[U-Boot] [patch v2 00/13] imx: mx6sabresd: support SPL FIT
This patch set is to support SPL FIT for mx6sabresd board. Patchset tested on 6qsabresd and 6qpsabresd board, works well. The mkimage_fit.sh is modified from sunxi code to generate u-boot.its.
V2: Rebased to latest master branch Include patch https://patchwork.ozlabs.org/patch/798992/ to make this patchset could be applied together.
Peng Fan (13): scripts: spl: fix typo arm: dts: include dts for imx6sabresd power: pmic/regulator allow dm be omited by SPL Makefile: build FIT image if CONFIG_SPL_FIT_GENERATOR defined imx: introduce mkimage_fit.sh imx: mx6sabresd: implement board_fit_config_name_match imx: mx6sabresd: enable SPL FIT scripts: spl: Disable DM MMC when SPL DM not enabled mmc: fsl_esdhc: switch to use CONFIG_IS_ENABLED power: pmic.h: include dm/ofnode.h board: freescale: common: add pfuze dm code imx: mx6sabresd: enable dm drivers imx: mx6sabresd: update README
Makefile | 4 + arch/arm/dts/Makefile | 3 + arch/arm/dts/imx6dl-sabresd.dts | 22 + arch/arm/dts/imx6dl.dtsi | 242 +++++++++++ arch/arm/dts/imx6q-sabresd.dts | 30 ++ arch/arm/dts/imx6q.dtsi | 164 ++++++- arch/arm/dts/imx6qdl-sabresd.dtsi | 738 ++++++++++++++++++++++++++++++++ arch/arm/dts/imx6qdl.dtsi | 100 +++-- arch/arm/dts/imx6qp-sabresd.dts | 93 ++++ arch/arm/dts/imx6qp.dtsi | 153 +++++++ arch/arm/mach-imx/mkimage_fit.sh | 63 +++ board/freescale/common/Makefile | 1 + board/freescale/common/pfuze.h | 5 + board/freescale/common/pfuze_dm.c | 89 ++++ board/freescale/mx6sabresd/README | 18 +- board/freescale/mx6sabresd/mx6sabresd.c | 339 ++++++--------- configs/mx6sabresd_defconfig | 22 +- drivers/mmc/fsl_esdhc.c | 14 +- drivers/power/pmic/Makefile | 4 +- drivers/power/regulator/Makefile | 2 +- include/configs/mx6sabresd.h | 15 +- include/power/pmic.h | 1 + scripts/Makefile.uncmd_spl | 3 +- 23 files changed, 1869 insertions(+), 256 deletions(-) create mode 100644 arch/arm/dts/imx6dl-sabresd.dts create mode 100644 arch/arm/dts/imx6q-sabresd.dts create mode 100644 arch/arm/dts/imx6qdl-sabresd.dtsi create mode 100644 arch/arm/dts/imx6qp-sabresd.dts create mode 100644 arch/arm/dts/imx6qp.dtsi create mode 100755 arch/arm/mach-imx/mkimage_fit.sh create mode 100644 board/freescale/common/pfuze_dm.c
Typo fix: CONIFG->CONFIG
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Tom Rini trini@konsulko.com --- scripts/Makefile.uncmd_spl | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/scripts/Makefile.uncmd_spl b/scripts/Makefile.uncmd_spl index 15d0836..b399411 100644 --- a/scripts/Makefile.uncmd_spl +++ b/scripts/Makefile.uncmd_spl @@ -9,7 +9,7 @@ ifdef CONFIG_SPL_BUILD ifndef CONFIG_SPL_DM CONFIG_DM_SERIAL= CONFIG_DM_GPIO= -CONIFG_DM_I2C= +CONFIG_DM_I2C= CONFIG_DM_SPI= CONFIG_DM_SPI_FLASH= endif
Import dts from commit aae4e7a8bc("Linux 4.13-rc4") for imx6sabresd board.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/dts/Makefile | 3 + arch/arm/dts/imx6dl-sabresd.dts | 22 ++ arch/arm/dts/imx6dl.dtsi | 242 +++++++++++++ arch/arm/dts/imx6q-sabresd.dts | 30 ++ arch/arm/dts/imx6q.dtsi | 164 ++++++++- arch/arm/dts/imx6qdl-sabresd.dtsi | 738 ++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx6qdl.dtsi | 100 ++++-- arch/arm/dts/imx6qp-sabresd.dts | 93 +++++ arch/arm/dts/imx6qp.dtsi | 153 ++++++++ 9 files changed, 1520 insertions(+), 25 deletions(-) create mode 100644 arch/arm/dts/imx6dl-sabresd.dts create mode 100644 arch/arm/dts/imx6q-sabresd.dts create mode 100644 arch/arm/dts/imx6qdl-sabresd.dtsi create mode 100644 arch/arm/dts/imx6qp-sabresd.dts create mode 100644 arch/arm/dts/imx6qp.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index c2dc240..a700864 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -356,6 +356,9 @@ dtb-$(CONFIG_MX6) += imx6ull-14x14-evk.dtb \ imx6sll-evk.dtb \ imx6dl-icore.dtb \ imx6dl-icore-rqs.dtb \ + imx6dl-sabresd.dtb \ + imx6q-sabresd.dtb \ + imx6qp-sabresd.dtb \ imx6q-icore.dtb \ imx6q-icore-rqs.dtb \ imx6q-logicpd.dtb \ diff --git a/arch/arm/dts/imx6dl-sabresd.dts b/arch/arm/dts/imx6dl-sabresd.dts new file mode 100644 index 0000000..9607afe --- /dev/null +++ b/arch/arm/dts/imx6dl-sabresd.dts @@ -0,0 +1,22 @@ +/* + * Copyright (C) 2013 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +/dts-v1/; + +#include "imx6dl.dtsi" +#include "imx6qdl-sabresd.dtsi" + +/ { + model = "Freescale i.MX6 DualLite SABRE Smart Device Board"; + compatible = "fsl,imx6dl-sabresd", "fsl,imx6dl"; +}; + +&ipu1_csi1_from_ipu1_csi1_mux { + clock-lanes = <0>; + data-lanes = <1 2>; +}; diff --git a/arch/arm/dts/imx6dl.dtsi b/arch/arm/dts/imx6dl.dtsi index 9a4c22c..8475e6c 100644 --- a/arch/arm/dts/imx6dl.dtsi +++ b/arch/arm/dts/imx6dl.dtsi @@ -100,6 +100,11 @@ }; };
+ capture-subsystem { + compatible = "fsl,imx-capture-subsystem"; + ports = <&ipu1_csi0>, <&ipu1_csi1>; + }; + display-subsystem { compatible = "fsl,imx-display-subsystem"; ports = <&ipu1_di0>, <&ipu1_di1>; @@ -111,6 +116,169 @@ }; };
+&gpio1 { + gpio-ranges = <&iomuxc 0 131 2>, <&iomuxc 2 137 8>, <&iomuxc 10 189 2>, + <&iomuxc 12 194 1>, <&iomuxc 13 193 1>, <&iomuxc 14 192 1>, + <&iomuxc 15 191 1>, <&iomuxc 16 185 2>, <&iomuxc 18 184 1>, + <&iomuxc 19 187 1>, <&iomuxc 20 183 1>, <&iomuxc 21 188 1>, + <&iomuxc 22 123 3>, <&iomuxc 25 121 1>, <&iomuxc 26 127 1>, + <&iomuxc 27 126 1>, <&iomuxc 28 128 1>, <&iomuxc 29 130 1>, + <&iomuxc 30 129 1>, <&iomuxc 31 122 1>; +}; + +&gpio2 { + gpio-ranges = <&iomuxc 0 161 8>, <&iomuxc 8 208 8>, <&iomuxc 16 74 1>, + <&iomuxc 17 73 1>, <&iomuxc 18 72 1>, <&iomuxc 19 71 1>, + <&iomuxc 20 70 1>, <&iomuxc 21 69 1>, <&iomuxc 22 68 1>, + <&iomuxc 23 79 2>, <&iomuxc 25 118 2>, <&iomuxc 27 117 1>, + <&iomuxc 28 113 4>; +}; + +&gpio3 { + gpio-ranges = <&iomuxc 0 97 2>, <&iomuxc 2 105 8>, <&iomuxc 10 99 6>, + <&iomuxc 16 81 16>; +}; + +&gpio4 { + gpio-ranges = <&iomuxc 5 136 1>, <&iomuxc 6 145 1>, <&iomuxc 7 150 1>, + <&iomuxc 8 146 1>, <&iomuxc 9 151 1>, <&iomuxc 10 147 1>, + <&iomuxc 11 152 1>, <&iomuxc 12 148 1>, <&iomuxc 13 153 1>, + <&iomuxc 14 149 1>, <&iomuxc 15 154 1>, <&iomuxc 16 39 7>, + <&iomuxc 23 56 1>, <&iomuxc 24 61 7>, <&iomuxc 31 46 1>; +}; + +&gpio5 { + gpio-ranges = <&iomuxc 0 120 1>, <&iomuxc 2 77 1>, <&iomuxc 4 76 1>, + <&iomuxc 5 47 9>, <&iomuxc 14 57 4>, <&iomuxc 18 37 1>, + <&iomuxc 19 36 1>, <&iomuxc 20 35 1>, <&iomuxc 21 38 1>, + <&iomuxc 22 29 6>, <&iomuxc 28 19 4>; +}; + +&gpio6 { + gpio-ranges = <&iomuxc 0 23 6>, <&iomuxc 6 75 1>, <&iomuxc 7 156 1>, + <&iomuxc 8 155 1>, <&iomuxc 9 170 1>, <&iomuxc 10 169 1>, + <&iomuxc 11 157 1>, <&iomuxc 14 158 3>, <&iomuxc 17 204 1>, + <&iomuxc 18 203 1>, <&iomuxc 19 182 1>, <&iomuxc 20 177 4>, + <&iomuxc 24 175 1>, <&iomuxc 25 171 1>, <&iomuxc 26 181 1>, + <&iomuxc 27 172 3>, <&iomuxc 30 176 1>, <&iomuxc 31 78 1>; +}; + +&gpio7 { + gpio-ranges = <&iomuxc 0 202 1>, <&iomuxc 1 201 1>, <&iomuxc 2 196 1>, + <&iomuxc 3 195 1>, <&iomuxc 4 197 4>, <&iomuxc 8 205 1>, + <&iomuxc 9 207 1>, <&iomuxc 10 206 1>, <&iomuxc 11 133 3>; +}; + +&gpr { + ipu1_csi0_mux: ipu1_csi0_mux@34 { + compatible = "video-mux"; + mux-controls = <&mux 0>; + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + ipu1_csi0_mux_from_mipi_vc0: endpoint { + remote-endpoint = <&mipi_vc0_to_ipu1_csi0_mux>; + }; + }; + + port@1 { + reg = <1>; + + ipu1_csi0_mux_from_mipi_vc1: endpoint { + remote-endpoint = <&mipi_vc1_to_ipu1_csi0_mux>; + }; + }; + + port@2 { + reg = <2>; + + ipu1_csi0_mux_from_mipi_vc2: endpoint { + remote-endpoint = <&mipi_vc2_to_ipu1_csi0_mux>; + }; + }; + + port@3 { + reg = <3>; + + ipu1_csi0_mux_from_mipi_vc3: endpoint { + remote-endpoint = <&mipi_vc3_to_ipu1_csi0_mux>; + }; + }; + + port@4 { + reg = <4>; + + ipu1_csi0_mux_from_parallel_sensor: endpoint { + }; + }; + + port@5 { + reg = <5>; + + ipu1_csi0_mux_to_ipu1_csi0: endpoint { + remote-endpoint = <&ipu1_csi0_from_ipu1_csi0_mux>; + }; + }; + }; + + ipu1_csi1_mux: ipu1_csi1_mux@34 { + compatible = "video-mux"; + mux-controls = <&mux 1>; + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + ipu1_csi1_mux_from_mipi_vc0: endpoint { + remote-endpoint = <&mipi_vc0_to_ipu1_csi1_mux>; + }; + }; + + port@1 { + reg = <1>; + + ipu1_csi1_mux_from_mipi_vc1: endpoint { + remote-endpoint = <&mipi_vc1_to_ipu1_csi1_mux>; + }; + }; + + port@2 { + reg = <2>; + + ipu1_csi1_mux_from_mipi_vc2: endpoint { + remote-endpoint = <&mipi_vc2_to_ipu1_csi1_mux>; + }; + }; + + port@3 { + reg = <3>; + + ipu1_csi1_mux_from_mipi_vc3: endpoint { + remote-endpoint = <&mipi_vc3_to_ipu1_csi1_mux>; + }; + }; + + port@4 { + reg = <4>; + + ipu1_csi1_mux_from_parallel_sensor: endpoint { + }; + }; + + port@5 { + reg = <5>; + + ipu1_csi1_mux_to_ipu1_csi1: endpoint { + remote-endpoint = <&ipu1_csi1_from_ipu1_csi1_mux>; + }; + }; + }; +}; + &gpt { compatible = "fsl,imx6dl-gpt"; }; @@ -119,6 +287,12 @@ compatible = "fsl,imx6dl-hdmi"; };
