[U-Boot] [PATCH 1/2] arm: mx6: Add UART8 base address for i.MX6UL
Add the base address for the i.MX6UL so that this UART can be used.
Signed-off-by: Stefan Roese sr@denx.de Cc: Ye Li ye.li@nxp.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/include/asm/arch-mx6/imx-regs.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index 5c45bf6..d0e6bf2 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -162,6 +162,7 @@ #endif #define UART1_BASE (ATZ1_BASE_ADDR + 0x20000) #define ESAI1_BASE_ADDR (ATZ1_BASE_ADDR + 0x24000) +#define UART8_BASE (ATZ1_BASE_ADDR + 0x24000) #define SSI1_BASE_ADDR (ATZ1_BASE_ADDR + 0x28000) #define SSI2_BASE_ADDR (ATZ1_BASE_ADDR + 0x2C000) #define SSI3_BASE_ADDR (ATZ1_BASE_ADDR + 0x30000)
This patch add support for the CCV xPress board which is equipped with the i.MX6UL. And provides the following interfaces:
- 128MiB DDR - UART - I2C - eMMC (with booting) - Ethernet - USB
This patch adds two build targets. One with and one without SPL. The non-SPL version is used for loading U-Boot via USB (imx_usb_loader).
Signed-off-by: Stefan Roese sr@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/cpu/armv7/mx6/Kconfig | 8 + board/ccv/xpress/Kconfig | 12 ++ board/ccv/xpress/MAINTAINERS | 7 + board/ccv/xpress/Makefile | 8 + board/ccv/xpress/imximage.cfg | 176 ++++++++++++++++++++++ board/ccv/xpress/spl.c | 116 +++++++++++++++ board/ccv/xpress/xpress.c | 331 +++++++++++++++++++++++++++++++++++++++++ configs/xpress_defconfig | 6 + configs/xpress_spl_defconfig | 7 + include/configs/xpress.h | 166 +++++++++++++++++++++ 10 files changed, 837 insertions(+) create mode 100644 board/ccv/xpress/Kconfig create mode 100644 board/ccv/xpress/MAINTAINERS create mode 100644 board/ccv/xpress/Makefile create mode 100644 board/ccv/xpress/imximage.cfg create mode 100644 board/ccv/xpress/spl.c create mode 100644 board/ccv/xpress/xpress.c create mode 100644 configs/xpress_defconfig create mode 100644 configs/xpress_spl_defconfig create mode 100644 include/configs/xpress.h
diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index c72a150..f5e62a7 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -153,6 +153,13 @@ config TARGET_WANDBOARD config TARGET_WARP bool "WaRP"
+config TARGET_XPRESS + bool "CCV xPress" + select MX6UL + select DM + select DM_THERMAL + select SUPPORT_SPL + endchoice
config SYS_SOC @@ -163,6 +170,7 @@ source "board/bachmann/ot1200/Kconfig" source "board/barco/platinum/Kconfig" source "board/barco/titanium/Kconfig" source "board/boundary/nitrogen6x/Kconfig" +source "board/ccv/xpress/Kconfig" source "board/compulab/cm_fx6/Kconfig" source "board/congatec/cgtqmx6eval/Kconfig" source "board/embest/mx6boards/Kconfig" diff --git a/board/ccv/xpress/Kconfig b/board/ccv/xpress/Kconfig new file mode 100644 index 0000000..9157013 --- /dev/null +++ b/board/ccv/xpress/Kconfig @@ -0,0 +1,12 @@ +if TARGET_XPRESS + +config SYS_BOARD + default "xpress" + +config SYS_VENDOR + default "ccv" + +config SYS_CONFIG_NAME + default "xpress" + +endif diff --git a/board/ccv/xpress/MAINTAINERS b/board/ccv/xpress/MAINTAINERS new file mode 100644 index 0000000..e242bfb --- /dev/null +++ b/board/ccv/xpress/MAINTAINERS @@ -0,0 +1,7 @@ +CCV XPRESS BOARD +M: Stefan Roese sr@denx.de +S: Maintained +F: board/ccv/xpress/ +F: include/configs/xpress.h +F: configs/xpress_defconfig +F: configs/xpress_spl_defconfig diff --git a/board/ccv/xpress/Makefile b/board/ccv/xpress/Makefile new file mode 100644 index 0000000..0d444b6 --- /dev/null +++ b/board/ccv/xpress/Makefile @@ -0,0 +1,8 @@ +# +# Copyright (C) 2015-2016 Stefan Roese sr@denx.de +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := xpress.o +obj-$(CONFIG_SPL_BUILD) += spl.o diff --git a/board/ccv/xpress/imximage.cfg b/board/ccv/xpress/imximage.cfg new file mode 100644 index 0000000..92167c9 --- /dev/null +++ b/board/ccv/xpress/imximage.cfg @@ -0,0 +1,176 @@ +/* + * Copyright (C) 2015-2016 Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ + +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * sd, nand + */ +BOOT_FROM sd + +/* + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +#define __ASSEMBLY__ +#include <config.h> + +/* Enable all clocks */ +DATA 4 0x020c4068 0xffffffff +DATA 4 0x020c406c 0xffffffff +DATA 4 0x020c4070 0xffffffff +DATA 4 0x020c4074 0xffffffff +DATA 4 0x020c4078 0xffffffff +DATA 4 0x020c407c 0xffffffff +DATA 4 0x020c4080 0xffffffff +DATA 4 0x020c4084 0xffffffff + +/* ddr io type */ +DATA 4 