[U-Boot-Users] [PATCH][RFC] disable flat i2c commands when CONFIG_I2C_CMD_TREE defined
I noticed that when using CONFIG_I2C_CMD_TREE to enable the 'i2c' command with its sub commands, I also get the flat i2c commands (imm, iprobe, ...) compiled into u-boot.
I think this is more than I need and want.
Does anything speak against disabling the flat i2c commands when CONFIG_I2C_CMD_TREE is defined?
This is how I've done it (please skip the SPD stuff).
Matthias
diff --git a/common/cmd_i2c.c b/common/cmd_i2c.c index 45cfde2..59a4276 100644 --- a/common/cmd_i2c.c +++ b/common/cmd_i2c.c @@ -701,6 +701,7 @@ int do_sdram ( cmd_tbl_t *cmdtp, int fl switch(data[2]) { case 2: puts ("EDO\n"); break; case 4: puts ("SDRAM\n"); break; + case 8: puts ("DDR2\n"); break; default: puts ("unknown\n"); break; } puts ("Row address bits "); @@ -722,6 +723,7 @@ int do_sdram ( cmd_tbl_t *cmdtp, int fl case 2: puts ("HSTL 1.5\n"); break; case 3: puts ("SSTL 3.3\n"); break; case 4: puts ("SSTL 2.5\n"); break; + case 5: puts ("SSTL 1.8\n"); break; default: puts ("unknown\n"); break; } printf("SDRAM cycle time %d.%d nS\n", @@ -948,6 +950,7 @@ int do_i2c(cmd_tbl_t * cmdtp, int flag,
+#if !defined(CONFIG_I2C_CMD_TREE) U_BOOT_CMD( imd, 4, 1, do_i2c_md, \ "imd - i2c memory display\n", \ @@ -1002,8 +1005,7 @@ U_BOOT_CMD( " (valid chip values 50..57)\n" ); #endif - -#if defined(CONFIG_I2C_CMD_TREE) +#else /* CONFIG_I2C_CMD_TREE */ U_BOOT_CMD( i2c, 6, 1, do_i2c, "i2c - I2C sub-system\n",
Matthias
Looks good. I can't think of a use case where both command formats would be useful, but maybe others can.
Please flip the order so it's
#if defined(CONFIG_I2C_CMD_TREE) U_BOOT_CMD( i2c, 6, 1, do_i2c, ... #else U_BOOT_CMD( imd, 4, 1, do_i2c_md, \ ... #endif
and submit as a proper patch.
regards, Ben
Ben Warren
Matthias Fuchs
