[PATCH 1/2] ARM: dts: imx: Add labels to remaining anatop regulators
Add labels to remaining anatop regulators, so their supplies can be assigned in board DTs. This is similar to Linux kernel commit 93385546ba369 ("ARM: dts: imx6qdl-sabresd: Assign corresponding power supply for LDOs") except it does not contain the unrelated sabresd changes.
Signed-off-by: Marek Vasut marex@denx.de Cc: Christoph Niedermaier cniedermaier@dh-electronics.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/dts/imx6qdl.dtsi | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/imx6qdl.dtsi b/arch/arm/dts/imx6qdl.dtsi index 1cdb498c720..efd89510d51 100644 --- a/arch/arm/dts/imx6qdl.dtsi +++ b/arch/arm/dts/imx6qdl.dtsi @@ -686,7 +686,7 @@ <0 54 IRQ_TYPE_LEVEL_HIGH>, <0 127 IRQ_TYPE_LEVEL_HIGH>;
- regulator-1p1 { + reg_vdd1p1: regulator-1p1 { compatible = "fsl,anatop-regulator"; regulator-name = "vdd1p1"; regulator-min-microvolt = <1000000>; @@ -701,7 +701,7 @@ anatop-enable-bit = <0>; };
- regulator-3p0 { + reg_vdd3p0: regulator-3p0 { compatible = "fsl,anatop-regulator"; regulator-name = "vdd3p0"; regulator-min-microvolt = <2800000>; @@ -716,7 +716,7 @@ anatop-enable-bit = <0>; };
- regulator-2p5 { + reg_vdd2p5: regulator-2p5 { compatible = "fsl,anatop-regulator"; regulator-name = "vdd2p5"; regulator-min-microvolt = <2250000>;
Synchronize DH DHCOM DTs with Linux commit 25960cafa06e ("Linux 5.15.12"). There is no functional change to the resulting DTs. The imx6qdl-dhcom-pdk2.dtsi had to be adjusted with additional headers, gpio.h, pwm.h, input.h, else the DT cannot be compiled, the same change is likely necessary in Linux.
Signed-off-by: Marek Vasut marex@denx.de Cc: Christoph Niedermaier cniedermaier@dh-electronics.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/dts/imx6dl-dhcom-pdk2.dts | 1 + arch/arm/dts/imx6q-dhcom-pdk2.dts | 17 +- arch/arm/dts/imx6qdl-dhcom-pdk2.dtsi | 324 ++++++++--- arch/arm/dts/imx6qdl-dhcom-som.dtsi | 815 +++++++++++++++++++++++++++ 4 files changed, 1078 insertions(+), 79 deletions(-) create mode 100644 arch/arm/dts/imx6qdl-dhcom-som.dtsi
diff --git a/arch/arm/dts/imx6dl-dhcom-pdk2.dts b/arch/arm/dts/imx6dl-dhcom-pdk2.dts index a0b51bcf389..d59687490cf 100644 --- a/arch/arm/dts/imx6dl-dhcom-pdk2.dts +++ b/arch/arm/dts/imx6dl-dhcom-pdk2.dts @@ -6,6 +6,7 @@ /dts-v1/;
#include "imx6dl.dtsi" +#include "imx6qdl-dhcom-som.dtsi" #include "imx6qdl-dhcom-pdk2.dtsi"
/ { diff --git a/arch/arm/dts/imx6q-dhcom-pdk2.dts b/arch/arm/dts/imx6q-dhcom-pdk2.dts index 5bab2db656e..d4d57370615 100644 --- a/arch/arm/dts/imx6q-dhcom-pdk2.dts +++ b/arch/arm/dts/imx6q-dhcom-pdk2.dts @@ -1,20 +1,25 @@ -// SPDX-License-Identifier: (GPL-2.0+) +// SPDX-License-Identifier: GPL-2.0+ /* - * Copyright (C) 2015-2019 DH electronics GmbH + * Copyright (C) 2015-2021 DH electronics GmbH * Copyright (C) 2018 Marek Vasut marex@denx.de + * + * DHCOM iMX6 variant: + * DHCM-iMX6Q-C0800-R102-F0819-E-SD-RTC-T-HS-I-01D2 + * DHCOM PCB number: 493-300 or newer + * PDK2 PCB number: 516-400 or newer */ - /dts-v1/;
#include "imx6q.dtsi" +#include "imx6qdl-dhcom-som.dtsi" #include "imx6qdl-dhcom-pdk2.dtsi"
/ { - model = "Freescale i.MX6 Quad/Dual DHCOM Premium Developer Kit (2)"; - compatible = "dh,imx6q-dhcom-pdk2", "dh,imx6q-dhcom", "fsl,imx6q"; + model = "DH electronics i.MX6Q DHCOM on Premium Developer Kit (2)"; + compatible = "dh,imx6q-dhcom-pdk2", "dh,imx6q-dhcom-som", + "fsl,imx6q"; };
&sata { status = "okay"; }; - diff --git a/arch/arm/dts/imx6qdl-dhcom-pdk2.dtsi b/arch/arm/dts/imx6qdl-dhcom-pdk2.dtsi index d8772a98966..bf6b3a5ce07 100644 --- a/arch/arm/dts/imx6qdl-dhcom-pdk2.dtsi +++ b/arch/arm/dts/imx6qdl-dhcom-pdk2.dtsi @@ -1,50 +1,193 @@ -// SPDX-License-Identifier: (GPL-2.0+) +// SPDX-License-Identifier: GPL-2.0+ /* - * Copyright (C) 2015-2019 DH electronics GmbH + * Copyright (C) 2015-2021 DH electronics GmbH * Copyright (C) 2018 Marek Vasut marex@denx.de */
-#include "imx6qdl-dhcom.dtsi" +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/pwm/pwm.h> +#include <dt-bindings/input/input.h>
/ { chosen { - stdout-path = &uart1; + stdout-path = "serial0:115200n8"; };
