[PATCH] efi_loader: check update capsule parameters
UpdateCapsule() must return EFI_INVALID_PARAMETER in a number of cases, listed by the UEFI specification and tested by the SCT. Add a common function to do that.
This fixes SCT UpdateCapsule_Conf failures.
Reviewed-by: Grant Likely grant.likely@arm.com Signed-off-by: Vincent Stehlé vincent.stehle@arm.com Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Alexander Graf agraf@csgraf.de --- include/efi_loader.h | 24 ++++++++++++++++++++++++ lib/efi_loader/efi_capsule.c | 8 ++++---- lib/efi_loader/efi_runtime.c | 8 ++++++++ 3 files changed, 36 insertions(+), 4 deletions(-)
diff --git a/include/efi_loader.h b/include/efi_loader.h index 0a9c82a257e..426d1c72d7d 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -910,6 +910,30 @@ extern const struct efi_firmware_management_protocol efi_fmp_fit; extern const struct efi_firmware_management_protocol efi_fmp_raw;
/* Capsule update */ +static inline efi_status_t +efi_valid_update_capsule_params(struct efi_capsule_header + **capsule_header_array, + efi_uintn_t capsule_count, + u64 scatter_gather_list) +{ + u32 flags; + + if (!capsule_count) + return EFI_INVALID_PARAMETER; + + flags = capsule_header_array[0]->flags; + + if (((flags & CAPSULE_FLAGS_PERSIST_ACROSS_RESET) && + !scatter_gather_list) || + ((flags & CAPSULE_FLAGS_POPULATE_SYSTEM_TABLE) && + !(flags & CAPSULE_FLAGS_PERSIST_ACROSS_RESET)) || + ((flags & CAPSULE_FLAGS_INITIATE_RESET) && + !(flags & CAPSULE_FLAGS_PERSIST_ACROSS_RESET))) + return EFI_INVALID_PARAMETER; + + return EFI_SUCCESS; +} + efi_status_t EFIAPI efi_update_capsule( struct efi_capsule_header **capsule_header_array, efi_uintn_t capsule_count, diff --git a/lib/efi_loader/efi_capsule.c b/lib/efi_loader/efi_capsule.c index 60309d4a07d..380cfd70290 100644 --- a/lib/efi_loader/efi_capsule.c +++ b/lib/efi_loader/efi_capsule.c @@ -442,12 +442,12 @@ efi_status_t EFIAPI efi_update_capsule( EFI_ENTRY("%p, %zu, %llu\n", capsule_header_array, capsule_count, scatter_gather_list);
- if (!capsule_count) { - ret = EFI_INVALID_PARAMETER; + ret = efi_valid_update_capsule_params(capsule_header_array, + capsule_count, + scatter_gather_list); + if (ret != EFI_SUCCESS) goto out; - }
- ret = EFI_SUCCESS; for (i = 0, capsule = *capsule_header_array; i < capsule_count; i++, capsule = *(++capsule_header_array)) { /* sanity check */ diff --git a/lib/efi_loader/efi_runtime.c b/lib/efi_loader/efi_runtime.c index 93a695fc27e..449ad8b9f36 100644 --- a/lib/efi_loader/efi_runtime.c +++ b/lib/efi_loader/efi_runtime.c @@ -467,6 +467,14 @@ efi_status_t __efi_runtime EFIAPI efi_update_capsule_unsupported( efi_uintn_t capsule_count, u64 scatter_gather_list) { + efi_status_t ret; + + ret = efi_valid_update_capsule_params(capsule_header_array, + capsule_count, + scatter_gather_list); + if (ret != EFI_SUCCESS) + return ret; + return EFI_UNSUPPORTED; }
Cc: Takahiro, Sughosh, Ilias
- u32 flags;
If capsule count > 1, don't you have to check all capsules headers?
- flags = capsule_header_array[0]->flags;
- if (((flags & CAPSULE_FLAGS_PERSIST_ACROSS_RESET) &&
What happens if capsule(0) has CAPSULE_FLAGS_INITIATE_RESET and capsule(4) has !CAPSULE_FLAGS_PERSIST_ACROSS_RESET?
Best regards
Heinrich
- return EFI_SUCCESS;
- efi_status_t EFIAPI efi_update_capsule( struct efi_capsule_header **capsule_header_array, efi_uintn_t capsule_count,
- ret = efi_valid_update_capsule_params(capsule_header_array,
capsule_count,
- if (ret != EFI_SUCCESS) goto out;
- efi_status_t ret;
capsule_count,
return ret;
- return EFI_UNSUPPORTED; }
Hi Vincent,
Thank you for the update.
First of all, I would like to make clear one thing: My initial implementation of capsule support does *not* intend to support "UpdateCapsule" as runtime API. Instead, the sole objective is to provide "delivery of capsules via file" (or capsule on disk) method.
This is because the initially-expected use case was that we would adopt capsules as an alternative for updating UEFI variables without using SetVariable runtime API. (This idea is no longer upheld, though.)
This is why the API does not handle nor check parameters in the current code. I even regret to have added EFI_RUNTIME_UPDATE_CAPSULE option, which makes people confused.
Nevertheless, I'm more than happy if other folks implement full semantics of UpdateCapsule.
- u32 flags;
Best regards
Heinrich
capsule_count,
- efi_status_t ret;
capsule_count,
This is "efi_update_capsule_unsupported" function. We don't have to check parameters.
-Takahiro Akashi
return ret;
On 6/12/21 2:13 AM, AKASHI Takahiro wrote:
Hi Vincent,
- u32 flags;
Best regards
Heinrich
capsule_count,
- efi_status_t ret;
capsule_count,
-Takahiro Akashi
Hello Vincent,
I will mark this patch as "changes requested". Please, send an updated version.
Best regards
Heinrich
return ret;
AKASHI Takahiro
Vincent Stehlé
