSize = ZSTD_decodeLiteralsBlock(dctx, src, srcSize); - if (ZSTD_isError(litCSize)) - return litCSize; - ip += litCSize; - srcSize -= litCSize; - } - if (sizeof(size_t) > 4) /* do not enable prefetching on 32-bits x86, as it's performance detrimental */ - /* likely because of register pressure */ - /* if that's the correct cause, then 32-bits ARM should be affected differently */ - /* it would be good to test this on ARM real hardware, to see if prefetch version improves speed */ - if (dctx->fParams.windowSize > (1 << 23)) - return ZSTD_decompressSequencesLong(dctx, dst, dstCapacity, ip, srcSize); - return ZSTD_decompressSequences(dctx, dst, dstCapacity, ip, srcSize); -} - -static void ZSTD_checkContinuity(ZSTD_DCtx *dctx, const void *dst) -{ - if (dst != dctx->previousDstEnd) { /* not contiguous */ - dctx->dictEnd = dctx->previousDstEnd; - dctx->vBase = (const char *)dst - ((const char *)(dctx->previousDstEnd) - (const char *)(dctx->base)); - dctx->base = dst; - dctx->previousDstEnd = dst; - } -} - -size_t ZSTD_decompressBlock(ZSTD_DCtx *dctx, void *dst, size_t dstCapacity, const void *src, size_t srcSize) -{ - size_t dSize; - ZSTD_checkContinuity(dctx, dst); - dSize = ZSTD_decompressBlock_internal(dctx, dst, dstCapacity, src, srcSize); - dctx->previousDstEnd = (char *)dst + dSize; - return dSize; -} - -/** ZSTD_insertBlock() : - insert `src` block into `dctx` history. Useful to track uncompressed blocks. */ -size_t ZSTD_insertBlock(ZSTD_DCtx *dctx, const void *blockStart, size_t blockSize) -{ - ZSTD_checkContinuity(dctx, blockStart); - dctx->previousDstEnd = (const char *)blockStart + blockSize; - return blockSize; -} - -size_t ZSTD_generateNxBytes(void *dst, size_t dstCapacity, BYTE byte, size_t length) -{ - if (length > dstCapacity) - return ERROR(dstSize_tooSmall); - memset(dst, byte, length); - return length; -} - -/** ZSTD_findFrameCompressedSize() : - * compatible with legacy mode - * `src` must point to the start of a ZSTD frame, ZSTD legacy frame, or skippable frame - * `srcSize` must be at least as large as the frame contained - * Return: the compressed size of the frame starting at `src` */ -size_t ZSTD_findFrameCompressedSize(const void *src, size_t srcSize) -{ - if (srcSize >= ZSTD_skippableHeaderSize && (ZSTD_readLE32(src) & 0xFFFFFFF0U) == ZSTD_MAGIC_SKIPPABLE_START) { - return ZSTD_skippableHeaderSize + ZSTD_readLE32((const BYTE *)src + 4); - } else { - const BYTE *ip = (const BYTE *)src; - const BYTE *const ipstart = ip; - size_t remainingSize = srcSize; - ZSTD_frameParams fParams; - - size_t const headerSize = ZSTD_frameHeaderSize(ip, remainingSize); - if (ZSTD_isError(headerSize)) - return headerSize; - - /* Frame Header */ - { - size_t const ret = ZSTD_getFrameParams(&fParams, ip, remainingSize); - if (ZSTD_isError(ret)) - return ret; - if (ret > 0) - return ERROR(srcSize_wrong); - } - - ip += headerSize; - remainingSize -= headerSize; - - /* Loop on each block */ - while (1) { - blockProperties_t blockProperties; - size_t const cBlockSize = ZSTD_getcBlockSize(ip, remainingSize, &blockProperties); - if (ZSTD_isError(cBlockSize)) - return cBlockSize; - - if (ZSTD_blockHeaderSize + cBlockSize > remainingSize) - return ERROR(srcSize_wrong); - - ip += ZSTD_blockHeaderSize + cBlockSize; - remainingSize -= ZSTD_blockHeaderSize + cBlockSize; - - if (blockProperties.lastBlock) - break; - } - - if (fParams.checksumFlag) { /* Frame content checksum */ - if (remainingSize < 4) - return ERROR(srcSize_wrong); - ip += 4; - remainingSize -= 4; - } - - return ip - ipstart; - } -} - -/*! ZSTD_decompressFrame() : -* @dctx must be properly initialized */ -static size_t ZSTD_decompressFrame(ZSTD_DCtx *dctx, void *dst, size_t dstCapacity, const void **srcPtr, size_t *srcSizePtr) -{ - const BYTE *ip = (const BYTE *)(*srcPtr); - BYTE *const ostart = (BYTE * const)dst; - BYTE *const oend = ostart + dstCapacity; - BYTE *op = ostart; - size_t remainingSize = *srcSizePtr; - - /* check */ - if (remainingSize < ZSTD_frameHeaderSize_min + ZSTD_blockHeaderSize) - return ERROR(srcSize_wrong); - - /* Frame Header */ - { - size_t const frameHeaderSize = ZSTD_frameHeaderSize(ip, ZSTD_frameHeaderSize_prefix); - if (ZSTD_isError(frameHeaderSize)) - return frameHeaderSize; - if (remainingSize < frameHeaderSize + ZSTD_blockHeaderSize) - return ERROR(srcSize_wrong); - CHECK_F(ZSTD_decodeFrameHeader(dctx, ip, frameHeaderSize)); - ip += frameHeaderSize; - remainingSize -= frameHeaderSize; - } - - /* Loop on each block */ - while (1) { - size_t decodedSize; - blockProperties_t blockProperties; - size_t const cBlockSize = ZSTD_getcBlockSize(ip, remainingSize, &blockProperties); - if (ZSTD_isError(cBlockSize)) - return cBlockSize; - - ip += ZSTD_blockHeaderSize; - remainingSize -= ZSTD_blockHeaderSize; - if (cBlockSize > remainingSize) - return ERROR(srcSize_wrong); - - switch (blockProperties.blockType) { - case bt_compressed: decodedSize = ZSTD_decompressBlock_internal(dctx, op, oend - op, ip, cBlockSize); break; - case bt_raw: decodedSize = ZSTD_copyRawBlock(op, oend - op, ip, cBlockSize); break; - case bt_rle: decodedSize = ZSTD_generateNxBytes(op, oend - op, *ip, blockProperties.origSize); break; - case bt_reserved: - default: return ERROR(corruption_detected); - } - - if (ZSTD_isError(decodedSize)) - return decodedSize; - if (dctx->fParams.checksumFlag) - xxh64_update(&dctx->xxhState, op, decodedSize); - op += decodedSize; - ip += cBlockSize; - remainingSize -= cBlockSize; - if (blockProperties.lastBlock) - break; - } - - if (dctx->fParams.checksumFlag) { /* Frame content checksum verification */ - U32 const checkCalc = (U32)xxh64_digest(&dctx->xxhState); - U32 checkRead; - if (remainingSize < 4) - return ERROR(checksum_wrong); - checkRead = ZSTD_readLE32(ip); - if (checkRead != checkCalc) - return ERROR(checksum_wrong); - ip += 4; - remainingSize -= 4; - } - - /* Allow caller to get size read */ - *srcPtr = ip; - *srcSizePtr = remainingSize; - return op - ostart; -} - -static const void *ZSTD_DDictDictContent(const ZSTD_DDict *ddict); -static size_t ZSTD_DDictDictSize(const ZSTD_DDict *ddict); - -static size_t ZSTD_decompressMultiFrame(ZSTD_DCtx *dctx, void *dst, size_t dstCapacity, const void *src, size_t srcSize, const void *dict, size_t dictSize, - const ZSTD_DDict *ddict) -{ - void *const dststart = dst; - - if (ddict) { - if (dict) { - /* programmer error, these two cases should be mutually exclusive */ - return ERROR(GENERIC); - } - - dict = ZSTD_DDictDictContent(ddict); - dictSize = ZSTD_DDictDictSize(ddict); - } - - while (srcSize >= ZSTD_frameHeaderSize_prefix) { - U32 magicNumber; - - magicNumber = ZSTD_readLE32(src); - if (magicNumber != ZSTD_MAGICNUMBER) { - if ((magicNumber & 0xFFFFFFF0U) == ZSTD_MAGIC_SKIPPABLE_START) { - size_t skippableSize; - if (srcSize < ZSTD_skippableHeaderSize) - return ERROR(srcSize_wrong); - skippableSize = ZSTD_readLE32((const BYTE *)src + 4) + ZSTD_skippableHeaderSize; - if (srcSize < skippableSize) { - return ERROR(srcSize_wrong); - } - - src = (const BYTE *)src + skippableSize; - srcSize -= skippableSize; - continue; - } else { - return ERROR(prefix_unknown); - } - } - - if (ddict) { - /* we were called from ZSTD_decompress_usingDDict */ - ZSTD_refDDict(dctx, ddict); - } else { - /* this will initialize correctly with no dict if dict == NULL, so - * use this in all cases but ddict */ - CHECK_F(ZSTD_decompressBegin_usingDict(dctx, dict, dictSize)); - } - ZSTD_checkContinuity(dctx, dst); - - { - const size_t res = ZSTD_decompressFrame(dctx, dst, dstCapacity, &src, &srcSize); - if (ZSTD_isError(res)) - return res; - /* don't need to bounds check this, ZSTD_decompressFrame will have - * already */ - dst = (BYTE *)dst + res; - dstCapacity -= res; - } - } - - if (srcSize) - return ERROR(srcSize_wrong); /* input not entirely consumed */ - - return (BYTE *)dst - (BYTE *)dststart; -} - -size_t ZSTD_decompress_usingDict(ZSTD_DCtx *dctx, void *dst, size_t dstCapacity, const void *src, size_t srcSize, const void *dict, size_t dictSize) -{ - return ZSTD_decompressMultiFrame(dctx, dst, dstCapacity, src, srcSize, dict, dictSize, NULL); -} - -size_t ZSTD_decompressDCtx(ZSTD_DCtx *dctx, void *dst, size_t dstCapacity, const void *src, size_t srcSize) -{ - return ZSTD_decompress_usingDict(dctx, dst, dstCapacity, src, srcSize, NULL, 0); -} - -/*-************************************** -* Advanced Streaming Decompression API -* Bufferless and synchronous -****************************************/ -size_t ZSTD_nextSrcSizeToDecompress(ZSTD_DCtx *dctx) { return dctx->expected; } - -ZSTD_nextInputType_e ZSTD_nextInputType(ZSTD_DCtx *dctx) -{ - switch (dctx->stage) { - default: /* should not happen */ - case ZSTDds_getFrameHeaderSize: - case ZSTDds_decodeFrameHeader: return ZSTDnit_frameHeader; - case ZSTDds_decodeBlockHeader: return ZSTDnit_blockHeader; - case ZSTDds_decompressBlock: return ZSTDnit_block; - case ZSTDds_decompressLastBlock: return ZSTDnit_lastBlock; - case ZSTDds_checkChecksum: return ZSTDnit_checksum; - case ZSTDds_decodeSkippableHeader: - case ZSTDds_skipFrame: return ZSTDnit_skippableFrame; - } -} - -int ZSTD_isSkipFrame(ZSTD_DCtx *dctx) { return dctx->stage == ZSTDds_skipFrame; } /* for zbuff */ - -/** ZSTD_decompressContinue() : -* @return : nb of bytes generated into `dst` (necessarily <= `dstCapacity) -* or an error code, which can be tested using ZSTD_isError() */ -size_t ZSTD_decompressContinue(ZSTD_DCtx *dctx, void *dst, size_t dstCapacity, const void *src, size_t srcSize) -{ - /* Sanity check */ - if (srcSize != dctx->expected) - return ERROR(srcSize_wrong); - if (dstCapacity) - ZSTD_checkContinuity(dctx, dst); - - switch (dctx->stage) { - case ZSTDds_getFrameHeaderSize: - if (srcSize != ZSTD_frameHeaderSize_prefix) - return ERROR(srcSize_wrong); /* impossible */ - if ((ZSTD_readLE32(src) & 0xFFFFFFF0U) == ZSTD_MAGIC_SKIPPABLE_START) { /* skippable frame */ - memcpy(dctx->headerBuffer, src, ZSTD_frameHeaderSize_prefix); - dctx->expected = ZSTD_skippableHeaderSize - ZSTD_frameHeaderSize_prefix; /* magic number + skippable frame length */ - dctx->stage = ZSTDds_decodeSkippableHeader; - return 0; - } - dctx->headerSize = ZSTD_frameHeaderSize(src, ZSTD_frameHeaderSize_prefix); - if (ZSTD_isError(dctx->headerSize)) - return dctx->headerSize; - memcpy(dctx->headerBuffer, src, ZSTD_frameHeaderSize_prefix); - if (dctx->headerSize > ZSTD_frameHeaderSize_prefix) { - dctx->expected = dctx->headerSize - ZSTD_frameHeaderSize_prefix; - dctx->stage = ZSTDds_decodeFrameHeader; - return 0; - } - dctx->expected = 0; /* not necessary to copy more */ - - case ZSTDds_decodeFrameHeader: - memcpy(dctx->headerBuffer + ZSTD_frameHeaderSize_prefix, src, dctx->expected); - CHECK_F(ZSTD_decodeFrameHeader(dctx, dctx->headerBuffer, dctx->headerSize)); - dctx->expected = ZSTD_blockHeaderSize; - dctx->stage = ZSTDds_decodeBlockHeader; - return 0; - - case ZSTDds_decodeBlockHeader: { - blockProperties_t bp; - size_t const cBlockSize = ZSTD_getcBlockSize(src, ZSTD_blockHeaderSize, &bp); - if (ZSTD_isError(cBlockSize)) - return cBlockSize; - dctx->expected = cBlockSize; - dctx->bType = bp.blockType; - dctx->rleSize = bp.origSize; - if (cBlockSize) { - dctx->stage = bp.lastBlock ? ZSTDds_decompressLastBlock : ZSTDds_decompressBlock; - return 0; - } - /* empty block */ - if (bp.lastBlock) { - if (dctx->fParams.checksumFlag) { - dctx->expected = 4; - dctx->stage = ZSTDds_checkChecksum; - } else { - dctx->expected = 0; /* end of frame */ - dctx->stage = ZSTDds_getFrameHeaderSize; - } - } else { - dctx->expected = 3; /* go directly to next header */ - dctx->stage = ZSTDds_decodeBlockHeader; - } - return 0; - } - case ZSTDds_decompressLastBlock: - case ZSTDds_decompressBlock: { - size_t rSize; - switch (dctx->bType) { - case bt_compressed: rSize = ZSTD_decompressBlock_internal(dctx, dst, dstCapacity, src, srcSize); break; - case bt_raw: rSize = ZSTD_copyRawBlock(dst, dstCapacity, src, srcSize); break; - case bt_rle: rSize = ZSTD_setRleBlock(dst, dstCapacity, src, srcSize, dctx->rleSize); break; - case bt_reserved: /* should never happen */ - default: return ERROR(corruption_detected); - } - if (ZSTD_isError(rSize)) - return rSize; - if (dctx->fParams.checksumFlag) - xxh64_update(&dctx->xxhState, dst, rSize); - - if (dctx->stage == ZSTDds_decompressLastBlock) { /* end of frame */ - if (dctx->fParams.checksumFlag) { /* another round for frame checksum */ - dctx->expected = 4; - dctx->stage = ZSTDds_checkChecksum; - } else { - dctx->expected = 0; /* ends here */ - dctx->stage = ZSTDds_getFrameHeaderSize; - } - } else { - dctx->stage = ZSTDds_decodeBlockHeader; - dctx->expected = ZSTD_blockHeaderSize; - dctx->previousDstEnd = (char *)dst + rSize; - } - return rSize; - } - case ZSTDds_checkChecksum: { - U32 const h32 = (U32)xxh64_digest(&dctx->xxhState); - U32 const check32 = ZSTD_readLE32(src); /* srcSize == 4, guaranteed by dctx->expected */ - if (check32 != h32) - return ERROR(checksum_wrong); - dctx->expected = 0; - dctx->stage = ZSTDds_getFrameHeaderSize; - return 0; - } - case ZSTDds_decodeSkippableHeader: { - memcpy(dctx->headerBuffer + ZSTD_frameHeaderSize_prefix, src, dctx->expected); - dctx->expected = ZSTD_readLE32(dctx->headerBuffer + 4); - dctx->stage = ZSTDds_skipFrame; - return 0; - } - case ZSTDds_skipFrame: { - dctx->expected = 0; - dctx->stage = ZSTDds_getFrameHeaderSize; - return 0; - } - default: - return ERROR(GENERIC); /* impossible */ - } -} - -static size_t ZSTD_refDictContent(ZSTD_DCtx *dctx, const void *dict, size_t dictSize) -{ - dctx->dictEnd = dctx->previousDstEnd; - dctx->vBase = (const char *)dict - ((const char *)(dctx->previousDstEnd) - (const char *)(dctx->base)); - dctx->base = dict; - dctx->previousDstEnd = (const char *)dict + dictSize; - return 0; -} - -/* ZSTD_loadEntropy() : - * dict : must point at beginning of a valid zstd dictionary - * Return: size of entropy tables read */ -static size_t ZSTD_loadEntropy(ZSTD_entropyTables_t *entropy, const void *const dict, size_t const dictSize) -{ - const BYTE *dictPtr = (const BYTE *)dict; - const BYTE *const dictEnd = dictPtr + dictSize; - - if (dictSize <= 8) - return ERROR(dictionary_corrupted); - dictPtr += 8; /* skip header = magic + dictID */ - - { - size_t const hSize = HUF_readDTableX4_wksp(entropy->hufTable, dictPtr, dictEnd - dictPtr, entropy->workspace, sizeof(entropy->workspace)); - if (HUF_isError(hSize)) - return ERROR(dictionary_corrupted); - dictPtr += hSize; - } - - { - short offcodeNCount[MaxOff + 1]; - U32 offcodeMaxValue = MaxOff, offcodeLog; - size_t const offcodeHeaderSize = FSE_readNCount(offcodeNCount, &offcodeMaxValue, &offcodeLog, dictPtr, dictEnd - dictPtr); - if (FSE_isError(offcodeHeaderSize)) - return ERROR(dictionary_corrupted); - if (offcodeLog > OffFSELog) - return ERROR(dictionary_corrupted); - CHECK_E(FSE_buildDTable_wksp(entropy->OFTable, offcodeNCount, offcodeMaxValue, offcodeLog, entropy->workspace, sizeof(entropy->workspace)), dictionary_corrupted); - dictPtr += offcodeHeaderSize; - } - - { - short matchlengthNCount[MaxML + 1]; - unsigned matchlengthMaxValue = MaxML, matchlengthLog; - size_t const matchlengthHeaderSize = FSE_readNCount(matchlengthNCount, &matchlengthMaxValue, &matchlengthLog, dictPtr, dictEnd - dictPtr); - if (FSE_isError(matchlengthHeaderSize)) - return ERROR(dictionary_corrupted); - if (matchlengthLog > MLFSELog) - return ERROR(dictionary_corrupted); - CHECK_E(FSE_buildDTable_wksp(entropy->MLTable, matchlengthNCount, matchlengthMaxValue, matchlengthLog, entropy->workspace, sizeof(entropy->workspace)), dictionary_corrupted); - dictPtr += matchlengthHeaderSize; - } - - { - short litlengthNCount[MaxLL + 1]; - unsigned litlengthMaxValue = MaxLL, litlengthLog; - size_t const litlengthHeaderSize = FSE_readNCount(litlengthNCount, &litlengthMaxValue, &litlengthLog, dictPtr, dictEnd - dictPtr); - if (FSE_isError(litlengthHeaderSize)) - return ERROR(dictionary_corrupted); - if (litlengthLog > LLFSELog) - return ERROR(dictionary_corrupted); - CHECK_E(FSE_buildDTable_wksp(entropy->LLTable, litlengthNCount, litlengthMaxValue, litlengthLog, entropy->workspace, sizeof(entropy->workspace)), dictionary_corrupted); - dictPtr += litlengthHeaderSize; - } - - if (dictPtr + 12 > dictEnd) - return ERROR(dictionary_corrupted); - { - int i; - size_t const dictContentSize = (size_t)(dictEnd - (dictPtr + 12)); - for (i = 0; i < 3; i++) { - U32 const rep = ZSTD_readLE32(dictPtr); - dictPtr += 4; - if (rep == 0 || rep >= dictContentSize) - return ERROR(dictionary_corrupted); - entropy->rep[i] = rep; - } - } - - return dictPtr - (const BYTE *)dict; -} - -static size_t ZSTD_decompress_insertDictionary(ZSTD_DCtx *dctx, const void *dict, size_t dictSize) -{ - if (dictSize < 8) - return ZSTD_refDictContent(dctx, dict, dictSize); - { - U32 const magic = ZSTD_readLE32(dict); - if (magic != ZSTD_DICT_MAGIC) { - return ZSTD_refDictContent(dctx, dict, dictSize); /* pure content mode */ - } - } - dctx->dictID = ZSTD_readLE32((const char *)dict + 4); - - /* load entropy tables */ - { - size_t const eSize = ZSTD_loadEntropy(&dctx->entropy, dict, dictSize); - if (ZSTD_isError(eSize)) - return ERROR(dictionary_corrupted); - dict = (const char *)dict + eSize; - dictSize -= eSize; - } - dctx->litEntropy = dctx->fseEntropy = 1; - - /* reference dictionary content */ - return ZSTD_refDictContent(dctx, dict, dictSize); -} - -size_t ZSTD_decompressBegin_usingDict(ZSTD_DCtx *dctx, const void *dict, size_t dictSize) -{ - CHECK_F(ZSTD_decompressBegin(dctx)); - if (dict && dictSize) - CHECK_E(ZSTD_decompress_insertDictionary(dctx, dict, dictSize), dictionary_corrupted); - return 0; -} - -/* ====== ZSTD_DDict ====== */ - -struct ZSTD_DDict_s { - void *dictBuffer; - const void *dictContent; - size_t dictSize; - ZSTD_entropyTables_t entropy; - U32 dictID; - U32 entropyPresent; - ZSTD_customMem cMem; -}; /* typedef'd to ZSTD_DDict within "zstd.h" */ - -size_t ZSTD_DDictWorkspaceBound(void) { return ZSTD_ALIGN(sizeof(ZSTD_stack)) + ZSTD_ALIGN(sizeof(ZSTD_DDict)); } - -static const void *ZSTD_DDictDictContent(const ZSTD_DDict *ddict) { return ddict->dictContent; } - -static size_t ZSTD_DDictDictSize(const ZSTD_DDict *ddict) { return ddict->dictSize; } - -static void ZSTD_refDDict(ZSTD_DCtx *dstDCtx, const ZSTD_DDict *ddict) -{ - ZSTD_decompressBegin(dstDCtx); /* init */ - if (ddict) { /* support refDDict on NULL */ - dstDCtx->dictID = ddict->dictID; - dstDCtx->base = ddict->dictContent; - dstDCtx->vBase = ddict->dictContent; - dstDCtx->dictEnd = (const BYTE *)ddict->dictContent + ddict->dictSize; - dstDCtx->previousDstEnd = dstDCtx->dictEnd; - if (ddict->entropyPresent) { - dstDCtx->litEntropy = 1; - dstDCtx->fseEntropy = 1; - dstDCtx->LLTptr = ddict->entropy.LLTable; - dstDCtx->MLTptr = ddict->entropy.MLTable; - dstDCtx->OFTptr = ddict->entropy.OFTable; - dstDCtx->HUFptr = ddict->entropy.hufTable; - dstDCtx->entropy.rep[0] = ddict->entropy.rep[0]; - dstDCtx->entropy.rep[1] = ddict->entropy.rep[1]; - dstDCtx->entropy.rep[2] = ddict->entropy.rep[2]; - } else { - dstDCtx->litEntropy = 0; - dstDCtx->fseEntropy = 0; - } - } -} - -static size_t ZSTD_loadEntropy_inDDict(ZSTD_DDict *ddict) -{ - ddict->dictID = 0; - ddict->entropyPresent = 0; - if (ddict->dictSize < 8) - return 0; - { - U32 const magic = ZSTD_readLE32(ddict->dictContent); - if (magic != ZSTD_DICT_MAGIC) - return 0; /* pure content mode */ - } - ddict->dictID = ZSTD_readLE32((const char *)ddict->dictContent + 4); - - /* load entropy tables */ - CHECK_E(ZSTD_loadEntropy(&ddict->entropy, ddict->dictContent, ddict->dictSize), dictionary_corrupted); - ddict->entropyPresent = 1; - return 0; -} - -static ZSTD_DDict *ZSTD_createDDict_advanced(const void *dict, size_t dictSize, unsigned byReference, ZSTD_customMem customMem) -{ - if (!customMem.customAlloc || !customMem.customFree) - return NULL; - - { - ZSTD_DDict *const ddict = (ZSTD_DDict *)ZSTD_malloc(sizeof(ZSTD_DDict), customMem); - if (!ddict) - return NULL; - ddict->cMem = customMem; - - if ((byReference) || (!dict) || (!dictSize)) { - ddict->dictBuffer = NULL; - ddict->dictContent = dict; - } else { - void *const internalBuffer = ZSTD_malloc(dictSize, customMem); - if (!internalBuffer) { - ZSTD_freeDDict(ddict); - return NULL; - } - memcpy(internalBuffer, dict, dictSize); - ddict->dictBuffer = internalBuffer; - ddict->dictContent = internalBuffer; - } - ddict->dictSize = dictSize; - ddict->entropy.hufTable[0] = (HUF_DTable)((HufLog)*0x1000001); /* cover both little and big endian */ - /* parse dictionary content */ - { - size_t const errorCode = ZSTD_loadEntropy_inDDict(ddict); - if (ZSTD_isError(errorCode)) { - ZSTD_freeDDict(ddict); - return NULL; - } - } - - return ddict; - } -} - -/*! ZSTD_initDDict() : -* Create a digested dictionary, to start decompression without startup delay. -* `dict` content is copied inside DDict. -* Consequently, `dict` can be released after `ZSTD_DDict` creation */ -ZSTD_DDict *ZSTD_initDDict(const void *dict, size_t dictSize, void *workspace, size_t workspaceSize) -{ - ZSTD_customMem const stackMem = ZSTD_initStack(workspace, workspaceSize); - return ZSTD_createDDict_advanced(dict, dictSize, 1, stackMem); -} - -size_t ZSTD_freeDDict(ZSTD_DDict *ddict) -{ - if (ddict == NULL) - return 0; /* support free on NULL */ - { - ZSTD_customMem const cMem = ddict->cMem; - ZSTD_free(ddict->dictBuffer, cMem); - ZSTD_free(ddict, cMem); - return 0; - } -} - -/*! ZSTD_getDictID_fromDict() : - * Provides the dictID stored within dictionary. - * if @return == 0, the dictionary is not conformant with Zstandard specification. - * It can still be loaded, but as a content-only dictionary. */ -unsigned ZSTD_getDictID_fromDict(const void *dict, size_t dictSize) -{ - if (dictSize < 8) - return 0; - if (ZSTD_readLE32(dict) != ZSTD_DICT_MAGIC) - return 0; - return ZSTD_readLE32((const char *)dict + 4); -} - -/*! ZSTD_getDictID_fromDDict() : - * Provides the dictID of the dictionary loaded into `ddict`. - * If @return == 0, the dictionary is not conformant to Zstandard specification, or empty. - * Non-conformant dictionaries can still be loaded, but as content-only dictionaries. */ -unsigned ZSTD_getDictID_fromDDict(const ZSTD_DDict *ddict) -{ - if (ddict == NULL) - return 0; - return ZSTD_getDictID_fromDict(ddict->dictContent, ddict->dictSize); -} - -/*! ZSTD_getDictID_fromFrame() : - * Provides the dictID required to decompressed the frame stored within `src`. - * If @return == 0, the dictID could not be decoded. - * This could for one of the following reasons : - * - The frame does not require a dictionary to be decoded (most common case). - * - The frame was built with dictID intentionally removed. Whatever dictionary is necessary is a hidden information. - * Note : this use case also happens when using a non-conformant dictionary. - * - `srcSize` is too small, and as a result, the frame header could not be decoded (only possible if `srcSize < ZSTD_FRAMEHEADERSIZE_MAX`). - * - This is not a Zstandard frame. - * When identifying the exact failure cause, it's possible to used ZSTD_getFrameParams(), which will provide a more precise error code. */ -unsigned ZSTD_getDictID_fromFrame(const void *src, size_t srcSize) -{ - ZSTD_frameParams zfp = {0, 0, 0, 0}; - size_t const hError = ZSTD_getFrameParams(&zfp, src, srcSize); - if (ZSTD_isError(hError)) - return 0; - return zfp.dictID; -} - -/*! ZSTD_decompress_usingDDict() : -* Decompression using a pre-digested Dictionary -* Use dictionary without significant overhead. */ -size_t ZSTD_decompress_usingDDict(ZSTD_DCtx *dctx, void *dst, size_t dstCapacity, const void *src, size_t srcSize, const ZSTD_DDict *ddict) -{ - /* pass content and size in case legacy frames are encountered */ - return ZSTD_decompressMultiFrame(dctx, dst, dstCapacity, src, srcSize, NULL, 0, ddict); -} - -/*===================================== -* Streaming decompression -*====================================*/ - -typedef enum { zdss_init, zdss_loadHeader, zdss_read, zdss_load, zdss_flush } ZSTD_dStreamStage; - -/* *** Resource management *** */ -struct ZSTD_DStream_s { - ZSTD_DCtx *dctx; - ZSTD_DDict *ddictLocal; - const ZSTD_DDict *ddict; - ZSTD_frameParams fParams; - ZSTD_dStreamStage stage; - char *inBuff; - size_t inBuffSize; - size_t inPos; - size_t maxWindowSize; - char *outBuff; - size_t outBuffSize; - size_t outStart; - size_t outEnd; - size_t blockSize; - BYTE headerBuffer[ZSTD_FRAMEHEADERSIZE_MAX]; /* tmp buffer to store frame header */ - size_t lhSize; - ZSTD_customMem customMem; - void *legacyContext; - U32 previousLegacyVersion; - U32 legacyVersion; - U32 hostageByte; -}; /* typedef'd to ZSTD_DStream within "zstd.h" */ - -size_t ZSTD_DStreamWorkspaceBound(size_t maxWindowSize) -{ - size_t const blockSize = MIN(maxWindowSize, ZSTD_BLOCKSIZE_ABSOLUTEMAX); - size_t const inBuffSize = blockSize; - size_t const outBuffSize = maxWindowSize + blockSize + WILDCOPY_OVERLENGTH * 2; - return ZSTD_DCtxWorkspaceBound() + ZSTD_ALIGN(sizeof(ZSTD_DStream)) + ZSTD_ALIGN(inBuffSize) + ZSTD_ALIGN(outBuffSize); -} - -static ZSTD_DStream *ZSTD_createDStream_advanced(ZSTD_customMem customMem) -{ - ZSTD_DStream *zds; - - if (!customMem.customAlloc || !customMem.customFree) - return NULL; - - zds = (ZSTD_DStream *)ZSTD_malloc(sizeof(ZSTD_DStream), customMem); - if (zds == NULL) - return NULL; - memset(zds, 0, sizeof(ZSTD_DStream)); - memcpy(&zds->customMem, &customMem, sizeof(ZSTD_customMem)); - zds->dctx = ZSTD_createDCtx_advanced(customMem); - if (zds->dctx == NULL) { - ZSTD_freeDStream(zds); - return NULL; - } - zds->stage = zdss_init; - zds->maxWindowSize = ZSTD_MAXWINDOWSIZE_DEFAULT; - return zds; -} - -ZSTD_DStream *ZSTD_initDStream(size_t maxWindowSize, void *workspace, size_t workspaceSize) -{ - ZSTD_customMem const stackMem = ZSTD_initStack(workspace, workspaceSize); - ZSTD_DStream *zds = ZSTD_createDStream_advanced(stackMem); - if (!zds) { - return NULL; - } - - zds->maxWindowSize = maxWindowSize; - zds->stage = zdss_loadHeader; - zds->lhSize = zds->inPos = zds->outStart = zds->outEnd = 0; - ZSTD_freeDDict(zds->ddictLocal); - zds->ddictLocal = NULL; - zds->ddict = zds->ddictLocal; - zds->legacyVersion = 0; - zds->hostageByte = 0; - - { - size_t const blockSize = MIN(zds->maxWindowSize, ZSTD_BLOCKSIZE_ABSOLUTEMAX); - size_t const neededOutSize = zds->maxWindowSize + blockSize + WILDCOPY_OVERLENGTH * 2; - - zds->inBuff = (char *)ZSTD_malloc(blockSize, zds->customMem); - zds->inBuffSize = blockSize; - zds->outBuff = (char *)ZSTD_malloc(neededOutSize, zds->customMem); - zds->outBuffSize = neededOutSize; - if (zds->inBuff == NULL || zds->outBuff == NULL) { - ZSTD_freeDStream(zds); - return NULL; - } - } - return zds; -} - -ZSTD_DStream *ZSTD_initDStream_usingDDict(size_t maxWindowSize, const ZSTD_DDict *ddict, void *workspace, size_t workspaceSize) -{ - ZSTD_DStream *zds = ZSTD_initDStream(maxWindowSize, workspace, workspaceSize); - if (zds) { - zds->ddict = ddict; - } - return zds; -} - -size_t ZSTD_freeDStream(ZSTD_DStream *zds) -{ - if (zds == NULL) - return 0; /* support free on null */ - { - ZSTD_customMem const cMem = zds->customMem; - ZSTD_freeDCtx(zds->dctx); - zds->dctx = NULL; - ZSTD_freeDDict(zds->ddictLocal); - zds->ddictLocal = NULL; - ZSTD_free(zds->inBuff, cMem); - zds->inBuff = NULL; - ZSTD_free(zds->outBuff, cMem); - zds->outBuff = NULL; - ZSTD_free(zds, cMem); - return 0; - } -} - -/* *** Initialization *** */ - -size_t ZSTD_DStreamInSize(void) { return ZSTD_BLOCKSIZE_ABSOLUTEMAX + ZSTD_blockHeaderSize; } -size_t ZSTD_DStreamOutSize(void) { return ZSTD_BLOCKSIZE_ABSOLUTEMAX; } - -size_t ZSTD_resetDStream(ZSTD_DStream *zds) -{ - zds->stage = zdss_loadHeader; - zds->lhSize = zds->inPos = zds->outStart = zds->outEnd = 0; - zds->legacyVersion = 0; - zds->hostageByte = 0; - return ZSTD_frameHeaderSize_prefix; -} - -/* ***** Decompression ***** */ - -ZSTD_STATIC size_t ZSTD_limitCopy(void *dst, size_t dstCapacity, const void *src, size_t srcSize) -{ - size_t const length = MIN(dstCapacity, srcSize); - memcpy(dst, src, length); - return length; -} - -size_t ZSTD_decompressStream(ZSTD_DStream *zds, ZSTD_outBuffer *output, ZSTD_inBuffer *input) -{ - const char *const istart = (const char *)(input->src) + input->pos; - const char *const iend = (const char *)(input->src) + input->size; - const char *ip = istart; - char *const ostart = (char *)(output->dst) + output->pos; - char *const oend = (char *)(output->dst) + output->size; - char *op = ostart; - U32 someMoreWork = 1; - - while (someMoreWork) { - switch (zds->stage) { - case zdss_init: - ZSTD_resetDStream(zds); /* transparent reset on starting decoding a new frame */ - /* fall-through */ - - case zdss_loadHeader: { - size_t const hSize = ZSTD_getFrameParams(&zds->fParams, zds->headerBuffer, zds->lhSize); - if (ZSTD_isError(hSize)) - return hSize; - if (hSize != 0) { /* need more input */ - size_t const toLoad = hSize - zds->lhSize; /* if hSize!=0, hSize > zds->lhSize */ - if (toLoad > (size_t)(iend - ip)) { /* not enough input to load full header */ - memcpy(zds->headerBuffer + zds->lhSize, ip, iend - ip); - zds->lhSize += iend - ip; - input->pos = input->size; - return (MAX(ZSTD_frameHeaderSize_min, hSize) - zds->lhSize) + - ZSTD_blockHeaderSize; /* remaining header bytes + next block header */ - } - memcpy(zds->headerBuffer + zds->lhSize, ip, toLoad); - zds->lhSize = hSize; - ip += toLoad; - break; - } - - /* check for single-pass mode opportunity */ - if (zds->fParams.frameContentSize && zds->fParams.windowSize /* skippable frame if == 0 */ - && (U64)(size_t)(oend - op) >= zds->fParams.frameContentSize) { - size_t const cSize = ZSTD_findFrameCompressedSize(istart, iend - istart); - if (cSize <= (size_t)(iend - istart)) { - size_t const decompressedSize = ZSTD_decompress_usingDDict(zds->dctx, op, oend - op, istart, cSize, zds->ddict); - if (ZSTD_isError(decompressedSize)) - return decompressedSize; - ip = istart + cSize; - op += decompressedSize; - zds->dctx->expected = 0; - zds->stage = zdss_init; - someMoreWork = 0; - break; - } - } - - /* Consume header */ - ZSTD_refDDict(zds->dctx, zds->ddict); - { - size_t const h1Size = ZSTD_nextSrcSizeToDecompress(zds->dctx); /* == ZSTD_frameHeaderSize_prefix */ - CHECK_F(ZSTD_decompressContinue(zds->dctx, NULL, 0, zds->headerBuffer, h1Size)); - { - size_t const h2Size = ZSTD_nextSrcSizeToDecompress(zds->dctx); - CHECK_F(ZSTD_decompressContinue(zds->dctx, NULL, 0, zds->headerBuffer + h1Size, h2Size)); - } - } - - zds->fParams.windowSize = MAX(zds->fParams.windowSize, 1U << ZSTD_WINDOWLOG_ABSOLUTEMIN); - if (zds->fParams.windowSize > zds->maxWindowSize) - return ERROR(frameParameter_windowTooLarge); - - /* Buffers are preallocated, but double check */ - { - size_t const blockSize = MIN(zds->maxWindowSize, ZSTD_BLOCKSIZE_ABSOLUTEMAX); - size_t const neededOutSize = zds->maxWindowSize + blockSize + WILDCOPY_OVERLENGTH * 2; - if (zds->inBuffSize < blockSize) { - return ERROR(GENERIC); - } - if (zds->outBuffSize < neededOutSize) { - return ERROR(GENERIC); - } - zds->blockSize = blockSize; - } - zds->stage = zdss_read; - } - /* pass-through */ - - case zdss_read: { - size_t const neededInSize = ZSTD_nextSrcSizeToDecompress(zds->dctx); - if (neededInSize == 0) { /* end of frame */ - zds->stage = zdss_init; - someMoreWork = 0; - break; - } - if ((size_t)(iend - ip) >= neededInSize) { /* decode directly from src */ - const int isSkipFrame = ZSTD_isSkipFrame(zds->dctx); - size_t const decodedSize = ZSTD_decompressContinue(zds->dctx, zds->outBuff + zds->outStart, - (isSkipFrame ? 0 : zds->outBuffSize - zds->outStart), ip, neededInSize); - if (ZSTD_isError(decodedSize)) - return decodedSize; - ip += neededInSize; - if (!decodedSize && !isSkipFrame) - break; /* this was just a header */ - zds->outEnd = zds->outStart + decodedSize; - zds->stage = zdss_flush; - break; - } - if (ip == iend) { - someMoreWork = 0; - break; - } /* no more input */ - zds->stage = zdss_load; - /* pass-through */ - } - - case zdss_load: { - size_t const neededInSize = ZSTD_nextSrcSizeToDecompress(zds->dctx); - size_t const toLoad = neededInSize - zds->inPos; /* should always be <= remaining space within inBuff */ - size_t loadedSize; - if (toLoad > zds->inBuffSize - zds->inPos) - return ERROR(corruption_detected); /* should never happen */ - loadedSize = ZSTD_limitCopy(zds->inBuff + zds->inPos, toLoad, ip, iend - ip); - ip += loadedSize; - zds->inPos += loadedSize; - if (loadedSize < toLoad) { - someMoreWork = 0; - break; - } /* not enough input, wait for more */ - - /* decode loaded input */ - { - const int isSkipFrame = ZSTD_isSkipFrame(zds->dctx); - size_t const decodedSize = ZSTD_decompressContinue(zds->dctx, zds->outBuff + zds->outStart, zds->outBuffSize - zds->outStart, - zds->inBuff, neededInSize); - if (ZSTD_isError(decodedSize)) - return decodedSize; - zds->inPos = 0; /* input is consumed */ - if (!decodedSize && !isSkipFrame) { - zds->stage = zdss_read; - break; - } /* this was just a header */ - zds->outEnd = zds->outStart + decodedSize; - zds->stage = zdss_flush; - /* pass-through */ - } - } - - case zdss_flush: { - size_t const toFlushSize = zds->outEnd - zds->outStart; - size_t const flushedSize = ZSTD_limitCopy(op, oend - op, zds->outBuff + zds->outStart, toFlushSize); - op += flushedSize; - zds->outStart += flushedSize; - if (flushedSize == toFlushSize) { /* flush completed */ - zds->stage = zdss_read; - if (zds->outStart + zds->blockSize > zds->outBuffSize) - zds->outStart = zds->outEnd = 0; - break; - } - /* cannot complete flush */ - someMoreWork = 0; - break; - } - default: - return ERROR(GENERIC); /* impossible */ - } - } - - /* result */ - input->pos += (size_t)(ip - istart); - output->pos += (size_t)(op - ostart); - { - size_t nextSrcSizeHint = ZSTD_nextSrcSizeToDecompress(zds->dctx); - if (!nextSrcSizeHint) { /* frame fully decoded */ - if (zds->outEnd == zds->outStart) { /* output fully flushed */ - if (zds->hostageByte) { - if (input->pos >= input->size) { - zds->stage = zdss_read; - return 1; - } /* can't release hostage (not present) */ - input->pos++; /* release hostage */ - } - return 0; - } - if (!zds->hostageByte) { /* output not fully flushed; keep last byte as hostage; will be released when all output is flushed */ - input->pos--; /* note : pos > 0, otherwise, impossible to finish reading last block */ - zds->hostageByte = 1; - } - return 1; - } - nextSrcSizeHint += ZSTD_blockHeaderSize * (ZSTD_nextInputType(zds->dctx) == ZSTDnit_block); /* preload header of next block */ - if (zds->inPos > nextSrcSizeHint) - return ERROR(GENERIC); /* should never happen */ - nextSrcSizeHint -= zds->inPos; /* already loaded*/ - return nextSrcSizeHint; - } -} - -EXPORT_SYMBOL(ZSTD_DCtxWorkspaceBound); -EXPORT_SYMBOL(ZSTD_initDCtx); -EXPORT_SYMBOL(ZSTD_decompressDCtx); -EXPORT_SYMBOL(ZSTD_decompress_usingDict); - -EXPORT_SYMBOL(ZSTD_DDictWorkspaceBound); -EXPORT_SYMBOL(ZSTD_initDDict); -EXPORT_SYMBOL(ZSTD_decompress_usingDDict); - -EXPORT_SYMBOL(ZSTD_DStreamWorkspaceBound); -EXPORT_SYMBOL(ZSTD_initDStream); -EXPORT_SYMBOL(ZSTD_initDStream_usingDDict); -EXPORT_SYMBOL(ZSTD_resetDStream); -EXPORT_SYMBOL(ZSTD_decompressStream); -EXPORT_SYMBOL(ZSTD_DStreamInSize); -EXPORT_SYMBOL(ZSTD_DStreamOutSize); - -EXPORT_SYMBOL(ZSTD_findFrameCompressedSize); -EXPORT_SYMBOL(ZSTD_getFrameContentSize); -EXPORT_SYMBOL(ZSTD_findDecompressedSize); - -EXPORT_SYMBOL(ZSTD_isFrame); -EXPORT_SYMBOL(ZSTD_getDictID_fromDict); -EXPORT_SYMBOL(ZSTD_getDictID_fromDDict); -EXPORT_SYMBOL(ZSTD_getDictID_fromFrame); - -EXPORT_SYMBOL(ZSTD_getFrameParams); -EXPORT_SYMBOL(ZSTD_decompressBegin); -EXPORT_SYMBOL(ZSTD_decompressBegin_usingDict); -EXPORT_SYMBOL(ZSTD_copyDCtx); -EXPORT_SYMBOL(ZSTD_nextSrcSizeToDecompress); -EXPORT_SYMBOL(ZSTD_decompressContinue); -EXPORT_SYMBOL(ZSTD_nextInputType); - -EXPORT_SYMBOL(ZSTD_decompressBlock); -EXPORT_SYMBOL(ZSTD_insertBlock); diff --git a/lib/zstd/decompress/huf_decompress.c b/lib/zstd/decompress/huf_decompress.c new file mode 100644 index 00000000000..89b269a641c --- /dev/null +++ b/lib/zstd/decompress/huf_decompress.c @@ -0,0 +1,1740 @@ +/* ****************************************************************** + * huff0 huffman decoder, + * part of Finite State Entropy library + * Copyright (c) Yann Collet, Facebook, Inc. + * + * You can contact the author at : + * - FSE+HUF source repository : https://github.com/Cyan4973/FiniteStateEntropy + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. +****************************************************************** */ + +/* ************************************************************** +* Dependencies +****************************************************************/ +#include "../common/zstd_deps.h" /* ZSTD_memcpy, ZSTD_memset */ +#include "../common/compiler.h" +#include "../common/bitstream.h" /* BIT_* */ +#include "../common/fse.h" /* to compress headers */ +#define HUF_STATIC_LINKING_ONLY +#include "../common/huf.h" +#include "../common/error_private.h" +#include "../common/zstd_internal.h" + +/* ************************************************************** +* Constants +****************************************************************/ + +#define HUF_DECODER_FAST_TABLELOG 11 + +/* ************************************************************** +* Macros +****************************************************************/ + +/* These two optional macros force the use one way or another of the two + * Huffman decompression implementations. You can't force in both directions + * at the same time. + */ +#if defined(HUF_FORCE_DECOMPRESS_X1) && \ + defined(HUF_FORCE_DECOMPRESS_X2) +#error "Cannot force the use of the X1 and X2 decoders at the same time!" +#endif + +#if ZSTD_ENABLE_ASM_X86_64_BMI2 && DYNAMIC_BMI2 +# define HUF_ASM_X86_64_BMI2_ATTRS BMI2_TARGET_ATTRIBUTE +#else +# define HUF_ASM_X86_64_BMI2_ATTRS +#endif + +#define HUF_EXTERN_C +#define HUF_ASM_DECL HUF_EXTERN_C + +#if DYNAMIC_BMI2 || (ZSTD_ENABLE_ASM_X86_64_BMI2 && defined(__BMI2__)) +# define HUF_NEED_BMI2_FUNCTION 1 +#else +# define HUF_NEED_BMI2_FUNCTION 0 +#endif + +#if !(ZSTD_ENABLE_ASM_X86_64_BMI2 && defined(__BMI2__)) +# define HUF_NEED_DEFAULT_FUNCTION 1 +#else +# define HUF_NEED_DEFAULT_FUNCTION 0 +#endif + +/* ************************************************************** +* Error Management +****************************************************************/ +#define HUF_isError ERR_isError + + +/* ************************************************************** +* Byte alignment for workSpace management +****************************************************************/ +#define HUF_ALIGN(x, a) HUF_ALIGN_MASK((x), (a) - 1) +#define HUF_ALIGN_MASK(x, mask) (((x) + (mask)) & ~(mask)) + + +/* ************************************************************** +* BMI2 Variant Wrappers +****************************************************************/ +#if DYNAMIC_BMI2 + +#define HUF_DGEN(fn) \ + \ + static size_t fn##_default( \ + void* dst, size_t dstSize, \ + const void* cSrc, size_t cSrcSize, \ + const HUF_DTable* DTable) \ + { \ + return fn##_body(dst, dstSize, cSrc, cSrcSize, DTable); \ + } \ + \ + static BMI2_TARGET_ATTRIBUTE size_t fn##_bmi2( \ + void* dst, size_t dstSize, \ + const void* cSrc, size_t cSrcSize, \ + const HUF_DTable* DTable) \ + { \ + return fn##_body(dst, dstSize, cSrc, cSrcSize, DTable); \ + } \ + \ + static size_t fn(void* dst, size_t dstSize, void const* cSrc, \ + size_t cSrcSize, HUF_DTable const* DTable, int bmi2) \ + { \ + if (bmi2) { \ + return fn##_bmi2(dst, dstSize, cSrc, cSrcSize, DTable); \ + } \ + return fn##_default(dst, dstSize, cSrc, cSrcSize, DTable); \ + } + +#else + +#define HUF_DGEN(fn) \ + static size_t fn(void* dst, size_t dstSize, void const* cSrc, \ + size_t cSrcSize, HUF_DTable const* DTable, int bmi2) \ + { \ + (void)bmi2; \ + return fn##_body(dst, dstSize, cSrc, cSrcSize, DTable); \ + } + +#endif + + +/*-***************************/ +/* generic DTableDesc */ +/*-***************************/ +typedef struct { BYTE maxTableLog; BYTE tableType; BYTE tableLog; BYTE reserved; } DTableDesc; + +static DTableDesc HUF_getDTableDesc(const HUF_DTable* table) +{ + DTableDesc dtd; + ZSTD_memcpy(&dtd, table, sizeof(dtd)); + return dtd; +} + +#if ZSTD_ENABLE_ASM_X86_64_BMI2 + +static size_t HUF_initDStream(BYTE const* ip) { + BYTE const lastByte = ip[7]; + size_t const bitsConsumed = lastByte ? 8 - BIT_highbit32(lastByte) : 0; + size_t const value = MEM_readLEST(ip) | 1; + assert(bitsConsumed <= 8); + return value << bitsConsumed; +} +typedef struct { + BYTE const* ip[4]; + BYTE* op[4]; + U64 bits[4]; + void const* dt; + BYTE const* ilimit; + BYTE* oend; + BYTE const* iend[4]; +} HUF_DecompressAsmArgs; + +/* + * Initializes args for the asm decoding loop. + * @returns 0 on success + * 1 if the fallback implementation should be used. + * Or an error code on failure. + */ +static size_t HUF_DecompressAsmArgs_init(HUF_DecompressAsmArgs* args, void* dst, size_t dstSize, void const* src, size_t srcSize, const HUF_DTable* DTable) +{ + void const* dt = DTable + 1; + U32 const dtLog = HUF_getDTableDesc(DTable).tableLog; + + const BYTE* const ilimit = (const BYTE*)src + 6 + 8; + + BYTE* const oend = (BYTE*)dst + dstSize; + + /* The following condition is false on x32 platform, + * but HUF_asm is not compatible with this ABI */ + if (!(MEM_isLittleEndian() && !MEM_32bits())) return 1; + + /* strict minimum : jump table + 1 byte per stream */ + if (srcSize < 10) + return ERROR(corruption_detected); + + /* Must have at least 8 bytes per stream because we don't handle initializing smaller bit containers. + * If table log is not correct at this point, fallback to the old decoder. + * On small inputs we don't have enough data to trigger the fast loop, so use the old decoder. + */ + if (dtLog != HUF_DECODER_FAST_TABLELOG) + return 1; + + /* Read the jump table. */ + { + const BYTE* const istart = (const BYTE*)src; + size_t const length1 = MEM_readLE16(istart); + size_t const length2 = MEM_readLE16(istart+2); + size_t const length3 = MEM_readLE16(istart+4); + size_t const length4 = srcSize - (length1 + length2 + length3 + 6); + args->iend[0] = istart + 6; /* jumpTable */ + args->iend[1] = args->iend[0] + length1; + args->iend[2] = args->iend[1] + length2; + args->iend[3] = args->iend[2] + length3; + + /* HUF_initDStream() requires this, and this small of an input + * won't benefit from the ASM loop anyways. + * length1 must be >= 16 so that ip[0] >= ilimit before the loop + * starts. + */ + if (length1 < 16 || length2 < 8 || length3 < 8 || length4 < 8) + return 1; + if (length4 > srcSize) return ERROR(corruption_detected); /* overflow */ + } + /* ip[] contains the position that is currently loaded into bits[]. */ + args->ip[0] = args->iend[1] - sizeof(U64); + args->ip[1] = args->iend[2] - sizeof(U64); + args->ip[2] = args->iend[3] - sizeof(U64); + args->ip[3] = (BYTE const*)src + srcSize - sizeof(U64); + + /* op[] contains the output pointers. */ + args->op[0] = (BYTE*)dst; + args->op[1] = args->op[0] + (dstSize+3)/4; + args->op[2] = args->op[1] + (dstSize+3)/4; + args->op[3] = args->op[2] + (dstSize+3)/4; + + /* No point to call the ASM loop for tiny outputs. */ + if (args->op[3] >= oend) + return 1; + + /* bits[] is the bit container. + * It is read from the MSB down to the LSB. + * It is shifted left as it is read, and zeros are + * shifted in. After the lowest valid bit a 1 is + * set, so that CountTrailingZeros(bits[]) can be used + * to count how many bits we've consumed. + */ + args->bits[0] = HUF_initDStream(args->ip[0]); + args->bits[1] = HUF_initDStream(args->ip[1]); + args->bits[2] = HUF_initDStream(args->ip[2]); + args->bits[3] = HUF_initDStream(args->ip[3]); + + /* If ip[] >= ilimit, it is guaranteed to be safe to + * reload bits[]. It may be beyond its section, but is + * guaranteed to be valid (>= istart). + */ + args->ilimit = ilimit; + + args->oend = oend; + args->dt = dt; + + return 0; +} + +static size_t HUF_initRemainingDStream(BIT_DStream_t* bit, HUF_DecompressAsmArgs const* args, int stream, BYTE* segmentEnd) +{ + /* Validate that we haven't overwritten. */ + if (args->op[stream] > segmentEnd) + return ERROR(corruption_detected); + /* Validate that we haven't read beyond iend[]. + * Note that ip[] may be < iend[] because the MSB is + * the next bit to read, and we may have consumed 100% + * of the stream, so down to iend[i] - 8 is valid. + */ + if (args->ip[stream] < args->iend[stream] - 8) + return ERROR(corruption_detected); + + /* Construct the BIT_DStream_t. */ + bit->bitContainer = MEM_readLE64(args->ip[stream]); + bit->bitsConsumed = ZSTD_countTrailingZeros((size_t)args->bits[stream]); + bit->start = (const char*)args->iend[0]; + bit->limitPtr = bit->start + sizeof(size_t); + bit->ptr = (const char*)args->ip[stream]; + + return 0; +} +#endif + + +#ifndef HUF_FORCE_DECOMPRESS_X2 + +/*-***************************/ +/* single-symbol decoding */ +/*-***************************/ +typedef struct { BYTE nbBits; BYTE byte; } HUF_DEltX1; /* single-symbol decoding */ + +/* + * Packs 4 HUF_DEltX1 structs into a U64. This is used to lay down 4 entries at + * a time. + */ +static U64 HUF_DEltX1_set4(BYTE symbol, BYTE nbBits) { + U64 D4; + if (MEM_isLittleEndian()) { + D4 = (symbol << 8) + nbBits; + } else { + D4 = symbol + (nbBits << 8); + } + D4 *= 0x0001000100010001ULL; + return D4; +} + +/* + * Increase the tableLog to targetTableLog and rescales the stats. + * If tableLog > targetTableLog this is a no-op. + * @returns New tableLog + */ +static U32 HUF_rescaleStats(BYTE* huffWeight, U32* rankVal, U32 nbSymbols, U32 tableLog, U32 targetTableLog) +{ + if (tableLog > targetTableLog) + return tableLog; + if (tableLog < targetTableLog) { + U32 const scale = targetTableLog - tableLog; + U32 s; + /* Increase the weight for all non-zero probability symbols by scale. */ + for (s = 0; s < nbSymbols; ++s) { + huffWeight[s] += (BYTE)((huffWeight[s] == 0) ? 