[U-Boot] [PATCH 01/15] powerpc/fsl-pci: Add generic code to setup PCIe controllers
Since all the PCIe controllers are connected over SERDES on the SoCs we can utilize is_serdes_configured() to determine if a controller is enabled. After which we can setup the ATMUs and LAWs for the controller in a common fashion and allow board code to specify what the controller is connected to for reporting reasons.
We also provide a per controller (rather than all) for some systems that may have special requirements.
Finally, we refactor the code used by the P1022DS to utilize the new generic code.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/include/asm/fsl_pci.h | 10 +++ board/freescale/p1022ds/p1022ds.c | 67 +------------------ drivers/pci/fsl_pci_init.c | 127 ++++++++++++++++++++++++++++++++++++ 3 files changed, 139 insertions(+), 65 deletions(-)
diff --git a/arch/powerpc/include/asm/fsl_pci.h b/arch/powerpc/include/asm/fsl_pci.h index 5cbe139..15ab50d 100644 --- a/arch/powerpc/include/asm/fsl_pci.h +++ b/arch/powerpc/include/asm/fsl_pci.h @@ -22,6 +22,8 @@ #define __FSL_PCI_H_
#include <asm/fsl_law.h> +#include <asm/fsl_serdes.h> +#include <pci.h>
int fsl_setup_hose(struct pci_controller *hose, unsigned long addr); int fsl_is_pci_agent(struct pci_controller *hose); @@ -172,6 +174,9 @@ struct fsl_pci_info {
int fsl_pci_init_port(struct fsl_pci_info *pci_info, struct pci_controller *hose, int busno); +int fsl_pcie_init_ctrl(int busno, u32 devdisr, enum srds_prtcl dev, + struct fsl_pci_info *pci_info); +int fsl_pcie_init_board(int busno);
#define SET_STD_PCI_INFO(x, num) \ { \ @@ -220,6 +225,7 @@ int fsl_pci_init_port(struct fsl_pci_info *pci_info, FT_FSL_PCIE2_SETUP; \ FT_FSL_PCIE3_SETUP; \ FT_FSL_PCIE4_SETUP; +#define FT_FSL_PCIE_SETUP FT_FSL_PCI_SETUP #elif defined(CONFIG_MPC85xx) #define FSL_PCI_COMPAT "fsl,mpc8540-pci" #define FSL_PCIE_COMPAT "fsl,mpc8548-pcie" @@ -229,6 +235,10 @@ int fsl_pci_init_port(struct fsl_pci_info *pci_info, FT_FSL_PCIE1_SETUP; \ FT_FSL_PCIE2_SETUP; \ FT_FSL_PCIE3_SETUP; +#define FT_FSL_PCIE_SETUP \ + FT_FSL_PCIE1_SETUP; \ + FT_FSL_PCIE2_SETUP; \ + FT_FSL_PCIE3_SETUP; #elif defined(CONFIG_MPC86xx) #define FSL_PCI_COMPAT "fsl,mpc8610-pci" #define FSL_PCIE_COMPAT "fsl,mpc8641-pcie" diff --git a/board/freescale/p1022ds/p1022ds.c b/board/freescale/p1022ds/p1022ds.c index 7cb549b..fc62a00 100644 --- a/board/freescale/p1022ds/p1022ds.c +++ b/board/freescale/p1022ds/p1022ds.c @@ -200,7 +200,7 @@ static u8 serdes_dev_slot[][SATA2 + 1] = { * Returns the name of the slot to which the PCIe or SATA controller is * connected */ -const char *serdes_slot_name(enum srds_prtcl device) +const char *board_serdes_name(enum srds_prtcl device) { ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; u32 pordevsr = in_be32(&gur->pordevsr); @@ -215,73 +215,10 @@ const char *serdes_slot_name(enum srds_prtcl device) return "Nothing"; }
-static void configure_pcie(struct fsl_pci_info *info, - struct pci_controller *hose, - const char *connected) -{ - static int bus_number = 0; - int is_endpoint; - - set_next_law(info->mem_phys, law_size_bits(info->mem_size), info->law); - set_next_law(info->io_phys, law_size_bits(info->io_size), info->law); - is_endpoint = fsl_setup_hose(hose, info->regs); - printf("PCIE%u: connected to %s as %s (base addr %lx)\n", - info->pci_num, connected, - is_endpoint ? "Endpoint" : "Root Complex", info->regs); - bus_number = fsl_pci_init_port(info, hose, bus_number); -} - -#ifdef CONFIG_PCIE1 -static struct pci_controller pcie1_hose; -#endif - -#ifdef CONFIG_PCIE2 -static struct pci_controller pcie2_hose; -#endif - -#ifdef CONFIG_PCIE3 -static struct pci_controller pcie3_hose; -#endif - #ifdef CONFIG_PCI void pci_init_board(void) { - ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; - struct fsl_pci_info pci_info; - u32 devdisr = in_be32(&gur->devdisr); - -#ifdef CONFIG_PCIE1 - if (is_serdes_configured(PCIE1) && !(devdisr & MPC85xx_DEVDISR_PCIE)) { - SET_STD_PCIE_INFO(pci_info, 1); - configure_pcie(&pci_info, &pcie1_hose, serdes_slot_name(PCIE1)); - } else { - printf("PCIE1: disabled\n"); - } -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE); /* disable */ -#endif - -#ifdef CONFIG_PCIE2 - if (is_serdes_configured(PCIE2) && !(devdisr & MPC85xx_DEVDISR_PCIE2)) { - SET_STD_PCIE_INFO(pci_info, 2); - configure_pcie(&pci_info, &pcie2_hose, serdes_slot_name(PCIE2)); - } else { - printf("PCIE2: disabled\n"); - } -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE2); /* disable */ -#endif - -#ifdef CONFIG_PCIE3 - if (is_serdes_configured(PCIE3) && !(devdisr & MPC85xx_DEVDISR_PCIE3)) { - SET_STD_PCIE_INFO(pci_info, 3); - configure_pcie(&pci_info, &pcie3_hose, serdes_slot_name(PCIE3)); - } else { - printf("PCIE3: disabled\n"); - } -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE3); /* disable */ -#endif + fsl_pcie_init_board(0); } #endif
diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c index 71ab02b..64c0198 100644 --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -18,6 +18,8 @@ */
#include <common.h> +#include <malloc.h> +#include <asm/fsl_serdes.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -513,6 +515,131 @@ void fsl_pci_config_unlock(struct pci_controller *hose) } }
+#if defined(CONFIG_PCIE1) || defined(CONFIG_PCIE2) || \ + defined(CONFIG_PCIE3) || defined(CONFIG_PCIE4) +int fsl_configure_pcie(struct fsl_pci_info *info, + struct pci_controller *hose, + const char *connected, int busno) +{ + int is_endpoint; + + set_next_law(info->mem_phys, law_size_bits(info->mem_size), info->law); + set_next_law(info->io_phys, law_size_bits(info->io_size), info->law); + is_endpoint = fsl_setup_hose(hose, info->regs); + printf("PCIE%u: connected to %s as %s (base addr %lx)\n", + info->pci_num, connected, + is_endpoint ? "Endpoint" : "Root Complex", info->regs); + return fsl_pci_init_port(info, hose, busno); +} + +#if defined(CONFIG_FSL_CORENET) + #define _DEVDISR_PCIE1 FSL_CORENET_DEVDISR_PCIE1 + #define _DEVDISR_PCIE2 FSL_CORENET_DEVDISR_PCIE2 + #define _DEVDISR_PCIE3 FSL_CORENET_DEVDISR_PCIE3 + #define _DEVDISR_PCIE4 FSL_CORENET_DEVDISR_PCIE4 + #define CONFIG_SYS_MPC8xxx_GUTS_ADDR CONFIG_SYS_MPC85xx_GUTS_ADDR +#elif defined(CONFIG_MPC85xx) + #define _DEVDISR_PCIE1 MPC85xx_DEVDISR_PCIE + #define _DEVDISR_PCIE2 MPC85xx_DEVDISR_PCIE2 + #define _DEVDISR_PCIE3 MPC85xx_DEVDISR_PCIE3 + #define _DEVDISR_PCIE4 0 + #define CONFIG_SYS_MPC8xxx_GUTS_ADDR CONFIG_SYS_MPC85xx_GUTS_ADDR +#elif defined(CONFIG_MPC86xx) + #define _DEVDISR_PCIE1 MPC86xx_DEVDISR_PCIE1 + #define _DEVDISR_PCIE2 MPC86xx_DEVDISR_PCIE2 + #define _DEVDISR_PCIE3 0 + #define _DEVDISR_PCIE4 0 + #define CONFIG_SYS_MPC8xxx_GUTS_ADDR \ + (&((immap_t *)CONFIG_SYS_IMMR)->im_gur) +#else +#error "No defines for DEVDISR_PCIE" +#endif + +/* Implement a dummy function for those platforms w/o SERDES */ +static const char *__board_serdes_name(enum srds_prtcl device) +{ + return NULL; +} + +__attribute__((weak, alias("__board_serdes_name"))) const char * +board_serdes_name(enum srds_prtcl device); + +static u32 devdisr_mask[] = { + _DEVDISR_PCIE1, + _DEVDISR_PCIE2, + _DEVDISR_PCIE3, + _DEVDISR_PCIE4, +}; + +int fsl_pcie_init_ctrl(int busno, u32 devdisr, enum srds_prtcl dev, + struct fsl_pci_info *pci_info) +{ + struct pci_controller *hose; + int num = dev - PCIE1; + + hose = calloc(1, sizeof(struct pci_controller)); + if (!hose) + return busno; + + if (is_serdes_configured(dev) && !(devdisr & devdisr_mask[num])) { + busno = fsl_configure_pcie(pci_info, hose, + board_serdes_name(dev), busno); + } else { + printf("PCIE%d: disabled\n", num + 1); + } + + return busno; +} + +int fsl_pcie_init_board(int busno) +{ + struct fsl_pci_info pci_info; + ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC8xxx_GUTS_ADDR; + u32 devdisr = in_be32(&gur->devdisr); + +#ifdef CONFIG_PCIE1 + SET_STD_PCIE_INFO(pci_info, 1); + busno = fsl_pcie_init_ctrl(busno, devdisr, PCIE1, &pci_info); +#else + setbits_be32(&gur->devdisr, _DEVDISR_PCIE1); /* disable */ +#endif + +#ifdef CONFIG_PCIE2 + SET_STD_PCIE_INFO(pci_info, 2); + busno = fsl_pcie_init_ctrl(busno, devdisr, PCIE2, &pci_info); +#else + setbits_be32(&gur->devdisr, _DEVDISR_PCIE2); /* disable */ +#endif + +#ifdef CONFIG_PCIE3 + SET_STD_PCIE_INFO(pci_info, 3); + busno = fsl_pcie_init_ctrl(busno, devdisr, PCIE3, &pci_info); +#else + setbits_be32(&gur->devdisr, _DEVDISR_PCIE3); /* disable */ +#endif + +#ifdef CONFIG_PCIE4 + SET_STD_PCIE_INFO(pci_info, 4); + busno = fsl_pcie_init_ctrl(busno, devdisr, PCIE4, &pci_info); +#else + setbits_be32(&gur->devdisr, _DEVDISR_PCIE4); /* disable */ +#endif + + return busno; +} +#else +int fsl_pcie_init_ctrl(int busno, u32 devdisr, enum srds_prtcl dev, + struct fsl_pci_info *pci_info) +{ + return busno; +} + +int fsl_pcie_init_board(int busno) +{ + return busno; +} +#endif + #ifdef CONFIG_OF_BOARD_SETUP #include <libfdt.h> #include <fdt_support.h>
Remove duplicated code in MPC8572DS board and utliize the common fsl_pcie_init_board(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/mpc8572ds/law.c | 8 +-- board/freescale/mpc8572ds/mpc8572ds.c | 100 ++++++-------------------------- 2 files changed, 20 insertions(+), 88 deletions(-)
diff --git a/board/freescale/mpc8572ds/law.c b/board/freescale/mpc8572ds/law.c index e13bb53..7c63f84 100644 --- a/board/freescale/mpc8572ds/law.c +++ b/board/freescale/mpc8572ds/law.c @@ -1,5 +1,5 @@ /* - * Copyright 2008 Freescale Semiconductor, Inc. + * Copyright 2008, 2010 Freescale Semiconductor, Inc. * * (C) Copyright 2000 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. @@ -29,12 +29,6 @@
struct law_entry law_table[] = { SET_LAW(CONFIG_SYS_FLASH_BASE_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_LBC), - SET_LAW(CONFIG_SYS_PCIE1_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCIE_1), - SET_LAW(CONFIG_SYS_PCIE1_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_1), - SET_LAW(CONFIG_SYS_PCIE2_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCIE_2), - SET_LAW(CONFIG_SYS_PCIE2_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_2), - SET_LAW(CONFIG_SYS_PCIE3_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCIE_3), - SET_LAW(CONFIG_SYS_PCIE3_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_3), SET_LAW(PIXIS_BASE_PHYS, LAW_SIZE_4K, LAW_TRGT_IF_LBC), SET_LAW(CONFIG_SYS_NAND_BASE_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_LBC), }; diff --git a/board/freescale/mpc8572ds/mpc8572ds.c b/board/freescale/mpc8572ds/mpc8572ds.c index c217c27..2b269f2 100644 --- a/board/freescale/mpc8572ds/mpc8572ds.c +++ b/board/freescale/mpc8572ds/mpc8572ds.c @@ -148,107 +148,45 @@ phys_size_t fixed_sdram (void)
#endif
-#ifdef CONFIG_PCIE1 -static struct pci_controller pcie1_hose; -#endif - -#ifdef CONFIG_PCIE2 -static struct pci_controller pcie2_hose; -#endif +#ifdef CONFIG_PCI +static const char *slot_names[] = { + [PCIE1] = "Slot 2", + [PCIE2] = "Slot 1", + [PCIE3] = "ULI", +};
-#ifdef CONFIG_PCIE3 -static struct pci_controller pcie3_hose; -#endif +const char *board_serdes_name(enum srds_prtcl device) +{ + return slot_names[device]; +}
-#ifdef CONFIG_PCI void pci_init_board(void) { - volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - struct fsl_pci_info pci_info[3]; - u32 devdisr, pordevsr, io_sel, temp32; - int first_free_busno = 0; - int num = 0; + struct pci_controller *hose;
- int pcie_ep, pcie_configured; + fsl_pcie_init_board(0);
- devdisr = in_be32(&gur->devdisr); - pordevsr = in_be32(&gur->pordevsr); - io_sel = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19; + hose = find_hose_by_cfg_addr((void *)(CONFIG_SYS_PCIE3_ADDR));
- debug (" pci_init_board: devdisr=%x, io_sel=%x\n", devdisr, io_sel); + if (hose) { + u32 temp32; + u8 uli_busno = hose->first_busno + 2;