clk_ext_audio_codec: clock-codec { - compatible = "fixed-clock"; #clock-cells = <0>; clock-frequency = <24000000>; + compatible = "fixed-clock"; + }; + + display_bl: display-bl { + brightness-levels = <0 16 22 30 40 55 75 102 138 188 255>; + compatible = "pwm-backlight"; + default-brightness-level = <8>; + enable-gpios = <&gpio3 27 GPIO_ACTIVE_HIGH>; /* GPIO G */ + pwms = <&pwm1 0 50000 PWM_POLARITY_INVERTED>; + status = "okay"; + }; + + lcd_display: disp0 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx-parallel-display"; + interface-pix-fmt = "rgb24"; + pinctrl-0 = <&pinctrl_ipu1_lcdif &pinctrl_dhcom_g>; + pinctrl-names = "default"; + status = "okay"; + + port@0 { + reg = <0>; + + lcd_display_in: endpoint { + remote-endpoint = <&ipu1_di0_disp0>; + }; + }; + + port@1 { + reg = <1>; + + lcd_display_out: endpoint { + remote-endpoint = <&lcd_panel_in>; + }; + }; + }; + + gpio-keys { + #size-cells = <0>; + compatible = "gpio-keys"; + + button-0 { + gpios = <&gpio1 2 GPIO_ACTIVE_LOW>; /* GPIO A */ + label = "TA1-GPIO-A"; + linux,code = <KEY_A>; + pinctrl-0 = <&pinctrl_dhcom_a>; + pinctrl-names = "default"; + wakeup-source; + }; + + button-1 { + gpios = <&gpio1 4 GPIO_ACTIVE_LOW>; /* GPIO B */ + label = "TA2-GPIO-B"; + linux,code = <KEY_B>; + pinctrl-0 = <&pinctrl_dhcom_b>; + pinctrl-names = "default"; + wakeup-source; + }; + + button-2 { + gpios = <&gpio1 5 GPIO_ACTIVE_LOW>; /* GPIO C */ + label = "TA3-GPIO-C"; + linux,code = <KEY_C>; + pinctrl-0 = <&pinctrl_dhcom_c>; + pinctrl-names = "default"; + wakeup-source; + }; + + button-3 { + gpios = <&gpio6 3 GPIO_ACTIVE_LOW>; /* GPIO D */ + label = "TA4-GPIO-D"; + linux,code = <KEY_D>; + pinctrl-0 = <&pinctrl_dhcom_d>; + pinctrl-names = "default"; + wakeup-source; + }; + }; + + led { + compatible = "gpio-leds"; + + /* + * Disable led-5, because GPIO E is + * already used as touch interrupt. + */ + led-5 { + color = <LED_COLOR_ID_GREEN>; + default-state = "off"; + function = LED_FUNCTION_INDICATOR; + gpios = <&gpio4 5 GPIO_ACTIVE_HIGH>; /* GPIO E */ + pinctrl-0 = <&pinctrl_dhcom_e>; + pinctrl-names = "default"; + status = "disabled"; + }; + + led-6 { + color = <LED_COLOR_ID_GREEN>; + default-state = "off"; + function = LED_FUNCTION_INDICATOR; + gpios = <&gpio4 20 GPIO_ACTIVE_HIGH>; /* GPIO F */ + pinctrl-0 = <&pinctrl_dhcom_f>; + pinctrl-names = "default"; + }; + + led-7 { + color = <LED_COLOR_ID_GREEN>; + default-state = "off"; + function = LED_FUNCTION_INDICATOR; + gpios = <&gpio4 7 GPIO_ACTIVE_HIGH>; /* GPIO H */ + pinctrl-0 = <&pinctrl_dhcom_h>; + pinctrl-names = "default"; + }; + + led-8 { + color = <LED_COLOR_ID_GREEN>; + default-state = "off"; + function = LED_FUNCTION_INDICATOR; + gpios = <&gpio4 8 GPIO_ACTIVE_HIGH>; /* GPIO I */ + pinctrl-0 = <&pinctrl_dhcom_i>; + pinctrl-names = "default"; + }; + }; + + panel { + backlight = <&display_bl>; + compatible = "edt,etm0700g0edh6"; + + port { + lcd_panel_in: endpoint { + remote-endpoint = <&lcd_display_out>; + }; + }; };
sound { - compatible = "fsl,imx-audio-sgtl5000"; - model = "imx-sgtl5000"; - ssi-controller = <&ssi1>; audio-codec = <&sgtl5000>; audio-routing = "MIC_IN", "Mic Jack", "Mic Jack", "Mic Bias", "LINE_IN", "Line In Jack", "Headphone Jack", "HP_OUT"; - mux-int-port = <1>; + compatible = "fsl,imx-audio-sgtl5000"; + model = "imx-sgtl5000"; mux-ext-port = <3>; + mux-int-port = <1>; + ssi-controller = <&ssi1>; }; };
&audmux { - pinctrl-names = "default"; pinctrl-0 = <&pinctrl_audmux_ext>; + pinctrl-names = "default"; + status = "okay"; +}; + +&can1 { status = "okay"; };
+&can2 { + status = "disabled"; +}; + /* 1G ethernet */ /delete-node/ ðphy0; &fec { phy-mode = "rgmii"; phy-handle = <ðphy7>; - pinctrl-names = "default"; pinctrl-0 = <&pinctrl_enet_1G>; + pinctrl-names = "default"; status = "okay";
mdio { @@ -58,20 +201,20 @@ pinctrl-0 = <&pinctrl_ethphy7>; pinctrl-names = "default"; reg = <7>; - reset-gpios = <&gpio3 29 GPIO_ACTIVE_LOW>; reset-assert-us = <1000>; reset-deassert-us = <1000>; + reset-gpios = <&gpio3 29 GPIO_ACTIVE_LOW>; rxc-skew-ps = <3000>; rxd0-skew-ps = <0>; rxd1-skew-ps = <0>; rxd2-skew-ps = <0>; rxd3-skew-ps = <0>; + rxdv-skew-ps = <0>; txc-skew-ps = <3000>; txd0-skew-ps = <0>; txd1-skew-ps = <0>; txd2-skew-ps = <0>; txd3-skew-ps = <0>; - rxdv-skew-ps = <0>; txen-skew-ps = <0>; }; }; @@ -84,103 +227,138 @@
&i2c2 { sgtl5000: codec@a { - compatible = "fsl,sgtl5000"; - reg = <0x0a>; #sound-dai-cells = <0>; clocks = <&clk_ext_audio_codec>; + compatible = "fsl,sgtl5000"; + reg = <0x0a>; VDDA-supply = <®_3p3v>; - VDDIO-supply = <®_3p3v>; + VDDIO-supply = <&sw2_reg>; + }; + + touchscreen@38 { + compatible = "edt,edt-ft5406"; + interrupt-parent = <&gpio4>; + interrupts = <5 IRQ_TYPE_EDGE_FALLING>; /* GPIO E */ + pinctrl-0 = <&pinctrl_dhcom_e>; + pinctrl-names = "default"; + reg = <0x38>; }; };
