[U-Boot-Users] [Fwd: Re: reducing size of u-boot binary]
dear jerry, thanks for your reply.i am using u-boot 1.1.5 .my binary is only 90kb & i still wanted to reduce the size.i thought compiling u-boot is like compiling linux kernel,ie source file for the disabled commands wont get compiled,now i understood that i was wrong.
i wanted to reduce size to less than 90kb because of constraints in available flash memory space.
i have done it by disabling bootp & rarp by using #define macros i didnt find option for that in /include/cmd_confdefs.h .
once again i thank you for your response
thanks & regards vibi sreenivasan
On Fri, 2007-12-14 at 07:20 -0500, Jerry Van Baren wrote:
vibi wrote:
hello, can any one please tell me how to reduce the size of u-boot.bin. i tried by disabling commands in the include/config/at91rm9200dk.h,as per the read me document even after this when i compile,i was unable to decrease the size.
thanks in advance.
How big is your binary, why do you need to reduce its size? I ask because most of the time this question is the result of a link gone bad where part of the linked binary lives in low memory space and part lives in high memory space. As a result, the .bin has a huge amount of filled (unused) data between the two.
Best regards, gvb
thanks in advance.
Best regards, gvb
Hi Vibi,
90K is already pretty small for a u-boot image. I don't know how small u-boot can get, but rule of thumb is 128K is a reasonable size for good functionality. http://www.denx.de/wiki/view/UBoot/DesignPrinciples
With respect to the commands, disabling commands should cut the actual command code out via #ifdefs, so disabling commands should result in a smaller image, even though all the files are still compiled. a) There is a limit to how much can be cut out by removing commands. There still is a lot of support code necessary. b) It is possible that a command that is disabled needs a support function, but the support function isn't disabled so not all the potential savings are realized.
Note that u-boot is going to a better configuration and linking methodology that doesn't compile unused pieces (as opposed to compiling code that is #ifdefed out). I don't expect this to save any significant amount of memory, but it is possible that it will turn up and fix errors or inefficiencies with the current method.
Best regards, gvb
Jerry Van Baren
vibi