- puts("\n"); -#ifdef CONFIG_PCIE3 - pcie_configured = is_serdes_configured(PCIE3); - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE3)){ - SET_STD_PCIE_INFO(pci_info[num], 3); - pcie_ep = fsl_setup_hose(&pcie3_hose, pci_info[num].regs); - printf("PCIE3: connected to ULI as %s (base addr %lx)\n", - pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie3_hose, first_free_busno); /* * Activate ULI1575 legacy chip by performing a fake * memory access. Needed to make ULI RTC work. * Device 1d has the first on-board memory BAR. */ - pci_hose_read_config_dword(&pcie3_hose, PCI_BDF(2, 0x1d, 0), + pci_hose_read_config_dword(hose, PCI_BDF(uli_busno, 0x1d, 0), PCI_BASE_ADDRESS_1, &temp32); + if (temp32 >= CONFIG_SYS_PCIE3_MEM_BUS) { - void *p = pci_mem_to_virt(PCI_BDF(2, 0x1d, 0), + void *p = pci_mem_to_virt(PCI_BDF(uli_busno, 0x1d, 0), temp32, 4, 0); debug(" uli1572 read to %p\n", p); in_be32(p); } - } else { - printf("PCIE3: disabled\n"); } - puts("\n"); -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE3); /* disable */ -#endif - -#ifdef CONFIG_PCIE2 - pcie_configured = is_serdes_configured(PCIE2); - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE2)){ - SET_STD_PCIE_INFO(pci_info[num], 2); - pcie_ep = fsl_setup_hose(&pcie2_hose, pci_info[num].regs); - printf("PCIE2: connected to Slot 1 as %s (base addr %lx)\n", - pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie2_hose, first_free_busno); - } else { - printf("PCIE2: disabled\n"); - } - - puts("\n"); -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE2); /* disable */ -#endif - -#ifdef CONFIG_PCIE1 - pcie_configured = is_serdes_configured(PCIE1); - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ - SET_STD_PCIE_INFO(pci_info[num], 1); - pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); - printf("PCIE1: connected to Slot 2 as %s (base addr %lx)\n", - pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie1_hose, first_free_busno); - } else { - printf("PCIE1: disabled\n"); - } - - puts("\n"); -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE); /* disable */ -#endif } #endif
Remove duplicated code in P2020DS board and utliize the common fsl_pcie_init_board(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/p2020ds/law.c | 8 +-- board/freescale/p2020ds/p2020ds.c | 114 ++++--------------------------------- 2 files changed, 12 insertions(+), 110 deletions(-)
diff --git a/board/freescale/p2020ds/law.c b/board/freescale/p2020ds/law.c index 28ed2ed..91642a9 100644 --- a/board/freescale/p2020ds/law.c +++ b/board/freescale/p2020ds/law.c @@ -1,5 +1,5 @@ /* - * Copyright 2008-2009 Freescale Semiconductor, Inc. + * Copyright 2008-2010 Freescale Semiconductor, Inc. * * (C) Copyright 2000 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. @@ -29,12 +29,6 @@
struct law_entry law_table[] = { SET_LAW(CONFIG_SYS_FLASH_BASE_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_LBC), - SET_LAW(CONFIG_SYS_PCIE1_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCIE_1), - SET_LAW(CONFIG_SYS_PCIE1_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_1), - SET_LAW(CONFIG_SYS_PCIE2_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCIE_2), - SET_LAW(CONFIG_SYS_PCIE2_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_2), - SET_LAW(CONFIG_SYS_PCIE3_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCIE_3), - SET_LAW(CONFIG_SYS_PCIE3_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_3), SET_LAW(PIXIS_BASE_PHYS, LAW_SIZE_4K, LAW_TRGT_IF_LBC), SET_LAW(CONFIG_SYS_NAND_BASE_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_LBC), }; diff --git a/board/freescale/p2020ds/p2020ds.c b/board/freescale/p2020ds/p2020ds.c index 07b0801..727de69 100644 --- a/board/freescale/p2020ds/p2020ds.c +++ b/board/freescale/p2020ds/p2020ds.c @@ -175,113 +175,21 @@ phys_size_t fixed_sdram(void)
#endif
-#ifdef CONFIG_PCIE1 -static struct pci_controller pcie1_hose; -#endif - -#ifdef CONFIG_PCIE2 -static struct pci_controller pcie2_hose; -#endif +#ifdef CONFIG_PCI +static const char *slot_names[] = { + [PCIE1] = "Slot 2", + [PCIE2] = "ULI", + [PCIE3] = "Slot 1", +};
-#ifdef CONFIG_PCI void pci_init_board(void) { - volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - struct fsl_pci_info pci_info[3]; - u32 devdisr, pordevsr, io_sel; - int first_free_busno = 0; - int num = 0; - - int pcie_ep, pcie_configured; - - devdisr = in_be32(&gur->devdisr); - pordevsr = in_be32(&gur->pordevsr); - io_sel = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19; - - debug (" pci_init_board: devdisr=%x, io_sel=%x\n", devdisr, io_sel); - - puts("\n"); -#ifdef CONFIG_PCIE2 - pcie_configured = is_serdes_configured(PCIE2); - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE2)) { - SET_STD_PCIE_INFO(pci_info[num], 2); - pcie_ep = fsl_setup_hose(&pcie2_hose, pci_info[num].regs); - printf("PCIE2: connected to ULI as %s (base addr %lx)\n", - pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie2_hose, first_free_busno); - - /* - * The workaround doesn't work on p2020 because the location - * we try and read isn't valid on p2020, fix this later - */ -#if 0 - /* - * Activate ULI1575 legacy chip by performing a fake - * memory access. Needed to make ULI RTC work. - * Device 1d has the first on-board memory BAR. - */ - - pci_hose_read_config_dword(hose, PCI_BDF(2, 0x1d, 0), - PCI_BASE_ADDRESS_1, &temp32); - if (temp32 >= CONFIG_SYS_PCIE3_MEM_BUS) { - void *p = pci_mem_to_virt(PCI_BDF(2, 0x1d, 0), - temp32, 4, 0); - debug(" uli1575 read to %p\n", p); - in_be32(p); - } -#endif - } else { - printf("PCIE2: disabled\n"); - } - puts("\n"); -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE2); /* disable */ -#endif - -#ifdef CONFIG_PCIE3 - pcie_configured = is_serdes_configured(PCIE3); - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE3)) { - SET_STD_PCIE_INFO(pci_info[num], 3); - pcie_ep = fsl_setup_hose(&pcie3_hose, pci_info[num].regs); - printf("PCIE3: connected to Slot 1 as %s (base addr %lx)\n", - pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie3_hose, first_free_busno); - } else { - printf("PCIE3: disabled\n"); - } - puts("\n"); -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE3); /* disable */ -#endif - -#ifdef CONFIG_PCIE1 - pcie_configured = is_serdes_configured(PCIE1); - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)) { - SET_STD_PCIE_INFO(pci_info[num], 1); - pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); - printf("PCIE1: connected to Slot 2 as %s (base addr %lx)\n", - pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie1_hose, first_free_busno); - } else { - printf("PCIE1: disabled\n"); - } - puts("\n"); -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE); /* disable */ -#endif + fsl_pcie_init_board(0); } #endif
Remove duplicated code in MPC8544DS board and utliize the common fsl_pcie_init_ctrl(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled.
We don't use the full fsl_pcie_init_ctrl() since we have to handle PCIE3 specially to setup the additional memory map region and we utilize a single LAW to cover the controller.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/mpc8544ds/law.c | 10 +--- board/freescale/mpc8544ds/mpc8544ds.c | 110 +++++++++++---------------------- 2 files changed, 37 insertions(+), 83 deletions(-)
diff --git a/board/freescale/mpc8544ds/law.c b/board/freescale/mpc8544ds/law.c index 3d308c8..59e03fc 100644 --- a/board/freescale/mpc8544ds/law.c +++ b/board/freescale/mpc8544ds/law.c @@ -1,5 +1,5 @@ /* - * Copyright 2008 Freescale Semiconductor, Inc. + * Copyright 2008, 2010 Freescale Semiconductor, Inc. * * (C) Copyright 2000 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. @@ -28,15 +28,7 @@ #include <asm/mmu.h>
struct law_entry law_table[] = { - SET_LAW(CONFIG_SYS_PCI1_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCI), - SET_LAW(CONFIG_SYS_PCI1_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCI), SET_LAW(CONFIG_SYS_LBC_NONCACHE_BASE, LAW_SIZE_128M, LAW_TRGT_IF_LBC), - SET_LAW(CONFIG_SYS_PCIE1_MEM_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_PCIE_1), - SET_LAW(CONFIG_SYS_PCIE1_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_1), - SET_LAW(CONFIG_SYS_PCIE2_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCIE_2), - SET_LAW(CONFIG_SYS_PCIE2_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_2), - /* contains both PCIE3 MEM & IO space */ - SET_LAW(CONFIG_SYS_PCIE3_MEM_PHYS, LAW_SIZE_4M, LAW_TRGT_IF_PCIE_3), };
int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/freescale/mpc8544ds/mpc8544ds.c b/board/freescale/mpc8544ds/mpc8544ds.c index 2b6900c..908077f 100644 --- a/board/freescale/mpc8544ds/mpc8544ds.c +++ b/board/freescale/mpc8544ds/mpc8544ds.c @@ -89,26 +89,28 @@ initdram(int board_type) static struct pci_controller pci1_hose; #endif
-#ifdef CONFIG_PCIE1 -static struct pci_controller pcie1_hose; -#endif - -#ifdef CONFIG_PCIE2 -static struct pci_controller pcie2_hose; -#endif - #ifdef CONFIG_PCIE3 static struct pci_controller pcie3_hose; #endif
+static const char *slot_names[] = { + [PCIE1] = "Slot 2", + [PCIE2] = "Slot 1", + [PCIE3] = "ULI", +}; + +const char *board_serdes_name(enum srds_prtcl device) +{ + return slot_names[device]; +} + void pci_init_board(void) { volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - struct fsl_pci_info pci_info[4]; + struct fsl_pci_info pci_info; u32 devdisr, pordevsr, io_sel; u32 porpllsr, pci_agent, pci_speed, pci_32, pci_arb, pci_clk_sel; int first_free_busno = 0; - int num = 0;
@@ -125,9 +127,12 @@ void pci_init_board(void) pcie_configured = is_serdes_configured(PCIE3);
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE3)){ - SET_STD_PCIE_INFO(pci_info[num], 3); - pcie_ep = fsl_setup_hose(&pcie3_hose, pci_info[num].regs); -#ifdef CONFIG_SYS_PCIE3_MEM_BUS2 + /* contains both PCIE3 MEM & IO space */ + set_next_law(CONFIG_SYS_PCIE3_MEM_PHYS, LAW_SIZE_4M, + LAW_TRGT_IF_PCIE_3); + SET_STD_PCIE_INFO(pci_info, 3); + pcie_ep = fsl_setup_hose(&pcie3_hose, pci_info.regs); + /* outbound memory */ pci_set_region(&pcie3_hose.regions[0], CONFIG_SYS_PCIE3_MEM_BUS2, @@ -136,11 +141,11 @@ void pci_init_board(void) PCI_REGION_MEM);
pcie3_hose.region_count = 1; -#endif + printf("PCIE3: connected to ULI as %s (base addr %lx)\n", pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], + pci_info.regs); + first_free_busno = fsl_pci_init_port(&pci_info, &pcie3_hose, first_free_busno);
/* @@ -157,64 +162,17 @@ void pci_init_board(void) #endif
#ifdef CONFIG_PCIE1 - pcie_configured = is_serdes_configured(PCIE1); - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ - SET_STD_PCIE_INFO(pci_info[num], 1); - pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); -#ifdef CONFIG_SYS_PCIE1_MEM_BUS2 - /* outbound memory */ - pci_set_region(&pcie1_hose.regions[0], - CONFIG_SYS_PCIE1_MEM_BUS2, - CONFIG_SYS_PCIE1_MEM_PHYS2, - CONFIG_SYS_PCIE1_MEM_SIZE2, - PCI_REGION_MEM); - - pcie1_hose.region_count = 1; -#endif - printf("PCIE1: connected to Slot 2 as %s (base addr %lx)\n", - pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie1_hose, first_free_busno); - } else { - printf("PCIE1: disabled\n"); - } - - puts("\n"); + SET_STD_PCIE_INFO(pci_info, 1); + first_free_busno = fsl_pcie_init_ctrl(first_free_busno, devdisr, PCIE1, &pci_info); #else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE); /* disable */ + setbits_be32(&gur->devdisr, _DEVDISR_PCIE1); /* disable */ #endif
#ifdef CONFIG_PCIE2 - pcie_configured = is_serdes_configured(PCIE2); - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE2)){ - SET_STD_PCIE_INFO(pci_info[num], 2); - pcie_ep = fsl_setup_hose(&pcie2_hose, pci_info[num].regs); -#ifdef CONFIG_SYS_PCIE2_MEM_BUS2 - /* outbound memory */ - pci_set_region(&pcie2_hose.regions[0], - CONFIG_SYS_PCIE2_MEM_BUS2, - CONFIG_SYS_PCIE2_MEM_PHYS2, - CONFIG_SYS_PCIE2_MEM_SIZE2, - PCI_REGION_MEM); - - pcie2_hose.region_count = 1; -#endif - printf("PCIE2: connected to Slot 1 as %s (base addr %lx)\n", - pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie2_hose, first_free_busno); - } else { - printf("PCIE2: disabled\n"); - } - - puts("\n"); + SET_STD_PCIE_INFO(pci_info, 2); + first_free_busno = fsl_pcie_init_ctrl(first_free_busno, devdisr, PCIE2, &pci_info); #else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE2); /* disable */ + setbits_be32(&gur->devdisr, _DEVDISR_PCIE2); /* disable */ #endif
#ifdef CONFIG_PCI1 @@ -224,8 +182,13 @@ void pci_init_board(void) pci_clk_sel = porpllsr & MPC85xx_PORDEVSR_PCI1_SPD;
if (!(devdisr & MPC85xx_DEVDISR_PCI1)) { - SET_STD_PCI_INFO(pci_info[num], 1); - pci_agent = fsl_setup_hose(&pci1_hose, pci_info[num].regs); + SET_STD_PCI_INFO(pci_info, 1); + set_next_law(pci_info.mem_phys, + law_size_bits(pci_info.mem_size), pci_info.law); + set_next_law(pci_info.io_phys, + law_size_bits(pci_info.io_size), pci_info.law); + + pci_agent = fsl_setup_hose(&pci1_hose, pci_info.regs); printf("PCI: %d bit, %s MHz, %s, %s, %s (base address %lx)\n", (pci_32) ? 32 : 64, (pci_speed == 33333000) ? "33" : @@ -233,9 +196,9 @@ void pci_init_board(void) pci_clk_sel ? "sync" : "async", pci_agent ? "agent" : "host", pci_arb ? "arbiter" : "external-arbiter", - pci_info[num].regs); + pci_info.regs);
- first_free_busno = fsl_pci_init_port(&pci_info[num++], + first_free_busno = fsl_pci_init_port(&pci_info, &pci1_hose, first_free_busno); } else { printf("PCI: disabled\n"); @@ -247,7 +210,6 @@ void pci_init_board(void) #endif }
- int last_stage_init(void) { return 0;
Remove duplicated code in MPC8536DS board and utliize the common fsl_pcie_init_board().