+&ipu1_csi1 { + ipu1_csi1_from_ipu1_csi1_mux: endpoint { + remote-endpoint = <&ipu1_csi1_mux_to_ipu1_csi1>; + }; +}; + &ldb { clocks = <&clks IMX6QDL_CLK_LDB_DI0_SEL>, <&clks IMX6QDL_CLK_LDB_DI1_SEL>, <&clks IMX6QDL_CLK_IPU1_DI0_SEL>, <&clks IMX6QDL_CLK_IPU1_DI1_SEL>, @@ -128,6 +302,74 @@ "di0", "di1"; };
+&mipi_csi { + port@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + + mipi_vc0_to_ipu1_csi0_mux: endpoint@0 { + remote-endpoint = <&ipu1_csi0_mux_from_mipi_vc0>; + }; + + mipi_vc0_to_ipu1_csi1_mux: endpoint@1 { + remote-endpoint = <&ipu1_csi1_mux_from_mipi_vc0>; + }; + }; + + port@2 { + reg = <2>; + #address-cells = <1>; + #size-cells = <0>; + + mipi_vc1_to_ipu1_csi0_mux: endpoint@0 { + remote-endpoint = <&ipu1_csi0_mux_from_mipi_vc1>; + }; + + mipi_vc1_to_ipu1_csi1_mux: endpoint@1 { + remote-endpoint = <&ipu1_csi1_mux_from_mipi_vc1>; + }; + }; + + port@3 { + reg = <3>; + #address-cells = <1>; + #size-cells = <0>; + + mipi_vc2_to_ipu1_csi0_mux: endpoint@0 { + remote-endpoint = <&ipu1_csi0_mux_from_mipi_vc2>; + }; + + mipi_vc2_to_ipu1_csi1_mux: endpoint@1 { + remote-endpoint = <&ipu1_csi1_mux_from_mipi_vc2>; + }; + }; + + port@4 { + reg = <4>; + #address-cells = <1>; + #size-cells = <0>; + + mipi_vc3_to_ipu1_csi0_mux: endpoint@0 { + remote-endpoint = <&ipu1_csi0_mux_from_mipi_vc3>; + }; + + mipi_vc3_to_ipu1_csi1_mux: endpoint@1 { + remote-endpoint = <&ipu1_csi1_mux_from_mipi_vc3>; + }; + }; +}; + +&mux { + mux-reg-masks = <0x34 0x00000007>, /* IPU_CSI0_MUX */ + <0x34 0x00000038>, /* IPU_CSI1_MUX */ + <0x0c 0x0000000c>, /* HDMI_MUX_CTL */ + <0x0c 0x000000c0>, /* LVDS0_MUX_CTL */ + <0x0c 0x00000300>, /* LVDS1_MUX_CTL */ + <0x28 0x00000003>, /* DCIC1_MUX_CTL */ + <0x28 0x0000000c>; /* DCIC2_MUX_CTL */ +}; + &vpu { compatible = "fsl,imx6dl-vpu", "cnm,coda960"; }; diff --git a/arch/arm/dts/imx6q-sabresd.dts b/arch/arm/dts/imx6q-sabresd.dts new file mode 100644 index 0000000..527772b --- /dev/null +++ b/arch/arm/dts/imx6q-sabresd.dts @@ -0,0 +1,30 @@ +/* + * Copyright 2012 Freescale Semiconductor, Inc. + * Copyright 2011 Linaro Ltd. + * + * The code contained herein is licensed under the GNU General Public + * License. You may obtain a copy of the GNU General Public License + * Version 2 or later at the following locations: + * + * http://www.opensource.org/licenses/gpl-license.html + * http://www.gnu.org/copyleft/gpl.html + */ + +/dts-v1/; + +#include "imx6q.dtsi" +#include "imx6qdl-sabresd.dtsi" + +/ { + model = "Freescale i.MX6 Quad SABRE Smart Device Board"; + compatible = "fsl,imx6q-sabresd", "fsl,imx6q"; +}; + +&sata { + status = "okay"; +}; + +&ipu1_csi1_from_mipi_vc1 { + clock-lanes = <0>; + data-lanes = <1 2>; +}; diff --git a/arch/arm/dts/imx6q.dtsi b/arch/arm/dts/imx6q.dtsi index c30c836..90a74173 100644 --- a/arch/arm/dts/imx6q.dtsi +++ b/arch/arm/dts/imx6q.dtsi @@ -125,7 +125,7 @@ clocks = <&clks IMX6QDL_CLK_OPENVG_AXI>, <&clks IMX6QDL_CLK_GPU2D_CORE>; clock-names = "bus", "core"; - power-domains = <&gpc 1>; + power-domains = <&pd_pu>; };
ipu2: ipu@02800000 { @@ -143,10 +143,18 @@
ipu2_csi0: port@0 { reg = <0>; + + ipu2_csi0_from_mipi_vc2: endpoint { + remote-endpoint = <&mipi_vc2_to_ipu2_csi0>; + }; };
ipu2_csi1: port@1 { reg = <1>; + + ipu2_csi1_from_ipu2_csi1_mux: endpoint { + remote-endpoint = <&ipu2_csi1_mux_to_ipu2_csi1>; + }; };
ipu2_di0: port@2 { @@ -198,6 +206,11 @@ }; };
+ capture-subsystem { + compatible = "fsl,imx-capture-subsystem"; + ports = <&ipu1_csi0>, <&ipu1_csi1>, <&ipu2_csi0>, <&ipu2_csi1>; + }; + display-subsystem { compatible = "fsl,imx-display-subsystem"; ports = <&ipu1_di0>, <&ipu1_di1>, <&ipu2_di0>, <&ipu2_di1>; @@ -209,6 +222,105 @@ }; };
+&gpio1 { + gpio-ranges = <&iomuxc 0 136 2>, <&iomuxc 2 141 1>, <&iomuxc 3 139 1>, + <&iomuxc 4 142 2>, <&iomuxc 6 140 1>, <&iomuxc 7 144 2>, + <&iomuxc 9 138 1>, <&iomuxc 10 213 3>, <&iomuxc 13 20 1>, + <&iomuxc 14 19 1>, <&iomuxc 15 21 1>, <&iomuxc 16 208 1>, + <&iomuxc 17 207 1>, <&iomuxc 18 210 3>, <&iomuxc 21 209 1>, + <&iomuxc 22 116 10>; +}; + +&gpio2 { + gpio-ranges = <&iomuxc 0 191 16>, <&iomuxc 16 55 14>, <&iomuxc 30 35 1>, + <&iomuxc 31 44 1>; +}; + +&gpio3 { + gpio-ranges = <&iomuxc 0 69 16>, <&iomuxc 16 36 8>, <&iomuxc 24 45 8>; +}; + +&gpio4 { + gpio-ranges = <&iomuxc 5 149 1>, <&iomuxc 6 126 10>, <&iomuxc 16 87 16>; +}; + +&gpio5 { + gpio-ranges = <&iomuxc 0 85 1>, <&iomuxc 2 34 1>, <&iomuxc 4 53 1>, + <&iomuxc 5 103 13>, <&iomuxc 18 150 14>; +}; + +&gpio6 { + gpio-ranges = <&iomuxc 0 164 6>, <&iomuxc 6 54 1>, <&iomuxc 7 181 5>, + <&iomuxc 14 186 3>, <&iomuxc 17 170 2>, <&iomuxc 19 22 12>, + <&iomuxc 31 86 1>; +}; + +&gpio7 { + gpio-ranges = <&iomuxc 0 172 9>, <&iomuxc 9 189 2>, <&iomuxc 11 146 3>; +}; + +&gpr { + ipu1_csi0_mux { + compatible = "video-mux"; + mux-controls = <&mux 0>; + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + ipu1_csi0_mux_from_mipi_vc0: endpoint { + remote-endpoint = <&mipi_vc0_to_ipu1_csi0_mux>; + }; + }; + + port@1 { + reg = <1>; + + ipu1_csi0_mux_from_parallel_sensor: endpoint { + }; + }; + + port@2 { + reg = <2>; + + ipu1_csi0_mux_to_ipu1_csi0: endpoint { + remote-endpoint = <&ipu1_csi0_from_ipu1_csi0_mux>; + }; + }; + }; + + ipu2_csi1_mux { + compatible = "video-mux"; + mux-controls = <&mux 1>; + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + ipu2_csi1_mux_from_mipi_vc3: endpoint { + remote-endpoint = <&mipi_vc3_to_ipu2_csi1_mux>; + }; + }; + + port@1 { + reg = <1>; + + ipu2_csi1_mux_from_parallel_sensor: endpoint { + }; + }; + + port@2 { + reg = <2>; + + ipu2_csi1_mux_to_ipu2_csi1: endpoint { + remote-endpoint = <&ipu2_csi1_from_ipu2_csi1_mux>; + }; + }; + }; +}; + &hdmi { compatible = "fsl,imx6q-hdmi";
@@ -229,6 +341,12 @@ }; };
+&ipu1_csi1 { + ipu1_csi1_from_mipi_vc1: endpoint { + remote-endpoint = <&mipi_vc1_to_ipu1_csi1>; + }; +}; + &ldb { clocks = <&clks IMX6QDL_CLK_LDB_DI0_SEL>, <&clks IMX6QDL_CLK_LDB_DI1_SEL>, <&clks IMX6QDL_CLK_IPU1_DI0_SEL>, <&clks IMX6QDL_CLK_IPU1_DI1_SEL>, @@ -275,6 +393,40 @@ }; };
+&mipi_csi { + port@1 { + reg = <1>; + + mipi_vc0_to_ipu1_csi0_mux: endpoint { + remote-endpoint = <&ipu1_csi0_mux_from_mipi_vc0>; + }; + }; + + port@2 { + reg = <2>; + + mipi_vc1_to_ipu1_csi1: endpoint { + remote-endpoint = <&ipu1_csi1_from_mipi_vc1>; + }; + }; + + port@3 { + reg = <3>; + + mipi_vc2_to_ipu2_csi0: endpoint { + remote-endpoint = <&ipu2_csi0_from_mipi_vc2>; + }; + }; + + port@4 { + reg = <4>; + + mipi_vc3_to_ipu2_csi1_mux: endpoint { + remote-endpoint = <&ipu2_csi1_mux_from_mipi_vc3>; + }; + }; +}; + &mipi_dsi { ports { port@2 { @@ -295,6 +447,16 @@ }; };
+&mux { + mux-reg-masks = <0x04 0x00080000>, /* MIPI_IPU1_MUX */ + <0x04 0x00100000>, /* MIPI_IPU2_MUX */ + <0x0c 0x0000000c>, /* HDMI_MUX_CTL */ + <0x0c 0x000000c0>, /* LVDS0_MUX_CTL */ + <0x0c 0x00000300>, /* LVDS1_MUX_CTL */ + <0x28 0x00000003>, /* DCIC1_MUX_CTL */ + <0x28 0x0000000c>; /* DCIC2_MUX_CTL */ +}; + &vpu { compatible = "fsl,imx6q-vpu", "cnm,coda960"; }; diff --git a/arch/arm/dts/imx6qdl-sabresd.dtsi b/arch/arm/dts/imx6qdl-sabresd.dtsi new file mode 100644 index 0000000..b72b6fa --- /dev/null +++ b/arch/arm/dts/imx6qdl-sabresd.dtsi @@ -0,0 +1,738 @@ +/* + * Copyright 2012 Freescale Semiconductor, Inc. + * Copyright 2011 Linaro Ltd. + * + * The code contained herein is licensed under the GNU General Public + * License. You may obtain a copy of the GNU General Public License + * Version 2 or later at the following locations: + * + * http://www.opensource.org/licenses/gpl-license.html + * http://www.gnu.org/copyleft/gpl.html + */ + +#include <dt-bindings/clock/imx6qdl-clock.