0 : scale); + } + /* Update rankVal to reflect the new weights. + * All weights except 0 get moved to weight + scale. + * Weights [1, scale] are empty. + */ + for (s = targetTableLog; s > scale; --s) { + rankVal[s] = rankVal[s - scale]; + } + for (s = scale; s > 0; --s) { + rankVal[s] = 0; + } + } + return targetTableLog; +} + +typedef struct { + U32 rankVal[HUF_TABLELOG_ABSOLUTEMAX + 1]; + U32 rankStart[HUF_TABLELOG_ABSOLUTEMAX + 1]; + U32 statsWksp[HUF_READ_STATS_WORKSPACE_SIZE_U32]; + BYTE symbols[HUF_SYMBOLVALUE_MAX + 1]; + BYTE huffWeight[HUF_SYMBOLVALUE_MAX + 1]; +} HUF_ReadDTableX1_Workspace; + + +size_t HUF_readDTableX1_wksp(HUF_DTable* DTable, const void* src, size_t srcSize, void* workSpace, size_t wkspSize) +{ + return HUF_readDTableX1_wksp_bmi2(DTable, src, srcSize, workSpace, wkspSize, /* bmi2 */ 0); +} + +size_t HUF_readDTableX1_wksp_bmi2(HUF_DTable* DTable, const void* src, size_t srcSize, void* workSpace, size_t wkspSize, int bmi2) +{ + U32 tableLog = 0; + U32 nbSymbols = 0; + size_t iSize; + void* const dtPtr = DTable + 1; + HUF_DEltX1* const dt = (HUF_DEltX1*)dtPtr; + HUF_ReadDTableX1_Workspace* wksp = (HUF_ReadDTableX1_Workspace*)workSpace; + + DEBUG_STATIC_ASSERT(HUF_DECOMPRESS_WORKSPACE_SIZE >= sizeof(*wksp)); + if (sizeof(*wksp) > wkspSize) return ERROR(tableLog_tooLarge); + + DEBUG_STATIC_ASSERT(sizeof(DTableDesc) == sizeof(HUF_DTable)); + /* ZSTD_memset(huffWeight, 0, sizeof(huffWeight)); */ /* is not necessary, even though some analyzer complain ... */ + + iSize = HUF_readStats_wksp(wksp->huffWeight, HUF_SYMBOLVALUE_MAX + 1, wksp->rankVal, &nbSymbols, &tableLog, src, srcSize, wksp->statsWksp, sizeof(wksp->statsWksp), bmi2); + if (HUF_isError(iSize)) return iSize; + + + /* Table header */ + { DTableDesc dtd = HUF_getDTableDesc(DTable); + U32 const maxTableLog = dtd.maxTableLog + 1; + U32 const targetTableLog = MIN(maxTableLog, HUF_DECODER_FAST_TABLELOG); + tableLog = HUF_rescaleStats(wksp->huffWeight, wksp->rankVal, nbSymbols, tableLog, targetTableLog); + if (tableLog > (U32)(dtd.maxTableLog+1)) return ERROR(tableLog_tooLarge); /* DTable too small, Huffman tree cannot fit in */ + dtd.tableType = 0; + dtd.tableLog = (BYTE)tableLog; + ZSTD_memcpy(DTable, &dtd, sizeof(dtd)); + } + + /* Compute symbols and rankStart given rankVal: + * + * rankVal already contains the number of values of each weight. + * + * symbols contains the symbols ordered by weight. First are the rankVal[0] + * weight 0 symbols, followed by the rankVal[1] weight 1 symbols, and so on. + * symbols[0] is filled (but unused) to avoid a branch. + * + * rankStart contains the offset where each rank belongs in the DTable. + * rankStart[0] is not filled because there are no entries in the table for + * weight 0. + */ + { + int n; + int nextRankStart = 0; + int const unroll = 4; + int const nLimit = (int)nbSymbols - unroll + 1; + for (n=0; n<(int)tableLog+1; n++) { + U32 const curr = nextRankStart; + nextRankStart += wksp->rankVal[n]; + wksp->rankStart[n] = curr; + } + for (n=0; n < nLimit; n += unroll) { + int u; + for (u=0; u < unroll; ++u) { + size_t const w = wksp->huffWeight[n+u]; + wksp->symbols[wksp->rankStart[w]++] = (BYTE)(n+u); + } + } + for (; n < (int)nbSymbols; ++n) { + size_t const w = wksp->huffWeight[n]; + wksp->symbols[wksp->rankStart[w]++] = (BYTE)n; + } + } + + /* fill DTable + * We fill all entries of each weight in order. + * That way length is a constant for each iteration of the outer loop. + * We can switch based on the length to a different inner loop which is + * optimized for that particular case. + */ + { + U32 w; + int symbol=wksp->rankVal[0]; + int rankStart=0; + for (w=1; w<tableLog+1; ++w) { + int const symbolCount = wksp->rankVal[w]; + int const length = (1 << w) >> 1; + int uStart = rankStart; + BYTE const nbBits = (BYTE)(tableLog + 1 - w); + int s; + int u; + switch (length) { + case 1: + for (s=0; s<symbolCount; ++s) { + HUF_DEltX1 D; + D.byte = wksp->symbols[symbol + s]; + D.nbBits = nbBits; + dt[uStart] = D; + uStart += 1; + } + break; + case 2: + for (s=0; s<symbolCount; ++s) { + HUF_DEltX1 D; + D.byte = wksp->symbols[symbol + s]; + D.nbBits = nbBits; + dt[uStart+0] = D; + dt[uStart+1] = D; + uStart += 2; + } + break; + case 4: + for (s=0; s<symbolCount; ++s) { + U64 const D4 = HUF_DEltX1_set4(wksp->symbols[symbol + s], nbBits); + MEM_write64(dt + uStart, D4); + uStart += 4; + } + break; + case 8: + for (s=0; s<symbolCount; ++s) { + U64 const D4 = HUF_DEltX1_set4(wksp->symbols[symbol + s], nbBits); + MEM_write64(dt + uStart, D4); + MEM_write64(dt + uStart + 4, D4); + uStart += 8; + } + break; + default: + for (s=0; s<symbolCount; ++s) { + U64 const D4 = HUF_DEltX1_set4(wksp->symbols[symbol + s], nbBits); + for (u=0; u < length; u += 16) { + MEM_write64(dt + uStart + u + 0, D4); + MEM_write64(dt + uStart + u + 4, D4); + MEM_write64(dt + uStart + u + 8, D4); + MEM_write64(dt + uStart + u + 12, D4); + } + assert(u == length); + uStart += length; + } + break; + } + symbol += symbolCount; + rankStart += symbolCount * length; + } + } + return iSize; +} + +FORCE_INLINE_TEMPLATE BYTE +HUF_decodeSymbolX1(BIT_DStream_t* Dstream, const HUF_DEltX1* dt, const U32 dtLog) +{ + size_t const val = BIT_lookBitsFast(Dstream, dtLog); /* note : dtLog >= 1 */ + BYTE const c = dt[val].byte; + BIT_skipBits(Dstream, dt[val].nbBits); + return c; +} + +#define HUF_DECODE_SYMBOLX1_0(ptr, DStreamPtr) \ + *ptr++ = HUF_decodeSymbolX1(DStreamPtr, dt, dtLog) + +#define HUF_DECODE_SYMBOLX1_1(ptr, DStreamPtr) \ + if (MEM_64bits() || (HUF_TABLELOG_MAX<=12)) \ + HUF_DECODE_SYMBOLX1_0(ptr, DStreamPtr) + +#define HUF_DECODE_SYMBOLX1_2(ptr, DStreamPtr) \ + if (MEM_64bits()) \ + HUF_DECODE_SYMBOLX1_0(ptr, DStreamPtr) + +HINT_INLINE size_t +HUF_decodeStreamX1(BYTE* p, BIT_DStream_t* const bitDPtr, BYTE* const pEnd, const HUF_DEltX1* const dt, const U32 dtLog) +{ + BYTE* const pStart = p; + + /* up to 4 symbols at a time */ + if ((pEnd - p) > 3) { + while ((BIT_reloadDStream(bitDPtr) == BIT_DStream_unfinished) & (p < pEnd-3)) { + HUF_DECODE_SYMBOLX1_2(p, bitDPtr); + HUF_DECODE_SYMBOLX1_1(p, bitDPtr); + HUF_DECODE_SYMBOLX1_2(p, bitDPtr); + HUF_DECODE_SYMBOLX1_0(p, bitDPtr); + } + } else { + BIT_reloadDStream(bitDPtr); + } + + /* [0-3] symbols remaining */ + if (MEM_32bits()) + while ((BIT_reloadDStream(bitDPtr) == BIT_DStream_unfinished) & (p < pEnd)) + HUF_DECODE_SYMBOLX1_0(p, bitDPtr); + + /* no more data to retrieve from bitstream, no need to reload */ + while (p < pEnd) + HUF_DECODE_SYMBOLX1_0(p, bitDPtr); + + return pEnd-pStart; +} + +FORCE_INLINE_TEMPLATE size_t +HUF_decompress1X1_usingDTable_internal_body( + void* dst, size_t dstSize, + const void* cSrc, size_t cSrcSize, + const HUF_DTable* DTable) +{ + BYTE* op = (BYTE*)dst; + BYTE* const oend = op + dstSize; + const void* dtPtr = DTable + 1; + const HUF_DEltX1* const dt = (const HUF_DEltX1*)dtPtr; + BIT_DStream_t bitD; + DTableDesc const dtd = HUF_getDTableDesc(DTable); + U32 const dtLog = dtd.tableLog; + + CHECK_F( BIT_initDStream(&bitD, cSrc, cSrcSize) ); + + HUF_decodeStreamX1(op, &bitD, oend, dt, dtLog); + + if (!BIT_endOfDStream(&bitD)) return ERROR(corruption_detected); + + return dstSize; +} + +FORCE_INLINE_TEMPLATE size_t +HUF_decompress4X1_usingDTable_internal_body( + void* dst, size_t dstSize, + const void* cSrc, size_t cSrcSize, + const HUF_DTable* DTable) +{ + /* Check */ + if (cSrcSize < 10) return ERROR(corruption_detected); /* strict minimum : jump table + 1 byte per stream */ + + { const BYTE* const istart = (const BYTE*) cSrc; + BYTE* const ostart = (BYTE*) dst; + BYTE* const oend = ostart + dstSize; + BYTE* const olimit = oend - 3; + const void* const dtPtr = DTable + 1; + const HUF_DEltX1* const dt = (const HUF_DEltX1*)dtPtr; + + /* Init */ + BIT_DStream_t bitD1; + BIT_DStream_t bitD2; + BIT_DStream_t bitD3; + BIT_DStream_t bitD4; + size_t const length1 = MEM_readLE16(istart); + size_t const length2 = MEM_readLE16(istart+2); + size_t const length3 = MEM_readLE16(istart+4); + size_t const length4 = cSrcSize - (length1 + length2 + length3 + 6); + const BYTE* const istart1 = istart + 6; /* jumpTable */ + const BYTE* const istart2 = istart1 + length1; + const BYTE* const istart3 = istart2 + length2; + const BYTE* const istart4 = istart3 + length3; + const size_t segmentSize = (dstSize+3) / 4; + BYTE* const opStart2 = ostart + segmentSize; + BYTE* const opStart3 = opStart2 + segmentSize; + BYTE* const opStart4 = opStart3 + segmentSize; + BYTE* op1 = ostart; + BYTE* op2 = opStart2; + BYTE* op3 = opStart3; + BYTE* op4 = opStart4; + DTableDesc const dtd = HUF_getDTableDesc(DTable); + U32 const dtLog = dtd.tableLog; + U32 endSignal = 1; + + if (length4 > cSrcSize) return ERROR(corruption_detected); /* overflow */ + if (opStart4 > oend) return ERROR(corruption_detected); /* overflow */ + CHECK_F( BIT_initDStream(&bitD1, istart1, length1) ); + CHECK_F( BIT_initDStream(&bitD2, istart2, length2) ); + CHECK_F( BIT_initDStream(&bitD3, istart3, length3) ); + CHECK_F( BIT_initDStream(&bitD4, istart4, length4) ); + + /* up to 16 symbols per loop (4 symbols per stream) in 64-bit mode */ + if ((size_t)(oend - op4) >= sizeof(size_t)) { + for ( ; (endSignal) & (op4 < olimit) ; ) { + HUF_DECODE_SYMBOLX1_2(op1, &bitD1); + HUF_DECODE_SYMBOLX1_2(op2, &bitD2); + HUF_DECODE_SYMBOLX1_2(op3, &bitD3); + HUF_DECODE_SYMBOLX1_2(op4, &bitD4); + HUF_DECODE_SYMBOLX1_1(op1, &bitD1); + HUF_DECODE_SYMBOLX1_1(op2, &bitD2); + HUF_DECODE_SYMBOLX1_1(op3, &bitD3); + HUF_DECODE_SYMBOLX1_1(op4, &bitD4); + HUF_DECODE_SYMBOLX1_2(op1, &bitD1); + HUF_DECODE_SYMBOLX1_2(op2, &bitD2); + HUF_DECODE_SYMBOLX1_2(op3, &bitD3); + HUF_DECODE_SYMBOLX1_2(op4, &bitD4); + HUF_DECODE_SYMBOLX1_0(op1, &bitD1); + HUF_DECODE_SYMBOLX1_0(op2, &bitD2); + HUF_DECODE_SYMBOLX1_0(op3, &bitD3); + HUF_DECODE_SYMBOLX1_0(op4, &bitD4); + endSignal &= BIT_reloadDStreamFast(&bitD1) == BIT_DStream_unfinished; + endSignal &= BIT_reloadDStreamFast(&bitD2) == BIT_DStream_unfinished; + endSignal &= BIT_reloadDStreamFast(&bitD3) == BIT_DStream_unfinished; + endSignal &= BIT_reloadDStreamFast(&bitD4) == BIT_DStream_unfinished; + } + } + + /* check corruption */ + /* note : should not be necessary : op# advance in lock step, and we control op4. + * but curiously, binary generated by gcc 7.2 & 7.3 with -mbmi2 runs faster when >=1 test is present */ + if (op1 > opStart2) return ERROR(corruption_detected); + if (op2 > opStart3) return ERROR(corruption_detected); + if (op3 > opStart4) return ERROR(corruption_detected); + /* note : op4 supposed already verified within main loop */ + + /* finish bitStreams one by one */ + HUF_decodeStreamX1(op1, &bitD1, opStart2, dt, dtLog); + HUF_decodeStreamX1(op2, &bitD2, opStart3, dt, dtLog); + HUF_decodeStreamX1(op3, &bitD3, opStart4, dt, dtLog); + HUF_decodeStreamX1(op4, &bitD4, oend, dt, dtLog); + + /* check */ + { U32 const endCheck = BIT_endOfDStream(&bitD1) & BIT_endOfDStream(&bitD2) & BIT_endOfDStream(&bitD3) & BIT_endOfDStream(&bitD4); + if (!endCheck) return ERROR(corruption_detected); } + + /* decoded size */ + return dstSize; + } +} + +#if HUF_NEED_BMI2_FUNCTION +static BMI2_TARGET_ATTRIBUTE +size_t HUF_decompress4X1_usingDTable_internal_bmi2(void* dst, size_t dstSize, void const* cSrc, + size_t cSrcSize, HUF_DTable const* DTable) { + return HUF_decompress4X1_usingDTable_internal_body(dst, dstSize, cSrc, cSrcSize, DTable); +} +#endif + +#if HUF_NEED_DEFAULT_FUNCTION +static +size_t HUF_decompress4X1_usingDTable_internal_default(void* dst, size_t dstSize, void const* cSrc, + size_t cSrcSize, HUF_DTable const* DTable) { + return HUF_decompress4X1_usingDTable_internal_body(dst, dstSize, cSrc, cSrcSize, DTable); +} +#endif + +#if ZSTD_ENABLE_ASM_X86_64_BMI2 + +HUF_ASM_DECL void HUF_decompress4X1_usingDTable_internal_bmi2_asm_loop(HUF_DecompressAsmArgs* args) ZSTDLIB_HIDDEN; + +static HUF_ASM_X86_64_BMI2_ATTRS +size_t +HUF_decompress4X1_usingDTable_internal_bmi2_asm( + void* dst, size_t dstSize, + const void* cSrc, size_t cSrcSize, + const HUF_DTable* DTable) +{ + void const* dt = DTable + 1; + const BYTE* const iend = (const BYTE*)cSrc + 6; + BYTE* const oend = (BYTE*)dst + dstSize; + HUF_DecompressAsmArgs args; + { + size_t const ret = HUF_DecompressAsmArgs_init(&args, dst, dstSize, cSrc, cSrcSize, DTable); + FORWARD_IF_ERROR(ret, "Failed to init asm args"); + if (ret != 0) + return HUF_decompress4X1_usingDTable_internal_bmi2(dst, dstSize, cSrc, cSrcSize, DTable); + } + + assert(args.ip[0] >= args.ilimit); + HUF_decompress4X1_usingDTable_internal_bmi2_asm_loop(&args); + + /* Our loop guarantees that ip[] >= ilimit and that we haven't + * overwritten any op[]. + */ + assert(args.ip[0] >= iend); + assert(args.ip[1] >= iend); + assert(args.ip[2] >= iend); + assert(args.ip[3] >= iend); + assert(args.op[3] <= oend); + (void)iend; + + /* finish bit streams one by one. */ + { + size_t const segmentSize = (dstSize+3) / 4; + BYTE* segmentEnd = (BYTE*)dst; + int i; + for (i = 0; i < 4; ++i) { + BIT_DStream_t bit; + if (segmentSize <= (size_t)(oend - segmentEnd)) + segmentEnd += segmentSize; + else + segmentEnd = oend; + FORWARD_IF_ERROR(HUF_initRemainingDStream(&bit, &args, i, segmentEnd), "corruption"); + /* Decompress and validate that we've produced exactly the expected length. */ + args.op[i] += HUF_decodeStreamX1(args.op[i], &bit, segmentEnd, (HUF_DEltX1 const*)dt, HUF_DECODER_FAST_TABLELOG); + if (args.op[i] != segmentEnd) return ERROR(corruption_detected); + } + } + + /* decoded size */ + return dstSize; +} +#endif /* ZSTD_ENABLE_ASM_X86_64_BMI2 */ + +typedef size_t (*HUF_decompress_usingDTable_t)(void *dst, size_t dstSize, + const void *cSrc, + size_t cSrcSize, + const HUF_DTable *DTable); + +HUF_DGEN(HUF_decompress1X1_usingDTable_internal) + +static size_t HUF_decompress4X1_usingDTable_internal(void* dst, size_t dstSize, void const* cSrc, + size_t cSrcSize, HUF_DTable const* DTable, int bmi2) +{ +#if DYNAMIC_BMI2 + if (bmi2) { +# if ZSTD_ENABLE_ASM_X86_64_BMI2 + return HUF_decompress4X1_usingDTable_internal_bmi2_asm(dst, dstSize, cSrc, cSrcSize, DTable); +# else + return HUF_decompress4X1_usingDTable_internal_bmi2(dst, dstSize, cSrc, cSrcSize, DTable); +# endif + } +#else + (void)bmi2; +#endif + +#if ZSTD_ENABLE_ASM_X86_64_BMI2 && defined(__BMI2__) + return HUF_decompress4X1_usingDTable_internal_bmi2_asm(dst, dstSize, cSrc, cSrcSize, DTable); +#else + return HUF_decompress4X1_usingDTable_internal_default(dst, dstSize, cSrc, cSrcSize, DTable); +#endif +} + + +size_t HUF_decompress1X1_usingDTable( + void* dst, size_t dstSize, + const void* cSrc, size_t cSrcSize, + const HUF_DTable* DTable) +{ + DTableDesc dtd = HUF_getDTableDesc(DTable); + if (dtd.tableType != 0) return ERROR(GENERIC); + return HUF_decompress1X1_usingDTable_internal(dst, dstSize, cSrc, cSrcSize, DTable, /* bmi2 */ 0); +} + +size_t HUF_decompress1X1_DCtx_wksp(HUF_DTable* DCtx, void* dst, size_t dstSize, + const void* cSrc, size_t cSrcSize, + void* workSpace, size_t wkspSize) +{ + const BYTE* ip = (const BYTE*) cSrc; + + size_t const hSize = HUF_readDTableX1_wksp(DCtx, cSrc, cSrcSize, workSpace, wkspSize); + if (HUF_isError(hSize)) return hSize; + if (hSize >= cSrcSize) return ERROR(srcSize_wrong); + ip += hSize; cSrcSize -= hSize; + + return HUF_decompress1X1_usingDTable_internal(dst, dstSize, ip, cSrcSize, DCtx, /* bmi2 */ 0); +} + + +size_t HUF_decompress4X1_usingDTable( + void* dst, size_t dstSize, + const void* cSrc, size_t cSrcSize, + const HUF_DTable* DTable) +{ + DTableDesc dtd = HUF_getDTableDesc(DTable); + if (dtd.tableType != 0) return ERROR(GENERIC); + return HUF_decompress4X1_usingDTable_internal(dst, dstSize, cSrc, cSrcSize, DTable, /* bmi2 */ 0); +} + +static size_t HUF_decompress4X1_DCtx_wksp_bmi2(HUF_DTable* dctx, void* dst, size_t dstSize, + const void* cSrc, size_t cSrcSize, + void* workSpace, size_t wkspSize, int bmi2) +{ + const BYTE* ip = (const BYTE*) cSrc; + + size_t const hSize = HUF_readDTableX1_wksp_bmi2(dctx, cSrc, cSrcSize, workSpace, wkspSize, bmi2); + if (HUF_isError(hSize)) return hSize; + if (hSize >= cSrcSize) return ERROR(srcSize_wrong); + ip += hSize; cSrcSize -= hSize; + + return HUF_decompress4X1_usingDTable_internal(dst, dstSize, ip, cSrcSize, dctx, bmi2); +} + +size_t HUF_decompress4X1_DCtx_wksp(HUF_DTable* dctx, void* dst, size_t dstSize, + const void* cSrc, size_t cSrcSize, + void* workSpace, size_t wkspSize) +{ + return HUF_decompress4X1_DCtx_wksp_bmi2(dctx, dst, dstSize, cSrc, cSrcSize, workSpace, wkspSize, 0); +} + + +#endif /* HUF_FORCE_DECOMPRESS_X2 */ + + +#ifndef HUF_FORCE_DECOMPRESS_X1 + +/* *************************/ +/* double-symbols decoding */ +/* *************************/ + +typedef struct { U16 sequence; BYTE nbBits; BYTE length; } HUF_DEltX2; /* double-symbols decoding */ +typedef struct { BYTE symbol; } sortedSymbol_t; +typedef U32 rankValCol_t[HUF_TABLELOG_MAX + 1]; +typedef rankValCol_t rankVal_t[HUF_TABLELOG_MAX]; + +/* + * Constructs a HUF_DEltX2 in a U32. + */ +static U32 HUF_buildDEltX2U32(U32 symbol, U32 nbBits, U32 baseSeq, int level) +{ + U32 seq; + DEBUG_STATIC_ASSERT(offsetof(HUF_DEltX2, sequence) == 0); + DEBUG_STATIC_ASSERT(offsetof(HUF_DEltX2, nbBits) == 2); + DEBUG_STATIC_ASSERT(offsetof(HUF_DEltX2, length) == 3); + DEBUG_STATIC_ASSERT(sizeof(HUF_DEltX2) == sizeof(U32)); + if (MEM_isLittleEndian()) { + seq = level == 1 ? symbol : (baseSeq + (symbol << 8)); + return seq + (nbBits << 16) + ((U32)level << 24); + } else { + seq = level == 1 ? (symbol << 8) : ((baseSeq << 8) + symbol); + return (seq << 16) + (nbBits << 8) + (U32)level; + } +} + +/* + * Constructs a HUF_DEltX2. + */ +static HUF_DEltX2 HUF_buildDEltX2(U32 symbol, U32 nbBits, U32 baseSeq, int level) +{ + HUF_DEltX2 DElt; + U32 const val = HUF_buildDEltX2U32(symbol, nbBits, baseSeq, level); + DEBUG_STATIC_ASSERT(sizeof(DElt) == sizeof(val)); + ZSTD_memcpy(&DElt, &val, sizeof(val)); + return DElt; +} + +/* + * Constructs 2 HUF_DEltX2s and packs them into a U64. + */ +static U64 HUF_buildDEltX2U64(U32 symbol, U32 nbBits, U16 baseSeq, int level) +{ + U32 DElt = HUF_buildDEltX2U32(symbol, nbBits, baseSeq, level); + return (U64)DElt + ((U64)DElt << 32); +} + +/* + * Fills the DTable rank with all the symbols from [begin, end) that are each + * nbBits long. + * + * @param DTableRank The start of the rank in the DTable. + * @param begin The first symbol to fill (inclusive). + * @param end The last symbol to fill (exclusive). + * @param nbBits Each symbol is nbBits long. + * @param tableLog The table log. + * @param baseSeq If level == 1 { 0 } else { the first level symbol } + * @param level The level in the table. Must be 1 or 2. + */ +static void HUF_fillDTableX2ForWeight( + HUF_DEltX2* DTableRank, + sortedSymbol_t const* begin, sortedSymbol_t const* end, + U32 nbBits, U32 tableLog, + U16 baseSeq, int const level) +{ + U32 const length = 1U << ((tableLog - nbBits) & 0x1F /* quiet static-analyzer */); + const sortedSymbol_t* ptr; + assert(level >= 1 && level <= 2); + switch (length) { + case 1: + for (ptr = begin; ptr != end; ++ptr) { + HUF_DEltX2 const DElt = HUF_buildDEltX2(ptr->symbol, nbBits, baseSeq, level); + *DTableRank++ = DElt; + } + break; + case 2: + for (ptr = begin; ptr != end; ++ptr) { + HUF_DEltX2 const DElt = HUF_buildDEltX2(ptr->symbol, nbBits, baseSeq, level); + DTableRank[0] = DElt; + DTableRank[1] = DElt; + DTableRank += 2; + } + break; + case 4: + for (ptr = begin; ptr != end; ++ptr) { + U64 const DEltX2 = HUF_buildDEltX2U64(ptr->symbol, nbBits, baseSeq, level); + ZSTD_memcpy(DTableRank + 0, &DEltX2, sizeof(DEltX2)); + ZSTD_memcpy(DTableRank + 2, &DEltX2, sizeof(DEltX2)); + DTableRank += 4; + } + break; + case 8: + for (ptr = begin; ptr != end; ++ptr) { + U64 const DEltX2 = HUF_buildDEltX2U64(ptr->symbol, nbBits, baseSeq, level); + ZSTD_memcpy(DTableRank + 0, &DEltX2, sizeof(DEltX2)); + ZSTD_memcpy(DTableRank + 2, &DEltX2, sizeof(DEltX2)); + ZSTD_memcpy(DTableRank + 4, &DEltX2, sizeof(DEltX2)); + ZSTD_memcpy(DTableRank + 6, &DEltX2, sizeof(DEltX2)); + DTableRank += 8; + } + break; + default: + for (ptr = begin; ptr != end; ++ptr) { + U64 const DEltX2 = HUF_buildDEltX2U64(ptr->symbol, nbBits, baseSeq, level); + HUF_DEltX2* const DTableRankEnd = DTableRank + length; + for (; DTableRank != DTableRankEnd; DTableRank += 8) { + ZSTD_memcpy(DTableRank + 0, &DEltX2, sizeof(DEltX2)); + ZSTD_memcpy(DTableRank + 2, &DEltX2, sizeof(DEltX2)); + ZSTD_memcpy(DTableRank + 4, &DEltX2, sizeof(DEltX2)); + ZSTD_memcpy(DTableRank + 6, &DEltX2, sizeof(DEltX2)); + } + } + break; + } +} + +/* HUF_fillDTableX2Level2() : + * `rankValOrigin` must be a table of at least (HUF_TABLELOG_MAX + 1) U32 */ +static void HUF_fillDTableX2Level2(HUF_DEltX2* DTable, U32 targetLog, const U32 consumedBits, + const U32* rankVal, const int minWeight, const int maxWeight1, + const sortedSymbol_t* sortedSymbols, U32 const* rankStart, + U32 nbBitsBaseline, U16 baseSeq) +{ + /* Fill skipped values (all positions up to rankVal[minWeight]). + * These are positions only get a single symbol because the combined weight + * is too large. + */ + if (minWeight>1) { + U32 const length = 1U << ((targetLog - consumedBits) & 0x1F /* quiet static-analyzer */); + U64 const DEltX2 = HUF_buildDEltX2U64(baseSeq, consumedBits, /* baseSeq */ 0, /* level */ 1); + int const skipSize = rankVal[minWeight]; + assert(length > 1); + assert((U32)skipSize < length); + switch (length) { + case 2: + assert(skipSize == 1); + ZSTD_memcpy(DTable, &DEltX2, sizeof(DEltX2)); + break; + case 4: + assert(skipSize <= 4); + ZSTD_memcpy(DTable + 0, &DEltX2, sizeof(DEltX2)); + ZSTD_memcpy(DTable + 2, &DEltX2, sizeof(DEltX2)); + break; + default: + { + int i; + for (i = 0; i < skipSize; i += 8) { + ZSTD_memcpy(DTable + i + 0, &DEltX2, sizeof(DEltX2)); + ZSTD_memcpy(DTable + i + 2, &DEltX2, sizeof(DEltX2)); + ZSTD_memcpy(DTable + i + 4, &DEltX2, sizeof(DEltX2)); + ZSTD_memcpy(DTable + i + 6, &DEltX2, sizeof(DEltX2)); + } + } + } + } + + /* Fill each of the second level symbols by weight. */ + { + int w; + for (w = minWeight; w < maxWeight1; ++w) { + int const begin = rankStart[w]; + int const end = rankStart[w+1]; + U32 const nbBits = nbBitsBaseline - w; + U32 const totalBits = nbBits + consumedBits; + HUF_fillDTableX2ForWeight( + DTable + rankVal[w], + sortedSymbols + begin, sortedSymbols + end, + totalBits, targetLog, + baseSeq, /* level */ 2); + } + } +} + +static void HUF_fillDTableX2(HUF_DEltX2* DTable, const U32 targetLog, + const sortedSymbol_t* sortedList, + const U32* rankStart, rankVal_t rankValOrigin, const U32 maxWeight, + const U32 nbBitsBaseline) +{ + U32* const rankVal = rankValOrigin[0]; + const int scaleLog = nbBitsBaseline - targetLog; /* note : targetLog >= srcLog, hence scaleLog <= 1 */ + const U32 minBits = nbBitsBaseline - maxWeight; + int w; + int const wEnd = (int)maxWeight + 1; + + /* Fill DTable in order of weight. */ + for (w = 1; w < wEnd; ++w) { + int const begin = (int)rankStart[w]; + int const end = (int)rankStart[w+1]; + U32 const nbBits = nbBitsBaseline - w; + + if (targetLog-nbBits >= minBits) { + /* Enough room for a second symbol. */ + int start = rankVal[w]; + U32 const length = 1U << ((targetLog - nbBits) & 0x1F /* quiet static-analyzer */); + int minWeight = nbBits + scaleLog; + int s; + if (minWeight < 1) minWeight = 1; + /* Fill the DTable for every symbol of weight w. + * These symbols get at least 1 second symbol. + */ + for (s = begin; s != end; ++s) { + HUF_fillDTableX2Level2( + DTable + start, targetLog, nbBits, + rankValOrigin[nbBits], minWeight, wEnd, + sortedList, rankStart, + nbBitsBaseline, sortedList[s].symbol); + start += length; + } + } else { + /* Only a single symbol. */ + HUF_fillDTableX2ForWeight( + DTable + rankVal[w], + sortedList + begin, sortedList + end, + nbBits, targetLog, + /* baseSeq */ 0, /* level */ 1); + } + } +} + +typedef struct { + rankValCol_t rankVal[HUF_TABLELOG_MAX]; + U32 rankStats[HUF_TABLELOG_MAX + 1]; + U32 rankStart0[HUF_TABLELOG_MAX + 3]; + sortedSymbol_t sortedSymbol[HUF_SYMBOLVALUE_MAX + 1]; + BYTE weightList[HUF_SYMBOLVALUE_MAX + 1]; + U32 calleeWksp[HUF_READ_STATS_WORKSPACE_SIZE_U32]; +} HUF_ReadDTableX2_Workspace; + +size_t HUF_readDTableX2_wksp(HUF_DTable* DTable, + const void* src, size_t srcSize, + void* workSpace, size_t wkspSize) +{ + return HUF_readDTableX2_wksp_bmi2(DTable, src, srcSize, workSpace, wkspSize, /* bmi2 */ 0); +} + +size_t HUF_readDTableX2_wksp_bmi2(HUF_DTable* DTable, + const void* src, size_t srcSize, + void* workSpace, size_t wkspSize, int bmi2) +{ + U32 tableLog, maxW, nbSymbols; + DTableDesc dtd = HUF_getDTableDesc(DTable); + U32 maxTableLog = dtd.maxTableLog; + size_t iSize; + void* dtPtr = DTable+1; /* force compiler to avoid strict-aliasing */ + HUF_DEltX2* const dt = (HUF_DEltX2*)dtPtr; + U32 *rankStart; + + HUF_ReadDTableX2_Workspace* const wksp = (HUF_ReadDTableX2_Workspace*)workSpace; + + if (sizeof(*wksp) > wkspSize) return ERROR(GENERIC); + + rankStart = wksp->rankStart0 + 1; + ZSTD_memset(wksp->rankStats, 0, sizeof(wksp->rankStats)); + ZSTD_memset(wksp->rankStart0, 0, sizeof(wksp->rankStart0)); + + DEBUG_STATIC_ASSERT(sizeof(HUF_DEltX2) == sizeof(HUF_DTable)); /* if compiler fails here, assertion is wrong */ + if (maxTableLog > HUF_TABLELOG_MAX) return ERROR(tableLog_tooLarge); + /* ZSTD_memset(weightList, 0, sizeof(weightList)); */ /* is not necessary, even though some analyzer complain ... */ + + iSize = HUF_readStats_wksp(wksp->weightList, HUF_SYMBOLVALUE_MAX + 1, wksp->rankStats, &nbSymbols, &tableLog, src, srcSize, wksp->calleeWksp, sizeof(wksp->calleeWksp), bmi2); + if (HUF_isError(iSize)) return iSize; + + /* check result */ + if (tableLog > maxTableLog) return ERROR(tableLog_tooLarge); /* DTable can't fit code depth */ + if (tableLog <= HUF_DECODER_FAST_TABLELOG && maxTableLog > HUF_DECODER_FAST_TABLELOG) maxTableLog = HUF_DECODER_FAST_TABLELOG; + + /* find maxWeight */ + for (maxW = tableLog; wksp->rankStats[maxW]==0; maxW--) {} /* necessarily finds a solution before 0 */ + + /* Get start index of each weight */ + { U32 w, nextRankStart = 0; + for (w=1; w<maxW+1; w++) { + U32 curr = nextRankStart; + nextRankStart += wksp->rankStats[w]; + rankStart[w] = curr; + } + rankStart[0] = nextRankStart; /* put all 0w symbols at the end of sorted list*/ + rankStart[maxW+1] = nextRankStart; + } + + /* sort symbols by weight */ + { U32 s; + for (s=0; s<nbSymbols; s++) { + U32 const w = wksp->weightList[s]; + U32 const r = rankStart[w]++; + wksp->sortedSymbol[r].symbol = (BYTE)s; + } + rankStart[0] = 0; /* forget 0w symbols; this is beginning of weight(1) */ + } + + /* Build rankVal */ + { U32* const rankVal0 = wksp->rankVal[0]; + { int const rescale = (maxTableLog-tableLog) - 1; /* tableLog <= maxTableLog */ + U32 nextRankVal = 0; + U32 w; + for (w=1; w<maxW+1; w++) { + U32 curr = nextRankVal; + nextRankVal += wksp->rankStats[w] << (w+rescale); + rankVal0[w] = curr; + } } + { U32 const minBits = tableLog+1 - maxW; + U32 consumed; + for (consumed = minBits; consumed < maxTableLog - minBits + 1; consumed++) { + U32* const rankValPtr = wksp->rankVal[consumed]; + U32 w; + for (w = 1; w < maxW+1; w++) { + rankValPtr[w] = rankVal0[w] >> consumed; + } } } } + + HUF_fillDTableX2(dt, maxTableLog, + wksp->sortedSymbol, + wksp->rankStart0, wksp->rankVal, maxW, + tableLog+1); + + dtd.tableLog = (BYTE)maxTableLog; + dtd.tableType = 1; + ZSTD_memcpy(DTable, &dtd, sizeof(dtd)); + return iSize; +} + + +FORCE_INLINE_TEMPLATE U32 +HUF_decodeSymbolX2(void* op, BIT_DStream_t* DStream, const HUF_DEltX2* dt, const U32 dtLog) +{ + size_t const val = BIT_lookBitsFast(DStream, dtLog); /* note : dtLog >= 1 */ + ZSTD_memcpy(op, &dt[val].sequence, 2); + BIT_skipBits(DStream, dt[val].nbBits); + return dt[val].length; +} + +FORCE_INLINE_TEMPLATE U32 +HUF_decodeLastSymbolX2(void* op, BIT_DStream_t* DStream, const HUF_DEltX2* dt, const U32 dtLog) +{ + size_t const val = BIT_lookBitsFast(DStream, dtLog); /* note : dtLog >= 1 */ + ZSTD_memcpy(op, &dt[val].sequence, 1); + if (dt[val].length==1) { + BIT_skipBits(DStream, dt[val].nbBits); + } else { + if (DStream->bitsConsumed < (sizeof(DStream->bitContainer)*8)) { + BIT_skipBits(DStream, dt[val].nbBits); + if (DStream->bitsConsumed > (sizeof(DStream->bitContainer)*8)) + /* ugly hack; works only because it's the last symbol. Note : can't easily extract nbBits from just this symbol */ + DStream->bitsConsumed = (sizeof(DStream->bitContainer)*8); + } + } + return 1; +} + +#define HUF_DECODE_SYMBOLX2_0(ptr, DStreamPtr) \ + ptr += HUF_decodeSymbolX2(ptr, DStreamPtr, dt, dtLog) + +#define HUF_DECODE_SYMBOLX2_1(ptr, DStreamPtr) \ + if (MEM_64bits() || (HUF_TABLELOG_MAX<=12)) \ + ptr += HUF_decodeSymbolX2(ptr, DStreamPtr, dt, dtLog) + +#define HUF_DECODE_SYMBOLX2_2(ptr, DStreamPtr) \ + if (MEM_64bits()) \ + ptr += HUF_decodeSymbolX2(ptr, DStreamPtr, dt, dtLog) + +HINT_INLINE size_t +HUF_decodeStreamX2(BYTE* p, BIT_DStream_t* bitDPtr, BYTE* const pEnd, + const HUF_DEltX2* const dt, const U32 dtLog) +{ + BYTE* const pStart = p; + + /* up to 8 symbols at a time */ + if ((size_t)(pEnd - p) >= sizeof(bitDPtr->bitContainer)) { + if (dtLog <= 11 && MEM_64bits()) { + /* up to 10 symbols at a time */ + while ((BIT_reloadDStream(bitDPtr) == BIT_DStream_unfinished) & (p < pEnd-9)) { + HUF_DECODE_SYMBOLX2_0(p, bitDPtr); + HUF_DECODE_SYMBOLX2_0(p, bitDPtr); + HUF_DECODE_SYMBOLX2_0(p, bitDPtr); + HUF_DECODE_SYMBOLX2_0(p, bitDPtr); + HUF_DECODE_SYMBOLX2_0(p, bitDPtr); + } + } else { + /* up to 8 symbols at a time */ + while ((BIT_reloadDStream(bitDPtr) == BIT_DStream_unfinished) & (p < pEnd-(sizeof(bitDPtr->bitContainer)-1))) { + HUF_DECODE_SYMBOLX2_2(p, bitDPtr); + HUF_DECODE_SYMBOLX2_1(p, bitDPtr); + HUF_DECODE_SYMBOLX2_2(p, bitDPtr); + HUF_DECODE_SYMBOLX2_0(p, bitDPtr); + } + } + } else { + BIT_reloadDStream(bitDPtr); + } + + /* closer to end : up to 2 symbols at a time */ + if ((size_t)(pEnd - p) >= 2) { + while ((BIT_reloadDStream(bitDPtr) == BIT_DStream_unfinished) & (p <= pEnd-2)) + HUF_DECODE_SYMBOLX2_0(p, bitDPtr); + + while (p <= pEnd-2) + HUF_DECODE_SYMBOLX2_0(p, bitDPtr); /* no need to reload : reached the end of DStream */ + } + + if (p < pEnd) + p += HUF_decodeLastSymbolX2(p, bitDPtr, dt, dtLog); + + return p-pStart; +} + +FORCE_INLINE_TEMPLATE size_t +HUF_decompress1X2_usingDTable_internal_body( + void* dst, size_t dstSize, + const void* cSrc, size_t cSrcSize, + const HUF_DTable* DTable) +{ + BIT_DStream_t bitD; + + /* Init */ + CHECK_F( BIT_initDStream(&bitD, cSrc, cSrcSize) ); + + /* decode */ + { BYTE* const ostart = (BYTE*) dst; + BYTE* const oend = ostart + dstSize; + const void* const dtPtr = DTable+1; /* force compiler to not use strict-aliasing */ + const HUF_DEltX2* const dt = (const HUF_DEltX2*)dtPtr; + DTableDesc const dtd = HUF_getDTableDesc(DTable); + HUF_decodeStreamX2(ostart, &bitD, oend, dt, dtd.tableLog); + } + + /* check */ + if (!BIT_endOfDStream(&bitD)) return ERROR(corruption_detected); + + /* decoded size */ + return dstSize; +} +FORCE_INLINE_TEMPLATE size_t +HUF_decompress4X2_usingDTable_internal_body( + void* dst, size_t dstSize, + const void* cSrc, size_t cSrcSize, + const HUF_DTable* DTable) +{ + if (cSrcSize < 10) return ERROR(corruption_detected); /* strict minimum : jump table + 1 byte per stream */ + + { const BYTE* const istart = (const BYTE*) cSrc; + BYTE* const ostart = (BYTE*) dst; + BYTE* const oend = ostart + dstSize; + BYTE* const olimit = oend - (sizeof(size_t)-1); + const void* const dtPtr = DTable+1; + const HUF_DEltX2* const dt = (const HUF_DEltX2*)dtPtr; + + /* Init */ + BIT_DStream_t bitD1; + BIT_DStream_t bitD2; + BIT_DStream_t bitD3; + BIT_DStream_t bitD4; + size_t const length1 = MEM_readLE16(istart); + size_t const length2 = MEM_readLE16(istart+2); + size_t const length3 = MEM_readLE16(istart+4); + size_t const length4 = cSrcSize - (length1 + length2 + length3 + 6); + const BYTE* const istart1 = istart + 6; /* jumpTable */ + const BYTE* const istart2 = istart1 + length1; + const BYTE* const istart3 = istart2 + length2; + const BYTE* const istart4 = istart3 + length3; + size_t const segmentSize = (dstSize+3) / 4; + BYTE* const opStart2 = ostart + segmentSize; + BYTE* const opStart3 = opStart2 + segmentSize; + BYTE* const opStart4 = opStart3 + segmentSize; + BYTE* op1 = ostart; + BYTE* op2 = opStart2; + BYTE* op3 = opStart3; + BYTE* op4 = opStart4; + U32 endSignal = 1; + DTableDesc const dtd = HUF_getDTableDesc(DTable); + U32 const dtLog = dtd.tableLog; + + if (length4 > cSrcSize) return ERROR(corruption_detected); /* overflow */ + if (opStart4 > oend) return ERROR(corruption_detected); /* overflow */ + CHECK_F( BIT_initDStream(&bitD1, istart1, length1) ); + CHECK_F( BIT_initDStream(&bitD2, istart2, length2) ); + CHECK_F( BIT_initDStream(&bitD3, istart3, length3) ); + CHECK_F( BIT_initDStream(&bitD4, istart4, length4) ); + + /* 16-32 symbols per loop (4-8 symbols per stream) */ + if ((size_t)(oend - op4) >= sizeof(size_t)) { + for ( ; (endSignal) & (op4 < olimit); ) { +#if defined(__clang__) && (defined(__x86_64__) || defined(__i386__)) + HUF_DECODE_SYMBOLX2_2(op1, &bitD1); + HUF_DECODE_SYMBOLX2_1(op1, &bitD1); + HUF_DECODE_SYMBOLX2_2(op1, &bitD1); + HUF_DECODE_SYMBOLX2_0(op1, &bitD1); + HUF_DECODE_SYMBOLX2_2(op2, &bitD2); + HUF_DECODE_SYMBOLX2_1(op2, &bitD2); + HUF_DECODE_SYMBOLX2_2(op2, &bitD2); + HUF_DECODE_SYMBOLX2_0(op2, &bitD2); + endSignal &= BIT_reloadDStreamFast(&bitD1) == BIT_DStream_unfinished; + endSignal &= BIT_reloadDStreamFast(&bitD2) == BIT_DStream_unfinished; + HUF_DECODE_SYMBOLX2_2(op3, &bitD3); + HUF_DECODE_SYMBOLX2_1(op3, &bitD3); + HUF_DECODE_SYMBOLX2_2(op3, &bitD3); + HUF_DECODE_SYMBOLX2_0(op3, &bitD3); + HUF_DECODE_SYMBOLX2_2(op4, &bitD4); + HUF_DECODE_SYMBOLX2_1(op4, &bitD4); + HUF_DECODE_SYMBOLX2_2(op4, &bitD4); + HUF_DECODE_SYMBOLX2_0(op4, &bitD4); + endSignal &= BIT_reloadDStreamFast(&bitD3) == BIT_DStream_unfinished; + endSignal &= BIT_reloadDStreamFast(&bitD4) == BIT_DStream_unfinished; +#else + HUF_DECODE_SYMBOLX2_2(op1, &bitD1); + HUF_DECODE_SYMBOLX2_2(op2, &bitD2); + HUF_DECODE_SYMBOLX2_2(op3, &bitD3); + HUF_DECODE_SYMBOLX2_2(op4, &bitD4); + HUF_DECODE_SYMBOLX2_1(op1, &bitD1); + HUF_DECODE_SYMBOLX2_1(op2, &bitD2); + HUF_DECODE_SYMBOLX2_1(op3, &bitD3); + HUF_DECODE_SYMBOLX2_1(op4, &bitD4); + HUF_DECODE_SYMBOLX2_2(op1, &bitD1); + HUF_DECODE_SYMBOLX2_2(op2, &bitD2); + HUF_DECODE_SYMBOLX2_2(op3, &bitD3); + HUF_DECODE_SYMBOLX2_2(op4, &bitD4); + HUF_DECODE_SYMBOLX2_0(op1, &bitD1); + HUF_DECODE_SYMBOLX2_0(op2, &bitD2); + HUF_DECODE_SYMBOLX2_0(op3, &bitD3); + HUF_DECODE_SYMBOLX2_0(op4, &bitD4); + endSignal = (U32)LIKELY((U32) + (BIT_reloadDStreamFast(&bitD1) == BIT_DStream_unfinished) + & (BIT_reloadDStreamFast(&bitD2) == BIT_DStream_unfinished) + & (BIT_reloadDStreamFast(&bitD3) == BIT_DStream_unfinished) + & (BIT_reloadDStreamFast(&bitD4) == BIT_DStream_unfinished)); +#endif + } + } + + /* check corruption */ + if (op1 > opStart2) return ERROR(corruption_detected); + if (op2 > opStart3) return ERROR(corruption_detected); + if (op3 > opStart4) return ERROR(corruption_detected); + /* note : op4 already verified within main loop */ + + /* finish bitStreams one by one */ + HUF_decodeStreamX2(op1, &bitD1, opStart2, dt, dtLog); + HUF_decodeStreamX2(op2, &bitD2, opStart3, dt, dtLog); + HUF_decodeStreamX2(op3, &bitD3, opStart4, dt, dtLog); + HUF_decodeStreamX2(op4, &bitD4, oend, dt, dtLog); + + /* check */ + { U32 const endCheck = BIT_endOfDStream(&bitD1) & BIT_endOfDStream(&bitD2) & BIT_endOfDStream(&bitD3) & BIT_endOfDStream(&bitD4); + if (!endCheck) return ERROR(corruption_detected); } + + /* decoded size */ + return dstSize; + } +} + +#if HUF_NEED_BMI2_FUNCTION +static BMI2_TARGET_ATTRIBUTE +size_t HUF_decompress4X2_usingDTable_internal_bmi2(void* dst, size_t dstSize, void const* cSrc, + size_t cSrcSize, HUF_DTable const* DTable) { + return HUF_decompress4X2_usingDTable_internal_body(dst, dstSize, cSrc, cSrcSize, DTable); +} +#endif + +#if HUF_NEED_DEFAULT_FUNCTION +static +size_t HUF_decompress4X2_usingDTable_internal_default(void* dst, size_t dstSize, void const* cSrc, + size_t cSrcSize, HUF_DTable const* DTable) { + return HUF_decompress4X2_usingDTable_internal_body(dst, dstSize, cSrc, cSrcSize, DTable); +} +#endif + +#if ZSTD_ENABLE_ASM_X86_64_BMI2 + +HUF_ASM_DECL void HUF_decompress4X2_usingDTable_internal_bmi2_asm_loop(HUF_DecompressAsmArgs* args) ZSTDLIB_HIDDEN; + +static HUF_ASM_X86_64_BMI2_ATTRS size_t +HUF_decompress4X2_usingDTable_internal_bmi2_asm( + void* dst, size_t dstSize, + const void* cSrc, size_t cSrcSize, + const HUF_DTable* DTable) { + void const* dt = DTable + 1; + const BYTE* const iend = (const BYTE*)cSrc + 6; + BYTE* const oend = (BYTE*)dst + dstSize; + HUF_DecompressAsmArgs args; + { + size_t const ret = HUF_DecompressAsmArgs_init(&args, dst, dstSize, cSrc, cSrcSize, DTable); + FORWARD_IF_ERROR(ret, "Failed to init asm args"); + if (ret != 0) + return HUF_decompress4X2_usingDTable_internal_bmi2(dst, dstSize, cSrc, cSrcSize, DTable); + } + + assert(args.ip[0] >= args.ilimit); + HUF_decompress4X2_usingDTable_internal_bmi2_asm_loop(&args); + + /* note : op4 already verified within main loop */ + assert(args.ip[0] >= iend); + assert(args.ip[1] >= iend); + assert(args.ip[2] >= iend); + assert(args.ip[3] >= iend); + assert(args.op[3] <= oend); + (void)iend; + + /* finish bitStreams one by one */ + { + size_t const segmentSize = (dstSize+3) / 4; + BYTE* segmentEnd = (BYTE*)dst; + int i; + for (i = 0; i < 4; ++i) { + BIT_DStream_t bit; + if (segmentSize <= (size_t)(oend - segmentEnd)) + segmentEnd += segmentSize; + else + segmentEnd = oend; + FORWARD_IF_ERROR(HUF_initRemainingDStream(&bit, &args, i, segmentEnd), "corruption"); + args.op[i] += HUF_decodeStreamX2(args.op[i], &bit, segmentEnd, (HUF_DEltX2 const*)dt, HUF_DECODER_FAST_TABLELOG); + if (args.op[i] != segmentEnd) + return ERROR(corruption_detected); + } + } + + /* decoded size */ + return dstSize; +} +#endif /* ZSTD_ENABLE_ASM_X86_64_BMI2 */ + +static size_t HUF_decompress4X2_usingDTable_internal(void* dst, size_t dstSize, void const* cSrc, + size_t cSrcSize, HUF_DTable const* DTable, int bmi2) +{ +#if DYNAMIC_BMI2 + if (bmi2) { +# if ZSTD_ENABLE_ASM_X86_64_BMI2 + return HUF_decompress4X2_usingDTable_internal_bmi2_asm(dst, dstSize, cSrc, cSrcSize, DTable); +# else + return HUF_decompress4X2_usingDTable_internal_bmi2(dst, dstSize, cSrc, cSrcSize, DTable); +# endif + } +#else + (void)bmi2; +#endif + +#if ZSTD_ENABLE_ASM_X86_64_BMI2 && defined(__BMI2__) + return HUF_decompress4X2_usingDTable_internal_bmi2_asm(dst, dstSize, cSrc, cSrcSize, DTable); +#else + return HUF_decompress4X2_usingDTable_internal_default(dst, dstSize, cSrc, cSrcSize, DTable); +#endif +} + +HUF_DGEN(HUF_decompress1X2_usingDTable_internal) + +size_t HUF_decompress1X2_usingDTable( + void* dst, size_t dstSize, + const void* cSrc, size_t cSrcSize, + const HUF_DTable* DTable) +{ + DTableDesc dtd = HUF_getDTableDesc(DTable); + if (dtd.tableType != 1) return ERROR(GENERIC); + return HUF_decompress1X2_usingDTable_internal(dst, dstSize, cSrc, cSrcSize, DTable, /* bmi2 */ 0); +} + +size_t HUF_decompress1X2_DCtx_wksp(HUF_DTable* DCtx, void* dst, size_t dstSize, + const void* cSrc, size_t cSrcSize, + void* workSpace, size_t wkspSize) +{ + const BYTE* ip = (const BYTE*) cSrc; + + size_t const hSize = HUF_readDTableX2_wksp(DCtx, cSrc, cSrcSize, + workSpace, wkspSize); + if (HUF_isError(hSize)) return hSize; + if (hSize >= cSrcSize) return ERROR(srcSize_wrong); + ip += hSize; cSrcSize -= hSize; + + return HUF_decompress1X2_usingDTable_internal(dst, dstSize, ip, cSrcSize, DCtx, /* bmi2 */ 0); +} + + +size_t HUF_decompress4X2_usingDTable( + void* dst, size_t dstSize, + const void* cSrc, size_t cSrcSize, + const HUF_DTable* DTable) +{ + DTableDesc dtd = HUF_getDTableDesc(DTable); + if (dtd.tableType != 1) return ERROR(GENERIC); + return HUF_decompress4X2_usingDTable_internal(dst, dstSize, cSrc, cSrcSize, DTable, /* bmi2 */ 0); +} + +static size_t HUF_decompress4X2_DCtx_wksp_bmi2(HUF_DTable* dctx, void* dst, size_t dstSize, + const void* cSrc, size_t cSrcSize, + void* workSpace, size_t wkspSize, int bmi2) +{ + const BYTE* ip = (const BYTE*) cSrc; + + size_t hSize = HUF_readDTableX2_wksp(dctx, cSrc, cSrcSize, + workSpace, wkspSize); + if (HUF_isError(hSize)) return hSize; + if (hSize >= cSrcSize) return ERROR(srcSize_wrong); + ip += hSize; cSrcSize -= hSize; + + return HUF_decompress4X2_usingDTable_internal(dst, dstSize, ip, cSrcSize, dctx, bmi2); +} + +size_t HUF_decompress4X2_DCtx_wksp(HUF_DTable* dctx, void* dst, size_t dstSize, + const void* cSrc, size_t cSrcSize, + void* workSpace, size_t wkspSize) +{ + return HUF_decompress4X2_DCtx_wksp_bmi2(dctx, dst, dstSize, cSrc, cSrcSize, workSpace, wkspSize, /* bmi2 */ 0); +} + + +#endif /* HUF_FORCE_DECOMPRESS_X1 */ + + +/* ***********************************/ +/* Universal decompression selectors */ +/* ***********************************/ + +size_t HUF_decompress1X_usingDTable(void* dst, size_t maxDstSize, + const void* cSrc, size_t cSrcSize, + const HUF_DTable* DTable) +{ + DTableDesc const dtd = HUF_getDTableDesc(DTable); +#if defined(HUF_FORCE_DECOMPRESS_X1) + (void)dtd; + assert(dtd.tableType == 0); + return HUF_decompress1X1_usingDTable_internal(dst, maxDstSize, cSrc, cSrcSize, DTable, /* bmi2 */ 0); +#elif defined(HUF_FORCE_DECOMPRESS_X2) + (void)dtd; + assert(dtd.tableType == 1); + return HUF_decompress1X2_usingDTable_internal(dst, maxDstSize, cSrc, cSrcSize, DTable, /* bmi2 */ 0); +#else + return dtd.tableType ? HUF_decompress1X2_usingDTable_internal(dst, maxDstSize, cSrc, cSrcSize, DTable, /* bmi2 */ 0) : + HUF_decompress1X1_usingDTable_internal(dst, maxDstSize, cSrc, cSrcSize, DTable, /* bmi2 */ 0); +#endif +} + +size_t HUF_decompress4X_usingDTable(void* dst, size_t maxDstSize, + const void* cSrc, size_t cSrcSize, + const HUF_DTable* DTable) +{ + DTableDesc const dtd = HUF_getDTableDesc(DTable); +#if defined(HUF_FORCE_DECOMPRESS_X1) + (void)dtd; + assert(dtd.tableType == 0); + return HUF_decompress4X1_usingDTable_internal(dst, maxDstSize, cSrc, cSrcSize, DTable, /* bmi2 */ 0); +#elif defined(HUF_FORCE_DECOMPRESS_X2) + (void)dtd; + assert(dtd.tableType == 1); + return HUF_decompress4X2_usingDTable_internal(dst, maxDstSize, cSrc, cSrcSize, DTable, /* bmi2 */ 0); +#else + return dtd.tableType ? HUF_decompress4X2_usingDTable_internal(dst, maxDstSize, cSrc, cSrcSize, DTable, /* bmi2 */ 0) : + HUF_decompress4X1_usingDTable_internal(dst, maxDstSize, cSrc, cSrcSize, DTable, /* bmi2 */ 0); +#endif +} + + +#if !defined(HUF_FORCE_DECOMPRESS_X1) && !defined(HUF_FORCE_DECOMPRESS_X2) +typedef struct { U32 tableTime; U32 decode256Time; } algo_time_t; +static const algo_time_t algoTime[16 /* Quantization */][2 /* single, double */] = +{ + /* single, double, quad */ + {{0,0}, {1,1}}, /* Q==0 : impossible */ + {{0,0}, {1,1}}, /* Q==1 : impossible */ + {{ 150,216}, { 381,119}}, /* Q == 2 : 12-18% */ + {{ 170,205}, { 514,112}}, /* Q == 3 : 18-25% */ + {{ 177,199}, { 539,110}}, /* Q == 4 : 25-32% */ + {{ 197,194}, { 644,107}}, /* Q == 5 : 32-38% */ + {{ 221,192}, { 735,107}}, /* Q == 6 : 38-44% */ + {{ 256,189}, { 881,106}}, /* Q == 7 : 44-50% */ + {{ 359,188}, {1167,109}}, /* Q == 8 : 50-56% */ + {{ 582,187}, {1570,114}}, /* Q == 9 : 56-62% */ + {{ 688,187}, {1712,122}}, /* Q ==10 : 62-69% */ + {{ 825,186}, {1965,136}}, /* Q ==11 : 69-75% */ + {{ 976,185}, {2131,150}}, /* Q ==12 : 75-81% */ + {{1180,186}, {2070,175}}, /* Q ==13 : 81-87% */ + {{1377,185}, {1731,202}}, /* Q ==14 : 87-93% */ + {{1412,185}, {1695,202}}, /* Q ==15 : 93-99% */ +}; +#endif + +/* HUF_selectDecoder() : + * Tells which decoder is likely to decode faster, + * based on a set of pre-computed metrics. + * @return : 0==HUF_decompress4X1, 1==HUF_decompress4X2 . + * Assumption : 0 < dstSize <= 128 KB */ +U32 HUF_selectDecoder (size_t dstSize, size_t cSrcSize) +{ + assert(dstSize > 0); + assert(dstSize <= 128*1024); +#if defined(HUF_FORCE_DECOMPRESS_X1) + (void)dstSize; + (void)cSrcSize; + return 0; +#elif defined(HUF_FORCE_DECOMPRESS_X2) + (void)dstSize; + (void)cSrcSize; + return 1; +#else + /* decoder timing evaluation */ + { U32 const Q = (cSrcSize >= dstSize) ? 15 : (U32)(cSrcSize * 16 / dstSize); /* Q < 16 */ + U32 const D256 = (U32)(dstSize >> 8); + U32 const DTime0 = algoTime[Q][0].tableTime + (algoTime[Q][0].decode256Time * D256); + U32 DTime1 = algoTime[Q][1].tableTime + (algoTime[Q][1].decode256Time * D256); + DTime1 += DTime1 >> 5; /* small advantage to algorithm using less memory, to reduce cache eviction */ + return DTime1 < DTime0; + } +#endif +} + + +size_t HUF_decompress4X_hufOnly_wksp(HUF_DTable* dctx, void* dst, + size_t dstSize, const void* cSrc, + size_t cSrcSize, void* workSpace, + size_t wkspSize) +{ + /* validation checks */ + if (dstSize == 0) return ERROR(dstSize_tooSmall); + if (cSrcSize == 0) return ERROR(corruption_detected); + + { U32 const algoNb = HUF_selectDecoder(dstSize, cSrcSize); +#if defined(HUF_FORCE_DECOMPRESS_X1) + (void)algoNb; + assert(algoNb == 0); + return HUF_decompress4X1_DCtx_wksp(dctx, dst, dstSize, cSrc, cSrcSize, workSpace, wkspSize); +#elif defined(HUF_FORCE_DECOMPRESS_X2) + (void)algoNb; + assert(algoNb == 1); + return HUF_decompress4X2_DCtx_wksp(dctx, dst, dstSize, cSrc, cSrcSize, workSpace, wkspSize); +#else + return algoNb ? HUF_decompress4X2_DCtx_wksp(dctx, dst, dstSize, cSrc, + cSrcSize, workSpace, wkspSize): + HUF_decompress4X1_DCtx_wksp(dctx, dst, dstSize, cSrc, cSrcSize, workSpace, wkspSize); +#endif + } +} + +size_t HUF_decompress1X_DCtx_wksp(HUF_DTable* dctx, void* dst, size_t dstSize, + const void* cSrc, size_t cSrcSize, + void* workSpace, size_t wkspSize) +{ + /* validation checks */ + if (dstSize == 0) return ERROR(dstSize_tooSmall); + if (cSrcSize > dstSize) return ERROR(corruption_detected); /* invalid */ + if (cSrcSize == dstSize) { ZSTD_memcpy(dst, cSrc, dstSize); return dstSize; } /* not compressed */ + if (cSrcSize == 1) { ZSTD_memset(dst, *(const BYTE*)cSrc, dstSize); return dstSize; } /* RLE */ + + { U32 const algoNb = HUF_selectDecoder(dstSize, cSrcSize); +#if defined(HUF_FORCE_DECOMPRESS_X1) + (void)algoNb; + assert(algoNb == 0); + return HUF_decompress1X1_DCtx_wksp(dctx, dst, dstSize, cSrc, + cSrcSize, workSpace, wkspSize); +#elif defined(HUF_FORCE_DECOMPRESS_X2) + (void)algoNb; + assert(algoNb == 1); + return HUF_decompress1X2_DCtx_wksp(dctx, dst, dstSize, cSrc, + cSrcSize, workSpace, wkspSize); +#else + return algoNb ? HUF_decompress1X2_DCtx_wksp(dctx, dst, dstSize, cSrc, + cSrcSize, workSpace, wkspSize): + HUF_decompress1X1_DCtx_wksp(dctx, dst, dstSize, cSrc, + cSrcSize, workSpace, wkspSize); +#endif + } +} + + +size_t HUF_decompress1X_usingDTable_bmi2(void* dst, size_t maxDstSize, const void* cSrc, size_t cSrcSize, const HUF_DTable* DTable, int bmi2) +{ + DTableDesc const dtd = HUF_getDTableDesc(DTable); +#if defined(HUF_FORCE_DECOMPRESS_X1) + (void)dtd; + assert(dtd.tableType == 0); + return HUF_decompress1X1_usingDTable_internal(dst, maxDstSize, cSrc, cSrcSize, DTable, bmi2); +#elif defined(HUF_FORCE_DECOMPRESS_X2) + (void)dtd; + assert(dtd.tableType == 1); + return HUF_decompress1X2_usingDTable_internal(dst, maxDstSize, cSrc, cSrcSize, DTable, bmi2); +#else + return dtd.tableType ? HUF_decompress1X2_usingDTable_internal(dst, maxDstSize, cSrc, cSrcSize, DTable, bmi2) : + HUF_decompress1X1_usingDTable_internal(dst, maxDstSize, cSrc, cSrcSize, DTable, bmi2); +#endif +} + +#ifndef HUF_FORCE_DECOMPRESS_X2 +size_t HUF_decompress1X1_DCtx_wksp_bmi2(HUF_DTable* dctx, void* dst, size_t dstSize, const void* cSrc, size_t cSrcSize, void* workSpace, size_t wkspSize, int bmi2) +{ + const BYTE* ip = (const BYTE*) cSrc; + + size_t const hSize = HUF_readDTableX1_wksp_bmi2(dctx, cSrc, cSrcSize, workSpace, wkspSize, bmi2); + if (HUF_isError(hSize)) return hSize; + if (hSize >= cSrcSize) return ERROR(srcSize_wrong); + ip += hSize; cSrcSize -= hSize; + + return HUF_decompress1X1_usingDTable_internal(dst, dstSize, ip, cSrcSize, dctx, bmi2); +} +#endif + +size_t HUF_decompress4X_usingDTable_bmi2(void* dst, size_t maxDstSize, const void* cSrc, size_t cSrcSize, const HUF_DTable* DTable, int bmi2) +{ + DTableDesc const dtd = HUF_getDTableDesc(DTable); +#if defined(HUF_FORCE_DECOMPRESS_X1) + (void)dtd; + assert(dtd.tableType == 0); + return HUF_decompress4X1_usingDTable_internal(dst, maxDstSize, cSrc, cSrcSize, DTable, bmi2); +#elif defined(HUF_FORCE_DECOMPRESS_X2) + (void)dtd; + assert(dtd.tableType == 1); + return HUF_decompress4X2_usingDTable_internal(dst, maxDstSize, cSrc, cSrcSize, DTable, bmi2); +#else + return dtd.tableType ? HUF_decompress4X2_usingDTable_internal(dst, maxDstSize, cSrc, cSrcSize, DTable, bmi2) : + HUF_decompress4X1_usingDTable_internal(dst, maxDstSize, cSrc, cSrcSize, DTable, bmi2); +#endif +} + +size_t HUF_decompress4X_hufOnly_wksp_bmi2(HUF_DTable* dctx, void* dst, size_t dstSize, const void* cSrc, size_t cSrcSize, void* workSpace, size_t wkspSize, int bmi2) +{ + /* validation checks */ + if (dstSize == 0) return ERROR(dstSize_tooSmall); + if (cSrcSize == 0) return ERROR(corruption_detected); + + { U32 const algoNb = HUF_selectDecoder(dstSize, cSrcSize); +#if defined(HUF_FORCE_DECOMPRESS_X1) + (void)algoNb; + assert(algoNb == 0); + return HUF_decompress4X1_DCtx_wksp_bmi2(dctx, dst, dstSize, cSrc, cSrcSize, workSpace, wkspSize, bmi2); +#elif defined(HUF_FORCE_DECOMPRESS_X2) + (void)algoNb; + assert(algoNb == 1); + return HUF_decompress4X2_DCtx_wksp_bmi2(dctx, dst, dstSize, cSrc, cSrcSize, workSpace, wkspSize, bmi2); +#else + return algoNb ? HUF_decompress4X2_DCtx_wksp_bmi2(dctx, dst, dstSize, cSrc, cSrcSize, workSpace, wkspSize, bmi2) : + HUF_decompress4X1_DCtx_wksp_bmi2(dctx, dst, dstSize, cSrc, cSrcSize, workSpace, wkspSize, bmi2); +#endif + } +} + diff --git a/lib/zstd/decompress/zstd_ddict.c b/lib/zstd/decompress/zstd_ddict.c new file mode 100644 index 00000000000..dbbc7919de5 --- /dev/null +++ b/lib/zstd/decompress/zstd_ddict.c @@ -0,0 +1,241 @@ +/* + * Copyright (c) Yann Collet, Facebook, Inc. + * All rights reserved. + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. + */ + +/* zstd_ddict.c : + * concentrates all logic that needs to know the internals of ZSTD_DDict object */ + +/*-******************************************************* +* Dependencies +*********************************************************/ +#include "../common/zstd_deps.h" /* ZSTD_memcpy, ZSTD_memmove, ZSTD_memset */ +#include "../common/cpu.h" /* bmi2 */ +#include "../common/mem.h" /* low level memory routines */ +#define FSE_STATIC_LINKING_ONLY +#include "../common/fse.h" +#define HUF_STATIC_LINKING_ONLY +#include "../common/huf.h" +#include "zstd_decompress_internal.h" +#include "zstd_ddict.h" + + + + +/*-******************************************************* +* Types +*********************************************************/ +struct ZSTD_DDict_s { + void* dictBuffer; + const void* dictContent; + size_t dictSize; + ZSTD_entropyDTables_t entropy; + U32 dictID; + U32 entropyPresent; + ZSTD_customMem cMem; +}; /* typedef'd to ZSTD_DDict within "zstd.h" */ + +const void* ZSTD_DDict_dictContent(const ZSTD_DDict* ddict) +{ + assert(ddict != NULL); + return ddict->dictContent; +} + +size_t ZSTD_DDict_dictSize(const ZSTD_DDict* ddict) +{ + assert(ddict != NULL); + return ddict->dictSize; +} + +void ZSTD_copyDDictParameters(ZSTD_DCtx* dctx, const ZSTD_DDict* ddict) +{ + DEBUGLOG(4, "ZSTD_copyDDictParameters"); + assert(dctx != NULL); + assert(ddict != NULL); + dctx->dictID = ddict->dictID; + dctx->prefixStart = ddict->dictContent; + dctx->virtualStart = ddict->dictContent; + dctx->dictEnd = (const BYTE*)ddict->dictContent + ddict->dictSize; + dctx->previousDstEnd = dctx->dictEnd; +#ifdef FUZZING_BUILD_MODE_UNSAFE_FOR_PRODUCTION + dctx->dictContentBeginForFuzzing = dctx->prefixStart; + dctx->dictContentEndForFuzzing = dctx->previousDstEnd; +#endif + if (ddict->entropyPresent) { + dctx->litEntropy = 1; + dctx->fseEntropy = 1; + dctx->LLTptr = ddict->entropy.LLTable; + dctx->MLTptr = ddict->entropy.MLTable; + dctx->OFTptr = ddict->entropy.OFTable; + dctx->HUFptr = ddict->entropy.hufTable; + dctx->entropy.rep[0] = ddict->entropy.rep[0]; + dctx->entropy.rep[1] = ddict->entropy.rep[1]; + dctx->entropy.rep[2] = ddict->entropy.rep[2]; + } else { + dctx->litEntropy = 0; + dctx->fseEntropy = 0; + } +} + + +static size_t +ZSTD_loadEntropy_intoDDict(ZSTD_DDict* ddict, + ZSTD_dictContentType_e dictContentType) +{ + ddict->dictID = 0; + ddict->entropyPresent = 0; + if (dictContentType == ZSTD_dct_rawContent) return 0; + + if (ddict->dictSize < 8) { + if (dictContentType == ZSTD_dct_fullDict) + return ERROR(dictionary_corrupted); /* only accept specified dictionaries */ + return 0; /* pure content mode */ + } + { U32 const magic = MEM_readLE32(ddict->dictContent); + if (magic != ZSTD_MAGIC_DICTIONARY) { + if (dictContentType == ZSTD_dct_fullDict) + return ERROR(dictionary_corrupted); /* only accept specified dictionaries */ + return 0; /* pure content mode */ + } + } + ddict->dictID = MEM_readLE32((const char*)ddict->dictContent + ZSTD_FRAMEIDSIZE); + + /* load entropy tables */ + RETURN_ERROR_IF(ZSTD_isError(ZSTD_loadDEntropy( + &ddict->entropy, ddict->dictContent, ddict->dictSize)), + dictionary_corrupted, ""); + ddict->entropyPresent = 1; + return 0; +} + + +static size_t ZSTD_initDDict_internal(ZSTD_DDict* ddict, + const void* dict, size_t dictSize, + ZSTD_dictLoadMethod_e dictLoadMethod, + ZSTD_dictContentType_e dictContentType) +{ + if ((dictLoadMethod == ZSTD_dlm_byRef) || (!dict) || (!dictSize)) { + ddict->dictBuffer = NULL; + ddict->dictContent = dict; + if (!dict) dictSize = 0; + } else { + void* const internalBuffer = ZSTD_customMalloc(dictSize, ddict->cMem); + ddict->dictBuffer = internalBuffer; + ddict->dictContent = internalBuffer; + if (!internalBuffer) return ERROR(memory_allocation); + ZSTD_memcpy(internalBuffer, dict, dictSize); + } + ddict->dictSize = dictSize; + ddict->entropy.hufTable[0] = (HUF_DTable)((HufLog)*0x1000001); /* cover both little and big endian */ + + /* parse dictionary content */ + FORWARD_IF_ERROR( ZSTD_loadEntropy_intoDDict(ddict, dictContentType) , ""); + + return 0; +} + +ZSTD_DDict* ZSTD_createDDict_advanced(const void* dict, size_t dictSize, + ZSTD_dictLoadMethod_e dictLoadMethod, + ZSTD_dictContentType_e dictContentType, + ZSTD_customMem customMem) +{ + if ((!customMem.customAlloc) ^ (!customMem.customFree)) return NULL; + + { ZSTD_DDict* const ddict = (ZSTD_DDict*) ZSTD_customMalloc(sizeof(ZSTD_DDict), customMem); + if (ddict == NULL) return NULL; + ddict->cMem = customMem; + { size_t const initResult = ZSTD_initDDict_internal(ddict, + dict, dictSize, + dictLoadMethod, dictContentType); + if (ZSTD_isError(initResult)) { + ZSTD_freeDDict(ddict); + return NULL; + } } + return ddict; + } +} + +/*! ZSTD_createDDict() : +* Create a digested dictionary, to start decompression without startup delay. +* `dict` content is copied inside DDict. +* Consequently, `dict` can be released after `ZSTD_DDict` creation */ +ZSTD_DDict* ZSTD_createDDict(const void* dict, size_t dictSize) +{ + ZSTD_customMem const allocator = { NULL, NULL, NULL }; + return ZSTD_createDDict_advanced(dict, dictSize, ZSTD_dlm_byCopy, ZSTD_dct_auto, allocator); +} + +/*! ZSTD_createDDict_byReference() : + * Create a digested dictionary, to start decompression without startup delay. + * Dictionary content is simply referenced, it will be accessed during decompression. + * Warning : dictBuffer must outlive DDict (DDict must be freed before dictBuffer) */ +ZSTD_DDict* ZSTD_createDDict_byReference(const void* dictBuffer, size_t dictSize) +{ + ZSTD_customMem const allocator = { NULL, NULL, NULL }; + return ZSTD_createDDict_advanced(dictBuffer, dictSize, ZSTD_dlm_byRef, ZSTD_dct_auto, allocator); +} + + +const ZSTD_DDict* ZSTD_initStaticDDict( + void* sBuffer, size_t sBufferSize, + const void* dict, size_t dictSize, + ZSTD_dictLoadMethod_e dictLoadMethod, + ZSTD_dictContentType_e dictContentType) +{ + size_t const neededSpace = sizeof(ZSTD_DDict) + + (dictLoadMethod == ZSTD_dlm_byRef ? 0 : dictSize); + ZSTD_DDict* const ddict = (ZSTD_DDict*)sBuffer; + assert(sBuffer != NULL); + assert(dict != NULL); + if ((size_t)sBuffer & 7) return NULL; /* 8-aligned */ + if (sBufferSize < neededSpace) return NULL; + if (dictLoadMethod == ZSTD_dlm_byCopy) { + ZSTD_memcpy(ddict+1, dict, dictSize); /* local copy */ + dict = ddict+1; + } + if (ZSTD_isError( ZSTD_initDDict_internal(ddict, + dict, dictSize, + ZSTD_dlm_byRef, dictContentType) )) + return NULL; + return ddict; +} + + +size_t ZSTD_freeDDict(ZSTD_DDict* ddict) +{ + if (ddict==NULL) return 0; /* support free on NULL */ + { ZSTD_customMem const cMem = ddict->cMem; + ZSTD_customFree(ddict->dictBuffer, cMem); + ZSTD_customFree(ddict, cMem); + return 0; + } +} + +/*! ZSTD_estimateDDictSize() : + * Estimate amount of memory that will be needed to create a dictionary for decompression. + * Note : dictionary created by reference using ZSTD_dlm_byRef are smaller */ +size_t ZSTD_estimateDDictSize(size_t dictSize, ZSTD_dictLoadMethod_e dictLoadMethod) +{ + return sizeof(ZSTD_DDict) + (dictLoadMethod == ZSTD_dlm_byRef ? 