0x020e04b4 0x000C0000 /* IOMUXC_SW_PAD_CTL_GRP_DDR_TYPE */ +DATA 4 0x020e04ac 0x00000000 /* IOMUXC_SW_PAD_CTL_GRP_DDRPKE */ + +/* clock */ +DATA 4 0x020e027c 0x00000030 /* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDCLK0_P */ + +/* control and address */ +DATA 4 0x020E0250 0x00000030 /* IOMUXC_SW_PAD_CTL_PAD_DRAM_CAS */ +DATA 4 0x020E024C 0x00000030 /* IOMUXC_SW_PAD_CTL_PAD_DRAM_RAS */ +DATA 4 0x020E0490 0x00000030 /* IOMUXC_SW_PAD_CTL_GRP_ADDDS */ +DATA 4 0x020E0288 0x00000030 /* IOMUXC_SW_PAD_CTL_PAD_DRAM_RESET */ +DATA 4 0x020E0270 0x00000000 /* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDBA2 - DSE can be + configured using Group Control Register: + IOMUXC_SW_PAD_CTL_GRP_CTLDS */ +DATA 4 0x020E0260 0x00000030 /* IOMUXC_SW_PAD_CTL_PAD_DRAM_ODT0 */ +DATA 4 0x020E0264 0x00000030 /* IOMUXC_SW_PAD_CTL_PAD_DRAM_ODT1 */ +DATA 4 0x020E04A0 0x00000030 /* IOMUXC_SW_PAD_CTL_GRP_CTLDS */ + +/* data strobes */ +DATA 4 0x020e0494 0x00020000 /* IOMUXC_SW_PAD_CTL_GRP_DDRMODE_CTL */ +DATA 4 0x020e0280 0x00000030 /* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS0_P */ +DATA 4 0x020e0284 0x00000030 /* IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS1_P */ + +/* data */ +DATA 4 0x020E04B0 0x00020000 /* IOMUXC_SW_PAD_CTL_GRP_DDRMODE */ +DATA 4 0x020E0498 0x00000030 /* IOMUXC_SW_PAD_CTL_GRP_B0DS */ +DATA 4 0x020E04A4 0x00000030 /* IOMUXC_SW_PAD_CTL_GRP_B1DS */ +DATA 4 0x020E0244 0x00000030 /* IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM0 */ +DATA 4 0x020E0248 0x00000030 /* IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM1 */ + +/* + * DDR Controller Registers + * + * Manufacturer: IM + * Device Part Number: IME1G16D3EEBG-15EI + * Clock Freq.: 400MHz + * Density per CS in Gb: 1 + * Chip Selects used: 1 + * Number of Banks: 8 + * Row address: 13 + * Column address: 10 + * Data bus width 16 + */ +DATA 4 0x021b001c 0x00008000 /* MMDC0_MDSCR, set the Configuration request bit + during MMDC set up */ + +/* + * Calibration setup + */ +DATA 4 0x021b0800 0xA1390003 /* DDR_PHY_P0_MPZQHWCTRL, enable both one-time & + periodic HW ZQ calibration. */ + +/* + * For target board, may need to run write leveling calibration to fine tune + * these settings. + */ +DATA 4 0x021b080c 0x00000000 + +/* Read DQS Gating calibration */ +DATA 4 0x021b083c 0x4164015C /* MPDGCTRL0 PHY0 */ + +/* Read calibration */ +DATA 4 0x021b0848 0x40404446 /* MPRDDLCTL PHY0 */ + +/* Write calibration */ +DATA 4 0x021b0850 0x40405A52 /* MPWRDLCTL PHY0 */ + +/* + * read data bit delay: (3 is the reccommended default value, although out of + * reset value is 0) + */ +DATA 4 0x021b081c 0x33333333 /* DDR_PHY_P0_MPREDQBY0DL3 */ +DATA 4 0x021b0820 0x33333333 /* DDR_PHY_P0_MPREDQBY1DL3 */ +DATA 4 0x021b082c 0xF3333333 +DATA 4 0x021b0830 0xF3333333 + +DATA 4 0x021b08c0 0x00921012 + +/* Clock Fine Tuning */ +DATA 4 0x021B0858 0x00000F00 /* [MMDC_MPSDCTRL] MMDC PHY CK Control Register */ + +/* Complete calibration by forced measurement: */ +DATA 4 0x021b08b8 0x00000800 /* DDR_PHY_P0_MPMUR0, frc_msr */ +/* + * Calibration setup end + */ + +/* MMDC init: */ +DATA 4 0x021b0004 0x0002002D /* MMDC0_MDPDC */ +DATA 4 0x021b0008 0x1B333030 /* MMDC0_MDOTC */ +DATA 4 0x021b000c 0x3F4352F3 /* MMDC0_MDCFG0 */ +DATA 4 0x021b0010 0xB66D0B63 /* MMDC0_MDCFG1 */ +DATA 4 0x021b0014 0x01FF00DB /* MMDC0_MDCFG2 */ + +/* + * MDMISC: RALAT kept to the high level of 5. + * MDMISC: consider reducing RALAT if your 528MHz board design allow that. + * Lower RALAT benefits: + * a. better operation at low frequency, for LPDDR2 freq < 100MHz, change RALAT + * to 3 + * b. Small performence improvment + */ +DATA 4 0x021b0018 0x00201740 /* MMDC0_MDMISC */ + +DATA 4 0x021b001c 0x00008000 /* MMDC0_MDSCR, set the Configuration request bit + during MMDC set up */ + +DATA 4 0x021b002c 0x000026D2 /* MMDC0_MDRWD */ +DATA 4 0x021b0030 0x00431023 /* MMDC0_MDOR */ +DATA 4 0x021b0040 0x00000047 /* Chan0 CS0_END */ +DATA 4 0x021b0000 0x82180000 /* MMDC0_MDCTL */ + +/* Mode register writes */ +DATA 4 0x021b001c 0x02008032 /* MMDC0_MDSCR, MR2 write, CS0 */ +DATA 4 0x021b001c 0x00008033 /* MMDC0_MDSCR, MR3 write, CS0 */ +DATA 4 0x021b001c 0x00048031 /* MMDC0_MDSCR, MR1 write, CS0 */ +DATA 4 0x021b001c 0x15208030 /* MMDC0_MDSCR, MR0 write, CS0 */ +DATA 4 0x021b001c 0x04008040 /* MMDC0_MDSCR, ZQ calibration command sent to + device on CS0 */ + +DATA 4 0x021b0020 0x00000800 /* MMDC0_MDREF */ +DATA 4 0x021b0818 0x00000227 /* DDR_PHY_P0_MPODTCTRL */ +DATA 4 0x021b0004 0x0002556D /* MMDC0_MDPDC now SDCTL power down enabled */ +DATA 4 0x021b0404 0x00011006 /* MMDC0_MAPSR ADOPT power down enabled, MMDC will + enter automatically to self-refresh while the + number of idle cycle reached. */ +DATA 4 0x021b001c 0x00000000 /* MMDC0_MDSCR, clear this register (especially + the configuration bit as initialization is + complete) */ diff --git a/board/ccv/xpress/spl.c b/board/ccv/xpress/spl.c new file mode 100644 index 0000000..d15b842 --- /dev/null +++ b/board/ccv/xpress/spl.c @@ -0,0 +1,116 @@ +/* + * SPL specific code for CCV xPress + * + * Copyright (C) 2015-2016 Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <spl.h> +#include <asm/io.h> +#include <asm/arch/mx6-ddr.h> +#include <asm/arch/crm_regs.h> + +/* Configuration for IM IME1G16D3EEBG-15EI, 64M x 16 -> 128MiB */ + +static struct mx6ul_iomux_grp_regs mx6_grp_ioregs = { + .grp_addds = 0x00000030, + .grp_ddrmode_ctl = 0x00020000, + .grp_b0ds = 0x00000030, + .grp_ctlds = 0x00000030, + .grp_b1ds = 0x00000030, + .grp_ddrpke = 0x00000000, + .grp_ddrmode = 0x00020000, + .grp_ddr_type = 0x000c0000, +}; + +static struct mx6ul_iomux_ddr_regs mx6_ddr_ioregs = { + .dram_dqm0 = 0x00000030, + .dram_dqm1 = 0x00000030, + .dram_ras = 0x00000030, + .dram_cas = 0x00000030, + .dram_odt0 = 0x00000030, + .dram_odt1 = 0x00000030, + .dram_sdba2 = 0x00000000, + .dram_sdclk_0 = 0x00000008, + .dram_sdqs0 = 0x00000038, + .dram_sdqs1 = 0x00000030, + .dram_reset = 0x00000030, +}; + +static struct mx6_mmdc_calibration mx6_mmcd_calib = { + .p0_mpwldectrl0 = 0x00000000, + .p0_mpdgctrl0 = 0x4164015C, + .p0_mprddlctl = 0x40404446, + .p0_mpwrdlctl = 0x40405A52, +}; + +struct mx6_ddr_sysinfo ddr_sysinfo = { + .dsize = 0, + .cs_density = 20, + .ncs = 1, + .cs1_mirror = 0, + .rtt_wr = 2, + .rtt_nom = 1, /* RTT_Nom = RZQ/2 */ + .walat = 1, /* Write additional latency */ + .ralat = 5, /* Read additional latency */ + .mif3_mode = 3, /* Command prediction working mode */ + .bi_on = 1, /* Bank interleaving enabled */ + .sde_to_rst = 0x10, /* 14 cycles, 200us (JEDEC default) */ + .rst_to_cke = 0x23, /* 33 cycles, 500us (JEDEC default) */ + .ddr_type = DDR_TYPE_DDR3, +}; + +static struct mx6_ddr3_cfg mem_ddr = { + .mem_speed = 800, + .density = 4, + .width = 16, + .banks = 8, + .rowaddr = 13, + .coladdr = 10, + .pagesz = 2, + .trcd = 1375, + .trcmin = 4875, + .trasmin = 3500, +}; + +static void ccgr_init(void) +{ + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + writel(0xFFFFFFFF, &ccm->CCGR0); + writel(0xFFFFFFFF, &ccm->CCGR1); + writel(0xFFFFFFFF, &ccm->CCGR2); + writel(0xFFFFFFFF, &ccm->CCGR3); + writel(0xFFFFFFFF, &ccm->CCGR4); + writel(0xFFFFFFFF, &ccm->CCGR5); + writel(0xFFFFFFFF, &ccm->CCGR6); + writel(0xFFFFFFFF, &ccm->CCGR7); +} + +static void spl_dram_init(void) +{ + mx6ul_dram_iocfg(mem_ddr.width, &mx6_ddr_ioregs, &mx6_grp_ioregs); + mx6_dram_cfg(&ddr_sysinfo, &mx6_mmcd_calib, &mem_ddr); +} + +void board_init_f(ulong dummy) +{ + /* Setup AIPS and disable watchdog */ + arch_cpu_init(); + + ccgr_init(); + + /* Setup iomux and i2c */ + board_early_init_f(); + + /* Setup GP timer */ + timer_init(); + + /* UART clocks enabled and gd valid - init serial console */ + preloader_console_init(); + + /* DDR initialization */ + spl_dram_init(); +} diff --git a/board/ccv/xpress/xpress.c b/board/ccv/xpress/xpress.c new file mode 100644 index 0000000..6fc76cd --- /dev/null +++ b/board/ccv/xpress/xpress.c @@ -0,0 +1,331 @@ +/* + * Copyright (C) 2015-2016 Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/arch/clock.h> +#include <asm/arch/iomux.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/mx6ul_pins.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/boot_mode.h> +#include <asm/imx-common/mxc_i2c.h> +#include <asm/io.h> +#include <common.h> +#include <fsl_esdhc.h> +#include <i2c.h> +#include <miiphy.h> +#include <mmc.h> +#include <netdev.h> +#include <usb.h> +#include <usb/ehci-fsl.