[U-Boot] [PATCH v4 1/2] QE/FMAN: modify CONFIG_SYS_QE_FMAN_FW_ADDR to CONFIG_SYS_FMAN_FW_ADDR and CONFIG_SYS_QE_FW_ADDR
CONFIG_SYS_QE_FMAN_FW_ADDR is used to both Fman and QE for microcode address. Now using CONFIG_SYS_FMAN_FW_ADDR for Fman microcode address, and CONFIG_SYS_QE_FW_ADDR for QE microcode address.
Signed-off-by: Zhao Qiang B45475@freescale.com --- Changes for v2: - no Changes for v3: - no Changes for v4: - no
README | 9 +++++++-- arch/powerpc/cpu/mpc85xx/cpu_init.c | 2 +- drivers/net/fm/fm.c | 12 ++++++------ drivers/qe/qe.c | 2 +- include/configs/B4860QDS.h | 10 +++++----- include/configs/MPC8569MDS.h | 2 +- include/configs/P1023RDB.h | 2 +- include/configs/P1023RDS.h | 4 ++-- include/configs/P2041RDB.h | 10 +++++----- include/configs/T1040QDS.h | 8 ++++---- include/configs/T1040RDB.h | 8 ++++---- include/configs/T1042RDB_PI.h | 8 ++++---- include/configs/T2080QDS.h | 10 +++++----- include/configs/T4240EMU.h | 2 +- include/configs/T4240QDS.h | 10 +++++----- include/configs/corenet_ds.h | 10 +++++----- include/configs/km/km8309-common.h | 2 +- include/configs/km/kmp204x-common.h | 2 +- include/configs/p1_p2_rdb_pc.h | 2 +- include/configs/p1_twr.h | 2 +- 20 files changed, 61 insertions(+), 56 deletions(-)
diff --git a/README b/README index 176de61..b2b2d73 100644 --- a/README +++ b/README @@ -4445,8 +4445,13 @@ This firmware often needs to be loaded during U-Boot booting, so macros are used to identify the storage device (NOR flash, SPI, etc) and the address within that device.
-- CONFIG_SYS_QE_FMAN_FW_ADDR - The address in the storage device where the firmware is located. The +- CONFIG_SYS_FMAN_FW_ADDR + The address in the storage device where the FMAN microcode is located. The + meaning of this address depends on which CONFIG_SYS_QE_FW_IN_xxx macro + is also specified. + +- CONFIG_SYS_QE_FW_ADDR + The address in the storage device where the QE microcode is located. The meaning of this address depends on which CONFIG_SYS_QE_FW_IN_xxx macro is also specified.
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index b31efb7..ec6eefb 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -743,7 +743,7 @@ void cpu_secondary_init_r(void)
/* load QE firmware from NAND flash to DDR first */ ret = nand_read(&nand_info[0], (loff_t)CONFIG_SYS_QE_FMAN_FW_IN_NAND, - &fw_length, (u_char *)CONFIG_SYS_QE_FMAN_FW_ADDR); + &fw_length, (u_char *)CONFIG_SYS_QE_FW_ADDR);
if (ret && ret == -EUCLEAN) { printf ("NAND read for QE firmware at offset %x failed %d\n", diff --git a/drivers/net/fm/fm.c b/drivers/net/fm/fm.c index bca20b3..400e9dd 100644 --- a/drivers/net/fm/fm.c +++ b/drivers/net/fm/fm.c @@ -350,16 +350,16 @@ int fm_init_common(int index, struct ccsr_fman *reg) { int rc; #if defined(CONFIG_SYS_QE_FMAN_FW_IN_NOR) - void *addr = (void *)CONFIG_SYS_QE_FMAN_FW_ADDR; + void *addr = (void *)CONFIG_SYS_FMAN_FW_ADDR; #elif defined(CONFIG_SYS_QE_FMAN_FW_IN_NAND) size_t fw_length = CONFIG_SYS_QE_FMAN_FW_LENGTH; void *addr = malloc(CONFIG_SYS_QE_FMAN_FW_LENGTH);
- rc = nand_read(&nand_info[0], (loff_t)CONFIG_SYS_QE_FMAN_FW_ADDR, + rc = nand_read(&nand_info[0], (loff_t)CONFIG_SYS_FMAN_FW_ADDR, &fw_length, (u_char *)addr); if (rc == -EUCLEAN) { printf("NAND read of FMAN firmware at offset 0x%x failed %d\n", - CONFIG_SYS_QE_FMAN_FW_ADDR, rc); + CONFIG_SYS_FMAN_FW_ADDR, rc); } #elif defined(CONFIG_SYS_QE_FW_IN_SPIFLASH) struct spi_flash *ucode_flash; @@ -371,7 +371,7 @@ int fm_init_common(int index, struct ccsr_fman *reg) if (!ucode_flash) printf("SF: probe for ucode failed\n"); else { - ret = spi_flash_read(ucode_flash, CONFIG_SYS_QE_FMAN_FW_ADDR, + ret = spi_flash_read(ucode_flash, CONFIG_SYS_FMAN_FW_ADDR, CONFIG_SYS_QE_FMAN_FW_LENGTH, addr); if (ret) printf("SF: read for ucode failed\n"); @@ -381,7 +381,7 @@ int fm_init_common(int index, struct ccsr_fman *reg) int dev = CONFIG_SYS_MMC_ENV_DEV; void *addr = malloc(CONFIG_SYS_QE_FMAN_FW_LENGTH); u32 cnt = CONFIG_SYS_QE_FMAN_FW_LENGTH / 512; - u32 blk = CONFIG_SYS_QE_FMAN_FW_ADDR / 512; + u32 blk = CONFIG_SYS_FMAN_FW_ADDR / 512; struct mmc *mmc = find_mmc_device(CONFIG_SYS_MMC_ENV_DEV);
