[U-Boot] [PATCH v2 1/4] spl: Kconfig: Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FAT
Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FAT so obj-$(CONFIG_$(SPL_)FS_FAT) can be used to control the build in both SPL and U-Boot.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/cpu/armv8/zynqmp/Kconfig | 2 +- arch/arm/mach-imx/spl.c | 2 +- arch/arm/mach-k3/am6_init.c | 2 +- arch/arm/mach-omap2/Kconfig | 6 +++--- arch/arm/mach-omap2/am33xx/Kconfig | 4 ++-- arch/arm/mach-socfpga/spl_a10.c | 2 +- arch/arm/mach-socfpga/spl_gen5.c | 2 +- arch/arm/mach-socfpga/spl_s10.c | 2 +- arch/arm/mach-zynq/Kconfig | 2 +- common/spl/Kconfig | 2 +- common/spl/Makefile | 2 +- common/spl/spl_mmc.c | 6 +++--- configs/am335x_baltos_defconfig | 2 +- configs/am335x_hs_evm_uart_defconfig | 2 +- configs/am335x_igep003x_defconfig | 2 +- configs/am335x_pdu001_defconfig | 2 +- configs/am335x_shc_defconfig | 2 +- configs/am335x_shc_ict_defconfig | 2 +- configs/am335x_shc_netboot_defconfig | 2 +- configs/am335x_shc_prompt_defconfig | 2 +- configs/am335x_shc_sdboot_defconfig | 2 +- configs/am335x_shc_sdboot_prompt_defconfig | 2 +- configs/am335x_sl50_defconfig | 2 +- configs/am65x_evm_a53_defconfig | 2 +- configs/am65x_evm_r5_defconfig | 2 +- configs/birdland_bav335a_defconfig | 2 +- configs/birdland_bav335b_defconfig | 2 +- configs/chiliboard_defconfig | 2 +- configs/cm_t335_defconfig | 2 +- configs/cm_t43_defconfig | 2 +- configs/draco_defconfig | 2 +- configs/etamin_defconfig | 2 +- configs/novena_defconfig | 2 +- configs/pcm051_rev1_defconfig | 2 +- configs/pcm051_rev3_defconfig | 2 +- configs/pengwyn_defconfig | 2 +- configs/pepper_defconfig | 2 +- configs/picosam9g45_defconfig | 2 +- configs/pxm2_defconfig | 2 +- configs/rastaban_defconfig | 2 +- configs/rut_defconfig | 2 +- configs/sama5d27_som1_ek_mmc1_defconfig | 2 +- configs/sama5d27_som1_ek_mmc_defconfig | 2 +- configs/sama5d2_xplained_emmc_defconfig | 2 +- configs/sama5d2_xplained_mmc_defconfig | 2 +- configs/sama5d3_xplained_mmc_defconfig | 2 +- configs/sama5d3xek_mmc_defconfig | 2 +- configs/sama5d4_xplained_mmc_defconfig | 2 +- configs/sama5d4ek_mmc_defconfig | 2 +- configs/socfpga_arria10_defconfig | 2 +- configs/socfpga_stratix10_defconfig | 2 +- configs/thuban_defconfig | 2 +- configs/ti814x_evm_defconfig | 2 +- configs/ti816x_evm_defconfig | 2 +- configs/xilinx_zynqmp_zc1232_revA_defconfig | 2 +- configs/xilinx_zynqmp_zc1254_revA_defconfig | 2 +- configs/xilinx_zynqmp_zc1275_revA_defconfig | 2 +- configs/xilinx_zynqmp_zc1275_revB_defconfig | 2 +- configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 2 +- configs/zynq_zc770_xm011_defconfig | 2 +- configs/zynq_zc770_xm011_x16_defconfig | 2 +- configs/zynq_zc770_xm012_defconfig | 2 +- configs/zynq_zc770_xm013_defconfig | 2 +- doc/README.SPL | 2 +- fs/Makefile | 2 +- include/configs/imx6_spl.h | 2 +- include/configs/imx7_spl.h | 2 +- include/configs/socfpga_common.h | 2 +- include/part.h | 2 +- 69 files changed, 74 insertions(+), 74 deletions(-)
diff --git a/arch/arm/cpu/armv8/zynqmp/Kconfig b/arch/arm/cpu/armv8/zynqmp/Kconfig index 8a311e1..e9f7e7e 100644 --- a/arch/arm/cpu/armv8/zynqmp/Kconfig +++ b/arch/arm/cpu/armv8/zynqmp/Kconfig @@ -1,6 +1,6 @@ if ARCH_ZYNQMP
-config SPL_FAT_SUPPORT +config SPL_FS_FAT default y
config SPL_LIBCOMMON_SUPPORT diff --git a/arch/arm/mach-imx/spl.c b/arch/arm/mach-imx/spl.c index a20b30d..6c57ef2 100644 --- a/arch/arm/mach-imx/spl.c +++ b/arch/arm/mach-imx/spl.c @@ -162,7 +162,7 @@ u32 spl_boot_mode(const u32 boot_device) /* for MMC return either RAW or FAT mode */ case BOOT_DEVICE_MMC1: case BOOT_DEVICE_MMC2: -#if defined(CONFIG_SPL_FAT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) return MMCSD_MODE_FS; #elif defined(CONFIG_SUPPORT_EMMC_BOOT) return MMCSD_MODE_EMMCBOOT; diff --git a/arch/arm/mach-k3/am6_init.c b/arch/arm/mach-k3/am6_init.c index e2fe00c..4aef3cd 100644 --- a/arch/arm/mach-k3/am6_init.c +++ b/arch/arm/mach-k3/am6_init.c @@ -106,7 +106,7 @@ u32 spl_boot_mode(const u32 boot_device) #endif
/* Everything else use filesystem if available */ -#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) return MMCSD_MODE_FS; #else return MMCSD_MODE_RAW; diff --git a/arch/arm/mach-omap2/Kconfig b/arch/arm/mach-omap2/Kconfig index 58e545a..7293362 100644 --- a/arch/arm/mach-omap2/Kconfig +++ b/arch/arm/mach-omap2/Kconfig @@ -14,7 +14,7 @@ config OMAP34XX select USE_TINY_PRINTF imply NAND_OMAP_GPMC imply SPL_EXT_SUPPORT - imply SPL_FAT_SUPPORT + imply SPL_FS_FAT imply SPL_GPIO_SUPPORT imply SPL_I2C_SUPPORT imply SPL_LIBCOMMON_SUPPORT @@ -36,7 +36,7 @@ config OMAP44XX imply NAND_OMAP_GPMC imply SPL_DISPLAY_PRINT imply SPL_EXT_SUPPORT - imply SPL_FAT_SUPPORT + imply SPL_FS_FAT imply SPL_GPIO_SUPPORT imply SPL_I2C_SUPPORT imply SPL_LIBCOMMON_SUPPORT @@ -60,7 +60,7 @@ config OMAP54XX imply SPL_DISPLAY_PRINT imply SPL_ENV_SUPPORT imply SPL_EXT_SUPPORT - imply SPL_FAT_SUPPORT + imply SPL_FS_FAT imply SPL_GPIO_SUPPORT imply SPL_I2C_SUPPORT imply SPL_LIBCOMMON_SUPPORT diff --git a/arch/arm/mach-omap2/am33xx/Kconfig b/arch/arm/mach-omap2/am33xx/Kconfig index 3529607..6902034 100644 --- a/arch/arm/mach-omap2/am33xx/Kconfig +++ b/arch/arm/mach-omap2/am33xx/Kconfig @@ -39,7 +39,7 @@ config TARGET_AM335X_EVM imply SPL_DM_SEQ_ALIAS imply SPL_ENV_SUPPORT imply SPL_EXT_SUPPORT - imply SPL_FAT_SUPPORT + imply SPL_FS_FAT imply SPL_GPIO_SUPPORT imply SPL_I2C_SUPPORT imply SPL_LIBCOMMON_SUPPORT @@ -232,7 +232,7 @@ config TARGET_AM43XX_EVM imply SPI_FLASH_BAR imply SPL_ENV_SUPPORT imply SPL_EXT_SUPPORT - imply SPL_FAT_SUPPORT + imply SPL_FS_FAT imply SPL_GPIO_SUPPORT imply SPL_I2C_SUPPORT imply SPL_LIBCOMMON_SUPPORT diff --git a/arch/arm/mach-socfpga/spl_a10.c b/arch/arm/mach-socfpga/spl_a10.c index d523167..bd21fc2 100644 --- a/arch/arm/mach-socfpga/spl_a10.c +++ b/arch/arm/mach-socfpga/spl_a10.c @@ -63,7 +63,7 @@ u32 spl_boot_device(void) #ifdef CONFIG_SPL_MMC_SUPPORT u32 spl_boot_mode(const u32 boot_device) { -#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) return MMCSD_MODE_FS; #else return MMCSD_MODE_RAW; diff --git a/arch/arm/mach-socfpga/spl_gen5.c b/arch/arm/mach-socfpga/spl_gen5.c index ccdc661..98d39a7 100644 --- a/arch/arm/mach-socfpga/spl_gen5.c +++ b/arch/arm/mach-socfpga/spl_gen5.c @@ -55,7 +55,7 @@ u32 spl_boot_device(void) #ifdef CONFIG_SPL_MMC_SUPPORT u32 spl_boot_mode(const u32 boot_device) { -#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) return MMCSD_MODE_FS; #else return MMCSD_MODE_RAW; diff --git a/arch/arm/mach-socfpga/spl_s10.c b/arch/arm/mach-socfpga/spl_s10.c index cc5dc4f..f40a156 100644 --- a/arch/arm/mach-socfpga/spl_s10.c +++ b/arch/arm/mach-socfpga/spl_s10.c @@ -33,7 +33,7 @@ u32 spl_boot_device(void) #ifdef CONFIG_SPL_MMC_SUPPORT u32 spl_boot_mode(const u32 boot_device) { -#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) return MMCSD_MODE_FS; #else return MMCSD_MODE_RAW; diff --git a/arch/arm/mach-zynq/Kconfig b/arch/arm/mach-zynq/Kconfig index a599ed6..8946da2 100644 --- a/arch/arm/mach-zynq/Kconfig +++ b/arch/arm/mach-zynq/Kconfig @@ -3,7 +3,7 @@ if ARCH_ZYNQ config SPL_LDSCRIPT default "arch/arm/mach-zynq/u-boot-spl.lds"
config SPL_LIBCOMMON_SUPPORT diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 0ddbffc..93e7fe9 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -394,7 +394,7 @@ config SPL_EXT_SUPPORT filesystem from within SPL. Support for the underlying block device (e.g. MMC or USB) must be enabled separately.