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_22K_UP | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define I2C_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ + PAD_CTL_ODE) + +#define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_PUE | \ + PAD_CTL_SPEED_HIGH | \ + PAD_CTL_DSE_48ohm | PAD_CTL_SRE_FAST) + +#define MDIO_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_PUE | \ + PAD_CTL_DSE_48ohm | PAD_CTL_SRE_FAST | PAD_CTL_ODE) + +#define ENET_CLK_PAD_CTRL (PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) + +#define ENET_RX_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_SPEED_HIGH | PAD_CTL_SRE_FAST) + +#define OTGID_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_HYS | \ + PAD_CTL_SRE_FAST) + +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) + +static struct i2c_pads_info i2c_pad_info1 = { + .scl = { + .i2c_mode = MX6_PAD_GPIO1_IO02__I2C1_SCL | PC, + .gpio_mode = MX6_PAD_GPIO1_IO02__GPIO1_IO02 | PC, + .gp = IMX_GPIO_NR(1, 2), + }, + .sda = { + .i2c_mode = MX6_PAD_GPIO1_IO03__I2C1_SDA | PC, + .gpio_mode = MX6_PAD_GPIO1_IO03__GPIO1_IO03 | PC, + .gp = IMX_GPIO_NR(1, 3), + }, +}; + +static struct i2c_pads_info i2c_pad_info2 = { + .scl = { + .i2c_mode = MX6_PAD_GPIO1_IO00__I2C2_SCL | PC, + .gpio_mode = MX6_PAD_GPIO1_IO00__GPIO1_IO00 | PC, + .gp = IMX_GPIO_NR(1, 0), + }, + .sda = { + .i2c_mode = MX6_PAD_GPIO1_IO01__I2C2_SDA | PC, + .gpio_mode = MX6_PAD_GPIO1_IO01__GPIO1_IO01 | PC, + .gp = IMX_GPIO_NR(1, 1), + }, +}; + +static struct i2c_pads_info i2c_pad_info4 = { + .scl = { + .i2c_mode = MX6_PAD_UART2_TX_DATA__I2C4_SCL | PC, + .gpio_mode = MX6_PAD_UART2_TX_DATA__GPIO1_IO20 | PC, + .gp = IMX_GPIO_NR(1, 20), + }, + .sda = { + .i2c_mode = MX6_PAD_UART2_RX_DATA__I2C4_SDA | PC, + .gpio_mode = MX6_PAD_UART2_RX_DATA__GPIO1_IO21 | PC, + .gp = IMX_GPIO_NR(1, 21), + }, +}; + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); + + return 0; +} + +static iomux_v3_cfg_t const uart1_pads[] = { + MX6_PAD_UART1_TX_DATA__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static iomux_v3_cfg_t const uart4_pads[] = { + MX6_PAD_UART4_TX_DATA__UART4_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_UART4_RX_DATA__UART4_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static iomux_v3_cfg_t const uart5_pads[] = { + MX6_PAD_GPIO1_IO04__UART5_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_GPIO1_IO05__UART5_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_GPIO1_IO09__UART5_DCE_CTS | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_GPIO1_IO08__UART5_DCE_RTS | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static iomux_v3_cfg_t const uart8_pads[] = { + MX6_PAD_ENET2_TX_DATA1__UART8_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_ENET2_TX_EN__UART8_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_ENET2_TX_CLK__UART8_DCE_CTS | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_ENET2_RX_ER__UART8_DCE_RTS | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static void setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); + imx_iomux_v3_setup_multiple_pads(uart4_pads, ARRAY_SIZE(uart4_pads)); + imx_iomux_v3_setup_multiple_pads(uart5_pads, ARRAY_SIZE(uart5_pads)); + imx_iomux_v3_setup_multiple_pads(uart8_pads, ARRAY_SIZE(uart8_pads)); +} + +/* eMMC on USDHC2 */ +static iomux_v3_cfg_t const usdhc2_pads[] = { + MX6_PAD_NAND_RE_B__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_WE_B__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA00__USDHC2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA01__USDHC2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA02__USDHC2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA03__USDHC2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA04__USDHC2_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA05__USDHC2_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA06__USDHC2_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NAND_DATA07__USDHC2_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + + /* + * RST_B + */ + MX6_PAD_NAND_ALE__USDHC2_RESET_B | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static struct fsl_esdhc_cfg usdhc_cfg = { + .esdhc_base = USDHC2_BASE_ADDR, + .max_bus_width = 8, +}; + +#define USDHC2_PWR_GPIO IMX_GPIO_NR(1, 9) + +int board_mmc_getcd(struct mmc *mmc) +{ + /* eMMC is always present */ + return 1; +} + +int board_mmc_init(bd_t *bis) +{ + imx_iomux_v3_setup_multiple_pads(usdhc2_pads, ARRAY_SIZE(usdhc2_pads)); + + usdhc_cfg.sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); + + return fsl_esdhc_initialize(bis, &usdhc_cfg); +} + +#define USB_OTHERREGS_OFFSET 0x800 +#define UCTRL_PWR_POL (1 << 9) + +static iomux_v3_cfg_t const usb_otg_pads[] = { + /* OTG1 */ + MX6_PAD_SD1_CMD__USB_OTG1_PWR | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD1_DATA0__ANATOP_OTG1_ID | MUX_PAD_CTRL(OTGID_PAD_CTRL), + /* OTG2 */ + MX6_PAD_SD1_DATA1__USB_OTG2_PWR | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD1_DATA3__ANATOP_OTG2_ID | MUX_PAD_CTRL(OTGID_PAD_CTRL), +}; + +static void setup_usb(void) +{ + imx_iomux_v3_setup_multiple_pads(usb_otg_pads, + ARRAY_SIZE(usb_otg_pads)); +} + +int board_usb_phy_mode(int port) +{ + if (port == 1) + return USB_INIT_HOST; + else + return usb_phy_mode(port); +} + +int board_ehci_hcd_init(int port) +{ + u32 *usbnc_usb_ctrl; + + if (port > 1) + return -EINVAL; + + usbnc_usb_ctrl = (u32 *)(USB_BASE_ADDR + USB_OTHERREGS_OFFSET + + port * 4); + + /* Set Power polarity */ + setbits_le32(usbnc_usb_ctrl, UCTRL_PWR_POL); + + return 0; +} + +static iomux_v3_cfg_t const fec1_pads[] = { + MX6_PAD_GPIO1_IO06__ENET1_MDIO | MUX_PAD_CTRL(MDIO_PAD_CTRL), + MX6_PAD_GPIO1_IO07__ENET1_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_TX_DATA0__ENET1_TDATA00 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_TX_DATA1__ENET1_TDATA01 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_TX_EN__ENET1_TX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 | MUX_PAD_CTRL(ENET_CLK_PAD_CTRL), + MX6_PAD_ENET1_RX_DATA0__ENET1_RDATA00 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_RX_DATA1__ENET1_RDATA01 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_RX_ER__ENET1_RX_ER | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_RX_EN__ENET1_RX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL), + + /* ENET1 reset */ + MX6_PAD_CSI_MCLK__GPIO4_IO17 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* ENET1 interrupt */ + MX6_PAD_CSI_PIXCLK__GPIO4_IO18 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +#define ENET_PHY_RESET_GPIO IMX_GPIO_NR(4, 17) + +int board_eth_init(bd_t *bis) +{ + int ret; + + imx_iomux_v3_setup_multiple_pads(fec1_pads, ARRAY_SIZE(fec1_pads)); + + /* Reset LAN8742 PHY */ + ret = gpio_request(ENET_PHY_RESET_GPIO, "phy-reset"); + if (!ret) + gpio_direction_output(ENET_PHY_RESET_GPIO , 0); + mdelay(10); + gpio_set_value(ENET_PHY_RESET_GPIO, 1); + mdelay(10); + + return cpu_eth_init(bis); +} + +static int setup_fec(int fec_id) +{ + struct iomuxc *const iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR; + int ret; + + /* + * Use 50M anatop loopback REF_CLK1 for ENET1, + * clear gpr1[13], set gpr1[17]. + */ + clrsetbits_le32(&iomuxc_regs->gpr[1], IOMUX_GPR1_FEC1_MASK, + IOMUX_GPR1_FEC1_CLOCK_MUX1_SEL_MASK); + + ret = enable_fec_anatop_clock(fec_id, ENET_50MHZ); + if (ret) + return ret; + + enable_enet_clk(1); + + return 0; +} + +int board_phy_config(struct phy_device *phydev) +{ + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} + +int board_early_init_f(void) +{ + setup_iomux_uart(); + + return 0; +} + +int board_init(void) +{ + /* Address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); + setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info2); + setup_i2c(3, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info4); + + setup_fec(CONFIG_FEC_ENET_DEV); + + setup_usb(); + + return 0; +} + +static const struct boot_mode board_boot_modes[] = { + /* 8 bit bus width */ + {"emmc", MAKE_CFGVAL(0x60, 0x28, 0x00, 0x00)}, + { NULL, 0 }, +}; + +int board_late_init(void) +{ + add_board_boot_modes(board_boot_modes); + setenv("board_name", "xpress"); + + return 0; +} + +int checkboard(void) +{ + puts("Board: CCV-EVA xPress\n"); + + return 0; +} diff --git a/configs/xpress_defconfig b/configs/xpress_defconfig new file mode 100644 index 0000000..033d32b --- /dev/null +++ b/configs/xpress_defconfig @@ -0,0 +1,6 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_TARGET_XPRESS=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/ccv/xpress/imximage.cfg" +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/xpress_spl_defconfig b/configs/xpress_spl_defconfig new file mode 100644 index 0000000..c2b1075 --- /dev/null +++ b/configs/xpress_spl_defconfig @@ -0,0 +1,7 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_TARGET_XPRESS=y +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/include/configs/xpress.h b/include/configs/xpress.h new file mode 100644 index 0000000..9bc536b --- /dev/null +++ b/include/configs/xpress.h @@ -0,0 +1,166 @@ +/* + * Copyright (C) 2015-2016 Stefan Roese sr@denx.de + * + * Configuration settings for the CCV xPress board + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef __XPRESS_CONFIG_H +#define __XPRESS_CONFIG_H + +#include "mx6_common.h" +#include <asm/imx-common/gpio.h> + +/* SPL options */ +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_MMC_SUPPORT +#include "imx6_spl.h" + +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (16 << 20) + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_LATE_INIT + +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART1_BASE + +/* MMC Configs */ +#define CONFIG_SYS_FSL_ESDHC_ADDR USDHC2_BASE_ADDR +#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */ + +/* I2C configs */ +#define CONFIG_CMD_I2C +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ +#define CONFIG_SYS_I2C_MXC_I2C4 /* enable I2C bus 4 */ +#define CONFIG_SYS_I2C_SPEED 100000 + +/* Miscellaneous configurable options */ +#define CONFIG_CMD_MEMTEST +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 0x10000000) + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_SYS_CONSOLE_INFO_QUIET +#define CONFIG_CMDLINE_EDITING + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR +#define PHYS_SDRAM_SIZE (128 << 20) + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH + +/* Environment is in stored in the eMMC boot partition */ +#define CONFIG_ENV_SIZE (16 << 10) +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_ENV_OFFSET (512 << 10) +#define CONFIG_SYS_MMC_ENV_DEV 0 /* USDHC2 */ +#define CONFIG_SYS_MMC_ENV_PART 1 /* boot parition */ +#define CONFIG_MMCROOT "/dev/mmcblk0p2" /* USDHC2 */ + +#define CONFIG_OF_LIBFDT +#define CONFIG_CMD_BOOTZ +#define CONFIG_CMD_BMODE +#define CONFIG_CMD_CACHE + +/* USB Configs */ +#define CONFIG_CMD_USB +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_MX6 +#define CONFIG_USB_STORAGE +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#define CONFIG_MXC_USB_FLAGS 0 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 + +#define CONFIG_FEC_MXC +#define CONFIG_MII +#define CONFIG_CMD_MII +#define CONFIG_FEC_ENET_DEV 0 +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_MXC_PHYADDR 0x0 +#define CONFIG_FEC_XCV_TYPE RMII +#define CONFIG_ETHPRIME "FEC" +#define CONFIG_PHYLIB +#define CONFIG_PHY_SMSC + +#define CONFIG_IMX_THERMAL + +#define CONFIG_SYS_MMC_IMG_LOAD_PART 1 + +#define CONFIG_UBOOT_SECTOR_START 0x2 +#define CONFIG_UBOOT_SECTOR_COUNT 0x3fe + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "script=boot.scr\0" \ + "image=zImage\0" \ + "console=ttymxc0\0" \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "fdt_file=undefined\0" \ + "fdt_addr=0x83000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ + "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ + "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ + "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ + "mmcautodetect=yes\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "bootz ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootz; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootz; " \ + "fi;\0" \ + "uboot=ccv/u-boot.imx\0" \ + "uboot_start="__stringify(CONFIG_UBOOT_SECTOR_START)"\0" \ + "uboot_size="__stringify(CONFIG_UBOOT_SECTOR_COUNT)"\0" \ + "update_uboot=if tftp ${uboot}; then " \ + "if itest ${filesize} > 0; then " \ + "mmc dev 0 1;" \ + "setexpr blkc ${filesize} / 0x200;" \ + "setexpr blkc ${blkc} + 1;" \ + "if itest ${blkc} <= ${uboot_size}; then " \ + "mmc write ${loadaddr} ${uboot_start} " \ + "${blkc};" \ + "fi;" \ + "fi; fi;" \ + "setenv filesize; setenv blkc\0" \ + "update_bootpart=mmc bootbus 0 2 1 2;mmc partconf 0 1 1 0\0" + +#endif /* __XPRESS_CONFIG_H */
- 128MiB DDR
- UART
- I2C
- Ethernet
- USB
- bool "CCV xPress"
- select MX6UL
- select DM
- select DM_THERMAL
- select SUPPORT_SPL
endchoice
+config SYS_BOARD
- default "xpress"
+config SYS_VENDOR
- default "ccv"
- default "xpress"
- Copyright (C) 2015-2016 Stefan Roese sr@denx.de
- Refer docs/README.imxmage for more details about how-to configure
- and create imximage boot image
- The syntax is taken as close as possible with the kwbimage
+IMAGE_VERSION 2
- Boot Device : one of
- sd, nand
+BOOT_FROM sd
- Device Configuration Data (DCD)
- Each entry must have the format:
- Addr-type Address Value
- where:
- DDR Controller Registers
- Manufacturer: IM
- Device Part Number: IME1G16D3EEBG-15EI
- Clock Freq.: 400MHz
- Density per CS in Gb: 1
- Chip Selects used: 1
- Number of Banks: 8
- Row address: 13
- Column address: 10
- Data bus width 16
- Calibration setup
- For target board, may need to run write leveling calibration to fine tune
- these settings.
- read data bit delay: (3 is the reccommended default value, although out of
- reset value is 0)
- Calibration setup end
- MDMISC: RALAT kept to the high level of 5.
