[U-Boot] [PATCH 1/2][v4] armv8: ls2080a: Reorganise NAND_BOOT code in config flag
Add CONFIG_NAND_BOOT config flag to organise NAND_BOOT specific code in config flag like -nand-boot specfic errata errata_rcw_src() -CONFIG_SYS_NAND_U_BOOT_DST,etc
Signed-off-by: Santan Kumar santan.kumar@nxp.com Signed-off-by: Priyanka Jain priyanka.jain@nxp.com Signed-off-by: Abhimanyu Saini abhimanyu.saini@nxp.com --- Changes for v4: Rebased to latest codebase Incorporated York's comments to remove CONFIG_SPL and move CONFIG_SPL_NAND_SUPPORT to kconfig
arch/arm/cpu/armv8/fsl-layerscape/soc.c | 2 +- configs/ls2080aqds_nand_defconfig | 1 + configs/ls2080ardb_nand_defconfig | 1 + include/configs/ls2080a_common.h | 2 ++ include/configs/ls2080aqds.h | 4 +++- 5 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 9e3cdd7..76e3af0 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -134,7 +134,7 @@ void erratum_a009635(void)
static void erratum_rcw_src(void) { -#if defined(CONFIG_SPL) +#if defined(CONFIG_SPL) && defined(CONFIG_NAND_BOOT) u32 __iomem *dcfg_ccsr = (u32 __iomem *)DCFG_BASE; u32 __iomem *dcfg_dcsr = (u32 __iomem *)DCFG_DCSR_BASE; u32 val; diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 2a649c5..7fe4262 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -10,6 +10,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_NAND_BOOT=y CONFIG_SYS_EXTRA_OPTIONS="NAND, LS2080A" CONFIG_BOOTDELAY=10 CONFIG_SPL=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index 81987fe..7c45541 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -10,6 +10,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_NAND_BOOT=y CONFIG_SYS_EXTRA_OPTIONS="NAND, LS2080A" CONFIG_BOOTDELAY=10 CONFIG_SPL=y diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 427f623..12078c3 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -222,8 +222,10 @@ unsigned long long get_qixis_addr(void); #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" #define CONFIG_SPL_TEXT_BASE 0x1800a000
+#ifdef CONFIG_NAND_BOOT #define CONFIG_SYS_NAND_U_BOOT_DST 0x80400000 #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_NAND_U_BOOT_DST +#endif #define CONFIG_SYS_SPL_MALLOC_SIZE 0x00100000 #define CONFIG_SYS_SPL_MALLOC_START 0x80200000 #define CONFIG_SYS_MONITOR_LEN (640 * 1024) diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index beacb99..4c48562 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -197,7 +197,8 @@ unsigned long get_board_ddr_clk(void); FTIM2_GPCM_TWP(0x3E)) #define CONFIG_SYS_CS3_FTIM3 0x0
-#if defined(CONFIG_SPL) && defined(CONFIG_NAND) +#if defined(CONFIG_SPL) +#if defined(CONFIG_NAND_BOOT) #define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NOR0_CSPR_EXT #define CONFIG_SYS_CSPR1 CONFIG_SYS_NOR0_CSPR_EARLY #define CONFIG_SYS_CSPR1_FINAL CONFIG_SYS_NOR0_CSPR @@ -233,6 +234,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SPL_PAD_TO 0x20000 #define CONFIG_SYS_NAND_U_BOOT_OFFS (256 * 1024) #define CONFIG_SYS_NAND_U_BOOT_SIZE (640 * 1024) +#endif #else #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT #define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR_EARLY
Signed-off-by: Santan Kumar santan.kumar@nxp.com Signed-off-by: Priyanka Jain priyanka.jain@nxp.com Signed-off-by: Abhimanyu Saini abhimanyu.saini@nxp.com --- Changes for v4: Rebased to latest codebase Incorporated York's comments to move CONFIG_SPL_MMC_SUPPORT to kconfig