-&iomuxc { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_hog_base &pinctrl_hog>; +&ipu1_di0_disp0 { + remote-endpoint = <&lcd_display_in>; +};
- pinctrl_hog: hog-grp { - fsl,pins = < - MX6QDL_PAD_GPIO_2__GPIO1_IO02 0x400120b0 - MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x400120b0 - MX6QDL_PAD_GPIO_5__GPIO1_IO05 0x400120b0 - MX6QDL_PAD_CSI0_DAT17__GPIO6_IO03 0x400120b0 - MX6QDL_PAD_GPIO_19__GPIO4_IO05 0x120b0 - MX6QDL_PAD_DI0_PIN4__GPIO4_IO20 0x400120b0 - MX6QDL_PAD_EIM_D27__GPIO3_IO27 0x120b0 - MX6QDL_PAD_KEY_ROW0__GPIO4_IO07 0x120b0 - MX6QDL_PAD_KEY_COL1__GPIO4_IO08 0x400120b0 - MX6QDL_PAD_NANDF_CS1__GPIO6_IO14 0x400120b0 - MX6QDL_PAD_NANDF_CS2__GPIO6_IO15 0x400120b0 - MX6QDL_PAD_KEY_ROW1__GPIO4_IO09 0x400120b0 - MX6QDL_PAD_SD3_DAT5__GPIO7_IO00 0x400120b0 - MX6QDL_PAD_SD3_DAT4__GPIO7_IO01 0x400120b0 - MX6QDL_PAD_CSI0_VSYNC__GPIO5_IO21 0x400120b0 - MX6QDL_PAD_GPIO_18__GPIO7_IO13 0x400120b0 - MX6QDL_PAD_SD1_CMD__GPIO1_IO18 0x400120b0 - MX6QDL_PAD_SD1_DAT0__GPIO1_IO16 0x400120b0 - MX6QDL_PAD_SD1_DAT1__GPIO1_IO17 0x400120b0 - MX6QDL_PAD_SD1_DAT2__GPIO1_IO19 0x400120b0 - MX6QDL_PAD_SD1_CLK__GPIO1_IO20 0x400120b0 - MX6QDL_PAD_CSI0_PIXCLK__GPIO5_IO18 0x400120b0 - MX6QDL_PAD_CSI0_MCLK__GPIO5_IO19 0x400120b0 - MX6QDL_PAD_KEY_COL0__GPIO4_IO06 0x400120b0 +&pcie { + pinctrl-0 = <&pinctrl_pcie &pinctrl_dhcom_j>; + reset-gpio = <&gpio6 14 GPIO_ACTIVE_LOW>; /* GPIO J */ + status = "okay"; +}; + +&pwm1 { + status = "okay"; +}; + +&ssi1 { + status = "okay"; +}; + +&usdhc2 { /* SD card */ + status = "okay"; +}; + +&iomuxc { + pinctrl-0 = < + /* + * The following DHCOM GPIOs are used on this board. + * Therefore, they have been removed from the list below. + * A: key TA1 + * B: key TA2 + * C: key TA3 + * D: key TA4 + * E: touchscreen + * F: led6 + * G: backlight enable + * H: led7 + * I: led8 + * J: PCIe reset + */ + &pinctrl_hog_base + &pinctrl_dhcom_k &pinctrl_dhcom_l + &pinctrl_dhcom_m &pinctrl_dhcom_n &pinctrl_dhcom_o + &pinctrl_dhcom_p &pinctrl_dhcom_q &pinctrl_dhcom_r + &pinctrl_dhcom_s &pinctrl_dhcom_t &pinctrl_dhcom_u + &pinctrl_dhcom_v &pinctrl_dhcom_w &pinctrl_dhcom_int >; - }; + pinctrl-names = "default";
pinctrl_audmux_ext: audmux-ext-grp { fsl,pins = < - MX6QDL_PAD_CSI0_DAT7__AUD3_RXD 0x130b0 MX6QDL_PAD_CSI0_DAT4__AUD3_TXC 0x130b0 MX6QDL_PAD_CSI0_DAT5__AUD3_TXD 0x110b0 MX6QDL_PAD_CSI0_DAT6__AUD3_TXFS 0x130b0 + MX6QDL_PAD_CSI0_DAT7__AUD3_RXD 0x130b0 >; };
pinctrl_enet_1G: enet-1G-grp { fsl,pins = < - MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x100b0 MX6QDL_PAD_ENET_MDC__ENET_MDC 0x100b0 - MX6QDL_PAD_RGMII_TXC__RGMII_TXC 0x100b0 - MX6QDL_PAD_RGMII_TD0__RGMII_TD0 0x100b0 - MX6QDL_PAD_RGMII_TD1__RGMII_TD1 0x100b0 - MX6QDL_PAD_RGMII_TD2__RGMII_TD2 0x100b0 - MX6QDL_PAD_RGMII_TD3__RGMII_TD3 0x100b0 - MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL 0x100b0 + MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x100b0 MX6QDL_PAD_ENET_REF_CLK__ENET_TX_CLK 0x100b0 - MX6QDL_PAD_RGMII_RXC__RGMII_RXC 0x1b0b0 MX6QDL_PAD_RGMII_RD0__RGMII_RD0 0x1b0b0 MX6QDL_PAD_RGMII_RD1__RGMII_RD1 0x1b0b0 MX6QDL_PAD_RGMII_RD2__RGMII_RD2 0x1b0b0 MX6QDL_PAD_RGMII_RD3__RGMII_RD3 0x1b0b0 MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL 0x1b0b0 + MX6QDL_PAD_RGMII_RXC__RGMII_RXC 0x1b0b0 + MX6QDL_PAD_RGMII_TD0__RGMII_TD0 0x100b0 + MX6QDL_PAD_RGMII_TD1__RGMII_TD1 0x100b0 + MX6QDL_PAD_RGMII_TD2__RGMII_TD2 0x100b0 + MX6QDL_PAD_RGMII_TD3__RGMII_TD3 0x100b0 + MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL 0x100b0 + MX6QDL_PAD_RGMII_TXC__RGMII_TXC 0x100b0 >; };
pinctrl_ethphy7: ethphy7-grp { fsl,pins = < + MX6QDL_PAD_EIM_D26__GPIO3_IO26 0xb1 /* WOL */ MX6QDL_PAD_EIM_D29__GPIO3_IO29 0xb0 /* Reset */ MX6QDL_PAD_GPIO_0__GPIO1_IO00 0xb1 /* Int */ - MX6QDL_PAD_EIM_D26__GPIO3_IO26 0xb1 /* WOL */ >; };
- pinctrl_pcie: pcie-grp { + pinctrl_ipu1_lcdif: ipu1-lcdif-grp { fsl,pins = < - MX6QDL_PAD_CSI0_DATA_EN__GPIO5_IO20 0x1b0b1 + MX6QDL_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK 0x38 + MX6QDL_PAD_DI0_PIN2__IPU1_DI0_PIN02 0x38 + MX6QDL_PAD_DI0_PIN3__IPU1_DI0_PIN03 0x38 + MX6QDL_PAD_DI0_PIN15__IPU1_DI0_PIN15 0x38 + MX6QDL_PAD_DISP0_DAT0__IPU1_DISP0_DATA00 0x38 + MX6QDL_PAD_DISP0_DAT1__IPU1_DISP0_DATA01 0x38 + MX6QDL_PAD_DISP0_DAT2__IPU1_DISP0_DATA02 0x38 + MX6QDL_PAD_DISP0_DAT3__IPU1_DISP0_DATA03 0x38 + MX6QDL_PAD_DISP0_DAT4__IPU1_DISP0_DATA04 0x38 + MX6QDL_PAD_DISP0_DAT5__IPU1_DISP0_DATA05 0x38 + MX6QDL_PAD_DISP0_DAT6__IPU1_DISP0_DATA06 0x38 + MX6QDL_PAD_DISP0_DAT7__IPU1_DISP0_DATA07 0x38 + MX6QDL_PAD_DISP0_DAT8__IPU1_DISP0_DATA08 0x38 + MX6QDL_PAD_DISP0_DAT9__IPU1_DISP0_DATA09 0x38 + MX6QDL_PAD_DISP0_DAT10__IPU1_DISP0_DATA10 0x38 + MX6QDL_PAD_DISP0_DAT11__IPU1_DISP0_DATA11 0x38 + MX6QDL_PAD_DISP0_DAT12__IPU1_DISP0_DATA12 0x38 + MX6QDL_PAD_DISP0_DAT13__IPU1_DISP0_DATA13 0x38 + MX6QDL_PAD_DISP0_DAT14__IPU1_DISP0_DATA14 0x38 + MX6QDL_PAD_DISP0_DAT15__IPU1_DISP0_DATA15 0x38 + MX6QDL_PAD_DISP0_DAT16__IPU1_DISP0_DATA16 0x38 + MX6QDL_PAD_DISP0_DAT17__IPU1_DISP0_DATA17 0x38 + MX6QDL_PAD_DISP0_DAT18__IPU1_DISP0_DATA18 0x38 + MX6QDL_PAD_DISP0_DAT19__IPU1_DISP0_DATA19 0x38 + MX6QDL_PAD_DISP0_DAT20__IPU1_DISP0_DATA20 0x38 + MX6QDL_PAD_DISP0_DAT21__IPU1_DISP0_DATA21 0x38 + MX6QDL_PAD_DISP0_DAT22__IPU1_DISP0_DATA22 0x38 + MX6QDL_PAD_DISP0_DAT23__IPU1_DISP0_DATA23 0x38 >; }; }; - -&pcie { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pcie>; - reset-gpio = <&gpio6 14 GPIO_ACTIVE_LOW>; - status = "okay"; -}; - -&ssi1 { - status = "okay"; -}; - -&usdhc3 { - status = "okay"; -}; diff --git a/arch/arm/dts/imx6qdl-dhcom-som.dtsi b/arch/arm/dts/imx6qdl-dhcom-som.dtsi new file mode 100644 index 00000000000..5d10c40313c --- /dev/null +++ b/arch/arm/dts/imx6qdl-dhcom-som.dtsi @@ -0,0 +1,815 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2015-2021 DH electronics GmbH + * Copyright (C) 2018 Marek Vasut marex@denx.de + */ + +#include <dt-bindings/pwm/pwm.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/clock/imx6qdl-clock.h> +#include <dt-bindings/input/input.h> + +/ { + aliases { + i2c0 = &i2c2; + i2c1 = &i2c1; + i2c2 = &i2c3; + mmc0 = &usdhc2; + mmc1 = &usdhc3; + mmc2 = &usdhc4; + mmc3 = &usdhc1; + rtc0 = &rtc_i2c; + rtc1 = &snvs_rtc; + serial0 = &uart1; + serial1 = &uart5; + serial2 = &uart4; + serial3 = &uart2; + serial4 = &uart3; + }; + + memory@10000000 { /* Appropriate memory size will be filled by U-Boot */ + device_type = "memory"; + reg = <0x10000000 0x20000000>; + }; + + reg_3p3v: regulator-3P3V { + compatible = "regulator-fixed"; + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "3P3V"; + }; + + reg_eth_vio: regulator-eth-vio { + compatible = "regulator-fixed"; + gpio = <&gpio1 7 0>; + pinctrl-0 = <&pinctrl_enet_vio>; + pinctrl-names = "default"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "eth_vio"; + vin-supply = <&sw2_reg>; + }; + + /* OE pin of the latch is low active */ + reg_latch_oe_on: regulator-latch-oe-on { + compatible = "regulator-fixed"; + gpio = <&gpio3 22 0>; + regulator-always-on; + regulator-name = "latch_oe_on"; + }; + + reg_usb_h1_vbus: regulator-usb-h1-vbus { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio3 31 0>; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-name = "usb_h1_vbus"; + }; + + reg_usb_otg_vbus: regulator-usb-otg-vbus { + compatible = "regulator-fixed"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-name = "usb_otg_vbus"; + }; +}; + +&can1 { + pinctrl-0 = <&pinctrl_flexcan1>; + pinctrl-names = "default"; + status = "okay"; +}; + +/* + * Special SoM hardware required which uses the pins from micro SD card. The + * pins SD3_DAT0 and SD3_DAT1 are muxed as can2 Tx and Rx. The signals for can2 + * Tx and Rx are routed to the DHCOM UART1 rts/cts pins. So to enable can2 on + * the board device tree file, the micro SD card must be disabled and the uart1 + * rts/cts must be disabled or output on other DHCOM pins. + */ +&can2 { + pinctrl-0 = <&pinctrl_flexcan2>; + pinctrl-names = "default"; + status = "disabled"; +}; + +&ecspi1 { + cs-gpios = <&gpio2 30 GPIO_ACTIVE_LOW>, <&gpio4 11 GPIO_ACTIVE_LOW>; + pinctrl-0 = <&pinctrl_ecspi1>; + pinctrl-names = "default"; + status = "okay"; + + flash@0 { /* S25FL116K */ + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + m25p,fast-read; + reg = <0>; + spi-max-frequency = <50000000>; + }; +}; + +&ecspi2 { + cs-gpios = <&gpio5 29 GPIO_ACTIVE_LOW>; + pinctrl-0 = <&pinctrl_ecspi2>; + pinctrl-names = "default"; + status = "disabled"; +}; + +&fec { + phy-mode = "rmii"; + phy-handle = <ðphy0>; + pinctrl-0 = <&pinctrl_enet_100M>; + pinctrl-names = "default"; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@0 { /* SMSC LAN8710Ai */ + compatible = "ethernet-phy-ieee802.3-c22"; + interrupt-parent = <&gpio4>; + interrupts = <15 IRQ_TYPE_LEVEL_LOW>; + pinctrl-0 = <&pinctrl_ethphy0>; + pinctrl-names = "default"; + reg = <0>; + reset-assert-us = <1000>; + reset-deassert-us = <1000>; + reset-gpios = <&gpio5 0 GPIO_ACTIVE_LOW>; + smsc,disable-energy-detect; /* Make plugin detection reliable */ + }; + }; +}; + +&gpio1 { + gpio-line-names = + "", "", "DHCOM-A", "", "DHCOM-B", "DHCOM-C", "", "", + "", "", "", "", "", "", "", "", + "DHCOM-R", "DHCOM-S", "DHCOM-Q", "DHCOM-T", "DHCOM-U", "", "", "", + "", "", "", "", "", "", "", ""; +}; + +&gpio2 { + gpio-line-names = + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", + "SOM-HW2", "", "", "SOM-HW0", "", "SOM-MEM1", "SOM-MEM0", "", + "", "", "", "", "", "", "", ""; +}; + +&gpio3 { + gpio-line-names = + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", + "", "", "", "DHCOM-G", "", "", "", ""; +}; + +&gpio4 { + gpio-line-names = + "", "", "", "", "", "DHCOM-E", "DHCOM-INT", "DHCOM-H", + "DHCOM-I", "DHCOM-L", "", "", "", "", "", "", + "", "", "", "", "DHCOM-F", "", "", "", + "", "", "", "", "", "", "", ""; +}; + +&gpio5 { + gpio-line-names = + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", + "", "", "DHCOM-V", "DHCOM-W", "", "DHCOM-O", "", "", + "", "", "", "", "", "", "", ""; +}; + +&gpio6 { + gpio-line-names = + "", "", "", "DHCOM-D", "", "", "SOM-HW1", "", + "", "", "", "", "", "", "DHCOM-J", "DHCOM-K", + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", ""; +}; + +&gpio7 { + gpio-line-names = + "DHCOM-M", "DHCOM-N", "", "", "", "", "", "", + "", "", "", "", "", "DHCOM-P", "", "", + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", ""; +}; + +&i2c1 { + /* + * Info: According to erratum ERR007805 clock frequency limit is 375000. + * The erratum for i.MX6S/DL is here [1] and for i.MX6Q/D is here [2]. + * [1] https://www.nxp.com/docs/en/errata/IMX6SDLCE.pdf + * [2] https://www.nxp.com/docs/en/errata/IMX6DQCE.pdf + */ + clock-frequency = <100000>; + pinctrl-0 = <&pinctrl_i2c1>; + pinctrl-1 = <&pinctrl_i2c1_gpio>; + pinctrl-names = "default", "gpio"; + scl-gpios = <&gpio3 21 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; + sda-gpios = <&gpio3 28 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; + status = "okay"; +}; + +&i2c2 { + /* Info: Clock frequency limit is 375000 (for details see i2c1) */ + clock-frequency = <100000>; + pinctrl-0 = <&pinctrl_i2c2>; + pinctrl-1 = <&pinctrl_i2c2_gpio>; + pinctrl-names = "default", "gpio"; + scl-gpios = <&gpio4 12 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; + sda-gpios = <&gpio4 13 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; + status = "okay"; +}; + +&i2c3 { + /* Info: Clock frequency limit is 375000 (for details see i2c1) */ + clock-frequency = <100000>; + pinctrl-0 = <&pinctrl_i2c3>; + pinctrl-1 = <&pinctrl_i2c3_gpio>; + pinctrl-names = "default", "gpio"; + scl-gpios = <&gpio1 3 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; + sda-gpios = <&gpio1 6 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; + status = "okay"; + + ltc3676: pmic@3c { + compatible = "lltc,ltc3676"; + interrupt-parent = <&gpio5>; + interrupts = <2 IRQ_TYPE_EDGE_FALLING>; + pinctrl-0 = <&pinctrl_pmic>; + pinctrl-names = "default"; + reg = <0x3c>; + + regulators { + sw1_reg: sw1 { + lltc,fb-voltage-divider = <100000 110000>; + regulator-always-on; + regulator-boot-on; + regulator-max-microvolt = <1527272>; + regulator-min-microvolt = <787500>; + regulator-ramp-delay = <7000>; + regulator-suspend-mem-microvolt = <1040000>; + }; + + sw2_reg: sw2 { + lltc,fb-voltage-divider = <100000 28000>; + regulator-always-on; + regulator-boot-on; + regulator-max-microvolt = <3657142>; + regulator-min-microvolt = <1885714>; + regulator-ramp-delay = <7000>; + }; + + sw3_reg: sw3 { + lltc,fb-voltage-divider = <100000 110000>; + regulator-always-on; + regulator-boot-on; + regulator-max-microvolt = <1527272>; + regulator-min-microvolt = <787500>; + regulator-ramp-delay = <7000>; + regulator-suspend-mem-microvolt = <980000>; + }; + + sw4_reg: sw4 { + lltc,fb-voltage-divider = <100000 93100>; + regulator-always-on; + regulator-boot-on; + regulator-max-microvolt = <1659291>; + regulator-min-microvolt = <855571>; + regulator-ramp-delay = <7000>; + }; + + ldo1_reg: ldo1 { + lltc,fb-voltage-divider = <102000 29400>; + regulator-always-on; + regulator-boot-on; + regulator-max-microvolt = <3240306>; + regulator-min-microvolt = <3240306>; + }; + + ldo2_reg: ldo2 { + lltc,fb-voltage-divider = <100000 41200>; + regulator-always-on; + regulator-boot-on; + regulator-max-microvolt = <2484708>; + regulator-min-microvolt = <2484708>; + }; + }; + }; + + touchscreen@49 { /* TSC2004 */ + compatible = "ti,tsc2004"; + interrupts-extended = <&gpio4 14 IRQ_TYPE_EDGE_FALLING>; + pinctrl-0 = <&pinctrl_tsc2004>; + pinctrl-names = "default"; + reg = <0x49>; + vio-supply = <®_3p3v>; + status = "disabled"; + }; + + eeprom@50 { + compatible = "atmel,24c02"; + pagesize = <16>; + reg = <0x50>; + }; + + rtc_i2c: rtc@56 { + compatible = "microcrystal,rv3029"; + interrupt-parent = <&gpio7>; + interrupts = <12 IRQ_TYPE_EDGE_FALLING>; + pinctrl-0 = <&pinctrl_rtc>; + pinctrl-names = "default"; + reg = <0x56>; + }; +}; + +&pcie { + pinctrl-0 = <&pinctrl_pcie>; + pinctrl-names = "default"; +}; + +&pwm1 { + pinctrl-0 = <&pinctrl_pwm1>; + pinctrl-names = "default"; +}; + +®_arm { + vin-supply = <&sw3_reg>; +}; + +®_pu { + vin-supply = <&sw1_reg>; +}; + +®_soc { + vin-supply = <&sw1_reg>; +}; + +®_vdd1p1 { + vin-supply = <&sw2_reg>; +}; + +®_vdd2p5 { + vin-supply = <&sw2_reg>; +}; + +&uart1 { /* DHCOM UART1 */ + dcd-gpios = <&gpio3 23 GPIO_ACTIVE_LOW>; + dsr-gpios = <&gpio3 25 GPIO_ACTIVE_LOW>; + dtr-gpios = <&gpio3 24 GPIO_ACTIVE_LOW>; + rng-gpios = <&gpio2 31 GPIO_ACTIVE_LOW>; + pinctrl-0 = <&pinctrl_uart1>; + pinctrl-names = "default"; + uart-has-rtscts; + status = "okay"; +}; + +&uart4 { /* DHCOM UART3 */ + pinctrl-0 = <&pinctrl_uart4>; + pinctrl-names = "default"; + status = "okay"; +}; + +&uart5 { /* DHCOM UART2 */ + pinctrl-0 = <&pinctrl_uart5>; + pinctrl-names = "default"; + uart-has-rtscts; + status = "okay"; +}; + +&usbh1 { + dr_mode = "host"; + pinctrl-0 = <&pinctrl_usbh1>; + pinctrl-names = "default"; + vbus-supply = <®_usb_h1_vbus>; + status = "okay"; +}; + +&usbotg { + disable-over-current; + dr_mode = "otg"; + pinctrl-0 = <&pinctrl_usbotg>; + pinctrl-names = "default"; + vbus-supply = <®_usb_otg_vbus>; + status = "okay"; +}; + +&usdhc2 { /* External SD card via DHCOM */ + cd-gpios = <&gpio6 16 GPIO_ACTIVE_HIGH>; + keep-power-in-suspend; + pinctrl-0 = <&pinctrl_usdhc2>; + pinctrl-names = "default"; + status = "disabled"; +}; + +&usdhc3 { /* Micro SD card on module */ + cd-gpios = <&gpio7 8 GPIO_ACTIVE_LOW>; + fsl,wp-controller; + keep-power-in-suspend; + pinctrl-0 = <&pinctrl_usdhc3>; + pinctrl-names = "default"; + status = "okay"; +}; + +&usdhc4 { /* eMMC on module */ + bus-width = <8>; + keep-power-in-suspend; + no-1-8-v; + non-removable; + pinctrl-0 = <&pinctrl_usdhc4>; + pinctrl-names = "default"; + status = "okay"; +}; + +&weim { + #address-cells = <2>; + #size-cells = <1>; + fsl,weim-cs-gpr = <&gpr>; + pinctrl-0 = <&pinctrl_weim &pinctrl_weim_cs0 &pinctrl_weim_cs1>; + pinctrl-names = "default"; + /* It is necessary to setup 2x 64MB otherwise setting gpr fails */ + ranges = <0 0 0x08000000 0x04000000>, /* CS0 */ + <1 0 0x0c000000 0x04000000>; /* CS1 */ + status = "disabled"; +}; + +&iomuxc { + pinctrl-0 = < + &pinctrl_hog_base + &pinctrl_dhcom_a &pinctrl_dhcom_b &pinctrl_dhcom_c + &pinctrl_dhcom_d &pinctrl_dhcom_e &pinctrl_dhcom_f + &pinctrl_dhcom_g &pinctrl_dhcom_h &pinctrl_dhcom_i + &pinctrl_dhcom_j &pinctrl_dhcom_k &pinctrl_dhcom_l + &pinctrl_dhcom_m &pinctrl_dhcom_n &pinctrl_dhcom_o + &pinctrl_dhcom_p &pinctrl_dhcom_q &pinctrl_dhcom_r + &pinctrl_dhcom_s &pinctrl_dhcom_t &pinctrl_dhcom_u + &pinctrl_dhcom_v &pinctrl_dhcom_w &pinctrl_dhcom_int + >; + pinctrl-names = "default"; + + pinctrl_hog_base: hog-base-grp { + fsl,pins = < + /* GPIOs for memory coding */ + MX6QDL_PAD_EIM_A16__GPIO2_IO22 0x120b0 + MX6QDL_PAD_EIM_A17__GPIO2_IO21 0x120b0 + /* GPIOs for hardware coding */ + MX6QDL_PAD_EIM_A19__GPIO2_IO19 0x120b0 + MX6QDL_PAD_EIM_A22__GPIO2_IO16 0x120b0 + MX6QDL_PAD_EIM_A23__GPIO6_IO06 0x120b0 + >; + }; + + /* DHCOM GPIOs */ + pinctrl_dhcom_a: dhcom-a-grp { + fsl,pins = <MX6QDL_PAD_GPIO_2__GPIO1_IO02 0x400120b0>; + }; + + pinctrl_dhcom_b: dhcom-b-grp { + fsl,pins = <MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x400120b0>; + }; + + pinctrl_dhcom_c: dhcom-c-grp { + fsl,pins = <MX6QDL_PAD_GPIO_5__GPIO1_IO05 0x400120b0>; + }; + + pinctrl_dhcom_d: dhcom-d-grp { + fsl,pins = <MX6QDL_PAD_CSI0_DAT17__GPIO6_IO03 0x400120b0>; + }; + + pinctrl_dhcom_e: dhcom-e-grp { + fsl,pins = <MX6QDL_PAD_GPIO_19__GPIO4_IO05 0x400120b0>; + }; + + pinctrl_dhcom_f: dhcom-f-grp { + fsl,pins = <MX6QDL_PAD_DI0_PIN4__GPIO4_IO20 0x400120b0>; + }; + + pinctrl_dhcom_g: dhcom-g-grp { + fsl,pins = <MX6QDL_PAD_EIM_D27__GPIO3_IO27 0x400120b0>; + }; + + pinctrl_dhcom_h: dhcom-h-grp { + fsl,pins = <MX6QDL_PAD_KEY_ROW0__GPIO4_IO07 0x400120b0>; + }; + + pinctrl_dhcom_i: dhcom-i-grp { + fsl,pins = <MX6QDL_PAD_KEY_COL1__GPIO4_IO08 0x400120b0>; + }; + + pinctrl_dhcom_j: dhcom-j-grp { + fsl,pins = <MX6QDL_PAD_NANDF_CS1__GPIO6_IO14 0x400120b0>; + }; + + pinctrl_dhcom_k: dhcom-k-grp { + fsl,pins = <MX6QDL_PAD_NANDF_CS2__GPIO6_IO15 0x400120b0>; + }; + + pinctrl_dhcom_l: dhcom-l-grp { + fsl,pins = <MX6QDL_PAD_KEY_ROW1__GPIO4_IO09 0x400120b0>; + }; + + pinctrl_dhcom_m: dhcom-m-grp { + fsl,pins = <MX6QDL_PAD_SD3_DAT5__GPIO7_IO00 0x400120b0>; + }; + + pinctrl_dhcom_n: dhcom-n-grp { + fsl,pins = <MX6QDL_PAD_SD3_DAT4__GPIO7_IO01 0x400120b0>; + }; + + pinctrl_dhcom_o: dhcom-o-grp { + fsl,pins = <MX6QDL_PAD_CSI0_VSYNC__GPIO5_IO21 0x400120b0>; + }; + + pinctrl_dhcom_p: dhcom-p-grp { + fsl,pins = <MX6QDL_PAD_GPIO_18__GPIO7_IO13 0x400120b0>; + }; + + pinctrl_dhcom_q: dhcom-q-grp { + fsl,pins = <MX6QDL_PAD_SD1_CMD__GPIO1_IO18 0x400120b0>; + }; + + pinctrl_dhcom_r: dhcom-r-grp { + fsl,pins = <MX6QDL_PAD_SD1_DAT0__GPIO1_IO16 0x400120b0>; + }; + + pinctrl_dhcom_s: dhcom-s-grp { + fsl,pins = <MX6QDL_PAD_SD1_DAT1__GPIO1_IO17 0x400120b0>; + }; + + pinctrl_dhcom_t: dhcom-t-grp { + fsl,pins = <MX6QDL_PAD_SD1_DAT2__GPIO1_IO19 0x400120b0>; + }; + + pinctrl_dhcom_u: dhcom-u-grp { + fsl,pins = <MX6QDL_PAD_SD1_CLK__GPIO1_IO20 0x400120b0>; + }; + + pinctrl_dhcom_v: dhcom-v-grp { + fsl,pins = <MX6QDL_PAD_CSI0_PIXCLK__GPIO5_IO18 0x400120b0>; + }; + + pinctrl_dhcom_w: dhcom-w-grp { + fsl,pins = <MX6QDL_PAD_CSI0_MCLK__GPIO5_IO19 0x400120b0>; + }; + + pinctrl_dhcom_int: dhcom-int-grp { + fsl,pins = <MX6QDL_PAD_KEY_COL0__GPIO4_IO06 0x400120b0>; + }; + + pinctrl_ecspi1: ecspi1-grp { + fsl,pins = < + MX6QDL_PAD_EIM_D16__ECSPI1_SCLK 0x100b1 + MX6QDL_PAD_EIM_D17__ECSPI1_MISO 0x100b1 + MX6QDL_PAD_EIM_D18__ECSPI1_MOSI 0x100b1 + MX6QDL_PAD_EIM_EB2__GPIO2_IO30 0x1b0b0 + MX6QDL_PAD_KEY_ROW2__GPIO4_IO11 0x1b0b0 + >; + }; + + pinctrl_ecspi2: ecspi2-grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT8__ECSPI2_SCLK 0x100b1 + MX6QDL_PAD_CSI0_DAT9__ECSPI2_MOSI 0x100b1 + MX6QDL_PAD_CSI0_DAT10__ECSPI2_MISO 0x100b1 + MX6QDL_PAD_CSI0_DAT11__GPIO5_IO29 0x1b0b0 + >; + }; + + pinctrl_enet_100M: enet-100M-grp { + fsl,pins = < + MX6QDL_PAD_ENET_CRS_DV__ENET_RX_EN 0x1b0b0 + MX6QDL_PAD_ENET_MDC__ENET_MDC 0x1b0b0 + MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x1b0b0 + MX6QDL_PAD_ENET_RX_ER__ENET_RX_ER 0x1b0b0 + MX6QDL_PAD_ENET_RXD0__ENET_RX_DATA0 0x1b0b0 + MX6QDL_PAD_ENET_RXD1__ENET_RX_DATA1 0x1b0b0 + MX6QDL_PAD_ENET_TX_EN__ENET_TX_EN 0x1b0b0 + MX6QDL_PAD_ENET_TXD0__ENET_TX_DATA0 0x1b0b0 + MX6QDL_PAD_ENET_TXD1__ENET_TX_DATA1 0x1b0b0 + MX6QDL_PAD_GPIO_16__ENET_REF_CLK 0x4001b0a8 + >; + }; + + pinctrl_enet_vio: enet-vio-grp { + fsl,pins = < + MX6QDL_PAD_GPIO_7__GPIO1_IO07 0x120b0 + >; + }; + + pinctrl_ethphy0: ethphy0-grp { + fsl,pins = < + MX6QDL_PAD_EIM_WAIT__GPIO5_IO00 0xb0 /* Reset */ + MX6QDL_PAD_KEY_ROW4__GPIO4_IO15 0xb1 /* Int */ + >; + }; + + pinctrl_flexcan1: flexcan1-grp { + fsl,pins = < + MX6QDL_PAD_GPIO_8__FLEXCAN1_RX 0x1b0b0 + MX6QDL_PAD_KEY_COL2__FLEXCAN1_TX 0x1b0b0 + >; + }; + + pinctrl_flexcan2: flexcan2-grp { + fsl,pins = < + MX6QDL_PAD_SD3_DAT0__FLEXCAN2_TX 0x1b0b0 + MX6QDL_PAD_SD3_DAT1__FLEXCAN2_RX 0x1b0b0 + >; + }; + + pinctrl_i2c1: i2c1-grp { + fsl,pins = < + MX6QDL_PAD_EIM_D21__I2C1_SCL 0x4001b8b1 + MX6QDL_PAD_EIM_D28__I2C1_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c1_gpio: i2c1-gpio-grp { + fsl,pins = < + MX6QDL_PAD_EIM_D21__GPIO3_IO21 0x4001b8b1 + MX6QDL_PAD_EIM_D28__GPIO3_IO28 0x4001b8b1 + >; + }; + + pinctrl_i2c2: i2c2-grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL3__I2C2_SCL 0x4001b8b1 + MX6QDL_PAD_KEY_ROW3__I2C2_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c2_gpio: i2c2-gpio-grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL3__GPIO4_IO12 0x4001b8b1 + MX6QDL_PAD_KEY_ROW3__GPIO4_IO13 0x4001b8b1 + >; + }; + + pinctrl_i2c3: i2c3-grp { + fsl,pins = < + MX6QDL_PAD_GPIO_3__I2C3_SCL 0x4001b8b1 + MX6QDL_PAD_GPIO_6__I2C3_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c3_gpio: i2c3-gpio-grp { + fsl,pins = < + MX6QDL_PAD_GPIO_3__GPIO1_IO03 0x4001b8b1 + MX6QDL_PAD_GPIO_6__GPIO1_IO06 0x4001b8b1 + >; + }; + + pinctrl_pcie: pcie-grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DATA_EN__GPIO5_IO20 0x1b0b1 /* Wake */ + >; + }; + + pinctrl_pmic: pmic-grp { + fsl,pins = < + MX6QDL_PAD_EIM_A25__GPIO5_IO02 0x1b0b0 + >; + }; + + pinctrl_pwm1: pwm1-grp { + fsl,pins = < + MX6QDL_PAD_SD1_DAT3__PWM1_OUT 0x1b0b1 + >; + }; + + pinctrl_rtc: rtc-grp { + fsl,pins = < + MX6QDL_PAD_GPIO_17__GPIO7_IO12 0x120b0 + >; + }; + + pinctrl_tsc2004: tsc2004-grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL4__GPIO4_IO14 