[U-Boot] [PATCH v3 0/8] Get socfpga gen5 SPL working again.
Socfpga gen5 SPL has been broken since moving to DM serial with v2018.07. Also, U-Boot console output has been broken since then. This series fixes this and makes some related small improvements.
Changes in v3: - moved uart0's "u-boot,dm-pre-reloc;" from socfpga.dtsi to board specific dts files since this can change per board - added patches 5-7 to boot SPL and U-Boot from fpga OnChip RAM - dropped Patch 5/6 "serial: ns16550: fix debug uart putc called before init" (this needs a more generic fix)
Changes in v2: - Improved comment on patch 1 - Removing gd->malloc_base assignment at the end of board_init_f() moved to an extra patch - don't change printf() to debug() in reset_manager_gen5.c socfpga_bridges_reset() (instead make debug uart handle this) - make ns16550 debug uart handle putc being called before init - removed the assignment of gd->malloc_limit from board_init()
Simon Goldschmidt (8): arm: socfpga: fix SPL on gen5 after moving to DM serial arm: socfpga: fix device trees to work with DM serial arm: socfpga: spl_gen5: clean up malloc_base assignment arm: socfpga: cyclone5: handle debug uart arm: socfpga: fix U-Boot running from fpga OnChip RAM arm: socfpga: gen5: combine some init code for SPL and U-Boot arm: socfpga: fix SPL booting from fpga OnChip RAM malloc_simple: calloc: don't call memset if malloc failed
arch/arm/dts/socfpga_arria5_socdk.dts | 5 ++ arch/arm/dts/socfpga_cyclone5_dbm_soc1.dts | 5 ++ .../arm/dts/socfpga_cyclone5_de0_nano_soc.dts | 5 ++ arch/arm/dts/socfpga_cyclone5_de10_nano.dts | 5 ++ arch/arm/dts/socfpga_cyclone5_de1_soc.dts | 5 ++ arch/arm/dts/socfpga_cyclone5_is1.dts | 5 ++ arch/arm/dts/socfpga_cyclone5_socdk.dts | 5 ++ arch/arm/dts/socfpga_cyclone5_sockit.dts | 5 ++ arch/arm/dts/socfpga_cyclone5_socrates.dts | 5 ++ arch/arm/dts/socfpga_cyclone5_sr1500.dts | 2 + arch/arm/dts/socfpga_cyclone5_vining_fpga.dts | 5 ++ arch/arm/mach-socfpga/Kconfig | 12 +++++ arch/arm/mach-socfpga/include/mach/misc.h | 4 ++ arch/arm/mach-socfpga/misc_gen5.c | 40 +++++++++------ arch/arm/mach-socfpga/spl_gen5.c | 49 ++++++------------- common/malloc_simple.c | 3 +- include/configs/socfpga_common.h | 13 +++++ 17 files changed, 125 insertions(+), 48 deletions(-)
There were NULL pointers dereferenced because DM was used too early without correct initialization: - malloc_simple returned NULL when called from preloader_console_init() because gd->malloc_limit was 0 - uclass_add dereferenced gd->uclass_root members which were NULL because dm_init (or one of its relatives) has not been called.
All this is fixed by calling spl_early_init before calling preloader_console_init.
This fixes commit 73172753f4f3 ("ARM: socfpga: Convert to DM serial")
Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com ---
Changes in v3: None Changes in v2: - Don't remove gd->malloc_base assignment at the end of board_init_f() (moved to an extra patch)
arch/arm/mach-socfpga/spl_gen5.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/mach-socfpga/spl_gen5.c b/arch/arm/mach-socfpga/spl_gen5.c index d6fe7d35af..9bdfaa3c1e 100644 --- a/arch/arm/mach-socfpga/spl_gen5.c +++ b/arch/arm/mach-socfpga/spl_gen5.c @@ -86,6 +86,7 @@ void board_init_f(ulong dummy) const struct cm_config *cm_default_cfg = cm_get_default_config(); unsigned long sdram_size; unsigned long reg; + int ret;
/* * First C code to run. Clear fake OCRAM ECC first as SBE @@ -152,6 +153,12 @@ void board_init_f(ulong dummy) /* unfreeze / thaw all IO banks */ sys_mgr_frzctrl_thaw_req();
+ ret = spl_early_init(); + if (ret) { + debug("spl_early_init() failed: %d\n", ret); + hang(); + } + /* enable console uart printing */ preloader_console_init();
Device trees need to have the serial console device available before relocation and require a stdout-path in chosen at least for SPL to have a console.