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> + +/ { + chosen { + stdout-path = &uart1; + }; + + memory { + reg = <0x10000000 0x40000000>; + }; + + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + reg_usb_otg_vbus: regulator@0 { + compatible = "regulator-fixed"; + reg = <0>; + regulator-name = "usb_otg_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio3 22 0>; + enable-active-high; + vin-supply = <&swbst_reg>; + }; + + reg_usb_h1_vbus: regulator@1 { + compatible = "regulator-fixed"; + reg = <1>; + regulator-name = "usb_h1_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio1 29 0>; + enable-active-high; + vin-supply = <&swbst_reg>; + }; + + reg_audio: regulator@2 { + compatible = "regulator-fixed"; + reg = <2>; + regulator-name = "wm8962-supply"; + gpio = <&gpio4 10 0>; + enable-active-high; + }; + + reg_pcie: regulator@3 { + compatible = "regulator-fixed"; + reg = <3>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pcie_reg>; + regulator-name = "MPCIE_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio3 19 0>; + regulator-always-on; + enable-active-high; + }; + }; + + gpio-keys { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_keys>; + + power { + label = "Power Button"; + gpios = <&gpio3 29 GPIO_ACTIVE_LOW>; + wakeup-source; + linux,code = <KEY_POWER>; + }; + + volume-up { + label = "Volume Up"; + gpios = <&gpio1 4 GPIO_ACTIVE_LOW>; + wakeup-source; + linux,code = <KEY_VOLUMEUP>; + }; + + volume-down { + label = "Volume Down"; + gpios = <&gpio1 5 GPIO_ACTIVE_LOW>; + wakeup-source; + linux,code = <KEY_VOLUMEDOWN>; + }; + }; + + sound { + compatible = "fsl,imx6q-sabresd-wm8962", + "fsl,imx-audio-wm8962"; + model = "wm8962-audio"; + ssi-controller = <&ssi2>; + audio-codec = <&codec>; + audio-routing = + "Headphone Jack", "HPOUTL", + "Headphone Jack", "HPOUTR", + "Ext Spk", "SPKOUTL", + "Ext Spk", "SPKOUTR", + "AMIC", "MICBIAS", + "IN3R", "AMIC"; + mux-int-port = <2>; + mux-ext-port = <3>; + }; + + backlight_lvds: backlight-lvds { + compatible = "pwm-backlight"; + pwms = <&pwm1 0 5000000>; + brightness-levels = <0 4 8 16 32 64 128 255>; + default-brightness-level = <7>; + status = "okay"; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_leds>; + + red { + gpios = <&gpio1 2 0>; + default-state = "on"; + }; + }; + + panel { + compatible = "hannstar,hsd100pxn1"; + backlight = <&backlight_lvds>; + + port { + panel_in: endpoint { + remote-endpoint = <&lvds0_out>; + }; + }; + }; +}; + +&ipu1_csi0_from_ipu1_csi0_mux { + bus-width = <8>; + data-shift = <12>; /* Lines 19:12 used */ + hsync-active = <1>; + vsync-active = <1>; +}; + +&ipu1_csi0_mux_from_parallel_sensor { + remote-endpoint = <&ov5642_to_ipu1_csi0_mux>; +}; + +&ipu1_csi0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ipu1_csi0>; +}; + +&mipi_csi { + status = "okay"; + + port@0 { + reg = <0>; + + mipi_csi2_in: endpoint { + remote-endpoint = <&ov5640_to_mipi_csi2>; + clock-lanes = <0>; + data-lanes = <1 2>; + }; + }; +}; + +&audmux { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_audmux>; + status = "okay"; +}; + +&clks { + assigned-clocks = <&clks IMX6QDL_CLK_LDB_DI0_SEL>, + <&clks IMX6QDL_CLK_LDB_DI1_SEL>; + assigned-clock-parents = <&clks IMX6QDL_CLK_PLL3_USB_OTG>, + <&clks IMX6QDL_CLK_PLL3_USB_OTG>; +}; + +&ecspi1 { + cs-gpios = <&gpio4 9 0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ecspi1>; + status = "okay"; + + flash: m25p80@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "st,m25p32", "jedec,spi-nor"; + spi-max-frequency = <20000000>; + reg = <0>; + }; +}; + +&fec { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet>; + phy-mode = "rgmii"; + phy-reset-gpios = <&gpio1 25 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&hdmi { + ddc-i2c-bus = <&i2c2>; + status = "okay"; +}; + +&i2c1 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; + + codec: wm8962@1a { + compatible = "wlf,wm8962"; + reg = <0x1a>; + clocks = <&clks IMX6QDL_CLK_CKO>; + DCVDD-supply = <®_audio>; + DBVDD-supply = <®_audio>; + AVDD-supply = <®_audio>; + CPVDD-supply = <®_audio>; + MICVDD-supply = <®_audio>; + PLLVDD-supply = <®_audio>; + SPKVDD1-supply = <®_audio>; + SPKVDD2-supply = <®_audio>; + gpio-cfg = < + 0x0000 /* 0:Default */ + 0x0000 /* 1:Default */ + 0x0013 /* 2:FN_DMICCLK */ + 0x0000 /* 3:Default */ + 0x8014 /* 4:FN_DMICCDAT */ + 0x0000 /* 5:Default */ + >; + }; + + ov5642: camera@3c { + compatible = "ovti,ov5642"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ov5642>; + clocks = <&clks IMX6QDL_CLK_CKO>; + clock-names = "xclk"; + reg = <0x3c>; + DOVDD-supply = <&vgen4_reg>; /* 1.8v */ + AVDD-supply = <&vgen3_reg>; /* 2.8v, rev C board is VGEN3 + rev B board is VGEN5 */ + DVDD-supply = <&vgen2_reg>; /* 1.5v*/ + powerdown-gpios = <&gpio1 16 GPIO_ACTIVE_HIGH>; + reset-gpios = <&gpio1 17 GPIO_ACTIVE_LOW>; + status = "disabled"; + + port { + ov5642_to_ipu1_csi0_mux: endpoint { + remote-endpoint = <&ipu1_csi0_mux_from_parallel_sensor>; + bus-width = <8>; + hsync-active = <1>; + vsync-active = <1>; + }; + }; + }; +}; + +&i2c2 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; + + ov5640: camera@3c { + compatible = "ovti,ov5640"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ov5640>; + reg = <0x3c>; + clocks = <&clks IMX6QDL_CLK_CKO>; + clock-names = "xclk"; + DOVDD-supply = <&vgen4_reg>; /* 1.8v */ + AVDD-supply = <&vgen3_reg>; /* 2.8v, rev C board is VGEN3 + rev B board is VGEN5 */ + DVDD-supply = <&vgen2_reg>; /* 1.5v*/ + powerdown-gpios = <&gpio1 19 GPIO_ACTIVE_HIGH>; + reset-gpios = <&gpio1 20 GPIO_ACTIVE_LOW>; + + port { + #address-cells = <1>; + #size-cells = <0>; + + ov5640_to_mipi_csi2: endpoint { + remote-endpoint = <&mipi_csi2_in>; + clock-lanes = <0>; + data-lanes = <1 2>; + }; + }; + }; + + pmic: pfuze100@08 { + compatible = "fsl,pfuze100"; + reg = <0x08>; + + regulators { + sw1a_reg: sw1ab { + regulator-min-microvolt = <300000>; + regulator-max-microvolt = <1875000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw1c_reg: sw1c { + regulator-min-microvolt = <300000>; + regulator-max-microvolt = <1875000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw2_reg: sw2 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw3a_reg: sw3a { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1975000>; + regulator-boot-on; + regulator-always-on; + }; + + sw3b_reg: sw3b { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1975000>; + regulator-boot-on; + regulator-always-on; + }; + + sw4_reg: sw4 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + }; + + swbst_reg: swbst { + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5150000>; + }; + + snvs_reg: vsnvs { + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <3000000>; + regulator-boot-on; + regulator-always-on; + }; + + vref_reg: vrefddr { + regulator-boot-on; + regulator-always-on; + }; + + vgen1_reg: vgen1 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + }; + + vgen2_reg: vgen2 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + }; + + vgen3_reg: vgen3 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + }; + + vgen4_reg: vgen4 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen5_reg: vgen5 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen6_reg: vgen6 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; +}; + +&i2c3 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + status = "okay"; + + egalax_ts@04 { + compatible = "eeti,egalax_ts"; + reg = <0x04>; + interrupt-parent = <&gpio6>; + interrupts = <7 2>; + wakeup-gpios = <&gpio6 7 0>; + }; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog>; + + imx6qdl-sabresd { + pinctrl_hog: hoggrp { + fsl,pins = < + MX6QDL_PAD_NANDF_D0__GPIO2_IO00 0x1b0b0 + MX6QDL_PAD_NANDF_D1__GPIO2_IO01 0x1b0b0 + MX6QDL_PAD_NANDF_D2__GPIO2_IO02 0x1b0b0 + MX6QDL_PAD_NANDF_D3__GPIO2_IO03 0x1b0b0 + MX6QDL_PAD_GPIO_0__CCM_CLKO1 0x130b0 + MX6QDL_PAD_NANDF_CLE__GPIO6_IO07 0x1b0b0 + MX6QDL_PAD_ENET_TXD1__GPIO1_IO29 0x1b0b0 + MX6QDL_PAD_EIM_D22__GPIO3_IO22 0x1b0b0 + MX6QDL_PAD_ENET_CRS_DV__GPIO1_IO25 0x1b0b0 + >; + }; + + pinctrl_audmux: audmuxgrp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT7__AUD3_RXD 0x130b0 + MX6QDL_PAD_CSI0_DAT4__AUD3_TXC 0x130b0 + MX6QDL_PAD_CSI0_DAT5__AUD3_TXD 0x110b0 + MX6QDL_PAD_CSI0_DAT6__AUD3_TXFS 0x130b0 + >; + }; + + pinctrl_ecspi1: ecspi1grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL1__ECSPI1_MISO 0x100b1 + MX6QDL_PAD_KEY_ROW0__ECSPI1_MOSI 0x100b1 + MX6QDL_PAD_KEY_COL0__ECSPI1_SCLK 0x100b1 + MX6QDL_PAD_KEY_ROW1__GPIO4_IO09 0x1b0b0 + >; + }; + + pinctrl_enet: enetgrp { + fsl,pins = < + MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x1b0b0 + MX6QDL_PAD_ENET_MDC__ENET_MDC 0x1b0b0 + MX6QDL_PAD_RGMII_TXC__RGMII_TXC 0x1b030 + MX6QDL_PAD_RGMII_TD0__RGMII_TD0 0x1b030 + MX6QDL_PAD_RGMII_TD1__RGMII_TD1 