[U-Boot] [PATCH] Fix ext2load return code
Make the ext2load command return 0 on success (instead of the file length).
Also fix output format (get rid of randoim newlines) and some coding style issues (long lines etc.).
Signed-off-by: Wolfgang Denk wd@denx.de --- common/cmd_ext2.c | 74 +++++++++++++++++++++++++++------------------------- 1 files changed, 38 insertions(+), 36 deletions(-)
diff --git a/common/cmd_ext2.c b/common/cmd_ext2.c index 6ee60c6..b7e4048 100644 --- a/common/cmd_ext2.c +++ b/common/cmd_ext2.c @@ -67,51 +67,50 @@ int do_ext2ls (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
if (argc < 3) { cmd_usage(cmdtp); - return(1); + return 1; } dev = (int)simple_strtoul (argv[2], &ep, 16); dev_desc = get_dev(argv[1],dev);
if (dev_desc == NULL) { printf ("\n** Block device %s %d not supported\n", argv[1], dev); - return(1); + return 1; }
if (*ep) { if (*ep != ':') { puts ("\n** Invalid boot device, use `dev[:part]' **\n"); - return(1); + return 1; } part = (int)simple_strtoul(++ep, NULL, 16); }
- if (argc == 4) { - filename = argv[3]; - } + if (argc == 4) + filename = argv[3];
PRINTF("Using device %s %d:%d, directory: %s\n", argv[1], dev, part, filename);
if ((part_length = ext2fs_set_blk_dev(dev_desc, part)) == 0) { printf ("** Bad partition - %s %d:%d **\n", argv[1], dev, part); ext2fs_close(); - return(1); + return 1; }
if (!ext2fs_mount(part_length)) { printf ("** Bad ext2 partition or disk - %s %d:%d **\n", argv[1], dev, part); ext2fs_close(); - return(1); + return 1; }
if (ext2fs_ls (filename)) { printf ("** Error ext2fs_ls() **\n"); ext2fs_close(); - return(1); + return 1; };
ext2fs_close();
- return(0); + return 0; }
U_BOOT_CMD( @@ -140,11 +139,11 @@ int do_ext2load (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) switch (argc) { case 3: addr_str = getenv("loadaddr"); - if (addr_str != NULL) { + if (addr_str != NULL) addr = simple_strtoul (addr_str, NULL, 16); - } else { + else addr = CONFIG_SYS_LOAD_ADDR; - } + filename = getenv ("bootfile"); count = 0; break; @@ -166,24 +165,24 @@ int do_ext2load (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
default: cmd_usage(cmdtp); - return(1); + return 1; }
if (!filename) { - puts ("\n** No boot file defined **\n"); - return(1); + puts ("** No boot file defined **\n"); + return 1; }
dev = (int)simple_strtoul (argv[2], &ep, 16); dev_desc = get_dev(argv[1],dev); if (dev_desc==NULL) { - printf ("\n** Block device %s %d not supported\n", argv[1], dev); - return(1); + printf ("** Block device %s %d not supported\n", argv[1], dev); + return 1; } if (*ep) { if (*ep != ':') { - puts ("\n** Invalid boot device, use `dev[:part]' **\n"); - return(1); + puts ("** Invalid boot device, use `dev[:part]' **\n"); + return 1; } part = (int)simple_strtoul(++ep, NULL, 16); } @@ -193,50 +192,53 @@ int do_ext2load (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) if (part != 0) { if (get_partition_info (dev_desc, part, &info)) { printf ("** Bad partition %d **\n", part); - return(1); + return 1; }
if (strncmp((char *)info.type, BOOT_PART_TYPE, sizeof(info.type)) != 0) { - printf ("\n** Invalid partition type "%.32s"" + printf ("** Invalid partition type "%.32s"" " (expect "" BOOT_PART_TYPE "")\n", info.type); - return(1); + return 1; } - PRINTF ("\nLoading from block device %s device %d, partition %d: " - "Name: %.32s Type: %.32s File:%s\n", - argv[1], dev, part, info.name, info.type, filename); + printf ("Loading file "%s" " + "from %s device %d:%d (%.32s)\n", + filename, + argv[1], dev, part, info.name); } else { - PRINTF ("\nLoading from block device %s device %d, File:%s\n", - argv[1], dev, filename); + printf ("Loading file "%s" from %s device %d\n", + filename, argv[1], dev); }
if (!ext2fs_mount(part_length)) { - printf ("** Bad ext2 partition or disk - %s %d:%d **\n", argv[1], dev, part); + printf ("** Bad ext2 partition or disk - %s %d:%d **\n", + argv[1], dev, part); ext2fs_close(); - return(1); + return 1; }
filelen = ext2fs_open(filename); if (filelen < 0) { printf("** File not found %s\n", filename); ext2fs_close(); - return(1); + return 1; } if ((count < filelen) && (count != 0)) { filelen = count; }
if (ext2fs_read((char *)addr, filelen) != filelen) { - printf("\n** Unable to read "%s" from %s %d:%d **\n", filename, argv[1], dev, part); + printf("** Unable to read "%s" from %s %d:%d **\n", + filename, argv[1], dev, part); ext2fs_close(); - return(1); + return 1; }
ext2fs_close(); @@ -244,11 +246,11 @@ int do_ext2load (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) /* Loading ok, update default load address */ load_addr = addr;
- printf ("\n%d bytes read\n", filelen); + printf ("%d bytes read\n", filelen); sprintf(buf, "%X", filelen); setenv("filesize", buf);
- return(filelen); + return 0; }
U_BOOT_CMD(