0x120b0 + >; + }; + + pinctrl_uart1: uart1-grp { + fsl,pins = < + MX6QDL_PAD_EIM_D19__UART1_CTS_B 0x4001b0b1 + MX6QDL_PAD_EIM_D20__UART1_RTS_B 0x1b0b1 + MX6QDL_PAD_EIM_D23__GPIO3_IO23 0x4001b0b1 + MX6QDL_PAD_EIM_D24__GPIO3_IO24 0x4001b0b1 + MX6QDL_PAD_EIM_D25__GPIO3_IO25 0x4001b0b1 + MX6QDL_PAD_EIM_EB3__GPIO2_IO31 0x4001b0b1 + MX6QDL_PAD_SD3_DAT6__UART1_RX_DATA 0x1b0b1 + MX6QDL_PAD_SD3_DAT7__UART1_TX_DATA 0x1b0b1 + >; + }; + + pinctrl_uart4: uart4-grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT12__UART4_TX_DATA 0x1b0b1 + MX6QDL_PAD_CSI0_DAT13__UART4_RX_DATA 0x1b0b1 + >; + }; + + pinctrl_uart5: uart5-grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT14__UART5_TX_DATA 0x1b0b1 + MX6QDL_PAD_CSI0_DAT15__UART5_RX_DATA 0x1b0b1 + MX6QDL_PAD_CSI0_DAT18__UART5_RTS_B 0x1b0b1 + MX6QDL_PAD_CSI0_DAT19__UART5_CTS_B 0x4001b0b1 + >; + }; + + pinctrl_usbh1: usbh1-grp { + fsl,pins = < + MX6QDL_PAD_EIM_D31__GPIO3_IO31 0x120b0 + >; + }; + + pinctrl_usbotg: usbotg-grp { + fsl,pins = < + MX6QDL_PAD_GPIO_1__USB_OTG_ID 0x17059 + >; + }; + + pinctrl_usdhc2: usdhc2-grp { + fsl,pins = < + MX6QDL_PAD_NANDF_CS3__GPIO6_IO16 0x120b0 + MX6QDL_PAD_SD2_CLK__SD2_CLK 0x10059 + MX6QDL_PAD_SD2_CMD__SD2_CMD 0x17059 + MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x17059 + MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x17059 + MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x17059 + MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x17059 + >; + }; + + pinctrl_usdhc3: usdhc3-grp { + fsl,pins = < + MX6QDL_PAD_SD3_CLK__SD3_CLK 0x10059 + MX6QDL_PAD_SD3_CMD__SD3_CMD 0x17059 + MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x17059 + MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x17059 + MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x17059 + MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x17059 + MX6QDL_PAD_SD3_RST__GPIO7_IO08 0x120b0 + >; + }; + + pinctrl_usdhc4: usdhc4-grp { + fsl,pins = < + MX6QDL_PAD_SD4_CLK__SD4_CLK 0x10059 + MX6QDL_PAD_SD4_CMD__SD4_CMD 0x17059 + MX6QDL_PAD_SD4_DAT0__SD4_DATA0 0x17059 + MX6QDL_PAD_SD4_DAT1__SD4_DATA1 0x17059 + MX6QDL_PAD_SD4_DAT2__SD4_DATA2 0x17059 + MX6QDL_PAD_SD4_DAT3__SD4_DATA3 0x17059 + MX6QDL_PAD_SD4_DAT4__SD4_DATA4 0x17059 + MX6QDL_PAD_SD4_DAT5__SD4_DATA5 0x17059 + MX6QDL_PAD_SD4_DAT6__SD4_DATA6 0x17059 + MX6QDL_PAD_SD4_DAT7__SD4_DATA7 0x17059 + >; + }; + + pinctrl_weim: weim-grp { + fsl,pins = < + MX6QDL_PAD_EIM_DA0__EIM_AD00 0xb0a6 + MX6QDL_PAD_EIM_DA1__EIM_AD01 0xb0a6 + MX6QDL_PAD_EIM_DA2__EIM_AD02 0xb0a6 + MX6QDL_PAD_EIM_DA3__EIM_AD03 0xb0a6 + MX6QDL_PAD_EIM_DA4__EIM_AD04 0xb0a6 + MX6QDL_PAD_EIM_DA5__EIM_AD05 0xb0a6 + MX6QDL_PAD_EIM_DA6__EIM_AD06 0xb0a6 + MX6QDL_PAD_EIM_DA7__EIM_AD07 0xb0a6 + MX6QDL_PAD_EIM_DA8__EIM_AD08 0xb0a6 + MX6QDL_PAD_EIM_DA9__EIM_AD09 0xb0a6 + MX6QDL_PAD_EIM_DA10__EIM_AD10 0xb0a6 + MX6QDL_PAD_EIM_DA11__EIM_AD11 0xb0a6 + MX6QDL_PAD_EIM_DA12__EIM_AD12 0xb0a6 + MX6QDL_PAD_EIM_DA13__EIM_AD13 0xb0a6 + MX6QDL_PAD_EIM_DA14__EIM_AD14 0xb0a6 + MX6QDL_PAD_EIM_DA15__EIM_AD15 0xb0a6 + MX6QDL_PAD_EIM_D22__GPIO3_IO22 0x130b0 + MX6QDL_PAD_EIM_LBA__EIM_LBA_B 0xb060 /* LE */ + MX6QDL_PAD_EIM_OE__EIM_OE_B 0xb0a6 + MX6QDL_PAD_EIM_RW__EIM_RW 0xb0a6 /* WE */ + >; + }; + + pinctrl_weim_cs0: weim-cs0-grp { + fsl,pins = < + MX6QDL_PAD_EIM_CS0__EIM_CS0_B 0xb0b1 + >; + }; + + pinctrl_weim_cs1: weim-cs1-grp { + fsl,pins = < + MX6QDL_PAD_EIM_CS1__EIM_CS1_B 0xb0b1 + >; + }; +};
Reviewed-by: Fabio Estevam festevam@gmail.com
Synchronize DH DHCOM DTs with Linux commit 25960cafa06e ("Linux 5.15.12"). There is no functional change to the resulting DTs. The imx6qdl-dhcom-pdk2.dtsi had to be adjusted with additional headers, gpio.h, pwm.h, input.h, else the DT cannot be compiled, the same change is likely necessary in Linux. Signed-off-by: Marek Vasut marex@denx.de Cc: Christoph Niedermaier cniedermaier@dh-electronics.com Cc: Stefano Babic sbabic@denx.de Reviewed-by: Fabio Estevam festevam@gmail.com
Best regards, Stefano Babic
Add labels to remaining anatop regulators, so their supplies can be assigned in board DTs. This is similar to Linux kernel commit 93385546ba369 ("ARM: dts: imx6qdl-sabresd: Assign corresponding power supply for LDOs") except it does not contain the unrelated sabresd changes. Signed-off-by: Marek Vasut marex@denx.de Cc: Christoph Niedermaier cniedermaier@dh-electronics.com Cc: Stefano Babic sbabic@denx.de Reviewed-by: Fabio Estevam festevam@gmail.com
Fabio Estevam
sbabic@denx.de