0x1b030 + MX6QDL_PAD_RGMII_TD2__RGMII_TD2 0x1b030 + MX6QDL_PAD_RGMII_TD3__RGMII_TD3 0x1b030 + MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL 0x1b030 + MX6QDL_PAD_ENET_REF_CLK__ENET_TX_CLK 0x1b0b0 + MX6QDL_PAD_RGMII_RXC__RGMII_RXC 0x1b030 + MX6QDL_PAD_RGMII_RD0__RGMII_RD0 0x1b030 + MX6QDL_PAD_RGMII_RD1__RGMII_RD1 0x1b030 + MX6QDL_PAD_RGMII_RD2__RGMII_RD2 0x1b030 + MX6QDL_PAD_RGMII_RD3__RGMII_RD3 0x1b030 + MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL 0x1b030 + MX6QDL_PAD_GPIO_16__ENET_REF_CLK 0x4001b0a8 + >; + }; + + pinctrl_gpio_keys: gpio_keysgrp { + fsl,pins = < + MX6QDL_PAD_EIM_D29__GPIO3_IO29 0x1b0b0 + MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x1b0b0 + MX6QDL_PAD_GPIO_5__GPIO1_IO05 0x1b0b0 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT8__I2C1_SDA 0x4001b8b1 + MX6QDL_PAD_CSI0_DAT9__I2C1_SCL 0x4001b8b1 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL3__I2C2_SCL 0x4001b8b1 + MX6QDL_PAD_KEY_ROW3__I2C2_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX6QDL_PAD_GPIO_3__I2C3_SCL 0x4001b8b1 + MX6QDL_PAD_GPIO_6__I2C3_SDA 0x4001b8b1 + >; + }; + + pinctrl_ipu1_csi0: ipu1csi0grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT12__IPU1_CSI0_DATA12 0x1b0b0 + MX6QDL_PAD_CSI0_DAT13__IPU1_CSI0_DATA13 0x1b0b0 + MX6QDL_PAD_CSI0_DAT14__IPU1_CSI0_DATA14 0x1b0b0 + MX6QDL_PAD_CSI0_DAT15__IPU1_CSI0_DATA15 0x1b0b0 + MX6QDL_PAD_CSI0_DAT16__IPU1_CSI0_DATA16 0x1b0b0 + MX6QDL_PAD_CSI0_DAT17__IPU1_CSI0_DATA17 0x1b0b0 + MX6QDL_PAD_CSI0_DAT18__IPU1_CSI0_DATA18 0x1b0b0 + MX6QDL_PAD_CSI0_DAT19__IPU1_CSI0_DATA19 0x1b0b0 + MX6QDL_PAD_CSI0_PIXCLK__IPU1_CSI0_PIXCLK 0x1b0b0 + MX6QDL_PAD_CSI0_MCLK__IPU1_CSI0_HSYNC 0x1b0b0 + MX6QDL_PAD_CSI0_VSYNC__IPU1_CSI0_VSYNC 0x1b0b0 + >; + }; + + pinctrl_ov5640: ov5640grp { + fsl,pins = < + MX6QDL_PAD_SD1_DAT2__GPIO1_IO19 0x1b0b0 + MX6QDL_PAD_SD1_CLK__GPIO1_IO20 0x1b0b0 + >; + }; + + pinctrl_ov5642: ov5642grp { + fsl,pins = < + MX6QDL_PAD_SD1_DAT0__GPIO1_IO16 0x1b0b0 + MX6QDL_PAD_SD1_DAT1__GPIO1_IO17 0x1b0b0 + >; + }; + + pinctrl_pcie: pciegrp { + fsl,pins = < + MX6QDL_PAD_GPIO_17__GPIO7_IO12 0x1b0b0 + >; + }; + + pinctrl_pcie_reg: pciereggrp { + fsl,pins = < + MX6QDL_PAD_EIM_D19__GPIO3_IO19 0x1b0b0 + >; + }; + + pinctrl_pwm1: pwm1grp { + fsl,pins = < + MX6QDL_PAD_SD1_DAT3__PWM1_OUT 0x1b0b1 + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT10__UART1_TX_DATA 0x1b0b1 + MX6QDL_PAD_CSI0_DAT11__UART1_RX_DATA 0x1b0b1 + >; + }; + + pinctrl_usbotg: usbotggrp { + fsl,pins = < + MX6QDL_PAD_ENET_RX_ER__USB_OTG_ID 0x17059 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX6QDL_PAD_SD2_CMD__SD2_CMD 0x17059 + MX6QDL_PAD_SD2_CLK__SD2_CLK 0x10059 + MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x17059 + MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x17059 + MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x17059 + MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x17059 + MX6QDL_PAD_NANDF_D4__SD2_DATA4 0x17059 + MX6QDL_PAD_NANDF_D5__SD2_DATA5 0x17059 + MX6QDL_PAD_NANDF_D6__SD2_DATA6 0x17059 + MX6QDL_PAD_NANDF_D7__SD2_DATA7 0x17059 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX6QDL_PAD_SD3_CMD__SD3_CMD 0x17059 + MX6QDL_PAD_SD3_CLK__SD3_CLK 0x10059 + MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x17059 + MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x17059 + MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x17059 + MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x17059 + MX6QDL_PAD_SD3_DAT4__SD3_DATA4 0x17059 + MX6QDL_PAD_SD3_DAT5__SD3_DATA5 0x17059 + MX6QDL_PAD_SD3_DAT6__SD3_DATA6 0x17059 + MX6QDL_PAD_SD3_DAT7__SD3_DATA7 0x17059 + >; + }; + + pinctrl_usdhc4: usdhc4grp { + fsl,pins = < + MX6QDL_PAD_SD4_CMD__SD4_CMD 0x17059 + MX6QDL_PAD_SD4_CLK__SD4_CLK 0x10059 + MX6QDL_PAD_SD4_DAT0__SD4_DATA0 0x17059 + MX6QDL_PAD_SD4_DAT1__SD4_DATA1 0x17059 + MX6QDL_PAD_SD4_DAT2__SD4_DATA2 0x17059 + MX6QDL_PAD_SD4_DAT3__SD4_DATA3 0x17059 + MX6QDL_PAD_SD4_DAT4__SD4_DATA4 0x17059 + MX6QDL_PAD_SD4_DAT5__SD4_DATA5 0x17059 + MX6QDL_PAD_SD4_DAT6__SD4_DATA6 0x17059 + MX6QDL_PAD_SD4_DAT7__SD4_DATA7 0x17059 + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX6QDL_PAD_GPIO_1__WDOG2_B 0x1b0b0 + >; + }; + }; + + gpio_leds { + pinctrl_gpio_leds: gpioledsgrp { + fsl,pins = < + MX6QDL_PAD_GPIO_2__GPIO1_IO02 0x1b0b0 + >; + }; + }; +}; + +&ldb { + status = "okay"; + + lvds-channel@1 { + fsl,data-mapping = "spwg"; + fsl,data-width = <18>; + status = "okay"; + + port@4 { + reg = <4>; + + lvds0_out: endpoint { + remote-endpoint = <&panel_in>; + }; + }; + }; +}; + +&pcie { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pcie>; + reset-gpio = <&gpio7 12 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&pwm1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm1>; + status = "okay"; +}; + +®_arm { + vin-supply = <&sw1a_reg>; +}; + +®_pu { + vin-supply = <&sw1c_reg>; +}; + +®_soc { + vin-supply = <&sw1c_reg>; +}; + +&snvs_poweroff { + status = "okay"; +}; + +&ssi2 { + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + status = "okay"; +}; + +&usbh1 { + vbus-supply = <®_usb_h1_vbus>; + status = "okay"; +}; + +&usbotg { + vbus-supply = <®_usb_otg_vbus>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbotg>; + disable-over-current; + status = "okay"; +}; + +&usdhc2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc2>; + bus-width = <8>; + cd-gpios = <&gpio2 2 GPIO_ACTIVE_LOW>; + wp-gpios = <&gpio2 3 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +&usdhc3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc3>; + bus-width = <8>; + cd-gpios = <&gpio2 0 GPIO_ACTIVE_LOW>; + wp-gpios = <&gpio2 1 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +&usdhc4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc4>; + bus-width = <8>; + non-removable; + no-1-8-v; + status = "okay"; +}; + +&wdog1 { + status = "disabled"; +}; + +&wdog2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; + status = "okay"; +}; diff --git a/arch/arm/dts/imx6qdl.dtsi b/arch/arm/dts/imx6qdl.dtsi index b13b0b2..a9723b9 100644 --- a/arch/arm/dts/imx6qdl.dtsi +++ b/arch/arm/dts/imx6qdl.dtsi @@ -13,9 +13,18 @@ #include <dt-bindings/clock/imx6qdl-clock.h> #include <dt-bindings/interrupt-controller/arm-gic.h>
-#include "skeleton.dtsi" - / { + #address-cells = <1>; + #size-cells = <1>; + /* + * The decompressor and also some bootloaders rely on a + * pre-existing /chosen node to be available to insert the + * command line and merge other ATAGS info. + * Also for U-Boot there must be a pre-existing /memory node. + */ + chosen {}; + memory { device_type = "memory"; reg = <0 0>; }; + aliases { ethernet0 = &fec; can0 = &can1; @@ -147,7 +156,7 @@ <&clks IMX6QDL_CLK_GPU3D_CORE>, <&clks IMX6QDL_CLK_GPU3D_SHADER>; clock-names = "bus", "core", "shader"; - power-domains = <&gpc 1>; + power-domains = <&pd_pu>; };
gpu_2d: gpu@00134000 { @@ -157,7 +166,7 @@ clocks = <&clks IMX6QDL_CLK_GPU2D_AXI>, <&clks IMX6QDL_CLK_GPU2D_CORE>; clock-names = "bus", "core"; - power-domains = <&gpc 1>; + power-domains = <&pd_pu>; };
timer@00a00600 { @@ -188,7 +197,7 @@ arm,shared-override; };
- pcie: pcie@0x01000000 { + pcie: pcie@1ffc000 { compatible = "fsl,imx6q-pcie", "snps,dw-pcie"; reg = <0x01ffc000 0x04000>, <0x01f00000 0x80000>; @@ -196,6 +205,7 @@ #address-cells = <3>; #size-cells = <2>; device_type = "pci"; + bus-range = <0x00 0xff>; ranges = <0x81000000 0 0 0x01f80000 0 0x00010000 /* downstream I/O */ 0x82000000 0 0x01000000 0x01000000 0 0x00f00000>; /* non-prefetchable memory */ num-lanes = <1>; @@ -204,9 +214,9 @@ #interrupt-cells = <1>; interrupt-map-mask = <0 0 0 0x7>; interrupt-map = <0 0 0 1 &gpc GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, - <0 0 0 2 &gpc GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, - <0 0 0 3 &gpc GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, - <0 0 0 4 &gpc GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; + <0 0 0 2 &gpc GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, + <0 0 0 3 &gpc GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, + <0 0 0 4 &gpc GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6QDL_CLK_PCIE_AXI>, <&clks IMX6QDL_CLK_LVDS1_GATE>, <&clks IMX6QDL_CLK_PCIE_REF_125M>; @@ -424,7 +434,7 @@ clocks = <&clks IMX6QDL_CLK_VPU_AXI>, <&clks IMX6QDL_CLK_MMDC_CH0_AXI>; clock-names = "per", "ahb"; - power-domains = <&gpc 1>; + power-domains = <&pd_pu>; resets = <&src 1>; iram = <&ocram>; }; @@ -625,8 +635,8 @@ regulator-1p1 { compatible = "fsl,anatop-regulator"; regulator-name = "vdd1p1"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1375000>; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1200000>; regulator-always-on; anatop-reg-offset = <0x110>; anatop-vol-bit-shift = <8>; @@ -634,6 +644,7 @@ anatop-min-bit-val = <4>; anatop-min-voltage = <800000>; anatop-max-voltage = <1375000>; + anatop-enable-bit = <0>; };