Changes in v3: - moved uart0's "u-boot,dm-pre-reloc;" from socfpga.dtsi to board specific dts files since this can change per board Changes in v2: None
arch/arm/dts/socfpga_arria5_socdk.dts | 5 +++++ arch/arm/dts/socfpga_cyclone5_dbm_soc1.dts | 5 +++++ arch/arm/dts/socfpga_cyclone5_de0_nano_soc.dts | 5 +++++ arch/arm/dts/socfpga_cyclone5_de10_nano.dts | 5 +++++ arch/arm/dts/socfpga_cyclone5_de1_soc.dts | 5 +++++ arch/arm/dts/socfpga_cyclone5_is1.dts | 5 +++++ arch/arm/dts/socfpga_cyclone5_socdk.dts | 5 +++++ arch/arm/dts/socfpga_cyclone5_sockit.dts | 5 +++++ arch/arm/dts/socfpga_cyclone5_socrates.dts | 5 +++++ arch/arm/dts/socfpga_cyclone5_sr1500.dts | 2 ++ arch/arm/dts/socfpga_cyclone5_vining_fpga.dts | 5 +++++ 11 files changed, 52 insertions(+)
diff --git a/arch/arm/dts/socfpga_arria5_socdk.dts b/arch/arm/dts/socfpga_arria5_socdk.dts index 449ba9cbb9..6f4de2f563 100644 --- a/arch/arm/dts/socfpga_arria5_socdk.dts +++ b/arch/arm/dts/socfpga_arria5_socdk.dts @@ -11,6 +11,7 @@
chosen { bootargs = "console=ttyS0,115200"; + stdout-path = "serial0:115200n8"; };
memory { @@ -99,3 +100,7 @@ cdns,tslch-ns = <4>; }; }; + +&uart0 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/socfpga_cyclone5_dbm_soc1.dts b/arch/arm/dts/socfpga_cyclone5_dbm_soc1.dts index aeb327dd5b..139a70f265 100644 --- a/arch/arm/dts/socfpga_cyclone5_dbm_soc1.dts +++ b/arch/arm/dts/socfpga_cyclone5_dbm_soc1.dts @@ -11,6 +11,7 @@
aliases { @@ -56,3 +57,7 @@ disable-over-current; status = "okay"; }; + +&uart0 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/socfpga_cyclone5_de0_nano_soc.dts b/arch/arm/dts/socfpga_cyclone5_de0_nano_soc.dts index f4a98e4bb0..d504150edd 100644 --- a/arch/arm/dts/socfpga_cyclone5_de0_nano_soc.dts +++ b/arch/arm/dts/socfpga_cyclone5_de0_nano_soc.dts @@ -11,6 +11,7 @@
aliases { @@ -75,3 +76,7 @@ &usb1 { status = "okay"; }; + +&uart0 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/socfpga_cyclone5_de10_nano.dts b/arch/arm/dts/socfpga_cyclone5_de10_nano.dts index 7da2d8b043..d4dd9e9bca 100644 --- a/arch/arm/dts/socfpga_cyclone5_de10_nano.dts +++ b/arch/arm/dts/socfpga_cyclone5_de10_nano.dts @@ -13,6 +13,7 @@
aliases { @@ -65,3 +66,7 @@ &usb1 { status = "okay"; }; + +&uart0 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/socfpga_cyclone5_de1_soc.dts b/arch/arm/dts/socfpga_cyclone5_de1_soc.dts index e6fadb4fc9..f62292284d 100644 --- a/arch/arm/dts/socfpga_cyclone5_de1_soc.dts +++ b/arch/arm/dts/socfpga_cyclone5_de1_soc.dts @@ -11,6 +11,7 @@
aliases { @@ -63,3 +64,7 @@ &usb1 { status = "okay"; }; + +&uart0 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/socfpga_cyclone5_is1.dts b/arch/arm/dts/socfpga_cyclone5_is1.dts index aa1ce2c3e2..4e94d86114 100644 --- a/arch/arm/dts/socfpga_cyclone5_is1.dts +++ b/arch/arm/dts/socfpga_cyclone5_is1.dts @@ -11,6 +11,7 @@
memory { @@ -102,3 +103,7 @@ &usb1 { status = "okay"; }; + +&uart0 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/socfpga_cyclone5_socdk.dts b/arch/arm/dts/socfpga_cyclone5_socdk.dts index 55c70abb02..c28be67bb9 100644 --- a/arch/arm/dts/socfpga_cyclone5_socdk.dts +++ b/arch/arm/dts/socfpga_cyclone5_socdk.dts @@ -11,6 +11,7 @@
memory { @@ -113,3 +114,7 @@ &usb1 { status = "okay"; }; + +&uart0 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/socfpga_cyclone5_sockit.dts b/arch/arm/dts/socfpga_cyclone5_sockit.dts index 08d8356d80..c7a6cf2db8 100644 --- a/arch/arm/dts/socfpga_cyclone5_sockit.dts +++ b/arch/arm/dts/socfpga_cyclone5_sockit.dts @@ -11,6 +11,7 @@
aliases { @@ -93,3 +94,7 @@ &usb1 { status = "okay"; }; + +&uart0 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/socfpga_cyclone5_socrates.dts b/arch/arm/dts/socfpga_cyclone5_socrates.dts index 0d452ae300..8cde9906a0 100644 --- a/arch/arm/dts/socfpga_cyclone5_socrates.dts +++ b/arch/arm/dts/socfpga_cyclone5_socrates.dts @@ -11,6 +11,7 @@
