[U-Boot-Users] [PATCH] Fix config files for out-of-tree building
Several board/<...>/config.mk files include dynamically built (by the Makefile) config files but used the wrong file name of $(TOPDIR)/board/$(BOARDDIR)/config.tmp instead if the correct $(OBJTREE)/board/$(BOARDDIR)/config.tmp
The bug is nasty because the build result is correct for the (normal) in-tree builds, and because 'sinclude' is used no errors get raised even for out-of-tree build tests. But out-of-tree builds use an incomplete and thus usually incorrect configuration...
Signed-off-by: Wolfgang Denk wd@denx.de --- board/BuS/EB+MCF-EV123/config.mk | 2 +- board/amcc/canyonlands/config.mk | 2 +- board/esd/mecp5200/config.mk | 2 +- board/linkstation/config.mk | 2 +- board/munices/config.mk | 2 +- board/v38b/config.mk | 2 +- 6 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/board/BuS/EB+MCF-EV123/config.mk b/board/BuS/EB+MCF-EV123/config.mk index 9fe2fc5..f03e396 100644 --- a/board/BuS/EB+MCF-EV123/config.mk +++ b/board/BuS/EB+MCF-EV123/config.mk @@ -22,7 +22,7 @@ # MA 02111-1307 USA #
-sinclude $(TOPDIR)/board/$(BOARDDIR)/textbase.mk +sinclude $(OBJTREE)/board/$(BOARDDIR)/textbase.mk ifndef TEXT_BASE TEXT_BASE = 0xFE000000 endif diff --git a/board/amcc/canyonlands/config.mk b/board/amcc/canyonlands/config.mk index 1e4bbc4..7e79536 100644 --- a/board/amcc/canyonlands/config.mk +++ b/board/amcc/canyonlands/config.mk @@ -24,7 +24,7 @@ # AMCC 460EX/460GT Evaluation Board (Canyonlands) board #
-sinclude $(TOPDIR)/board/$(BOARDDIR)/config.tmp +sinclude $(OBJTREE)/board/$(BOARDDIR)/config.tmp
ifndef TEXT_BASE TEXT_BASE = 0xFFFA0000 diff --git a/board/esd/mecp5200/config.mk b/board/esd/mecp5200/config.mk index 07b5de1..170779d 100644 --- a/board/esd/mecp5200/config.mk +++ b/board/esd/mecp5200/config.mk @@ -32,7 +32,7 @@ # 0x00100000 boot from RAM (for testing only) #
ifndef TEXT_BASE ## Standard: boot high diff --git a/board/linkstation/config.mk b/board/linkstation/config.mk index bdf611d..d048290 100644 --- a/board/linkstation/config.mk +++ b/board/linkstation/config.mk @@ -35,7 +35,7 @@ # 0x07F00000 boot from RAM #
ifndef TEXT_BASE # For flash image - all models diff --git a/board/munices/config.mk b/board/munices/config.mk index d226244..1b573bc 100644 --- a/board/munices/config.mk +++ b/board/munices/config.mk @@ -29,7 +29,7 @@ # 0xFFF00000 boot high (standard configuration) #
ifndef TEXT_BASE TEXT_BASE = 0xFFF00000 diff --git a/board/v38b/config.mk b/board/v38b/config.mk index 75577fc..bc55fc7 100644 --- a/board/v38b/config.mk +++ b/board/v38b/config.mk @@ -25,7 +25,7 @@ # MarelV38B board #
TEXT_BASE = 0xFF000000