regulator-3p0 { @@ -648,20 +659,22 @@ anatop-min-bit-val = <0>; anatop-min-voltage = <2625000>; anatop-max-voltage = <3400000>; + anatop-enable-bit = <0>; };
regulator-2p5 { compatible = "fsl,anatop-regulator"; regulator-name = "vdd2p5"; - regulator-min-microvolt = <2000000>; + regulator-min-microvolt = <2250000>; regulator-max-microvolt = <2750000>; regulator-always-on; anatop-reg-offset = <0x130>; anatop-vol-bit-shift = <8>; anatop-vol-bit-width = <5>; anatop-min-bit-val = <0>; - anatop-min-voltage = <2000000>; - anatop-max-voltage = <2750000>; + anatop-min-voltage = <2100000>; + anatop-max-voltage = <2875000>; + anatop-enable-bit = <0>; };
reg_arm: regulator-vddcore { @@ -787,19 +800,39 @@ interrupts = <0 89 IRQ_TYPE_LEVEL_HIGH>, <0 90 IRQ_TYPE_LEVEL_HIGH>; interrupt-parent = <&intc>; - pu-supply = <®_pu>; - clocks = <&clks IMX6QDL_CLK_GPU3D_CORE>, - <&clks IMX6QDL_CLK_GPU3D_SHADER>, - <&clks IMX6QDL_CLK_GPU2D_CORE>, - <&clks IMX6QDL_CLK_GPU2D_AXI>, - <&clks IMX6QDL_CLK_OPENVG_AXI>, - <&clks IMX6QDL_CLK_VPU_AXI>; - #power-domain-cells = <1>; + clocks = <&clks IMX6QDL_CLK_IPG>; + clock-names = "ipg"; + + pgc { + #address-cells = <1>; + #size-cells = <0>; + + power-domain@0 { + reg = <0>; + #power-domain-cells = <0>; + }; + pd_pu: power-domain@1 { + reg = <1>; + #power-domain-cells = <0>; + power-supply = <®_pu>; + clocks = <&clks IMX6QDL_CLK_GPU3D_CORE>, + <&clks IMX6QDL_CLK_GPU3D_SHADER>, + <&clks IMX6QDL_CLK_GPU2D_CORE>, + <&clks IMX6QDL_CLK_GPU2D_AXI>, + <&clks IMX6QDL_CLK_OPENVG_AXI>, + <&clks IMX6QDL_CLK_VPU_AXI>; + }; + }; };
gpr: iomuxc-gpr@020e0000 { - compatible = "fsl,imx6q-iomuxc-gpr", "syscon"; + compatible = "fsl,imx6q-iomuxc-gpr", "syscon", "simple-mfd"; reg = <0x020e0000 0x38>; + + mux: mux-controller { + compatible = "mmio-mux"; + #mux-control-cells = <1>; + }; };
iomuxc: iomuxc@020e0000 { @@ -807,7 +840,7 @@ reg = <0x020e0000 0x4000>; };
- ldb: ldb@020e0008 { + ldb: ldb { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6q-ldb", "fsl,imx53-ldb"; @@ -1092,10 +1125,14 @@ };
weim: weim@021b8000 { + #address-cells = <2>; + #size-cells = <1>; compatible = "fsl,imx6q-weim"; reg = <0x021b8000 0x4000>; interrupts = <0 14 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6QDL_CLK_EIM_SLOW>; + fsl,weim-cs-gpr = <&gpr>; + status = "disabled"; };
ocotp: ocotp@021bc000 { @@ -1121,7 +1158,16 @@ };
mipi_csi: mipi@021dc000 { + compatible = "fsl,imx6-mipi-csi2"; reg = <0x021dc000 0x4000>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 100 0x04>, <0 101 0x04>; + clocks = <&clks IMX6QDL_CLK_HSI_TX>, + <&clks IMX6QDL_CLK_VIDEO_27M>, + <&clks IMX6QDL_CLK_EIM_PODF>; + clock-names = "dphy", "ref", "pix"; + status = "disabled"; };
mipi_dsi: mipi@021e0000 { @@ -1153,8 +1199,10 @@ };
vdoa@021e4000 { + compatible = "fsl,imx6q-vdoa"; reg = <0x021e4000 0x4000>; interrupts = <0 18 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6QDL_CLK_VDOA>; };
uart2: serial@021e8000 { @@ -1221,6 +1269,10 @@
ipu1_csi0: port@0 { reg = <0>; + + ipu1_csi0_from_ipu1_csi0_mux: endpoint { + remote-endpoint = <&ipu1_csi0_mux_to_ipu1_csi0>; + }; };
ipu1_csi1: port@1 { diff --git a/arch/arm/dts/imx6qp-sabresd.dts b/arch/arm/dts/imx6qp-sabresd.dts new file mode 100644 index 0000000..a8a5004 --- /dev/null +++ b/arch/arm/dts/imx6qp-sabresd.dts @@ -0,0 +1,93 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; + +#include "imx6qp.dtsi" +#include "imx6qdl-sabresd.dtsi" + +/ { + model = "Freescale i.MX6 Quad Plus SABRE Smart Device Board"; + compatible = "fsl,imx6qp-sabresd", "fsl,imx6qp"; +}; + +®_arm { + vin-supply = <&sw2_reg>; +}; + +&iomuxc { + imx6qdl-sabresd { + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX6QDL_PAD_SD2_CMD__SD2_CMD 0x17059 + MX6QDL_PAD_SD2_CLK__SD2_CLK 0x10071 + MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x17059 + MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x17059 + MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x17059 + MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x17059 + MX6QDL_PAD_NANDF_D4__SD2_DATA4 0x17059 + MX6QDL_PAD_NANDF_D5__SD2_DATA5 0x17059 + MX6QDL_PAD_NANDF_D6__SD2_DATA6 0x17059 + MX6QDL_PAD_NANDF_D7__SD2_DATA7 0x17059 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX6QDL_PAD_SD3_CMD__SD3_CMD 0x17059 + MX6QDL_PAD_SD3_CLK__SD3_CLK 0x10071 + MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x17059 + MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x17059 + MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x17059 + MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x17059 + MX6QDL_PAD_SD3_DAT4__SD3_DATA4 0x17059 + MX6QDL_PAD_SD3_DAT5__SD3_DATA5 0x17059 + MX6QDL_PAD_SD3_DAT6__SD3_DATA6 0x17059 + MX6QDL_PAD_SD3_DAT7__SD3_DATA7 0x17059 + >; + }; + }; +}; + +&pcie { + status = "disabled"; +}; diff --git a/arch/arm/dts/imx6qp.dtsi b/arch/arm/dts/imx6qp.dtsi new file mode 100644 index 0000000..299d863 --- /dev/null +++ b/arch/arm/dts/imx6qp.dtsi @@ -0,0 +1,153 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#include "imx6q.dtsi" + +/ { + soc { + ocram2: sram@00940000 { + compatible = "mmio-sram"; + reg = <0x00940000 0x20000>; + clocks = <&clks IMX6QDL_CLK_OCRAM>; + }; + + ocram3: sram@00960000 { + compatible = "mmio-sram"; + reg = <0x00960000 0x20000>; + clocks = <&clks IMX6QDL_CLK_OCRAM>; + }; + + aips-bus@02100000 { + pre1: pre@21c8000 { + compatible = "fsl,imx6qp-pre"; + reg = <0x021c8000 0x1000>; + interrupts = <GIC_SPI 90 IRQ_TYPE_EDGE_RISING>; + clocks = <&clks IMX6QDL_CLK_PRE0>; + clock-names = "axi"; + fsl,iram = <&ocram2>; + }; + + pre2: pre@21c9000 { + compatible = "fsl,imx6qp-pre"; + reg = <0x021c9000 0x1000>; + interrupts = <GIC_SPI 97 IRQ_TYPE_EDGE_RISING>; + clocks = <&clks IMX6QDL_CLK_PRE1>; + clock-names = "axi"; + fsl,iram = <&ocram2>; + }; + + pre3: pre@21ca000 { + compatible = "fsl,imx6qp-pre"; + reg = <0x021ca000 0x1000>; + interrupts = <GIC_SPI 98 IRQ_TYPE_EDGE_RISING>; + clocks = <&clks IMX6QDL_CLK_PRE2>; + clock-names = "axi"; + fsl,iram = <&ocram3>; + }; + + pre4: pre@21cb000 { + compatible = "fsl,imx6qp-pre"; + reg = <0x021cb000 0x1000>; + interrupts = <GIC_SPI 99 IRQ_TYPE_EDGE_RISING>; + clocks = <&clks IMX6QDL_CLK_PRE3>; + clock-names = "axi"; + fsl,iram = <&ocram3>; + }; + + prg1: prg@21cc000 { + compatible = "fsl,imx6qp-prg"; + reg = <0x021cc000 0x1000>; + clocks = <&clks IMX6QDL_CLK_PRG0_APB>, + <&clks IMX6QDL_CLK_PRG0_AXI>; + clock-names = "ipg", "axi"; + fsl,pres = <&pre1>, <&pre2>, <&pre3>; + }; + + prg2: prg@21cd000 { + compatible = "fsl,imx6qp-prg"; + reg = <0x021cd000 0x1000>; + clocks = <&clks IMX6QDL_CLK_PRG1_APB>, + <&clks IMX6QDL_CLK_PRG1_AXI>; + clock-names = "ipg", "axi"; + fsl,pres = <&pre4>, <&pre2>, <&pre3>; + }; + }; + }; +}; + +&fec { + /delete-property/interrupts-extended; + interrupts = <0 118 IRQ_TYPE_LEVEL_HIGH>, + <0 119 IRQ_TYPE_LEVEL_HIGH>; +}; + +&gpc { + compatible = "fsl,imx6qp-gpc", "fsl,imx6q-gpc"; +}; + +&ipu1 { + compatible = "fsl,imx6qp-ipu", "fsl,imx6q-ipu"; + fsl,prg = <&prg1>; +}; + +&ipu2 { + compatible = "fsl,imx6qp-ipu", "fsl,imx6q-ipu"; + fsl,prg = <&prg2>; +}; + +&ldb { + clocks = <&clks IMX6QDL_CLK_LDB_DI0_SEL>, <&clks IMX6QDL_CLK_LDB_DI1_SEL>, + <&clks IMX6QDL_CLK_IPU1_DI0_SEL>, <&clks IMX6QDL_CLK_IPU1_DI1_SEL>, + <&clks IMX6QDL_CLK_IPU2_DI0_SEL>, <&clks IMX6QDL_CLK_IPU2_DI1_SEL>, + <&clks IMX6QDL_CLK_LDB_DI0_PODF>, <&clks IMX6QDL_CLK_LDB_DI1_PODF>; + clock-names = "di0_pll", "di1_pll", + "di0_sel", "di1_sel", "di2_sel", "di3_sel", + "di0", "di1"; +}; + +&mmdc0 { + compatible = "fsl,imx6qp-mmdc", "fsl,imx6q-mmdc"; +}; + +&pcie { + compatible = "fsl,imx6qp-pcie", "snps,dw-pcie"; +};