aliases { @@ -84,3 +85,7 @@ disable-over-current; status = "okay"; }; + +&uart0 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/socfpga_cyclone5_sr1500.dts b/arch/arm/dts/socfpga_cyclone5_sr1500.dts index 341df7a3e7..86c61fe081 100644 --- a/arch/arm/dts/socfpga_cyclone5_sr1500.dts +++ b/arch/arm/dts/socfpga_cyclone5_sr1500.dts @@ -11,6 +11,7 @@
aliases { @@ -67,6 +68,7 @@
&uart0 { status = "okay"; + u-boot,dm-pre-reloc; };
&usb1 { diff --git a/arch/arm/dts/socfpga_cyclone5_vining_fpga.dts b/arch/arm/dts/socfpga_cyclone5_vining_fpga.dts index 7a032af3a4..85ab56379f 100644 --- a/arch/arm/dts/socfpga_cyclone5_vining_fpga.dts +++ b/arch/arm/dts/socfpga_cyclone5_vining_fpga.dts @@ -11,6 +11,7 @@
aliases { @@ -108,3 +109,7 @@ &usb1 { status = "okay"; }; + +&uart0 { + u-boot,dm-pre-reloc; +};
Changes in v3:
Why are these not in socfpga-u-boot.dtsi ? We have the mechanism to grab CONFIG_SYS_CPU/CONFIG_SYS_SOC/CONFIG_SYS_VENDOR-u-boot.dtsi automatically so that we don't have to modify the files we sync in from upstream.
Changes in v3:
Ehrm, I don't know, really. The DTS files for socfpga already have many U-Boot specifics and are quite different to Linux. It might make sense to sync them, but do we really have to do this for 2018.09?
Keep in mind that this series exists to fix that 2018.07 broke on these boards.
Simon
Changes in v3:
Well, I think given that you're adding these changes right now, they should be added to the correct file so that they aren't lost on re-sync later. It would be adding: &uart0 { u-boot,dm-pre-reloc; };
once to arch/arm/dts/socfpga-u-boot.dtsi rather than for every board.
Changes in v3:
Pulling the U-Boot specific crap would be most welcome, but it could be a separate patch.
Changes in v3:
So you want to add stuff now and pull it out later? That seems counter intuitive, but sure, you're the custodian here. When do you plan to do the clean-up, for v2018.11?
Tom Rini trini@konsulko.com schrieb am Mo., 13. Aug. 2018, 15:33:
Changes in v3:
from
upstream.
these boards.
Can we do this in one step with syncing up to the latest Linux device trees?
Simon
> Device trees need to have the serial console device available > before relocation and require a stdout-path in chosen at least > for SPL to have a console. > > Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com > --- > > Changes in v3: > - moved uart0's "u-boot,dm-pre-reloc;" from socfpga.dtsi to board > specific dts files since this can change per board
from
upstream.
these boards.
I honestly don't understand the hesitation to not introduce more change than is required now. But, I will defer. I do want to know when people plan to fix this however, as that feels like a reasonable compromise to me.
On Mon, Aug 13, 2018 at 3:17 PM Tom Rini trini@konsulko.com wrote: > > On Mon, Aug 13, 2018 at 09:33:45AM +0200, Simon Goldschmidt wrote: > >> Device trees need to have the serial console device available >> before relocation and require a stdout-path in chosen at least >> for SPL to have a console. >> >> Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com >> --- >> >> Changes in v3: >> - moved uart0's "u-boot,dm-pre-reloc;" from socfpga.dtsi to board >> specific dts files since this can change per board > > Why are these not in socfpga-u-boot.dtsi ? We have the mechanism to > grab CONFIG_SYS_CPU/CONFIG_SYS_SOC/CONFIG_SYS_VENDOR-u-boot.dtsi > automatically so that we don't have to modify the files we sync in
from
> upstream.
these boards.
I presume Simon will stick around, so I'm happy to cut him some slack ...
