[U-Boot] [PATCH] driver: net: fsl-mc: Update MC memory allocation code
Firmware of Management Complex (MC) should be loaded at 512MB aligned privately allocated memory at DRAM end. And this memory should be reduced from total memory available for general purposes.
Update memory allocation code in MC driver to support above requirements.
Signed-off-by: Priyanka Jain priyanka.jain@nxp.com --- drivers/net/fsl-mc/mc.c | 98 +++++++++++++++++++++------------------------- 1 files changed, 45 insertions(+), 53 deletions(-)
diff --git a/drivers/net/fsl-mc/mc.c b/drivers/net/fsl-mc/mc.c index 46b8a6b..df3f7fa 100644 --- a/drivers/net/fsl-mc/mc.c +++ b/drivers/net/fsl-mc/mc.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2014 Freescale Semiconductor + * Copyright (C) 2014, 2016 Freescale Semiconductor * * SPDX-License-Identifier: GPL-2.0+ */ @@ -41,6 +41,7 @@ struct fsl_dpbp_obj *dflt_dpbp = NULL; struct fsl_dpio_obj *dflt_dpio = NULL; struct fsl_dpni_obj *dflt_dpni = NULL; static u64 mc_lazy_dpl_addr; +static u64 mc_ram_addr;
#ifdef DEBUG void dump_ram_words(const char *title, void *addr) @@ -89,11 +90,11 @@ void dump_mc_ccsr_regs(struct mc_ccsr_registers __iomem *mc_ccsr_regs) * Copying MC firmware or DPL image to DDR */ static int mc_copy_image(const char *title, - u64 image_addr, u32 image_size, u64 mc_ram_addr) + u64 image_addr, u32 image_size, u64 mc_addr) { - debug("%s copied to address %p\n", title, (void *)mc_ram_addr); - memcpy((void *)mc_ram_addr, (void *)image_addr, image_size); - flush_dcache_range(mc_ram_addr, mc_ram_addr + image_size); + debug("%s copied to address %p\n", title, (void *)mc_addr); + memcpy((void *)mc_addr, (void *)image_addr, image_size); + flush_dcache_range(mc_addr, mc_addr + image_size); return 0; }
@@ -156,16 +157,14 @@ int parse_mc_firmware_fit_image(u64 mc_fw_addr, /* * Calculates the values to be used to specify the address range * for the MC private DRAM block, in the MCFBALR/MCFBAHR registers. - * It returns the highest 512MB-aligned address within the given - * address range, in '*aligned_base_addr', and the number of 256 MiB - * blocks in it, in 'num_256mb_blocks'. + * It stores the highest 512MB-aligned address within the given + * address range, in 'mc_ram_addr', and returns the number of 256 MB + * blocks in 'num_256mb_blocks'. */ -static int calculate_mc_private_ram_params(u64 mc_private_ram_start_addr, - size_t mc_ram_size, - u64 *aligned_base_addr, +static int calculate_mc_private_ram_params(size_t mc_ram_size, u8 *num_256mb_blocks) { - u64 addr; + u64 mc_ram_end_addr; u16 num_blocks;
if (mc_ram_size % MC_RAM_SIZE_ALIGNMENT != 0) { @@ -180,18 +179,39 @@ static int calculate_mc_private_ram_params(u64 mc_private_ram_start_addr, mc_ram_size); return -EINVAL; } + *num_256mb_blocks = num_blocks;
- addr = (mc_private_ram_start_addr + mc_ram_size - 1) & + /* + * The MC private DRAM block will be carved at the end of DRAM + */ + if (gd->bd->bi_dram[1].start) { + mc_ram_end_addr = + gd->bd->bi_dram[1].start + gd->bd->bi_dram[1].size; + } else { + mc_ram_end_addr = + gd->bd->bi_dram[0].start + gd->bd->bi_dram[0].size; + } + + mc_ram_addr = (mc_ram_end_addr - mc_ram_size) & MC_RAM_BASE_ADDR_ALIGNMENT_MASK;
