[U-Boot-Users] [PATCH] DM644x: This patch removes all boardspecific code from the arch. part for DM644x (DaVinci) boards
Hello Jean-Christophe,
Wolfgang D. still had some comments on comments in this patch, a fixed version is below. Do you require the other patch with the PMDRA board addition also to be resend?
Best regards, Pieter
Signed-off-by: Pieter Voorthuijsen pv@prodrive.nl --- cpu/arm926ejs/davinci/lowlevel_init.S | 76 +++++++++++++++++++----------- cpu/arm926ejs/davinci/nand.c | 42 +++--------------- include/asm-arm/arch-davinci/hardware.h | 2 + include/configs/davinci_dvevm.h | 44 +++++++++++++++--- include/configs/davinci_schmoogie.h | 18 +++++++- include/configs/davinci_sonata.h | 17 +++++++ 6 files changed, 126 insertions(+), 73 deletions(-)
diff --git a/cpu/arm926ejs/davinci/lowlevel_init.S b/cpu/arm926ejs/davinci/lowlevel_init.S index a87c112..5dd70d5 100644 --- a/cpu/arm926ejs/davinci/lowlevel_init.S +++ b/cpu/arm926ejs/davinci/lowlevel_init.S @@ -3,6 +3,8 @@ * * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net * + * Copyright (C) 2008 Prodrive BV pv@prodrive.nl + * * Partially based on TI sources, original copyrights follow: */
@@ -156,17 +158,17 @@ WaitPPL2Loop:
/* Program the PLL Multiplier */ ldr r6, PLL2_PLLM - mov r2, $0x17 /* 162 MHz */ + mov r2, $CFG_DAVINCI_PLL2_PLLM str r2, [r6]
/* Program the PLL2 Divisor Value */ ldr r6, PLL2_DIV2 - mov r3, $0x01 + mov r3, $CFG_DAVINCI_PLL2_DIV2 str r3, [r6]
/* Program the PLL2 Divisor Value */ ldr r6, PLL2_DIV1 - mov r4, $0x0b /* 54 MHz */ + mov r4, $CFG_DAVINCI_PLL2_DIV1 str r4, [r6]
/* PLL2 DIV2 MMR */ @@ -273,7 +275,7 @@ checkDDRStatClkStop: bne checkDDRStatClkStop
/*------------------------------------------------------* - * Program DDR2 MMRs for 162MHz Setting * + * Program DDR2 MMRs * *------------------------------------------------------*/
/* Program PHY Control Register */ @@ -288,12 +290,12 @@ checkDDRStatClkStop:
/* Program SDRAM TIM-0 Config Register */ ldr r6, SDTIM0 - ldr r7, SDTIM0_VAL_162MHz + ldr r7, SDTIM0_VAL str r7, [r6]
/* Program SDRAM TIM-1 Config Register */ ldr r6, SDTIM1 - ldr r7, SDTIM1_VAL_162MHz + ldr r7, SDTIM1_VAL str r7, [r6]
/* Program the SDRAM Bank Config Control Register */ @@ -435,7 +437,7 @@ WaitLoop:
/* Program the PLL Multiplier */ ldr r6, PLL1_PLLM - mov r3, $0x15 /* For 594MHz */ + mov r3, $CFG_DAVINCI_PLL1_PLLM str r3, [r6]
/* Wait for PLL to Reset Properly */ @@ -467,7 +469,7 @@ PLL1Lock: nop
/*------------------------------------------------------* - * AEMIF configuration for NOR Flash (double check) * + * AEMIF configuration for NAND/NOR Flash * *------------------------------------------------------*/ ldr r0, _PINMUX0 ldr r1, _DEV_SETTING @@ -479,6 +481,12 @@ PLL1Lock: orr r2, r2, r1 str r2, [r0]