-config SPL_FAT_SUPPORT +config SPL_FS_FAT bool "Support FAT filesystems" select FS_FAT help diff --git a/common/spl/Makefile b/common/spl/Makefile index a130a5b..5d4d6ed 100644 --- a/common/spl/Makefile +++ b/common/spl/Makefile @@ -23,7 +23,7 @@ obj-$(CONFIG_$(SPL_TPL_)MMC_SUPPORT) += spl_mmc.o obj-$(CONFIG_$(SPL_TPL_)ATF) += spl_atf.o obj-$(CONFIG_$(SPL_TPL_)OPTEE) += spl_optee.o obj-$(CONFIG_$(SPL_TPL_)USB_SUPPORT) += spl_usb.o -obj-$(CONFIG_$(SPL_TPL_)FAT_SUPPORT) += spl_fat.o +obj-$(CONFIG_$(SPL_TPL_)FS_FAT) += spl_fat.o obj-$(CONFIG_$(SPL_TPL_)EXT_SUPPORT) += spl_ext.o obj-$(CONFIG_$(SPL_TPL_)SATA_SUPPORT) += spl_sata.o obj-$(CONFIG_$(SPL_TPL_)DFU_SUPPORT) += spl_dfu.o diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index 4d55dcc..e526167 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -238,7 +238,7 @@ static int spl_mmc_do_fs_boot(struct spl_image_info *spl_image, struct mmc *mmc) { int err = -ENOSYS;
-#ifdef CONFIG_SPL_FAT_SUPPORT +#ifdef CONFIG_SPL_FS_FAT if (!spl_start_uboot()) { err = spl_load_image_fat_os(spl_image, mmc_get_blk_desc(mmc), CONFIG_SYS_MMCSD_FS_BOOT_PARTITION); @@ -269,7 +269,7 @@ static int spl_mmc_do_fs_boot(struct spl_image_info *spl_image, struct mmc *mmc) #endif #endif
-#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) err = -ENOENT; #endif
@@ -284,7 +284,7 @@ static int spl_mmc_do_fs_boot(struct spl_image_info *spl_image, struct mmc *mmc)
u32 __weak spl_boot_mode(const u32 boot_device) { -#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) return MMCSD_MODE_FS; #elif defined(CONFIG_SUPPORT_EMMC_BOOT) return MMCSD_MODE_EMMCBOOT; diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index 05d41ae..f5c25af 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -7,7 +7,7 @@ CONFIG_TARGET_AM335X_BALTOS=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y diff --git a/configs/am335x_hs_evm_uart_defconfig b/configs/am335x_hs_evm_uart_defconfig index 419b41c..b868bc1 100644 --- a/configs/am335x_hs_evm_uart_defconfig +++ b/configs/am335x_hs_evm_uart_defconfig @@ -6,7 +6,7 @@ CONFIG_AM33XX=y CONFIG_ISW_ENTRY_ADDR=0x40301950 # CONFIG_SPL_MMC_SUPPORT is not set CONFIG_SPL=y -# CONFIG_SPL_FAT_SUPPORT is not set +# CONFIG_SPL_FS_FAT is not set # CONFIG_SPL_LIBDISK_SUPPORT is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_IMAGE_POST_PROCESS=y diff --git a/configs/am335x_igep003x_defconfig b/configs/am335x_igep003x_defconfig index 16affb8..af7f34c 100644 --- a/configs/am335x_igep003x_defconfig +++ b/configs/am335x_igep003x_defconfig @@ -9,7 +9,7 @@ CONFIG_TARGET_AM335X_IGEP003X=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/am335x_pdu001_defconfig b/configs/am335x_pdu001_defconfig index 3cb38af..2e64baf 100644 --- a/configs/am335x_pdu001_defconfig +++ b/configs/am335x_pdu001_defconfig @@ -7,7 +7,7 @@ CONFIG_TARGET_PDU001=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_LOCALVERSION="-EETS-1.0.0" CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/am335x_shc_defconfig b/configs/am335x_shc_defconfig index 25e1a4f..215ac61 100644 --- a/configs/am335x_shc_defconfig +++ b/configs/am335x_shc_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_AM335X_SHC=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SERIES=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/am335x_shc_ict_defconfig b/configs/am335x_shc_ict_defconfig index 9ebfe5e..a335d24 100644 --- a/configs/am335x_shc_ict_defconfig +++ b/configs/am335x_shc_ict_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_AM335X_SHC=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SHC_ICT=y CONFIG_SERIES=y diff --git a/configs/am335x_shc_netboot_defconfig b/configs/am335x_shc_netboot_defconfig index 064b3c3..7c66740 100644 --- a/configs/am335x_shc_netboot_defconfig +++ b/configs/am335x_shc_netboot_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_AM335X_SHC=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SHC_NETBOOT=y CONFIG_SERIES=y diff --git a/configs/am335x_shc_prompt_defconfig b/configs/am335x_shc_prompt_defconfig index dce8334..984c643 100644 --- a/configs/am335x_shc_prompt_defconfig +++ b/configs/am335x_shc_prompt_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_AM335X_SHC=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SERIES=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/am335x_shc_sdboot_defconfig b/configs/am335x_shc_sdboot_defconfig index e4e6ade..6fab356 100644 --- a/configs/am335x_shc_sdboot_defconfig +++ b/configs/am335x_shc_sdboot_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_AM335X_SHC=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SHC_SDBOOT=y CONFIG_SERIES=y diff --git a/configs/am335x_shc_sdboot_prompt_defconfig b/configs/am335x_shc_sdboot_prompt_defconfig index e4e6ade..6fab356 100644 --- a/configs/am335x_shc_sdboot_prompt_defconfig +++ b/configs/am335x_shc_sdboot_prompt_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_AM335X_SHC=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SHC_SDBOOT=y CONFIG_SERIES=y diff --git a/configs/am335x_sl50_defconfig b/configs/am335x_sl50_defconfig index a45fd3d..8908b34 100644 --- a/configs/am335x_sl50_defconfig +++ b/configs/am335x_sl50_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_AM335X_SL50=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT" diff --git a/configs/am65x_evm_a53_defconfig b/configs/am65x_evm_a53_defconfig index a17cf7c..8f6fd25 100644 --- a/configs/am65x_evm_a53_defconfig +++ b/configs/am65x_evm_a53_defconfig @@ -9,7 +9,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 diff --git a/configs/am65x_evm_r5_defconfig b/configs/am65x_evm_r5_defconfig index 237b9e8..d2ec2dd 100644 --- a/configs/am65x_evm_r5_defconfig +++ b/configs/am65x_evm_r5_defconfig @@ -10,7 +10,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index 89c7778..90e3bee 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_BAV335X=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_BAV_VERSION=1 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index e3dc88b..05082b5 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_BAV335X=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_BAV_VERSION=2 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index 3de0223..f99bec6 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -7,7 +7,7 @@ CONFIG_TARGET_CHILIBOARD=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index 134b093..04857bd 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_CM_T335=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index eb4a8f5..356dbb2 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -7,7 +7,7 @@ CONFIG_TARGET_CM_T43=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index be64c1a..60f679c 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -11,7 +11,7 @@ CONFIG_TARGET_DRACO=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index a6b03f9..525e0d9 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -11,7 +11,7 @@ CONFIG_TARGET_ETAMIN=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 7eda3ac..6274e2f 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -9,7 +9,7 @@ CONFIG_TARGET_KOSAGI_NOVENA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_CMD_HDMIDETECT=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/pcm051_rev1_defconfig b/configs/pcm051_rev1_defconfig index 0be0caa..9d83a7b 100644 --- a/configs/pcm051_rev1_defconfig +++ b/configs/pcm051_rev1_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_PCM051=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="REV1" diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index 33e8225..53c4ece 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_PCM051=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="REV3" diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index 3c8684a..ce94b86 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_PENGWYN=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/pepper_defconfig b/configs/pepper_defconfig index 1dc3944..edc5da5 100644 --- a/configs/pepper_defconfig +++ b/configs/pepper_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_PEPPER=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/picosam9g45_defconfig b/configs/picosam9g45_defconfig index 699e2e2..36ae439 100644 --- a/configs/picosam9g45_defconfig +++ b/configs/picosam9g45_defconfig @@ -9,7 +9,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_MMC" diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 4a5c3c6..086b6f0 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -11,7 +11,7 @@ CONFIG_TARGET_PXM2=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index 09b64a3..7fbcdc3 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -11,7 +11,7 @@ CONFIG_TARGET_RASTABAN=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index 08eafc2..32d7143 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -11,7 +11,7 @@ CONFIG_TARGET_RUT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y diff --git a/configs/sama5d27_som1_ek_mmc1_defconfig b/configs/sama5d27_som1_ek_mmc1_defconfig index 13395ef..5f4abe8 100644 --- a/configs/sama5d27_som1_ek_mmc1_defconfig +++ b/configs/sama5d27_som1_ek_mmc1_defconfig @@ -13,7 +13,7 @@ CONFIG_SPL=y CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xf8020000 CONFIG_DEBUG_UART_CLOCK=82000000 -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/sama5d27_som1_ek_mmc_defconfig b/configs/sama5d27_som1_ek_mmc_defconfig index e260554..5dcd80c 100644 --- a/configs/sama5d27_som1_ek_mmc_defconfig +++ b/configs/sama5d27_som1_ek_mmc_defconfig @@ -13,7 +13,7 @@ CONFIG_SPL=y CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xf8020000 CONFIG_DEBUG_UART_CLOCK=82000000 -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/sama5d2_xplained_emmc_defconfig b/configs/sama5d2_xplained_emmc_defconfig index 4e61692..d6c30e2 100644 --- a/configs/sama5d2_xplained_emmc_defconfig +++ b/configs/sama5d2_xplained_emmc_defconfig @@ -13,7 +13,7 @@ CONFIG_SPL=y CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xf8020000 CONFIG_DEBUG_UART_CLOCK=83000000 -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index fd25261..49e2a73 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -13,7 +13,7 @@ CONFIG_SPL=y CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xf8020000 CONFIG_DEBUG_UART_CLOCK=83000000 -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/sama5d3_xplained_mmc_defconfig b/configs/sama5d3_xplained_mmc_defconfig index eab38ec..c7b7736 100644 --- a/configs/sama5d3_xplained_mmc_defconfig +++ b/configs/sama5d3_xplained_mmc_defconfig @@ -13,7 +13,7 @@ CONFIG_SPL=y CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xffffee00 CONFIG_DEBUG_UART_CLOCK=132000000 -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index 6faea0e..a4f10fa 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -13,7 +13,7 @@ CONFIG_SPL=y CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xffffee00 CONFIG_DEBUG_UART_CLOCK=132000000 -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index