[U-Boot] [PATCH] spi: davinci: Remove duplicate code to set bus and cs for slave
It's done in spi_alloc_slave().
Signed-off-by: Axel Lin axel.lin@ingics.com --- drivers/spi/davinci_spi.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/drivers/spi/davinci_spi.c b/drivers/spi/davinci_spi.c index 0ec5b9d..bf18362 100644 --- a/drivers/spi/davinci_spi.c +++ b/drivers/spi/davinci_spi.c @@ -32,9 +32,6 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, if (!ds) return NULL;
- ds->slave.bus = bus; - ds->slave.cs = cs; - switch (bus) { case SPI0_BUS: ds->regs = (struct davinci_spi_regs *)SPI0_BASE;
ds->slave.cs = cs;
-- 1.9.1
Applied to u-boot-spi/master
thanks!
Axel Lin
Jagan Teki