0 : dictSize); +} + +size_t ZSTD_sizeof_DDict(const ZSTD_DDict* ddict) +{ + if (ddict==NULL) return 0; /* support sizeof on NULL */ + return sizeof(*ddict) + (ddict->dictBuffer ? ddict->dictSize : 0) ; +} + +/*! ZSTD_getDictID_fromDDict() : + * Provides the dictID of the dictionary loaded into `ddict`. + * If @return == 0, the dictionary is not conformant to Zstandard specification, or empty. + * Non-conformant dictionaries can still be loaded, but as content-only dictionaries. */ +unsigned ZSTD_getDictID_fromDDict(const ZSTD_DDict* ddict) +{ + if (ddict==NULL) return 0; + return ZSTD_getDictID_fromDict(ddict->dictContent, ddict->dictSize); +} diff --git a/lib/zstd/decompress/zstd_ddict.h b/lib/zstd/decompress/zstd_ddict.h new file mode 100644 index 00000000000..8c1a79d666f --- /dev/null +++ b/lib/zstd/decompress/zstd_ddict.h @@ -0,0 +1,44 @@ +/* + * Copyright (c) Yann Collet, Facebook, Inc. + * All rights reserved. + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. + */ + + +#ifndef ZSTD_DDICT_H +#define ZSTD_DDICT_H + +/*-******************************************************* + * Dependencies + *********************************************************/ +#include "../common/zstd_deps.h" /* size_t */ +#include <linux/zstd.h> /* ZSTD_DDict, and several public functions */ + + +/*-******************************************************* + * Interface + *********************************************************/ + +/* note: several prototypes are already published in `zstd.h` : + * ZSTD_createDDict() + * ZSTD_createDDict_byReference() + * ZSTD_createDDict_advanced() + * ZSTD_freeDDict() + * ZSTD_initStaticDDict() + * ZSTD_sizeof_DDict() + * ZSTD_estimateDDictSize() + * ZSTD_getDictID_fromDict() + */ + +const void* ZSTD_DDict_dictContent(const ZSTD_DDict* ddict); +size_t ZSTD_DDict_dictSize(const ZSTD_DDict* ddict); + +void ZSTD_copyDDictParameters(ZSTD_DCtx* dctx, const ZSTD_DDict* ddict); + + + +#endif /* ZSTD_DDICT_H */ diff --git a/lib/zstd/decompress/zstd_decompress.c b/lib/zstd/decompress/zstd_decompress.c new file mode 100644 index 00000000000..b9b935a9f5c --- /dev/null +++ b/lib/zstd/decompress/zstd_decompress.c @@ -0,0 +1,2131 @@ +/* + * Copyright (c) Yann Collet, Facebook, Inc. + * All rights reserved. + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. + */ + + +/* *************************************************************** +* Tuning parameters +*****************************************************************/ +/*! + * HEAPMODE : + * Select how default decompression function ZSTD_decompress() allocates its context, + * on stack (0), or into heap (1, default; requires malloc()). + * Note that functions with explicit context such as ZSTD_decompressDCtx() are unaffected. + */ +#ifndef ZSTD_HEAPMODE +# define ZSTD_HEAPMODE 1 +#endif + +/*! +* LEGACY_SUPPORT : +* if set to 1+, ZSTD_decompress() can decode older formats (v0.1+) +*/ + +/*! + * MAXWINDOWSIZE_DEFAULT : + * maximum window size accepted by DStream __by default__. + * Frames requiring more memory will be rejected. + * It's possible to set a different limit using ZSTD_DCtx_setMaxWindowSize(). + */ +#ifndef ZSTD_MAXWINDOWSIZE_DEFAULT +# define ZSTD_MAXWINDOWSIZE_DEFAULT (((U32)1 << ZSTD_WINDOWLOG_LIMIT_DEFAULT) + 1) +#endif + +/*! + * NO_FORWARD_PROGRESS_MAX : + * maximum allowed nb of calls to ZSTD_decompressStream() + * without any forward progress + * (defined as: no byte read from input, and no byte flushed to output) + * before triggering an error. + */ +#ifndef ZSTD_NO_FORWARD_PROGRESS_MAX +# define ZSTD_NO_FORWARD_PROGRESS_MAX 16 +#endif + + +/*-******************************************************* +* Dependencies +*********************************************************/ +#include "../common/zstd_deps.h" /* ZSTD_memcpy, ZSTD_memmove, ZSTD_memset */ +#include "../common/mem.h" /* low level memory routines */ +#define FSE_STATIC_LINKING_ONLY +#include "../common/fse.h" +#define HUF_STATIC_LINKING_ONLY +#include "../common/huf.h" +#include <linux/xxhash.h> /* xxh64_reset, xxh64_update, xxh64_digest, XXH64 */ +#include "../common/zstd_internal.h" /* blockProperties_t */ +#include "zstd_decompress_internal.h" /* ZSTD_DCtx */ +#include "zstd_ddict.h" /* ZSTD_DDictDictContent */ +#include "zstd_decompress_block.h" /* ZSTD_decompressBlock_internal */ + + + + +/* *********************************** + * Multiple DDicts Hashset internals * + *************************************/ + +#define DDICT_HASHSET_MAX_LOAD_FACTOR_COUNT_MULT 4 +#define DDICT_HASHSET_MAX_LOAD_FACTOR_SIZE_MULT 3 /* These two constants represent SIZE_MULT/COUNT_MULT load factor without using a float. + * Currently, that means a 0.75 load factor. + * So, if count * COUNT_MULT / size * SIZE_MULT != 0, then we've exceeded + * the load factor of the ddict hash set. + */ + +#define DDICT_HASHSET_TABLE_BASE_SIZE 64 +#define DDICT_HASHSET_RESIZE_FACTOR 2 + +/* Hash function to determine starting position of dict insertion within the table + * Returns an index between [0, hashSet->ddictPtrTableSize] + */ +static size_t ZSTD_DDictHashSet_getIndex(const ZSTD_DDictHashSet* hashSet, U32 dictID) { + const U64 hash = xxh64(&dictID, sizeof(U32), 0); + /* DDict ptr table size is a multiple of 2, use size - 1 as mask to get index within [0, hashSet->ddictPtrTableSize) */ + return hash & (hashSet->ddictPtrTableSize - 1); +} + +/* Adds DDict to a hashset without resizing it. + * If inserting a DDict with a dictID that already exists in the set, replaces the one in the set. + * Returns 0 if successful, or a zstd error code if something went wrong. + */ +static size_t ZSTD_DDictHashSet_emplaceDDict(ZSTD_DDictHashSet* hashSet, const ZSTD_DDict* ddict) { + const U32 dictID = ZSTD_getDictID_fromDDict(ddict); + size_t idx = ZSTD_DDictHashSet_getIndex(hashSet, dictID); + const size_t idxRangeMask = hashSet->ddictPtrTableSize - 1; + RETURN_ERROR_IF(hashSet->ddictPtrCount == hashSet->ddictPtrTableSize, GENERIC, "Hash set is full!"); + DEBUGLOG(4, "Hashed index: for dictID: %u is %zu", dictID, idx); + while (hashSet->ddictPtrTable[idx] != NULL) { + /* Replace existing ddict if inserting ddict with same dictID */ + if (ZSTD_getDictID_fromDDict(hashSet->ddictPtrTable[idx]) == dictID) { + DEBUGLOG(4, "DictID already exists, replacing rather than adding"); + hashSet->ddictPtrTable[idx] = ddict; + return 0; + } + idx &= idxRangeMask; + idx++; + } + DEBUGLOG(4, "Final idx after probing for dictID %u is: %zu", dictID, idx); + hashSet->ddictPtrTable[idx] = ddict; + hashSet->ddictPtrCount++; + return 0; +} + +/* Expands hash table by factor of DDICT_HASHSET_RESIZE_FACTOR and + * rehashes all values, allocates new table, frees old table. + * Returns 0 on success, otherwise a zstd error code. + */ +static size_t ZSTD_DDictHashSet_expand(ZSTD_DDictHashSet* hashSet, ZSTD_customMem customMem) { + size_t newTableSize = hashSet->ddictPtrTableSize * DDICT_HASHSET_RESIZE_FACTOR; + const ZSTD_DDict** newTable = (const ZSTD_DDict**)ZSTD_customCalloc(sizeof(ZSTD_DDict*) * newTableSize, customMem); + const ZSTD_DDict** oldTable = hashSet->ddictPtrTable; + size_t oldTableSize = hashSet->ddictPtrTableSize; + size_t i; + + DEBUGLOG(4, "Expanding DDict hash table! Old size: %zu new size: %zu", oldTableSize, newTableSize); + RETURN_ERROR_IF(!newTable, memory_allocation, "Expanded hashset allocation failed!"); + hashSet->ddictPtrTable = newTable; + hashSet->ddictPtrTableSize = newTableSize; + hashSet->ddictPtrCount = 0; + for (i = 0; i < oldTableSize; ++i) { + if (oldTable[i] != NULL) { + FORWARD_IF_ERROR(ZSTD_DDictHashSet_emplaceDDict(hashSet, oldTable[i]), ""); + } + } + ZSTD_customFree((void*)oldTable, customMem); + DEBUGLOG(4, "Finished re-hash"); + return 0; +} + +/* Fetches a DDict with the given dictID + * Returns the ZSTD_DDict* with the requested dictID. If it doesn't exist, then returns NULL. + */ +static const ZSTD_DDict* ZSTD_DDictHashSet_getDDict(ZSTD_DDictHashSet* hashSet, U32 dictID) { + size_t idx = ZSTD_DDictHashSet_getIndex(hashSet, dictID); + const size_t idxRangeMask = hashSet->ddictPtrTableSize - 1; + DEBUGLOG(4, "Hashed index: for dictID: %u is %zu", dictID, idx); + for (;;) { + size_t currDictID = ZSTD_getDictID_fromDDict(hashSet->ddictPtrTable[idx]); + if (currDictID == dictID || currDictID == 0) { + /* currDictID == 0 implies a NULL ddict entry */ + break; + } else { + idx &= idxRangeMask; /* Goes to start of table when we reach the end */ + idx++; + } + } + DEBUGLOG(4, "Final idx after probing for dictID %u is: %zu", dictID, idx); + return hashSet->ddictPtrTable[idx]; +} + +/* Allocates space for and returns a ddict hash set + * The hash set's ZSTD_DDict* table has all values automatically set to NULL to begin with. + * Returns NULL if allocation failed. + */ +static ZSTD_DDictHashSet* ZSTD_createDDictHashSet(ZSTD_customMem customMem) { + ZSTD_DDictHashSet* ret = (ZSTD_DDictHashSet*)ZSTD_customMalloc(sizeof(ZSTD_DDictHashSet), customMem); + DEBUGLOG(4, "Allocating new hash set"); + if (!ret) + return NULL; + ret->ddictPtrTable = (const ZSTD_DDict**)ZSTD_customCalloc(DDICT_HASHSET_TABLE_BASE_SIZE * sizeof(ZSTD_DDict*), customMem); + if (!ret->ddictPtrTable) { + ZSTD_customFree(ret, customMem); + return NULL; + } + ret->ddictPtrTableSize = DDICT_HASHSET_TABLE_BASE_SIZE; + ret->ddictPtrCount = 0; + return ret; +} + +/* Frees the table of ZSTD_DDict* within a hashset, then frees the hashset itself. + * Note: The ZSTD_DDict* within the table are NOT freed. + */ +static void ZSTD_freeDDictHashSet(ZSTD_DDictHashSet* hashSet, ZSTD_customMem customMem) { + DEBUGLOG(4, "Freeing ddict hash set"); + if (hashSet && hashSet->ddictPtrTable) { + ZSTD_customFree((void*)hashSet->ddictPtrTable, customMem); + } + if (hashSet) { + ZSTD_customFree(hashSet, customMem); + } +} + +/* Public function: Adds a DDict into the ZSTD_DDictHashSet, possibly triggering a resize of the hash set. + * Returns 0 on success, or a ZSTD error. + */ +static size_t ZSTD_DDictHashSet_addDDict(ZSTD_DDictHashSet* hashSet, const ZSTD_DDict* ddict, ZSTD_customMem customMem) { + DEBUGLOG(4, "Adding dict ID: %u to hashset with - Count: %zu Tablesize: %zu", ZSTD_getDictID_fromDDict(ddict), hashSet->ddictPtrCount, hashSet->ddictPtrTableSize); + if (hashSet->ddictPtrCount * DDICT_HASHSET_MAX_LOAD_FACTOR_COUNT_MULT / hashSet->ddictPtrTableSize * DDICT_HASHSET_MAX_LOAD_FACTOR_SIZE_MULT != 0) { + FORWARD_IF_ERROR(ZSTD_DDictHashSet_expand(hashSet, customMem), ""); + } + FORWARD_IF_ERROR(ZSTD_DDictHashSet_emplaceDDict(hashSet, ddict), ""); + return 0; +} + +/*-************************************************************* +* Context management +***************************************************************/ +size_t ZSTD_sizeof_DCtx (const ZSTD_DCtx* dctx) +{ + if (dctx==NULL) return 0; /* support sizeof NULL */ + return sizeof(*dctx) + + ZSTD_sizeof_DDict(dctx->ddictLocal) + + dctx->inBuffSize + dctx->outBuffSize; +} + +size_t ZSTD_estimateDCtxSize(void) { return sizeof(ZSTD_DCtx); } + + +static size_t ZSTD_startingInputLength(ZSTD_format_e format) +{ + size_t const startingInputLength = ZSTD_FRAMEHEADERSIZE_PREFIX(format); + /* only supports formats ZSTD_f_zstd1 and ZSTD_f_zstd1_magicless */ + assert( (format == ZSTD_f_zstd1) || (format == ZSTD_f_zstd1_magicless) ); + return startingInputLength; +} + +static void ZSTD_DCtx_resetParameters(ZSTD_DCtx* dctx) +{ + assert(dctx->streamStage == zdss_init); + dctx->format = ZSTD_f_zstd1; + dctx->maxWindowSize = ZSTD_MAXWINDOWSIZE_DEFAULT; + dctx->outBufferMode = ZSTD_bm_buffered; + dctx->forceIgnoreChecksum = ZSTD_d_validateChecksum; + dctx->refMultipleDDicts = ZSTD_rmd_refSingleDDict; +} + +static void ZSTD_initDCtx_internal(ZSTD_DCtx* dctx) +{ + dctx->staticSize = 0; + dctx->ddict = NULL; + dctx->ddictLocal = NULL; + dctx->dictEnd = NULL; + dctx->ddictIsCold = 0; + dctx->dictUses = ZSTD_dont_use; + dctx->inBuff = NULL; + dctx->inBuffSize = 0; + dctx->outBuffSize = 0; + dctx->streamStage = zdss_init; + dctx->noForwardProgress = 0; + dctx->oversizedDuration = 0; +#if DYNAMIC_BMI2 + dctx->bmi2 = ZSTD_cpuSupportsBmi2(); +#endif + dctx->ddictSet = NULL; + ZSTD_DCtx_resetParameters(dctx); +#ifdef FUZZING_BUILD_MODE_UNSAFE_FOR_PRODUCTION + dctx->dictContentEndForFuzzing = NULL; +#endif +} + +ZSTD_DCtx* ZSTD_initStaticDCtx(void *workspace, size_t workspaceSize) +{ + ZSTD_DCtx* const dctx = (ZSTD_DCtx*) workspace; + + if ((size_t)workspace & 7) return NULL; /* 8-aligned */ + if (workspaceSize < sizeof(ZSTD_DCtx)) return NULL; /* minimum size */ + + ZSTD_initDCtx_internal(dctx); + dctx->staticSize = workspaceSize; + dctx->inBuff = (char*)(dctx+1); + return dctx; +} + +static ZSTD_DCtx* ZSTD_createDCtx_internal(ZSTD_customMem customMem) { + if ((!customMem.customAlloc) ^ (!customMem.customFree)) return NULL; + + { ZSTD_DCtx* const dctx = (ZSTD_DCtx*)ZSTD_customMalloc(sizeof(*dctx), customMem); + if (!dctx) return NULL; + dctx->customMem = customMem; + ZSTD_initDCtx_internal(dctx); + return dctx; + } +} + +ZSTD_DCtx* ZSTD_createDCtx_advanced(ZSTD_customMem customMem) +{ + return ZSTD_createDCtx_internal(customMem); +} + +ZSTD_DCtx* ZSTD_createDCtx(void) +{ + DEBUGLOG(3, "ZSTD_createDCtx"); + return ZSTD_createDCtx_internal(ZSTD_defaultCMem); +} + +static void ZSTD_clearDict(ZSTD_DCtx* dctx) +{ + ZSTD_freeDDict(dctx->ddictLocal); + dctx->ddictLocal = NULL; + dctx->ddict = NULL; + dctx->dictUses = ZSTD_dont_use; +} + +size_t ZSTD_freeDCtx(ZSTD_DCtx* dctx) +{ + if (dctx==NULL) return 0; /* support free on NULL */ + RETURN_ERROR_IF(dctx->staticSize, memory_allocation, "not compatible with static DCtx"); + { ZSTD_customMem const cMem = dctx->customMem; + ZSTD_clearDict(dctx); + ZSTD_customFree(dctx->inBuff, cMem); + dctx->inBuff = NULL; + if (dctx->ddictSet) { + ZSTD_freeDDictHashSet(dctx->ddictSet, cMem); + dctx->ddictSet = NULL; + } + ZSTD_customFree(dctx, cMem); + return 0; + } +} + +/* no longer useful */ +void ZSTD_copyDCtx(ZSTD_DCtx* dstDCtx, const ZSTD_DCtx* srcDCtx) +{ + size_t const toCopy = (size_t)((char*)(&dstDCtx->inBuff) - (char*)dstDCtx); + ZSTD_memcpy(dstDCtx, srcDCtx, toCopy); /* no need to copy workspace */ +} + +/* Given a dctx with a digested frame params, re-selects the correct ZSTD_DDict based on + * the requested dict ID from the frame. If there exists a reference to the correct ZSTD_DDict, then + * accordingly sets the ddict to be used to decompress the frame. + * + * If no DDict is found, then no action is taken, and the ZSTD_DCtx::ddict remains as-is. + * + * ZSTD_d_refMultipleDDicts must be enabled for this function to be called. + */ +static void ZSTD_DCtx_selectFrameDDict(ZSTD_DCtx* dctx) { + assert(dctx->refMultipleDDicts && dctx->ddictSet); + DEBUGLOG(4, "Adjusting DDict based on requested dict ID from frame"); + if (dctx->ddict) { + const ZSTD_DDict* frameDDict = ZSTD_DDictHashSet_getDDict(dctx->ddictSet, dctx->fParams.dictID); + if (frameDDict) { + DEBUGLOG(4, "DDict found!"); + ZSTD_clearDict(dctx); + dctx->dictID = dctx->fParams.dictID; + dctx->ddict = frameDDict; + dctx->dictUses = ZSTD_use_indefinitely; + } + } +} + + +/*-************************************************************* + * Frame header decoding + ***************************************************************/ + +/*! ZSTD_isFrame() : + * Tells if the content of `buffer` starts with a valid Frame Identifier. + * Note : Frame Identifier is 4 bytes. If `size < 4`, @return will always be 0. + * Note 2 : Legacy Frame Identifiers are considered valid only if Legacy Support is enabled. + * Note 3 : Skippable Frame Identifiers are considered valid. */ +unsigned ZSTD_isFrame(const void* buffer, size_t size) +{ + if (size < ZSTD_FRAMEIDSIZE) return 0; + { U32 const magic = MEM_readLE32(buffer); + if (magic == ZSTD_MAGICNUMBER) return 1; + if ((magic & ZSTD_MAGIC_SKIPPABLE_MASK) == ZSTD_MAGIC_SKIPPABLE_START) return 1; + } + return 0; +} + +/*! ZSTD_isSkippableFrame() : + * Tells if the content of `buffer` starts with a valid Frame Identifier for a skippable frame. + * Note : Frame Identifier is 4 bytes. If `size < 4`, @return will always be 0. + */ +unsigned ZSTD_isSkippableFrame(const void* buffer, size_t size) +{ + if (size < ZSTD_FRAMEIDSIZE) return 0; + { U32 const magic = MEM_readLE32(buffer); + if ((magic & ZSTD_MAGIC_SKIPPABLE_MASK) == ZSTD_MAGIC_SKIPPABLE_START) return 1; + } + return 0; +} + +/* ZSTD_frameHeaderSize_internal() : + * srcSize must be large enough to reach header size fields. + * note : only works for formats ZSTD_f_zstd1 and ZSTD_f_zstd1_magicless. + * @return : size of the Frame Header + * or an error code, which can be tested with ZSTD_isError() */ +static size_t ZSTD_frameHeaderSize_internal(const void* src, size_t srcSize, ZSTD_format_e format) +{ + size_t const minInputSize = ZSTD_startingInputLength(format); + RETURN_ERROR_IF(srcSize < minInputSize, srcSize_wrong, ""); + + { BYTE const fhd = ((const BYTE*)src)[minInputSize-1]; + U32 const dictID= fhd & 3; + U32 const singleSegment = (fhd >> 5) & 1; + U32 const fcsId = fhd >> 6; + return minInputSize + !singleSegment + + ZSTD_did_fieldSize[dictID] + ZSTD_fcs_fieldSize[fcsId] + + (singleSegment && !fcsId); + } +} + +/* ZSTD_frameHeaderSize() : + * srcSize must be >= ZSTD_frameHeaderSize_prefix. + * @return : size of the Frame Header, + * or an error code (if srcSize is too small) */ +size_t ZSTD_frameHeaderSize(const void* src, size_t srcSize) +{ + return ZSTD_frameHeaderSize_internal(src, srcSize, ZSTD_f_zstd1); +} + + +/* ZSTD_getFrameHeader_advanced() : + * decode Frame Header, or require larger `srcSize`. + * note : only works for formats ZSTD_f_zstd1 and ZSTD_f_zstd1_magicless + * @return : 0, `zfhPtr` is correctly filled, + * >0, `srcSize` is too small, value is wanted `srcSize` amount, + * or an error code, which can be tested using ZSTD_isError() */ +size_t ZSTD_getFrameHeader_advanced(ZSTD_frameHeader* zfhPtr, const void* src, size_t srcSize, ZSTD_format_e format) +{ + const BYTE* ip = (const BYTE*)src; + size_t const minInputSize = ZSTD_startingInputLength(format); + + ZSTD_memset(zfhPtr, 0, sizeof(*zfhPtr)); /* not strictly necessary, but static analyzer do not understand that zfhPtr is only going to be read only if return value is zero, since they are 2 different signals */ + if (srcSize < minInputSize) return minInputSize; + RETURN_ERROR_IF(src==NULL, GENERIC, "invalid parameter"); + + if ( (format != ZSTD_f_zstd1_magicless) + && (MEM_readLE32(src) != ZSTD_MAGICNUMBER) ) { + if ((MEM_readLE32(src) & ZSTD_MAGIC_SKIPPABLE_MASK) == ZSTD_MAGIC_SKIPPABLE_START) { + /* skippable frame */ + if (srcSize < ZSTD_SKIPPABLEHEADERSIZE) + return ZSTD_SKIPPABLEHEADERSIZE; /* magic number + frame length */ + ZSTD_memset(zfhPtr, 0, sizeof(*zfhPtr)); + zfhPtr->frameContentSize = MEM_readLE32((const char *)src + ZSTD_FRAMEIDSIZE); + zfhPtr->frameType = ZSTD_skippableFrame; + return 0; + } + RETURN_ERROR(prefix_unknown, ""); + } + + /* ensure there is enough `srcSize` to fully read/decode frame header */ + { size_t const fhsize = ZSTD_frameHeaderSize_internal(src, srcSize, format); + if (srcSize < fhsize) return fhsize; + zfhPtr->headerSize = (U32)fhsize; + } + + { BYTE const fhdByte = ip[minInputSize-1]; + size_t pos = minInputSize; + U32 const dictIDSizeCode = fhdByte&3; + U32 const checksumFlag = (fhdByte>>2)&1; + U32 const singleSegment = (fhdByte>>5)&1; + U32 const fcsID = fhdByte>>6; + U64 windowSize = 0; + U32 dictID = 0; + U64 frameContentSize = ZSTD_CONTENTSIZE_UNKNOWN; + RETURN_ERROR_IF((fhdByte & 0x08) != 0, frameParameter_unsupported, + "reserved bits, must be zero"); + + if (!singleSegment) { + BYTE const wlByte = ip[pos++]; + U32 const windowLog = (wlByte >> 3) + ZSTD_WINDOWLOG_ABSOLUTEMIN; + RETURN_ERROR_IF(windowLog > ZSTD_WINDOWLOG_MAX, frameParameter_windowTooLarge, ""); + windowSize = (1ULL << windowLog); + windowSize += (windowSize >> 3) * (wlByte&7); + } + switch(dictIDSizeCode) + { + default: + assert(0); /* impossible */ + ZSTD_FALLTHROUGH; + case 0 : break; + case 1 : dictID = ip[pos]; pos++; break; + case 2 : dictID = MEM_readLE16(ip+pos); pos+=2; break; + case 3 : dictID = MEM_readLE32(ip+pos); pos+=4; break; + } + switch(fcsID) + { + default: + assert(0); /* impossible */ + ZSTD_FALLTHROUGH; + case 0 : if (singleSegment) frameContentSize = ip[pos]; break; + case 1 : frameContentSize = MEM_readLE16(ip+pos)+256; break; + case 2 : frameContentSize = MEM_readLE32(ip+pos); break; + case 3 : frameContentSize = MEM_readLE64(ip+pos); break; + } + if (singleSegment) windowSize = frameContentSize; + + zfhPtr->frameType = ZSTD_frame; + zfhPtr->frameContentSize = frameContentSize; + zfhPtr->windowSize = windowSize; + zfhPtr->blockSizeMax = (unsigned) MIN(windowSize, ZSTD_BLOCKSIZE_MAX); + zfhPtr->dictID = dictID; + zfhPtr->checksumFlag = checksumFlag; + } + return 0; +} + +/* ZSTD_getFrameHeader() : + * decode Frame Header, or require larger `srcSize`. + * note : this function does not consume input, it only reads it. + * @return : 0, `zfhPtr` is correctly filled, + * >0, `srcSize` is too small, value is wanted `srcSize` amount, + * or an error code, which can be tested using ZSTD_isError() */ +size_t ZSTD_getFrameHeader(ZSTD_frameHeader* zfhPtr, const void* src, size_t srcSize) +{ + return ZSTD_getFrameHeader_advanced(zfhPtr, src, srcSize, ZSTD_f_zstd1); +} + +/* ZSTD_getFrameContentSize() : + * compatible with legacy mode + * @return : decompressed size of the single frame pointed to be `src` if known, otherwise + * - ZSTD_CONTENTSIZE_UNKNOWN if the size cannot be determined + * - ZSTD_CONTENTSIZE_ERROR if an error occurred (e.g. invalid magic number, srcSize too small) */ +unsigned long long ZSTD_getFrameContentSize(const void *src, size_t srcSize) +{ + { ZSTD_frameHeader zfh; + if (ZSTD_getFrameHeader(&zfh, src, srcSize) != 0) + return ZSTD_CONTENTSIZE_ERROR; + if (zfh.frameType == ZSTD_skippableFrame) { + return 0; + } else { + return zfh.frameContentSize; + } } +} + +static size_t readSkippableFrameSize(void const* src, size_t srcSize) +{ + size_t const skippableHeaderSize = ZSTD_SKIPPABLEHEADERSIZE; + U32 sizeU32; + + RETURN_ERROR_IF(srcSize < ZSTD_SKIPPABLEHEADERSIZE, srcSize_wrong, ""); + + sizeU32 = MEM_readLE32((BYTE const*)src + ZSTD_FRAMEIDSIZE); + RETURN_ERROR_IF((U32)(sizeU32 + ZSTD_SKIPPABLEHEADERSIZE) < sizeU32, + frameParameter_unsupported, ""); + { + size_t const skippableSize = skippableHeaderSize + sizeU32; + RETURN_ERROR_IF(skippableSize > srcSize, srcSize_wrong, ""); + return skippableSize; + } +} + +/*! ZSTD_readSkippableFrame() : + * Retrieves a zstd skippable frame containing data given by src, and writes it to dst buffer. + * + * The parameter magicVariant will receive the magicVariant that was supplied when the frame was written, + * i.e. magicNumber - ZSTD_MAGIC_SKIPPABLE_START. This can be NULL if the caller is not interested + * in the magicVariant. + * + * Returns an error if destination buffer is not large enough, or if the frame is not skippable. + * + * @return : number of bytes written or a ZSTD error. + */ +ZSTDLIB_API size_t ZSTD_readSkippableFrame(void* dst, size_t dstCapacity, unsigned* magicVariant, + const void* src, size_t srcSize) +{ + U32 const magicNumber = MEM_readLE32(src); + size_t skippableFrameSize = readSkippableFrameSize(src, srcSize); + size_t skippableContentSize = skippableFrameSize - ZSTD_SKIPPABLEHEADERSIZE; + + /* check input validity */ + RETURN_ERROR_IF(!ZSTD_isSkippableFrame(src, srcSize), frameParameter_unsupported, ""); + RETURN_ERROR_IF(skippableFrameSize < ZSTD_SKIPPABLEHEADERSIZE || skippableFrameSize > srcSize, srcSize_wrong, ""); + RETURN_ERROR_IF(skippableContentSize > dstCapacity, dstSize_tooSmall, ""); + + /* deliver payload */ + if (skippableContentSize > 0 && dst != NULL) + ZSTD_memcpy(dst, (const BYTE *)src + ZSTD_SKIPPABLEHEADERSIZE, skippableContentSize); + if (magicVariant != NULL) + *magicVariant = magicNumber - ZSTD_MAGIC_SKIPPABLE_START; + return skippableContentSize; +} + +/* ZSTD_findDecompressedSize() : + * compatible with legacy mode + * `srcSize` must be the exact length of some number of ZSTD compressed and/or + * skippable frames + * @return : decompressed size of the frames contained */ +unsigned long long ZSTD_findDecompressedSize(const void* src, size_t srcSize) +{ + unsigned long long totalDstSize = 0; + + while (srcSize >= ZSTD_startingInputLength(ZSTD_f_zstd1)) { + U32 const magicNumber = MEM_readLE32(src); + + if ((magicNumber & ZSTD_MAGIC_SKIPPABLE_MASK) == ZSTD_MAGIC_SKIPPABLE_START) { + size_t const skippableSize = readSkippableFrameSize(src, srcSize); + if (ZSTD_isError(skippableSize)) { + return ZSTD_CONTENTSIZE_ERROR; + } + assert(skippableSize <= srcSize); + + src = (const BYTE *)src + skippableSize; + srcSize -= skippableSize; + continue; + } + + { unsigned long long const ret = ZSTD_getFrameContentSize(src, srcSize); + if (ret >= ZSTD_CONTENTSIZE_ERROR) return ret; + + /* check for overflow */ + if (totalDstSize + ret < totalDstSize) return ZSTD_CONTENTSIZE_ERROR; + totalDstSize += ret; + } + { size_t const frameSrcSize = ZSTD_findFrameCompressedSize(src, srcSize); + if (ZSTD_isError(frameSrcSize)) { + return ZSTD_CONTENTSIZE_ERROR; + } + + src = (const BYTE *)src + frameSrcSize; + srcSize -= frameSrcSize; + } + } /* while (srcSize >= ZSTD_frameHeaderSize_prefix) */ + + if (srcSize) return ZSTD_CONTENTSIZE_ERROR; + + return totalDstSize; +} + +/* ZSTD_getDecompressedSize() : + * compatible with legacy mode + * @return : decompressed size if known, 0 otherwise + note : 0 can mean any of the following : + - frame content is empty + - decompressed size field is not present in frame header + - frame header unknown / not supported + - frame header not complete (`srcSize` too small) */ +unsigned long long ZSTD_getDecompressedSize(const void* src, size_t srcSize) +{ + unsigned long long const ret = ZSTD_getFrameContentSize(src, srcSize); + ZSTD_STATIC_ASSERT(ZSTD_CONTENTSIZE_ERROR < ZSTD_CONTENTSIZE_UNKNOWN); + return (ret >= ZSTD_CONTENTSIZE_ERROR) ? 0 : ret; +} + + +/* ZSTD_decodeFrameHeader() : + * `headerSize` must be the size provided by ZSTD_frameHeaderSize(). + * If multiple DDict references are enabled, also will choose the correct DDict to use. + * @return : 0 if success, or an error code, which can be tested using ZSTD_isError() */ +static size_t ZSTD_decodeFrameHeader(ZSTD_DCtx* dctx, const void* src, size_t headerSize) +{ + size_t const result = ZSTD_getFrameHeader_advanced(&(dctx->fParams), src, headerSize, dctx->format); + if (ZSTD_isError(result)) return result; /* invalid header */ + RETURN_ERROR_IF(result>0, srcSize_wrong, "headerSize too small"); + + /* Reference DDict requested by frame if dctx references multiple ddicts */ + if (dctx->refMultipleDDicts == ZSTD_rmd_refMultipleDDicts && dctx->ddictSet) { + ZSTD_DCtx_selectFrameDDict(dctx); + } + +#ifndef FUZZING_BUILD_MODE_UNSAFE_FOR_PRODUCTION + /* Skip the dictID check in fuzzing mode, because it makes the search + * harder. + */ + RETURN_ERROR_IF(dctx->fParams.dictID && (dctx->dictID != dctx->fParams.dictID), + dictionary_wrong, ""); +#endif + dctx->validateChecksum = (dctx->fParams.checksumFlag && !dctx->forceIgnoreChecksum) ? 1 : 0; + if (dctx->validateChecksum) xxh64_reset(&dctx->xxhState, 0); + dctx->processedCSize += headerSize; + return 0; +} + +static ZSTD_frameSizeInfo ZSTD_errorFrameSizeInfo(size_t ret) +{ + ZSTD_frameSizeInfo frameSizeInfo; + frameSizeInfo.compressedSize = ret; + frameSizeInfo.decompressedBound = ZSTD_CONTENTSIZE_ERROR; + return frameSizeInfo; +} + +static ZSTD_frameSizeInfo ZSTD_findFrameSizeInfo(const void* src, size_t srcSize) +{ + ZSTD_frameSizeInfo frameSizeInfo; + ZSTD_memset(&frameSizeInfo, 0, sizeof(ZSTD_frameSizeInfo)); + + + if ((srcSize >= ZSTD_SKIPPABLEHEADERSIZE) + && (MEM_readLE32(src) & ZSTD_MAGIC_SKIPPABLE_MASK) == ZSTD_MAGIC_SKIPPABLE_START) { + frameSizeInfo.compressedSize = readSkippableFrameSize(src, srcSize); + assert(ZSTD_isError(frameSizeInfo.compressedSize) || + frameSizeInfo.compressedSize <= srcSize); + return frameSizeInfo; + } else { + const BYTE* ip = (const BYTE*)src; + const BYTE* const ipstart = ip; + size_t remainingSize = srcSize; + size_t nbBlocks = 0; + ZSTD_frameHeader zfh; + + /* Extract Frame Header */ + { size_t const ret = ZSTD_getFrameHeader(&zfh, src, srcSize); + if (ZSTD_isError(ret)) + return ZSTD_errorFrameSizeInfo(ret); + if (ret > 0) + return ZSTD_errorFrameSizeInfo(ERROR(srcSize_wrong)); + } + + ip += zfh.headerSize; + remainingSize -= zfh.headerSize; + + /* Iterate over each block */ + while (1) { + blockProperties_t blockProperties; + size_t const cBlockSize = ZSTD_getcBlockSize(ip, remainingSize, &blockProperties); + if (ZSTD_isError(cBlockSize)) + return ZSTD_errorFrameSizeInfo(cBlockSize); + + if (ZSTD_blockHeaderSize + cBlockSize > remainingSize) + return ZSTD_errorFrameSizeInfo(ERROR(srcSize_wrong)); + + ip += ZSTD_blockHeaderSize + cBlockSize; + remainingSize -= ZSTD_blockHeaderSize + cBlockSize; + nbBlocks++; + + if (blockProperties.lastBlock) break; + } + + /* Final frame content checksum */ + if (zfh.checksumFlag) { + if (remainingSize < 4) + return ZSTD_errorFrameSizeInfo(ERROR(srcSize_wrong)); + ip += 4; + } + + frameSizeInfo.compressedSize = (size_t)(ip - ipstart); + frameSizeInfo.decompressedBound = (zfh.frameContentSize != ZSTD_CONTENTSIZE_UNKNOWN) + ? zfh.frameContentSize + : nbBlocks * zfh.blockSizeMax; + return frameSizeInfo; + } +} + +/* ZSTD_findFrameCompressedSize() : + * compatible with legacy mode + * `src` must point to the start of a ZSTD frame, ZSTD legacy frame, or skippable frame + * `srcSize` must be at least as large as the frame contained + * @return : the compressed size of the frame starting at `src` */ +size_t ZSTD_findFrameCompressedSize(const void *src, size_t srcSize) +{ + ZSTD_frameSizeInfo const frameSizeInfo = ZSTD_findFrameSizeInfo(src, srcSize); + return frameSizeInfo.compressedSize; +} + +/* ZSTD_decompressBound() : + * compatible with legacy mode + * `src` must point to the start of a ZSTD frame or a skippeable frame + * `srcSize` must be at least as large as the frame contained + * @return : the maximum decompressed size of the compressed source + */ +unsigned long long ZSTD_decompressBound(const void* src, size_t srcSize) +{ + unsigned long long bound = 0; + /* Iterate over each frame */ + while (srcSize > 0) { + ZSTD_frameSizeInfo const frameSizeInfo = ZSTD_findFrameSizeInfo(src, srcSize); + size_t const compressedSize = frameSizeInfo.compressedSize; + unsigned long long const decompressedBound = frameSizeInfo.decompressedBound; + if (ZSTD_isError(compressedSize) || decompressedBound == ZSTD_CONTENTSIZE_ERROR) + return ZSTD_CONTENTSIZE_ERROR; + assert(srcSize >= compressedSize); + src = (const BYTE*)src + compressedSize; + srcSize -= compressedSize; + bound += decompressedBound; + } + return bound; +} + + +/*-************************************************************* + * Frame decoding + ***************************************************************/ + +/* ZSTD_insertBlock() : + * insert `src` block into `dctx` history. Useful to track uncompressed blocks. */ +size_t ZSTD_insertBlock(ZSTD_DCtx* dctx, const void* blockStart, size_t blockSize) +{ + DEBUGLOG(5, "ZSTD_insertBlock: %u bytes", (unsigned)blockSize); + ZSTD_checkContinuity(dctx, blockStart, blockSize); + dctx->previousDstEnd = (const char*)blockStart + blockSize; + return blockSize; +} + + +static size_t ZSTD_copyRawBlock(void* dst, size_t dstCapacity, + const void* src, size_t srcSize) +{ + DEBUGLOG(5, "ZSTD_copyRawBlock"); + RETURN_ERROR_IF(srcSize > dstCapacity, dstSize_tooSmall, ""); + if (dst == NULL) { + if (srcSize == 0) return 0; + RETURN_ERROR(dstBuffer_null, ""); + } + ZSTD_memcpy(dst, src, srcSize); + return srcSize; +} + +static size_t ZSTD_setRleBlock(void* dst, size_t dstCapacity, + BYTE b, + size_t regenSize) +{ + RETURN_ERROR_IF(regenSize > dstCapacity, dstSize_tooSmall, ""); + if (dst == NULL) { + if (regenSize == 0) return 0; + RETURN_ERROR(dstBuffer_null, ""); + } + ZSTD_memset(dst, b, regenSize); + return regenSize; +} + +static void ZSTD_DCtx_trace_end(ZSTD_DCtx const* dctx, U64 uncompressedSize, U64 compressedSize, unsigned streaming) +{ + (void)dctx; + (void)uncompressedSize; + (void)compressedSize; + (void)streaming; +} + + +/*! ZSTD_decompressFrame() : + * @dctx must be properly initialized + * will update *srcPtr and *srcSizePtr, + * to make *srcPtr progress by one frame. */ +static size_t ZSTD_decompressFrame(ZSTD_DCtx* dctx, + void* dst, size_t dstCapacity, + const void** srcPtr, size_t *srcSizePtr) +{ + const BYTE* const istart = (const BYTE*)(*srcPtr); + const BYTE* ip = istart; + BYTE* const ostart = (BYTE*)dst; + BYTE* const oend = dstCapacity != 0 ? ostart + dstCapacity : ostart; + BYTE* op = ostart; + size_t remainingSrcSize = *srcSizePtr; + + DEBUGLOG(4, "ZSTD_decompressFrame (srcSize:%i)", (int)*srcSizePtr); + + /* check */ + RETURN_ERROR_IF( + remainingSrcSize < ZSTD_FRAMEHEADERSIZE_MIN(dctx->format)+ZSTD_blockHeaderSize, + srcSize_wrong, ""); + + /* Frame Header */ + { size_t const frameHeaderSize = ZSTD_frameHeaderSize_internal( + ip, ZSTD_FRAMEHEADERSIZE_PREFIX(dctx->format), dctx->format); + if (ZSTD_isError(frameHeaderSize)) return frameHeaderSize; + RETURN_ERROR_IF(remainingSrcSize < frameHeaderSize+ZSTD_blockHeaderSize, + srcSize_wrong, ""); + FORWARD_IF_ERROR( ZSTD_decodeFrameHeader(dctx, ip, frameHeaderSize) , ""); + ip += frameHeaderSize; remainingSrcSize -= frameHeaderSize; + } + + /* Loop on each block */ + while (1) { + size_t decodedSize; + blockProperties_t blockProperties; + size_t const cBlockSize = ZSTD_getcBlockSize(ip, remainingSrcSize, &blockProperties); + if (ZSTD_isError(cBlockSize)) return cBlockSize; + + ip += ZSTD_blockHeaderSize; + remainingSrcSize -= ZSTD_blockHeaderSize; + RETURN_ERROR_IF(cBlockSize > remainingSrcSize, srcSize_wrong, ""); + + switch(blockProperties.blockType) + { + case bt_compressed: + decodedSize = ZSTD_decompressBlock_internal(dctx, op, (size_t)(oend-op), ip, cBlockSize, /* frame */ 1, not_streaming); + break; + case bt_raw : + decodedSize = ZSTD_copyRawBlock(op, (size_t)(oend-op), ip, cBlockSize); + break; + case bt_rle : + decodedSize = ZSTD_setRleBlock(op, (size_t)(oend-op), *ip, blockProperties.origSize); + break; + case bt_reserved : + default: + RETURN_ERROR(corruption_detected, "invalid block type"); + } + + if (ZSTD_isError(decodedSize)) return decodedSize; + if (dctx->validateChecksum) + xxh64_update(&dctx->xxhState, op, decodedSize); + if (decodedSize != 0) + op += decodedSize; + assert(ip != NULL); + ip += cBlockSize; + remainingSrcSize -= cBlockSize; + if (blockProperties.lastBlock) break; + } + + if (dctx->fParams.frameContentSize != ZSTD_CONTENTSIZE_UNKNOWN) { + RETURN_ERROR_IF((U64)(op-ostart) != dctx->fParams.frameContentSize, + corruption_detected, ""); + } + if (dctx->fParams.checksumFlag) { /* Frame content checksum verification */ + RETURN_ERROR_IF(remainingSrcSize<4, checksum_wrong, ""); + if (!dctx->forceIgnoreChecksum) { + U32 const checkCalc = (U32)xxh64_digest(&dctx->xxhState); + U32 checkRead; + checkRead = MEM_readLE32(ip); + RETURN_ERROR_IF(checkRead != checkCalc, checksum_wrong, ""); + } + ip += 4; + remainingSrcSize -= 4; + } + ZSTD_DCtx_trace_end(dctx, (U64)(op-ostart), (U64)(ip-istart), /* streaming */ 0); + /* Allow caller to get size read */ + *srcPtr = ip; + *srcSizePtr = remainingSrcSize; + return (size_t)(op-ostart); +} + +static size_t ZSTD_decompressMultiFrame(ZSTD_DCtx* dctx, + void* dst, size_t dstCapacity, + const void* src, size_t srcSize, + const void* dict, size_t dictSize, + const ZSTD_DDict* ddict) +{ + void* const dststart = dst; + int moreThan1Frame = 0; + + DEBUGLOG(5, "ZSTD_decompressMultiFrame"); + assert(dict==NULL || ddict==NULL); /* either dict or ddict set, not both */ + + if (ddict) { + dict = ZSTD_DDict_dictContent(ddict); + dictSize = ZSTD_DDict_dictSize(ddict); + } + + while (srcSize >= ZSTD_startingInputLength(dctx->format)) { + + + { U32 const magicNumber = MEM_readLE32(src); + DEBUGLOG(4, "reading magic number %08X (expecting %08X)", + (unsigned)magicNumber, ZSTD_MAGICNUMBER); + if ((magicNumber & ZSTD_MAGIC_SKIPPABLE_MASK) == ZSTD_MAGIC_SKIPPABLE_START) { + size_t const skippableSize = readSkippableFrameSize(src, srcSize); + FORWARD_IF_ERROR(skippableSize, "readSkippableFrameSize failed"); + assert(skippableSize <= srcSize); + + src = (const BYTE *)src + skippableSize; + srcSize -= skippableSize; + continue; + } } + + if (ddict) { + /* we were called from ZSTD_decompress_usingDDict */ + FORWARD_IF_ERROR(ZSTD_decompressBegin_usingDDict(dctx, ddict), ""); + } else { + /* this will initialize correctly with no dict if dict == NULL, so + * use this in all cases but ddict */ + FORWARD_IF_ERROR(ZSTD_decompressBegin_usingDict(dctx, dict, dictSize), ""); + } + ZSTD_checkContinuity(dctx, dst, dstCapacity); + + { const size_t res = ZSTD_decompressFrame(dctx, dst, dstCapacity, + &src, &srcSize); + RETURN_ERROR_IF( + (ZSTD_getErrorCode(res) == ZSTD_error_prefix_unknown) + && (moreThan1Frame==1), + srcSize_wrong, + "At least one frame successfully completed, " + "but following bytes are garbage: " + "it's more likely to be a srcSize error, " + "specifying more input bytes than size of frame(s). " + "Note: one could be unlucky, it might be a corruption error instead, " + "happening right at the place where we expect zstd magic bytes. " + "But this is _much_ less likely than a srcSize field error."); + if (ZSTD_isError(res)) return res; + assert(res <= dstCapacity); + if (res != 0) + dst = (BYTE*)dst + res; + dstCapacity -= res; + } + moreThan1Frame = 1; + } /* while (srcSize >= ZSTD_frameHeaderSize_prefix) */ + + RETURN_ERROR_IF(srcSize, srcSize_wrong, "input not entirely consumed"); + + return (size_t)((BYTE*)dst - (BYTE*)dststart); +} + +size_t ZSTD_decompress_usingDict(ZSTD_DCtx* dctx, + void* dst, size_t dstCapacity, + const void* src, size_t srcSize, + const void* dict, size_t dictSize) +{ + return ZSTD_decompressMultiFrame(dctx, dst, dstCapacity, src, srcSize, dict, dictSize, NULL); +} + + +static ZSTD_DDict const* ZSTD_getDDict(ZSTD_DCtx* dctx) +{ + switch (dctx->dictUses) { + default: + assert(0 /* Impossible */); + ZSTD_FALLTHROUGH; + case ZSTD_dont_use: + ZSTD_clearDict(dctx); + return NULL; + case ZSTD_use_indefinitely: + return dctx->ddict; + case ZSTD_use_once: + dctx->dictUses = ZSTD_dont_use; + return dctx->ddict; + } +} + +size_t ZSTD_decompressDCtx(ZSTD_DCtx* dctx, void* dst, size_t dstCapacity, const void* src, size_t srcSize) +{ + return ZSTD_decompress_usingDDict(dctx, dst, dstCapacity, src, srcSize, ZSTD_getDDict(dctx)); +} + + +size_t ZSTD_decompress(void* dst, size_t dstCapacity, const void* src, size_t srcSize) +{ +#if defined(ZSTD_HEAPMODE) && (ZSTD_HEAPMODE>=1) + size_t regenSize; + ZSTD_DCtx* const dctx = ZSTD_createDCtx_internal(ZSTD_defaultCMem); + RETURN_ERROR_IF(dctx==NULL, memory_allocation, "NULL pointer!"); + regenSize = ZSTD_decompressDCtx(dctx, dst, dstCapacity, src, srcSize); + ZSTD_freeDCtx(dctx); + return regenSize; +#else /* stack mode */ + ZSTD_DCtx dctx; + ZSTD_initDCtx_internal(&dctx); + return ZSTD_decompressDCtx(&dctx, dst, dstCapacity, src, srcSize); +#endif +} + + +/*-************************************** +* Advanced Streaming Decompression API +* Bufferless and synchronous +****************************************/ +size_t ZSTD_nextSrcSizeToDecompress(ZSTD_DCtx* dctx) { return dctx->expected; } + +/* + * Similar to ZSTD_nextSrcSizeToDecompress(), but when a block input can be streamed, + * we allow taking a partial block as the input. Currently only raw uncompressed blocks can + * be streamed. + * + * For blocks that can be streamed, this allows us to reduce the latency until we produce + * output, and avoid copying the input. + * + * @param inputSize - The total amount of input that the caller currently has. + */ +static size_t ZSTD_nextSrcSizeToDecompressWithInputSize(ZSTD_DCtx* dctx, size_t inputSize) { + if (!(dctx->stage == ZSTDds_decompressBlock || dctx->stage == ZSTDds_decompressLastBlock)) + return dctx->expected; + if (dctx->bType != bt_raw) + return dctx->expected; + return BOUNDED(1, inputSize, dctx->expected); +} + +ZSTD_nextInputType_e ZSTD_nextInputType(ZSTD_DCtx* dctx) { + switch(dctx->stage) + { + default: /* should not happen */ + assert(0); + ZSTD_FALLTHROUGH; + case ZSTDds_getFrameHeaderSize: + ZSTD_FALLTHROUGH; + case ZSTDds_decodeFrameHeader: + return ZSTDnit_frameHeader; + case ZSTDds_decodeBlockHeader: + return ZSTDnit_blockHeader; + case ZSTDds_decompressBlock: + return ZSTDnit_block; + case ZSTDds_decompressLastBlock: + return ZSTDnit_lastBlock; + case ZSTDds_checkChecksum: + return ZSTDnit_checksum; + case ZSTDds_decodeSkippableHeader: + ZSTD_FALLTHROUGH; + case ZSTDds_skipFrame: + return ZSTDnit_skippableFrame; + } +} + +static int ZSTD_isSkipFrame(ZSTD_DCtx* dctx) { return dctx->stage == ZSTDds_skipFrame; } + +/* ZSTD_decompressContinue() : + * srcSize : must be the exact nb of bytes expected (see ZSTD_nextSrcSizeToDecompress()) + * @return : nb of bytes generated into `dst` (necessarily <= `dstCapacity) + * or an error code, which can be tested using ZSTD_isError() */ +size_t ZSTD_decompressContinue(ZSTD_DCtx* dctx, void* dst, size_t dstCapacity, const void* src, size_t srcSize) +{ + DEBUGLOG(5, "ZSTD_decompressContinue (srcSize:%u)", (unsigned)srcSize); + /* Sanity check */ + RETURN_ERROR_IF(srcSize != ZSTD_nextSrcSizeToDecompressWithInputSize(dctx, srcSize), srcSize_wrong, "not allowed"); + ZSTD_checkContinuity(dctx, dst, dstCapacity); + + dctx->processedCSize += srcSize; + + switch (dctx->stage) + { + case ZSTDds_getFrameHeaderSize : + assert(src != NULL); + if (dctx->format == ZSTD_f_zstd1) { /* allows header */ + assert(srcSize >= ZSTD_FRAMEIDSIZE); /* to read skippable magic number */ + if ((MEM_readLE32(src) & ZSTD_MAGIC_SKIPPABLE_MASK) == ZSTD_MAGIC_SKIPPABLE_START) { /* skippable frame */ + ZSTD_memcpy(dctx->headerBuffer, src, srcSize); + dctx->expected = ZSTD_SKIPPABLEHEADERSIZE - srcSize; /* remaining to load to get full skippable frame header */ + dctx->stage = ZSTDds_decodeSkippableHeader; + return 0; + } } + dctx->headerSize = ZSTD_frameHeaderSize_internal(src, srcSize, dctx->format); + if (ZSTD_isError(dctx->headerSize)) return dctx->headerSize; + ZSTD_memcpy(dctx->headerBuffer, src, srcSize); + dctx->expected = dctx->headerSize - srcSize; + dctx->stage = ZSTDds_decodeFrameHeader; + return 0; + + case ZSTDds_decodeFrameHeader: + assert(src != NULL); + ZSTD_memcpy(dctx->headerBuffer + (dctx->headerSize - srcSize), src, srcSize); + FORWARD_IF_ERROR(ZSTD_decodeFrameHeader(dctx, dctx->headerBuffer, dctx->headerSize), ""); + dctx->expected = ZSTD_blockHeaderSize; + dctx->stage = ZSTDds_decodeBlockHeader; + return 0; + + case ZSTDds_decodeBlockHeader: + { blockProperties_t bp; + size_t const cBlockSize = ZSTD_getcBlockSize(src, ZSTD_blockHeaderSize, &bp); + if (ZSTD_isError(cBlockSize)) return cBlockSize; + RETURN_ERROR_IF(cBlockSize > dctx->fParams.blockSizeMax, corruption_detected, "Block Size Exceeds Maximum"); + dctx->expected = cBlockSize; + dctx->bType = bp.blockType; + dctx->rleSize = bp.origSize; + if (cBlockSize) { + dctx->stage = bp.lastBlock ? ZSTDds_decompressLastBlock : ZSTDds_decompressBlock; + return 0; + } + /* empty block */ + if (bp.lastBlock) { + if (dctx->fParams.checksumFlag) { + dctx->expected = 4; + dctx->stage = ZSTDds_checkChecksum; + } else { + dctx->expected = 0; /* end of frame */ + dctx->stage = ZSTDds_getFrameHeaderSize; + } + } else { + dctx->expected = ZSTD_blockHeaderSize; /* jump to next header */ + dctx->stage = ZSTDds_decodeBlockHeader; + } + return 0; + } + + case ZSTDds_decompressLastBlock: + case ZSTDds_decompressBlock: + DEBUGLOG(5, "ZSTD_decompressContinue: case ZSTDds_decompressBlock"); + { size_t rSize; + switch(dctx->bType) + { + case bt_compressed: + DEBUGLOG(5, "ZSTD_decompressContinue: case bt_compressed"); + rSize = ZSTD_decompressBlock_internal(dctx, dst, dstCapacity, src, srcSize, /* frame */ 1, is_streaming); + dctx->expected = 0; /* Streaming not supported */ + break; + case bt_raw : + assert(srcSize <= dctx->expected); + rSize = ZSTD_copyRawBlock(dst, dstCapacity, src, srcSize); + FORWARD_IF_ERROR(rSize, "ZSTD_copyRawBlock failed"); + assert(rSize == srcSize); + dctx->expected -= rSize; + break; + case bt_rle : + rSize = ZSTD_setRleBlock(dst, dstCapacity, *(const BYTE*)src, dctx->rleSize); + dctx->expected = 0; /* Streaming not supported */ + break; + case bt_reserved : /* should never happen */ + default: + RETURN_ERROR(corruption_detected, "invalid block type"); + } + FORWARD_IF_ERROR(rSize, ""); + RETURN_ERROR_IF(rSize > dctx->fParams.blockSizeMax, corruption_detected, "Decompressed Block Size Exceeds Maximum"); + DEBUGLOG(5, "ZSTD_decompressContinue: decoded size from block : %u", (unsigned)rSize); + dctx->decodedSize += rSize; + if (dctx->validateChecksum) xxh64_update(&dctx->xxhState, dst, rSize); + dctx->previousDstEnd = (char*)dst + rSize; + + /* Stay on the same stage until we are finished streaming the block. */ + if (dctx->expected > 0) { + return rSize; + } + + if (dctx->stage == ZSTDds_decompressLastBlock) { /* end of frame */ + DEBUGLOG(4, "ZSTD_decompressContinue: decoded size from frame : %u", (unsigned)dctx->decodedSize); + RETURN_ERROR_IF( + dctx->fParams.frameContentSize != ZSTD_CONTENTSIZE_UNKNOWN + && dctx->decodedSize != dctx->fParams.frameContentSize, + corruption_detected, ""); + if (dctx->fParams.checksumFlag) { /* another round for frame checksum */ + dctx->expected = 4; + dctx->stage = ZSTDds_checkChecksum; + } else { + ZSTD_DCtx_trace_end(dctx, dctx->decodedSize, dctx->processedCSize, /* streaming */ 1); + dctx->expected = 0; /* ends here */ + dctx->stage = ZSTDds_getFrameHeaderSize; + } + } else { + dctx->stage = ZSTDds_decodeBlockHeader; + dctx->expected = ZSTD_blockHeaderSize; + } + return rSize; + } + + case ZSTDds_checkChecksum: + assert(srcSize == 4); /* guaranteed by dctx->expected */ + { + if (dctx->validateChecksum) { + U32 const h32 = (U32)xxh64_digest(&dctx->xxhState); + U32 const check32 = MEM_readLE32(src); + DEBUGLOG(4, "ZSTD_decompressContinue: checksum : calculated %08X :: %08X read", (unsigned)h32, (unsigned)check32); + RETURN_ERROR_IF(check32 != h32, checksum_wrong, ""); + } + ZSTD_DCtx_trace_end(dctx, dctx->decodedSize, dctx->processedCSize, /* streaming */ 1); + dctx->expected = 0; + dctx->stage = ZSTDds_getFrameHeaderSize; + return 0; + } + + case ZSTDds_decodeSkippableHeader: + assert(src != NULL); + assert(srcSize <= ZSTD_SKIPPABLEHEADERSIZE); + ZSTD_memcpy(dctx->headerBuffer + (ZSTD_SKIPPABLEHEADERSIZE - srcSize), src, srcSize); /* complete skippable header */ + dctx->expected = MEM_readLE32(dctx->headerBuffer + ZSTD_FRAMEIDSIZE); /* note : dctx->expected can grow seriously large, beyond local buffer size */ + dctx->stage = ZSTDds_skipFrame; + return 0; + + case ZSTDds_skipFrame: + dctx->expected = 0; + dctx->stage = ZSTDds_getFrameHeaderSize; + return 0; + + default: + assert(0); /* impossible */ + RETURN_ERROR(GENERIC, "impossible to reach"); /* some compiler require default to do something */ + } +} + + +static size_t ZSTD_refDictContent(ZSTD_DCtx* dctx, const void* dict, size_t dictSize) +{ + dctx->dictEnd = dctx->previousDstEnd; + dctx->virtualStart = (const char*)dict - ((const char*)(dctx->previousDstEnd) - (const char*)(dctx->prefixStart)); + dctx->prefixStart = dict; + dctx->previousDstEnd = (const char*)dict + dictSize; +#ifdef FUZZING_BUILD_MODE_UNSAFE_FOR_PRODUCTION + dctx->dictContentBeginForFuzzing = dctx->prefixStart; + dctx->dictContentEndForFuzzing = dctx->previousDstEnd; +#endif + return 0; +} + +/*! ZSTD_loadDEntropy() : + * dict : must point at beginning of a valid zstd dictionary. + * @return : size of entropy tables read */ +size_t +ZSTD_loadDEntropy(ZSTD_entropyDTables_t* entropy, + const void* const dict, size_t const dictSize) +{ + const BYTE* dictPtr = (const BYTE*)dict; + const BYTE* const dictEnd = dictPtr + dictSize; + + RETURN_ERROR_IF(dictSize <= 8, dictionary_corrupted, "dict is too small"); + assert(MEM_readLE32(dict) == ZSTD_MAGIC_DICTIONARY); /* dict must be valid */ + dictPtr += 8; /* skip header = magic + dictID */ + + ZSTD_STATIC_ASSERT(offsetof(ZSTD_entropyDTables_t, OFTable) == offsetof(ZSTD_entropyDTables_t, LLTable) + sizeof(entropy->LLTable)); + ZSTD_STATIC_ASSERT(offsetof(ZSTD_entropyDTables_t, MLTable) == offsetof(ZSTD_entropyDTables_t, OFTable) + sizeof(entropy->OFTable)); + ZSTD_STATIC_ASSERT(sizeof(entropy->LLTable) + sizeof(entropy->OFTable) + sizeof(entropy->MLTable) >= HUF_DECOMPRESS_WORKSPACE_SIZE); + { void* const workspace = &entropy->LLTable; /* use fse tables as temporary workspace; implies fse tables are grouped together */ + size_t const workspaceSize = sizeof(entropy->LLTable) + sizeof(entropy->OFTable) + sizeof(entropy->MLTable); +#ifdef HUF_FORCE_DECOMPRESS_X1 + /* in minimal huffman, we always use X1 variants */ + size_t const hSize = HUF_readDTableX1_wksp(entropy->hufTable, + dictPtr, dictEnd - dictPtr, + workspace, workspaceSize); +#else + size_t const hSize = HUF_readDTableX2_wksp(entropy->hufTable, + dictPtr, (size_t)(dictEnd - dictPtr), + workspace, workspaceSize); +#endif + RETURN_ERROR_IF(HUF_isError(hSize), dictionary_corrupted, ""); + dictPtr += hSize; + } + + { short offcodeNCount[MaxOff+1]; + unsigned offcodeMaxValue = MaxOff, offcodeLog; + size_t const offcodeHeaderSize = FSE_readNCount(offcodeNCount, &offcodeMaxValue, &offcodeLog, dictPtr, (size_t)(dictEnd-dictPtr)); + RETURN_ERROR_IF(FSE_isError(offcodeHeaderSize), dictionary_corrupted, ""); + RETURN_ERROR_IF(offcodeMaxValue > MaxOff, dictionary_corrupted, ""); + RETURN_ERROR_IF(offcodeLog > OffFSELog, dictionary_corrupted, ""); + ZSTD_buildFSETable( entropy->OFTable, + offcodeNCount, offcodeMaxValue, + OF_base, OF_bits, + offcodeLog, + entropy->workspace, sizeof(entropy->workspace), + /* bmi2 */0); + dictPtr += offcodeHeaderSize; + } + + { short matchlengthNCount[MaxML+1]; + unsigned matchlengthMaxValue = MaxML, matchlengthLog; + size_t const matchlengthHeaderSize = FSE_readNCount(matchlengthNCount, &matchlengthMaxValue, &matchlengthLog, dictPtr, (size_t)(dictEnd-dictPtr)); + RETURN_ERROR_IF(FSE_isError(matchlengthHeaderSize), dictionary_corrupted, ""); + RETURN_ERROR_IF(matchlengthMaxValue > MaxML, dictionary_corrupted, ""); + RETURN_ERROR_IF(matchlengthLog > MLFSELog, dictionary_corrupted, ""); + ZSTD_buildFSETable( entropy->MLTable, + matchlengthNCount, matchlengthMaxValue, + ML_base, ML_bits, + matchlengthLog, + entropy->workspace, sizeof(entropy->workspace), + /* bmi2 */ 0); + dictPtr += matchlengthHeaderSize; + } + + { short litlengthNCount[MaxLL+1]; + unsigned litlengthMaxValue = MaxLL, litlengthLog; + size_t const litlengthHeaderSize = FSE_readNCount(litlengthNCount, &litlengthMaxValue, &litlengthLog, dictPtr, (size_t)(dictEnd-dictPtr)); + RETURN_ERROR_IF(FSE_isError(litlengthHeaderSize), dictionary_corrupted, ""); + RETURN_ERROR_IF(litlengthMaxValue > MaxLL, dictionary_corrupted, ""); + RETURN_ERROR_IF(litlengthLog > LLFSELog, dictionary_corrupted, ""); + ZSTD_buildFSETable( entropy->LLTable, + litlengthNCount, litlengthMaxValue, + LL_base, LL_bits, + litlengthLog, + entropy->workspace, sizeof(entropy->workspace), + /* bmi2 */ 0); + dictPtr += litlengthHeaderSize; + } + + RETURN_ERROR_IF(dictPtr+12 > dictEnd, dictionary_corrupted, ""); + { int i; + size_t const dictContentSize = (size_t)(dictEnd - (dictPtr+12)); + for (i=0; i<3; i++) { + U32 const rep = MEM_readLE32(dictPtr); dictPtr += 4; + RETURN_ERROR_IF(rep==0 || rep > dictContentSize, + dictionary_corrupted, ""); + entropy->rep[i] = rep; + } } + + return (size_t)(dictPtr - (const BYTE*)dict); +} + +static size_t ZSTD_decompress_insertDictionary(ZSTD_DCtx* dctx, const void* dict, size_t dictSize) +{ + if (dictSize < 8) return ZSTD_refDictContent(dctx, dict, dictSize); + { U32 const magic = MEM_readLE32(dict); + if (magic != ZSTD_MAGIC_DICTIONARY) { + return ZSTD_refDictContent(dctx, dict, dictSize); /* pure content mode */ + } } + dctx->dictID = MEM_readLE32((const char*)dict + ZSTD_FRAMEIDSIZE); + + /* load entropy tables */ + { size_t const eSize = ZSTD_loadDEntropy(&dctx->entropy, dict, dictSize); + RETURN_ERROR_IF(ZSTD_isError(eSize), dictionary_corrupted, ""); + dict = (const char*)dict + eSize; + dictSize -= eSize; + } + dctx->litEntropy = dctx->fseEntropy = 1; + + /* reference dictionary content */ + return ZSTD_refDictContent(dctx, dict, dictSize); +} + +size_t ZSTD_decompressBegin(ZSTD_DCtx* dctx) +{ + assert(dctx != NULL); + dctx->expected = ZSTD_startingInputLength(dctx->format); /* dctx->format must be properly set */ + dctx->stage = ZSTDds_getFrameHeaderSize; + dctx->processedCSize = 0; + dctx->decodedSize = 0; + dctx->previousDstEnd = NULL; + dctx->prefixStart = NULL; + dctx->virtualStart = NULL; + dctx->dictEnd = NULL; + dctx->entropy.hufTable[0] = (HUF_DTable)((HufLog)*0x1000001); /* cover both little and big endian */ + dctx->litEntropy = dctx->fseEntropy = 0; + dctx->dictID = 0; + dctx->bType = bt_reserved; + ZSTD_STATIC_ASSERT(sizeof(dctx->entropy.rep) == sizeof(repStartValue)); + ZSTD_memcpy(dctx->entropy.rep, repStartValue, sizeof(repStartValue)); /* initial repcodes */ + dctx->LLTptr = dctx->entropy.LLTable; + dctx->MLTptr = dctx->entropy.MLTable; + dctx->OFTptr = dctx->entropy.OFTable; + dctx->HUFptr = dctx->entropy.hufTable; + return 0; +} + +size_t ZSTD_decompressBegin_usingDict(ZSTD_DCtx* dctx, const void* dict, size_t dictSize) +{ + FORWARD_IF_ERROR( ZSTD_decompressBegin(dctx) , ""); + if (dict && dictSize) + RETURN_ERROR_IF( + ZSTD_isError(ZSTD_decompress_insertDictionary(dctx, dict, dictSize)), + dictionary_corrupted, ""); + return 