- MDMISC: consider reducing RALAT if your 528MHz board design allow that.
- Lower RALAT benefits:
- a. better operation at low frequency, for LPDDR2 freq < 100MHz, change RALAT
- to 3
- b. Small performence improvment
device on CS0 */
complete) */
- SPL specific code for CCV xPress
- .grp_addds = 0x00000030,
- .grp_ddrmode_ctl = 0x00020000,
- .grp_b0ds = 0x00000030,
- .grp_ctlds = 0x00000030,
- .grp_b1ds = 0x00000030,
- .grp_ddrpke = 0x00000000,
- .grp_ddrmode = 0x00020000,
- .grp_ddr_type = 0x000c0000,
- .dram_dqm0 = 0x00000030,
- .dram_dqm1 = 0x00000030,
- .dram_ras = 0x00000030,
- .dram_cas = 0x00000030,
- .dram_odt0 = 0x00000030,
- .dram_odt1 = 0x00000030,
- .dram_sdba2 = 0x00000000,
- .dram_sdclk_0 = 0x00000008,
- .dram_sdqs0 = 0x00000038,
- .dram_sdqs1 = 0x00000030,
- .dram_reset = 0x00000030,
- .p0_mpwldectrl0 = 0x00000000,
- .p0_mpdgctrl0 = 0x4164015C,
- .p0_mprddlctl = 0x40404446,
- .p0_mpwrdlctl = 0x40405A52,
- .dsize = 0,
- .cs_density = 20,
- .ncs = 1,
- .cs1_mirror = 0,
- .rtt_wr = 2,
- .rtt_nom = 1, /* RTT_Nom = RZQ/2 */
- .walat = 1, /* Write additional latency */
- .ralat = 5, /* Read additional latency */
- .mif3_mode = 3, /* Command prediction working mode */
- .bi_on = 1, /* Bank interleaving enabled */
- .sde_to_rst = 0x10, /* 14 cycles, 200us (JEDEC default) */
- .rst_to_cke = 0x23, /* 33 cycles, 500us (JEDEC default) */
- .ddr_type = DDR_TYPE_DDR3,
- .mem_speed = 800,
- .density = 4,
- .width = 16,
- .banks = 8,
- .rowaddr = 13,
- .coladdr = 10,
- .pagesz = 2,
- .trcd = 1375,
- .trcmin = 4875,
- .trasmin = 3500,
- struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR;
- writel(0xFFFFFFFF, &ccm->CCGR0);
- writel(0xFFFFFFFF, &ccm->CCGR1);
- writel(0xFFFFFFFF, &ccm->CCGR2);
- writel(0xFFFFFFFF, &ccm->CCGR3);
- writel(0xFFFFFFFF, &ccm->CCGR4);
- writel(0xFFFFFFFF, &ccm->CCGR5);
- writel(0xFFFFFFFF, &ccm->CCGR6);
- writel(0xFFFFFFFF, &ccm->CCGR7);
- mx6ul_dram_iocfg(mem_ddr.width, &mx6_ddr_ioregs, &mx6_grp_ioregs);
- mx6_dram_cfg(&ddr_sysinfo, &mx6_mmcd_calib, &mem_ddr);
- /* Setup AIPS and disable watchdog */
- arch_cpu_init();
- ccgr_init();
- /* Setup iomux and i2c */
- board_early_init_f();
- /* Setup GP timer */
- timer_init();
- /* UART clocks enabled and gd valid - init serial console */
- preloader_console_init();
- /* DDR initialization */
- spl_dram_init();
- PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \
- PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
- PAD_CTL_PUS_22K_UP | PAD_CTL_SPEED_LOW | \
- PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
- PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \
- PAD_CTL_ODE)
- PAD_CTL_SPEED_HIGH | \
- PAD_CTL_DSE_48ohm | PAD_CTL_SRE_FAST)
- PAD_CTL_DSE_48ohm | PAD_CTL_SRE_FAST | PAD_CTL_ODE)
- PAD_CTL_SPEED_HIGH | PAD_CTL_SRE_FAST)
- PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_LOW | \
- PAD_CTL_DSE_80ohm | PAD_CTL_HYS | \
- PAD_CTL_SRE_FAST)
- .scl = {
- .sda = {
- .scl = {
- .sda = {
- .scl = {
- .sda = {
- gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE);
- MX6_PAD_UART1_TX_DATA__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_UART4_TX_DATA__UART4_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_UART4_RX_DATA__UART4_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_GPIO1_IO04__UART5_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_GPIO1_IO05__UART5_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_GPIO1_IO09__UART5_DCE_CTS | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_GPIO1_IO08__UART5_DCE_RTS | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_ENET2_TX_DATA1__UART8_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_ENET2_TX_EN__UART8_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_ENET2_TX_CLK__UART8_DCE_CTS | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_ENET2_RX_ER__UART8_DCE_RTS | MUX_PAD_CTRL(UART_PAD_CTRL),
- imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads));
- imx_iomux_v3_setup_multiple_pads(uart4_pads, ARRAY_SIZE(uart4_pads));
- imx_iomux_v3_setup_multiple_pads(uart5_pads, ARRAY_SIZE(uart5_pads));
- imx_iomux_v3_setup_multiple_pads(uart8_pads, ARRAY_SIZE(uart8_pads));
- MX6_PAD_NAND_RE_B__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_NAND_WE_B__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_NAND_DATA00__USDHC2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_NAND_DATA01__USDHC2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_NAND_DATA02__USDHC2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_NAND_DATA03__USDHC2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_NAND_DATA04__USDHC2_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_NAND_DATA05__USDHC2_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_NAND_DATA06__USDHC2_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_NAND_DATA07__USDHC2_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
