[U-Boot-Users] [PATCH 2/2] Remove the obsolete terse version of do_mii()
We now have more useful version of do_mii() and everybody use it. Grald Van Baren says
When I originally wrote the mii command 6(!) years ago, I wrote a verbose version that printed human readable decomposition of the flags, etc., and a terse one that didn't print as much stuff and thus had a smaller memory footprint.
It sounds like the terse version has withered and died, apparently people are only using the verbose version (which is very understandable, I do myself).
Signed-off-by: Shinya Kuribayashi shinya.kuribayashi@necel.com Signed-off-by: Gerald Van Baren vanbaren@cideas.com ---
common/cmd_mii.c | 139 ------------------------------------------------------ 1 files changed, 0 insertions(+), 139 deletions(-)
diff --git a/common/cmd_mii.c b/common/cmd_mii.c index b99bd06..e44e45c 100644 --- a/common/cmd_mii.c +++ b/common/cmd_mii.c @@ -29,143 +29,6 @@ #include <command.h> #include <miiphy.h>
-#ifdef CONFIG_TERSE_MII -/* - * Display values from last command. - */ -uint last_op; -uint last_addr; -uint last_data; -uint last_reg; - -/* - * MII device/info/read/write - * - * Syntax: - * mii device {devname} - * mii info {addr} - * mii read {addr} {reg} - * mii write {addr} {reg} {data} - */ -int do_mii (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) -{ - char op; - unsigned char addr, reg; - unsigned short data; - int rcode = 0; - char *devname; - - if (argc < 2) { - printf ("Usage:\n%s\n", cmdtp->usage); - return 1; - } - -#if defined(CONFIG_8xx) || defined(CONFIG_MCF52x2) - mii_init (); -#endif - - /* - * We use the last specified parameters, unless new ones are - * entered. - */ - op = last_op; - addr = last_addr; - data = last_data; - reg = last_reg; - - if ((flag & CMD_FLAG_REPEAT) == 0) { - op = argv[1][0]; - if (argc >= 3) - addr = simple_strtoul (argv[2], NULL, 16); - if (argc >= 4) - reg = simple_strtoul (argv[3], NULL, 16); - if (argc >= 5) - data = simple_strtoul (argv[4], NULL, 16); - } - - /* use current device */ - devname = miiphy_get_current_dev(); - - /* - * check device/read/write/list. - */ - if (op == 'i') { - unsigned char j, start, end; - unsigned int oui; - unsigned char model; - unsigned char rev; - - /* - * Look for any and all PHYs. Valid addresses are 0..31. - */ - if (argc >= 3) { - start = addr; end = addr + 1; - } else { - start = 0; end = 31; - } - - for (j = start; j < end; j++) { - if (miiphy_info (devname, j, &oui, &model, &rev) == 0) { - printf ("PHY 0x%02X: " - "OUI = 0x%04X, " - "Model = 0x%02X, " - "Rev = 0x%02X, " - "%3dbase%s, %s\n", - j, oui, model, rev, - miiphy_speed (devname, j), - miiphy_is_1000base_x (devname, j) - ? "X" : "T", - (miiphy_duplex (devname, j) == FULL) - ? "FDX" : "HDX"); - } - } - } else if (op == 'r') { - if (miiphy_read (devname, addr, reg, &data) != 0) { - puts ("Error reading from the PHY\n"); - rcode = 1; - } else { - printf ("%04X\n", data & 0x0000FFFF); - } - } else if (op == 'w') { - if (miiphy_write (devname, addr, reg, data) != 0) { - puts ("Error writing to the PHY\n"); - rcode = 1; - } - } else if (op == 'd') { - if (argc == 2) - miiphy_listdev (); - else - miiphy_set_current_dev (argv[2]); - } else { - printf ("Usage:\n%s\n", cmdtp->usage); - return 1; - } - - /* - * Save the parameters for repeats. - */ - last_op = op; - last_addr = addr; - last_data = data; - last_reg = reg; - - return rcode; -} - -/***************************************************/ - -U_BOOT_CMD( - mii, 5, 1, do_mii, - "mii - MII utility commands\n", - "device - list available devices\n" - "mii device <devname> - set current device\n" - "mii info <addr> - display MII PHY info\n" - "mii read <addr> <reg> - read MII PHY <addr> register <reg>\n" - "mii write <addr> <reg> <data> - write MII PHY <addr> register <reg>\n" -); - -#else /* ! CONFIG_TERSE_MII ================================================= */ - typedef struct _MII_reg_desc_t { ushort regno; char * name; @@ -601,5 +464,3 @@ U_BOOT_CMD( "mii dump <addr> <reg> - pretty-print <addr> <reg> (0-5 only)\n" "Addr and/or reg may be ranges, e.g. 2-7.\n" ); - -#endif /* CONFIG_TERSE_MII */
Hi Shinya,
Thanks for the patch to clean this up. While I agree with the patch, I would appreciate respinning it: * I should be an "Acked by" rather than a signed off by since I didn't do anything to generate the patch itself.
* I would also offer the following summary rather than quoting my original email (including the 6(!) year reference, which will look kinda funny in 2012 ;-):
Remove the "terse" version of the mii command, eliminating an #ifdef and apparently unused code. The space savings of the "terse" version is not significant and it isn't worth the extra maintenance effort to keep it.
Acked-by: Gerald Van Baren vanbaren@cideas.com
Thanks, gvb
- I should be an "Acked by" rather than a signed off by since I didn't
As you are the original writer, IMHO you could/should signed-off-by :-) But it was my bad to add your sign without asking you. I'll resubmit the patch later with your acked-by.
- I would also offer the following summary rather than quoting my
Thanks for your kind summary.
Shinya
I figure that an acked-by is more appropriate than a signed-off-by because, while I approve of the patch, I didn't actually contribute to it directly (I contributed the anti-patch, that is, the code that is being removed... but that already has my signed-off-by on it).
Shinya
Thanks for rerolling, gvb
Signed-off-by: Shinya Kuribayashi shinya.kuribayashi@necel.com Acked-by: Gerald Van Baren vanbaren@cideas.com ---
Applied, thanks.
Applied, thanks.
It isn't a big deal, but Shinya re-rolled this with a better description and my "acked by" rather than "SOB".
Best regards, gvb
Applied, thanks.
...here http://article.gmane.org/gmane.comp.boot-loaders.u-boot/34682/match=kuribayashi
gvb
participants (5)
gvb.uboot
Jerry Van Baren
Shinya Kuribayashi
Shinya Kuribayashi