Tom Rini trini@konsulko.com schrieb am Mo., 13. Aug. 2018, 15:41:
wrote:
> >> Device trees need to have the serial console device available >> before relocation and require a stdout-path in chosen at least >> for SPL to have a console. >> >> Signed-off-by: Simon Goldschmidt <
simon.k.r.goldschmidt@gmail.com>
board
mechanism to
in
from
> upstream.
make
these boards.
they
re-sync
board.
be
a separate patch.
trees?
It's holiday season here so I can't say I'll be available all the time until the 2018.09 release. That's why I don't want to do changes I can't thoroughly test right now.
I might try the sync in September. It should not be too much work, but I can only test one of the boards (the SoCrates).
Simom
From: Simon Goldschmidt sgoldschmidt@de.pepperl-fuchs.com
In spl_gen5's board_init_f(), gd->malloc_base is manually assigned at the end of the function to point to sdram. This code is outdated as by now, the heap is switched to sdram by the common function spl_relocate_stack_gd() if the appropriate defines are set.
As it was, the value assigned manually was directly overwritten by this common code, so remove the manual assignment.
Changes in v3: None Changes in v2: - this patch is new in v2 of the series (extracted from PATCH v1 1/6)
arch/arm/mach-socfpga/spl_gen5.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/arch/arm/mach-socfpga/spl_gen5.c b/arch/arm/mach-socfpga/spl_gen5.c index 9bdfaa3c1e..0d5526656d 100644 --- a/arch/arm/mach-socfpga/spl_gen5.c +++ b/arch/arm/mach-socfpga/spl_gen5.c @@ -184,7 +184,4 @@ void board_init_f(ulong dummy) }
socfpga_bridges_reset(1); - - /* Configure simple malloc base pointer into RAM. */ - gd->malloc_base = CONFIG_SYS_TEXT_BASE + (1024 * 1024); }
If CONFIG_DEBUG_UART is enabled, correctly initialize the debug uart before console is initialized to debug early boot problems in SPL.
Changes in v3: None Changes in v2: - don't change printf() to debug() in reset_manager_gen5.c socfpga_bridges_reset()
arch/arm/mach-socfpga/spl_gen5.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/mach-socfpga/spl_gen5.c b/arch/arm/mach-socfpga/spl_gen5.c index 0d5526656d..0e685f6ee5 100644 --- a/arch/arm/mach-socfpga/spl_gen5.c +++ b/arch/arm/mach-socfpga/spl_gen5.c @@ -20,6 +20,7 @@ #include <asm/arch/scu.h> #include <asm/arch/nic301.h> #include <asm/sections.h> +#include <debug_uart.h> #include <fdtdec.h> #include <watchdog.h>
@@ -153,6 +154,11 @@ void board_init_f(ulong dummy) /* unfreeze / thaw all IO banks */ sys_mgr_frzctrl_thaw_req();
+#ifdef CONFIG_DEBUG_UART + socfpga_per_reset(SOCFPGA_RESET(UART0), 0); + debug_uart_init(); +#endif + ret = spl_early_init(); if (ret) { debug("spl_early_init() failed: %d\n", ret);
gd->env_addr points to pre-relocation address even after relocation. This leads to an abort in env_callback_init when loading the environment.
Fix this by enabling CONFIG_SYS_EXTRA_ENV_RELOC.
Changes in v3: this patch is new in v3 Changes in v2: None
include/configs/socfpga_common.h | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 8ebf6b85fe..2fb207c86a 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -284,6 +284,14 @@ unsigned int cm_get_qspi_controller_clk_hz(void); #define CONFIG_SPL_STACK CONFIG_SYS_SPL_MALLOC_START #endif
+#ifdef CONFIG_TARGET_SOCFPGA_GEN5 +/* When U-Boot is started from FPGA, prevent gd->env_addr to point into + * FPGA OnChip RAM after relocation + */ +#define CONFIG_SYS_EXTRA_ENV_RELOC +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ +#endif + /* Extra Environment */ #ifndef CONFIG_SPL_BUILD
Doesn't this apply to gen10 too ?
- FPGA OnChip RAM after relocation
Marek Vasut marex@denx.de schrieb am Mo., 13. Aug. 2018, 15:29:
Ehrm, I really don't know. As I don't know gen10, I didn't want to break it.