0; +} + + +/* ====== ZSTD_DDict ====== */ + +size_t ZSTD_decompressBegin_usingDDict(ZSTD_DCtx* dctx, const ZSTD_DDict* ddict) +{ + DEBUGLOG(4, "ZSTD_decompressBegin_usingDDict"); + assert(dctx != NULL); + if (ddict) { + const char* const dictStart = (const char*)ZSTD_DDict_dictContent(ddict); + size_t const dictSize = ZSTD_DDict_dictSize(ddict); + const void* const dictEnd = dictStart + dictSize; + dctx->ddictIsCold = (dctx->dictEnd != dictEnd); + DEBUGLOG(4, "DDict is %s", + dctx->ddictIsCold ? "~cold~" : "hot!"); + } + FORWARD_IF_ERROR( ZSTD_decompressBegin(dctx) , ""); + if (ddict) { /* NULL ddict is equivalent to no dictionary */ + ZSTD_copyDDictParameters(dctx, ddict); + } + return 0; +} + +/*! ZSTD_getDictID_fromDict() : + * Provides the dictID stored within dictionary. + * if @return == 0, the dictionary is not conformant with Zstandard specification. + * It can still be loaded, but as a content-only dictionary. */ +unsigned ZSTD_getDictID_fromDict(const void* dict, size_t dictSize) +{ + if (dictSize < 8) return 0; + if (MEM_readLE32(dict) != ZSTD_MAGIC_DICTIONARY) return 0; + return MEM_readLE32((const char*)dict + ZSTD_FRAMEIDSIZE); +} + +/*! ZSTD_getDictID_fromFrame() : + * Provides the dictID required to decompress frame stored within `src`. + * If @return == 0, the dictID could not be decoded. + * This could for one of the following reasons : + * - The frame does not require a dictionary (most common case). + * - The frame was built with dictID intentionally removed. + * Needed dictionary is a hidden information. + * Note : this use case also happens when using a non-conformant dictionary. + * - `srcSize` is too small, and as a result, frame header could not be decoded. + * Note : possible if `srcSize < ZSTD_FRAMEHEADERSIZE_MAX`. + * - This is not a Zstandard frame. + * When identifying the exact failure cause, it's possible to use + * ZSTD_getFrameHeader(), which will provide a more precise error code. */ +unsigned ZSTD_getDictID_fromFrame(const void* src, size_t srcSize) +{ + ZSTD_frameHeader zfp = { 0, 0, 0, ZSTD_frame, 0, 0, 0 }; + size_t const hError = ZSTD_getFrameHeader(&zfp, src, srcSize); + if (ZSTD_isError(hError)) return 0; + return zfp.dictID; +} + + +/*! ZSTD_decompress_usingDDict() : +* Decompression using a pre-digested Dictionary +* Use dictionary without significant overhead. */ +size_t ZSTD_decompress_usingDDict(ZSTD_DCtx* dctx, + void* dst, size_t dstCapacity, + const void* src, size_t srcSize, + const ZSTD_DDict* ddict) +{ + /* pass content and size in case legacy frames are encountered */ + return ZSTD_decompressMultiFrame(dctx, dst, dstCapacity, src, srcSize, + NULL, 0, + ddict); +} + + +/*===================================== +* Streaming decompression +*====================================*/ + +ZSTD_DStream* ZSTD_createDStream(void) +{ + DEBUGLOG(3, "ZSTD_createDStream"); + return ZSTD_createDCtx_internal(ZSTD_defaultCMem); +} + +ZSTD_DStream* ZSTD_initStaticDStream(void *workspace, size_t workspaceSize) +{ + return ZSTD_initStaticDCtx(workspace, workspaceSize); +} + +ZSTD_DStream* ZSTD_createDStream_advanced(ZSTD_customMem customMem) +{ + return ZSTD_createDCtx_internal(customMem); +} + +size_t ZSTD_freeDStream(ZSTD_DStream* zds) +{ + return ZSTD_freeDCtx(zds); +} + + +/* *** Initialization *** */ + +size_t ZSTD_DStreamInSize(void) { return ZSTD_BLOCKSIZE_MAX + ZSTD_blockHeaderSize; } +size_t ZSTD_DStreamOutSize(void) { return ZSTD_BLOCKSIZE_MAX; } + +size_t ZSTD_DCtx_loadDictionary_advanced(ZSTD_DCtx* dctx, + const void* dict, size_t dictSize, + ZSTD_dictLoadMethod_e dictLoadMethod, + ZSTD_dictContentType_e dictContentType) +{ + RETURN_ERROR_IF(dctx->streamStage != zdss_init, stage_wrong, ""); + ZSTD_clearDict(dctx); + if (dict && dictSize != 0) { + dctx->ddictLocal = ZSTD_createDDict_advanced(dict, dictSize, dictLoadMethod, dictContentType, dctx->customMem); + RETURN_ERROR_IF(dctx->ddictLocal == NULL, memory_allocation, "NULL pointer!"); + dctx->ddict = dctx->ddictLocal; + dctx->dictUses = ZSTD_use_indefinitely; + } + return 0; +} + +size_t ZSTD_DCtx_loadDictionary_byReference(ZSTD_DCtx* dctx, const void* dict, size_t dictSize) +{ + return ZSTD_DCtx_loadDictionary_advanced(dctx, dict, dictSize, ZSTD_dlm_byRef, ZSTD_dct_auto); +} + +size_t ZSTD_DCtx_loadDictionary(ZSTD_DCtx* dctx, const void* dict, size_t dictSize) +{ + return ZSTD_DCtx_loadDictionary_advanced(dctx, dict, dictSize, ZSTD_dlm_byCopy, ZSTD_dct_auto); +} + +size_t ZSTD_DCtx_refPrefix_advanced(ZSTD_DCtx* dctx, const void* prefix, size_t prefixSize, ZSTD_dictContentType_e dictContentType) +{ + FORWARD_IF_ERROR(ZSTD_DCtx_loadDictionary_advanced(dctx, prefix, prefixSize, ZSTD_dlm_byRef, dictContentType), ""); + dctx->dictUses = ZSTD_use_once; + return 0; +} + +size_t ZSTD_DCtx_refPrefix(ZSTD_DCtx* dctx, const void* prefix, size_t prefixSize) +{ + return ZSTD_DCtx_refPrefix_advanced(dctx, prefix, prefixSize, ZSTD_dct_rawContent); +} + + +/* ZSTD_initDStream_usingDict() : + * return : expected size, aka ZSTD_startingInputLength(). + * this function cannot fail */ +size_t ZSTD_initDStream_usingDict(ZSTD_DStream* zds, const void* dict, size_t dictSize) +{ + DEBUGLOG(4, "ZSTD_initDStream_usingDict"); + FORWARD_IF_ERROR( ZSTD_DCtx_reset(zds, ZSTD_reset_session_only) , ""); + FORWARD_IF_ERROR( ZSTD_DCtx_loadDictionary(zds, dict, dictSize) , ""); + return ZSTD_startingInputLength(zds->format); +} + +/* note : this variant can't fail */ +size_t ZSTD_initDStream(ZSTD_DStream* zds) +{ + DEBUGLOG(4, "ZSTD_initDStream"); + return ZSTD_initDStream_usingDDict(zds, NULL); +} + +/* ZSTD_initDStream_usingDDict() : + * ddict will just be referenced, and must outlive decompression session + * this function cannot fail */ +size_t ZSTD_initDStream_usingDDict(ZSTD_DStream* dctx, const ZSTD_DDict* ddict) +{ + FORWARD_IF_ERROR( ZSTD_DCtx_reset(dctx, ZSTD_reset_session_only) , ""); + FORWARD_IF_ERROR( ZSTD_DCtx_refDDict(dctx, ddict) , ""); + return ZSTD_startingInputLength(dctx->format); +} + +/* ZSTD_resetDStream() : + * return : expected size, aka ZSTD_startingInputLength(). + * this function cannot fail */ +size_t ZSTD_resetDStream(ZSTD_DStream* dctx) +{ + FORWARD_IF_ERROR(ZSTD_DCtx_reset(dctx, ZSTD_reset_session_only), ""); + return ZSTD_startingInputLength(dctx->format); +} + + +size_t ZSTD_DCtx_refDDict(ZSTD_DCtx* dctx, const ZSTD_DDict* ddict) +{ + RETURN_ERROR_IF(dctx->streamStage != zdss_init, stage_wrong, ""); + ZSTD_clearDict(dctx); + if (ddict) { + dctx->ddict = ddict; + dctx->dictUses = ZSTD_use_indefinitely; + if (dctx->refMultipleDDicts == ZSTD_rmd_refMultipleDDicts) { + if (dctx->ddictSet == NULL) { + dctx->ddictSet = ZSTD_createDDictHashSet(dctx->customMem); + if (!dctx->ddictSet) { + RETURN_ERROR(memory_allocation, "Failed to allocate memory for hash set!"); + } + } + assert(!dctx->staticSize); /* Impossible: ddictSet cannot have been allocated if static dctx */ + FORWARD_IF_ERROR(ZSTD_DDictHashSet_addDDict(dctx->ddictSet, ddict, dctx->customMem), ""); + } + } + return 0; +} + +/* ZSTD_DCtx_setMaxWindowSize() : + * note : no direct equivalence in ZSTD_DCtx_setParameter, + * since this version sets windowSize, and the other sets windowLog */ +size_t ZSTD_DCtx_setMaxWindowSize(ZSTD_DCtx* dctx, size_t maxWindowSize) +{ + ZSTD_bounds const bounds = ZSTD_dParam_getBounds(ZSTD_d_windowLogMax); + size_t const min = (size_t)1 << bounds.lowerBound; + size_t const max = (size_t)1 << bounds.upperBound; + RETURN_ERROR_IF(dctx->streamStage != zdss_init, stage_wrong, ""); + RETURN_ERROR_IF(maxWindowSize < min, parameter_outOfBound, ""); + RETURN_ERROR_IF(maxWindowSize > max, parameter_outOfBound, ""); + dctx->maxWindowSize = maxWindowSize; + return 0; +} + +size_t ZSTD_DCtx_setFormat(ZSTD_DCtx* dctx, ZSTD_format_e format) +{ + return ZSTD_DCtx_setParameter(dctx, ZSTD_d_format, (int)format); +} + +ZSTD_bounds ZSTD_dParam_getBounds(ZSTD_dParameter dParam) +{ + ZSTD_bounds bounds = { 0, 0, 0 }; + switch(dParam) { + case ZSTD_d_windowLogMax: + bounds.lowerBound = ZSTD_WINDOWLOG_ABSOLUTEMIN; + bounds.upperBound = ZSTD_WINDOWLOG_MAX; + return bounds; + case ZSTD_d_format: + bounds.lowerBound = (int)ZSTD_f_zstd1; + bounds.upperBound = (int)ZSTD_f_zstd1_magicless; + ZSTD_STATIC_ASSERT(ZSTD_f_zstd1 < ZSTD_f_zstd1_magicless); + return bounds; + case ZSTD_d_stableOutBuffer: + bounds.lowerBound = (int)ZSTD_bm_buffered; + bounds.upperBound = (int)ZSTD_bm_stable; + return bounds; + case ZSTD_d_forceIgnoreChecksum: + bounds.lowerBound = (int)ZSTD_d_validateChecksum; + bounds.upperBound = (int)ZSTD_d_ignoreChecksum; + return bounds; + case ZSTD_d_refMultipleDDicts: + bounds.lowerBound = (int)ZSTD_rmd_refSingleDDict; + bounds.upperBound = (int)ZSTD_rmd_refMultipleDDicts; + return bounds; + default:; + } + bounds.error = ERROR(parameter_unsupported); + return bounds; +} + +/* ZSTD_dParam_withinBounds: + * @return 1 if value is within dParam bounds, + * 0 otherwise */ +static int ZSTD_dParam_withinBounds(ZSTD_dParameter dParam, int value) +{ + ZSTD_bounds const bounds = ZSTD_dParam_getBounds(dParam); + if (ZSTD_isError(bounds.error)) return 0; + if (value < bounds.lowerBound) return 0; + if (value > bounds.upperBound) return 0; + return 1; +} + +#define CHECK_DBOUNDS(p,v) { \ + RETURN_ERROR_IF(!ZSTD_dParam_withinBounds(p, v), parameter_outOfBound, ""); \ +} + +size_t ZSTD_DCtx_getParameter(ZSTD_DCtx* dctx, ZSTD_dParameter param, int* value) +{ + switch (param) { + case ZSTD_d_windowLogMax: + *value = (int)ZSTD_highbit32((U32)dctx->maxWindowSize); + return 0; + case ZSTD_d_format: + *value = (int)dctx->format; + return 0; + case ZSTD_d_stableOutBuffer: + *value = (int)dctx->outBufferMode; + return 0; + case ZSTD_d_forceIgnoreChecksum: + *value = (int)dctx->forceIgnoreChecksum; + return 0; + case ZSTD_d_refMultipleDDicts: + *value = (int)dctx->refMultipleDDicts; + return 0; + default:; + } + RETURN_ERROR(parameter_unsupported, ""); +} + +size_t ZSTD_DCtx_setParameter(ZSTD_DCtx* dctx, ZSTD_dParameter dParam, int value) +{ + RETURN_ERROR_IF(dctx->streamStage != zdss_init, stage_wrong, ""); + switch(dParam) { + case ZSTD_d_windowLogMax: + if (value == 0) value = ZSTD_WINDOWLOG_LIMIT_DEFAULT; + CHECK_DBOUNDS(ZSTD_d_windowLogMax, value); + dctx->maxWindowSize = ((size_t)1) << value; + return 0; + case ZSTD_d_format: + CHECK_DBOUNDS(ZSTD_d_format, value); + dctx->format = (ZSTD_format_e)value; + return 0; + case ZSTD_d_stableOutBuffer: + CHECK_DBOUNDS(ZSTD_d_stableOutBuffer, value); + dctx->outBufferMode = (ZSTD_bufferMode_e)value; + return 0; + case ZSTD_d_forceIgnoreChecksum: + CHECK_DBOUNDS(ZSTD_d_forceIgnoreChecksum, value); + dctx->forceIgnoreChecksum = (ZSTD_forceIgnoreChecksum_e)value; + return 0; + case ZSTD_d_refMultipleDDicts: + CHECK_DBOUNDS(ZSTD_d_refMultipleDDicts, value); + if (dctx->staticSize != 0) { + RETURN_ERROR(parameter_unsupported, "Static dctx does not support multiple DDicts!"); + } + dctx->refMultipleDDicts = (ZSTD_refMultipleDDicts_e)value; + return 0; + default:; + } + RETURN_ERROR(parameter_unsupported, ""); +} + +size_t ZSTD_DCtx_reset(ZSTD_DCtx* dctx, ZSTD_ResetDirective reset) +{ + if ( (reset == ZSTD_reset_session_only) + || (reset == ZSTD_reset_session_and_parameters) ) { + dctx->streamStage = zdss_init; + dctx->noForwardProgress = 0; + } + if ( (reset == ZSTD_reset_parameters) + || (reset == ZSTD_reset_session_and_parameters) ) { + RETURN_ERROR_IF(dctx->streamStage != zdss_init, stage_wrong, ""); + ZSTD_clearDict(dctx); + ZSTD_DCtx_resetParameters(dctx); + } + return 0; +} + + +size_t ZSTD_sizeof_DStream(const ZSTD_DStream* dctx) +{ + return ZSTD_sizeof_DCtx(dctx); +} + +size_t ZSTD_decodingBufferSize_min(unsigned long long windowSize, unsigned long long frameContentSize) +{ + size_t const blockSize = (size_t) MIN(windowSize, ZSTD_BLOCKSIZE_MAX); + /* space is needed to store the litbuffer after the output of a given block without stomping the extDict of a previous run, as well as to cover both windows against wildcopy*/ + unsigned long long const neededRBSize = windowSize + blockSize + ZSTD_BLOCKSIZE_MAX + (WILDCOPY_OVERLENGTH * 2); + unsigned long long const neededSize = MIN(frameContentSize, neededRBSize); + size_t const minRBSize = (size_t) neededSize; + RETURN_ERROR_IF((unsigned long long)minRBSize != neededSize, + frameParameter_windowTooLarge, ""); + return minRBSize; +} + +size_t ZSTD_estimateDStreamSize(size_t windowSize) +{ + size_t const blockSize = MIN(windowSize, ZSTD_BLOCKSIZE_MAX); + size_t const inBuffSize = blockSize; /* no block can be larger */ + size_t const outBuffSize = ZSTD_decodingBufferSize_min(windowSize, ZSTD_CONTENTSIZE_UNKNOWN); + return ZSTD_estimateDCtxSize() + inBuffSize + outBuffSize; +} + +size_t ZSTD_estimateDStreamSize_fromFrame(const void* src, size_t srcSize) +{ + U32 const windowSizeMax = 1U << ZSTD_WINDOWLOG_MAX; /* note : should be user-selectable, but requires an additional parameter (or a dctx) */ + ZSTD_frameHeader zfh; + size_t const err = ZSTD_getFrameHeader(&zfh, src, srcSize); + if (ZSTD_isError(err)) return err; + RETURN_ERROR_IF(err>0, srcSize_wrong, ""); + RETURN_ERROR_IF(zfh.windowSize > windowSizeMax, + frameParameter_windowTooLarge, ""); + return ZSTD_estimateDStreamSize((size_t)zfh.windowSize); +} + + +/* ***** Decompression ***** */ + +static int ZSTD_DCtx_isOverflow(ZSTD_DStream* zds, size_t const neededInBuffSize, size_t const neededOutBuffSize) +{ + return (zds->inBuffSize + zds->outBuffSize) >= (neededInBuffSize + neededOutBuffSize) * ZSTD_WORKSPACETOOLARGE_FACTOR; +} + +static void ZSTD_DCtx_updateOversizedDuration(ZSTD_DStream* zds, size_t const neededInBuffSize, size_t const neededOutBuffSize) +{ + if (ZSTD_DCtx_isOverflow(zds, neededInBuffSize, neededOutBuffSize)) + zds->oversizedDuration++; + else + zds->oversizedDuration = 0; +} + +static int ZSTD_DCtx_isOversizedTooLong(ZSTD_DStream* zds) +{ + return zds->oversizedDuration >= ZSTD_WORKSPACETOOLARGE_MAXDURATION; +} + +/* Checks that the output buffer hasn't changed if ZSTD_obm_stable is used. */ +static size_t ZSTD_checkOutBuffer(ZSTD_DStream const* zds, ZSTD_outBuffer const* output) +{ + ZSTD_outBuffer const expect = zds->expectedOutBuffer; + /* No requirement when ZSTD_obm_stable is not enabled. */ + if (zds->outBufferMode != ZSTD_bm_stable) + return 0; + /* Any buffer is allowed in zdss_init, this must be the same for every other call until + * the context is reset. + */ + if (zds->streamStage == zdss_init) + return 0; + /* The buffer must match our expectation exactly. */ + if (expect.dst == output->dst && expect.pos == output->pos && expect.size == output->size) + return 0; + RETURN_ERROR(dstBuffer_wrong, "ZSTD_d_stableOutBuffer enabled but output differs!"); +} + +/* Calls ZSTD_decompressContinue() with the right parameters for ZSTD_decompressStream() + * and updates the stage and the output buffer state. This call is extracted so it can be + * used both when reading directly from the ZSTD_inBuffer, and in buffered input mode. + * NOTE: You must break after calling this function since the streamStage is modified. + */ +static size_t ZSTD_decompressContinueStream( + ZSTD_DStream* zds, char** op, char* oend, + void const* src, size_t srcSize) { + int const isSkipFrame = ZSTD_isSkipFrame(zds); + if (zds->outBufferMode == ZSTD_bm_buffered) { + size_t const dstSize = isSkipFrame ? 0 : zds->outBuffSize - zds->outStart; + size_t const decodedSize = ZSTD_decompressContinue(zds, + zds->outBuff + zds->outStart, dstSize, src, srcSize); + FORWARD_IF_ERROR(decodedSize, ""); + if (!decodedSize && !isSkipFrame) { + zds->streamStage = zdss_read; + } else { + zds->outEnd = zds->outStart + decodedSize; + zds->streamStage = zdss_flush; + } + } else { + /* Write directly into the output buffer */ + size_t const dstSize = isSkipFrame ? 0 : (size_t)(oend - *op); + size_t const decodedSize = ZSTD_decompressContinue(zds, *op, dstSize, src, srcSize); + FORWARD_IF_ERROR(decodedSize, ""); + *op += decodedSize; + /* Flushing is not needed. */ + zds->streamStage = zdss_read; + assert(*op <= oend); + assert(zds->outBufferMode == ZSTD_bm_stable); + } + return 0; +} + +size_t ZSTD_decompressStream(ZSTD_DStream* zds, ZSTD_outBuffer* output, ZSTD_inBuffer* input) +{ + const char* const src = (const char*)input->src; + const char* const istart = input->pos != 0 ? src + input->pos : src; + const char* const iend = input->size != 0 ? src + input->size : src; + const char* ip = istart; + char* const dst = (char*)output->dst; + char* const ostart = output->pos != 0 ? dst + output->pos : dst; + char* const oend = output->size != 0 ? dst + output->size : dst; + char* op = ostart; + U32 someMoreWork = 1; + + DEBUGLOG(5, "ZSTD_decompressStream"); + RETURN_ERROR_IF( + input->pos > input->size, + srcSize_wrong, + "forbidden. in: pos: %u vs size: %u", + (U32)input->pos, (U32)input->size); + RETURN_ERROR_IF( + output->pos > output->size, + dstSize_tooSmall, + "forbidden. out: pos: %u vs size: %u", + (U32)output->pos, (U32)output->size); + DEBUGLOG(5, "input size : %u", (U32)(input->size - input->pos)); + FORWARD_IF_ERROR(ZSTD_checkOutBuffer(zds, output), ""); + + while (someMoreWork) { + switch(zds->streamStage) + { + case zdss_init : + DEBUGLOG(5, "stage zdss_init => transparent reset "); + zds->streamStage = zdss_loadHeader; + zds->lhSize = zds->inPos = zds->outStart = zds->outEnd = 0; + zds->hostageByte = 0; + zds->expectedOutBuffer = *output; + ZSTD_FALLTHROUGH; + + case zdss_loadHeader : + DEBUGLOG(5, "stage zdss_loadHeader (srcSize : %u)", (U32)(iend - ip)); + { size_t const hSize = ZSTD_getFrameHeader_advanced(&zds->fParams, zds->headerBuffer, zds->lhSize, zds->format); + if (zds->refMultipleDDicts && zds->ddictSet) { + ZSTD_DCtx_selectFrameDDict(zds); + } + DEBUGLOG(5, "header size : %u", (U32)hSize); + if (ZSTD_isError(hSize)) { + return hSize; /* error */ + } + if (hSize != 0) { /* need more input */ + size_t const toLoad = hSize - zds->lhSize; /* if hSize!=0, hSize > zds->lhSize */ + size_t const remainingInput = (size_t)(iend-ip); + assert(iend >= ip); + if (toLoad > remainingInput) { /* not enough input to load full header */ + if (remainingInput > 0) { + ZSTD_memcpy(zds->headerBuffer + zds->lhSize, ip, remainingInput); + zds->lhSize += remainingInput; + } + input->pos = input->size; + return (MAX((size_t)ZSTD_FRAMEHEADERSIZE_MIN(zds->format), hSize) - zds->lhSize) + ZSTD_blockHeaderSize; /* remaining header bytes + next block header */ + } + assert(ip != NULL); + ZSTD_memcpy(zds->headerBuffer + zds->lhSize, ip, toLoad); zds->lhSize = hSize; ip += toLoad; + break; + } } + + /* check for single-pass mode opportunity */ + if (zds->fParams.frameContentSize != ZSTD_CONTENTSIZE_UNKNOWN + && zds->fParams.frameType != ZSTD_skippableFrame + && (U64)(size_t)(oend-op) >= zds->fParams.frameContentSize) { + size_t const cSize = ZSTD_findFrameCompressedSize(istart, (size_t)(iend-istart)); + if (cSize <= (size_t)(iend-istart)) { + /* shortcut : using single-pass mode */ + size_t const decompressedSize = ZSTD_decompress_usingDDict(zds, op, (size_t)(oend-op), istart, cSize, ZSTD_getDDict(zds)); + if (ZSTD_isError(decompressedSize)) return decompressedSize; + DEBUGLOG(4, "shortcut to single-pass ZSTD_decompress_usingDDict()") + ip = istart + cSize; + op += decompressedSize; + zds->expected = 0; + zds->streamStage = zdss_init; + someMoreWork = 0; + break; + } } + + /* Check output buffer is large enough for ZSTD_odm_stable. */ + if (zds->outBufferMode == ZSTD_bm_stable + && zds->fParams.frameType != ZSTD_skippableFrame + && zds->fParams.frameContentSize != ZSTD_CONTENTSIZE_UNKNOWN + && (U64)(size_t)(oend-op) < zds->fParams.frameContentSize) { + RETURN_ERROR(dstSize_tooSmall, "ZSTD_obm_stable passed but ZSTD_outBuffer is too small"); + } + + /* Consume header (see ZSTDds_decodeFrameHeader) */ + DEBUGLOG(4, "Consume header"); + FORWARD_IF_ERROR(ZSTD_decompressBegin_usingDDict(zds, ZSTD_getDDict(zds)), ""); + + if ((MEM_readLE32(zds->headerBuffer) & ZSTD_MAGIC_SKIPPABLE_MASK) == ZSTD_MAGIC_SKIPPABLE_START) { /* skippable frame */ + zds->expected = MEM_readLE32(zds->headerBuffer + ZSTD_FRAMEIDSIZE); + zds->stage = ZSTDds_skipFrame; + } else { + FORWARD_IF_ERROR(ZSTD_decodeFrameHeader(zds, zds->headerBuffer, zds->lhSize), ""); + zds->expected = ZSTD_blockHeaderSize; + zds->stage = ZSTDds_decodeBlockHeader; + } + + /* control buffer memory usage */ + DEBUGLOG(4, "Control max memory usage (%u KB <= max %u KB)", + (U32)(zds->fParams.windowSize >>10), + (U32)(zds->maxWindowSize >> 10) ); + zds->fParams.windowSize = MAX(zds->fParams.windowSize, 1U << ZSTD_WINDOWLOG_ABSOLUTEMIN); + RETURN_ERROR_IF(zds->fParams.windowSize > zds->maxWindowSize, + frameParameter_windowTooLarge, ""); + + /* Adapt buffer sizes to frame header instructions */ + { size_t const neededInBuffSize = MAX(zds->fParams.blockSizeMax, 4 /* frame checksum */); + size_t const neededOutBuffSize = zds->outBufferMode == ZSTD_bm_buffered + ? ZSTD_decodingBufferSize_min(zds->fParams.windowSize, zds->fParams.frameContentSize) + : 0; + + ZSTD_DCtx_updateOversizedDuration(zds, neededInBuffSize, neededOutBuffSize); + + { int const tooSmall = (zds->inBuffSize < neededInBuffSize) || (zds->outBuffSize < neededOutBuffSize); + int const tooLarge = ZSTD_DCtx_isOversizedTooLong(zds); + + if (tooSmall || tooLarge) { + size_t const bufferSize = neededInBuffSize + neededOutBuffSize; + DEBUGLOG(4, "inBuff : from %u to %u", + (U32)zds->inBuffSize, (U32)neededInBuffSize); + DEBUGLOG(4, "outBuff : from %u to %u", + (U32)zds->outBuffSize, (U32)neededOutBuffSize); + if (zds->staticSize) { /* static DCtx */ + DEBUGLOG(4, "staticSize : %u", (U32)zds->staticSize); + assert(zds->staticSize >= sizeof(ZSTD_DCtx)); /* controlled at init */ + RETURN_ERROR_IF( + bufferSize > zds->staticSize - sizeof(ZSTD_DCtx), + memory_allocation, ""); + } else { + ZSTD_customFree(zds->inBuff, zds->customMem); + zds->inBuffSize = 0; + zds->outBuffSize = 0; + zds->inBuff = (char*)ZSTD_customMalloc(bufferSize, zds->customMem); + RETURN_ERROR_IF(zds->inBuff == NULL, memory_allocation, ""); + } + zds->inBuffSize = neededInBuffSize; + zds->outBuff = zds->inBuff + zds->inBuffSize; + zds->outBuffSize = neededOutBuffSize; + } } } + zds->streamStage = zdss_read; + ZSTD_FALLTHROUGH; + + case zdss_read: + DEBUGLOG(5, "stage zdss_read"); + { size_t const neededInSize = ZSTD_nextSrcSizeToDecompressWithInputSize(zds, (size_t)(iend - ip)); + DEBUGLOG(5, "neededInSize = %u", (U32)neededInSize); + if (neededInSize==0) { /* end of frame */ + zds->streamStage = zdss_init; + someMoreWork = 0; + break; + } + if ((size_t)(iend-ip) >= neededInSize) { /* decode directly from src */ + FORWARD_IF_ERROR(ZSTD_decompressContinueStream(zds, &op, oend, ip, neededInSize), ""); + ip += neededInSize; + /* Function modifies the stage so we must break */ + break; + } } + if (ip==iend) { someMoreWork = 0; break; } /* no more input */ + zds->streamStage = zdss_load; + ZSTD_FALLTHROUGH; + + case zdss_load: + { size_t const neededInSize = ZSTD_nextSrcSizeToDecompress(zds); + size_t const toLoad = neededInSize - zds->inPos; + int const isSkipFrame = ZSTD_isSkipFrame(zds); + size_t loadedSize; + /* At this point we shouldn't be decompressing a block that we can stream. */ + assert(neededInSize == ZSTD_nextSrcSizeToDecompressWithInputSize(zds, iend - ip)); + if (isSkipFrame) { + loadedSize = MIN(toLoad, (size_t)(iend-ip)); + } else { + RETURN_ERROR_IF(toLoad > zds->inBuffSize - zds->inPos, + corruption_detected, + "should never happen"); + loadedSize = ZSTD_limitCopy(zds->inBuff + zds->inPos, toLoad, ip, (size_t)(iend-ip)); + } + ip += loadedSize; + zds->inPos += loadedSize; + if (loadedSize < toLoad) { someMoreWork = 0; break; } /* not enough input, wait for more */ + + /* decode loaded input */ + zds->inPos = 0; /* input is consumed */ + FORWARD_IF_ERROR(ZSTD_decompressContinueStream(zds, &op, oend, zds->inBuff, neededInSize), ""); + /* Function modifies the stage so we must break */ + break; + } + case zdss_flush: + { size_t const toFlushSize = zds->outEnd - zds->outStart; + size_t const flushedSize = ZSTD_limitCopy(op, (size_t)(oend-op), zds->outBuff + zds->outStart, toFlushSize); + op += flushedSize; + zds->outStart += flushedSize; + if (flushedSize == toFlushSize) { /* flush completed */ + zds->streamStage = zdss_read; + if ( (zds->outBuffSize < zds->fParams.frameContentSize) + && (zds->outStart + zds->fParams.blockSizeMax > zds->outBuffSize) ) { + DEBUGLOG(5, "restart filling outBuff from beginning (left:%i, needed:%u)", + (int)(zds->outBuffSize - zds->outStart), + (U32)zds->fParams.blockSizeMax); + zds->outStart = zds->outEnd = 0; + } + break; + } } + /* cannot complete flush */ + someMoreWork = 0; + break; + + default: + assert(0); /* impossible */ + RETURN_ERROR(GENERIC, "impossible to reach"); /* some compiler require default to do something */ + } } + + /* result */ + input->pos = (size_t)(ip - (const char*)(input->src)); + output->pos = (size_t)(op - (char*)(output->dst)); + + /* Update the expected output buffer for ZSTD_obm_stable. */ + zds->expectedOutBuffer = *output; + + if ((ip==istart) && (op==ostart)) { /* no forward progress */ + zds->noForwardProgress ++; + if (zds->noForwardProgress >= ZSTD_NO_FORWARD_PROGRESS_MAX) { + RETURN_ERROR_IF(op==oend, dstSize_tooSmall, ""); + RETURN_ERROR_IF(ip==iend, srcSize_wrong, ""); + assert(0); + } + } else { + zds->noForwardProgress = 0; + } + { size_t nextSrcSizeHint = ZSTD_nextSrcSizeToDecompress(zds); + if (!nextSrcSizeHint) { /* frame fully decoded */ + if (zds->outEnd == zds->outStart) { /* output fully flushed */ + if (zds->hostageByte) { + if (input->pos >= input->size) { + /* can't release hostage (not present) */ + zds->streamStage = zdss_read; + return 1; + } + input->pos++; /* release hostage */ + } /* zds->hostageByte */ + return 0; + } /* zds->outEnd == zds->outStart */ + if (!zds->hostageByte) { /* output not fully flushed; keep last byte as hostage; will be released when all output is flushed */ + input->pos--; /* note : pos > 0, otherwise, impossible to finish reading last block */ + zds->hostageByte=1; + } + return 1; + } /* nextSrcSizeHint==0 */ + nextSrcSizeHint += ZSTD_blockHeaderSize * (ZSTD_nextInputType(zds) == ZSTDnit_block); /* preload header of next block */ + assert(zds->inPos <= nextSrcSizeHint); + nextSrcSizeHint -= zds->inPos; /* part already loaded*/ + return nextSrcSizeHint; + } +} + +size_t ZSTD_decompressStream_simpleArgs ( + ZSTD_DCtx* dctx, + void* dst, size_t dstCapacity, size_t* dstPos, + const void* src, size_t srcSize, size_t* srcPos) +{ + ZSTD_outBuffer output = { dst, dstCapacity, *dstPos }; + ZSTD_inBuffer input = { src, srcSize, *srcPos }; + /* ZSTD_compress_generic() will check validity of dstPos and srcPos */ + size_t const cErr = ZSTD_decompressStream(dctx, &output, &input); + *dstPos = output.pos; + *srcPos = input.pos; + return cErr; +} diff --git a/lib/zstd/decompress/zstd_decompress_block.c b/lib/zstd/decompress/zstd_decompress_block.c new file mode 100644 index 00000000000..c1913b8e7c8 --- /dev/null +++ b/lib/zstd/decompress/zstd_decompress_block.c @@ -0,0 +1,2072 @@ +/* + * Copyright (c) Yann Collet, Facebook, Inc. + * All rights reserved. + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. + */ + +/* zstd_decompress_block : + * this module takes care of decompressing _compressed_ block */ + +/*-******************************************************* +* Dependencies +*********************************************************/ +#include "../common/zstd_deps.h" /* ZSTD_memcpy, ZSTD_memmove, ZSTD_memset */ +#include "../common/compiler.h" /* prefetch */ +#include "../common/cpu.h" /* bmi2 */ +#include "../common/mem.h" /* low level memory routines */ +#define FSE_STATIC_LINKING_ONLY +#include "../common/fse.h" +#define HUF_STATIC_LINKING_ONLY +#include "../common/huf.h" +#include "../common/zstd_internal.h" +#include "zstd_decompress_internal.h" /* ZSTD_DCtx */ +#include "zstd_ddict.h" /* ZSTD_DDictDictContent */ +#include "zstd_decompress_block.h" + +/*_******************************************************* +* Macros +**********************************************************/ + +/* These two optional macros force the use one way or another of the two + * ZSTD_decompressSequences implementations. You can't force in both directions + * at the same time. + */ +#if defined(ZSTD_FORCE_DECOMPRESS_SEQUENCES_SHORT) && \ + defined(ZSTD_FORCE_DECOMPRESS_SEQUENCES_LONG) +#error "Cannot force the use of the short and the long ZSTD_decompressSequences variants!" +#endif + + +/*_******************************************************* +* Memory operations +**********************************************************/ +static void ZSTD_copy4(void* dst, const void* src) { ZSTD_memcpy(dst, src, 4); } + + +/*-************************************************************* + * Block decoding + ***************************************************************/ + +/*! ZSTD_getcBlockSize() : + * Provides the size of compressed block from block header `src` */ +size_t ZSTD_getcBlockSize(const void* src, size_t srcSize, + blockProperties_t* bpPtr) +{ + RETURN_ERROR_IF(srcSize < ZSTD_blockHeaderSize, srcSize_wrong, ""); + + { U32 const cBlockHeader = MEM_readLE24(src); + U32 const cSize = cBlockHeader >> 3; + bpPtr->lastBlock = cBlockHeader & 1; + bpPtr->blockType = (blockType_e)((cBlockHeader >> 1) & 3); + bpPtr->origSize = cSize; /* only useful for RLE */ + if (bpPtr->blockType == bt_rle) return 1; + RETURN_ERROR_IF(bpPtr->blockType == bt_reserved, corruption_detected, ""); + return cSize; + } +} + +/* Allocate buffer for literals, either overlapping current dst, or split between dst and litExtraBuffer, or stored entirely within litExtraBuffer */ +static void ZSTD_allocateLiteralsBuffer(ZSTD_DCtx* dctx, void* const dst, const size_t dstCapacity, const size_t litSize, + const streaming_operation streaming, const size_t expectedWriteSize, const unsigned splitImmediately) +{ + if (streaming == not_streaming && dstCapacity > ZSTD_BLOCKSIZE_MAX + WILDCOPY_OVERLENGTH + litSize + WILDCOPY_OVERLENGTH) + { + /* room for litbuffer to fit without read faulting */ + dctx->litBuffer = (BYTE*)dst + ZSTD_BLOCKSIZE_MAX + WILDCOPY_OVERLENGTH; + dctx->litBufferEnd = dctx->litBuffer + litSize; + dctx->litBufferLocation = ZSTD_in_dst; + } + else if (litSize > ZSTD_LITBUFFEREXTRASIZE) + { + /* won't fit in litExtraBuffer, so it will be split between end of dst and extra buffer */ + if (splitImmediately) { + /* won't fit in litExtraBuffer, so it will be split between end of dst and extra buffer */ + dctx->litBuffer = (BYTE*)dst + expectedWriteSize - litSize + ZSTD_LITBUFFEREXTRASIZE - WILDCOPY_OVERLENGTH; + dctx->litBufferEnd = dctx->litBuffer + litSize - ZSTD_LITBUFFEREXTRASIZE; + } + else { + /* initially this will be stored entirely in dst during huffman decoding, it will partially shifted to litExtraBuffer after */ + dctx->litBuffer = (BYTE*)dst + expectedWriteSize - litSize; + dctx->litBufferEnd = (BYTE*)dst + expectedWriteSize; + } + dctx->litBufferLocation = ZSTD_split; + } + else + { + /* fits entirely within litExtraBuffer, so no split is necessary */ + dctx->litBuffer = dctx->litExtraBuffer; + dctx->litBufferEnd = dctx->litBuffer + litSize; + dctx->litBufferLocation = ZSTD_not_in_dst; + } +} + +/* Hidden declaration for fullbench */ +size_t ZSTD_decodeLiteralsBlock(ZSTD_DCtx* dctx, + const void* src, size_t srcSize, + void* dst, size_t dstCapacity, const streaming_operation streaming); +/*! ZSTD_decodeLiteralsBlock() : + * Where it is possible to do so without being stomped by the output during decompression, the literals block will be stored + * in the dstBuffer. If there is room to do so, it will be stored in full in the excess dst space after where the current + * block will be output. Otherwise it will be stored at the end of the current dst blockspace, with a small portion being + * stored in dctx->litExtraBuffer to help keep it "ahead" of the current output write. + * + * @return : nb of bytes read from src (< srcSize ) + * note : symbol not declared but exposed for fullbench */ +size_t ZSTD_decodeLiteralsBlock(ZSTD_DCtx* dctx, + const void* src, size_t srcSize, /* note : srcSize < BLOCKSIZE */ + void* dst, size_t dstCapacity, const streaming_operation streaming) +{ + DEBUGLOG(5, "ZSTD_decodeLiteralsBlock"); + RETURN_ERROR_IF(srcSize < MIN_CBLOCK_SIZE, corruption_detected, ""); + + { const BYTE* const istart = (const BYTE*) src; + symbolEncodingType_e const litEncType = (symbolEncodingType_e)(istart[0] & 3); + + switch(litEncType) + { + case set_repeat: + DEBUGLOG(5, "set_repeat flag : re-using stats from previous compressed literals block"); + RETURN_ERROR_IF(dctx->litEntropy==0, dictionary_corrupted, ""); + ZSTD_FALLTHROUGH; + + case set_compressed: + RETURN_ERROR_IF(srcSize < 5, corruption_detected, "srcSize >= MIN_CBLOCK_SIZE == 3; here we need up to 5 for case 3"); + { size_t lhSize, litSize, litCSize; + U32 singleStream=0; + U32 const lhlCode = (istart[0] >> 2) & 3; + U32 const lhc = MEM_readLE32(istart); + size_t hufSuccess; + size_t expectedWriteSize = MIN(ZSTD_BLOCKSIZE_MAX, dstCapacity); + switch(lhlCode) + { + case 0: case 1: default: /* note : default is impossible, since lhlCode into [0..3] */ + /* 2 - 2 - 10 - 10 */ + singleStream = !lhlCode; + lhSize = 3; + litSize = (lhc >> 4) & 0x3FF; + litCSize = (lhc >> 14) & 0x3FF; + break; + case 2: + /* 2 - 2 - 14 - 14 */ + lhSize = 4; + litSize = (lhc >> 4) & 0x3FFF; + litCSize = lhc >> 18; + break; + case 3: + /* 2 - 2 - 18 - 18 */ + lhSize = 5; + litSize = (lhc >> 4) & 0x3FFFF; + litCSize = (lhc >> 22) + ((size_t)istart[4] << 10); + break; + } + RETURN_ERROR_IF(litSize > 0 && dst == NULL, dstSize_tooSmall, "NULL not handled"); + RETURN_ERROR_IF(litSize > ZSTD_BLOCKSIZE_MAX, corruption_detected, ""); + RETURN_ERROR_IF(litCSize + lhSize > srcSize, corruption_detected, ""); + RETURN_ERROR_IF(expectedWriteSize < litSize , dstSize_tooSmall, ""); + ZSTD_allocateLiteralsBuffer(dctx, dst, dstCapacity, litSize, streaming, expectedWriteSize, 0); + + /* prefetch huffman table if cold */ + if (dctx->ddictIsCold && (litSize > 768 /* heuristic */)) { + PREFETCH_AREA(dctx->HUFptr, sizeof(dctx->entropy.hufTable)); + } + + if (litEncType==set_repeat) { + if (singleStream) { + hufSuccess = HUF_decompress1X_usingDTable_bmi2( + dctx->litBuffer, litSize, istart+lhSize, litCSize, + dctx->HUFptr, ZSTD_DCtx_get_bmi2(dctx)); + } else { + hufSuccess = HUF_decompress4X_usingDTable_bmi2( + dctx->litBuffer, litSize, istart+lhSize, litCSize, + dctx->HUFptr, ZSTD_DCtx_get_bmi2(dctx)); + } + } else { + if (singleStream) { +#if defined(HUF_FORCE_DECOMPRESS_X2) + hufSuccess = HUF_decompress1X_DCtx_wksp( + dctx->entropy.hufTable, dctx->litBuffer, litSize, + istart+lhSize, litCSize, dctx->workspace, + sizeof(dctx->workspace)); +#else + hufSuccess = HUF_decompress1X1_DCtx_wksp_bmi2( + dctx->entropy.hufTable, dctx->litBuffer, litSize, + istart+lhSize, litCSize, dctx->workspace, + sizeof(dctx->workspace), ZSTD_DCtx_get_bmi2(dctx)); +#endif + } else { + hufSuccess = HUF_decompress4X_hufOnly_wksp_bmi2( + dctx->entropy.hufTable, dctx->litBuffer, litSize, + istart+lhSize, litCSize, dctx->workspace, + sizeof(dctx->workspace), ZSTD_DCtx_get_bmi2(dctx)); + } + } + if (dctx->litBufferLocation == ZSTD_split) + { + ZSTD_memcpy(dctx->litExtraBuffer, dctx->litBufferEnd - ZSTD_LITBUFFEREXTRASIZE, ZSTD_LITBUFFEREXTRASIZE); + ZSTD_memmove(dctx->litBuffer + ZSTD_LITBUFFEREXTRASIZE - WILDCOPY_OVERLENGTH, dctx->litBuffer, litSize - ZSTD_LITBUFFEREXTRASIZE); + dctx->litBuffer += ZSTD_LITBUFFEREXTRASIZE - WILDCOPY_OVERLENGTH; + dctx->litBufferEnd -= WILDCOPY_OVERLENGTH; + } + + RETURN_ERROR_IF(HUF_isError(hufSuccess), corruption_detected, ""); + + dctx->litPtr = dctx->litBuffer; + dctx->litSize = litSize; + dctx->litEntropy = 1; + if (litEncType==set_compressed) dctx->HUFptr = dctx->entropy.hufTable; + return litCSize + lhSize; + } + + case set_basic: + { size_t litSize, lhSize; + U32 const lhlCode = ((istart[0]) >> 2) & 3; + size_t expectedWriteSize = MIN(ZSTD_BLOCKSIZE_MAX, dstCapacity); + switch(lhlCode) + { + case 0: case 2: default: /* note : default is impossible, since lhlCode into [0..3] */ + lhSize = 1; + litSize = istart[0] >> 3; + break; + case 1: + lhSize = 2; + litSize = MEM_readLE16(istart) >> 4; + break; + case 3: + lhSize = 3; + litSize = MEM_readLE24(istart) >> 4; + break; + } + + RETURN_ERROR_IF(litSize > 0 && dst == NULL, dstSize_tooSmall, "NULL not handled"); + RETURN_ERROR_IF(expectedWriteSize < litSize, dstSize_tooSmall, ""); + ZSTD_allocateLiteralsBuffer(dctx, dst, dstCapacity, litSize, streaming, expectedWriteSize, 1); + if (lhSize+litSize+WILDCOPY_OVERLENGTH > srcSize) { /* risk reading beyond src buffer with wildcopy */ + RETURN_ERROR_IF(litSize+lhSize > srcSize, corruption_detected, ""); + if (dctx->litBufferLocation == ZSTD_split) + { + ZSTD_memcpy(dctx->litBuffer, istart + lhSize, litSize - ZSTD_LITBUFFEREXTRASIZE); + ZSTD_memcpy(dctx->litExtraBuffer, istart + lhSize + litSize - ZSTD_LITBUFFEREXTRASIZE, ZSTD_LITBUFFEREXTRASIZE); + } + else + { + ZSTD_memcpy(dctx->litBuffer, istart + lhSize, litSize); + } + dctx->litPtr = dctx->litBuffer; + dctx->litSize = litSize; + return lhSize+litSize; + } + /* direct reference into compressed stream */ + dctx->litPtr = istart+lhSize; + dctx->litSize = litSize; + dctx->litBufferEnd = dctx->litPtr + litSize; + dctx->litBufferLocation = ZSTD_not_in_dst; + return lhSize+litSize; + } + + case set_rle: + { U32 const lhlCode = ((istart[0]) >> 2) & 3; + size_t litSize, lhSize; + size_t expectedWriteSize = MIN(ZSTD_BLOCKSIZE_MAX, dstCapacity); + switch(lhlCode) + { + case 0: case 2: default: /* note : default is impossible, since lhlCode into [0..3] */ + lhSize = 1; + litSize = istart[0] >> 3; + break; + case 1: + lhSize = 2; + litSize = MEM_readLE16(istart) >> 4; + break; + case 3: + lhSize = 3; + litSize = MEM_readLE24(istart) >> 4; + RETURN_ERROR_IF(srcSize<4, corruption_detected, "srcSize >= MIN_CBLOCK_SIZE == 3; here we need lhSize+1 = 4"); + break; + } + RETURN_ERROR_IF(litSize > 0 && dst == NULL, dstSize_tooSmall, "NULL not handled"); + RETURN_ERROR_IF(litSize > ZSTD_BLOCKSIZE_MAX, corruption_detected, ""); + RETURN_ERROR_IF(expectedWriteSize < litSize, dstSize_tooSmall, ""); + ZSTD_allocateLiteralsBuffer(dctx, dst, dstCapacity, litSize, streaming, expectedWriteSize, 1); + if (dctx->litBufferLocation == ZSTD_split) + { + ZSTD_memset(dctx->litBuffer, istart[lhSize], litSize - ZSTD_LITBUFFEREXTRASIZE); + ZSTD_memset(dctx->litExtraBuffer, istart[lhSize], ZSTD_LITBUFFEREXTRASIZE); + } + else + { + ZSTD_memset(dctx->litBuffer, istart[lhSize], litSize); + } + dctx->litPtr = dctx->litBuffer; + dctx->litSize = litSize; + return lhSize+1; + } + default: + RETURN_ERROR(corruption_detected, "impossible"); + } + } +} + +/* Default FSE distribution tables. + * These are pre-calculated FSE decoding tables using default distributions as defined in specification : + * https://github.com/facebook/zstd/blob/release/doc/zstd_compression_format.md... + * They were generated programmatically with following method : + * - start from default distributions, present in /lib/common/zstd_internal.h + * - generate tables normally, using ZSTD_buildFSETable() + * - printout the content of tables + * - pretify output, report below, test with fuzzer to ensure it's correct */ + +/* Default FSE distribution table for Literal Lengths */ +static const ZSTD_seqSymbol LL_defaultDTable[(1<<LL_DEFAULTNORMLOG)+1] = { + { 1, 1, 1, LL_DEFAULTNORMLOG}, /* header : fastMode, tableLog */ + /* nextState, nbAddBits, nbBits, baseVal */ + { 0, 0, 4, 0}, { 16, 0, 4, 0}, + { 32, 0, 5, 1}, { 0, 0, 5, 3}, + { 0, 0, 5, 4}, { 0, 0, 5, 6}, + { 0, 0, 5, 7}, { 0, 0, 5, 9}, + { 0, 0, 5, 10}, { 0, 0, 5, 12}, + { 0, 0, 6, 14}, { 0, 1, 5, 16}, + { 0, 1, 5, 20}, { 0, 1, 5, 22}, + { 0, 2, 5, 28}, { 0, 3, 5, 32}, + { 0, 4, 5, 48}, { 32, 6, 5, 64}, + { 0, 7, 5, 128}, { 0, 8, 6, 256}, + { 0, 10, 6, 1024}, { 0, 12, 6, 4096}, + { 32, 0, 4, 0}, { 0, 0, 4, 1}, + { 0, 0, 5, 2}, { 32, 0, 5, 4}, + { 0, 0, 5, 5}, { 32, 0, 5, 7}, + { 0, 0, 5, 8}, { 32, 0, 5, 10}, + { 0, 0, 5, 11}, { 0, 0, 6, 13}, + { 32, 1, 5, 16}, { 0, 1, 5, 18}, + { 32, 1, 5, 22}, { 0, 2, 5, 24}, + { 32, 3, 5, 32}, { 0, 3, 5, 40}, + { 0, 6, 4, 64}, { 16, 6, 4, 64}, + { 32, 7, 5, 128}, { 0, 9, 6, 512}, + { 0, 11, 6, 2048}, { 48, 0, 4, 0}, + { 16, 0, 4, 1}, { 32, 0, 5, 2}, + { 32, 0, 5, 3}, { 32, 0, 5, 5}, + { 32, 0, 5, 6}, { 32, 0, 5, 8}, + { 32, 0, 5, 9}, { 32, 0, 5, 11}, + { 32, 0, 5, 12}, { 0, 0, 6, 15}, + { 32, 1, 5, 18}, { 32, 1, 5, 20}, + { 32, 2, 5, 24}, { 32, 2, 5, 28}, + { 32, 3, 5, 40}, { 32, 4, 5, 48}, + { 0, 16, 6,65536}, { 0, 15, 6,32768}, + { 0, 14, 6,16384}, { 0, 13, 6, 8192}, +}; /* LL_defaultDTable */ + +/* Default FSE distribution table for Offset Codes */ +static const ZSTD_seqSymbol OF_defaultDTable[(1<<OF_DEFAULTNORMLOG)+1] = { + { 1, 1, 1, OF_DEFAULTNORMLOG}, /* header : fastMode, tableLog */ + /* nextState, nbAddBits, nbBits, baseVal */ + { 0, 0, 5, 0}, { 0, 6, 4, 61}, + { 0, 9, 5, 509}, { 0, 15, 5,32765}, + { 0, 21, 5,2097149}, { 0, 3, 5, 5}, + { 0, 7, 4, 125}, { 0, 12, 5, 4093}, + { 0, 18, 5,262141}, { 0, 23, 5,8388605}, + { 0, 5, 5, 29}, { 0, 8, 4, 253}, + { 0, 14, 5,16381}, { 0, 20, 5,1048573}, + { 0, 2, 5, 1}, { 16, 7, 4, 125}, + { 0, 11, 5, 2045}, { 0, 17, 5,131069}, + { 0, 22, 5,4194301}, { 0, 4, 5, 13}, + { 16, 8, 4, 253}, { 0, 13, 5, 8189}, + { 0, 19, 5,524285}, { 0, 1, 5, 1}, + { 16, 6, 4, 61}, { 0, 10, 5, 1021}, + { 0, 16, 5,65533}, { 0, 28, 5,268435453}, + { 0, 27, 5,134217725}, { 0, 26, 5,67108861}, + { 0, 25, 5,33554429}, { 0, 24, 5,16777213}, +}; /* OF_defaultDTable */ + + +/* Default FSE distribution table for Match Lengths */ +static const ZSTD_seqSymbol ML_defaultDTable[(1<<ML_DEFAULTNORMLOG)+1] = { + { 1, 1, 1, ML_DEFAULTNORMLOG}, /* header : fastMode, tableLog */ + /* nextState, nbAddBits, nbBits, baseVal */ + { 0, 0, 6, 3}, { 0, 0, 4, 4}, + { 32, 0, 5, 5}, { 0, 0, 5, 6}, + { 0, 0, 5, 8}, { 0, 0, 5, 9}, + { 0, 0, 5, 11}, { 0, 0, 6, 13}, + { 0, 0, 6, 16}, { 0, 0, 6, 19}, + { 0, 0, 6, 22}, { 0, 0, 6, 25}, + { 0, 0, 6, 28}, { 0, 0, 6, 31}, + { 0, 0, 6, 34}, { 0, 1, 6, 37}, + { 0, 1, 6, 41}, { 0, 2, 6, 47}, + { 0, 3, 6, 59}, { 0, 4, 6, 83}, + { 0, 7, 6, 131}, { 0, 9, 6, 515}, + { 16, 0, 4, 4}, { 0, 0, 4, 5}, + { 32, 0, 5, 6}, { 0, 0, 5, 7}, + { 32, 0, 5, 9}, { 0, 0, 5, 10}, + { 0, 0, 6, 12}, { 0, 0, 6, 15}, + { 0, 0, 6, 18}, { 0, 0, 6, 21}, + { 0, 0, 6, 24}, { 0, 0, 6, 27}, + { 0, 0, 6, 30}, { 0, 0, 6, 33}, + { 0, 1, 6, 35}, { 0, 1, 6, 39}, + { 0, 2, 6, 43}, { 0, 3, 6, 51}, + { 0, 4, 6, 67}, { 0, 5, 6, 99}, + { 0, 8, 6, 259}, { 32, 0, 4, 4}, + { 48, 0, 4, 4}, { 16, 0, 4, 5}, + { 32, 0, 5, 7}, { 32, 0, 5, 8}, + { 32, 0, 5, 10}, { 32, 0, 5, 11}, + { 0, 0, 6, 14}, { 0, 0, 6, 17}, + { 0, 0, 6, 20}, { 0, 0, 6, 23}, + { 0, 0, 6, 26}, { 0, 0, 6, 29}, + { 0, 0, 6, 32}, { 0, 16, 6,65539}, + { 0, 15, 6,32771}, { 0, 14, 6,16387}, + { 0, 13, 6, 8195}, { 0, 12, 6, 4099}, + { 0, 11, 6, 2051}, { 0, 10, 6, 1027}, +}; /* ML_defaultDTable */ + + +static void ZSTD_buildSeqTable_rle(ZSTD_seqSymbol* dt, U32 baseValue, U8 nbAddBits) +{ + void* ptr = dt; + ZSTD_seqSymbol_header* const DTableH = (ZSTD_seqSymbol_header*)ptr; + ZSTD_seqSymbol* const cell = dt + 1; + + DTableH->tableLog = 0; + DTableH->fastMode = 0; + + cell->nbBits = 0; + cell->nextState = 0; + assert(nbAddBits < 255); + cell->nbAdditionalBits = nbAddBits; + cell->baseValue = baseValue; +} + + +/* ZSTD_buildFSETable() : + * generate FSE decoding table for one symbol (ll, ml or off) + * cannot fail if input is valid => + * all inputs are presumed validated at this stage */ +FORCE_INLINE_TEMPLATE +void ZSTD_buildFSETable_body(ZSTD_seqSymbol* dt, + const short* normalizedCounter, unsigned maxSymbolValue, + const U32* baseValue, const U8* nbAdditionalBits, + unsigned tableLog, void* wksp, size_t wkspSize) +{ + ZSTD_seqSymbol* const tableDecode = dt+1; + U32 const maxSV1 = maxSymbolValue + 1; + U32 const tableSize = 1 << tableLog; + + U16* symbolNext = (U16*)wksp; + BYTE* spread = (BYTE*)(symbolNext + MaxSeq + 1); + U32 highThreshold = tableSize - 1; + + + /* Sanity Checks */ + assert(maxSymbolValue <= MaxSeq); + assert(tableLog <= MaxFSELog); + assert(wkspSize >= ZSTD_BUILD_FSE_TABLE_WKSP_SIZE); + (void)wkspSize; + /* Init, lay down lowprob symbols */ + { ZSTD_seqSymbol_header DTableH; + DTableH.tableLog = tableLog; + DTableH.fastMode = 1; + { S16 const largeLimit= (S16)(1 << (tableLog-1)); + U32 s; + for (s=0; s<maxSV1; s++) { + if (normalizedCounter[s]==-1) { + tableDecode[highThreshold--].baseValue = s; + symbolNext[s] = 1; + } else { + if (normalizedCounter[s] >= largeLimit) DTableH.fastMode=0; + assert(normalizedCounter[s]>=0); + symbolNext[s] = (U16)normalizedCounter[s]; + } } } + ZSTD_memcpy(dt, &DTableH, sizeof(DTableH)); + } + + /* Spread symbols */ + assert(tableSize <= 512); + /* Specialized symbol spreading for the case when there are + * no low probability (-1 count) symbols. When compressing + * small blocks we avoid low probability symbols to hit this + * case, since header decoding speed matters more. + */ + if (highThreshold == tableSize - 1) { + size_t const tableMask = tableSize-1; + size_t const step = FSE_TABLESTEP(tableSize); + /* First lay down the symbols in order. + * We use a uint64_t to lay down 8 bytes at a time. This reduces branch + * misses since small blocks generally have small table logs, so nearly + * all symbols have counts <= 8. We ensure we have 8 bytes at the end of + * our buffer to handle the over-write. + */ + { + U64 const add = 0x0101010101010101ull; + size_t pos = 0; + U64 sv = 0; + U32 s; + for (s=0; s<maxSV1; ++s, sv += add) { + int i; + int const n = normalizedCounter[s]; + MEM_write64(spread + pos, sv); + for (i = 8; i < n; i += 8) { + MEM_write64(spread + pos + i, sv); + } + pos += n; + } + } + /* Now we spread those positions across the table. + * The benefit of doing it in two stages is that we avoid the the + * variable size inner loop, which caused lots of branch misses. + * Now we can run through all the positions without any branch misses. + * We unroll the loop twice, since that is what emperically worked best. + */ + { + size_t position = 0; + size_t s; + size_t const unroll = 2; + assert(tableSize % unroll == 0); /* FSE_MIN_TABLELOG is 5 */ + for (s = 0; s < (size_t)tableSize; s += unroll) { + size_t u; + for (u = 0; u < unroll; ++u) { + size_t const uPosition = (position + (u * step)) & tableMask; + tableDecode[uPosition].baseValue = spread[s + u]; + } + position = (position + (unroll * step)) & tableMask; + } + assert(position == 0); + } + } else { + U32 const tableMask = tableSize-1; + U32 const step = FSE_TABLESTEP(tableSize); + U32 s, position = 0; + for (s=0; s<maxSV1; s++) { + int i; + int const n = normalizedCounter[s]; + for (i=0; i<n; i++) { + tableDecode[position].baseValue = s; + position = (position + step) & tableMask; + while (position > highThreshold) position = (position + step) & tableMask; /* lowprob area */ + } } + assert(position == 0); /* position must reach all cells once, otherwise normalizedCounter is incorrect */ + } + + /* Build Decoding table */ + { + U32 u; + for (u=0; u<tableSize; u++) { + U32 const symbol = tableDecode[u].baseValue; + U32 const nextState = symbolNext[symbol]++; + tableDecode[u].nbBits = (BYTE) (tableLog - BIT_highbit32(nextState) ); + tableDecode[u].nextState = (U16) ( (nextState << tableDecode[u].nbBits) - tableSize); + assert(nbAdditionalBits[symbol] < 255); + tableDecode[u].nbAdditionalBits = nbAdditionalBits[symbol]; + tableDecode[u].baseValue = baseValue[symbol]; + } + } +} + +/* Avoids the FORCE_INLINE of the _body() function. */ +static void ZSTD_buildFSETable_body_default(ZSTD_seqSymbol* dt, + const short* normalizedCounter, unsigned maxSymbolValue, + const U32* baseValue, const U8* nbAdditionalBits, + unsigned tableLog, void* wksp, size_t wkspSize) +{ + ZSTD_buildFSETable_body(dt, normalizedCounter, maxSymbolValue, + baseValue, nbAdditionalBits, tableLog, wksp, wkspSize); +} + +#if DYNAMIC_BMI2 +BMI2_TARGET_ATTRIBUTE static void ZSTD_buildFSETable_body_bmi2(ZSTD_seqSymbol* dt, + const short* normalizedCounter, unsigned maxSymbolValue, + const U32* baseValue, const U8* nbAdditionalBits, + unsigned tableLog, void* wksp, size_t wkspSize) +{ + ZSTD_buildFSETable_body(dt, normalizedCounter, maxSymbolValue, + baseValue, nbAdditionalBits, tableLog, wksp, wkspSize); +} +#endif + +void ZSTD_buildFSETable(ZSTD_seqSymbol* dt, + const short* normalizedCounter, unsigned maxSymbolValue, + const U32* baseValue, const U8* nbAdditionalBits, + unsigned tableLog, void* wksp, size_t wkspSize, int bmi2) +{ +#if DYNAMIC_BMI2 + if (bmi2) { + ZSTD_buildFSETable_body_bmi2(dt, normalizedCounter, maxSymbolValue, + baseValue, nbAdditionalBits, tableLog, wksp, wkspSize); + return; + } +#endif + (void)bmi2; + ZSTD_buildFSETable_body_default(dt, normalizedCounter, maxSymbolValue, + baseValue, nbAdditionalBits, tableLog, wksp, wkspSize); +} + + +/*! ZSTD_buildSeqTable() : + * @return : nb bytes read from src, + * or an error code if it fails */ +static size_t ZSTD_buildSeqTable(ZSTD_seqSymbol* DTableSpace, const ZSTD_seqSymbol** DTablePtr, + symbolEncodingType_e type, unsigned max, U32 maxLog, + const void* src, size_t srcSize, + const U32* baseValue, const U8* nbAdditionalBits, + const ZSTD_seqSymbol* defaultTable, U32 flagRepeatTable, + int ddictIsCold, int nbSeq, U32* wksp, size_t wkspSize, + int bmi2) +{ + switch(type) + { + case set_rle : + RETURN_ERROR_IF(!srcSize, srcSize_wrong, ""); + RETURN_ERROR_IF((*(const BYTE*)src) > max, corruption_detected, ""); + { U32 const symbol = *(const BYTE*)src; + U32 const baseline = baseValue[symbol]; + U8 const nbBits = nbAdditionalBits[symbol]; + ZSTD_buildSeqTable_rle(DTableSpace, baseline, nbBits); + } + *DTablePtr = DTableSpace; + return 1; + case set_basic : + *DTablePtr = defaultTable; + return 0; + case set_repeat: + RETURN_ERROR_IF(!flagRepeatTable, corruption_detected, ""); + /* prefetch FSE table if used */ + if (ddictIsCold && (nbSeq > 24 /* heuristic */)) { + const void* const pStart = *DTablePtr; + size_t const pSize = sizeof(ZSTD_seqSymbol) * (SEQSYMBOL_TABLE_SIZE(maxLog)); + PREFETCH_AREA(pStart, pSize); + } + return 0; + case set_compressed : + { unsigned tableLog; + S16 norm[MaxSeq+1]; + size_t const headerSize = FSE_readNCount(norm, &max, &tableLog, src, srcSize); + RETURN_ERROR_IF(FSE_isError(headerSize), corruption_detected, ""); + RETURN_ERROR_IF(tableLog > maxLog, corruption_detected, ""); + ZSTD_buildFSETable(DTableSpace, norm, max, baseValue, nbAdditionalBits, tableLog, wksp, wkspSize, bmi2); + *DTablePtr = DTableSpace; + return headerSize; + } + default : + assert(0); + RETURN_ERROR(GENERIC, "impossible"); + } +} + +size_t ZSTD_decodeSeqHeaders(ZSTD_DCtx* dctx, int* nbSeqPtr, + const void* src, size_t srcSize) +{ + const BYTE* const istart = (const BYTE*)src; + const BYTE* const iend = istart + srcSize; + const BYTE* ip = istart; + int nbSeq; + DEBUGLOG(5, "ZSTD_decodeSeqHeaders"); + + /* check */ + RETURN_ERROR_IF(srcSize < MIN_SEQUENCES_SIZE, srcSize_wrong, ""); + + /* SeqHead */ + nbSeq = *ip++; + if (!nbSeq) { + *nbSeqPtr=0; + RETURN_ERROR_IF(srcSize != 1, srcSize_wrong, ""); + return 1; + } + if (nbSeq > 0x7F) { + if (nbSeq == 0xFF) { + RETURN_ERROR_IF(ip+2 > iend, srcSize_wrong, ""); + nbSeq = MEM_readLE16(ip) + LONGNBSEQ; + ip+=2; + } else { + RETURN_ERROR_IF(ip >= iend, srcSize_wrong, ""); + nbSeq = ((nbSeq-0x80)<<8) + *ip++; + } + } + *nbSeqPtr = nbSeq; + + /* FSE table descriptors */ + RETURN_ERROR_IF(ip+1 > iend, srcSize_wrong, ""); /* minimum possible size: 1 byte for symbol encoding types */ + { symbolEncodingType_e const LLtype = (symbolEncodingType_e)(*ip >> 6); + symbolEncodingType_e const OFtype = (symbolEncodingType_e)((*ip >> 4) & 3); + symbolEncodingType_e const MLtype = (symbolEncodingType_e)((*ip >> 2) & 3); + ip++; + + /* Build DTables */ + { size_t const llhSize = ZSTD_buildSeqTable(dctx->entropy.LLTable, &dctx->LLTptr, + LLtype, MaxLL, LLFSELog, + ip, iend-ip, + LL_base, LL_bits, + LL_defaultDTable, dctx->fseEntropy, + dctx->ddictIsCold, nbSeq, + dctx->workspace, sizeof(dctx->workspace), + ZSTD_DCtx_get_bmi2(dctx)); + RETURN_ERROR_IF(ZSTD_isError(llhSize), corruption_detected, "ZSTD_buildSeqTable