[PATCH] Allow colon in PXE bootfile URLs
From: Lyle Franklin lylejfranklin@gmail.com Date: Sun, 15 Aug 2021 07:17:14 -0400 Subject: [PATCH] Allow colon in PXE bootfile URLs
- U-boot's PXE flow supports prefixing your bootfile name with an IP address to fetch from a server other than the DHCP server, e.g. `hostIPaddr:bootfilename`:
https://github.com/u-boot/u-boot/commit/a93907c43f847f076dd0e34ee3b69b5e8e6d... - However, this breaks bootfile paths which contain a colon, e.g. `f0:ad:4e:10:1b:87/7/pxelinux.cfg/default` - This patch checks whether the `hostIPaddr` prefix is a valid IP address before overriding the serverIP otherwise the whole bootfile path is preserved
Signed-off-by: Lyle Franklin lylejfranklin@gmail.com --- net/net.c | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/net/net.c b/net/net.c index c2992a0908..30fc0a29d7 100644 --- a/net/net.c +++ b/net/net.c @@ -1540,14 +1540,18 @@ int is_serverip_in_cmd(void) int net_parse_bootfile(struct in_addr *ipaddr, char *filename, int max_len) { char *colon; + struct in_addr ip;
if (net_boot_file_name[0] == '\0') return 0;
colon = strchr(net_boot_file_name, ':'); if (colon) { - if (ipaddr) - *ipaddr = string_to_ip(net_boot_file_name); + ip = string_to_ip(net_boot_file_name); + if (ipaddr && ip.s_addr) + *ipaddr = ip; + } + if (ip.s_addr) { strncpy(filename, colon + 1, max_len); } else { strncpy(filename, net_boot_file_name, max_len);
struct in_addr ip;
- if (ipaddr)
- ip = string_to_ip(net_boot_file_name);
- if (ipaddr && ip.s_addr)
- *ipaddr = ip;
- if (ip.s_addr) { strncpy(filename, colon + 1, max_len); } else { strncpy(filename, net_boot_file_name, max_len);
-- 2.31.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
struct in_addr ip;
- if (ipaddr)
- *ipaddr = ip;
-- 2.31.1
Patch doesn't apply, please rebase and resend. Additionally, it looks like there is wrong indentation, please check patch with checkpatch before resubmitting Thanks, Ramon
- U-boot's PXE flow supports prefixing your bootfile name with an IP address to fetch from a server other than the DHCP server, e.g. `hostIPaddr:bootfilename`: https://github.com/u-boot/u-boot/commit/a93907c43f847f076dd0e34ee3b69b5e8e6d... - However, this breaks bootfile paths which contain a colon, e.g. `f0:ad:4e:10:1b:87/7/pxelinux.cfg/default` - This patch checks whether the `hostIPaddr` prefix is a valid IP address before overriding the serverIP otherwise the whole bootfile path is preserved
diff --git a/net/net.c b/net/net.c index 072a82d8f9..57ed77795a 100644 --- a/net/net.c +++ b/net/net.c @@ -1538,14 +1538,18 @@ int is_serverip_in_cmd(void) int net_parse_bootfile(struct in_addr *ipaddr, char *filename, int max_len) { char *colon; + struct in_addr ip;
struct in_addr ip; if (net_boot_file_name[0] == '\0') return 0; colon = strchr(net_boot_file_name, ':'); if (colon) {
if (ipaddr)
*ipaddr = ip;
-- 2.31.1
Applied to u-boot-net/next Thanks, Ramon
Signed-off-by: Lyle Franklin lylejfranklin@gmail.com --- net/net.c | 9 +++++++-- 1 file changed, 7 insertions(+), 2 deletions(-)
diff --git a/net/net.c b/net/net.c index 072a82d8f9..034a5d6e67 100644 --- a/net/net.c +++ b/net/net.c @@ -1538,14 +1538,19 @@ int is_serverip_in_cmd(void) int net_parse_bootfile(struct in_addr *ipaddr, char *filename, int max_len) { char *colon; + struct in_addr ip; + ip.s_addr = 0;
Lyle Franklin
Ramon Fried
