[U-Boot] [PATCH 0/2] SiFive UART support
This patchset adds SiFive UART driver for SiFive UART found on SiFive boards.
The driver is tested on QEMU sifive_u machine. In fact, with this patchset same U-Boot binary boots on QEMU virt machine and QEMU sifive_u machine in both M-mode and S-mode.
The patches are based upon latest RISC-V UBoot tree (git://git.denx.de/u-boot-riscv.git) at commit id ce41c65382300b4be2b84df3c06c2aa6c591741d
Anup Patel (2): drivers: serial: Add SiFive UART driver riscv: qemu: Enable SiFive UART driver in defconfigs
configs/qemu-riscv32_defconfig | 1 + configs/qemu-riscv32_smode_defconfig | 1 + configs/qemu-riscv64_defconfig | 1 + configs/qemu-riscv64_smode_defconfig | 1 + drivers/serial/Kconfig | 13 ++ drivers/serial/Makefile | 1 + drivers/serial/serial_sifive.c | 193 +++++++++++++++++++++++++++ 7 files changed, 211 insertions(+) create mode 100644 drivers/serial/serial_sifive.c
This patch adds SiFive UART driver. The driver is 100% DM driver and it determines input clock using clk framework.
Signed-off-by: Anup Patel anup@brainfault.org --- drivers/serial/Kconfig | 13 +++ drivers/serial/Makefile | 1 + drivers/serial/serial_sifive.c | 193 +++++++++++++++++++++++++++++++++ 3 files changed, 207 insertions(+) create mode 100644 drivers/serial/serial_sifive.c
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 3bcc61e731..30f7e00557 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -343,6 +343,13 @@ config DEBUG_UART_SANDBOX start up driver model. The driver will be available until the real driver model serial is running.
+config DEBUG_UART_SIFIVE + bool "SiFive UART" + help + Select this to enable a debug UART using the serial_sifive driver. You + will need to provide parameters to make this work. The driver will + be available until the real driver-model serial is running. + config DEBUG_UART_STM32 bool "STMicroelectronics STM32" depends on STM32_SERIAL @@ -685,6 +692,12 @@ config PXA_SERIAL If you have a machine based on a Marvell XScale PXA2xx CPU you can enable its onboard serial ports by enabling this option.
+config SIFIVE_SERIAL + bool "SiFive UART support" + depends on DM_SERIAL + help + This driver supports the SiFive UART. If unsure say N. + config STI_ASC_SERIAL bool "STMicroelectronics on-chip UART" depends on DM_SERIAL && ARCH_STI diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index b6377b1076..b6781535a8 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -68,6 +68,7 @@ obj-$(CONFIG_NULLDEV_SERIAL) += serial_nulldev.o obj-$(CONFIG_OWL_SERIAL) += serial_owl.o obj-$(CONFIG_OMAP_SERIAL) += serial_omap.o obj-$(CONFIG_MTK_SERIAL) += serial_mtk.o +obj-$(CONFIG_SIFIVE_SERIAL) += serial_sifive.o
ifndef CONFIG_SPL_BUILD obj-$(CONFIG_USB_TTY) += usbtty.o diff --git a/drivers/serial/serial_sifive.c b/drivers/serial/serial_sifive.c new file mode 100644 index 0000000000..cce05d5a01 --- /dev/null +++ b/drivers/serial/serial_sifive.c @@ -0,0 +1,193 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2012 Michal Simek monstr@monstr.eu + * Copyright (C) 2011-2012 Xilinx, Inc. All rights reserved. + */ + +#include <clk.h> +#include <common.h> +#include <debug_uart.h> +#include <dm.h> +#include <errno.h> +#include <fdtdec.h> +#include <watchdog.h> +#include <asm/io.h> +#include <linux/compiler.h> +#include <serial.