[U-Boot-Users] [PATCH] Make bootretry work when command line editing is enabled
Currently, when CONFIG_CMDLINE_EDITING is set, bootretry doesn't work. This patch fixes the problem.
Signed-off-by: Andreas Engel andreas.engel@ericsson.com
diff -urpN u-boot-1.3.1/common/main.c u-boot-local/common/main.c --- u-boot-1.3.1/common/main.c 2007-12-06 10:21:19.000000000 +0100 +++ u-boot-local/common/main.c 2008-01-09 16:42:03.000000000 +0100 @@ -710,6 +710,13 @@ static int cread_line(char *buf, unsigne
while (1) { rlen = 1; +#ifdef CONFIG_BOOT_RETRY_TIME + while (!tstc()) { /* while no incoming data */ + if (retry_time >= 0 && get_ticks() > endtime) + return (-2); /* timed out */ + } +#endif + ichar = getcmd_getch();
if ((ichar == '\n') || (ichar == '\r')) {
In message 94BF386B051B5849BA84A45DDFC4E60A02090095@esealmw118.eemea.ericsson.se you wrote:
Applied, thank.s
Andreas Engel
