[U-Boot] ARM Pull Request
Hi Wolfgang,
Please pull The following changes since commit 09fee8e8677a6265e89144ccc163bf00e321769e: Wolfgang Denk (1): Coding Style cleanup; update CHANGELOG
git://git.denx.de/u-boot-arm.git master
Alessandro Rubini (3): Added nomadik.h header Nand driver for Nomadik SoC Enable Ethernet for Nomadik 8815 Evaluation Kit
Dirk Behme (5): OMAP3: Overo: Clean up pin mux and GPIO configuration OMAP3: Beagle: Add board revision detection OMAP3: Add OMAP3 auto detection OMAP3: Pandora: Update pin mux OMAP3: Clean up MMC code
Hugo Villeneuve (1): ARM DaVinci: Add common peripherals and modules enable functions.
Jean-Christophe PLAGNIOL-VILLARD (4): arm: add uart dcc support davinci: fix implicit declaration of function 'davinci_errata_workarounds' nomadik/nand: fix 'ecc512' discards qualifiers from pointer target type nmdk8815: fix onenand support
board/davinci/common/psc.c | 65 ++++++++ board/davinci/common/psc.h | 4 + board/davinci/dvevm/dvevm.c | 35 +---- board/davinci/schmoogie/schmoogie.c | 37 ++---- board/davinci/sffsdr/sffsdr.c | 31 +---- board/davinci/sonata/sonata.c | 35 +---- board/omap3/beagle/beagle.c | 41 +++++ board/omap3/beagle/beagle.h | 3 +- board/omap3/evm/evm.h | 1 - board/omap3/overo/Makefile | 1 + board/omap3/overo/overo.c | 13 -- board/omap3/overo/overo.h | 19 ++- board/omap3/pandora/pandora.h | 13 +- board/omap3/zoom1/zoom1.h | 1 - board/st/nmdk8815/nmdk8815.c | 5 +- common/devices.c | 3 + cpu/arm_cortexa8/omap3/sys_info.c | 31 ++++- drivers/mmc/omap3_mmc.c | 137 +++++++++--------- drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/nomadik.c | 221 ++++++++++++++++++++++++++++ drivers/serial/Makefile | 1 + drivers/serial/arm_dcc.c | 226 +++++++++++++++++++++++++++++ include/asm-arm/arch-omap3/cpu.h | 20 +++ include/asm-arm/arch-omap3/mmc_host_def.h | 64 +++++--- include/asm-arm/arch-omap3/omap3.h | 6 +- include/asm-arm/arch-omap3/sys_proto.h | 1 - include/configs/nmdk8815.h | 48 ++----- include/devices.h | 3 + include/nomadik.h | 39 +++++ lib_arm/board.c | 3 + 30 files changed, 842 insertions(+), 266 deletions(-) create mode 100644 drivers/mtd/nand/nomadik.c create mode 100644 drivers/serial/arm_dcc.c create mode 100644 include/nomadik.h
Best Regards, J.
Dear Jean-Christophe,
Jean-Christophe PLAGNIOL-VILLARD wrote:
Hi Wolfgang,
Any hint or idea when we will get a mach-types update?
Dirk
Dear Dirk,
It will be included with the v2009.03-rc1 release which will come into existence in ... less than one hour.
Keep your fingers crossed.
Dear Jean-Christophe PLAGNIOL-VILLARD,
In message 20090222173300.GA7417@game.jcrosoft.org you wrote:
Hi Wolfgang,
Applied, thanks.
Dirk Behme
