[U-Boot] [PATCH v2 7/8] armv8: fsl-layerscape: Move DDR config options to Kconfig
Move DDR3, DDR4 and realted options to Kconfig and clean up existing uses.
Signed-off-by: York Sun york.sun@nxp.com
Changes in v2: No patch
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 54 +++++++++++++++++++++++ arch/arm/include/asm/arch-fsl-layerscape/config.h | 14 ------ configs/ls1043aqds_defconfig | 2 +- configs/ls1043aqds_lpuart_defconfig | 3 +- configs/ls1043aqds_nand_defconfig | 3 +- configs/ls1043aqds_nor_ddr3_defconfig | 1 + configs/ls1043aqds_qspi_defconfig | 3 +- configs/ls1043aqds_sdcard_ifc_defconfig | 3 +- configs/ls1043aqds_sdcard_qspi_defconfig | 3 +- configs/ls1043ardb_SECURE_BOOT_defconfig | 3 +- configs/ls1043ardb_defconfig | 2 +- configs/ls1043ardb_nand_defconfig | 3 +- configs/ls1043ardb_sdcard_defconfig | 3 +- include/configs/ls1043a_common.h | 4 -- include/configs/ls1043aqds.h | 3 -- include/configs/ls2080a_common.h | 1 - 16 files changed, 73 insertions(+), 32 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 66e509e..52a3535 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -1,22 +1,31 @@ config ARCH_LS1012A bool select FSL_LSCH2 + select SYS_FSL_DDR_BE select SYS_FSL_MMDC select SYS_FSL_ERRATUM_A010315
config ARCH_LS1043A bool select FSL_LSCH2 + select SYS_FSL_DDR_BE + select SYS_FSL_DDR_VER_50 select SYS_FSL_ERRATUM_A010315
config ARCH_LS1046A bool select FSL_LSCH2 + select SYS_FSL_DDR_BE + select SYS_FSL_DDR4 + select SYS_FSL_DDR_VER_50 select SYS_FSL_SRDS_2
config ARCH_LS2080A bool select FSL_LSCH3 + select SYS_FSL_DDR4 + select SYS_FSL_DDR_LE + select SYS_FSL_DDR_VER_50 select SYS_FSL_HAS_DP_DDR select SYS_FSL_SRDS_2
@@ -76,4 +85,49 @@ config SYS_FSL_SRDS_2 config SYS_HAS_SERDES bool
+config SYS_FSL_DDR + bool "Freescale DDR driver" + help + Select Freescale General DDR driver, shared between most Freescale + PowerPC- based SoCs (such as mpc83xx, mpc85xx, mpc86xx) and ARM- + based Layerscape SoCs (such as ls2080a). + +config SYS_FSL_DDR_BE + bool + help + Access DDR registers in big-endian. + +config SYS_FSL_DDR_LE + bool + help + Access DDR registers in little-endian. + +config SYS_FSL_DDR_VER + int + default 50 if SYS_FSL_DDR_VER_50 + +config SYS_FSL_DDR_VER_50 + bool + +config SYS_FSL_DDRC_ARM_GEN3 + bool + +config SYS_FSL_DDRC_GEN4 + bool + +config SYS_FSL_DDR3 + bool "Freescale DDR3 controller" + depends on !SYS_FSL_DDR4 + select SYS_FSL_DDR + select SYS_FSL_DDRC_ARM_GEN3 + help + Enable Freescale DDR3 controller on ARM-based SoCs. + +config SYS_FSL_DDR4 + bool "Freescale DDR4 controller" + select SYS_FSL_DDR + select SYS_FSL_DDRC_GEN4 + help + Enable Freescale DDR4 controller. + endmenu diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 3039e72..4201e0f 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -12,17 +12,6 @@
#define CONFIG_STANDALONE_LOAD_ADDR 0x80300000
-#ifdef CONFIG_SYS_FSL_DDR4 -#define CONFIG_SYS_FSL_DDRC_GEN4 -#else -#define CONFIG_SYS_FSL_DDRC_ARM_GEN3 /* Enable Freescale ARM DDR3 driver */ -#endif - -#ifndef CONFIG_ARCH_LS1012A -#define CONFIG_SYS_FSL_DDR /* Freescale DDR driver */ -#define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_5_0 -#endif - /* * Reserve secure memory * To be aligned with MMU block size @@ -42,7 +31,6 @@ #define CONFIG_SYS_FSL_OCRAM_SIZE 0x00200000 /* 2M */
/* DDR */ -#define CONFIG_SYS_FSL_DDR_LE #define CONFIG_SYS_LS2_DDR_BLOCK1_SIZE ((phys_size_t)2 << 30) #define CONFIG_MAX_MEM_MAPPED CONFIG_SYS_LS2_DDR_BLOCK1_SIZE
@@ -166,7 +154,6 @@ #define CONFIG_SYS_NUM_FMAN 1 #define CONFIG_SYS_NUM_FM1_DTSEC 7 #define CONFIG_SYS_NUM_FM1_10GEC 1 -#define CONFIG_SYS_FSL_DDR_BE #define CONFIG_SYS_DDR_BLOCK1_SIZE ((phys_size_t)2 << 30) #define CONFIG_MAX_MEM_MAPPED CONFIG_SYS_DDR_BLOCK1_SIZE
@@ -204,7 +191,6 @@ #define CONFIG_SYS_NUM_FMAN 1 #define CONFIG_SYS_NUM_FM1_DTSEC 8 #define CONFIG_SYS_NUM_FM1_10GEC 2 -#define CONFIG_SYS_FSL_DDR_BE #define CONFIG_SYS_DDR_BLOCK1_SIZE ((phys_size_t)2 << 30) #define CONFIG_MAX_MEM_MAPPED CONFIG_SYS_DDR_BLOCK1_SIZE
diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig index b209486..91382ff 100644 --- a/configs/ls1043aqds_defconfig +++ b/configs/ls1043aqds_defconfig @@ -4,7 +4,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" +CONFIG_SYS_FSL_DDR4=y CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/ls1043aqds_lpuart_defconfig b/configs/ls1043aqds_lpuart_defconfig index a60ea68..0508885 100644 --- a/configs/ls1043aqds_lpuart_defconfig +++ b/configs/ls1043aqds_lpuart_defconfig @@ -4,7 +4,8 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-lpuart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,LPUART" +CONFIG_SYS_EXTRA_OPTIONS="LPUART" +CONFIG_SYS_FSL_DDR4=y CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index 593f244..0e2df72 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -12,7 +12,8 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,RAMBOOT_PBL,SPL_FSL_PBL,NAND_BOOT" +CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,NAND_BOOT" +CONFIG_SYS_FSL_DDR4=y CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=10 CONFIG_SPL=y diff --git a/configs/ls1043aqds_nor_ddr3_defconfig b/configs/ls1043aqds_nor_ddr3_defconfig index a844d9d..7c051ab 100644 --- a/configs/ls1043aqds_nor_ddr3_defconfig +++ b/configs/ls1043aqds_nor_ddr3_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y +CONFIG_SYS_FSL_DDR3=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_USB=y diff --git a/configs/ls1043aqds_qspi_defconfig b/configs/ls1043aqds_qspi_defconfig index 92e5e80..bde0350 100644 --- a/configs/ls1043aqds_qspi_defconfig +++ b/configs/ls1043aqds_qspi_defconfig @@ -4,7 +4,8 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,QSPI_BOOT" +CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" +CONFIG_SYS_FSL_DDR4=y CONFIG_QSPI_BOOT=y CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index e360906..4354db9 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -12,7 +12,8 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" +CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" +CONFIG_SYS_FSL_DDR4=y CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=10 CONFIG_SPL=y diff --git a/configs/ls1043aqds_sdcard_qspi_defconfig b/configs/ls1043aqds_sdcard_qspi_defconfig index b6ece37..b4e0624 100644 --- a/configs/ls1043aqds_sdcard_qspi_defconfig +++ b/configs/ls1043aqds_sdcard_qspi_defconfig @@ -12,7 +12,8 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" +CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" +CONFIG_SYS_FSL_DDR4=y CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=10 CONFIG_SPL=y diff --git a/configs/ls1043ardb_SECURE_BOOT_defconfig b/configs/ls1043ardb_SECURE_BOOT_defconfig index f51e020..d45a464 100644 --- a/configs/ls1043ardb_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_SECURE_BOOT_defconfig @@ -4,7 +4,8 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, SECURE_BOOT" +CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" +CONFIG_SYS_FSL_DDR4=y CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index 5c20e44..528c845 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -4,7 +4,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" +CONFIG_SYS_FSL_DDR4=y CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index a203030..6149f7f 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -12,7 +12,8 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,NAND_BOOT,SYS_FSL_DDR4" +CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,NAND_BOOT" +CONFIG_SYS_FSL_DDR4=y CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=10 CONFIG_SPL=y diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index 323bb77..7dc6064 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -12,7 +12,8 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SYS_FSL_DDR4" +CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" +CONFIG_SYS_FSL_DDR4=y CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=10 CONFIG_SPL=y diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 3a85b6a..0fd69bf 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -24,10 +24,6 @@ #define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_BOARD_EARLY_INIT_F 1
-#ifndef CONFIG_SYS_FSL_DDR4 -#define CONFIG_SYS_FSL_DDR3 /* Use DDR3 memory */ -#endif - #define CONFIG_VERY_BIG_RAM #define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000 #define CONFIG_SYS_FSL_DDR_SDRAM_BASE_PHY 0 diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index b18fcc0..b80e316 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -42,9 +42,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_SPD_BUS_NUM 0
#define CONFIG_FSL_DDR_INTERACTIVE /* Interactive debugging */ -#ifndef CONFIG_SYS_FSL_DDR4 -#define CONFIG_SYS_FSL_DDR3 /* Use DDR3 memory */ -#endif
#define CONFIG_DDR_ECC #ifdef CONFIG_DDR_ECC diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 187aee1..3dd4da8 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -46,7 +46,6 @@ #define CONFIG_FSL_DDR_INTERACTIVE /* Interactive debugging */ #endif #ifndef CONFIG_SYS_FSL_DDR4 -#define CONFIG_SYS_FSL_DDR3 /* Use DDR3 memory */ #define CONFIG_SYS_DDR_RAW_TIMING #endif
York Sun
