[PATCH] Fix corner case in bad block table handling.
In the unlikely event that both blocks 10 and 11 are marked as bad (on a 32 bit machine), then the process of marking block 10 as bad stomps on cached entry for block 11. There are (of course) other examples.
Signed-off-by: Patrick Doyle pdoyle@irobot.com --- drivers/mtd/nand/bbt.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/bbt.c b/drivers/mtd/nand/bbt.c index 7e0ad3190c..eb1184aadb 100644 --- a/drivers/mtd/nand/bbt.c +++ b/drivers/mtd/nand/bbt.c @@ -124,7 +124,7 @@ int nanddev_bbt_set_block_status(struct nand_device *nand, unsigned int entry, unsigned int rbits = bits_per_block + offs - BITS_PER_LONG;
pos[1] &= ~GENMASK(rbits - 1, 0); - pos[1] |= val >> rbits; + pos[1] |= val >> (bits_per_block - rbits); }
Looks good to me.
Fixes: 9c3736a3de21 ("mtd: nand: Add core infrastructure to deal with NAND devices") Reviewed-by: Richard Weinberger richard@nod.at
-- Thanks, //richard
Signed-off-by: Patrick Doyle pdoyle@irobot.com Reviewed-by: Richard Weinberger richard@nod.at
Doyle, Patrick
Richard Weinberger
