[U-Boot] env default -f -a crash with 2012.10-rc2
"env default -f -a" crashes on ARM with last tree.
The reason is due to commit
commit b64b7c3df7906342ca8abe8ae31c0c12ced3f401 Author: Gerlando Falauto gerlando.falauto@keymile.com Date: Fri Aug 24 00:11:41 2012 +0000
env: make "env default" selective, check and apply
that calls set_env_default() with do_apply=1.
Really the crash happens in lib/hashtable.c due to changes in 152874b65b8060e7b026933ce332a9687256e28c:
commit 152874b65b8060e7b026933ce332a9687256e28c Author: Gerlando Falauto gerlando.falauto@keymile.com Date: Fri Aug 24 00:11:40 2012 +0000
env: check and apply changes on delete/destroy
Signed-off-by: Gerlando Falauto gerlando.falauto@keymile.com Reviewed-by: Marek Vasut marex@denx.de
if (do_apply && htab->apply != NULL) { /* deletion is always forced */ htab->apply(ep->key, ep->data, NULL, H_FORCE); }
When htab->apply is called in hdestroy_r, it crashes. Has anybody see the same issue ? Gerlando, what do you think about it ?
Best regards, Stefano Babic
Stefano Babic