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/mpc8536ds/mpc8536ds.c | 125 ++++++-------------------------- 1 files changed, 24 insertions(+), 101 deletions(-)
diff --git a/board/freescale/mpc8536ds/mpc8536ds.c b/board/freescale/mpc8536ds/mpc8536ds.c index bd80cb7..c005ab7 100644 --- a/board/freescale/mpc8536ds/mpc8536ds.c +++ b/board/freescale/mpc8536ds/mpc8536ds.c @@ -177,123 +177,46 @@ phys_size_t fixed_sdram (void) static struct pci_controller pci1_hose; #endif
-#ifdef CONFIG_PCIE1 -static struct pci_controller pcie1_hose; -#endif - -#ifdef CONFIG_PCIE2 -static struct pci_controller pcie2_hose; -#endif +#ifdef CONFIG_PCI +static const char *slot_names[] = { + [PCIE1] = "Slot 1", + [PCIE2] = "Slot 2", + [PCIE3] = "Slot 3", +};
-#ifdef CONFIG_PCI void pci_init_board(void) { ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - struct fsl_pci_info pci_info[4]; - u32 devdisr, pordevsr, io_sel; + struct fsl_pci_info pci_info; + u32 devdisr, pordevsr; u32 porpllsr, pci_agent, pci_speed, pci_32, pci_arb, pci_clk_sel; - int first_free_busno = 0; - int num = 0; + int first_free_busno;
- int pcie_ep, pcie_configured; + first_free_busno = fsl_pcie_init_board(0);
+#ifdef CONFIG_PCI1 devdisr = in_be32(&gur->devdisr); pordevsr = in_be32(&gur->pordevsr); porpllsr = in_be32(&gur->porpllsr); - io_sel = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19; - - debug(" pci_init_board: devdisr=%x, io_sel=%x\n", devdisr, io_sel);
- puts("\n"); -#ifdef CONFIG_PCIE3 - pcie_configured = is_serdes_configured(PCIE3); - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE3)){ - set_next_law(CONFIG_SYS_PCIE3_MEM_PHYS, LAW_SIZE_512M, - LAW_TRGT_IF_PCIE_3); - set_next_law(CONFIG_SYS_PCIE3_IO_PHYS, LAW_SIZE_64K, - LAW_TRGT_IF_PCIE_3); - SET_STD_PCIE_INFO(pci_info[num], 3); - pcie_ep = fsl_setup_hose(&pcie3_hose, pci_info[num].regs); - printf("PCIE3: connected to Slot3 as %s (base address %lx)\n", - pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie3_hose, first_free_busno); - } else { - printf("PCIE3: disabled\n"); - } - - puts("\n"); -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE3); /* disable */ -#endif - -#ifdef CONFIG_PCIE1 - pcie_configured = is_serdes_configured(PCIE1); - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ - set_next_law(CONFIG_SYS_PCIE1_MEM_PHYS, LAW_SIZE_128M, - LAW_TRGT_IF_PCIE_1); - set_next_law(CONFIG_SYS_PCIE1_IO_PHYS, LAW_SIZE_64K, - LAW_TRGT_IF_PCIE_1); - SET_STD_PCIE_INFO(pci_info[num], 1); - pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); - printf("PCIE1: connected to Slot1 as %s (base address %lx)\n", - pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie1_hose, first_free_busno); - } else { - printf("PCIE1: disabled\n"); - } - - puts("\n"); -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE); /* disable */ -#endif - -#ifdef CONFIG_PCIE2 - pcie_configured = is_serdes_configured(PCIE2); - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE2)){ - set_next_law(CONFIG_SYS_PCIE2_MEM_PHYS, LAW_SIZE_128M, - LAW_TRGT_IF_PCIE_2); - set_next_law(CONFIG_SYS_PCIE2_IO_PHYS, LAW_SIZE_64K, - LAW_TRGT_IF_PCIE_2); - SET_STD_PCIE_INFO(pci_info[num], 2); - pcie_ep = fsl_setup_hose(&pcie2_hose, pci_info[num].regs); - printf("PCIE2: connected to Slot 2 as %s (base address %lx)\n", - pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie2_hose, first_free_busno); - } else { - printf("PCIE2: disabled\n"); - } - - puts("\n"); -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE2); /* disable */ -#endif - -#ifdef CONFIG_PCI1 pci_speed = 66666000; pci_32 = 1; pci_arb = pordevsr & MPC85xx_PORDEVSR_PCI1_ARB; pci_clk_sel = porpllsr & MPC85xx_PORDEVSR_PCI1_SPD;
if (!(devdisr & MPC85xx_DEVDISR_PCI1)) { - set_next_law(CONFIG_SYS_PCI1_MEM_PHYS, LAW_SIZE_256M, - LAW_TRGT_IF_PCI); - set_next_law(CONFIG_SYS_PCI1_IO_PHYS, LAW_SIZE_64K, - LAW_TRGT_IF_PCI); - SET_STD_PCI_INFO(pci_info[num], 1); - pci_agent = fsl_setup_hose(&pci1_hose, pci_info[num].regs); + SET_STD_PCI_INFO(pci_info, 1); + set_next_law(pci_info.mem_phys, + law_size_bits(pci_info.mem_size), pci_info.law); + set_next_law(pci_info.io_phys, + law_size_bits(pci_info.io_size), pci_info.law); + + pci_agent = fsl_setup_hose(&pci1_hose, pci_info.regs); printf("PCI: %d bit, %s MHz, %s, %s, %s (base address %lx)\n", (pci_32) ? 32 : 64, (pci_speed == 33333000) ? "33" : @@ -301,9 +224,9 @@ void pci_init_board(void) pci_clk_sel ? "sync" : "async", pci_agent ? "agent" : "host", pci_arb ? "arbiter" : "external-arbiter", - pci_info[num].regs); + pci_info.regs);
Remove duplicated code in MPC8641HPCN board and utliize the common fsl_pcie_init_board(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/mpc8641hpcn/law.c | 7 +--- board/freescale/mpc8641hpcn/mpc8641hpcn.c | 56 +++++----------------------- 2 files changed, 11 insertions(+), 52 deletions(-)
diff --git a/board/freescale/mpc8641hpcn/law.c b/board/freescale/mpc8641hpcn/law.c index 8c8ce95..30a7b70 100644 --- a/board/freescale/mpc8641hpcn/law.c +++ b/board/freescale/mpc8641hpcn/law.c @@ -53,12 +53,7 @@ struct law_entry law_table[] = { #if !defined(CONFIG_SPD_EEPROM) SET_LAW(CONFIG_SYS_DDR_SDRAM_BASE, LAW_SIZE_256M, LAW_TRGT_IF_DDR_1), #endif -#ifdef CONFIG_PCI - SET_LAW(CONFIG_SYS_PCIE1_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCI_1), - SET_LAW(CONFIG_SYS_PCIE2_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCI_2), - SET_LAW(CONFIG_SYS_PCIE1_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCI_1), - SET_LAW(CONFIG_SYS_PCIE2_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCI_2), -#elif defined(CONFIG_RIO) +#if defined(CONFIG_RIO) SET_LAW(CONFIG_SYS_RIO_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_RIO), #endif SET_LAW(PIXIS_BASE_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_LBC), diff --git a/board/freescale/mpc8641hpcn/mpc8641hpcn.c b/board/freescale/mpc8641hpcn/mpc8641hpcn.c index e951021..be70dc2 100644 --- a/board/freescale/mpc8641hpcn/mpc8641hpcn.c +++ b/board/freescale/mpc8641hpcn/mpc8641hpcn.c @@ -127,64 +127,28 @@ fixed_sdram(void) } #endif /* !defined(CONFIG_SPD_EEPROM) */
- -#if defined(CONFIG_PCI) -static struct pci_controller pcie1_hose; -#endif /* CONFIG_PCI */ - -#ifdef CONFIG_PCIE2 -static struct pci_controller pcie2_hose; -#endif /* CONFIG_PCIE2 */ - -int first_free_busno = 0; +static const char *slot_names[] = { + [PCIE1] = "ULI", + [PCIE2] = "", +}; + +const char *board_serdes_name(enum srds_prtcl device) +{ + return slot_names[device]; +}
void pci_init_board(void) { - struct fsl_pci_info pci_info[2]; - int pcie_ep; - int num = 0; + fsl_pcie_init_board(0);
#ifdef CONFIG_PCIE1 - volatile immap_t *immap = (immap_t *) CONFIG_SYS_CCSRBAR; - volatile ccsr_gur_t *gur = &immap->im_gur; - uint devdisr = in_be32(&gur->devdisr); - int pcie_configured = is_serdes_configured(PCIE1); - - if (pcie_configured && !(devdisr & MPC86xx_DEVDISR_PCIEX1)) { - SET_STD_PCIE_INFO(pci_info[num], 1); - pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); - printf("PCIE1: connected to ULI as %s (base addr %lx)\n", - pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie1_hose, first_free_busno); - /* * Activate ULI1575 legacy chip by performing a fake * memory access. Needed to make ULI RTC work. */ in_be32((unsigned *) ((char *)(CONFIG_SYS_PCIE1_MEM_VIRT + CONFIG_SYS_PCIE1_MEM_SIZE - 0x1000000))); - - } else { - puts("PCIE1: disabled\n"); - } -#else - puts("PCIE1: disabled\n"); #endif /* CONFIG_PCIE1 */ - -#ifdef CONFIG_PCIE2 - SET_STD_PCIE_INFO(pci_info[num], 2); - pcie_ep = fsl_setup_hose(&pcie2_hose, pci_info[num].regs); - printf("PCIE2: connected as %s (base addr %lx)\n", - pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie2_hose, first_free_busno); -#else - puts("PCIE2: disabled\n"); -#endif /* CONFIG_PCIE2 */ - }
Remove duplicated code in MPC8548CDS board and utliize the common fsl_pcie_init_board(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/mpc8548cds/law.c | 10 +------ board/freescale/mpc8548cds/mpc8548cds.c | 46 ++++++++++--------------------- 2 files changed, 16 insertions(+), 40 deletions(-)
diff --git a/board/freescale/mpc8548cds/law.c b/board/freescale/mpc8548cds/law.c index 98748aa..e59fee8 100644 --- a/board/freescale/mpc8548cds/law.c +++ b/board/freescale/mpc8548cds/law.c @@ -1,5 +1,5 @@ /* - * Copyright 2008 Freescale Semiconductor, Inc. + * Copyright 2008,2010 Freescale Semiconductor, Inc. * * (C) Copyright 2000 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. @@ -51,18 +51,10 @@ */
struct law_entry law_table[] = { -#ifdef CONFIG_SYS_PCI1_MEM_PHYS - SET_LAW(CONFIG_SYS_PCI1_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCI), - SET_LAW(CONFIG_SYS_PCI1_IO_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_PCI), -#endif #ifdef CONFIG_SYS_PCI2_MEM_PHYS SET_LAW(CONFIG_SYS_PCI2_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCI_2), SET_LAW(CONFIG_SYS_PCI2_IO_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_PCI_2), #endif -#ifdef CONFIG_SYS_PCIE1_MEM_PHYS - SET_LAW(CONFIG_SYS_PCIE1_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCIE_1), - SET_LAW(CONFIG_SYS_PCIE1_IO_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_PCIE_1), -#endif /* LBC window - maps 256M 0xf0000000 -> 0xffffffff */ SET_LAW(CONFIG_SYS_LBC_SDRAM_BASE, LAW_SIZE_256M, LAW_TRGT_IF_LBC), #ifdef CONFIG_SYS_RIO_MEM_PHYS diff --git a/board/freescale/mpc8548cds/mpc8548cds.c b/board/freescale/mpc8548cds/mpc8548cds.c index ebeb897..0f8d04e 100644 --- a/board/freescale/mpc8548cds/mpc8548cds.c +++ b/board/freescale/mpc8548cds/mpc8548cds.c @@ -254,20 +254,18 @@ static struct pci_controller pci1_hose = { static struct pci_controller pci2_hose; #endif /* CONFIG_PCI2 */
-#ifdef CONFIG_PCIE1 -static struct pci_controller pcie1_hose; -#endif /* CONFIG_PCIE1 */ +const char *board_serdes_name(enum srds_prtcl device) +{ + return "Slot"; +}