failed"); + ip += llhSize; + } + + { size_t const ofhSize = ZSTD_buildSeqTable(dctx->entropy.OFTable, &dctx->OFTptr, + OFtype, MaxOff, OffFSELog, + ip, iend-ip, + OF_base, OF_bits, + OF_defaultDTable, dctx->fseEntropy, + dctx->ddictIsCold, nbSeq, + dctx->workspace, sizeof(dctx->workspace), + ZSTD_DCtx_get_bmi2(dctx)); + RETURN_ERROR_IF(ZSTD_isError(ofhSize), corruption_detected, "ZSTD_buildSeqTable failed"); + ip += ofhSize; + } + + { size_t const mlhSize = ZSTD_buildSeqTable(dctx->entropy.MLTable, &dctx->MLTptr, + MLtype, MaxML, MLFSELog, + ip, iend-ip, + ML_base, ML_bits, + ML_defaultDTable, dctx->fseEntropy, + dctx->ddictIsCold, nbSeq, + dctx->workspace, sizeof(dctx->workspace), + ZSTD_DCtx_get_bmi2(dctx)); + RETURN_ERROR_IF(ZSTD_isError(mlhSize), corruption_detected, "ZSTD_buildSeqTable failed"); + ip += mlhSize; + } + } + + return ip-istart; +} + + +typedef struct { + size_t litLength; + size_t matchLength; + size_t offset; +} seq_t; + +typedef struct { + size_t state; + const ZSTD_seqSymbol* table; +} ZSTD_fseState; + +typedef struct { + BIT_DStream_t DStream; + ZSTD_fseState stateLL; + ZSTD_fseState stateOffb; + ZSTD_fseState stateML; + size_t prevOffset[ZSTD_REP_NUM]; +} seqState_t; + +/*! ZSTD_overlapCopy8() : + * Copies 8 bytes from ip to op and updates op and ip where ip <= op. + * If the offset is < 8 then the offset is spread to at least 8 bytes. + * + * Precondition: *ip <= *op + * Postcondition: *op - *op >= 8 + */ +HINT_INLINE void ZSTD_overlapCopy8(BYTE** op, BYTE const** ip, size_t offset) { + assert(*ip <= *op); + if (offset < 8) { + /* close range match, overlap */ + static const U32 dec32table[] = { 0, 1, 2, 1, 4, 4, 4, 4 }; /* added */ + static const int dec64table[] = { 8, 8, 8, 7, 8, 9,10,11 }; /* subtracted */ + int const sub2 = dec64table[offset]; + (*op)[0] = (*ip)[0]; + (*op)[1] = (*ip)[1]; + (*op)[2] = (*ip)[2]; + (*op)[3] = (*ip)[3]; + *ip += dec32table[offset]; + ZSTD_copy4(*op+4, *ip); + *ip -= sub2; + } else { + ZSTD_copy8(*op, *ip); + } + *ip += 8; + *op += 8; + assert(*op - *ip >= 8); +} + +/*! ZSTD_safecopy() : + * Specialized version of memcpy() that is allowed to READ up to WILDCOPY_OVERLENGTH past the input buffer + * and write up to 16 bytes past oend_w (op >= oend_w is allowed). + * This function is only called in the uncommon case where the sequence is near the end of the block. It + * should be fast for a single long sequence, but can be slow for several short sequences. + * + * @param ovtype controls the overlap detection + * - ZSTD_no_overlap: The source and destination are guaranteed to be at least WILDCOPY_VECLEN bytes apart. + * - ZSTD_overlap_src_before_dst: The src and dst may overlap and may be any distance apart. + * The src buffer must be before the dst buffer. + */ +static void ZSTD_safecopy(BYTE* op, const BYTE* const oend_w, BYTE const* ip, ptrdiff_t length, ZSTD_overlap_e ovtype) { + ptrdiff_t const diff = op - ip; + BYTE* const oend = op + length; + + assert((ovtype == ZSTD_no_overlap && (diff <= -8 || diff >= 8 || op >= oend_w)) || + (ovtype == ZSTD_overlap_src_before_dst && diff >= 0)); + + if (length < 8) { + /* Handle short lengths. */ + while (op < oend) *op++ = *ip++; + return; + } + if (ovtype == ZSTD_overlap_src_before_dst) { + /* Copy 8 bytes and ensure the offset >= 8 when there can be overlap. */ + assert(length >= 8); + ZSTD_overlapCopy8(&op, &ip, diff); + length -= 8; + assert(op - ip >= 8); + assert(op <= oend); + } + + if (oend <= oend_w) { + /* No risk of overwrite. */ + ZSTD_wildcopy(op, ip, length, ovtype); + return; + } + if (op <= oend_w) { + /* Wildcopy until we get close to the end. */ + assert(oend > oend_w); + ZSTD_wildcopy(op, ip, oend_w - op, ovtype); + ip += oend_w - op; + op += oend_w - op; + } + /* Handle the leftovers. */ + while (op < oend) *op++ = *ip++; +} + +/* ZSTD_safecopyDstBeforeSrc(): + * This version allows overlap with dst before src, or handles the non-overlap case with dst after src + * Kept separate from more common ZSTD_safecopy case to avoid performance impact to the safecopy common case */ +static void ZSTD_safecopyDstBeforeSrc(BYTE* op, BYTE const* ip, ptrdiff_t length) { + ptrdiff_t const diff = op - ip; + BYTE* const oend = op + length; + + if (length < 8 || diff > -8) { + /* Handle short lengths, close overlaps, and dst not before src. */ + while (op < oend) *op++ = *ip++; + return; + } + + if (op <= oend - WILDCOPY_OVERLENGTH && diff < -WILDCOPY_VECLEN) { + ZSTD_wildcopy(op, ip, oend - WILDCOPY_OVERLENGTH - op, ZSTD_no_overlap); + ip += oend - WILDCOPY_OVERLENGTH - op; + op += oend - WILDCOPY_OVERLENGTH - op; + } + + /* Handle the leftovers. */ + while (op < oend) *op++ = *ip++; +} + +/* ZSTD_execSequenceEnd(): + * This version handles cases that are near the end of the output buffer. It requires + * more careful checks to make sure there is no overflow. By separating out these hard + * and unlikely cases, we can speed up the common cases. + * + * NOTE: This function needs to be fast for a single long sequence, but doesn't need + * to be optimized for many small sequences, since those fall into ZSTD_execSequence(). + */ +FORCE_NOINLINE +size_t ZSTD_execSequenceEnd(BYTE* op, + BYTE* const oend, seq_t sequence, + const BYTE** litPtr, const BYTE* const litLimit, + const BYTE* const prefixStart, const BYTE* const virtualStart, const BYTE* const dictEnd) +{ + BYTE* const oLitEnd = op + sequence.litLength; + size_t const sequenceLength = sequence.litLength + sequence.matchLength; + const BYTE* const iLitEnd = *litPtr + sequence.litLength; + const BYTE* match = oLitEnd - sequence.offset; + BYTE* const oend_w = oend - WILDCOPY_OVERLENGTH; + + /* bounds checks : careful of address space overflow in 32-bit mode */ + RETURN_ERROR_IF(sequenceLength > (size_t)(oend - op), dstSize_tooSmall, "last match must fit within dstBuffer"); + RETURN_ERROR_IF(sequence.litLength > (size_t)(litLimit - *litPtr), corruption_detected, "try to read beyond literal buffer"); + assert(op < op + sequenceLength); + assert(oLitEnd < op + sequenceLength); + + /* copy literals */ + ZSTD_safecopy(op, oend_w, *litPtr, sequence.litLength, ZSTD_no_overlap); + op = oLitEnd; + *litPtr = iLitEnd; + + /* copy Match */ + if (sequence.offset > (size_t)(oLitEnd - prefixStart)) { + /* offset beyond prefix */ + RETURN_ERROR_IF(sequence.offset > (size_t)(oLitEnd - virtualStart), corruption_detected, ""); + match = dictEnd - (prefixStart - match); + if (match + sequence.matchLength <= dictEnd) { + ZSTD_memmove(oLitEnd, match, sequence.matchLength); + return sequenceLength; + } + /* span extDict & currentPrefixSegment */ + { size_t const length1 = dictEnd - match; + ZSTD_memmove(oLitEnd, match, length1); + op = oLitEnd + length1; + sequence.matchLength -= length1; + match = prefixStart; + } + } + ZSTD_safecopy(op, oend_w, match, sequence.matchLength, ZSTD_overlap_src_before_dst); + return sequenceLength; +} + +/* ZSTD_execSequenceEndSplitLitBuffer(): + * This version is intended to be used during instances where the litBuffer is still split. It is kept separate to avoid performance impact for the good case. + */ +FORCE_NOINLINE +size_t ZSTD_execSequenceEndSplitLitBuffer(BYTE* op, + BYTE* const oend, const BYTE* const oend_w, seq_t sequence, + const BYTE** litPtr, const BYTE* const litLimit, + const BYTE* const prefixStart, const BYTE* const virtualStart, const BYTE* const dictEnd) +{ + BYTE* const oLitEnd = op + sequence.litLength; + size_t const sequenceLength = sequence.litLength + sequence.matchLength; + const BYTE* const iLitEnd = *litPtr + sequence.litLength; + const BYTE* match = oLitEnd - sequence.offset; + + + /* bounds checks : careful of address space overflow in 32-bit mode */ + RETURN_ERROR_IF(sequenceLength > (size_t)(oend - op), dstSize_tooSmall, "last match must fit within dstBuffer"); + RETURN_ERROR_IF(sequence.litLength > (size_t)(litLimit - *litPtr), corruption_detected, "try to read beyond literal buffer"); + assert(op < op + sequenceLength); + assert(oLitEnd < op + sequenceLength); + + /* copy literals */ + RETURN_ERROR_IF(op > *litPtr && op < *litPtr + sequence.litLength, dstSize_tooSmall, "output should not catch up to and overwrite literal buffer"); + ZSTD_safecopyDstBeforeSrc(op, *litPtr, sequence.litLength); + op = oLitEnd; + *litPtr = iLitEnd; + + /* copy Match */ + if (sequence.offset > (size_t)(oLitEnd - prefixStart)) { + /* offset beyond prefix */ + RETURN_ERROR_IF(sequence.offset > (size_t)(oLitEnd - virtualStart), corruption_detected, ""); + match = dictEnd - (prefixStart - match); + if (match + sequence.matchLength <= dictEnd) { + ZSTD_memmove(oLitEnd, match, sequence.matchLength); + return sequenceLength; + } + /* span extDict & currentPrefixSegment */ + { size_t const length1 = dictEnd - match; + ZSTD_memmove(oLitEnd, match, length1); + op = oLitEnd + length1; + sequence.matchLength -= length1; + match = prefixStart; + } + } + ZSTD_safecopy(op, oend_w, match, sequence.matchLength, ZSTD_overlap_src_before_dst); + return sequenceLength; +} + +HINT_INLINE +size_t ZSTD_execSequence(BYTE* op, + BYTE* const oend, seq_t sequence, + const BYTE** litPtr, const BYTE* const litLimit, + const BYTE* const prefixStart, const BYTE* const virtualStart, const BYTE* const dictEnd) +{ + BYTE* const oLitEnd = op + sequence.litLength; + size_t const sequenceLength = sequence.litLength + sequence.matchLength; + BYTE* const oMatchEnd = op + sequenceLength; /* risk : address space overflow (32-bits) */ + BYTE* const oend_w = oend - WILDCOPY_OVERLENGTH; /* risk : address space underflow on oend=NULL */ + const BYTE* const iLitEnd = *litPtr + sequence.litLength; + const BYTE* match = oLitEnd - sequence.offset; + + assert(op != NULL /* Precondition */); + assert(oend_w < oend /* No underflow */); + /* Handle edge cases in a slow path: + * - Read beyond end of literals + * - Match end is within WILDCOPY_OVERLIMIT of oend + * - 32-bit mode and the match length overflows + */ + if (UNLIKELY( + iLitEnd > litLimit || + oMatchEnd > oend_w || + (MEM_32bits() && (size_t)(oend - op) < sequenceLength + WILDCOPY_OVERLENGTH))) + return ZSTD_execSequenceEnd(op, oend, sequence, litPtr, litLimit, prefixStart, virtualStart, dictEnd); + + /* Assumptions (everything else goes into ZSTD_execSequenceEnd()) */ + assert(op <= oLitEnd /* No overflow */); + assert(oLitEnd < oMatchEnd /* Non-zero match & no overflow */); + assert(oMatchEnd <= oend /* No underflow */); + assert(iLitEnd <= litLimit /* Literal length is in bounds */); + assert(oLitEnd <= oend_w /* Can wildcopy literals */); + assert(oMatchEnd <= oend_w /* Can wildcopy matches */); + + /* Copy Literals: + * Split out litLength <= 16 since it is nearly always true. +1.6% on gcc-9. + * We likely don't need the full 32-byte wildcopy. + */ + assert(WILDCOPY_OVERLENGTH >= 16); + ZSTD_copy16(op, (*litPtr)); + if (UNLIKELY(sequence.litLength > 16)) { + ZSTD_wildcopy(op + 16, (*litPtr) + 16, sequence.litLength - 16, ZSTD_no_overlap); + } + op = oLitEnd; + *litPtr = iLitEnd; /* update for next sequence */ + + /* Copy Match */ + if (sequence.offset > (size_t)(oLitEnd - prefixStart)) { + /* offset beyond prefix -> go into extDict */ + RETURN_ERROR_IF(UNLIKELY(sequence.offset > (size_t)(oLitEnd - virtualStart)), corruption_detected, ""); + match = dictEnd + (match - prefixStart); + if (match + sequence.matchLength <= dictEnd) { + ZSTD_memmove(oLitEnd, match, sequence.matchLength); + return sequenceLength; + } + /* span extDict & currentPrefixSegment */ + { size_t const length1 = dictEnd - match; + ZSTD_memmove(oLitEnd, match, length1); + op = oLitEnd + length1; + sequence.matchLength -= length1; + match = prefixStart; + } + } + /* Match within prefix of 1 or more bytes */ + assert(op <= oMatchEnd); + assert(oMatchEnd <= oend_w); + assert(match >= prefixStart); + assert(sequence.matchLength >= 1); + + /* Nearly all offsets are >= WILDCOPY_VECLEN bytes, which means we can use wildcopy + * without overlap checking. + */ + if (LIKELY(sequence.offset >= WILDCOPY_VECLEN)) { + /* We bet on a full wildcopy for matches, since we expect matches to be + * longer than literals (in general). In silesia, ~10% of matches are longer + * than 16 bytes. + */ + ZSTD_wildcopy(op, match, (ptrdiff_t)sequence.matchLength, ZSTD_no_overlap); + return sequenceLength; + } + assert(sequence.offset < WILDCOPY_VECLEN); + + /* Copy 8 bytes and spread the offset to be >= 8. */ + ZSTD_overlapCopy8(&op, &match, sequence.offset); + + /* If the match length is > 8 bytes, then continue with the wildcopy. */ + if (sequence.matchLength > 8) { + assert(op < oMatchEnd); + ZSTD_wildcopy(op, match, (ptrdiff_t)sequence.matchLength - 8, ZSTD_overlap_src_before_dst); + } + return sequenceLength; +} + +HINT_INLINE +size_t ZSTD_execSequenceSplitLitBuffer(BYTE* op, + BYTE* const oend, const BYTE* const oend_w, seq_t sequence, + const BYTE** litPtr, const BYTE* const litLimit, + const BYTE* const prefixStart, const BYTE* const virtualStart, const BYTE* const dictEnd) +{ + BYTE* const oLitEnd = op + sequence.litLength; + size_t const sequenceLength = sequence.litLength + sequence.matchLength; + BYTE* const oMatchEnd = op + sequenceLength; /* risk : address space overflow (32-bits) */ + const BYTE* const iLitEnd = *litPtr + sequence.litLength; + const BYTE* match = oLitEnd - sequence.offset; + + assert(op != NULL /* Precondition */); + assert(oend_w < oend /* No underflow */); + /* Handle edge cases in a slow path: + * - Read beyond end of literals + * - Match end is within WILDCOPY_OVERLIMIT of oend + * - 32-bit mode and the match length overflows + */ + if (UNLIKELY( + iLitEnd > litLimit || + oMatchEnd > oend_w || + (MEM_32bits() && (size_t)(oend - op) < sequenceLength + WILDCOPY_OVERLENGTH))) + return ZSTD_execSequenceEndSplitLitBuffer(op, oend, oend_w, sequence, litPtr, litLimit, prefixStart, virtualStart, dictEnd); + + /* Assumptions (everything else goes into ZSTD_execSequenceEnd()) */ + assert(op <= oLitEnd /* No overflow */); + assert(oLitEnd < oMatchEnd /* Non-zero match & no overflow */); + assert(oMatchEnd <= oend /* No underflow */); + assert(iLitEnd <= litLimit /* Literal length is in bounds */); + assert(oLitEnd <= oend_w /* Can wildcopy literals */); + assert(oMatchEnd <= oend_w /* Can wildcopy matches */); + + /* Copy Literals: + * Split out litLength <= 16 since it is nearly always true. +1.6% on gcc-9. + * We likely don't need the full 32-byte wildcopy. + */ + assert(WILDCOPY_OVERLENGTH >= 16); + ZSTD_copy16(op, (*litPtr)); + if (UNLIKELY(sequence.litLength > 16)) { + ZSTD_wildcopy(op+16, (*litPtr)+16, sequence.litLength-16, ZSTD_no_overlap); + } + op = oLitEnd; + *litPtr = iLitEnd; /* update for next sequence */ + + /* Copy Match */ + if (sequence.offset > (size_t)(oLitEnd - prefixStart)) { + /* offset beyond prefix -> go into extDict */ + RETURN_ERROR_IF(UNLIKELY(sequence.offset > (size_t)(oLitEnd - virtualStart)), corruption_detected, ""); + match = dictEnd + (match - prefixStart); + if (match + sequence.matchLength <= dictEnd) { + ZSTD_memmove(oLitEnd, match, sequence.matchLength); + return sequenceLength; + } + /* span extDict & currentPrefixSegment */ + { size_t const length1 = dictEnd - match; + ZSTD_memmove(oLitEnd, match, length1); + op = oLitEnd + length1; + sequence.matchLength -= length1; + match = prefixStart; + } } + /* Match within prefix of 1 or more bytes */ + assert(op <= oMatchEnd); + assert(oMatchEnd <= oend_w); + assert(match >= prefixStart); + assert(sequence.matchLength >= 1); + + /* Nearly all offsets are >= WILDCOPY_VECLEN bytes, which means we can use wildcopy + * without overlap checking. + */ + if (LIKELY(sequence.offset >= WILDCOPY_VECLEN)) { + /* We bet on a full wildcopy for matches, since we expect matches to be + * longer than literals (in general). In silesia, ~10% of matches are longer + * than 16 bytes. + */ + ZSTD_wildcopy(op, match, (ptrdiff_t)sequence.matchLength, ZSTD_no_overlap); + return sequenceLength; + } + assert(sequence.offset < WILDCOPY_VECLEN); + + /* Copy 8 bytes and spread the offset to be >= 8. */ + ZSTD_overlapCopy8(&op, &match, sequence.offset); + + /* If the match length is > 8 bytes, then continue with the wildcopy. */ + if (sequence.matchLength > 8) { + assert(op < oMatchEnd); + ZSTD_wildcopy(op, match, (ptrdiff_t)sequence.matchLength-8, ZSTD_overlap_src_before_dst); + } + return sequenceLength; +} + + +static void +ZSTD_initFseState(ZSTD_fseState* DStatePtr, BIT_DStream_t* bitD, const ZSTD_seqSymbol* dt) +{ + const void* ptr = dt; + const ZSTD_seqSymbol_header* const DTableH = (const ZSTD_seqSymbol_header*)ptr; + DStatePtr->state = BIT_readBits(bitD, DTableH->tableLog); + DEBUGLOG(6, "ZSTD_initFseState : val=%u using %u bits", + (U32)DStatePtr->state, DTableH->tableLog); + BIT_reloadDStream(bitD); + DStatePtr->table = dt + 1; +} + +FORCE_INLINE_TEMPLATE void +ZSTD_updateFseStateWithDInfo(ZSTD_fseState* DStatePtr, BIT_DStream_t* bitD, U16 nextState, U32 nbBits) +{ + size_t const lowBits = BIT_readBits(bitD, nbBits); + DStatePtr->state = nextState + lowBits; +} + +/* We need to add at most (ZSTD_WINDOWLOG_MAX_32 - 1) bits to read the maximum + * offset bits. But we can only read at most (STREAM_ACCUMULATOR_MIN_32 - 1) + * bits before reloading. This value is the maximum number of bytes we read + * after reloading when we are decoding long offsets. + */ +#define LONG_OFFSETS_MAX_EXTRA_BITS_32 \ + (ZSTD_WINDOWLOG_MAX_32 > STREAM_ACCUMULATOR_MIN_32 \ + ? ZSTD_WINDOWLOG_MAX_32 - STREAM_ACCUMULATOR_MIN_32 \ + : 0) + +typedef enum { ZSTD_lo_isRegularOffset, ZSTD_lo_isLongOffset=1 } ZSTD_longOffset_e; + +FORCE_INLINE_TEMPLATE seq_t +ZSTD_decodeSequence(seqState_t* seqState, const ZSTD_longOffset_e longOffsets) +{ + seq_t seq; + const ZSTD_seqSymbol* const llDInfo = seqState->stateLL.table + seqState->stateLL.state; + const ZSTD_seqSymbol* const mlDInfo = seqState->stateML.table + seqState->stateML.state; + const ZSTD_seqSymbol* const ofDInfo = seqState->stateOffb.table + seqState->stateOffb.state; + seq.matchLength = mlDInfo->baseValue; + seq.litLength = llDInfo->baseValue; + { U32 const ofBase = ofDInfo->baseValue; + BYTE const llBits = llDInfo->nbAdditionalBits; + BYTE const mlBits = mlDInfo->nbAdditionalBits; + BYTE const ofBits = ofDInfo->nbAdditionalBits; + BYTE const totalBits = llBits+mlBits+ofBits; + + U16 const llNext = llDInfo->nextState; + U16 const mlNext = mlDInfo->nextState; + U16 const ofNext = ofDInfo->nextState; + U32 const llnbBits = llDInfo->nbBits; + U32 const mlnbBits = mlDInfo->nbBits; + U32 const ofnbBits = ofDInfo->nbBits; + /* + * As gcc has better branch and block analyzers, sometimes it is only + * valuable to mark likelyness for clang, it gives around 3-4% of + * performance. + */ + + /* sequence */ + { size_t offset; + #if defined(__clang__) + if (LIKELY(ofBits > 1)) { + #else + if (ofBits > 1) { + #endif + ZSTD_STATIC_ASSERT(ZSTD_lo_isLongOffset == 1); + ZSTD_STATIC_ASSERT(LONG_OFFSETS_MAX_EXTRA_BITS_32 == 5); + assert(ofBits <= MaxOff); + if (MEM_32bits() && longOffsets && (ofBits >= STREAM_ACCUMULATOR_MIN_32)) { + U32 const extraBits = ofBits - MIN(ofBits, 32 - seqState->DStream.bitsConsumed); + offset = ofBase + (BIT_readBitsFast(&seqState->DStream, ofBits - extraBits) << extraBits); + BIT_reloadDStream(&seqState->DStream); + if (extraBits) offset += BIT_readBitsFast(&seqState->DStream, extraBits); + assert(extraBits <= LONG_OFFSETS_MAX_EXTRA_BITS_32); /* to avoid another reload */ + } else { + offset = ofBase + BIT_readBitsFast(&seqState->DStream, ofBits/*>0*/); /* <= (ZSTD_WINDOWLOG_MAX-1) bits */ + if (MEM_32bits()) BIT_reloadDStream(&seqState->DStream); + } + seqState->prevOffset[2] = seqState->prevOffset[1]; + seqState->prevOffset[1] = seqState->prevOffset[0]; + seqState->prevOffset[0] = offset; + } else { + U32 const ll0 = (llDInfo->baseValue == 0); + if (LIKELY((ofBits == 0))) { + offset = seqState->prevOffset[ll0]; + seqState->prevOffset[1] = seqState->prevOffset[!ll0]; + seqState->prevOffset[0] = offset; + } else { + offset = ofBase + ll0 + BIT_readBitsFast(&seqState->DStream, 1); + { size_t temp = (offset==3) ? seqState->prevOffset[0] - 1 : seqState->prevOffset[offset]; + temp += !temp; /* 0 is not valid; input is corrupted; force offset to 1 */ + if (offset != 1) seqState->prevOffset[2] = seqState->prevOffset[1]; + seqState->prevOffset[1] = seqState->prevOffset[0]; + seqState->prevOffset[0] = offset = temp; + } } } + seq.offset = offset; + } + + #if defined(__clang__) + if (UNLIKELY(mlBits > 0)) + #else + if (mlBits > 0) + #endif + seq.matchLength += BIT_readBitsFast(&seqState->DStream, mlBits/*>0*/); + + if (MEM_32bits() && (mlBits+llBits >= STREAM_ACCUMULATOR_MIN_32-LONG_OFFSETS_MAX_EXTRA_BITS_32)) + BIT_reloadDStream(&seqState->DStream); + if (MEM_64bits() && UNLIKELY(totalBits >= STREAM_ACCUMULATOR_MIN_64-(LLFSELog+MLFSELog+OffFSELog))) + BIT_reloadDStream(&seqState->DStream); + /* Ensure there are enough bits to read the rest of data in 64-bit mode. */ + ZSTD_STATIC_ASSERT(16+LLFSELog+MLFSELog+OffFSELog < STREAM_ACCUMULATOR_MIN_64); + + #if defined(__clang__) + if (UNLIKELY(llBits > 0)) + #else + if (llBits > 0) + #endif + seq.litLength += BIT_readBitsFast(&seqState->DStream, llBits/*>0*/); + + if (MEM_32bits()) + BIT_reloadDStream(&seqState->DStream); + + DEBUGLOG(6, "seq: litL=%u, matchL=%u, offset=%u", + (U32)seq.litLength, (U32)seq.matchLength, (U32)seq.offset); + + ZSTD_updateFseStateWithDInfo(&seqState->stateLL, &seqState->DStream, llNext, llnbBits); /* <= 9 bits */ + ZSTD_updateFseStateWithDInfo(&seqState->stateML, &seqState->DStream, mlNext, mlnbBits); /* <= 9 bits */ + if (MEM_32bits()) BIT_reloadDStream(&seqState->DStream); /* <= 18 bits */ + ZSTD_updateFseStateWithDInfo(&seqState->stateOffb, &seqState->DStream, ofNext, ofnbBits); /* <= 8 bits */ + } + + return seq; +} + +#ifdef FUZZING_BUILD_MODE_UNSAFE_FOR_PRODUCTION +MEM_STATIC int ZSTD_dictionaryIsActive(ZSTD_DCtx const* dctx, BYTE const* prefixStart, BYTE const* oLitEnd) +{ + size_t const windowSize = dctx->fParams.windowSize; + /* No dictionary used. */ + if (dctx->dictContentEndForFuzzing == NULL) return 0; + /* Dictionary is our prefix. */ + if (prefixStart == dctx->dictContentBeginForFuzzing) return 1; + /* Dictionary is not our ext-dict. */ + if (dctx->dictEnd != dctx->dictContentEndForFuzzing) return 0; + /* Dictionary is not within our window size. */ + if ((size_t)(oLitEnd - prefixStart) >= windowSize) return 0; + /* Dictionary is active. */ + return 1; +} + +MEM_STATIC void ZSTD_assertValidSequence( + ZSTD_DCtx const* dctx, + BYTE const* op, BYTE const* oend, + seq_t const seq, + BYTE const* prefixStart, BYTE const* virtualStart) +{ +#if DEBUGLEVEL >= 1 + size_t const windowSize = dctx->fParams.windowSize; + size_t const sequenceSize = seq.litLength + seq.matchLength; + BYTE const* const oLitEnd = op + seq.litLength; + DEBUGLOG(6, "Checking sequence: litL=%u matchL=%u offset=%u", + (U32)seq.litLength, (U32)seq.matchLength, (U32)seq.offset); + assert(op <= oend); + assert((size_t)(oend - op) >= sequenceSize); + assert(sequenceSize <= ZSTD_BLOCKSIZE_MAX); + if (ZSTD_dictionaryIsActive(dctx, prefixStart, oLitEnd)) { + size_t const dictSize = (size_t)((char const*)dctx->dictContentEndForFuzzing - (char const*)dctx->dictContentBeginForFuzzing); + /* Offset must be within the dictionary. */ + assert(seq.offset <= (size_t)(oLitEnd - virtualStart)); + assert(seq.offset <= windowSize + dictSize); + } else { + /* Offset must be within our window. */ + assert(seq.offset <= windowSize); + } +#else + (void)dctx, (void)op, (void)oend, (void)seq, (void)prefixStart, (void)virtualStart; +#endif +} +#endif + +#ifndef ZSTD_FORCE_DECOMPRESS_SEQUENCES_LONG + + +FORCE_INLINE_TEMPLATE size_t +DONT_VECTORIZE +ZSTD_decompressSequences_bodySplitLitBuffer( ZSTD_DCtx* dctx, + void* dst, size_t maxDstSize, + const void* seqStart, size_t seqSize, int nbSeq, + const ZSTD_longOffset_e isLongOffset, + const int frame) +{ + const BYTE* ip = (const BYTE*)seqStart; + const BYTE* const iend = ip + seqSize; + BYTE* const ostart = (BYTE*)dst; + BYTE* const oend = ostart + maxDstSize; + BYTE* op = ostart; + const BYTE* litPtr = dctx->litPtr; + const BYTE* litBufferEnd = dctx->litBufferEnd; + const BYTE* const prefixStart = (const BYTE*) (dctx->prefixStart); + const BYTE* const vBase = (const BYTE*) (dctx->virtualStart); + const BYTE* const dictEnd = (const BYTE*) (dctx->dictEnd); + DEBUGLOG(5, "ZSTD_decompressSequences_bodySplitLitBuffer"); + (void)frame; + + /* Regen sequences */ + if (nbSeq) { + seqState_t seqState; + dctx->fseEntropy = 1; + { U32 i; for (i=0; i<ZSTD_REP_NUM; i++) seqState.prevOffset[i] = dctx->entropy.rep[i]; } + RETURN_ERROR_IF( + ERR_isError(BIT_initDStream(&seqState.DStream, ip, iend-ip)), + corruption_detected, ""); + ZSTD_initFseState(&seqState.stateLL, &seqState.DStream, dctx->LLTptr); + ZSTD_initFseState(&seqState.stateOffb, &seqState.DStream, dctx->OFTptr); + ZSTD_initFseState(&seqState.stateML, &seqState.DStream, dctx->MLTptr); + assert(dst != NULL); + + ZSTD_STATIC_ASSERT( + BIT_DStream_unfinished < BIT_DStream_completed && + BIT_DStream_endOfBuffer < BIT_DStream_completed && + BIT_DStream_completed < BIT_DStream_overflow); + + /* decompress without overrunning litPtr begins */ + { + seq_t sequence = ZSTD_decodeSequence(&seqState, isLongOffset); + /* Align the decompression loop to 32 + 16 bytes. + * + * zstd compiled with gcc-9 on an Intel i9-9900k shows 10% decompression + * speed swings based on the alignment of the decompression loop. This + * performance swing is caused by parts of the decompression loop falling + * out of the DSB. The entire decompression loop should fit in the DSB, + * when it can't we get much worse performance. You can measure if you've + * hit the good case or the bad case with this perf command for some + * compressed file test.zst: + * + * perf stat -e cycles -e instructions -e idq.all_dsb_cycles_any_uops \ + * -e idq.all_mite_cycles_any_uops -- ./zstd -tq test.zst + * + * If you see most cycles served out of the MITE you've hit the bad case. + * If you see most cycles served out of the DSB you've hit the good case. + * If it is pretty even then you may be in an okay case. + * + * This issue has been reproduced on the following CPUs: + * - Kabylake: Macbook Pro (15-inch, 2019) 2.4 GHz Intel Core i9 + * Use Instruments->Counters to get DSB/MITE cycles. + * I never got performance swings, but I was able to + * go from the good case of mostly DSB to half of the + * cycles served from MITE. + * - Coffeelake: Intel i9-9900k + * - Coffeelake: Intel i7-9700k + * + * I haven't been able to reproduce the instability or DSB misses on any + * of the following CPUS: + * - Haswell + * - Broadwell: Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GH + * - Skylake + * + * Alignment is done for each of the three major decompression loops: + * - ZSTD_decompressSequences_bodySplitLitBuffer - presplit section of the literal buffer + * - ZSTD_decompressSequences_bodySplitLitBuffer - postsplit section of the literal buffer + * - ZSTD_decompressSequences_body + * Alignment choices are made to minimize large swings on bad cases and influence on performance + * from changes external to this code, rather than to overoptimize on the current commit. + * + * If you are seeing performance stability this script can help test. + * It tests on 4 commits in zstd where I saw performance change. + * + * https://gist.github.com/terrelln/9889fc06a423fd5ca6e99351564473f4 + */ +#if defined(__x86_64__) + __asm__(".p2align 6"); +# if __GNUC__ >= 7 + /* good for gcc-7, gcc-9, and gcc-11 */ + __asm__("nop"); + __asm__(".p2align 5"); + __asm__("nop"); + __asm__(".p2align 4"); +# if __GNUC__ == 8 || __GNUC__ == 10 + /* good for gcc-8 and gcc-10 */ + __asm__("nop"); + __asm__(".p2align 3"); +# endif +# endif +#endif + + /* Handle the initial state where litBuffer is currently split between dst and litExtraBuffer */ + for (; litPtr + sequence.litLength <= dctx->litBufferEnd; ) { + size_t const oneSeqSize = ZSTD_execSequenceSplitLitBuffer(op, oend, litPtr + sequence.litLength - WILDCOPY_OVERLENGTH, sequence, &litPtr, litBufferEnd, prefixStart, vBase, dictEnd); +#if defined(FUZZING_BUILD_MODE_UNSAFE_FOR_PRODUCTION) && defined(FUZZING_ASSERT_VALID_SEQUENCE) + assert(!ZSTD_isError(oneSeqSize)); + if (frame) ZSTD_assertValidSequence(dctx, op, oend, sequence, prefixStart, vBase); +#endif + if (UNLIKELY(ZSTD_isError(oneSeqSize))) + return oneSeqSize; + DEBUGLOG(6, "regenerated sequence size : %u", (U32)oneSeqSize); + op += oneSeqSize; + if (UNLIKELY(!--nbSeq)) + break; + BIT_reloadDStream(&(seqState.DStream)); + sequence = ZSTD_decodeSequence(&seqState, isLongOffset); + } + + /* If there are more sequences, they will need to read literals from litExtraBuffer; copy over the remainder from dst and update litPtr and litEnd */ + if (nbSeq > 0) { + const size_t leftoverLit = dctx->litBufferEnd - litPtr; + if (leftoverLit) + { + RETURN_ERROR_IF(leftoverLit > (size_t)(oend - op), dstSize_tooSmall, "remaining lit must fit within dstBuffer"); + ZSTD_safecopyDstBeforeSrc(op, litPtr, leftoverLit); + sequence.litLength -= leftoverLit; + op += leftoverLit; + } + litPtr = dctx->litExtraBuffer; + litBufferEnd = dctx->litExtraBuffer + ZSTD_LITBUFFEREXTRASIZE; + dctx->litBufferLocation = ZSTD_not_in_dst; + { + size_t const oneSeqSize = ZSTD_execSequence(op, oend, sequence, &litPtr, litBufferEnd, prefixStart, vBase, dictEnd); +#if defined(FUZZING_BUILD_MODE_UNSAFE_FOR_PRODUCTION) && defined(FUZZING_ASSERT_VALID_SEQUENCE) + assert(!ZSTD_isError(oneSeqSize)); + if (frame) ZSTD_assertValidSequence(dctx, op, oend, sequence, prefixStart, vBase); +#endif + if (UNLIKELY(ZSTD_isError(oneSeqSize))) + return oneSeqSize; + DEBUGLOG(6, "regenerated sequence size : %u", (U32)oneSeqSize); + op += oneSeqSize; + if (--nbSeq) + BIT_reloadDStream(&(seqState.DStream)); + } + } + } + + if (nbSeq > 0) /* there is remaining lit from extra buffer */ + { + +#if defined(__x86_64__) + __asm__(".p2align 6"); + __asm__("nop"); +# if __GNUC__ != 7 + /* worse for gcc-7 better for gcc-8, gcc-9, and gcc-10 and clang */ + __asm__(".p2align 4"); + __asm__("nop"); + __asm__(".p2align 3"); +# elif __GNUC__ >= 11 + __asm__(".p2align 3"); +# else + __asm__(".p2align 5"); + __asm__("nop"); + __asm__(".p2align 3"); +# endif +#endif + + for (; ; ) { + seq_t const sequence = ZSTD_decodeSequence(&seqState, isLongOffset); + size_t const oneSeqSize = ZSTD_execSequence(op, oend, sequence, &litPtr, litBufferEnd, prefixStart, vBase, dictEnd); +#if defined(FUZZING_BUILD_MODE_UNSAFE_FOR_PRODUCTION) && defined(FUZZING_ASSERT_VALID_SEQUENCE) + assert(!ZSTD_isError(oneSeqSize)); + if (frame) ZSTD_assertValidSequence(dctx, op, oend, sequence, prefixStart, vBase); +#endif + if (UNLIKELY(ZSTD_isError(oneSeqSize))) + return oneSeqSize; + DEBUGLOG(6, "regenerated sequence size : %u", (U32)oneSeqSize); + op += oneSeqSize; + if (UNLIKELY(!--nbSeq)) + break; + BIT_reloadDStream(&(seqState.DStream)); + } + } + + /* check if reached exact end */ + DEBUGLOG(5, "ZSTD_decompressSequences_bodySplitLitBuffer: after decode loop, remaining nbSeq : %i", nbSeq); + RETURN_ERROR_IF(nbSeq, corruption_detected, ""); + RETURN_ERROR_IF(BIT_reloadDStream(&seqState.DStream) < BIT_DStream_completed, corruption_detected, ""); + /* save reps for next block */ + { U32 i; for (i=0; i<ZSTD_REP_NUM; i++) dctx->entropy.rep[i] = (U32)(seqState.prevOffset[i]); } + } + + /* last literal segment */ + if (dctx->litBufferLocation == ZSTD_split) /* split hasn't been reached yet, first get dst then copy litExtraBuffer */ + { + size_t const lastLLSize = litBufferEnd - litPtr; + RETURN_ERROR_IF(lastLLSize > (size_t)(oend - op), dstSize_tooSmall, ""); + if (op != NULL) { + ZSTD_memmove(op, litPtr, lastLLSize); + op += lastLLSize; + } + litPtr = dctx->litExtraBuffer; + litBufferEnd = dctx->litExtraBuffer + ZSTD_LITBUFFEREXTRASIZE; + dctx->litBufferLocation = ZSTD_not_in_dst; + } + { size_t const lastLLSize = litBufferEnd - litPtr; + RETURN_ERROR_IF(lastLLSize > (size_t)(oend-op), dstSize_tooSmall, ""); + if (op != NULL) { + ZSTD_memcpy(op, litPtr, lastLLSize); + op += lastLLSize; + } + } + + return op-ostart; +} + +FORCE_INLINE_TEMPLATE size_t +DONT_VECTORIZE +ZSTD_decompressSequences_body(ZSTD_DCtx* dctx, + void* dst, size_t maxDstSize, + const void* seqStart, size_t seqSize, int nbSeq, + const ZSTD_longOffset_e isLongOffset, + const int frame) +{ + const BYTE* ip = (const BYTE*)seqStart; + const BYTE* const iend = ip + seqSize; + BYTE* const ostart = (BYTE*)dst; + BYTE* const oend = dctx->litBufferLocation == ZSTD_not_in_dst ? ostart + maxDstSize : dctx->litBuffer; + BYTE* op = ostart; + const BYTE* litPtr = dctx->litPtr; + const BYTE* const litEnd = litPtr + dctx->litSize; + const BYTE* const prefixStart = (const BYTE*)(dctx->prefixStart); + const BYTE* const vBase = (const BYTE*)(dctx->virtualStart); + const BYTE* const dictEnd = (const BYTE*)(dctx->dictEnd); + DEBUGLOG(5, "ZSTD_decompressSequences_body"); + (void)frame; + + /* Regen sequences */ + if (nbSeq) { + seqState_t seqState; + dctx->fseEntropy = 1; + { U32 i; for (i = 0; i < ZSTD_REP_NUM; i++) seqState.prevOffset[i] = dctx->entropy.rep[i]; } + RETURN_ERROR_IF( + ERR_isError(BIT_initDStream(&seqState.DStream, ip, iend - ip)), + corruption_detected, ""); + ZSTD_initFseState(&seqState.stateLL, &seqState.DStream, dctx->LLTptr); + ZSTD_initFseState(&seqState.stateOffb, &seqState.DStream, dctx->OFTptr); + ZSTD_initFseState(&seqState.stateML, &seqState.DStream, dctx->MLTptr); + assert(dst != NULL); + + ZSTD_STATIC_ASSERT( + BIT_DStream_unfinished < BIT_DStream_completed && + BIT_DStream_endOfBuffer < BIT_DStream_completed && + BIT_DStream_completed < BIT_DStream_overflow); + +#if defined(__x86_64__) + __asm__(".p2align 6"); + __asm__("nop"); +# if __GNUC__ >= 7 + __asm__(".p2align 5"); + __asm__("nop"); + __asm__(".p2align 3"); +# else + __asm__(".p2align 4"); + __asm__("nop"); + __asm__(".p2align 3"); +# endif +#endif + + for ( ; ; ) { + seq_t const sequence = ZSTD_decodeSequence(&seqState, isLongOffset); + size_t const oneSeqSize = ZSTD_execSequence(op, oend, sequence, &litPtr, litEnd, prefixStart, vBase, dictEnd); +#if defined(FUZZING_BUILD_MODE_UNSAFE_FOR_PRODUCTION) && defined(FUZZING_ASSERT_VALID_SEQUENCE) + assert(!ZSTD_isError(oneSeqSize)); + if (frame) ZSTD_assertValidSequence(dctx, op, oend, sequence, prefixStart, vBase); +#endif + if (UNLIKELY(ZSTD_isError(oneSeqSize))) + return oneSeqSize; + DEBUGLOG(6, "regenerated sequence size : %u", (U32)oneSeqSize); + op += oneSeqSize; + if (UNLIKELY(!--nbSeq)) + break; + BIT_reloadDStream(&(seqState.DStream)); + } + + /* check if reached exact end */ + DEBUGLOG(5, "ZSTD_decompressSequences_body: after decode loop, remaining nbSeq : %i", nbSeq); + RETURN_ERROR_IF(nbSeq, corruption_detected, ""); + RETURN_ERROR_IF(BIT_reloadDStream(&seqState.DStream) < BIT_DStream_completed, corruption_detected, ""); + /* save reps for next block */ + { U32 i; for (i=0; i<ZSTD_REP_NUM; i++) dctx->entropy.rep[i] = (U32)(seqState.prevOffset[i]); } + } + + /* last literal segment */ + { size_t const lastLLSize = litEnd - litPtr; + RETURN_ERROR_IF(lastLLSize > (size_t)(oend-op), dstSize_tooSmall, ""); + if (op != NULL) { + ZSTD_memcpy(op, litPtr, lastLLSize); + op += lastLLSize; + } + } + + return op-ostart; +} + +static size_t +ZSTD_decompressSequences_default(ZSTD_DCtx* dctx, + void* dst, size_t maxDstSize, + const void* seqStart, size_t seqSize, int nbSeq, + const ZSTD_longOffset_e isLongOffset, + const int frame) +{ + return ZSTD_decompressSequences_body(dctx, dst, maxDstSize, seqStart, seqSize, nbSeq, isLongOffset, frame); +} + +static size_t +ZSTD_decompressSequencesSplitLitBuffer_default(ZSTD_DCtx* dctx, + void* dst, size_t maxDstSize, + const void* seqStart, size_t seqSize, int nbSeq, + const ZSTD_longOffset_e isLongOffset, + const int frame) +{ + return ZSTD_decompressSequences_bodySplitLitBuffer(dctx, dst, maxDstSize, seqStart, seqSize, nbSeq, isLongOffset, frame); +} +#endif /* ZSTD_FORCE_DECOMPRESS_SEQUENCES_LONG */ + +#ifndef ZSTD_FORCE_DECOMPRESS_SEQUENCES_SHORT + +FORCE_INLINE_TEMPLATE size_t +ZSTD_prefetchMatch(size_t prefetchPos, seq_t const sequence, + const BYTE* const prefixStart, const BYTE* const dictEnd) +{ + prefetchPos += sequence.litLength; + { const BYTE* const matchBase = (sequence.offset > prefetchPos) ? dictEnd : prefixStart; + const BYTE* const match = matchBase + prefetchPos - sequence.offset; /* note : this operation can overflow when seq.offset is really too large, which can only happen when input is corrupted. + * No consequence though : memory address is only used for prefetching, not for dereferencing */ + PREFETCH_L1(match); PREFETCH_L1(match+CACHELINE_SIZE); /* note : it's safe to invoke PREFETCH() on any memory address, including invalid ones */ + } + return prefetchPos + sequence.matchLength; +} + +/* This decoding function employs prefetching + * to reduce latency impact of cache misses. + * It's generally employed when block contains a significant portion of long-distance matches + * or when coupled with a "cold" dictionary */ +FORCE_INLINE_TEMPLATE size_t +ZSTD_decompressSequencesLong_body( + ZSTD_DCtx* dctx, + void* dst, size_t maxDstSize, + const void* seqStart, size_t seqSize, int nbSeq, + const ZSTD_longOffset_e isLongOffset, + const int frame) +{ + const BYTE* ip = (const BYTE*)seqStart; + const BYTE* const iend = ip + seqSize; + BYTE* const ostart = (BYTE*)dst; + BYTE* const oend = dctx->litBufferLocation == ZSTD_in_dst ? dctx->litBuffer : ostart + maxDstSize; + BYTE* op = ostart; + const BYTE* litPtr = dctx->litPtr; + const BYTE* litBufferEnd = dctx->litBufferEnd; + const BYTE* const prefixStart = (const BYTE*) (dctx->prefixStart); + const BYTE* const dictStart = (const BYTE*) (dctx->virtualStart); + const BYTE* const dictEnd = (const BYTE*) (dctx->dictEnd); + (void)frame; + + /* Regen sequences */ + if (nbSeq) { +#define STORED_SEQS 8 +#define STORED_SEQS_MASK (STORED_SEQS-1) +#define ADVANCED_SEQS STORED_SEQS + seq_t sequences[STORED_SEQS]; + int const seqAdvance = MIN(nbSeq, ADVANCED_SEQS); + seqState_t seqState; + int seqNb; + size_t prefetchPos = (size_t)(op-prefixStart); /* track position relative to prefixStart */ + + dctx->fseEntropy = 1; + { int i; for (i=0; i<ZSTD_REP_NUM; i++) seqState.prevOffset[i] = dctx->entropy.rep[i]; } + assert(dst != NULL); + assert(iend >= ip); + RETURN_ERROR_IF( + ERR_isError(BIT_initDStream(&seqState.DStream, ip, iend-ip)), + corruption_detected, ""); + ZSTD_initFseState(&seqState.stateLL, &seqState.DStream, dctx->LLTptr); + ZSTD_initFseState(&seqState.stateOffb, &seqState.DStream, dctx->OFTptr); + ZSTD_initFseState(&seqState.stateML, &seqState.DStream, dctx->MLTptr); + + /* prepare in advance */ + for (seqNb=0; (BIT_reloadDStream(&seqState.DStream) <= BIT_DStream_completed) && (seqNb<seqAdvance); seqNb++) { + seq_t const sequence = ZSTD_decodeSequence(&seqState, isLongOffset); + prefetchPos = ZSTD_prefetchMatch(prefetchPos, sequence, prefixStart, dictEnd); + sequences[seqNb] = sequence; + } + RETURN_ERROR_IF(seqNb<seqAdvance, corruption_detected, ""); + + /* decompress without stomping litBuffer */ + for (; (BIT_reloadDStream(&(seqState.DStream)) <= BIT_DStream_completed) && (seqNb < nbSeq); seqNb++) { + seq_t sequence = ZSTD_decodeSequence(&seqState, isLongOffset); + size_t oneSeqSize; + + if (dctx->litBufferLocation == ZSTD_split && litPtr + sequences[(seqNb - ADVANCED_SEQS) & STORED_SEQS_MASK].litLength > dctx->litBufferEnd) + { + /* lit buffer is reaching split point, empty out the first buffer and transition to litExtraBuffer */ + const size_t leftoverLit = dctx->litBufferEnd - litPtr; + if (leftoverLit) + { + RETURN_ERROR_IF(leftoverLit > (size_t)(oend - op), dstSize_tooSmall, "remaining lit must fit within dstBuffer"); + ZSTD_safecopyDstBeforeSrc(op, litPtr, leftoverLit); + sequences[(seqNb - ADVANCED_SEQS) & STORED_SEQS_MASK].litLength -= leftoverLit; + op += leftoverLit; + } + litPtr = dctx->litExtraBuffer; + litBufferEnd = dctx->litExtraBuffer + ZSTD_LITBUFFEREXTRASIZE; + dctx->litBufferLocation = ZSTD_not_in_dst; + oneSeqSize = ZSTD_execSequence(op, oend, sequences[(seqNb - ADVANCED_SEQS) & STORED_SEQS_MASK], &litPtr, litBufferEnd, prefixStart, dictStart, dictEnd); +#if defined(FUZZING_BUILD_MODE_UNSAFE_FOR_PRODUCTION) && defined(FUZZING_ASSERT_VALID_SEQUENCE) + assert(!ZSTD_isError(oneSeqSize)); + if (frame) ZSTD_assertValidSequence(dctx, op, oend, sequences[(seqNb - ADVANCED_SEQS) & STORED_SEQS_MASK], prefixStart, dictStart); +#endif + if (ZSTD_isError(oneSeqSize)) return oneSeqSize; + + prefetchPos = ZSTD_prefetchMatch(prefetchPos, sequence, prefixStart, dictEnd); + sequences[seqNb & STORED_SEQS_MASK] = sequence; + op += oneSeqSize; + } + else + { + /* lit buffer is either wholly contained in first or second split, or not split at all*/ + oneSeqSize = dctx->litBufferLocation == ZSTD_split ? + ZSTD_execSequenceSplitLitBuffer(op, oend, litPtr + sequences[(seqNb - ADVANCED_SEQS) & STORED_SEQS_MASK].litLength - WILDCOPY_OVERLENGTH, sequences[(seqNb - ADVANCED_SEQS) & STORED_SEQS_MASK], &litPtr, litBufferEnd, prefixStart, dictStart, dictEnd) : + ZSTD_execSequence(op, oend, sequences[(seqNb - ADVANCED_SEQS) & STORED_SEQS_MASK], &litPtr, litBufferEnd, prefixStart, dictStart, dictEnd); +#if defined(FUZZING_BUILD_MODE_UNSAFE_FOR_PRODUCTION) && defined(FUZZING_ASSERT_VALID_SEQUENCE) + assert(!ZSTD_isError(oneSeqSize)); + if (frame) ZSTD_assertValidSequence(dctx, op, oend, sequences[(seqNb - ADVANCED_SEQS) & STORED_SEQS_MASK], prefixStart, dictStart); +#endif + if (ZSTD_isError(oneSeqSize)) return oneSeqSize; + + prefetchPos = ZSTD_prefetchMatch(prefetchPos, sequence, prefixStart, dictEnd); + sequences[seqNb & STORED_SEQS_MASK] = sequence; + op += oneSeqSize; + } + } + RETURN_ERROR_IF(seqNb<nbSeq, corruption_detected, ""); + + /* finish queue */ + seqNb -= seqAdvance; + for ( ; seqNb<nbSeq ; seqNb++) { + seq_t *sequence = &(sequences[seqNb&STORED_SEQS_MASK]); + if (dctx->litBufferLocation == ZSTD_split && litPtr + sequence->litLength > dctx->litBufferEnd) + { + const size_t leftoverLit = dctx->litBufferEnd - litPtr; + if (leftoverLit) + { + RETURN_ERROR_IF(leftoverLit > (size_t)(oend - op), dstSize_tooSmall, "remaining lit must fit within dstBuffer"); + ZSTD_safecopyDstBeforeSrc(op, litPtr, leftoverLit); + sequence->litLength -= leftoverLit; + op += leftoverLit; + } + litPtr = dctx->litExtraBuffer; + litBufferEnd = dctx->litExtraBuffer + ZSTD_LITBUFFEREXTRASIZE; + dctx->litBufferLocation = ZSTD_not_in_dst; + { + size_t const oneSeqSize = ZSTD_execSequence(op, oend, *sequence, &litPtr, litBufferEnd, prefixStart, dictStart, dictEnd); +#if defined(FUZZING_BUILD_MODE_UNSAFE_FOR_PRODUCTION) && defined(FUZZING_ASSERT_VALID_SEQUENCE) + assert(!ZSTD_isError(oneSeqSize)); + if (frame) ZSTD_assertValidSequence(dctx, op, oend, sequences[seqNb&STORED_SEQS_MASK], prefixStart, dictStart); +#endif + if (ZSTD_isError(oneSeqSize)) return oneSeqSize; + op += oneSeqSize; + } + } + else + { + size_t const oneSeqSize = dctx->litBufferLocation == ZSTD_split ? + ZSTD_execSequenceSplitLitBuffer(op, oend, litPtr + sequence->litLength - WILDCOPY_OVERLENGTH, *sequence, &litPtr, litBufferEnd, prefixStart, dictStart, dictEnd) : + ZSTD_execSequence(op, oend, *sequence, &litPtr, litBufferEnd, prefixStart, dictStart, dictEnd); +#if defined(FUZZING_BUILD_MODE_UNSAFE_FOR_PRODUCTION) && defined(FUZZING_ASSERT_VALID_SEQUENCE) + assert(!ZSTD_isError(oneSeqSize)); + if (frame) ZSTD_assertValidSequence(dctx, op, oend, sequences[seqNb&STORED_SEQS_MASK], prefixStart, dictStart); +#endif + if (ZSTD_isError(oneSeqSize)) return oneSeqSize; + op += oneSeqSize; + } + } + + /* save reps for next block */ + { U32 i; for (i=0; i<ZSTD_REP_NUM; i++) dctx->entropy.rep[i] = (U32)(seqState.prevOffset[i]); } + } + + /* last literal segment */ + if (dctx->litBufferLocation == ZSTD_split) /* first deplete literal buffer in dst, then copy litExtraBuffer */ + { + size_t const lastLLSize = litBufferEnd - litPtr; + RETURN_ERROR_IF(lastLLSize > (size_t)(oend - op), dstSize_tooSmall, ""); + if (op != NULL) { + ZSTD_memmove(op, litPtr, lastLLSize); + op += lastLLSize; + } + litPtr = dctx->litExtraBuffer; + litBufferEnd = dctx->litExtraBuffer + ZSTD_LITBUFFEREXTRASIZE; + } + { size_t const lastLLSize = litBufferEnd - litPtr; + RETURN_ERROR_IF(lastLLSize > (size_t)(oend-op), dstSize_tooSmall, ""); + if (op != NULL) { + ZSTD_memmove(op, litPtr, lastLLSize); + op += lastLLSize; + } + } + + return op-ostart; +} + +static size_t +ZSTD_decompressSequencesLong_default(ZSTD_DCtx* dctx, + void* dst, size_t maxDstSize, + const void* seqStart, size_t seqSize, int nbSeq, + const ZSTD_longOffset_e isLongOffset, + const int frame) +{ + return ZSTD_decompressSequencesLong_body(dctx, dst, maxDstSize, seqStart, seqSize, nbSeq, isLongOffset, frame); +} +#endif /* ZSTD_FORCE_DECOMPRESS_SEQUENCES_SHORT */ + + + +#if DYNAMIC_BMI2 + +#ifndef ZSTD_FORCE_DECOMPRESS_SEQUENCES_LONG +static BMI2_TARGET_ATTRIBUTE size_t +DONT_VECTORIZE +ZSTD_decompressSequences_bmi2(ZSTD_DCtx* dctx, + void* dst, size_t maxDstSize, + const void* seqStart, size_t seqSize, int nbSeq, + const ZSTD_longOffset_e isLongOffset, + const int frame) +{ + return ZSTD_decompressSequences_body(dctx, dst, maxDstSize, seqStart, seqSize, nbSeq, isLongOffset, frame); +} +static BMI2_TARGET_ATTRIBUTE size_t +DONT_VECTORIZE +ZSTD_decompressSequencesSplitLitBuffer_bmi2(ZSTD_DCtx* dctx, + void* dst, size_t maxDstSize, + const void* seqStart, size_t seqSize, int nbSeq, + const ZSTD_longOffset_e isLongOffset, + const int frame) +{ + return ZSTD_decompressSequences_bodySplitLitBuffer(dctx, dst, maxDstSize, seqStart, seqSize, nbSeq, isLongOffset, frame); +} +#endif /* ZSTD_FORCE_DECOMPRESS_SEQUENCES_LONG */ + +#ifndef ZSTD_FORCE_DECOMPRESS_SEQUENCES_SHORT +static BMI2_TARGET_ATTRIBUTE size_t +ZSTD_decompressSequencesLong_bmi2(ZSTD_DCtx* dctx, + void* dst, size_t maxDstSize, + const void* seqStart, size_t seqSize, int nbSeq, + const ZSTD_longOffset_e isLongOffset, + const int frame) +{ + return ZSTD_decompressSequencesLong_body(dctx, dst, maxDstSize, seqStart, seqSize, nbSeq, isLongOffset, frame); +} +#endif /* ZSTD_FORCE_DECOMPRESS_SEQUENCES_SHORT */ + +#endif /* DYNAMIC_BMI2 */ + +typedef size_t (*ZSTD_decompressSequences_t)( + ZSTD_DCtx* dctx, + void* dst, size_t maxDstSize, + const void* seqStart, size_t seqSize, int nbSeq, + const ZSTD_longOffset_e isLongOffset, + const int frame); + +#ifndef ZSTD_FORCE_DECOMPRESS_SEQUENCES_LONG +static size_t +ZSTD_decompressSequences(ZSTD_DCtx* dctx, void* dst, size_t maxDstSize, + const void* seqStart, size_t seqSize, int nbSeq, + const ZSTD_longOffset_e isLongOffset, + const int frame) +{ + DEBUGLOG(5, "ZSTD_decompressSequences"); +#if DYNAMIC_BMI2 + if (ZSTD_DCtx_get_bmi2(dctx)) { + return ZSTD_decompressSequences_bmi2(dctx, dst, maxDstSize, seqStart, seqSize, nbSeq, isLongOffset, frame); + } +#endif + return ZSTD_decompressSequences_default(dctx, dst, maxDstSize, seqStart, seqSize, nbSeq, isLongOffset, frame); +} +static size_t +ZSTD_decompressSequencesSplitLitBuffer(ZSTD_DCtx* dctx, void* dst, size_t maxDstSize, + const void* seqStart, size_t seqSize, int nbSeq, + const ZSTD_longOffset_e isLongOffset, + const int frame) +{ + DEBUGLOG(5, "ZSTD_decompressSequencesSplitLitBuffer"); +#if DYNAMIC_BMI2 + if (ZSTD_DCtx_get_bmi2(dctx)) { + return ZSTD_decompressSequencesSplitLitBuffer_bmi2(dctx, dst, maxDstSize, seqStart, seqSize, nbSeq, isLongOffset, frame); + } +#endif + return ZSTD_decompressSequencesSplitLitBuffer_default(dctx, dst, maxDstSize, seqStart, seqSize, nbSeq, isLongOffset, frame); +} +#endif /* ZSTD_FORCE_DECOMPRESS_SEQUENCES_LONG */ + + +#ifndef ZSTD_FORCE_DECOMPRESS_SEQUENCES_SHORT +/* ZSTD_decompressSequencesLong() : + * decompression function triggered when a minimum share of offsets is considered "long", + * aka out of cache. + * note : "long" definition seems overloaded here, sometimes meaning "wider than bitstream register", and sometimes meaning "farther than memory cache distance". + * This function will try to mitigate main memory latency through the use of prefetching */ +static size_t +ZSTD_decompressSequencesLong(ZSTD_DCtx* dctx, + void* dst, size_t maxDstSize, + const void* seqStart, size_t seqSize, int nbSeq, + const ZSTD_longOffset_e isLongOffset, + const int frame) +{ + DEBUGLOG(5, "ZSTD_decompressSequencesLong"); +#if DYNAMIC_BMI2 + if (ZSTD_DCtx_get_bmi2(dctx)) { + return ZSTD_decompressSequencesLong_bmi2(dctx, dst, maxDstSize, seqStart, seqSize, nbSeq, isLongOffset, frame); + } +#endif + return ZSTD_decompressSequencesLong_default(dctx, dst, maxDstSize, seqStart, seqSize, nbSeq, isLongOffset, frame); +} +#endif /* ZSTD_FORCE_DECOMPRESS_SEQUENCES_SHORT */ + + + +#if !defined(ZSTD_FORCE_DECOMPRESS_SEQUENCES_SHORT) && \ + !defined(ZSTD_FORCE_DECOMPRESS_SEQUENCES_LONG) +/* ZSTD_getLongOffsetsShare() : + * condition : offTable must be valid + * @return : "share" of long offsets (arbitrarily defined as > (1<<23)) + * compared to maximum possible of (1<<OffFSELog) */ +static unsigned +ZSTD_getLongOffsetsShare(const ZSTD_seqSymbol* offTable) +{ + const void* ptr = offTable; + U32 const tableLog = ((const ZSTD_seqSymbol_header*)ptr)[0].tableLog; + const ZSTD_seqSymbol* table = offTable + 1; + U32 const max = 1 << tableLog; + U32 u, total = 0; + DEBUGLOG(5, "ZSTD_getLongOffsetsShare: (tableLog=%u)", tableLog); + + assert(max <= (1 << OffFSELog)); /* max not too large */ + for (u=0; u<max; u++) { + if (table[u].nbAdditionalBits > 22) total += 1; + } + + assert(tableLog <= OffFSELog); + total <<= (OffFSELog - tableLog); /* scale to OffFSELog */ + + return total; +} +#endif + +size_t +ZSTD_decompressBlock_internal(ZSTD_DCtx* dctx, + void* dst, size_t dstCapacity, + const void* src, size_t srcSize, const int frame, const streaming_operation streaming) +{ /* blockType == blockCompressed */ + const BYTE* ip = (const BYTE*)src; + /* isLongOffset must be true if there are long offsets. + * Offsets are long if they are larger than 2^STREAM_ACCUMULATOR_MIN. + * We don't expect that to be the case in 64-bit mode. + * In block mode, window size is not known, so we have to be conservative. + * (note: but it could be evaluated from current-lowLimit) + */ + ZSTD_longOffset_e const isLongOffset = (ZSTD_longOffset_e)(MEM_32bits() && (!frame || (dctx->fParams.windowSize > (1ULL << STREAM_ACCUMULATOR_MIN)))); + DEBUGLOG(5, "ZSTD_decompressBlock_internal (size : %u)", (U32)srcSize); + + RETURN_ERROR_IF(srcSize >= ZSTD_BLOCKSIZE_MAX, srcSize_wrong, ""); + + /* Decode literals section */ + { size_t const litCSize = ZSTD_decodeLiteralsBlock(dctx, src, srcSize, dst, dstCapacity, streaming); + DEBUGLOG(5, "ZSTD_decodeLiteralsBlock : %u", (U32)litCSize); + if (ZSTD_isError(litCSize)) return litCSize; + ip += litCSize; + srcSize -= litCSize; + } + + /* Build Decoding Tables */ + { + /* These macros control at build-time which decompressor implementation + * we use. If neither is defined, we do some inspection and dispatch at + * runtime. + */ +#if !defined(ZSTD_FORCE_DECOMPRESS_SEQUENCES_SHORT) && \ + !defined(ZSTD_FORCE_DECOMPRESS_SEQUENCES_LONG) + int usePrefetchDecoder = dctx->ddictIsCold; +#endif + int nbSeq; + size_t const seqHSize = ZSTD_decodeSeqHeaders(dctx, &nbSeq, ip, srcSize); + if (ZSTD_isError(seqHSize)) return seqHSize; + ip += seqHSize; + srcSize -= seqHSize; + + RETURN_ERROR_IF(dst == NULL && nbSeq > 0, dstSize_tooSmall, "NULL not handled"); + +#if !defined(ZSTD_FORCE_DECOMPRESS_SEQUENCES_SHORT) && \ + !defined(ZSTD_FORCE_DECOMPRESS_SEQUENCES_LONG) + if ( !usePrefetchDecoder + && (!frame || (dctx->fParams.windowSize > (1<<24))) + && (nbSeq>ADVANCED_SEQS) ) { /* could probably use a larger nbSeq limit */ + U32 const shareLongOffsets = ZSTD_getLongOffsetsShare(dctx->OFTptr); + U32 const minShare = MEM_64bits() ? 