Depends on York MMU patches: http://patchwork.ozlabs.org/bundle/yorksun/Rewrite_MMU/ For correct type of image creation: https://patchwork.ozlabs.org/patch/671466/
arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 6 +-- .../cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c | 6 +-- board/freescale/ls2080a/ls2080a.c | 6 +-- board/freescale/ls2080aqds/eth.c | 8 +--- board/freescale/ls2080aqds/ls2080aqds.c | 4 +- configs/ls2080aqds_sdcard_defconfig | 54 ++++++++++++++++++++++ include/configs/ls2080aqds.h | 9 +++- 7 files changed, 75 insertions(+), 18 deletions(-) create mode 100644 configs/ls2080aqds_sdcard_defconfig
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index cebbb0f..58d63df 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -465,7 +465,7 @@ int cpu_eth_init(bd_t *bis) { int error = 0;
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) error = fsl_mc_ldpaa_init(bis); #endif #ifdef CONFIG_FMAN_ENET @@ -608,7 +608,7 @@ phys_size_t board_reserve_ram_top(phys_size_t ram_size) { phys_size_t ram_top = ram_size;
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) /* The start address of MC reserved memory needs to be aligned. */ ram_top -= mc_get_dram_block_size(); ram_top &= ~(CONFIG_SYS_MC_RSV_MEM_ALIGN - 1); @@ -723,7 +723,7 @@ void dram_init_banksize(void) } #endif /* CONFIG_SYS_MEM_RESERVE_SECURE */
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) /* Assign memory for MC */ #ifdef CONFIG_SYS_DDR_BLOCK3_BASE if (gd->bd->bi_dram[2].size >= diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c index 955e0b7..ef97556 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c @@ -18,7 +18,7 @@ static u8 serdes1_prtcl_map[SERDES_PRCTL_COUNT]; static u8 serdes2_prtcl_map[SERDES_PRCTL_COUNT]; #endif
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) int xfi_dpmac[XFI8 + 1]; int sgmii_dpmac[SGMII16 + 1]; #endif @@ -110,7 +110,7 @@ void serdes_init(u32 sd, u32 sd_addr, u32 rcwsr, u32 sd_prctl_mask, debug("Unknown SerDes lane protocol %d\n", lane_prtcl); else { serdes_prtcl_map[lane_prtcl] = 1; -#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) switch (lane_prtcl) { case QSGMII_A: case QSGMII_B: @@ -141,7 +141,7 @@ void serdes_init(u32 sd, u32 sd_addr, u32 rcwsr, u32 sd_prctl_mask,
void fsl_serdes_init(void) { -#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) int i , j;
for (i = XFI1, j = 1; i <= XFI8; i++, j++) diff --git a/board/freescale/ls2080a/ls2080a.c b/board/freescale/ls2080a/ls2080a.c index 9e7701d..b357eaa 100644 --- a/board/freescale/ls2080a/ls2080a.c +++ b/board/freescale/ls2080a/ls2080a.c @@ -64,13 +64,13 @@ int board_eth_init(bd_t *bis) error = smc91111_initialize(0, CONFIG_SMC91111_BASE); #endif
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) error = cpu_eth_init(bis); #endif return error; }
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) void fdt_fixup_board_enet(void *fdt) { int offset; @@ -128,7 +128,7 @@ int ft_board_setup(void *blob, bd_t *bd)
fdt_fixup_memory_banks(blob, base, size, 2);
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) fdt_fixup_board_enet(blob); #endif
diff --git a/board/freescale/ls2080aqds/eth.c b/board/freescale/ls2080aqds/eth.c index 59361e9..302ff76 100644 --- a/board/freescale/ls2080aqds/eth.c +++ b/board/freescale/ls2080aqds/eth.c @@ -22,7 +22,7 @@
#define MC_BOOT_ENV_VAR "mcinitcmd"