void pci_init_board(void) { volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - struct fsl_pci_info pci_info[4]; + struct fsl_pci_info pci_info; u32 devdisr, pordevsr, io_sel; u32 porpllsr, pci_agent, pci_speed, pci_32, pci_arb, pci_clk_sel; int first_free_busno = 0; - int num = 0; - - int pcie_ep, pcie_configured;
devdisr = in_be32(&gur->devdisr); pordevsr = in_be32(&gur->pordevsr); @@ -283,8 +281,13 @@ void pci_init_board(void) pci_clk_sel = porpllsr & MPC85xx_PORDEVSR_PCI1_SPD;
if (!(devdisr & MPC85xx_DEVDISR_PCI1)) { - SET_STD_PCI_INFO(pci_info[num], 1); - pci_agent = fsl_setup_hose(&pci1_hose, pci_info[num].regs); + SET_STD_PCI_INFO(pci_info, 1); + set_next_law(pci_info.mem_phys, + law_size_bits(pci_info.mem_size), pci_info.law); + set_next_law(pci_info.io_phys, + law_size_bits(pci_info.io_size), pci_info.law); + + pci_agent = fsl_setup_hose(&pci1_hose, pci_info.regs); printf("PCI: %d bit, %s MHz, %s, %s, %s (base address %lx)\n", (pci_32) ? 32 : 64, (pci_speed == 33333000) ? "33" : @@ -292,9 +295,9 @@ void pci_init_board(void) pci_clk_sel ? "sync" : "async", pci_agent ? "agent" : "host", pci_arb ? "arbiter" : "external-arbiter", - pci_info[num].regs); + pci_info.regs);
#ifdef CONFIG_PCIX_CHECK @@ -332,26 +335,7 @@ void pci_init_board(void) setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCI2); /* disable */ #endif /* CONFIG_PCI2 */
-#ifdef CONFIG_PCIE1 - pcie_configured = is_serdes_configured(PCIE1); - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ - SET_STD_PCIE_INFO(pci_info[num], 1); - pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); - printf("PCIE1: connected to Slot as %s (base addr %lx)\n", - pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie1_hose, first_free_busno); - } else { - printf("PCIE1: disabled\n"); - } - - puts("\n"); -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE); /* disable */ -#endif + fsl_pcie_init_board(first_free_busno); }
Remove duplicated code in MPC8572 DS board and utliize the common fsl_pcie_init_board().
Signed-off-by: Kumar Gala galak@kernel.crashing.org CC: Peter Tyser ptyser@xes-inc.com --- board/xes/common/fsl_8xxx_pci.c | 82 ++++----------------------------------- board/xes/xpedite517x/law.c | 8 ---- board/xes/xpedite520x/law.c | 4 -- board/xes/xpedite537x/law.c | 12 ------ board/xes/xpedite550x/law.c | 12 ------ 5 files changed, 8 insertions(+), 110 deletions(-)
diff --git a/board/xes/common/fsl_8xxx_pci.c b/board/xes/common/fsl_8xxx_pci.c index 4135849..202520d 100644 --- a/board/xes/common/fsl_8xxx_pci.c +++ b/board/xes/common/fsl_8xxx_pci.c @@ -34,15 +34,6 @@ #ifdef CONFIG_PCI1 static struct pci_controller pci1_hose; #endif -#ifdef CONFIG_PCIE1 -static struct pci_controller pcie1_hose; -#endif -#ifdef CONFIG_PCIE2 -static struct pci_controller pcie2_hose; -#endif -#ifdef CONFIG_PCIE3 -static struct pci_controller pcie3_hose; -#endif
/* * 85xx and 86xx share naming conventions, but different layout. @@ -69,22 +60,13 @@ static struct pci_controller pcie3_hose;
void pci_init_board(void) { - struct fsl_pci_info pci_info[3]; int first_free_busno = 0; - int num = 0; - int pcie_ep; - __maybe_unused int pcie_configured;
-#if defined(CONFIG_MPC85xx) +#ifdef CONFIG_PCI1 + int pcie_ep; + struct fsl_pci_info pci_info; volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); -#elif defined(CONFIG_MPC86xx) - immap_t *immap = (immap_t *)CONFIG_SYS_IMMR; - volatile ccsr_gur_t *gur = &immap->im_gur; -#endif u32 devdisr = in_be32(&gur->devdisr); - -#ifdef CONFIG_PCI1 - u32 pordevsr = in_be32(&gur->pordevsr); uint pci_spd_norm = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1_SPD; uint pci_32 = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1_PCI32; uint pci_arb = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1_ARB; @@ -92,8 +74,8 @@ void pci_init_board(void) uint freq = CONFIG_SYS_CLK_FREQ / 1000 / 1000;
if (!(devdisr & MPC85xx_DEVDISR_PCI1)) { - SET_STD_PCI_INFO(pci_info[num], 1); - pcie_ep = fsl_setup_hose(&pci1_hose, pci_info[num].regs); + SET_STD_PCI_INFO(pci_info, 1); + pcie_ep = fsl_setup_hose(&pci1_hose, pci_info.regs); printf("PCI1: %d bit %s, %s %d MHz, %s, %s\n", pci_32 ? 32 : 64, pcix ? "PCIX" : "PCI", @@ -102,66 +84,18 @@ void pci_init_board(void) pcie_ep ? "agent" : "host", pci_arb ? "arbiter" : "external-arbiter");
- first_free_busno = fsl_pci_init_port(&pci_info[num++], + first_free_busno = fsl_pci_init_port(&pci_info, &pci1_hose, first_free_busno); } else { printf("PCI1: disabled\n"); } #elif defined CONFIG_MPC8548 + volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); /* PCI1 not present on MPC8572 */ setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCI1); #endif
-#ifdef CONFIG_PCIE1 - pcie_configured = is_serdes_configured(PCIE1); - - if (pcie_configured && !(devdisr & MPC8xxx_DEVDISR_PCIE1)) { - SET_STD_PCIE_INFO(pci_info[num], 1); - pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); - printf("PCIE1: connected as %s\n", - pcie_ep ? "Endpoint" : "Root Complex"); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie1_hose, first_free_busno); - } else { - printf("PCIE1: disabled\n"); - } -#else - setbits_be32(&gur->devdisr, MPC8xxx_DEVDISR_PCIE1); -#endif /* CONFIG_PCIE1 */ - -#ifdef CONFIG_PCIE2 - pcie_configured = is_serdes_configured(PCIE2); - - if (pcie_configured && !(devdisr & MPC8xxx_DEVDISR_PCIE2)) { - SET_STD_PCIE_INFO(pci_info[num], 2); - pcie_ep = fsl_setup_hose(&pcie2_hose, pci_info[num].regs); - printf("PCIE2: connected as %s\n", - pcie_ep ? "Endpoint" : "Root Complex"); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie2_hose, first_free_busno); - } else { - printf("PCIE2: disabled\n"); - } -#else - setbits_be32(&gur->devdisr, MPC8xxx_DEVDISR_PCIE2); -#endif /* CONFIG_PCIE2 */ - -#ifdef CONFIG_PCIE3 - pcie_configured = is_serdes_configured(PCIE3); - - if (pcie_configured && !(devdisr & MPC8xxx_DEVDISR_PCIE3)) { - SET_STD_PCIE_INFO(pci_info[num], 3); - pcie_ep = fsl_setup_hose(&pcie3_hose, pci_info[num].regs); - printf("PCIE3: connected as %s\n", - pcie_ep ? "Endpoint" : "Root Complex"); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie3_hose, first_free_busno); - } else { - printf("PCIE3: disabled\n"); - } -#else - setbits_be32(&gur->devdisr, MPC8xxx_DEVDISR_PCIE3); -#endif /* CONFIG_PCIE3 */ + fsl_pcie_init_board(first_free_busno); }
#if defined(CONFIG_OF_BOARD_SETUP) diff --git a/board/xes/xpedite517x/law.c b/board/xes/xpedite517x/law.c index 0b7d9ef..df23df1 100644 --- a/board/xes/xpedite517x/law.c +++ b/board/xes/xpedite517x/law.c @@ -39,14 +39,6 @@ struct law_entry law_table[] = { /* NAND LAW covers 2 NAND flashes */ SET_LAW(CONFIG_SYS_NAND_BASE, LAW_SIZE_512K, LAW_TRGT_IF_LBC), #endif -#ifdef CONFIG_SYS_PCIE1_MEM_PHYS - SET_LAW(CONFIG_SYS_PCIE1_MEM_PHYS, LAW_SIZE_1G, LAW_TRGT_IF_PCIE_1), - SET_LAW(CONFIG_SYS_PCIE1_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCIE_1), -#endif -#ifdef CONFIG_SYS_PCIE2_MEM_PHYS - SET_LAW(CONFIG_SYS_PCIE2_MEM_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_PCIE_2), - SET_LAW(CONFIG_SYS_PCIE2_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCIE_2), -#endif };
int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/xes/xpedite520x/law.c b/board/xes/xpedite520x/law.c index bbfcb9d..3afb3ae 100644 --- a/board/xes/xpedite520x/law.c +++ b/board/xes/xpedite520x/law.c @@ -38,10 +38,6 @@ struct law_entry law_table[] = { /* LBC window - maps 256M 0xf0000000 -> 0xffffffff */ SET_LAW(CONFIG_SYS_FLASH_BASE2, LAW_SIZE_256M, LAW_TRGT_IF_LBC), SET_LAW(CONFIG_SYS_NAND_BASE, LAW_SIZE_1M, LAW_TRGT_IF_LBC), -#if CONFIG_SYS_PCI1_MEM_PHYS - SET_LAW(CONFIG_SYS_PCI1_MEM_PHYS, LAW_SIZE_1G, LAW_TRGT_IF_PCI_1), - SET_LAW(CONFIG_SYS_PCI1_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCI_1), -#endif #if CONFIG_SYS_PCI2_MEM_PHYS SET_LAW(CONFIG_SYS_PCI2_MEM_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_PCI_2), SET_LAW(CONFIG_SYS_PCI2_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCI_2), diff --git a/board/xes/xpedite537x/law.c b/board/xes/xpedite537x/law.c index daee676..54c28da 100644 --- a/board/xes/xpedite537x/law.c +++ b/board/xes/xpedite537x/law.c @@ -37,18 +37,6 @@ struct law_entry law_table[] = { SET_LAW(CONFIG_SYS_FLASH_BASE2, LAW_SIZE_256M, LAW_TRGT_IF_LBC), SET_LAW(CONFIG_SYS_NAND_BASE, LAW_SIZE_1M, LAW_TRGT_IF_LBC), -#ifdef CONFIG_SYS_PCIE1_MEM_PHYS - SET_LAW(CONFIG_SYS_PCIE1_MEM_PHYS, LAW_SIZE_1G, LAW_TRGT_IF_PCIE_1), - SET_LAW(CONFIG_SYS_PCIE1_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCIE_1), -#endif -#ifdef CONFIG_SYS_PCIE2_MEM_PHYS - SET_LAW(CONFIG_SYS_PCIE2_MEM_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_PCIE_2), - SET_LAW(CONFIG_SYS_PCIE2_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCIE_2), -#endif -#ifdef CONFIG_SYS_PCIE3_MEM_PHYS - SET_LAW(CONFIG_SYS_PCIE3_MEM_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_PCIE_3), - SET_LAW(CONFIG_SYS_PCIE3_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCIE_3), -#endif };
int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/xes/xpedite550x/law.c b/board/xes/xpedite550x/law.c index 4d4445d..66f1cf9 100644 --- a/board/xes/xpedite550x/law.c +++ b/board/xes/xpedite550x/law.c @@ -37,18 +37,6 @@ struct law_entry law_table[] = { SET_LAW(CONFIG_SYS_FLASH_BASE2, LAW_SIZE_256M, LAW_TRGT_IF_LBC), SET_LAW(CONFIG_SYS_NAND_BASE, LAW_SIZE_1M, LAW_TRGT_IF_LBC), -#ifdef CONFIG_SYS_PCIE1_MEM_PHYS - SET_LAW(CONFIG_SYS_PCIE1_MEM_PHYS, LAW_SIZE_1G, LAW_TRGT_IF_PCIE_1), - SET_LAW(CONFIG_SYS_PCIE1_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCIE_1), -#endif -#ifdef CONFIG_SYS_PCIE2_MEM_PHYS - SET_LAW(CONFIG_SYS_PCIE2_MEM_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_PCIE_2), - SET_LAW(CONFIG_SYS_PCIE2_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCIE_2), -#endif -#ifdef CONFIG_SYS_PCIE3_MEM_PHYS - SET_LAW(CONFIG_SYS_PCIE3_MEM_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_PCIE_3), - SET_LAW(CONFIG_SYS_PCIE3_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCIE_3), -#endif };
Remove duplicated code in TQM 85xx boards and utliize the common fsl_pcie_init_board().
