Re: [U-Boot] [PATCH 2/2] MTD:NAND: ADD new ECC mode NAND_ECC_HW_OOB_FIRST
On Mon, Aug 10, 2009 at 01:27:56PM -0400, s-paulraj@dal.design.ti.com wrote:
This patch adds the new mode NAND_ECC_HW_OOB_FIRST in the nand code to support 4-bit ECC on TI DaVinci devices with large page (up to 2K) NAND chips. This ECC mode is similar to NAND_ECC_HW, with the exception of read_page API that first reads the OOB area, reads the data in chunks, feeds the ECC from OOB area to the ECC hw engine and perform any correction on the data as per the ECC status reported by the engine.
This patch has been accepted by Andrew Morton and can be found at
http://userweb.kernel.org/~akpm/mmotm/broken-out/mtd-nand-add-new-ecc-mode-e...
Signed-off-by: Sandeep Paulraj s-paulraj@ti.com Signed-off-by: Sneha Narnakaje nsnehaprabha@ti.com
Applied to u-boot-nand-flash/next.
-Scott
Scott Wood