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_TXFIFO_FULL 0x80000000 +#define UART_RXFIFO_EMPTY 0x80000000 +#define UART_RXFIFO_DATA 0x000000ff +#define UART_TXCTRL_TXEN 0x1 +#define UART_RXCTRL_RXEN 0x1 + +struct uart_sifive { + u32 txfifo; + u32 rxfifo; + u32 txctrl; + u32 rxctrl; + u32 ie; + u32 ip; + u32 div; +}; + +struct sifive_uart_platdata { + unsigned int clock; + struct uart_sifive *regs; +}; + +/* Set up the baud rate in gd struct */ +static void _sifive_serial_setbrg(struct uart_sifive *regs, + unsigned long clock, unsigned long baud) +{ + writel((u32)((clock / baud) - 1), ®s->div); +} + +static void _sifive_serial_init(struct uart_sifive *regs) +{ + writel(UART_TXCTRL_TXEN, ®s->txctrl); + writel(UART_RXCTRL_RXEN, ®s->rxctrl); + writel(0, ®s->ie); +} + +static int _sifive_serial_putc(struct uart_sifive *regs, const char c) +{ + if (readl(®s->txfifo) & UART_TXFIFO_FULL) + return -EAGAIN; + + writel(c, ®s->txfifo); + + return 0; +} + +static int _sifive_serial_getc(struct uart_sifive *regs) +{ + int ch = readl(®s->rxfifo); + + if (ch & UART_RXFIFO_EMPTY) + return -EAGAIN; + ch &= UART_RXFIFO_DATA; + + return (!ch) ? -EAGAIN : ch; +} + +static int sifive_serial_setbrg(struct udevice *dev, int baudrate) +{ + int err; + struct clk clk; + struct sifive_uart_platdata *platdata = dev_get_platdata(dev); + + err = clk_get_by_index(dev, 0, &clk); + if (!err) { + err = clk_get_rate(&clk); + if (!IS_ERR_VALUE(err)) + platdata->clock = err; + } else if (err != -ENOENT && err != -ENODEV && err != -ENOSYS) { + debug("SiFive UART failed to get clock\n"); + return err; + } + + if (!platdata->clock) + platdata->clock = dev_read_u32_default(dev, "clock-frequency", 0); + if (!platdata->clock) { + debug("SiFive UART clock not defined\n"); + return -EINVAL; + } + + _sifive_serial_setbrg(platdata->regs, platdata->clock, baudrate); + + return 0; +} + +static int sifive_serial_probe(struct udevice *dev) +{ + struct sifive_uart_platdata *platdata = dev_get_platdata(dev); + + /* No need to reinitialize the UART after relocation */ + if (gd->flags & GD_FLG_RELOC) + return 0; + + _sifive_serial_init(platdata->regs); + + return 0; +} + +static int sifive_serial_getc(struct udevice *dev) +{ + int c; + struct sifive_uart_platdata *platdata = dev_get_platdata(dev); + struct uart_sifive *regs = platdata->regs; + + while ((c = _sifive_serial_getc(regs)) == -EAGAIN) ; + + return c; +} + +static int sifive_serial_putc(struct udevice *dev, const char ch) +{ + int rc; + struct sifive_uart_platdata *platdata = dev_get_platdata(dev); + + while ((rc = _sifive_serial_putc(platdata->regs, ch)) == -EAGAIN) ; + + return rc; +} + +static int sifive_serial_ofdata_to_platdata(struct udevice *dev) +{ + struct sifive_uart_platdata *platdata = dev_get_platdata(dev); + + platdata->regs = (struct uart_sifive *)dev_read_addr(dev); + if (IS_ERR(platdata->regs)) + return PTR_ERR(platdata->regs); + + return 0; +} + +static const struct dm_serial_ops sifive_serial_ops = { + .putc = sifive_serial_putc, + .getc = sifive_serial_getc, + .setbrg = sifive_serial_setbrg, +}; + +static const struct udevice_id sifive_serial_ids[] = { + { .compatible = "sifive,uart0" }, + { } +}; + +U_BOOT_DRIVER(serial_sifive) = { + .name = "serial_sifive", + .id = UCLASS_SERIAL, + .of_match = sifive_serial_ids, + .ofdata_to_platdata = sifive_serial_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct sifive_uart_platdata), + .probe = sifive_serial_probe, + .ops = &sifive_serial_ops, + .priv_auto_alloc_size = sizeof(struct sifive_uart_platdata), +}; + +#ifdef CONFIG_DEBUG_UART_SIFIVE +static inline void _debug_uart_init(void) +{ + struct uart_sifive *regs = + (struct uart_sifive *)CONFIG_DEBUG_UART_BASE; + + _sifive_serial_setbrg(regs, CONFIG_DEBUG_UART_CLOCK, + CONFIG_BAUDRATE); + _sifive_serial_init(regs); +} + +static inline void _debug_uart_putc(int ch) +{ + struct uart_sifive *regs = + (struct uart_sifive *)CONFIG_DEBUG_UART_BASE; + + while (_sifive_serial_putc(regs, ch) == -EAGAIN) + WATCHDOG_RESET(); +} + +DEBUG_UART_FUNCS + +#endif
- bool "SiFive UART"
- help
- bool "SiFive UART support"
- depends on DM_SERIAL
- help
- Copyright (C) 2012 Michal Simek monstr@monstr.eu
- Copyright (C) 2011-2012 Xilinx, Inc. All rights reserved.