Signed-off-by: Kumar Gala galak@kernel.crashing.org CC: wd@denx.de --- board/tqc/tqm85xx/law.c | 9 +-------- board/tqc/tqm85xx/tqm85xx.c | 41 ++++++++++++----------------------------- 2 files changed, 13 insertions(+), 37 deletions(-)
diff --git a/board/tqc/tqm85xx/law.c b/board/tqc/tqm85xx/law.c index e684ba2..c596303 100644 --- a/board/tqc/tqm85xx/law.c +++ b/board/tqc/tqm85xx/law.c @@ -67,20 +67,13 @@
struct law_entry law_table[] = { SET_LAW(CONFIG_SYS_DDR_SDRAM_BASE, LAW_SIZE_2G, LAW_TRGT_IF_DDR), - SET_LAW(CONFIG_SYS_PCI1_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCI), SET_LAW(CONFIG_SYS_LBC_FLASH_BASE, LAW_3_SIZE, LAW_TRGT_IF_LBC), - SET_LAW(CONFIG_SYS_PCI1_IO_PHYS, LAW_SIZE_16M, LAW_TRGT_IF_PCI), -#ifdef CONFIG_PCIE1 - SET_LAW(CONFIG_SYS_PCIE1_MEM_BUS, LAW_5_SIZE, LAW_TRGT_IF_PCIE_1), -#else /* !CONFIG_PCIE1 */ +#ifndef CONFIG_PCIE1 SET_LAW(CONFIG_SYS_RIO_MEM_BASE, LAW_5_SIZE, LAW_TRGT_IF_RIO), #endif /* CONFIG_PCIE1 */ #if defined(CONFIG_CAN_DRIVER) || defined(CONFIG_NAND) SET_LAW(CONFIG_SYS_CAN_BASE, LAW_SIZE_16M, LAW_TRGT_IF_LBC), #endif /* CONFIG_CAN_DRIVER || CONFIG_NAND */ -#ifdef CONFIG_PCIE1 - SET_LAW(CONFIG_SYS_PCIE1_IO_BUS, LAW_SIZE_16M, LAW_TRGT_IF_PCIE_1), -#endif /* CONFIG_PCIE */ };
int num_law_entries = ARRAY_SIZE (law_table); diff --git a/board/tqc/tqm85xx/tqm85xx.c b/board/tqc/tqm85xx/tqm85xx.c index 43c73e1..99b1331 100644 --- a/board/tqc/tqm85xx/tqm85xx.c +++ b/board/tqc/tqm85xx/tqm85xx.c @@ -541,31 +541,29 @@ void local_bus_init (void) static struct pci_controller pci1_hose; #endif /* CONFIG_PCI1 */
-#ifdef CONFIG_PCIE1 -static struct pci_controller pcie1_hose; -#endif /* CONFIG_PCIE1 */ - void pci_init_board (void) { - struct fsl_pci_info pci_info[2]; + volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); int first_free_busno = 0; - int num = 0; +#ifdef CONFIG_PCI1 + struct fsl_pci_info pci_info; int pcie_ep; - __maybe_unused int pcie_configured;
- volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); u32 devdisr = in_be32(&gur->devdisr); - u32 pordevsr = in_be32(&gur->pordevsr);
-#ifdef CONFIG_PCI1 uint pci_32 = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1_PCI32; uint pci_arb = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1_ARB; uint pci_speed = CONFIG_SYS_CLK_FREQ; /* PCI PSPEED in [4:5] */ uint pci_clk_sel = in_be32(&gur->porpllsr) & MPC85xx_PORDEVSR_PCI1_SPD;
if (!(devdisr & MPC85xx_DEVDISR_PCI1)) { - SET_STD_PCI_INFO(pci_info[num], 1); - pcie_ep = fsl_setup_hose(&pci1_hose, pci_info[num].regs); + SET_STD_PCI_INFO(pci_info, 1); + set_next_law(pci_info.mem_phys, + law_size_bits(pci_info.mem_size), pci_info.law); + set_next_law(pci_info.io_phys, + law_size_bits(pci_info.io_size), pci_info.law); + + pcie_ep = fsl_setup_hose(&pci1_hose, pci_info.regs); printf("PCI1: %d bit, %s MHz, %s, %s, %s\n", (pci_32) ? 32 : 64, (pci_speed == 33333333) ? "33" : @@ -573,7 +571,7 @@ void pci_init_board (void) pci_clk_sel ? "sync" : "async", pcie_ep ? "agent" : "host", pci_arb ? "arbiter" : "external-arbiter"); - first_free_busno = fsl_pci_init_port(&pci_info[num++], + first_free_busno = fsl_pci_init_port(&pci_info, &pci1_hose, first_free_busno); #ifdef CONFIG_PCIX_CHECK if (!(in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1)) { @@ -596,22 +594,7 @@ void pci_init_board (void) setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCI1); #endif
-#ifdef CONFIG_PCIE1 - pcie_configured = is_serdes_configured(PCIE1); - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)) { - SET_STD_PCIE_INFO(pci_info[num], 1); - pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); - printf("PCIE1: connected as %s\n", - pcie_ep ? "Endpoint" : "Root Complex"); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie1_hose, first_free_busno); - } else { - printf("PCIE1: disabled\n"); - } -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE); -#endif /* CONFIG_PCIE1 */ + fsl_pcie_init_board(first_free_busno); }
Remove duplicated code in MPC8568MDS board and utliize the common fsl_pcie_init_board(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/mpc8568mds/law.c | 6 +--- board/freescale/mpc8568mds/mpc8568mds.c | 52 +++++++++++-------------------- 2 files changed, 19 insertions(+), 39 deletions(-)
diff --git a/board/freescale/mpc8568mds/law.c b/board/freescale/mpc8568mds/law.c index 3114e8a..e24b72b 100644 --- a/board/freescale/mpc8568mds/law.c +++ b/board/freescale/mpc8568mds/law.c @@ -1,5 +1,5 @@ /* - * Copyright 2008 Freescale Semiconductor, Inc. + * Copyright 2008, 2010 Freescale Semiconductor, Inc. * * (C) Copyright 2000 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. @@ -50,10 +50,6 @@ */
struct law_entry law_table[] = { - SET_LAW(CONFIG_SYS_PCI1_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCI), - SET_LAW(CONFIG_SYS_PCIE1_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCIE_1), - SET_LAW(CONFIG_SYS_PCI1_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCI), - SET_LAW(CONFIG_SYS_PCIE1_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCIE_1), SET_LAW(CONFIG_SYS_SRIO_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_RIO), /* LBC window - maps 256M. That's SDRAM, BCSR, PIBs, and Flash */ SET_LAW(CONFIG_SYS_LBC_SDRAM_BASE, LAW_SIZE_256M, LAW_TRGT_IF_LBC), diff --git a/board/freescale/mpc8568mds/mpc8568mds.c b/board/freescale/mpc8568mds/mpc8568mds.c index 71cfbf0..525622c 100644 --- a/board/freescale/mpc8568mds/mpc8568mds.c +++ b/board/freescale/mpc8568mds/mpc8568mds.c @@ -305,10 +305,6 @@ static struct pci_controller pci1_hose = { }; #endif /* CONFIG_PCI */
-#ifdef CONFIG_PCIE1 -static struct pci_controller pcie1_hose; -#endif /* CONFIG_PCIE1 */ - /* * pib_init() -- Initialize the PCA9555 IO expander on the PIB board */ @@ -352,16 +348,19 @@ pib_init(void) }
#ifdef CONFIG_PCI +const char *board_serdes_name(enum srds_prtcl device) +{ + return "Slot"; +} + void pci_init_board(void) { volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - struct fsl_pci_info pci_info[2]; + int first_free_busno = 0; +#ifdef CONFIG_PCI1 + struct fsl_pci_info pci_info; u32 devdisr, pordevsr, io_sel; u32 porpllsr, pci_agent, pci_speed, pci_32, pci_arb, pci_clk_sel; - int first_free_busno = 0; - int num = 0; - - int pcie_ep, pcie_configured;
devdisr = in_be32(&gur->devdisr); pordevsr = in_be32(&gur->pordevsr); @@ -370,15 +369,19 @@ void pci_init_board(void)
if (!(devdisr & MPC85xx_DEVDISR_PCI1)) { - SET_STD_PCI_INFO(pci_info[num], 1); - pci_agent = fsl_setup_hose(&pci1_hose, pci_info[num].regs); + SET_STD_PCI_INFO(pci_info, 1); + set_next_law(pci_info.mem_phys, + law_size_bits(pci_info.mem_size), pci_info.law); + set_next_law(pci_info.io_phys, + law_size_bits(pci_info.io_size), pci_info.law); + + pci_agent = fsl_setup_hose(&pci1_hose, pci_info.regs); printf("PCI: %d bit, %s MHz, %s, %s, %s (base address %lx)\n", (pci_32) ? 32 : 64, (pci_speed == 33333000) ? "33" : @@ -386,9 +389,9 @@ void pci_init_board(void) pci_clk_sel ? "sync" : "async", pci_agent ? "agent" : "host", pci_arb ? "arbiter" : "external-arbiter", - pci_info[num].regs); + pci_info.regs);
- first_free_busno = fsl_pci_init_port(&pci_info[num++], + first_free_busno = fsl_pci_init_port(&pci_info, &pci1_hose, first_free_busno); } else { printf("PCI: disabled\n"); @@ -399,26 +402,7 @@ void pci_init_board(void) setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCI1); /* disable */ #endif
-#ifdef CONFIG_PCIE1 - pcie_configured = is_serdes_configured(PCIE1); - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ - SET_STD_PCIE_INFO(pci_info[num], 1); - pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); - printf("PCIE1: connected to Slot as %s (base addr %lx)\n", - pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie1_hose, first_free_busno); - } else { - printf("PCIE1: disabled\n"); - } - - puts("\n"); -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE); /* disable */ -#endif + fsl_pcie_init_board(first_free_busno); } #endif /* CONFIG_PCI */
Remove duplicated code in MPC8569MDS board and utliize the common fsl_pcie_init_board(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/mpc8569mds/law.c | 4 +-- board/freescale/mpc8569mds/mpc8569mds.c | 44 ++++-------------------------- 2 files changed, 7 insertions(+), 41 deletions(-)
diff --git a/board/freescale/mpc8569mds/law.c b/board/freescale/mpc8569mds/law.c index 60eea45..bcd0311 100644 --- a/board/freescale/mpc8569mds/law.c +++ b/board/freescale/mpc8569mds/law.c @@ -1,5 +1,5 @@ /* - * Copyright 2009 Freescale Semiconductor, Inc. + * Copyright 2009-2010 Freescale Semiconductor, Inc. * * (C) Copyright 2000 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. @@ -51,8 +51,6 @@ struct law_entry law_table[] = { #ifndef CONFIG_SPD_EEPROM SET_LAW(CONFIG_SYS_DDR_SDRAM_BASE, LAW_SIZE_1G, LAW_TRGT_IF_DDR), #endif - SET_LAW(CONFIG_SYS_PCIE1_MEM_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_PCIE_1), - SET_LAW(CONFIG_SYS_PCIE1_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCIE_1), SET_LAW(CONFIG_SYS_BCSR_BASE_PHYS, LAW_SIZE_128M, LAW_TRGT_IF_LBC), SET_LAW(CONFIG_SYS_SRIO_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_RIO), }; diff --git a/board/freescale/mpc8569mds/mpc8569mds.c b/board/freescale/mpc8569mds/mpc8569mds.c index 9700b8c..773188c 100644 --- a/board/freescale/mpc8569mds/mpc8569mds.c +++ b/board/freescale/mpc8569mds/mpc8569mds.c @@ -554,51 +554,19 @@ static void fdt_board_fixup_qe_usb(void *blob, bd_t *bd) clrbits_8(&bcsr[17], BCSR17_nUSBEN); }
