[PATCH v3 0/4] Enable OSPI boot for j721s2
The series enables ospi boot for j721s2.
Test logs: https://gist.github.com/manorit2001/6bb91885c608e3a8cb0267ab2c614781
Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com --- Changes in v3: - Rebase on top of -next - Remove SF_DEFAULT_MODE as it's default 0 - Add new properties in correct location as per savedefconfig - Link to v2: https://lore.kernel.org/r/20240528-b4-upstream-j721s2-ospi-support-v2-0-b2e3...
--- Manorit Chawdhry (3): arch: arm: dts: k3-j721s2-r5: Override ospi and fss for 32-bit mode arch: arm: dts: k3-j721s2-*-u-boot.dtsi: Enable the ospi0 node configs: j721s2_evm_*_defconfig: Enable OSPI configs
Pratyush Yadav (1): mtd: spi-nor-core: Do not start or end writes at odd address in DTR mode
.../dts/k3-j721s2-common-proc-board-u-boot.dtsi | 4 +- arch/arm/dts/k3-j721s2-r5.dtsi | 13 +++++ configs/j721s2_evm_a72_defconfig | 1 + configs/j721s2_evm_r5_defconfig | 1 + drivers/mtd/spi/spi-nor-core.c | 59 ++++++++++++++++++++-- 5 files changed, 73 insertions(+), 5 deletions(-) --- base-commit: 15d0dcc0ec1f424199dff2a3cbe037bc3a7d8749 change-id: 20240322-b4-upstream-j721s2-ospi-support-d45dfaa926dc
On DTR capable flashes like Micron Xcella the writes cannot start or end at an odd address in DTR mode. Extra 0xff bytes need to be prepended or appended respectively to make sure both the start and end addresses are even.
Signed-off-by: Pratyush Yadav p.yadav@ti.com Signed-off-by: Apurva Nandan a-nandan@ti.com Signed-off-by: Vignesh Raghavendra vigneshr@ti.com Tested-by: Jonathan Humphreys j-humphreys@ti.com Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com --- drivers/mtd/spi/spi-nor-core.c | 59 +++++++++++++++++++++++++++++++++++++++--- 1 file changed, 55 insertions(+), 4 deletions(-)
diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index 982dd251150d..aea611fef523 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -1804,11 +1804,62 @@ static int spi_nor_write(struct mtd_info *mtd, loff_t to, size_t len, if (ret < 0) return ret; #endif + write_enable(nor); - ret = nor->write(nor, addr, page_remain, buf + i); - if (ret < 0) - goto write_err; - written = ret; + + /* + * On DTR capable flashes like Micron Xcella the writes cannot + * start or end at an odd address in DTR mode. So we need to + * append or prepend extra 0xff bytes to make sure the start + * address and end address are even. + */ + if (spi_nor_protocol_is_dtr(nor->write_proto) && + ((addr | page_remain) & 1)) { + u_char *tmp; + size_t extra_bytes = 0; + + tmp = kmalloc(nor->page_size, 0); + if (!tmp) { + ret = -ENOMEM; + goto write_err; + } + + /* Prepend a 0xff byte if the start address is odd. */ + if (addr & 1) { + tmp[0] = 0xff; + memcpy(tmp + 1, buf + i, page_remain); + addr--; + page_remain++; + extra_bytes++; + } else { + memcpy(tmp, buf + i, page_remain); + } + + /* Append a 0xff byte if the end address is odd. */ + if ((addr + page_remain) & 1) { + tmp[page_remain + extra_bytes] = 0xff; + extra_bytes++; + page_remain++; + } + + ret = nor->write(nor, addr, page_remain, tmp); + + kfree(tmp); + + if (ret < 0) + goto write_err; + + /* + * We write extra bytes but they are not part of the + * original write. + */ + written = ret - extra_bytes; + } else { + ret = nor->write(nor, addr, page_remain, buf + i); + if (ret < 0) + goto write_err; + written = ret; + }
ret = spi_nor_wait_till_ready(nor); if (ret)
R5 being a 32-bit processor can't understand the 64-bit mapping being done in ospi node. Override the ospi node for 32-bit register ranges and the fss node ( the parent node of ospi ) to map the ranges for the updated child node correctly.
Reviewed-by: Apurva Nandan a-nandan@ti.com Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com --- arch/arm/dts/k3-j721s2-r5.dtsi | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/arch/arm/dts/k3-j721s2-r5.dtsi b/arch/arm/dts/k3-j721s2-r5.dtsi index eb0df42583a3..dbea6b9d0113 100644 --- a/arch/arm/dts/k3-j721s2-r5.dtsi +++ b/arch/arm/dts/k3-j721s2-r5.dtsi @@ -79,3 +79,16 @@ &mcu_udmap { ti,sci = <&dm_tifs>; }; + +&ospi0 { + reg = <0x0 0x47040000 0x0 0x100>, + <0x0 0x50000000 0x0 0x8000000>; +}; + +&fss { + /* fss node has 64 bit address regions mapped to it and since the ospi + * nodes is being override, override the fss node ranges as well + */ + ranges = <0x0 0x47000000 0x0 0x47000000 0x0 0x00068400>, + <0x0 0x50000000 0x0 0x50000000 0x0 0x08000000>; +};
Enable ospi0 node for all boot stages
Reviewed-by: Apurva Nandan a-nandan@ti.com Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com --- arch/arm/dts/k3-j721s2-common-proc-board-u-boot.dtsi | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/k3-j721s2-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721s2-common-proc-board-u-boot.dtsi index 91a82b3b7ca6..54eb9b4072c7 100644 --- a/arch/arm/dts/k3-j721s2-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721s2-common-proc-board-u-boot.dtsi @@ -102,7 +102,9 @@ };
&ospi0 { - status = "disabled"; + flash@0 { + bootph-all; + }; };
&ospi1 {
Enable OSPI related configs to boot using OSPI
Reviewed-by: Apurva Nandan a-nandan@ti.com Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com --- configs/j721s2_evm_a72_defconfig | 1 + configs/j721s2_evm_r5_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/j721s2_evm_a72_defconfig b/configs/j721s2_evm_a72_defconfig index 5ed8d00662e3..5c3b52baaee7 100644 --- a/configs/j721s2_evm_a72_defconfig +++ b/configs/j721s2_evm_a72_defconfig @@ -10,6 +10,7 @@ CONFIG_SOC_K3_J721S2=y CONFIG_TARGET_J721S2_A72_EVM=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80480000 +CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_ENV_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y diff --git a/configs/j721s2_evm_r5_defconfig b/configs/j721s2_evm_r5_defconfig index 3c958cafbe8f..7413ddd08106 100644 --- a/configs/j721s2_evm_r5_defconfig +++ b/configs/j721s2_evm_r5_defconfig @@ -10,6 +10,7 @@ CONFIG_K3_EARLY_CONS=y CONFIG_TARGET_J721S2_R5_EVM=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x41c76000 +CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_ENV_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y
Manorit Chawdhry