- if (addr < mc_private_ram_start_addr) { - printf("fsl-mc: ERROR: bad start address %#llx\n", - mc_private_ram_start_addr); + if (mc_ram_addr > mc_ram_end_addr) { + printf("fsl-mc: ERROR: bad end address %#llx\n", + mc_ram_end_addr); return -EFAULT; }
- *aligned_base_addr = addr; - *num_256mb_blocks = num_blocks; + /* + * Total DRAM available for general purpose will get + * reduced by the size of private DRAM allocated to MC. + */ + if (gd->bd->bi_dram[1].start) { + gd->bd->bi_dram[1].size = + mc_ram_addr - gd->bd->bi_dram[1].start; + } else { + gd->bd->bi_dram[0].size = + mc_ram_addr - gd->bd->bi_dram[0].start; + } return 0; }
@@ -225,7 +245,7 @@ static int mc_fixup_dpc(u64 dpc_addr) return 0; }
-static int load_mc_dpc(u64 mc_ram_addr, size_t mc_ram_size, u64 mc_dpc_addr) +static int load_mc_dpc(size_t mc_ram_size, u64 mc_dpc_addr) { u64 mc_dpc_offset; #ifndef CONFIG_SYS_LS_MC_DPC_IN_DDR @@ -282,7 +302,7 @@ static int load_mc_dpc(u64 mc_ram_addr, size_t mc_ram_size, u64 mc_dpc_addr) return 0; }
-static int load_mc_dpl(u64 mc_ram_addr, size_t mc_ram_size, u64 mc_dpl_addr) +static int load_mc_dpl(size_t mc_ram_size, u64 mc_dpl_addr) { u64 mc_dpl_offset; #ifndef CONFIG_SYS_LS_MC_DPL_IN_DDR @@ -365,7 +385,6 @@ __weak bool soc_has_aiop(void)
static int load_mc_aiop_img(u64 aiop_fw_addr) { - u64 mc_ram_addr = mc_get_dram_addr(); #ifndef CONFIG_SYS_LS_MC_DPC_IN_DDR void *aiop_img; #endif @@ -443,7 +462,6 @@ int mc_init(u64 mc_fw_addr, u64 mc_dpc_addr) int error = 0; int portal_id = 0; struct mc_ccsr_registers __iomem *mc_ccsr_regs = MC_CCSR_BASE_ADDR; - u64 mc_ram_addr = mc_get_dram_addr(); u32 reg_gsr; u32 reg_mcfbalr; #ifndef CONFIG_SYS_LS_MC_FW_IN_DDR @@ -451,14 +469,11 @@ int mc_init(u64 mc_fw_addr, u64 mc_dpc_addr) size_t raw_image_size = 0; #endif struct mc_version mc_ver_info; - u64 mc_ram_aligned_base_addr; u8 mc_ram_num_256mb_blocks; size_t mc_ram_size = mc_get_dram_block_size();
- error = calculate_mc_private_ram_params(mc_ram_addr, - mc_ram_size, - &mc_ram_aligned_base_addr, + error = calculate_mc_private_ram_params(mc_ram_size, &mc_ram_num_256mb_blocks); if (error != 0) goto out; @@ -493,7 +508,7 @@ int mc_init(u64 mc_fw_addr, u64 mc_dpc_addr) #endif dump_ram_words("firmware", (void *)mc_ram_addr);
- error = load_mc_dpc(mc_ram_addr, mc_ram_size, mc_dpc_addr); + error = load_mc_dpc(mc_ram_size, mc_dpc_addr); if (error != 0) goto out;
@@ -503,11 +518,11 @@ int mc_init(u64 mc_fw_addr, u64 mc_dpc_addr) /* * Tell MC what is the address range of the DRAM block assigned to it: */ - reg_mcfbalr = (u32)mc_ram_aligned_base_addr | + reg_mcfbalr = (u32)mc_ram_addr | (mc_ram_num_256mb_blocks - 1); out_le32(&mc_ccsr_regs->reg_mcfbalr, reg_mcfbalr); out_le32(&mc_ccsr_regs->reg_mcfbahr, - (u32)(mc_ram_aligned_base_addr >> 32)); + (u32)(mc_ram_addr >> 32)); out_le32(&mc_ccsr_regs->reg_mcfapr, FSL_BYPASS_AMQ);
/* @@ -570,13 +585,12 @@ int mc_apply_dpl(u64 mc_dpl_addr) struct mc_ccsr_registers __iomem *mc_ccsr_regs = MC_CCSR_BASE_ADDR; int error = 0; u32 reg_gsr; - u64 mc_ram_addr = mc_get_dram_addr(); size_t mc_ram_size = mc_get_dram_block_size();
if (!mc_dpl_addr) return -1;
- error = load_mc_dpl(mc_ram_addr, mc_ram_size, mc_dpl_addr); + error = load_mc_dpl(mc_ram_size, mc_dpl_addr); if (error != 0) return error;
@@ -611,28 +625,6 @@ int get_dpl_apply_status(void) }