7 : 20; /* heuristic values, correspond to 2.73% and 7.81% */ + usePrefetchDecoder = (shareLongOffsets >= minShare); + } +#endif + + dctx->ddictIsCold = 0; + +#if !defined(ZSTD_FORCE_DECOMPRESS_SEQUENCES_SHORT) && \ + !defined(ZSTD_FORCE_DECOMPRESS_SEQUENCES_LONG) + if (usePrefetchDecoder) +#endif +#ifndef ZSTD_FORCE_DECOMPRESS_SEQUENCES_SHORT + return ZSTD_decompressSequencesLong(dctx, dst, dstCapacity, ip, srcSize, nbSeq, isLongOffset, frame); +#endif + +#ifndef ZSTD_FORCE_DECOMPRESS_SEQUENCES_LONG + /* else */ + if (dctx->litBufferLocation == ZSTD_split) + return ZSTD_decompressSequencesSplitLitBuffer(dctx, dst, dstCapacity, ip, srcSize, nbSeq, isLongOffset, frame); + else + return ZSTD_decompressSequences(dctx, dst, dstCapacity, ip, srcSize, nbSeq, isLongOffset, frame); +#endif + } +} + + +void ZSTD_checkContinuity(ZSTD_DCtx* dctx, const void* dst, size_t dstSize) +{ + if (dst != dctx->previousDstEnd && dstSize > 0) { /* not contiguous */ + dctx->dictEnd = dctx->previousDstEnd; + dctx->virtualStart = (const char*)dst - ((const char*)(dctx->previousDstEnd) - (const char*)(dctx->prefixStart)); + dctx->prefixStart = dst; + dctx->previousDstEnd = dst; + } +} + + +size_t ZSTD_decompressBlock(ZSTD_DCtx* dctx, + void* dst, size_t dstCapacity, + const void* src, size_t srcSize) +{ + size_t dSize; + ZSTD_checkContinuity(dctx, dst, dstCapacity); + dSize = ZSTD_decompressBlock_internal(dctx, dst, dstCapacity, src, srcSize, /* frame */ 0, not_streaming); + dctx->previousDstEnd = (char*)dst + dSize; + return dSize; +} diff --git a/lib/zstd/decompress/zstd_decompress_block.h b/lib/zstd/decompress/zstd_decompress_block.h new file mode 100644 index 00000000000..3d2d57a5d25 --- /dev/null +++ b/lib/zstd/decompress/zstd_decompress_block.h @@ -0,0 +1,68 @@ +/* + * Copyright (c) Yann Collet, Facebook, Inc. + * All rights reserved. + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. + */ + + +#ifndef ZSTD_DEC_BLOCK_H +#define ZSTD_DEC_BLOCK_H + +/*-******************************************************* + * Dependencies + *********************************************************/ +#include "../common/zstd_deps.h" /* size_t */ +#include <linux/zstd.h> /* DCtx, and some public functions */ +#include "../common/zstd_internal.h" /* blockProperties_t, and some public functions */ +#include "zstd_decompress_internal.h" /* ZSTD_seqSymbol */ + + +/* === Prototypes === */ + +/* note: prototypes already published within `zstd.h` : + * ZSTD_decompressBlock() + */ + +/* note: prototypes already published within `zstd_internal.h` : + * ZSTD_getcBlockSize() + * ZSTD_decodeSeqHeaders() + */ + + + /* Streaming state is used to inform allocation of the literal buffer */ +typedef enum { + not_streaming = 0, + is_streaming = 1 +} streaming_operation; + +/* ZSTD_decompressBlock_internal() : + * decompress block, starting at `src`, + * into destination buffer `dst`. + * @return : decompressed block size, + * or an error code (which can be tested using ZSTD_isError()) + */ +size_t ZSTD_decompressBlock_internal(ZSTD_DCtx* dctx, + void* dst, size_t dstCapacity, + const void* src, size_t srcSize, const int frame, const streaming_operation streaming); + +/* ZSTD_buildFSETable() : + * generate FSE decoding table for one symbol (ll, ml or off) + * this function must be called with valid parameters only + * (dt is large enough, normalizedCounter distribution total is a power of 2, max is within range, etc.) + * in which case it cannot fail. + * The workspace must be 4-byte aligned and at least ZSTD_BUILD_FSE_TABLE_WKSP_SIZE bytes, which is + * defined in zstd_decompress_internal.h. + * Internal use only. + */ +void ZSTD_buildFSETable(ZSTD_seqSymbol* dt, + const short* normalizedCounter, unsigned maxSymbolValue, + const U32* baseValue, const U8* nbAdditionalBits, + unsigned tableLog, void* wksp, size_t wkspSize, + int bmi2); + + +#endif /* ZSTD_DEC_BLOCK_H */ diff --git a/lib/zstd/decompress/zstd_decompress_internal.h b/lib/zstd/decompress/zstd_decompress_internal.h new file mode 100644 index 00000000000..98102edb6a8 --- /dev/null +++ b/lib/zstd/decompress/zstd_decompress_internal.h @@ -0,0 +1,228 @@ +/* + * Copyright (c) Yann Collet, Facebook, Inc. + * All rights reserved. + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. + */ + + +/* zstd_decompress_internal: + * objects and definitions shared within lib/decompress modules */ + + #ifndef ZSTD_DECOMPRESS_INTERNAL_H + #define ZSTD_DECOMPRESS_INTERNAL_H + + +/*-******************************************************* + * Dependencies + *********************************************************/ +#include "../common/mem.h" /* BYTE, U16, U32 */ +#include "../common/zstd_internal.h" /* constants : MaxLL, MaxML, MaxOff, LLFSELog, etc. */ + + + +/*-******************************************************* + * Constants + *********************************************************/ +static UNUSED_ATTR const U32 LL_base[MaxLL+1] = { + 0, 1, 2, 3, 4, 5, 6, 7, + 8, 9, 10, 11, 12, 13, 14, 15, + 16, 18, 20, 22, 24, 28, 32, 40, + 48, 64, 0x80, 0x100, 0x200, 0x400, 0x800, 0x1000, + 0x2000, 0x4000, 0x8000, 0x10000 }; + +static UNUSED_ATTR const U32 OF_base[MaxOff+1] = { + 0, 1, 1, 5, 0xD, 0x1D, 0x3D, 0x7D, + 0xFD, 0x1FD, 0x3FD, 0x7FD, 0xFFD, 0x1FFD, 0x3FFD, 0x7FFD, + 0xFFFD, 0x1FFFD, 0x3FFFD, 0x7FFFD, 0xFFFFD, 0x1FFFFD, 0x3FFFFD, 0x7FFFFD, + 0xFFFFFD, 0x1FFFFFD, 0x3FFFFFD, 0x7FFFFFD, 0xFFFFFFD, 0x1FFFFFFD, 0x3FFFFFFD, 0x7FFFFFFD }; + +static UNUSED_ATTR const U8 OF_bits[MaxOff+1] = { + 0, 1, 2, 3, 4, 5, 6, 7, + 8, 9, 10, 11, 12, 13, 14, 15, + 16, 17, 18, 19, 20, 21, 22, 23, + 24, 25, 26, 27, 28, 29, 30, 31 }; + +static UNUSED_ATTR const U32 ML_base[MaxML+1] = { + 3, 4, 5, 6, 7, 8, 9, 10, + 11, 12, 13, 14, 15, 16, 17, 18, + 19, 20, 21, 22, 23, 24, 25, 26, + 27, 28, 29, 30, 31, 32, 33, 34, + 35, 37, 39, 41, 43, 47, 51, 59, + 67, 83, 99, 0x83, 0x103, 0x203, 0x403, 0x803, + 0x1003, 0x2003, 0x4003, 0x8003, 0x10003 }; + + +/*-******************************************************* + * Decompression types + *********************************************************/ + typedef struct { + U32 fastMode; + U32 tableLog; + } ZSTD_seqSymbol_header; + + typedef struct { + U16 nextState; + BYTE nbAdditionalBits; + BYTE nbBits; + U32 baseValue; + } ZSTD_seqSymbol; + + #define SEQSYMBOL_TABLE_SIZE(log) (1 + (1 << (log))) + +#define ZSTD_BUILD_FSE_TABLE_WKSP_SIZE (sizeof(S16) * (MaxSeq + 1) + (1u << MaxFSELog) + sizeof(U64)) +#define ZSTD_BUILD_FSE_TABLE_WKSP_SIZE_U32 ((ZSTD_BUILD_FSE_TABLE_WKSP_SIZE + sizeof(U32) - 1) / sizeof(U32)) + +typedef struct { + ZSTD_seqSymbol LLTable[SEQSYMBOL_TABLE_SIZE(LLFSELog)]; /* Note : Space reserved for FSE Tables */ + ZSTD_seqSymbol OFTable[SEQSYMBOL_TABLE_SIZE(OffFSELog)]; /* is also used as temporary workspace while building hufTable during DDict creation */ + ZSTD_seqSymbol MLTable[SEQSYMBOL_TABLE_SIZE(MLFSELog)]; /* and therefore must be at least HUF_DECOMPRESS_WORKSPACE_SIZE large */ + HUF_DTable hufTable[HUF_DTABLE_SIZE(HufLog)]; /* can accommodate HUF_decompress4X */ + U32 rep[ZSTD_REP_NUM]; + U32 workspace[ZSTD_BUILD_FSE_TABLE_WKSP_SIZE_U32]; +} ZSTD_entropyDTables_t; + +typedef enum { ZSTDds_getFrameHeaderSize, ZSTDds_decodeFrameHeader, + ZSTDds_decodeBlockHeader, ZSTDds_decompressBlock, + ZSTDds_decompressLastBlock, ZSTDds_checkChecksum, + ZSTDds_decodeSkippableHeader, ZSTDds_skipFrame } ZSTD_dStage; + +typedef enum { zdss_init=0, zdss_loadHeader, + zdss_read, zdss_load, zdss_flush } ZSTD_dStreamStage; + +typedef enum { + ZSTD_use_indefinitely = -1, /* Use the dictionary indefinitely */ + ZSTD_dont_use = 0, /* Do not use the dictionary (if one exists free it) */ + ZSTD_use_once = 1 /* Use the dictionary once and set to ZSTD_dont_use */ +} ZSTD_dictUses_e; + +/* Hashset for storing references to multiple ZSTD_DDict within ZSTD_DCtx */ +typedef struct { + const ZSTD_DDict** ddictPtrTable; + size_t ddictPtrTableSize; + size_t ddictPtrCount; +} ZSTD_DDictHashSet; + +#ifndef ZSTD_DECODER_INTERNAL_BUFFER +# define ZSTD_DECODER_INTERNAL_BUFFER (1 << 16) +#endif + +#define ZSTD_LBMIN 64 +#define ZSTD_LBMAX (128 << 10) + +/* extra buffer, compensates when dst is not large enough to store litBuffer */ +#define ZSTD_LITBUFFEREXTRASIZE BOUNDED(ZSTD_LBMIN, ZSTD_DECODER_INTERNAL_BUFFER, ZSTD_LBMAX) + +typedef enum { + ZSTD_not_in_dst = 0, /* Stored entirely within litExtraBuffer */ + ZSTD_in_dst = 1, /* Stored entirely within dst (in memory after current output write) */ + ZSTD_split = 2 /* Split between litExtraBuffer and dst */ +} ZSTD_litLocation_e; + +struct ZSTD_DCtx_s +{ + const ZSTD_seqSymbol* LLTptr; + const ZSTD_seqSymbol* MLTptr; + const ZSTD_seqSymbol* OFTptr; + const HUF_DTable* HUFptr; + ZSTD_entropyDTables_t entropy; + U32 workspace[HUF_DECOMPRESS_WORKSPACE_SIZE_U32]; /* space needed when building huffman tables */ + const void* previousDstEnd; /* detect continuity */ + const void* prefixStart; /* start of current segment */ + const void* virtualStart; /* virtual start of previous segment if it was just before current one */ + const void* dictEnd; /* end of previous segment */ + size_t expected; + ZSTD_frameHeader fParams; + U64 processedCSize; + U64 decodedSize; + blockType_e bType; /* used in ZSTD_decompressContinue(), store blockType between block header decoding and block decompression stages */ + ZSTD_dStage stage; + U32 litEntropy; + U32 fseEntropy; + struct xxh64_state xxhState; + size_t headerSize; + ZSTD_format_e format; + ZSTD_forceIgnoreChecksum_e forceIgnoreChecksum; /* User specified: if == 1, will ignore checksums in compressed frame. Default == 0 */ + U32 validateChecksum; /* if == 1, will validate checksum. Is == 1 if (fParams.checksumFlag == 1) and (forceIgnoreChecksum == 0). */ + const BYTE* litPtr; + ZSTD_customMem customMem; + size_t litSize; + size_t rleSize; + size_t staticSize; +#if DYNAMIC_BMI2 != 0 + int bmi2; /* == 1 if the CPU supports BMI2 and 0 otherwise. CPU support is determined dynamically once per context lifetime. */ +#endif + + /* dictionary */ + ZSTD_DDict* ddictLocal; + const ZSTD_DDict* ddict; /* set by ZSTD_initDStream_usingDDict(), or ZSTD_DCtx_refDDict() */ + U32 dictID; + int ddictIsCold; /* if == 1 : dictionary is "new" for working context, and presumed "cold" (not in cpu cache) */ + ZSTD_dictUses_e dictUses; + ZSTD_DDictHashSet* ddictSet; /* Hash set for multiple ddicts */ + ZSTD_refMultipleDDicts_e refMultipleDDicts; /* User specified: if == 1, will allow references to multiple DDicts. Default == 0 (disabled) */ + + /* streaming */ + ZSTD_dStreamStage streamStage; + char* inBuff; + size_t inBuffSize; + size_t inPos; + size_t maxWindowSize; + char* outBuff; + size_t outBuffSize; + size_t outStart; + size_t outEnd; + size_t lhSize; + U32 hostageByte; + int noForwardProgress; + ZSTD_bufferMode_e outBufferMode; + ZSTD_outBuffer expectedOutBuffer; + + /* workspace */ + BYTE* litBuffer; + const BYTE* litBufferEnd; + ZSTD_litLocation_e litBufferLocation; + BYTE litExtraBuffer[ZSTD_LITBUFFEREXTRASIZE + WILDCOPY_OVERLENGTH]; /* literal buffer can be split between storage within dst and within this scratch buffer */ + BYTE headerBuffer[ZSTD_FRAMEHEADERSIZE_MAX]; + + size_t oversizedDuration; + +#ifdef FUZZING_BUILD_MODE_UNSAFE_FOR_PRODUCTION + void const* dictContentBeginForFuzzing; + void const* dictContentEndForFuzzing; +#endif + + /* Tracing */ +}; /* typedef'd to ZSTD_DCtx within "zstd.h" */ + +MEM_STATIC int ZSTD_DCtx_get_bmi2(const struct ZSTD_DCtx_s *dctx) { +#if DYNAMIC_BMI2 != 0 + return dctx->bmi2; +#else + (void)dctx; + return 0; +#endif +} + +/*-******************************************************* + * Shared internal functions + *********************************************************/ + +/*! ZSTD_loadDEntropy() : + * dict : must point at beginning of a valid zstd dictionary. + * @return : size of dictionary header (size of magic number + dict ID + entropy tables) */ +size_t ZSTD_loadDEntropy(ZSTD_entropyDTables_t* entropy, + const void* const dict, size_t const dictSize); + +/*! ZSTD_checkContinuity() : + * check if next `dst` follows previous position, where decompression ended. + * If yes, do nothing (continue on current segment). + * If not, classify previous segment as "external dictionary", and start a new segment. + * This function cannot fail. */ +void ZSTD_checkContinuity(ZSTD_DCtx* dctx, const void* dst, size_t dstSize); + + +#endif /* ZSTD_DECOMPRESS_INTERNAL_H */ diff --git a/lib/zstd/decompress_sources.h b/lib/zstd/decompress_sources.h new file mode 100644 index 00000000000..a06ca187aab --- /dev/null +++ b/lib/zstd/decompress_sources.h @@ -0,0 +1,34 @@ +/* SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause */ +/* + * Copyright (c) Facebook, Inc. + * All rights reserved. + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. + */ + +/* + * This file includes every .c file needed for decompression. + * It is used by lib/decompress_unzstd.c to include the decompression + * source into the translation-unit, so it can be used for kernel + * decompression. + */ + +/* + * Disable the ASM Huffman implementation because we need to + * include all the sources. + */ +#define ZSTD_DISABLE_ASM 1 + +#include "common/debug.c" +#include "common/entropy_common.c" +#include "common/error_private.c" +#include "common/fse_decompress.c" +#include "common/zstd_common.c" +#include "decompress/huf_decompress.c" +#include "decompress/zstd_ddict.c" +#include "decompress/zstd_decompress.c" +#include "decompress/zstd_decompress_block.c" +#include "zstd_decompress_module.c" diff --git a/lib/zstd/entropy_common.c b/lib/zstd/entropy_common.c deleted file mode 100644 index 071fef997e7..00000000000 --- a/lib/zstd/entropy_common.c +++ /dev/null @@ -1,213 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0 or BSD-2-Clause) -/* - * Common functions of New Generation Entropy library - * Copyright (C) 2016, Yann Collet. - * - * You can contact the author at : - * - Source repository : https://github.com/Cyan4973/FiniteStateEntropy - */ - -/* ************************************* -* Dependencies -***************************************/ -#include "error_private.h" /* ERR_*, ERROR */ -#include "fse.h" -#include "huf.h" -#include "mem.h" - -/*=== Version ===*/ -unsigned FSE_versionNumber(void) { return FSE_VERSION_NUMBER; } - -/*=== Error Management ===*/ -unsigned FSE_isError(size_t code) { return ERR_isError(code); } - -unsigned HUF_isError(size_t code) { return ERR_isError(code); } - -/*-************************************************************** -* FSE NCount encoding-decoding -****************************************************************/ -size_t FSE_readNCount(short *normalizedCounter, unsigned *maxSVPtr, unsigned *tableLogPtr, const void *headerBuffer, size_t hbSize) -{ - const BYTE *const istart = (const BYTE *)headerBuffer; - const BYTE *const iend = istart + hbSize; - const BYTE *ip = istart; - int nbBits; - int remaining; - int threshold; - U32 bitStream; - int bitCount; - unsigned charnum = 0; - int previous0 = 0; - - if (hbSize < 4) - return ERROR(srcSize_wrong); - bitStream = ZSTD_readLE32(ip); - nbBits = (bitStream & 0xF) + FSE_MIN_TABLELOG; /* extract tableLog */ - if (nbBits > FSE_TABLELOG_ABSOLUTE_MAX) - return ERROR(tableLog_tooLarge); - bitStream >>= 4; - bitCount = 4; - *tableLogPtr = nbBits; - remaining = (1 << nbBits) + 1; - threshold = 1 << nbBits; - nbBits++; - - while ((remaining > 1) & (charnum <= *maxSVPtr)) { - if (previous0) { - unsigned n0 = charnum; - while ((bitStream & 0xFFFF) == 0xFFFF) { - n0 += 24; - if (ip < iend - 5) { - ip += 2; - bitStream = ZSTD_readLE32(ip) >> bitCount; - } else { - bitStream >>= 16; - bitCount += 16; - } - } - while ((bitStream & 3) == 3) { - n0 += 3; - bitStream >>= 2; - bitCount += 2; - } - n0 += bitStream & 3; - bitCount += 2; - if (n0 > *maxSVPtr) - return ERROR(maxSymbolValue_tooSmall); - while (charnum < n0) - normalizedCounter[charnum++] = 0; - if ((ip <= iend - 7) || (ip + (bitCount >> 3) <= iend - 4)) { - ip += bitCount >> 3; - bitCount &= 7; - bitStream = ZSTD_readLE32(ip) >> bitCount; - } else { - bitStream >>= 2; - } - } - { - int const max = (2 * threshold - 1) - remaining; - int count; - - if ((bitStream & (threshold - 1)) < (U32)max) { - count = bitStream & (threshold - 1); - bitCount += nbBits - 1; - } else { - count = bitStream & (2 * threshold - 1); - if (count >= threshold) - count -= max; - bitCount += nbBits; - } - - count--; /* extra accuracy */ - remaining -= count < 0 ? -count : count; /* -1 means +1 */ - normalizedCounter[charnum++] = (short)count; - previous0 = !count; - while (remaining < threshold) { - nbBits--; - threshold >>= 1; - } - - if ((ip <= iend - 7) || (ip + (bitCount >> 3) <= iend - 4)) { - ip += bitCount >> 3; - bitCount &= 7; - } else { - bitCount -= (int)(8 * (iend - 4 - ip)); - ip = iend - 4; - } - bitStream = ZSTD_readLE32(ip) >> (bitCount & 31); - } - } /* while ((remaining>1) & (charnum<=*maxSVPtr)) */ - if (remaining != 1) - return ERROR(corruption_detected); - if (bitCount > 32) - return ERROR(corruption_detected); - *maxSVPtr = charnum - 1; - - ip += (bitCount + 7) >> 3; - return ip - istart; -} - -/*! HUF_readStats() : - Read compact Huffman tree, saved by HUF_writeCTable(). - `huffWeight` is destination buffer. - `rankStats` is assumed to be a table of at least HUF_TABLELOG_MAX U32. - @return : size read from `src` , or an error Code . - Note : Needed by HUF_readCTable() and HUF_readDTableX?() . -*/ -size_t HUF_readStats_wksp(BYTE *huffWeight, size_t hwSize, U32 *rankStats, U32 *nbSymbolsPtr, U32 *tableLogPtr, const void *src, size_t srcSize, void *workspace, size_t workspaceSize) -{ - U32 weightTotal; - const BYTE *ip = (const BYTE *)src; - size_t iSize; - size_t oSize; - - if (!srcSize) - return ERROR(srcSize_wrong); - iSize = ip[0]; - /* memset(huffWeight, 0, hwSize); */ /* is not necessary, even though some analyzer complain ... */ - - if (iSize >= 128) { /* special header */ - oSize = iSize - 127; - iSize = ((oSize + 1) / 2); - if (iSize + 1 > srcSize) - return ERROR(srcSize_wrong); - if (oSize >= hwSize) - return ERROR(corruption_detected); - ip += 1; - { - U32 n; - for (n = 0; n < oSize; n += 2) { - huffWeight[n] = ip[n / 2] >> 4; - huffWeight[n + 1] = ip[n / 2] & 15; - } - } - } else { /* header compressed with FSE (normal case) */ - if (iSize + 1 > srcSize) - return ERROR(srcSize_wrong); - oSize = FSE_decompress_wksp(huffWeight, hwSize - 1, ip + 1, iSize, 6, workspace, workspaceSize); /* max (hwSize-1) values decoded, as last one is implied */ - if (FSE_isError(oSize)) - return oSize; - } - - /* collect weight stats */ - memset(rankStats, 0, (HUF_TABLELOG_MAX + 1) * sizeof(U32)); - weightTotal = 0; - { - U32 n; - for (n = 0; n < oSize; n++) { - if (huffWeight[n] >= HUF_TABLELOG_MAX) - return ERROR(corruption_detected); - rankStats[huffWeight[n]]++; - weightTotal += (1 << huffWeight[n]) >> 1; - } - } - if (weightTotal == 0) - return ERROR(corruption_detected); - - /* get last non-null symbol weight (implied, total must be 2^n) */ - { - U32 const tableLog = BIT_highbit32(weightTotal) + 1; - if (tableLog > HUF_TABLELOG_MAX) - return ERROR(corruption_detected); - *tableLogPtr = tableLog; - /* determine last weight */ - { - U32 const total = 1 << tableLog; - U32 const rest = total - weightTotal; - U32 const verif = 1 << BIT_highbit32(rest); - U32 const lastWeight = BIT_highbit32(rest) + 1; - if (verif != rest) - return ERROR(corruption_detected); /* last value must be a clean power of 2 */ - huffWeight[oSize] = (BYTE)lastWeight; - rankStats[lastWeight]++; - } - } - - /* check tree construction validity */ - if ((rankStats[1] < 2) || (rankStats[1] & 1)) - return ERROR(corruption_detected); /* by construction : at least 2 elts of rank 1, must be even */ - - /* results */ - *nbSymbolsPtr = (U32)(oSize + 1); - return iSize + 1; -} diff --git a/lib/zstd/error_private.h b/lib/zstd/error_private.h deleted file mode 100644 index d4824e25b2a..00000000000 --- a/lib/zstd/error_private.h +++ /dev/null @@ -1,43 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 or BSD-3-Clause-Clear) */ -/** - * Copyright (c) 2016-present, Yann Collet, Facebook, Inc. - * All rights reserved. - */ - -/* Note : this module is expected to remain private, do not expose it */ - -#ifndef ERROR_H_MODULE -#define ERROR_H_MODULE - -/* **************************************** -* Dependencies -******************************************/ -#include <linux/types.h> /* size_t */ -#include <linux/zstd.h> /* enum list */ - -/* **************************************** -* Compiler-specific -******************************************/ -#define ERR_STATIC static __attribute__((unused)) - -/*-**************************************** -* Customization (error_public.h) -******************************************/ -typedef ZSTD_ErrorCode ERR_enum; -#define PREFIX(name) ZSTD_error_##name - -/*-**************************************** -* Error codes handling -******************************************/ -#define ERROR(name) ((size_t)-PREFIX(name)) - -ERR_STATIC unsigned ERR_isError(size_t code) { return (code > ERROR(maxCode)); } - -ERR_STATIC ERR_enum ERR_getErrorCode(size_t code) -{ - if (!ERR_isError(code)) - return (ERR_enum)0; - return (ERR_enum)(0 - code); -} - -#endif /* ERROR_H_MODULE */ diff --git a/lib/zstd/fse.h b/lib/zstd/fse.h deleted file mode 100644 index 42f80ff73ec..00000000000 --- a/lib/zstd/fse.h +++ /dev/null @@ -1,545 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 or BSD-2-Clause) */ -/* - * FSE : Finite State Entropy codec - * Public Prototypes declaration - * Copyright (C) 2013-2016, Yann Collet. - * - * You can contact the author at : - * - Source repository : https://github.com/Cyan4973/FiniteStateEntropy - */ -#ifndef FSE_H -#define FSE_H - -/*-***************************************** -* Dependencies -******************************************/ -#include <linux/types.h> /* size_t, ptrdiff_t */ - -/*-***************************************** -* FSE_PUBLIC_API : control library symbols visibility -******************************************/ -#define FSE_PUBLIC_API - -/*------ Version ------*/ -#define FSE_VERSION_MAJOR 0 -#define FSE_VERSION_MINOR 9 -#define FSE_VERSION_RELEASE 0 - -#define FSE_LIB_VERSION FSE_VERSION_MAJOR.FSE_VERSION_MINOR.FSE_VERSION_RELEASE -#define FSE_QUOTE(str) #str -#define FSE_EXPAND_AND_QUOTE(str) FSE_QUOTE(str) -#define FSE_VERSION_STRING FSE_EXPAND_AND_QUOTE(FSE_LIB_VERSION) - -#define FSE_VERSION_NUMBER (FSE_VERSION_MAJOR * 100 * 100 + FSE_VERSION_MINOR * 100 + FSE_VERSION_RELEASE) -FSE_PUBLIC_API unsigned FSE_versionNumber(void); /**< library version number; to be used when checking dll version */ - -/*-***************************************** -* Tool functions -******************************************/ -FSE_PUBLIC_API size_t FSE_compressBound(size_t size); /* maximum compressed size */ - -/* Error Management */ -FSE_PUBLIC_API unsigned FSE_isError(size_t code); /* tells if a return value is an error code */ - -/*-***************************************** -* FSE detailed API -******************************************/ -/*! -FSE_compress() does the following: -1. count symbol occurrence from source[] into table count[] -2. normalize counters so that sum(count[]) == Power_of_2 (2^tableLog) -3. save normalized counters to memory buffer using writeNCount() -4. build encoding table 'CTable' from normalized counters -5. encode the data stream using encoding table 'CTable' - -FSE_decompress() does the following: -1. read normalized counters with readNCount() -2. build decoding table 'DTable' from normalized counters -3. decode the data stream using decoding table 'DTable' - -The following API allows targeting specific sub-functions for advanced tasks. -For example, it's possible to compress several blocks using the same 'CTable', -or to save and provide normalized distribution using external method. -*/ - -/* *** COMPRESSION *** */ -/*! FSE_optimalTableLog(): - dynamically downsize 'tableLog' when conditions are met. - It saves CPU time, by using smaller tables, while preserving or even improving compression ratio. - @return : recommended tableLog (necessarily <= 'maxTableLog') */ -FSE_PUBLIC_API unsigned FSE_optimalTableLog(unsigned maxTableLog, size_t srcSize, unsigned maxSymbolValue); - -/*! FSE_normalizeCount(): - normalize counts so that sum(count[]) == Power_of_2 (2^tableLog) - 'normalizedCounter' is a table of short, of minimum size (maxSymbolValue+1). - @return : tableLog, - or an errorCode, which can be tested using FSE_isError() */ -FSE_PUBLIC_API size_t FSE_normalizeCount(short *normalizedCounter, unsigned tableLog, const unsigned *count, size_t srcSize, unsigned maxSymbolValue); - -/*! FSE_NCountWriteBound(): - Provides the maximum possible size of an FSE normalized table, given 'maxSymbolValue' and 'tableLog'. - Typically useful for allocation purpose. */ -FSE_PUBLIC_API size_t FSE_NCountWriteBound(unsigned maxSymbolValue, unsigned tableLog); - -/*! FSE_writeNCount(): - Compactly save 'normalizedCounter' into 'buffer'. - @return : size of the compressed table, - or an errorCode, which can be tested using FSE_isError(). */ -FSE_PUBLIC_API size_t FSE_writeNCount(void *buffer, size_t bufferSize, const short *normalizedCounter, unsigned maxSymbolValue, unsigned tableLog); - -/*! Constructor and Destructor of FSE_CTable. - Note that FSE_CTable size depends on 'tableLog' and 'maxSymbolValue' */ -typedef unsigned FSE_CTable; /* don't allocate that. It's only meant to be more restrictive than void* */ - -/*! FSE_compress_usingCTable(): - Compress `src` using `ct` into `dst` which must be already allocated. - @return : size of compressed data (<= `dstCapacity`), - or 0 if compressed data could not fit into `dst`, - or an errorCode, which can be tested using FSE_isError() */ -FSE_PUBLIC_API size_t FSE_compress_usingCTable(void *dst, size_t dstCapacity, const void *src, size_t srcSize, const FSE_CTable *ct); - -/*! -Tutorial : ----------- -The first step is to count all symbols. FSE_count() does this job very fast. -Result will be saved into 'count', a table of unsigned int, which must be already allocated, and have 'maxSymbolValuePtr[0]+1' cells. -'src' is a table of bytes of size 'srcSize'. All values within 'src' MUST be <= maxSymbolValuePtr[0] -maxSymbolValuePtr[0] will be updated, with its real value (necessarily <= original value) -FSE_count() will return the number of occurrence of the most frequent symbol. -This can be used to know if there is a single symbol within 'src', and to quickly evaluate its compressibility. -If there is an error, the function will return an ErrorCode (which can be tested using FSE_isError()). - -The next step is to normalize the frequencies. -FSE_normalizeCount() will ensure that sum of frequencies is == 2 ^'tableLog'. -It also guarantees a minimum of 1 to any Symbol with frequency >= 1. -You can use 'tableLog'==0 to mean "use default tableLog value". -If you are unsure of which tableLog value to use, you can ask FSE_optimalTableLog(), -which will provide the optimal valid tableLog given sourceSize, maxSymbolValue, and a user-defined maximum (0 means "default"). - -The result of FSE_normalizeCount() will be saved into a table, -called 'normalizedCounter', which is a table of signed short. -'normalizedCounter' must be already allocated, and have at least 'maxSymbolValue+1' cells. -The return value is tableLog if everything proceeded as expected. -It is 0 if there is a single symbol within distribution. -If there is an error (ex: invalid tableLog value), the function will return an ErrorCode (which can be tested using FSE_isError()). - -'normalizedCounter' can be saved in a compact manner to a memory area using FSE_writeNCount(). -'buffer' must be already allocated. -For guaranteed success, buffer size must be at least FSE_headerBound(). -The result of the function is the number of bytes written into 'buffer'. -If there is an error, the function will return an ErrorCode (which can be tested using FSE_isError(); ex : buffer size too small). - -'normalizedCounter' can then be used to create the compression table 'CTable'. -The space required by 'CTable' must be already allocated, using FSE_createCTable(). -You can then use FSE_buildCTable() to fill 'CTable'. -If there is an error, both functions will return an ErrorCode (which can be tested using FSE_isError()). - -'CTable' can then be used to compress 'src', with FSE_compress_usingCTable(). -Similar to FSE_count(), the convention is that 'src' is assumed to be a table of char of size 'srcSize' -The function returns the size of compressed data (without header), necessarily <= `dstCapacity`. -If it returns '0', compressed data could not fit into 'dst'. -If there is an error, the function will return an ErrorCode (which can be tested using FSE_isError()). -*/ - -/* *** DECOMPRESSION *** */ - -/*! FSE_readNCount(): - Read compactly saved 'normalizedCounter' from 'rBuffer'. - @return : size read from 'rBuffer', - or an errorCode, which can be tested using FSE_isError(). - maxSymbolValuePtr[0] and tableLogPtr[0] will also be updated with their respective values */ -FSE_PUBLIC_API size_t FSE_readNCount(short *normalizedCounter, unsigned *maxSymbolValuePtr, unsigned *tableLogPtr, const void *rBuffer, size_t rBuffSize); - -/*! Constructor and Destructor of FSE_DTable. - Note that its size depends on 'tableLog' */ -typedef unsigned FSE_DTable; /* don't allocate that. It's just a way to be more restrictive than void* */ - -/*! FSE_buildDTable(): - Builds 'dt', which must be already allocated, using FSE_createDTable(). - return : 0, or an errorCode, which can be tested using FSE_isError() */ -FSE_PUBLIC_API size_t FSE_buildDTable_wksp(FSE_DTable *dt, const short *normalizedCounter, unsigned maxSymbolValue, unsigned tableLog, void *workspace, size_t workspaceSize); - -/*! FSE_decompress_usingDTable(): - Decompress compressed source `cSrc` of size `cSrcSize` using `dt` - into `dst` which must be already allocated. - @return : size of regenerated data (necessarily <= `dstCapacity`), - or an errorCode, which can be tested using FSE_isError() */ -FSE_PUBLIC_API size_t FSE_decompress_usingDTable(void *dst, size_t dstCapacity, const void *cSrc, size_t cSrcSize, const FSE_DTable *dt); - -/*! -Tutorial : ----------- -(Note : these functions only decompress FSE-compressed blocks. - If block is uncompressed, use memcpy() instead - If block is a single repeated byte, use memset() instead ) - -The first step is to obtain the normalized frequencies of symbols. -This can be performed by FSE_readNCount() if it was saved using FSE_writeNCount(). -'normalizedCounter' must be already allocated, and have at least 'maxSymbolValuePtr[0]+1' cells of signed short. -In practice, that means it's necessary to know 'maxSymbolValue' beforehand, -or size the table to handle worst case situations (typically 256). -FSE_readNCount() will provide 'tableLog' and 'maxSymbolValue'. -The result of FSE_readNCount() is the number of bytes read from 'rBuffer'. -Note that 'rBufferSize' must be at least 4 bytes, even if useful information is less than that. -If there is an error, the function will return an error code, which can be tested using FSE_isError(). - -The next step is to build the decompression tables 'FSE_DTable' from 'normalizedCounter'. -This is performed by the function FSE_buildDTable(). -The space required by 'FSE_DTable' must be already allocated using FSE_createDTable(). -If there is an error, the function will return an error code, which can be tested using FSE_isError(). - -`FSE_DTable` can then be used to decompress `cSrc`, with FSE_decompress_usingDTable(). -`cSrcSize` must be strictly correct, otherwise decompression will fail. -FSE_decompress_usingDTable() result will tell how many bytes were regenerated (<=`dstCapacity`). -If there is an error, the function will return an error code, which can be tested using FSE_isError(). (ex: dst buffer too small) -*/ - -/* *** Dependency *** */ -#include "bitstream.h" - -/* ***************************************** -* Static allocation -*******************************************/ -/* FSE buffer bounds */ -#define FSE_NCOUNTBOUND 512 -#define FSE_BLOCKBOUND(size) (size + (size >> 7)) -#define FSE_COMPRESSBOUND(size) (FSE_NCOUNTBOUND + FSE_BLOCKBOUND(size)) /* Macro version, useful for static allocation */ - -/* It is possible to statically allocate FSE CTable/DTable as a table of FSE_CTable/FSE_DTable using below macros */ -#define FSE_CTABLE_SIZE_U32(maxTableLog, maxSymbolValue) (1 + (1 << (maxTableLog - 1)) + ((maxSymbolValue + 1) * 2)) -#define FSE_DTABLE_SIZE_U32(maxTableLog) (1 + (1 << maxTableLog)) - -/* ***************************************** -* FSE advanced API -*******************************************/ -/* FSE_count_wksp() : - * Same as FSE_count(), but using an externally provided scratch buffer. - * `workSpace` size must be table of >= `1024` unsigned - */ -size_t FSE_count_wksp(unsigned *count, unsigned *maxSymbolValuePtr, const void *source, size_t sourceSize, unsigned *workSpace); - -/* FSE_countFast_wksp() : - * Same as FSE_countFast(), but using an externally provided scratch buffer. - * `workSpace` must be a table of minimum `1024` unsigned - */ -size_t FSE_countFast_wksp(unsigned *count, unsigned *maxSymbolValuePtr, const void *src, size_t srcSize, unsigned *workSpace); - -/*! FSE_count_simple - * Same as FSE_countFast(), but does not use any additional memory (not even on stack). - * This function is unsafe, and will segfault if any value within `src` is `> *maxSymbolValuePtr` (presuming it's also the size of `count`). -*/ -size_t FSE_count_simple(unsigned *count, unsigned *maxSymbolValuePtr, const void *src, size_t srcSize); - -unsigned FSE_optimalTableLog_internal(unsigned maxTableLog, size_t srcSize, unsigned maxSymbolValue, unsigned minus); -/**< same as FSE_optimalTableLog(), which used `minus==2` */ - -size_t FSE_buildCTable_raw(FSE_CTable *ct, unsigned nbBits); -/**< build a fake FSE_CTable, designed for a flat distribution, where each symbol uses nbBits */ - -size_t FSE_buildCTable_rle(FSE_CTable *ct, unsigned char symbolValue); -/**< build a fake FSE_CTable, designed to compress always the same symbolValue */ - -/* FSE_buildCTable_wksp() : - * Same as FSE_buildCTable(), but using an externally allocated scratch buffer (`workSpace`). - * `wkspSize` must be >= `(1<<tableLog)`. - */ -size_t FSE_buildCTable_wksp(FSE_CTable *ct, const short *normalizedCounter, unsigned maxSymbolValue, unsigned tableLog, void *workSpace, size_t wkspSize); - -size_t FSE_buildDTable_raw(FSE_DTable *dt, unsigned nbBits); -/**< build a fake FSE_DTable, designed to read a flat distribution where each symbol uses nbBits */ - -size_t FSE_buildDTable_rle(FSE_DTable *dt, unsigned char symbolValue); -/**< build a fake FSE_DTable, designed to always generate the same symbolValue */ - -size_t FSE_decompress_wksp(void *dst, size_t dstCapacity, const void *cSrc, size_t cSrcSize, unsigned maxLog, void *workspace, size_t workspaceSize); -/**< same as FSE_decompress(), using an externally allocated `workSpace` produced with `FSE_DTABLE_SIZE_U32(maxLog)` */ - -/* ***************************************** -* FSE symbol compression API -*******************************************/ -/*! - This API consists of small unitary functions, which highly benefit from being inlined. - Hence their body are included in next section. -*/ -typedef struct { - ptrdiff_t value; - const void *stateTable; - const void *symbolTT; - unsigned stateLog; -} FSE_CState_t; - -static void FSE_initCState(FSE_CState_t *CStatePtr, const FSE_CTable *ct); - -static void FSE_encodeSymbol(BIT_CStream_t *bitC, FSE_CState_t *CStatePtr, unsigned symbol); - -static void FSE_flushCState(BIT_CStream_t *bitC, const FSE_CState_t *CStatePtr); - -/**< -These functions are inner components of FSE_compress_usingCTable(). -They allow the creation of custom streams, mixing multiple tables and bit sources. - -A key property to keep in mind is that encoding and decoding are done **in reverse direction**. -So the first symbol you will encode is the last you will decode, like a LIFO stack. - -You will need a few variables to track your CStream. They are : - -FSE_CTable ct; // Provided by FSE_buildCTable() -BIT_CStream_t bitStream; // bitStream tracking structure -FSE_CState_t state; // State tracking structure (can have several) - - -The first thing to do is to init bitStream and state. - size_t errorCode = BIT_initCStream(&bitStream, dstBuffer, maxDstSize); - FSE_initCState(&state, ct); - -Note that BIT_initCStream() can produce an error code, so its result should be tested, using FSE_isError(); -You can then encode your input data, byte after byte. -FSE_encodeSymbol() outputs a maximum of 'tableLog' bits at a time. -Remember decoding will be done in reverse direction. - FSE_encodeByte(&bitStream, &state, symbol); - -At any time, you can also add any bit sequence. -Note : maximum allowed nbBits is 25, for compatibility with 32-bits decoders - BIT_addBits(&bitStream, bitField, nbBits); - -The above methods don't commit data to memory, they just store it into local register, for speed. -Local register size is 64-bits on 64-bits systems, 32-bits on 32-bits systems (size_t). -Writing data to memory is a manual operation, performed by the flushBits function. - BIT_flushBits(&bitStream); - -Your last FSE encoding operation shall be to flush your last state value(s). - FSE_flushState(&bitStream, &state); - -Finally, you must close the bitStream. -The function returns the size of CStream in bytes. -If data couldn't fit into dstBuffer, it will return a 0 ( == not compressible) -If there is an error, it returns an errorCode (which can be tested using FSE_isError()). - size_t size = BIT_closeCStream(&bitStream); -*/ - -/* ***************************************** -* FSE symbol decompression API -*******************************************/ -typedef struct { - size_t state; - const void *table; /* precise table may vary, depending on U16 */ -} FSE_DState_t; - -static void FSE_initDState(FSE_DState_t *DStatePtr, BIT_DStream_t *bitD, const FSE_DTable *dt); - -static unsigned char FSE_decodeSymbol(FSE_DState_t *DStatePtr, BIT_DStream_t *bitD); - -static unsigned FSE_endOfDState(const FSE_DState_t *DStatePtr); - -/**< -Let's now decompose FSE_decompress_usingDTable() into its unitary components. -You will decode FSE-encoded symbols from the bitStream, -and also any other bitFields you put in, **in reverse order**. - -You will need a few variables to track your bitStream. They are : - -BIT_DStream_t DStream; // Stream context -FSE_DState_t DState; // State context. Multiple ones are possible -FSE_DTable* DTablePtr; // Decoding table, provided by FSE_buildDTable() - -The first thing to do is to init the bitStream. - errorCode = BIT_initDStream(&DStream, srcBuffer, srcSize); - -You should then retrieve your initial state(s) -(in reverse flushing order if you have several ones) : - errorCode = FSE_initDState(&DState, &DStream, DTablePtr); - -You can then decode your data, symbol after symbol. -For information the maximum number of bits read by FSE_decodeSymbol() is 'tableLog'. -Keep in mind that symbols are decoded in reverse order, like a LIFO stack (last in, first out). - unsigned char symbol = FSE_decodeSymbol(&DState, &DStream); - -You can retrieve any bitfield you eventually stored into the bitStream (in reverse order) -Note : maximum allowed nbBits is 25, for 32-bits compatibility - size_t bitField = BIT_readBits(&DStream, nbBits); - -All above operations only read from local register (which size depends on size_t). -Refueling the register from memory is manually performed by the reload method. - endSignal = FSE_reloadDStream(&DStream); - -BIT_reloadDStream() result tells if there is still some more data to read from DStream. -BIT_DStream_unfinished : there is still some data left into the DStream. -BIT_DStream_endOfBuffer : Dstream reached end of buffer. Its container may no longer be completely filled. -BIT_DStream_completed : Dstream reached its exact end, corresponding in general to decompression completed. -BIT_DStream_tooFar : Dstream went too far. Decompression result is corrupted. - -When reaching end of buffer (BIT_DStream_endOfBuffer), progress slowly, notably if you decode multiple symbols per loop, -to properly detect the exact end of stream. -After each decoded symbol, check if DStream is fully consumed using this simple test : - BIT_reloadDStream(&DStream) >= BIT_DStream_completed - -When it's done, verify decompression is fully completed, by checking both DStream and the relevant states. -Checking if DStream has reached its end is performed by : - BIT_endOfDStream(&DStream); -Check also the states. There might be some symbols left there, if some high probability ones (>50%) are possible. - FSE_endOfDState(&DState); -*/ - -/* ***************************************** -* FSE unsafe API -*******************************************/ -static unsigned char FSE_decodeSymbolFast(FSE_DState_t *DStatePtr, BIT_DStream_t *bitD); -/* faster, but works only if nbBits is always >= 1 (otherwise, result will be corrupted) */ - -/* ***************************************** -* Implementation of inlined functions -*******************************************/ -typedef struct { - int deltaFindState; - U32 deltaNbBits; -} FSE_symbolCompressionTransform; /* total 8 bytes */ - -ZSTD_STATIC void FSE_initCState(FSE_CState_t *statePtr, const FSE_CTable *ct) -{ - const void *ptr = ct; - const U16 *u16ptr = (const U16 *)ptr; - const U32 tableLog = ZSTD_read16(ptr); - statePtr->value = (ptrdiff_t)1 << tableLog; - statePtr->stateTable = u16ptr + 2; - statePtr->symbolTT = ((const U32 *)ct + 1 + (tableLog ? (1 << (tableLog - 1)) : 1)); - statePtr->stateLog = tableLog; -} - -/*! FSE_initCState2() : -* Same as FSE_initCState(), but the first symbol to include (which will be the last to be read) -* uses the smallest state value possible, saving the cost of this symbol */ -ZSTD_STATIC void FSE_initCState2(FSE_CState_t *statePtr, const FSE_CTable *ct, U32 symbol) -{ - FSE_initCState(statePtr, ct); - { - const FSE_symbolCompressionTransform symbolTT = ((const FSE_symbolCompressionTransform *)(statePtr->symbolTT))[symbol]; - const U16 *stateTable = (const U16 *)(statePtr->stateTable); - U32 nbBitsOut = (U32)((symbolTT.deltaNbBits + (1 << 15)) >> 16); - statePtr->value = (nbBitsOut << 16) - symbolTT.deltaNbBits; - statePtr->value = stateTable[(statePtr->value >> nbBitsOut) + symbolTT.deltaFindState]; - } -} - -ZSTD_STATIC void FSE_encodeSymbol(BIT_CStream_t *bitC, FSE_CState_t *statePtr, U32 symbol) -{ - const FSE_symbolCompressionTransform symbolTT = ((const FSE_symbolCompressionTransform *)(statePtr->symbolTT))[symbol]; - const U16 *const stateTable = (const U16 *)(statePtr->stateTable); - U32 nbBitsOut = (U32)((statePtr->value + symbolTT.deltaNbBits) >> 16); - BIT_addBits(bitC, statePtr->value, nbBitsOut); - statePtr->value = stateTable[(statePtr->value >> nbBitsOut) + symbolTT.deltaFindState]; -} - -ZSTD_STATIC void FSE_flushCState(BIT_CStream_t *bitC, const FSE_CState_t *statePtr) -{ - BIT_addBits(bitC, statePtr->value, statePtr->stateLog); - BIT_flushBits(bitC); -} - -/* ====== Decompression ====== */ - -typedef struct { - U16 tableLog; - U16 fastMode; -} FSE_DTableHeader; /* sizeof U32 */ - -typedef struct { - unsigned short newState; - unsigned char symbol; - unsigned char nbBits; -} FSE_decode_t; /* size == U32 */ - -ZSTD_STATIC void FSE_initDState(FSE_DState_t *DStatePtr, BIT_DStream_t *bitD, const FSE_DTable *dt) -{ - const void *ptr = dt; - const FSE_DTableHeader *const DTableH = (const FSE_DTableHeader *)ptr; - DStatePtr->state = BIT_readBits(bitD, DTableH->tableLog); - BIT_reloadDStream(bitD); - DStatePtr->table = dt + 1; -} - -ZSTD_STATIC BYTE FSE_peekSymbol(const FSE_DState_t *DStatePtr) -{ - FSE_decode_t const DInfo = ((const FSE_decode_t *)(DStatePtr->table))[DStatePtr->state]; - return DInfo.symbol; -} - -ZSTD_STATIC void FSE_updateState(FSE_DState_t *DStatePtr, BIT_DStream_t *bitD) -{ - FSE_decode_t const DInfo = ((const FSE_decode_t *)(DStatePtr->table))[DStatePtr->state]; - U32 const nbBits = DInfo.nbBits; - size_t const lowBits = BIT_readBits(bitD, nbBits); - DStatePtr->state = DInfo.newState + lowBits; -} - -ZSTD_STATIC BYTE FSE_decodeSymbol(FSE_DState_t *DStatePtr, BIT_DStream_t *bitD) -{ - FSE_decode_t const DInfo = ((const FSE_decode_t *)(DStatePtr->table))[DStatePtr->state]; - U32 const nbBits = DInfo.nbBits; - BYTE const symbol = DInfo.symbol; - size_t const lowBits = BIT_readBits(bitD, nbBits); - - DStatePtr->state = DInfo.newState + lowBits; - return symbol; -} - -/*! FSE_decodeSymbolFast() : - unsafe, only works if no symbol has a probability > 50% */ -ZSTD_STATIC BYTE FSE_decodeSymbolFast(FSE_DState_t *DStatePtr, BIT_DStream_t *bitD) -{ - FSE_decode_t const DInfo = ((const FSE_decode_t *)(DStatePtr->table))[DStatePtr->state]; - U32 const nbBits = DInfo.nbBits; - BYTE const symbol = DInfo.symbol; - size_t const lowBits = BIT_readBitsFast(bitD, nbBits); - - DStatePtr->state = DInfo.newState + lowBits; - return symbol; -} - -ZSTD_STATIC unsigned FSE_endOfDState(const FSE_DState_t *DStatePtr) { return DStatePtr->state == 0; } - -/* ************************************************************** -* Tuning parameters -****************************************************************/ -/*!MEMORY_USAGE : -* Memory usage formula : N->2^N Bytes (examples : 10 -> 1KB; 12 -> 4KB ; 16 -> 64KB; 20 -> 1MB; etc.) -* Increasing memory usage improves compression ratio -* Reduced memory usage can improve speed, due to cache effect -* Recommended max value is 14, for 16KB, which nicely fits into Intel x86 L1 cache */ -#ifndef FSE_MAX_MEMORY_USAGE -#define FSE_MAX_MEMORY_USAGE 14 -#endif -#ifndef FSE_DEFAULT_MEMORY_USAGE -#define FSE_DEFAULT_MEMORY_USAGE 13 -#endif - -/*!FSE_MAX_SYMBOL_VALUE : -* Maximum symbol value authorized. -* Required for proper stack allocation */ -#ifndef FSE_MAX_SYMBOL_VALUE -#define FSE_MAX_SYMBOL_VALUE 255 -#endif - -/* ************************************************************** -* template functions type & suffix -****************************************************************/ -#define FSE_FUNCTION_TYPE BYTE -#define FSE_FUNCTION_EXTENSION -#define FSE_DECODE_TYPE FSE_decode_t - -/* *************************************************************** -* Constants -*****************************************************************/ -#define FSE_MAX_TABLELOG (FSE_MAX_MEMORY_USAGE - 2) -#define FSE_MAX_TABLESIZE (1U << FSE_MAX_TABLELOG) -#define FSE_MAXTABLESIZE_MASK (FSE_MAX_TABLESIZE - 1) -#define FSE_DEFAULT_TABLELOG (FSE_DEFAULT_MEMORY_USAGE - 2) -#define FSE_MIN_TABLELOG 5 - -#define FSE_TABLELOG_ABSOLUTE_MAX 15 -#if FSE_MAX_TABLELOG > FSE_TABLELOG_ABSOLUTE_MAX -#error "FSE_MAX_TABLELOG > FSE_TABLELOG_ABSOLUTE_MAX is not supported" -#endif - -#define FSE_TABLESTEP(tableSize) ((tableSize >> 1) + (tableSize >> 3) + 3) - -#endif /* FSE_H */ diff --git a/lib/zstd/fse_decompress.c b/lib/zstd/fse_decompress.c deleted file mode 100644 index 3b4522b427d..00000000000 --- a/lib/zstd/fse_decompress.c +++ /dev/null @@ -1,302 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0 or BSD-2-Clause) -/* - * FSE : Finite State Entropy decoder - * Copyright (C) 2013-2015, Yann Collet. - * - * You can contact the author at : - * - Source repository : https://github.com/Cyan4973/FiniteStateEntropy - */ - -/* ************************************************************** -* Compiler specifics -****************************************************************/ -#define FORCE_INLINE static __always_inline - -/* ************************************************************** -* Includes -****************************************************************/ -#include "bitstream.h" -#include "fse.h" -#include <linux/compiler.h> -#include <linux/kernel.h> -#include <linux/string.h> /* memcpy, memset */ - -/* ************************************************************** -* Error Management -****************************************************************/ -#define FSE_isError ERR_isError -#define FSE_STATIC_ASSERT(c) \ - { \ - enum { FSE_static_assert = 1 / (int)(!!