[U-Boot] [PULL] Please pull u-boot-imx
Hi Tom,
please pull from u-boot-imx, thanks !
The following changes since commit f33cdaa4c3da4a8fd35aa2f9a3172f31cc887b35:
Prepare v2015.04 (2015-04-13 10:53:03 -0400)
git://www.denx.de/git/u-boot-imx.git master
for you to fetch changes up to 205d58699b157df75f1aa0b363ea9c21add21a0c:
mx6cuboxi: Load the correct 'fdtfile' variable (2015-04-27 13:13:58 +0200)
---------------------------------------------------------------- Eric Nelson (1): nitrogen6x: allow gzipped bitmap display
Fabio Estevam (9): mx6: Add initial SPL support for HummingBoard-i2eX mx6sabresd: Fix SPL memory description mx6sabresd: Remove uneeded ifdef mx6cuboxi: Fix the defconfig name mx6cuboxi: Prepare for multi SoC support mx6cuboxi: Introduce multi-SoC support mx6cuboxi: Differentiate Cubox-i and Hummingboard mx6cuboxi: Use more standard namings for fdt variables mx6cuboxi: Load the correct 'fdtfile' variable
Jörg Krause (1): ARM: mxs: Get boot mode from OCRAM
Pushpal Sidhu (3): imx: ventana: add DT fixup for GW522x to change PCIE_RST# GPIO imx: ventana: Add new memory configuration imx: ventana: Update missing memory/calib handling
Stefan Roese (1): arm: mx6: tqma6: Extract baseboard configs into separate config file
Tim Harvey (34): arm: mx6: ddr: add pd_fast_exit flag to system information fdt: add new fdt_fixup_display function to configure display imx: ventana: disable 4k tftp/nfs packets imx: ventana: add i210 support imx: ventana: assign default ethprime dynamically imx: ventana: remove unused GPIO configuration imx: ventana: add usb_pcisel hwconfig support imx: ventana: enable precharge power-down fast-exit mode imx: ventana: add support for 4Gb density mem devices with IMX6DL imx: ventana: set LTC3676 PMIC to appropriate values per datasheet imx: ventana: config: add USB Mass Storage (ums) support imx: ventana: config: Support ramdisk imx: ventana: config: enable edid support imx: ventana: config: enable EXT4 filesystem read/write support imx: ventana: fix various sparse warnings imx: ventana: disable IMX6 watchdogs on GW51xx RevA and RevB imx: ventana: Add support for GW551x imx: ventana: add usb_pgood_delay 2sec default imx: ventana: add wdis config for GW5520 imx: ventana: only pinmux FEC enet signals for boards using it imx: ventana: update boot scripts to support ubifs boot vol imx: ventana: remove GSC hwmon voltage rail min/max test imx: ventana: add mem_mb dynamic env var imx: ventana: gsc: add new hwmon rails imx: ventana: added DT fixup for GW551x-A video input imx: ventana: updated 16bit DDR calibration imx: ventana: remove 128x16 calibration (share with 128x32) imx: ventana: add DT fixup for GW54xx compatibility with older kernels imx: ventana: add support for DLC-700JMGT4 and DLC-800FIGT3 LCD displays imx: ventana: added device-tree display configuration for LVDS displays imx: ventana: add 'gsc wd' command for enabling and disabling GSC watchdog imx: ventana: use hdmiinfmt env var to override HDMI capture format imx: ventana: set HDMI video in to yuv422bt656 for GW551x-A power: pfuze100: fix LDO_EN bit value
gaurav rana (1): iMX: Fix compilation error when enabling SECURE_BOOT
arch/arm/Kconfig | 6 ++ arch/arm/cpu/arm926ejs/mxs/spl_boot.c | 29 ++-------- arch/arm/cpu/armv7/mx6/ddr.c | 7 ++- arch/arm/include/asm/arch-mx6/mx6-ddr.h | 1 + board/freescale/common/Makefile | 3 +- board/freescale/mx6sabresd/mx6sabresd.c | 13 ++--- board/gateworks/gw_ventana/eeprom.c | 10 +++- board/gateworks/gw_ventana/gsc.c | 130 +++++++++++++++++++++++++++++------------ board/gateworks/gw_ventana/gsc.h | 10 +++- board/gateworks/gw_ventana/gw_ventana.c | 367 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++-------------------- board/gateworks/gw_ventana/gw_ventana_spl.c | 129 ++++++++++++++++++++++++++++++++++++----- board/gateworks/gw_ventana/ventana_eeprom.h | 1 + board/solidrun/mx6cuboxi/Kconfig | 15 +++++ board/solidrun/mx6cuboxi/MAINTAINERS | 6 ++ board/solidrun/mx6cuboxi/Makefile | 9 +++ board/solidrun/mx6cuboxi/README | 21 +++++++ board/solidrun/mx6cuboxi/mx6cuboxi.c | 510 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ common/fdt_support.c | 29 ++++++++++ configs/mx6cuboxi_defconfig | 6 ++ include/configs/gw_ventana.h | 68 ++++++++++++++-------- include/configs/mx6cuboxi.h | 218 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ include/configs/nitrogen6x.h | 3 + include/configs/tqma6.h | 57 ++++++------------ include/configs/tqma6_mba6.h | 30 ++++++++++ include/fdt_support.h | 13 +++++ include/power/pfuze100_pmic.h | 2 +- 26 files changed, 1480 insertions(+), 213 deletions(-) create mode 100644 board/solidrun/mx6cuboxi/Kconfig create mode 100644 board/solidrun/mx6cuboxi/MAINTAINERS create mode 100644 board/solidrun/mx6cuboxi/Makefile create mode 100644 board/solidrun/mx6cuboxi/README create mode 100644 board/solidrun/mx6cuboxi/mx6cuboxi.c create mode 100644 configs/mx6cuboxi_defconfig create mode 100644 include/configs/mx6cuboxi.h create mode 100644 include/configs/tqma6_mba6.h
On Tue, Apr 28, 2015 at 05:01:11PM +0200, Stefano Babic wrote:
Hi Tom,
Stefano Babic