if (!mmc) @@ -395,7 +395,7 @@ int fm_init_common(int index, struct ccsr_fman *reg) flush_cache((ulong)addr, cnt * 512); } #elif defined(CONFIG_SYS_QE_FMAN_FW_IN_REMOTE) - void *addr = (void *)CONFIG_SYS_QE_FMAN_FW_ADDR; + void *addr = (void *)CONFIG_SYS_FMAN_FW_ADDR; #else void *addr = NULL; #endif diff --git a/drivers/qe/qe.c b/drivers/qe/qe.c index b5ddc4b..b1da75e 100644 --- a/drivers/qe/qe.c +++ b/drivers/qe/qe.c @@ -165,7 +165,7 @@ void qe_init(uint qe_base) /* * Upload microcode to IRAM for those SOCs which do not have ROM in QE. */ - qe_upload_firmware((const void *)CONFIG_SYS_QE_FMAN_FW_ADDR); + qe_upload_firmware((const void *)CONFIG_SYS_QE_FW_ADDR);
/* enable the microcode in IRAM */ out_be32(&qe_immr->iram.iready,QE_IRAM_READY); diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 39c0b6d..d4d606f 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -597,7 +597,7 @@ unsigned long get_board_ddr_clk(void); * env, so we got 0x110000. */ #define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x110000 #elif defined(CONFIG_SDCARD) /* * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is @@ -605,10 +605,10 @@ unsigned long get_board_ddr_clk(void); * 0x2000 (16 blocks), 8 + 1089 + 16 = 1113, enlarge it to 1130. */ #define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1130) +#define CONFIG_SYS_FMAN_FW_ADDR (512 * 1130) #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* * Slave has no ucode locally, it can fetch this from remote. When implementing @@ -618,10 +618,10 @@ unsigned long get_board_ddr_clk(void); * master LAW->the ucode address in master's memory space. */ #define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xFFE00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xFFE00000 #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index d877e8b..5208069 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -494,7 +494,7 @@ extern unsigned long get_clock_freq(void);
/* QE microcode/firmware address */ #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xfff00000 +#define CONFIG_SYS_QE_FW_ADDR 0xfff00000
/* * BOOTP options diff --git a/include/configs/P1023RDB.h b/include/configs/P1023RDB.h index 78a0aa2..7c83362 100644 --- a/include/configs/P1023RDB.h +++ b/include/configs/P1023RDB.h @@ -361,7 +361,7 @@ extern unsigned long get_clock_freq(void); /* Default address of microcode for the Linux Fman driver */ /* QE microcode/firmware address */ #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH)
diff --git a/include/configs/P1023RDS.h b/include/configs/P1023RDS.h index d2aaf98..5d015e0 100644 --- a/include/configs/P1023RDS.h +++ b/include/configs/P1023RDS.h @@ -502,10 +502,10 @@ extern unsigned long get_clock_freq(void); /* Default address of microcode for the Linux Fman driver */ /* QE microcode/firmware address */ #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #else #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x1f00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x1f00000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 6934c61..a02e438 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -508,7 +508,7 @@ unsigned long get_board_sys_clk(unsigned long dummy); * env, so we got 0x110000. */ #define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x110000 #elif defined(CONFIG_SDCARD) /* * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is @@ -516,10 +516,10 @@ unsigned long get_board_sys_clk(unsigned long dummy); * 0x2000 (16 blocks), 8 + 1650 + 16 = 1674, enlarge it to 1680. */ #define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1680) +#define CONFIG_SYS_FMAN_FW_ADDR (512 * 