(c)) }; \ - } /* use only *after* variable declarations */ - -/* check and forward error code */ -#define CHECK_F(f) \ - { \ - size_t const e = f; \ - if (FSE_isError(e)) \ - return e; \ - } - -/* ************************************************************** -* Templates -****************************************************************/ -/* - designed to be included - for type-specific functions (template emulation in C) - Objective is to write these functions only once, for improved maintenance -*/ - -/* safety checks */ -#ifndef FSE_FUNCTION_EXTENSION -#error "FSE_FUNCTION_EXTENSION must be defined" -#endif -#ifndef FSE_FUNCTION_TYPE -#error "FSE_FUNCTION_TYPE must be defined" -#endif - -/* Function names */ -#define FSE_CAT(X, Y) X##Y -#define FSE_FUNCTION_NAME(X, Y) FSE_CAT(X, Y) -#define FSE_TYPE_NAME(X, Y) FSE_CAT(X, Y) - -/* Function templates */ - -size_t FSE_buildDTable_wksp(FSE_DTable *dt, const short *normalizedCounter, unsigned maxSymbolValue, unsigned tableLog, void *workspace, size_t workspaceSize) -{ - void *const tdPtr = dt + 1; /* because *dt is unsigned, 32-bits aligned on 32-bits */ - FSE_DECODE_TYPE *const tableDecode = (FSE_DECODE_TYPE *)(tdPtr); - U16 *symbolNext = (U16 *)workspace; - - U32 const maxSV1 = maxSymbolValue + 1; - U32 const tableSize = 1 << tableLog; - U32 highThreshold = tableSize - 1; - - /* Sanity Checks */ - if (workspaceSize < sizeof(U16) * (FSE_MAX_SYMBOL_VALUE + 1)) - return ERROR(tableLog_tooLarge); - if (maxSymbolValue > FSE_MAX_SYMBOL_VALUE) - return ERROR(maxSymbolValue_tooLarge); - if (tableLog > FSE_MAX_TABLELOG) - return ERROR(tableLog_tooLarge); - - /* Init, lay down lowprob symbols */ - { - FSE_DTableHeader DTableH; - DTableH.tableLog = (U16)tableLog; - DTableH.fastMode = 1; - { - S16 const largeLimit = (S16)(1 << (tableLog - 1)); - U32 s; - for (s = 0; s < maxSV1; s++) { - if (normalizedCounter[s] == -1) { - tableDecode[highThreshold--].symbol = (FSE_FUNCTION_TYPE)s; - symbolNext[s] = 1; - } else { - if (normalizedCounter[s] >= largeLimit) - DTableH.fastMode = 0; - symbolNext[s] = normalizedCounter[s]; - } - } - } - memcpy(dt, &DTableH, sizeof(DTableH)); - } - - /* Spread symbols */ - { - U32 const tableMask = tableSize - 1; - U32 const step = FSE_TABLESTEP(tableSize); - U32 s, position = 0; - for (s = 0; s < maxSV1; s++) { - int i; - for (i = 0; i < normalizedCounter[s]; i++) { - tableDecode[position].symbol = (FSE_FUNCTION_TYPE)s; - position = (position + step) & tableMask; - while (position > highThreshold) - position = (position + step) & tableMask; /* lowprob area */ - } - } - if (position != 0) - return ERROR(GENERIC); /* position must reach all cells once, otherwise normalizedCounter is incorrect */ - } - - /* Build Decoding table */ - { - U32 u; - for (u = 0; u < tableSize; u++) { - FSE_FUNCTION_TYPE const symbol = (FSE_FUNCTION_TYPE)(tableDecode[u].symbol); - U16 nextState = symbolNext[symbol]++; - tableDecode[u].nbBits = (BYTE)(tableLog - BIT_highbit32((U32)nextState)); - tableDecode[u].newState = (U16)((nextState << tableDecode[u].nbBits) - tableSize); - } - } - - return 0; -} - -/*-******************************************************* -* Decompression (Byte symbols) -*********************************************************/ -size_t FSE_buildDTable_rle(FSE_DTable *dt, BYTE symbolValue) -{ - void *ptr = dt; - FSE_DTableHeader *const DTableH = (FSE_DTableHeader *)ptr; - void *dPtr = dt + 1; - FSE_decode_t *const cell = (FSE_decode_t *)dPtr; - - DTableH->tableLog = 0; - DTableH->fastMode = 0; - - cell->newState = 0; - cell->symbol = symbolValue; - cell->nbBits = 0; - - return 0; -} - -size_t FSE_buildDTable_raw(FSE_DTable *dt, unsigned nbBits) -{ - void *ptr = dt; - FSE_DTableHeader *const DTableH = (FSE_DTableHeader *)ptr; - void *dPtr = dt + 1; - FSE_decode_t *const dinfo = (FSE_decode_t *)dPtr; - const unsigned tableSize = 1 << nbBits; - const unsigned tableMask = tableSize - 1; - const unsigned maxSV1 = tableMask + 1; - unsigned s; - - /* Sanity checks */ - if (nbBits < 1) - return ERROR(GENERIC); /* min size */ - - /* Build Decoding Table */ - DTableH->tableLog = (U16)nbBits; - DTableH->fastMode = 1; - for (s = 0; s < maxSV1; s++) { - dinfo[s].newState = 0; - dinfo[s].symbol = (BYTE)s; - dinfo[s].nbBits = (BYTE)nbBits; - } - - return 0; -} - -FORCE_INLINE size_t FSE_decompress_usingDTable_generic(void *dst, size_t maxDstSize, const void *cSrc, size_t cSrcSize, const FSE_DTable *dt, - const unsigned fast) -{ - BYTE *const ostart = (BYTE *)dst; - BYTE *op = ostart; - BYTE *const omax = op + maxDstSize; - BYTE *const olimit = omax - 3; - - BIT_DStream_t bitD; - FSE_DState_t state1; - FSE_DState_t state2; - - /* Init */ - CHECK_F(BIT_initDStream(&bitD, cSrc, cSrcSize)); - - FSE_initDState(&state1, &bitD, dt); - FSE_initDState(&state2, &bitD, dt); - -#define FSE_GETSYMBOL(statePtr) fast ? FSE_decodeSymbolFast(statePtr, &bitD) : FSE_decodeSymbol(statePtr, &bitD) - - /* 4 symbols per loop */ - for (; (BIT_reloadDStream(&bitD) == BIT_DStream_unfinished) & (op < olimit); op += 4) { - op[0] = FSE_GETSYMBOL(&state1); - - if (FSE_MAX_TABLELOG * 2 + 7 > sizeof(bitD.bitContainer) * 8) /* This test must be static */ - BIT_reloadDStream(&bitD); - - op[1] = FSE_GETSYMBOL(&state2); - - if (FSE_MAX_TABLELOG * 4 + 7 > sizeof(bitD.bitContainer) * 8) /* This test must be static */ - { - if (BIT_reloadDStream(&bitD) > BIT_DStream_unfinished) { - op += 2; - break; - } - } - - op[2] = FSE_GETSYMBOL(&state1); - - if (FSE_MAX_TABLELOG * 2 + 7 > sizeof(bitD.bitContainer) * 8) /* This test must be static */ - BIT_reloadDStream(&bitD); - - op[3] = FSE_GETSYMBOL(&state2); - } - - /* tail */ - /* note : BIT_reloadDStream(&bitD) >= FSE_DStream_partiallyFilled; Ends at exactly BIT_DStream_completed */ - while (1) { - if (op > (omax - 2)) - return ERROR(dstSize_tooSmall); - *op++ = FSE_GETSYMBOL(&state1); - if (BIT_reloadDStream(&bitD) == BIT_DStream_overflow) { - *op++ = FSE_GETSYMBOL(&state2); - break; - } - - if (op > (omax - 2)) - return ERROR(dstSize_tooSmall); - *op++ = FSE_GETSYMBOL(&state2); - if (BIT_reloadDStream(&bitD) == BIT_DStream_overflow) { - *op++ = FSE_GETSYMBOL(&state1); - break; - } - } - - return op - ostart; -} - -size_t FSE_decompress_usingDTable(void *dst, size_t originalSize, const void *cSrc, size_t cSrcSize, const FSE_DTable *dt) -{ - const void *ptr = dt; - const FSE_DTableHeader *DTableH = (const FSE_DTableHeader *)ptr; - const U32 fastMode = DTableH->fastMode; - - /* select fast mode (static) */ - if (fastMode) - return FSE_decompress_usingDTable_generic(dst, originalSize, cSrc, cSrcSize, dt, 1); - return FSE_decompress_usingDTable_generic(dst, originalSize, cSrc, cSrcSize, dt, 0); -} - -size_t FSE_decompress_wksp(void *dst, size_t dstCapacity, const void *cSrc, size_t cSrcSize, unsigned maxLog, void *workspace, size_t workspaceSize) -{ - const BYTE *const istart = (const BYTE *)cSrc; - const BYTE *ip = istart; - unsigned tableLog; - unsigned maxSymbolValue = FSE_MAX_SYMBOL_VALUE; - size_t NCountLength; - - FSE_DTable *dt; - short *counting; - size_t spaceUsed32 = 0; - - FSE_STATIC_ASSERT(sizeof(FSE_DTable) == sizeof(U32)); - - dt = (FSE_DTable *)((U32 *)workspace + spaceUsed32); - spaceUsed32 += FSE_DTABLE_SIZE_U32(maxLog); - counting = (short *)((U32 *)workspace + spaceUsed32); - spaceUsed32 += ALIGN(sizeof(short) * (FSE_MAX_SYMBOL_VALUE + 1), sizeof(U32)) >> 2; - - if ((spaceUsed32 << 2) > workspaceSize) - return ERROR(tableLog_tooLarge); - workspace = (U32 *)workspace + spaceUsed32; - workspaceSize -= (spaceUsed32 << 2); - - /* normal FSE decoding mode */ - NCountLength = FSE_readNCount(counting, &maxSymbolValue, &tableLog, istart, cSrcSize); - if (FSE_isError(NCountLength)) - return NCountLength; - // if (NCountLength >= cSrcSize) return ERROR(srcSize_wrong); /* too small input size; supposed to be already checked in NCountLength, only remaining - // case : NCountLength==cSrcSize */ - if (tableLog > maxLog) - return ERROR(tableLog_tooLarge); - ip += NCountLength; - cSrcSize -= NCountLength; - - CHECK_F(FSE_buildDTable_wksp(dt, counting, maxSymbolValue, tableLog, workspace, workspaceSize)); - - return FSE_decompress_usingDTable(dst, dstCapacity, ip, cSrcSize, dt); /* always return, even if it is an error code */ -} diff --git a/lib/zstd/huf.h b/lib/zstd/huf.h deleted file mode 100644 index 01630f5669d..00000000000 --- a/lib/zstd/huf.h +++ /dev/null @@ -1,182 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 or BSD-2-Clause) */ -/* - * Huffman coder, part of New Generation Entropy library - * header file - * Copyright (C) 2013-2016, Yann Collet. - * - * You can contact the author at : - * - Source repository : https://github.com/Cyan4973/FiniteStateEntropy - */ -#ifndef HUF_H_298734234 -#define HUF_H_298734234 - -/* *** Dependencies *** */ -#include <linux/types.h> /* size_t */ - -/* *** Tool functions *** */ -#define HUF_BLOCKSIZE_MAX (128 * 1024) /**< maximum input size for a single block compressed with HUF_compress */ -size_t HUF_compressBound(size_t size); /**< maximum compressed size (worst case) */ - -/* Error Management */ -unsigned HUF_isError(size_t code); /**< tells if a return value is an error code */ - -/* *** Advanced function *** */ - -/** HUF_compress4X_wksp() : -* Same as HUF_compress2(), but uses externally allocated `workSpace`, which must be a table of >= 1024 unsigned */ -size_t HUF_compress4X_wksp(void *dst, size_t dstSize, const void *src, size_t srcSize, unsigned maxSymbolValue, unsigned tableLog, void *workSpace, - size_t wkspSize); /**< `workSpace` must be a table of at least HUF_COMPRESS_WORKSPACE_SIZE_U32 unsigned */ - -/* *** Dependencies *** */ -#include "mem.h" /* U32 */ - -/* *** Constants *** */ -#define HUF_TABLELOG_MAX 12 /* max configured tableLog (for static allocation); can be modified up to HUF_ABSOLUTEMAX_TABLELOG */ -#define HUF_TABLELOG_DEFAULT 11 /* tableLog by default, when not specified */ -#define HUF_SYMBOLVALUE_MAX 255 - -#define HUF_TABLELOG_ABSOLUTEMAX 15 /* absolute limit of HUF_MAX_TABLELOG. Beyond that value, code does not work */ -#if (HUF_TABLELOG_MAX > HUF_TABLELOG_ABSOLUTEMAX) -#error "HUF_TABLELOG_MAX is too large !" -#endif - -/* **************************************** -* Static allocation -******************************************/ -/* HUF buffer bounds */ -#define HUF_CTABLEBOUND 129 -#define HUF_BLOCKBOUND(size) (size + (size >> 8) + 8) /* only true if incompressible pre-filtered with fast heuristic */ -#define HUF_COMPRESSBOUND(size) (HUF_CTABLEBOUND + HUF_BLOCKBOUND(size)) /* Macro version, useful for static allocation */ - -/* static allocation of HUF's Compression Table */ -#define HUF_CREATE_STATIC_CTABLE(name, maxSymbolValue) \ - U32 name##hb[maxSymbolValue + 1]; \ - void *name##hv = &(name##hb); \ - HUF_CElt *name = (HUF_CElt *)(name##hv) /* no final ; */ - -/* static allocation of HUF's DTable */ -typedef U32 HUF_DTable; -#define HUF_DTABLE_SIZE(maxTableLog) (1 + (1 << (maxTableLog))) -#define HUF_CREATE_STATIC_DTABLEX2(DTable, maxTableLog) HUF_DTable DTable[HUF_DTABLE_SIZE((maxTableLog)-1)] = {((U32)((maxTableLog)-1) * 0x01000001)} -#define HUF_CREATE_STATIC_DTABLEX4(DTable, maxTableLog) HUF_DTable DTable[HUF_DTABLE_SIZE(maxTableLog)] = {((U32)(maxTableLog)*0x01000001)} - -/* The workspace must have alignment at least 4 and be at least this large */ -#define HUF_COMPRESS_WORKSPACE_SIZE (6 << 10) -#define HUF_COMPRESS_WORKSPACE_SIZE_U32 (HUF_COMPRESS_WORKSPACE_SIZE / sizeof(U32)) - -/* The workspace must have alignment at least 4 and be at least this large */ -#define HUF_DECOMPRESS_WORKSPACE_SIZE (3 << 10) -#define HUF_DECOMPRESS_WORKSPACE_SIZE_U32 (HUF_DECOMPRESS_WORKSPACE_SIZE / sizeof(U32)) - -/* **************************************** -* Advanced decompression functions -******************************************/ -size_t HUF_decompress4X_DCtx_wksp(HUF_DTable *dctx, void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize, void *workspace, size_t workspaceSize); /**< decodes RLE and uncompressed */ -size_t HUF_decompress4X_hufOnly_wksp(HUF_DTable *dctx, void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize, void *workspace, - size_t workspaceSize); /**< considers RLE and uncompressed as errors */ -size_t HUF_decompress4X2_DCtx_wksp(HUF_DTable *dctx, void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize, void *workspace, - size_t workspaceSize); /**< single-symbol decoder */ -size_t HUF_decompress4X4_DCtx_wksp(HUF_DTable *dctx, void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize, void *workspace, - size_t workspaceSize); /**< double-symbols decoder */ - -/* **************************************** -* HUF detailed API -******************************************/ -/*! -HUF_compress() does the following: -1. count symbol occurrence from source[] into table count[] using FSE_count() -2. (optional) refine tableLog using HUF_optimalTableLog() -3. build Huffman table from count using HUF_buildCTable() -4. save Huffman table to memory buffer using HUF_writeCTable_wksp() -5. encode the data stream using HUF_compress4X_usingCTable() - -The following API allows targeting specific sub-functions for advanced tasks. -For example, it's possible to compress several blocks using the same 'CTable', -or to save and regenerate 'CTable' using external methods. -*/ -/* FSE_count() : find it within "fse.h" */ -unsigned HUF_optimalTableLog(unsigned maxTableLog, size_t srcSize, unsigned maxSymbolValue); -typedef struct HUF_CElt_s HUF_CElt; /* incomplete type */ -size_t HUF_writeCTable_wksp(void *dst, size_t maxDstSize, const HUF_CElt *CTable, unsigned maxSymbolValue, unsigned huffLog, void *workspace, size_t workspaceSize); -size_t HUF_compress4X_usingCTable(void *dst, size_t dstSize, const void *src, size_t srcSize, const HUF_CElt *CTable); - -typedef enum { - HUF_repeat_none, /**< Cannot use the previous table */ - HUF_repeat_check, /**< Can use the previous table but it must be checked. Note : The previous table must have been constructed by HUF_compress{1, - 4}X_repeat */ - HUF_repeat_valid /**< Can use the previous table and it is asumed to be valid */ -} HUF_repeat; -/** HUF_compress4X_repeat() : -* Same as HUF_compress4X_wksp(), but considers using hufTable if *repeat != HUF_repeat_none. -* If it uses hufTable it does not modify hufTable or repeat. -* If it doesn't, it sets *repeat = HUF_repeat_none, and it sets hufTable to the table used. -* If preferRepeat then the old table will always be used if valid. */ -size_t HUF_compress4X_repeat(void *dst, size_t dstSize, const void *src, size_t srcSize, unsigned maxSymbolValue, unsigned tableLog, void *workSpace, - size_t wkspSize, HUF_CElt *hufTable, HUF_repeat *repeat, - int preferRepeat); /**< `workSpace` must be a table of at least HUF_COMPRESS_WORKSPACE_SIZE_U32 unsigned */ - -/** HUF_buildCTable_wksp() : - * Same as HUF_buildCTable(), but using externally allocated scratch buffer. - * `workSpace` must be aligned on 4-bytes boundaries, and be at least as large as a table of 1024 unsigned. - */ -size_t HUF_buildCTable_wksp(HUF_CElt *tree, const U32 *count, U32 maxSymbolValue, U32 maxNbBits, void *workSpace, size_t wkspSize); - -/*! HUF_readStats() : - Read compact Huffman tree, saved by HUF_writeCTable(). - `huffWeight` is destination buffer. - @return : size read from `src` , or an error Code . - Note : Needed by HUF_readCTable() and HUF_readDTableXn() . */ -size_t HUF_readStats_wksp(BYTE *huffWeight, size_t hwSize, U32 *rankStats, U32 *nbSymbolsPtr, U32 *tableLogPtr, const void *src, size_t srcSize, - void *workspace, size_t workspaceSize); - -/** HUF_readCTable() : -* Loading a CTable saved with HUF_writeCTable() */ -size_t HUF_readCTable_wksp(HUF_CElt *CTable, unsigned maxSymbolValue, const void *src, size_t srcSize, void *workspace, size_t workspaceSize); - -/* -HUF_decompress() does the following: -1. select the decompression algorithm (X2, X4) based on pre-computed heuristics -2. build Huffman table from save, using HUF_readDTableXn() -3. decode 1 or 4 segments in parallel using HUF_decompressSXn_usingDTable -*/ - -/** HUF_selectDecoder() : -* Tells which decoder is likely to decode faster, -* based on a set of pre-determined metrics. -* @return : 0==HUF_decompress4X2, 1==HUF_decompress4X4 . -* Assumption : 0 < cSrcSize < dstSize <= 128 KB */ -U32 HUF_selectDecoder(size_t dstSize, size_t cSrcSize); - -size_t HUF_readDTableX2_wksp(HUF_DTable *DTable, const void *src, size_t srcSize, void *workspace, size_t workspaceSize); -size_t HUF_readDTableX4_wksp(HUF_DTable *DTable, const void *src, size_t srcSize, void *workspace, size_t workspaceSize); - -size_t HUF_decompress4X_usingDTable(void *dst, size_t maxDstSize, const void *cSrc, size_t cSrcSize, const HUF_DTable *DTable); -size_t HUF_decompress4X2_usingDTable(void *dst, size_t maxDstSize, const void *cSrc, size_t cSrcSize, const HUF_DTable *DTable); -size_t HUF_decompress4X4_usingDTable(void *dst, size_t maxDstSize, const void *cSrc, size_t cSrcSize, const HUF_DTable *DTable); - -/* single stream variants */ - -size_t HUF_compress1X_wksp(void *dst, size_t dstSize, const void *src, size_t srcSize, unsigned maxSymbolValue, unsigned tableLog, void *workSpace, - size_t wkspSize); /**< `workSpace` must be a table of at least HUF_COMPRESS_WORKSPACE_SIZE_U32 unsigned */ -size_t HUF_compress1X_usingCTable(void *dst, size_t dstSize, const void *src, size_t srcSize, const HUF_CElt *CTable); -/** HUF_compress1X_repeat() : -* Same as HUF_compress1X_wksp(), but considers using hufTable if *repeat != HUF_repeat_none. -* If it uses hufTable it does not modify hufTable or repeat. -* If it doesn't, it sets *repeat = HUF_repeat_none, and it sets hufTable to the table used. -* If preferRepeat then the old table will always be used if valid. */ -size_t HUF_compress1X_repeat(void *dst, size_t dstSize, const void *src, size_t srcSize, unsigned maxSymbolValue, unsigned tableLog, void *workSpace, - size_t wkspSize, HUF_CElt *hufTable, HUF_repeat *repeat, - int preferRepeat); /**< `workSpace` must be a table of at least HUF_COMPRESS_WORKSPACE_SIZE_U32 unsigned */ - -size_t HUF_decompress1X_DCtx_wksp(HUF_DTable *dctx, void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize, void *workspace, size_t workspaceSize); -size_t HUF_decompress1X2_DCtx_wksp(HUF_DTable *dctx, void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize, void *workspace, - size_t workspaceSize); /**< single-symbol decoder */ -size_t HUF_decompress1X4_DCtx_wksp(HUF_DTable *dctx, void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize, void *workspace, - size_t workspaceSize); /**< double-symbols decoder */ - -size_t HUF_decompress1X_usingDTable(void *dst, size_t maxDstSize, const void *cSrc, size_t cSrcSize, - const HUF_DTable *DTable); /**< automatic selection of sing or double symbol decoder, based on DTable */ -size_t HUF_decompress1X2_usingDTable(void *dst, size_t maxDstSize, const void *cSrc, size_t cSrcSize, const HUF_DTable *DTable); -size_t HUF_decompress1X4_usingDTable(void *dst, size_t maxDstSize, const void *cSrc, size_t cSrcSize, const HUF_DTable *DTable); - -#endif /* HUF_H_298734234 */ diff --git a/lib/zstd/huf_decompress.c b/lib/zstd/huf_decompress.c deleted file mode 100644 index 97145b06088..00000000000 --- a/lib/zstd/huf_decompress.c +++ /dev/null @@ -1,930 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0 or BSD-2-Clause) -/* - * Huffman decoder, part of New Generation Entropy library - * Copyright (C) 2013-2016, Yann Collet. - * - * You can contact the author at : - * - Source repository : https://github.com/Cyan4973/FiniteStateEntropy - */ - -/* ************************************************************** -* Compiler specifics -****************************************************************/ -#define FORCE_INLINE static __always_inline - -/* ************************************************************** -* Dependencies -****************************************************************/ -#include "bitstream.h" /* BIT_* */ -#include "fse.h" /* header compression */ -#include "huf.h" -#include <linux/compiler.h> -#include <linux/kernel.h> -#include <linux/string.h> /* memcpy, memset */ - -/* ************************************************************** -* Error Management -****************************************************************/ -#define HUF_STATIC_ASSERT(c) \ - { \ - enum { HUF_static_assert = 1 / (int)(!!(c)) }; \ - } /* use only *after* variable declarations */ - -/*-***************************/ -/* generic DTableDesc */ -/*-***************************/ - -typedef struct { - BYTE maxTableLog; - BYTE tableType; - BYTE tableLog; - BYTE reserved; -} DTableDesc; - -static DTableDesc HUF_getDTableDesc(const HUF_DTable *table) -{ - DTableDesc dtd; - memcpy(&dtd, table, sizeof(dtd)); - return dtd; -} - -/*-***************************/ -/* single-symbol decoding */ -/*-***************************/ - -typedef struct { - BYTE byte; - BYTE nbBits; -} HUF_DEltX2; /* single-symbol decoding */ - -size_t HUF_readDTableX2_wksp(HUF_DTable *DTable, const void *src, size_t srcSize, void *workspace, size_t workspaceSize) -{ - U32 tableLog = 0; - U32 nbSymbols = 0; - size_t iSize; - void *const dtPtr = DTable + 1; - HUF_DEltX2 *const dt = (HUF_DEltX2 *)dtPtr; - - U32 *rankVal; - BYTE *huffWeight; - size_t spaceUsed32 = 0; - - rankVal = (U32 *)workspace + spaceUsed32; - spaceUsed32 += HUF_TABLELOG_ABSOLUTEMAX + 1; - huffWeight = (BYTE *)((U32 *)workspace + spaceUsed32); - spaceUsed32 += ALIGN(HUF_SYMBOLVALUE_MAX + 1, sizeof(U32)) >> 2; - - if ((spaceUsed32 << 2) > workspaceSize) - return ERROR(tableLog_tooLarge); - workspace = (U32 *)workspace + spaceUsed32; - workspaceSize -= (spaceUsed32 << 2); - - HUF_STATIC_ASSERT(sizeof(DTableDesc) == sizeof(HUF_DTable)); - /* memset(huffWeight, 0, sizeof(huffWeight)); */ /* is not necessary, even though some analyzer complain ... */ - - iSize = HUF_readStats_wksp(huffWeight, HUF_SYMBOLVALUE_MAX + 1, rankVal, &nbSymbols, &tableLog, src, srcSize, workspace, workspaceSize); - if (HUF_isError(iSize)) - return iSize; - - /* Table header */ - { - DTableDesc dtd = HUF_getDTableDesc(DTable); - if (tableLog > (U32)(dtd.maxTableLog + 1)) - return ERROR(tableLog_tooLarge); /* DTable too small, Huffman tree cannot fit in */ - dtd.tableType = 0; - dtd.tableLog = (BYTE)tableLog; - memcpy(DTable, &dtd, sizeof(dtd)); - } - - /* Calculate starting value for each rank */ - { - U32 n, nextRankStart = 0; - for (n = 1; n < tableLog + 1; n++) { - U32 const curr = nextRankStart; - nextRankStart += (rankVal[n] << (n - 1)); - rankVal[n] = curr; - } - } - - /* fill DTable */ - { - U32 n; - for (n = 0; n < nbSymbols; n++) { - U32 const w = huffWeight[n]; - U32 const length = (1 << w) >> 1; - U32 u; - HUF_DEltX2 D; - D.byte = (BYTE)n; - D.nbBits = (BYTE)(tableLog + 1 - w); - for (u = rankVal[w]; u < rankVal[w] + length; u++) - dt[u] = D; - rankVal[w] += length; - } - } - - return iSize; -} - -static BYTE HUF_decodeSymbolX2(BIT_DStream_t *Dstream, const HUF_DEltX2 *dt, const U32 dtLog) -{ - size_t const val = BIT_lookBitsFast(Dstream, dtLog); /* note : dtLog >= 1 */ - BYTE const c = dt[val].byte; - BIT_skipBits(Dstream, dt[val].nbBits); - return c; -} - -#define HUF_DECODE_SYMBOLX2_0(ptr, DStreamPtr) *ptr++ = HUF_decodeSymbolX2(DStreamPtr, dt, dtLog) - -#define HUF_DECODE_SYMBOLX2_1(ptr, DStreamPtr) \ - if (ZSTD_64bits() || (HUF_TABLELOG_MAX <= 12)) \ - HUF_DECODE_SYMBOLX2_0(ptr, DStreamPtr) - -#define HUF_DECODE_SYMBOLX2_2(ptr, DStreamPtr) \ - if (ZSTD_64bits()) \ - HUF_DECODE_SYMBOLX2_0(ptr, DStreamPtr) - -FORCE_INLINE size_t HUF_decodeStreamX2(BYTE *p, BIT_DStream_t *const bitDPtr, BYTE *const pEnd, const HUF_DEltX2 *const dt, const U32 dtLog) -{ - BYTE *const pStart = p; - - /* up to 4 symbols at a time */ - while ((BIT_reloadDStream(bitDPtr) == BIT_DStream_unfinished) && (p <= pEnd - 4)) { - HUF_DECODE_SYMBOLX2_2(p, bitDPtr); - HUF_DECODE_SYMBOLX2_1(p, bitDPtr); - HUF_DECODE_SYMBOLX2_2(p, bitDPtr); - HUF_DECODE_SYMBOLX2_0(p, bitDPtr); - } - - /* closer to the end */ - while ((BIT_reloadDStream(bitDPtr) == BIT_DStream_unfinished) && (p < pEnd)) - HUF_DECODE_SYMBOLX2_0(p, bitDPtr); - - /* no more data to retrieve from bitstream, hence no need to reload */ - while (p < pEnd) - HUF_DECODE_SYMBOLX2_0(p, bitDPtr); - - return pEnd - pStart; -} - -static size_t HUF_decompress1X2_usingDTable_internal(void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize, const HUF_DTable *DTable) -{ - BYTE *op = (BYTE *)dst; - BYTE *const oend = op + dstSize; - const void *dtPtr = DTable + 1; - const HUF_DEltX2 *const dt = (const HUF_DEltX2 *)dtPtr; - BIT_DStream_t bitD; - DTableDesc const dtd = HUF_getDTableDesc(DTable); - U32 const dtLog = dtd.tableLog; - - { - size_t const errorCode = BIT_initDStream(&bitD, cSrc, cSrcSize); - if (HUF_isError(errorCode)) - return errorCode; - } - - HUF_decodeStreamX2(op, &bitD, oend, dt, dtLog); - - /* check */ - if (!BIT_endOfDStream(&bitD)) - return ERROR(corruption_detected); - - return dstSize; -} - -size_t HUF_decompress1X2_usingDTable(void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize, const HUF_DTable *DTable) -{ - DTableDesc dtd = HUF_getDTableDesc(DTable); - if (dtd.tableType != 0) - return ERROR(GENERIC); - return HUF_decompress1X2_usingDTable_internal(dst, dstSize, cSrc, cSrcSize, DTable); -} - -size_t HUF_decompress1X2_DCtx_wksp(HUF_DTable *DCtx, void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize, void *workspace, size_t workspaceSize) -{ - const BYTE *ip = (const BYTE *)cSrc; - - size_t const hSize = HUF_readDTableX2_wksp(DCtx, cSrc, cSrcSize, workspace, workspaceSize); - if (HUF_isError(hSize)) - return hSize; - if (hSize >= cSrcSize) - return ERROR(srcSize_wrong); - ip += hSize; - cSrcSize -= hSize; - - return HUF_decompress1X2_usingDTable_internal(dst, dstSize, ip, cSrcSize, DCtx); -} - -static size_t HUF_decompress4X2_usingDTable_internal(void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize, const HUF_DTable *DTable) -{ - /* Check */ - if (cSrcSize < 10) - return ERROR(corruption_detected); /* strict minimum : jump table + 1 byte per stream */ - - { - const BYTE *const istart = (const BYTE *)cSrc; - BYTE *const ostart = (BYTE *)dst; - BYTE *const oend = ostart + dstSize; - const void *const dtPtr = DTable + 1; - const HUF_DEltX2 *const dt = (const HUF_DEltX2 *)dtPtr; - - /* Init */ - BIT_DStream_t bitD1; - BIT_DStream_t bitD2; - BIT_DStream_t bitD3; - BIT_DStream_t bitD4; - size_t const length1 = ZSTD_readLE16(istart); - size_t const length2 = ZSTD_readLE16(istart + 2); - size_t const length3 = ZSTD_readLE16(istart + 4); - size_t const length4 = cSrcSize - (length1 + length2 + length3 + 6); - const BYTE *const istart1 = istart + 6; /* jumpTable */ - const BYTE *const istart2 = istart1 + length1; - const BYTE *const istart3 = istart2 + length2; - const BYTE *const istart4 = istart3 + length3; - const size_t segmentSize = (dstSize + 3) / 4; - BYTE *const opStart2 = ostart + segmentSize; - BYTE *const opStart3 = opStart2 + segmentSize; - BYTE *const opStart4 = opStart3 + segmentSize; - BYTE *op1 = ostart; - BYTE *op2 = opStart2; - BYTE *op3 = opStart3; - BYTE *op4 = opStart4; - U32 endSignal; - DTableDesc const dtd = HUF_getDTableDesc(DTable); - U32 const dtLog = dtd.tableLog; - - if (length4 > cSrcSize) - return ERROR(corruption_detected); /* overflow */ - { - size_t const errorCode = BIT_initDStream(&bitD1, istart1, length1); - if (HUF_isError(errorCode)) - return errorCode; - } - { - size_t const errorCode = BIT_initDStream(&bitD2, istart2, length2); - if (HUF_isError(errorCode)) - return errorCode; - } - { - size_t const errorCode = BIT_initDStream(&bitD3, istart3, length3); - if (HUF_isError(errorCode)) - return errorCode; - } - { - size_t const errorCode = BIT_initDStream(&bitD4, istart4, length4); - if (HUF_isError(errorCode)) - return errorCode; - } - - /* 16-32 symbols per loop (4-8 symbols per stream) */ - endSignal = BIT_reloadDStream(&bitD1) | BIT_reloadDStream(&bitD2) | BIT_reloadDStream(&bitD3) | BIT_reloadDStream(&bitD4); - for (; (endSignal == BIT_DStream_unfinished) && (op4 < (oend - 7));) { - HUF_DECODE_SYMBOLX2_2(op1, &bitD1); - HUF_DECODE_SYMBOLX2_2(op2, &bitD2); - HUF_DECODE_SYMBOLX2_2(op3, &bitD3); - HUF_DECODE_SYMBOLX2_2(op4, &bitD4); - HUF_DECODE_SYMBOLX2_1(op1, &bitD1); - HUF_DECODE_SYMBOLX2_1(op2, &bitD2); - HUF_DECODE_SYMBOLX2_1(op3, &bitD3); - HUF_DECODE_SYMBOLX2_1(op4, &bitD4); - HUF_DECODE_SYMBOLX2_2(op1, &bitD1); - HUF_DECODE_SYMBOLX2_2(op2, &bitD2); - HUF_DECODE_SYMBOLX2_2(op3, &bitD3); - HUF_DECODE_SYMBOLX2_2(op4, &bitD4); - HUF_DECODE_SYMBOLX2_0(op1, &bitD1); - HUF_DECODE_SYMBOLX2_0(op2, &bitD2); - HUF_DECODE_SYMBOLX2_0(op3, &bitD3); - HUF_DECODE_SYMBOLX2_0(op4, &bitD4); - endSignal = BIT_reloadDStream(&bitD1) | BIT_reloadDStream(&bitD2) | BIT_reloadDStream(&bitD3) | BIT_reloadDStream(&bitD4); - } - - /* check corruption */ - if (op1 > opStart2) - return ERROR(corruption_detected); - if (op2 > opStart3) - return ERROR(corruption_detected); - if (op3 > opStart4) - return ERROR(corruption_detected); - /* note : op4 supposed already verified within main loop */ - - /* finish bitStreams one by one */ - HUF_decodeStreamX2(op1, &bitD1, opStart2, dt, dtLog); - HUF_decodeStreamX2(op2, &bitD2, opStart3, dt, dtLog); - HUF_decodeStreamX2(op3, &bitD3, opStart4, dt, dtLog); - HUF_decodeStreamX2(op4, &bitD4, oend, dt, dtLog); - - /* check */ - endSignal = BIT_endOfDStream(&bitD1) & BIT_endOfDStream(&bitD2) & BIT_endOfDStream(&bitD3) & BIT_endOfDStream(&bitD4); - if (!endSignal) - return ERROR(corruption_detected); - - /* decoded size */ - return dstSize; - } -} - -size_t HUF_decompress4X2_usingDTable(void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize, const HUF_DTable *DTable) -{ - DTableDesc dtd = HUF_getDTableDesc(DTable); - if (dtd.tableType != 0) - return ERROR(GENERIC); - return HUF_decompress4X2_usingDTable_internal(dst, dstSize, cSrc, cSrcSize, DTable); -} - -size_t HUF_decompress4X2_DCtx_wksp(HUF_DTable *dctx, void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize, void *workspace, size_t workspaceSize) -{ - const BYTE *ip = (const BYTE *)cSrc; - - size_t const hSize = HUF_readDTableX2_wksp(dctx, cSrc, cSrcSize, workspace, workspaceSize); - if (HUF_isError(hSize)) - return hSize; - if (hSize >= cSrcSize) - return ERROR(srcSize_wrong); - ip += hSize; - cSrcSize -= hSize; - - return HUF_decompress4X2_usingDTable_internal(dst, dstSize, ip, cSrcSize, dctx); -} - -/* *************************/ -/* double-symbols decoding */ -/* *************************/ -typedef struct { - U16 sequence; - BYTE nbBits; - BYTE length; -} HUF_DEltX4; /* double-symbols decoding */ - -typedef struct { - BYTE symbol; - BYTE weight; -} sortedSymbol_t; - -/* HUF_fillDTableX4Level2() : - * `rankValOrigin` must be a table of at least (HUF_TABLELOG_MAX + 1) U32 */ -static void HUF_fillDTableX4Level2(HUF_DEltX4 *DTable, U32 sizeLog, const U32 consumed, const U32 *rankValOrigin, const int minWeight, - const sortedSymbol_t *sortedSymbols, const U32 sortedListSize, U32 nbBitsBaseline, U16 baseSeq) -{ - HUF_DEltX4 DElt; - U32 rankVal[HUF_TABLELOG_MAX + 1]; - - /* get pre-calculated rankVal */ - memcpy(rankVal, rankValOrigin, sizeof(rankVal)); - - /* fill skipped values */ - if (minWeight > 1) { - U32 i, skipSize = rankVal[minWeight]; - ZSTD_writeLE16(&(DElt.sequence), baseSeq); - DElt.nbBits = (BYTE)(consumed); - DElt.length = 1; - for (i = 0; i < skipSize; i++) - DTable[i] = DElt; - } - - /* fill DTable */ - { - U32 s; - for (s = 0; s < sortedListSize; s++) { /* note : sortedSymbols already skipped */ - const U32 symbol = sortedSymbols[s].symbol; - const U32 weight = sortedSymbols[s].weight; - const U32 nbBits = nbBitsBaseline - weight; - const U32 length = 1 << (sizeLog - nbBits); - const U32 start = rankVal[weight]; - U32 i = start; - const U32 end = start + length; - - ZSTD_writeLE16(&(DElt.sequence), (U16)(baseSeq + (symbol << 8))); - DElt.nbBits = (BYTE)(nbBits + consumed); - DElt.length = 2; - do { - DTable[i++] = DElt; - } while (i < end); /* since length >= 1 */ - - rankVal[weight] += length; - } - } -} - -typedef U32 rankVal_t[HUF_TABLELOG_MAX][HUF_TABLELOG_MAX + 1]; -typedef U32 rankValCol_t[HUF_TABLELOG_MAX + 1]; - -static void HUF_fillDTableX4(HUF_DEltX4 *DTable, const U32 targetLog, const sortedSymbol_t *sortedList, const U32 sortedListSize, const U32 *rankStart, - rankVal_t rankValOrigin, const U32 maxWeight, const U32 nbBitsBaseline) -{ - U32 rankVal[HUF_TABLELOG_MAX + 1]; - const int scaleLog = nbBitsBaseline - targetLog; /* note : targetLog >= srcLog, hence scaleLog <= 1 */ - const U32 minBits = nbBitsBaseline - maxWeight; - U32 s; - - memcpy(rankVal, rankValOrigin, sizeof(rankVal)); - - /* fill DTable */ - for (s = 0; s < sortedListSize; s++) { - const U16 symbol = sortedList[s].symbol; - const U32 weight = sortedList[s].weight; - const U32 nbBits = nbBitsBaseline - weight; - const U32 start = rankVal[weight]; - const U32 length = 1 << (targetLog - nbBits); - - if (targetLog - nbBits >= minBits) { /* enough room for a second symbol */ - U32 sortedRank; - int minWeight = nbBits + scaleLog; - if (minWeight < 1) - minWeight = 1; - sortedRank = rankStart[minWeight]; - HUF_fillDTableX4Level2(DTable + start, targetLog - nbBits, nbBits, rankValOrigin[nbBits], minWeight, sortedList + sortedRank, - sortedListSize - sortedRank, nbBitsBaseline, symbol); - } else { - HUF_DEltX4 DElt; - ZSTD_writeLE16(&(DElt.sequence), symbol); - DElt.nbBits = (BYTE)(nbBits); - DElt.length = 1; - { - U32 const end = start + length; - U32 u; - for (u = start; u < end; u++) - DTable[u] = DElt; - } - } - rankVal[weight] += length; - } -} - -size_t HUF_readDTableX4_wksp(HUF_DTable *DTable, const void *src, size_t srcSize, void *workspace, size_t workspaceSize) -{ - U32 tableLog, maxW, sizeOfSort, nbSymbols; - DTableDesc dtd = HUF_getDTableDesc(DTable); - U32 const maxTableLog = dtd.maxTableLog; - size_t iSize; - void *dtPtr = DTable + 1; /* force compiler to avoid strict-aliasing */ - HUF_DEltX4 *const dt = (HUF_DEltX4 *)dtPtr; - U32 *rankStart; - - rankValCol_t *rankVal; - U32 *rankStats; - U32 *rankStart0; - sortedSymbol_t *sortedSymbol; - BYTE *weightList; - size_t spaceUsed32 = 0; - - HUF_STATIC_ASSERT((sizeof(rankValCol_t) & 3) == 0); - - rankVal = (rankValCol_t *)((U32 *)workspace + spaceUsed32); - spaceUsed32 += (sizeof(rankValCol_t) * HUF_TABLELOG_MAX) >> 2; - rankStats = (U32 *)workspace + spaceUsed32; - spaceUsed32 += HUF_TABLELOG_MAX + 1; - rankStart0 = (U32 *)workspace + spaceUsed32; - spaceUsed32 += HUF_TABLELOG_MAX + 2; - sortedSymbol = (sortedSymbol_t *)((U32 *)workspace + spaceUsed32); - spaceUsed32 += ALIGN(sizeof(sortedSymbol_t) * (HUF_SYMBOLVALUE_MAX + 1), sizeof(U32)) >> 2; - weightList = (BYTE *)((U32 *)workspace + spaceUsed32); - spaceUsed32 += ALIGN(HUF_SYMBOLVALUE_MAX + 1, sizeof(U32)) >> 2; - - if ((spaceUsed32 << 2) > workspaceSize) - return ERROR(tableLog_tooLarge); - workspace = (U32 *)workspace + spaceUsed32; - workspaceSize -= (spaceUsed32 << 2); - - rankStart = rankStart0 + 1; - memset(rankStats, 0, sizeof(U32) * (2 * HUF_TABLELOG_MAX + 2 + 1)); - - HUF_STATIC_ASSERT(sizeof(HUF_DEltX4) == sizeof(HUF_DTable)); /* if compiler fails here, assertion is wrong */ - if (maxTableLog > HUF_TABLELOG_MAX) - return ERROR(tableLog_tooLarge); - /* memset(weightList, 0, sizeof(weightList)); */ /* is not necessary, even though some analyzer complain ... */ - - iSize = HUF_readStats_wksp(weightList, HUF_SYMBOLVALUE_MAX + 1, rankStats, &nbSymbols, &tableLog, src, srcSize, workspace, workspaceSize); - if (HUF_isError(iSize)) - return iSize; - - /* check result */ - if (tableLog > maxTableLog) - return ERROR(tableLog_tooLarge); /* DTable can't fit code depth */ - - /* find maxWeight */ - for (maxW = tableLog; rankStats[maxW] == 0; maxW--) { - } /* necessarily finds a solution before 0 */ - - /* Get start index of each weight */ - { - U32 w, nextRankStart = 0; - for (w = 1; w < maxW + 1; w++) { - U32 curr = nextRankStart; - nextRankStart += rankStats[w]; - rankStart[w] = curr; - } - rankStart[0] = nextRankStart; /* put all 0w symbols at the end of sorted list*/ - sizeOfSort = nextRankStart; - } - - /* sort symbols by weight */ - { - U32 s; - for (s = 0; s < nbSymbols; s++) { - U32 const w = weightList[s]; - U32 const r = rankStart[w]++; - sortedSymbol[r].symbol = (BYTE)s; - sortedSymbol[r].weight = (BYTE)w; - } - rankStart[0] = 0; /* forget 0w symbols; this is beginning of weight(1) */ - } - - /* Build rankVal */ - { - U32 *const rankVal0 = rankVal[0]; - { - int const rescale = (maxTableLog - tableLog) - 1; /* tableLog <= maxTableLog */ - U32 nextRankVal = 0; - U32 w; - for (w = 1; w < maxW + 1; w++) { - U32 curr = nextRankVal; - nextRankVal += rankStats[w] << (w + rescale); - rankVal0[w] = curr; - } - } - { - U32 const minBits = tableLog + 1 - maxW; - U32 consumed; - for (consumed = minBits; consumed < maxTableLog - minBits + 1; consumed++) { - U32 *const rankValPtr = rankVal[consumed]; - U32 w; - for (w = 1; w < maxW + 1; w++) { - rankValPtr[w] = rankVal0[w] >> consumed; - } - } - } - } - - HUF_fillDTableX4(dt, maxTableLog, sortedSymbol, sizeOfSort, rankStart0, rankVal, maxW, tableLog + 1); - - dtd.tableLog = (BYTE)maxTableLog; - dtd.tableType = 1; - memcpy(DTable, &dtd, sizeof(dtd)); - return iSize; -} - -static U32 HUF_decodeSymbolX4(void *op, BIT_DStream_t *DStream, const HUF_DEltX4 *dt, const U32 dtLog) -{ - size_t const val = BIT_lookBitsFast(DStream, dtLog); /* note : dtLog >= 1 */ - memcpy(op, dt + val, 2); - BIT_skipBits(DStream, dt[val].nbBits); - return dt[val].length; -} - -static U32 HUF_decodeLastSymbolX4(void *op, BIT_DStream_t *DStream, const HUF_DEltX4 *dt, const U32 dtLog) -{ - size_t const val = BIT_lookBitsFast(DStream, dtLog); /* note : dtLog >= 1 */ - memcpy(op, dt + val, 1); - if (dt[val].length == 1) - BIT_skipBits(DStream, dt[val].nbBits); - else { - if (DStream->bitsConsumed < (sizeof(DStream->bitContainer) * 8)) { - BIT_skipBits(DStream, dt[val].nbBits); - if (DStream->bitsConsumed > (sizeof(DStream->bitContainer) * 8)) - /* ugly hack; works only because it's the last symbol. Note : can't easily extract nbBits from just this symbol */ - DStream->bitsConsumed = (sizeof(DStream->bitContainer) * 8); - } - } - return 1; -} - -#define HUF_DECODE_SYMBOLX4_0(ptr, DStreamPtr) ptr += HUF_decodeSymbolX4(ptr, DStreamPtr, dt, dtLog) - -#define HUF_DECODE_SYMBOLX4_1(ptr, DStreamPtr) \ - if (ZSTD_64bits() || (HUF_TABLELOG_MAX <= 12)) \ - ptr += HUF_decodeSymbolX4(ptr, DStreamPtr, dt, dtLog) - -#define HUF_DECODE_SYMBOLX4_2(ptr, DStreamPtr) \ - if (ZSTD_64bits()) \ - ptr += HUF_decodeSymbolX4(ptr, DStreamPtr, dt, dtLog) - -FORCE_INLINE size_t HUF_decodeStreamX4(BYTE *p, BIT_DStream_t *bitDPtr, BYTE *const pEnd, const HUF_DEltX4 *const dt, const U32 dtLog) -{ - BYTE *const pStart = p; - - /* up to 8 symbols at a time */ - while ((BIT_reloadDStream(bitDPtr) == BIT_DStream_unfinished) & (p < pEnd - (sizeof(bitDPtr->bitContainer) - 1))) { - HUF_DECODE_SYMBOLX4_2(p, bitDPtr); - HUF_DECODE_SYMBOLX4_1(p, bitDPtr); - HUF_DECODE_SYMBOLX4_2(p, bitDPtr); - HUF_DECODE_SYMBOLX4_0(p, bitDPtr); - } - - /* closer to end : up to 2 symbols at a time */ - while ((BIT_reloadDStream(bitDPtr) == BIT_DStream_unfinished) & (p <= pEnd - 2)) - HUF_DECODE_SYMBOLX4_0(p, bitDPtr); - - while (p <= pEnd - 2) - HUF_DECODE_SYMBOLX4_0(p, bitDPtr); /* no need to reload : reached the end of DStream */ - - if (p < pEnd) - p += HUF_decodeLastSymbolX4(p, bitDPtr, dt, dtLog); - - return p - pStart; -} - -static size_t HUF_decompress1X4_usingDTable_internal(void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize, const HUF_DTable *DTable) -{ - BIT_DStream_t bitD; - - /* Init */ - { - size_t const errorCode = BIT_initDStream(&bitD, cSrc, cSrcSize); - if (HUF_isError(errorCode)) - return errorCode; - } - - /* decode */ - { - BYTE *const ostart = (BYTE *)dst; - BYTE *const oend = ostart + dstSize; - const void *const dtPtr = DTable + 1; /* force compiler to not use strict-aliasing */ - const HUF_DEltX4 *const dt = (const HUF_DEltX4 *)dtPtr; - DTableDesc const dtd = HUF_getDTableDesc(DTable); - HUF_decodeStreamX4(ostart, &bitD, oend, dt, dtd.tableLog); - } - - /* check */ - if (!BIT_endOfDStream(&bitD)) - return ERROR(corruption_detected); - - /* decoded size */ - return dstSize; -} - -size_t HUF_decompress1X4_usingDTable(void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize, const HUF_DTable *DTable) -{ - DTableDesc dtd = HUF_getDTableDesc(DTable); - if (dtd.tableType != 1) - return ERROR(GENERIC); - return HUF_decompress1X4_usingDTable_internal(dst, dstSize, cSrc, cSrcSize, DTable); -} - -size_t HUF_decompress1X4_DCtx_wksp(HUF_DTable *DCtx, void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize, void *workspace, size_t workspaceSize) -{ - const BYTE *ip = (const BYTE *)cSrc; - - size_t const hSize = HUF_readDTableX4_wksp(DCtx, cSrc, cSrcSize, workspace, workspaceSize); - if (HUF_isError(hSize)) - return hSize; - if (hSize >= cSrcSize) - return ERROR(srcSize_wrong); - ip += hSize; - cSrcSize -= hSize; - - return HUF_decompress1X4_usingDTable_internal(dst, dstSize, ip, cSrcSize, DCtx); -} - -static size_t HUF_decompress4X4_usingDTable_internal(void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize, const HUF_DTable *DTable) -{ - if (cSrcSize < 10) - return ERROR(corruption_detected); /* strict minimum : jump table + 1 byte per stream */ - - { - const BYTE *const istart = (const BYTE *)cSrc; - BYTE *const ostart = (BYTE *)dst; - BYTE *const oend = ostart + dstSize; - const void *const dtPtr = DTable + 1; - const HUF_DEltX4 *const dt = (const HUF_DEltX4 *)dtPtr; - - /* Init */ - BIT_DStream_t bitD1; - BIT_DStream_t bitD2; - BIT_DStream_t bitD3; - BIT_DStream_t bitD4; - size_t const length1 = ZSTD_readLE16(istart); - size_t const length2 = ZSTD_readLE16(istart + 2); - size_t const length3 = ZSTD_readLE16(istart + 4); - size_t const length4 = cSrcSize - (length1 + length2 + length3 + 6); - const BYTE *const istart1 = istart + 6; /* jumpTable */ - const BYTE *const istart2 = istart1 + length1; - const BYTE *const istart3 = istart2 + length2; - const BYTE *const istart4 = istart3 + length3; - size_t const segmentSize = (dstSize + 3) / 4; - BYTE *const opStart2 = ostart + segmentSize; - BYTE *const opStart3 = opStart2 + segmentSize; - BYTE *const opStart4 = opStart3 + segmentSize; - BYTE *op1 = ostart; - BYTE *op2 = opStart2; - BYTE *op3 = opStart3; - BYTE *op4 = opStart4; - U32 endSignal; - DTableDesc const dtd = HUF_getDTableDesc(DTable); - U32 const dtLog = dtd.tableLog; - - if (length4 > cSrcSize) - return ERROR(corruption_detected); /* overflow */ - { - size_t const errorCode = BIT_initDStream(&bitD1, istart1, length1); - if (HUF_isError(errorCode)) - return errorCode; - } - { - size_t const errorCode = BIT_initDStream(&bitD2, istart2, length2); - if (HUF_isError(errorCode)) - return errorCode; - } - { - size_t const errorCode = BIT_initDStream(&bitD3, istart3, length3); - if (HUF_isError(errorCode)) - return errorCode; - } - { - size_t const errorCode = BIT_initDStream(&bitD4, istart4, length4); - if (HUF_isError(errorCode)) - return errorCode; - } - - /* 16-32 symbols per loop (4-8 symbols per stream) */ - endSignal = BIT_reloadDStream(&bitD1) | BIT_reloadDStream(&bitD2) | BIT_reloadDStream(&bitD3) | BIT_reloadDStream(&bitD4); - for (; (endSignal == BIT_DStream_unfinished) & (op4 < (oend - (sizeof(bitD4.bitContainer) - 1)));) { - HUF_DECODE_SYMBOLX4_2(op1, &bitD1); - HUF_DECODE_SYMBOLX4_2(op2, &bitD2); - HUF_DECODE_SYMBOLX4_2(op3, &bitD3); - HUF_DECODE_SYMBOLX4_2(op4, &bitD4); - HUF_DECODE_SYMBOLX4_1(op1, &bitD1); - HUF_DECODE_SYMBOLX4_1(op2, &bitD2); - HUF_DECODE_SYMBOLX4_1(op3, &bitD3); - HUF_DECODE_SYMBOLX4_1(op4, &bitD4); - HUF_DECODE_SYMBOLX4_2(op1, &bitD1); - HUF_DECODE_SYMBOLX4_2(op2, &bitD2); - HUF_DECODE_SYMBOLX4_2(op3, &bitD3); - HUF_DECODE_SYMBOLX4_2(op4, &bitD4); - HUF_DECODE_SYMBOLX4_0(op1, &bitD1); - HUF_DECODE_SYMBOLX4_0(op2, &bitD2); - HUF_DECODE_SYMBOLX4_0(op3, &bitD3); - HUF_DECODE_SYMBOLX4_0(op4, &bitD4); - - endSignal = BIT_reloadDStream(&bitD1) | BIT_reloadDStream(&bitD2) | BIT_reloadDStream(&bitD3) | BIT_reloadDStream(&bitD4); - } - - /* check corruption */ - if (op1 > opStart2) - return ERROR(corruption_detected); - if (op2 > opStart3) - return ERROR(corruption_detected); - if (op3 > opStart4) - return ERROR(corruption_detected); - /* note : op4 already verified within main loop */ - - /* finish bitStreams one by one */ - HUF_decodeStreamX4(op1, &bitD1, opStart2, dt, dtLog); - HUF_decodeStreamX4(op2, &bitD2, opStart3, dt, dtLog); - HUF_decodeStreamX4(op3, &bitD3, opStart4, dt, dtLog); - HUF_decodeStreamX4(op4, &bitD4, oend, dt, dtLog); - - /* check */ - { - U32 const endCheck = BIT_endOfDStream(&bitD1) & BIT_endOfDStream(&bitD2) & BIT_endOfDStream(&bitD3) & BIT_endOfDStream(&bitD4); - if (!endCheck) - return ERROR(corruption_detected); - } - - /* decoded size */ - return dstSize; - } -} - -size_t HUF_decompress4X4_usingDTable(void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize, const HUF_DTable *DTable) -{ - DTableDesc dtd = HUF_getDTableDesc(DTable); - if (dtd.tableType != 1) - return ERROR(GENERIC); - return HUF_decompress4X4_usingDTable_internal(dst, dstSize, cSrc, cSrcSize, DTable); -} - -size_t HUF_decompress4X4_DCtx_wksp(HUF_DTable *dctx, void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize, void *workspace, size_t workspaceSize) -{ - const BYTE *ip = (const BYTE *)cSrc; - - size_t hSize = HUF_readDTableX4_wksp(dctx, cSrc, cSrcSize, workspace, workspaceSize); - if (HUF_isError(hSize)) - return hSize; - if (hSize >= cSrcSize) - return ERROR(srcSize_wrong); - ip += hSize; - cSrcSize -= hSize; - - return HUF_decompress4X4_usingDTable_internal(dst, dstSize, ip, cSrcSize, dctx); -} - -/* ********************************/ -/* Generic decompression selector */ -/* ********************************/ - -size_t HUF_decompress1X_usingDTable(void *dst, size_t maxDstSize, const void *cSrc, size_t cSrcSize, const HUF_DTable *DTable) -{ - DTableDesc const dtd = HUF_getDTableDesc(DTable); - return dtd.tableType ? HUF_decompress1X4_usingDTable_internal(dst, maxDstSize, cSrc, cSrcSize, DTable) - : HUF_decompress1X2_usingDTable_internal(dst, maxDstSize, cSrc, cSrcSize, DTable); -} - -size_t HUF_decompress4X_usingDTable(void *dst, size_t maxDstSize, const void *cSrc, size_t cSrcSize, const HUF_DTable *DTable) -{ - DTableDesc const dtd = HUF_getDTableDesc(DTable); - return dtd.tableType ? HUF_decompress4X4_usingDTable_internal(dst, maxDstSize, cSrc, cSrcSize, DTable) - : HUF_decompress4X2_usingDTable_internal(dst, maxDstSize, cSrc, cSrcSize, DTable); -} - -typedef struct { - U32 tableTime; - U32 decode256Time; -} algo_time_t; -static const algo_time_t algoTime[16 /* Quantization */][3 /* single, double, quad */] = { - /* single, double, quad */ - {{0, 0}, {1, 1}, {2, 2}}, /* Q==0 : impossible */ - {{0, 0}, {1, 1}, {2, 2}}, /* Q==1 : impossible */ - {{38, 130}, {1313, 74}, {2151, 38}}, /* Q == 2 : 12-18% */ - {{448, 128}, {1353, 74}, {2238, 41}}, /* Q == 3 : 18-25% */ - {{556, 128}, {1353, 74}, {2238, 47}}, /* Q == 4 : 25-32% */ - {{714, 128}, {1418, 74}, {2436, 53}}, /* Q == 5 : 32-38% */ - {{883, 128}, {1437, 74}, {2464, 61}}, /* Q == 6 : 38-44% */ - {{897, 128}, {1515, 75}, {2622, 68}}, /* Q == 7 : 44-50% */ - {{926, 128}, {1613, 75}, {2730, 75}}, /* Q == 8 : 50-56% */ - {{947, 128}, {1729, 77}, {3359, 77}}, /* Q == 9 : 56-62% */ - {{1107, 128}, {2083, 81}, {4006, 84}}, /* Q ==10 : 62-69% */ - {{1177, 128}, {2379, 87}, {4785, 88}}, /* Q ==11 : 69-75% */ - {{1242, 128}, {2415, 93}, {5155, 84}}, /* Q ==12 : 75-81% */ - {{1349, 128}, {2644, 106}, {5260, 106}}, /* Q ==13 : 81-87% */ - {{1455, 128}, {2422, 124}, {4174, 124}}, /* Q ==14 : 87-93% */ - {{722, 128}, {1891, 145}, {1936, 146}}, /* Q ==15 : 93-99% */ -}; - -/** HUF_selectDecoder() : -* Tells which decoder is likely to decode faster, -* based on a set of pre-determined metrics. -* @return : 0==HUF_decompress4X2, 1==HUF_decompress4X4 . -* Assumption : 0 < cSrcSize < dstSize <= 128 KB */ -U32 HUF_selectDecoder(size_t dstSize, size_t cSrcSize) -{ - /* decoder timing evaluation */ - U32 const Q = (U32)(cSrcSize * 16 / dstSize); /* Q < 16 since dstSize > cSrcSize */ - U32 const D256 = (U32)(dstSize >> 8); - U32 const DTime0 = algoTime[Q][0].tableTime + (algoTime[Q][0].decode256Time * D256); - U32 DTime1 = algoTime[Q][1].tableTime + (algoTime[Q][1].decode256Time * D256); - DTime1 += DTime1 >> 3; /* advantage to algorithm using less memory, for cache eviction */ - - return DTime1 < DTime0; -} - -typedef size_t (*decompressionAlgo)(void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize); - -size_t HUF_decompress4X_DCtx_wksp(HUF_DTable *dctx, void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize, void *workspace, size_t workspaceSize) -{ - /* validation checks */ - if (dstSize == 0) - return ERROR(dstSize_tooSmall); - if (cSrcSize > dstSize) - return ERROR(corruption_detected); /* invalid */ - if (cSrcSize == dstSize) { - memcpy(dst, cSrc, dstSize); - return dstSize; - } /* not compressed */ - if (cSrcSize == 1) { - memset(dst, *(const BYTE *)cSrc, dstSize); - return dstSize; - } /* RLE */ - - { - U32 const algoNb = HUF_selectDecoder(dstSize, cSrcSize); - return algoNb ? HUF_decompress4X4_DCtx_wksp(dctx, dst, dstSize, cSrc, cSrcSize, workspace, workspaceSize) - : HUF_decompress4X2_DCtx_wksp(dctx, dst, dstSize, cSrc, cSrcSize, workspace, workspaceSize); - } -} - -size_t HUF_decompress4X_hufOnly_wksp(HUF_DTable *dctx, void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize, void *workspace, size_t workspaceSize) -{ - /* validation checks */ - if (dstSize == 0) - return ERROR(dstSize_tooSmall); - if ((cSrcSize >= dstSize) || (cSrcSize <= 1)) - return ERROR(corruption_detected); /* invalid */ - - { - U32 const algoNb = HUF_selectDecoder(dstSize, cSrcSize); - return algoNb ? HUF_decompress4X4_DCtx_wksp(dctx, dst, dstSize, cSrc, cSrcSize, workspace, workspaceSize) - : HUF_decompress4X2_DCtx_wksp(dctx, dst, dstSize, cSrc, cSrcSize, workspace, workspaceSize); - } -} - -size_t HUF_decompress1X_DCtx_wksp(HUF_DTable *dctx, void *dst, size_t dstSize, const void *cSrc, size_t cSrcSize, void *workspace, size_t workspaceSize) -{ - /* validation checks */ - if (dstSize == 0) - return ERROR(dstSize_tooSmall); - if (cSrcSize > dstSize) - return ERROR(corruption_detected); /* invalid */ - if (cSrcSize == dstSize) { - memcpy(dst, cSrc, dstSize); - return dstSize; - } /* not compressed */ - if (cSrcSize == 1) { - memset(dst, *(const BYTE *)cSrc, dstSize); - return dstSize; - } /* RLE */ - - { - U32 const algoNb = HUF_selectDecoder(dstSize, cSrcSize); - return algoNb ? HUF_decompress1X4_DCtx_wksp(dctx, dst, dstSize, cSrc, cSrcSize, workspace, workspaceSize) - : HUF_decompress1X2_DCtx_wksp(dctx, dst, dstSize, cSrc, cSrcSize, workspace, workspaceSize); - } -} diff --git a/lib/zstd/mem.h b/lib/zstd/mem.h deleted file mode 100644 index 7225b39742c..00000000000 --- a/lib/zstd/mem.h +++ /dev/null @@ -1,142 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 or BSD-3-Clause-Clear) */ -/** - * Copyright (c) 2016-present, Yann Collet, Facebook, Inc. - * All rights reserved. - */ - -#ifndef MEM_H_MODULE -#define MEM_H_MODULE - -/*-**************************************** -* Dependencies -******************************************/ -#include <asm/unaligned.h> -#include <compiler.h> -#include <linux/string.h> /* memcpy */ -#include <linux/types.h> /* size_t, ptrdiff_t */ - -/*-**************************************** -* Compiler specifics -******************************************/ -#define ZSTD_STATIC static __inline __attribute__((unused)) - -/*-************************************************************** -* Basic Types -*****************************************************************/ -typedef uint8_t BYTE; -typedef uint16_t U16; -typedef int16_t S16; -typedef uint32_t U32; -typedef int32_t S32; -typedef uint64_t U64; -typedef int64_t S64; -typedef ptrdiff_t iPtrDiff; -typedef uintptr_t uPtrDiff; - -/*-************************************************************** -* Memory I/O -*****************************************************************/ -ZSTD_STATIC unsigned ZSTD_32bits(void) { return sizeof(size_t) == 4; } -ZSTD_STATIC unsigned ZSTD_64bits(void) { return sizeof(size_t) == 8; } - -#if defined(__LITTLE_ENDIAN) -#define ZSTD_LITTLE_ENDIAN 1 -#else -#define ZSTD_LITTLE_ENDIAN 0 -#endif - -ZSTD_STATIC unsigned ZSTD_isLittleEndian(void) { return ZSTD_LITTLE_ENDIAN; } - -ZSTD_STATIC U16 ZSTD_read16(const void *memPtr) { return get_unaligned((const U16 *)memPtr); } - -ZSTD_STATIC U32 ZSTD_read32(const void *memPtr) { return get_unaligned((const U32 *)memPtr); } - -ZSTD_STATIC U64 ZSTD_read64(const void *memPtr) { return get_unaligned((const U64 *)memPtr); } - -ZSTD_STATIC size_t ZSTD_readST(const void *memPtr) { return get_unaligned((const size_t *)memPtr); } - -ZSTD_STATIC void ZSTD_write16(void *memPtr, U16 value) { put_unaligned(value, (U16 *)memPtr); } - -ZSTD_STATIC void ZSTD_write32(void *memPtr, U32 value) { put_unaligned(value, (U32 *)memPtr); } - -ZSTD_STATIC void ZSTD_write64(void *memPtr, U64 value) { put_unaligned(value, (U64 *)memPtr); } - -/*=== Little endian r/w ===*/ - -ZSTD_STATIC U16 ZSTD_readLE16(const void *memPtr) { return get_unaligned_le16(memPtr); } - -ZSTD_STATIC void ZSTD_writeLE16(void *memPtr, U16 val) { put_unaligned_le16(val, memPtr); } - -ZSTD_STATIC U32 ZSTD_readLE24(const void *memPtr) { return ZSTD_readLE16(memPtr) + (((const BYTE *)memPtr)[2] << 16); } - -ZSTD_STATIC void ZSTD_writeLE24(void *memPtr, U32 val) -{ - ZSTD_writeLE16(memPtr, (U16)val); - ((BYTE *)memPtr)[2] = (BYTE)(val >> 16); -} - -ZSTD_STATIC U32 ZSTD_readLE32(const void *memPtr) { return get_unaligned_le32(memPtr); } - -ZSTD_STATIC void ZSTD_writeLE32(void *memPtr, U32 val32) { put_unaligned_le32(val32, memPtr); } - -ZSTD_STATIC U64 ZSTD_readLE64(const void *memPtr) { return get_unaligned_le64(memPtr); } - -ZSTD_STATIC void ZSTD_writeLE64(void *memPtr, U64 val64) { put_unaligned_le64(val64, memPtr); } - -ZSTD_STATIC size_t ZSTD_readLEST(const void *memPtr) -{ - if (ZSTD_32bits()) - return (size_t)ZSTD_readLE32(memPtr); - else - return (size_t)ZSTD_readLE64(memPtr); -} - -ZSTD_STATIC void ZSTD_writeLEST(void *memPtr, size_t val) -{ - if (ZSTD_32bits()) - ZSTD_writeLE32(memPtr, (U32)val); - else - ZSTD_writeLE64(memPtr, (U64)val); -} - -/*=== Big endian r/w ===*/ - -ZSTD_STATIC U32 ZSTD_readBE32(const void *memPtr) { return get_unaligned_be32(memPtr); } - -ZSTD_STATIC void ZSTD_writeBE32(void *memPtr, U32 val32) { put_unaligned_be32(val32, memPtr); } - -ZSTD_STATIC U64 ZSTD_readBE64(const void *memPtr) { return get_unaligned_be64(memPtr); } - -ZSTD_STATIC void ZSTD_writeBE64(void *memPtr, U64 val64) { put_unaligned_be64(val64, memPtr); } - -ZSTD_STATIC size_t ZSTD_readBEST(const void *memPtr) -{ - if (ZSTD_32bits()) - return (size_t)ZSTD_readBE32(memPtr); - else - return (size_t)ZSTD_readBE64(memPtr); -} - -ZSTD_STATIC void ZSTD_writeBEST(void *memPtr, size_t val) -{ - if (ZSTD_32bits()) - ZSTD_writeBE32(memPtr, (U32)val); - else - ZSTD_writeBE64(memPtr, (U64)val); -} - -/* function safe only for comparisons */ -ZSTD_STATIC U32 ZSTD_readMINMATCH(const void *memPtr, U32 length) -{ - switch (length) { - default: - case 4: return ZSTD_read32(memPtr); - case 3: - if (ZSTD_isLittleEndian()) - return ZSTD_read32(memPtr) << 8; - else - return ZSTD_read32(memPtr) >> 8; - } -} - -#endif /* MEM_H_MODULE */ diff --git a/lib/zstd/zstd.c b/lib/zstd/zstd.c index bf9cd19cfa3..18f841343d1 100644 --- a/lib/zstd/zstd.c +++ b/lib/zstd/zstd.c @@ -13,14 +13,12 @@
int zstd_decompress(struct abuf *in, struct abuf *out) { - ZSTD_DStream *dstream; - ZSTD_inBuffer in_buf; - ZSTD_outBuffer out_buf; + zstd_dctx *ctx; + size_t wsize, len; void *workspace; - size_t wsize; int ret;
- wsize = ZSTD_DStreamWorkspaceBound(abuf_size(in)); + wsize = zstd_dctx_workspace_bound(); workspace = malloc(wsize); if (!workspace) { debug("%s: cannot allocate workspace of size %zu\n", __func__, @@ -28,36 +26,34 @@ int zstd_decompress(struct abuf *in, struct abuf *out) return -ENOMEM; }
- dstream = ZSTD_initDStream(abuf_size(in), workspace, wsize); - if (!dstream) { - log_err("%s: ZSTD_initDStream failed\n", __func__); + ctx = zstd_init_dctx(workspace, wsize); + if (!ctx) { + log_err("%s: zstd_init_dctx() failed\n", __func__); ret = -EPERM; goto do_free; }