I could try to check the sources, but without knowing the architecture details and having a board to test, I might break things...
of monitor */
-- Best regards, Marek Vasut
On 08/13/2018 03:33 PM, Simon Goldschmidt wrote:
Marek Vasut <marex@denx.de mailto:marex@denx.de> schrieb am Mo., 13. Aug. 2018, 15:29:
On 08/13/2018 09:33 AM, Simon Goldschmidt wrote: > gd->env_addr points to pre-relocation address even after > relocation. This leads to an abort in env_callback_init > when loading the environment. > > Fix this by enabling CONFIG_SYS_EXTRA_ENV_RELOC. Doesn't this apply to gen10 too ?
I'll probably be able to intercept that breakage, so just send a V4 with that ifdef removed.
> Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com <mailto:simon.k.r.goldschmidt@gmail.com>> > --- > > Changes in v3: this patch is new in v3 > Changes in v2: None > > include/configs/socfpga_common.h | 8 ++++++++ > 1 file changed, 8 insertions(+) > > diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h > index 8ebf6b85fe..2fb207c86a 100644 > --- a/include/configs/socfpga_common.h > +++ b/include/configs/socfpga_common.h > @@ -284,6 +284,14 @@ unsigned int cm_get_qspi_controller_clk_hz(void); > #define CONFIG_SPL_STACK CONFIG_SYS_SPL_MALLOC_START > #endif > > +#ifdef CONFIG_TARGET_SOCFPGA_GEN5 > +/* When U-Boot is started from FPGA, prevent gd->env_addr to point into > + * FPGA OnChip RAM after relocation > + */ > +#define CONFIG_SYS_EXTRA_ENV_RELOC > +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ > +#endif > + > /* Extra Environment */ > #ifndef CONFIG_SPL_BUILD > > -- Best regards, Marek Vasut
Some of the code for low level system initialization in SPL's board_init_f() and U-Boot's arch_early_init_r() is the same, so let's combine it into a single function called from both.
arch/arm/mach-socfpga/include/mach/misc.h | 4 +++ arch/arm/mach-socfpga/misc_gen5.c | 33 +++++++++++++---------- arch/arm/mach-socfpga/spl_gen5.c | 30 +-------------------- 3 files changed, 24 insertions(+), 43 deletions(-)
diff --git a/arch/arm/mach-socfpga/include/mach/misc.h b/arch/arm/mach-socfpga/include/mach/misc.h index 7fe77ac8d8..aa7f38d4ea 100644 --- a/arch/arm/mach-socfpga/include/mach/misc.h +++ b/arch/arm/mach-socfpga/include/mach/misc.h @@ -27,6 +27,10 @@ unsigned int shared_uart_com_port(const void *blob); unsigned int uart_com_port(const void *blob); #endif
+#ifdef CONFIG_TARGET_SOCFPGA_GEN5 +void socfpga_init_bus_mapping(void); +#endif + void do_bridge_reset(int enable);
#endif /* _MISC_H_ */ diff --git a/arch/arm/mach-socfpga/misc_gen5.c b/arch/arm/mach-socfpga/misc_gen5.c index 848551c73f..32af1a9084 100644 --- a/arch/arm/mach-socfpga/misc_gen5.c +++ b/arch/arm/mach-socfpga/misc_gen5.c @@ -175,6 +175,24 @@ static void socfpga_nic301_slave_ns(void) writel(0x1, &nic301_regs->sdrdata); }
+void socfpga_init_bus_mapping(void) +{ + socfpga_bridges_reset(1); + + socfpga_nic301_slave_ns(); + + /* + * Private components security: + * U-Boot : configure private timer, global timer and cpu component + * access as non secure for kernel stage (as required by Linux) + */ + setbits_le32(&scu_regs->sacr, 0xfff); + + /* Configure the L2 controller to make SDRAM start at 0 */ + writel(0x1, &nic301_regs->remap); /* remap.mpuzero */ + writel(0x1, &pl310->pl310_addr_filter_start); +} + static u32 iswgrp_handoff[8];
