[U-Boot] [PATCH] arm: serial: Add debug UART capability to the pl01x driver
This patch adds an ability to use pl01x as a debug UART. It must be configured like other types of debug UARTs
Signed-off-by: Sergey Temerkhanov s.temerkhanov@gmail.com Signed-off-by: Radha Mohan Chintakuntla rchintakuntla@cavium.com ---
drivers/serial/Kconfig | 20 ++++++++++++++++++++ drivers/serial/serial_pl01x.c | 28 ++++++++++++++++++++++++++++ 2 files changed, 48 insertions(+)
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index ccb80d2..b471adc 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -77,6 +77,13 @@ config DEBUG_UART_S5P will need to provide parameters to make this work. The driver will be available until the real driver-model serial is running.
+config DEBUG_UART_PL01X + bool "pl01x" + help + Select this to enable a debug UART using the pl01x driver. You + will need to provide parameters to make this work. The driver will + be available until the real driver model serial is running. + endchoice
config DEBUG_UART_BASE @@ -109,6 +116,19 @@ config DEBUG_UART_SHIFT value. Use this value to specify the shift to use, where 0=byte registers, 2=32-bit word registers, etc.
+config DEBUG_UART_SKIP_INIT + bool "Skip UART initialition" + help + Select this if the UART you want to use for debug output is already + initialized by the time U-Boot starts its execution. + +config DEBUG_UART_PL011 + bool "PL011 UART type" + depends on DEBUG_UART_PL01X + help + Select this if the UART you want to use for debug output is of type + PL011. + config ROCKCHIP_SERIAL bool "Rockchip on-chip UART support" depends on ARCH_UNIPHIER && DM_SERIAL diff --git a/drivers/serial/serial_pl01x.c b/drivers/serial/serial_pl01x.c index e6ceaa1..5e96bf4 100644 --- a/drivers/serial/serial_pl01x.c +++ b/drivers/serial/serial_pl01x.c @@ -391,3 +391,31 @@ U_BOOT_DRIVER(serial_pl01x) = { };
#endif + +#ifdef CONFIG_DEBUG_UART_PL01X + +#include <debug_uart.h> + +void debug_uart_init(void) +{ +#ifndef CONFIG_DEBUG_UART_SKIP_INIT + struct pl01x_regs *regs = (struct pl01x_regs *)CONFIG_DEBUG_UART_BASE; + enum pl01x_type type = CONFIG_IS_ENABLED(DEBUG_UART_PL011) ? + TYPE_PL011 : TYPE_PL010; + + pl01x_generic_serial_init(regs, type); + pl01x_generic_setbrg(regs, type, + CONFIG_DEBUG_UART_CLOCK, CONFIG_BAUDRATE); +#endif +} + +static inline void _debug_uart_putc(int ch) +{ + struct pl01x_regs *regs = (struct pl01x_regs *)CONFIG_DEBUG_UART_BASE; + + pl01x_putc(regs, ch); +} + +DEBUG_UART_FUNCS + +#endif
Hi Sergey,
On 8 September 2015 at 12:14, Sergey Temerkhanov s.temerkhanov@gmail.com wrote:
bool "pl01x"
help
endchoice
spelling. Also can you please put this in a separate patch? I have another debug UART patch which might allow this to be implemented differently.
help
I think this one needs to go up in the choice section: prompt "Select which UART will provide the debug UART"
help
PL011.
#endif
+#endif +}
+DEBUG_UART_FUNCS
2.2.0
Sergey Temerkhanov