bfcea3f..9f15c97 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -13,7 +13,7 @@ CONFIG_SPL=y CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xfc00c000 CONFIG_DEBUG_UART_CLOCK=100000000 -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index 45e6539..9e2e1a9 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -13,7 +13,7 @@ CONFIG_SPL=y CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xfc00c000 CONFIG_DEBUG_UART_CLOCK=88000000 -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/socfpga_arria10_defconfig b/configs/socfpga_arria10_defconfig index e5fc807..038a708 100644 --- a/configs/socfpga_arria10_defconfig +++ b/configs/socfpga_arria10_defconfig @@ -33,7 +33,7 @@ CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_DM_MMC=y CONFIG_SPL_MMC_SUPPORT=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_FS_LOADER=y CONFIG_FPGA_SOCFPGA=y diff --git a/configs/socfpga_stratix10_defconfig b/configs/socfpga_stratix10_defconfig index 5f3d733..bc3a3a3 100644 --- a/configs/socfpga_stratix10_defconfig +++ b/configs/socfpga_stratix10_defconfig @@ -5,7 +5,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_SOCFPGA_STRATIX10_SOCDK=y CONFIG_SPL=y CONFIG_IDENT_STRING="socfpga_stratix10" -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_BOOTDELAY=5 CONFIG_SPL_SPI_LOAD=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index b856b9d..2adf156 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -11,7 +11,7 @@ CONFIG_TARGET_THUBAN=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y diff --git a/configs/ti814x_evm_defconfig b/configs/ti814x_evm_defconfig index b78dc7e..1343d8f 100644 --- a/configs/ti814x_evm_defconfig +++ b/configs/ti814x_evm_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_TI814X_EVM=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index 381f464..2e8a598 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_TI816X_EVM=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 diff --git a/configs/xilinx_zynqmp_zc1232_revA_defconfig b/configs/xilinx_zynqmp_zc1232_revA_defconfig index 7521fc4..8596bd8 100644 --- a/configs/xilinx_zynqmp_zc1232_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1232_revA_defconfig @@ -5,7 +5,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xff000000 CONFIG_DEBUG_UART_CLOCK=100000000 -# CONFIG_SPL_FAT_SUPPORT is not set +# CONFIG_SPL_FS_FAT is not set # CONFIG_SPL_LIBDISK_SUPPORT is not set CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/xilinx_zynqmp_zc1254_revA_defconfig b/configs/xilinx_zynqmp_zc1254_revA_defconfig index e0822b9..95ae16c 100644 --- a/configs/xilinx_zynqmp_zc1254_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1254_revA_defconfig @@ -5,7 +5,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xff000000 CONFIG_DEBUG_UART_CLOCK=100000000 -# CONFIG_SPL_FAT_SUPPORT is not set +# CONFIG_SPL_FS_FAT is not set # CONFIG_SPL_LIBDISK_SUPPORT is not set CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/xilinx_zynqmp_zc1275_revA_defconfig b/configs/xilinx_zynqmp_zc1275_revA_defconfig index 3afed69..7997047 100644 --- a/configs/xilinx_zynqmp_zc1275_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1275_revA_defconfig @@ -5,7 +5,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xff000000 CONFIG_DEBUG_UART_CLOCK=100000000 -# CONFIG_SPL_FAT_SUPPORT is not set +# CONFIG_SPL_FS_FAT is not set # CONFIG_SPL_LIBDISK_SUPPORT is not set CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/xilinx_zynqmp_zc1275_revB_defconfig b/configs/xilinx_zynqmp_zc1275_revB_defconfig index 7e31b11..e0e52f9 100644 --- a/configs/xilinx_zynqmp_zc1275_revB_defconfig +++ b/configs/xilinx_zynqmp_zc1275_revB_defconfig @@ -6,7 +6,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xff000000 CONFIG_DEBUG_UART_CLOCK=100000000 -# CONFIG_SPL_FAT_SUPPORT is not set +# CONFIG_SPL_FS_FAT is not set # CONFIG_SPL_LIBDISK_SUPPORT is not set CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index c2b3d18..bb738ae 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -5,7 +5,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xff000000 CONFIG_DEBUG_UART_CLOCK=100000000 -# CONFIG_SPL_FAT_SUPPORT is not set +# CONFIG_SPL_FS_FAT is not set # CONFIG_SPL_LIBDISK_SUPPORT is not set CONFIG_ZYNQMP_USB=y CONFIG_DEBUG_UART=y diff --git a/configs/zynq_zc770_xm011_defconfig b/configs/zynq_zc770_xm011_defconfig index c15877d..70a76e6 100644 --- a/configs/zynq_zc770_xm011_defconfig +++ b/configs/zynq_zc770_xm011_defconfig @@ -6,7 +6,7 @@ CONFIG_DEBUG_UART_BASE=0xe0001000 CONFIG_DEBUG_UART_CLOCK=50000000 CONFIG_IDENT_STRING=" Xilinx Zynq ZC770 XM011" CONFIG_SPL_STACK_R_ADDR=0x200000 -# CONFIG_SPL_FAT_SUPPORT is not set +# CONFIG_SPL_FS_FAT is not set CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y diff --git a/configs/zynq_zc770_xm011_x16_defconfig b/configs/zynq_zc770_xm011_x16_defconfig index 60627da..2a6ffa5 100644 --- a/configs/zynq_zc770_xm011_x16_defconfig +++ b/configs/zynq_zc770_xm011_x16_defconfig @@ -6,7 +6,7 @@ CONFIG_DEBUG_UART_BASE=0xe0001000 CONFIG_DEBUG_UART_CLOCK=50000000 CONFIG_IDENT_STRING=" Xilinx Zynq ZC770 XM011 x16" CONFIG_SPL_STACK_R_ADDR=0x200000 -# CONFIG_SPL_FAT_SUPPORT is not set +# CONFIG_SPL_FS_FAT is not set CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y diff --git a/configs/zynq_zc770_xm012_defconfig b/configs/zynq_zc770_xm012_defconfig index aa20971..8c92505 100644 --- a/configs/zynq_zc770_xm012_defconfig +++ b/configs/zynq_zc770_xm012_defconfig @@ -4,7 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x4000000 CONFIG_SPL=y CONFIG_IDENT_STRING=" Xilinx Zynq ZC770 XM012" CONFIG_SPL_STACK_R_ADDR=0x200000 -# CONFIG_SPL_FAT_SUPPORT is not set +# CONFIG_SPL_FS_FAT is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y diff --git a/configs/zynq_zc770_xm013_defconfig b/configs/zynq_zc770_xm013_defconfig index a08bd29..630e392 100644 --- a/configs/zynq_zc770_xm013_defconfig +++ b/configs/zynq_zc770_xm013_defconfig @@ -4,7 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x4000000 CONFIG_SPL=y CONFIG_IDENT_STRING=" Xilinx Zynq ZC770 XM013" CONFIG_SPL_STACK_R_ADDR=0x200000 -# CONFIG_SPL_FAT_SUPPORT is not set +# CONFIG_SPL_FS_FAT is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y diff --git a/doc/README.SPL b/doc/README.SPL index fc1ca1a..48981bd 100644 --- a/doc/README.SPL +++ b/doc/README.SPL @@ -53,7 +53,7 @@ CONFIG_SPL_MMC_SUPPORT (drivers/mmc/libmmc.o) CONFIG_SPL_SERIAL_SUPPORT (drivers/serial/libserial.o) CONFIG_SPL_SPI_FLASH_SUPPORT (drivers/mtd/spi/libspi_flash.o) CONFIG_SPL_SPI_SUPPORT (drivers/spi/libspi.o) -CONFIG_SPL_FAT_SUPPORT (fs/fat/libfat.o) +CONFIG_SPL_FS_FAT (fs/fat/libfat.o) CONFIG_SPL_EXT_SUPPORT CONFIG_SPL_LIBGENERIC_SUPPORT (lib/libgeneric.o) CONFIG_SPL_POWER_SUPPORT (drivers/power/libpower.o) diff --git a/fs/Makefile b/fs/Makefile index f21cd23..bebea6a 100644 --- a/fs/Makefile +++ b/fs/Makefile @@ -6,7 +6,7 @@
ifdef CONFIG_SPL_BUILD obj-$(CONFIG_FS_LOADER) += fs.o -obj-$(CONFIG_SPL_FAT_SUPPORT) += fat/ +obj-$(CONFIG_SPL_FS_FAT) += fat/ obj-$(CONFIG_SPL_EXT_SUPPORT) += ext4/ else obj-y += fs.o diff --git a/include/configs/imx6_spl.h b/include/configs/imx6_spl.h index 720ff04..60a925d 100644 --- a/include/configs/imx6_spl.h +++ b/include/configs/imx6_spl.h @@ -43,7 +43,7 @@ #endif
/* Define the payload for FAT/EXT support */ -#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) # ifdef CONFIG_OF_CONTROL # define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot-dtb.img" # else diff --git a/include/configs/imx7_spl.h b/include/configs/imx7_spl.h index 1eb6cd8..116ea1a 100644 --- a/include/configs/imx7_spl.h +++ b/include/configs/imx7_spl.h @@ -38,7 +38,7 @@ #endif
/* Define the payload for FAT/EXT support */ -#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) # ifdef CONFIG_OF_CONTROL # define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot-dtb.img" # else diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index bd8f5c8..735430a 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -267,7 +267,7 @@ unsigned int cm_get_qspi_controller_clk_hz(void);
/* SPL SDMMC boot support */ #ifdef CONFIG_SPL_MMC_SUPPORT -#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot-dtb.img" #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #endif diff --git a/include/part.h b/include/part.h index 0750aee..388e130 100644 --- a/include/part.h +++ b/include/part.h @@ -246,7 +246,7 @@ static inline int blk_get_device_part_str(const char *ifname, */ #ifdef CONFIG_SPL_BUILD # define part_print_ptr(x) NULL -# if defined(CONFIG_SPL_EXT_SUPPORT) || defined(CONFIG_SPL_FAT_SUPPORT) || \ +# if defined(CONFIG_SPL_EXT_SUPPORT) || defined(CONFIG_SPL_FS_FAT) || \ defined(CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION) # define part_get_info_ptr(x) x # else
Most of the time SPL only needs very simple FAT reading, so having CONFIG_IS_ENABLED(FAT_WRITE) to exclude it from SPL build would help to save 64KiB default max clustersize from memory.
Changes in v2: - Changed to CONFIG_IS_ENABLED(FAT_WRITE) to control build for FAT write int both SPL and U-Boot - Changed to CONFIG_IS_ENABLED for config FS_FAT too. --- common/spl/Kconfig | 7 +++++++ fs/fat/Makefile | 4 ++-- fs/fat/fat.c | 3 ++- fs/fs.c | 2 +- 4 files changed, 12 insertions(+), 4 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 93e7fe9..9042117 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -403,6 +403,13 @@ config SPL_FS_FAT filesystem from within SPL. Support for the underlying block device (e.g. MMC or USB) must be enabled separately.
+config SPL_FAT_WRITE + bool "Support write for FAT filesystems" + help + Enable write support for FAT and VFAT filesystems with SPL. + Support for the underlying block device (e.g. MMC or USB) must be + enabled separately. + config SPL_FPGA_SUPPORT bool "Support FPGAs" help diff --git a/fs/fat/Makefile b/fs/fat/Makefile index e64b61a..f84efac 100644 --- a/fs/fat/Makefile +++ b/fs/fat/Makefile @@ -1,5 +1,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_FS_FAT) := fat.o -obj-$(CONFIG_FAT_WRITE):= fat_write.o +obj-$(CONFIG_$(SPL_)FS_FAT) = fat.o +obj-$(CONFIG_$(SPL_)FAT_WRITE) = fat_write.o diff --git a/fs/fat/fat.c b/fs/fat/fat.c index ac8913e..ecfa255 100644 --- a/fs/fat/fat.c +++ b/fs/fat/fat.c @@ -145,7 +145,8 @@ static void get_name(dir_entry *dirent, char *s_name) }
static int flush_dirty_fat_buffer(fsdata *mydata); -#if !defined(CONFIG_FAT_WRITE) + +#if !CONFIG_IS_ENABLED(FAT_WRITE) /* Stub for read only operation */ int flush_dirty_fat_buffer(fsdata *mydata) { diff --git a/fs/fs.c b/fs/fs.c index cb26517..48b8e9a 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -168,7 +168,7 @@ static struct fstype_info fstypes[] = { .exists = fat_exists, .size = fat_size, .read = fat_read_file, -#ifdef CONFIG_FAT_WRITE +#if CONFIG_IS_ENABLED(FAT_WRITE) .write = file_fat_write, .unlink = fat_unlink, .mkdir = fat_mkdir,
Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
Changes in v2:
help
enabled separately.