* RST_B
- MX6_PAD_NAND_ALE__USDHC2_RESET_B | MUX_PAD_CTRL(NO_PAD_CTRL),
- .esdhc_base = USDHC2_BASE_ADDR,
- .max_bus_width = 8,
- /* eMMC is always present */
- return 1;
- imx_iomux_v3_setup_multiple_pads(usdhc2_pads, ARRAY_SIZE(usdhc2_pads));
- usdhc_cfg.sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK);
- return fsl_esdhc_initialize(bis, &usdhc_cfg);
- /* OTG1 */
- MX6_PAD_SD1_CMD__USB_OTG1_PWR | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_SD1_DATA0__ANATOP_OTG1_ID | MUX_PAD_CTRL(OTGID_PAD_CTRL),
- /* OTG2 */
- MX6_PAD_SD1_DATA1__USB_OTG2_PWR | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_SD1_DATA3__ANATOP_OTG2_ID | MUX_PAD_CTRL(OTGID_PAD_CTRL),
- imx_iomux_v3_setup_multiple_pads(usb_otg_pads,
- if (port == 1)
- else
- u32 *usbnc_usb_ctrl;
- if (port > 1)
return -EINVAL;
- usbnc_usb_ctrl = (u32 *)(USB_BASE_ADDR + USB_OTHERREGS_OFFSET +
port * 4);
- /* Set Power polarity */
- setbits_le32(usbnc_usb_ctrl, UCTRL_PWR_POL);
- MX6_PAD_GPIO1_IO06__ENET1_MDIO | MUX_PAD_CTRL(MDIO_PAD_CTRL),
- MX6_PAD_GPIO1_IO07__ENET1_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET1_TX_DATA0__ENET1_TDATA00 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET1_TX_DATA1__ENET1_TDATA01 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET1_TX_EN__ENET1_TX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 | MUX_PAD_CTRL(ENET_CLK_PAD_CTRL),
- MX6_PAD_ENET1_RX_DATA0__ENET1_RDATA00 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET1_RX_DATA1__ENET1_RDATA01 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET1_RX_ER__ENET1_RX_ER | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET1_RX_EN__ENET1_RX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL),
- /* ENET1 reset */
- MX6_PAD_CSI_MCLK__GPIO4_IO17 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* ENET1 interrupt */
- MX6_PAD_CSI_PIXCLK__GPIO4_IO18 | MUX_PAD_CTRL(NO_PAD_CTRL),
- int ret;
- imx_iomux_v3_setup_multiple_pads(fec1_pads, ARRAY_SIZE(fec1_pads));
- /* Reset LAN8742 PHY */
- ret = gpio_request(ENET_PHY_RESET_GPIO, "phy-reset");
- if (!ret)
- mdelay(10);
- gpio_set_value(ENET_PHY_RESET_GPIO, 1);
- mdelay(10);
- return cpu_eth_init(bis);
- struct iomuxc *const iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR;
- int ret;
- clrsetbits_le32(&iomuxc_regs->gpr[1], IOMUX_GPR1_FEC1_MASK,
- ret = enable_fec_anatop_clock(fec_id, ENET_50MHZ);
- if (ret)
return ret;
- enable_enet_clk(1);
- if (phydev->drv->config)
- setup_iomux_uart();
- /* Address of boot parameters */
- gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1);
- setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info2);
- setup_i2c(3, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info4);
- setup_fec(CONFIG_FEC_ENET_DEV);
- setup_usb();
- /* 8 bit bus width */
- {"emmc", MAKE_CFGVAL(0x60, 0x28, 0x00, 0x00)},
- { NULL, 0 },
- add_board_boot_modes(board_boot_modes);
- setenv("board_name", "xpress");
- puts("Board: CCV-EVA xPress\n");
- Configuration settings for the CCV xPress board
- (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
- (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
- "script=boot.scr\0" \
- "image=zImage\0" \
- "console=ttymxc0\0" \
- "fdt_high=0xffffffff\0" \
- "initrd_high=0xffffffff\0" \
- "fdt_file=undefined\0" \
- "fdt_addr=0x83000000\0" \
- "boot_fdt=try\0" \
- "ip_dyn=yes\0" \
- "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \
- "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \
- "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \
- "mmcautodetect=yes\0" \
- "mmcargs=setenv bootargs console=${console},${baudrate} " \
- "loadbootscript=" \
- "bootscript=echo Running bootscript from mmc ...; " \
"source\0" \
- "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \
- "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \
- "mmcboot=echo Booting from mmc ...; " \
"run mmcargs; " \
"else " \
"bootz; " \
"else " \
"fi; " \
"fi; " \
"else " \
"bootz; " \
"fi;\0" \
- "uboot=ccv/u-boot.imx\0" \
- "uboot_start="__stringify(CONFIG_UBOOT_SECTOR_START)"\0" \
- "uboot_size="__stringify(CONFIG_UBOOT_SECTOR_COUNT)"\0" \
- "update_uboot=if tftp ${uboot}; then " \
"mmc dev 0 1;" \
"${blkc};" \
"fi;" \
"fi; fi;" \
- "update_bootpart=mmc bootbus 0 2 1 2;mmc partconf 0 1 1 0\0"
Reviewed-by : Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Stefan Roese
Stefano Babic