1680) #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* * Slave has no ucode locally, it can fetch this from remote. When implementing @@ -529,10 +529,10 @@ unsigned long get_board_sys_clk(unsigned long dummy); * master LAW->the ucode address in master's memory space. */ #define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xFFE00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xFFE00000 #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 91b511b..0282922 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -579,7 +579,7 @@ unsigned long get_board_ddr_clk(void); * env, so we got 0x110000. */ #define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x110000 #elif defined(CONFIG_SDCARD) /* * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is @@ -587,13 +587,13 @@ unsigned long get_board_ddr_clk(void); * 0x2000 (16 blocks), 8 + 1650 + 16 = 1674, enlarge it to 1680. */ #define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1680) +#define CONFIG_SYS_FMAN_FW_ADDR (512 * 1680) #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/T1040RDB.h b/include/configs/T1040RDB.h index 65b4b26..1ca1a1a 100644 --- a/include/configs/T1040RDB.h +++ b/include/configs/T1040RDB.h @@ -517,7 +517,7 @@ * env, so we got 0x110000. */ #define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x110000 #elif defined(CONFIG_SDCARD) /* * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is @@ -525,13 +525,13 @@ * 0x2000 (16 blocks), 8 + 1650 + 16 = 1674, enlarge it to 1680. */ #define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1680) +#define CONFIG_SYS_FMAN_FW_ADDR (512 * 1680) #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (4 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (4 * CONFIG_SYS_NAND_BLOCK_SIZE) #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/T1042RDB_PI.h b/include/configs/T1042RDB_PI.h index 104bb92..5b248e4 100644 --- a/include/configs/T1042RDB_PI.h +++ b/include/configs/T1042RDB_PI.h @@ -525,7 +525,7 @@ * env, so we got 0x110000. */ #define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x110000 #elif defined(CONFIG_SDCARD) /* * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is @@ -533,13 +533,13 @@ * 0x2000 (16 blocks), 8 + 1650 + 16 = 1674, enlarge it to 1680. */ #define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1680) +#define CONFIG_SYS_FMAN_FW_ADDR (512 * 1680) #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (4 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (4 * CONFIG_SYS_NAND_BLOCK_SIZE) #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/T2080QDS.h b/include/configs/T2080QDS.h index d6d1f93..26828e5 100644 --- a/include/configs/T2080QDS.h +++ b/include/configs/T2080QDS.h @@ -540,7 +540,7 @@ unsigned long get_board_ddr_clk(void); * env, so we got 0x110000. */ #define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x110000 #elif defined(CONFIG_SDCARD) /* * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is @@ -548,10 +548,10 @@ unsigned long get_board_ddr_clk(void); * 0x2000 (16 blocks), 8 + 1650 + 16 = 1674, enlarge it to 1680. */ #define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1680) +#define CONFIG_SYS_FMAN_FW_ADDR (512 * 1680) #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* * Slave has no ucode locally, it can fetch this from remote. When implementing @@ -561,10 +561,10 @@ unsigned long get_board_ddr_clk(void); * master LAW->the ucode address in master's memory space. */ #define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xFFE00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xFFE00000 #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/T4240EMU.h b/include/configs/T4240EMU.h index c81c457..ad5a9a6 100644 --- a/include/configs/T4240EMU.h +++ b/include/configs/T4240EMU.h @@ -98,7 +98,7 @@ #define CONFIG_SYS_INTERLAKEN
diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index 0d43c27..d88b3b5 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -375,7 +375,7 @@ unsigned long get_board_ddr_clk(void); * env, so we got 0x110000. */ #define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x110000 #elif defined(CONFIG_SDCARD) /* * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is @@ -383,10 +383,10 @@ unsigned long get_board_ddr_clk(void); * 0x2000 (16 blocks), 8 + 1650 + 16 = 1674, enlarge it to 1680. */ #define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1680) +#define CONFIG_SYS_FMAN_FW_ADDR (512 * 1680) #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* * Slave has no ucode locally, it can fetch this from remote. When implementing @@ -396,10 +396,10 @@ unsigned long get_board_ddr_clk(void); * master LAW->the ucode address in master's memory space. */ #define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xFFE00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xFFE00000 #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index fa748f7..be00871 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -514,7 +514,7 @@ * env, so we got 0x110000. */ #define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#define CONFIG_SYS_FMAN_FW_ADDR 0x110000 #elif defined(CONFIG_SDCARD) /* * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is @@ -522,10 +522,10 @@ * 0x2000 (16 blocks), 8 + 1650 + 16 = 1674, enlarge it to 1680. */ #define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1680) +#define CONFIG_SYS_FMAN_FW_ADDR (512 * 1680) #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* * Slave has no ucode locally, it can fetch this from remote. When implementing @@ -535,10 +535,10 @@ * master LAW->the ucode address in master's memory space. */ #define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xFFE00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xFFE00000 #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/km/km8309-common.h b/include/configs/km/km8309-common.h index 47355ab..d27911f 100644 --- a/include/configs/km/km8309-common.h +++ b/include/configs/km/km8309-common.h @@ -28,7 +28,7 @@ /* QE microcode/firmware address */ #define CONFIG_SYS_QE_FMAN_FW_IN_NOR /* at end of uboot partition, before env */ -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xF00B0000 +#define CONFIG_SYS_QE_FW_ADDR 0xF00B0000
/* * System IO Config diff --git a/include/configs/km/kmp204x-common.h b/include/configs/km/kmp204x-common.h index 0463fcb..fbe9940 100644 --- a/include/configs/km/kmp204x-common.h +++ b/include/configs/km/kmp204x-common.h @@ -334,7 +334,7 @@ unsigned long get_board_sys_clk(unsigned long dummy); * ucode is stored after env, so we got 0x120000. */ #define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x120000 +#define CONFIG_SYS_QE_FW_ADDR 0x120000 #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH)
diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 95e23ac..93a0aa9 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -769,7 +769,7 @@ #ifdef CONFIG_QE /* QE microcode/firmware address */ #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xefec0000 +#define CONFIG_SYS_QE_FW_ADDR 0xefec0000 #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #endif /* CONFIG_QE */
diff --git a/include/configs/p1_twr.h b/include/configs/p1_twr.h index a7fe90f..f6b76b8 100644 --- a/include/configs/p1_twr.h +++ b/include/configs/p1_twr.h @@ -352,7 +352,7 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #ifdef CONFIG_QE /* QE microcode/firmware address */ #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xefec0000 +#define CONFIG_SYS_QE_FW_ADDR 0xefec0000 #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #endif /* CONFIG_QE */
Changes for v2:
- no
Changes for v3:
- no
Changes for v4:
- no
Please double check the change for km. It has compiling error. It seems to use FMAN but you changed it to QE.
York
York Sun
Zhao Qiang