+#if !CONFIG_IS_ENABLED(FAT_WRITE) /* Stub for read only operation */ int flush_dirty_fat_buffer(fsdata *mydata) { diff --git a/fs/fs.c b/fs/fs.c index cb26517..48b8e9a 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -168,7 +168,7 @@ static struct fstype_info fstypes[] = { .exists = fat_exists, .size = fat_size, .read = fat_read_file, -#ifdef CONFIG_FAT_WRITE +#if CONFIG_IS_ENABLED(FAT_WRITE) .write = file_fat_write, .unlink = fat_unlink, .mkdir = fat_mkdir, -- 2.2.0
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Reviewed-by: Tom Rini trini@konsulko.com
Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPLY_FS_EXT4 so both obj-$(CONFIG_$(SPL_)FS_EXT4) and CONFIG_IS_ENABLED(FS_EXT4) can be used to control the build in both SPL and U-Boot.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/mach-k3/am6_init.c | 2 +- arch/arm/mach-omap2/Kconfig | 6 +++--- arch/arm/mach-omap2/am33xx/Kconfig | 4 ++-- arch/arm/mach-socfpga/spl_a10.c | 2 +- arch/arm/mach-socfpga/spl_gen5.c | 2 +- arch/arm/mach-socfpga/spl_s10.c | 2 +- common/spl/Kconfig | 2 +- common/spl/Makefile | 2 +- common/spl/spl_mmc.c | 6 +++--- configs/am335x_baltos_defconfig | 2 +- configs/am335x_hs_evm_defconfig | 2 +- configs/am335x_hs_evm_uart_defconfig | 2 +- configs/am335x_igep003x_defconfig | 2 +- configs/am335x_shc_defconfig | 2 +- configs/am335x_shc_ict_defconfig | 2 +- configs/am335x_shc_netboot_defconfig | 2 +- configs/am335x_shc_prompt_defconfig | 2 +- configs/am335x_shc_sdboot_defconfig | 2 +- configs/am335x_shc_sdboot_prompt_defconfig | 2 +- configs/am335x_sl50_defconfig | 2 +- configs/am3517_crane_defconfig | 2 +- configs/am3517_evm_defconfig | 2 +- configs/birdland_bav335a_defconfig | 2 +- configs/birdland_bav335b_defconfig | 2 +- configs/cgtqmx6eval_defconfig | 2 +- configs/cl-som-am57x_defconfig | 2 +- configs/cm_t335_defconfig | 2 +- configs/cm_t35_defconfig | 2 +- configs/cm_t43_defconfig | 2 +- configs/eco5pk_defconfig | 2 +- configs/igep0032_defconfig | 2 +- configs/igep00x0_defconfig | 2 +- configs/mcx_defconfig | 2 +- configs/mt_ventoux_defconfig | 2 +- configs/mx6cuboxi_defconfig | 2 +- configs/mx6sabreauto_defconfig | 2 +- configs/mx6sabresd_defconfig | 2 +- configs/mx6slevk_spl_defconfig | 2 +- configs/mx6sxsabresd_spl_defconfig | 2 +- configs/mx6ul_14x14_evk_defconfig | 2 +- configs/mx6ul_9x9_evk_defconfig | 2 +- configs/novena_defconfig | 2 +- configs/omap3_beagle_defconfig | 2 +- configs/omap3_evm_defconfig | 2 +- configs/omap3_ha_defconfig | 2 +- configs/omap4_panda_defconfig | 2 +- configs/pcm051_rev1_defconfig | 2 +- configs/pcm051_rev3_defconfig | 2 +- configs/pcm058_defconfig | 2 +- configs/pengwyn_defconfig | 2 +- configs/pepper_defconfig | 2 +- configs/pfla02_defconfig | 2 +- configs/platinum_picon_defconfig | 2 +- configs/platinum_titanium_defconfig | 2 +- configs/sksimx6_defconfig | 2 +- configs/sniper_defconfig | 2 +- configs/tao3530_defconfig | 2 +- configs/twister_defconfig | 2 +- configs/udoo_defconfig | 2 +- configs/udoo_neo_defconfig | 2 +- configs/wandboard_defconfig | 2 +- configs/xpress_spl_defconfig | 2 +- configs/zc5202_defconfig | 2 +- configs/zc5601_defconfig | 2 +- doc/README.SPL | 2 +- fs/Makefile | 2 +- include/configs/imx6_spl.h | 2 +- include/configs/imx7_spl.h | 2 +- include/configs/socfpga_common.h | 2 +- include/part.h | 2 +- 70 files changed, 75 insertions(+), 75 deletions(-)
diff --git a/arch/arm/mach-k3/am6_init.c b/arch/arm/mach-k3/am6_init.c index 4aef3cd..a555319 100644 --- a/arch/arm/mach-k3/am6_init.c +++ b/arch/arm/mach-k3/am6_init.c @@ -106,7 +106,7 @@ u32 spl_boot_mode(const u32 boot_device) #endif
/* Everything else use filesystem if available */ -#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_FS_EXT4) return MMCSD_MODE_FS; #else return MMCSD_MODE_RAW; diff --git a/arch/arm/mach-omap2/Kconfig b/arch/arm/mach-omap2/Kconfig index 7293362..d29f1ca 100644 --- a/arch/arm/mach-omap2/Kconfig +++ b/arch/arm/mach-omap2/Kconfig @@ -13,7 +13,7 @@ config OMAP34XX select ARM_ERRATA_725233 select USE_TINY_PRINTF imply NAND_OMAP_GPMC - imply SPL_EXT_SUPPORT + imply SPL_FS_EXT4 imply SPL_FS_FAT imply SPL_GPIO_SUPPORT imply SPL_I2C_SUPPORT @@ -35,7 +35,7 @@ config OMAP44XX imply NAND_OMAP_ELM imply NAND_OMAP_GPMC imply SPL_DISPLAY_PRINT - imply SPL_EXT_SUPPORT + imply SPL_FS_EXT4 imply SPL_FS_FAT imply SPL_GPIO_SUPPORT imply SPL_I2C_SUPPORT @@ -59,7 +59,7 @@ config OMAP54XX imply NAND_OMAP_GPMC imply SPL_DISPLAY_PRINT imply SPL_ENV_SUPPORT - imply SPL_EXT_SUPPORT + imply SPL_FS_EXT4 imply SPL_FS_FAT imply SPL_GPIO_SUPPORT imply SPL_I2C_SUPPORT diff --git a/arch/arm/mach-omap2/am33xx/Kconfig b/arch/arm/mach-omap2/am33xx/Kconfig index 6902034..85fe6e1 100644 --- a/arch/arm/mach-omap2/am33xx/Kconfig +++ b/arch/arm/mach-omap2/am33xx/Kconfig @@ -38,7 +38,7 @@ config TARGET_AM335X_EVM imply SPL_DM imply SPL_DM_SEQ_ALIAS imply SPL_ENV_SUPPORT - imply SPL_EXT_SUPPORT + imply SPL_FS_EXT4 imply SPL_FS_FAT imply SPL_GPIO_SUPPORT imply SPL_I2C_SUPPORT @@ -231,7 +231,7 @@ config TARGET_AM43XX_EVM imply DM_SPI_FLASH imply SPI_FLASH_BAR imply SPL_ENV_SUPPORT - imply SPL_EXT_SUPPORT + imply SPL_FS_EXT4 imply SPL_FS_FAT imply SPL_GPIO_SUPPORT imply SPL_I2C_SUPPORT diff --git a/arch/arm/mach-socfpga/spl_a10.c b/arch/arm/mach-socfpga/spl_a10.c index bd21fc2..3b521e5 100644 --- a/arch/arm/mach-socfpga/spl_a10.c +++ b/arch/arm/mach-socfpga/spl_a10.c @@ -63,7 +63,7 @@ u32 spl_boot_device(void) #ifdef CONFIG_SPL_MMC_SUPPORT u32 spl_boot_mode(const u32 boot_device) { -#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_FS_EXT4) return MMCSD_MODE_FS; #else return MMCSD_MODE_RAW; diff --git a/arch/arm/mach-socfpga/spl_gen5.c b/arch/arm/mach-socfpga/spl_gen5.c index 98d39a7..4c9f799 100644 --- a/arch/arm/mach-socfpga/spl_gen5.c +++ b/arch/arm/mach-socfpga/spl_gen5.c @@ -55,7 +55,7 @@ u32 spl_boot_device(void) #ifdef CONFIG_SPL_MMC_SUPPORT u32 spl_boot_mode(const u32 boot_device) { -#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_FS_EXT4) return MMCSD_MODE_FS; #else return MMCSD_MODE_RAW; diff --git a/arch/arm/mach-socfpga/spl_s10.c b/arch/arm/mach-socfpga/spl_s10.c index f40a156..a3db20a 100644 --- a/arch/arm/mach-socfpga/spl_s10.c +++ b/arch/arm/mach-socfpga/spl_s10.c @@ -33,7 +33,7 @@ u32 spl_boot_device(void) #ifdef CONFIG_SPL_MMC_SUPPORT u32 spl_boot_mode(const u32 boot_device) { -#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_FS_EXT4) return MMCSD_MODE_FS; #else return MMCSD_MODE_RAW; diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 9042117..c1b0557 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -386,7 +386,7 @@ config SPL_ETH_SUPPORT is required since the network stack uses a number of environment variables. See also SPL_NET_SUPPORT.
-config SPL_EXT_SUPPORT +config SPL_FS_EXT4 bool "Support EXT filesystems" help Enable support for EXT2/3/4 filesystems with SPL. This permits diff --git a/common/spl/Makefile b/common/spl/Makefile index 5d4d6ed..0c20133 100644 --- a/common/spl/Makefile +++ b/common/spl/Makefile @@ -24,7 +24,7 @@ obj-$(CONFIG_$(SPL_TPL_)ATF) += spl_atf.o obj-$(CONFIG_$(SPL_TPL_)OPTEE) += spl_optee.o obj-$(CONFIG_$(SPL_TPL_)USB_SUPPORT) += spl_usb.o obj-$(CONFIG_$(SPL_TPL_)FS_FAT) += spl_fat.o -obj-$(CONFIG_$(SPL_TPL_)EXT_SUPPORT) += spl_ext.o +obj-$(CONFIG_$(SPL_TPL_)FS_EXT4) += spl_ext.o obj-$(CONFIG_$(SPL_TPL_)SATA_SUPPORT) += spl_sata.o obj-$(CONFIG_$(SPL_TPL_)DFU_SUPPORT) += spl_dfu.o obj-$(CONFIG_$(SPL_TPL_)SPI_LOAD) += spl_spi.o diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index e526167..324d91c 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -253,7 +253,7 @@ static int spl_mmc_do_fs_boot(struct spl_image_info *spl_image, struct mmc *mmc) return err; #endif #endif -#ifdef CONFIG_SPL_EXT_SUPPORT +#ifdef CONFIG_SPL_FS_EXT4 if (!spl_start_uboot()) { err = spl_load_image_ext_os(spl_image, mmc_get_blk_desc(mmc), CONFIG_SYS_MMCSD_FS_BOOT_PARTITION); @@ -269,7 +269,7 @@ static int spl_mmc_do_fs_boot(struct spl_image_info *spl_image, struct mmc *mmc) #endif #endif
-#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_FS_EXT4) err = -ENOENT; #endif
u32 __weak spl_boot_mode(const u32 boot_device) { -#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_FS_EXT4) return MMCSD_MODE_FS; #elif defined(CONFIG_SUPPORT_EMMC_BOOT) return MMCSD_MODE_EMMCBOOT; diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index f5c25af..238a18c 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -16,7 +16,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_POWER_SUPPORT=y diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index aa6e966..a285a66 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -18,7 +18,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_FIT_IMAGE_TINY=y # CONFIG_SPL_ENV_SUPPORT is not set -# CONFIG_SPL_EXT_SUPPORT is not set +# CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_MTD_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set # CONFIG_SPL_YMODEM_SUPPORT is not set diff --git a/configs/am335x_hs_evm_uart_defconfig b/configs/am335x_hs_evm_uart_defconfig index b868bc1..230bc26 100644 --- a/configs/am335x_hs_evm_uart_defconfig +++ b/configs/am335x_hs_evm_uart_defconfig @@ -16,7 +16,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y # CONFIG_SPL_ENV_SUPPORT is not set -# CONFIG_SPL_EXT_SUPPORT is not set +# CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_MTD_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/am335x_igep003x_defconfig b/configs/am335x_igep003x_defconfig index af7f34c..34f2f3f 100644 --- a/configs/am335x_igep003x_defconfig +++ b/configs/am335x_igep003x_defconfig @@ -17,7 +17,7 @@ CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0033" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/am335x_shc_defconfig b/configs/am335x_shc_defconfig index 215ac61..1089d48 100644 --- a/configs/am335x_shc_defconfig +++ b/configs/am335x_shc_defconfig @@ -15,7 +15,7 @@ CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_OS_BOOT=y diff --git a/configs/am335x_shc_ict_defconfig b/configs/am335x_shc_ict_defconfig index a335d24..38bc06c 100644 --- a/configs/am335x_shc_ict_defconfig +++ b/configs/am335x_shc_ict_defconfig @@ -16,7 +16,7 @@ CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_OS_BOOT=y diff --git a/configs/am335x_shc_netboot_defconfig b/configs/am335x_shc_netboot_defconfig index 7c66740..6c7bbf8 100644 --- a/configs/am335x_shc_netboot_defconfig +++ b/configs/am335x_shc_netboot_defconfig @@ -17,7 +17,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL_ENV_SUPPORT=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_OS_BOOT=y diff --git a/configs/am335x_shc_prompt_defconfig b/configs/am335x_shc_prompt_defconfig index 984c643..05f57d5 100644 --- a/configs/am335x_shc_prompt_defconfig +++ b/configs/am335x_shc_prompt_defconfig @@ -15,7 +15,7 @@ CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_OS_BOOT=y diff --git a/configs/am335x_shc_sdboot_defconfig b/configs/am335x_shc_sdboot_defconfig index 6fab356..0c545fc 100644 --- a/configs/am335x_shc_sdboot_defconfig +++ b/configs/am335x_shc_sdboot_defconfig @@ -16,7 +16,7 @@ CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_OS_BOOT=y diff --git a/configs/am335x_shc_sdboot_prompt_defconfig b/configs/am335x_shc_sdboot_prompt_defconfig index 6fab356..0c545fc 100644 --- a/configs/am335x_shc_sdboot_prompt_defconfig +++ b/configs/am335x_shc_sdboot_prompt_defconfig @@ -16,7 +16,7 @@ CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_OS_BOOT=y diff --git a/configs/am335x_sl50_defconfig b/configs/am335x_sl50_defconfig index 8908b34..95ae54c 100644 --- a/configs/am335x_sl50_defconfig +++ b/configs/am335x_sl50_defconfig @@ -15,7 +15,7 @@ CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL_ENV_SUPPORT=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_OS_BOOT=y diff --git a/configs/am3517_crane_defconfig