+ ldr r0, ACFG2 + ldr r1, ACFG2_VAL + ldr r2, [r0] + and r1, r2, r1 + str r1, [r0] + ldr r0, ACFG3 ldr r1, ACFG3_VAL ldr r2, [r0] @@ -497,6 +505,12 @@ PLL1Lock: and r1, r2, r1 str r1, [r0]
+ ldr r0, NANDFCR + ldr r1, NANDFCR_VAL + ldr r2, [r0] + and r1, r2, r1 + str r1, [r0] + /*--------------------------------------* * VTP manual Calibration * *--------------------------------------*/ @@ -560,24 +574,36 @@ _PINMUX1: .word 0x01c40004 /* Device Configuration Registers */
_DEV_SETTING: - .word 0x00000c1f + .word CFG_DAVINCI_PINMUX_0
WAITCFG: .word 0x01e00004 WAITCFG_VAL: - .word 0 + .word CFG_DAVINCI_WAITCFG +ACFG2: + .word 0x01e00010 +ACFG2_VAL: + .word CFG_DAVINCI_ACFG2 ACFG3: .word 0x01e00014 ACFG3_VAL: - .word 0x3ffffffd + .word CFG_DAVINCI_ACFG3 ACFG4: .word 0x01e00018 ACFG4_VAL: - .word 0x3ffffffd + .word CFG_DAVINCI_ACFG4 ACFG5: .word 0x01e0001c ACFG5_VAL: - .word 0x3ffffffd + .word CFG_DAVINCI_ACFG5 +NANDFCR: + .word 0x01e00060 +NANDFCR_VAL: +#ifdef CFG_DAVINCI_NANDCE + .word (1 << (CFG_DAVINCI_NANDCE - 2)) +#else + .word 0x00000000 +#endif
MDCTL_DDR2: .word 0x01c41a34 @@ -599,33 +625,27 @@ PSC_FLAG_CLEAR: PSC_GEM_FLAG_CLEAR: .word 0xfffffeff
-/* DDR2 MMR & CONFIGURATION VALUES, 162 MHZ clock */ +/* DDR2 MMR & CONFIGURATION VALUES */ DDRCTL: .word 0x200000e4 DDRCTL_VAL: - .word 0x50006405 + .word CFG_DAVINCI_DDRCTL SDREF: .word 0x2000000c SDREF_VAL: - .word 0x000005c3 + .word CFG_DAVINCI_SDREF SDCFG: .word 0x20000008 SDCFG_VAL: -#ifdef DDR_4BANKS - .word 0x00178622 -#elif defined DDR_8BANKS - .word 0x00178632 -#else -#error "Unknown DDR configuration!!!" -#endif + .word CFG_DAVINCI_SDCFG SDTIM0: .word 0x20000010 -SDTIM0_VAL_162MHz: - .word 0x28923211 +SDTIM0_VAL: + .word CFG_DAVINCI_SDTIM0 SDTIM1: .word 0x20000014 -SDTIM1_VAL_162MHz: - .word 0x0016c722 +SDTIM1_VAL: + .word CFG_DAVINCI_SDTIM1 VTPIOCR: .word 0x200000f0 /* VTP IO Control register */ DDRVTPR: @@ -699,7 +719,7 @@ PLL2_DIV_MASK: MMARG_BRF0: .word 0x01c42010 /* BRF margin mode 0 (R/W)*/ MMARG_BRF0_VAL: - .word 0x00444400 + .word CFG_DAVINCI_MMARG_BRF0
DDR2_START_ADDR: .word 0x80000000 diff --git a/cpu/arm926ejs/davinci/nand.c b/cpu/arm926ejs/davinci/nand.c index 127be9f..e49645c 100644 --- a/cpu/arm926ejs/davinci/nand.c +++ b/cpu/arm926ejs/davinci/nand.c @@ -117,7 +117,7 @@ static void nand_davinci_enable_hwecc(struct mtd_info *mtd, int mode) dummy = emif_addr->NANDF3ECC; dummy = emif_addr->NANDF4ECC;
- emif_addr->NANDFCR |= (1 << 8); + emif_addr->NANDFCR |= (1 << (CFG_DAVINCI_NANDCE + 6)); }
static u_int32_t nand_davinci_readecc(struct mtd_info *mtd, u_int32_t region) @@ -147,7 +147,7 @@ static int nand_davinci_calculate_ecc(struct mtd_info *mtd, const u_char *dat, u
n = (this->eccmode == NAND_ECC_HW12_2048) ? 4 : 1;
