[U-Boot] [PATCH] imx: imx8m: fix boot when CONFIG_$(SPL_)CLK not defined
When CONFIG_$(SPL_)CLK not defined, the clock controller device not exist, so to avoid boot failure for platform not have CONFIG_$(SPL_)CLK, add a check.
Reviewed-by: Patrick Wildt patrick@blueri.se Tested-by: Patrick Wildt patrick@blueri.se Signed-off-by: Peng Fan peng.fan@nxp.com ---
V1: Based on pull request https://github.com/MrVan/u-boot/tree/imx-master-10-15
arch/arm/mach-imx/imx8m/soc.c | 14 ++++++++------ 1 file changed, 8 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index c46031dd12..3e73ca3cca 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -236,12 +236,14 @@ int arch_cpu_init_dm(void) struct udevice *dev; int ret;
- ret = uclass_get_device_by_name(UCLASS_CLK, - "clock-controller@30380000", - &dev); - if (ret < 0) { - printf("Failed to find clock node. Check device tree\n"); - return ret; + if (CONFIG_IS_ENABLED(CLK)) { + ret = uclass_get_device_by_name(UCLASS_CLK, + "clock-controller@30380000", + &dev); + if (ret < 0) { + printf("Failed to find clock node. Check device tree\n"); + return ret; + } }
Peng Fan
