[U-Boot] [PATCH v2 0/3] atmel_nand: misc update in atmel nandflash driver
Since the nand driver is synced with v4.1 kernel, here is a update also for atmel_nand driver. which includes: 1. fix format and using definition not magic number. 2. use ecc_{strength, step}_ds instead of our own function.
Changes in v2: - following Andreas' advice, change the message for more concise. - collect the Reviewed-by from Andreas. - drop a patch: [PATCH 3/4] atmel_nand: increase more delay to support MT29F32G08CBADA
Josh Wu (3): atmel_nand: use nand ecc_{strength,step}_ds instead of our own function atmel_nand: add '\n' in the end of error message for better display atmel_nand: use the definition: PMECC_OOB_RESERVED_BYTES instead magic number
drivers/mtd/nand/atmel_nand.c | 50 +++++++++-------------------------------- 1 file changed, 10 insertions(+), 40 deletions(-)
Since ecc_{strength,step}_ds is introduced in nand_chip structure for minimum ecc requirements. So we can use them directly and remove our own get_onfi_ecc_param function.
Signed-off-by: Josh Wu josh.wu@atmel.com Reviewed-by: Andreas Bießmann andreas.devel@googlemail.com Signed-off-by: Wenyou Yang wenyou.yang@atmel.com ---
Changes in v2: None
drivers/mtd/nand/atmel_nand.c | 44 +++++++---------------------------------- 1 file changed, 7 insertions(+), 37 deletions(-)
diff --git a/drivers/mtd/nand/atmel_nand.c b/drivers/mtd/nand/atmel_nand.c index 0d4f327..e179f74 100644 --- a/drivers/mtd/nand/atmel_nand.c +++ b/drivers/mtd/nand/atmel_nand.c @@ -677,34 +677,6 @@ static void atmel_pmecc_core_init(struct mtd_info *mtd)
#ifdef CONFIG_SYS_NAND_ONFI_DETECTION /* - * get_onfi_ecc_param - Get ECC requirement from ONFI parameters - * @ecc_bits: store the ONFI ECC correct bits capbility - * @sector_size: in how many bytes that ONFI require to correct @ecc_bits - * - * Returns -1 if ONFI parameters is not supported. In this case @ecc_bits, - * @sector_size are initialize to 0. - * Return 0 if success to get the ECC requirement. - */ -static int get_onfi_ecc_param(struct nand_chip *chip, - int *ecc_bits, int *sector_size) -{ - *ecc_bits = *sector_size = 0; - - if (chip->onfi_params.ecc_bits == 0xff) - /* TODO: the sector_size and ecc_bits need to be find in - * extended ecc parameter, currently we don't support it. - */ - return -1; - - *ecc_bits = chip->onfi_params.ecc_bits; - - /* The default sector size (ecc codeword size) is 512 */ - *sector_size = 512; - - return 0; -} - -/* * pmecc_choose_ecc - Get ecc requirement from ONFI parameters. If * pmecc_corr_cap or pmecc_sector_size is 0, then set it as * ONFI ECC parameters. @@ -724,17 +696,15 @@ static int pmecc_choose_ecc(struct atmel_nand_host *host, /* Get ECC requirement from ONFI parameters */ *cap = *sector_size = 0; if (chip->onfi_version) { - if (!get_onfi_ecc_param(chip, cap, sector_size)) { - MTDDEBUG(MTD_DEBUG_LEVEL1, "ONFI params, minimum required ECC: %d bits in %d bytes\n", - *cap, *sector_size); - } else { - dev_info(host->dev, "NAND chip ECC reqirement is in Extended ONFI parameter, we don't support yet.\n"); - } - } else { - dev_info(host->dev, "NAND chip is not ONFI compliant, assume ecc_bits is 2 in 512 bytes"); + *cap = chip->ecc_strength_ds; + *sector_size = chip->ecc_step_ds; + MTDDEBUG(MTD_DEBUG_LEVEL1, "ONFI params, minimum required ECC: %d bits in %d bytes\n", + *cap, *sector_size); } + if (*cap == 0 && *sector_size == 0) { - /* Non-ONFI compliant or use extended ONFI parameters */ + /* Non-ONFI compliant */ + dev_info(host->dev, "NAND chip is not ONFI compliant, assume ecc_bits is 2 in 512 bytes\n"); *cap = 2; *sector_size = 512; }
Dear Wenyou Yang,
Wenyou Yang wenyou.yang@atmel.com writes:
Changes in v2: None
applied to u-boot-atmel/master, thanks!
Best regards, Andreas Bießmann
Also align the open parenthesis.
Signed-off-by: Josh Wu josh.wu@atmel.com Signed-off-by: Wenyou Yang wenyou.yang@atmel.com ---
Changes in v2: None
drivers/mtd/nand/atmel_nand.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/nand/atmel_nand.c b/drivers/mtd/nand/atmel_nand.c index e179f74..852883b 100644 --- a/drivers/mtd/nand/atmel_nand.c +++ b/drivers/mtd/nand/atmel_nand.c @@ -821,8 +821,8 @@ static int atmel_pmecc_nand_init_params(struct nand_chip *nand, * from ONFI. */ if (pmecc_choose_ecc(host, nand, &cap, §or_size)) { - dev_err(host->dev, "The NAND flash's ECC requirement(ecc_bits: %d, sector_size: %d) are not support!", - cap, sector_size); + dev_err(host->dev, "Required ECC %d bits in %d bytes not supported!\n", + cap, sector_size); return -EINVAL; }
Changes in v2: None
cap, sector_size);
return -EINVAL; }cap, sector_size);
Dear Wenyou Yang,
Signed-off-by: Josh Wu josh.wu@atmel.com Signed-off-by: Wenyou Yang wenyou.yang@atmel.com Reviewed-by: Andreas Bießmann andreas.devel@googlemail.com
Changes in v2: None
As atmel_nand_ecc.h is sync with v4.1 kernel, which adds the PMECC_OOB_RESERVED_BYTES. So use it in the driver.
drivers/mtd/nand/atmel_nand.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/atmel_nand.c b/drivers/mtd/nand/atmel_nand.c index 852883b..73fd403 100644 --- a/drivers/mtd/nand/atmel_nand.c +++ b/drivers/mtd/nand/atmel_nand.c @@ -901,7 +901,7 @@ static int atmel_pmecc_nand_init_params(struct nand_chip *nand, return -EINVAL; }
- if (nand->ecc.bytes > mtd->oobsize - 2) { + if (nand->ecc.bytes > mtd->oobsize - PMECC_OOB_RESERVED_BYTES) { dev_err(host->dev, "No room for ECC bytes\n"); return -EINVAL; }
Dear Wenyou Yang,
Changes in v2:
Andreas Bießmann
Wenyou Yang