- u32 txfifo;
- u32 rxfifo;
- u32 txctrl;
- u32 rxctrl;
- u32 ie;
- u32 ip;
- u32 div;
- unsigned int clock;
- struct uart_sifive *regs;
- writel((u32)((clock / baud) - 1), ®s->div);
- writel(UART_TXCTRL_TXEN, ®s->txctrl);
- writel(UART_RXCTRL_RXEN, ®s->rxctrl);
- writel(0, ®s->ie);
- if (readl(®s->txfifo) & UART_TXFIFO_FULL)
return -EAGAIN;
- writel(c, ®s->txfifo);
- int ch = readl(®s->rxfifo);
- if (ch & UART_RXFIFO_EMPTY)
return -EAGAIN;
- ch &= UART_RXFIFO_DATA;
- return (!ch) ? -EAGAIN : ch;
- int err;
- struct clk clk;
- struct sifive_uart_platdata *platdata = dev_get_platdata(dev);
- err = clk_get_by_index(dev, 0, &clk);
- if (!err) {
- } else if (err != -ENOENT && err != -ENODEV && err != -ENOSYS) {
return err;
- if (!platdata->clock)
- if (!platdata->clock) {
return -EINVAL;
- _sifive_serial_setbrg(platdata->regs, platdata->clock, baudrate);
I don't see anything that ensures the TX FIFO is drained before changing the baud rate. I don't know anything about u-boot so I'm not sure if that's expected.
- /* No need to reinitialize the UART after relocation */
- if (gd->flags & GD_FLG_RELOC)
- _sifive_serial_init(platdata->regs);
- int c;
- struct uart_sifive *regs = platdata->regs;
- while ((c = _sifive_serial_getc(regs)) == -EAGAIN) ;
- return c;
- int rc;
- while ((rc = _sifive_serial_putc(platdata->regs, ch)) == -EAGAIN) ;
- return rc;
- platdata->regs = (struct uart_sifive *)dev_read_addr(dev);
- if (IS_ERR(platdata->regs))
- .putc = sifive_serial_putc,
- .getc = sifive_serial_getc,
- .setbrg = sifive_serial_setbrg,
- { .compatible = "sifive,uart0" },
- .name = "serial_sifive",
- .id = UCLASS_SERIAL,
- .of_match = sifive_serial_ids,
- .ofdata_to_platdata = sifive_serial_ofdata_to_platdata,
- .platdata_auto_alloc_size = sizeof(struct sifive_uart_platdata),
- .probe = sifive_serial_probe,
- .ops = &sifive_serial_ops,
- .priv_auto_alloc_size = sizeof(struct sifive_uart_platdata),
- _sifive_serial_setbrg(regs, CONFIG_DEBUG_UART_CLOCK,
CONFIG_BAUDRATE);
- _sifive_serial_init(regs);
- while (_sifive_serial_putc(regs, ch) == -EAGAIN)
WATCHDOG_RESET();
+DEBUG_UART_FUNCS
Reviewed-by: Palmer Dabbelt palmer@sifive.com
Thanks!
bool "SiFive UART"
help
help
u32 txfifo;
u32 rxfifo;
u32 txctrl;
u32 rxctrl;
u32 ie;
u32 ip;
u32 div;
unsigned int clock;
writel(0, ®s->ie);
return -EAGAIN;
return -EAGAIN;
int err;
struct clk clk;
if (!err) {
return err;
return -EINVAL;
Ohh yes, u-boot serial drivers usually don't drain TX FIFO.