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) /* - In LS2080A there are only 16 SERDES lanes, spread across 2 SERDES banks. * Bank 1 -> Lanes A, B, C, D, E, F, G, H * Bank 2 -> Lanes A,B, C, D, E, F, G, H @@ -834,8 +834,8 @@ void ls2080a_handle_phy_interface_xsgmii(int i) int board_eth_init(bd_t *bis) { int error; +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) char *mc_boot_env_var; -#ifdef CONFIG_FSL_MC_ENET struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; int serdes1_prtcl = (in_le32(&gur->rcwsr[28]) & FSL_CHASSIS3_RCWSR28_SRDS1_PRTCL_MASK) @@ -918,7 +918,3 @@ int board_eth_init(bd_t *bis) error = pci_eth_init(bis); return error; } - -#ifdef CONFIG_FSL_MC_ENET - -#endif diff --git a/board/freescale/ls2080aqds/ls2080aqds.c b/board/freescale/ls2080aqds/ls2080aqds.c index 6da9c6c..f36fb98 100644 --- a/board/freescale/ls2080aqds/ls2080aqds.c +++ b/board/freescale/ls2080aqds/ls2080aqds.c @@ -280,7 +280,7 @@ int arch_misc_init(void) } #endif
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) void fdt_fixup_board_enet(void *fdt) { int offset; @@ -336,7 +336,7 @@ int ft_board_setup(void *blob, bd_t *bd)
fsl_fdt_fixup_dr_usb(blob, bd);
diff --git a/configs/ls2080aqds_sdcard_defconfig b/configs/ls2080aqds_sdcard_defconfig new file mode 100644 index 0000000..e6f55dd --- /dev/null +++ b/configs/ls2080aqds_sdcard_defconfig @@ -0,0 +1,54 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS2080AQDS=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, LS2080A" +CONFIG_SD_BOOT=y +CONFIG_BOOTDELAY=10 +CONFIG_SPL=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 +CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_OF_EMBED=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_DM_SPI_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y +CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y +CONFIG_FSL_QSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_STORAGE=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 4c48562..e57e038 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -165,12 +165,14 @@ unsigned long get_board_ddr_clk(void); #define QIXIS_LBMAP_DFLTBANK 0x00 #define QIXIS_LBMAP_ALTBANK 0x04 #define QIXIS_LBMAP_NAND 0x09 +#define QIXIS_LBMAP_SD 0x00 #define QIXIS_LBMAP_QSPI 0x0f #define QIXIS_RST_CTL_RESET 0x31 #define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 #define QIXIS_RCFG_CTL_RECONFIG_START 0x21 #define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 #define QIXIS_RCW_SRC_NAND 0x107 +#define QIXIS_RCW_SRC_SD 0x40 #define QIXIS_RCW_SRC_QSPI 0x62 #define QIXIS_RST_FORCE_MEM 0x01
@@ -234,6 +236,11 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SPL_PAD_TO 0x20000 #define CONFIG_SYS_NAND_U_BOOT_OFFS (256 * 1024) #define CONFIG_SYS_NAND_U_BOOT_SIZE (640 * 1024) +#elif defined(CONFIG_SD_BOOT) +#define CONFIG_ENV_OFFSET 0x200000 +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SIZE 0x20000 #endif #else #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT @@ -393,7 +400,7 @@ unsigned long get_board_ddr_clk(void); #endif /* CONFIG_SECURE_BOOT */
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) #define CONFIG_FSL_MEMAC #define CONFIG_PHYLIB #define CONFIG_PHYLIB_10G
Depends on York MMU patches: https://emea01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fpatchwork.... For correct type of image creation: https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpatchwork...