b/configs/am3517_crane_defconfig index 0e210f0..530407b 100644 --- a/configs/am3517_crane_defconfig +++ b/configs/am3517_crane_defconfig @@ -8,7 +8,7 @@ CONFIG_EMIF4=y CONFIG_SPL=y CONFIG_NR_DRAM_BANKS=2 CONFIG_BOOTDELAY=10 -# CONFIG_SPL_EXT_SUPPORT is not set +# CONFIG_SPL_FS_EXT4 is not set CONFIG_HUSH_PARSER=y # CONFIG_CMDLINE_EDITING is not set CONFIG_SYS_PROMPT="AM3517_CRANE # " diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 1480557..d55a01b 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -13,7 +13,7 @@ CONFIG_BOOTDELAY=10 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_VERSION_VARIABLE=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y -# CONFIG_SPL_EXT_SUPPORT is not set +# CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_MTD_SUPPORT=y CONFIG_SYS_PROMPT="AM3517_EVM # " # CONFIG_CMD_IMI is not set diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index 90e3bee..4d746d9 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -17,7 +17,7 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MUSB_NEW_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index 05082b5..edc3950 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -17,7 +17,7 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MUSB_NEW_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index 015bab0..3c07fb6 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -20,7 +20,7 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_MISC_INIT_R=y CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/cl-som-am57x_defconfig b/configs/cl-som-am57x_defconfig index c5337f9..5c3f81f 100644 --- a/configs/cl-som-am57x_defconfig +++ b/configs/cl-som-am57x_defconfig @@ -8,7 +8,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_VERSION_VARIABLE=y -# CONFIG_SPL_EXT_SUPPORT is not set +# CONFIG_SPL_FS_EXT4 is not set # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_PROMPT="U-Boot# " diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index 04857bd..85ffad7 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -14,7 +14,7 @@ CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_POWER_SUPPORT=y diff --git a/configs/cm_t35_defconfig b/configs/cm_t35_defconfig index f1fe2d0..c74ab0c 100644 --- a/configs/cm_t35_defconfig +++ b/configs/cm_t35_defconfig @@ -8,7 +8,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y -# CONFIG_SPL_EXT_SUPPORT is not set +# CONFIG_SPL_FS_EXT4 is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T3x # " CONFIG_CMD_BOOTZ=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index 356dbb2..efb29b3 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -19,7 +19,7 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x480 -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MTD_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set diff --git a/configs/eco5pk_defconfig b/configs/eco5pk_defconfig index bc6b85f..b48d8e7 100644 --- a/configs/eco5pk_defconfig +++ b/configs/eco5pk_defconfig @@ -7,7 +7,7 @@ CONFIG_EMIF4=y CONFIG_SPL=y CONFIG_NR_DRAM_BANKS=2 CONFIG_BOOTDELAY=10 -# CONFIG_SPL_EXT_SUPPORT is not set +# CONFIG_SPL_FS_EXT4 is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ECO5-PK # " CONFIG_CMD_EEPROM=y diff --git a/configs/igep0032_defconfig b/configs/igep0032_defconfig index 3836487..c08c7b9 100644 --- a/configs/igep0032_defconfig +++ b/configs/igep0032_defconfig @@ -11,7 +11,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set -# CONFIG_SPL_EXT_SUPPORT is not set +# CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_ONENAND_SUPPORT=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/igep00x0_defconfig b/configs/igep00x0_defconfig index f2989e3..4f2287d 100644 --- a/configs/igep00x0_defconfig +++ b/configs/igep00x0_defconfig @@ -11,7 +11,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set -# CONFIG_SPL_EXT_SUPPORT is not set +# CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_ONENAND_SUPPORT=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/mcx_defconfig b/configs/mcx_defconfig index c30a4dd..a70865c 100644 --- a/configs/mcx_defconfig +++ b/configs/mcx_defconfig @@ -10,7 +10,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y -# CONFIG_SPL_EXT_SUPPORT is not set +# CONFIG_SPL_FS_EXT4 is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="mcx # " # CONFIG_CMD_IMI is not set diff --git a/configs/mt_ventoux_defconfig b/configs/mt_ventoux_defconfig index 1635c69..33b961a 100644 --- a/configs/mt_ventoux_defconfig +++ b/configs/mt_ventoux_defconfig @@ -9,7 +9,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_BOOTDELAY=10 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y -# CONFIG_SPL_EXT_SUPPORT is not set +# CONFIG_SPL_FS_EXT4 is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="mt_ventoux => " CONFIG_CMD_EEPROM=y diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index 6e73a97..0064734 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -16,7 +16,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y # CONFIG_CMD_FLASH is not set diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index 8856567..d7f2ec9 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -16,7 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SUPPORT_RAW_INITRD=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index e0202ef..f27fa7e 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -15,7 +15,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SUPPORT_RAW_INITRD=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_USB_HOST_SUPPORT=y diff --git a/configs/mx6slevk_spl_defconfig b/configs/mx6slevk_spl_defconfig index 4689ed7..e603676 100644 --- a/configs/mx6slevk_spl_defconfig +++ b/configs/mx6slevk_spl_defconfig @@ -14,7 +14,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/mx6sxsabresd_spl_defconfig b/configs/mx6sxsabresd_spl_defconfig index 4a44554..12606ad 100644 --- a/configs/mx6sxsabresd_spl_defconfig +++ b/configs/mx6sxsabresd_spl_defconfig @@ -16,7 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SUPPORT_RAW_INITRD=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index 607045f..d04f4a8 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -15,7 +15,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index 2c8be5f..332700d 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -15,7 +15,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 6274e2f..303c577 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -22,7 +22,7 @@ CONFIG_BOOTCOMMAND="run distro_bootcmd ; run net_nfs" CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_CMD_ASKENV=y diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index 4fb8aec..68f8dee 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -9,7 +9,7 @@ CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DEFAULT_FDT_FILE="omap3-beagle.dtb" CONFIG_VERSION_VARIABLE=y -# CONFIG_SPL_EXT_SUPPORT is not set +# CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="BeagleBoard # " diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 2b8caf2..22e6233 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -9,7 +9,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DEFAULT_FDT_FILE="omap3-evm.dtb" CONFIG_VERSION_VARIABLE=y -# CONFIG_SPL_EXT_SUPPORT is not set +# CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="OMAP3_EVM # " diff --git a/configs/omap3_ha_defconfig b/configs/omap3_ha_defconfig index 6b3fb31..8b71e26 100644 --- a/configs/omap3_ha_defconfig +++ b/configs/omap3_ha_defconfig @@ -7,7 +7,7 @@ CONFIG_SPL=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SYS_EXTRA_OPTIONS="SYS_BOARD_OMAP3_HA" CONFIG_BOOTDELAY=3 -# CONFIG_SPL_EXT_SUPPORT is not set +# CONFIG_SPL_FS_EXT4 is not set CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig index 41df480..1456be7 100644 --- a/configs/omap4_panda_defconfig +++ b/configs/omap4_panda_defconfig @@ -8,7 +8,7 @@ CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run f CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y -# CONFIG_SPL_EXT_SUPPORT is not set +# CONFIG_SPL_FS_EXT4 is not set # CONFIG_SPL_I2C_SUPPORT is not set # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_OS_BOOT=y diff --git a/configs/pcm051_rev1_defconfig b/configs/pcm051_rev1_defconfig index 9d83a7b..bf9c7ac 100644 --- a/configs/pcm051_rev1_defconfig +++ b/configs/pcm051_rev1_defconfig @@ -18,7 +18,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_ETH_SUPPORT=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_NET_SUPPORT=y diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index 53c4ece..ae101a5 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -18,7 +18,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_ETH_SUPPORT=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_NET_SUPPORT=y diff --git a/configs/pcm058_defconfig b/configs/pcm058_defconfig index 66ee9ed..cec9296 100644 --- a/configs/pcm058_defconfig +++ b/configs/pcm058_defconfig @@ -21,7 +21,7 @@ CONFIG_BOOTDELAY=3 CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_DMA_SUPPORT=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index ce94b86..27ce200 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -17,7 +17,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_ETH_SUPPORT=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_NET_SUPPORT=y diff --git a/configs/pepper_defconfig b/configs/pepper_defconfig index edc5da5..5ac91e3 100644 --- a/configs/pepper_defconfig +++ b/configs/pepper_defconfig @@ -14,7 +14,7 @@ CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_POWER_SUPPORT=y diff --git a/configs/pfla02_defconfig b/configs/pfla02_defconfig index 18d35a1..21e1d17 100644 --- a/configs/pfla02_defconfig +++ b/configs/pfla02_defconfig @@ -21,7 +21,7 @@ CONFIG_BOOTDELAY=3 CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_DMA_SUPPORT=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/platinum_picon_defconfig b/configs/platinum_picon_defconfig index 91487c1..a5eef86 100644 --- a/configs/platinum_picon_defconfig +++ b/configs/platinum_picon_defconfig @@ -16,7 +16,7 @@ CONFIG_SUPPORT_RAW_INITRD=y CONFIG_MISC_INIT_R=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_DMA_SUPPORT=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/platinum_titanium_defconfig b/configs/platinum_titanium_defconfig index ee06306..dd73c7d 100644 --- a/configs/platinum_titanium_defconfig +++ b/configs/platinum_titanium_defconfig @@ -16,7 +16,7 @@ CONFIG_SUPPORT_RAW_INITRD=y CONFIG_MISC_INIT_R=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_DMA_SUPPORT=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/sksimx6_defconfig b/configs/sksimx6_defconfig index bd9cc73..d38fb9a 100644 --- a/configs/sksimx6_defconfig +++ b/configs/sksimx6_defconfig @@ -22,7 +22,7 @@ CONFIG_SILENT_CONSOLE=y CONFIG_SILENT_U_BOOT_ONLY=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_CMD_GPIO=y diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index b7ded76..deb2261 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -11,7 +11,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=2 -# CONFIG_SPL_EXT_SUPPORT is not set +# CONFIG_SPL_FS_EXT4 is not set # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SYS_PROMPT="sniper # " # CONFIG_CMD_FLASH is not set diff --git a/configs/tao3530_defconfig b/configs/tao3530_defconfig index daca05e..01c7554 100644 --- a/configs/tao3530_defconfig +++ b/configs/tao3530_defconfig @@ -6,7 +6,7 @@ CONFIG_TARGET_TAO3530=y CONFIG_SPL=y CONFIG_NR_DRAM_BANKS=2 CONFIG_BOOTDELAY=3 -# CONFIG_SPL_EXT_SUPPORT is not set +# CONFIG_SPL_FS_EXT4 is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="TAO-3530 # " # CONFIG_CMD_IMI is not set diff --git a/configs/twister_defconfig b/configs/twister_defconfig index 5632e6d..04c713f 100644 --- a/configs/twister_defconfig +++ b/configs/twister_defconfig @@ -7,7 +7,7 @@ CONFIG_EMIF4=y CONFIG_SPL=y CONFIG_NR_DRAM_BANKS=2 