int arch_early_init_r(void) @@ -193,20 +211,7 @@ int arch_early_init_r(void) for (i = 0; i < 8; i++) /* Cache initial SW setting regs */ iswgrp_handoff[i] = readl(&sysmgr_regs->iswgrp_handoff[i]);
- socfpga_bridges_reset(1); - - socfpga_nic301_slave_ns(); - - /* - * Private components security: - * U-Boot : configure private timer, global timer and cpu component - * access as non secure for kernel stage (as required by Linux) - */ - setbits_le32(&scu_regs->sacr, 0xfff); - - /* Configure the L2 controller to make SDRAM start at 0 */ - writel(0x1, &nic301_regs->remap); /* remap.mpuzero */ - writel(0x1, &pl310->pl310_addr_filter_start); + socfpga_init_bus_mapping();
/* Add device descriptor to FPGA device table */ socfpga_fpga_add(); diff --git a/arch/arm/mach-socfpga/spl_gen5.c b/arch/arm/mach-socfpga/spl_gen5.c index 0e685f6ee5..631905fbee 100644 --- a/arch/arm/mach-socfpga/spl_gen5.c +++ b/arch/arm/mach-socfpga/spl_gen5.c @@ -5,7 +5,6 @@
#include <common.h> #include <asm/io.h> -#include <asm/pl310.h> #include <asm/u-boot.h> #include <asm/utils.h> #include <image.h> @@ -17,8 +16,6 @@ #include <asm/arch/misc.h> #include <asm/arch/scan_manager.h> #include <asm/arch/sdram.h> -#include <asm/arch/scu.h> -#include <asm/arch/nic301.h> #include <asm/sections.h> #include <debug_uart.h> #include <fdtdec.h> @@ -26,12 +23,6 @@
DECLARE_GLOBAL_DATA_PTR;
-static struct pl310_regs *const pl310 = - (struct pl310_regs *)CONFIG_SYS_PL310_BASE; -static struct scu_registers *scu_regs = - (struct scu_registers *)SOCFPGA_MPUSCU_ADDRESS; -static struct nic301_registers *nic301_regs = - (struct nic301_registers *)SOCFPGA_L3REGS_ADDRESS; static const struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS;
@@ -72,16 +63,6 @@ u32 spl_boot_mode(const u32 boot_device) } #endif
-static void socfpga_nic301_slave_ns(void) -{ - writel(0x1, &nic301_regs->lwhps2fpgaregs); - writel(0x1, &nic301_regs->hps2fpgaregs); - writel(0x1, &nic301_regs->acp); - writel(0x1, &nic301_regs->rom); - writel(0x1, &nic301_regs->ocram); - writel(0x1, &nic301_regs->sdrdata); -} - void board_init_f(ulong dummy) { const struct cm_config *cm_default_cfg = cm_get_default_config(); @@ -103,14 +84,7 @@ void board_init_f(ulong dummy)
memset(__bss_start, 0, __bss_end - __bss_start);
- socfpga_nic301_slave_ns(); - - /* Configure ARM MPU SNSAC register. */ - setbits_le32(&scu_regs->sacr, 0xfff); - - /* Remap SDRAM to 0x0 */ - writel(0x1, &nic301_regs->remap); /* remap.mpuzero */ - writel(0x1, &pl310->pl310_addr_filter_start); + socfpga_init_bus_mapping();
debug("Freezing all I/O banks\n"); /* freeze all IO banks */ @@ -118,8 +92,6 @@ void board_init_f(ulong dummy)
/* Put everything into reset but L4WD0. */ socfpga_per_reset_all(); - /* Put FPGA bridges into reset too. */ - socfpga_bridges_reset(1);
socfpga_per_reset(SOCFPGA_RESET(SDR), 0); socfpga_per_reset(SOCFPGA_RESET(UART0), 0);
Should be called something like socfpga_something_remap_something(), since it configures the mapping of the first 1 MiB of RAM . otherwise OK
Drop this from the function, this has nothing to do with the remap settings.
To boot from fpga OnChip RAM, some changes are required in SPL to ensure the code is linked to the correct address (in contrast to QSPI and MMC boot, FPGA boot executes SPL in place instead of copying it to SRAM) and that fpga OnChip RAM stays accessible while SPL runs (don't disable fpga bridges).
This adds a new config option (CONFIG_SPL_SOCFPGA_BOOT_FROM_FPGA) for socfpga gen5 boards.