/** - * Return the MC address of private DRAM block. - */ -u64 mc_get_dram_addr(void) -{ - u64 mc_ram_addr; - - /* - * The MC private DRAM block was already carved at the end of DRAM - * by board_init_f() using CONFIG_SYS_MEM_TOP_HIDE: - */ - if (gd->bd->bi_dram[1].start) { - mc_ram_addr = - gd->bd->bi_dram[1].start + gd->bd->bi_dram[1].size; - } else { - mc_ram_addr = - gd->bd->bi_dram[0].start + gd->bd->bi_dram[0].size; - } - - return mc_ram_addr; -} - -/** * Return the actual size of the MC private DRAM block. */ unsigned long mc_get_dram_block_size(void)
It is already reserved at the alignment of CONFIG_SYS_MC_RSV_MEM_ALIGN, which is 512MB. What are you changing?
- Copyright (C) 2014 Freescale Semiconductor
- Copyright (C) 2014, 2016 Freescale Semiconductor
- Copying MC firmware or DPL image to DDR
- debug("%s copied to address %p\n", title, (void *)mc_addr);
- memcpy((void *)mc_addr, (void *)image_addr, image_size);
- flush_dcache_range(mc_addr, mc_addr + image_size); return 0;
- Calculates the values to be used to specify the address range
- for the MC private DRAM block, in the MCFBALR/MCFBAHR registers.
- It returns the highest 512MB-aligned address within the given
- address range, in '*aligned_base_addr', and the number of 256 MiB
- blocks in it, in 'num_256mb_blocks'.
- It stores the highest 512MB-aligned address within the given
- address range, in 'mc_ram_addr', and returns the number of 256 MB
- blocks in 'num_256mb_blocks'.
size_t mc_ram_size,
- u64 addr;
mc_ram_end_addr =
- } else {
mc_ram_end_addr =
- mc_ram_addr = (mc_ram_end_addr - mc_ram_size) & MC_RAM_BASE_ADDR_ALIGNMENT_MASK;
- if (mc_ram_addr > mc_ram_end_addr) {
return -EFAULT; }mc_ram_end_addr);
- } else {
NAK. You cannot change the global memory size within MC driver. Please explain what is not working with current memory reservation.
York
-----Original Message----- From: york sun Sent: Monday, December 19, 2016 10:43 PM To: Priyanka Jain priyanka.jain@nxp.com; u-boot@lists.denx.de Subject: Re: [PATCH] driver: net: fsl-mc: Update MC memory allocation code
*mc_ccsr_regs)
mc_fw_addr,
size_t mc_ram_size,
- u64 addr;
+179,39
mc_ram_end_addr =
- } else {
mc_ram_end_addr =
- } else {
York
With initial code, mc_ram_addr is getting value of end address of non-secure memory which is 0x83c000,0000. At further end we have 2GB secure memory, which is intended for PPA.
Based on value of mcmemsize the code is allocating memory mc_ram_addr + mcmemsize which means memory is allocated out of secure region. PPA fits in last 512M block. So, we are left with maximum 1.5GB of secure memory available for MC private allocated memory in current code.
Now we have requirement to support upto 5GB memory MC memory. So, I have redesigned the logic to allocate memory from end of non-secure memory and reduce this memory available for general purpose.
Please suggest if you think this should be implemented differently
Priyanka
*mc_ccsr_regs)
mc_fw_addr,
size_t mc_ram_size,
- u64 addr;
+179,39
mc_ram_end_addr =
- } else {
mc_ram_end_addr =
- } else {
York
MC doesn't use secure memory. It has its own reserved memory under secure memory.
First, I don't know why MC need such huge size of memory. It doesn't sound right.
Second, if you do need such huge memory, all you have to do is to return correct size from mc_get_dram_block_size().
York
Priyanka Jain
york sun