Please update MAINTAINERS file and add commit message. Please squash your patch which enables PPA for this boot config http://patchwork.ozlabs.org/patch/741504/
York
-----Original Message----- From: York Sun [mailto:york.sun@nxp.com] Sent: Wednesday, April 12, 2017 9:13 PM To: Santan Kumar santan.kumar@nxp.com; u-boot@lists.denx.de Cc: Priyanka Jain priyanka.jain@nxp.com; Abhimanyu Saini abhimanyu.saini@nxp.com Subject: Re: [PATCH 2/2][v4] armv8: ls2080aqds: Add support for SD boot
hwork.ozlabs.org%2Fbundle%2Fyorksun%2FRewrite_MMU%2F&data=01%7 C01%7Cyo
rk.sun%40nxp.com%7Cb6b2df7806744cde8d4508d47a8065e0%7C686ea1d3bc 2b4c6f
a92cd99c5c301635%7C0&sdata=AvZVek9YBqogA8SDUuILS1EFkubGSxa7Uqh QY9cYi7s
%3D&reserved=0 For correct type of image creation:
chwork.ozlabs.org%2Fpatch%2F671466%2F&data=01%7C01%7Cyork.sun%40 nxp.co
m%7Cb6b2df7806744cde8d4508d47a8065e0%7C686ea1d3bc2b4c6fa92cd99c5 c30163
5%7C0&sdata=i7xPTeYu4AGy%2BzGCeGvptGmTTR8H8roYkWk46%2FiibRM% 3D&reserve
d=0
York
[Santan Kumar] Ok, I will update the MAINTAINERS file and PPA patch. In commit message: This patch adds SD boot support for LS2080aqds board. The SD boot image need to be programmed into the sdcard first. Then the booting will start from sd card. Is it ok or do you want me to add any specific information?
On 04/12/2017 11:18 PM, Santan Kumar wrote:
<snip>
York
That's useless. Why do you add SD boot now? If there is a reason we couldn't have it before, but we can have it now, please explain.
If there is any particular instruction for SD, please add to the README file.
York
-----Original Message----- From: York Sun [mailto:york.sun@nxp.com] Sent: Thursday, April 13, 2017 9:15 PM To: Santan Kumar santan.kumar@nxp.com; u-boot@lists.denx.de Cc: Priyanka Jain priyanka.jain@nxp.com; Abhimanyu Saini abhimanyu.saini@nxp.com Subject: Re: [PATCH 2/2][v4] armv8: ls2080aqds: Add support for SD boot
<snip>
York
York
Sd-boot patches has been in-review in upstream from a long time. Also RDB board does not support SD-boot. As a feature SD-boot feature can only be tested on QDS. We will update README with proper instructions.
Priyanka
Can we get rid of the extra options for NAND? I think it can be replaced by CONFIG_NAND_BOOT, can't it?
I have sent a patch to get rid of the LS2080A do you don't have to worry about that. http://patchwork.ozlabs.org/patch/746782/
This is exactly what I was thinking. So we don't need the CONFIG_NAND macro. After this patch, can you sent another clean up patch to remove other CONFIG_NAND macros? You don't have to respin this patch.
York
-----Original Message----- From: York Sun [mailto:york.sun@nxp.com] Sent: Monday, April 10, 2017 10:15 PM To: Santan Kumar santan.kumar@nxp.com; u-boot@lists.denx.de Cc: Priyanka Jain priyanka.jain@nxp.com; Abhimanyu Saini abhimanyu.saini@nxp.com Subject: Re: [PATCH 1/2][v4] armv8: ls2080a: Reorganise NAND_BOOT code in config flag
code
[Santan Kumar] CONFIG_NAND_BOOT has been added for the requirements of NAND boot specification While NAND is being used for NAND support specification both are using for difference purpose.
[Santan Kumar] yes, After this patch I don't need LS2080A in extra option. Do I need to send next version to remove this or you will take care in your patch?
York
code
OK. I will let it go for now. In long term we will convert this option to Kconfig.
I will take care of it.
York
Priyanka Jain
Santan Kumar
York Sun
