The current TPM emulation in drivers/tpm/tpm(2)_tis_sandbox.c is not spec compliant.
A TPM emulation as UNIX socket exists with https://github.com/stefanberger/swtpm.git. QEMU already uses this emulator.
Couldn't the sandbox do the same? I think this is the fastest way to get a compliant sandbox TPM.
Best regards
Heinrich
Hi Heinrich,
Do you mean it is incomplete or that it has bugs? If it is incomplete, what is needed by U-Boot?
Well we could if we need it. Are you sure it is a good idea? There is a lot of code there. Are you thinking it would be copied into the U-Boot tree and kept in sync with a script, perhaps? Presumably the project would accept changes we need?
On Sat, Aug 28, 2021 at 10:19 PM Simon Glass sjg@chromium.org wrote:
Hi Heinrich,
qemu doesn't copy it in, why can't it just run independently as part of the CI process? The rust TPM2 bindings do that here: https://github.com/parallaxsecond/rust-tss-esapi/blob/main/tss-esapi/tests/a...
Hi Heinrich,
Keep in mind this is exposed as an MMIIO device. I did send a driver for it a while back [1]. In case we decide to use this, we can probably re-use that
[1] https://lore.kernel.org/u-boot/20210707162604.84196-1-ilias.apalodimas@linar...
Regards /Ilias
Hi Heinrich,
@Simon Just have look at the bunch of TPM related error messages generated on the sandbox:
=> host bind 0 ../sandbox.img => load host 0:1 $kernel_addr_r EFI/grub/shimriscv64.efi 755200 bytes read in 5 ms (144 MiB/s) => bootefi $kernel_addr_r Scanning disk mmc2.blk... No valid Btrfs found Bad magic number for SquashFS image. ** Unrecognized filesystem type ** Scanning disk mmc1.blk... No valid Btrfs found Bad magic number for SquashFS image. ** Unrecognized filesystem type ** Scanning disk mmc0.blk... No valid Btrfs found Bad magic number for SquashFS image. ** Unrecognized filesystem type ** Scanning disk host0... Found 5 disks Cannot install EFI_TCG2_PROTOCOL <<<<<<<<<<<<<<<<<<<<<<<<<<< "dfu_alt_info" env variable not defined! Probably dfu_alt_info not defined "dfu_alt_info" env variable not defined! Probably dfu_alt_info not defined Booting /EFI\grub\shimriscv64.efi PE image measurement failed <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< .sbat copied to 0x000000002ca7b000 .sbat = sbat,1,SBAT Version,sbat,1,https://github.com/rhboot/shim/blob/main/SBAT.md shim,1,UEFI shim,shim,1,https://github.com/rhboot/shim
tcg2 measurement fails(0x8000000000000007) <<<<<<<<<<<<<<<<
Regards /Ilias
Currently we don't test measured boot. I would prefer the tests to run on the sandbox and not in QEMU. This makes debugging much easier.
Best regards
Heinrich
Hi Heinrich,
Hi Heinrich,
OK...then I wonder what it would take to improve the sandbox TPM driver enough for these to pass? We have to think about cost/benefit of the amount of code we are bringing in, debugability, etc.
Regards /Ilias
I couldn't agree more; development also.
Ilias Apalodimas
Peter Robinson