-#ifdef CONFIG_PCIE1 -static struct pci_controller pcie1_hose; -#endif /* CONFIG_PCIE1 */ - #ifdef CONFIG_PCI -void pci_init_board(void) +const char *board_serdes_name(enum srds_prtcl device) { - volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - struct fsl_pci_info pci_info[1]; - u32 devdisr, pordevsr, io_sel; - int first_free_busno = 0; - int num = 0; - - int pcie_ep, pcie_configured; - - devdisr = in_be32(&gur->devdisr); - pordevsr = in_be32(&gur->pordevsr); - io_sel = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19; - - debug (" pci_init_board: devdisr=%x, io_sel=%x\n", devdisr, io_sel); + return "Slot"; +}
+void pci_init_board(void) +{ #if defined(CONFIG_PQ_MDS_PIB) pib_init(); #endif
-#ifdef CONFIG_PCIE1 - pcie_configured = is_serdes_configured(PCIE1); - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ - SET_STD_PCIE_INFO(pci_info[num], 1); - pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); - printf("PCIE1: connected to Slot as %s (base addr %lx)\n", - pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie1_hose, first_free_busno); - } else { - printf("PCIE1: disabled\n"); - } - - puts("\n"); -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE); /* disable */ -#endif - + fsl_pcie_init_board(0); } #endif /* CONFIG_PCI */
Remove duplicated code in P1_P2_RDB boards and utliize the common fsl_pcie_init_board(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/p1_p2_rdb/law.c | 6 +--- board/freescale/p1_p2_rdb/pci.c | 64 +++++--------------------------------- 2 files changed, 10 insertions(+), 60 deletions(-)
diff --git a/board/freescale/p1_p2_rdb/law.c b/board/freescale/p1_p2_rdb/law.c index 1320d5d..4c80fa6 100644 --- a/board/freescale/p1_p2_rdb/law.c +++ b/board/freescale/p1_p2_rdb/law.c @@ -1,5 +1,5 @@ /* - * Copyright 2009 Freescale Semiconductor, Inc. + * Copyright 2009-2010 Freescale Semiconductor, Inc. * * See file CREDITS for list of people who contributed to this * project. @@ -26,10 +26,6 @@
struct law_entry law_table[] = { SET_LAW(CONFIG_SYS_FLASH_BASE_PHYS, LAW_SIZE_16M, LAW_TRGT_IF_LBC), - SET_LAW(CONFIG_SYS_PCIE1_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCIE_1), - SET_LAW(CONFIG_SYS_PCIE1_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_1), - SET_LAW(CONFIG_SYS_PCIE2_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCIE_2), - SET_LAW(CONFIG_SYS_PCIE2_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_2), SET_LAW(CONFIG_SYS_VSC7385_BASE_PHYS, LAW_SIZE_128K, LAW_TRGT_IF_LBC), SET_LAW(CONFIG_SYS_NAND_BASE_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_LBC), }; diff --git a/board/freescale/p1_p2_rdb/pci.c b/board/freescale/p1_p2_rdb/pci.c index 2034459..ccfc996 100644 --- a/board/freescale/p1_p2_rdb/pci.c +++ b/board/freescale/p1_p2_rdb/pci.c @@ -32,65 +32,19 @@
-#ifdef CONFIG_PCIE1 -static struct pci_controller pcie1_hose; -#endif +static const char *slot_names[] = { + [PCIE1] = "Slot 2", + [PCIE2] = "Slot 1", +};
-#ifdef CONFIG_PCIE2 -static struct pci_controller pcie2_hose; -#endif +const char *board_serdes_name(enum srds_prtcl device) +{ + return slot_names[device]; +}
void pci_init_board(void) { - volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - struct fsl_pci_info pci_info[2]; - u32 devdisr, pordevsr; - int first_free_busno = 0; - int num = 0; - - int pcie_ep, pcie_configured; - - devdisr = in_be32(&gur->devdisr); - pordevsr = in_be32(&gur->pordevsr); - - puts("\n"); -#ifdef CONFIG_PCIE2 - pcie_configured = is_serdes_configured(PCIE2); - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ - SET_STD_PCIE_INFO(pci_info[num], 2); - pcie_ep = fsl_setup_hose(&pcie2_hose, pci_info[num].regs); - printf("PCIE2: connected to Slot 1 as %s (base addr %lx)\n", - pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie2_hose, first_free_busno); - } else { - printf("PCIE2: disabled\n"); - } - puts("\n"); -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE2); /* disable */ -#endif - -#ifdef CONFIG_PCIE1 - pcie_configured = is_serdes_configured(PCIE1); - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ - SET_STD_PCIE_INFO(pci_info[num], 1); - pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); - printf("PCIE1: connected to Slot 2 as %s (base addr %lx)\n", - pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie1_hose, first_free_busno); - } else { - printf("PCIE1: disabled\n"); - } - puts("\n"); -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE); /* disable */ -#endif + fsl_pcie_init_board(0); }
void ft_pci_board_setup(void *blob)
Remove duplicated code in MPC8610HPCD board and utliize the common fsl_pcie_init_board(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/mpc8610hpcd/law.c | 8 +--- board/freescale/mpc8610hpcd/mpc8610hpcd.c | 80 +++++++++-------------------- 2 files changed, 25 insertions(+), 63 deletions(-)
diff --git a/board/freescale/mpc8610hpcd/law.c b/board/freescale/mpc8610hpcd/law.c index 0fc8384..26e41b6 100644 --- a/board/freescale/mpc8610hpcd/law.c +++ b/board/freescale/mpc8610hpcd/law.c @@ -1,5 +1,5 @@ /* - * Copyright 2008 Freescale Semiconductor, Inc. + * Copyright 2008,2010 Freescale Semiconductor, Inc. * * (C) Copyright 2000 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. @@ -31,14 +31,8 @@ struct law_entry law_table[] = { #if !defined(CONFIG_SPD_EEPROM) SET_LAW(CONFIG_SYS_DDR_SDRAM_BASE, LAW_SIZE_512M, LAW_TRGT_IF_DDR_1), #endif - SET_LAW(CONFIG_SYS_PCIE1_MEM_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_PCIE_1), - SET_LAW(CONFIG_SYS_PCIE2_MEM_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_PCIE_2), SET_LAW(PIXIS_BASE, LAW_SIZE_2M, LAW_TRGT_IF_LBC), - SET_LAW(CONFIG_SYS_PCIE1_IO_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_PCIE_1), - SET_LAW(CONFIG_SYS_PCIE2_IO_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_PCIE_2), SET_LAW(CONFIG_SYS_FLASH_BASE, LAW_SIZE_256M, LAW_TRGT_IF_LBC), - SET_LAW(CONFIG_SYS_PCI1_MEM_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_PCI_1), - SET_LAW(CONFIG_SYS_PCI1_IO_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_PCI_1) };
int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/freescale/mpc8610hpcd/mpc8610hpcd.c b/board/freescale/mpc8610hpcd/mpc8610hpcd.c index 8abd917..e1ccff8 100644 --- a/board/freescale/mpc8610hpcd/mpc8610hpcd.c +++ b/board/freescale/mpc8610hpcd/mpc8610hpcd.c @@ -213,78 +213,44 @@ config_table:pci_mpc86xxcts_config_table }; #endif /* CONFIG_PCI */
-#ifdef CONFIG_PCIE1 -static struct pci_controller pcie1_hose; -#endif - -#ifdef CONFIG_PCIE2 -static struct pci_controller pcie2_hose; -#endif +static const char *slot_names[] = { + [PCIE1] = "ULI", + [PCIE2] = "Slot 1", +}; + +const char *board_serdes_name(enum srds_prtcl device) +{ + return slot_names[device]; +}
void pci_init_board(void) { volatile immap_t *immap = (immap_t *) CONFIG_SYS_CCSRBAR; volatile ccsr_gur_t *gur = &immap->im_gur; - struct fsl_pci_info pci_info[3]; + struct fsl_pci_info pci_info; u32 devdisr, pordevsr; - int first_free_busno = 0; - int num = 0; - - int pci_agent, pcie_ep, pcie_configured; + int first_free_busno; + int pci_agent;
-#ifdef CONFIG_PCIE1 - pcie_configured = is_serdes_configured(PCIE1); - - if (pcie_configured && !(devdisr & MPC86xx_DEVDISR_PCIE1)){ - SET_STD_PCIE_INFO(pci_info[num], 1); - pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); - printf("PCIE1: connected to ULI as %s (base addr %lx)\n", - pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie1_hose, first_free_busno); - } else { - printf("PCIE1: disabled\n"); - } - - puts("\n"); -#else - setbits_be32(&gur->devdisr, MPC86xx_DEVDISR_PCIE1); /* disable */ -#endif - -#ifdef CONFIG_PCIE2 - pcie_configured = is_serdes_configured(PCIE2); - - if (pcie_configured && !(devdisr & MPC86xx_DEVDISR_PCIE2)){ - SET_STD_PCIE_INFO(pci_info[num], 2); - pcie_ep = fsl_setup_hose(&pcie2_hose, pci_info[num].regs); - printf("PCIE2: connected to Slot as %s (base addr %lx)\n", - pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie2_hose, first_free_busno); - } else { - printf("PCIE2: disabled\n"); - } - - puts("\n"); -#else - setbits_be32(&gur->devdisr, MPC86xx_DEVDISR_PCIE2); /* disable */ -#endif + first_free_busno = fsl_pcie_init_board(0);
#ifdef CONFIG_PCI1 if (!(devdisr & MPC86xx_DEVDISR_PCI1)) { - SET_STD_PCI_INFO(pci_info[num], 1); - pci_agent = fsl_setup_hose(&pci1_hose, pci_info[num].regs); + SET_STD_PCI_INFO(pci_info, 1); + set_next_law(pci_info.mem_phys, + law_size_bits(pci_info.mem_size), pci_info.law); + set_next_law(pci_info.io_phys, + law_size_bits(pci_info.io_size), pci_info.law); + + pci_agent = fsl_setup_hose(&pci1_hose, pci_info.regs); printf("PCI: connected to PCI slots as %s" \ " (base address %lx)\n", pci_agent ? "Agent" : "Host", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], + pci_info.regs); + first_free_busno = fsl_pci_init_port(&pci_info, &pci1_hose, first_free_busno); } else { printf("PCI: disabled\n"); @@ -294,6 +260,8 @@ void pci_init_board(void) #else setbits_be32(&gur->devdisr, MPC86xx_DEVDISR_PCI1); /* disable */ #endif + + fsl_pcie_init_board(first_free_busno); }
Remove duplicated code in SBC8641 board and utliize the common fsl_pcie_init_board(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled.