arch/arm/mach-socfpga/Kconfig | 12 ++++++++++++ arch/arm/mach-socfpga/misc_gen5.c | 11 +++++++++-- arch/arm/mach-socfpga/spl_gen5.c | 3 ++- include/configs/socfpga_common.h | 5 +++++ 4 files changed, 28 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig index 5c1df2cf1f..a909395aac 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -132,3 +132,15 @@ config SYS_CONFIG_NAME default "socfpga_vining_fpga" if TARGET_SOCFPGA_SAMTEC_VINING_FPGA
endif + +if TARGET_SOCFPGA_GEN5 + +config SPL_SOCFPGA_BOOT_FROM_FPGA + bool "Allow booting SPL from FPGA OnChip RAM" + default n + help + Boot from FPGA: this changes the linker address for SPL code to run + from FPGA OnChip memory instead of SRAM and ensures FPGA OnChip RAM + stays accessible while SPL runs. + +endif diff --git a/arch/arm/mach-socfpga/misc_gen5.c b/arch/arm/mach-socfpga/misc_gen5.c index 32af1a9084..00df16d0b1 100644 --- a/arch/arm/mach-socfpga/misc_gen5.c +++ b/arch/arm/mach-socfpga/misc_gen5.c @@ -177,7 +177,8 @@ static void socfpga_nic301_slave_ns(void)
void socfpga_init_bus_mapping(void) { - socfpga_bridges_reset(1); + if (!CONFIG_IS_ENABLED(SOCFPGA_BOOT_FROM_FPGA)) + socfpga_bridges_reset(1);
@@ -189,7 +190,13 @@ void socfpga_init_bus_mapping(void) setbits_le32(&scu_regs->sacr, 0xfff);
/* Configure the L2 controller to make SDRAM start at 0 */ - writel(0x1, &nic301_regs->remap); /* remap.mpuzero */ + if (CONFIG_IS_ENABLED(SOCFPGA_BOOT_FROM_FPGA)) { + /* remap.mpuzero, keep fpga bridge enabled */ + writel(0x9, &nic301_regs->remap); + } else { + /* remap.mpuzero */ + writel(0x1, &nic301_regs->remap); + } writel(0x1, &pl310->pl310_addr_filter_start); }
diff --git a/arch/arm/mach-socfpga/spl_gen5.c b/arch/arm/mach-socfpga/spl_gen5.c index 631905fbee..1a16c46915 100644 --- a/arch/arm/mach-socfpga/spl_gen5.c +++ b/arch/arm/mach-socfpga/spl_gen5.c @@ -161,5 +161,6 @@ void board_init_f(ulong dummy) hang(); }
- socfpga_bridges_reset(1); + if (!CONFIG_IS_ENABLED(SOCFPGA_BOOT_FROM_FPGA)) + socfpga_bridges_reset(1); } diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 2fb207c86a..3cdde0f926 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -239,7 +239,12 @@ unsigned int cm_get_qspi_controller_clk_hz(void); * 0xFFEz_zzzz ...... Malloc area (grows up to top) * 0xFFE3_FFFF ...... End of SRAM (top) */ +#if CONFIG_SPL_SOCFPGA_BOOT_FROM_FPGA +/* SPL executed from FPGA */ +#define CONFIG_SPL_TEXT_BASE 0xC0000000 +#else #define CONFIG_SPL_TEXT_BASE CONFIG_SYS_INIT_RAM_ADDR +#endif #define CONFIG_SPL_MAX_SIZE CONFIG_SYS_INIT_RAM_SIZE
#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10)
I wonder if you can somehow detect that you're booting from FPGA , using BSEL readout maybe, but then I guess you have a problem with the link address ... hrm.
endif
- bool "Allow booting SPL from FPGA OnChip RAM"
If you converted SPL_TEXT_BASE to Kconfig , then selecting this could flip it to correct value. Can you do that ?
- default n
- help
- if (CONFIG_IS_ENABLED(SOCFPGA_BOOT_FROM_FPGA)) {
- } else {
/* remap.mpuzero */
- } writel(0x1, &pl310->pl310_addr_filter_start);
- if (!CONFIG_IS_ENABLED(SOCFPGA_BOOT_FROM_FPGA))
- 0xFFEz_zzzz ...... Malloc area (grows up to top)
- 0xFFE3_FFFF ...... End of SRAM (top)
I was trying that, but we need to fix the linker address anyway, so...
endif
Sure, I'll try that.
default n
help
run
RAM
socfpga_bridges_reset(1); socfpga_nic301_slave_ns();
} else {
/* remap.mpuzero */
On 08/13/2018 09:33 AM, Simon Goldschmidt wrote: > To boot from fpga OnChip RAM, some changes are required in SPL > to ensure the code is linked to the correct address (in contrast > to QSPI and MMC boot, FPGA boot executes SPL in place instead of > copying it to SRAM) and that fpga OnChip RAM stays accessible while > SPL runs (don't disable fpga bridges). > > This adds a new config option (CONFIG_SPL_SOCFPGA_BOOT_FROM_FPGA) > for socfpga gen5 boards. > > Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com <mailto:simon.k.r.goldschmidt@gmail.com>> I wonder if you can somehow detect that you're booting from FPGA , using BSEL readout maybe, but then I guess you have a problem with the link address ... hrm.
