[U-Boot] [PATCH] dm: core: Add dev_get_addr_size_index() to retrieve addr and size
The currently available functions accessing the 'reg' property of a device only retrieve the address. Sometimes its also necessary to retrieve the size described by the 'reg' property. This patch adds the new function dev_get_addr_size_index() which retrieves both, the address and the size described by the 'reg' property.
Signed-off-by: Stefan Roese sr@denx.de Cc: Simon Glass sjg@chromium.org --- drivers/core/device.c | 22 ++++++++++++++++++++++ include/dm/device.h | 16 ++++++++++++++++ 2 files changed, 38 insertions(+)
diff --git a/drivers/core/device.c b/drivers/core/device.c index dcf5d9d..ec43654 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -693,6 +693,28 @@ fdt_addr_t dev_get_addr_index(struct udevice *dev, int index) #endif }
+fdt_addr_t dev_get_addr_size_index(struct udevice *dev, int index, + fdt_size_t *size) +{ +#if CONFIG_IS_ENABLED(OF_CONTROL) + /* + * Only get the size in this first call. We'll get the addr in the + * next call to the exisiting dev_get_xxx function which handles + * all config options. + */ + fdtdec_get_addr_size_auto_noparent(gd->fdt_blob, dev->of_offset, + "reg", 1, size, false); + + /* + * Get the base address via the existing function which handles + * all Kconfig cases + */ + return dev_get_addr_index(dev, index); +#else + return FDT_ADDR_T_NONE; +#endif +} + fdt_addr_t dev_get_addr_name(struct udevice *dev, const char *name) { #if CONFIG_IS_ENABLED(OF_CONTROL) diff --git a/include/dm/device.h b/include/dm/device.h index babf8ac..9948bd4 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -497,6 +497,22 @@ void *dev_map_physmem(struct udevice *dev, unsigned long size); fdt_addr_t dev_get_addr_index(struct udevice *dev, int index);
/** + * dev_get_addr_size_index() - Get the indexed reg property of a device + * + * Returns the address and size specified in the 'reg' property of a device. + * + * @dev: Pointer to a device + * @index: the 'reg' property can hold a list of <addr, size> pairs + * and @index is used to select which one is required + * @size: Pointer to size varible - this function returns the size + * specified in the 'reg' property here + * + * @return addr + */ +fdt_addr_t dev_get_addr_size_index(struct udevice *dev, int index, + fdt_size_t *size); + +/** * dev_get_addr_name() - Get the reg property of a device, indexed by name * * @dev: Pointer to a device
Hi Stefan,
fdt_size_t *size)
Does this take account of 'index'?
* all Kconfig cases
+#else
+#endif +}
- dev_get_addr_size_index() - Get the indexed reg property of a device
- Returns the address and size specified in the 'reg' property of a device.
- @dev: Pointer to a device
- @index: the 'reg' property can hold a list of <addr, size> pairs
- @size: Pointer to size varible - this function returns the size
- @return addr
fdt_size_t *size);
- dev_get_addr_name() - Get the reg property of a device, indexed by name
-- 2.10.2
Hi Simon,
fdt_size_t *size)
No, copy and paste error. Thanks for spotting. v2 will follow soon.
Thanks, Stefan
Stefan Roese