Signed-off-by: Kumar Gala galak@kernel.crashing.org CC: Paul Gortmaker paul.gortmaker@windriver.com --- board/sbc8641d/law.c | 4 --- board/sbc8641d/sbc8641d.c | 63 +------------------------------------------- 2 files changed, 2 insertions(+), 65 deletions(-)
diff --git a/board/sbc8641d/law.c b/board/sbc8641d/law.c index 705e1c2..a6f60ee 100644 --- a/board/sbc8641d/law.c +++ b/board/sbc8641d/law.c @@ -49,11 +49,7 @@ struct law_entry law_table[] = { SET_LAW(CONFIG_SYS_DDR_SDRAM_BASE + 0x10000000, LAW_SIZE_256M, LAW_TRGT_IF_DDR_2), #endif - SET_LAW(CONFIG_SYS_PCIE1_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCI_1), - SET_LAW(CONFIG_SYS_PCIE2_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCI_2), SET_LAW(0xf8000000, LAW_SIZE_2M, LAW_TRGT_IF_LBC), - SET_LAW(CONFIG_SYS_PCIE1_IO_PHYS, LAW_SIZE_16M, LAW_TRGT_IF_PCI_1), - SET_LAW(CONFIG_SYS_PCIE2_IO_PHYS, LAW_SIZE_16M, LAW_TRGT_IF_PCI_2), SET_LAW(0xfe000000, LAW_SIZE_32M, LAW_TRGT_IF_LBC), SET_LAW(CONFIG_SYS_RIO_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_RIO) }; diff --git a/board/sbc8641d/sbc8641d.c b/board/sbc8641d/sbc8641d.c index 5ee8f73..5c30b26 100644 --- a/board/sbc8641d/sbc8641d.c +++ b/board/sbc8641d/sbc8641d.c @@ -181,70 +181,11 @@ long int fixed_sdram (void) * Initialize PCI Devices, report devices found. */
-#ifndef CONFIG_PCI_PNP -static struct pci_config_table pci_fsl86xxads_config_table[] = { - {PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, - PCI_IDSEL_NUMBER, PCI_ANY_ID, - pci_cfgfunc_config_device, {PCI_ENET0_IOADDR, - PCI_ENET0_MEMADDR, - PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER}}, - {} -}; -#endif - -static struct pci_controller pcie1_hose = { -#ifndef CONFIG_PCI_PNP - config_table:pci_mpc86xxcts_config_table -#endif -}; -#endif /* CONFIG_PCI */ - -#ifdef CONFIG_PCIE2 -static struct pci_controller pcie2_hose; -#endif /* CONFIG_PCIE2 */ - -int first_free_busno = 0; - void pci_init_board(void) { - struct fsl_pci_info pci_info[2]; - volatile immap_t *immap = (immap_t *) CONFIG_SYS_CCSRBAR; - volatile ccsr_gur_t *gur = &immap->im_gur; - uint devdisr = in_be32(&gur->devdisr); - int pcie_ep; - int num = 0; - -#ifdef CONFIG_PCIE1 - int pcie_configured = is_serdes_configured(PCIE1); - - if (pcie_configured && !(devdisr & MPC86xx_DEVDISR_PCIEX1)) { - SET_STD_PCIE_INFO(pci_info[num], 1); - pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); - printf("PCIE1: connected as %s (base addr %lx)\n", - pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie1_hose, first_free_busno); - } else { - puts("PCIE1: disabled\n"); - } -#else - puts("PCIE1: disabled\n"); -#endif /* CONFIG_PCIE1 */ - -#ifdef CONFIG_PCIE2 - - SET_STD_PCIE_INFO(pci_info[num], 2); - pcie_ep = fsl_setup_hose(&pcie2_hose, pci_info[num].regs); - printf("PCIE2: connected as %s (base addr %lx)\n", - pcie_ep ? "Endpoint" : "Root Complex", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie2_hose, first_free_busno); -#else - puts("PCIE2: disabled\n"); -#endif /* CONFIG_PCIE2 */ + fsl_pcie_init_board(0); } +#endif /* CONFIG_PCI */
Remove duplicated code in SBC8548 board and utliize the common fsl_pcie_init_board(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled.
Signed-off-by: Kumar Gala galak@kernel.crashing.org CC: Paul Gortmaker paul.gortmaker@windriver.com --- board/sbc8548/law.c | 8 ------- board/sbc8548/sbc8548.c | 50 ++++++++++++---------------------------------- 2 files changed, 13 insertions(+), 45 deletions(-)
diff --git a/board/sbc8548/law.c b/board/sbc8548/law.c index 6d1efc0..5fa9db0 100644 --- a/board/sbc8548/law.c +++ b/board/sbc8548/law.c @@ -50,14 +50,6 @@ struct law_entry law_table[] = { #ifndef CONFIG_SPD_EEPROM SET_LAW(CONFIG_SYS_DDR_SDRAM_BASE, LAW_SIZE_256M, LAW_TRGT_IF_DDR), #endif -#ifdef CONFIG_SYS_PCI1_MEM_PHYS - SET_LAW(CONFIG_SYS_PCI1_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCI), - SET_LAW(CONFIG_SYS_PCI1_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCI), -#endif -#ifdef CONFIG_SYS_PCIE1_MEM_PHYS - SET_LAW(CONFIG_SYS_PCIE1_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCIE_1), - SET_LAW(CONFIG_SYS_PCIE1_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCIE_1), -#endif /* LBC window - maps 256M 0xf0000000 -> 0xffffffff */ SET_LAW(CONFIG_SYS_LBC_SDRAM_BASE, LAW_SIZE_256M, LAW_TRGT_IF_LBC), }; diff --git a/board/sbc8548/sbc8548.c b/board/sbc8548/sbc8548.c index 06c1eea..f0e591b 100644 --- a/board/sbc8548/sbc8548.c +++ b/board/sbc8548/sbc8548.c @@ -310,33 +310,19 @@ long int fixed_sdram (void) static struct pci_controller pci1_hose; #endif /* CONFIG_PCI1 */
-#ifdef CONFIG_PCIE1 -static struct pci_controller pcie1_hose; -#endif /* CONFIG_PCIE1 */ - - #ifdef CONFIG_PCI void pci_init_board(void) { volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - struct fsl_pci_info pci_info[2]; - u32 devdisr, pordevsr, porpllsr, io_sel; int first_free_busno = 0; - int num = 0; - -#ifdef CONFIG_PCIE1 - int pcie_configured; -#endif - - devdisr = in_be32(&gur->devdisr); - pordevsr = in_be32(&gur->pordevsr); - porpllsr = in_be32(&gur->porpllsr); - io_sel = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19; - - debug(" pci_init_board: devdisr=%x, io_sel=%x\n", devdisr, io_sel);
#ifdef CONFIG_PCI1 + struct fsl_pci_info pci_info; + u32 devdisr = in_be32(&gur->devdisr); + u32 pordevsr = in_be32(&gur->pordevsr); + u32 porpllsr = in_be32(&gur->porpllsr); + if (!(devdisr & MPC85xx_DEVDISR_PCI1)) { uint pci_32 = pordevsr & MPC85xx_PORDEVSR_PCI1_PCI32; uint pci_arb = pordevsr & MPC85xx_PORDEVSR_PCI1_ARB; @@ -350,8 +336,13 @@ pci_init_board(void) pci_clk_sel ? "sync" : "async", pci_arb ? "arbiter" : "external-arbiter");
- SET_STD_PCI_INFO(pci_info[num], 1); - first_free_busno = fsl_pci_init_port(&pci_info[num++], + SET_STD_PCI_INFO(pci_info, 1); + set_next_law(pci_info.mem_phys, + law_size_bits(pci_info.mem_size), pci_info.law); + set_next_law(pci_info.io_phys, + law_size_bits(pci_info.io_size), pci_info.law); + + first_free_busno = fsl_pci_init_port(&pci_info, &pci1_hose, first_free_busno); } else { printf("PCI: disabled\n"); @@ -364,22 +355,7 @@ pci_init_board(void)
setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCI2); /* disable PCI2 */
-#ifdef CONFIG_PCIE1 - pcie_configured = is_serdes_configured(PCIE1); - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ - SET_STD_PCIE_INFO(pci_info[num], 1); - printf("PCIE: base address %lx\n", pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie1_hose, first_free_busno); - } else { - printf("PCIE: disabled\n"); - } - - puts("\n"); -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE); /* disable */ -#endif + fsl_pcie_init_board(first_free_busno); } #endif
[[PATCH 15/15] powerpc/85xx: Rework SBC8548 pci_init_board to use common FSL PCIe code] On 17/12/2010 (Fri 17:50) Kumar Gala wrote:
Tested-by: Paul Gortmaker paul.gortmaker@windriver.com
Tested with Peter's anti-NULL patch on top of the mpc85xx dev branch. Board has both PCI-X and PCI-e slots, with e1000 and skge respectively.
P.
U-Boot 2010.12-00426-ged7ea8f (Jan 06 2011 - 15:43:08)
CPU: 8548E, Version: 2.0, (0x80390020) Core: E500, Version: 2.0, (0x80210020) Clock Configuration: CPU0:990 MHz, CCB:396 MHz, DDR:198 MHz (396 MT/s data rate), LBC:99 MHz L1: D-cache 32 kB enabled I-cache 32 kB enabled Board: Wind River SBC8548 Rev. 0x2 I2C: ready DRAM: SDRAM: 128 MiB DDR: 256 MiB (DDR2, 64-bit, CL=4, ECC off) DDR Chip-Select Interleaving Mode: CS0+CS1 FLASH: 72 MiB L2: 512 KB already enabled *** Warning - bad CRC, using default environment
PCI: Host, 64 bit, 66 MHz, sync, arbiter 00:01.0 - 8086:1026 - Network controller PCI1: Bus 00 - 00
PCIe1: Root Complex, x1, regs @ 0xe000a000 02:00.0 - 1148:9e00 - Network controller PCIe1: Bus 01 - 02 In: serial Out: serial Err: serial Net: eTSEC0, eTSEC1 Hit any key to stop autoboot: 0 => pci 0 Scanning PCI devices on bus 0 BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ 00.00.00 0x1057 0x0012 Processor 0x20 00.01.00 0x8086 0x1026 Network controller 0x00 => pci 1 Scanning PCI devices on bus 1 BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ 01.00.00 0x1957 0x0012 Processor 0x20 => pci 2 Scanning PCI devices on bus 2 BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ 02.00.00 0x1148 0x9e00 Network controller 0x00 =>
applied to 85xx, fixed commit typo s/utliize/utilize/
- k
- k
- k
- k
- k
- k
- k
Thanks for the cleanup. What branch should this series be applied to? And are there prerequisites? I'm having issues applying them to test and review.
Looks like a copy/paste from the MPC8572.
On all the patches in the series s/utliize/utilize/.
<snip>
Is there a reason PCI1 wasn't changed over too? I see pci1_hose is still referenced below, but other boards with a PCI1 don't use similar code.
<snip>
The PCI2 law can be removed too. Its not currently used on any boards supported by mainline U-Boot.
Thanks, Peter
<snip>
Will fix, oops ;)
I was trying to limit how much clean up I did so left this to just PCIe interfaces. Normal PCI and PCI-X is something I might get around to but one thing at a time
<snip>
Ok, will remove in updated patch
- k
Any direction on how these should be applied for testing?
<snip>
Ah, OK. If we're removing the LAW entries for PCI1 in law.c below, how is a LAW being set for PCI1? It looks like PCIe laws are set in fsl_configure_pcie(), and PCI LAWs are set via set_next_law() in board-specific code? I'm not seeing the call to set_next_law() in X-ES board specific code after this change though.
Best, Peter
<snip>
<snip>
I've pushed a 'dev' branch on u-boot-85xx.git on denx.de with the current set of patches applied.
- k
<snip>
Thanks. Things are much tidier now. I had a few comments. Let me know if you'd like me to submit patches to address any of them.
* There's a large chunk of defines that are no longer needed in the X-ES board code:
--- a/board/xes/common/fsl_8xxx_pci.c +++ b/board/xes/common/fsl_8xxx_pci.c @@ -35,29 +35,6 @@ static struct pci_controller pci1_hose; #endif
-/* - * 85xx and 86xx share naming conventions, but different layout. - * Correlate names to CPU-specific values to share common - * PCI code. - */ -#if defined(CONFIG_MPC85xx) -#define MPC8xxx_DEVDISR_PCIE1 MPC85xx_DEVDISR_PCIE -#define MPC8xxx_DEVDISR_PCIE2 MPC85xx_DEVDISR_PCIE2 -#define MPC8xxx_DEVDISR_PCIE3 MPC85xx_DEVDISR_PCIE3 -#define MPC8xxx_PORDEVSR_IO_SEL MPC85xx_PORDEVSR_IO_SEL -#define MPC8xxx_PORDEVSR_IO_SEL_SHIFT MPC85xx_PORDEVSR_IO_SEL_SHIFT -#define MPC8xxx_PORBMSR_HA MPC85xx_PORBMSR_HA -#define MPC8xxx_PORBMSR_HA_SHIFT MPC85xx_PORBMSR_HA_SHIFT -#elif defined(CONFIG_MPC86xx) -#define MPC8xxx_DEVDISR_PCIE1 MPC86xx_DEVDISR_PCIEX1 -#define MPC8xxx_DEVDISR_PCIE2 MPC86xx_DEVDISR_PCIEX2 -#define MPC8xxx_DEVDISR_PCIE3 0 /* 8641 doesn't have PCIe3 */ -#define MPC8xxx_PORDEVSR_IO_SEL MPC8641_PORDEVSR_IO_SEL -#define MPC8xxx_PORDEVSR_IO_SEL_SHIFT MPC8641_PORDEVSR_IO_SEL_SHIFT -#define MPC8xxx_PORBMSR_HA MPC8641_PORBMSR_HA -#define MPC8xxx_PORBMSR_HA_SHIFT MPC8641_PORBMSR_HA_SHIFT -#endif - void pci_init_board(void) { int first_free_busno = 0;
* It'd be nice if boards didn't have to define board_serdes_name(), or at least a sane print statement was used if it wasn't. When I booted an X-ES board the first time I got: PCIE1: connected to <NULL> as Endpoint (base addr ef008000) PCIE1: Bus 00 - 00 PCIE2: connected to <NULL> as Endpoint (base addr ef009000) PCIE2: Bus 01 - 01
Other boards will have the same issue. Something like the following?: --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -526,8 +526,8 @@ int fsl_configure_pcie(struct fsl_pci_info *info, set_next_law(info->mem_phys, law_size_bits(info->mem_size), info->law); set_next_law(info->io_phys, law_size_bits(info->io_size), info->law); is_endpoint = fsl_setup_hose(hose, info->regs); - printf("PCIE%u: connected to %s as %s (base addr %lx)\n", - info->pci_num, connected, + printf("PCIE%u: connected%s%s as %s (base addr %lx)\n", + info->pci_num, connected ? " to " : "", connected ? connected : "", is_endpoint ? "Endpoint" : "Root Complex", info->regs); return fsl_pci_init_port(info, hose, busno); }
* Lastly, what about using a new define to specify the PCIe port's name instead of making each board add a board_serdes_name() function? This reduces each board directory's clutter and makes it so all PCIe-related configuration and naming occurs in the board's config.h file. As an example that uses the xpedite517x and mpc8572ds: --- a/board/freescale/mpc8572ds/mpc8572ds.c +++ b/board/freescale/mpc8572ds/mpc8572ds.c @@ -149,17 +149,6 @@ phys_size_t fixed_sdram (void) #endif
#ifdef CONFIG_PCI -static const char *slot_names[] = { - [PCIE1] = "Slot 2", - [PCIE2] = "Slot 1", - [PCIE3] = "ULI", -}; - -const char *board_serdes_name(enum srds_prtcl device) -{ - return slot_names[device]; -} - void pci_init_board(void) { struct pci_controller *hose; --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -558,7 +558,26 @@ int fsl_configure_pcie(struct fsl_pci_info *info, /* Implement a dummy function for those platforms w/o SERDES */ static const char *__board_serdes_name(enum srds_prtcl device) { - return NULL; + switch (device) { +#ifdef CONFIG_SYS_PCIE1_NAME + case PCIE1: + return CONFIG_SYS_PCIE1_NAME; +#endif +#ifdef CONFIG_SYS_PCIE2_NAME + case PCIE2: + return CONFIG_SYS_PCIE2_NAME; +#endif +#ifdef CONFIG_SYS_PCIE3_NAME + case PCIE3: + return CONFIG_SYS_PCIE3_NAME; +#endif +#ifdef CONFIG_SYS_PCIE4_NAME + case PCIE4: + return CONFIG_SYS_PCIE4_NAME; +#endif + default: + return NULL; + } }
__attribute__((weak, alias("__board_serdes_name"))) const char * --- a/include/configs/xpedite517x.h +++ b/include/configs/xpedite517x.h @@ -347,6 +347,7 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 #define CONFIG_SYS_PCIE1_IO_PHYS 0xe8000000 #define CONFIG_SYS_PCIE1_IO_SIZE 0x00800000 /* 8M */ +#define CONFIG_SYS_PCIE1_NAME "PEX8518 Switch"
/* PCIE2 - VPX P1 */ #define CONFIG_SYS_PCIE2_MEM_BUS 0xc0000000 @@ -355,6 +356,7 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 #define CONFIG_SYS_PCIE2_IO_PHYS 0xe8800000 #define CONFIG_SYS_PCIE2_IO_SIZE 0x00800000 /* 8M */ +#define CONFIG_SYS_PCIE2_NAME "VPX Fabric A"
/* * Networking options --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -485,6 +485,7 @@ #define CONFIG_SYS_PCIE3_IO_PHYS 0xffc00000 #endif #define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_SYS_PCIE3_NAME "ULI"
/* controller 2, Slot 2, tgtid 2, Base address 9000 */ #define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 @@ -504,6 +505,7 @@ #define CONFIG_SYS_PCIE2_IO_PHYS 0xffc10000 #endif #define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_SYS_PCIE2_NAME "Slot 1"
/* controller 1, Slot 1, tgtid 1, Base address a000 */ #define CONFIG_SYS_PCIE1_MEM_VIRT 0xc0000000 @@ -523,6 +525,7 @@ #define CONFIG_SYS_PCIE1_IO_PHYS 0xffc20000 #endif #define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ +#define CONFIG_SYS_PCIE1_NAME "Slot 2"
Best, Peter
Remove duplicated code in MPC8xxx XES boards and utilize the common fsl_pcie_init_board().