If required we can add it via separate patch.
int c;
return c;
int rc;
return rc;
CONFIG_BAUDRATE);
WATCHDOG_RESET();
+DEBUG_UART_FUNCS
Thanks, Anup
Hi Anup,
bool "SiFive UART"
help
help
nits: pls update the copyright notice
u32 txfifo;
u32 rxfifo;
u32 txctrl;
u32 rxctrl;
u32 ie;
u32 ip;
u32 div;
unsigned int clock;
writel(0, ®s->ie);
return -EAGAIN;
return -EAGAIN;
int err;
struct clk clk;
if (!err) {
return err;
return -EINVAL;
int c;
return c;
int rc;
return rc;
This is not used anywhere in this driver.
CONFIG_BAUDRATE);
WATCHDOG_RESET();
+DEBUG_UART_FUNCS
Regards, Bin
On Mon, Dec 10, 2018 at 7:25 AM Bin Meng bmeng.cn@gmail.com wrote:
Hi Anup,
bool "SiFive UART"
help
help
Thanks for catching it. I will update it.
u32 txfifo;
u32 rxfifo;
u32 txctrl;
u32 rxctrl;
u32 ie;
u32 ip;
u32 div;
unsigned int clock;
writel(0, ®s->ie);
return -EAGAIN;
return -EAGAIN;
int err;
struct clk clk;
if (!err) {
return err;
return -EINVAL;
int c;
return c;
int rc;
return rc;
Ok, I will remove priv_auto_alloc_size.
CONFIG_BAUDRATE);
WATCHDOG_RESET();
+DEBUG_UART_FUNCS
Regards, Bin
Regards, Anup
This patch enables SiFive UART driver in all QEMU RISC-V defconfigs.
Signed-off-by: Anup Patel anup@brainfault.org --- configs/qemu-riscv32_defconfig | 1 + configs/qemu-riscv32_smode_defconfig | 1 + configs/qemu-riscv64_defconfig | 1 + configs/qemu-riscv64_smode_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/configs/qemu-riscv32_defconfig b/configs/qemu-riscv32_defconfig index 6334d8c0fc..79c8d54cc7 100644 --- a/configs/qemu-riscv32_defconfig +++ b/configs/qemu-riscv32_defconfig @@ -7,3 +7,4 @@ CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y # CONFIG_CMD_MII is not set CONFIG_OF_PRIOR_STAGE=y +CONFIG_SIFIVE_SERIAL=y diff --git a/configs/qemu-riscv32_smode_defconfig b/configs/qemu-riscv32_smode_defconfig index 0a84ec1874..b733dbed2f 100644 --- a/configs/qemu-riscv32_smode_defconfig +++ b/configs/qemu-riscv32_smode_defconfig @@ -8,3 +8,4 @@ CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y # CONFIG_CMD_MII is not set CONFIG_OF_PRIOR_STAGE=y +CONFIG_SIFIVE_SERIAL=y diff --git a/configs/qemu-riscv64_defconfig b/configs/qemu-riscv64_defconfig index 2d9ead93a2..a9d19a5574 100644 --- a/configs/qemu-riscv64_defconfig +++ b/configs/qemu-riscv64_defconfig @@ -8,3 +8,4 @@ CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y # CONFIG_CMD_MII is not set CONFIG_OF_PRIOR_STAGE=y +CONFIG_SIFIVE_SERIAL=y diff --git a/configs/qemu-riscv64_smode_defconfig b/configs/qemu-riscv64_smode_defconfig index b012443370..8adc23f826 100644 --- a/configs/qemu-riscv64_smode_defconfig +++ b/configs/qemu-riscv64_smode_defconfig @@ -9,3 +9,4 @@ CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y # CONFIG_CMD_MII is not set CONFIG_OF_PRIOR_STAGE=y +CONFIG_SIFIVE_SERIAL=y
Hi Anup,
Can we "imply SIFIVE_SERIAL" in BOARD_SPECIFIC_OPTIONS in board/emulation/qemu-riscv/Kconfig instead?
[snip]
Regards, Bin
Hi Anup,
Sure, will do. If it works then I will drop this patch.
Regards, Anup
Hi Anup,
I was unable to get this working with QEMU sifive_u target. I am using:
$ qemu-system-riscv64 -nographic -M sifive_u -kernel u-boot
with QEMU version 3.0.50
Regards, Bin
Anup Patel
Bin Meng
Palmer Dabbelt
