[U-Boot] Bad FIT image found
I'm trying to boot my rtos OSE with the bootm command but it fails.
I have made a uimage for the rtos and download it to the target at address 0x1000000.
I've also downloaded a flat device tree blob to address 0x400000.
u-boot says
=> bootm 0x1000000 - 0x400000
WARNING: adjusting available memory to 30000000
## Booting kernel from Legacy Image at 01000000 ...
Image Name: kalle
Image Type: PowerPC Linux Kernel Image (uncompressed)
Data Size: 3232544 Bytes = 3.1 MB
Load Address: 00200000
Entry Point: 00200000
Verifying Checksum ... OK
## Flattened Device Tree blob at 00400000
Booting using the fdt blob at 0x400000
Loading Kernel Image ... OK
OK
ERROR: image is not a fdt - must RESET the board to recover.
U-Boot 2009.11-00002-g56804ff (May 14 2010 - 09:57:11)
When I do fdt header on the blob u-boot says
=> fdt header
magic: 0xd00dfeed
totalsize: 0xa34a (41802)
off_dt_struct: 0x38
off_dt_strings: 0x8df4
off_mem_rsvmap: 0x28
version: 17
last_comp_version: 16
boot_cpuid_phys: 0x0
size_dt_strings: 0x556
size_dt_struct: 0x8dbc
number mem_rsv: 0x0
That looks OK to me.
When I do iminfo on the blob u-boot says
=> iminfo
## Checking Image at 00400000 ...
FIT image found
Bad FIT image format!
Can anyone tell me what the problem is?
Leif Sörman Software Engineer R&D OSE Labs Core Enea Skalholtsgatan 9, Box 1033, SE-164 21 Kista, Sweden Direct: +46 8 5071 4218 Mobile: +46 70 971 4218 leif.sorman@enea.com www.enea.com
This message, including attachments, is CONFIDENTIAL. It may also be privileged or otherwise protected by law. If you received this email by mistake please let us know by reply and then delete it from your system; you should not copy it or disclose its contents to anyone.
Leif Sörman
