[PATCH] xilinx: kconfig: Move sourcing of board Kconfig to mach folders
Do not source xilinx board Kconfig by other boards. These configs should be available only when Xilinx platforms are selected.
arch/arm/Kconfig | 4 ---- arch/arm/mach-versal/Kconfig | 3 +++ arch/arm/mach-zynq/Kconfig | 3 +++ arch/arm/mach-zynqmp/Kconfig | 3 +++ 4 files changed, 9 insertions(+), 4 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 80702c23d345..df4bbd252aca 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1997,10 +1997,6 @@ source "board/tcl/sl50/Kconfig" source "board/toradex/colibri_pxa270/Kconfig" source "board/variscite/dart_6ul/Kconfig" source "board/vscom/baltos/Kconfig" -source "board/xilinx/Kconfig" -source "board/xilinx/zynq/Kconfig" -source "board/xilinx/zynqmp/Kconfig" -source "board/xilinx/versal/Kconfig" source "board/phytium/durian/Kconfig" source "board/xen/xenguest_arm64/Kconfig"
diff --git a/arch/arm/mach-versal/Kconfig b/arch/arm/mach-versal/Kconfig index e1d66e8d32b7..ebd2da3887ec 100644 --- a/arch/arm/mach-versal/Kconfig +++ b/arch/arm/mach-versal/Kconfig @@ -62,4 +62,7 @@ config VERSAL_NO_DDR This option configures MMU with no DDR to avoid speculative access to DDR memory where DDR is not present.
+source "board/xilinx/Kconfig" +source "board/xilinx/versal/Kconfig" + endif diff --git a/arch/arm/mach-zynq/Kconfig b/arch/arm/mach-zynq/Kconfig index 79f831e6df2c..e54310383b29 100644 --- a/arch/arm/mach-zynq/Kconfig +++ b/arch/arm/mach-zynq/Kconfig @@ -70,4 +70,7 @@ config BOOT_INIT_FILE config ZYNQ_SDHCI_MAX_FREQ default 52000000
+source "board/xilinx/Kconfig" +source "board/xilinx/zynq/Kconfig" + endif diff --git a/arch/arm/mach-zynqmp/Kconfig b/arch/arm/mach-zynqmp/Kconfig index d82a737a699e..f1301f6661a1 100644 --- a/arch/arm/mach-zynqmp/Kconfig +++ b/arch/arm/mach-zynqmp/Kconfig @@ -171,4 +171,7 @@ config SD1_LSHFT_MODE
endchoice
+source "board/xilinx/Kconfig" +source "board/xilinx/zynqmp/Kconfig" + endif
čt 27. 8. 2020 v 15:39 odesílatel Michal Simek michal.simek@xilinx.com napsal:
endchoice
endif
2.28.0
Applied with syncing defconfigs. M
Michal Simek
Michal Simek