Allow the dm driver be omited by SPL.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Simon Glass sjg@chromium.org Cc: Keerthy j-keerthy@ti.com Cc: Minkyu Kang mk7.kang@samsung.com Cc: Stefan Agner stefan.agner@toradex.com Cc: Hou Zhiqiang Zhiqiang.Hou@nxp.com Cc: Jacob Chen jacob-chen@iotwrt.com Cc: Kever Yang kever.yang@rock-chips.com Cc: Stefano Babic sbabic@denx.de --- drivers/power/pmic/Makefile | 4 ++-- drivers/power/regulator/Makefile | 2 +- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index f7bdfa5..4abdaf6 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -5,10 +5,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_DM_PMIC) += pmic-uclass.o +obj-$(CONFIG_$(SPL_)DM_PMIC) += pmic-uclass.o obj-$(CONFIG_DM_PMIC_MAX77686) += max77686.o obj-$(CONFIG_DM_PMIC_MAX8998) += max8998.o -obj-$(CONFIG_DM_PMIC_PFUZE100) += pfuze100.o +obj-$(CONFIG_$(SPL_)DM_PMIC_PFUZE100) += pfuze100.o obj-$(CONFIG_PMIC_S2MPS11) += s2mps11.o obj-$(CONFIG_DM_PMIC_SANDBOX) += sandbox.o i2c_pmic_emul.o obj-$(CONFIG_PMIC_ACT8846) += act8846.o diff --git a/drivers/power/regulator/Makefile b/drivers/power/regulator/Makefile index 18fb870..ec1b1e0 100644 --- a/drivers/power/regulator/Makefile +++ b/drivers/power/regulator/Makefile @@ -9,7 +9,7 @@ obj-$(CONFIG_$(SPL_)DM_REGULATOR) += regulator-uclass.o obj-$(CONFIG_REGULATOR_ACT8846) += act8846.o obj-$(CONFIG_REGULATOR_AS3722) += as3722_regulator.o obj-$(CONFIG_DM_REGULATOR_MAX77686) += max77686.o -obj-$(CONFIG_DM_REGULATOR_PFUZE100) += pfuze100.o +obj-$(CONFIG_$(SPL_)DM_REGULATOR_PFUZE100) += pfuze100.o obj-$(CONFIG_REGULATOR_PWM) += pwm_regulator.o obj-$(CONFIG_$(SPL_)DM_REGULATOR_FIXED) += fixed.o obj-$(CONFIG_$(SPL_)DM_REGULATOR_GPIO) += gpio-regulator.o
Build FIT image if CONFIG_SPL_FIT_GENERATOR defined.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Simon Glass sjg@chromium.org Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Bin Meng bmeng.cn@gmail.com Cc: Andre Przywara andre.przywara@arm.com Cc: "Cooper Jr., Franklin" fcooper@ti.com Cc: "Álvaro Fernández Rojas" noltari@gmail.com Cc: Stefano Babic sbabic@denx.de --- Makefile | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/Makefile b/Makefile index 50a002e..fbe7714 100644 --- a/Makefile +++ b/Makefile @@ -804,6 +804,10 @@ ALL-y += u-boot-tegra.bin u-boot-nodtb-tegra.bin ALL-$(CONFIG_OF_SEPARATE) += u-boot-dtb-tegra.bin endif
+ifneq ($(CONFIG_SPL_FIT_GENERATOR),) +ALL-y += u-boot.itb +endif + # Add optional build target if defined in board/cpu/soc headers ifneq ($(CONFIG_BUILD_TARGET),) ALL-y += $(CONFIG_BUILD_TARGET:"%"=%)
Introduce mkimage_fit.sh which is modifed from board/sunxi/mksunxi_fit_atf.sh. ATF is dropped and modified for arm32 arch.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com --- arch/arm/mach-imx/mkimage_fit.sh | 63 ++++++++++++++++++++++++++++++++++++++++ 1 file changed, 63 insertions(+) create mode 100755 arch/arm/mach-imx/mkimage_fit.sh
diff --git a/arch/arm/mach-imx/mkimage_fit.sh b/arch/arm/mach-imx/mkimage_fit.sh new file mode 100755 index 0000000..18628de --- /dev/null +++ b/arch/arm/mach-imx/mkimage_fit.sh @@ -0,0 +1,63 @@ +#!/bin/sh +# +# script to generate FIT image source for 32-bit imx boards with +# multiple device trees (given on the command line) +# +# usage: $0 <dt_name> [<dt_name> [<dt_name] ...] + +cat << __HEADER_EOF +/dts-v1/; + +/ { + description = "Configuration to load ATF before U-Boot"; + #address-cells = <1>; + + images { + uboot@1 { + description = "U-Boot (32-bit)"; + data = /incbin/("u-boot-nodtb.bin"); + type = "standalone"; + arch = "arm32"; + compression = "none"; + load = <0x17800000>; + }; +__HEADER_EOF + +cnt=1 +for dtname in $* +do + cat << __FDT_IMAGE_EOF + fdt@$cnt { + description = "$(basename $dtname .dtb)"; + data = /incbin/("$dtname"); + type = "flat_dt"; + compression = "none"; + }; +__FDT_IMAGE_EOF + cnt=$((cnt+1)) +done + +cat << __CONF_HEADER_EOF + }; + configurations { + default = "config@1"; + +__CONF_HEADER_EOF + +cnt=1 +for dtname in $* +do + cat << __CONF_SECTION_EOF + config@$cnt { + description = "$(basename $dtname .dtb)"; + firmware = "uboot@1"; + fdt = "fdt@$cnt"; + }; +__CONF_SECTION_EOF + cnt=$((cnt+1)) +done + +cat << __ITS_EOF + }; +}; +__ITS_EOF
Implement board_fit_config_name_match.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com --- board/freescale/mx6sabresd/mx6sabresd.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index e416042..ff99a30 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -734,6 +734,19 @@ int spl_start_uboot(void) } #endif
+#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + if (is_mx6dq() && !strcmp(name, "imx6q-sabresd")) + return 0; + else if (is_mx6sdl() && !strcmp(name, "imx6dl-sabresd")) + return 0; + else if (is_mx6dqp() && !strcmp(name, "imx6qp-sabresd")) + return 0; + return -EINVAL; +} +#endif + static void ccgr_init(void) { struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR;
Enable SPL FIT. Now DM drivers are not enabled, so boards boot as before with only the difference that loading dtb.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com --- configs/mx6sabresd_defconfig | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index e42e9c8..be3a18c 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -9,6 +9,10 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_VIDEO=y +CONFIG_DEFAULT_DEVICE_TREE="imx6q-sabresd" +CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit.sh" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6QDL" CONFIG_ENV_IS_IN_MMC=y CONFIG_BOOTDELAY=3 @@ -38,6 +42,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_CONTROL=y +CONFIG_OF_LIST="imx6q-sabresd imx6dl-sabresd imx6qp-sabresd" CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y @@ -51,4 +57,3 @@ CONFIG_G_DNL_MANUFACTURER="FSL" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 # CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_OF_LIBFDT=y
Disable DM MMC when SPL DM not enabled.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Simon Glass sjg@chromium.org --- scripts/Makefile.uncmd_spl | 1 + 1 file changed, 1 insertion(+)
diff --git a/scripts/Makefile.uncmd_spl b/scripts/Makefile.uncmd_spl index b399411..983686f 100644 --- a/scripts/Makefile.uncmd_spl +++ b/scripts/Makefile.uncmd_spl @@ -12,6 +12,7 @@ CONFIG_DM_GPIO= CONFIG_DM_I2C= CONFIG_DM_SPI= CONFIG_DM_SPI_FLASH= +CONFIG_DM_MMC= endif
endif
Switch to use CONFIG_IS_ENABLED.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Stefano Babic sbabic@denx.de --- drivers/mmc/fsl_esdhc.c | 14 +++++++------- 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 3abd2d3..5a1c7aa 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -107,7 +107,7 @@ struct fsl_esdhc_priv { int non_removable; int wp_enable; int vs18_enable; -#ifdef CONFIG_DM_GPIO +#if CONFIG_IS_ENABLED(DM_GPIO) struct gpio_desc cd_gpio; struct gpio_desc wp_gpio; #endif @@ -690,10 +690,10 @@ static int esdhc_getcd(struct mmc *mmc) return 1; #endif
-#ifdef CONFIG_DM_MMC +#if CONFIG_IS_ENABLED(DM_MMC) if (priv->non_removable) return 1; -#ifdef CONFIG_DM_GPIO +#if CONFIG_IS_ENABLED(DM_GPIO) if (dm_gpio_is_valid(&priv->cd_gpio)) return dm_gpio_get_value(&priv->cd_gpio); #endif @@ -825,7 +825,7 @@ static int fsl_esdhc_init(struct fsl_esdhc_priv *priv) return 0; }
-#ifndef CONFIG_DM_MMC +#if !CONFIG_IS_ENABLED(DM_MMC) static int fsl_esdhc_cfg_to_priv(struct fsl_esdhc_cfg *cfg, struct fsl_esdhc_priv *priv) { @@ -956,7 +956,7 @@ void fdt_fixup_esdhc(void *blob, bd_t *bd) } #endif
-#ifdef CONFIG_DM_MMC +#if CONFIG_IS_ENABLED(DM_MMC) #include <asm/arch/clock.h> __weak void init_clk_usdhc(u32 index) { @@ -992,7 +992,7 @@ static int fsl_esdhc_probe(struct udevice *dev) priv->non_removable = 1; } else { priv->non_removable = 0; -#ifdef CONFIG_DM_GPIO +#if CONFIG_IS_ENABLED(DM_GPIO) gpio_request_by_name_nodev(offset_to_ofnode(node), "cd-gpios", 0, &priv->cd_gpio, GPIOD_IS_IN); #endif @@ -1000,7 +1000,7 @@ static int fsl_esdhc_probe(struct udevice *dev)
priv->wp_enable = 1;
-#ifdef CONFIG_DM_GPIO +#if CONFIG_IS_ENABLED(DM_GPIO) ret = gpio_request_by_name_nodev(offset_to_ofnode(node), "wp-gpios", 0, &priv->wp_gpio, GPIOD_IS_IN); if (ret)
Include dm/ofnode.h.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Simon Glass sjg@chromium.org Cc: Stefano Babic sbabic@denx.de --- include/power/pmic.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/power/pmic.h b/include/power/pmic.h index 4b34316..f2fe537 100644 --- a/include/power/pmic.h +++ b/include/power/pmic.h @@ -11,6 +11,7 @@ #ifndef __CORE_PMIC_H_ #define __CORE_PMIC_H_
+#include <dm/ofnode.h> #include <i2c.h> #include <linux/list.h> #include <power/power_chrg.h>
Please see below.