- region = 1; + region = (CFG_DAVINCI_NANDCE - 1); while (n--) { tmp = nand_davinci_readecc(mtd, region); *ecc_code++ = tmp; @@ -311,40 +311,10 @@ static int nand_davinci_waitfunc(struct mtd_info *mtd, struct nand_chip *this, i
static void nand_flash_init(void) { - u_int32_t acfg1 = 0x3ffffffc; - u_int32_t acfg2 = 0x3ffffffc; - u_int32_t acfg3 = 0x3ffffffc; - u_int32_t acfg4 = 0x3ffffffc; - emifregs emif_regs; - - /*------------------------------------------------------------------* - * NAND FLASH CHIP TIMEOUT @ 459 MHz * - * * - * AEMIF.CLK freq = PLL1/6 = 459/6 = 76.5 MHz * - * AEMIF.CLK period = 1/76.5 MHz = 13.1 ns * - * * - *------------------------------------------------------------------*/ - acfg1 = 0 - | (0 << 31 ) /* selectStrobe */ - | (0 << 30 ) /* extWait */ - | (1 << 26 ) /* writeSetup 10 ns */ - | (3 << 20 ) /* writeStrobe 40 ns */ - | (1 << 17 ) /* writeHold 10 ns */ - | (1 << 13 ) /* readSetup 10 ns */ - | (5 << 7 ) /* readStrobe 60 ns */ - | (1 << 4 ) /* readHold 10 ns */ - | (3 << 2 ) /* turnAround ?? ns */ - | (0 << 0 ) /* asyncSize 8-bit bus */ - ; - - emif_regs = (emifregs)DAVINCI_ASYNC_EMIF_CNTRL_BASE; - - emif_regs->AWCCR |= 0x10000000; - emif_regs->AB1CR = acfg1; /* 0x08244128 */; - emif_regs->AB2CR = acfg2; - emif_regs->AB3CR = acfg3; - emif_regs->AB4CR = acfg4; - emif_regs->NANDFCR = 0x00000101; + /* + * All EMIF initialization is done in lowlevel_init.S + * and config values are in the board config files + */ }
int board_nand_init(struct nand_chip *nand) diff --git a/include/asm-arm/arch-davinci/hardware.h b/include/asm-arm/arch-davinci/hardware.h index ebcdcfe..2b3eb90 100644 --- a/include/asm-arm/arch-davinci/hardware.h +++ b/include/asm-arm/arch-davinci/hardware.h @@ -150,6 +150,8 @@ typedef volatile unsigned int * dv_reg_p;
#define VDD3P3V_PWDN (0x01c40048) #define UART0_PWREMU_MGMT (0x01c20030) +#define UART1_PWREMU_MGMT (0x01c20430) +#define UART2_PWREMU_MGMT (0x01c20830)
#define PSC_SILVER_BULLET (0x01c41a20)
diff --git a/include/configs/davinci_dvevm.h b/include/configs/davinci_dvevm.h index 8ecd059..5a2554c 100644 --- a/include/configs/davinci_dvevm.h +++ b/include/configs/davinci_dvevm.h @@ -52,6 +52,10 @@ #define DV_EVM #define CFG_NAND_SMALLPAGE #define CFG_USE_NOR +#define CFG_USE_INTEL_NOR /* + * Define this when your DVEVM has Intel + * flash instead of AMD flash + */ /*===================*/ /* SoC Configuration */ /*===================*/ @@ -60,6 +64,23 @@ #define CFG_TIMERBASE 0x01c21400 /* use timer 0 */ #define CFG_HZ_CLOCK 27000000 /* Timer Input clock freq */ #define CFG_HZ 1000 +#define CFG_DAVINCI_PINMUX_0 0x00000c1f +#define CFG_DAVINCI_WAITCFG 0x00000000 +#define CFG_DAVINCI_ACFG2 0x3ffffffd /* CE configs */ +#define CFG_DAVINCI_ACFG3 0x3ffffffd +#define CFG_DAVINCI_ACFG4 0x3ffffffd +#define CFG_DAVINCI_ACFG5 0x3ffffffd +#undef CFG_DAVINCI_NANDCE /* When using NAND, define 2,3 or 4 */ +#define CFG_DAVINCI_DDRCTL 0x50006405 /* DDR timing config */ +#define CFG_DAVINCI_SDREF 0x000005c3 +#define CFG_DAVINCI_SDCFG 0x00178632 /* 8 banks */ +#define CFG_DAVINCI_SDTIM0 0x28923211 +#define CFG_DAVINCI_SDTIM1 0x0016c722 +#define CFG_DAVINCI_MMARG_BRF0 0x00444400 +#define CFG_DAVINCI_PLL1_PLLM 0x15 /* DM6446 = 0x15, DM6441 = 0x12, DM6441_LV = 0x0e */ +#define CFG_DAVINCI_PLL2_PLLM 0x17 /* 162 MHz */ +#define CFG_DAVINCI_PLL2_DIV1 0x0b /* 54 MHz */ +#define CFG_DAVINCI_PLL2_DIV2 0x01 /*====================================================*/ /* EEPROM definitions for Atmel 24C256BN SEEPROM chip */ /* on Sonata/DV_EVM board. No EEPROM on schmoogie. */ @@ -114,7 +135,7 @@ #ifdef CFG_USE_NAND #undef CFG_ENV_IS_IN_FLASH #define CFG_NO_FLASH -#define CFG_ENV_IS_IN_NAND /* U-Boot env in NAND Flash */ +#define CFG_ENV_IS_IN_NAND /* U-Boot env in NAND Flash */ #ifdef CFG_NAND_SMALLPAGE #define CFG_ENV_SECT_SIZE 512 /* Env sector Size */ #define CFG_ENV_SIZE SZ_16K @@ -139,24 +160,31 @@ #undef CONFIG_SKIP_RELOCATE_UBOOT #endif #define CFG_ENV_IS_IN_FLASH -#undef CFG_NO_FLASH +#undef CFG_NO_FLASH #define CFG_FLASH_CFI_DRIVER #define CFG_FLASH_CFI #define CFG_MAX_FLASH_BANKS 1 /* max number of flash banks */ -#define CFG_FLASH_SECT_SZ 0x10000 /* 64KB sect size AMD Flash */ -#define CFG_ENV_OFFSET (CFG_FLASH_SECT_SZ*3) -#define PHYS_FLASH_1 0x02000000 /* CS2 Base address */ +#define CFG_ENV_ADDR (PHYS_FLASH_1 + 0x40000) +#define CFG_ENV_OFFSET (CFG_ENV_ADDR) +#define CFG_FLASH_USE_BUFFER_WRITE 1 /* use buffered writes (20x faster) */ +#define PHYS_FLASH_1 0x02000000 /* CS2 Base address */ #define CFG_FLASH_BASE PHYS_FLASH_1 /* Flash Base for U-Boot */ -#define PHYS_FLASH_SIZE 0x2000000 /* Flash size 32MB */ +#define PHYS_FLASH_SIZE 0x2000000 /* Flash size 32MB */ #define CFG_MAX_FLASH_SECT (PHYS_FLASH_SIZE/CFG_FLASH_SECT_SZ) #define CFG_ENV_SECT_SIZE CFG_FLASH_SECT_SZ /* Env sector Size */ +#ifdef CFG_USE_INTEL_NOR +#define CFG_FLASH_SECT_SZ 0x20000 /* 128KB sect size INTEL Flash */ +#define CFG_FLASH_PROTECTION 1 +#else +#define CFG_FLASH_SECT_SZ 0x10000 /* 64KB sect size AMD Flash */ +#endif #endif /*==============================*/ /* U-Boot general configuration */ /*==============================*/ -#undef CONFIG_USE_IRQ /* No IRQ/FIQ in U-Boot */ +#undef CONFIG_USE_IRQ /* No IRQ/FIQ in U-Boot */ #define CONFIG_MISC_INIT_R -#undef CONFIG_BOOTDELAY +#undef CONFIG_BOOTDELAY #define CONFIG_BOOTFILE "uImage" /* Boot file name */ #define CFG_PROMPT "U-Boot > " /* Monitor Command Prompt */ #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/davinci_schmoogie.h b/include/configs/davinci_schmoogie.h index 96c9a30..2449522 