Signed-off-by: Kumar Gala galak@kernel.crashing.org CC: Peter Tyser ptyser@xes-inc.com --- * Fix commit message copy/paste issue per Peter T. * Fixed utilize typo per Peter T. * removed PCI2 on xpedite520x per Peter T. * Removed duplicate/now unused MPC8xxx defines per Peter T.
board/xes/common/fsl_8xxx_pci.c | 110 +++++---------------------------------- board/xes/xpedite517x/law.c | 8 --- board/xes/xpedite520x/law.c | 8 --- board/xes/xpedite537x/law.c | 12 ---- board/xes/xpedite550x/law.c | 12 ---- 5 files changed, 13 insertions(+), 137 deletions(-)
diff --git a/board/xes/common/fsl_8xxx_pci.c b/board/xes/common/fsl_8xxx_pci.c index 4135849..28c83c7 100644 --- a/board/xes/common/fsl_8xxx_pci.c +++ b/board/xes/common/fsl_8xxx_pci.c @@ -34,57 +34,16 @@ #ifdef CONFIG_PCI1 static struct pci_controller pci1_hose; #endif -#ifdef CONFIG_PCIE1 -static struct pci_controller pcie1_hose; -#endif -#ifdef CONFIG_PCIE2 -static struct pci_controller pcie2_hose; -#endif -#ifdef CONFIG_PCIE3 -static struct pci_controller pcie3_hose; -#endif - -/* - * 85xx and 86xx share naming conventions, but different layout. - * Correlate names to CPU-specific values to share common - * PCI code. - */ -#if defined(CONFIG_MPC85xx) -#define MPC8xxx_DEVDISR_PCIE1 MPC85xx_DEVDISR_PCIE -#define MPC8xxx_DEVDISR_PCIE2 MPC85xx_DEVDISR_PCIE2 -#define MPC8xxx_DEVDISR_PCIE3 MPC85xx_DEVDISR_PCIE3 -#define MPC8xxx_PORDEVSR_IO_SEL MPC85xx_PORDEVSR_IO_SEL -#define MPC8xxx_PORDEVSR_IO_SEL_SHIFT MPC85xx_PORDEVSR_IO_SEL_SHIFT -#define MPC8xxx_PORBMSR_HA MPC85xx_PORBMSR_HA -#define MPC8xxx_PORBMSR_HA_SHIFT MPC85xx_PORBMSR_HA_SHIFT -#elif defined(CONFIG_MPC86xx) -#define MPC8xxx_DEVDISR_PCIE1 MPC86xx_DEVDISR_PCIEX1 -#define MPC8xxx_DEVDISR_PCIE2 MPC86xx_DEVDISR_PCIEX2 -#define MPC8xxx_DEVDISR_PCIE3 0 /* 8641 doesn't have PCIe3 */ -#define MPC8xxx_PORDEVSR_IO_SEL MPC8641_PORDEVSR_IO_SEL -#define MPC8xxx_PORDEVSR_IO_SEL_SHIFT MPC8641_PORDEVSR_IO_SEL_SHIFT -#define MPC8xxx_PORBMSR_HA MPC8641_PORBMSR_HA -#define MPC8xxx_PORBMSR_HA_SHIFT MPC8641_PORBMSR_HA_SHIFT -#endif
-#if defined(CONFIG_MPC85xx) +#ifdef CONFIG_PCI1 + int pcie_ep; + struct fsl_pci_info pci_info; volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); -#elif defined(CONFIG_MPC86xx) - immap_t *immap = (immap_t *)CONFIG_SYS_IMMR; - volatile ccsr_gur_t *gur = &immap->im_gur; -#endif u32 devdisr = in_be32(&gur->devdisr); - -#ifdef CONFIG_PCI1 - u32 pordevsr = in_be32(&gur->pordevsr); uint pci_spd_norm = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1_SPD; uint pci_32 = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1_PCI32; uint pci_arb = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1_ARB; @@ -92,8 +51,13 @@ void pci_init_board(void) uint freq = CONFIG_SYS_CLK_FREQ / 1000 / 1000;
if (!(devdisr & MPC85xx_DEVDISR_PCI1)) { - SET_STD_PCI_INFO(pci_info[num], 1); - pcie_ep = fsl_setup_hose(&pci1_hose, pci_info[num].regs); + SET_STD_PCI_INFO(pci_info, 1); + set_next_law(pci_info.mem_phys, + law_size_bits(pci_info.mem_size), pci_info.law); + set_next_law(pci_info.io_phys, + law_size_bits(pci_info.io_size), pci_info.law); + + pcie_ep = fsl_setup_hose(&pci1_hose, pci_info.regs); printf("PCI1: %d bit %s, %s %d MHz, %s, %s\n", pci_32 ? 32 : 64, pcix ? "PCIX" : "PCI", @@ -102,66 +66,18 @@ void pci_init_board(void) pcie_ep ? "agent" : "host", pci_arb ? "arbiter" : "external-arbiter");
int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/xes/xpedite520x/law.c b/board/xes/xpedite520x/law.c index bbfcb9d..5c1fcd2 100644 --- a/board/xes/xpedite520x/law.c +++ b/board/xes/xpedite520x/law.c @@ -38,14 +38,6 @@ struct law_entry law_table[] = { /* LBC window - maps 256M 0xf0000000 -> 0xffffffff */ SET_LAW(CONFIG_SYS_FLASH_BASE2, LAW_SIZE_256M, LAW_TRGT_IF_LBC), SET_LAW(CONFIG_SYS_NAND_BASE, LAW_SIZE_1M, LAW_TRGT_IF_LBC), -#if CONFIG_SYS_PCI1_MEM_PHYS - SET_LAW(CONFIG_SYS_PCI1_MEM_PHYS, LAW_SIZE_1G, LAW_TRGT_IF_PCI_1), - SET_LAW(CONFIG_SYS_PCI1_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCI_1), -#endif -#if CONFIG_SYS_PCI2_MEM_PHYS - SET_LAW(CONFIG_SYS_PCI2_MEM_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_PCI_2), - SET_LAW(CONFIG_SYS_PCI2_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCI_2), -#endif };
int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/xes/xpedite537x/law.c b/board/xes/xpedite537x/law.c index daee676..54c28da 100644 --- a/board/xes/xpedite537x/law.c +++ b/board/xes/xpedite537x/law.c @@ -37,18 +37,6 @@ struct law_entry law_table[] = { SET_LAW(CONFIG_SYS_FLASH_BASE2, LAW_SIZE_256M, LAW_TRGT_IF_LBC), SET_LAW(CONFIG_SYS_NAND_BASE, LAW_SIZE_1M, LAW_TRGT_IF_LBC), -#ifdef CONFIG_SYS_PCIE1_MEM_PHYS - SET_LAW(CONFIG_SYS_PCIE1_MEM_PHYS, LAW_SIZE_1G, LAW_TRGT_IF_PCIE_1), - SET_LAW(CONFIG_SYS_PCIE1_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCIE_1), -#endif -#ifdef CONFIG_SYS_PCIE2_MEM_PHYS - SET_LAW(CONFIG_SYS_PCIE2_MEM_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_PCIE_2), - SET_LAW(CONFIG_SYS_PCIE2_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCIE_2), -#endif -#ifdef CONFIG_SYS_PCIE3_MEM_PHYS - SET_LAW(CONFIG_SYS_PCIE3_MEM_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_PCIE_3), - SET_LAW(CONFIG_SYS_PCIE3_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCIE_3), -#endif };
- Fix commit message copy/paste issue per Peter T.
- Fixed utilize typo per Peter T.
- removed PCI2 on xpedite520x per Peter T.
- Removed duplicate/now unused MPC8xxx defines per Peter T.
applied to 85xx
- k
Best, Peter
Yep, that was missing, will fix ;)
- k
- k
- k
Remove duplicated code in MPC8536DS board and utliize the common fsl_pcie_init_board().
board/freescale/mpc8536ds/mpc8536ds.c | 125 ++++++-------------------------- 1 files changed, 24 insertions(+), 101 deletions(-)
- k
Remove duplicated code in MPC8544DS board and utliize the common fsl_pcie_init_ctrl(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled.
We don't use the full fsl_pcie_init_ctrl() since we have to handle PCIE3 specially to setup the additional memory map region and we utilize a single LAW to cover the controller.
board/freescale/mpc8544ds/law.c | 10 +--- board/freescale/mpc8544ds/mpc8544ds.c | 110 +++++++++++---------------------- 2 files changed, 37 insertions(+), 83 deletions(-)
- k
Remove duplicated code in P2020DS board and utliize the common fsl_pcie_init_board(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled.
board/freescale/p2020ds/law.c | 8 +-- board/freescale/p2020ds/p2020ds.c | 114 ++++--------------------------------- 2 files changed, 12 insertions(+), 110 deletions(-)
Added attribution to Leo Li's original P2020 DS serdes clean up patches.
- k
Remove duplicated code in MPC8572DS board and utliize the common fsl_pcie_init_board(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled.
board/freescale/mpc8572ds/law.c | 8 +-- board/freescale/mpc8572ds/mpc8572ds.c | 100 ++++++-------------------------- 2 files changed, 20 insertions(+), 88 deletions(-)
* added signed off by Chenhui Zhao b26998@freescale.com
- k
Since all the PCIe controllers are connected over SERDES on the SoCs we can utilize is_serdes_configured() to determine if a controller is enabled. After which we can setup the ATMUs and LAWs for the controller in a common fashion and allow board code to specify what the controller is connected to for reporting reasons.
We also provide a per controller (rather than all) for some systems that may have special requirements.
Finally, we refactor the code used by the P1022DS to utilize the new generic code.
arch/powerpc/include/asm/fsl_pci.h | 10 +++ board/freescale/p1022ds/p1022ds.c | 67 +------------------ drivers/pci/fsl_pci_init.c | 127 ++++++++++++++++++++++++++++++++++++ 3 files changed, 139 insertions(+), 65 deletions(-)
applied to 85xx
- k
Kumar Gala
Paul Gortmaker
Peter Tyser