CONFIG_BOOTDELAY=10 -# CONFIG_SPL_EXT_SUPPORT is not set +# CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="twister => " diff --git a/configs/udoo_defconfig b/configs/udoo_defconfig index c9a860c..7199953 100644 --- a/configs/udoo_defconfig +++ b/configs/udoo_defconfig @@ -15,7 +15,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_CMD_GPIO=y diff --git a/configs/udoo_neo_defconfig b/configs/udoo_neo_defconfig index de0e037..7ce0e97 100644 --- a/configs/udoo_neo_defconfig +++ b/configs/udoo_neo_defconfig @@ -16,7 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_ENV_SUPPORT=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_WATCHDOG_SUPPORT=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 4d8ccff..b3d3e7a 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -20,7 +20,7 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y # CONFIG_CMD_FLASH is not set diff --git a/configs/xpress_spl_defconfig b/configs/xpress_spl_defconfig index 7eefa92..cc28e10 100644 --- a/configs/xpress_spl_defconfig +++ b/configs/xpress_spl_defconfig @@ -15,7 +15,7 @@ CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/zc5202_defconfig b/configs/zc5202_defconfig index c79cd22..03cbd1e 100644 --- a/configs/zc5202_defconfig +++ b/configs/zc5202_defconfig @@ -18,7 +18,7 @@ CONFIG_BOOTDELAY=3 CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx6q-zc5202.dtb" CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/zc5601_defconfig b/configs/zc5601_defconfig index e92c63d..b96943d 100644 --- a/configs/zc5601_defconfig +++ b/configs/zc5601_defconfig @@ -18,7 +18,7 @@ CONFIG_BOOTDELAY=3 CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx6q-zc5601.dtb" CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/doc/README.SPL b/doc/README.SPL index 48981bd..7a30fef 100644 --- a/doc/README.SPL +++ b/doc/README.SPL @@ -54,7 +54,7 @@ CONFIG_SPL_SERIAL_SUPPORT (drivers/serial/libserial.o) CONFIG_SPL_SPI_FLASH_SUPPORT (drivers/mtd/spi/libspi_flash.o) CONFIG_SPL_SPI_SUPPORT (drivers/spi/libspi.o) CONFIG_SPL_FS_FAT (fs/fat/libfat.o) -CONFIG_SPL_EXT_SUPPORT +CONFIG_SPL_FS_EXT4 CONFIG_SPL_LIBGENERIC_SUPPORT (lib/libgeneric.o) CONFIG_SPL_POWER_SUPPORT (drivers/power/libpower.o) CONFIG_SPL_NAND_SUPPORT (drivers/mtd/nand/raw/libnand.o) diff --git a/fs/Makefile b/fs/Makefile index bebea6a..10c735a 100644 --- a/fs/Makefile +++ b/fs/Makefile @@ -7,7 +7,7 @@ ifdef CONFIG_SPL_BUILD obj-$(CONFIG_FS_LOADER) += fs.o obj-$(CONFIG_SPL_FS_FAT) += fat/ -obj-$(CONFIG_SPL_EXT_SUPPORT) += ext4/ +obj-$(CONFIG_SPL_FS_EXT4) += ext4/ else obj-y += fs.o
diff --git a/include/configs/imx6_spl.h b/include/configs/imx6_spl.h index 60a925d..3d9a7dc 100644 --- a/include/configs/imx6_spl.h +++ b/include/configs/imx6_spl.h @@ -43,7 +43,7 @@ #endif
/* Define the payload for FAT/EXT support */ -#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_FS_EXT4) # ifdef CONFIG_OF_CONTROL # define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot-dtb.img" # else diff --git a/include/configs/imx7_spl.h b/include/configs/imx7_spl.h index 116ea1a..aca32db 100644 --- a/include/configs/imx7_spl.h +++ b/include/configs/imx7_spl.h @@ -38,7 +38,7 @@ #endif
/* Define the payload for FAT/EXT support */ -#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_FS_EXT4) # ifdef CONFIG_OF_CONTROL # define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot-dtb.img" # else diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 735430a..4551cb2 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -267,7 +267,7 @@ unsigned int cm_get_qspi_controller_clk_hz(void);
/* SPL SDMMC boot support */ #ifdef CONFIG_SPL_MMC_SUPPORT -#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_FS_EXT4) #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot-dtb.img" #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #endif diff --git a/include/part.h b/include/part.h index 388e130..ebca546 100644 --- a/include/part.h +++ b/include/part.h @@ -246,7 +246,7 @@ static inline int blk_get_device_part_str(const char *ifname, */ #ifdef CONFIG_SPL_BUILD # define part_print_ptr(x) NULL -# if defined(CONFIG_SPL_EXT_SUPPORT) || defined(CONFIG_SPL_FS_FAT) || \ +# if defined(CONFIG_SPL_FS_EXT4) || defined(CONFIG_SPL_FS_FAT) || \ defined(CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION) # define part_get_info_ptr(x) x # else
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Reviewed-by: Tom Rini trini@konsulko.com
CONFIG_SPL_FS_EXT4 can be used to include/exclude the FS EXT4 from SPL build. Excluding the FS EXT4 from SPL build can help to save 20KiB memory.
changes in v2: - Changed both config checking SPL_BUILD and FS_EXT4 to CONFIG_IS_ENABLED(FS_EXT4). --- fs/fs.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/fs/fs.c b/fs/fs.c index 48b8e9a..21adbde 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -183,7 +183,8 @@ static struct fstype_info fstypes[] = { .closedir = fat_closedir, }, #endif -#ifdef CONFIG_FS_EXT4 + +#if CONFIG_IS_ENABLED(FS_EXT4) { .fstype = FS_TYPE_EXT, .name = "ext4",
Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FAT so obj-$(CONFIG_$(SPL_)FS_FAT) can be used to control the build in both SPL and U-Boot.
arch/arm/cpu/armv8/zynqmp/Kconfig | 2 +- arch/arm/mach-imx/spl.c | 2 +- arch/arm/mach-k3/am6_init.c | 2 +- arch/arm/mach-omap2/Kconfig | 6 +++--- arch/arm/mach-omap2/am33xx/Kconfig | 4 ++-- arch/arm/mach-socfpga/spl_a10.c | 2 +- arch/arm/mach-socfpga/spl_gen5.c | 2 +- arch/arm/mach-socfpga/spl_s10.c | 2 +- arch/arm/mach-zynq/Kconfig | 2 +- common/spl/Kconfig | 2 +- common/spl/Makefile | 2 +- common/spl/spl_mmc.c | 6 +++--- configs/am335x_baltos_defconfig | 2 +- configs/am335x_hs_evm_uart_defconfig | 2 +- configs/am335x_igep003x_defconfig | 2 +- configs/am335x_pdu001_defconfig | 2 +- configs/am335x_shc_defconfig | 2 +- configs/am335x_shc_ict_defconfig | 2 +- configs/am335x_shc_netboot_defconfig | 2 +- configs/am335x_shc_prompt_defconfig | 2 +- configs/am335x_shc_sdboot_defconfig | 2 +- configs/am335x_shc_sdboot_prompt_defconfig | 2 +- configs/am335x_sl50_defconfig | 2 +- configs/am65x_evm_a53_defconfig | 2 +- configs/am65x_evm_r5_defconfig | 2 +- configs/birdland_bav335a_defconfig | 2 +- configs/birdland_bav335b_defconfig | 2 +- configs/chiliboard_defconfig | 2 +- configs/cm_t335_defconfig | 2 +- configs/cm_t43_defconfig | 2 +- configs/draco_defconfig | 2 +- configs/etamin_defconfig | 2 +- configs/novena_defconfig | 2 +- configs/pcm051_rev1_defconfig | 2 +- configs/pcm051_rev3_defconfig | 2 +- configs/pengwyn_defconfig | 2 +- configs/pepper_defconfig | 2 +- configs/picosam9g45_defconfig | 2 +- configs/pxm2_defconfig | 2 +- configs/rastaban_defconfig | 2 +- configs/rut_defconfig | 2 +- configs/sama5d27_som1_ek_mmc1_defconfig | 2 +- configs/sama5d27_som1_ek_mmc_defconfig | 2 +- configs/sama5d2_xplained_emmc_defconfig | 2 +- configs/sama5d2_xplained_mmc_defconfig | 2 +- configs/sama5d3_xplained_mmc_defconfig | 2 +- configs/sama5d3xek_mmc_defconfig | 2 +- configs/sama5d4_xplained_mmc_defconfig | 2 +- configs/sama5d4ek_mmc_defconfig | 2 +- configs/socfpga_arria10_defconfig | 2 +- configs/socfpga_stratix10_defconfig | 2 +- configs/thuban_defconfig | 2 +- configs/ti814x_evm_defconfig | 2 +- configs/ti816x_evm_defconfig | 2 +- configs/xilinx_zynqmp_zc1232_revA_defconfig | 2 +- configs/xilinx_zynqmp_zc1254_revA_defconfig | 2 +- configs/xilinx_zynqmp_zc1275_revA_defconfig | 2 +- configs/xilinx_zynqmp_zc1275_revB_defconfig | 2 +- configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 2 +- configs/zynq_zc770_xm011_defconfig | 2 +- configs/zynq_zc770_xm011_x16_defconfig | 2 +- configs/zynq_zc770_xm012_defconfig | 2 +- configs/zynq_zc770_xm013_defconfig | 2 +- doc/README.SPL | 2 +- fs/Makefile | 2 +- include/configs/imx6_spl.h | 2 +- include/configs/imx7_spl.h | 2 +- include/configs/socfpga_common.h | 2 +- include/part.h | 2 +- 69 files changed, 74 insertions(+), 74 deletions(-)
diff --git a/arch/arm/cpu/armv8/zynqmp/Kconfig b/arch/arm/cpu/armv8/zynqmp/Kconfig index 8a311e1..e9f7e7e 100644 --- a/arch/arm/cpu/armv8/zynqmp/Kconfig +++ b/arch/arm/cpu/armv8/zynqmp/Kconfig @@ -1,6 +1,6 @@ if ARCH_ZYNQMP
-config SPL_FAT_SUPPORT +config SPL_FS_FAT default y
config SPL_LIBCOMMON_SUPPORT diff --git a/arch/arm/mach-imx/spl.c b/arch/arm/mach-imx/spl.c index a20b30d..6c57ef2 100644 --- a/arch/arm/mach-imx/spl.c +++ b/arch/arm/mach-imx/spl.c @@ -162,7 +162,7 @@ u32 spl_boot_mode(const u32 boot_device) /* for MMC return either RAW or FAT mode */ case BOOT_DEVICE_MMC1: case BOOT_DEVICE_MMC2: -#if defined(CONFIG_SPL_FAT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) return MMCSD_MODE_FS; #elif defined(CONFIG_SUPPORT_EMMC_BOOT) return MMCSD_MODE_EMMCBOOT; diff --git a/arch/arm/mach-k3/am6_init.c b/arch/arm/mach-k3/am6_init.c index e2fe00c..4aef3cd 100644 --- a/arch/arm/mach-k3/am6_init.c +++ b/arch/arm/mach-k3/am6_init.c @@ -106,7 +106,7 @@ u32 spl_boot_mode(const u32 boot_device) #endif
-#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) return MMCSD_MODE_FS; #else return MMCSD_MODE_RAW; diff --git a/arch/arm/mach-omap2/Kconfig b/arch/arm/mach-omap2/Kconfig index 58e545a..7293362 100644 --- a/arch/arm/mach-omap2/Kconfig +++ b/arch/arm/mach-omap2/Kconfig @@ -14,7 +14,7 @@ config OMAP34XX select USE_TINY_PRINTF imply NAND_OMAP_GPMC imply SPL_EXT_SUPPORT
imply SPL_FAT_SUPPORT
imply SPL_FS_FAT imply SPL_GPIO_SUPPORT imply SPL_I2C_SUPPORT imply SPL_LIBCOMMON_SUPPORT
@@ -36,7 +36,7 @@ config OMAP44XX imply NAND_OMAP_GPMC imply SPL_DISPLAY_PRINT imply SPL_EXT_SUPPORT
@@ -60,7 +60,7 @@ config OMAP54XX imply SPL_DISPLAY_PRINT imply SPL_ENV_SUPPORT imply SPL_EXT_SUPPORT
diff --git a/arch/arm/mach-omap2/am33xx/Kconfig b/arch/arm/mach-omap2/am33xx/Kconfig index 3529607..6902034 100644 --- a/arch/arm/mach-omap2/am33xx/Kconfig +++ b/arch/arm/mach-omap2/am33xx/Kconfig @@ -39,7 +39,7 @@ config TARGET_AM335X_EVM imply SPL_DM_SEQ_ALIAS imply SPL_ENV_SUPPORT imply SPL_EXT_SUPPORT
@@ -232,7 +232,7 @@ config TARGET_AM43XX_EVM imply SPI_FLASH_BAR imply SPL_ENV_SUPPORT imply SPL_EXT_SUPPORT
diff --git a/arch/arm/mach-socfpga/spl_a10.c b/arch/arm/mach-socfpga/spl_a10.c index d523167..bd21fc2 100644 --- a/arch/arm/mach-socfpga/spl_a10.c +++ b/arch/arm/mach-socfpga/spl_a10.c @@ -63,7 +63,7 @@ u32 spl_boot_device(void) #ifdef CONFIG_SPL_MMC_SUPPORT u32 spl_boot_mode(const u32 boot_device) { -#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) return MMCSD_MODE_FS; #else return MMCSD_MODE_RAW; diff --git a/arch/arm/mach-socfpga/spl_gen5.c b/arch/arm/mach-socfpga/spl_gen5.c index ccdc661..98d39a7 100644 --- a/arch/arm/mach-socfpga/spl_gen5.c +++ b/arch/arm/mach-socfpga/spl_gen5.c @@ -55,7 +55,7 @@ u32 spl_boot_device(void) #ifdef CONFIG_SPL_MMC_SUPPORT u32 spl_boot_mode(const u32 boot_device) { -#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) return MMCSD_MODE_FS; #else return MMCSD_MODE_RAW; diff --git a/arch/arm/mach-socfpga/spl_s10.c b/arch/arm/mach-socfpga/spl_s10.c index cc5dc4f..f40a156 100644 --- a/arch/arm/mach-socfpga/spl_s10.c +++ b/arch/arm/mach-socfpga/spl_s10.c @@ -33,7 +33,7 @@ u32 spl_boot_device(void) #ifdef CONFIG_SPL_MMC_SUPPORT u32 spl_boot_mode(const u32 boot_device) { -#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) return MMCSD_MODE_FS; #else return MMCSD_MODE_RAW; diff --git a/arch/arm/mach-zynq/Kconfig b/arch/arm/mach-zynq/Kconfig index a599ed6..8946da2 100644 --- a/arch/arm/mach-zynq/Kconfig +++ b/arch/arm/mach-zynq/Kconfig @@ -3,7 +3,7 @@ if ARCH_ZYNQ config SPL_LDSCRIPT default "arch/arm/mach-zynq/u-boot-spl.lds"
config SPL_LIBCOMMON_SUPPORT diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 0ddbffc..93e7fe9 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -394,7 +394,7 @@ config SPL_EXT_SUPPORT filesystem from within SPL. Support for the underlying block device (e.g. MMC or USB) must be enabled separately.