- in_buf.src = abuf_data(in); - in_buf.pos = 0; - in_buf.size = abuf_size(in); - - out_buf.dst = abuf_data(out); - out_buf.pos = 0; - out_buf.size = abuf_size(out); - - while (1) { - size_t res; - - res = ZSTD_decompressStream(dstream, &out_buf, &in_buf); - if (ZSTD_isError(res)) { - ret = ZSTD_getErrorCode(res); - log_err("ZSTD_decompressStream error %d\n", ret); - goto do_free; - } + /* + * Find out how large the frame actually is, there may be junk at + * the end of the frame that zstd_decompress_dctx() can't handle. + */ + len = zstd_find_frame_compressed_size(abuf_data(in), abuf_size(in)); + if (zstd_is_error(len)) { + log_err("%s: failed to detect compressed size: %d\n", __func__, + zstd_get_error_code(len)); + goto do_free; + }
- if (in_buf.pos >= abuf_size(in) || !res) - break; + len = zstd_decompress_dctx(ctx, abuf_data(out), abuf_size(out), + abuf_data(in), len); + if (zstd_is_error(len)) { + log_err("%s: failed to decompress: %d\n", __func__, + zstd_get_error_code(len)); + ret = -EINVAL; + goto do_free; }
- ret = out_buf.pos; + ret = len; do_free: free(workspace); return ret; diff --git a/lib/zstd/zstd_common.c b/lib/zstd/zstd_common.c deleted file mode 100644 index 6b2c79eeb65..00000000000 --- a/lib/zstd/zstd_common.c +++ /dev/null @@ -1,66 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0 or BSD-3-Clause-Clear) -/** - * Copyright (c) 2016-present, Yann Collet, Facebook, Inc. - * All rights reserved. - */ - -/*-************************************* -* Dependencies -***************************************/ -#include "error_private.h" -#include "zstd_internal.h" /* declaration of ZSTD_isError, ZSTD_getErrorName, ZSTD_getErrorCode, ZSTD_getErrorString, ZSTD_versionNumber */ -#include <malloc.h> -#include <linux/kernel.h> - -/*=************************************************************** -* Custom allocator -****************************************************************/ - -#define stack_push(stack, size) \ - ({ \ - void *const ptr = ZSTD_PTR_ALIGN((stack)->ptr); \ - (stack)->ptr = (char *)ptr + (size); \ - (stack)->ptr <= (stack)->end ? ptr : NULL; \ - }) - -ZSTD_customMem ZSTD_initStack(void *workspace, size_t workspaceSize) -{ - ZSTD_customMem stackMem = {ZSTD_stackAlloc, ZSTD_stackFree, workspace}; - ZSTD_stack *stack = (ZSTD_stack *)workspace; - /* Verify preconditions */ - if (!workspace || workspaceSize < sizeof(ZSTD_stack) || workspace != ZSTD_PTR_ALIGN(workspace)) { - ZSTD_customMem error = {NULL, NULL, NULL}; - return error; - } - /* Initialize the stack */ - stack->ptr = workspace; - stack->end = (char *)workspace + workspaceSize; - stack_push(stack, sizeof(ZSTD_stack)); - return stackMem; -} - -void *ZSTD_stackAllocAll(void *opaque, size_t *size) -{ - ZSTD_stack *stack = (ZSTD_stack *)opaque; - *size = (BYTE const *)stack->end - (BYTE *)ZSTD_PTR_ALIGN(stack->ptr); - return stack_push(stack, *size); -} - -void *ZSTD_stackAlloc(void *opaque, size_t size) -{ - ZSTD_stack *stack = (ZSTD_stack *)opaque; - return stack_push(stack, size); -} -void ZSTD_stackFree(void *opaque, void *address) -{ - (void)opaque; - (void)address; -} - -void *ZSTD_malloc(size_t size, ZSTD_customMem customMem) { return customMem.customAlloc(customMem.opaque, size); } - -void ZSTD_free(void *ptr, ZSTD_customMem customMem) -{ - if (ptr != NULL) - customMem.customFree(customMem.opaque, ptr); -} diff --git a/lib/zstd/zstd_common_module.c b/lib/zstd/zstd_common_module.c new file mode 100644 index 00000000000..73b97c2778c --- /dev/null +++ b/lib/zstd/zstd_common_module.c @@ -0,0 +1,32 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/* + * Copyright (c) Facebook, Inc. + * All rights reserved. + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. + */ + +#include <linux/compat.h> + +#include "common/huf.h" +#include "common/fse.h" +#include "common/zstd_internal.h" + +// Export symbols shared by compress and decompress into a common module + +#undef ZSTD_isError /* defined within zstd_internal.h */ +EXPORT_SYMBOL_GPL(FSE_readNCount); +EXPORT_SYMBOL_GPL(HUF_readStats); +EXPORT_SYMBOL_GPL(HUF_readStats_wksp); +EXPORT_SYMBOL_GPL(ZSTD_isError); +EXPORT_SYMBOL_GPL(ZSTD_getErrorName); +EXPORT_SYMBOL_GPL(ZSTD_getErrorCode); +EXPORT_SYMBOL_GPL(ZSTD_customMalloc); +EXPORT_SYMBOL_GPL(ZSTD_customCalloc); +EXPORT_SYMBOL_GPL(ZSTD_customFree); + +MODULE_LICENSE("Dual BSD/GPL"); +MODULE_DESCRIPTION("Zstd Common"); diff --git a/lib/zstd/zstd_decompress_module.c b/lib/zstd/zstd_decompress_module.c new file mode 100644 index 00000000000..06cf3e43bca --- /dev/null +++ b/lib/zstd/zstd_decompress_module.c @@ -0,0 +1,105 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/* + * Copyright (c) Facebook, Inc. + * All rights reserved. + * + * This source code is licensed under both the BSD-style license (found in the + * LICENSE file in the root directory of this source tree) and the GPLv2 (found + * in the COPYING file in the root directory of this source tree). + * You may select, at your option, one of the above-listed licenses. + */ + +#include <linux/kernel.h> +#include <linux/compat.h> +#include <linux/string.h> +#include <linux/zstd.h> + +#include "common/zstd_deps.h" + +/* Common symbols. zstd_compress must depend on zstd_decompress. */ + +unsigned int zstd_is_error(size_t code) +{ + return ZSTD_isError(code); +} +EXPORT_SYMBOL(zstd_is_error); + +zstd_error_code zstd_get_error_code(size_t code) +{ + return ZSTD_getErrorCode(code); +} +EXPORT_SYMBOL(zstd_get_error_code); + +const char *zstd_get_error_name(size_t code) +{ + return ZSTD_getErrorName(code); +} +EXPORT_SYMBOL(zstd_get_error_name); + +/* Decompression symbols. */ + +size_t zstd_dctx_workspace_bound(void) +{ + return ZSTD_estimateDCtxSize(); +} +EXPORT_SYMBOL(zstd_dctx_workspace_bound); + +zstd_dctx *zstd_init_dctx(void *workspace, size_t workspace_size) +{ + if (workspace == NULL) + return NULL; + return ZSTD_initStaticDCtx(workspace, workspace_size); +} +EXPORT_SYMBOL(zstd_init_dctx); + +size_t zstd_decompress_dctx(zstd_dctx *dctx, void *dst, size_t dst_capacity, + const void *src, size_t src_size) +{ + return ZSTD_decompressDCtx(dctx, dst, dst_capacity, src, src_size); +} +EXPORT_SYMBOL(zstd_decompress_dctx); + +size_t zstd_dstream_workspace_bound(size_t max_window_size) +{ + return ZSTD_estimateDStreamSize(max_window_size); +} +EXPORT_SYMBOL(zstd_dstream_workspace_bound); + +zstd_dstream *zstd_init_dstream(size_t max_window_size, void *workspace, + size_t workspace_size) +{ + if (workspace == NULL) + return NULL; + (void)max_window_size; + return ZSTD_initStaticDStream(workspace, workspace_size); +} +EXPORT_SYMBOL(zstd_init_dstream); + +size_t zstd_reset_dstream(zstd_dstream *dstream) +{ + return ZSTD_resetDStream(dstream); +} +EXPORT_SYMBOL(zstd_reset_dstream); + +size_t zstd_decompress_stream(zstd_dstream *dstream, zstd_out_buffer *output, + zstd_in_buffer *input) +{ + return ZSTD_decompressStream(dstream, output, input); +} +EXPORT_SYMBOL(zstd_decompress_stream); + +size_t zstd_find_frame_compressed_size(const void *src, size_t src_size) +{ + return ZSTD_findFrameCompressedSize(src, src_size); +} +EXPORT_SYMBOL(zstd_find_frame_compressed_size); + +size_t zstd_get_frame_header(zstd_frame_header *header, const void *src, + size_t src_size) +{ + return ZSTD_getFrameHeader(header, src, src_size); +} +EXPORT_SYMBOL(zstd_get_frame_header); + +MODULE_LICENSE("Dual BSD/GPL"); +MODULE_DESCRIPTION("Zstd Decompressor"); diff --git a/lib/zstd/zstd_internal.h b/lib/zstd/zstd_internal.h deleted file mode 100644 index 551340c8b51..00000000000 --- a/lib/zstd/zstd_internal.h +++ /dev/null @@ -1,253 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 or BSD-3-Clause-Clear) */ -/** - * Copyright (c) 2016-present, Yann Collet, Facebook, Inc. - * All rights reserved. - */ - -#ifndef ZSTD_CCOMMON_H_MODULE -#define ZSTD_CCOMMON_H_MODULE - -/*-******************************************************* -* Compiler specifics -*********************************************************/ -#define FORCE_INLINE static __always_inline -#define FORCE_NOINLINE static noinline - -/*-************************************* -* Dependencies -***************************************/ -#include "error_private.h" -#include "mem.h" -#include <linux/compiler.h> -#include <linux/kernel.h> -#include <linux/xxhash.h> -#include <linux/zstd.h> - -/*-************************************* -* shared macros -***************************************/ -#define MIN(a, b) ((a) < (b) ? (a) : (b)) -#define MAX(a, b) ((a) > (b) ? (a) : (b)) -#define CHECK_F(f) \ - { \ - size_t const errcod = f; \ - if (ERR_isError(errcod)) \ - return errcod; \ - } /* check and Forward error code */ -#define CHECK_E(f, e) \ - { \ - size_t const errcod = f; \ - if (ERR_isError(errcod)) \ - return ERROR(e); \ - } /* check and send Error code */ -#define ZSTD_STATIC_ASSERT(c) \ - { \ - enum { ZSTD_static_assert = 1 / (int)(!!(c)) }; \ - } - -/*-************************************* -* Common constants -***************************************/ -#define ZSTD_OPT_NUM (1 << 12) -#define ZSTD_DICT_MAGIC 0xEC30A437 /* v0.7+ */ - -#define ZSTD_REP_NUM 3 /* number of repcodes */ -#define ZSTD_REP_CHECK (ZSTD_REP_NUM) /* number of repcodes to check by the optimal parser */ -#define ZSTD_REP_MOVE (ZSTD_REP_NUM - 1) -#define ZSTD_REP_MOVE_OPT (ZSTD_REP_NUM) -static const U32 repStartValue[ZSTD_REP_NUM] = {1, 4, 8}; - -#define KB *(1 << 10) -#define MB *(1 << 20) -#define GB *(1U << 30) - -#define BIT7 128 -#define BIT6 64 -#define BIT5 32 -#define BIT4 16 -#define BIT1 2 -#define BIT0 1 - -#define ZSTD_WINDOWLOG_ABSOLUTEMIN 10 -static const size_t ZSTD_fcs_fieldSize[4] = {0, 2, 4, 8}; -static const size_t ZSTD_did_fieldSize[4] = {0, 1, 2, 4}; - -#define ZSTD_BLOCKHEADERSIZE 3 /* C standard doesn't allow `static const` variable to be init using another `static const` variable */ -static const size_t ZSTD_blockHeaderSize = ZSTD_BLOCKHEADERSIZE; -typedef enum { bt_raw, bt_rle, bt_compressed, bt_reserved } blockType_e; - -#define MIN_SEQUENCES_SIZE 1 /* nbSeq==0 */ -#define MIN_CBLOCK_SIZE (1 /*litCSize*/ + 1 /* RLE or RAW */ + MIN_SEQUENCES_SIZE /* nbSeq==0 */) /* for a non-null block */ - -#define HufLog 12 -typedef enum { set_basic, set_rle, set_compressed, set_repeat } symbolEncodingType_e; - -#define LONGNBSEQ 0x7F00 - -#define MINMATCH 3 -#define EQUAL_READ32 4 - -#define Litbits 8 -#define MaxLit ((1 << Litbits) - 1) -#define MaxML 52 -#define MaxLL 35 -#define MaxOff 28 -#define MaxSeq MAX(MaxLL, MaxML) /* Assumption : MaxOff < MaxLL,MaxML */ -#define MLFSELog 9 -#define LLFSELog 9 -#define OffFSELog 8 - -static const U32 LL_bits[MaxLL + 1] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 2, 2, 3, 3, 4, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16}; -static const S16 LL_defaultNorm[MaxLL + 1] = {4, 3, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 2, 3, 2, 1, 1, 1, 1, 1, -1, -1, -1, -1}; -#define LL_DEFAULTNORMLOG 6 /* for static allocation */ -static const U32 LL_defaultNormLog = LL_DEFAULTNORMLOG; - -static const U32 ML_bits[MaxML + 1] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, - 0, 0, 0, 0, 0, 1, 1, 1, 1, 2, 2, 3, 3, 4, 4, 5, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16}; -static const S16 ML_defaultNorm[MaxML + 1] = {1, 4, 3, 2, 2, 2, 2, 2, 2, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, - 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, -1, -1, -1, -1, -1, -1, -1}; -#define ML_DEFAULTNORMLOG 6 /* for static allocation */ -static const U32 ML_defaultNormLog = ML_DEFAULTNORMLOG; - -static const S16 OF_defaultNorm[MaxOff + 1] = {1, 1, 1, 1, 1, 1, 2, 2, 2, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, -1, -1, -1, -1, -1}; -#define OF_DEFAULTNORMLOG 5 /* for static allocation */ -static const U32 OF_defaultNormLog = OF_DEFAULTNORMLOG; - -/*-******************************************* -* Shared functions to include for inlining -*********************************************/ -ZSTD_STATIC void ZSTD_copy8(void *dst, const void *src) { - memcpy(dst, src, 8); -} -/*! ZSTD_wildcopy() : -* custom version of memcpy(), can copy up to 7 bytes too many (8 bytes if length==0) */ -#define WILDCOPY_OVERLENGTH 8 -ZSTD_STATIC void ZSTD_wildcopy(void *dst, const void *src, ptrdiff_t length) -{ - const BYTE* ip = (const BYTE*)src; - BYTE* op = (BYTE*)dst; - BYTE* const oend = op + length; - /* Work around https://gcc.gnu.org/bugzilla/show_bug.cgi?id=81388. - * Avoid the bad case where the loop only runs once by handling the - * special case separately. This doesn't trigger the bug because it - * doesn't involve pointer/integer overflow. - */ - if (length <= 8) - return ZSTD_copy8(dst, src); - do { - ZSTD_copy8(op, ip); - op += 8; - ip += 8; - } while (op < oend); -} - -/*-******************************************* -* Private interfaces -*********************************************/ -typedef struct ZSTD_stats_s ZSTD_stats_t; - -typedef struct { - U32 off; - U32 len; -} ZSTD_match_t; - -typedef struct { - U32 price; - U32 off; - U32 mlen; - U32 litlen; - U32 rep[ZSTD_REP_NUM]; -} ZSTD_optimal_t; - -typedef struct seqDef_s { - U32 offset; - U16 litLength; - U16 matchLength; -} seqDef; - -typedef struct { - seqDef *sequencesStart; - seqDef *sequences; - BYTE *litStart; - BYTE *lit; - BYTE *llCode; - BYTE *mlCode; - BYTE *ofCode; - U32 longLengthID; /* 0 == no longLength; 1 == Lit.longLength; 2 == Match.longLength; */ - U32 longLengthPos; - /* opt */ - ZSTD_optimal_t *priceTable; - ZSTD_match_t *matchTable; - U32 *matchLengthFreq; - U32 *litLengthFreq; - U32 *litFreq; - U32 *offCodeFreq; - U32 matchLengthSum; - U32 matchSum; - U32 litLengthSum; - U32 litSum; - U32 offCodeSum; - U32 log2matchLengthSum; - U32 log2matchSum; - U32 log2litLengthSum; - U32 log2litSum; - U32 log2offCodeSum; - U32 factor; - U32 staticPrices; - U32 cachedPrice; - U32 cachedLitLength; - const BYTE *cachedLiterals; -} seqStore_t; - -const seqStore_t *ZSTD_getSeqStore(const ZSTD_CCtx *ctx); -void ZSTD_seqToCodes(const seqStore_t *seqStorePtr); -int ZSTD_isSkipFrame(ZSTD_DCtx *dctx); - -/*= Custom memory allocation functions */ -typedef void *(*ZSTD_allocFunction)(void *opaque, size_t size); -typedef void (*ZSTD_freeFunction)(void *opaque, void *address); -typedef struct { - ZSTD_allocFunction customAlloc; - ZSTD_freeFunction customFree; - void *opaque; -} ZSTD_customMem; - -void *ZSTD_malloc(size_t size, ZSTD_customMem customMem); -void ZSTD_free(void *ptr, ZSTD_customMem customMem); - -/*====== stack allocation ======*/ - -typedef struct { - void *ptr; - const void *end; -} ZSTD_stack; - -#define ZSTD_ALIGN(x) ALIGN(x, sizeof(size_t)) -#define ZSTD_PTR_ALIGN(p) PTR_ALIGN(p, sizeof(size_t)) - -ZSTD_customMem ZSTD_initStack(void *workspace, size_t workspaceSize); - -void *ZSTD_stackAllocAll(void *opaque, size_t *size); -void *ZSTD_stackAlloc(void *opaque, size_t size); -void ZSTD_stackFree(void *opaque, void *address); - -/*====== common function ======*/ - -ZSTD_STATIC U32 ZSTD_highbit32(U32 val) { return 31 - __builtin_clz(val); } - -/* hidden functions */ - -/* ZSTD_invalidateRepCodes() : - * ensures next compression will not use repcodes from previous block. - * Note : only works with regular variant; - * do not use with extDict variant ! */ -void ZSTD_invalidateRepCodes(ZSTD_CCtx *cctx); - -size_t ZSTD_freeCCtx(ZSTD_CCtx *cctx); -size_t ZSTD_freeDCtx(ZSTD_DCtx *dctx); -size_t ZSTD_freeCDict(ZSTD_CDict *cdict); -size_t ZSTD_freeDDict(ZSTD_DDict *cdict); -size_t ZSTD_freeCStream(ZSTD_CStream *zcs); -size_t ZSTD_freeDStream(ZSTD_DStream *zds); - -#endif /* ZSTD_CCOMMON_H_MODULE */ diff --git a/lib/zstd/zstd_opt.h b/lib/zstd/zstd_opt.h deleted file mode 100644 index af0aaf5b20d..00000000000 --- a/lib/zstd/zstd_opt.h +++ /dev/null @@ -1,1004 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 or BSD-3-Clause-Clear) */ -/** - * Copyright (c) 2016-present, Przemyslaw Skibinski, Yann Collet, Facebook, Inc. - * All rights reserved. - */ - -/* Note : this file is intended to be included within zstd_compress.c */ - -#ifndef ZSTD_OPT_H_91842398743 -#define ZSTD_OPT_H_91842398743 - -#define ZSTD_LITFREQ_ADD 2 -#define ZSTD_FREQ_DIV 4 -#define ZSTD_MAX_PRICE (1 << 30) - -/*-************************************* -* Price functions for optimal parser -***************************************/ -FORCE_INLINE void ZSTD_setLog2Prices(seqStore_t *ssPtr) -{ - ssPtr->log2matchLengthSum = ZSTD_highbit32(ssPtr->matchLengthSum + 1); - ssPtr->log2litLengthSum = ZSTD_highbit32(ssPtr->litLengthSum + 1); - ssPtr->log2litSum = ZSTD_highbit32(ssPtr->litSum + 1); - ssPtr->log2offCodeSum = ZSTD_highbit32(ssPtr->offCodeSum + 1); - ssPtr->factor = 1 + ((ssPtr->litSum >> 5) / ssPtr->litLengthSum) + ((ssPtr->litSum << 1) / (ssPtr->litSum + ssPtr->matchSum)); -} - -ZSTD_STATIC void ZSTD_rescaleFreqs(seqStore_t *ssPtr, const BYTE *src, size_t srcSize) -{ - unsigned u; - - ssPtr->cachedLiterals = NULL; - ssPtr->cachedPrice = ssPtr->cachedLitLength = 0; - ssPtr->staticPrices = 0; - - if (ssPtr->litLengthSum == 0) { - if (srcSize <= 1024) - ssPtr->staticPrices = 1; - - for (u = 0; u <= MaxLit; u++) - ssPtr->litFreq[u] = 0; - for (u = 0; u < srcSize; u++) - ssPtr->litFreq[src[u]]++; - - ssPtr->litSum = 0; - ssPtr->litLengthSum = MaxLL + 1; - ssPtr->matchLengthSum = MaxML + 1; - ssPtr->offCodeSum = (MaxOff + 1); - ssPtr->matchSum = (ZSTD_LITFREQ_ADD << Litbits); - - for (u = 0; u <= MaxLit; u++) { - ssPtr->litFreq[u] = 1 + (ssPtr->litFreq[u] >> ZSTD_FREQ_DIV); - ssPtr->litSum += ssPtr->litFreq[u]; - } - for (u = 0; u <= MaxLL; u++) - ssPtr->litLengthFreq[u] = 1; - for (u = 0; u <= MaxML; u++) - ssPtr->matchLengthFreq[u] = 1; - for (u = 0; u <= MaxOff; u++) - ssPtr->offCodeFreq[u] = 1; - } else { - ssPtr->matchLengthSum = 0; - ssPtr->litLengthSum = 0; - ssPtr->offCodeSum = 0; - ssPtr->matchSum = 0; - ssPtr->litSum = 0; - - for (u = 0; u <= MaxLit; u++) { - ssPtr->litFreq[u] = 1 + (ssPtr->litFreq[u] >> (ZSTD_FREQ_DIV + 1)); - ssPtr->litSum += ssPtr->litFreq[u]; - } - for (u = 0; u <= MaxLL; u++) { - ssPtr->litLengthFreq[u] = 1 + (ssPtr->litLengthFreq[u] >> (ZSTD_FREQ_DIV + 1)); - ssPtr->litLengthSum += ssPtr->litLengthFreq[u]; - } - for (u = 0; u <= MaxML; u++) { - ssPtr->matchLengthFreq[u] = 1 + (ssPtr->matchLengthFreq[u] >> ZSTD_FREQ_DIV); - ssPtr->matchLengthSum += ssPtr->matchLengthFreq[u]; - ssPtr->matchSum += ssPtr->matchLengthFreq[u] * (u + 3); - } - ssPtr->matchSum *= ZSTD_LITFREQ_ADD; - for (u = 0; u <= MaxOff; u++) { - ssPtr->offCodeFreq[u] = 1 + (ssPtr->offCodeFreq[u] >> ZSTD_FREQ_DIV); - ssPtr->offCodeSum += ssPtr->offCodeFreq[u]; - } - } - - ZSTD_setLog2Prices(ssPtr); -} - -FORCE_INLINE U32 ZSTD_getLiteralPrice(seqStore_t *ssPtr, U32 litLength, const BYTE *literals) -{ - U32 price, u; - - if (ssPtr->staticPrices) - return ZSTD_highbit32((U32)litLength + 1) + (litLength * 6); - - if (litLength == 0) - return ssPtr->log2litLengthSum - ZSTD_highbit32(ssPtr->litLengthFreq[0] + 1); - - /* literals */ - if (ssPtr->cachedLiterals == literals) { - U32 const additional = litLength - ssPtr->cachedLitLength; - const BYTE *literals2 = ssPtr->cachedLiterals + ssPtr->cachedLitLength; - price = ssPtr->cachedPrice + additional * ssPtr->log2litSum; - for (u = 0; u < additional; u++) - price -= ZSTD_highbit32(ssPtr->litFreq[literals2[u]] + 1); - ssPtr->cachedPrice = price; - ssPtr->cachedLitLength = litLength; - } else { - price = litLength * ssPtr->log2litSum; - for (u = 0; u < litLength; u++) - price -= ZSTD_highbit32(ssPtr->litFreq[literals[u]] + 1); - - if (litLength >= 12) { - ssPtr->cachedLiterals = literals; - ssPtr->cachedPrice = price; - ssPtr->cachedLitLength = litLength; - } - } - - /* literal Length */ - { - const BYTE LL_deltaCode = 19; - const BYTE llCode = (litLength > 63) ? (BYTE)ZSTD_highbit32(litLength) + LL_deltaCode : LL_Code[litLength]; - price += LL_bits[llCode] + ssPtr->log2litLengthSum - ZSTD_highbit32(ssPtr->litLengthFreq[llCode] + 1); - } - - return price; -} - -FORCE_INLINE U32 ZSTD_getPrice(seqStore_t *seqStorePtr, U32 litLength, const BYTE *literals, U32 offset, U32 matchLength, const int ultra) -{ - /* offset */ - U32 price; - BYTE const offCode = (BYTE)ZSTD_highbit32(offset + 1); - - if (seqStorePtr->staticPrices) - return ZSTD_getLiteralPrice(seqStorePtr, litLength, literals) + ZSTD_highbit32((U32)matchLength + 1) + 16 + offCode; - - price = offCode + seqStorePtr->log2offCodeSum - ZSTD_highbit32(seqStorePtr->offCodeFreq[offCode] + 1); - if (!ultra && offCode >= 20) - price += (offCode - 19) * 2; - - /* match Length */ - { - const BYTE ML_deltaCode = 36; - const BYTE mlCode = (matchLength > 127) ? (BYTE)ZSTD_highbit32(matchLength) + ML_deltaCode : ML_Code[matchLength]; - price += ML_bits[mlCode] + seqStorePtr->log2matchLengthSum - ZSTD_highbit32(seqStorePtr->matchLengthFreq[mlCode] + 1); - } - - return price + ZSTD_getLiteralPrice(seqStorePtr, litLength, literals) + seqStorePtr->factor; -} - -ZSTD_STATIC void ZSTD_updatePrice(seqStore_t *seqStorePtr, U32 litLength, const BYTE *literals, U32 offset, U32 matchLength) -{ - U32 u; - - /* literals */ - seqStorePtr->litSum += litLength * ZSTD_LITFREQ_ADD; - for (u = 0; u < litLength; u++) - seqStorePtr->litFreq[literals[u]] += ZSTD_LITFREQ_ADD; - - /* literal Length */ - { - const BYTE LL_deltaCode = 19; - const BYTE llCode = (litLength > 63) ? (BYTE)ZSTD_highbit32(litLength) + LL_deltaCode : LL_Code[litLength]; - seqStorePtr->litLengthFreq[llCode]++; - seqStorePtr->litLengthSum++; - } - - /* match offset */ - { - BYTE const offCode = (BYTE)ZSTD_highbit32(offset + 1); - seqStorePtr->offCodeSum++; - seqStorePtr->offCodeFreq[offCode]++; - } - - /* match Length */ - { - const BYTE ML_deltaCode = 36; - const BYTE mlCode = (matchLength > 127) ? (BYTE)ZSTD_highbit32(matchLength) + ML_deltaCode : ML_Code[matchLength]; - seqStorePtr->matchLengthFreq[mlCode]++; - seqStorePtr->matchLengthSum++; - } - - ZSTD_setLog2Prices(seqStorePtr); -} - -#define SET_PRICE(pos, mlen_, offset_, litlen_, price_) \ - { \ - while (last_pos < pos) { \ - opt[last_pos + 1].price = ZSTD_MAX_PRICE; \ - last_pos++; \ - } \ - opt[pos].mlen = mlen_; \ - opt[pos].off = offset_; \ - opt[pos].litlen = litlen_; \ - opt[pos].price = price_; \ - } - -/* Update hashTable3 up to ip (excluded) - Assumption : always within prefix (i.e. not within extDict) */ -FORCE_INLINE -U32 ZSTD_insertAndFindFirstIndexHash3(ZSTD_CCtx *zc, const BYTE *ip) -{ - U32 *const hashTable3 = zc->hashTable3; - U32 const hashLog3 = zc->hashLog3; - const BYTE *const base = zc->base; - U32 idx = zc->nextToUpdate3; - const U32 target = zc->nextToUpdate3 = (U32)(ip - base); - const size_t hash3 = ZSTD_hash3Ptr(ip, hashLog3); - - while (idx < target) { - hashTable3[ZSTD_hash3Ptr(base + idx, hashLog3)] = idx; - idx++; - } - - return hashTable3[hash3]; -} - -/*-************************************* -* Binary Tree search -***************************************/ -static U32 ZSTD_insertBtAndGetAllMatches(ZSTD_CCtx *zc, const BYTE *const ip, const BYTE *const iLimit, U32 nbCompares, const U32 mls, U32 extDict, - ZSTD_match_t *matches, const U32 minMatchLen) -{ - const BYTE *const base = zc->base; - const U32 curr = (U32)(ip - base); - const U32 hashLog = zc->params.cParams.hashLog; - const size_t h = ZSTD_hashPtr(ip, hashLog, mls); - U32 *const hashTable = zc->hashTable; - U32 matchIndex = hashTable[h]; - U32 *const bt = zc->chainTable; - const U32 btLog = zc->params.cParams.chainLog - 1; - const U32 btMask = (1U << btLog) - 1; - size_t commonLengthSmaller = 0, commonLengthLarger = 0; - const BYTE *const dictBase = zc->dictBase; - const U32 dictLimit = zc->dictLimit; - const BYTE *const dictEnd = dictBase + dictLimit; - const BYTE *const prefixStart = base + dictLimit; - const U32 btLow = btMask >= curr ? 0 : curr - btMask; - const U32 windowLow = zc->lowLimit; - U32 *smallerPtr = bt + 2 * (curr & btMask); - U32 *largerPtr = bt + 2 * (curr & btMask) + 1; - U32 matchEndIdx = curr + 8; - U32 dummy32; /* to be nullified at the end */ - U32 mnum = 0; - - const U32 minMatch = (mls == 3) ? 3 : 4; - size_t bestLength = minMatchLen - 1; - - if (minMatch == 3) { /* HC3 match finder */ - U32 const matchIndex3 = ZSTD_insertAndFindFirstIndexHash3(zc, ip); - if (matchIndex3 > windowLow && (curr - matchIndex3 < (1 << 18))) { - const BYTE *match; - size_t currMl = 0; - if ((!extDict) || matchIndex3 >= dictLimit) { - match = base + matchIndex3; - if (match[bestLength] == ip[bestLength]) - currMl = ZSTD_count(ip, match, iLimit); - } else { - match = dictBase + matchIndex3; - if (ZSTD_readMINMATCH(match, MINMATCH) == - ZSTD_readMINMATCH(ip, MINMATCH)) /* assumption : matchIndex3 <= dictLimit-4 (by table construction) */ - currMl = ZSTD_count_2segments(ip + MINMATCH, match + MINMATCH, iLimit, dictEnd, prefixStart) + MINMATCH; - } - - /* save best solution */ - if (currMl > bestLength) { - bestLength = currMl; - matches[mnum].off = ZSTD_REP_MOVE_OPT + curr - matchIndex3; - matches[mnum].len = (U32)currMl; - mnum++; - if (currMl > ZSTD_OPT_NUM) - goto update; - if (ip + currMl == iLimit) - goto update; /* best possible, and avoid read overflow*/ - } - } - } - - hashTable[h] = curr; /* Update Hash Table */ - - while (nbCompares-- && (matchIndex > windowLow)) { - U32 *nextPtr = bt + 2 * (matchIndex & btMask); - size_t matchLength = MIN(commonLengthSmaller, commonLengthLarger); /* guaranteed minimum nb of common bytes */ - const BYTE *match; - - if ((!extDict) || (matchIndex + matchLength >= dictLimit)) { - match = base + matchIndex; - if (match[matchLength] == ip[matchLength]) { - matchLength += ZSTD_count(ip + matchLength + 1, match + matchLength + 1, iLimit) + 1; - } - } else { - match = dictBase + matchIndex; - matchLength += ZSTD_count_2segments(ip + matchLength, match + matchLength, iLimit, dictEnd, prefixStart); - if (matchIndex + matchLength >= dictLimit) - match = base + matchIndex; /* to prepare for next usage of match[matchLength] */ - } - - if (matchLength > bestLength) { - if (matchLength > matchEndIdx - matchIndex) - matchEndIdx = matchIndex + (U32)matchLength; - bestLength = matchLength; - matches[mnum].off = ZSTD_REP_MOVE_OPT + curr - matchIndex; - matches[mnum].len = (U32)matchLength; - mnum++; - if (matchLength > ZSTD_OPT_NUM) - break; - if (ip + matchLength == iLimit) /* equal : no way to know if inf or sup */ - break; /* drop, to guarantee consistency (miss a little bit of compression) */ - } - - if (match[matchLength] < ip[matchLength]) { - /* match is smaller than curr */ - *smallerPtr = matchIndex; /* update smaller idx */ - commonLengthSmaller = matchLength; /* all smaller will now have at least this guaranteed common length */ - if (matchIndex <= btLow) { - smallerPtr = &dummy32; - break; - } /* beyond tree size, stop the search */ - smallerPtr = nextPtr + 1; /* new "smaller" => larger of match */ - matchIndex = nextPtr[1]; /* new matchIndex larger than previous (closer to curr) */ - } else { - /* match is larger than curr */ - *largerPtr = matchIndex; - commonLengthLarger = matchLength; - if (matchIndex <= btLow) { - largerPtr = &dummy32; - break; - } /* beyond tree size, stop the search */ - largerPtr = nextPtr; - matchIndex = nextPtr[0]; - } - } - - *smallerPtr = *largerPtr = 0; - -update: - zc->nextToUpdate = (matchEndIdx > curr + 8) ? matchEndIdx - 8 : curr + 1; - return mnum; -} - -/** Tree updater, providing best match */ -static U32 ZSTD_BtGetAllMatches(ZSTD_CCtx *zc, const BYTE *const ip, const BYTE *const iLimit, const U32 maxNbAttempts, const U32 mls, ZSTD_match_t *matches, - const U32 minMatchLen) -{ - if (ip < zc->base + zc->nextToUpdate) - return 0; /* skipped area */ - ZSTD_updateTree(zc, ip, iLimit, maxNbAttempts, mls); - return ZSTD_insertBtAndGetAllMatches(zc, ip, iLimit, maxNbAttempts, mls, 0, matches, minMatchLen); -} - -static U32 ZSTD_BtGetAllMatches_selectMLS(ZSTD_CCtx *zc, /* Index table will be updated */ - const BYTE *ip, const BYTE *const iHighLimit, const U32 maxNbAttempts, const U32 matchLengthSearch, - ZSTD_match_t *matches, const U32 minMatchLen) -{ - switch (matchLengthSearch) { - case 3: return ZSTD_BtGetAllMatches(zc, ip, iHighLimit, maxNbAttempts, 3, matches, minMatchLen); - default: - case 4: return ZSTD_BtGetAllMatches(zc, ip, iHighLimit, maxNbAttempts, 4, matches, minMatchLen); - case 5: return ZSTD_BtGetAllMatches(zc, ip, iHighLimit, maxNbAttempts, 5, matches, minMatchLen); - case 7: - case 6: return ZSTD_BtGetAllMatches(zc, ip, iHighLimit, maxNbAttempts, 6, matches, minMatchLen); - } -} - -/** Tree updater, providing best match */ -static U32 ZSTD_BtGetAllMatches_extDict(ZSTD_CCtx *zc, const BYTE *const ip, const BYTE *const iLimit, const U32 maxNbAttempts, const U32 mls, - ZSTD_match_t *matches, const U32 minMatchLen) -{ - if (ip < zc->base + zc->nextToUpdate) - return 0; /* skipped area */ - ZSTD_updateTree_extDict(zc, ip, iLimit, maxNbAttempts, mls); - return ZSTD_insertBtAndGetAllMatches(zc, ip, iLimit, maxNbAttempts, mls, 1, matches, minMatchLen); -} - -static U32 ZSTD_BtGetAllMatches_selectMLS_extDict(ZSTD_CCtx *zc, /* Index table will be updated */ - const BYTE *ip, const BYTE *const iHighLimit, const U32 maxNbAttempts, const U32 matchLengthSearch, - ZSTD_match_t *matches, const U32 minMatchLen) -{ - switch (matchLengthSearch) { - case 3: return ZSTD_BtGetAllMatches_extDict(zc, ip, iHighLimit, maxNbAttempts, 3, matches, minMatchLen); - default: - case 4: return ZSTD_BtGetAllMatches_extDict(zc, ip, iHighLimit, maxNbAttempts, 4, matches, minMatchLen); - case 5: return ZSTD_BtGetAllMatches_extDict(zc, ip, iHighLimit, maxNbAttempts, 5, matches, minMatchLen); - case 7: - case 6: return ZSTD_BtGetAllMatches_extDict(zc, ip, iHighLimit, maxNbAttempts, 6, matches, minMatchLen); - } -} - -/*-******************************* -* Optimal parser -*********************************/ -FORCE_INLINE -void ZSTD_compressBlock_opt_generic(ZSTD_CCtx *ctx, const void *src, size_t srcSize, const int ultra) -{ - seqStore_t *seqStorePtr = &(ctx->seqStore); - const BYTE *const istart = (const BYTE *)src; - const BYTE *ip = istart; - const BYTE *anchor = istart; - const BYTE *const iend = istart + srcSize; - const BYTE *const ilimit = iend - 8; - const BYTE *const base = ctx->base; - const BYTE *const prefixStart = base + ctx->dictLimit; - - const U32 maxSearches = 1U << ctx->params.cParams.searchLog; - const U32 sufficient_len = ctx->params.cParams.targetLength; - const U32 mls = ctx->params.cParams.searchLength; - const U32 minMatch = (ctx->params.cParams.searchLength == 3) ? 3 : 4; - - ZSTD_optimal_t *opt = seqStorePtr->priceTable; - ZSTD_match_t *matches = seqStorePtr->matchTable; - const BYTE *inr; - U32 offset, rep[ZSTD_REP_NUM]; - - /* init */ - ctx->nextToUpdate3 = ctx->nextToUpdate; - ZSTD_rescaleFreqs(seqStorePtr, (const BYTE *)src, srcSize); - ip += (ip == prefixStart); - { - U32 i; - for (i = 0; i < ZSTD_REP_NUM; i++) - rep[i] = ctx->rep[i]; - } - - /* Match Loop */ - while (ip < ilimit) { - U32 cur, match_num, last_pos, litlen, price; - U32 u, mlen, best_mlen, best_off, litLength; - memset(opt, 0, sizeof(ZSTD_optimal_t)); - last_pos = 0; - litlen = (U32)(ip - anchor); - - /* check repCode */ - { - U32 i, last_i = ZSTD_REP_CHECK + (ip == anchor); - for (i = (ip == anchor); i < last_i; i++) { - const S32 repCur = (i == ZSTD_REP_MOVE_OPT) ? (rep[0] - 1) : rep[i]; - if ((repCur > 0) && (repCur < (S32)(ip - prefixStart)) && - (ZSTD_readMINMATCH(ip, minMatch) == ZSTD_readMINMATCH(ip - repCur, minMatch))) { - mlen = (U32)ZSTD_count(ip + minMatch, ip + minMatch - repCur, iend) + minMatch; - if (mlen > sufficient_len || mlen >= ZSTD_OPT_NUM) { - best_mlen = mlen; - best_off = i; - cur = 0; - last_pos = 1; - goto _storeSequence; - } - best_off = i - (ip == anchor); - do { - price = ZSTD_getPrice(seqStorePtr, litlen, anchor, best_off, mlen - MINMATCH, ultra); - if (mlen > last_pos || price < opt[mlen].price) - SET_PRICE(mlen, mlen, i, litlen, price); /* note : macro modifies last_pos */ - mlen--; - } while (mlen >= minMatch); - } - } - } - - match_num = ZSTD_BtGetAllMatches_selectMLS(ctx, ip, iend, maxSearches, mls, matches, minMatch); - - if (!last_pos && !match_num) { - ip++; - continue; - } - - if (match_num && (matches[match_num - 1].len > sufficient_len || matches[match_num - 1].len >= ZSTD_OPT_NUM)) { - best_mlen = matches[match_num - 1].len; - best_off = matches[match_num - 1].off; - cur = 0; - last_pos = 1; - goto _storeSequence; - } - - /* set prices using matches at position = 0 */ - best_mlen = (last_pos) ? last_pos : minMatch; - for (u = 0; u < match_num; u++) { - mlen = (u > 0) ? matches[u - 1].len + 1 : best_mlen; - best_mlen = matches[u].len; - while (mlen <= best_mlen) { - price = ZSTD_getPrice(seqStorePtr, litlen, anchor, matches[u].off - 1, mlen - MINMATCH, ultra); - if (mlen > last_pos || price < opt[mlen].price) - SET_PRICE(mlen, mlen, matches[u].off, litlen, price); /* note : macro modifies last_pos */ - mlen++; - } - } - - if (last_pos < minMatch) { - ip++; - continue; - } - - /* initialize opt[0] */ - { - U32 i; - for (i = 0; i < ZSTD_REP_NUM; i++) - opt[0].rep[i] = rep[i]; - } - opt[0].mlen = 1; - opt[0].litlen = litlen; - - /* check further positions */ - for (cur = 1; cur <= last_pos; cur++) { - inr = ip + cur; - - if (opt[cur - 1].mlen == 1) { - litlen = opt[cur - 1].litlen + 1; - if (cur > litlen) { - price = opt[cur - litlen].price + ZSTD_getLiteralPrice(seqStorePtr, litlen, inr - litlen); - } else - price = ZSTD_getLiteralPrice(seqStorePtr, litlen, anchor); - } else { - litlen = 1; - price = opt[cur - 1].price + ZSTD_getLiteralPrice(seqStorePtr, litlen, inr - 1); - } - - if (cur > last_pos || price <= opt[cur].price) - SET_PRICE(cur, 1, 0, litlen, price); - - if (cur == last_pos) - break; - - if (inr > ilimit) /* last match must start at a minimum distance of 8 from oend */ - continue; - - mlen = opt[cur].mlen; - if (opt[cur].off > ZSTD_REP_MOVE_OPT) { - opt[cur].rep[2] = opt[cur - mlen].rep[1]; - opt[cur].rep[1] = opt[cur - mlen].rep[0]; - opt[cur].rep[0] = opt[cur].off - ZSTD_REP_MOVE_OPT; - } else { - opt[cur].rep[2] = (opt[cur].off > 1) ? opt[cur - mlen].rep[1] : opt[cur - mlen].rep[2]; - opt[cur].rep[1] = (opt[cur].off > 0) ? opt[cur - mlen].rep[0] : opt[cur - mlen].rep[1]; - opt[cur].rep[0] = - ((opt[cur].off == ZSTD_REP_MOVE_OPT) && (mlen != 1)) ? (opt[cur - mlen].rep[0] - 1) : (opt[cur - mlen].rep[opt[cur].off]); - } - - best_mlen = minMatch; - { - U32 i, last_i = ZSTD_REP_CHECK + (mlen != 1); - for (i = (opt[cur].mlen != 1); i < last_i; i++) { /* check rep */ - const S32 repCur = (i == ZSTD_REP_MOVE_OPT) ? (opt[cur].rep[0] - 1) : opt[cur].rep[i]; - if ((repCur > 0) && (repCur < (S32)(inr - prefixStart)) && - (ZSTD_readMINMATCH(inr, minMatch) == ZSTD_readMINMATCH(inr - repCur, minMatch))) { - mlen = (U32)ZSTD_count(inr + minMatch, inr + minMatch - repCur, iend) + minMatch; - - if (mlen > sufficient_len || cur + mlen >= ZSTD_OPT_NUM) { - best_mlen = mlen; - best_off = i; - last_pos = cur + 1; - goto _storeSequence; - } - - best_off = i - (opt[cur].mlen != 1); - if (mlen > best_mlen) - best_mlen = mlen; - - do { - if (opt[cur].mlen == 1) { - litlen = opt[cur].litlen; - if (cur > litlen) { - price = opt[cur - litlen].price + ZSTD_getPrice(seqStorePtr, litlen, inr - litlen, - best_off, mlen - MINMATCH, ultra); - } else - price = ZSTD_getPrice(seqStorePtr, litlen, anchor, best_off, mlen - MINMATCH, ultra); - } else { - litlen = 0; - price = opt[cur].price + ZSTD_getPrice(seqStorePtr, 0, NULL, best_off, mlen - MINMATCH, ultra); - } - - if (cur + mlen > last_pos || price <= opt[cur + mlen].price) - SET_PRICE(cur + mlen, mlen, i, litlen, price); - mlen--; - } while (mlen >= minMatch); - } - } - } - - match_num = ZSTD_BtGetAllMatches_selectMLS(ctx, inr, iend, maxSearches, mls, matches, best_mlen); - - if (match_num > 0 && (matches[match_num - 1].len > sufficient_len || cur + matches[match_num - 1].len >= ZSTD_OPT_NUM)) { - best_mlen = matches[match_num - 1].len; - best_off = matches[match_num - 1].off; - last_pos = cur + 1; - goto _storeSequence; - } - - /* set prices using matches at position = cur */ - for (u = 0; u < match_num; u++) { - mlen = (u > 0) ? matches[u - 1].len + 1 : best_mlen; - best_mlen = matches[u].len; - - while (mlen <= best_mlen) { - if (opt[cur].mlen == 1) { - litlen = opt[cur].litlen; - if (cur > litlen) - price = opt[cur - litlen].price + ZSTD_getPrice(seqStorePtr, litlen, ip + cur - litlen, - matches[u].off - 1, mlen - MINMATCH, ultra); - else - price = ZSTD_getPrice(seqStorePtr, litlen, anchor, matches[u].off - 1, mlen - MINMATCH, ultra); - } else { - litlen = 0; - price = opt[cur].price + ZSTD_getPrice(seqStorePtr, 0, NULL, matches[u].off - 1, mlen - MINMATCH, ultra); - } - - if (cur + mlen > last_pos || (price < opt[cur + mlen].price)) - SET_PRICE(cur + mlen, mlen, matches[u].off, litlen, price); - - mlen++; - } - } - } - - best_mlen = opt[last_pos].mlen; - best_off = opt[last_pos].off; - cur = last_pos - best_mlen; - - /* store sequence */ -_storeSequence: /* cur, last_pos, best_mlen, best_off have to be set */ - opt[0].mlen = 1; - - while (1) { - mlen = opt[cur].mlen; - offset = opt[cur].off; - opt[cur].mlen = best_mlen; - opt[cur].off = best_off; - best_mlen = mlen; - best_off = offset; - if (mlen > cur) - break; - cur -= mlen; - } - - for (u = 0; u <= last_pos;) { - u += opt[u].mlen; - } - - for (cur = 0; cur < last_pos;) { - mlen = opt[cur].mlen; - if (mlen == 1) { - ip++; - cur++; - continue; - } - offset = opt[cur].off; - cur += mlen; - litLength = (U32)(ip - anchor); - - if (offset > ZSTD_REP_MOVE_OPT) { - rep[2] = rep[1]; - rep[1] = rep[0]; - rep[0] = offset - ZSTD_REP_MOVE_OPT; - offset--; - } else { - if (offset != 0) { - best_off = (offset == ZSTD_REP_MOVE_OPT) ? (rep[0] - 1) : (rep[offset]); - if (offset != 1) - rep[2] = rep[1]; - rep[1] = rep[0]; - rep[0] = best_off; - } - if (litLength == 0) - offset--; - } - - ZSTD_updatePrice(seqStorePtr, litLength, anchor, offset, mlen - MINMATCH); - ZSTD_storeSeq(seqStorePtr, litLength, anchor, offset, mlen - MINMATCH); - anchor = ip = ip + mlen; - } - } /* for (cur=0; cur < last_pos; ) */ - - /* Save reps for next block */ - { - int i; - for (i = 0; i < ZSTD_REP_NUM; i++) - ctx->repToConfirm[i] = rep[i]; - } - - /* Last Literals */ - { - size_t const lastLLSize = iend - anchor; - memcpy(seqStorePtr->lit, anchor, lastLLSize); - seqStorePtr->lit += lastLLSize; - } -} - -FORCE_INLINE -void ZSTD_compressBlock_opt_extDict_generic(ZSTD_CCtx *ctx, const void *src, size_t srcSize, const int ultra) -{ - seqStore_t *seqStorePtr = &(ctx->seqStore); - const BYTE *const istart = (const BYTE *)src; - const BYTE *ip = istart; - const BYTE *anchor = istart; - const BYTE *const iend = istart + srcSize; - const BYTE *const ilimit = iend - 8; - const BYTE *const base = ctx->base; - const U32 lowestIndex = ctx->lowLimit; - const U32 dictLimit = ctx->dictLimit; - const BYTE *const prefixStart = base + dictLimit; - const BYTE *const dictBase = ctx->dictBase; - const BYTE *const dictEnd = dictBase + dictLimit; - - const U32 maxSearches = 1U << ctx->params.cParams.searchLog; - const U32 sufficient_len = ctx->params.cParams.targetLength; - const U32 mls = ctx->params.cParams.searchLength; - const U32 minMatch = (ctx->params.cParams.searchLength == 3) ? 3 : 4; - - ZSTD_optimal_t *opt = seqStorePtr->priceTable; - ZSTD_match_t *matches = seqStorePtr->matchTable; - const BYTE *inr; - - /* init */ - U32 offset, rep[ZSTD_REP_NUM]; - { - U32 i; - for (i = 0; i < ZSTD_REP_NUM; i++) - rep[i] = ctx->rep[i]; - } - - ctx->nextToUpdate3 = ctx->nextToUpdate; - ZSTD_rescaleFreqs(seqStorePtr, (const BYTE *)src, srcSize); - ip += (ip == prefixStart); - - /* Match Loop */ - while (ip < ilimit) { - U32 cur, match_num, last_pos, litlen, price; - U32 u, mlen, best_mlen, best_off, litLength; - U32 curr = (U32)(ip - base); - memset(opt, 0, sizeof(ZSTD_optimal_t)); - last_pos = 0; - opt[0].litlen = (U32)(ip - anchor); - - /* check repCode */ - { - U32 i, last_i = ZSTD_REP_CHECK + (ip == anchor); - for (i = (ip == anchor); i < last_i; i++) { - const S32 repCur = (i == ZSTD_REP_MOVE_OPT) ? (rep[0] - 1) : rep[i]; - const U32 repIndex = (U32)(curr - repCur); - const BYTE *const repBase = repIndex < dictLimit ? dictBase : base; - const BYTE *const repMatch = repBase + repIndex; - if ((repCur > 0 && repCur <= (S32)curr) && - (((U32)((dictLimit - 1) - repIndex) >= 3) & (repIndex > lowestIndex)) /* intentional overflow */ - && (ZSTD_readMINMATCH(ip, minMatch) == ZSTD_readMINMATCH(repMatch, minMatch))) { - /* repcode detected we should take it */ - const BYTE *const repEnd = repIndex < dictLimit ? dictEnd : iend; - mlen = (U32)ZSTD_count_2segments(ip + minMatch, repMatch + minMatch, iend, repEnd, prefixStart) + minMatch; - - if (mlen > sufficient_len || mlen >= ZSTD_OPT_NUM) { - best_mlen = mlen; - best_off = i; - cur = 0; - last_pos = 1; - goto _storeSequence; - } - - best_off = i - (ip == anchor); - litlen = opt[0].litlen; - do { - price = ZSTD_getPrice(seqStorePtr, litlen, anchor, best_off, mlen - MINMATCH, ultra); - if (mlen > last_pos || price < opt[mlen].price) - SET_PRICE(mlen, mlen, i, litlen, price); /* note : macro modifies last_pos */ - mlen--; - } while (mlen >= minMatch); - } - } - } - - match_num = ZSTD_BtGetAllMatches_selectMLS_extDict(ctx, ip, iend, maxSearches, mls, matches, minMatch); /* first search (depth 0) */ - - if (!last_pos && !match_num) { - ip++; - continue; - } - - { - U32 i; - for (i = 0; i < ZSTD_REP_NUM; i++) - opt[0].rep[i] = rep[i]; - } - opt[0].mlen = 1; - - if (match_num && (matches[match_num - 1].len > sufficient_len || matches[match_num - 1].len >= ZSTD_OPT_NUM)) { - best_mlen = matches[match_num - 1].len; - best_off = matches[match_num - 1].off; - cur = 0; - last_pos = 1; - goto _storeSequence; - } - - best_mlen = (last_pos) ? last_pos : minMatch; - - /* set prices using matches at position = 0 */ - for (u = 0; u < match_num; u++) { - mlen = (u > 0) ? matches[u - 1].len + 1 : best_mlen; - best_mlen = matches[u].len; - litlen = opt[0].litlen; - while (mlen <= best_mlen) { - price = ZSTD_getPrice(seqStorePtr, litlen, anchor, matches[u].off - 1, mlen - MINMATCH, ultra); - if (mlen > last_pos || price < opt[mlen].price) - SET_PRICE(mlen, mlen, matches[u].off, litlen, price); - mlen++; - } - } - - if (last_pos < minMatch) { - ip++; - continue; - } - - /* check further positions */ - for (cur = 1; cur <= last_pos; cur++) { - inr = ip + cur; - - if (opt[cur - 1].mlen == 1) { - litlen = opt[cur - 1].litlen + 1; - if (cur > litlen) { - price = opt[cur - litlen].price + ZSTD_getLiteralPrice(seqStorePtr, litlen, inr - litlen); - } else - price = ZSTD_getLiteralPrice(seqStorePtr, litlen, anchor); - } else { - litlen = 1; - price = opt[cur - 1].price + ZSTD_getLiteralPrice(seqStorePtr, litlen, inr - 1); - } - - if (cur > last_pos || price <= opt[cur].price) - SET_PRICE(cur, 1, 0, litlen, price); - - if (cur == last_pos) - break; - - if (inr > ilimit) /* last match must start at a minimum distance of 8 from oend */ - continue; - - mlen = opt[cur].mlen; - if (opt[cur].off > ZSTD_REP_MOVE_OPT) { - opt[cur].rep[2] = opt[cur - mlen].rep[1]; - opt[cur].rep[1] = opt[cur - mlen].rep[0]; - opt[cur].rep[0] = opt[cur].off - ZSTD_REP_MOVE_OPT; - } else { - opt[cur].rep[2] = (opt[cur].off > 1) ? opt[cur - mlen].rep[1] : opt[cur - mlen].rep[2]; - opt[cur].rep[1] = (opt[cur].off > 0) ? opt[cur - mlen].rep[0] : opt[cur - mlen].rep[1]; - opt[cur].rep[0] = - ((opt[cur].off == ZSTD_REP_MOVE_OPT) && (mlen != 1)) ? (opt[cur - mlen].rep[0] - 1) : (opt[cur - mlen].rep[opt[cur].off]); - } - - best_mlen = minMatch; - { - U32 i, last_i = ZSTD_REP_CHECK + (mlen != 1); - for (i = (mlen != 1); i < last_i; i++) { - const S32 repCur = (i == ZSTD_REP_MOVE_OPT) ? (opt[cur].rep[0] - 1) : opt[cur].rep[i]; - const U32 repIndex = (U32)(curr + cur - repCur); - const BYTE *const repBase = repIndex < dictLimit ? dictBase : base; - const BYTE *const repMatch = repBase + repIndex; - if ((repCur > 0 && repCur <= (S32)(curr + cur)) && - (((U32)((dictLimit - 1) - repIndex) >= 3) & (repIndex > lowestIndex)) /* intentional overflow */ - && (ZSTD_readMINMATCH(inr, minMatch) == ZSTD_readMINMATCH(repMatch, minMatch))) { - /* repcode detected */ - const BYTE *const repEnd = repIndex < dictLimit ? dictEnd : iend; - mlen = (U32)ZSTD_count_2segments(inr + minMatch, repMatch + minMatch, iend, repEnd, prefixStart) + minMatch; - - if (mlen > sufficient_len || cur + mlen >= ZSTD_OPT_NUM) { - best_mlen = mlen; - best_off = i; - last_pos = cur + 1; - goto _storeSequence; - } - - best_off = i - (opt[cur].mlen != 1); - if (mlen > best_mlen) - best_mlen = mlen; - - do { - if (opt[cur].mlen == 1) { - litlen = opt[cur].litlen; - if (cur > litlen) { - price = opt[cur - litlen].price + ZSTD_getPrice(seqStorePtr, litlen, inr - litlen, - best_off, mlen - MINMATCH, ultra); - } else - price = ZSTD_getPrice(seqStorePtr, litlen, anchor, best_off, mlen - MINMATCH, ultra); - } else { - litlen = 0; - price = opt[cur].price + ZSTD_getPrice(seqStorePtr, 0, NULL, best_off, mlen - MINMATCH, ultra); - } - - if (cur + mlen > last_pos || price <= opt[cur + mlen].price) - SET_PRICE(cur + mlen, mlen, i, litlen, price); - mlen--; - } while (mlen >= minMatch); - } - } - } - - match_num = ZSTD_BtGetAllMatches_selectMLS_extDict(ctx, inr, iend, maxSearches, mls, matches, minMatch); - - if (match_num > 0 && (matches[match_num - 1].len > sufficient_len || cur + matches[match_num - 1].len >= ZSTD_OPT_NUM)) { - best_mlen = matches[match_num - 1].len; - best_off = matches[match_num - 1].off; - last_pos = cur + 1; - goto _storeSequence; - } - - /* set prices using matches at position = cur */ - for (u = 0; u < match_num; u++) { - mlen = (u > 0) ? matches[u - 1].len + 1 : best_mlen; - best_mlen = matches[u].len; - - while (mlen <= best_mlen) { - if (opt[cur].mlen == 1) { - litlen = opt[cur].litlen; - if (cur > litlen) - price = opt[cur - litlen].price + ZSTD_getPrice(seqStorePtr, litlen, ip + cur - litlen, - matches[u].off - 1, mlen - MINMATCH, ultra); - else - price = ZSTD_getPrice(seqStorePtr, litlen, anchor, matches[u].off - 1, mlen - MINMATCH, ultra); - } else { - litlen = 0; - price = opt[cur].price + ZSTD_getPrice(seqStorePtr, 0, NULL, matches[u].off - 1, mlen - MINMATCH, ultra); - } - - if (cur + mlen > last_pos || (price < opt[cur + mlen].price)) - SET_PRICE(cur + mlen, mlen, matches[u].off, litlen, price); - - mlen++; - } - } - } /* for (cur = 1; cur <= last_pos; cur++) */ - - best_mlen = opt[last_pos].mlen; - best_off = opt[last_pos].off; - cur = last_pos - best_mlen; - - /* store sequence */ -_storeSequence: /* cur, last_pos, best_mlen, best_off have to be set */ - opt[0].mlen = 1; - - while (1) { - mlen = opt[cur].mlen; - offset = opt[cur].off; - opt[cur].mlen = best_mlen; - opt[cur].off = best_off; - best_mlen = mlen; - best_off = offset; - if (mlen > cur) - break; - cur -= mlen; - } - - for (u = 0; u <= last_pos;) { - u += opt[u].mlen; - } - - for (cur = 0; cur < last_pos;) { - mlen = opt[cur].mlen; - if (mlen == 1) { - ip++; - cur++; - continue; - } - offset = opt[cur].off; - cur += mlen; - litLength = (U32)(ip - anchor); - - if (offset > ZSTD_REP_MOVE_OPT) { - rep[2] = rep[1]; - rep[1] = rep[0]; - rep[0] = offset - ZSTD_REP_MOVE_OPT; - offset--; - } else { - if (offset != 0) { - best_off = (offset == ZSTD_REP_MOVE_OPT) ? (rep[0] - 1) : (rep[offset]); - if (offset != 1) - rep[2] = rep[1]; - rep[1] = rep[0]; - rep[0] = best_off; - } - - if (litLength == 0) - offset--; - } - - ZSTD_updatePrice(seqStorePtr, litLength, anchor, offset, mlen - MINMATCH); - ZSTD_storeSeq(seqStorePtr, litLength, anchor, offset, mlen - MINMATCH); - anchor = ip = ip + mlen; - } - } /* for (cur=0; cur < last_pos; ) */ - - /* Save reps for next block */ - { - int i; - for (i = 0; i < ZSTD_REP_NUM; i++) - ctx->repToConfirm[i] = rep[i]; - } - - /* Last Literals */ - { - size_t lastLLSize = iend - anchor; - memcpy(seqStorePtr->lit, anchor, lastLLSize); - seqStorePtr->lit += lastLLSize; - } -} - -#endif /* ZSTD_OPT_H_91842398743 */
Signed-off-by: Brandon Maier brandon.maier@collins.com --- v2: - added zstd uncompression test v3: - use sizeof() instead of magic number for length --- test/Kconfig | 2 +- test/compression.c | 71 ++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 72 insertions(+), 1 deletion(-)
diff --git a/test/Kconfig b/test/Kconfig index a6b463e4d06..dd2f082ce63 100644 --- a/test/Kconfig +++ b/test/Kconfig @@ -64,7 +64,7 @@ endif config UT_COMPRESSION bool "Unit test for compression" depends on UNIT_TEST - depends on CMDLINE && GZIP_COMPRESSED && BZIP2 && LZMA && LZO && LZ4 + depends on CMDLINE && GZIP_COMPRESSED && BZIP2 && LZMA && LZO && LZ4 && ZSTD default y help Enables tests for compression and decompression routines for simple diff --git a/test/compression.c b/test/compression.c index 82e29c9b86b..eae1884938f 100644 --- a/test/compression.c +++ b/test/compression.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <abuf.h> #include <bootm.h> #include <command.h> #include <gzip.h> @@ -22,6 +23,7 @@ #include <lzma/LzmaTools.h>
#include <linux/lzo.h> +#include <linux/zstd.h> #include <test/compression.h> #include <test/suites.h> #include <test/ut.h> @@ -121,6 +123,23 @@ static const char lz4_compressed[] = "\x9d\x12\x8c\x9d"; static const unsigned long lz4_compressed_size = 276;
+/* zstd -19 -c /tmp/plain.txt > /tmp/plain.zst */ +static const char zstd_compressed[] = + "\x28\xb5\x2f\xfd\x64\x5e\x00\xbd\x05\x00\x02\x0e\x26\x1a\x70\x17" + "\xb8\x0d\x0c\x53\x5c\x9d\x97\xee\xa0\x5d\x84\x89\x3f\x5c\x7a\x78" + "\x00\x80\x80\x0f\xe8\xdf\xaf\x06\x66\xd0\x23\xa6\x7a\x64\x8e\xf4" + "\x0d\x5b\x47\x65\x26\x7e\x81\xdd\x0b\xe7\x5a\x95\x3d\x49\xcc\x67" + "\xe0\x2d\x46\x58\xb6\xac\x64\x16\xf2\xe0\xf8\x16\x17\xaf\xda\x8f" + "\x37\xc0\xc3\x0d\x3b\x89\x57\x15\x1e\x46\x46\x12\x9a\x84\xbe\xa6" + "\xab\xcf\x50\x90\x5f\x78\x01\xd2\xc0\x51\x72\x59\x0b\xea\xab\xf2" + "\xd4\x2b\x2d\x26\x7c\x10\x66\x78\x42\x64\x45\x3f\xa5\x15\x6f\xbd" + "\x4a\x61\xe1\xc8\x27\xc0\xe3\x95\x0c\xf9\xca\x7c\xf5\x13\x30\xc3" + "\x1a\x7c\x7d\xa4\x17\x0b\xff\x14\xa6\x7a\x95\xa0\x34\xbc\xce\x21" + "\x78\x36\x23\x33\x11\x09\x00\x60\x13\x00\x63\xa3\x8e\x28\x94\x55" + "\x15\xb6\x26\x68\x05\x4f\x23\x12\xee\x53\x55\x2d\x44\x2f\x54\x95" + "\x01\xe4\xf4\x6e\xfa"; +static const unsigned long zstd_compressed_size = sizeof(zstd_compressed) - 1; +
#define TEST_BUFFER_SIZE 512
@@ -296,6 +315,45 @@ static int uncompress_using_lz4(struct unit_test_state *uts, return (ret != 0); }
+static int compress_using_zstd(struct unit_test_state *uts, + void *in, unsigned long in_size, + void *out, unsigned long out_max, + unsigned long *out_size) +{ + /* There is no zstd compression in u-boot, so fake it. */ + ut_asserteq(in_size, strlen(plain)); + ut_asserteq_mem(plain, in, in_size); + + if (zstd_compressed_size > out_max) + return -1; + + memcpy(out, zstd_compressed, zstd_compressed_size); + if (out_size) + *out_size = zstd_compressed_size; + + return 0; +} + +static int uncompress_using_zstd(struct unit_test_state *uts, + void *in, unsigned long in_size, + void *out, unsigned long out_max, + unsigned long *out_size) +{ + struct abuf in_buf, out_buf; + int ret; + + abuf_init_set(&in_buf, in, in_size); + abuf_init_set(&out_buf, out, out_max); + + ret = zstd_decompress(&in_buf, &out_buf); + if (ret >= 0) { + *out_size = ret; + ret = 0; + } + + return ret; +} + #define errcheck(statement) if (!(statement)) { \ fprintf(stderr, "\tFailed: %s\n", #statement); \ ret = 1; \ @@ -440,6 +498,13 @@ static int compression_test_lz4(struct unit_test_state *uts) } COMPRESSION_TEST(compression_test_lz4, 0);
+static int compression_test_zstd(struct unit_test_state *uts) +{ + return run_test(uts, "zstd", compress_using_zstd, + uncompress_using_zstd); +} +COMPRESSION_TEST(compression_test_zstd, 0); + static int compress_using_none(struct unit_test_state *uts, void *in, unsigned long in_size, void *out, unsigned long out_max, @@ -530,6 +595,12 @@ static int compression_test_bootm_lz4(struct unit_test_state *uts) } COMPRESSION_TEST(compression_test_bootm_lz4, 0);
+static int compression_test_bootm_zstd(struct unit_test_state *uts) +{ + return run_bootm_test(uts, IH_COMP_ZSTD, compress_using_zstd); +} +COMPRESSION_TEST(compression_test_bootm_zstd, 0); + static int compression_test_bootm_none(struct unit_test_state *uts) { return run_bootm_test(uts, IH_COMP_NONE, compress_using_none);
Brandon Maier