Should be under i2c.h I think
2.6.2
Add pfuze dm code, this code does the same thing as pfuze.c, but only effects when CONFIG_$(SPL_)DM_PMIC_PFUZE100 enabled.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: York Sun york.sun@nxp.com Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Stefano Babic sbabic@denx.de --- board/freescale/common/Makefile | 1 + board/freescale/common/pfuze.h | 5 +++ board/freescale/common/pfuze_dm.c | 89 +++++++++++++++++++++++++++++++++++++++ 3 files changed, 95 insertions(+) create mode 100644 board/freescale/common/pfuze_dm.c
diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index 1c53fb6..620dced 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -61,6 +61,7 @@ obj-$(CONFIG_VSC_CROSSBAR) += vsc3316_3308.o obj-$(CONFIG_IDT8T49N222A) += idt8t49n222a_serdes_clk.o obj-$(CONFIG_ZM7300) += zm7300.o obj-$(CONFIG_POWER_PFUZE100) += pfuze.o +obj-$(CONFIG_$(SPL_)DM_PMIC_PFUZE100) += pfuze_dm.o obj-$(CONFIG_POWER_MC34VR500) += mc34vr500.o
obj-$(CONFIG_LS102XA_STREAM_ID) += ls102xa_stream_id.o diff --git a/board/freescale/common/pfuze.h b/board/freescale/common/pfuze.h index 53cfc99..9c4c92a 100644 --- a/board/freescale/common/pfuze.h +++ b/board/freescale/common/pfuze.h @@ -7,7 +7,12 @@ #ifndef __PFUZE_BOARD_HELPER__ #define __PFUZE_BOARD_HELPER__
+#if CONFIG_IS_ENABLED(DM_PMIC_PFUZE100) +struct udevice *pfuze_common_init(void); +int pfuze_mode_init(struct udevice *dev, u32 mode); +#else struct pmic *pfuze_common_init(unsigned char i2cbus); int pfuze_mode_init(struct pmic *p, u32 mode); +#endif
#endif diff --git a/board/freescale/common/pfuze_dm.c b/board/freescale/common/pfuze_dm.c new file mode 100644 index 0000000..c6af627 --- /dev/null +++ b/board/freescale/common/pfuze_dm.c @@ -0,0 +1,89 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <errno.h> +#include <power/pmic.h> +#include <power/pfuze100_pmic.h> + +int pfuze_mode_init(struct udevice *dev, u32 mode) +{ + unsigned char offset, i, switch_num; + u32 id; + int ret; + + id = pmic_reg_read(dev, PFUZE100_DEVICEID); + id = id & 0xf; + + if (id == 0) { + switch_num = 6; + offset = PFUZE100_SW1CMODE; + } else if (id == 1) { + switch_num = 4; + offset = PFUZE100_SW2MODE; + } else { + printf("Not supported, id=%d\n", id); + return -EINVAL; + } + + ret = pmic_reg_write(dev, PFUZE100_SW1ABMODE, mode); + if (ret < 0) { + printf("Set SW1AB mode error!\n"); + return ret; + } + + for (i = 0; i < switch_num - 1; i++) { + ret = pmic_reg_write(dev, offset + i * SWITCH_SIZE, mode); + if (ret < 0) { + printf("Set switch 0x%x mode error!\n", + offset + i * SWITCH_SIZE); + return ret; + } + } + + return ret; +} + +struct udevice *pfuze_common_init(void) +{ + struct udevice *dev; + int ret; + unsigned int reg, dev_id, rev_id; + + ret = pmic_get("pfuze100", &dev); + if (ret == -ENODEV) + return NULL; + + dev_id = pmic_reg_read(dev, PFUZE100_DEVICEID); + rev_id = pmic_reg_read(dev, PFUZE100_REVID); + printf("PMIC: PFUZE100! DEV_ID=0x%x REV_ID=0x%x\n", dev_id, rev_id); + + /* Set SW1AB stanby volage to 0.975V */ + reg = pmic_reg_read(dev, PFUZE100_SW1ABSTBY); + reg &= ~SW1x_STBY_MASK; + reg |= SW1x_0_975V; + pmic_reg_write(dev, PFUZE100_SW1ABSTBY, reg); + + /* Set SW1AB/VDDARM step ramp up time from 16us to 4us/25mV */ + reg = pmic_reg_read(dev, PFUZE100_SW1ABCONF); + reg &= ~SW1xCONF_DVSSPEED_MASK; + reg |= SW1xCONF_DVSSPEED_4US; + pmic_reg_write(dev, PFUZE100_SW1ABCONF, reg); + + /* Set SW1C standby voltage to 0.975V */ + reg = pmic_reg_read(dev, PFUZE100_SW1CSTBY); + reg &= ~SW1x_STBY_MASK; + reg |= SW1x_0_975V; + pmic_reg_write(dev, PFUZE100_SW1CSTBY, reg); + + /* Set SW1C/VDDSOC step ramp up time from 16us to 4us/25mV */ + reg = pmic_reg_read(dev, PFUZE100_SW1CCONF); + reg &= ~SW1xCONF_DVSSPEED_MASK; + reg |= SW1xCONF_DVSSPEED_4US; + pmic_reg_write(dev, PFUZE100_SW1CCONF, reg); + + return dev; +}
Enable DM MMC/I2C/PMIC/GPIO/REGULATOR.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de --- board/freescale/mx6sabresd/mx6sabresd.c | 326 +++++++++++++------------------- configs/mx6sabresd_defconfig | 15 ++ include/configs/mx6sabresd.h | 15 +- 3 files changed, 146 insertions(+), 210 deletions(-)
diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index ff99a30..845b5b5 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -12,7 +12,6 @@ #include <asm/arch/mx6-pins.h> #include <linux/errno.h> #include <asm/gpio.h> -#include <asm/mach-imx/mxc_i2c.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/video.h> @@ -24,7 +23,6 @@ #include <asm/arch/crm_regs.h> #include <asm/io.h> #include <asm/arch/sys_proto.h> -#include <i2c.h> #include <power/pmic.h> #include <power/pfuze100_pmic.h> #include "../common/pfuze.h" @@ -46,14 +44,6 @@ DECLARE_GLOBAL_DATA_PTR; #define SPI_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_SPEED_MED | \ PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST)
-#define I2C_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ - PAD_CTL_ODE | PAD_CTL_SRE_FAST) - -#define I2C_PMIC 1 - -#define I2C_PAD MUX_PAD_CTRL(I2C_PAD_CTRL) - #define DISP0_PWR_EN IMX_GPIO_NR(1, 21)
#define KEY_VOL_UP IMX_GPIO_NR(1, 4) @@ -93,6 +83,7 @@ static void setup_iomux_enet(void) { SETUP_IOMUX_PADS(enet_pads);
+ gpio_request(IMX_GPIO_NR(1, 25), "phy_rst"); /* Reset AR8031 PHY */ gpio_direction_output(IMX_GPIO_NR(1, 25) , 0); mdelay(10); @@ -100,47 +91,6 @@ static void setup_iomux_enet(void) udelay(100); }
-static iomux_v3_cfg_t const usdhc2_pads[] = { - IOMUX_PADS(PAD_SD2_CLK__SD2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD2_CMD__SD2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD2_DAT0__SD2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD2_DAT1__SD2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD2_DAT2__SD2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD2_DAT3__SD2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_NANDF_D4__SD2_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_NANDF_D5__SD2_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_NANDF_D6__SD2_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_NANDF_D7__SD2_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_NANDF_D2__GPIO2_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL)), /* CD */ -}; - -static iomux_v3_cfg_t const usdhc3_pads[] = { - IOMUX_PADS(PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_DAT4__SD3_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_DAT5__SD3_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_DAT6__SD3_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_DAT7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_NANDF_D0__GPIO2_IO00 | MUX_PAD_CTRL(NO_PAD_CTRL)), /* CD */ -}; - -static iomux_v3_cfg_t const usdhc4_pads[] = { - IOMUX_PADS(PAD_SD4_CLK__SD4_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD4_CMD__SD4_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD4_DAT0__SD4_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD4_DAT1__SD4_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD4_DAT2__SD4_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD4_DAT3__SD4_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD4_DAT4__SD4_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD4_DAT5__SD4_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD4_DAT6__SD4_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD4_DAT7__SD4_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), -}; - static iomux_v3_cfg_t const ecspi1_pads[] = { IOMUX_PADS(PAD_KEY_COL0__ECSPI1_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL)), IOMUX_PADS(PAD_KEY_COL1__ECSPI1_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL)), @@ -187,6 +137,7 @@ static iomux_v3_cfg_t const bl_pads[] = { static void enable_backlight(void) { SETUP_IOMUX_PADS(bl_pads); + gpio_request(DISP0_PWR_EN, "disp0_pwr_en"); gpio_direction_output(DISP0_PWR_EN, 1); }
@@ -201,32 +152,6 @@ static void enable_lvds(struct display_info_t const *dev) enable_backlight(); }
-static struct i2c_pads_info mx6q_i2c_pad_info1 = { - .scl = { - .i2c_mode = MX6Q_PAD_KEY_COL3__I2C2_SCL | I2C_PAD, - .gpio_mode = MX6Q_PAD_KEY_COL3__GPIO4_IO12 | I2C_PAD, - .gp = IMX_GPIO_NR(4, 12) - }, - .sda = { - .i2c_mode = MX6Q_PAD_KEY_ROW3__I2C2_SDA | I2C_PAD, - .gpio_mode = MX6Q_PAD_KEY_ROW3__GPIO4_IO13 | I2C_PAD, - .gp = IMX_GPIO_NR(4, 13) - } -}; - -static struct i2c_pads_info mx6dl_i2c_pad_info1 = { - .scl = { - .i2c_mode = MX6DL_PAD_KEY_COL3__I2C2_SCL | I2C_PAD, - .gpio_mode = MX6DL_PAD_KEY_COL3__GPIO4_IO12 | I2C_PAD, - .gp = IMX_GPIO_NR(4, 12) - }, - .sda = { - .i2c_mode = MX6DL_PAD_KEY_ROW3__I2C2_SDA | I2C_PAD, - .gpio_mode = MX6DL_PAD_KEY_ROW3__GPIO4_IO13 | I2C_PAD, - .gp = IMX_GPIO_NR(4, 13) - } -}; - static void setup_spi(void) { SETUP_IOMUX_PADS(ecspi1_pads); @@ -253,121 +178,11 @@ static void setup_iomux_uart(void) SETUP_IOMUX_PADS(uart1_pads); }
-#ifdef CONFIG_FSL_ESDHC -struct fsl_esdhc_cfg usdhc_cfg[3] = { - {USDHC2_BASE_ADDR}, - {USDHC3_BASE_ADDR}, - {USDHC4_BASE_ADDR}, -}; - -#define USDHC2_CD_GPIO IMX_GPIO_NR(2, 2) -#define USDHC3_CD_GPIO IMX_GPIO_NR(2, 0) - int board_mmc_get_env_dev(int devno) { return devno - 1; }