-config SPL_FAT_SUPPORT +config SPL_FS_FAT bool "Support FAT filesystems" select FS_FAT help diff --git a/common/spl/Makefile b/common/spl/Makefile index a130a5b..5d4d6ed 100644 --- a/common/spl/Makefile +++ b/common/spl/Makefile @@ -23,7 +23,7 @@ obj-$(CONFIG_$(SPL_TPL_)MMC_SUPPORT) += spl_mmc.o obj-$(CONFIG_$(SPL_TPL_)ATF) += spl_atf.o obj-$(CONFIG_$(SPL_TPL_)OPTEE) += spl_optee.o obj-$(CONFIG_$(SPL_TPL_)USB_SUPPORT) += spl_usb.o -obj-$(CONFIG_$(SPL_TPL_)FAT_SUPPORT) += spl_fat.o +obj-$(CONFIG_$(SPL_TPL_)FS_FAT) += spl_fat.o obj-$(CONFIG_$(SPL_TPL_)EXT_SUPPORT) += spl_ext.o obj-$(CONFIG_$(SPL_TPL_)SATA_SUPPORT) += spl_sata.o obj-$(CONFIG_$(SPL_TPL_)DFU_SUPPORT) += spl_dfu.o diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index 4d55dcc..e526167 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -238,7 +238,7 @@ static int spl_mmc_do_fs_boot(struct spl_image_info *spl_image, struct mmc *mmc) { int err = -ENOSYS;
-#ifdef CONFIG_SPL_FAT_SUPPORT +#ifdef CONFIG_SPL_FS_FAT if (!spl_start_uboot()) { err = spl_load_image_fat_os(spl_image, mmc_get_blk_desc(mmc), CONFIG_SYS_MMCSD_FS_BOOT_PARTITION); @@ -269,7 +269,7 @@ static int spl_mmc_do_fs_boot(struct spl_image_info *spl_image, struct mmc *mmc) #endif #endif
-#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) err = -ENOENT; #endif
@@ -284,7 +284,7 @@ static int spl_mmc_do_fs_boot(struct spl_image_info *spl_image, struct mmc *mmc)
u32 __weak spl_boot_mode(const u32 boot_device) { -#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) return MMCSD_MODE_FS; #elif defined(CONFIG_SUPPORT_EMMC_BOOT) return MMCSD_MODE_EMMCBOOT; diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index 05d41ae..f5c25af 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -7,7 +7,7 @@ CONFIG_TARGET_AM335X_BALTOS=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y diff --git a/configs/am335x_hs_evm_uart_defconfig b/configs/am335x_hs_evm_uart_defconfig index 419b41c..b868bc1 100644 --- a/configs/am335x_hs_evm_uart_defconfig +++ b/configs/am335x_hs_evm_uart_defconfig @@ -6,7 +6,7 @@ CONFIG_AM33XX=y CONFIG_ISW_ENTRY_ADDR=0x40301950 # CONFIG_SPL_MMC_SUPPORT is not set CONFIG_SPL=y -# CONFIG_SPL_FAT_SUPPORT is not set +# CONFIG_SPL_FS_FAT is not set # CONFIG_SPL_LIBDISK_SUPPORT is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_IMAGE_POST_PROCESS=y diff --git a/configs/am335x_igep003x_defconfig b/configs/am335x_igep003x_defconfig index 16affb8..af7f34c 100644 --- a/configs/am335x_igep003x_defconfig +++ b/configs/am335x_igep003x_defconfig @@ -9,7 +9,7 @@ CONFIG_TARGET_AM335X_IGEP003X=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/am335x_pdu001_defconfig b/configs/am335x_pdu001_defconfig index 3cb38af..2e64baf 100644 --- a/configs/am335x_pdu001_defconfig +++ b/configs/am335x_pdu001_defconfig @@ -7,7 +7,7 @@ CONFIG_TARGET_PDU001=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_LOCALVERSION="-EETS-1.0.0" CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/am335x_shc_defconfig b/configs/am335x_shc_defconfig index 25e1a4f..215ac61 100644 --- a/configs/am335x_shc_defconfig +++ b/configs/am335x_shc_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_AM335X_SHC=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SERIES=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/am335x_shc_ict_defconfig b/configs/am335x_shc_ict_defconfig index 9ebfe5e..a335d24 100644 --- a/configs/am335x_shc_ict_defconfig +++ b/configs/am335x_shc_ict_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_AM335X_SHC=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SHC_ICT=y CONFIG_SERIES=y diff --git a/configs/am335x_shc_netboot_defconfig b/configs/am335x_shc_netboot_defconfig index 064b3c3..7c66740 100644 --- a/configs/am335x_shc_netboot_defconfig +++ b/configs/am335x_shc_netboot_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_AM335X_SHC=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SHC_NETBOOT=y CONFIG_SERIES=y diff --git a/configs/am335x_shc_prompt_defconfig b/configs/am335x_shc_prompt_defconfig index dce8334..984c643 100644 --- a/configs/am335x_shc_prompt_defconfig +++ b/configs/am335x_shc_prompt_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_AM335X_SHC=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SERIES=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/am335x_shc_sdboot_defconfig b/configs/am335x_shc_sdboot_defconfig index e4e6ade..6fab356 100644 --- a/configs/am335x_shc_sdboot_defconfig +++ b/configs/am335x_shc_sdboot_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_AM335X_SHC=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SHC_SDBOOT=y CONFIG_SERIES=y diff --git a/configs/am335x_shc_sdboot_prompt_defconfig b/configs/am335x_shc_sdboot_prompt_defconfig index e4e6ade..6fab356 100644 --- a/configs/am335x_shc_sdboot_prompt_defconfig +++ b/configs/am335x_shc_sdboot_prompt_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_AM335X_SHC=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SHC_SDBOOT=y CONFIG_SERIES=y diff --git a/configs/am335x_sl50_defconfig b/configs/am335x_sl50_defconfig index a45fd3d..8908b34 100644 --- a/configs/am335x_sl50_defconfig +++ b/configs/am335x_sl50_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_AM335X_SL50=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT" diff --git a/configs/am65x_evm_a53_defconfig b/configs/am65x_evm_a53_defconfig index a17cf7c..8f6fd25 100644 --- a/configs/am65x_evm_a53_defconfig +++ b/configs/am65x_evm_a53_defconfig @@ -9,7 +9,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 diff --git a/configs/am65x_evm_r5_defconfig b/configs/am65x_evm_r5_defconfig index 237b9e8..d2ec2dd 100644 --- a/configs/am65x_evm_r5_defconfig +++ b/configs/am65x_evm_r5_defconfig @@ -10,7 +10,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index 89c7778..90e3bee 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_BAV335X=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_BAV_VERSION=1 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index e3dc88b..05082b5 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_BAV335X=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_BAV_VERSION=2 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index 3de0223..f99bec6 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -7,7 +7,7 @@ CONFIG_TARGET_CHILIBOARD=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index 134b093..04857bd 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_CM_T335=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index eb4a8f5..356dbb2 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -7,7 +7,7 @@ CONFIG_TARGET_CM_T43=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index be64c1a..60f679c 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -11,7 +11,7 @@ CONFIG_TARGET_DRACO=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index a6b03f9..525e0d9 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -11,7 +11,7 @@ CONFIG_TARGET_ETAMIN=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 7eda3ac..6274e2f 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -9,7 +9,7 @@ CONFIG_TARGET_KOSAGI_NOVENA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_CMD_HDMIDETECT=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/pcm051_rev1_defconfig b/configs/pcm051_rev1_defconfig index 0be0caa..9d83a7b 100644 --- a/configs/pcm051_rev1_defconfig +++ b/configs/pcm051_rev1_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_PCM051=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="REV1" diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index 33e8225..53c4ece 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_PCM051=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="REV3" diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index 3c8684a..ce94b86 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_PENGWYN=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/pepper_defconfig b/configs/pepper_defconfig index 1dc3944..edc5da5 100644 --- a/configs/pepper_defconfig +++ b/configs/pepper_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_PEPPER=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/picosam9g45_defconfig b/configs/picosam9g45_defconfig index 699e2e2..36ae439 100644 --- a/configs/picosam9g45_defconfig +++ b/configs/picosam9g45_defconfig @@ -9,7 +9,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_MMC" diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 4a5c3c6..086b6f0 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -11,7 +11,7 @@ CONFIG_TARGET_PXM2=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index 09b64a3..7fbcdc3 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -11,7 +11,7 @@ CONFIG_TARGET_RASTABAN=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index 08eafc2..32d7143 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -11,7 +11,7 @@ CONFIG_TARGET_RUT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y diff --git a/configs/sama5d27_som1_ek_mmc1_defconfig b/configs/sama5d27_som1_ek_mmc1_defconfig index 13395ef..5f4abe8 100644 --- a/configs/sama5d27_som1_ek_mmc1_defconfig +++ b/configs/sama5d27_som1_ek_mmc1_defconfig @@ -13,7 +13,7 @@ CONFIG_SPL=y CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xf8020000 CONFIG_DEBUG_UART_CLOCK=82000000 -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/sama5d27_som1_ek_mmc_defconfig b/configs/sama5d27_som1_ek_mmc_defconfig index e260554..5dcd80c 100644 --- a/configs/sama5d27_som1_ek_mmc_defconfig +++ b/configs/sama5d27_som1_ek_mmc_defconfig @@ -13,7 +13,7 @@ CONFIG_SPL=y CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xf8020000 CONFIG_DEBUG_UART_CLOCK=82000000 -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/sama5d2_xplained_emmc_defconfig b/configs/sama5d2_xplained_emmc_defconfig index 4e61692..d6c30e2 100644 --- a/configs/sama5d2_xplained_emmc_defconfig +++ b/configs/sama5d2_xplained_emmc_defconfig @@ -13,7 +13,7 @@ CONFIG_SPL=y CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xf8020000 