Right
> --- > > Changes in v3: this patch is new in v3 > Changes in v2: None > > arch/arm/mach-socfpga/Kconfig | 12 ++++++++++++ > arch/arm/mach-socfpga/misc_gen5.c | 11 +++++++++-- > arch/arm/mach-socfpga/spl_gen5.c | 3 ++- > include/configs/socfpga_common.h | 5 +++++ > 4 files changed, 28 insertions(+), 3 deletions(-) > > diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig > index 5c1df2cf1f..a909395aac 100644 > --- a/arch/arm/mach-socfpga/Kconfig > +++ b/arch/arm/mach-socfpga/Kconfig > @@ -132,3 +132,15 @@ config SYS_CONFIG_NAME > default "socfpga_vining_fpga" if TARGET_SOCFPGA_SAMTEC_VINING_FPGA > > endif > + > +if TARGET_SOCFPGA_GEN5 > + > +config SPL_SOCFPGA_BOOT_FROM_FPGA > + bool "Allow booting SPL from FPGA OnChip RAM" If you converted SPL_TEXT_BASE to Kconfig , then selecting this could flip it to correct value. Can you do that ?
Look at tools/moveconfig.py
> + default n > + help > + Boot from FPGA: this changes the linker address for SPL code to run > + from FPGA OnChip memory instead of SRAM and ensures FPGA OnChip RAM > + stays accessible while SPL runs. > + > +endif > diff --git a/arch/arm/mach-socfpga/misc_gen5.c b/arch/arm/mach-socfpga/misc_gen5.c > index 32af1a9084..00df16d0b1 100644 > --- a/arch/arm/mach-socfpga/misc_gen5.c > +++ b/arch/arm/mach-socfpga/misc_gen5.c > @@ -177,7 +177,8 @@ static void socfpga_nic301_slave_ns(void) > > void socfpga_init_bus_mapping(void) > { > - socfpga_bridges_reset(1); > + if (!CONFIG_IS_ENABLED(SOCFPGA_BOOT_FROM_FPGA)) > + socfpga_bridges_reset(1); > > socfpga_nic301_slave_ns(); > > @@ -189,7 +190,13 @@ void socfpga_init_bus_mapping(void) > setbits_le32(&scu_regs->sacr, 0xfff); > > /* Configure the L2 controller to make SDRAM start at 0 */ > - writel(0x1, &nic301_regs->remap); /* remap.mpuzero */ > + if (CONFIG_IS_ENABLED(SOCFPGA_BOOT_FROM_FPGA)) { > + /* remap.mpuzero, keep fpga bridge enabled */ > + writel(0x9, &nic301_regs->remap); > + } else { > + /* remap.mpuzero */ > + writel(0x1, &nic301_regs->remap); > + } > writel(0x1, &pl310->pl310_addr_filter_start); > } > > diff --git a/arch/arm/mach-socfpga/spl_gen5.c b/arch/arm/mach-socfpga/spl_gen5.c > index 631905fbee..1a16c46915 100644 > --- a/arch/arm/mach-socfpga/spl_gen5.c > +++ b/arch/arm/mach-socfpga/spl_gen5.c > @@ -161,5 +161,6 @@ void board_init_f(ulong dummy) > hang(); > } > > - socfpga_bridges_reset(1); > + if (!CONFIG_IS_ENABLED(SOCFPGA_BOOT_FROM_FPGA)) > + socfpga_bridges_reset(1); > } > diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h > index 2fb207c86a..3cdde0f926 100644 > --- a/include/configs/socfpga_common.h > +++ b/include/configs/socfpga_common.h > @@ -239,7 +239,12 @@ unsigned int cm_get_qspi_controller_clk_hz(void); > * 0xFFEz_zzzz ...... Malloc area (grows up to top) > * 0xFFE3_FFFF ...... End of SRAM (top) > */ > +#if CONFIG_SPL_SOCFPGA_BOOT_FROM_FPGA > +/* SPL executed from FPGA */ > +#define CONFIG_SPL_TEXT_BASE 0xC0000000 > +#else > #define CONFIG_SPL_TEXT_BASE CONFIG_SYS_INIT_RAM_ADDR > +#endif > #define CONFIG_SPL_MAX_SIZE CONFIG_SYS_INIT_RAM_SIZE > > #if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) > -- Best regards, Marek Vasut
malloc_simple() can return 0 if out of memory. Don't call memset from calloc() in this case but rely on the caller checking the return value.
Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Reviewed-by: Marek Vasut marex@denx.de
common/malloc_simple.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/common/malloc_simple.c b/common/malloc_simple.c index c14f8b59c1..871b5444bd 100644 --- a/common/malloc_simple.c +++ b/common/malloc_simple.c @@ -57,7 +57,8 @@ void *calloc(size_t nmemb, size_t elem_size) void *ptr;
ptr = malloc(size); - memset(ptr, '\0', size); + if (ptr) + memset(ptr, '\0', size);
return ptr; }
Changes in v3:
Changes in v2:
I applied some of this to u-boot-socfpga/master , so you dont have to repost those.
Changes in v3:
Changes in v2:
Ok, thanks!
Simon
Simon Goldschmidt
