[PATCH v3] rockchip: include: asm: fix entering download mode rk3066
Keep track of the re-entries with help of the lr register. This binary can be re-used and called from various BROM functions. Only when it's called from the part that handles SPI, NAND or EMMC hardware it needs to early return to BROM ones. In download mode when it handles data on USB OTG and UART0 this section must be skipped.
Unlike newer Rockchip SoC models the rk3066 BROM code does not have built-in support to enter download mode on return to BROM. This binary must check the boot mode register for the BOOT_BROM_DOWNLOAD flag and reset if it's set. It then returns to BROM to the end of the function that reads boot blocks.
From there the BROM code goes into a download mode and waits for data
on USB OTG and UART0.
Signed-off-by: Johan Jonker jbx6244@gmail.com ---
Note: Normal U-boot flow is OK. In download mode this binary hangs after return to BROM for unknown reasons. Replace CODE471_OPTION with 30_LPDDR2_300MHz_DD.bin for now.
Changed V3: Kconfig option for rk3066 only Restyle
Changed V2: Move file to rk3066 specific location Replace retry_counter by LR check Add DNL mode return address Restyle Reword --- arch/arm/include/asm/arch-rk3066/boot0.h | 77 +++++++++++++++++++++++- arch/arm/mach-rockchip/Kconfig | 2 +- arch/arm/mach-rockchip/rk3066/Kconfig | 8 +++ 3 files changed, 85 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-rk3066/boot0.h b/arch/arm/include/asm/arch-rk3066/boot0.h index 28c0fb9a4c6b..6bf3828c84e9 100644 --- a/arch/arm/include/asm/arch-rk3066/boot0.h +++ b/arch/arm/include/asm/arch-rk3066/boot0.h @@ -3,6 +3,81 @@ #ifndef __ASM_ARCH_BOOT0_H__ #define __ASM_ARCH_BOOT0_H__
-#include <asm/arch-rockchip/boot0.h> +#include <asm/arch-rockchip/boot_mode.h>
+/* + * Execution starts on the instruction following this 4-byte header + * (containing the magic 'RK30'). This magic constant will be written into + * the final image by the rkimage tool, but we need to reserve space for it here. + */ +#ifdef CONFIG_SPL_BUILD + b 1f /* if overwritten, entry-address is at the next word */ +1: +#endif + +#if CONFIG_IS_ENABLED(ROCKCHIP_EARLYRETURN_TO_BROM) +/* + * Keep track of the re-entries with help of the lr register. + * This binary can be re-used and called from various BROM functions. + * Only when it's called from the part that handles SPI, NAND or EMMC + * hardware it needs to early return to BROM ones. + * In download mode when it handles data on USB OTG and UART0 + * this section must be skipped. + */ + ldr r3, =CONFIG_ROCKCHIP_BOOT_LR_REG + cmp lr, r3 /* if (LR != CONFIG_ROCKCHIP_BOOT_LR_REG) */ + bne reset /* goto reset; */ +/* + * Unlike newer Rockchip SoC models the rk3066 BROM code does not have built-in + * support to enter download mode on return to BROM. This binary must check + * the boot mode register for the BOOT_BROM_DOWNLOAD flag and reset if it's set. + * It then returns to BROM to the end of the function that reads boot blocks. + * From there the BROM code goes into a download mode and waits for data + * on USB OTG and UART0. + */ + ldr r2, =BOOT_BROM_DOWNLOAD + ldr r3, =CONFIG_ROCKCHIP_BOOT_MODE_REG + ldr r0, [r3] /* if (readl(CONFIG_ROCKCHIP_BOOT_MODE_REG) != */ + cmp r0, r2 /* BOOT_BROM_DOWNLOAD) { */ + bne early_return /* goto early_return; */ + /* } else { */ + mov r0, #0 + str r0, [r3] /* writel(0, CONFIG_ROCKCHIP_BOOT_MODE_REG); */ + + ldr r3, =CONFIG_ROCKCHIP_BOOT_RETURN_REG + bx r3 /* return to CONFIG_ROCKCHIP_BOOT_RETURN_REG;*/ + /* } */ +early_return: + bx lr /* return to LR in BROM */ + +SAVE_SP_ADDR: + .word 0 + + .globl save_boot_params +save_boot_params: + push {r1-r12, lr} + ldr r0, =SAVE_SP_ADDR + str sp, [r0] + b save_boot_params_ret + + .globl back_to_bootrom +back_to_bootrom: + ldr r0, =SAVE_SP_ADDR + ldr sp, [r0] + mov r0, #0 + pop {r1-r12, pc} +#endif + +#if (defined(CONFIG_SPL_BUILD)) +/* U-Boot proper of armv7 does not need this */ + b reset +#endif + +/* + * For armv7, the addr '_start' will be used as vector start address + * and is written to the VBAR register, which needs to aligned to 0x20. + */ + .align(5), 0x0 +_start: + ARM_VECTORS #endif diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index c43c185c17c5..6c56324f66bc 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -401,7 +401,7 @@ config SPL_ROCKCHIP_BACK_TO_BROM config TPL_ROCKCHIP_BACK_TO_BROM bool "TPL returns to bootrom" default y - select ROCKCHIP_BROM_HELPER + select ROCKCHIP_BROM_HELPER if !ROCKCHIP_RK3066 select TPL_BOOTROM_SUPPORT depends on TPL help diff --git a/arch/arm/mach-rockchip/rk3066/Kconfig b/arch/arm/mach-rockchip/rk3066/Kconfig index 95d7fc8a2917..4a79a829adec 100644 --- a/arch/arm/mach-rockchip/rk3066/Kconfig +++ b/arch/arm/mach-rockchip/rk3066/Kconfig @@ -10,6 +10,14 @@ config TARGET_MK808 config ROCKCHIP_BOOT_MODE_REG default 0x20004040
+config ROCKCHIP_BOOT_LR_REG + hex + default 0x00001058 + +config ROCKCHIP_BOOT_RETURN_REG + hex + default 0x00001100 + config SYS_SOC default "rk3066"
-- 2.39.2
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- Execution starts on the instruction following this 4-byte header
- (containing the magic 'RK30'). This magic constant will be written into
- the final image by the rkimage tool, but we need to reserve space for it here.
- b 1f /* if overwritten, entry-address is at the next word */
+1: +#endif
- Keep track of the re-entries with help of the lr register.
- This binary can be re-used and called from various BROM functions.
- Only when it's called from the part that handles SPI, NAND or EMMC
- hardware it needs to early return to BROM ones.
- In download mode when it handles data on USB OTG and UART0
- this section must be skipped.
- ldr r3, =CONFIG_ROCKCHIP_BOOT_LR_REG
- cmp lr, r3 /* if (LR != CONFIG_ROCKCHIP_BOOT_LR_REG) */
- bne reset /* goto reset; */
- Unlike newer Rockchip SoC models the rk3066 BROM code does not have built-in
- support to enter download mode on return to BROM. This binary must check
- the boot mode register for the BOOT_BROM_DOWNLOAD flag and reset if it's set.
- It then returns to BROM to the end of the function that reads boot blocks.
- From there the BROM code goes into a download mode and waits for data
- on USB OTG and UART0.
- ldr r2, =BOOT_BROM_DOWNLOAD
- ldr r3, =CONFIG_ROCKCHIP_BOOT_MODE_REG
- ldr r0, [r3] /* if (readl(CONFIG_ROCKCHIP_BOOT_MODE_REG) != */
- cmp r0, r2 /* BOOT_BROM_DOWNLOAD) { */
- bne early_return /* goto early_return; */
/* } else { */
- mov r0, #0
- str r0, [r3] /* writel(0, CONFIG_ROCKCHIP_BOOT_MODE_REG); */
- ldr r3, =CONFIG_ROCKCHIP_BOOT_RETURN_REG
- bx r3 /* return to CONFIG_ROCKCHIP_BOOT_RETURN_REG;*/
+early_return:
- bx lr /* return to LR in BROM */
+SAVE_SP_ADDR:
- .word 0
- .globl save_boot_params
+save_boot_params:
- push {r1-r12, lr}
- ldr r0, =SAVE_SP_ADDR
- str sp, [r0]
- b save_boot_params_ret
- .globl back_to_bootrom
+back_to_bootrom:
- ldr sp, [r0]
- mov r0, #0
- pop {r1-r12, pc}
- b reset
- For armv7, the addr '_start' will be used as vector start address
- and is written to the VBAR register, which needs to aligned to 0x20.
- .align(5), 0x0
+_start:
- ARM_VECTORS #endif
- select ROCKCHIP_BROM_HELPER if !ROCKCHIP_RK3066 select TPL_BOOTROM_SUPPORT depends on TPL help
- hex
- default 0x00001058
- hex
- default 0x00001100
- config SYS_SOC default "rk3066"
-- 2.39.2
Johan Jonker
Kever Yang