-int board_mmc_getcd(struct mmc *mmc) -{ - struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; - int ret = 0; - - switch (cfg->esdhc_base) { - case USDHC2_BASE_ADDR: - ret = !gpio_get_value(USDHC2_CD_GPIO); - break; - case USDHC3_BASE_ADDR: - ret = !gpio_get_value(USDHC3_CD_GPIO); - break; - case USDHC4_BASE_ADDR: - ret = 1; /* eMMC/uSDHC4 is always present */ - break; - } - - return ret; -} - -int board_mmc_init(bd_t *bis) -{ -#ifndef CONFIG_SPL_BUILD - int ret; - int i; - - /* - * According to the board_mmc_init() the following map is done: - * (U-Boot device node) (Physical Port) - * mmc0 SD2 - * mmc1 SD3 - * mmc2 eMMC - */ - for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { - switch (i) { - case 0: - SETUP_IOMUX_PADS(usdhc2_pads); - gpio_direction_input(USDHC2_CD_GPIO); - usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); - break; - case 1: - SETUP_IOMUX_PADS(usdhc3_pads); - gpio_direction_input(USDHC3_CD_GPIO); - usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); - break; - case 2: - SETUP_IOMUX_PADS(usdhc4_pads); - usdhc_cfg[2].sdhc_clk = mxc_get_clock(MXC_ESDHC4_CLK); - break; - default: - printf("Warning: you configured more USDHC controllers" - "(%d) then supported by the board (%d)\n", - i + 1, CONFIG_SYS_FSL_USDHC_NUM); - return -EINVAL; - } - - ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); - if (ret) - return ret; - } - - return 0; -#else - struct src *psrc = (struct src *)SRC_BASE_ADDR; - unsigned reg = readl(&psrc->sbmr1) >> 11; - /* - * Upon reading BOOT_CFG register the following map is done: - * Bit 11 and 12 of BOOT_CFG register can determine the current - * mmc port - * 0x1 SD1 - * 0x2 SD2 - * 0x3 SD4 - */ - - switch (reg & 0x3) { - case 0x1: - SETUP_IOMUX_PADS(usdhc2_pads); - usdhc_cfg[0].esdhc_base = USDHC2_BASE_ADDR; - usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); - gd->arch.sdhc_clk = usdhc_cfg[0].sdhc_clk; - break; - case 0x2: - SETUP_IOMUX_PADS(usdhc3_pads); - usdhc_cfg[0].esdhc_base = USDHC3_BASE_ADDR; - usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); - gd->arch.sdhc_clk = usdhc_cfg[0].sdhc_clk; - break; - case 0x3: - SETUP_IOMUX_PADS(usdhc4_pads); - usdhc_cfg[0].esdhc_base = USDHC4_BASE_ADDR; - usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC4_CLK); - gd->arch.sdhc_clk = usdhc_cfg[0].sdhc_clk; - break; - } - - return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); -#endif -} -#endif - static int ar8031_phy_fixup(struct phy_device *phydev) { unsigned short val; @@ -580,6 +395,8 @@ static void setup_usb(void) imx_iomux_set_gpr_register(1, 13, 1, 0);
SETUP_IOMUX_PADS(usb_hc1_pads); + + gpio_request(IMX_GPIO_NR(1, 29), "usb1"); }
int board_ehci_hcd_init(int port) @@ -632,13 +449,13 @@ int board_init(void) /* address of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
+ gpio_request(IMX_GPIO_NR(3, 19), "pcie_power"); + gpio_request(IMX_GPIO_NR(7, 12), "pcie_reset"); + #ifdef CONFIG_MXC_SPI setup_spi(); #endif - if (is_mx6dq() || is_mx6dqp()) - setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6q_i2c_pad_info1); - else - setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6dl_i2c_pad_info1); + #ifdef CONFIG_USB_EHCI_MX6 setup_usb(); #endif @@ -646,34 +463,36 @@ int board_init(void) return 0; }
+#ifndef CONFIG_SPL_BUILD int power_init_board(void) { - struct pmic *p; + struct udevice *dev; unsigned int reg; int ret;
- p = pfuze_common_init(I2C_PMIC); - if (!p) + dev = pfuze_common_init(); + if (!dev) return -ENODEV;
- ret = pfuze_mode_init(p, APS_PFM); + ret = pfuze_mode_init(dev, APS_PFM); if (ret < 0) return ret;
/* Increase VGEN3 from 2.5 to 2.8V */ - pmic_reg_read(p, PFUZE100_VGEN3VOL, ®); + reg = pmic_reg_read(dev, PFUZE100_VGEN3VOL); reg &= ~LDO_VOL_MASK; reg |= LDOB_2_80V; - pmic_reg_write(p, PFUZE100_VGEN3VOL, reg); + pmic_reg_write(dev, PFUZE100_VGEN3VOL, reg);
/* Increase VGEN5 from 2.8 to 3V */ - pmic_reg_read(p, PFUZE100_VGEN5VOL, ®); + reg = pmic_reg_read(dev, PFUZE100_VGEN5VOL); reg &= ~LDO_VOL_MASK; reg |= LDOB_3_00V; - pmic_reg_write(p, PFUZE100_VGEN5VOL, reg); + pmic_reg_write(dev, PFUZE100_VGEN5VOL, reg);
return 0; } +#endif
#ifdef CONFIG_MXC_SPI int board_spi_cs_gpio(unsigned bus, unsigned cs) @@ -747,6 +566,115 @@ int board_fit_config_name_match(const char *name) } #endif
+#ifdef CONFIG_FSL_ESDHC +static iomux_v3_cfg_t const usdhc2_pads[] = { + IOMUX_PADS(PAD_SD2_CLK__SD2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD2_CMD__SD2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD2_DAT0__SD2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD2_DAT1__SD2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD2_DAT2__SD2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD2_DAT3__SD2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_D4__SD2_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_D5__SD2_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_D6__SD2_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_D7__SD2_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_D2__GPIO2_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL)), /* CD */ +}; + +static iomux_v3_cfg_t const usdhc3_pads[] = { + IOMUX_PADS(PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT4__SD3_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT5__SD3_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT6__SD3_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_D0__GPIO2_IO00 | MUX_PAD_CTRL(NO_PAD_CTRL)), /* CD */ +}; + +static iomux_v3_cfg_t const usdhc4_pads[] = { + IOMUX_PADS(PAD_SD4_CLK__SD4_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD4_CMD__SD4_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD4_DAT0__SD4_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD4_DAT1__SD4_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD4_DAT2__SD4_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD4_DAT3__SD4_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD4_DAT4__SD4_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD4_DAT5__SD4_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD4_DAT6__SD4_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD4_DAT7__SD4_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), +}; + +struct fsl_esdhc_cfg usdhc_cfg[3] = { + {USDHC2_BASE_ADDR}, + {USDHC3_BASE_ADDR}, + {USDHC4_BASE_ADDR}, +}; + +#define USDHC2_CD_GPIO IMX_GPIO_NR(2, 2) +#define USDHC3_CD_GPIO IMX_GPIO_NR(2, 0) + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC2_BASE_ADDR: + ret = !gpio_get_value(USDHC2_CD_GPIO); + break; + case USDHC3_BASE_ADDR: + ret = !gpio_get_value(USDHC3_CD_GPIO); + break; + case USDHC4_BASE_ADDR: + ret = 1; /* eMMC/uSDHC4 is always present */ + break; + } + + return ret; +} + +int board_mmc_init(bd_t *bis) +{ + struct src *psrc = (struct src *)SRC_BASE_ADDR; + unsigned reg = readl(&psrc->sbmr1) >> 11; + /* + * Upon reading BOOT_CFG register the following map is done: + * Bit 11 and 12 of BOOT_CFG register can determine the current + * mmc port + * 0x1 SD1 + * 0x2 SD2 + * 0x3 SD4 + */ + + switch (reg & 0x3) { + case 0x1: + SETUP_IOMUX_PADS(usdhc2_pads); + usdhc_cfg[0].esdhc_base = USDHC2_BASE_ADDR; + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); + gd->arch.sdhc_clk = usdhc_cfg[0].sdhc_clk; + break; + case 0x2: + SETUP_IOMUX_PADS(usdhc3_pads); + usdhc_cfg[0].esdhc_base = USDHC3_BASE_ADDR; + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + gd->arch.sdhc_clk = usdhc_cfg[0].sdhc_clk; + break; + case 0x3: + SETUP_IOMUX_PADS(usdhc4_pads); + usdhc_cfg[0].esdhc_base = USDHC4_BASE_ADDR; + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC4_CLK); + gd->arch.sdhc_clk = usdhc_cfg[0].sdhc_clk; + break; + } + + return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); +} +#endif + static void ccgr_init(void) { struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index be3a18c..7ec158f 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -37,6 +37,8 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y @@ -44,10 +46,23 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_OF_LIST="imx6q-sabresd imx6dl-sabresd imx6qp-sabresd" +# CONFIG_BLK is not set +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_DM_MMC=y +# CONFIG_DM_MMC_OPS is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PCI=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PFUZE100=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_PFUZE100=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/include/configs/mx6sabresd.h b/include/configs/mx6sabresd.h index 27e7672..95e1666 100644 --- a/include/configs/mx6sabresd.h +++ b/include/configs/mx6sabresd.h @@ -46,20 +46,9 @@ #define CONFIG_PCIE_IMX_POWER_GPIO IMX_GPIO_NR(3, 19) #endif
-/* I2C Configs */ -#define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC -#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ -#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ -#define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_I2C_SPEED 100000
-/* PMIC */ -#define CONFIG_POWER -#define CONFIG_POWER_I2C -#define CONFIG_POWER_PFUZE100 -#define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08 - /* USB Configs */ #ifdef CONFIG_CMD_USB #define CONFIG_EHCI_HCD_INIT_AFTER_RESET @@ -70,4 +59,8 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 /* Enabled USB controller number */ #endif
+#ifdef CONFIG_SPL_BUILD +#undef CONFIG_SYS_I2C_MXC +#endif + #endif /* __MX6SABRESD_CONFIG_H */
Update README since we use FIT now.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de --- board/freescale/mx6sabresd/README | 18 +++++++++--------- 1 file changed, 9 insertions(+), 9 deletions(-)
diff --git a/board/freescale/mx6sabresd/README b/board/freescale/mx6sabresd/README index 4b4df06..8b10fe7 100644 --- a/board/freescale/mx6sabresd/README +++ b/board/freescale/mx6sabresd/README @@ -21,15 +21,15 @@ $ make mx6sabresd_defconfig
$ make
-This will generate the SPL and u-boot.img binaries. +This will generate the SPL and u-boot.itb binaries.
- Flash the SPL binary into the SD card:
$ sudo dd if=SPL of=/dev/sdX bs=1K seek=1 && sync
-- Flash the u-boot.img binary into the SD card: +- Flash the u-boot.itb binary into the SD card:
-$ sudo dd if=u-boot.img of=/dev/sdX bs=1K seek=69 && sync +$ sudo dd if=u-boot.itb of=/dev/sdX bs=1K seek=69 && sync
2. Booting from eMMC @@ -39,7 +39,7 @@ $ make mx6sabresd_defconfig
$ make
- Boot first from SD card as shown in the previous section
@@ -51,10 +51,10 @@ Mount the eMMC in the host PC:
=> ums 0 mmc 2
-- Flash SPL and u-boot.img binaries into the eMMC: +- Flash SPL and u-boot.itb binaries into the eMMC:
$ sudo dd if=SPL of=/dev/sdX bs=1K seek=1 && sync -$ sudo dd if=u-boot.img of=/dev/sdX bs=1K seek=69 && sync +$ sudo dd if=u-boot.itb of=/dev/sdX bs=1K seek=69 && sync
Set SW6 to eMMC 8-bit boot: 11010110
@@ -65,15 +65,15 @@ Set SW6 to eMMC 8-bit boot: 11010110 $ make mx6sabresd_defconfig $ make
-This will generate the SPL image called SPL and the u-boot.img. +This will generate the SPL image called SPL and the u-boot.itb.
- Flash the SPL image into the SD card:
$ sudo dd if=SPL of=/dev/sdX bs=1K seek=1 oflag=sync status=none && sync
-- Flash the u-boot.img image into the SD card: +- Flash the u-boot.itb image into the SD card:
-$ sudo dd if=u-boot.img of=/dev/sdX bs=1K seek=69 oflag=sync status=none && sync +$ sudo dd if=u-boot.itb of=/dev/sdX bs=1K seek=69 oflag=sync status=none && sync
Create a partition for root file system and extract it there:
Peng Fan