100644 --- a/include/configs/davinci_schmoogie.h +++ b/include/configs/davinci_schmoogie.h @@ -35,6 +35,23 @@ #define CFG_TIMERBASE 0x01c21400 /* use timer 0 */ #define CFG_HZ_CLOCK 27000000 /* Timer Input clock freq */ #define CFG_HZ 1000 +#define CFG_DAVINCI_PINMUX_0 0x00000c1f +#define CFG_DAVINCI_WAITCFG 0x00000000 +#define CFG_DAVINCI_ACFG2 0x0432229c /* CE configs */ +#define CFG_DAVINCI_ACFG3 0x3ffffffd +#define CFG_DAVINCI_ACFG4 0x3ffffffd +#define CFG_DAVINCI_ACFG5 0x3ffffffd +#define CFG_DAVINCI_NANDCE 2 /* When using NAND, define 2,3 or 4 */ +#define CFG_DAVINCI_DDRCTL 0x50006405 /* DDR timing config */ +#define CFG_DAVINCI_SDREF 0x000005c3 +#define CFG_DAVINCI_SDCFG 0x00178622 /* 4 banks */ +#define CFG_DAVINCI_SDTIM0 0x28923211 +#define CFG_DAVINCI_SDTIM1 0x0016c722 +#define CFG_DAVINCI_MMARG_BRF0 0x00444400 +#define CFG_DAVINCI_PLL1_PLLM 0x15 /* DM6446 = 0x15, DM6441 = 0x12, DM6441_LV = 0x0e */ +#define CFG_DAVINCI_PLL2_PLLM 0x17 /* 162 MHz */ +#define CFG_DAVINCI_PLL2_DIV1 0x0b /* 54 MHz */ +#define CFG_DAVINCI_PLL2_DIV2 0x01 /*=============*/ /* Memory Info */ /*=============*/ @@ -46,7 +63,6 @@ #define CONFIG_STACKSIZE (256*1024) /* regular stack */ #define PHYS_SDRAM_1 0x80000000 /* DDR Start */ #define PHYS_SDRAM_1_SIZE 0x08000000 /* DDR size 128MB */ -#define DDR_4BANKS /* 4-bank DDR2 (128MB) */ /*====================*/ /* Serial Driver info */ /*====================*/ diff --git a/include/configs/davinci_sonata.h b/include/configs/davinci_sonata.h index de8c4fa..3436037 100644 --- a/include/configs/davinci_sonata.h +++ b/include/configs/davinci_sonata.h @@ -60,6 +60,23 @@ #define CFG_TIMERBASE 0x01c21400 /* use timer 0 */ #define CFG_HZ_CLOCK 27000000 /* Timer Input clock freq */ #define CFG_HZ 1000 +#define CFG_DAVINCI_PINMUX_0 0x00000c1f +#define CFG_DAVINCI_WAITCFG 0x00000000 +#define CFG_DAVINCI_ACFG2 0x3ffffffd /* CE configs */ +#define CFG_DAVINCI_ACFG3 0x3ffffffd +#define CFG_DAVINCI_ACFG4 0x3ffffffd +#define CFG_DAVINCI_ACFG5 0x3ffffffd +#undef CFG_DAVINCI_NANDCE /* When using NAND, define 2,3 or 4 */ +#define CFG_DAVINCI_DDRCTL 0x50006405 /* DDR timing config */ +#define CFG_DAVINCI_SDREF 0x000005c3 +#define CFG_DAVINCI_SDCFG 0x00178632 /* 8 banks */ +#define CFG_DAVINCI_SDTIM0 0x28923211 +#define CFG_DAVINCI_SDTIM1 0x0016c722 +#define CFG_DAVINCI_MMARG_BRF0 0x00444400 +#define CFG_DAVINCI_PLL1_PLLM 0x15 /* DM6446 = 0x15, DM6441 = 0x12, DM6441_LV = 0x0e */ +#define CFG_DAVINCI_PLL2_PLLM 0x17 /* 162 MHz */ +#define CFG_DAVINCI_PLL2_DIV1 0x0b /* 54 MHz */ +#define CFG_DAVINCI_PLL2_DIV2 0x01 /*====================================================*/ /* EEPROM definitions for Atmel 24C256BN SEEPROM chip */ /* on Sonata/DV_EVM board. No EEPROM on schmoogie. */
Pieter Voorthuijsen