CONFIG_DEBUG_UART_CLOCK=83000000 -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index fd25261..49e2a73 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -13,7 +13,7 @@ CONFIG_SPL=y CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xf8020000 CONFIG_DEBUG_UART_CLOCK=83000000 -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/sama5d3_xplained_mmc_defconfig b/configs/sama5d3_xplained_mmc_defconfig index eab38ec..c7b7736 100644 --- a/configs/sama5d3_xplained_mmc_defconfig +++ b/configs/sama5d3_xplained_mmc_defconfig @@ -13,7 +13,7 @@ CONFIG_SPL=y CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xffffee00 CONFIG_DEBUG_UART_CLOCK=132000000 -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index 6faea0e..a4f10fa 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -13,7 +13,7 @@ CONFIG_SPL=y CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xffffee00 CONFIG_DEBUG_UART_CLOCK=132000000 -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index bfcea3f..9f15c97 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -13,7 +13,7 @@ CONFIG_SPL=y CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xfc00c000 CONFIG_DEBUG_UART_CLOCK=100000000 -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index 45e6539..9e2e1a9 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -13,7 +13,7 @@ CONFIG_SPL=y CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xfc00c000 CONFIG_DEBUG_UART_CLOCK=88000000 -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/socfpga_arria10_defconfig b/configs/socfpga_arria10_defconfig index e5fc807..038a708 100644 --- a/configs/socfpga_arria10_defconfig +++ b/configs/socfpga_arria10_defconfig @@ -33,7 +33,7 @@ CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_DM_MMC=y CONFIG_SPL_MMC_SUPPORT=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_FS_LOADER=y CONFIG_FPGA_SOCFPGA=y diff --git a/configs/socfpga_stratix10_defconfig b/configs/socfpga_stratix10_defconfig index 5f3d733..bc3a3a3 100644 --- a/configs/socfpga_stratix10_defconfig +++ b/configs/socfpga_stratix10_defconfig @@ -5,7 +5,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_SOCFPGA_STRATIX10_SOCDK=y CONFIG_SPL=y CONFIG_IDENT_STRING="socfpga_stratix10" -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_BOOTDELAY=5 CONFIG_SPL_SPI_LOAD=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index b856b9d..2adf156 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -11,7 +11,7 @@ CONFIG_TARGET_THUBAN=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y diff --git a/configs/ti814x_evm_defconfig b/configs/ti814x_evm_defconfig index b78dc7e..1343d8f 100644 --- a/configs/ti814x_evm_defconfig +++ b/configs/ti814x_evm_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_TI814X_EVM=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index 381f464..2e8a598 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -8,7 +8,7 @@ CONFIG_TARGET_TI816X_EVM=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 diff --git a/configs/xilinx_zynqmp_zc1232_revA_defconfig b/configs/xilinx_zynqmp_zc1232_revA_defconfig index 7521fc4..8596bd8 100644 --- a/configs/xilinx_zynqmp_zc1232_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1232_revA_defconfig @@ -5,7 +5,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xff000000 CONFIG_DEBUG_UART_CLOCK=100000000 -# CONFIG_SPL_FAT_SUPPORT is not set +# CONFIG_SPL_FS_FAT is not set # CONFIG_SPL_LIBDISK_SUPPORT is not set CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/xilinx_zynqmp_zc1254_revA_defconfig b/configs/xilinx_zynqmp_zc1254_revA_defconfig index e0822b9..95ae16c 100644 --- a/configs/xilinx_zynqmp_zc1254_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1254_revA_defconfig @@ -5,7 +5,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xff000000 CONFIG_DEBUG_UART_CLOCK=100000000 -# CONFIG_SPL_FAT_SUPPORT is not set +# CONFIG_SPL_FS_FAT is not set # CONFIG_SPL_LIBDISK_SUPPORT is not set CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/xilinx_zynqmp_zc1275_revA_defconfig b/configs/xilinx_zynqmp_zc1275_revA_defconfig index 3afed69..7997047 100644 --- a/configs/xilinx_zynqmp_zc1275_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1275_revA_defconfig @@ -5,7 +5,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xff000000 CONFIG_DEBUG_UART_CLOCK=100000000 -# CONFIG_SPL_FAT_SUPPORT is not set +# CONFIG_SPL_FS_FAT is not set # CONFIG_SPL_LIBDISK_SUPPORT is not set CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/xilinx_zynqmp_zc1275_revB_defconfig b/configs/xilinx_zynqmp_zc1275_revB_defconfig index 7e31b11..e0e52f9 100644 --- a/configs/xilinx_zynqmp_zc1275_revB_defconfig +++ b/configs/xilinx_zynqmp_zc1275_revB_defconfig @@ -6,7 +6,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xff000000 CONFIG_DEBUG_UART_CLOCK=100000000 -# CONFIG_SPL_FAT_SUPPORT is not set +# CONFIG_SPL_FS_FAT is not set # CONFIG_SPL_LIBDISK_SUPPORT is not set CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index c2b3d18..bb738ae 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -5,7 +5,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xff000000 CONFIG_DEBUG_UART_CLOCK=100000000 -# CONFIG_SPL_FAT_SUPPORT is not set +# CONFIG_SPL_FS_FAT is not set # CONFIG_SPL_LIBDISK_SUPPORT is not set CONFIG_ZYNQMP_USB=y CONFIG_DEBUG_UART=y diff --git a/configs/zynq_zc770_xm011_defconfig b/configs/zynq_zc770_xm011_defconfig index c15877d..70a76e6 100644 --- a/configs/zynq_zc770_xm011_defconfig +++ b/configs/zynq_zc770_xm011_defconfig @@ -6,7 +6,7 @@ CONFIG_DEBUG_UART_BASE=0xe0001000 CONFIG_DEBUG_UART_CLOCK=50000000 CONFIG_IDENT_STRING=" Xilinx Zynq ZC770 XM011" CONFIG_SPL_STACK_R_ADDR=0x200000 -# CONFIG_SPL_FAT_SUPPORT is not set +# CONFIG_SPL_FS_FAT is not set CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y diff --git a/configs/zynq_zc770_xm011_x16_defconfig b/configs/zynq_zc770_xm011_x16_defconfig index 60627da..2a6ffa5 100644 --- a/configs/zynq_zc770_xm011_x16_defconfig +++ b/configs/zynq_zc770_xm011_x16_defconfig @@ -6,7 +6,7 @@ CONFIG_DEBUG_UART_BASE=0xe0001000 CONFIG_DEBUG_UART_CLOCK=50000000 CONFIG_IDENT_STRING=" Xilinx Zynq ZC770 XM011 x16" CONFIG_SPL_STACK_R_ADDR=0x200000 -# CONFIG_SPL_FAT_SUPPORT is not set +# CONFIG_SPL_FS_FAT is not set CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y diff --git a/configs/zynq_zc770_xm012_defconfig b/configs/zynq_zc770_xm012_defconfig index aa20971..8c92505 100644 --- a/configs/zynq_zc770_xm012_defconfig +++ b/configs/zynq_zc770_xm012_defconfig @@ -4,7 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x4000000 CONFIG_SPL=y CONFIG_IDENT_STRING=" Xilinx Zynq ZC770 XM012" CONFIG_SPL_STACK_R_ADDR=0x200000 -# CONFIG_SPL_FAT_SUPPORT is not set +# CONFIG_SPL_FS_FAT is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y diff --git a/configs/zynq_zc770_xm013_defconfig b/configs/zynq_zc770_xm013_defconfig index a08bd29..630e392 100644 --- a/configs/zynq_zc770_xm013_defconfig +++ b/configs/zynq_zc770_xm013_defconfig @@ -4,7 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x4000000 CONFIG_SPL=y CONFIG_IDENT_STRING=" Xilinx Zynq ZC770 XM013" CONFIG_SPL_STACK_R_ADDR=0x200000 -# CONFIG_SPL_FAT_SUPPORT is not set +# CONFIG_SPL_FS_FAT is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y diff --git a/doc/README.SPL b/doc/README.SPL index fc1ca1a..48981bd 100644 --- a/doc/README.SPL +++ b/doc/README.SPL @@ -53,7 +53,7 @@ CONFIG_SPL_MMC_SUPPORT (drivers/mmc/libmmc.o) CONFIG_SPL_SERIAL_SUPPORT (drivers/serial/libserial.o) CONFIG_SPL_SPI_FLASH_SUPPORT (drivers/mtd/spi/libspi_flash.o) CONFIG_SPL_SPI_SUPPORT (drivers/spi/libspi.o) -CONFIG_SPL_FAT_SUPPORT (fs/fat/libfat.o) +CONFIG_SPL_FS_FAT (fs/fat/libfat.o) CONFIG_SPL_EXT_SUPPORT CONFIG_SPL_LIBGENERIC_SUPPORT (lib/libgeneric.o) CONFIG_SPL_POWER_SUPPORT (drivers/power/libpower.o) diff --git a/fs/Makefile b/fs/Makefile index f21cd23..bebea6a 100644 --- a/fs/Makefile +++ b/fs/Makefile @@ -6,7 +6,7 @@
ifdef CONFIG_SPL_BUILD obj-$(CONFIG_FS_LOADER) += fs.o -obj-$(CONFIG_SPL_FAT_SUPPORT) += fat/ +obj-$(CONFIG_SPL_FS_FAT) += fat/ obj-$(CONFIG_SPL_EXT_SUPPORT) += ext4/ else obj-y += fs.o diff --git a/include/configs/imx6_spl.h b/include/configs/imx6_spl.h index 720ff04..60a925d 100644 --- a/include/configs/imx6_spl.h +++ b/include/configs/imx6_spl.h @@ -43,7 +43,7 @@ #endif
/* Define the payload for FAT/EXT support */ -#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) # ifdef CONFIG_OF_CONTROL # define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot-dtb.img" # else diff --git a/include/configs/imx7_spl.h b/include/configs/imx7_spl.h index 1eb6cd8..116ea1a 100644 --- a/include/configs/imx7_spl.h +++ b/include/configs/imx7_spl.h @@ -38,7 +38,7 @@ #endif
/* Define the payload for FAT/EXT support */ -#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) # ifdef CONFIG_OF_CONTROL # define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot-dtb.img" # else diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index bd8f5c8..735430a 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -267,7 +267,7 @@ unsigned int cm_get_qspi_controller_clk_hz(void);
/* SPL SDMMC boot support */ #ifdef CONFIG_SPL_MMC_SUPPORT -#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_EXT_SUPPORT) #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot-dtb.img" #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #endif diff --git a/include/part.h b/include/part.h index 0750aee..388e130 100644 --- a/include/part.h +++ b/include/part.h @@ -246,7 +246,7 @@ static inline int blk_get_device_part_str(const char *ifname, */ #ifdef CONFIG_SPL_BUILD # define part_print_ptr(x) NULL -# if defined(CONFIG_SPL_EXT_SUPPORT) || defined(CONFIG_SPL_FAT_SUPPORT) || \ +# if defined(CONFIG_SPL_EXT_SUPPORT) || defined(CONFIG_SPL_FS_FAT) || \ defined(CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION) # define part_get_info_ptr(x) x
# else
2.2.0
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Reviewed-by: Tom Rini trini@konsulko.com
Simon Goldschmidt
